[OpenLayers-Commits] r11097 - in sandbox/elemoine/draw-feature: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 10 14:59:31 EST 2011
Author: erilem
Date: 2011-02-10 11:59:31 -0800 (Thu, 10 Feb 2011)
New Revision: 11097
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js
   sandbox/elemoine/draw-feature/tests/Handler/Path.html
   sandbox/elemoine/draw-feature/tests/Handler/Point.html
   sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
drawing handlers - in deactivate handle the where the layer is already destroyed
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js	2011-02-10 19:28:39 UTC (rev 11096)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js	2011-02-10 19:59:31 UTC (rev 11097)
@@ -165,12 +165,13 @@
      * Parameters:
      * pixel - {<OpenLayers.Pixel>} The updated pixel location for the latest
      *     point.
+     * drawing - {Boolean} Indicate if we're currently drawing.
-    modifyFeature: function(pixel) {
+    modifyFeature: function(pixel, drawing) {
         var lonlat = this.control.map.getLonLatFromPixel(pixel);
         this.point.geometry.x = lonlat.lon;
         this.point.geometry.y = lonlat.lat;
-        this.callback("modify", [this.point.geometry, this.getSketch()]);
+        this.callback("modify", [this.point.geometry, this.getSketch(), drawing]);
         this.point.geometry.clearBounds();
         this.drawFeature();
@@ -254,7 +255,7 @@
             this.addPoint(evt.xy);
             return false;
-        this.modifyFeature(evt.xy);
+        this.modifyFeature(evt.xy, !!this.lastUp);
         return true;
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js	2011-02-10 19:28:39 UTC (rev 11096)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js	2011-02-10 19:59:31 UTC (rev 11097)
@@ -170,13 +170,14 @@
         if(!OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
             return false;
-        this.cancel();
+        this.cancel(true);
         // If a layer's map property is set to null, it means that that layer
         // isn't added to the map. Since we ourself added the layer to the map
         // in activate(), we can assume that if this.layer.map is null it means
         // that the layer has been destroyed (as a result of map.destroy() for
         // example.
         if (this.layer.map != null) {
+            this.destroyFeature();
             this.layer.destroy(false);
         this.layer = null;
@@ -212,8 +213,10 @@
      * Parameters:
      * cancel - {Boolean} Call cancel instead of done callback.  Default is
      *     false.
+     * noNew - {Boolean} Do not create a new feature after
+     *     finalization.  Default is false.
-    finalize: function(cancel) {
+    finalize: function(cancel, noNew) {
         var key = cancel ? "cancel" : "done";
         this.drawing = false;
         this.mouseDown = false;
@@ -223,7 +226,7 @@
         if(cancel || !this.persist) {
-        if(!cancel) {
+        if(!noNew) {
             this.createFeature();
@@ -231,9 +234,13 @@
      * APIMethod: cancel
      * Finish the geometry and call the "cancel" callback.
+     * Parameters:
+     *     cancelation.  Default is false.
-    cancel: function() {
-        this.finalize(true);
+    cancel: function(noNew) {
+        this.finalize(true, noNew);
@@ -279,7 +286,7 @@
         var lonlat = this.map.getLonLatFromPixel(pixel);
-        this.callback("modify", [this.point.geometry, this.point]);
+        this.callback("modify", [this.point.geometry, this.point, false]);
         this.drawFeature();
Modified: sandbox/elemoine/draw-feature/tests/Handler/Path.html
--- sandbox/elemoine/draw-feature/tests/Handler/Path.html	2011-02-10 19:28:39 UTC (rev 11096)
+++ sandbox/elemoine/draw-feature/tests/Handler/Path.html	2011-02-10 19:59:31 UTC (rev 11097)
@@ -116,7 +116,7 @@
     function test_callbacks(t) {
-        t.plan(37);
+        t.plan(39);
         var map = new OpenLayers.Map("map", {
             resolutions: [1]
@@ -248,7 +248,7 @@
              "[dblclick] correct feature");
         // cancel
         handler.cancel();
-        t.eq(logs.length, 1, "[cancel] called back");
+        t.eq(logs.length, 2, "[cancel] called back");
         log = logs.shift();
         t.eq(log.type, "cancel", "[cancel] canced called");
         t.geom_eq(log.args[0],
@@ -257,7 +257,11 @@
             "[cancel] correct linestring"
+        log = logs.shift();
+        t.eq(log.type, "create", "[cancel] create called");
+        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-200, 125),
+                  "[cancel] correct point");
         map.destroy();
Modified: sandbox/elemoine/draw-feature/tests/Handler/Point.html
--- sandbox/elemoine/draw-feature/tests/Handler/Point.html	2011-02-10 19:28:39 UTC (rev 11096)
+++ sandbox/elemoine/draw-feature/tests/Handler/Point.html	2011-02-10 19:59:31 UTC (rev 11097)
@@ -142,7 +142,7 @@
-        t.plan(23);
+        t.plan(25);
             resolutions: [1]
@@ -227,11 +227,15 @@
         t.eq(logs.length, 0, "[mouseup] not called back");
         // cancel
         handler.cancel();
         log = logs.shift();
         map.destroy();
Modified: sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
--- sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-10 19:28:39 UTC (rev 11096)
+++ sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-10 19:59:31 UTC (rev 11097)
@@ -109,7 +109,7 @@
-        t.plan(36);
+        t.plan(38);
             resolutions: [1]
@@ -262,9 +262,13 @@
         // cancel
         handler.cancel();
         log = logs.shift();
         map.destroy();
More information about the Commits mailing list
