[OpenLayers-Commits] r11133 - in trunk/openlayers: lib/OpenLayers tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 17 10:04:53 EST 2011
Author: bartvde
Date: 2011-02-17 07:04:53 -0800 (Thu, 17 Feb 2011)
New Revision: 11133
   trunk/openlayers/lib/OpenLayers/Request.js
   trunk/openlayers/tests/Request.html
OpenLayers.Request issue method creates URLs such as http://service?&key=value, p=fvanderbiest, r=me (closes #3055)
Modified: trunk/openlayers/lib/OpenLayers/Request.js
--- trunk/openlayers/lib/OpenLayers/Request.js	2011-02-17 05:29:11 UTC (rev 11132)
+++ trunk/openlayers/lib/OpenLayers/Request.js	2011-02-17 15:04:53 UTC (rev 11133)
@@ -125,14 +125,8 @@
         // create request, open, and set headers
         var request = new OpenLayers.Request.XMLHttpRequest();
-        var url = config.url;
-        if(config.params) {
-            var paramString = OpenLayers.Util.getParameterString(config.params);
-            if(paramString.length > 0) {
-                var separator = (url.indexOf('?') > -1) ? '&' : '?';
-                url += separator + paramString;
+        var url = OpenLayers.Util.urlAppend(config.url,
+            OpenLayers.Util.getParameterString(config.params));
         var sameOrigin = !(url.indexOf("http") == 0);
         var urlParts = !sameOrigin && url.match(this.URL_SPLIT_REGEX);
         if (urlParts) {
Modified: trunk/openlayers/tests/Request.html
--- trunk/openlayers/tests/Request.html	2011-02-17 05:29:11 UTC (rev 11132)
+++ trunk/openlayers/tests/Request.html	2011-02-17 15:04:53 UTC (rev 11133)
@@ -20,7 +20,7 @@
     function test_issue(t) {
         setup();
-        t.plan(21);
+        t.plan(22);
         var request, config;
         var proto = OpenLayers.Request.XMLHttpRequest.prototype;
         var issue = OpenLayers.Function.bind(OpenLayers.Request.issue,
@@ -81,7 +81,18 @@
             t.eq(url, config.url + "&foo=bar", "existing query string gets extended with &");
         request = issue(config);
+        // test that query string doesn't get ? followed by &
+        config = {
+            method: "GET",
+            url: "http://example.com/service?",
+            params: {"foo": "bar"}
+        proto.open = function(method, url, async, user, password) {
+            t.eq(url, config.url + "foo=bar", "existing query string ending with ? gets extended without &");
+        request = issue(config);
         // reset open method
         proto.open = _open;
More information about the Commits mailing list
