[OpenLayers-Commits] r11089 - in sandbox/elemoine/draw-feature: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 10 06:30:30 EST 2011
Author: erilem
Date: 2011-02-10 03:30:30 -0800 (Thu, 10 Feb 2011)
New Revision: 11089
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Polygon.js
   sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
polygon handler - support drawing holes
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js	2011-02-10 10:46:45 UTC (rev 11088)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js	2011-02-10 11:30:30 UTC (rev 11089)
@@ -281,10 +281,11 @@
                 this.finalize();
             } else {
                 if(this.lastDown.equals(evt.xy)) {
-                    if(this.lastUp == null && this.persist) {
+                    var first = this.lastUp == null;
+                    if(first && this.persist) {
                         this.destroyPersistedFeature();
-                    this.addPoint(evt.xy);
+                    this.addPoint(evt.xy, first);
                     this.lastUp = evt.xy;
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Polygon.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Polygon.js	2011-02-10 10:46:45 UTC (rev 11088)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Polygon.js	2011-02-10 11:30:30 UTC (rev 11089)
@@ -85,13 +85,29 @@
         this.line = new OpenLayers.Feature.Vector(
             new OpenLayers.Geometry.LinearRing([this.point.geometry])
-        // check for hole digitizing
-        var polygon;
-        if (this.holeModifier && this.evt && this.evt[this.holeModifier]) {
+        this.polygon = new OpenLayers.Feature.Vector(
+            new OpenLayers.Geometry.Polygon([this.line.geometry])
+        this.callback("create", [this.point.geometry, this.getSketch()]);
+        this.point.geometry.clearBounds();
+        this.layer.addFeatures([this.polygon, this.point], {silent: true});
+     * Method: addPoint
+     * Add point to geometry.
+     * Parameters:
+     * pixel - {<OpenLayers.Pixel>} The pixel location for the new point.
+     * first - {Boolean} Indicate whether this is the first point we're
+     *     adding.
+    addPoint: function(pixel, first) {
+        if(first && this.holeModifier &&
+           this.evt && this.evt[this.holeModifier]) {
             var geometry = this.point.geometry;
             var features = this.control.layer.features;
-            var candidate;
+            var candidate, polygon;
             // look for intersections, last drawn gets priority
             for (var i=features.length-1; i>=0; --i) {
                 candidate = features[i].geometry;
@@ -113,15 +129,7 @@
-        if (!polygon) {
-            this.polygon = new OpenLayers.Feature.Vector(
-                new OpenLayers.Geometry.Polygon([this.line.geometry])
-        this.callback("create", [this.point.geometry, this.getSketch()]);
-        this.point.geometry.clearBounds();
-        this.layer.addFeatures([this.polygon, this.point], {silent: true});
+        OpenLayers.Handler.Path.prototype.addPoint.apply(this, arguments);
Modified: sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
--- sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-10 10:46:45 UTC (rev 11088)
+++ sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-10 11:30:30 UTC (rev 11089)
@@ -269,7 +269,7 @@
         map.destroy();
-    function _test_rings(t) {
+    function test_rings(t) {
         t.plan(12);
         var log = [];
@@ -315,6 +315,7 @@
         log = [];
         // start at -9, 9
         event = {xy: new OpenLayers.Pixel(-9, 9)};
+        trigger("mousemove", event);
         trigger("mousedown", event);
         trigger("mouseup", event);
         // draw to -1, 9
@@ -339,7 +340,7 @@
         trigger("dblclick", event);
         // make assertions
-        t.eq(log.length, 9, "a) correct number of events");
+        t.eq(log.length, 10, "a) correct number of events");
         t.eq(log[log.length-1].type, "featureadded", "a) featureadded event last");
         t.eq(log[log.length-1].feature.geometry.getArea(), 64, "a) correct polygon area");
@@ -347,6 +348,7 @@
         log = [];
         // start at -6, 6
         event = {xy: new OpenLayers.Pixel(-6, 6), altKey: true};
         // draw to -3, 6
@@ -371,7 +373,7 @@
         // make assertions
-        t.eq(log.length, 8, "b) correct number of events");
+        t.eq(log.length, 9, "b) correct number of events");
         t.eq(log[log.length-1].type, "sketchcomplete", "b) sketchcomplete event last");
         t.eq(log[log.length-1].feature.geometry.getArea(), 55, "b) correct polygon area");
@@ -380,6 +382,7 @@
         log = [];
         // start at -2, 2
         event = {xy: new OpenLayers.Pixel(-2, 2)};
         // draw to 2, 2
@@ -404,7 +407,7 @@
         // make assertions
-        t.eq(log.length, 9, "c) correct number of events");
+        t.eq(log.length, 10, "c) correct number of events");
         t.eq(log[log.length-1].type, "featureadded", "c) featureadded event last");
         t.eq(log[log.length-1].feature.geometry.getArea(), 16, "c) correct polygon area");
@@ -412,6 +415,7 @@
         log = [];
         // start at -1, 1
         event = {xy: new OpenLayers.Pixel(-1, 1), altKey: true};
         // draw to 1, 1
@@ -441,7 +445,7 @@
         // make assertions
-        t.eq(log.length, 11, "d) correct number of events");
+        t.eq(log.length, 12, "d) correct number of events");
         t.eq(log[log.length-1].type, "sketchcomplete", "d) sketchcomplete event last");
         t.eq(log[log.length-1].feature.geometry.getArea(), 12, "d) correct polygon area");
More information about the Commits mailing list
