[OpenLayers-Commits] r11114 - in sandbox/elemoine/draw-feature:
lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org
Sun Feb 13 17:08:57 EST 2011
Author: erilem
Date: 2011-02-13 14:08:57 -0800 (Sun, 13 Feb 2011)
New Revision: 11114
sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
sandbox/elemoine/draw-feature/tests/Handler/Path.html
sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
freehand must be active on mousedown for freehand drawing
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js 2011-02-13 22:08:46 UTC (rev 11113)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js 2011-02-13 22:08:57 UTC (rev 11114)
@@ -45,6 +45,13 @@
freehandToggle: 'shiftKey',
+ * Property: freehandMouseDown
+ * {Boolean} The mouse is down, and freehand was active when mousedown
+ * occurred.
+ freehandMouseDown: false,
* Constructor: OpenLayers.Handler.Path
* Create a new path hander
@@ -233,6 +240,7 @@
this.mouseDown = true;
this.lastDown = evt.xy;
if (this.freehandMode(evt)) {
+ this.freehandMouseDown = true;
return false;
} else {
return !this.stopDown;
@@ -251,7 +259,7 @@
* {Boolean} Allow event propagation
mousemove: function (evt) {
- if(this.mouseDown && this.freehandMode(evt)) {
+ if(this.freehandMouseDown && this.freehandMode(evt)) {
if(this.persist) {
this.destroyPersistedFeature();
@@ -282,7 +290,7 @@
return false;
if(this.mouseDown) {
- if(this.freehandMode(evt)) {
this.removePoint();
this.finalize();
} else {
@@ -296,6 +304,7 @@
this.mouseDown = false;
+ this.freehandMouseDown = false;
return !this.stopUp;
return true;
Modified: sandbox/elemoine/draw-feature/tests/Handler/Path.html
--- sandbox/elemoine/draw-feature/tests/Handler/Path.html 2011-02-13 22:08:46 UTC (rev 11113)
+++ sandbox/elemoine/draw-feature/tests/Handler/Path.html 2011-02-13 22:08:57 UTC (rev 11114)
@@ -265,6 +265,55 @@
map.destroy();
+ function test_toggle_freehand(t) {
+ t.plan(2);
+ var map = new OpenLayers.Map("map", {
+ resolutions: [1]
+ var layer = new OpenLayers.Layer.Vector("foo", {
+ maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+ isBaseLayer: true
+ map.addLayer(layer);
+ var control = new OpenLayers.Control({});
+ var handler = new OpenLayers.Handler.Path(control, {
+ done: function(g) {
+ log++;
+ }, {persist: true});
+ control.handler = handler;
+ map.addControl(control);
+ map.setCenter(new OpenLayers.LonLat(0, 0), 0);
+ handler.activate();
+ log = 0;
+ handler.mousemove(
+ {type: "mousemove", xy: new OpenLayers.Pixel(0, 0)});
+ handler.mousedown(
+ {type: "mousedown", xy: new OpenLayers.Pixel(0, 0), shiftKey: true});
+ {type: "mousemove", xy: new OpenLayers.Pixel(1, 1), shiftKey: true});
+ {type: "mousemove", xy: new OpenLayers.Pixel(2, 2), shiftKey: true});
+ handler.mouseup(
+ {type: "mouseup", xy: new OpenLayers.Pixel(0, 0), shiftKey: true});
+ t.eq(log, 1, "feature drawn when shift pressed on mousedown");
+ log = 0;
+ {type: "mousedown", xy: new OpenLayers.Pixel(0, 0), shiftKey: false});
+ handler.mouseup(
+ t.eq(log, 0, "feature not drawn when shift not pressed on mousedown");
function test_persist(t) {
t.plan(4);
Modified: sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
--- sandbox/elemoine/draw-feature/tests/Handler/Polygon.html 2011-02-13 22:08:46 UTC (rev 11113)
+++ sandbox/elemoine/draw-feature/tests/Handler/Polygon.html 2011-02-13 22:08:57 UTC (rev 11114)
@@ -273,6 +273,55 @@
map.destroy();
+ t.plan(2);
+ resolutions: [1]
+ isBaseLayer: true
+ var handler = new OpenLayers.Handler.Polygon(control, {
+ log++;
+ log = 0;
+ handler.mouseup(
+ log = 0;
+ handler.mouseup(
t.plan(4);
More information about the Commits
