[OpenLayers-Commits] r11240 - sandbox/camptocamp/mobile/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Feb 22 09:31:43 EST 2011
Author: fredj
Date: 2011-02-22 06:31:43 -0800 (Tue, 22 Feb 2011)
New Revision: 11240
   sandbox/camptocamp/mobile/openlayers/examples/mobile-jq.html
remove header, update footer
Modified: sandbox/camptocamp/mobile/openlayers/examples/mobile-jq.html
--- sandbox/camptocamp/mobile/openlayers/examples/mobile-jq.html	2011-02-22 14:30:03 UTC (rev 11239)
+++ sandbox/camptocamp/mobile/openlayers/examples/mobile-jq.html	2011-02-22 14:31:43 UTC (rev 11240)
@@ -24,7 +24,7 @@
             .ui-content {
                 padding: 0;
-            .ui-footer, .ui-header {
+            .ui-footer {
                 text-align: center;
                 padding: 5px 0;
@@ -40,15 +40,14 @@
         </style>
         <script>
             $(document).ready(function() {
-                // fix height of content to allow for header & footer
+                // fix height of content
                 function fixContentHeight() {
-                    var header = $("div[data-role='header']:visible");
-                    var footer = $("div[data-role='footer']:visible");
-                    var content = $("div[data-role='content']:visible:visible");
-                    var viewHeight = $(window).height();
+                    var footer = $("div[data-role='footer']:visible"),
+                        content = $("div[data-role='content']:visible:visible"),
+                        viewHeight = $(window).height(),
+                        contentHeight = viewHeight - footer.outerHeight();
-                    var contentHeight = viewHeight - header.outerHeight() - footer.outerHeight();
-                    if ((content.outerHeight() + header.outerHeight() + footer.outerHeight()) !== viewHeight) {
+                    if ((content.outerHeight() + footer.outerHeight()) !== viewHeight) {
                         contentHeight -= (content.outerHeight() - content.height());
                         content.height(contentHeight);
@@ -61,73 +60,20 @@
                 $(window).bind("orientationchange resize pageshow", fixContentHeight);
                 fixContentHeight();
-                // add behavior to navigation buttons
-                $("#west").click(function() {
-                    pan(-0.25, 0);
-                $("#north").click(function() {
-                    pan(0, -0.25);
-                $("#south").click(function() {
-                    pan(0, 0.25);
-                $("#east").click(function() {
-                    pan(0.25, 0);
-                // add behavior to drawing controls
-                function deactivateControls() {
-                    $.each(map.getControlsByClass(/DrawFeature/), function(index, control) {
-                        control.deactivate();
-                    map.getControlsBy("id", "mod-control")[0].deactivate();
-                $("#nav, #point, #line, #poly, #mod").change(function(event) {
-                    deactivateControls();
-                    // jquery mobile bug regarding change makes us go through all inputs
-                    // https://github.com/jquery/jquery-mobile/issues/issue/1088
-                    var val = $("input:radio[name=controls]:checked").val();
-                    if (val !== "nav") {
-                        map.getControlsBy("id", val + "-control")[0].activate();
-                $("#nav").click();
-                $("#nav").click(); // jquery mobile bug forces 2 calls to refresh radio ui
         </script>
     </head>
     <body>
         <div data-role="page">
-            <div data-role="header">
-                <input id="west" type="button" data-icon="arrow-l" value="west">
-                <input id="north" type="button" data-icon="arrow-u" value="north">
-                <input id="south" type="button" data-icon="arrow-d" value="south">
-                <input id="east" type="button" data-icon="arrow-r" value="east">
-            </div>
             <div data-role="content">
                 <div id="map"></div>
             </div>
             <div data-role="footer">
-                <form id="controls">
-                    <fieldset data-role="controlgroup" data-type="horizontal" data-role="fieldcontain">
-                        <input id="nav" type="radio" name="controls" value="nav" checked="checked">
-                        <label for="nav">navigate</label>
-                        <input id="point" type="radio" name="controls" value="point">
-                        <label for="point">point</label>
-                        <input id="line" type="radio" name="controls" value="line">
-                        <label for="line">line</label>
-                        <input id="poly" type="radio" name="controls" value="poly">
-                        <label for="poly">poly</label>
-                        <input id="mod" type="radio" name="controls" value="mod">
-                        <label for="mod">modify</label>
-                    </fieldset>
-                </form>
+              <a href="" data-icon="search" data-role="button">Search</a>
+              <a href="" data-icon="locate" data-role="button">Locate</a>
+              <a href="" data-icon="layers" data-role="button">Layers</a>
             </div>
         </div>
     </body>
More information about the Commits mailing list
