[OpenLayers-Commits] r11225 - trunk/openlayers/tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Feb 22 06:10:35 EST 2011
Author: erilem
Date: 2011-02-22 03:10:35 -0800 (Tue, 22 Feb 2011)
New Revision: 11225
   trunk/openlayers/tests/Handler/Drag.html
add a touch events related test for the drag handler, no functional change
Modified: trunk/openlayers/tests/Handler/Drag.html
--- trunk/openlayers/tests/Handler/Drag.html	2011-02-22 10:36:38 UTC (rev 11224)
+++ trunk/openlayers/tests/Handler/Drag.html	2011-02-22 11:10:35 UTC (rev 11225)
@@ -289,6 +289,57 @@
+    function test_Handler_Drag_touch(t) {
+        // In this test we verify that "touchstart", "touchmove", and
+        // "touchend" events set expected states in the drag handler.
+        // We also verify that we stop event bubbling as appropriate.
+        t.plan(12);
+        // set up
+        var m = new OpenLayers.Map('map', {controls: []});
+        var c = new OpenLayers.Control();
+        m.addControl(c);
+        var h = new OpenLayers.Handler.Drag(c, {
+            done: function(px) { log = px; }});
+        h.activate();
+        var _stop = OpenLayers.Event.stop;
+        OpenLayers.Event.stop = function(e) { log = e; };
+        var Px = OpenLayers.Pixel, e, log;
+        // test
+        e = {touches: [{}], xy: new Px(0, 0)};
+        m.events.triggerEvent('touchstart', e);
+        t.eq(h.started, true, '[touchstart] started is set');
+        t.eq(h.start.x, 0, '[touchstart] start.x is correct');
+        t.eq(h.start.y, 0, '[touchstart] start.y is correct');
+        t.eq(log, undefined, '[touchstart] event is not stopped');
+        e = {xy: new Px(1, 1)};
+        m.events.triggerEvent('touchmove', e);
+        t.eq(h.dragging, true, '[touchmove] dragging is set');
+        t.eq(h.last.x, 1, '[touchstart] last.x is correct');
+        t.eq(h.last.y, 1, '[touchstart] last.y is correct');
+        t.ok(log == e, '[touchmove] event is stopped');
+        e = {xy: new Px(2, 2)};
+        m.events.triggerEvent('touchend', e);
+        t.eq(h.started, false, '[touchend] started is reset');
+        // the "done" callback gets the position of the last touchmove
+        t.eq(log.x, 1, '[touchend] done callback got correct x position');
+        t.eq(log.y, 1, '[touchend] done callback got correct y position');
+        // tear down
+        OpenLayers.Event.stop = _stop;
+        m.destroy();
     function test_Handler_Drag_submethods(t) {
         t.plan(8);
More information about the Commits mailing list
