[OpenLayers-Commits] r11231 - in trunk/openlayers/examples: . img
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Feb 22 08:06:35 EST 2011
Author: erilem
Date: 2011-02-22 05:06:35 -0800 (Tue, 22 Feb 2011)
New Revision: 11231
Added:
   trunk/openlayers/examples/img/
   trunk/openlayers/examples/img/marker_shadow.png
   trunk/openlayers/examples/img/popupMatrix.jpg
   trunk/openlayers/examples/img/small.jpg
   trunk/openlayers/examples/img/thinlong.jpg
   trunk/openlayers/examples/img/widelong.jpg
   trunk/openlayers/examples/img/wideshort.jpg
Removed:
   trunk/openlayers/examples/marker_shadow.png
   trunk/openlayers/examples/popupMatrix.jpg
   trunk/openlayers/examples/small.jpg
   trunk/openlayers/examples/thinlong.jpg
   trunk/openlayers/examples/widelong.jpg
   trunk/openlayers/examples/wideshort.jpg
   trunk/openlayers/examples/marker-shadow.html
   trunk/openlayers/examples/popupMatrix.html
move the examples images in an "img" directory, no functional change
Copied: trunk/openlayers/examples/img/marker_shadow.png (from rev 11230, trunk/openlayers/examples/marker_shadow.png)
(Binary files differ)
Copied: trunk/openlayers/examples/img/popupMatrix.jpg (from rev 11230, trunk/openlayers/examples/popupMatrix.jpg)
Copied: trunk/openlayers/examples/img/small.jpg (from rev 11230, trunk/openlayers/examples/small.jpg)
Copied: trunk/openlayers/examples/img/thinlong.jpg (from rev 11230, trunk/openlayers/examples/thinlong.jpg)
Copied: trunk/openlayers/examples/img/widelong.jpg (from rev 11230, trunk/openlayers/examples/widelong.jpg)
Copied: trunk/openlayers/examples/img/wideshort.jpg (from rev 11230, trunk/openlayers/examples/wideshort.jpg)
Modified: trunk/openlayers/examples/marker-shadow.html
--- trunk/openlayers/examples/marker-shadow.html	2011-02-22 12:08:30 UTC (rev 11230)
+++ trunk/openlayers/examples/marker-shadow.html	2011-02-22 13:06:35 UTC (rev 11231)
@@ -39,7 +39,7 @@
                     styleMap: new OpenLayers.StyleMap({
                         // Set the external graphic and background graphic images.
                         externalGraphic: "../img/marker-gold.png",
-                        backgroundGraphic: "./marker_shadow.png",
+                        backgroundGraphic: "./img/marker_shadow.png",
                         // Makes sure the background graphic is placed correctly relative
                         // to the external graphic.
Deleted: trunk/openlayers/examples/marker_shadow.png
Modified: trunk/openlayers/examples/popupMatrix.html
--- trunk/openlayers/examples/popupMatrix.html	2011-02-22 12:08:30 UTC (rev 11230)
+++ trunk/openlayers/examples/popupMatrix.html	2011-02-22 13:06:35 UTC (rev 11231)
@@ -83,7 +83,7 @@
             layer = new OpenLayers.Layer.Image(
                 "popupMatrix",
-                "popupMatrix.jpg",
+                "img/popupMatrix.jpg",
                 new OpenLayers.Bounds(-82.5,-71.5,97.5,67.5),
                 new OpenLayers.Size(1024,768)
@@ -109,52 +109,52 @@
             //anchored popup small contents no autosize
             ll = new OpenLayers.LonLat(-55,20);
             popupClass = OpenLayers.Popup.Anchored;
-            popupContentHTML = '<img src="small.jpg"></img>';
+            popupContentHTML = '<img src="img/small.jpg"></img>';
             addMarker(ll, popupClass, popupContentHTML);
             //anchored popup small contents no autosize closebox
             var ll = new OpenLayers.LonLat(-50,20);
             addMarker(ll, popupClass, popupContentHTML, true);
             //anchored popup small contents autosize
             ll = new OpenLayers.LonLat(-40,20);
             popupClass = AutoSizeAnchored;
             //anchored popup small contents autosize closebox
             ll = new OpenLayers.LonLat(-35,20);
             //anchored popup small contents autosize minsize
             ll = new OpenLayers.LonLat(-25,20);
             popupClass = AutoSizeAnchoredMinSize;
             //anchored popup small contents autosize minsize closebox
             ll = new OpenLayers.LonLat(-20,20);
             //anchored popup small contents autosize maxsize
             ll = new OpenLayers.LonLat(-10,20);
             popupClass = AutoSizeAnchoredMaxSize;
             //anchored popup small contents autosize maxsize closebox
             ll = new OpenLayers.LonLat(-5,20);
@@ -186,39 +186,39 @@
             //anchored popup wide short fixed contents autosize
             ll = new OpenLayers.LonLat(35,20);
-            popupContentHTML = '<img src="wideshort.jpg"></img>';
+            popupContentHTML = '<img src="img/wideshort.jpg"></img>';
             //anchored popup wide short fixed contents autosize closebox
             ll = new OpenLayers.LonLat(40,20);
             //anchored popup thin long fixed contents autosize
             ll = new OpenLayers.LonLat(50,20);
-            popupContentHTML = '<img src="thinlong.jpg"></img>';
+            popupContentHTML = '<img src="img/thinlong.jpg"></img>';
             //anchored popup thin long fixed contents autosize closebox
             ll = new OpenLayers.LonLat(55,20);
             //anchored popup wide long fixed contents autosize
             ll = new OpenLayers.LonLat(65,20);
-            popupContentHTML = '<img  src="widelong.jpg"></img>'
+            popupContentHTML = '<img  src="img/widelong.jpg"></img>'
             //anchored popup wide long fixed contents autosize closebox
             ll = new OpenLayers.LonLat(70,20);
@@ -228,52 +228,52 @@
             //anchored popup small contents no autosize overflow
             var ll = new OpenLayers.LonLat(-55,15);
             addMarker(ll, popupClass, popupContentHTML, false, true);
             //anchored popup small contents no autosize closebox overflow
             var ll = new OpenLayers.LonLat(-50,15);
             addMarker(ll, popupClass, popupContentHTML, true, true);
             //anchored popup small contents autosize overflow
             ll = new OpenLayers.LonLat(-40,15);
             //anchored popup small contents autosize closebox overflow
             ll = new OpenLayers.LonLat(-35,15);
             //anchored popup small contents autosize minsize overflow
             ll = new OpenLayers.LonLat(-25,15);
             //anchored popup small contents autosize minsize closebox overflow
             ll = new OpenLayers.LonLat(-20,15);
             //anchored popup small contents autosize maxsize overflow
             ll = new OpenLayers.LonLat(-10,15);
             //anchored popup small contents autosize maxsize closebox overflow
             ll = new OpenLayers.LonLat(-5,15);
@@ -305,39 +305,39 @@
             //anchored popup wide short fixed contents autosize overflow
             ll = new OpenLayers.LonLat(35,15);
             //anchored popup wide short fixed contents autosize closebox overflow
             ll = new OpenLayers.LonLat(40,15);
             //anchored popup thin long fixed contents autosize overflow
             ll = new OpenLayers.LonLat(50,15);
             //anchored popup thin long fixed contents autosize closebox overflow
             ll = new OpenLayers.LonLat(55,15);
             //anchored popup wide long fixed contents autosize overflow
             ll = new OpenLayers.LonLat(65,15);
             //anchored popup wide long fixed contents autosize closebox overflow
             ll = new OpenLayers.LonLat(70,15);
@@ -348,52 +348,52 @@
             //anchored bubble popup small contents no autosize
             var ll = new OpenLayers.LonLat(-55,5);
             popupClass = OpenLayers.Popup.AnchoredBubble;
             addMarker(ll, popupClass, popupContentHTML, false);
             //anchored bubble popup small contents no autosize closebox
             var ll = new OpenLayers.LonLat(-50,5);
             //anchored bubble popup small contents autosize
             ll = new OpenLayers.LonLat(-40,5);
             popupClass = AutoSizeAnchoredBubble;
             //anchored bubble popup small contents autosize closebox
             ll = new OpenLayers.LonLat(-35,5);
             //anchored bubble popup small contents autosize minsize
             ll = new OpenLayers.LonLat(-25,5);
             popupClass = AutoSizeAnchoredBubbleMinSize;
             //anchored bubble popup small contents autosize minsize closebox
             ll = new OpenLayers.LonLat(-20,5);
             //anchored bubble popup small contents autosize maxsize
             ll = new OpenLayers.LonLat(-10,5);
             popupClass = AutoSizeAnchoredBubbleMaxSize;
             //anchored bubble popup small contents autosize maxsize closebox
             ll = new OpenLayers.LonLat(-5,5);
@@ -426,39 +426,39 @@
             //anchored bubble popup wide short fixed contents autosize
             ll = new OpenLayers.LonLat(35,5);
             //anchored bubble popup wide short fixed contents autosize closebox
             ll = new OpenLayers.LonLat(40,5);
             //anchored bubble popup thin long fixed contents autosize
             ll = new OpenLayers.LonLat(50,5);
             //anchored bubble popup thin long fixed contents autosize closebox
             ll = new OpenLayers.LonLat(55,5);
             //anchored bubble popup wide long fixed contents autosize
             ll = new OpenLayers.LonLat(65,5);
             //anchored bubble popup wide long fixed contents autosize closebox
             ll = new OpenLayers.LonLat(70,5);
@@ -468,52 +468,52 @@
             var ll = new OpenLayers.LonLat(-55,0);
             var ll = new OpenLayers.LonLat(-50,0);
             ll = new OpenLayers.LonLat(-40,0);
             ll = new OpenLayers.LonLat(-35,0);
             ll = new OpenLayers.LonLat(-25,0);
             ll = new OpenLayers.LonLat(-20,0);
             ll = new OpenLayers.LonLat(-10,0);
             ll = new OpenLayers.LonLat(-5,0);
@@ -546,39 +546,39 @@
             //anchored bubble popup wide short fixed contents autosize overflow
             ll = new OpenLayers.LonLat(35,0);
             //anchored bubble popup wide short fixed contents autosize closebox overflow
             ll = new OpenLayers.LonLat(40,0);
             //anchored bubble popup thin long fixed contents autosize overflow
             ll = new OpenLayers.LonLat(50,0);
             //anchored bubble popup thin long fixed contents autosize closebox overflow
             ll = new OpenLayers.LonLat(55,0);
             //anchored bubble popup wide long fixed contents autosize overflow
             ll = new OpenLayers.LonLat(65,0);
             //anchored bubble popup wide long fixed contents autosize closebox overflow
             ll = new OpenLayers.LonLat(70,0);
    //FRAMED
@@ -590,52 +590,52 @@
             var ll = new OpenLayers.LonLat(-55,-15);
             popupClass = OpenLayers.Popup.FramedCloud;
             var ll = new OpenLayers.LonLat(-50,-15);
             ll = new OpenLayers.LonLat(-40,-15);
             popupClass = AutoSizeFramedCloud;
             ll = new OpenLayers.LonLat(-35,-15);
             ll = new OpenLayers.LonLat(-25,-15);
             popupClass = AutoSizeFramedCloudMinSize;
             ll = new OpenLayers.LonLat(-20,-15);
             ll = new OpenLayers.LonLat(-10,-15);
             popupClass = AutoSizeFramedCloudMaxSize;
             ll = new OpenLayers.LonLat(-5,-15);
@@ -668,39 +668,39 @@
             ll = new OpenLayers.LonLat(35,-15);
             ll = new OpenLayers.LonLat(40,-15);
             ll = new OpenLayers.LonLat(50,-15);
             ll = new OpenLayers.LonLat(55,-15);
             ll = new OpenLayers.LonLat(65,-15);
             ll = new OpenLayers.LonLat(70,-15);
@@ -710,52 +710,52 @@
             var ll = new OpenLayers.LonLat(-55,-20);
             var ll = new OpenLayers.LonLat(-50,-20);
             ll = new OpenLayers.LonLat(-40,-20);
             ll = new OpenLayers.LonLat(-35,-20);
             ll = new OpenLayers.LonLat(-25,-20);
             ll = new OpenLayers.LonLat(-20,-20);
             ll = new OpenLayers.LonLat(-10,-20);
             ll = new OpenLayers.LonLat(-5,-20);
@@ -788,39 +788,39 @@
             ll = new OpenLayers.LonLat(35,-20);
             ll = new OpenLayers.LonLat(40,-20);
             ll = new OpenLayers.LonLat(50,-20);
             ll = new OpenLayers.LonLat(55,-20);
             ll = new OpenLayers.LonLat(65,-20);
             ll = new OpenLayers.LonLat(70,-20);
@@ -881,16 +881,16 @@
       <div id="map" class="smallmap"></div>
         <!-- preloading these images so the autosize will work correctly -->
-        <img src="wideshort.jpg" style="position:absolute; top:-5000px; left: -5000px"></img>
-        <img src="widelong.jpg" style="position:absolute; top:-5000px; left: -5000px"></img>
-        <img src="thinlong.jpg" style="position:absolute; top:-5000px; left: -5000px"></img>
+        <img src="img/wideshort.jpg" style="position:absolute; top:-5000px; left: -5000px"></img>
+        <img src="img/widelong.jpg" style="position:absolute; top:-5000px; left: -5000px"></img>
+        <img src="img/thinlong.jpg" style="position:absolute; top:-5000px; left: -5000px"></img>
        <p> All of the images in this file a pre-cached, meaning they are
            loaded immediately when you load the page (they are just placed
            far offscreen, that's why you don't see them).
        </p>
        <br>
-       <p> The only image that is *not* preloaded is small.jpg, the brazilian
+       <p> The only image that is *not* preloaded is img/small.jpg, the brazilian
            flag. We do this in order to test out to make sure that our auto-sizing
              code does in fact activate itself as the images load. To verify
              this, clear your cache and reload this example page. Click on
Deleted: trunk/openlayers/examples/popupMatrix.jpg
Deleted: trunk/openlayers/examples/small.jpg
Deleted: trunk/openlayers/examples/thinlong.jpg
Deleted: trunk/openlayers/examples/widelong.jpg
Deleted: trunk/openlayers/examples/wideshort.jpg
More information about the Commits mailing list
