[OpenLayers-Commits] r11154 - sandbox/elemoine/draw-feature/tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Feb 20 11:44:06 EST 2011
Author: erilem
Date: 2011-02-20 08:44:06 -0800 (Sun, 20 Feb 2011)
New Revision: 11154
   sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
refactor the Polygon handler tests a bit
Modified: sandbox/elemoine/draw-feature/tests/Handler/Polygon.html
--- sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-20 16:43:53 UTC (rev 11153)
+++ sandbox/elemoine/draw-feature/tests/Handler/Polygon.html	2011-02-20 16:44:06 UTC (rev 11154)
@@ -683,7 +683,56 @@
         map.destroy();
-    function test_stopDown_true(t) {
+    function test_Handler_Polygon_destroy(t) {
+        t.plan(8);
+        var map = new OpenLayers.Map('map');
+        map.addLayer(new OpenLayers.Layer.WMS("", "", {}));
+        map.zoomToMaxExtent();
+        var control = new OpenLayers.Control();
+        map.addControl(control);
+        var handler = new OpenLayers.Handler.Polygon(control, {foo: 'bar'});
+        handler.activate();
+        var evt = {xy: new OpenLayers.Pixel(150, 75), which: 1};
+        handler.mousedown(evt);
+        t.ok(handler.layer,
+             "handler has a layer prior to destroy");
+        t.ok(handler.point,
+             "handler has a point prior to destroy");
+        t.ok(handler.line,
+             "handler has a line prior to destroy");
+        t.ok(handler.polygon,
+             "handler has a polygon prior to destroy");
+        handler.destroy();
+        t.eq(handler.layer, null,
+             "handler.layer is null after destroy");
+        t.eq(handler.point, null,
+             "handler.point is null after destroy");
+        t.eq(handler.line, null,
+             "handler.line is null after destroy");
+        t.eq(handler.polygon, null,
+             "handler.polygon is null after destroy");
+        map.destroy();
+    // Sequence tests
+    // Sequence tests basically involve executing a sequence of events
+    // and testing the resulting geometry.
+    // Below are tests for various drawing sequences. Tests can be
+    // added here each a non-working sequence is found.
+    // stopDown:true, stopUp:true
+    // a) click on (0, 0)
+    // b) mousedown on (0.5, 0.5)
+    // c) mouseup on (1, 1)
+    // d) click on (0, 10)
+    // e) dblclick on (10, 10)
+    function test_sequence1(t) {
         t.plan(1);
         var map = new OpenLayers.Map("map", {
             resolutions: [1]
@@ -748,7 +797,13 @@
             ]), "geometry is correct");
-    function test_stopDown_false(t) {
+    // stopDown:false, stopUp:false
+    function test_sequence2(t) {
         t.plan(1);
             resolutions: [1]
@@ -813,41 +868,6 @@
-    function test_Handler_Polygon_destroy(t) {
-        t.plan(8);
-        var map = new OpenLayers.Map('map');
-        map.addLayer(new OpenLayers.Layer.WMS("", "", {}));
-        map.zoomToMaxExtent();
-        var control = new OpenLayers.Control();
-        map.addControl(control);
-        var handler = new OpenLayers.Handler.Polygon(control, {foo: 'bar'});
-        handler.activate();
-        var evt = {xy: new OpenLayers.Pixel(150, 75), which: 1};
-        handler.mousedown(evt);
-        t.ok(handler.layer,
-             "handler has a layer prior to destroy");
-        t.ok(handler.point,
-             "handler has a point prior to destroy");
-        t.ok(handler.line,
-             "handler has a line prior to destroy");
-        t.ok(handler.polygon,
-             "handler has a polygon prior to destroy");
-        handler.destroy();
-        t.eq(handler.layer, null,
-             "handler.layer is null after destroy");
-        t.eq(handler.point, null,
-             "handler.point is null after destroy");
-        t.eq(handler.line, null,
-             "handler.line is null after destroy");
-        t.eq(handler.polygon, null,
-             "handler.polygon is null after destroy");
-        map.destroy();
   </script>
 </head>
 <body>
More information about the Commits mailing list
