[OpenLayers-Commits] r11208 - in trunk/openlayers: examples lib lib/OpenLayers/Control tests tests/Control
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Feb 21 12:38:11 EST 2011
Author: erilem
Date: 2011-02-21 09:38:11 -0800 (Mon, 21 Feb 2011)
New Revision: 11208
Added:
   trunk/openlayers/examples/mobile-touchnavigation-control.html
   trunk/openlayers/lib/OpenLayers/Control/TouchNavigation.js
   trunk/openlayers/tests/Control/TouchNavigation.html
   trunk/openlayers/lib/OpenLayers.js
   trunk/openlayers/tests/list-tests.html
add a touch device-specific navigation control, p=bbinet, r=me (closes #3068)
Added: trunk/openlayers/examples/mobile-touchnavigation-control.html
--- trunk/openlayers/examples/mobile-touchnavigation-control.html	                        (rev 0)
+++ trunk/openlayers/examples/mobile-touchnavigation-control.html	2011-02-21 17:38:11 UTC (rev 11208)
@@ -0,0 +1,44 @@
+<!DOCTYPE html>
+<html>
+  <head>
+    <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
+    <meta name="apple-mobile-web-app-capable" content="yes" />
+    <title>OpenLayers TouchNavigation Control</title>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
+    <link rel="stylesheet" href="style.css" type="text/css" />
+    <script src="../lib/OpenLayers.js"></script>
+    <script type="text/javascript">
+        var map, layer;
+        function init() {
+            map = new OpenLayers.Map( 'map', { controls: [
+                new OpenLayers.Control.TouchNavigation({
+                    dragPanOptions: {
+                        interval: 0 // non-zero kills performance on some mobile phones
+            layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+                    "http://vmap0.tiles.osgeo.org/wms/vmap0",
+                    {layers: 'basic'} );
+            map.addLayer(layer);
+            map.setCenter(new OpenLayers.LonLat(5, 40), 2);
+    </script>
+  </head>
+  <body onload="init()">
+    <h1 id="title">TouchNavigation Control</h1>
+    <div id="tags">
+        mobile, touch, drag, move, zoom, navigate
+    </div>
+    <div id="shortdesc">Demonstrate TouchNavigation Control features</div>
+    <div id="map" class="smallmap"></div>
+    <div id="docs">
+        This example demonstrates a couple features of the TouchNavigation
+        control. The TouchNavigation control controls most map dragging,
+        movement, zooming, etc, optimized for mobile devices.
+    </div>
+  </body>
+</html>
Added: trunk/openlayers/lib/OpenLayers/Control/TouchNavigation.js
--- trunk/openlayers/lib/OpenLayers/Control/TouchNavigation.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Control/TouchNavigation.js	2011-02-21 17:38:11 UTC (rev 11208)
@@ -0,0 +1,148 @@
+/* Copyright (c) 2006-2010 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Control/DragPan.js
+ * @requires OpenLayers/Handler/Click.js
+ * Class: OpenLayers.Control.TouchNavigation
+ * The navigation control handles map browsing with touch events (dragging,
+ *     double-tapping, and tap with two fingers).  Create a new navigation
+ *     control with the <OpenLayers.Control.TouchNavigation> control.
+ * Inherits:
+ *  - <OpenLayers.Control>
+OpenLayers.Control.TouchNavigation = OpenLayers.Class(OpenLayers.Control, {
+     * Property: dragPan
+     * {<OpenLayers.Control.DragPan>}
+    dragPan: null,
+     * APIProprety: dragPanOptions
+     * {Object} Options passed to the DragPan control.
+    dragPanOptions: null,
+     * APIProperty: documentDrag
+     * {Boolean} Allow panning of the map by dragging outside map viewport.
+     *     Default is false.
+    documentDrag: false,
+     * APIProperty: autoActivate
+     * {Boolean} Activate the control when it is added to a map.  Default is
+     *     true.
+    autoActivate: true,
+     * Constructor: OpenLayers.Control.TouchNavigation
+     * Create a new navigation control
+     * Parameters:
+     * options - {Object} An optional object whose properties will be set on
+     *                    the control
+    initialize: function(options) {
+        this.handlers = {};
+        OpenLayers.Control.prototype.initialize.apply(this, arguments);
+     * Method: destroy
+     * The destroy method is used to perform any clean up before the control
+     * is dereferenced.  Typically this is where event listeners are removed
+     * to prevent memory leaks.
+    destroy: function() {
+        this.deactivate();
+        if(this.dragPan) {
+            this.dragPan.destroy();
+        this.dragPan = null;
+        OpenLayers.Control.prototype.destroy.apply(this,arguments);
+     * Method: activate
+    activate: function() {
+        if(OpenLayers.Control.prototype.activate.apply(this,arguments)) {
+            this.dragPan.activate();
+            this.handlers.click.activate();
+            return true;
+        return false;
+     * Method: deactivate
+    deactivate: function() {
+        if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)) {
+            this.dragPan.deactivate();
+            this.handlers.click.deactivate();
+            return true;
+        return false;
+     * Method: draw
+    draw: function() {
+        var clickCallbacks = {
+            'click': this.defaultClick,
+            'dblclick': this.defaultDblClick
+        var clickOptions = {
+            'double': true,
+            'stopDouble': true
+        this.handlers.click = new OpenLayers.Handler.Click(
+            this, clickCallbacks, clickOptions
+        this.dragPan = new OpenLayers.Control.DragPan(
+            OpenLayers.Util.extend({
+                map: this.map,
+                documentDrag: this.documentDrag
+            }, this.dragPanOptions)
+        this.dragPan.draw();
+     * Method: defaultClick
+     * Parameters:
+     * evt - {Event}
+    defaultClick: function (evt) {
+        if(evt.lasttouches && evt.lasttouches.length == 2) {
+            this.map.zoomOut();
+     * Method: defaultDblClick
+     * Parameters:
+     * evt - {Event}
+    defaultDblClick: function (evt) {
+        var newCenter = this.map.getLonLatFromViewPortPx(evt.xy);
+        this.map.setCenter(newCenter, this.map.zoom + 1);
+    CLASS_NAME: "OpenLayers.Control.TouchNavigation"
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js	2011-02-21 17:31:19 UTC (rev 11207)
+++ trunk/openlayers/lib/OpenLayers.js	2011-02-21 17:38:11 UTC (rev 11208)
@@ -180,6 +180,7 @@
                 "OpenLayers/Control/ZoomToMaxExtent.js",
                 "OpenLayers/Control/DragPan.js",
                 "OpenLayers/Control/Navigation.js",
+                "OpenLayers/Control/TouchNavigation.js",
                 "OpenLayers/Control/MouseDefaults.js",
                 "OpenLayers/Control/MousePosition.js",
                 "OpenLayers/Control/OverviewMap.js",
Added: trunk/openlayers/tests/Control/TouchNavigation.html
--- trunk/openlayers/tests/Control/TouchNavigation.html	                        (rev 0)
+++ trunk/openlayers/tests/Control/TouchNavigation.html	2011-02-21 17:38:11 UTC (rev 11208)
@@ -0,0 +1,109 @@
+<html>
+<head>
+  <script src="../OLLoader.js"></script>
+    function test_Control_TouchNavigation_constructor (t) {
+        t.plan( 2 );
+        var options = {bar: "foo"};
+        var temp = OpenLayers.Control.prototype.initialize;
+        OpenLayers.Control.prototype.initialize = function(opt) {
+            t.eq(opt, options,
+                 "constructor calls parent with the correct options");
+        var control = new OpenLayers.Control.TouchNavigation(options);
+        t.ok(control instanceof OpenLayers.Control.TouchNavigation,
+            "new OpenLayers.Control returns object");
+        OpenLayers.Control.prototype.initialize = temp;
+    function test_Control_TouchNavigation_destroy(t) {
+        t.plan(6);
+        var control = {
+            events: {
+                    t.ok(true, "events destroyed");
+                t.ok(true, "navigation control deactivated before being destroyed");
+            dragPan: {
+                    t.ok(true, "dragPan destroyed");
+            handlers: {
+                click: {
+                        t.ok(true, "clickHandler destroyed");
+        //this will also trigger one test by calling OpenLayers.Control's destroy
+        // and three more for the destruction of dragPan, zoomBox, and wheelHandler
+        OpenLayers.Control.TouchNavigation.prototype.destroy.apply(control, []);
+        t.eq(control.dragPan, null, "'dragPan' set to null");
+        t.eq(control.handlers, null, "handlers set to null");
+    function test_documentDrag(t) {
+        t.plan(2);
+         * These tests confirm that the documentDrag property is false by
+         * default and is passed on to the DragPan control.  Tests of panning
+         * while dragging outside the viewport should go in the DragPan tests.
+         * Tests of the document events and appropriate callbacks from the
+         * handler should go in the Drag handler tests.
+         var nav = new OpenLayers.Control.TouchNavigation();
+         t.eq(nav.documentDrag, false, "documentDrag false by default");
+         var map = new OpenLayers.Map({
+             div: document.body,
+             controls: [new OpenLayers.Control.TouchNavigation({documentDrag: true})]
+         nav = map.controls[0];
+         t.eq(nav.dragPan.documentDrag, true, "documentDrag set on the DragPan control");
+         map.destroy();
+    function test_dragPanOptions(t) {
+        t.plan(2);
+         t.eq(nav.dragPanOptions, null, "dragPanOptions null by default");
+             controls: [
+                     dragPanOptions: {foo: 'bar'}
+         t.eq(nav.dragPan.foo, 'bar',
+            "foo property is set on the DragPan control");
+         map.destroy();
+  </script>
+</head>
+<body>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html	2011-02-21 17:31:19 UTC (rev 11207)
+++ trunk/openlayers/tests/list-tests.html	2011-02-21 17:38:11 UTC (rev 11208)
@@ -36,6 +36,7 @@
     <li>Control/SelectFeature.html</li>
     <li>Control/Snapping.html</li>
     <li>Control/Split.html</li>
+    <li>Control/TouchNavigation.html</li>
     <li>Control/TransformFeature.html</li>
     <li>Control/WMSGetFeatureInfo.html</li>
     <li>Control/WMTSGetFeatureInfo.html</li>
More information about the Commits mailing list
