[OpenLayers-Commits] r11119 - trunk/openlayers/examples
    commits-20090109 at openlayers.org
    Tue Feb 15 19:34:16 EST 2011
Author: tschaub
Date: 2011-02-15 16:34:16 -0800 (Tue, 15 Feb 2011)
New Revision: 11119
Added:
   trunk/openlayers/examples/mobile-jq.html
   trunk/openlayers/examples/mobile.js
Add example using jQuery mobile (limited functionality).
Added: trunk/openlayers/examples/mobile-jq.html
--- trunk/openlayers/examples/mobile-jq.html	                        (rev 0)
+++ trunk/openlayers/examples/mobile-jq.html	2011-02-16 00:34:16 UTC (rev 11119)
@@ -0,0 +1,134 @@
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>OpenLayers with jQuery Mobile</title>
+        <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;"/>
+        <link rel="stylesheet" href="http://code.jquery.com/mobile/1.0a3/jquery.mobile-1.0a3.min.css">
+        <script src="http://code.jquery.com/jquery-1.5.min.js"></script>
+        <script src="http://code.jquery.com/mobile/1.0a3/jquery.mobile-1.0a3.min.js"></script>
+        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+        <script src="../lib/OpenLayers.js"></script>
+        <script src="mobile.js"></script>
+        <style>
+            html {
+                height: 100%;
+            body: {
+                margin: 0;
+                padding: 0;
+                height: 100%;
+            .ui-content {
+                padding: 0;
+            .ui-footer, .ui-header {
+                text-align: center;
+                padding: 5px 0;
+            #log {
+                display: none;
+            #map {
+                width: 100%;
+                height: 100%;
+            .olControlAttribution {
+                font-size: 10px;
+                bottom: 5px;
+                right: 5px;
+        </style>
+        <script>
+            $(document).ready(function() {
+                // fix height of content to allow for header & footer
+                function fixContentHeight() {
+                    var header = $("div[data-role='header']:visible");
+                    var footer = $("div[data-role='footer']:visible");
+                    var content = $("div[data-role='content']:visible:visible");
+                    var viewHeight = $(window).height();
+                    var contentHeight = viewHeight - header.outerHeight() - footer.outerHeight();
+                    if ((content.outerHeight() + header.outerHeight() + footer.outerHeight()) !== viewHeight) {
+                        contentHeight -= (content.outerHeight() - content.height());
+                        content.height(contentHeight);
+                    if (window.map) {
+                        map.updateSize();
+                    } else {
+                        // initialize map
+                        init();
+                $(window).bind("orientationchange resize pageshow", fixContentHeight);
+                fixContentHeight();
+                // add behavior to navigation buttons
+                $("#west").click(function() {
+                    pan(-0.25, 0);
+                $("#north").click(function() {
+                    pan(0, -0.25);
+                $("#south").click(function() {
+                    pan(0, 0.25);
+                $("#east").click(function() {
+                    pan(0.25, 0);
+                // add behavior to drawing controls
+                function deactivateControls() {
+                    $.each(map.getControlsByClass(/DrawFeature/), function(index, control) {
+                        control.deactivate();
+                    map.getControlsBy("id", "mod-control")[0].deactivate();
+                $("#nav, #point, #line, #poly, #mod").change(function(event) {
+                    deactivateControls();
+                    // jquery mobile bug regarding change makes us go through all inputs
+                    // https://github.com/jquery/jquery-mobile/issues/issue/1088
+                    var val = $("input:radio[name=controls]:checked").val();
+                    if (val !== "nav") {
+                        map.getControlsBy("id", val + "-control")[0].activate();
+                $("#nav").click();
+                $("#nav").click(); // jquery mobile bug forces 2 calls to refresh radio ui
+        </script>
+    </head>
+    <body>
+        <div data-role="page">
+            <div data-role="header">
+                <input id="west" type="button" data-icon="arrow-l" value="west">
+                <input id="north" type="button" data-icon="arrow-u" value="north">
+                <input id="south" type="button" data-icon="arrow-d" value="south">
+                <input id="east" type="button" data-icon="arrow-r" value="east">
+            </div>
+            <div data-role="content">
+                <div id="map"></div>
+            </div>
+            <div data-role="footer">
+                <form id="controls">
+                    <fieldset data-role="controlgroup" data-type="horizontal" data-role="fieldcontain">
+                        <input id="nav" type="radio" name="controls" value="nav" checked="checked">
+                        <label for="nav">navigate</label>
+                        <input id="point" type="radio" name="controls" value="point">
+                        <label for="point">point</label>
+                        <input id="line" type="radio" name="controls" value="line">
+                        <label for="line">line</label>
+                        <input id="poly" type="radio" name="controls" value="poly">
+                        <label for="poly">poly</label>
+                        <input id="mod" type="radio" name="controls" value="mod">
+                        <label for="mod">modify</label>
+                    </fieldset>
+                </form>
+            </div>
+        </div>
+        <div id="log"></div>
+    </body>
+</html>
\ No newline at end of file
Added: trunk/openlayers/examples/mobile.js
--- trunk/openlayers/examples/mobile.js	                        (rev 0)
+++ trunk/openlayers/examples/mobile.js	2011-02-16 00:34:16 UTC (rev 11119)
@@ -0,0 +1,86 @@
+// initialize map when page ready
+var map;
+function init() {
+    var gg = new OpenLayers.Projection("EPSG:4326");
+    var sm = new OpenLayers.Projection("EPSG:900913");
+    // layer for drawn features
+    var vector = new OpenLayers.Layer.Vector();
+    // create map
+    map = new OpenLayers.Map({
+        div: "map",
+        projection: sm,
+        units: "m",
+        numZoomLevels: 18,
+        maxResolution: 156543.0339,
+        maxExtent: new OpenLayers.Bounds(
+            -20037508.34, -20037508.34, 20037508.34, 20037508.34
+        controls: [
+            new OpenLayers.Control.Navigation(),
+            new OpenLayers.Control.Attribution(),
+            new OpenLayers.Control.DrawFeature(
+                vector, OpenLayers.Handler.Point, {id: "point-control"}
+                vector, OpenLayers.Handler.Path, {id: "line-control"}
+                vector, OpenLayers.Handler.Polygon, {id: "poly-control"}
+            new OpenLayers.Control.ModifyFeature(vector, {id: "mod-control"}),
+        layers: [new OpenLayers.Layer.OSM(), vector],
+        center: new OpenLayers.LonLat(0, 0),
+        zoom: 1
+    // attempt to get position
+    if (window.navigator && navigator.geolocation) {
+        navigator.geolocation.getCurrentPosition(
+            updatePosition,
+            function failure(error) {
+                updateLog(error.message);
+                enableHighAccuracy: true
+// get position if possible
+var position;
+function updatePosition(pos) {
+    position = pos;
+    var lon =  position.coords.longitude;
+    var lat = position.coords.latitude;
+    updateLog("position: lon " + lon + ", lat " + lat);
+    map.setCenter(
+        new OpenLayers.LonLat(lon, lat).transform(gg, sm)
+// allow simple logging
+var log = [];
+function updateLog(message) {
+    log.push(message);
+    var div = document.createElement("div");
+    div.appendChild(document.createTextNode(message));
+    document.getElementById("log").appendChild(div);
+    if (window.console) {
+        console.log(message);
+function clearLog() {
+    log.length = 0;
+    document.getElementById("log").innerHTML = "";
+function pan(fx, fy) {
+    var size = map.getSize();
+    map.pan(size.w * fx, size.h * fy);
More information about the Commits
