[OpenLayers-Commits] r11107 - sandbox/elemoine/draw-feature/tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Feb 11 15:54:03 EST 2011
Author: erilem
Date: 2011-02-11 12:54:03 -0800 (Fri, 11 Feb 2011)
New Revision: 11107
   sandbox/elemoine/draw-feature/tests/Handler/Path.html
   sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
factor out code in the path handler and polygon handler tests
Modified: sandbox/elemoine/draw-feature/tests/Handler/Path.html
--- sandbox/elemoine/draw-feature/tests/Handler/Path.html	2011-02-11 20:53:55 UTC (rev 11106)
+++ sandbox/elemoine/draw-feature/tests/Handler/Path.html	2011-02-11 20:54:03 UTC (rev 11107)
@@ -283,44 +283,30 @@
         handler.activate();
+        function draw() {
+            handler.mousemove(
+                {type: "mousemove", xy: new OpenLayers.Pixel(0, 0)});
+            handler.mousedown(
+                {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
+            handler.mouseup(
+                {type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
+                {type: "mousemove", xy: new OpenLayers.Pixel(1, 1)});
+            handler.dblclick(
+                {type: "dblclick", xy: new OpenLayers.Pixel(1, 1)});
         handler.persist = false;
-        handler.mousemove(
-            {type: "mousemove", xy: new OpenLayers.Pixel(0, 0)});
-        handler.mousedown(
-            {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
-        handler.mouseup(
-            {type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
-            {type: "mousemove", xy: new OpenLayers.Pixel(1, 1)});
-        handler.dblclick(
-            {type: "dblclick", xy: new OpenLayers.Pixel(1, 1)});
+        draw();
         t.eq(handler.layer.features.length, 2,
              "feature destroyed on dblclick when persist is false");
         handler.persist = true;
-        handler.mouseup(
-        handler.dblclick(
+        draw();
         var feature = handler.layer.features[0];
         t.eq(handler.layer.features.length, 3,
              "feature not destroyed on dblclick when persist is true");
-        handler.mouseup(
-        handler.dblclick(
+        draw();
         t.ok(handler.layer.features[0] !== feature,
              "persisted feature destroyed on next dblclick");
@@ -343,46 +329,32 @@
         map.addControl(control);
         map.setCenter(new OpenLayers.LonLat(0, 0), 0);
+        function draw() {
+                {type: "mousemove", xy: new OpenLayers.Pixel(2, 2)});
+            handler.mouseup(
         handler.activate();
-            {type: "mousemove", xy: new OpenLayers.Pixel(2, 2)});
-        handler.mouseup(
+        draw();
              "feature destroyed on mouseup when persist is false");
-        handler.mouseup(
+        draw();
              "feature not destroyed on mouseup when persist is true");
-        handler.mouseup(
+        draw();
              "persisted feature destroyed on next mouseup");
Modified: sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
--- sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-11 20:53:55 UTC (rev 11106)
+++ sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-11 20:54:03 UTC (rev 11107)
@@ -289,64 +289,38 @@
+        function draw() {
+            handler.mouseup(
+                {type: "mousedown", xy: new OpenLayers.Pixel(1, 1)});
+            handler.mouseup(
+                {type: "mouseup", xy: new OpenLayers.Pixel(1, 1)});
+            handler.dblclick(
+                {type: "dblclick", xy: new OpenLayers.Pixel(2, 2)});
         handler.activate();
-        handler.mouseup(
-            {type: "mousedown", xy: new OpenLayers.Pixel(1, 1)});
-        handler.mouseup(
-            {type: "mouseup", xy: new OpenLayers.Pixel(1, 1)});
-        handler.dblclick(
-            {type: "dblclick", xy: new OpenLayers.Pixel(2, 2)});
+        draw();
-        handler.mouseup(
-        handler.mouseup(
-        handler.dblclick(
+        draw();
-        handler.mouseup(
-        handler.mouseup(
-        handler.dblclick(
+        draw();
More information about the Commits mailing list
