[OpenLayers-Commits] r11091 - sandbox/elemoine/draw-feature/tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 10 06:30:43 EST 2011
Author: erilem
Date: 2011-02-10 03:30:43 -0800 (Thu, 10 Feb 2011)
New Revision: 11091
   sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
test_persist for the polygon handler
Modified: sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
--- sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-10 11:30:36 UTC (rev 11090)
+++ sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-10 11:30:43 UTC (rev 11091)
@@ -269,6 +269,86 @@
         map.destroy();
+    function test_persist(t) {
+        t.plan(3);
+        var map = new OpenLayers.Map("map", {
+            resolutions: [1]
+        var layer = new OpenLayers.Layer.Vector("foo", {
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+            isBaseLayer: true
+        map.addLayer(layer);
+        var control = new OpenLayers.Control({});
+        var handler = new OpenLayers.Handler.Polygon(control, {});
+        control.handler = handler;
+        map.addControl(control);
+        map.setCenter(new OpenLayers.LonLat(0, 0), 0);
+        handler.activate();
+        handler.persist = false;
+        handler.mousemove(
+            {type: "mousemove", xy: new OpenLayers.Pixel(0, 0)});
+        handler.mousedown(
+            {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
+            {type: "mousemove", xy: new OpenLayers.Pixel(1, 1)});
+            {type: "mousedown", xy: new OpenLayers.Pixel(1, 1)});
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(1, 1)});
+            {type: "mousemove", xy: new OpenLayers.Pixel(2, 2)});
+        handler.dblclick(
+            {type: "dblclick", xy: new OpenLayers.Pixel(2, 2)});
+        t.eq(handler.layer.features.length, 2,
+             "feature destroyed on dblclick when persist is false");
+        handler.persist = true;
+        handler.mouseup(
+        handler.mouseup(
+        handler.dblclick(
+        var feature = handler.layer.features[0];
+        t.eq(handler.layer.features.length, 3,
+             "feature not destroyed on dblclick when persist is true");
+        handler.mouseup(
+        handler.mouseup(
+        handler.dblclick(
+        t.ok(handler.layer.features[0] !== feature,
+             "persisted feature destroyed on next dblclick");
+        map.destroy();
     function test_rings(t) {
         t.plan(12);
More information about the Commits mailing list
