[OpenLayers-Commits] r11257 - in sandbox/bartvde/adapters/openlayers: . adapters tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Feb 22 11:42:30 EST 2011
Author: bartvde
Date: 2011-02-22 08:42:30 -0800 (Tue, 22 Feb 2011)
New Revision: 11257
Added:
   sandbox/bartvde/adapters/openlayers/adapters/
   sandbox/bartvde/adapters/openlayers/adapters/ext-bridge.js
   sandbox/bartvde/adapters/openlayers/adapters/ext-core.js
   sandbox/bartvde/adapters/openlayers/adapters/sencha-touch.js
   sandbox/bartvde/adapters/openlayers/tests/OLLoader.js
   sandbox/bartvde/adapters/openlayers/tests/Util.html
starting to work on the adapters (Marc Jansen)
Added: sandbox/bartvde/adapters/openlayers/adapters/ext-bridge.js
--- sandbox/bartvde/adapters/openlayers/adapters/ext-bridge.js	                        (rev 0)
+++ sandbox/bartvde/adapters/openlayers/adapters/ext-bridge.js	2011-02-22 16:42:30 UTC (rev 11257)
@@ -0,0 +1,25 @@
+if(typeof Ext === "undefined"){
+    throw "Ext not found.";
+Ext.apply(OpenLayers.Util,
+        pagePosition: function(forElement) {
+            var pos = [0, 0];
+            var viewportElement = OpenLayers.Util.getViewportElement();
+            if (!forElement || forElement == window || forElement == viewportElement) {
+                // viewport is always at 0,0 as that defined the coordinate system for
+                // this function - this avoids special case checks in the code below
+                return pos;
+            } else {
+                return Ext.get(forElement).getXY();
+        getElement: function() {
+            var array = Array.prototype.slice.call(arguments);
+            var elements = Ext.get(array).elements;
+            return (elements.length === 1) ? elements[0] : elements;
Added: sandbox/bartvde/adapters/openlayers/adapters/ext-core.js
--- sandbox/bartvde/adapters/openlayers/adapters/ext-core.js	                        (rev 0)
+++ sandbox/bartvde/adapters/openlayers/adapters/ext-core.js	2011-02-22 16:42:30 UTC (rev 11257)
@@ -0,0 +1,8 @@
+ * Ext Core Library 3.0
+ * http://extjs.com/
+ * Copyright(c) 2006-2009, Ext JS, LLC.
+ * MIT Licensed - http://extjs.com/license/mit.txt
+window.undefined=window.undefined;Ext={version:"3.1.0"};Ext.apply=function(d,e,b){if(b){Ext.apply(d,b)}if(d&&e&&typeof e=="object"){for(var a in e){d[a]=e[a]}}return d};(function(){var h=0,t=Object.prototype.toString,u=navigator.userAgent.toLowerCase(),z=function(e){return e.test(u)},j=document,m=j.compatMode=="CSS1Compat",B=z(/opera/),i=z(/chrome/),v=z(/webkit/),y=!i&&z(/safari/),g=y&&z(/applewebkit\/4/),b=y&&z(/version\/3/),C=y&&z(/version\/4/),s=!B&&z(/msie/),q=s&&z(/msie 7/),p=s&&z(/msie 8/),r=s&&!q&&!p,o=!v&&z(/gecko/),d=o&&z(/rv:1\.8/),a=o&&z(/rv:1\.9/),w=s&&!m,A=z(/windows|win32/),l=z(/macintosh|mac os x/),k=z(/adobeair/),n=z(/linux/),c=/^https/i.test(window.location.protocol);if(r){try{j.execCommand("BackgroundImageCache",false,true)}catch(x){}}Ext.apply(Ext,{SSL_SECURE_URL:c&&s?'javascript:""':"about:blank",isStrict:m,isSecure:c,isReady:false,enableGarbageCollector:true,enableListenerCollection:false,enableNestedListenerRemoval:false,USE_NATIVE_JSON:false,applyIf:fu
 nction(D,E){if(D){for(var e in E){if(!Ext.isDefined(D[e])){D[e]=E[e]}}}return D},id:function(e,D){return(e=Ext.getDom(e)||{}).id=e.id||(D||"ext-gen")+(++h)},extend:function(){var D=function(F){for(var E in F){this[E]=F[E]}};var e=Object.prototype.constructor;return function(K,H,J){if(Ext.isObject(H)){J=H;H=K;K=J.constructor!=e?J.constructor:function(){H.apply(this,arguments)}}var G=function(){},I,E=H.prototype;G.prototype=E;I=K.prototype=new G();I.constructor=K;K.superclass=E;if(E.constructor==e){E.constructor=H}K.override=function(F){Ext.override(K,F)};I.superclass=I.supr=(function(){return E});I.override=D;Ext.override(K,J);K.extend=function(F){return Ext.extend(K,F)};return K}}(),override:function(e,E){if(E){var D=e.prototype;Ext.apply(D,E);if(Ext.isIE&&E.hasOwnProperty("toString")){D.toString=E.toString}}},namespace:function(){var D,e;Ext.each(arguments,function(E){e=E.split(".");D=window[e[0]]=window[e[0]]||{};Ext.each(e.slice(1),function(F){D=D[F]=D[F]||{}})});return D
 },urlEncode:function(H,G){var E,D=[],F=encodeURIComponent;Ext.iterate(H,function(e,I){E=Ext.isEmpty(I);Ext.each(E?e:I,function(J){D.push("&",F(e),"=",(!Ext.isEmpty(J)&&(J!=e||!E))?(Ext.isDate(J)?Ext.encode(J).replace(/"/g,""):F(J)):"")})});if(!G){D.shift();G=""}return G+D.join("")},urlDecode:function(E,D){if(Ext.isEmpty(E)){return{}}var H={},G=E.split("&"),I=decodeURIComponent,e,F;Ext.each(G,function(J){J=J.split("=");e=I(J[0]);F=I(J[1]);H[e]=D||!H[e]?F:[].concat(H[e]).concat(F)});return H},urlAppend:function(e,D){if(!Ext.isEmpty(D)){return e+(e.indexOf("?")===-1?"?":"&")+D}return e},toArray:function(){return s?function(E,H,F,G){G=[];for(var D=0,e=E.length;D<e;D++){G.push(E[D])}return G.slice(H||0,F||G.length)}:function(e,E,D){return Array.prototype.slice.call(e,E||0,D||e.length)}}(),isIterable:function(e){if(Ext.isArray(e)||e.callee){return true}if(/NodeList|HTMLCollection/.test(t.call(e))){return true}return((typeof e.nextNode!="undefined"||e.item)&&Ext.isNumber(e.length))
 },each:function(G,F,E){if(Ext.isEmpty(G,true)){return}if(!Ext.isIterable(G)||Ext.isPrimitive(G)){G=[G]}for(var D=0,e=G.length;D<e;D++){if(F.call(E||G[D],G[D],D,G)===false){return D}}},iterate:function(E,D,e){if(Ext.isEmpty(E)){return}if(Ext.isIterable(E)){Ext.each(E,D,e);return}else{if(Ext.isObject(E)){for(var F in E){if(E.hasOwnProperty(F)){if(D.call(e||E,F,E[F],E)===false){return}}}}}},getDom:function(e){if(!e||!j){return null}return e.dom?e.dom:(Ext.isString(e)?j.getElementById(e):e)},getBody:function(){return Ext.get(j.body||j.documentElement)},removeNode:s&&!p?function(){var e;return function(D){if(D&&D.tagName!="BODY"){(Ext.enableNestedListenerRemoval)?Ext.EventManager.purgeElement(D,true):Ext.EventManager.removeAll(D);e=e||j.createElement("div");e.appendChild(D);e.innerHTML="";delete Ext.elCache[D.id]}}}():function(e){if(e&&e.parentNode&&e.tagName!="BODY"){(Ext.enableNestedListenerRemoval)?Ext.EventManager.purgeElement(e,true):Ext.EventManager.removeAll(e);e.parentNod
 e.removeChild(e);delete Ext.elCache[e.id]}},isEmpty:function(D,e){return D===null||D===undefined||((Ext.isArray(D)&&!D.length))||(!e?D==="":false)},isArray:function(e){return t.apply(e)==="[object Array]"},isDate:function(e){return t.apply(e)==="[object Date]"},isObject:function(e){return !!e&&Object.prototype.toString.call(e)==="[object Object]"},isPrimitive:function(e){return Ext.isString(e)||Ext.isNumber(e)||Ext.isBoolean(e)},isFunction:function(e){return t.apply(e)==="[object Function]"},isNumber:function(e){return typeof e==="number"&&isFinite(e)},isString:function(e){return typeof e==="string"},isBoolean:function(e){return typeof e==="boolean"},isElement:function(e){return !!e&&e.tagName},isDefined:function(e){return typeof e!=="undefined"},isOpera:B,isWebKit:v,isChrome:i,isSafari:y,isSafari3:b,isSafari4:C,isSafari2:g,isIE:s,isIE6:r,isIE7:q,isIE8:p,isGecko:o,isGecko2:d,isGecko3:a,isBorderBox:w,isLinux:n,isWindows:A,isMac:l,isAir:k});Ext.ns=Ext.namespace})();Ext.ns("Ext
 .util","Ext.lib","Ext.data");Ext.elCache={};Ext.apply(Function.prototype,{createInterceptor:function(b,a){var c=this;return !Ext.isFunction(b)?this:function(){var e=this,d=arguments;b.target=e;b.method=c;return(b.apply(a||e||window,d)!==false)?c.apply(e||window,d):null}},createCallback:function(){var a=arguments,b=this;return function(){return b.apply(window,a)}},createDelegate:function(c,b,a){var d=this;return function(){var g=b||arguments;if(a===true){g=Array.prototype.slice.call(arguments,0);g=g.concat(b)}else{if(Ext.isNumber(a)){g=Array.prototype.slice.call(arguments,0);var e=[a,0].concat(b);Array.prototype.splice.apply(g,e)}}return d.apply(c||window,g)}},defer:function(c,e,b,a){var d=this.createDelegate(e,b,a);if(c>0){return setTimeout(d,c)}d();return 0}});Ext.applyIf(String,{format:function(b){var a=Ext.toArray(arguments,1);return b.replace(/\{(\d+)\}/g,function(c,d){return a[d]})}});Ext.applyIf(Array.prototype,{indexOf:function(b,c){var a=this.length;c=c||0;c+=(c<0)?a
 :0;for(;c<a;++c){if(this[c]===b){return c}}return -1},remove:function(b){var a=this.indexOf(b);if(a!=-1){this.splice(a,1)}return this}});Ext.util.TaskRunner=function(e){e=e||10;var g=[],a=[],b=0,h=false,d=function(){h=false;clearInterval(b);b=0},i=function(){if(!h){h=true;b=setInterval(j,e)}},c=function(k){a.push(k);if(k.onStop){k.onStop.apply(k.scope||k)}},j=function(){var m=a.length,o=new Date().getTime();if(m>0){for(var q=0;q<m;q++){g.remove(a[q])}a=[];if(g.length<1){d();return}}for(var q=0,p,l,n,k=g.length;q<k;++q){p=g[q];l=o-p.taskRunTime;if(p.interval<=l){n=p.run.apply(p.scope||p,p.args||[++p.taskRunCount]);p.taskRunTime=o;if(n===false||p.taskRunCount===p.repeat){c(p);return}}if(p.duration&&p.duration<=(o-p.taskStartTime)){c(p)}}};this.start=function(k){g.push(k);k.taskStartTime=new Date().getTime();k.taskRunTime=0;k.taskRunCount=0;i();return k};this.stop=function(k){c(k);return k};this.stopAll=function(){d();for(var l=0,k=g.length;l<k;l++){if(g[l].onStop){g[l].onStop(
 )}}g=[];a=[]}};Ext.TaskMgr=new Ext.util.TaskRunner();Ext.util.DelayedTask=function(d,c,a){var e=this,g,b=function(){clearInterval(g);g=null;d.apply(c,a||[])};e.delay=function(i,k,j,h){e.cancel();d=k||d;c=j||c;a=h||a;g=setInterval(b,i)};e.cancel=function(){if(g){clearInterval(g);g=null}}};(function(){var b;function c(d){if(!b){b=new Ext.Element.Flyweight()}b.dom=d;return b}(function(){var h=document,e=h.compatMode=="CSS1Compat",g=Math.max,d=Math.round,i=parseInt;Ext.lib.Dom={isAncestor:function(k,l){var j=false;k=Ext.getDom(k);l=Ext.getDom(l);if(k&&l){if(k.contains){return k.contains(l)}else{if(k.compareDocumentPosition){return !!(k.compareDocumentPosition(l)&16)}else{while(l=l.parentNode){j=l==k||j}}}}return j},getViewWidth:function(j){return j?this.getDocumentWidth():this.getViewportWidth()},getViewHeight:function(j){return j?this.getDocumentHeight():this.getViewportHeight()},getDocumentHeight:function(){return g(!e?h.body.scrollHeight:h.documentElement.scrollHeight,this.ge
 tViewportHeight())},getDocumentWidth:function(){return g(!e?h.body.scrollWidth:h.documentElement.scrollWidth,this.getViewportWidth())},getViewportHeight:function(){return Ext.isIE?(Ext.isStrict?h.documentElement.clientHeight:h.body.clientHeight):self.innerHeight},getViewportWidth:function(){return !Ext.isStrict&&!Ext.isOpera?h.body.clientWidth:Ext.isIE?h.documentElement.clientWidth:self.innerWidth},getY:function(j){return this.getXY(j)[1]},getX:function(j){return this.getXY(j)[0]},getXY:function(l){var k,r,t,w,m,n,v=0,s=0,u,j,o=(h.body||h.documentElement),q=[0,0];l=Ext.getDom(l);if(l!=o){if(l.getBoundingClientRect){t=l.getBoundingClientRect();u=c(document).getScroll();q=[d(t.left+u.left),d(t.top+u.top)]}else{k=l;j=c(l).isStyle("position","absolute");while(k){r=c(k);v+=k.offsetLeft;s+=k.offsetTop;j=j||r.isStyle("position","absolute");if(Ext.isGecko){s+=w=i(r.getStyle("borderTopWidth"),10)||0;v+=m=i(r.getStyle("borderLeftWidth"),10)||0;if(k!=l&&!r.isStyle("overflow","visible")
 ){v+=m;s+=w}}k=k.offsetParent}if(Ext.isSafari&&j){v-=o.offsetLeft;s-=o.offsetTop}if(Ext.isGecko&&!j){n=c(o);v+=i(n.getStyle("borderLeftWidth"),10)||0;s+=i(n.getStyle("borderTopWidth"),10)||0}k=l.parentNode;while(k&&k!=o){if(!Ext.isOpera||(k.tagName!="TR"&&!c(k).isStyle("display","inline"))){v-=k.scrollLeft;s-=k.scrollTop}k=k.parentNode}q=[v,s]}}return q},setXY:function(k,l){(k=Ext.fly(k,"_setXY")).position();var m=k.translatePoints(l),j=k.dom.style,n;for(n in m){if(!isNaN(m[n])){j[n]=m[n]+"px"}}},setX:function(k,j){this.setXY(k,[j,false])},setY:function(j,k){this.setXY(j,[false,k])}}})();Ext.lib.Event=function(){var x=false,h={},B=0,q=[],d,D=false,l=window,H=document,m=200,t=20,C=0,s=0,j=1,n=2,u=2,y=3,v="scrollLeft",r="scrollTop",g="unload",A="mouseover",G="mouseout",e=function(){var I;if(l.addEventListener){I=function(M,K,L,J){if(K=="mouseenter"){L=L.createInterceptor(p);M.addEventListener(A,L,(J))}else{if(K=="mouseleave"){L=L.createInterceptor(p);M.addEventListener(G,L,(J)
 )}else{M.addEventListener(K,L,(J))}}return L}}else{if(l.attachEvent){I=function(M,K,L,J){M.attachEvent("on"+K,L);return L}}else{I=function(){}}}return I}(),i=function(){var I;if(l.removeEventListener){I=function(M,K,L,J){if(K=="mouseenter"){K=A}else{if(K=="mouseleave"){K=G}}M.removeEventListener(K,L,(J))}}else{if(l.detachEvent){I=function(L,J,K){L.detachEvent("on"+J,K)}}else{I=function(){}}}return I}();function p(I){return !w(I.currentTarget,z.getRelatedTarget(I))}function w(I,J){if(I&&I.firstChild){while(J){if(J===I){return true}J=J.parentNode;if(J&&(J.nodeType!=1)){J=null}}}return false}function E(){var K=false,O=[],M,L,I,J,N=!x||(B>0);if(!D){D=true;for(L=0,I=q.length;L<I;L++){J=q[L];if(J&&(M=H.getElementById(J.id))){if(!J.checkReady||x||M.nextSibling||(H&&H.body)){M=J.override?(J.override===true?J.obj:J.override):M;J.fn.call(M,J.obj);q.remove(J)}else{O.push(J)}}}B=(O.length===0)?0:B-1;if(N){o()}else{clearInterval(d);d=null}K=!(D=false)}return K}function o(){if(!d){var I=f
 unction(){E()};d=setInterval(I,t)}}function F(){var I=H.documentElement,J=H.body;if(I&&(I[r]||I[v])){return[I[v],I[r]]}else{if(J){return[J[v],J[r]]}else{return[0,0]}}}function k(I,J){I=I.browserEvent||I;var K=I["page"+J];if(!K&&K!==0){K=I["client"+J]||0;if(Ext.isIE){K+=F()[J=="X"?0:1]}}return K}var z={extAdapter:true,onAvailable:function(K,I,L,J){q.push({id:K,fn:I,obj:L,override:J,checkReady:false});B=m;o()},addListener:function(K,I,J){K=Ext.getDom(K);if(K&&J){if(I==g){if(h[K.id]===undefined){h[K.id]=[]}h[K.id].push([I,J]);return J}return e(K,I,J,false)}return false},removeListener:function(O,K,N){O=Ext.getDom(O);var M,J,I,L;if(O&&N){if(K==g){if((L=h[O.id])!==undefined){for(M=0,J=L.length;M<J;M++){if((I=L[M])&&I[s]==K&&I[j]==N){h[id].splice(M,1)}}}return}i(O,K,N,false)}},getTarget:function(I){I=I.browserEvent||I;return this.resolveTextNode(I.target||I.srcElement)},resolveTextNode:Ext.isGecko?function(J){if(!J){return}var I=HTMLElement.prototype.toString.call(J);if(I=="[xpcon
 nect wrapped native prototype]"||I=="[object XULElement]"){return}return J.nodeType==3?J.parentNode:J}:function(I){return I&&I.nodeType==3?I.parentNode:I},getRelatedTarget:function(I){I=I.browserEvent||I;return this.resolveTextNode(I.relatedTarget||(I.type==G?I.toElement:I.type==A?I.fromElement:null))},getPageX:function(I){return k(I,"X")},getPageY:function(I){return k(I,"Y")},getXY:function(I){return[this.getPageX(I),this.getPageY(I)]},stopEvent:function(I){this.stopPropagation(I);this.preventDefault(I)},stopPropagation:function(I){I=I.browserEvent||I;if(I.stopPropagation){I.stopPropagation()}else{I.cancelBubble=true}},preventDefault:function(I){I=I.browserEvent||I;if(I.preventDefault){I.preventDefault()}else{I.returnValue=false}},getEvent:function(I){I=I||l.event;if(!I){var J=this.getEvent.caller;while(J){I=J.arguments[0];if(I&&Event==I.constructor){break}J=J.caller}}return I},getCharCode:function(I){I=I.browserEvent||I;return I.charCode||I.keyCode||0},getListeners:functio
 n(J,I){Ext.EventManager.getListeners(J,I)},purgeElement:function(J,K,I){Ext.EventManager.purgeElement(J,K,I)},_load:function(J){x=true;var I=Ext.lib.Event;if(Ext.isIE&&J!==true){i(l,"load",arguments.callee)}},_unload:function(P){var J=Ext.lib.Event,M,L,K,S,Q,I,O,N,T;for(I in h){Q=h[I];for(M=0,O=Q.length;M<O;M++){S=Q[M];if(S){try{T=S[y]?(S[y]===true?S[u]:S[y]):l;S[j].call(T,J.getEvent(P),S[u])}catch(R){}}}}h=null;Ext.EventManager._unload();i(l,g,J._unload)}};z.on=z.addListener;z.un=z.removeListener;if(H&&H.body){z._load(true)}else{e(l,"load",z._load)}e(l,g,z._unload);E();return z}();Ext.lib.Ajax=function(){var h=["MSXML2.XMLHTTP.3.0","MSXML2.XMLHTTP","Microsoft.XMLHTTP"],d="Content-Type";function i(t){var s=t.conn,u;function r(v,w){for(u in w){if(w.hasOwnProperty(u)){v.setRequestHeader(u,w[u])}}}if(l.defaultHeaders){r(s,l.defaultHeaders)}if(l.headers){r(s,l.headers);delete l.headers}}function e(u,t,s,r){return{tId:u,status:s?-1:0,statusText:s?"transaction aborted":"communicat
 ion failure",isAbort:s,isTimeout:r,argument:t}}function k(r,s){(l.headers=l.headers||{})[r]=s}function p(A,y){var u={},w,x=A.conn,r,v;try{w=A.conn.getAllResponseHeaders();Ext.each(w.replace(/\r\n/g,"\n").split("\n"),function(s){r=s.indexOf(":");if(r>=0){v=s.substr(0,r).toLowerCase();if(s.charAt(r+1)==" "){++r}u[v]=s.substr(r+1)}})}catch(z){}return{tId:A.tId,status:x.status,statusText:x.statusText,getResponseHeader:function(s){return u[s.toLowerCase()]},getAllResponseHeaders:function(){return w},responseText:x.responseText,responseXML:x.responseXML,argument:y}}function o(r){r.conn=null;r=null}function g(w,x,s,r){if(!x){o(w);return}var u,t;try{if(w.conn.status!==undefined&&w.conn.status!=0){u=w.conn.status}else{u=13030}}catch(v){u=13030}if((u>=200&&u<300)||(Ext.isIE&&u==1223)){t=p(w,x.argument);if(x.success){if(!x.scope){x.success(t)}else{x.success.apply(x.scope,[t])}}}else{switch(u){case 12002:case 12029:case 12030:case 12031:case 12152:case 13030:t=e(w.tId,x.argument,(s?s:fa
 lse),r);if(x.failure){if(!x.scope){x.failure(t)}else{x.failure.apply(x.scope,[t])}}break;default:t=p(w,x.argument);if(x.failure){if(!x.scope){x.failure(t)}else{x.failure.apply(x.scope,[t])}}}}o(w);t=null}function n(t,w){w=w||{};var r=t.conn,v=t.tId,s=l.poll,u=w.timeout||null;if(u){l.timeout[v]=setTimeout(function(){l.abort(t,w,true)},u)}s[v]=setInterval(function(){if(r&&r.readyState==4){clearInterval(s[v]);s[v]=null;if(u){clearTimeout(l.timeout[v]);l.timeout[v]=null}g(t,w)}},l.pollInterval)}function j(v,s,u,r){var t=m()||null;if(t){t.conn.open(v,s,true);if(l.useDefaultXhrHeader){k("X-Requested-With",l.defaultXhrHeader)}if(r&&l.useDefaultHeader&&(!l.headers||!l.headers[d])){k(d,l.defaultPostHeader)}if(l.defaultHeaders||l.headers){i(t)}n(t,u);t.conn.send(r||null)}return t}function m(){var s;try{if(s=q(l.transactionId)){l.transactionId++}}catch(r){}finally{return s}}function q(u){var r;try{r=new XMLHttpRequest()}catch(t){for(var s=0;s<h.length;++s){try{r=new ActiveXObject(h[s])
 ;break}catch(t){}}}finally{return{conn:r,tId:u}}}var l={request:function(r,t,u,v,z){if(z){var w=this,s=z.xmlData,x=z.jsonData,y;Ext.applyIf(w,z);if(s||x){y=w.headers;if(!y||!y[d]){k(d,s?"text/xml":"application/json")}v=s||(!Ext.isPrimitive(x)?Ext.encode(x):x)}}return j(r||z.method||"POST",t,u,v)},serializeForm:function(s){var t=s.elements||(document.forms[s]||Ext.getDom(s)).elements,z=false,y=encodeURIComponent,w,A,r,u,v="",x;Ext.each(t,function(B){r=B.name;x=B.type;if(!B.disabled&&r){if(/select-(one|multiple)/i.test(x)){Ext.each(B.options,function(C){if(C.selected){v+=String.format("{0}={1}&",y(r),y((C.hasAttribute?C.hasAttribute("value"):C.getAttribute("value")!==null)?C.value:C.text))}})}else{if(!/file|undefined|reset|button/i.test(x)){if(!(/radio|checkbox/i.test(x)&&!B.checked)&&!(x=="submit"&&z)){v+=y(r)+"="+y(B.value)+"&";z=/submit/i.test(x)}}}}});return v.substr(0,v.length-1)},useDefaultHeader:true,defaultPostHeader:"application/x-www-form-urlencoded; charset=UTF-8",u
 seDefaultXhrHeader:true,defaultXhrHeader:"XMLHttpRequest",poll:{},timeout:{},pollInterval:50,transactionId:0,abort:function(u,w,r){var t=this,v=u.tId,s=false;if(t.isCallInProgress(u)){u.conn.abort();clearInterval(t.poll[v]);t.poll[v]=null;clearTimeout(l.timeout[v]);t.timeout[v]=null;g(u,w,(s=true),r)}return s},isCallInProgress:function(r){return r.conn&&!{0:true,4:true}[r.conn.readyState]}};return l}();(function(){var h=Ext.lib,j=/width|height|opacity|padding/i,g=/^((width|height)|(top|left))$/,d=/width|height|top$|bottom$|left$|right$/i,i=/\d+(em|%|en|ex|pt|in|cm|mm|pc)$/i,k=function(l){return typeof l!=="undefined"},e=function(){return new Date()};h.Anim={motion:function(o,m,p,q,l,n){return this.run(o,m,p,q,l,n,Ext.lib.Motion)},run:function(p,m,r,s,l,o,n){n=n||Ext.lib.AnimBase;if(typeof s=="string"){s=Ext.lib.Easing[s]}var q=new n(p,m,r,s);q.animateX(function(){if(Ext.isFunction(l)){l.call(o)}});return q}};h.AnimBase=function(m,l,n,o){if(m){this.init(m,l,n,o)}};h.AnimBase.
 prototype={doMethod:function(l,o,m){var n=this;return n.method(n.curFrame,o,m-o,n.totalFrames)},setAttr:function(l,n,m){if(j.test(l)&&n<0){n=0}Ext.fly(this.el,"_anim").setStyle(l,n+m)},getAttr:function(l){var n=Ext.fly(this.el),o=n.getStyle(l),m=g.exec(l)||[];if(o!=="auto"&&!i.test(o)){return parseFloat(o)}return(!!(m[2])||(n.getStyle("position")=="absolute"&&!!(m[3])))?n.dom["offset"+m[0].charAt(0).toUpperCase()+m[0].substr(1)]:0},getDefaultUnit:function(l){return d.test(l)?"px":""},animateX:function(o,l){var m=this,n=function(){m.onComplete.removeListener(n);if(Ext.isFunction(o)){o.call(l||m,m)}};m.onComplete.addListener(n,m);m.animate()},setRunAttr:function(q){var s=this,t=this.attributes[q],u=t.to,r=t.by,v=t.from,w=t.unit,m=(this.runAttrs[q]={}),n;if(!k(u)&&!k(r)){return false}var l=k(v)?v:s.getAttr(q);if(k(u)){n=u}else{if(k(r)){if(Ext.isArray(l)){n=[];for(var o=0,p=l.length;o<p;o++){n[o]=l[o]+r[o]}}else{n=l+r}}}Ext.apply(m,{start:l,end:n,unit:k(w)?w:s.getDefaultUnit(q)}
 )},init:function(m,q,p,l){var s=this,o=0,t=h.AnimMgr;Ext.apply(s,{isAnimated:false,startTime:null,el:Ext.getDom(m),attributes:q||{},duration:p||1,method:l||h.Easing.easeNone,useSec:true,curFrame:0,totalFrames:t.fps,runAttrs:{},animate:function(){var v=this,w=v.duration;if(v.isAnimated){return false}v.curFrame=0;v.totalFrames=v.useSec?Math.ceil(t.fps*w):w;t.registerElement(v)},stop:function(v){var w=this;if(v){w.curFrame=w.totalFrames;w._onTween.fire()}t.stop(w)}});var u=function(){var w=this,v;w.onStart.fire();w.runAttrs={};for(v in this.attributes){this.setRunAttr(v)}w.isAnimated=true;w.startTime=e();o=0};var r=function(){var w=this;w.onTween.fire({duration:e()-w.startTime,curFrame:w.curFrame});var x=w.runAttrs;for(var v in x){this.setAttr(v,w.doMethod(v,x[v].start,x[v].end),x[v].unit)}++o};var n=function(){var v=this,x=(e()-v.startTime)/1000,w={duration:x,frames:o,fps:o/x};v.isAnimated=false;o=0;v.onComplete.fire(w)};s.onStart=new Ext.util.Event(s);s.onTween=new Ext.util.E
 vent(s);s.onComplete=new Ext.util.Event(s);(s._onStart=new Ext.util.Event(s)).addListener(u);(s._onTween=new Ext.util.Event(s)).addListener(r);(s._onComplete=new Ext.util.Event(s)).addListener(n)}};Ext.lib.AnimMgr=new function(){var p=this,n=null,m=[],l=0;Ext.apply(p,{fps:1000,delay:1,registerElement:function(r){m.push(r);++l;r._onStart.fire();p.start()},unRegister:function(s,r){s._onComplete.fire();r=r||q(s);if(r!=-1){m.splice(r,1)}if(--l<=0){p.stop()}},start:function(){if(n===null){n=setInterval(p.run,p.delay)}},stop:function(t){if(!t){clearInterval(n);for(var s=0,r=m.length;s<r;++s){if(m[0].isAnimated){p.unRegister(m[0],0)}}m=[];n=null;l=0}else{p.unRegister(t)}},run:function(){var u,t,r,s;for(t=0,r=m.length;t<r;t++){s=m[t];if(s&&s.isAnimated){u=s.totalFrames;if(s.curFrame<u||u===null){++s.curFrame;if(s.useSec){o(s)}s._onTween.fire()}else{p.stop(s)}}}}});var q=function(t){var s,r;for(s=0,r=m.length;s<r;s++){if(m[s]===t){return s}}return -1};var o=function(s){var w=s.totalF
 rames,v=s.curFrame,u=s.duration,t=(v*u*1000/w),r=(e()-s.startTime),x=0;if(r<u*1000){x=Math.round((r/t-1)*v)}else{x=w-(v+1)}if(x>0&&isFinite(x)){if(s.curFrame+x>=w){x=w-(v+1)}s.curFrame+=x}}};h.Bezier=new function(){this.getPosition=function(q,p){var s=q.length,o=[],r=1-p,m,l;for(m=0;m<s;++m){o[m]=[q[m][0],q[m][1]]}for(l=1;l<s;++l){for(m=0;m<s-l;++m){o[m][0]=r*o[m][0]+p*o[parseInt(m+1,10)][0];o[m][1]=r*o[m][1]+p*o[parseInt(m+1,10)][1]}}return[o[0][0],o[0][1]]}};h.Easing={easeNone:function(m,l,o,n){return o*m/n+l},easeIn:function(m,l,o,n){return o*(m/=n)*m+l},easeOut:function(m,l,o,n){return -o*(m/=n)*(m-2)+l}};(function(){h.Motion=function(q,p,r,s){if(q){h.Motion.superclass.constructor.call(this,q,p,r,s)}};Ext.extend(h.Motion,Ext.lib.AnimBase);var o=h.Motion.superclass,n=h.Motion.prototype,m=/^points$/i;Ext.apply(h.Motion.prototype,{setAttr:function(p,t,s){var r=this,q=o.setAttr;if(m.test(p)){s=s||"px";q.call(r,"left",t[0],s);q.call(r,"top",t[1],s)}else{q.call(r,p,t,s)}},getA
 ttr:function(p){var r=this,q=o.getAttr;return m.test(p)?[q.call(r,"left"),q.call(r,"top")]:q.call(r,p)},doMethod:function(p,s,q){var r=this;return m.test(p)?h.Bezier.getPosition(r.runAttrs[p],r.method(r.curFrame,0,100,r.totalFrames)/100):o.doMethod.call(r,p,s,q)},setRunAttr:function(w){if(m.test(w)){var y=this,r=this.el,B=this.attributes.points,u=B.control||[],z=B.from,A=B.to,x=B.by,C=h.Dom,q,t,s,v,p;if(u.length>0&&!Ext.isArray(u[0])){u=[u]}else{}Ext.fly(r,"_anim").position();C.setXY(r,k(z)?z:C.getXY(r));q=y.getAttr("points");if(k(A)){s=l.call(y,A,q);for(t=0,v=u.length;t<v;++t){u[t]=l.call(y,u[t],q)}}else{if(k(x)){s=[q[0]+x[0],q[1]+x[1]];for(t=0,v=u.length;t<v;++t){u[t]=[q[0]+u[t][0],q[1]+u[t][1]]}}}p=this.runAttrs[w]=[q];if(u.length>0){p=p.concat(u)}p[p.length]=s}else{o.setRunAttr.call(this,w)}}});var l=function(p,r){var q=h.Dom.getXY(this.el);return[p[0]-q[0]+r[0],p[1]-q[1]+r[1]]}})()})();(function(){var d=Math.abs,j=Math.PI,i=Math.asin,h=Math.pow,e=Math.sin,g=Ext.lib;Ext.
 apply(g.Easing,{easeBoth:function(l,k,n,m){return((l/=m/2)<1)?n/2*l*l+k:-n/2*((--l)*(l-2)-1)+k},easeInStrong:function(l,k,n,m){return n*(l/=m)*l*l*l+k},easeOutStrong:function(l,k,n,m){return -n*((l=l/m-1)*l*l*l-1)+k},easeBothStrong:function(l,k,n,m){return((l/=m/2)<1)?n/2*l*l*l*l+k:-n/2*((l-=2)*l*l*l-2)+k},elasticIn:function(m,k,r,q,l,o){if(m==0||(m/=q)==1){return m==0?k:k+r}o=o||(q*0.3);var n;if(l>=d(r)){n=o/(2*j)*i(r/l)}else{l=r;n=o/4}return -(l*h(2,10*(m-=1))*e((m*q-n)*(2*j)/o))+k},elasticOut:function(m,k,r,q,l,o){if(m==0||(m/=q)==1){return m==0?k:k+r}o=o||(q*0.3);var n;if(l>=d(r)){n=o/(2*j)*i(r/l)}else{l=r;n=o/4}return l*h(2,-10*m)*e((m*q-n)*(2*j)/o)+r+k},elasticBoth:function(m,k,r,q,l,o){if(m==0||(m/=q/2)==2){return m==0?k:k+r}o=o||(q*(0.3*1.5));var n;if(l>=d(r)){n=o/(2*j)*i(r/l)}else{l=r;n=o/4}return m<1?-0.5*(l*h(2,10*(m-=1))*e((m*q-n)*(2*j)/o))+k:l*h(2,-10*(m-=1))*e((m*q-n)*(2*j)/o)*0.5+r+k},backIn:function(l,k,o,n,m){m=m||1.70158;return o*(l/=n)*l*((m+1)*l-m)+k},bac
 kOut:function(l,k,o,n,m){if(!m){m=1.70158}return o*((l=l/n-1)*l*((m+1)*l+m)+1)+k},backBoth:function(l,k,o,n,m){m=m||1.70158;return((l/=n/2)<1)?o/2*(l*l*(((m*=(1.525))+1)*l-m))+k:o/2*((l-=2)*l*(((m*=(1.525))+1)*l+m)+2)+k},bounceIn:function(l,k,n,m){return n-g.Easing.bounceOut(m-l,0,n,m)+k},bounceOut:function(l,k,n,m){if((l/=m)<(1/2.75)){return n*(7.5625*l*l)+k}else{if(l<(2/2.75)){return n*(7.5625*(l-=(1.5/2.75))*l+0.75)+k}else{if(l<(2.5/2.75)){return n*(7.5625*(l-=(2.25/2.75))*l+0.9375)+k}}}return n*(7.5625*(l-=(2.625/2.75))*l+0.984375)+k},bounceBoth:function(l,k,n,m){return(l<m/2)?g.Easing.bounceIn(l*2,0,n,m)*0.5+k:g.Easing.bounceOut(l*2-m,0,n,m)*0.5+n*0.5+k}})})();(function(){var i=Ext.lib;i.Anim.color=function(q,o,r,s,n,p){return i.Anim.run(q,o,r,s,n,p,i.ColorAnim)};i.ColorAnim=function(o,n,p,q){i.ColorAnim.superclass.constructor.call(this,o,n,p,q)};Ext.extend(i.ColorAnim,i.AnimBase);var k=i.ColorAnim.superclass,j=/color$/i,g=/^transparent|rgba\(0, 0, 0, 0\)$/,m=/^rgb\(([0
 -9]+)\s*,\s*([0-9]+)\s*,\s*([0-9]+)\)$/i,d=/^#?([0-9A-F]{2})([0-9A-F]{2})([0-9A-F]{2})$/i,e=/^#?([0-9A-F]{1})([0-9A-F]{1})([0-9A-F]{1})$/i,h=function(n){return typeof n!=="undefined"};function l(o){var q=parseInt,p,n=null,r;if(o.length==3){return o}Ext.each([d,m,e],function(t,s){p=(s%2==0)?16:10;r=t.exec(o);if(r&&r.length==4){n=[q(r[1],p),q(r[2],p),q(r[3],p)];return false}});return n}Ext.apply(i.ColorAnim.prototype,{getAttr:function(n){var p=this,o=p.el,q;if(j.test(n)){while(o&&g.test(q=Ext.fly(o).getStyle(n))){o=o.parentNode;q="fff"}}else{q=k.getAttr.call(p,n)}return q},doMethod:function(t,n,p){var u=this,o,r=Math.floor,q,s,w;if(j.test(t)){o=[];for(q=0,s=n.length;q<s;q++){w=n[q];o[q]=k.doMethod.call(u,t,w,p[q])}o="rgb("+r(o[0])+","+r(o[1])+","+r(o[2])+")"}else{o=k.doMethod.call(u,t,n,p)}return o},setRunAttr:function(s){var u=this,v=u.attributes[s],w=v.to,t=v.by,o;k.setRunAttr.call(u,s);o=u.runAttrs[s];if(j.test(s)){var n=l(o.start),p=l(o.end);if(!h(w)&&h(t)){p=l(t);for(var
 q=0,r=n.length;q<r;q++){p[q]=n[q]+p[q]}}o.start=n;o.end=p}}})})();(function(){var d=Ext.lib;d.Anim.scroll=function(k,i,l,m,h,j){return d.Anim.run(k,i,l,m,h,j,d.Scroll)};d.Scroll=function(i,h,j,k){if(i){d.Scroll.superclass.constructor.call(this,i,h,j,k)}};Ext.extend(d.Scroll,d.ColorAnim);var g=d.Scroll.superclass,e="scroll";Ext.apply(d.Scroll.prototype,{doMethod:function(h,n,i){var l,k=this,m=k.curFrame,j=k.totalFrames;if(h==e){l=[k.method(m,n[0],i[0]-n[0],j),k.method(m,n[1],i[1]-n[1],j)]}else{l=g.doMethod.call(k,h,n,i)}return l},getAttr:function(h){var i=this;if(h==e){return[i.el.scrollLeft,i.el.scrollTop]}else{return g.getAttr.call(i,h)}},setAttr:function(h,k,j){var i=this;if(h==e){i.el.scrollLeft=k[0];i.el.scrollTop=k[1]}else{g.setAttr.call(i,h,k,j)}}})})();if(Ext.isIE){function a(){var d=Function.prototype;delete d.createSequence;delete d.defer;delete d.createDelegate;delete d.createCallback;delete d.createInterceptor;window.detachEvent("onunload",a)}window.attachEvent("o
 nunload",a)}})();(function(){var i=Ext.util,l=Ext.toArray,k=Ext.each,a=Ext.isObject,h=true,j=false;i.Observable=function(){var m=this,n=m.events;if(m.listeners){m.on(m.listeners);delete m.listeners}m.events=n||{}};i.Observable.prototype={filterOptRe:/^(?:scope|delay|buffer|single)$/,fireEvent:function(){var m=l(arguments),o=m[0].toLowerCase(),p=this,n=h,s=p.events[o],r,t;if(p.eventsSuspended===h){if(r=p.eventQueue){r.push(m)}}else{if(a(s)&&s.bubble){if(s.fire.apply(s,m.slice(1))===j){return j}t=p.getBubbleTarget&&p.getBubbleTarget();if(t&&t.enableBubble){if(!t.events[o]||!Ext.isObject(t.events[o])||!t.events[o].bubble){t.enableBubble(o)}return t.fireEvent.apply(t,m)}}else{if(a(s)){m.shift();n=s.fire.apply(s,m)}}}return n},addListener:function(p,s,u,n){var r=this,q,v,t,m;if(a(p)){n=p;for(q in n){v=n[q];if(!r.filterOptRe.test(q)){r.addListener(q,v.fn||v,v.scope||n.scope,v.fn?v:n)}}}else{p=p.toLowerCase();m=r.events[p]||h;if(Ext.isBoolean(m)){r.events[p]=m=new i.Event(r,p)}m.ad
 dListener(s,u,a(n)?n:{})}},removeListener:function(m,o,n){var p=this.events[m.toLowerCase()];if(a(p)){p.removeListener(o,n)}},purgeListeners:function(){var o=this.events,m,n;for(n in o){m=o[n];if(a(m)){m.clearListeners()}}},addEvents:function(q){var p=this;p.events=p.events||{};if(Ext.isString(q)){var m=arguments,n=m.length;while(n--){p.events[m[n]]=p.events[m[n]]||h}}else{Ext.applyIf(p.events,q)}},hasListener:function(m){var n=this.events[m];return a(n)&&n.listeners.length>0},suspendEvents:function(m){this.eventsSuspended=h;if(m&&!this.eventQueue){this.eventQueue=[]}},resumeEvents:function(){var m=this,n=m.eventQueue||[];m.eventsSuspended=j;delete m.eventQueue;k(n,function(o){m.fireEvent.apply(m,o)})}};var e=i.Observable.prototype;e.on=e.addListener;e.un=e.removeListener;i.Observable.releaseCapture=function(m){m.fireEvent=e.fireEvent};function g(n,p,m){return function(){if(p.target==arguments[0]){n.apply(m,l(arguments))}}}function c(p,q,m,n){m.task=new i.DelayedTask();retur
 n function(){m.task.delay(q.buffer,p,n,l(arguments))}}function d(o,p,n,m){return function(){p.removeListener(n,m);return o.apply(m,arguments)}}function b(p,q,m,n){return function(){var o=new i.DelayedTask();if(!m.tasks){m.tasks=[]}m.tasks.push(o);o.delay(q.delay||10,p,n,l(arguments))}}i.Event=function(n,m){this.name=m;this.obj=n;this.listeners=[]};i.Event.prototype={addListener:function(p,o,n){var q=this,m;o=o||q.obj;if(!q.isListening(p,o)){m=q.createListener(p,o,n);if(q.firing){q.listeners=q.listeners.slice(0)}q.listeners.push(m)}},createListener:function(q,p,r){r=r||{},p=p||this.obj;var m={fn:q,scope:p,options:r},n=q;if(r.target){n=g(n,r,p)}if(r.delay){n=b(n,r,m,p)}if(r.single){n=d(n,this,q,p)}if(r.buffer){n=c(n,r,m,p)}m.fireFn=n;return m},findListener:function(q,p){var r=this.listeners,n=r.length,m,o;while(n--){m=r[n];if(m){o=m.scope;if(m.fn==q&&(o==p||o==this.obj)){return n}}}return -1},isListening:function(n,m){return this.findListener(n,m)!=-1},removeListener:function(
 r,q){var p,m,n,s=this,o=j;if((p=s.findListener(r,q))!=-1){if(s.firing){s.listeners=s.listeners.slice(0)}m=s.listeners[p];if(m.task){m.task.cancel();delete m.task}n=m.tasks&&m.tasks.length;if(n){while(n--){m.tasks[n].cancel()}delete m.tasks}s.listeners.splice(p,1);o=h}return o},clearListeners:function(){var o=this,m=o.listeners,n=m.length;while(n--){o.removeListener(m[n].fn,m[n].scope)}},fire:function(){var r=this,o=l(arguments),q=r.listeners,m=q.length,p=0,n;if(m>0){r.firing=h;for(;p<m;p++){n=q[p];if(n&&n.fireFn.apply(n.scope||r.obj||window,o)===j){return(r.firing=j)}}}r.firing=j;return h}}})();Ext.DomHelper=function(){var s=null,j=/^(?:br|frame|hr|img|input|link|meta|range|spacer|wbr|area|param|col)$/i,l=/^table|tbody|tr|td$/i,p,m="afterbegin",n="afterend",c="beforebegin",o="beforeend",a="<table>",h="</table>",b=a+"<tbody>",i="</tbody>"+h,k=b+"<tr>",r="</tr>"+i;function g(w,y,x,z,v,t){var u=p.insertHtml(z,Ext.getDom(w),q(y));return x?Ext.get(u,true):u}function q(z){var v=""
 ,u,y,x,t,A;if(Ext.isString(z)){v=z}else{if(Ext.isArray(z)){for(var w=0;w<z.length;w++){if(z[w]){v+=q(z[w])}}}else{v+="<"+(z.tag=z.tag||"div");Ext.iterate(z,function(B,C){if(!/tag|children|cn|html$/i.test(B)){if(Ext.isObject(C)){v+=" "+B+'="';Ext.iterate(C,function(E,D){v+=E+":"+D+";"});v+='"'}else{v+=" "+({cls:"class",htmlFor:"for"}[B]||B)+'="'+C+'"'}}});if(j.test(z.tag)){v+="/>"}else{v+=">";if((A=z.children||z.cn)){v+=q(A)}else{if(z.html){v+=z.html}}v+="</"+z.tag+">"}}}return v}function e(A,x,w,y){s.innerHTML=[x,w,y].join("");var t=-1,v=s,u;while(++t<A){v=v.firstChild}if(u=v.nextSibling){var z=document.createDocumentFragment();while(v){u=v.nextSibling;z.appendChild(v);v=u}v=z}return v}function d(t,u,w,v){var x,y;s=s||document.createElement("div");if(t=="td"&&(u==m||u==o)||!/td|tr|tbody/i.test(t)&&(u==c||u==n)){return}y=u==c?w:u==n?w.nextSibling:u==m?w.firstChild:null;if(u==c||u==n){w=w.parentNode}if(t=="td"||(t=="tr"&&(u==o||u==m))){x=e(4,k,v,r)}else{if((t=="tbody"&&(u==o||
 u==m))||(t=="tr"&&(u==c||u==n))){x=e(3,b,v,i)}else{x=e(2,a,v,h)}}w.insertBefore(x,y);return x}p={markup:function(t){return q(t)},applyStyles:function(w,x){if(x){var u=0,t,v;w=Ext.fly(w);if(Ext.isFunction(x)){x=x.call()}if(Ext.isString(x)){x=x.trim().split(/\s*(?::|;)\s*/);for(t=x.length;u<t;){w.setStyle(x[u++],x[u++])}}else{if(Ext.isObject(x)){w.setStyle(x)}}}},insertHtml:function(y,t,z){var x={},v,B,A,C,w,u;y=y.toLowerCase();x[c]=["BeforeBegin","previousSibling"];x[n]=["AfterEnd","nextSibling"];if(t.insertAdjacentHTML){if(l.test(t.tagName)&&(u=d(t.tagName.toLowerCase(),y,t,z))){return u}x[m]=["AfterBegin","firstChild"];x[o]=["BeforeEnd","lastChild"];if((v=x[y])){t.insertAdjacentHTML(v[0],z);return t[v[1]]}}else{A=t.ownerDocument.createRange();B="setStart"+(/end/i.test(y)?"After":"Before");if(x[y]){A[B](t);C=A.createContextualFragment(z);t.parentNode.insertBefore(C,y==c?t:t.nextSibling);return t[(y==c?"previous":"next")+"Sibling"]}else{w=(y==m?"first":"last")+"Child";if(t.fi
 rstChild){A[B](t[w]);C=A.createContextualFragment(z);if(y==m){t.insertBefore(C,t.firstChild)}else{t.appendChild(C)}}else{t.innerHTML=z}return t[w]}}throw'Illegal insertion point -> "'+y+'"'},insertBefore:function(t,v,u){return g(t,v,u,c)},insertAfter:function(t,v,u){return g(t,v,u,n,"nextSibling")},insertFirst:function(t,v,u){return g(t,v,u,m,"firstChild")},append:function(t,v,u){return g(t,v,u,o,"",true)},overwrite:function(t,v,u){t=Ext.getDom(t);t.innerHTML=q(v);return u?Ext.get(t.firstChild):t.firstChild},createHtml:q};return p}();Ext.Template=function(d){var e=this,b=arguments,c=[];if(Ext.isArray(d)){d=d.join("")}else{if(b.length>1){Ext.each(b,function(a){if(Ext.isObject(a)){Ext.apply(e,a)}else{c.push(a)}});d=c.join("")}}e.html=d;if(e.compiled){e.compile()}};Ext.Template.prototype={re:/\{([\w-]+)\}/g,applyTemplate:function(a){var b=this;return b.compiled?b.compiled(a):b.html.replace(b.re,function(c,d){return a[d]!==undefined?a[d]:""})},set:function(a,c){var b=this;b.html
 =a;b.compiled=null;return c?b.compile():b},compile:function(){var me=this,sep=Ext.isGecko?"+":",";function fn(m,name){name="values['"+name+"']";return"'"+sep+"("+name+" == undefined ? '' : "+name+")"+sep+"'"}eval("this.compiled = function(values){ return "+(Ext.isGecko?"'":"['")+me.html.replace(/\\/g,"\\\\").replace(/(\r\n|\n)/g,"\\n").replace(/'/g,"\\'").replace(this.re,fn)+(Ext.isGecko?"';};":"'].join('');};"));return me},insertFirst:function(b,a,c){return this.doInsert("afterBegin",b,a,c)},insertBefore:function(b,a,c){return this.doInsert("beforeBegin",b,a,c)},insertAfter:function(b,a,c){return this.doInsert("afterEnd",b,a,c)},append:function(b,a,c){return this.doInsert("beforeEnd",b,a,c)},doInsert:function(c,e,b,a){e=Ext.getDom(e);var d=Ext.DomHelper.insertHtml(c,e,this.applyTemplate(b));return a?Ext.get(d,true):d},overwrite:function(b,a,c){b=Ext.getDom(b);b.innerHTML=this.applyTemplate(a);return c?Ext.get(b.firstChild,true):b.firstChild}};Ext.Template.prototype.apply=Ex
 t.Template.prototype.applyTemplate;Ext.Template.from=function(b,a){b=Ext.getDom(b);return new Ext.Template(b.value||b.innerHTML,a||"")};Ext.DomQuery=function(){var cache={},simpleCache={},valueCache={},nonSpace=/\S/,trimRe=/^\s+|\s+$/g,tplRe=/\{(\d+)\}/g,modeRe=/^(\s?[\/>+~]\s?|\s|$)/,tagTokenRe=/^(#)?([\w-\*]+)/,nthRe=/(\d*)n\+?(\d*)/,nthRe2=/\D/,isIE=window.ActiveXObject?true:false,key=30803;eval("var batch = 30803;");function child(p,index){var i=0,n=p.firstChild;while(n){if(n.nodeType==1){if(++i==index){return n}}n=n.nextSibling}return null}function next(n){while((n=n.nextSibling)&&n.nodeType!=1){}return n}function prev(n){while((n=n.previousSibling)&&n.nodeType!=1){}return n}function children(d){var n=d.firstChild,ni=-1,nx;while(n){nx=n.nextSibling;if(n.nodeType==3&&!nonSpace.test(n.nodeValue)){d.removeChild(n)}else{n.nodeIndex=++ni}n=nx}return this}function byClassName(c,a,v){if(!v){return c}var r=[],ri=-1,cn;for(var i=0,ci;ci=c[i];i++){if((" "+ci.className+" ").indexO
 f(v)!=-1){r[++ri]=ci}}return r}function attrValue(n,attr){if(!n.tagName&&typeof n.length!="undefined"){n=n[0]}if(!n){return null}if(attr=="for"){return n.htmlFor}if(attr=="class"||attr=="className"){return n.className}return n.getAttribute(attr)||n[attr]}function getNodes(ns,mode,tagName){var result=[],ri=-1,cs;if(!ns){return result}tagName=tagName||"*";if(typeof ns.getElementsByTagName!="undefined"){ns=[ns]}if(!mode){for(var i=0,ni;ni=ns[i];i++){cs=ni.getElementsByTagName(tagName);for(var j=0,ci;ci=cs[j];j++){result[++ri]=ci}}}else{if(mode=="/"||mode==">"){var utag=tagName.toUpperCase();for(var i=0,ni,cn;ni=ns[i];i++){cn=ni.childNodes;for(var j=0,cj;cj=cn[j];j++){if(cj.nodeName==utag||cj.nodeName==tagName||tagName=="*"){result[++ri]=cj}}}}else{if(mode=="+"){var utag=tagName.toUpperCase();for(var i=0,n;n=ns[i];i++){while((n=n.nextSibling)&&n.nodeType!=1){}if(n&&(n.nodeName==utag||n.nodeName==tagName||tagName=="*")){result[++ri]=n}}}else{if(mode=="~"){var utag=tagName.toUpper
 Case();for(var i=0,n;n=ns[i];i++){while((n=n.nextSibling)){if(n.nodeName==utag||n.nodeName==tagName||tagName=="*"){result[++ri]=n}}}}}}}return result}function concat(a,b){if(b.slice){return a.concat(b)}for(var i=0,l=b.length;i<l;i++){a[a.length]=b[i]}return a}function byTag(cs,tagName){if(cs.tagName||cs==document){cs=[cs]}if(!tagName){return cs}var r=[],ri=-1;tagName=tagName.toLowerCase();for(var i=0,ci;ci=cs[i];i++){if(ci.nodeType==1&&ci.tagName.toLowerCase()==tagName){r[++ri]=ci}}return r}function byId(cs,attr,id){if(cs.tagName||cs==document){cs=[cs]}if(!id){return cs}var r=[],ri=-1;for(var i=0,ci;ci=cs[i];i++){if(ci&&ci.id==id){r[++ri]=ci;return r}}return r}function byAttribute(cs,attr,value,op,custom){var r=[],ri=-1,st=custom=="{",f=Ext.DomQuery.operators[op],a,ih;for(var i=0,ci;ci=cs[i];i++){if(ci.nodeType!=1){continue}ih=ci.innerHTML;if(ih!==null&&ih!==undefined){if(st){a=Ext.DomQuery.getStyle(ci,attr)}else{if(attr=="class"||attr=="className"){a=ci.className}else{if(at
 tr=="for"){a=ci.htmlFor}else{if(attr=="href"){a=ci.getAttribute("href",2)}else{a=ci.getAttribute(attr)}}}}}else{a=ci.getAttribute(attr)}if((f&&f(a,value))||(!f&&a)){r[++ri]=ci}}return r}function byPseudo(cs,name,value){return Ext.DomQuery.pseudos[name](cs,value)}function nodupIEXml(cs){var d=++key,r;cs[0].setAttribute("_nodup",d);r=[cs[0]];for(var i=1,len=cs.length;i<len;i++){var c=cs[i];if(!c.getAttribute("_nodup")!=d){c.setAttribute("_nodup",d);r[r.length]=c}}for(var i=0,len=cs.length;i<len;i++){cs[i].removeAttribute("_nodup")}return r}function nodup(cs){if(!cs){return[]}var len=cs.length,c,i,r=cs,cj,ri=-1;if(!len||typeof cs.nodeType!="undefined"||len==1){return cs}if(isIE&&typeof cs[0].selectSingleNode!="undefined"){return nodupIEXml(cs)}var d=++key;cs[0]._nodup=d;for(i=1;c=cs[i];i++){if(c._nodup!=d){c._nodup=d}else{r=[];for(var j=0;j<i;j++){r[++ri]=cs[j]}for(j=i+1;cj=cs[j];j++){if(cj._nodup!=d){cj._nodup=d;r[++ri]=cj}}return r}}return r}function quickDiffIEXml(c1,c2){var
  d=++key,r=[];for(var i=0,len=c1.length;i<len;i++){c1[i].setAttribute("_qdiff",d)}for(var i=0,len=c2.length;i<len;i++){if(c2[i].getAttribute("_qdiff")!=d){r[r.length]=c2[i]}}for(var i=0,len=c1.length;i<len;i++){c1[i].removeAttribute("_qdiff")}return r}function quickDiff(c1,c2){var len1=c1.length,d=++key,r=[];if(!len1){return c2}if(isIE&&typeof c1[0].selectSingleNode!="undefined"){return quickDiffIEXml(c1,c2)}for(var i=0;i<len1;i++){c1[i]._qdiff=d}for(var i=0,len=c2.length;i<len;i++){if(c2[i]._qdiff!=d){r[r.length]=c2[i]}}return r}function quickId(ns,mode,root,id){if(ns==root){var d=root.ownerDocument||root;return d.getElementById(id)}ns=getNodes(ns,mode,"*");return byId(ns,null,id)}return{getStyle:function(el,name){return Ext.fly(el).getStyle(name)},compile:function(path,type){type=type||"select";var fn=["var f = function(root){\n var mode; ++batch; var n = root || document;\n"],q=path,mode,lq,tk=Ext.DomQuery.matchers,tklen=tk.length,mm,lmode=q.match(modeRe);if(lmode&&lmode[
 1]){fn[fn.length]='mode="'+lmode[1].replace(trimRe,"")+'";';q=q.replace(lmode[1],"")}while(path.substr(0,1)=="/"){path=path.substr(1)}while(q&&lq!=q){lq=q;var tm=q.match(tagTokenRe);if(type=="select"){if(tm){if(tm[1]=="#"){fn[fn.length]='n = quickId(n, mode, root, "'+tm[2]+'");'}else{fn[fn.length]='n = getNodes(n, mode, "'+tm[2]+'");'}q=q.replace(tm[0],"")}else{if(q.substr(0,1)!="@"){fn[fn.length]='n = getNodes(n, mode, "*");'}}}else{if(tm){if(tm[1]=="#"){fn[fn.length]='n = byId(n, null, "'+tm[2]+'");'}else{fn[fn.length]='n = byTag(n, "'+tm[2]+'");'}q=q.replace(tm[0],"")}}while(!(mm=q.match(modeRe))){var matched=false;for(var j=0;j<tklen;j++){var t=tk[j];var m=q.match(t.re);if(m){fn[fn.length]=t.select.replace(tplRe,function(x,i){return m[i]});q=q.replace(m[0],"");matched=true;break}}if(!matched){throw'Error parsing selector, parsing failed at "'+q+'"'}}if(mm[1]){fn[fn.length]='mode="'+mm[1].replace(trimRe,"")+'";';q=q.replace(mm[1],"")}}fn[fn.length]="return nodup(n);\n}";e
 val(fn.join(""));return f},select:function(path,root,type){if(!root||root==document){root=document}if(typeof root=="string"){root=document.getElementById(root)}var paths=path.split(","),results=[];for(var i=0,len=paths.length;i<len;i++){var p=paths[i].replace(trimRe,"");if(!cache[p]){cache[p]=Ext.DomQuery.compile(p);if(!cache[p]){throw p+" is not a valid selector"}}var result=cache[p](root);if(result&&result!=document){results=results.concat(result)}}if(paths.length>1){return nodup(results)}return results},selectNode:function(path,root){return Ext.DomQuery.select(path,root)[0]},selectValue:function(path,root,defaultValue){path=path.replace(trimRe,"");if(!valueCache[path]){valueCache[path]=Ext.DomQuery.compile(path,"select")}var n=valueCache[path](root),v;n=n[0]?n[0]:n;if(typeof n.normalize=="function"){n.normalize()}v=(n&&n.firstChild?n.firstChild.nodeValue:null);return((v===null||v===undefined||v==="")?defaultValue:v)},selectNumber:function(path,root,defaultValue){var v=Ext
 .DomQuery.selectValue(path,root,defaultValue||0);return parseFloat(v)},is:function(el,ss){if(typeof el=="string"){el=document.getElementById(el)}var isArray=Ext.isArray(el),result=Ext.DomQuery.filter(isArray?el:[el],ss);return isArray?(result.length==el.length):(result.length>0)},filter:function(els,ss,nonMatches){ss=ss.replace(trimRe,"");if(!simpleCache[ss]){simpleCache[ss]=Ext.DomQuery.compile(ss,"simple")}var result=simpleCache[ss](els);return nonMatches?quickDiff(result,els):result},matchers:[{re:/^\.([\w-]+)/,select:'n = byClassName(n, null, " {1} ");'},{re:/^\:([\w-]+)(?:\(((?:[^\s>\/]*|.*?))\))?/,select:'n = byPseudo(n, "{1}", "{2}");'},{re:/^(?:([\[\{])(?:@)?([\w-]+)\s?(?:(=|.=)\s?['"]?(.*?)["']?)?[\]\}])/,select:'n = byAttribute(n, "{2}", "{4}", "{3}", "{1}");'},{re:/^#([\w-]+)/,select:'n = byId(n, null, "{1}");'},{re:/^@([\w-]+)/,select:'return {firstChild:{nodeValue:attrValue(n, "{1}")}};'}],operators:{"=":function(a,v){return a==v},"!=":function(a,v){return a!=v}
 ,"^=":function(a,v){return a&&a.substr(0,v.length)==v},"$=":function(a,v){return a&&a.substr(a.length-v.length)==v},"*=":function(a,v){return a&&a.indexOf(v)!==-1},"%=":function(a,v){return(a%v)==0},"|=":function(a,v){return a&&(a==v||a.substr(0,v.length+1)==v+"-")},"~=":function(a,v){return a&&(" "+a+" ").indexOf(" "+v+" ")!=-1}},pseudos:{"first-child":function(c){var r=[],ri=-1,n;for(var i=0,ci;ci=n=c[i];i++){while((n=n.previousSibling)&&n.nodeType!=1){}if(!n){r[++ri]=ci}}return r},"last-child":function(c){var r=[],ri=-1,n;for(var i=0,ci;ci=n=c[i];i++){while((n=n.nextSibling)&&n.nodeType!=1){}if(!n){r[++ri]=ci}}return r},"nth-child":function(c,a){var r=[],ri=-1,m=nthRe.exec(a=="even"&&"2n"||a=="odd"&&"2n+1"||!nthRe2.test(a)&&"n+"+a||a),f=(m[1]||1)-0,l=m[2]-0;for(var i=0,n;n=c[i];i++){var pn=n.parentNode;if(batch!=pn._batch){var j=0;for(var cn=pn.firstChild;cn;cn=cn.nextSibling){if(cn.nodeType==1){cn.nodeIndex=++j}}pn._batch=batch}if(f==1){if(l==0||n.nodeIndex==l){r[++ri]=n
 }}else{if((n.nodeIndex+l)%f==0){r[++ri]=n}}}return r},"only-child":function(c){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if(!prev(ci)&&!next(ci)){r[++ri]=ci}}return r},empty:function(c){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){var cns=ci.childNodes,j=0,cn,empty=true;while(cn=cns[j]){++j;if(cn.nodeType==1||cn.nodeType==3){empty=false;break}}if(empty){r[++ri]=ci}}return r},contains:function(c,v){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if((ci.textContent||ci.innerText||"").indexOf(v)!=-1){r[++ri]=ci}}return r},nodeValue:function(c,v){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if(ci.firstChild&&ci.firstChild.nodeValue==v){r[++ri]=ci}}return r},checked:function(c){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if(ci.checked==true){r[++ri]=ci}}return r},not:function(c,ss){return Ext.DomQuery.filter(c,ss,true)},any:function(c,selectors){var ss=selectors.split("|"),r=[],ri=-1,s;for(var i=0,ci;ci=c[i];i++){for(var j=0;s=ss[j];j++){if(Ext.DomQuery.is(ci,s)){r[++ri]=ci;break}}}return
  r},odd:function(c){return this["nth-child"](c,"odd")},even:function(c){return this["nth-child"](c,"even")},nth:function(c,a){return c[a-1]||[]},first:function(c){return c[0]||[]},last:function(c){return c[c.length-1]||[]},has:function(c,ss){var s=Ext.DomQuery.select,r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if(s(ss,ci).length>0){r[++ri]=ci}}return r},next:function(c,ss){var is=Ext.DomQuery.is,r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){var n=next(ci);if(n&&is(n,ss)){r[++ri]=ci}}return r},prev:function(c,ss){var is=Ext.DomQuery.is,r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){var n=prev(ci);if(n&&is(n,ss)){r[++ri]=ci}}return r}}}}();Ext.query=Ext.DomQuery.select;Ext.EventManager=function(){var u,m,i=false,l=Ext.lib.Event,n=Ext.lib.Dom,b=document,v=window,e="ie-deferred-loader",o="DOMContentLoaded",g=/^(?:scope|delay|buffer|single|stopEvent|preventDefault|stopPropagation|normalized|args|delegate)$/,q=[];function k(y){var B=false,x=0,w=q.length,B=false,z=false,A;if(y){if(y.getElementById||y.
 navigator){for(;x<w;++x){A=q[x];if(A.el===y){B=A.id;break}}if(!B){B=Ext.id(y);q.push({id:B,el:y});z=true}}else{B=Ext.id(y)}if(!Ext.elCache[B]){Ext.Element.addToCache(new Ext.Element(y),B);if(z){Ext.elCache[B].skipGC=true}}}return B}function j(y,A,D,z,x,F){y=Ext.getDom(y);var w=k(y),E=Ext.elCache[w].events,B;B=l.on(y,A,x);E[A]=E[A]||[];E[A].push([D,x,F,B,z]);if(A=="mousewheel"&&y.addEventListener){var C=["DOMMouseScroll",x,false];y.addEventListener.apply(y,C);Ext.EventManager.addListener(v,"unload",function(){y.removeEventListener.apply(y,C)})}if(A=="mousedown"&&y==document){Ext.EventManager.stoppedMouseDownEvent.addListener(x)}}function c(){if(!i){Ext.isReady=i=true;if(m){clearInterval(m)}if(Ext.isGecko||Ext.isOpera){b.removeEventListener(o,c,false)}if(Ext.isIE){var w=b.getElementById(e);if(w){w.onreadystatechange=null;w.parentNode.removeChild(w)}}if(u){u.fire();u.listeners=[]}}}function a(){var w="complete";u=new Ext.util.Event();if(Ext.isGecko||Ext.isOpera){b.addEventListe
 ner(o,c,false)}else{if(Ext.isIE){b.write("<script id="+e+' defer="defer" src="//:"><\/script>');b.getElementById(e).onreadystatechange=function(){if(this.readyState==w){c()}}}else{if(Ext.isWebKit){m=setInterval(function(){if(b.readyState==w){c()}},10)}}}l.on(v,"load",c)}function s(w,x){return function(){var y=Ext.toArray(arguments);if(x.target==Ext.EventObject.setEvent(y[0]).target){w.apply(this,y)}}}function t(x,y,w){return function(z){w.delay(y.buffer,x,null,[new Ext.EventObjectImpl(z)])}}function p(A,z,w,y,x){return function(B){Ext.EventManager.removeListener(z,w,y,x);A(B)}}function d(x,y,w){return function(A){var z=new Ext.util.DelayedTask(x);if(!w.tasks){w.tasks=[]}w.tasks.push(z);z.delay(y.delay||10,x,null,[new Ext.EventObjectImpl(A)])}}function h(B,A,w,D,E){var x=!Ext.isObject(w)?{}:w,y=Ext.getDom(B),z;D=D||x.fn;E=E||x.scope;if(!y){throw'Error listening for "'+A+'". Element "'+B+"\" doesn't exist."}function C(G){if(!Ext){return}G=Ext.EventObject.setEvent(G);var F;if(x
 .delegate){if(!(F=G.getTarget(x.delegate,y))){return}}else{F=G.target}if(x.stopEvent){G.stopEvent()}if(x.preventDefault){G.preventDefault()}if(x.stopPropagation){G.stopPropagation()}if(x.normalized){G=G.browserEvent}D.call(E||y,G,F,x)}if(x.target){C=s(C,x)}if(x.delay){C=d(C,x,D)}if(x.single){C=p(C,y,A,D,E)}if(x.buffer){z=new Ext.util.DelayedTask(C);C=t(C,x,z)}j(y,A,D,z,C,E);return C}var r={addListener:function(y,w,A,z,x){if(Ext.isObject(w)){var D=w,B,C;for(B in D){C=D[B];if(!g.test(B)){if(Ext.isFunction(C)){h(y,B,D,C,D.scope)}else{h(y,B,C)}}}}else{h(y,w,x,A,z)}},removeListener:function(z,D,H,I){z=Ext.getDom(z);var w=k(z),F=z&&(Ext.elCache[w].events)[D]||[],x,C,A,B,y,E,G;for(C=0,E=F.length;C<E;C++){if(Ext.isArray(G=F[C])&&G[0]==H&&(!I||G[2]==I)){if(G[4]){G[4].cancel()}B=H.tasks&&H.tasks.length;if(B){while(B--){H.tasks[B].cancel()}delete H.tasks}y=x=G[1];if(l.extAdapter){y=G[3]}l.un(z,D,y);F.splice(C,1);if(F.length===0){delete Ext.elCache[w].events[D]}for(B in Ext.elCache[w].e
 vents){return false}Ext.elCache[w].events={};return false}}if(D=="mousewheel"&&z.addEventListener&&x){z.removeEventListener("DOMMouseScroll",x,false)}if(D=="mousedown"&&z==b&&x){Ext.EventManager.stoppedMouseDownEvent.removeListener(x)}},removeAll:function(x){x=Ext.getDom(x);var w=k(x),C=Ext.elCache[w]||{},F=C.events||{},B,A,D,y,E,z;for(y in F){if(F.hasOwnProperty(y)){B=F[y];for(A=0,D=B.length;A<D;A++){E=B[A];if(E[4]){E[4].cancel()}if(E[0].tasks&&(z=E[0].tasks.length)){while(z--){E[0].tasks[z].cancel()}delete E.tasks}l.un(x,y,l.extAdapter?E[3]:E[1])}}}if(Ext.elCache[w]){Ext.elCache[w].events={}}},getListeners:function(z,w){z=Ext.getDom(z);var B=k(z),x=Ext.elCache[B]||{},A=x.events||{},y=[];if(A&&A[w]){return A[w]}else{return null}},purgeElement:function(y,w,A){y=Ext.getDom(y);var x=k(y),D=Ext.elCache[x]||{},E=D.events||{},z,C,B;if(A){if(E&&E.hasOwnProperty(A)){C=E[A];for(z=0,B=C.length;z<B;z++){Ext.EventManager.removeListener(y,A,C[z][0])}}}else{Ext.EventManager.removeAll(y)}
 if(w&&y&&y.childNodes){for(z=0,B=y.childNodes.length;z<B;z++){Ext.EventManager.purgeElement(y.childNodes[z],w,A)}}},_unload:function(){var w;for(w in Ext.elCache){Ext.EventManager.removeAll(w)}},onDocumentReady:function(y,x,w){if(i){u.addListener(y,x,w);u.fire();u.listeners=[]}else{if(!u){a()}w=w||{};w.delay=w.delay||1;u.addListener(y,x,w)}}};r.on=r.addListener;r.un=r.removeListener;r.stoppedMouseDownEvent=new Ext.util.Event();return r}();Ext.onReady=Ext.EventManager.onDocumentReady;(function(){var a=function(){var c=document.body||document.getElementsByTagName("body")[0];if(!c){return false}var b=[" ",Ext.isIE?"ext-ie "+(Ext.isIE6?"ext-ie6":(Ext.isIE7?"ext-ie7":"ext-ie8")):Ext.isGecko?"ext-gecko "+(Ext.isGecko2?"ext-gecko2":"ext-gecko3"):Ext.isOpera?"ext-opera":Ext.isWebKit?"ext-webkit":""];if(Ext.isSafari){b.push("ext-safari "+(Ext.isSafari2?"ext-safari2":(Ext.isSafari3?"ext-safari3":"ext-safari4")))}else{if(Ext.isChrome){b.push("ext-chrome")}}if(Ext.isMac){b.push("ext-mac
 ")}if(Ext.isLinux){b.push("ext-linux")}if(Ext.isStrict||Ext.isBorderBox){var d=c.parentNode;if(d){d.className+=Ext.isStrict?" ext-strict":" ext-border-box"}}c.className+=b.join(" ");return true};if(!a()){Ext.onReady(a)}})();Ext.EventObject=function(){var b=Ext.lib.Event,a={3:13,63234:37,63235:39,63232:38,63233:40,63276:33,63277:34,63272:46,63273:36,63275:35},c=Ext.isIE?{1:0,4:1,2:2}:(Ext.isWebKit?{1:0,2:1,3:2}:{0:0,1:1,2:2});Ext.EventObjectImpl=function(d){if(d){this.setEvent(d.browserEvent||d)}};Ext.EventObjectImpl.prototype={setEvent:function(g){var d=this;if(g==d||(g&&g.browserEvent)){return g}d.browserEvent=g;if(g){d.button=g.button?c[g.button]:(g.which?g.which-1:-1);if(g.type=="click"&&d.button==-1){d.button=0}d.type=g.type;d.shiftKey=g.shiftKey;d.ctrlKey=g.ctrlKey||g.metaKey||false;d.altKey=g.altKey;d.keyCode=g.keyCode;d.charCode=g.charCode;d.target=b.getTarget(g);d.xy=b.getXY(g)}else{d.button=-1;d.shiftKey=false;d.ctrlKey=false;d.altKey=false;d.keyCode=0;d.charCode=0;
 d.target=null;d.xy=[0,0]}return d},stopEvent:function(){var d=this;if(d.browserEvent){if(d.browserEvent.type=="mousedown"){Ext.EventManager.stoppedMouseDownEvent.fire(d)}b.stopEvent(d.browserEvent)}},preventDefault:function(){if(this.browserEvent){b.preventDefault(this.browserEvent)}},stopPropagation:function(){var d=this;if(d.browserEvent){if(d.browserEvent.type=="mousedown"){Ext.EventManager.stoppedMouseDownEvent.fire(d)}b.stopPropagation(d.browserEvent)}},getCharCode:function(){return this.charCode||this.keyCode},getKey:function(){return this.normalizeKey(this.keyCode||this.charCode)},normalizeKey:function(d){return Ext.isSafari?(a[d]||d):d},getPageX:function(){return this.xy[0]},getPageY:function(){return this.xy[1]},getXY:function(){return this.xy},getTarget:function(e,g,d){return e?Ext.fly(this.target).findParent(e,g,d):(d?Ext.get(this.target):this.target)},getRelatedTarget:function(){return this.browserEvent?b.getRelatedTarget(this.browserEvent):null},getWheelDelta:fu
 nction(){var d=this.browserEvent;var g=0;if(d.wheelDelta){g=d.wheelDelta/120}else{if(d.detail){g=-d.detail/3}}return g},within:function(g,h,d){if(g){var e=this[h?"getRelatedTarget":"getTarget"]();return e&&((d?(e==Ext.getDom(g)):false)||Ext.fly(g).contains(e))}return false}};return new Ext.EventObjectImpl()}();(function(){var j=document;Ext.Element=function(o,p){var q=typeof o=="string"?j.getElementById(o):o,r;if(!q){return null}r=q.id;if(!p&&r&&Ext.elCache[r]){return Ext.elCache[r].el}this.dom=q;this.id=r||Ext.id(q)};var a=Ext.lib.Dom,g=Ext.DomHelper,m=Ext.lib.Event,e=Ext.lib.Anim,h=Ext.Element,b=Ext.elCache;h.prototype={set:function(t,q){var r=this.dom,p,s,q=(q!==false)&&!!r.setAttribute;for(p in t){if(t.hasOwnProperty(p)){s=t[p];if(p=="style"){g.applyStyles(r,s)}else{if(p=="cls"){r.className=s}else{if(q){r.setAttribute(p,s)}else{r[p]=s}}}}}return this},defaultUnit:"px",is:function(o){return Ext.DomQuery.is(this.dom,o)},focus:function(r,q){var o=this,q=q||o.dom;try{if(Numb
 er(r)){o.focus.defer(r,null,[null,q])}else{q.focus()}}catch(p){}return o},blur:function(){try{this.dom.blur()}catch(o){}return this},getValue:function(o){var p=this.dom.value;return o?parseInt(p,10):p},addListener:function(o,r,q,p){Ext.EventManager.on(this.dom,o,r,q||this,p);return this},removeListener:function(o,q,p){Ext.EventManager.removeListener(this.dom,o,q,p||this);return this},removeAllListeners:function(){Ext.EventManager.removeAll(this.dom);return this},purgeAllListeners:function(){Ext.EventManager.purgeElement(this,true);return this},addUnits:function(o){if(o===""||o=="auto"||o===undefined){o=o||""}else{if(!isNaN(o)||!k.test(o)){o=o+(this.defaultUnit||"px")}}return o},load:function(p,q,o){Ext.Ajax.request(Ext.apply({params:q,url:p.url||p,callback:o,el:this.dom,indicatorText:p.indicatorText||""},Ext.isObject(p)?p:{}));return this},isBorderBox:function(){return i[(this.dom.tagName||"").toLowerCase()]||Ext.isBorderBox},remove:function(){var o=this,p=o.dom;if(p){delete
  o.dom;Ext.removeNode(p)}},hover:function(p,o,r,q){var s=this;s.on("mouseenter",p,r||s.dom,q);s.on("mouseleave",o,r||s.dom,q);return s},contains:function(o){return !o?false:Ext.lib.Dom.isAncestor(this.dom,o.dom?o.dom:o)},getAttributeNS:function(p,o){return this.getAttribute(o,p)},getAttribute:Ext.isIE?function(o,q){var r=this.dom,p=typeof r[q+":"+o];if(["undefined","unknown"].indexOf(p)==-1){return r[q+":"+o]}return r[o]}:function(o,p){var q=this.dom;return q.getAttributeNS(p,o)||q.getAttribute(p+":"+o)||q.getAttribute(o)||q[o]},update:function(o){if(this.dom){this.dom.innerHTML=o}return this}};var n=h.prototype;h.addMethods=function(p){Ext.apply(n,p)};n.on=n.addListener;n.un=n.removeListener;n.autoBoxAdjust=true;var k=/\d+(px|em|%|en|ex|pt|in|cm|mm|pc)$/i,d;h.get=function(p){var o,s,r;if(!p){return null}if(typeof p=="string"){if(!(s=j.getElementById(p))){return null}if(b[p]&&b[p].el){o=b[p].el;o.dom=s}else{o=h.addToCache(new h(s))}return o}else{if(p.tagName){if(!(r=p.id)){r
 =Ext.id(p)}if(b[r]&&b[r].el){o=b[r].el;o.dom=p}else{o=h.addToCache(new h(p))}return o}else{if(p instanceof h){if(p!=d){p.dom=j.getElementById(p.id)||p.dom}return p}else{if(p.isComposite){return p}else{if(Ext.isArray(p)){return h.select(p)}else{if(p==j){if(!d){var q=function(){};q.prototype=h.prototype;d=new q();d.dom=j}return d}}}}}}return null};h.addToCache=function(o,p){p=p||o.id;b[p]={el:o,data:{},events:{}};return o};h.data=function(p,o,q){p=h.get(p);if(!p){return null}var r=b[p.id].data;if(arguments.length==2){return r[o]}else{return(r[o]=q)}};function l(){if(!Ext.enableGarbageCollector){clearInterval(h.collectorThreadId)}else{var p,r,u,s;for(p in b){s=b[p];if(s.skipGC){continue}r=s.el;u=r.dom;if(!u||!u.parentNode||(!u.offsetParent&&!j.getElementById(p))){if(Ext.enableListenerCollection){Ext.EventManager.removeAll(u)}delete b[p]}}if(Ext.isIE){var q={};for(p in b){q[p]=b[p]}b=Ext.elCache=q}}}h.collectorThreadId=setInterval(l,30000);var c=function(){};c.prototype=h.protot
 ype;h.Flyweight=function(o){this.dom=o};h.Flyweight.prototype=new c();h.Flyweight.prototype.isFlyweight=true;h._flyweights={};h.fly=function(q,o){var p=null;o=o||"_global";if(q=Ext.getDom(q)){(h._flyweights[o]=h._flyweights[o]||new h.Flyweight()).dom=q;p=h._flyweights[o]}return p};Ext.get=h.get;Ext.fly=h.fly;var i=Ext.isStrict?{select:1}:{input:1,select:1,textarea:1};if(Ext.isIE||Ext.isGecko){i.button=1}Ext.EventManager.on(window,"unload",function(){delete b;delete h._flyweights})})();Ext.Element.addMethods(function(){var d="parentNode",b="nextSibling",c="previousSibling",e=Ext.DomQuery,a=Ext.get;return{findParent:function(m,l,h){var j=this.dom,g=document.body,k=0,i;if(Ext.isGecko&&Object.prototype.toString.call(j)=="[object XULElement]"){return null}l=l||50;if(isNaN(l)){i=Ext.getDom(l);l=Number.MAX_VALUE}while(j&&j.nodeType==1&&k<l&&j!=g&&j!=i){if(e.is(j,m)){return h?a(j):j}k++;j=j.parentNode}return null},findParentNode:function(j,i,g){var h=Ext.fly(this.dom.parentNode,"_in
 ternal");return h?h.findParent(j,i,g):null},up:function(h,g){return this.findParentNode(h,g,true)},select:function(g){return Ext.Element.select(g,this.dom)},query:function(g){return e.select(g,this.dom)},child:function(g,h){var i=e.selectNode(g,this.dom);return h?i:a(i)},down:function(g,h){var i=e.selectNode(" > "+g,this.dom);return h?i:a(i)},parent:function(g,h){return this.matchNode(d,d,g,h)},next:function(g,h){return this.matchNode(b,b,g,h)},prev:function(g,h){return this.matchNode(c,c,g,h)},first:function(g,h){return this.matchNode(b,"firstChild",g,h)},last:function(g,h){return this.matchNode(c,"lastChild",g,h)},matchNode:function(h,k,g,i){var j=this.dom[k];while(j){if(j.nodeType==1&&(!g||e.is(j,g))){return !i?a(j):j}j=j[h]}return null}}}());Ext.Element.addMethods(function(){var c=Ext.getDom,a=Ext.get,b=Ext.DomHelper;return{appendChild:function(d){return a(d).appendTo(this)},appendTo:function(d){c(d).appendChild(this.dom);return this},insertBefore:function(d){(d=c(d)).pa
 rentNode.insertBefore(this.dom,d);return this},insertAfter:function(d){(d=c(d)).parentNode.insertBefore(this.dom,d.nextSibling);return this},insertFirst:function(e,d){e=e||{};if(e.nodeType||e.dom||typeof e=="string"){e=c(e);this.dom.insertBefore(e,this.dom.firstChild);return !d?a(e):e}else{return this.createChild(e,this.dom.firstChild,d)}},replace:function(d){d=a(d);this.insertBefore(d);d.remove();return this},replaceWith:function(d){var e=this;if(d.nodeType||d.dom||typeof d=="string"){d=c(d);e.dom.parentNode.insertBefore(d,e.dom)}else{d=b.insertBefore(e.dom,d)}delete Ext.elCache[e.id];Ext.removeNode(e.dom);e.id=Ext.id(e.dom=d);Ext.Element.addToCache(e.isFlyweight?new Ext.Element(e.dom):e);return e},createChild:function(e,d,g){e=e||{tag:"div"};return d?b.insertBefore(d,e,g!==true):b[!this.dom.firstChild?"overwrite":"append"](this.dom,e,g!==true)},wrap:function(d,e){var g=b.insertBefore(this.dom,d||{tag:"div"},!e);g.dom?g.dom.appendChild(this.dom):g.appendChild(this.dom);retu
 rn g},insertHtml:function(e,g,d){var h=b.insertHtml(e,this.dom,g);return d?Ext.get(h):h}}}());Ext.Element.addMethods(function(){var h={},x=/(-[a-z])/gi,b={},s=document.defaultView,u=Ext.isIE?"styleFloat":"cssFloat",C=/alpha\(opacity=(.*)\)/i,l=/^\s+|\s+$/g,A=Ext.Element,d="padding",c="margin",y="border",t="-left",q="-right",w="-top",o="-bottom",j="-width",r=Math,z="hidden",e="isClipped",k="overflow",n="overflow-x",m="overflow-y",B="originalClip",i={l:y+t+j,r:y+q+j,t:y+w+j,b:y+o+j},g={l:d+t,r:d+q,t:d+w,b:d+o},a={l:c+t,r:c+q,t:c+w,b:c+o},D=Ext.Element.data;function p(E,F){return F.charAt(1).toUpperCase()}function v(E){return h[E]||(h[E]=E=="float"?u:E.replace(x,p))}return{adjustWidth:function(E){var F=this;var G=Ext.isNumber(E);if(G&&F.autoBoxAdjust&&!F.isBorderBox()){E-=(F.getBorderWidth("lr")+F.getPadding("lr"))}return(G&&E<0)?0:E},adjustHeight:function(E){var F=this;var G=Ext.isNumber(E);if(G&&F.autoBoxAdjust&&!F.isBorderBox()){E-=(F.getBorderWidth("tb")+F.getPadding("tb"))
 }return(G&&E<0)?0:E},addClass:function(H){var I=this,G,E,F;H=Ext.isArray(H)?H:[H];for(G=0,E=H.length;G<E;G++){F=H[G];if(F){I.dom.className+=(!I.hasClass(F)&&F?" "+F:"")}}return I},radioClass:function(H){var I=this.dom.parentNode.childNodes,F;H=Ext.isArray(H)?H:[H];for(var G=0,E=I.length;G<E;G++){F=I[G];if(F&&F.nodeType==1){Ext.fly(F,"_internal").removeClass(H)}}return this.addClass(H)},removeClass:function(H){var I=this,F;H=Ext.isArray(H)?H:[H];if(I.dom&&I.dom.className){for(var G=0,E=H.length;G<E;G++){F=H[G];if(F){I.dom.className=I.dom.className.replace(b[F]=b[F]||new RegExp("(?:^|\\s+)"+F+"(?:\\s+|$)","g")," ")}}}return I},toggleClass:function(E){return this.hasClass(E)?this.removeClass(E):this.addClass(E)},hasClass:function(E){return E&&(" "+this.dom.className+" ").indexOf(" "+E+" ")!=-1},replaceClass:function(F,E){return this.removeClass(F).addClass(E)},isStyle:function(E,F){return this.getStyle(E)==F},getStyle:function(){return s&&s.getComputedStyle?function(K){var H=th
 is.dom,E,G,F,I,J=Ext.isWebKit,I;if(H==document){return null}K=v(K);if(J&&/marginRight/.test(K)){I=this.getStyle("display");H.style.display="inline-block"}F=(E=H.style[K])?E:(G=s.getComputedStyle(H,""))?G[K]:null;if(J){if(F=="rgba(0, 0, 0, 0)"){F="transparent"}else{if(I){H.style.display=I}}}return F}:function(I){var G=this.dom,E,F;if(G==document){return null}if(I=="opacity"){if(G.style.filter.match){if(E=G.style.filter.match(C)){var H=parseFloat(E[1]);if(!isNaN(H)){return H?H/100:0}}}return 1}I=v(I);return G.style[I]||((F=G.currentStyle)?F[I]:null)}}(),getColor:function(E,F,J){var H=this.getStyle(E),G=Ext.isDefined(J)?J:"#",I;if(!H||/transparent|inherit/.test(H)){return F}if(/^r/.test(H)){Ext.each(H.slice(4,H.length-1).split(","),function(K){I=parseInt(K,10);G+=(I<16?"0":"")+I.toString(16)})}else{H=H.replace("#","");G+=H.length==3?H.replace(/^(\w)(\w)(\w)$/,"$1$1$2$2$3$3"):H}return(G.length>5?G.toLowerCase():F)},setStyle:function(I,H){var F,G,E;if(!Ext.isObject(I)){F={};F[I]=
 H;I=F}for(G in I){H=I[G];G=="opacity"?this.setOpacity(H):this.dom.style[v(G)]=H}return this},setOpacity:function(F,E){var I=this,G=I.dom.style;if(!E||!I.anim){if(Ext.isIE){var H=F<1?"alpha(opacity="+F*100+")":"",J=G.filter.replace(C,"").replace(l,"");G.zoom=1;G.filter=J+(J.length>0?" ":"")+H}else{G.opacity=F}}else{I.anim({opacity:{to:F}},I.preanim(arguments,1),null,0.35,"easeIn")}return I},clearOpacity:function(){var E=this.dom.style;if(Ext.isIE){if(!Ext.isEmpty(E.filter)){E.filter=E.filter.replace(C,"").replace(l,"")}}else{E.opacity=E["-moz-opacity"]=E["-khtml-opacity"]=""}return this},getHeight:function(G){var F=this,I=F.dom,H=Ext.isIE&&F.isStyle("display","none"),E=r.max(I.offsetHeight,H?0:I.clientHeight)||0;E=!G?E:E-F.getBorderWidth("tb")-F.getPadding("tb");return E<0?0:E},getWidth:function(F){var G=this,I=G.dom,H=Ext.isIE&&G.isStyle("display","none"),E=r.max(I.offsetWidth,H?0:I.clientWidth)||0;E=!F?E:E-G.getBorderWidth("lr")-G.getPadding("lr");return E<0?0:E},setWidth:f
 unction(F,E){var G=this;F=G.adjustWidth(F);!E||!G.anim?G.dom.style.width=G.addUnits(F):G.anim({width:{to:F}},G.preanim(arguments,1));return G},setHeight:function(E,F){var G=this;E=G.adjustHeight(E);!F||!G.anim?G.dom.style.height=G.addUnits(E):G.anim({height:{to:E}},G.preanim(arguments,1));return G},getBorderWidth:function(E){return this.addStyles(E,i)},getPadding:function(E){return this.addStyles(E,g)},clip:function(){var E=this,F=E.dom;if(!D(F,e)){D(F,e,true);D(F,B,{o:E.getStyle(k),x:E.getStyle(n),y:E.getStyle(m)});E.setStyle(k,z);E.setStyle(n,z);E.setStyle(m,z)}return E},unclip:function(){var E=this,G=E.dom;if(D(G,e)){D(G,e,false);var F=D(G,B);if(F.o){E.setStyle(k,F.o)}if(F.x){E.setStyle(n,F.x)}if(F.y){E.setStyle(m,F.y)}}return E},addStyles:function(J,I){var K=0,F=J.match(/\w/g),H;for(var G=0,E=F.length;G<E;G++){H=F[G]&&parseInt(this.getStyle(I[F[G]]),10);if(H){K+=r.abs(H)}}return K},margins:a}}());(function(){var a=Ext.lib.Dom,b="left",g="right",d="top",i="bottom",h="posi
 tion",c="static",e="relative",j="auto",k="z-index";Ext.Element.addMethods({getX:function(){return a.getX(this.dom)},getY:function(){return a.getY(this.dom)},getXY:function(){return a.getXY(this.dom)},getOffsetsTo:function(l){var n=this.getXY(),m=Ext.fly(l,"_internal").getXY();return[n[0]-m[0],n[1]-m[1]]},setX:function(l,m){return this.setXY([l,this.getY()],this.animTest(arguments,m,1))},setY:function(m,l){return this.setXY([this.getX(),m],this.animTest(arguments,l,1))},setLeft:function(l){this.setStyle(b,this.addUnits(l));return this},setTop:function(l){this.setStyle(d,this.addUnits(l));return this},setRight:function(l){this.setStyle(g,this.addUnits(l));return this},setBottom:function(l){this.setStyle(i,this.addUnits(l));return this},setXY:function(n,l){var m=this;if(!l||!m.anim){a.setXY(m.dom,n)}else{m.anim({points:{to:n}},m.preanim(arguments,1),"motion")}return m},setLocation:function(l,n,m){return this.setXY([l,n],this.animTest(arguments,m,2))},moveTo:function(l,n,m){retu
 rn this.setXY([l,n],this.animTest(arguments,m,2))},getLeft:function(l){return !l?this.getX():parseInt(this.getStyle(b),10)||0},getRight:function(l){var m=this;return !l?m.getX()+m.getWidth():(m.getLeft(true)+m.getWidth())||0},getTop:function(l){return !l?this.getY():parseInt(this.getStyle(d),10)||0},getBottom:function(l){var m=this;return !l?m.getY()+m.getHeight():(m.getTop(true)+m.getHeight())||0},position:function(p,o,l,n){var m=this;if(!p&&m.isStyle(h,c)){m.setStyle(h,e)}else{if(p){m.setStyle(h,p)}}if(o){m.setStyle(k,o)}if(l||n){m.setXY([l||false,n||false])}},clearPositioning:function(l){l=l||"";this.setStyle({left:l,right:l,top:l,bottom:l,"z-index":"",position:c});return this},getPositioning:function(){var m=this.getStyle(b);var n=this.getStyle(d);return{position:this.getStyle(h),left:m,right:m?"":this.getStyle(g),top:n,bottom:n?"":this.getStyle(i),"z-index":this.getStyle(k)}},setPositioning:function(l){var n=this,m=n.dom.style;n.setStyle(l);if(l.right==j){m.right=""}if(
 l.bottom==j){m.bottom=""}return n},translatePoints:function(m,u){u=isNaN(m[1])?u:m[1];m=isNaN(m[0])?m:m[0];var q=this,r=q.isStyle(h,e),s=q.getXY(),n=parseInt(q.getStyle(b),10),p=parseInt(q.getStyle(d),10);n=!isNaN(n)?n:(r?0:q.dom.offsetLeft);p=!isNaN(p)?p:(r?0:q.dom.offsetTop);return{left:(m-s[0]+n),top:(u-s[1]+p)}},animTest:function(m,l,n){return !!l&&this.preanim?this.preanim(m,n):false}})})();Ext.Element.addMethods({isScrollable:function(){var a=this.dom;return a.scrollHeight>a.clientHeight||a.scrollWidth>a.clientWidth},scrollTo:function(a,b){this.dom["scroll"+(/top/i.test(a)?"Top":"Left")]=b;return this},getScroll:function(){var i=this.dom,h=document,a=h.body,c=h.documentElement,b,g,e;if(i==h||i==a){if(Ext.isIE&&Ext.isStrict){b=c.scrollLeft;g=c.scrollTop}else{b=window.pageXOffset;g=window.pageYOffset}e={left:b||(a?a.scrollLeft:0),top:g||(a?a.scrollTop:0)}}else{e={left:i.scrollLeft,top:i.scrollTop}}return e}});Ext.Element.VISIBILITY=1;Ext.Element.DISPLAY=2;Ext.Element.add
 Methods(function(){var h="visibility",d="display",b="hidden",j="none",a="originalDisplay",c="visibilityMode",e=Ext.Element.DISPLAY,g=Ext.Element.data,i=function(m){var l=g(m,a);if(l===undefined){g(m,a,l="")}return l},k=function(n){var l=g(n,c);if(l===undefined){g(n,c,l=1)}return l};return{originalDisplay:"",visibilityMode:1,setVisibilityMode:function(l){g(this.dom,c,l);return this},animate:function(m,o,n,p,l){this.anim(m,{duration:o,callback:n,easing:p},l);return this},anim:function(o,p,m,r,n,l){m=m||"run";p=p||{};var q=this,s=Ext.lib.Anim[m](q.dom,o,(p.duration||r)||0.35,(p.easing||n)||"easeOut",function(){if(l){l.call(q)}if(p.callback){p.callback.call(p.scope||q,q,p)}},q);p.anim=s;return s},preanim:function(l,m){return !l[m]?false:(Ext.isObject(l[m])?l[m]:{duration:l[m+1],callback:l[m+2],easing:l[m+3]})},isVisible:function(){return !this.isStyle(h,b)&&!this.isStyle(d,j)},setVisible:function(p,m){var n=this,o=n.dom,l=k(this.dom)==e;if(!m||!n.anim){if(l){n.setDisplayed(p)}el
 se{n.fixDisplay();o.style.visibility=p?"visible":b}}else{if(p){n.setOpacity(0.01);n.setVisible(true)}n.anim({opacity:{to:(p?1:0)}},n.preanim(arguments,1),null,0.35,"easeIn",function(){if(!p){o.style[l?d:h]=(l)?j:b;Ext.fly(o).setOpacity(1)}})}return n},toggle:function(l){var m=this;m.setVisible(!m.isVisible(),m.preanim(arguments,0));return m},setDisplayed:function(l){if(typeof l=="boolean"){l=l?i(this.dom):j}this.setStyle(d,l);return this},fixDisplay:function(){var l=this;if(l.isStyle(d,j)){l.setStyle(h,b);l.setStyle(d,i(this.dom));if(l.isStyle(d,j)){l.setStyle(d,"block")}}},hide:function(l){this.setVisible(false,this.preanim(arguments,0));return this},show:function(l){this.setVisible(true,this.preanim(arguments,0));return this}}}());(function(){var y=null,A=undefined,k=true,t=false,j="setX",h="setY",a="setXY",n="left",l="bottom",s="top",m="right",q="height",g="width",i="points",w="hidden",z="absolute",u="visible",e="motion",o="position",r="easeOut",d=new Ext.Element.Flyweigh
 t(),v={},x=function(B){return B||{}},p=function(B){d.dom=B;d.id=Ext.id(B);return d},c=function(B){if(!v[B]){v[B]=[]}return v[B]},b=function(C,B){v[C]=B};Ext.enableFx=k;Ext.Fx={switchStatements:function(C,D,B){return D.apply(this,B[C])},slideIn:function(H,E){E=x(E);var J=this,G=J.dom,M=G.style,O,B,L,D,C,M,I,N,K,F;H=H||"t";J.queueFx(E,function(){O=p(G).getXY();p(G).fixDisplay();B=p(G).getFxRestore();L={x:O[0],y:O[1],0:O[0],1:O[1],width:G.offsetWidth,height:G.offsetHeight};L.right=L.x+L.width;L.bottom=L.y+L.height;p(G).setWidth(L.width).setHeight(L.height);D=p(G).fxWrap(B.pos,E,w);M.visibility=u;M.position=z;function P(){p(G).fxUnwrap(D,B.pos,E);M.width=B.width;M.height=B.height;p(G).afterFx(E)}N={to:[L.x,L.y]};K={to:L.width};F={to:L.height};function Q(U,R,V,S,X,Z,ac,ab,aa,W,T){var Y={};p(U).setWidth(V).setHeight(S);if(p(U)[X]){p(U)[X](Z)}R[ac]=R[ab]="0";if(aa){Y.width=aa}if(W){Y.height=W}if(T){Y.points=T}return Y}I=p(G).switchStatements(H.toLowerCase(),Q,{t:[D,M,L.width,0,y,y,
 n,l,y,F,y],l:[D,M,0,L.height,y,y,m,s,K,y,y],r:[D,M,L.width,L.height,j,L.right,n,s,y,y,N],b:[D,M,L.width,L.height,h,L.bottom,n,s,y,F,N],tl:[D,M,0,0,y,y,m,l,K,F,N],bl:[D,M,0,0,h,L.y+L.height,m,s,K,F,N],br:[D,M,0,0,a,[L.right,L.bottom],n,s,K,F,N],tr:[D,M,0,0,j,L.x+L.width,n,l,K,F,N]});M.visibility=u;p(D).show();arguments.callee.anim=p(D).fxanim(I,E,e,0.5,r,P)});return J},slideOut:function(F,D){D=x(D);var H=this,E=H.dom,K=E.style,L=H.getXY(),C,B,I,J,G={to:0};F=F||"t";H.queueFx(D,function(){B=p(E).getFxRestore();I={x:L[0],y:L[1],0:L[0],1:L[1],width:E.offsetWidth,height:E.offsetHeight};I.right=I.x+I.width;I.bottom=I.y+I.height;p(E).setWidth(I.width).setHeight(I.height);C=p(E).fxWrap(B.pos,D,u);K.visibility=u;K.position=z;p(C).setWidth(I.width).setHeight(I.height);function M(){D.useDisplay?p(E).setDisplayed(t):p(E).hide();p(E).fxUnwrap(C,B.pos,D);K.width=B.width;K.height=B.height;p(E).afterFx(D)}function N(O,W,U,X,S,V,R,T,Q){var P={};O[W]=O[U]="0";P[X]=S;if(V){P[V]=R}if(T){P[T]=Q}r
 eturn P}J=p(E).switchStatements(F.toLowerCase(),N,{t:[K,n,l,q,G],l:[K,m,s,g,G],r:[K,n,s,g,G,i,{to:[I.right,I.y]}],b:[K,n,s,q,G,i,{to:[I.x,I.bottom]}],tl:[K,m,l,g,G,q,G],bl:[K,m,s,g,G,q,G,i,{to:[I.x,I.bottom]}],br:[K,n,s,g,G,q,G,i,{to:[I.x+I.width,I.bottom]}],tr:[K,n,l,g,G,q,G,i,{to:[I.right,I.y]}]});arguments.callee.anim=p(C).fxanim(J,D,e,0.5,r,M)});return H},puff:function(H){H=x(H);var F=this,G=F.dom,C=G.style,D,B,E;F.queueFx(H,function(){D=p(G).getWidth();B=p(G).getHeight();p(G).clearOpacity();p(G).show();E=p(G).getFxRestore();function I(){H.useDisplay?p(G).setDisplayed(t):p(G).hide();p(G).clearOpacity();p(G).setPositioning(E.pos);C.width=E.width;C.height=E.height;C.fontSize="";p(G).afterFx(H)}arguments.callee.anim=p(G).fxanim({width:{to:p(G).adjustWidth(D*2)},height:{to:p(G).adjustHeight(B*2)},points:{by:[-D*0.5,-B*0.5]},opacity:{to:0},fontSize:{to:200,unit:"%"}},H,e,0.5,r,I)});return F},switchOff:function(F){F=x(F);var D=this,E=D.dom,B=E.style,C;D.queueFx(F,function(){p(
 E).clearOpacity();p(E).clip();C=p(E).getFxRestore();function G(){F.useDisplay?p(E).setDisplayed(t):p(E).hide();p(E).clearOpacity();p(E).setPositioning(C.pos);B.width=C.width;B.height=C.height;p(E).afterFx(F)}p(E).fxanim({opacity:{to:0.3}},y,y,0.1,y,function(){p(E).clearOpacity();(function(){p(E).fxanim({height:{to:1},points:{by:[0,p(E).getHeight()*0.5]}},F,e,0.3,"easeIn",G)}).defer(100)})});return D},highlight:function(D,H){H=x(H);var F=this,G=F.dom,B=H.attr||"backgroundColor",C={},E;F.queueFx(H,function(){p(G).clearOpacity();p(G).show();function I(){G.style[B]=E;p(G).afterFx(H)}E=G.style[B];C[B]={from:D||"ffff9c",to:H.endColor||p(G).getColor(B)||"ffffff"};arguments.callee.anim=p(G).fxanim(C,H,"color",1,"easeIn",I)});return F},frame:function(B,E,H){H=x(H);var D=this,G=D.dom,C,F;D.queueFx(H,function(){B=B||"#C3DAF9";if(B.length==6){B="#"+B}E=E||1;p(G).show();var L=p(G).getXY(),J={x:L[0],y:L[1],0:L[0],1:L[1],width:G.offsetWidth,height:G.offsetHeight},I=function(){C=p(document.
 body||document.documentElement).createChild({style:{position:z,"z-index":35000,border:"0px solid "+B}});return C.queueFx({},K)};arguments.callee.anim={isAnimated:true,stop:function(){E=0;C.stopFx()}};function K(){var M=Ext.isBorderBox?2:1;F=C.anim({top:{from:J.y,to:J.y-20},left:{from:J.x,to:J.x-20},borderWidth:{from:0,to:10},opacity:{from:1,to:0},height:{from:J.height,to:J.height+20*M},width:{from:J.width,to:J.width+20*M}},{duration:H.duration||1,callback:function(){C.remove();--E>0?I():p(G).afterFx(H)}});arguments.callee.anim={isAnimated:true,stop:function(){F.stop()}}}I()});return D},pause:function(D){var C=this.dom,B;this.queueFx({},function(){B=setTimeout(function(){p(C).afterFx({})},D*1000);arguments.callee.anim={isAnimated:true,stop:function(){clearTimeout(B);p(C).afterFx({})}}});return this},fadeIn:function(D){D=x(D);var B=this,C=B.dom,E=D.endOpacity||1;B.queueFx(D,function(){p(C).setOpacity(0);p(C).fixDisplay();C.style.visibility=u;arguments.callee.anim=p(C).fxanim({
 opacity:{to:E}},D,y,0.5,r,function(){if(E==1){p(C).clearOpacity()}p(C).afterFx(D)})});return B},fadeOut:function(E){E=x(E);var C=this,D=C.dom,B=D.style,F=E.endOpacity||0;C.queueFx(E,function(){arguments.callee.anim=p(D).fxanim({opacity:{to:F}},E,y,0.5,r,function(){if(F==0){Ext.Element.data(D,"visibilityMode")==Ext.Element.DISPLAY||E.useDisplay?B.display="none":B.visibility=w;p(D).clearOpacity()}p(D).afterFx(E)})});return C},scale:function(B,C,D){this.shift(Ext.apply({},D,{width:B,height:C}));return this},shift:function(D){D=x(D);var C=this.dom,B={};this.queueFx(D,function(){for(var E in D){if(D[E]!=A){B[E]={to:D[E]}}}B.width?B.width.to=p(C).adjustWidth(D.width):B;B.height?B.height.to=p(C).adjustWidth(D.height):B;if(B.x||B.y||B.xy){B.points=B.xy||{to:[B.x?B.x.to:p(C).getX(),B.y?B.y.to:p(C).getY()]}}arguments.callee.anim=p(C).fxanim(B,D,e,0.35,r,function(){p(C).afterFx(D)})});return this},ghost:function(E,C){C=x(C);var G=this,D=G.dom,J=D.style,H={opacity:{to:0},points:{}},K=H.
 points,B,I,F;E=E||"b";G.queueFx(C,function(){B=p(D).getFxRestore();I=p(D).getWidth();F=p(D).getHeight();function L(){C.useDisplay?p(D).setDisplayed(t):p(D).hide();p(D).clearOpacity();p(D).setPositioning(B.pos);J.width=B.width;J.height=B.height;p(D).afterFx(C)}K.by=p(D).switchStatements(E.toLowerCase(),function(N,M){return[N,M]},{t:[0,-F],l:[-I,0],r:[I,0],b:[0,F],tl:[-I,-F],bl:[-I,F],br:[I,F],tr:[I,-F]});arguments.callee.anim=p(D).fxanim(H,C,e,0.5,r,L)});return G},syncFx:function(){var B=this;B.fxDefaults=Ext.apply(B.fxDefaults||{},{block:t,concurrent:k,stopFx:t});return B},sequenceFx:function(){var B=this;B.fxDefaults=Ext.apply(B.fxDefaults||{},{block:t,concurrent:t,stopFx:t});return B},nextFx:function(){var B=c(this.dom.id)[0];if(B){B.call(this)}},hasActiveFx:function(){return c(this.dom.id)[0]},stopFx:function(B){var C=this,E=C.dom.id;if(C.hasActiveFx()){var D=c(E)[0];if(D&&D.anim){if(D.anim.isAnimated){b(E,[D]);D.anim.stop(B!==undefined?B:k)}else{b(E,[])}}}return C},befor
 eFx:function(B){if(this.hasActiveFx()&&!B.concurrent){if(B.stopFx){this.stopFx();return k}return t}return k},hasFxBlock:function(){var B=c(this.dom.id);return B&&B[0]&&B[0].block},queueFx:function(E,B){var C=p(this.dom);if(!C.hasFxBlock()){Ext.applyIf(E,C.fxDefaults);if(!E.concurrent){var D=C.beforeFx(E);B.block=E.block;c(C.dom.id).push(B);if(D){C.nextFx()}}else{B.call(C)}}return C},fxWrap:function(H,F,D){var E=this.dom,C,B;if(!F.wrap||!(C=Ext.getDom(F.wrap))){if(F.fixPosition){B=p(E).getXY()}var G=document.createElement("div");G.style.visibility=D;C=E.parentNode.insertBefore(G,E);p(C).setPositioning(H);if(p(C).isStyle(o,"static")){p(C).position("relative")}p(E).clearPositioning("auto");p(C).clip();C.appendChild(E);if(B){p(C).setXY(B)}}return C},fxUnwrap:function(C,F,E){var D=this.dom;p(D).clearPositioning();p(D).setPositioning(F);if(!E.wrap){var B=p(C).dom.parentNode;B.insertBefore(D,C);p(C).remove()}},getFxRestore:function(){var B=this.dom.style;return{pos:this.getPosition
 ing(),width:B.width,height:B.height}},afterFx:function(C){var B=this.dom,D=B.id;if(C.afterStyle){p(B).setStyle(C.afterStyle)}if(C.afterCls){p(B).addClass(C.afterCls)}if(C.remove==k){p(B).remove()}if(C.callback){C.callback.call(C.scope,p(B))}if(!C.concurrent){c(D).shift();p(B).nextFx()}},fxanim:function(E,F,C,G,D,B){C=C||"run";F=F||{};var H=Ext.lib.Anim[C](this.dom,E,(F.duration||G)||0.35,(F.easing||D)||r,B,this);F.anim=H;return H}};Ext.Fx.resize=Ext.Fx.scale;Ext.Element.addMethods(Ext.Fx)})();Ext.CompositeElementLite=function(b,a){this.elements=[];this.add(b,a);this.el=new Ext.Element.Flyweight()};Ext.CompositeElementLite.prototype={isComposite:true,getElement:function(a){var b=this.el;b.dom=a;b.id=a.id;return b},transformElement:function(a){return Ext.getDom(a)},getCount:function(){return this.elements.length},add:function(d,b){var e=this,g=e.elements;if(!d){return this}if(Ext.isString(d)){d=Ext.Element.selectorFunction(d,b)}else{if(d.isComposite){d=d.elements}else{if(!Ext.
 isIterable(d)){d=[d]}}}for(var c=0,a=d.length;c<a;++c){g.push(e.transformElement(d[c]))}return e},invoke:function(g,b){var h=this,d=h.elements,a=d.length,j,c;for(c=0;c<a;c++){j=d[c];if(j){Ext.Element.prototype[g].apply(h.getElement(j),b)}}return h},item:function(b){var d=this,c=d.elements[b],a=null;if(c){a=d.getElement(c)}return a},addListener:function(b,j,h,g){var d=this.elements,a=d.length,c,k;for(c=0;c<a;c++){k=d[c];if(k){Ext.EventManager.on(k,b,j,h||k,g)}}return this},each:function(g,d){var h=this,c=h.elements,a=c.length,b,j;for(b=0;b<a;b++){j=c[b];if(j){j=this.getElement(j);if(g.call(d||j,j,h,b)){break}}}return h},fill:function(a){var b=this;b.elements=[];b.add(a);return b},filter:function(a){var b=[],d=this,e=d.elements,c=Ext.isFunction(a)?a:function(g){return g.is(a)};d.each(function(j,g,h){if(c(j,h)!==false){b[b.length]=d.transformElement(j)}});d.elements=b;return d},indexOf:function(a){return this.elements.indexOf(this.transformElement(a))},replaceElement:function(e
 ,c,a){var b=!isNaN(e)?e:this.indexOf(e),g;if(b>-1){c=Ext.getDom(c);if(a){g=this.elements[b];g.parentNode.insertBefore(c,g);Ext.removeNode(g)}this.elements.splice(b,1,c)}return this},clear:function(){this.elements=[]}};Ext.CompositeElementLite.prototype.on=Ext.CompositeElementLite.prototype.addListener;(function(){var c,b=Ext.Element.prototype,a=Ext.CompositeElementLite.prototype;for(c in b){if(Ext.isFunction(b[c])){(function(d){a[d]=a[d]||function(){return this.invoke(d,arguments)}}).call(a,c)}}})();if(Ext.DomQuery){Ext.Element.selectorFunction=Ext.DomQuery.select}Ext.Element.select=function(a,b){var c;if(typeof a=="string"){c=Ext.Element.selectorFunction(a,b)}else{if(a.length!==undefined){c=a}else{throw"Invalid selector"}}return new Ext.CompositeElementLite(c)};Ext.select=Ext.Element.select;(function(){var b="beforerequest",e="requestcomplete",d="requestexception",h=undefined,c="load",i="POST",a="GET",g=window;Ext.data.Connection=function(j){Ext.apply(this,j);this.addEvents
 (b,e,d);Ext.data.Connection.superclass.constructor.call(this)};Ext.extend(Ext.data.Connection,Ext.util.Observable,{timeout:30000,autoAbort:false,disableCaching:true,disableCachingParam:"_dc",request:function(n){var s=this;if(s.fireEvent(b,s,n)){if(n.el){if(!Ext.isEmpty(n.indicatorText)){s.indicatorText='<div class="loading-indicator">'+n.indicatorText+"</div>"}if(s.indicatorText){Ext.getDom(n.el).innerHTML=s.indicatorText}n.success=(Ext.isFunction(n.success)?n.success:function(){}).createInterceptor(function(o){Ext.getDom(n.el).innerHTML=o.responseText})}var l=n.params,k=n.url||s.url,j,q={success:s.handleResponse,failure:s.handleFailure,scope:s,argument:{options:n},timeout:n.timeout||s.timeout},m,t;if(Ext.isFunction(l)){l=l.call(n.scope||g,n)}l=Ext.urlEncode(s.extraParams,Ext.isObject(l)?Ext.urlEncode(l):l);if(Ext.isFunction(k)){k=k.call(n.scope||g,n)}if((m=Ext.getDom(n.form))){k=k||m.action;if(n.isUpload||/multipart\/form-data/i.test(m.getAttribute("enctype"))){return s.doF
 ormUpload.call(s,n,l,k)}t=Ext.lib.Ajax.serializeForm(m);l=l?(l+"&"+t):t}j=n.method||s.method||((l||n.xmlData||n.jsonData)?i:a);if(j===a&&(s.disableCaching&&n.disableCaching!==false)||n.disableCaching===true){var r=n.disableCachingParam||s.disableCachingParam;k=Ext.urlAppend(k,r+"="+(new Date().getTime()))}n.headers=Ext.apply(n.headers||{},s.defaultHeaders||{});if(n.autoAbort===true||s.autoAbort){s.abort()}if((j==a||n.xmlData||n.jsonData)&&l){k=Ext.urlAppend(k,l);l=""}return(s.transId=Ext.lib.Ajax.request(j,k,q,l,n))}else{return n.callback?n.callback.apply(n.scope,[n,h,h]):null}},isLoading:function(j){return j?Ext.lib.Ajax.isCallInProgress(j):!!this.transId},abort:function(j){if(j||this.isLoading()){Ext.lib.Ajax.abort(j||this.transId)}},handleResponse:function(j){this.transId=false;var k=j.argument.options;j.argument=k?k.argument:null;this.fireEvent(e,this,j,k);if(k.success){k.success.call(k.scope,j,k)}if(k.callback){k.callback.call(k.scope,k,true,j)}},handleFailure:function(
 j,l){this.transId=false;var k=j.argument.options;j.argument=k?k.argument:null;this.fireEvent(d,this,j,k,l);if(k.failure){k.failure.call(k.scope,j,k)}if(k.callback){k.callback.call(k.scope,k,false,j)}},doFormUpload:function(q,j,k){var l=Ext.id(),v=document,r=v.createElement("iframe"),m=Ext.getDom(q.form),u=[],t,p="multipart/form-data",n={target:m.target,method:m.method,encoding:m.encoding,enctype:m.enctype,action:m.action};Ext.fly(r).set({id:l,name:l,cls:"x-hidden"});v.body.appendChild(r);Ext.fly(r).set({src:Ext.SSL_SECURE_URL});if(Ext.isIE){document.frames[l].name=l}Ext.fly(m).set({target:l,method:i,enctype:p,encoding:p,action:k||n.action});Ext.iterate(Ext.urlDecode(j,false),function(w,o){t=v.createElement("input");Ext.fly(t).set({type:"hidden",value:o,name:w});m.appendChild(t);u.push(t)});function s(){var x=this,w={responseText:"",responseXML:null,argument:q.argument},A,z;try{A=r.contentWindow.document||r.contentDocument||g.frames[l].document;if(A){if(A.body){if(/textarea/i
 .test((z=A.body.firstChild||{}).tagName)){w.responseText=z.value}else{w.responseText=A.body.innerHTML}}w.responseXML=A.XMLDocument||A}}catch(y){}Ext.EventManager.removeListener(r,c,s,x);x.fireEvent(e,x,w,q);function o(D,C,B){if(Ext.isFunction(D)){D.apply(C,B)}}o(q.success,q.scope,[w,q]);o(q.callback,q.scope,[q,true,w]);if(!x.debugUploads){setTimeout(function(){Ext.removeNode(r)},100)}}Ext.EventManager.on(r,c,s,this);m.submit();Ext.fly(m).set(n);Ext.each(u,function(o){Ext.removeNode(o)})}})})();Ext.Ajax=new Ext.data.Connection({autoAbort:false,serializeForm:function(a){return Ext.lib.Ajax.serializeForm(a)}});Ext.util.JSON=new (function(){var useHasOwn=!!{}.hasOwnProperty,isNative=function(){var useNative=null;return function(){if(useNative===null){useNative=Ext.USE_NATIVE_JSON&&window.JSON&&JSON.toString()=="[object JSON]"}return useNative}}(),pad=function(n){return n<10?"0"+n:n},doDecode=function(json){return eval("("+json+")")},doEncode=function(o){if(!Ext.isDefined(o)||o==
 =null){return"null"}else{if(Ext.isArray(o)){return encodeArray(o)}else{if(Ext.isDate(o)){return Ext.util.JSON.encodeDate(o)}else{if(Ext.isString(o)){return encodeString(o)}else{if(typeof o=="number"){return isFinite(o)?String(o):"null"}else{if(Ext.isBoolean(o)){return String(o)}else{var a=["{"],b,i,v;for(i in o){if(!o.getElementsByTagName){if(!useHasOwn||o.hasOwnProperty(i)){v=o[i];switch(typeof v){case"undefined":case"function":case"unknown":break;default:if(b){a.push(",")}a.push(doEncode(i),":",v===null?"null":doEncode(v));b=true}}}}a.push("}");return a.join("")}}}}}}},m={"\b":"\\b","\t":"\\t","\n":"\\n","\f":"\\f","\r":"\\r",'"':'\\"',"\\":"\\\\"},encodeString=function(s){if(/["\\\x00-\x1f]/.test(s)){return'"'+s.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c}c=b.charCodeAt();return"\\u00"+Math.floor(c/16).toString(16)+(c%16).toString(16)})+'"'}return'"'+s+'"'},encodeArray=function(o){var a=["["],b,i,l=o.length,v;for(i=0;i<l;i+=1){v=o[i];switch(typeof
 v){case"undefined":case"function":case"unknown":break;default:if(b){a.push(",")}a.push(v===null?"null":Ext.util.JSON.encode(v));b=true}}a.push("]");return a.join("")};this.encodeDate=function(o){return'"'+o.getFullYear()+"-"+pad(o.getMonth()+1)+"-"+pad(o.getDate())+"T"+pad(o.getHours())+":"+pad(o.getMinutes())+":"+pad(o.getSeconds())+'"'};this.encode=function(){var ec;return function(o){if(!ec){ec=isNative()?JSON.stringify:doEncode}return ec(o)}}();this.decode=function(){var dc;return function(json){if(!dc){dc=isNative()?JSON.parse:doDecode}return dc(json)}}()})();Ext.encode=Ext.util.JSON.encode;Ext.decode=Ext.util.JSON.decode;
\ No newline at end of file
Added: sandbox/bartvde/adapters/openlayers/adapters/sencha-touch.js
--- sandbox/bartvde/adapters/openlayers/adapters/sencha-touch.js	                        (rev 0)
+++ sandbox/bartvde/adapters/openlayers/adapters/sencha-touch.js	2011-02-22 16:42:30 UTC (rev 11257)
@@ -0,0 +1,6 @@
+    Copyright(c) 2010 Sencha Inc.
+    licensing at sencha.com
+    http://www.sencha.com/touchlicense
+if(typeof Ext==="undefined"){Ext={}}Ext.apply=(function(){for(var a in {valueOf:1}){return function(c,b,e){if(e){Ext.apply(c,e)}if(c&&b&&typeof b==="object"){for(var d in b){c[d]=b[d]}}return c}}return function(c,b,e){if(e){Ext.apply(c,e)}if(c&&b&&typeof b==="object"){for(var d in b){c[d]=b[d]}if(b.toString!==Object.prototype.toString){c.toString=b.toString}if(b.valueOf!==Object.prototype.valueOf){c.valueOf=b.valueOf}}return c}})();Ext.apply(Ext,{platformVersion:"1.0",platformVersionDetail:{major:1,minor:0,patch:2},userAgent:navigator.userAgent.toLowerCase(),cache:{},idSeed:1000,BLANK_IMAGE_URL:"data:image/gif;base64,R0lGODlhAQABAID/AMDAwAAAACH5BAEAAAAALAAAAAABAAEAAAICRAEAOw==",isStrict:document.compatMode=="CSS1Compat",windowId:"ext-window",documentId:"ext-document",emptyFn:function(){},isSecure:/^https/i.test(window.location.protocol),isReady:false,enableGarbageCollector:true,enableListenerCollection:true,applyIf:function(b,a){var c,d;if(b){for(c in a){if(b[c]===d){b[c]=a[
 c]}}}return b},repaint:function(){var a=Ext.getBody().createChild({cls:"x-mask x-mask-transparent"});setTimeout(function(){a.remove()},0)},id:function(a,b){a=Ext.getDom(a)||{};if(a===document){a.id=this.documentId}else{if(a===window){a.id=this.windowId}}a.id=a.id||((b||"ext-gen")+(++Ext.idSeed));return a.id},extend:function(){var b=function(d){for(var c in d){if(!d.hasOwnProperty(c)){continue}this[c]=d[c]}};var a=Object.prototype.constructor;return function(c,h,f){if(Ext.isObject(h)){f=h;h=c;c=f.constructor!=a?f.constructor:function(){h.apply(this,arguments)}}if(!h){throw"Attempting to extend from a class which has not been loaded on the page."}var e=function(){},d,g=h.prototype;e.prototype=g;d=c.prototype=new e();d.constructor=c;c.superclass=g;if(g.constructor==a){g.constructor=h}c.override=function(i){Ext.override(c,i)};d.superclass=d.supr=(function(){return g});d.override=b;d.proto=d;c.override(f);c.extend=function(i){return Ext.extend(c,i)};return c}}(),override:function
 (a,b){Ext.apply(a.prototype,b)},namespace:function(){var e=arguments.length,d,f,c,a,h,g,b;for(d=0;d<e;d++){f=arguments[d];g=f.split(".");if(window.Ext){b=window[g[0]]=Object(window[g[0]])}else{b=arguments.callee.caller.arguments[0]}for(a=1,h=g.length;a<h;a++){b=b[g[a]]=Object(b[g[a]])}}return b},urlEncode:function(f,d){var b,a=[],c=encodeURIComponent;Ext.iterate(f,function(e,g){b=Ext.isEmpty(g);Ext.each(b?e:g,function(h){a.push("&",c(e),"=",(!Ext.isEmpty(h)&&(h!=e||!b))?(Ext.isDate(h)?Ext.encode(h).replace(/"/g,""):c(h)):"")})});if(!d){a.shift();d=""}return d+a.join("")},urlDecode:function(c,b){if(Ext.isEmpty(c)){return{}}var g={},f=c.split("&"),h=decodeURIComponent,a,e;Ext.each(f,function(d){d=d.split("=");a=h(d[0]);e=h(d[1]);g[a]=b||!g[a]?e:[].concat(g[a]).concat(e)});return g},htmlEncode:function(a){return Ext.util.Format.htmlEncode(a)},htmlDecode:function(a){return Ext.util.Format.htmlDecode(a)},urlAppend:function(a,b){if(!Ext.isEmpty(b)){return a+(a.indexOf("?")===-1?"?
 ":"&")+b}return a},toArray:function(c,b,a){return Array.prototype.slice.call(c,b||0,a||c.length)},each:function(e,d,c){if(Ext.isEmpty(e,true)){return 0}if(!Ext.isIterable(e)||Ext.isPrimitive(e)){e=[e]}for(var b=0,a=e.length;b<a;b++){if(d.call(c||e[b],e[b],b,e)===false){return b}}return true},iterate:function(c,b,a){if(Ext.isEmpty(c)){return}if(Ext.isIterable(c)){Ext.each(c,b,a);return}else{if(Ext.isObject(c)){for(var d in c){if(c.hasOwnProperty(d)){if(b.call(a||c,d,c[d],c)===false){return}}}}}},pluck:function(a,c){var b=[];Ext.each(a,function(d){b.push(d[c])});return b},getBody:function(){return Ext.get(document.body||false)},getHead:function(){var a;return function(){if(a==undefined){a=Ext.get(DOC.getElementsByTagName("head")[0])}return a}}(),getDoc:function(){return Ext.get(document)},getCmp:function(a){return Ext.ComponentMgr.get(a)},getOrientation:function(){return window.innerHeight>window.innerWidth?"portrait":"landscape"},isIterable:function(a){if(!a){return false}if(
 Ext.isArray(a)||a.callee){return true}if(/NodeList|HTMLCollection/.test(Object.prototype.toString.call(a))){return true}return((typeof a.nextNode!="undefined"||a.item)&&Ext.isNumber(a.length))||false},num:function(b,a){b=Number(Ext.isEmpty(b)||Ext.isArray(b)||typeof b=="boolean"||(typeof b=="string"&&Ext.util.Format.trim(b).length==0)?NaN:b);return isNaN(b)?a:b},isEmpty:function(d,a){var b=d==null,c=(Ext.isArray(d)&&!d.length),e=!a?d==="":false;return b||c||e},isArray:function(a){return Object.prototype.toString.apply(a)==="[object Array]"},isDate:function(a){return Object.prototype.toString.apply(a)==="[object Date]"},isObject:function(a){return !!a&&!a.tagName&&Object.prototype.toString.call(a)==="[object Object]"},isPrimitive:function(a){return Ext.isString(a)||Ext.isNumber(a)||Ext.isBoolean(a)},isFunction:function(a){return Object.prototype.toString.apply(a)==="[object Function]"},isNumber:function(a){return Object.prototype.toString.apply(a)==="[object Number]"&&isFinit
 e(a)},isString:function(a){return typeof a==="string"},isBoolean:function(a){return Object.prototype.toString.apply(a)==="[object Boolean]"},isElement:function(a){return a?!!a.tagName:false},isDefined:function(a){return typeof a!=="undefined"},destroy:function(){var c=arguments.length,b,a;for(b=0;b<c;b++){a=arguments[b];if(a){if(Ext.isArray(a)){this.destroy.apply(this,a)}else{if(Ext.isFunction(a.destroy)){a.destroy()}else{if(a.dom){a.remove()}}}}}}});Ext.SSL_SECURE_URL=Ext.isSecure&&"about:blank";Ext.ns=Ext.namespace;Ext.ns("Ext.util","Ext.data","Ext.list","Ext.form","Ext.menu","Ext.state","Ext.layout","Ext.app","Ext.ux","Ext.plugins","Ext.direct","Ext.lib","Ext.gesture");Ext.util.Observable=Ext.extend(Object,{isObservable:true,constructor:function(a){var b=this;Ext.apply(b,a);if(b.listeners){b.on(b.listeners);delete b.listeners}b.events=b.events||{};if(this.bubbleEvents){this.enableBubble(this.bubbleEvents)}},eventOptionsRe:/^(?:scope|delay|buffer|single|stopEvent|preventDe
 fault|stopPropagation|normalized|args|delegate|element|vertical|horizontal)$/,addManagedListener:function(h,d,f,e,c){var g=this,a=g.managedListeners=g.managedListeners||[],b;if(Ext.isObject(d)){c=d;for(d in c){if(!c.hasOwnProperty(d)){continue}b=c[d];if(!g.eventOptionsRe.test(d)){g.addManagedListener(h,d,b.fn||b,b.scope||c.scope,b.fn?b:c)}}}else{a.push({item:h,ename:d,fn:f,scope:e,options:c});h.on(d,f,e,c)}},removeManagedListener:function(k,e,h,l){var g=this,b,d,j,c,a,f;if(Ext.isObject(e)){b=e;for(e in b){if(!b.hasOwnProperty(e)){continue}d=b[e];if(!g.eventOptionsRe.test(e)){g.removeManagedListener(k,e,d.fn||d,d.scope||b.scope)}}}j=this.managedListeners?this.managedListeners.slice():[];a=j.length;for(f=0;f<a;f++){c=j[f];if(c.item===k&&c.ename===e&&(!h||c.fn===h)&&(!l||c.scope===l)){this.managedListeners.remove(c);k.un(c.ename,c.fn,c.scope)}}},fireEvent:function(){var h=this,c=Ext.toArray(arguments),e=c[0].toLowerCase(),d=true,g=h.events[e],b=h.eventQueue,f;if(h.eventsSuspend
 ed===true){if(b){b.push(c)}return false}else{if(g&&Ext.isObject(g)&&g.bubble){if(g.fire.apply(g,c.slice(1))===false){return false}f=h.getBubbleTarget&&h.getBubbleTarget();if(f&&f.isObservable){if(!f.events[e]||!Ext.isObject(f.events[e])||!f.events[e].bubble){f.enableBubble(e)}return f.fireEvent.apply(f,c)}}else{if(g&&Ext.isObject(g)){c.shift();d=g.fire.apply(g,c)}}}return d},addListener:function(b,d,c,g){var f=this,a,e;if(Ext.isObject(b)){g=b;for(b in g){if(!g.hasOwnProperty(b)){continue}a=g[b];if(!f.eventOptionsRe.test(b)){f.addListener(b,a.fn||a,a.scope||g.scope,a.fn?a:g)}}}else{b=b.toLowerCase();f.events[b]=f.events[b]||true;e=f.events[b]||true;if(Ext.isBoolean(e)){f.events[b]=e=new Ext.util.Event(f,b)}e.addListener(d,c,Ext.isObject(g)?g:{})}},removeListener:function(b,d,c){var f=this,a,e;if(Ext.isObject(b)){var g=b;for(b in g){if(!g.hasOwnProperty(b)){continue}a=g[b];if(!f.eventOptionsRe.test(b)){f.removeListener(b,a.fn||a,a.scope||g.scope)}}}else{b=b.toLowerCase();e=f.e
 vents[b];if(e.isEvent){e.removeListener(d,c)}}},clearListeners:function(){var b=this.events,c,a;for(a in b){if(!b.hasOwnProperty(a)){continue}c=b[a];if(c.isEvent){c.clearListeners()}}this.clearManagedListeners()},purgeListeners:function(){console.warn("MixedCollection: purgeListeners has been deprecated. Please use clearListeners.");return this.clearListeners.apply(this,arguments)},clearManagedListeners:function(){var b=this.managedListeners||[],d=b.length,c,a;for(c=0;c<d;c++){a=b[c];a.item.un(a.ename,a.fn,a.scope)}this.managedListener=[]},purgeManagedListeners:function(){console.warn("MixedCollection: purgeManagedListeners has been deprecated. Please use clearManagedListeners.");return this.clearManagedListeners.apply(this,arguments)},addEvents:function(e){var d=this;d.events=d.events||{};if(Ext.isString(e)){var b=arguments,c=b.length;while(c--){d.events[b[c]]=d.events[b[c]]||true}}else{Ext.applyIf(d.events,e)}},hasListener:function(a){var b=this.events[a];return b.isEvent=
 ==true&&b.listeners.length>0},suspendEvents:function(a){this.eventsSuspended=true;if(a&&!this.eventQueue){this.eventQueue=[]}},resumeEvents:function(){var a=this,b=a.eventQueue||[];a.eventsSuspended=false;delete a.eventQueue;Ext.each(b,function(c){a.fireEvent.apply(a,c)})},relayEvents:function(b,e,h){h=h||"";var g=this,a=e.length,d,c;function f(i){return function(){return g.fireEvent.apply(g,[h+i].concat(Array.prototype.slice.call(arguments,0,-1)))}}for(d=0,a=e.length;d<a;d++){c=e[d].substr(h.length);g.events[c]=g.events[c]||true;b.on(c,f(c),g)}},enableBubble:function(a){var b=this;if(!Ext.isEmpty(a)){a=Ext.isArray(a)?a:Ext.toArray(arguments);Ext.each(a,function(c){c=c.toLowerCase();var d=b.events[c]||true;if(Ext.isBoolean(d)){d=new Ext.util.Event(b,c);b.events[c]=d}d.bubble=true})}}});Ext.override(Ext.util.Observable,{on:Ext.util.Observable.prototype.addListener,un:Ext.util.Observable.prototype.removeListener,mon:Ext.util.Observable.prototype.addManagedListener,mun:Ext.util
 .Observable.prototype.removeManagedListener});Ext.util.Observable.releaseCapture=function(a){a.fireEvent=Ext.util.Observable.prototype.fireEvent};Ext.util.Observable.capture=function(c,b,a){c.fireEvent=Ext.createInterceptor(c.fireEvent,b,a)};Ext.util.Observable.observe=function(a,b){if(a){if(!a.isObservable){Ext.applyIf(a,new Ext.util.Observable());Ext.util.Observable.capture(a.prototype,a.fireEvent,a)}if(typeof b=="object"){a.on(b)}return a}};Ext.util.Observable.observeClass=Ext.util.Observable.observe;Ext.util.Event=Ext.extend(Object,(function(){function b(e,f,g,d){f.task=new Ext.util.DelayedTask();return function(){f.task.delay(g.buffer,e,d,Ext.toArray(arguments))}}function a(e,f,g,d){return function(){var h=new Ext.util.DelayedTask();if(!f.tasks){f.tasks=[]}f.tasks.push(h);h.delay(g.delay||10,e,d,Ext.toArray(arguments))}}function c(e,f,g,d){return function(){f.ev.removeListener(f.fn,d);return e.apply(d,arguments)}}return{isEvent:true,constructor:function(e,d){this.name=d
 ;this.observable=e;this.listeners=[]},addListener:function(f,e,d){var g=this,h;e=e||g.observable;if(!g.isListening(f,e)){h=g.createListener(f,e,d);if(g.firing){g.listeners=g.listeners.slice(0)}g.listeners.push(h)}},createListener:function(f,e,h){h=h||{};e=e||this.observable;var g={fn:f,scope:e,o:h,ev:this},d=f;if(h.delay){d=a(d,g,h,e)}if(h.buffer){d=b(d,g,h,e)}if(h.single){d=c(d,g,h,e)}g.fireFn=d;return g},findListener:function(h,g){var f=this.listeners,d=f.length,j,e;while(d--){j=f[d];if(j){e=j.scope;if(j.fn==h&&(e==g||e==this.observable)){return d}}}return -1},isListening:function(e,d){return this.findListener(e,d)!==-1},removeListener:function(g,f){var h=this,e,i,d;e=h.findListener(g,f);if(e!=-1){i=h.listeners[e];if(h.firing){h.listeners=h.listeners.slice(0)}if(i.task){i.task.cancel();delete i.task}d=i.tasks&&i.tasks.length;if(d){while(d--){i.tasks[d].cancel()}delete i.tasks}h.listeners.splice(e,1);return true}return false},clearListeners:function(){var e=this.listeners,d
 =e.length;while(d--){this.removeListener(e[d].fn,e[d].scope)}},fire:function(){var h=this,f=h.listeners,g=f.length,e,d,j;if(g>0){h.firing=true;for(e=0;e<g;e++){j=f[e];d=arguments.length?Array.prototype.slice.call(arguments,0):[];if(j.o){d.push(j.o)}if(j&&j.fireFn.apply(j.scope||h.observable,d)===false){return(h.firing=false)}}}h.firing=false;return true}}})());Ext.util.Stateful=Ext.extend(Ext.util.Observable,{editing:false,dirty:false,persistanceProperty:"data",constructor:function(a){Ext.applyIf(this,{data:{}});this.modified={};this[this.persistanceProperty]={};Ext.util.Stateful.superclass.constructor.call(this,a)},get:function(a){return this[this.persistanceProperty][a]},set:function(g,e){var a=this.fields,d=[],f,c,b;if(arguments.length==1&&Ext.isObject(g)){for(c in g){if(!g.hasOwnProperty(c)){continue}f=a.get(c);if(f&&f.convert!==f.type.convert){d.push(c);continue}this.set(c,g[c])}for(b=0;b<d.length;b++){f=d[b];this.set(f,g[f])}}else{if(a){f=a.get(g);if(f&&f.convert){e=f.
 convert(e,this)}}this[this.persistanceProperty][g]=e;this.dirty=true;if(!this.editing){this.afterEdit()}}},getChanges:function(){var a=this.modified,b={},c;for(c in a){if(a.hasOwnProperty(c)){b[c]=this[this.persistanceProperty][c]}}return b},isModified:function(a){return !!(this.modified&&this.modified.hasOwnProperty(a))},setDirty:function(){this.dirty=true;if(!this.modified){this.modified={}}this.fields.each(function(a){this.modified[a.name]=this[this.persistanceProperty][a.name]},this)},markDirty:function(){throw new Error("Stateful: markDirty has been deprecated. Please use setDirty.")},reject:function(a){var b=this.modified,c;for(c in b){if(!b.hasOwnProperty(c)){continue}if(typeof b[c]!="function"){this[this.persistanceProperty][c]=b[c]}}this.dirty=false;this.editing=false;delete this.modified;if(a!==true){this.afterReject()}},commit:function(a){this.dirty=false;this.editing=false;delete this.modified;if(a!==true){this.afterCommit()}},copy:function(a){return new this.con
 structor(Ext.apply({},this[this.persistanceProperty]),a||this.internalId)}});Ext.util.HashMap=Ext.extend(Ext.util.Observable,{constructor:function(a){this.addEvents("add","clear","remove","replace");Ext.util.HashMap.superclass.constructor.call(this,a);this.clear(true)},getCount:function(){return this.length},getData:function(a,b){if(b===undefined){b=a;a=this.getKey(b)}return[a,b]},getKey:function(a){return a.id},add:function(a,d){var b=this,c;if(b.containsKey(a)){throw new Error("This key already exists in the HashMap")}c=this.getData(a,d);a=c[0];d=c[1];b.map[a]=d;++b.length;b.fireEvent("add",b,a,d);return d},replace:function(b,d){var c=this,e=c.map,a;if(!c.containsKey(b)){c.add(b,d)}a=e[b];e[b]=d;c.fireEvent("replace",c,b,d,a);return d},remove:function(b){var a=this.findKey(b);if(a!==undefined){return this.removeByKey(a)}return false},removeByKey:function(a){var b=this,c;if(b.containsKey(a)){c=b.map[a];delete b.map[a];--b.length;b.fireEvent("remove",b,a,c);return true}retur
 n false},get:function(a){return this.map[a]},clear:function(a){var b=this;b.map={};b.length=0;if(a!==true){b.fireEvent("clear",b)}return b},containsKey:function(a){return this.map[a]!==undefined},contains:function(a){return this.containsKey(this.findKey(a))},getKeys:function(){return this.getArray(true)},getValues:function(){return this.getArray(false)},getArray:function(d){var a=[],b,c=this.map;for(b in c){if(c.hasOwnProperty(b)){a.push(d?b:c[b])}}return a},each:function(d,c){var a=Ext.apply({},this.map),b,e=this.length;c=c||this;for(b in a){if(a.hasOwnProperty(b)){if(d.call(c,b,a[b],e)===false){break}}}return this},clone:function(){var c=new Ext.util.HashMap(),b=this.map,a;c.suspendEvents();for(a in b){if(b.hasOwnProperty(a)){c.add(a,b[a])}}c.resumeEvents();return c},findKey:function(b){var a,c=this.map;for(a in c){if(c.hasOwnProperty(a)&&c[a]===b){return a}}return undefined}});Ext.util.MixedCollection=function(b,a){this.items=[];this.map={};this.keys=[];this.length=0;this
 .addEvents("clear","add","replace","remove","sort");this.allowFunctions=b===true;if(a){this.getKey=a}Ext.util.MixedCollection.superclass.constructor.call(this)};Ext.extend(Ext.util.MixedCollection,Ext.util.Observable,{allowFunctions:false,add:function(b,d){var e=d,c=b;if(arguments.length==1){e=c;c=this.getKey(e)}if(typeof c!="undefined"&&c!==null){var a=this.map[c];if(typeof a!="undefined"){return this.replace(c,e)}this.map[c]=e}this.length++;this.items.push(e);this.keys.push(c);this.fireEvent("add",this.length-1,e,c);return e},getKey:function(a){return a.id},replace:function(c,d){if(arguments.length==1){d=arguments[0];c=this.getKey(d)}var a=this.map[c];if(typeof c=="undefined"||c===null||typeof a=="undefined"){return this.add(c,d)}var b=this.indexOfKey(c);this.items[b]=d;this.map[c]=d;this.fireEvent("replace",c,a,d);return d},addAll:function(e){if(arguments.length>1||Ext.isArray(e)){var b=arguments.length>1?arguments:e;for(var d=0,a=b.length;d<a;d++){this.add(b[d])}}else{fo
 r(var c in e){if(!e.hasOwnProperty(c)){continue}if(this.allowFunctions||typeof e[c]!="function"){this.add(c,e[c])}}}},each:function(e,d){var b=[].concat(this.items);for(var c=0,a=b.length;c<a;c++){if(e.call(d||b[c],b[c],c,a)===false){break}}},eachKey:function(d,c){for(var b=0,a=this.keys.length;b<a;b++){d.call(c||window,this.keys[b],this.items[b],b,a)}},findBy:function(d,c){for(var b=0,a=this.items.length;b<a;b++){if(d.call(c||window,this.items[b],this.keys[b])){return this.items[b]}}return null},insert:function(a,b,d){var c=b,e=d;if(arguments.length==2){e=c;c=this.getKey(e)}if(this.containsKey(c)){this.suspendEvents();this.removeByKey(c);this.resumeEvents()}if(a>=this.length){return this.add(c,e)}this.length++;this.items.splice(a,0,e);if(typeof c!="undefined"&&c!==null){this.map[c]=e}this.keys.splice(a,0,c);this.fireEvent("add",a,e,c);return e},remove:function(a){return this.removeAt(this.indexOf(a))},removeAll:function(a){Ext.each(a||[],function(b){this.remove(b)},this);re
 turn this},removeAt:function(a){if(a<this.length&&a>=0){this.length--;var c=this.items[a];this.items.splice(a,1);var b=this.keys[a];if(typeof b!="undefined"){delete this.map[b]}this.keys.splice(a,1);this.fireEvent("remove",c,b);return c}return false},removeByKey:function(a){return this.removeAt(this.indexOfKey(a))},removeKey:function(){console.warn("MixedCollection: removeKey has been deprecated. Please use removeByKey.");return this.removeByKey.apply(this,arguments)},getCount:function(){return this.length},indexOf:function(a){return this.items.indexOf(a)},indexOfKey:function(a){return this.keys.indexOf(a)},get:function(b){var a=this.map[b],c=a!==undefined?a:(typeof b=="number")?this.items[b]:undefined;return typeof c!="function"||this.allowFunctions?c:null},item:function(){console.warn("MixedCollection: item has been deprecated. Please use get.");return this.get.apply(this,arguments)},getAt:function(a){return this.items[a]},itemAt:function(){console.warn("MixedCollection: i
 temAt has been deprecated. Please use getAt.");return this.getAt.apply(this,arguments)},getByKey:function(a){return this.map[a]},key:function(){console.warn("MixedCollection: key has been deprecated. Please use getByKey.");return this.getByKey.apply(this,arguments)},contains:function(a){return this.indexOf(a)!=-1},containsKey:function(a){return typeof this.map[a]!="undefined"},clear:function(){this.length=0;this.items=[];this.keys=[];this.map={};this.fireEvent("clear")},first:function(){return this.items[0]},last:function(){return this.items[this.length-1]},_sort:function(j,a,h){var d,e,b=String(a).toUpperCase()=="DESC"?-1:1,g=[],k=this.keys,f=this.items;h=h||function(i,c){return i-c};for(d=0,e=f.length;d<e;d++){g[g.length]={key:k[d],value:f[d],index:d}}g.sort(function(i,c){var l=h(i[j],c[j])*b;if(l===0){l=(i.index<c.index?-1:1)}return l});for(d=0,e=g.length;d<e;d++){f[d]=g[d].value;k[d]=g[d].key}this.fireEvent("sort",this)},sort:function(c,e){var d=c;if(Ext.isString(c)){d=[
 new Ext.util.Sorter({property:c,direction:e||"ASC"})]}else{if(c instanceof Ext.util.Sorter){d=[c]}else{if(Ext.isObject(c)){d=[new Ext.util.Sorter(c)]}}}var b=d.length;if(b==0){return}var a=function(h,g){var f=d[0].sort(h,g),k=d.length,j;for(j=1;j<k;j++){f=f||d[j].sort.call(this,h,g)}return f};this.sortBy(a)},sortBy:function(c){var b=this.items,f=this.keys,e=b.length,a=[],d;for(d=0;d<e;d++){a[d]={key:f[d],value:b[d],index:d}}a.sort(function(h,g){var i=c(h.value,g.value);if(i===0){i=(h.index<g.index?-1:1)}return i});for(d=0;d<e;d++){b[d]=a[d].value;f[d]=a[d].key}this.fireEvent("sort",this)},reorder:function(d){this.suspendEvents();var b=this.items,c=0,f=b.length,a=[],e=[],g;for(g in d){a[d[g]]=b[g]}for(c=0;c<f;c++){if(d[c]==undefined){e.push(b[c])}}for(c=0;c<f;c++){if(a[c]==undefined){a[c]=e.shift()}}this.clear();this.addAll(a);this.resumeEvents();this.fireEvent("sort",this)},sortByKey:function(a,b){this._sort("key",a,b||function(d,c){var f=String(d).toUpperCase(),e=String(c).
 toUpperCase();return f>e?1:(f<e?-1:0)})},keySort:function(){console.warn("MixedCollection: keySort has been deprecated. Please use sortByKey.");return this.sortByKey.apply(this,arguments)},getRange:function(e,a){var b=this.items;if(b.length<1){return[]}e=e||0;a=Math.min(typeof a=="undefined"?this.length-1:a,this.length-1);var c,d=[];if(e<=a){for(c=e;c<=a;c++){d[d.length]=b[c]}}else{for(c=e;c>=a;c--){d[d.length]=b[c]}}return d},filter:function(d,c,f,a){var b=[];if(Ext.isString(d)){b.push(new Ext.util.Filter({property:d,value:c,anyMatch:f,caseSensitive:a}))}else{if(Ext.isArray(d)||d instanceof Ext.util.Filter){b=b.concat(d)}}var e=function(g){var m=true,n=b.length,h;for(h=0;h<n;h++){var l=b[h],k=l.filterFn,j=l.scope;m=m&&k.call(j,g)}return m};return this.filterBy(e)},filterBy:function(e,d){var a=new Ext.util.MixedCollection(),g=this.keys,b=this.items,f=b.length,c;a.getKey=this.getKey;for(c=0;c<f;c++){if(e.call(d||this,b[c],g[c])){a.add(g[c],b[c])}}return a},findIndex:function(
 c,b,e,d,a){if(Ext.isEmpty(b,false)){return -1}b=this.createValueMatcher(b,d,a);return this.findIndexBy(function(f){return f&&b.test(f[c])},null,e)},findIndexBy:function(f,e,g){var b=this.keys,d=this.items;for(var c=(g||0),a=d.length;c<a;c++){if(f.call(e||this,d[c],b[c])){return c}}return -1},createValueMatcher:function(c,e,a,b){if(!c.exec){var d=Ext.util.Format.escapeRegex;c=String(c);if(e===true){c=d(c)}else{c="^"+d(c);if(b===true){c+="$"}}c=new RegExp(c,a?"":"i")}return c},clone:function(){var e=new Ext.util.MixedCollection();var b=this.keys,d=this.items;for(var c=0,a=d.length;c<a;c++){e.add(b[c],d[c])}e.getKey=this.getKey;return e}});Ext.AbstractManager=Ext.extend(Object,{typeName:"type",constructor:function(a){Ext.apply(this,a||{});this.all=new Ext.util.HashMap();this.types={}},get:function(a){return this.all.get(a)},register:function(a){this.all.add(a)},unregister:function(a){this.all.remove(a)},registerType:function(b,a){this.types[b]=a;a[this.typeName]=b},isRegistered
 :function(a){return this.types[a]!==undefined},create:function(a,d){var b=a[this.typeName]||a.type||d,c=this.types[b];if(c==undefined){throw new Error(Ext.util.Format.format("The '{0}' type has not been registered with this manager",b))}return new c(a)},onAvailable:function(d,c,b){var a=this.all;a.on("add",function(e,f){if(f.id==d){c.call(b||f,f);a.un("add",c,b)}})},each:function(b,a){this.all.each(b,a||this)},getCount:function(){return this.all.getCount()}});Ext.util.DelayedTask=function(d,c,a){var e=this,f,b=function(){clearInterval(f);f=null;d.apply(c,a||[])};this.delay=function(h,j,i,g){e.cancel();d=j||d;c=i||c;a=g||a;f=setInterval(b,h)};this.cancel=function(){if(f){clearInterval(f);f=null}}};Ext.util.GeoLocation=Ext.extend(Ext.util.Observable,{autoUpdate:true,latitude:null,longitude:null,accuracy:null,altitude:null,altitudeAccuracy:null,heading:null,speed:null,timestamp:null,allowHighAccuracy:false,timeout:Infinity,maximumAge:0,setMaximumAge:function(a){this.maximumAge=
 a;this.setAutoUpdate(this.autoUpdate)},setTimeout:function(a){this.timeout=a;this.setAutoUpdate(this.autoUpdate)},setAllowHighAccuracy:function(a){this.allowHighAccuracy=a;this.setAutoUpdate(this.autoUpdate)},provider:null,watchOperation:null,constructor:function(a){Ext.apply(this,a);this.coords=this;if(Ext.supports.GeoLocation){this.provider=this.provider||(navigator.geolocation?navigator.geolocation:(window.google||{}).gears?google.gears.factory.create("beta.geolocation"):null)}this.addEvents("update","locationerror","locationupdate");Ext.util.GeoLocation.superclass.constructor.call(this);if(this.autoUpdate){var b=this;setTimeout(function(){b.setAutoUpdate(b.autoUpdate)},0)}},setAutoUpdate:function(a){if(this.watchOperation!==null){this.provider.clearWatch(this.watchOperation);this.watchOperation=null}if(!a){return true}if(!Ext.supports.GeoLocation){this.fireEvent("locationerror",this,false,false,true,null);return false}try{this.watchOperation=this.provider.watchPosition(E
 xt.createDelegate(this.fireUpdate,this),Ext.createDelegate(this.fireError,this),this.parseOptions())}catch(b){this.autoUpdate=false;this.fireEvent("locationerror",this,false,false,true,b.message);return false}return true},updateLocation:function(g,a,c){var b=this;var f=function(h,e){if(e){b.fireError(e)}else{b.fireEvent("locationerror",b,false,false,true,h)}if(g){g.call(a||b,null,b)}b.fireEvent("update",false,b)};if(!Ext.supports.GeoLocation){setTimeout(function(){f(null)},0);return}try{this.provider.getCurrentPosition(function(e){b.fireUpdate(e);if(g){g.call(a||b,b,b)}b.fireEvent("update",b,b)},function(e){f(null,e)},c?c:this.parseOptions())}catch(d){setTimeout(function(){f(d.message)},0)}},fireUpdate:function(a){this.timestamp=a.timestamp;this.latitude=a.coords.latitude;this.longitude=a.coords.longitude;this.accuracy=a.coords.accuracy;this.altitude=a.coords.altitude;this.altitudeAccuracy=a.coords.altitudeAccuracy;this.heading=typeof a.coords.heading=="undefined"?null:a.coo
 rds.heading;this.speed=typeof a.coords.speed=="undefined"?null:a.coords.speed;this.fireEvent("locationupdate",this)},fireError:function(a){this.fireEvent("locationerror",this,a.code==a.TIMEOUT,a.code==a.PERMISSION_DENIED,a.code==a.POSITION_UNAVAILABLE,a.message==undefined?null:a.message)},parseOptions:function(){var a={maximumAge:this.maximumAge,allowHighAccuracy:this.allowHighAccuracy};if(this.timeout!==Infinity){a.timeout=this.timeout}return a},getLocation:function(c,a){var b=this;if(this.latitude!==null){c.call(a||b,b,b)}else{b.updateLocation(c,a)}}});Ext.util.Point=Ext.extend(Object,{constructor:function(a,b){this.x=(a!=null&&!isNaN(a))?a:0;this.y=(b!=null&&!isNaN(b))?b:0;return this},copy:function(){return new Ext.util.Point(this.x,this.y)},copyFrom:function(a){this.x=a.x;this.y=a.y;return this},toString:function(){return"Point["+this.x+","+this.y+"]"},equals:function(a){return(this.x==a.x&&this.y==a.y)},isWithin:function(b,a){if(!Ext.isObject(a)){a={x:a};a.y=a.x}return
 (this.x<=b.x+a.x&&this.x>=b.x-a.x&&this.y<=b.y+a.y&&this.y>=b.y-a.y)},translate:function(a,b){if(a!=null&&!isNaN(a)){this.x+=a}if(b!=null&&!isNaN(b)){this.y+=b}},roundedEquals:function(a){return(Math.round(this.x)==Math.round(a.x)&&Math.round(this.y)==Math.round(a.y))}});Ext.util.Point.fromEvent=function(c){var b=(c.changedTouches&&c.changedTouches.length>0)?c.changedTouches[0]:c;return new Ext.util.Point(b.pageX,b.pageY)};Ext.util.Offset=Ext.extend(Object,{constructor:function(a,b){this.x=(a!=null&&!isNaN(a))?a:0;this.y=(b!=null&&!isNaN(b))?b:0;return this},copy:function(){return new Ext.util.Offset(this.x,this.y)},copyFrom:function(a){this.x=a.x;this.y=a.y},toString:function(){return"Offset["+this.x+","+this.y+"]"},equals:function(a){if(!(a instanceof Ext.util.Offset)){throw new Error("offset must be an instance of Ext.util.Offset")}return(this.x==a.x&&this.y==a.y)},round:function(b){if(!isNaN(b)){var a=Math.pow(10,b);this.x=Math.round(this.x*a)/a;this.y=Math.round(this.y*
 a)/a}else{this.x=Math.round(this.x);this.y=Math.round(this.y)}},isZero:function(){return this.x==0&&this.y==0}});Ext.util.Offset.fromObject=function(a){return new Ext.util.Offset(a.x,a.y)};Ext.util.Region=Ext.extend(Object,{constructor:function(d,f,a,c){var e=this;e.top=d;e[1]=d;e.right=f;e.bottom=a;e.left=c;e[0]=c},contains:function(b){var a=this;return(b.left>=a.left&&b.right<=a.right&&b.top>=a.top&&b.bottom<=a.bottom)},intersect:function(g){var f=this,d=Math.max(f.top,g.top),e=Math.min(f.right,g.right),a=Math.min(f.bottom,g.bottom),c=Math.max(f.left,g.left);if(a>d&&e>c){return new Ext.util.Region(d,e,a,c)}else{return false}},union:function(g){var f=this,d=Math.min(f.top,g.top),e=Math.max(f.right,g.right),a=Math.max(f.bottom,g.bottom),c=Math.min(f.left,g.left);return new Ext.util.Region(d,e,a,c)},constrainTo:function(b){var a=this,c=Ext.util.Numbers.constrain;a.top=c(a.top,b.top,b.bottom);a.bottom=c(a.bottom,b.top,b.bottom);a.left=c(a.left,b.left,b.right);a.right=c(a.right
 ,b.left,b.right);return a},adjust:function(d,f,a,c){var e=this;e.top+=d;e.left+=c;e.right+=f;e.bottom+=a;return e},getOutOfBoundOffset:function(a,b){if(!Ext.isObject(a)){if(a=="x"){return this.getOutOfBoundOffsetX(b)}else{return this.getOutOfBoundOffsetY(b)}}else{b=a;var c=new Ext.util.Offset();c.x=this.getOutOfBoundOffsetX(b.x);c.y=this.getOutOfBoundOffsetY(b.y);return c}},getOutOfBoundOffsetX:function(a){if(a<=this.left){return this.left-a}else{if(a>=this.right){return this.right-a}}return 0},getOutOfBoundOffsetY:function(a){if(a<=this.top){return this.top-a}else{if(a>=this.bottom){return this.bottom-a}}return 0},isOutOfBound:function(a,b){if(!Ext.isObject(a)){if(a=="x"){return this.isOutOfBoundX(b)}else{return this.isOutOfBoundY(b)}}else{b=a;return(this.isOutOfBoundX(b.x)||this.isOutOfBoundY(b.y))}},isOutOfBoundX:function(a){return(a<this.left||a>this.right)},isOutOfBoundY:function(a){return(a<this.top||a>this.bottom)},restrict:function(b,d,a){if(Ext.isObject(b)){var c;a=
 d;d=b;if(d.copy){c=d.copy()}else{c={x:d.x,y:d.y}}c.x=this.restrictX(d.x,a);c.y=this.restrictY(d.y,a);return c}else{if(b=="x"){return this.restrictX(d,a)}else{return this.restrictY(d,a)}}},restrictX:function(b,a){if(!a){a=1}if(b<=this.left){b-=(b-this.left)*a}else{if(b>=this.right){b-=(b-this.right)*a}}return b},restrictY:function(b,a){if(!a){a=1}if(b<=this.top){b-=(b-this.top)*a}else{if(b>=this.bottom){b-=(b-this.bottom)*a}}return b},getSize:function(){return{width:this.right-this.left,height:this.bottom-this.top}},copy:function(){return new Ext.util.Region(this.top,this.right,this.bottom,this.left)},toString:function(){return"Region["+this.top+","+this.right+","+this.bottom+","+this.left+"]"},translateBy:function(a){this.left+=a.x;this.right+=a.x;this.top+=a.y;this.bottom+=a.y;return this},round:function(){this.top=Math.round(this.top);this.right=Math.round(this.right);this.bottom=Math.round(this.bottom);this.left=Math.round(this.left);return this},equals:function(a){return
 (this.top==a.top&&this.right==a.right&&this.bottom==a.bottom&&this.left==a.left)}});Ext.util.Region.getRegion=function(a){return Ext.fly(a).getPageBox(true)};Ext.util.Region.from=function(a){return new Ext.util.Region(a.top,a.right,a.bottom,a.left)};Ext.Template=Ext.extend(Object,{constructor:function(d){var f=this,b=arguments,a=[],g,c,e;f.initialConfig={};if(Ext.isArray(d)){d=d.join("")}else{if(b.length>1){for(c=0,e=b.length;c<e;c++){g=b[c];if(typeof g=="object"){Ext.apply(f.initialConfig,g);Ext.apply(f,g)}else{a.push(g)}}d=a.join("")}}f.html=d;if(f.compiled){f.compile()}},isTemplate:true,disableFormats:false,re:/\{([\w-]+)(?:\:([\w\.]*)(?:\((.*?)?\))?)?\}/g,applyTemplate:function(a){var f=this,c=f.disableFormats!==true,e=Ext.util.Format,b=f;if(f.compiled){return f.compiled(a)}function d(g,i,j,h){if(j&&c){if(h){h=[a[i]].concat(new Function("return ["+h+"];")())}else{h=[a[i]]}if(j.substr(0,5)=="this."){return b[j.substr(5)].apply(b,h)}else{return e[j].apply(e,h)}}else{return
  a[i]!==undefined?a[i]:""}}return f.html.replace(f.re,d)},set:function(a,c){var b=this;b.html=a;b.compiled=null;return c?b.compile():b},compileARe:/\\/g,compileBRe:/(\r\n|\n)/g,compileCRe:/'/g,compile:function(){var me=this,fm=Ext.util.Format,useFormat=me.disableFormats!==true,body,bodyReturn;function fn(m,name,format,args){if(format&&useFormat){args=args?","+args:"";if(format.substr(0,5)!="this."){format="fm."+format+"("}else{format="this."+format.substr(5)+"("}}else{args="";format="(values['"+name+"'] == undefined ? '' : "}return"',"+format+"values['"+name+"']"+args+") ,'"}bodyReturn=me.html.replace(me.compileARe,"\\\\").replace(me.compileBRe,"\\n").replace(me.compileCRe,"\\'").replace(me.re,fn);body="this.compiled = function(values){ return ['"+bodyReturn+"'].join('');};";eval(body);return me},insertFirst:function(b,a,c){return this.doInsert("afterBegin",b,a,c)},insertBefore:function(b,a,c){return this.doInsert("beforeBegin",b,a,c)},insertAfter:function(b,a,c){return this
 .doInsert("afterEnd",b,a,c)},append:function(b,a,c){return this.doInsert("beforeEnd",b,a,c)},doInsert:function(c,e,b,a){e=Ext.getDom(e);var d=Ext.DomHelper.insertHtml(c,e,this.applyTemplate(b));return a?Ext.get(d,true):d},overwrite:function(b,a,c){b=Ext.getDom(b);b.innerHTML=this.applyTemplate(a);return c?Ext.get(b.firstChild,true):b.firstChild}});Ext.Template.prototype.apply=Ext.Template.prototype.applyTemplate;Ext.Template.from=function(b,a){b=Ext.getDom(b);return new Ext.Template(b.value||b.innerHTML,a||"")};Ext.XTemplate=Ext.extend(Ext.Template,{argsRe:/<tpl\b[^>]*>((?:(?=([^<]+))\2|<(?!tpl\b[^>]*>))*?)<\/tpl>/,nameRe:/^<tpl\b[^>]*?for="(.*?)"/,ifRe:/^<tpl\b[^>]*?if="(.*?)"/,execRe:/^<tpl\b[^>]*?exec="(.*?)"/,constructor:function(){Ext.XTemplate.superclass.constructor.apply(this,arguments);var y=this,h=y.html,v=y.argsRe,c=y.nameRe,t=y.ifRe,x=y.execRe,o=0,j=[],n="values",w="parent",k="xindex",l="xcount",d="return ",b="with(values){ ",p,f,u,a,e,g,q,z,s;h=["<tpl>",h,"</tpl>
 "].join("");while((p=h.match(v))){e=null;g=null;q=null;f=p[0].match(c);u=p[0].match(t);a=p[0].match(x);e=u?u[1]:null;if(e){g=new Function(n,w,k,l,b+"try{"+d+Ext.util.Format.htmlDecode(e)+";}catch(e){return;}}")}e=a?a[1]:null;if(e){q=new Function(n,w,k,l,b+Ext.util.Format.htmlDecode(e)+";}")}z=f?f[1]:null;if(z){if(z==="."){z=n}else{if(z===".."){z=w}}z=new Function(n,w,"try{"+b+d+z+";}}catch(e){return;}")}j.push({id:o,target:z,exec:q,test:g,body:p[1]||""});h=h.replace(p[0],"{xtpl"+o+"}");o=o+1}for(s=j.length-1;s>=0;--s){y.compileTpl(j[s])}y.master=j[j.length-1];y.tpls=j},applySubTemplate:function(g,a,c,e,f){var d=this,b=d.tpls[g];return b.compiled.call(d,a,c,e,f)},codeRe:/\{\[((?:\\\]|.|\n)*?)\]\}/g,re:/\{([\w-\.\#]+)(?:\:([\w\.]*)(?:\((.*?)?\))?)?(\s?[\+\-\*\/]\s?[\d\.\+\-\*\/\(\)]+)?\}/g,compileTpl:function(tpl){var fm=Ext.util.Format,me=this,useFormat=me.disableFormats!==true,body,bodyReturn,evaluatedFn;function fn(m,name,format,args,math){var v;if(name.substr(0,4)=="xtpl")
 {return"',this.applySubTemplate("+name.substr(4)+", values, parent, xindex, xcount),'"}if(name=="."){v='typeof values == "string" ? values : ""'}else{if(name=="#"){v="xindex"}else{if(name.substr(0,7)=="parent."){v=name}else{if(name.indexOf(".")!=-1){v="values."+name}else{v="values['"+name+"']"}}}}if(math){v="("+v+math+")"}if(format&&useFormat){args=args?","+args:"";if(format.substr(0,5)!="this."){format="fm."+format+"("}else{format="this."+format.substr(5)+"("}}else{args="";format="("+v+" === undefined ? '' : "}return"',"+format+v+args+"),'"}function codeFn(m,code){return"',("+code.replace(me.compileARe,"'")+"),'"}bodyReturn=tpl.body.replace(me.compileBRe,"\\n").replace(me.compileCRe,"\\'").replace(me.re,fn).replace(me.codeRe,codeFn);body="evaluatedFn = function(values, parent, xindex, xcount){return ['"+bodyReturn+"'].join('');};";eval(body);tpl.compiled=function(values,parent,xindex,xcount){var vs,length,buffer,i;if(tpl.test&&!tpl.test.call(me,values,parent,xindex,xcount))
 {return""}vs=tpl.target?tpl.target.call(me,values,parent):values;if(!vs){return""}parent=tpl.target?values:parent;if(tpl.target&&Ext.isArray(vs)){buffer=[],length=vs.length;if(tpl.exec){for(i=0;i<length;i++){buffer[buffer.length]=evaluatedFn.call(me,vs[i],parent,i+1,length);tpl.exec.call(me,vs[i],parent,i+1,length)}}else{for(i=0;i<length;i++){buffer[buffer.length]=evaluatedFn.call(me,vs[i],parent,i+1,length)}}return buffer.join("")}if(tpl.exec){tpl.exec.call(me,vs,parent,xindex,xcount)}return evaluatedFn.call(me,vs,parent,xindex,xcount)};return this},applyTemplate:function(a){return this.master.compiled.call(this,a,{},1,1)},compile:function(){return this}});Ext.XTemplate.prototype.apply=Ext.XTemplate.prototype.applyTemplate;Ext.XTemplate.from=function(b,a){b=Ext.getDom(b);return new Ext.XTemplate(b.value||b.innerHTML,a||{})};Ext.util.Sorter=Ext.extend(Object,{direction:"ASC",constructor:function(a){Ext.apply(this,a);if(this.property==undefined&&this.sorterFn==undefined){thro
 w"A Sorter requires either a property or a sorter function"}this.sort=this.createSortFunction(this.sorterFn||this.defaultSorterFn)},createSortFunction:function(b){var c=this,d=c.property,e=c.direction,a=e.toUpperCase()=="DESC"?-1:1;return function(g,f){return a*b.call(c,g,f)}},defaultSorterFn:function(b,a){var d=this.getRoot(b)[this.property],c=this.getRoot(a)[this.property];return d>c?1:(d<c?-1:0)},getRoot:function(a){return this.root==undefined?a:a[this.root]}});Ext.util.Filter=Ext.extend(Object,{anyMatch:false,exactMatch:false,caseSensitive:false,constructor:function(a){Ext.apply(this,a);this.filter=this.filter||this.filterFn;if(this.filter==undefined){if(this.property==undefined||this.value==undefined){}else{this.filter=this.createFilterFn()}this.filterFn=this.filter}},createFilterFn:function(){var a=this,c=a.createValueMatcher(),b=a.property;return function(d){return c.test(a.getRoot.call(a,d)[b])}},getRoot:function(a){return this.root==undefined?a:a[this.root]},createV
 alueMatcher:function(){var d=this,e=d.value,f=d.anyMatch,c=d.exactMatch,a=d.caseSensitive,b=Ext.util.Format.escapeRegex;if(!e.exec){e=String(e);if(f===true){e=b(e)}else{e="^"+b(e);if(c===true){e+="$"}}e=new RegExp(e,a?"":"i")}return e}});Ext.util.Functions={createInterceptor:function(d,c,b,a){var e=d;if(!Ext.isFunction(c)){return d}else{return function(){var g=this,f=arguments;c.target=g;c.method=d;return(c.apply(b||g||window,f)!==false)?d.apply(g||window,f):a||null}}},createDelegate:function(c,d,b,a){if(!Ext.isFunction(c)){return c}return function(){var f=b||arguments;if(a===true){f=Array.prototype.slice.call(arguments,0);f=f.concat(b)}else{if(Ext.isNumber(a)){f=Array.prototype.slice.call(arguments,0);var e=[a,0].concat(b);Array.prototype.splice.apply(f,e)}}return c.apply(d||window,f)}},defer:function(d,c,e,b,a){d=Ext.util.Functions.createDelegate(d,e,b,a);if(c>0){return setTimeout(d,c)}d();return 0},createSequence:function(c,b,a){if(!Ext.isFunction(b)){return c}else{return
  function(){var d=c.apply(this||window,arguments);b.apply(a||this||window,arguments);return d}}}};Ext.defer=Ext.util.Functions.defer;Ext.createInterceptor=Ext.util.Functions.createInterceptor;Ext.createSequence=Ext.util.Functions.createSequence;Ext.createDelegate=Ext.util.Functions.createDelegate;Ext.util.Date={getElapsed:function(b,a){return Math.abs(b-(a||new Date))}};Ext.util.Numbers={toFixedBroken:(0.9).toFixed()!=1,constrain:function(c,b,a){c=parseFloat(c);if(!isNaN(b)){c=Math.max(c,b)}if(!isNaN(a)){c=Math.min(c,a)}return c},toFixed:function(c,a){if(Ext.util.Numbers.toFixedBroken){a=a||0;var b=Math.pow(10,a);return Math.round(c*b)/b}return c.toFixed(a)}};Ext.util.Format={defaultDateFormat:"m/d/Y",escapeRe:/('|\\)/g,trimRe:/^[\x09\x0a\x0b\x0c\x0d\x20\xa0\u1680\u180e\u2000\u2001\u2002\u2003\u2004\u2005\u2006\u2007\u2008\u2009\u200a\u2028\u2029\u202f\u205f\u3000]+|[\x09\x0a\x0b\x0c\x0d\x20\xa0\u1680\u180e\u2000\u2001\u2002\u2003\u2004\u2005\u2006\u2007\u2008\u2009\u200a\u2
 028\u2029\u202f\u205f\u3000]+$/g,formatRe:/\{(\d+)\}/g,escapeRegexRe:/([-.*+?^${}()|[\]\/\\])/g,ellipsis:function(c,a,d){if(c&&c.length>a){if(d){var e=c.substr(0,a-2),b=Math.max(e.lastIndexOf(" "),e.lastIndexOf("."),e.lastIndexOf("!"),e.lastIndexOf("?"));if(b!=-1&&b>=(a-15)){return e.substr(0,b)+"..."}}return c.substr(0,a-3)+"..."}return c},escapeRegex:function(a){return a.replace(Ext.util.Format.escapeRegexRe,"\\$1")},escape:function(a){return a.replace(Ext.util.Format.escapeRe,"\\$1")},toggle:function(b,c,a){return b==c?a:c},trim:function(a){return a.replace(Ext.util.Format.trimRe,"")},leftPad:function(d,b,c){var a=String(d);c=c||" ";while(a.length<b){a=c+a}return a},format:function(b){var a=Ext.toArray(arguments,1);return b.replace(Ext.util.Format.formatRe,function(c,d){return a[d]})},htmlEncode:function(a){return !a?a:String(a).replace(/&/g,"&amp;").replace(/>/g,"&gt;").replace(/</g,"&lt;").replace(/"/g,"&quot;")},htmlDecode:function(a){return !a?a:String(a).replace(/&gt
 ;/g,">").replace(/&lt;/g,"<").replace(/&quot;/g,'"').replace(/&amp;/g,"&")},date:function(a,b){if(!a){return""}if(!Ext.isDate(a)){a=new Date(Date.parse(a))}return a.dateFormat(b||Ext.util.Format.defaultDateFormat)}};Ext.LoadMask=Ext.extend(Ext.util.Observable,{msg:"Loading...",msgCls:"x-mask-loading",disabled:false,constructor:function(b,a){this.el=Ext.get(b);Ext.apply(this,a);this.addEvents("show","hide");if(this.store){this.bindStore(this.store,true)}Ext.LoadMask.superclass.constructor.call(this)},bindStore:function(a,b){if(!b&&this.store){this.mun(this.store,{scope:this,beforeload:this.onBeforeLoad,load:this.onLoad,exception:this.onLoad});if(!a){this.store=null}}if(a){a=Ext.StoreMgr.lookup(a);this.mon(a,{scope:this,beforeload:this.onBeforeLoad,load:this.onLoad,exception:this.onLoad})}this.store=a;if(a&&a.isLoading()){this.onBeforeLoad()}},disable:function(){this.disabled=true},enable:function(){this.disabled=false},isDisabled:function(){return this.disabled},onLoad:functi
 on(){this.el.unmask();this.fireEvent("hide",this,this.el,this.store)},onBeforeLoad:function(){if(!this.disabled){this.el.mask('<div class="x-loading-spinner"><span class="x-loading-top"></span><span class="x-loading-right"></span><span class="x-loading-bottom"></span><span class="x-loading-left"></span></div><div class="x-loading-msg">'+this.msg+"</div>",this.msgCls,false);this.fireEvent("show",this,this.el,this.store)}},show:function(){this.onBeforeLoad()},hide:function(){this.onLoad()},destroy:function(){this.hide();this.clearListeners()}});Ext.applyIf(Array.prototype,{indexOf:function(b,c){var a=this.length;c=c||0;c+=(c<0)?a:0;for(;c<a;++c){if(this[c]===b){return c}}return -1},remove:function(b){var a=this.indexOf(b);if(a!=-1){this.splice(a,1)}return this},contains:function(a){return this.indexOf(a)!==-1}});Ext.ComponentMgr=new Ext.AbstractManager({typeName:"xtype",create:function(b,d){if(b.isComponent){return b}else{var c=b.xtype||d,a=this.types[c];if(!a){throw"Attemptin
 g to create a component with an xtype that has not been registered: "+c}return new a(b)}return b.render?b:new (b)},registerType:function(b,a){this.types[b]=a;a[this.typeName]=b;a.prototype[this.typeName]=b}});Ext.reg=function(){return Ext.ComponentMgr.registerType.apply(Ext.ComponentMgr,arguments)};Ext.create=function(){return Ext.ComponentMgr.create.apply(Ext.ComponentMgr,arguments)};Ext.ComponentQuery=new function(){var g=this,j=["var r = [],","i = 0,","it = arguments[0],","l = it.length,","c;","for (; i < l; i++) {","c = it[i].{0};","if (c) {","r.push(c);","}","}","return r;"].join(""),e=function(o,n){return n.method.apply(this,[o].concat(n.args))},a=function(p,u){var n=[],q,t=p.length,s,o=u!=">";for(q=0;q<t;q++){s=p[q];if(s.getRefItems){n=n.concat(s.getRefItems(o))}}return n},f=function(o){var n=[],p,s=o.length,q;for(p=0;p<s;p++){q=o[p];while(!!(q=q.ownerCt)){n.push(q)}}return n},l=function(o,u,t){if(u=="*"){return o.slice()}else{var n=[],p,s=o.length,q;for(p=0;p<s;p++){
 q=o[p];if(q.isXType(u,t)){n.push(q)}}return n}},i=function(o,s){var n=[],p,t=o.length,q;for(p=0;p<t;p++){q=o[p];if(q.el?q.el.hasCls(s):q.initCls().contains(s)){n.push(q)}}return n},m=function(p,v,o,u){var n=[],q,t=p.length,s;for(q=0;q<t;q++){s=p[q];if((u===undefined)?!!s[v]:(s[v]==u)){n.push(s)}}return n},d=function(o,t){var n=[],p,s=o.length,q;for(p=0;p<s;p++){q=o[p];if(q.getItemId()==t){n.push(q)}}return n},k=function(n,o,p){return g.pseudos[o](n,p)},h=/^(\s?([>\^])\s?|\s|$)/,c=/^(?:(#)?([\w-]+|\*)(?:\((true|false)\))?)|(?:\{([^\}]+)\})/,b=[{re:/^\.([\w-]+)(?:\((true|false)\))?/,method:l},{re:/^(?:[\[\{](?:@)?([\w-]+)\s?(?:(=|.=)\s?['"]?(.*?)["']?)?[\]\}])/,method:m},{re:/^#([\w-]+)/,method:d},{re:/^\:([\w-]+)(?:\(((?:[^\s>\/]*|.*?))\))?/,method:k}];g.Query=Ext.extend(Object,{constructor:function(n){n=n||{};Ext.apply(this,n)},execute:function(o){var q=this.operations,t=q.length,p,s,n;if(!o){n=Ext.ComponentMgr.all.items.slice()}for(s=0;s<t;s++){p=q[s];if(p.mode=="^"){n=f(n|
 |[o])}else{if(p.mode){n=a(n||[o],p.mode)}else{n=e(n||a([o]),p)}}if(s==t-1){return n}}return[]},is:function(p){var o=this.operations,s=o.length,q,n=Ext.isArray(p)?p:[p];for(q=0;q<s&&n.length;q++){n=e(n,o[q])}return n.length!=0}});Ext.apply(this,{cache:{},pseudos:{},query:function(n,w){var x=n.split(","),q=x.length,o,t,p=[],y=[],v={},s,u;for(o=0;o<q;o++){n=Ext.util.Format.trim(x[o]);t=this.cache[n];if(!t){this.cache[n]=t=this.parse(n)}p=p.concat(t.execute(w))}if(q>1){s=p.length;for(o=0;o<s;o++){u=p[o];if(!v[u.id]){y.push(u);v[u.id]=true}}p=y}return p},is:function(o,n){if(!n){return true}var p=this.cache[n];if(!p){this.cache[n]=p=this.parse(n)}return p.is(o)},parse:function(o){var n=[],u=b.length,v,p,w,x,y,t,q,s;while(o&&v!=o){v=o;p=o.match(c);if(p){w=p[1];if(w=="#"){n.push({method:d,args:[Ext.util.Format.trim(p[2])]})}else{if(w=="."){n.push({method:i,args:[Ext.util.Format.trim(p[2])]})}else{if(p[4]){n.push({method:new Function(Ext.util.Format.format(j,p[4])),args:[]})}else{n.p
 ush({method:l,args:[Ext.util.Format.trim(p[2]),Boolean(p[3])]})}}}o=o.replace(p[0],"")}while(!(x=o.match(h))){for(q=0;o&&q<u;q++){s=b[q];y=o.match(s.re);if(y){n.push({method:s.method,args:y.splice(1)});o=o.replace(y[0],"");break}if(q==(u-1)){throw'Invalid ComponentQuery selector: "'+arguments[0]+'"'}}}if(x[1]){n.push({mode:x[2]||x[1]});o=o.replace(x[0],"")}}return new g.Query({operations:n})}})};Ext.PluginMgr=new Ext.AbstractManager({typeName:"ptype",create:function(b,c){var a=this.types[b.ptype||c];if(a.init){return a}else{return new a(b)}},findByType:function(c,f){var e=[],b=this.types;for(var a in b){if(!b.hasOwnProperty(a)){continue}var d=b[a];if(d.type==c&&(!f||(f===true&&d.isDefault))){e.push(d)}}return e}});Ext.preg=function(){return Ext.PluginMgr.registerType.apply(Ext.PluginMgr,arguments)};Ext.EventManager={optionsRe:/^(?:capture|scope|delay|buffer|single|stopEvent|disableLocking|preventDefault|stopPropagation|normalized|args|delegate|horizontal|vertical|dragThresho
 ld|holdThreshold|doubleTapThreshold|cancelThreshold|singleTapThreshold|fireClickEvent)$/,touchRe:/^(?:pinch|pinchstart|pinchend|tap|singletap|doubletap|swipe|swipeleft|swiperight|drag|dragstart|dragend|touchdown|touchstart|touchmove|touchend|taphold|tapstart|tapcancel)$/i,addListener:function(b,a,e,d,g){if(Ext.isObject(a)){this.handleListenerConfig(b,a);return}var f=Ext.getDom(b);if(!f){throw'Error listening for "'+a+'". Element "'+b+"\" doesn't exist."}if(!e){throw'Error listening for "'+a+'". No handler function specified'}var h=this.touchRe.test(a);var c=this.createListenerWrap(f,a,e,d,g,h);this.getEventListenerCache(f,a).push({fn:e,wrap:c,scope:d});if(h){Ext.gesture.Manager.addEventListener(f,a,c,g)}else{g=g||{};f.addEventListener(a,c,g.capture||false)}},removeListener:function(g,k,l,m){if(Ext.isObject(k)){this.handleListenerConfig(g,k,true);return}var e=Ext.getDom(g),a=this.getEventListenerCache(e,k),h=a.length,f,c,b,d;while(h--){c=a[h];if(c&&(!l||c.fn==l)&&(!m||c.scope
 ===m)){b=c.wrap;if(b.task){clearTimeout(b.task);delete b.task}f=b.tasks&&b.tasks.length;if(f){while(f--){clearTimeout(b.tasks[f])}delete b.tasks}if(this.touchRe.test(k)){Ext.gesture.Manager.removeEventListener(e,k,b)}else{e.removeEventListener(k,b,false)}a.splice(h,1)}}},removeAll:function(b){var d=Ext.getDom(b),a=this.getElementEventCache(d),c;for(c in a){if(!a.hasOwnProperty(c)){continue}this.removeListener(d,c)}Ext.cache[d.id].events={}},purgeElement:function(d,e,b){var f=Ext.getDom(d),c=0,a;if(b){this.removeListener(f,b)}else{this.removeAll(f)}if(e&&f&&f.childNodes){for(a=d.childNodes.length;c<a;c++){this.purgeElement(d.childNodes[c],e,b)}}},handleListenerConfig:function(d,b,a){var c,e;for(c in b){if(!b.hasOwnProperty(c)){continue}if(!this.optionsRe.test(c)){e=b[c];if(Ext.isFunction(e)){this[(a?"remove":"add")+"Listener"](d,c,e,b.scope,b)}else{this[(a?"remove":"add")+"Listener"](d,c,b.fn,b.scope,b)}}}},getId:function(a){var b=false,c;a=Ext.getDom(a);if(a===document||a===
 window){b=true}c=Ext.id(a);if(!Ext.cache[c]){Ext.Element.addToCache(new Ext.Element(a),c);if(b){Ext.cache[c].skipGarbageCollection=true}}return c},createListenerWrap:function(h,a,c,b,g,i){g=!Ext.isObject(g)?{}:g;var d=["if(!window.Ext) {return;}"];if(i){d.push("e = new Ext.TouchEventObjectImpl(e, args);")}else{if(g.buffer||g.delay){d.push("e = new Ext.EventObjectImpl(e);")}else{d.push("e = Ext.EventObject.setEvent(e);")}}if(g.delegate){d.push('var t = e.getTarget("'+g.delegate+'", this);');d.push("if(!t) {return;}")}else{d.push("var t = e.target;")}if(g.target){d.push("if(e.target !== o.target) {return;}")}if(g.stopEvent){d.push("e.stopEvent();")}else{if(g.preventDefault){d.push("e.preventDefault();")}if(g.stopPropagation){d.push("e.stopPropagation();")}}if(g.normalized===false){d.push("e = e.browserEvent;")}if(g.buffer){d.push("(wrap.task && clearTimeout(wrap.task));");d.push("wrap.task = setTimeout(function(){")}if(g.delay){d.push("wrap.tasks = wrap.tasks || [];");d.push("
 wrap.tasks.push(setTimeout(function(){")}d.push("fn.call(scope || dom, e, t, o);");if(g.single){d.push("Ext.EventManager.removeListener(dom, ename, fn, scope);")}if(g.delay){d.push("}, "+g.delay+"));")}if(g.buffer){d.push("}, "+g.buffer+");")}var e=new Function("e","o","fn","scope","ename","dom","wrap","args",d.join("\n"));return function(j,f){e.call(h,j,g,c,b,a,h,arguments.callee,f)}},getEventListenerCache:function(c,a){var b=this.getElementEventCache(c);return b[a]||(b[a]=[])},getElementEventCache:function(b){var a=Ext.cache[this.getId(b)];return a.events||(a.events={})},onDocumentReady:function(d,c,b){var f=this,g=f.readyEvent,e;if(Ext.isReady){g||(g=new Ext.util.Event());g.addListener(d,c,b);g.fire();g.listeners=[]}else{if(!g){g=f.readyEvent=new Ext.util.Event();var a=function(){Ext.isReady=true;window.removeEventListener("load",arguments.callee,false);if(e){clearInterval(e)}setTimeout(function(){Ext.supports.init();Ext.gesture.Manager.init();Ext.orientation=Ext.Element.
 getOrientation();g.fire({orientation:Ext.orientation,width:Ext.Element.getViewportWidth(),height:Ext.Element.getViewportHeight()});g.listeners=[]},50)};e=setInterval(function(){if(/loaded|complete/.test(document.readyState)){clearInterval(e);e=null;a()}},10);window.addEventListener("load",a,false)}b=b||{};b.delay=b.delay||1;g.addListener(d,c,b)}},onWindowResize:function(c,b,a){var e=this,f=e.resizeEvent;if(!f){e.resizeEvent=f=new Ext.util.Event();var d=function(){f.fire(Ext.Element.getViewportWidth(),Ext.Element.getViewportHeight())};this.addListener(window,"resize",d,this)}f.addListener(c,b,a)},onOrientationChange:function(c,b,a){var e=this,d=e.orientationEvent;if(!d){e.orientationEvent=d=new Ext.util.Event();var f=function(g,h){Ext.orientation=Ext.Viewport.getOrientation();d.fire(Ext.orientation,h.width,h.height)};Ext.Viewport.on("resize",f,this)}d.addListener(c,b,a)},unOrientationChange:function(c,b,a){var e=this,d=e.orientationEvent;if(d){d.removeListener(c,b,a)}}};Ext.E
 ventManager.on=Ext.EventManager.addListener;Ext.EventManager.un=Ext.EventManager.removeListener;Ext.onReady=Ext.EventManager.onDocumentReady;Ext.EventObjectImpl=Ext.extend(Object,{constructor:function(a){if(a){this.setEvent(a.browserEvent||a)}},setEvent:function(c){var b=this;if(c==b||(c&&c.browserEvent)){return c}b.browserEvent=c;if(c){b.type=c.type;var a=c.target;b.target=a&&a.nodeType==3?a.parentNode:a;b.xy=[c.pageX,c.pageY];b.timestamp=c.timeStamp}else{b.target=null;b.xy=[0,0]}return b},stopEvent:function(){this.stopPropagation();this.preventDefault()},preventDefault:function(){if(this.browserEvent){this.browserEvent.preventDefault()}},stopPropagation:function(){if(this.browserEvent){this.browserEvent.stopPropagation()}},getPageX:function(){return this.xy[0]},getPageY:function(){return this.xy[1]},getXY:function(){return this.xy},getTarget:function(b,c,a){return b?Ext.fly(this.target).findParent(b,c,a):(a?Ext.get(this.target):this.target)},getTime:function(){return this.
 timestamp}});Ext.EventObject=new Ext.EventObjectImpl();Ext.is={init:function(b){var c=this.platforms,e=c.length,d,a;b=b||window.navigator;for(d=0;d<e;d++){a=c[d];this[a.identity]=a.regex.test(b[a.property])}this.Desktop=this.Mac||this.Windows||(this.Linux&&!this.Android);this.Tablet=this.iPad;this.Phone=!this.Desktop&&!this.Tablet;this.iOS=this.iPhone||this.iPad||this.iPod;this.Standalone=!!window.navigator.standalone},platforms:[{property:"platform",regex:/iPhone/i,identity:"iPhone"},{property:"platform",regex:/iPod/i,identity:"iPod"},{property:"userAgent",regex:/iPad/i,identity:"iPad"},{property:"userAgent",regex:/Blackberry/i,identity:"Blackberry"},{property:"userAgent",regex:/Android/i,identity:"Android"},{property:"platform",regex:/Mac/i,identity:"Mac"},{property:"platform",regex:/Win/i,identity:"Windows"},{property:"platform",regex:/Linux/i,identity:"Linux"}]};Ext.is.init();Ext.supports={init:function(){var d=document,f=d.createElement("div"),b=this.tests,c=b.length,a,
 e;f.innerHTML=['<div style="height:30px;width:50px;">','<div style="height:20px;width:20px;"></div>',"</div>",'<div style="float:left; background-color:transparent;"></div>'].join("");d.body.appendChild(f);for(a=0;a<c;a++){e=b[a];this[e.identity]=e.fn.call(this,d,f)}d.body.removeChild(f)},OrientationChange:((typeof window.orientation!="undefined")&&("onorientationchange" in window)),DeviceMotion:("ondevicemotion" in window),Touch:("ontouchstart" in window)&&(!Ext.is.Desktop),tests:[{identity:"Transitions",fn:function(f,h){var e=["webkit","Moz","o","ms","khtml"],g="TransitionEnd",a=[e[0]+g,"transitionend",e[2]+g,e[3]+g,e[4]+g],d=e.length,c=0,b=false;h=Ext.get(h);for(;c<d;c++){if(h.getStyle(e[c]+"TransitionProperty")){Ext.supports.CSS3Prefix=e[c];Ext.supports.CSS3TransitionEnd=a[c];b=true;break}}return b}},{identity:"RightMargin",fn:function(b,c,a){a=b.defaultView;return !(a&&a.getComputedStyle(c.firstChild.firstChild,null).marginRight!="0px")}},{identity:"TransparentColor",fn
 :function(b,c,a){a=b.defaultView;return !(a&&a.getComputedStyle(c.lastChild,null).backgroundColor!="transparent")}},{identity:"SVG",fn:function(a){return !!a.createElementNS&&!!a.createElementNS("http://www.w3.org/2000/svg","svg").createSVGRect}},{identity:"Canvas",fn:function(a){return !!a.createElement("canvas").getContext}},{identity:"VML",fn:function(a){var b=a.createElement("div");b.innerHTML="<!--[if vml]><br><br><![endif]-->";return(b.childNodes.length==2)}},{identity:"Float",fn:function(a,b){return !!b.lastChild.style.cssFloat}},{identity:"AudioTag",fn:function(a){return !!a.createElement("audio").canPlayType}},{identity:"History",fn:function(){return !!(window.history&&history.pushState)}},{identity:"CSS3DTransform",fn:function(){return(typeof WebKitCSSMatrix!="undefined"&&new WebKitCSSMatrix().hasOwnProperty("m41"))}},{identity:"CSS3LinearGradient",fn:function(e,g){var d="background-image:",b="-webkit-gradient(linear, left top, right bottom, from(black), to(white))
 ",f="linear-gradient(left top, black, white)",c="-moz-"+f,a=[d+b,d+f,d+c];g.style.cssText=a.join(";");return(""+g.style.backgroundImage).indexOf("gradient")!==-1}},{identity:"CSS3BorderRadius",fn:function(d,e){var b=["borderRadius","BorderRadius","MozBorderRadius","WebkitBorderRadius","OBorderRadius","KhtmlBorderRadius"],c=false,a;for(a=0;a<b.length;a++){if(document.body.style[b[a]]!==undefined){return c=true}}return c}},{identity:"GeoLocation",fn:function(){return(typeof navigator!="undefined"&&typeof navigator.geolocation!="undefined")||(typeof google!="undefined"&&typeof google.gears!="undefined")}}]};Ext.data.Batch=Ext.extend(Ext.util.Observable,{autoStart:false,current:-1,total:0,isRunning:false,isComplete:false,hasException:false,pauseOnException:true,constructor:function(a){this.addEvents("complete","exception","operationcomplete","operation-complete");Ext.data.Batch.superclass.constructor.call(this,a);this.operations=[]},add:function(a){this.total++;a.setBatch(this);
 this.operations.push(a)},start:function(){this.hasException=false;this.isRunning=true;this.runNextOperation()},runNextOperation:function(){this.runOperation(this.current+1)},pause:function(){this.isRunning=false},runOperation:function(d){var c=this.operations,b=c[d];if(b==undefined){this.isRunning=false;this.isComplete=true;this.fireEvent("complete",this,c[c.length-1])}else{this.current=d;var a=function(e){var f=e.hasException();if(f){this.hasException=true;this.fireEvent("exception",this,e)}else{this.fireEvent("operation-complete",this,e);this.fireEvent("operationcomplete",this,e)}if(f&&this.pauseOnException){this.pause()}else{e.setCompleted();this.runNextOperation()}};b.setStarted();this.proxy[b.action](b,a,this)}}});Ext.data.Model=Ext.extend(Ext.util.Stateful,{evented:false,isModel:true,phantom:false,idProperty:"id",constructor:function(e,g){e=e||{};this.internalId=(g||g===0)?g:Ext.data.Model.id(this);Ext.data.Model.superclass.constructor.apply(this);var a=this.fields.ite
 ms,d=a.length,f,b,c;for(c=0;c<d;c++){f=a[c];b=f.name;if(e[b]==undefined){e[b]=f.defaultValue}}this.set(e);this.dirty=false;if(this.getId()){this.phantom=false}if(typeof this.init=="function"){this.init()}},validate:function(){var j=new Ext.data.Errors(),c=this.validations,e=Ext.data.validations,b,d,h,a,g,f;if(c){b=c.length;for(f=0;f<b;f++){d=c[f];h=d.field||d.name;g=d.type;a=e[g](d,this.get(h));if(!a){j.add({field:h,message:d.message||e[g+"Message"]})}}}return j},getProxy:function(){return this.constructor.proxy},save:function(j){var f=this,a=f.phantom?"create":"update";j=j||{};Ext.apply(j,{records:[f],action:a});var b=new Ext.data.Operation(j),h=j.success,d=j.failure,e=j.callback,i=j.scope,c;var g=function(k){c=k.getRecords()[0];if(k.wasSuccessful()){f.set(c.data);c.dirty=false;if(typeof h=="function"){h.call(i,c,k)}}else{if(typeof d=="function"){d.call(i,c,k)}}if(typeof e=="function"){e.call(i,c,k)}};f.getProxy()[a](b,g,f);return f},getId:function(){return this.get(this.id
 Property)},setId:function(a){this.set(this.idProperty,a)},join:function(a){this.store=a},unjoin:function(a){delete this.store},afterEdit:function(){this.callStore("afterEdit")},afterReject:function(){this.callStore("afterReject")},afterCommit:function(){this.callStore("afterCommit")},callStore:function(b){var a=this.store;if(a!=undefined&&typeof a[b]=="function"){a[b](this)}}});Ext.apply(Ext.data.Model,{setProxy:function(a){a=Ext.data.ProxyMgr.create(a);a.setModel(this);this.proxy=a;return a},load:function(a,b){b=Ext.applyIf(b||{},{action:"read",id:a});var c=new Ext.data.Operation(b),f=b.callback,h=b.success,e=b.failure,i=b.scope,d,g;g=function(j){d=j.getRecords()[0];if(j.wasSuccessful()){if(typeof h=="function"){h.call(i,d,j)}}else{if(typeof e=="function"){e.call(i,d,j)}}if(typeof f=="function"){f.call(i,d,j)}};this.proxy.read(c,g,this)}});Ext.data.Model.id=function(a){a.phantom=true;return[Ext.data.Model.PREFIX,"-",Ext.data.Model.AUTO_ID++].join("")};Ext.ns("Ext.data.Recor
 d");Ext.data.Record.id=Ext.data.Model.id;Ext.data.Model.PREFIX="ext-record";Ext.data.Model.AUTO_ID=1;Ext.data.Model.EDIT="edit";Ext.data.Model.REJECT="reject";Ext.data.Model.COMMIT="commit";Ext.data.Association=Ext.extend(Object,{primaryKey:"id",constructor:function(b){Ext.apply(this,b);var c=Ext.ModelMgr.types,d=b.ownerModel,f=b.associatedModel,e=c[d],g=c[f],a;if(e==undefined){throw new Error("The configured ownerModel was not valid (you tried "+d+")")}if(g==undefined){throw new Error("The configured associatedModel was not valid (you tried "+f+")")}this.ownerModel=e;this.associatedModel=g;Ext.applyIf(this,{ownerName:d,associatedName:f})}});Ext.data.HasManyAssociation=Ext.extend(Ext.data.Association,{constructor:function(c){Ext.data.HasManyAssociation.superclass.constructor.apply(this,arguments);var a=this.ownerModel.prototype,b=this.name;Ext.applyIf(this,{storeName:b+"Store",foreignKey:this.ownerName.toLowerCase()+"_id"});a[b]=this.createStore()},createStore:function(){var
  f=this.associatedModel,b=this.storeName,c=this.foreignKey,a=this.primaryKey,e=this.filterProperty,d=this.storeConfig||{};return function(){var j=this,h,i,g={};if(j[b]==undefined){if(e){i={property:e,value:j.get(e),exactMatch:true}}else{i={property:c,value:j.get(a),exactMatch:true}}g[c]=j.get(a);h=Ext.apply({},d,{model:f,filters:[i],remoteFilter:false,modelDefaults:g});j[b]=new Ext.data.Store(h)}return j[b]}}});Ext.data.BelongsToAssociation=Ext.extend(Ext.data.Association,{constructor:function(c){Ext.data.BelongsToAssociation.superclass.constructor.apply(this,arguments);var e=this,a=e.ownerModel.prototype,f=e.associatedName,d=e.getterName||"get"+f,b=e.setterName||"set"+f;Ext.applyIf(e,{name:f,foreignKey:f.toLowerCase()+"_id",instanceName:f+"BelongsToInstance"});a[d]=e.createGetter();a[b]=e.createSetter()},createSetter:function(){var c=this,d=c.ownerModel,e=c.associatedModel,b=c.foreignKey,a=c.primaryKey;return function(h,f,g){this.set(b,h);if(typeof f=="function"){f={callbac
 k:f,scope:g||this}}if(Ext.isObject(f)){return this.save(f)}}},createGetter:function(){var d=this,f=d.ownerModel,e=d.associatedName,g=d.associatedModel,c=d.foreignKey,b=d.primaryKey,a=d.instanceName;return function(j,k){j=j||{};var l=this.get(c),h,i;if(this[a]==undefined){h=Ext.ModelMgr.create({},e);h.set(b,l);if(typeof j=="function"){j={callback:j,scope:k||this}}g.load(l,j)}else{h=this[a];if(typeof j=="function"){j.call(k||this,h)}if(j.success){j.success.call(k||this,h)}if(j.callback){j.callback.call(k||this,h)}return h}}}});Ext.data.PolymorphicAssociation=Ext.extend(Ext.data.Association,{constructor:function(c){Ext.data.PolymorphicAssociation.superclass.constructor.call(this,c);var a=this.ownerModel.prototype,b=this.name;Ext.applyIf(this,{associationIdField:this.ownerName.toLowerCase()+"_id"});a[b]=this.createStore()},createStore:function(){var b=this,f=this.ownerName,d=this.name+"Store",g=this.associatedModel,c=this.primaryKey,a="associated_id",e="associated_model";return
 function(){var k=this,h={},i,j;if(k[d]==undefined){j=[{property:a,value:k.get(c),exactMatch:true},{property:e,value:f,exactMatch:true}];h[a]=k.get(c);h[e]=f;i=Ext.apply({},b.storeConfig||{},{model:g,filters:j,remoteFilter:false,modelDefaults:h});k[d]=new Ext.data.Store(i)}return k[d]}}});Ext.data.validations={presenceMessage:"must be present",lengthMessage:"is the wrong length",formatMessage:"is the wrong format",inclusionMessage:"is not included in the list of acceptable values",exclusionMessage:"is not an acceptable value",presence:function(a,b){if(b==undefined){b=a}return !!b},length:function(b,e){if(e==undefined){return false}var d=e.length,c=b.min,a=b.max;if((c&&d<c)||(a&&d>a)){return false}else{return true}},format:function(a,b){return !!(a.matcher&&a.matcher.test(b))},inclusion:function(a,b){return a.list&&a.list.indexOf(b)!=-1},exclusion:function(a,b){return a.list&&a.list.indexOf(b)==-1}};Ext.data.Errors=Ext.extend(Ext.util.MixedCollection,{isValid:function(){return
  this.length==0},getByField:function(e){var d=[],a,c,b;for(b=0;b<this.length;b++){a=this.items[b];if(a.field==e){d.push(a)}}return d}});Ext.data.Field=Ext.extend(Object,{constructor:function(b){if(Ext.isString(b)){b={name:b}}Ext.apply(this,b);var d=Ext.data.Types,a=this.sortType,c;if(this.type){if(Ext.isString(this.type)){this.type=d[this.type.toUpperCase()]||d.AUTO}}else{this.type=d.AUTO}if(Ext.isString(a)){this.sortType=Ext.data.SortTypes[a]}else{if(Ext.isEmpty(a)){this.sortType=this.type.sortType}}if(!this.convert){this.convert=this.type.convert}},dateFormat:null,useNull:false,defaultValue:"",mapping:null,sortType:null,sortDir:"ASC",allowBlank:true});Ext.data.SortTypes={none:function(a){return a},stripTagsRE:/<\/?[^>]+>/gi,asText:function(a){return String(a).replace(this.stripTagsRE,"")},asUCText:function(a){return String(a).toUpperCase().replace(this.stripTagsRE,"")},asUCString:function(a){return String(a).toUpperCase()},asDate:function(a){if(!a){return 0}if(Ext.isDate(a
 )){return a.getTime()}return Date.parse(String(a))},asFloat:function(a){var b=parseFloat(String(a).replace(/,/g,""));return isNaN(b)?0:b},asInt:function(a){var b=parseInt(String(a).replace(/,/g,""),10);return isNaN(b)?0:b}};Ext.data.Types=new function(){var a=Ext.data.SortTypes;Ext.apply(this,{stripRe:/[\$,%]/g,AUTO:{convert:function(b){return b},sortType:a.none,type:"auto"},STRING:{convert:function(b){return(b===undefined||b===null)?"":String(b)},sortType:a.asUCString,type:"string"},INT:{convert:function(b){return b!==undefined&&b!==null&&b!==""?parseInt(String(b).replace(Ext.data.Types.stripRe,""),10):(this.useNull?null:0)},sortType:a.none,type:"int"},FLOAT:{convert:function(b){return b!==undefined&&b!==null&&b!==""?parseFloat(String(b).replace(Ext.data.Types.stripRe,""),10):(this.useNull?null:0)},sortType:a.none,type:"float"},BOOL:{convert:function(b){return b===true||b==="true"||b==1},sortType:a.none,type:"bool"},DATE:{convert:function(c){var d=this.dateFormat;if(!c){ret
 urn null}if(Ext.isDate(c)){return c}if(d){if(d=="timestamp"){return new Date(c*1000)}if(d=="time"){return new Date(parseInt(c,10))}return Date.parseDate(c,d)}var b=Date.parse(c);return b?new Date(b):null},sortType:a.asDate,type:"date"}});Ext.apply(this,{BOOLEAN:this.BOOL,INTEGER:this.INT,NUMBER:this.FLOAT})};Ext.ModelMgr=new Ext.AbstractManager({typeName:"mtype",defaultProxyType:"ajax",associationStack:[],registerType:function(t,s){var e=Ext.PluginMgr,l=e.findByType("model",true),k=s.fields||[],p=s.associations||[],o=s.belongsTo,h=s.hasMany,q=s.extend,j=s.plugins||[],b,c,d,n,f,a,g,m;if(o){if(!Ext.isArray(o)){o=[o]}for(n=0;n<o.length;n++){b=o[n];if(!Ext.isObject(b)){b={model:b}}Ext.apply(b,{type:"belongsTo"});p.push(b)}delete s.belongsTo}if(h){if(!Ext.isArray(h)){h=[h]}for(n=0;n<h.length;n++){b=h[n];if(!Ext.isObject(b)){b={model:b}}Ext.apply(b,{type:"hasMany"});p.push(b)}delete s.hasMany}if(q){f=this.types[q];a=f.prototype;g=a.validations;m=f.proxy;k=a.fields.items.concat(k);
 p=a.associations.items.concat(p);s.validations=g?g.concat(s.validations):s.validations}else{f=Ext.data.Model;m=s.proxy}c=Ext.extend(f,s);for(n=0,d=j.length;n<d;n++){l.push(e.create(j[n]))}this.types[t]=c;Ext.override(c,{plugins:l,fields:this.createFields(k),associations:this.createAssociations(p,t)});c.modelName=t;Ext.data.Model.setProxy.call(c,m||this.defaultProxyType);c.getProxy=c.prototype.getProxy;c.load=function(){Ext.data.Model.load.apply(this,arguments)};for(n=0,d=l.length;n<d;n++){l[n].bootstrap(c,s)}c.defined=true;this.onModelDefined(c);return c},onModelDefined:function(c){var a=this.associationStack,f=a.length,e=[],b,d;for(d=0;d<f;d++){b=a[d];if(b.associatedModel==c.modelName){e.push(b)}}f=e.length;for(d=0;d<f;d++){this.addAssociation(e[d],this.types[e[d].ownerModel].prototype.associations);a.remove(e[d])}},createAssociations:function(e,b){var f=e.length,d,c,a;c=new Ext.util.MixedCollection(false,function(g){return g.name});for(d=0;d<f;d++){a=e[d];Ext.apply(a,{owne
 rModel:b,associatedModel:a.model});if(this.types[a.model]==undefined){this.associationStack.push(a)}else{this.addAssociation(a,c)}}return c},addAssociation:function(a,b){var c=a.type;if(c=="belongsTo"){b.add(new Ext.data.BelongsToAssociation(a))}if(c=="hasMany"){b.add(new Ext.data.HasManyAssociation(a))}if(c=="polymorphic"){b.add(new Ext.data.PolymorphicAssociation(a))}},createFields:function(a){var d=a.length,c,b;b=new Ext.util.MixedCollection(false,function(e){return e.name});for(c=0;c<d;c++){b.add(new Ext.data.Field(a[c]))}return b},getModel:function(b){var a=b;if(typeof a=="string"){a=this.types[a]}return a},create:function(c,b,d){var a=typeof b=="function"?b:this.types[b||c.name];return new a(c,d)}});Ext.regModel=function(){return Ext.ModelMgr.registerType.apply(Ext.ModelMgr,arguments)};Ext.data.Operation=Ext.extend(Object,{synchronous:true,action:undefined,filters:undefined,sorters:undefined,group:undefined,start:undefined,limit:undefined,batch:undefined,started:false,
 running:false,complete:false,success:undefined,exception:false,error:undefined,constructor:function(a){Ext.apply(this,a||{})},setStarted:function(){this.started=true;this.running=true},setCompleted:function(){this.complete=true;this.running=false},setSuccessful:function(){this.success=true},setException:function(a){this.exception=true;this.success=false;this.running=false;this.error=a},markStarted:function(){console.warn("Operation: markStarted has been deprecated. Please use setStarted");return this.setStarted()},markCompleted:function(){console.warn("Operation: markCompleted has been deprecated. Please use setCompleted");return this.setCompleted()},markSuccessful:function(){console.warn("Operation: markSuccessful has been deprecated. Please use setSuccessful");return this.setSuccessful()},markException:function(){console.warn("Operation: markException has been deprecated. Please use setException");return this.setException()},hasException:function(){return this.exception===
 true},getError:function(){return this.error},getRecords:function(){var a=this.getResultSet();return(a==undefined?this.records:a.records)},getResultSet:function(){return this.resultSet},isStarted:function(){return this.started===true},isRunning:function(){return this.running===true},isComplete:function(){return this.complete===true},wasSuccessful:function(){return this.isComplete()&&this.success===true},setBatch:function(a){this.batch=a},allowWrite:function(){return this.action!="read"}});Ext.data.ProxyMgr=new Ext.AbstractManager({create:function(a){if(a==undefined||typeof a=="string"){a={type:a}}if(!(a instanceof Ext.data.Proxy)){Ext.applyIf(a,{type:this.defaultProxyType,model:this.model});var b=a[this.typeName]||a.type,c=this.types[b];if(c==undefined){throw new Error(Ext.util.Format.format("The '{0}' type has not been registered with this manager",b))}return new c(a)}else{return a}}});Ext.data.ReaderMgr=new Ext.AbstractManager({typeName:"rtype"});Ext.data.Request=Ext.extend
 (Object,{action:undefined,params:undefined,method:"GET",url:undefined,constructor:function(a){Ext.apply(this,a)}});Ext.data.ResultSet=Ext.extend(Object,{loaded:true,count:0,total:0,success:false,constructor:function(a){Ext.apply(this,a);this.totalRecords=this.total;if(a.count==undefined){this.count=this.records.length}}});Ext.data.AbstractStore=Ext.extend(Ext.util.Observable,{remoteSort:false,remoteFilter:false,autoLoad:false,autoSave:false,batchUpdateMode:"operation",filterOnLoad:true,sortOnLoad:true,defaultSortDirection:"ASC",implicitModel:false,defaultProxyType:"memory",isDestroyed:false,isStore:true,constructor:function(a){this.addEvents("add","remove","update","datachanged","beforeload","load","beforesync");Ext.apply(this,a);this.removed=[];this.sortToggle={};Ext.data.AbstractStore.superclass.constructor.apply(this,arguments);this.model=Ext.ModelMgr.getModel(a.model);Ext.applyIf(this,{modelDefaults:{}});if(!this.model&&a.fields){this.model=Ext.regModel("ImplicitModel-"+
 this.storeId||Ext.id(),{fields:a.fields});delete this.fields;this.implicitModel=true}this.setProxy(a.proxy||this.model.proxy);if(this.id&&!this.storeId){this.storeId=this.id;delete this.id}if(this.storeId){Ext.StoreMgr.register(this)}this.sorters=new Ext.util.MixedCollection();this.sorters.addAll(this.decodeSorters(a.sorters));this.filters=new Ext.util.MixedCollection();this.filters.addAll(this.decodeFilters(a.filters))},setProxy:function(a){if(a instanceof Ext.data.Proxy){a.setModel(this.model)}else{Ext.applyIf(a,{model:this.model});a=Ext.data.ProxyMgr.create(a)}this.proxy=a;return this.proxy},getProxy:function(){return this.proxy},create:function(d,c){var a=Ext.ModelMgr.create(Ext.applyIf(d,this.modelDefaults),this.model.modelName),b;c=c||{};Ext.applyIf(c,{action:"create",records:[a]});b=new Ext.data.Operation(c);this.proxy.create(b,this.onProxyWrite,this);return a},read:function(){return this.load.apply(this,arguments)},onProxyRead:Ext.emptyFn,update:function(b){b=b||{};E
 xt.applyIf(b,{action:"update",records:this.getUpdatedRecords()});var a=new Ext.data.Operation(b);return this.proxy.update(a,this.onProxyWrite,this)},onProxyWrite:Ext.emptyFn,destroy:function(b){b=b||{};Ext.applyIf(b,{action:"destroy",records:this.getRemovedRecords()});var a=new Ext.data.Operation(b);return this.proxy.destroy(a,this.onProxyWrite,this)},onBatchOperationComplete:function(b,a){return this.onProxyWrite(a)},onBatchComplete:function(c,a){var b=c.operations,e=b.length,d;this.suspendEvents();for(d=0;d<e;d++){this.onProxyWrite(b[d])}this.resumeEvents();this.fireEvent("datachanged",this)},onBatchException:function(b,a){},filterNew:function(a){return a.phantom==true||a.needsAdd==true},getNewRecords:function(){return[]},getUpdatedRecords:function(){return[]},filterDirty:function(a){return a.dirty==true},getRemovedRecords:function(){return this.removed},sort:function(b,a){},decodeSorters:function(d){if(!Ext.isArray(d)){if(d==undefined){d=[]}else{d=[d]}}var c=d.length,e=Ex
 t.util.Sorter,a,b;for(b=0;b<c;b++){a=d[b];if(!(a instanceof e)){if(Ext.isString(a)){a={property:a}}Ext.applyIf(a,{root:"data",direction:"ASC"});if(a.fn){a.sorterFn=a.fn}if(typeof a=="function"){a={sorterFn:a}}d[b]=new e(a)}}return d},filter:function(a,b){},createSortFunction:function(d,c){c=c||"ASC";var b=c.toUpperCase()=="DESC"?-1:1;var a=this.model.prototype.fields,e=a.get(d).sortType;return function(g,f){var i=e(g.data[d]),h=e(f.data[d]);return b*(i>h?1:(i<h?-1:0))}},decodeFilters:function(e){if(!Ext.isArray(e)){if(e==undefined){e=[]}else{e=[e]}}var d=e.length,a=Ext.util.Filter,b,c;for(c=0;c<d;c++){b=e[c];if(!(b instanceof a)){Ext.apply(b,{root:"data"});if(b.fn){b.filterFn=b.fn}if(typeof b=="function"){b={filterFn:b}}e[c]=new a(b)}}return e},clearFilter:function(a){},isFiltered:function(){},filterBy:function(b,a){},sync:function(){var d=this,b={},e=d.getNewRecords(),c=d.getUpdatedRecords(),a=d.getRemovedRecords(),f=false;if(e.length>0){b.create=e;f=true}if(c.length>0){b.u
 pdate=c;f=true}if(a.length>0){b.destroy=a;f=true}if(f&&d.fireEvent("beforesync",b)!==false){d.proxy.batch(b,d.getBatchListeners())}},getBatchListeners:function(){var a={scope:this,exception:this.onBatchException};if(this.batchUpdateMode=="operation"){a.operationcomplete=this.onBatchOperationComplete}else{a.complete=this.onBatchComplete}return a},save:function(){return this.sync.apply(this,arguments)},load:function(b){var c=this,a;b=b||{};Ext.applyIf(b,{action:"read",filters:c.filters.items,sorters:c.sorters.items});a=new Ext.data.Operation(b);if(c.fireEvent("beforeload",c,a)!==false){c.loading=true;c.proxy.read(a,c.onProxyLoad,c)}return c},afterEdit:function(a){this.fireEvent("update",this,a,Ext.data.Model.EDIT)},afterReject:function(a){this.fireEvent("update",this,a,Ext.data.Model.REJECT)},afterCommit:function(a){if(this.autoSave){this.sync()}this.fireEvent("update",this,a,Ext.data.Model.COMMIT)},clearData:Ext.emptyFn,destroyStore:function(){if(!this.isDestroyed){if(this.st
 oreId){Ext.StoreMgr.unregister(this)}this.clearData();this.data=null;this.tree=null;this.reader=this.writer=null;this.clearListeners();this.isDestroyed=true;if(this.implicitModel){Ext.destroy(this.model)}}},getSortState:function(){return this.sortInfo},getCount:function(){},getById:function(a){},removeAll:function(){}});Ext.data.Store=Ext.extend(Ext.data.AbstractStore,{remoteSort:false,remoteFilter:false,groupField:undefined,groupDir:"ASC",pageSize:25,currentPage:1,clearOnPageLoad:true,implicitModel:false,loading:false,sortOnFilter:true,isStore:true,constructor:function(a){a=a||{};this.data=new Ext.util.MixedCollection(false,function(d){return d.internalId});if(a.data){this.inlineData=a.data;delete a.data}Ext.data.Store.superclass.constructor.call(this,a);var b=this.proxy,c=this.inlineData;if(c){if(b instanceof Ext.data.MemoryProxy){b.data=c;this.read()}else{this.add.apply(this,c)}this.sort();delete this.inlineData}else{if(this.autoLoad){Ext.defer(this.load,10,this,[typeof t
 his.autoLoad=="object"?this.autoLoad:undefined])}}},getGroups:function(){var d=this.data.items,f=d.length,a=[],c={},b,g,h,e;for(e=0;e<f;e++){b=d[e];g=this.getGroupString(b);h=c[g];if(h==undefined){h={name:g,children:[]};a.push(h);c[g]=h}h.children.push(b)}return a},getGroupString:function(a){return a.get(this.groupField)},first:function(){return this.data.first()},last:function(){return this.data.last()},insert:function(d,c){var e,b,a;c=[].concat(c);for(e=0,a=c.length;e<a;e++){b=this.createModel(c[e]);b.set(this.modelDefaults);this.data.insert(d+e,b);b.join(this)}if(this.snapshot){this.snapshot.addAll(c)}this.fireEvent("add",this,c,d);this.fireEvent("datachanged",this)},add:function(b){if(!Ext.isArray(b)){b=Array.prototype.slice.apply(arguments)}var d=b.length,a,c;for(c=0;c<d;c++){a=this.createModel(b[c]);if(a.phantom==false){a.needsAdd=true}b[c]=a}this.insert(this.data.length,b);return b},createModel:function(a){if(!(a instanceof Ext.data.Model)){a=Ext.ModelMgr.create(a,thi
 s.model)}return a},each:function(b,a){this.data.each(b,a)},remove:function(b){if(!Ext.isArray(b)){b=[b]}var e=b.length,d,c,a;for(d=0;d<e;d++){a=b[d];c=this.data.indexOf(a);if(c>-1){this.removed.push(a);if(this.snapshot){this.snapshot.remove(a)}a.unjoin(this);this.data.remove(a);this.fireEvent("remove",this,a,c)}}this.fireEvent("datachanged",this)},removeAt:function(b){var a=this.getAt(b);if(a){this.remove(a)}},load:function(a){a=a||{};if(Ext.isFunction(a)){a={callback:a}}Ext.applyIf(a,{group:{field:this.groupField,direction:this.groupDir},start:0,limit:this.pageSize,addRecords:false});return Ext.data.Store.superclass.load.call(this,a)},isLoading:function(){return this.loading},onProxyLoad:function(b){var a=b.getRecords();this.loadRecords(a,b.addRecords);this.loading=false;this.fireEvent("load",this,a,b.wasSuccessful());this.fireEvent("read",this,a,b.wasSuccessful());var c=b.callback;if(typeof c=="function"){c.call(b.scope||this,a,b,b.wasSuccessful())}},onProxyWrite:function(
 c){var g=this.data,f=c.action,b=c.getRecords(),e=b.length,h=c.callback,a,d;if(c.wasSuccessful()){if(f=="create"||f=="update"){for(d=0;d<e;d++){a=b[d];a.phantom=false;a.join(this);g.replace(a)}}else{if(f=="destroy"){for(d=0;d<e;d++){a=b[d];a.unjoin(this);g.remove(a)}this.removed=[]}}this.fireEvent("datachanged")}if(typeof h=="function"){h.call(c.scope||this,b,c,c.wasSuccessful())}},getNewRecords:function(){return this.data.filterBy(this.filterNew).items},getUpdatedRecords:function(){return this.data.filterBy(this.filterDirty).items},sort:function(e,d){if(Ext.isString(e)){var c=e,b=this.sortToggle,a=Ext.util.Format.toggle;if(d==undefined){b[c]=a(b[c]||"","ASC","DESC");d=b[c]}e={property:c,direction:d}}if(arguments.length!=0){this.sorters.clear()}this.sorters.addAll(this.decodeSorters(e));if(this.remoteSort){this.load()}else{this.data.sort(this.sorters.items);this.fireEvent("datachanged",this)}},filter:function(a,b){if(Ext.isString(a)){a={property:a,value:b}}this.filters.addAll
 (this.decodeFilters(a));if(this.remoteFilter){this.load()}else{this.snapshot=this.snapshot||this.data.clone();this.data=this.data.filter(this.filters.items);if(this.sortOnFilter&&!this.remoteSort){this.sort()}else{this.fireEvent("datachanged",this)}}},clearFilter:function(a){this.filters.clear();if(this.isFiltered()){this.data=this.snapshot.clone();delete this.snapshot;if(a!==true){this.fireEvent("datachanged",this)}}},isFiltered:function(){return !!this.snapshot&&this.snapshot!=this.data},filterBy:function(b,a){this.snapshot=this.snapshot||this.data.clone();this.data=this.queryBy(b,a||this);this.fireEvent("datachanged",this)},queryBy:function(b,a){var c=this.snapshot||this.data;return c.filterBy(b,a||this)},loadData:function(f,a){var c=this.model,e=f.length,d,b;for(d=0;d<e;d++){b=f[d];if(!(b instanceof Ext.data.Model)){f[d]=Ext.ModelMgr.create(b,c)}}this.loadRecords(f,a)},loadRecords:function(a,d){if(!d){this.data.clear()}this.data.addAll(a);for(var b=0,c=a.length;b<c;b++){
 a[b].needsAdd=false;a[b].join(this)}this.suspendEvents();if(this.filterOnLoad&&!this.remoteFilter){this.filter()}if(this.sortOnLoad&&!this.remoteSort){this.sort()}this.resumeEvents();this.fireEvent("datachanged",this,a)},loadPage:function(a){this.currentPage=a;this.read({page:a,start:(a-1)*this.pageSize,limit:this.pageSize,addRecords:!this.clearOnPageLoad})},nextPage:function(){this.loadPage(this.currentPage+1)},previousPage:function(){this.loadPage(this.currentPage-1)},clearData:function(){this.data.each(function(a){a.unjoin()});this.data.clear()},find:function(e,d,g,f,a,c){var b=this.createFilterFn(e,d,f,a,c);return b?this.data.findIndexBy(b,null,g):-1},findRecord:function(){var a=this.find.apply(this,arguments);return a!=-1?this.getAt(a):null},createFilterFn:function(d,c,e,a,b){if(Ext.isEmpty(c)){return false}c=this.data.createValueMatcher(c,e,a,b);return function(f){return c.test(f.data[d])}},findExact:function(b,a,c){return this.data.findIndexBy(function(d){return d.get
 (b)===a},this,c)},findBy:function(b,a,c){return this.data.findIndexBy(b,a,c)},collect:function(f,g,a){var k=[],h={},b,j,e,d,c;if(a===true&&this.snapshot){d=this.snapshot.items}else{d=this.data.items}b=d.length;for(c=0;c<b;c++){j=d[c].data[f];e=String(j);if((g||!Ext.isEmpty(j))&&!h[e]){h[e]=true;k[k.length]=j}}return k},sum:function(e,f,a){var b=this.data.items,d=0,c;f=f||0;a=(a||a===0)?a:b.length-1;for(c=f;c<=a;c++){d+=(b[c].data[e]||0)}return d},getCount:function(){return this.data.length||0},getAt:function(a){return this.data.getAt(a)},getRange:function(b,a){return this.data.getRange(b,a)},getById:function(a){return(this.snapshot||this.data).findBy(function(b){return b.getId()===a})},indexOf:function(a){return this.data.indexOf(a)},indexOfId:function(a){return this.data.indexOfKey(a)},removeAll:function(b){var a=[];this.each(function(c){a.push(c)});this.clearData();if(this.snapshot){this.snapshot.clear()}if(b!==true){this.fireEvent("clear",this,a)}}});Ext.data.TreeStore=Ex
 t.extend(Ext.data.AbstractStore,{clearOnLoad:true,nodeParam:"node",defaultRootId:"root",constructor:function(c){c=c||{};var a=c.root||{};a.id=a.id||this.defaultRootId;var b=new Ext.data.RecordNode(a);this.tree=new Ext.data.Tree(b);this.tree.treeStore=this;Ext.data.TreeStore.superclass.constructor.call(this,c);if(c.root){this.read({node:b,doPreload:true})}},getRootNode:function(){return this.tree.getRootNode()},getNodeById:function(a){return this.tree.getNodeById(a)},load:function(e){e=e||{};e.params=e.params||{};var f=e.node||this.tree.getRootNode(),d,c,a=this.proxy.reader,b;if(this.clearOnLoad){while(f.firstChild){f.removeChild(f.firstChild)}}if(!e.doPreload){Ext.applyIf(e,{node:f});c=f.getRecord();e.params[this.nodeParam]=c?c.getId():"root";return Ext.data.TreeStore.superclass.load.call(this,e)}else{b=a.getRoot(f.isRoot?f.attributes:f.getRecord().raw);d=a.extractData(b,true);this.fillNode(f,d);return true}},fillNode:function(g,c){g.loaded=true;var f=c.length,a,e=0,d,b=g.su
 bStore;for(;e<f;e++){d=c[e].raw;c[e].data.leaf=d.leaf;a=new Ext.data.RecordNode({id:c[e].getId(),leaf:d.leaf,record:c[e],expanded:d.expanded});g.appendChild(a);if(c[e].doPreload){this.load({node:a,doPreload:true})}}if(b){if(this.clearOnLoad){b.removeAll()}b.add.apply(b,c)}},onProxyLoad:function(b){var a=b.getRecords();this.fillNode(b.node,a);this.fireEvent("read",this,b.node,a,b.wasSuccessful());var c=b.callback;if(typeof c=="function"){c.call(b.scope||this,a,b,b.wasSuccessful())}},getSubStore:function(a){if(a&&a.node){a=a.node}return a.getSubStore()},removeAll:function(){var a=this.getRootNode();a.destroy()}});Ext.StoreMgr=Ext.apply(new Ext.util.MixedCollection(),{register:function(){for(var a=0,b;(b=arguments[a]);a++){this.add(b)}},unregister:function(){for(var a=0,b;(b=arguments[a]);a++){this.remove(this.lookup(b))}},lookup:function(e){if(Ext.isArray(e)){var b=["field1"],d=!Ext.isArray(e[0]);if(!d){for(var c=2,a=e[0].length;c<=a;++c){b.push("field"+c)}}return new Ext.data
 .ArrayStore({data:e,fields:b,expandData:d,autoDestroy:true,autoCreated:true})}return Ext.isObject(e)?(e.events?e:Ext.create(e,"store")):this.get(e)},getKey:function(a){return a.storeId}});Ext.regStore=function(c,b){var a;if(Ext.isObject(c)){b=c}else{b.storeId=c}if(b instanceof Ext.data.Store){a=b}else{a=new Ext.data.Store(b)}return Ext.StoreMgr.register(a)};Ext.getStore=function(a){return Ext.StoreMgr.lookup(a)};Ext.data.WriterMgr=new Ext.AbstractManager({});Ext.data.Tree=Ext.extend(Ext.util.Observable,{constructor:function(a){this.nodeHash={};this.root=null;if(a){this.setRootNode(a)}this.addEvents("append","remove","move","insert","beforeappend","beforeremove","beforemove","beforeinsert");Ext.data.Tree.superclass.constructor.call(this)},pathSeparator:"/",proxyNodeEvent:function(){return this.fireEvent.apply(this,arguments)},getRootNode:function(){return this.root},setRootNode:function(a){this.root=a;a.ownerTree=this;a.isRoot=true;this.registerNode(a);return a},getNodeById:f
 unction(a){return this.nodeHash[a]},registerNode:function(a){this.nodeHash[a.id]=a},unregisterNode:function(a){delete this.nodeHash[a.id]},toString:function(){return"[Tree"+(this.id?" "+this.id:"")+"]"}});Ext.data.Node=Ext.extend(Ext.util.Observable,{constructor:function(a){this.attributes=a||{};this.leaf=!!this.attributes.leaf;this.id=this.attributes.id;if(!this.id){this.id=Ext.id(null,"xnode-");this.attributes.id=this.id}this.childNodes=[];this.parentNode=null;this.firstChild=null;this.lastChild=null;this.previousSibling=null;this.nextSibling=null;this.addEvents({append:true,remove:true,move:true,insert:true,beforeappend:true,beforeremove:true,beforemove:true,beforeinsert:true});this.listeners=this.attributes.listeners;Ext.data.Node.superclass.constructor.call(this)},fireEvent:function(b){if(Ext.data.Node.superclass.fireEvent.apply(this,arguments)===false){return false}var a=this.getOwnerTree();if(a){if(a.proxyNodeEvent.apply(a,arguments)===false){return false}}return true
 },isLeaf:function(){return this.leaf===true},setFirstChild:function(a){this.firstChild=a},setLastChild:function(a){this.lastChild=a},isLast:function(){return(!this.parentNode?true:this.parentNode.lastChild==this)},isFirst:function(){return(!this.parentNode?true:this.parentNode.firstChild==this)},hasChildNodes:function(){return !this.isLeaf()&&this.childNodes.length>0},isExpandable:function(){return this.attributes.expandable||this.hasChildNodes()},appendChild:function(e){var f=false,d,a;if(Ext.isArray(e)){f=e}else{if(arguments.length>1){f=arguments}}if(f){a=f.length;for(d=0;d<a;d++){this.appendChild(f[d])}}else{if(this.fireEvent("beforeappend",this.ownerTree,this,e)===false){return false}var b=this.childNodes.length;var c=e.parentNode;if(c){if(e.fireEvent("beforemove",e.getOwnerTree(),e,c,this,b)===false){return false}c.removeChild(e)}b=this.childNodes.length;if(b===0){this.setFirstChild(e)}this.childNodes.push(e);e.parentNode=this;var g=this.childNodes[b-1];if(g){e.previous
 Sibling=g;g.nextSibling=e}else{e.previousSibling=null}e.nextSibling=null;this.setLastChild(e);e.setOwnerTree(this.getOwnerTree());this.fireEvent("append",this.ownerTree,this,e,b);if(c){e.fireEvent("move",this.ownerTree,e,c,this,b)}return e}},removeChild:function(c,b){var a=this.indexOf(c);if(a==-1){return false}if(this.fireEvent("beforeremove",this.ownerTree,this,c)===false){return false}this.childNodes.splice(a,1);if(c.previousSibling){c.previousSibling.nextSibling=c.nextSibling}if(c.nextSibling){c.nextSibling.previousSibling=c.previousSibling}if(this.firstChild==c){this.setFirstChild(c.nextSibling)}if(this.lastChild==c){this.setLastChild(c.previousSibling)}this.fireEvent("remove",this.ownerTree,this,c);if(b){c.destroy(true)}else{c.clear()}return c},clear:function(a){this.setOwnerTree(null,a);this.parentNode=this.previousSibling=this.nextSibling=null;if(a){this.firstChild=this.lastChild=null}},destroy:function(a){if(a===true){this.clearListeners();this.clear(true);Ext.each(
 this.childNodes,function(b){b.destroy(true)});this.childNodes=null}else{this.remove(true)}},insertBefore:function(d,a){if(!a){return this.appendChild(d)}if(d==a){return false}if(this.fireEvent("beforeinsert",this.ownerTree,this,d,a)===false){return false}var b=this.indexOf(a),c=d.parentNode,e=b;if(c==this&&this.indexOf(d)<b){e--}if(c){if(d.fireEvent("beforemove",d.getOwnerTree(),d,c,this,b,a)===false){return false}c.removeChild(d)}if(e===0){this.setFirstChild(d)}this.childNodes.splice(e,0,d);d.parentNode=this;var f=this.childNodes[e-1];if(f){d.previousSibling=f;f.nextSibling=d}else{d.previousSibling=null}d.nextSibling=a;a.previousSibling=d;d.setOwnerTree(this.getOwnerTree());this.fireEvent("insert",this.ownerTree,this,d,a);if(c){d.fireEvent("move",this.ownerTree,d,c,this,e,a)}return d},remove:function(b){var a=this.parentNode;if(a){a.removeChild(this,b)}return this},removeAll:function(a){var c=this.childNodes,b;while((b=c[0])){this.removeChild(b,a)}return this},getChildAt:fu
 nction(a){return this.childNodes[a]},replaceChild:function(a,c){var b=c?c.nextSibling:null;this.removeChild(c);this.insertBefore(a,b);return c},indexOf:function(a){return this.childNodes.indexOf(a)},getOwnerTree:function(){if(!this.ownerTree){var a=this;while(a){if(a.ownerTree){this.ownerTree=a.ownerTree;break}a=a.parentNode}}return this.ownerTree},getDepth:function(){var b=0,a=this;while(a.parentNode){++b;a=a.parentNode}return b},setOwnerTree:function(a,b){if(a!=this.ownerTree){if(this.ownerTree){this.ownerTree.unregisterNode(this)}this.ownerTree=a;if(b!==true){Ext.each(this.childNodes,function(c){c.setOwnerTree(a)})}if(a){a.registerNode(this)}}},setId:function(b){if(b!==this.id){var a=this.ownerTree;if(a){a.unregisterNode(this)}this.id=this.attributes.id=b;if(a){a.registerNode(this)}this.onIdChange(b)}},onIdChange:Ext.emptyFn,getPath:function(c){c=c||"id";var e=this.parentNode,a=[this.attributes[c]];while(e){a.unshift(e.attributes[c]);e=e.parentNode}var d=this.getOwnerTree
 ().pathSeparator;return d+a.join(d)},bubble:function(c,b,a){var d=this;while(d){if(c.apply(b||d,a||[d])===false){break}d=d.parentNode}},cascadeBy:function(d,c,a){if(d.apply(c||this,a||[this])!==false){var f=this.childNodes,e=f.length,b;for(b=0;b<e;b++){f[b].cascadeBy(d,c,a)}}},eachChild:function(d,c,a){var f=this.childNodes,e=f.length,b;for(b=0;b<e;b++){if(d.apply(c||this,a||[f[b]])===false){break}}},findChild:function(b,c,a){return this.findChildBy(function(){return this.attributes[b]==c},null,a)},findChildBy:function(g,f,b){var e=this.childNodes,a=e.length,d=0,h,c;for(;d<a;d++){h=e[d];if(g.call(f||h,h)===true){return h}else{if(b){c=h.findChildBy(g,f,b);if(c!=null){return c}}}}return null},sort:function(e,d){var c=this.childNodes,a=c.length,b,g;if(a>0){var f=d?function(){return e.apply(d,arguments)}:e;c.sort(f);for(b=0;b<a;b++){g=c[b];g.previousSibling=c[b-1];g.nextSibling=c[b+1];if(b===0){this.setFirstChild(g)}if(b==a-1){this.setLastChild(g)}}}},contains:function(a){return
  a.isAncestor(this)},isAncestor:function(a){var b=this.parentNode;while(b){if(b==a){return true}b=b.parentNode}return false},toString:function(){return"[Node"+(this.id?" "+this.id:"")+"]"}});Ext.data.RecordNode=Ext.extend(Ext.data.Node,{constructor:function(a){a=a||{};if(a.record){a.record.node=this}Ext.data.RecordNode.superclass.constructor.call(this,a)},getChildRecords:function(){var e=this.childNodes,d=e.length,b=0,a=[],c;for(;b<d;b++){c=e[b].attributes.record;c.data.leaf=e[b].leaf;a.push(c)}return a},getRecord:function(){return this.attributes.record},getSubStore:function(){if(this.isLeaf()){throw"Attempted to get a substore of a leaf node."}var b=this.getOwnerTree().treeStore;if(!this.subStore){this.subStore=new Ext.data.Store({model:b.model});var a=this.getChildRecords();this.subStore.add.apply(this.subStore,a)}if(!this.loaded){b.load({node:this})}return this.subStore},destroy:function(b){if(this.subStore){this.subStore.destroyStore()}var a=this.attributes;if(a.record)
 {delete a.record.node;delete a.record}return Ext.data.RecordNode.superclass.destroy.call(this,b)}});Ext.data.Proxy=Ext.extend(Ext.util.Observable,{batchOrder:"create,update,destroy",defaultReaderType:"json",defaultWriterType:"json",constructor:function(a){a=a||{};if(a.model==undefined){delete a.model}Ext.data.Proxy.superclass.constructor.call(this,a);if(this.model!=undefined&&!(this.model instanceof Ext.data.Model)){this.setModel(this.model)}},setModel:function(b,c){this.model=Ext.ModelMgr.getModel(b);var a=this.reader,d=this.writer;this.setReader(a);this.setWriter(d);if(c&&this.store){this.store.setModel(this.model)}},getModel:function(){return this.model},setReader:function(a){if(a==undefined||typeof a=="string"){a={type:a}}if(a instanceof Ext.data.Reader){a.setModel(this.model)}else{Ext.applyIf(a,{proxy:this,model:this.model,type:this.defaultReaderType});a=Ext.data.ReaderMgr.create(a)}this.reader=a;return this.reader},getReader:function(){return this.reader},setWriter:fun
 ction(a){if(a==undefined||typeof a=="string"){a={type:a}}if(!(a instanceof Ext.data.Writer)){Ext.applyIf(a,{model:this.model,type:this.defaultWriterType});a=Ext.data.WriterMgr.create(a)}this.writer=a;return this.writer},getWriter:function(){return this.writer},create:Ext.emptyFn,read:Ext.emptyFn,update:Ext.emptyFn,destroy:Ext.emptyFn,batch:function(b,c){var a=new Ext.data.Batch({proxy:this,listeners:c||{}});Ext.each(this.batchOrder.split(","),function(d){if(b[d]){a.add(new Ext.data.Operation({action:d,records:b[d]}))}},this);a.start();return a}});Ext.data.DataProxy=Ext.data.Proxy;Ext.data.ProxyMgr.registerType("proxy",Ext.data.Proxy);Ext.data.ServerProxy=Ext.extend(Ext.data.Proxy,{pageParam:"page",startParam:"start",limitParam:"limit",groupParam:"group",sortParam:"sort",filterParam:"filter",noCache:true,cacheString:"_dc",timeout:30000,constructor:function(a){a=a||{};Ext.data.ServerProxy.superclass.constructor.call(this,a);this.extraParams=a.extraParams||{};this.nocache=this.
 noCache},create:function(){return this.doRequest.apply(this,arguments)},read:function(){return this.doRequest.apply(this,arguments)},update:function(){return this.doRequest.apply(this,arguments)},destroy:function(){return this.doRequest.apply(this,arguments)},buildRequest:function(a){var c=Ext.applyIf(a.params||{},this.extraParams||{});c=Ext.applyIf(c,this.getParams(c,a));var b=new Ext.data.Request({params:c,action:a.action,records:a.records,operation:a});b.url=this.buildUrl(b);a.request=b;return b},encodeSorters:function(d){var b=[],c=d.length,a;for(a=0;a<c;a++){b[a]={property:d[a].property,direction:d[a].direction}}return Ext.encode(b)},encodeFilters:function(d){var b=[],c=d.length,a;for(a=0;a<c;a++){b[a]={property:d[a].property,value:d[a].value}}return Ext.encode(b)},encodeGroupers:function(a){return Ext.encode(a)},getParams:function(e,f){e=e||{};var l=f.group,k=f.sorters,d=f.filters,j=f.page,b=f.start,g=f.limit,n=this.pageParam,i=this.startParam,m=this.limitParam,h=this.
 groupParam,c=this.sortParam,a=this.filterParam;if(n&&j){e[n]=j}if(i&&b){e[i]=b}if(m&&g){e[m]=g}if(h&&l&&l.field){e[h]=this.encodeGroupers(l)}if(c&&k&&k.length>0){e[c]=this.encodeSorters(k)}if(a&&d&&d.length>0){e[a]=this.encodeFilters(d)}return e},buildUrl:function(b){var a=b.url||this.url;if(!a){throw new Error("You are using a ServerProxy but have not supplied it with a url.")}if(this.noCache){a=Ext.urlAppend(a,Ext.util.Format.format("{0}={1}",this.cacheString,(new Date().getTime())))}return a},doRequest:function(a,c,b){throw new Error("The doRequest function has not been implemented on your Ext.data.ServerProxy subclass. See src/data/ServerProxy.js for details")},afterRequest:Ext.emptyFn,onDestroy:function(){Ext.destroy(this.reader,this.writer);Ext.data.ServerProxy.superclass.destroy.apply(this,arguments)}});Ext.data.AjaxProxy=Ext.extend(Ext.data.ServerProxy,{actionMethods:{create:"POST",read:"GET",update:"POST",destroy:"POST"},constructor:function(){this.addEvents("except
 ion");Ext.data.AjaxProxy.superclass.constructor.apply(this,arguments)},doRequest:function(a,e,b){var d=this.getWriter(),c=this.buildRequest(a,e,b);if(a.allowWrite()){c=d.write(c)}Ext.apply(c,{headers:this.headers,timeout:this.timeout,scope:this,callback:this.createRequestCallback(c,a,e,b),method:this.getMethod(c),disableCaching:false});Ext.Ajax.request(c);return c},getMethod:function(a){return this.actionMethods[a.action]},createRequestCallback:function(d,a,e,b){var c=this;return function(i,j,h){if(j===true){var g=c.getReader(),f=g.read(h);Ext.apply(a,{response:h,resultSet:f});a.setCompleted();a.setSuccessful()}else{c.fireEvent("exception",this,h,a);a.setException()}if(typeof e=="function"){e.call(b||c,a)}c.afterRequest(d,true)}}});Ext.data.ProxyMgr.registerType("ajax",Ext.data.AjaxProxy);Ext.data.HttpProxy=Ext.data.AjaxProxy;Ext.data.RestProxy=Ext.extend(Ext.data.AjaxProxy,{appendId:true,actionMethods:{create:"POST",read:"GET",update:"PUT",destroy:"DELETE"},api:{create:"cre
 ate",read:"read",update:"update",destroy:"destroy"},buildUrl:function(d){var b=d.operation.records||[],a=b[0],e=this.format,c=d.url||this.url;if(this.appendId&&a){if(!c.match(/\/$/)){c+="/"}c+=a.getId()}if(e){if(!c.match(/\.$/)){c+="."}c+=e}d.url=c;return Ext.data.RestProxy.superclass.buildUrl.apply(this,arguments)}});Ext.data.ProxyMgr.registerType("rest",Ext.data.RestProxy);Ext.apply(Ext,{getHead:function(){var a;return function(){if(a==undefined){a=Ext.get(document.getElementsByTagName("head")[0])}return a}}()});Ext.data.ScriptTagProxy=Ext.extend(Ext.data.ServerProxy,{defaultWriterType:"base",callbackParam:"callback",scriptIdPrefix:"stcScript",callbackPrefix:"stcCallback",recordParam:"records",lastRequest:undefined,autoAppendParams:true,constructor:function(){this.addEvents("exception");Ext.data.ScriptTagProxy.superclass.constructor.apply(this,arguments)},doRequest:function(f,j,k){var i=Ext.util.Format.format,a=++Ext.data.ScriptTagProxy.TRANS_ID,c=i("{0}{1}",this.scriptIdP
 refix,a),d=i("{0}{1}",this.callbackPrefix,a);var e=this.getWriter(),g=this.buildRequest(f),b=Ext.urlAppend(g.url,i("{0}={1}",this.callbackParam,d));if(f.allowWrite()){g=e.write(g)}Ext.apply(g,{url:b,transId:a,scriptId:c,stCallback:d});g.timeoutId=Ext.defer(this.createTimeoutHandler,this.timeout,this,[g,f]);window[d]=this.createRequestCallback(g,f,j,k);var h=document.createElement("script");h.setAttribute("src",b);h.setAttribute("async",true);h.setAttribute("type","text/javascript");h.setAttribute("id",c);Ext.getHead().appendChild(h);f.setStarted();this.lastRequest=g;return g},createRequestCallback:function(d,a,e,b){var c=this;return function(h){var g=c.getReader(),f=g.read(h);Ext.apply(a,{response:h,resultSet:f});a.setCompleted();a.setSuccessful();if(typeof e=="function"){e.call(b||c,a)}c.afterRequest(d,true)}},afterRequest:function(){var a=function(b){return function(){window[b]=undefined;try{delete window[b]}catch(c){}}};return function(c,b){Ext.get(c.scriptId).remove();cl
 earTimeout(c.timeoutId);var d=c.stCallback;if(b){a(d)();this.lastRequest.completed=true}else{window[d]=a(d)}}}(),buildUrl:function(f){var b=Ext.data.ScriptTagProxy.superclass.buildUrl.call(this,f),g=Ext.apply({},f.params),e=g.filters,d,c;delete g.filters;if(this.autoAppendParams){b=Ext.urlAppend(b,Ext.urlEncode(g))}if(e&&e.length){for(c=0;c<e.length;c++){d=e[c];if(d.value){b=Ext.urlAppend(b,d.property+"="+d.value)}}}var a=f.records;if(Ext.isArray(a)&&a.length>0){b=Ext.urlAppend(b,Ext.util.Format.format("{0}={1}",this.recordParam,this.encodeRecords(a)))}return b},destroy:function(){this.abort();Ext.data.ScriptTagProxy.superclass.destroy.apply(this,arguments)},isLoading:function(){var a=this.lastRequest;return(a!=undefined&&!a.completed)},abort:function(){if(this.isLoading()){this.afterRequest(this.lastRequest)}},encodeRecords:function(a){var d="";for(var b=0,c=a.length;b<c;b++){d+=Ext.urlEncode(a[b].data)}return d},createTimeoutHandler:function(b,a){this.afterRequest(b,false)
 ;this.fireEvent("exception",this,b,a);if(typeof b.callback=="function"){b.callback.call(b.scope||window,null,b.options,false)}}});Ext.data.ScriptTagProxy.TRANS_ID=1000;Ext.data.ProxyMgr.registerType("scripttag",Ext.data.ScriptTagProxy);Ext.data.ClientProxy=Ext.extend(Ext.data.Proxy,{clear:function(){throw new Error("The Ext.data.ClientProxy subclass that you are using has not defined a 'clear' function. See src/data/ClientProxy.js for details.")}});Ext.data.MemoryProxy=Ext.extend(Ext.data.ClientProxy,{constructor:function(a){Ext.data.MemoryProxy.superclass.constructor.call(this,a);this.setReader(this.reader)},read:function(c,e,d){var b=this.getReader(),a=b.read(this.data);Ext.apply(c,{resultSet:a});c.setCompleted();if(typeof e=="function"){e.call(d||this,c)}},clear:Ext.emptyFn});Ext.data.ProxyMgr.registerType("memory",Ext.data.MemoryProxy);Ext.data.WebStorageProxy=Ext.extend(Ext.data.ClientProxy,{id:undefined,constructor:function(a){Ext.data.WebStorageProxy.superclass.constr
 uctor.call(this,a);this.cache={};if(this.getStorageObject()==undefined){throw"Local Storage is not supported in this browser, please use another type of data proxy"}this.id=this.id||(this.store?this.store.storeId:undefined);if(this.id==undefined){throw"No unique id was provided to the local storage proxy. See Ext.data.LocalStorageProxy documentation for details"}this.initialize()},create:function(e,h,j){var d=e.records,c=d.length,a=this.getIds(),b,g,f;e.setStarted();for(f=0;f<c;f++){g=d[f];if(g.phantom){g.phantom=false;b=this.getNextId()}else{b=g.getId()}this.setRecord(g,b);a.push(b)}this.setIds(a);e.setCompleted();e.setSuccessful();if(typeof h=="function"){h.call(j||this,e)}},read:function(e,h,j){var d=[],a=this.getIds(),c=a.length,f,b,g;if(e.id){g=this.getRecord(e.id);if(g){d.push(g);e.setSuccessful()}}else{for(f=0;f<c;f++){d.push(this.getRecord(a[f]))}e.setSuccessful()}e.setCompleted();e.resultSet=new Ext.data.ResultSet({records:d,total:d.length,loaded:true});if(typeof h=
 ="function"){h.call(j||this,e)}},update:function(e,h,j){var d=e.records,c=d.length,a=this.getIds(),g,b,f;e.setStarted();for(f=0;f<c;f++){g=d[f];this.setRecord(g);b=g.getId();if(b!==undefined&&a.indexOf(b)==-1){a.push(b)}}this.setIds(a);e.setCompleted();e.setSuccessful();if(typeof h=="function"){h.call(j||this,e)}},destroy:function(b,h,e){var a=b.records,f=a.length,d=this.getIds(),g=[].concat(d),c;for(c=0;c<f;c++){g.remove(a[c].getId());this.removeRecord(a[c],false)}this.setIds(g);if(typeof h=="function"){h.call(e||this,b)}},getRecord:function(c){if(this.cache[c]==undefined){var a=Ext.decode(this.getStorageObject().getItem(this.getRecordKey(c))),f={},e=this.model,j=e.prototype.fields.items,d=j.length,g,k,b,h;for(g=0;g<d;g++){k=j[g];b=k.name;if(typeof k.decode=="function"){f[b]=k.decode(a[b])}else{f[b]=a[b]}}h=new e(f);h.phantom=false;this.cache[c]=h}return this.cache[c]},setRecord:function(j,c){if(c){j.setId(c)}else{c=j.getId()}var a=j.data,f={},h=this.model,k=h.prototype.fie
 lds.items,d=k.length,g,l,b;for(g=0;g<d;g++){l=k[g];b=l.name;if(typeof l.encode=="function"){f[b]=l.encode(a[b],j)}else{f[b]=a[b]}}var e=this.getStorageObject(),m=this.getRecordKey(c);this.cache[c]=j;e.removeItem(m);e.setItem(m,Ext.encode(f))},removeRecord:function(c,b){if(c instanceof Ext.data.Model){c=c.getId()}if(b!==false){var a=this.getIds();a.remove(c);this.setIds(a)}this.getStorageObject().removeItem(this.getRecordKey(c))},getRecordKey:function(a){if(a instanceof Ext.data.Model){a=a.getId()}return Ext.util.Format.format("{0}-{1}",this.id,a)},getRecordCounterKey:function(){return Ext.util.Format.format("{0}-counter",this.id)},getIds:function(){var b=(this.getStorageObject().getItem(this.id)||"").split(","),c=b.length,a;if(c==1&&b[0]==""){b=[]}else{for(a=0;a<c;a++){b[a]=parseInt(b[a],10)}}return b},setIds:function(a){var b=this.getStorageObject(),c=a.join(",");b.removeItem(this.id);if(!Ext.isEmpty(c)){b.setItem(this.id,c)}},getNextId:function(){var d=this.getStorageObjec
 t(),a=this.getRecordCounterKey(),c=d[a],b,e;if(c==undefined){b=this.getIds();c=b[b.length-1]||0}e=parseInt(c,10)+1;d.setItem(a,e);return e},initialize:function(){var a=this.getStorageObject();a.setItem(this.id,a.getItem(this.id)||"")},clear:function(){var d=this.getStorageObject(),c=this.getIds(),a=c.length,b;for(b=0;b<a;b++){this.removeRecord(c[b])}d.removeItem(this.getRecordCounterKey());d.removeItem(this.id)},getStorageObject:function(){throw new Error("The getStorageObject function has not been defined in your Ext.data.WebStorageProxy subclass")}});Ext.data.LocalStorageProxy=Ext.extend(Ext.data.WebStorageProxy,{getStorageObject:function(){return window.localStorage}});Ext.data.ProxyMgr.registerType("localstorage",Ext.data.LocalStorageProxy);Ext.data.SessionStorageProxy=Ext.extend(Ext.data.WebStorageProxy,{getStorageObject:function(){return window.sessionStorage}});Ext.data.ProxyMgr.registerType("sessionstorage",Ext.data.SessionStorageProxy);Ext.data.Reader=Ext.extend(Obj
 ect,{idProperty:"id",totalProperty:"total",successProperty:"success",root:"",implicitIncludes:true,nullResultSet:new Ext.data.ResultSet({total:0,count:0,records:[],success:true}),constructor:function(a){Ext.apply(this,a||{});this.model=Ext.ModelMgr.getModel(a.model);if(this.model){this.buildExtractors()}},setModel:function(a,b){this.model=Ext.ModelMgr.getModel(a);this.buildExtractors(true);if(b&&this.proxy){this.proxy.setModel(this.model,true)}},read:function(a){var b=a;if(a){if(a.responseText){b=this.getResponseData(a)}return this.readRecords(b)}else{return this.nullResultSet}},readRecords:function(f){this.rawData=f;f=this.getData(f);var a=this.getRoot(f),d=a.length,g=true,e,b,c;if(this.totalProperty){e=parseInt(this.getTotal(f),10);if(!isNaN(e)){d=e}}if(this.successProperty){e=this.getSuccess(f);if(e===false||e==="false"){g=false}}b=this.extractData(a,true);c=b.length;return new Ext.data.ResultSet({total:d||c,count:c,records:b,success:g})},extractData:function(j,a){var k=[
 ],f=[],d=this.model,c=j.length,l=this.idProperty,e,b,h,g;for(g=0;g<c;g++){e=j[g];k=this.extractValues(e);b=this.getId(e);if(a===true){h=new d(k,b);h.raw=e;f.push(h);if(this.implicitIncludes){this.readAssociated(h,e)}}else{k[l]=b;f.push(k)}}return f},readAssociated:function(h,g){var e=h.associations.items,a=e.length,d,m,n,c,b,k,j,l,f;for(f=0;f<a;f++){d=e[f];m=d.name;c=this.getAssociatedDataRoot(g,d.associationKey||m);n=d.associatedModel;if(c){k=n.proxy;if(k){j=k.getReader()}else{j=new this.constructor({model:d.associatedName})}if(d.type=="hasMany"){l=h[m]();l.add.apply(l,j.read(c).records);b=n.prototype.associations.findBy(function(i){return i.type=="belongsTo"&&i.associatedName==h.constructor.modelName});if(b){l.data.each(function(i){i[b.instanceName]=h})}}else{if(d.type=="belongsTo"){h[d.instanceName]=j.read([c]).records[0]}}}}},getAssociatedDataRoot:function(b,a){return b[a]},extractValues:function(f){var a=this.model.prototype.fields.items,d=a.length,b={},g,e,c;for(c=0;c<
 d;c++){g=a[c];e=this.extractorFunctions[c](f)||g.defaultValue;b[g.name]=e}return b},getData:function(a){return a},getRoot:function(a){return a},getResponseData:function(a){throw new Error("getResponseData must be implemented in the Ext.data.Reader subclass")},onMetaChange:function(c){var a=c.fields,b;Ext.apply(this,c);if(a){b=Ext.regModel("JsonReader-Model"+Ext.id(),{fields:a});this.setModel(b,true)}else{this.buildExtractors(true)}},buildExtractors:function(d){if(d===true){delete this.extractorFunctions}if(this.extractorFunctions){return}var f=this.id||this.idProperty,c=this.totalProperty,b=this.successProperty,e=this.messageProperty;if(c){this.getTotal=this.createAccessor(c)}if(b){this.getSuccess=this.createAccessor(b)}if(e){this.getMessage=this.createAccessor(e)}if(f){var a=this.createAccessor(f);this.getId=function(g){var h=a(g);return(h==undefined||h=="")?null:h}}else{this.getId=function(){return null}}this.buildFieldExtractors()},buildFieldExtractors:function(){var a=th
 is.model.prototype.fields.items,c=a.length,b=0,f=[],e,d;for(;b<c;b++){e=a[b];d=(e.mapping!==undefined&&e.mapping!==null)?e.mapping:e.name;f.push(this.createAccessor(d))}this.extractorFunctions=f}});Ext.data.Writer=Ext.extend(Object,{constructor:function(a){Ext.apply(this,a)},write:function(e){var b=e.operation,a=b.records||[],d=a.length,c=0,f=[];for(;c<d;c++){f.push(this.getRecordData(a[c]))}return this.writeRecords(e,f)},getRecordData:function(a){return a.data}});Ext.data.WriterMgr.registerType("base",Ext.data.Writer);Ext.data.JsonWriter=Ext.extend(Ext.data.Writer,{root:"records",encode:false,writeRecords:function(a,b){if(this.encode===true){b=Ext.encode(b)}a.jsonData=a.jsonData||{};a.jsonData[this.root]=b;return a}});Ext.data.WriterMgr.registerType("json",Ext.data.JsonWriter);Ext.data.JsonReader=Ext.extend(Ext.data.Reader,{root:"",readRecords:function(a){if(a.metaData){this.onMetaChange(a.metaData)}this.jsonData=a;return Ext.data.JsonReader.superclass.readRecords.call(this
 ,a)},getResponseData:function(a){try{var c=Ext.decode(a.responseText)}catch(b){throw"Ext.data.JsonReader.getResponseData: Unable to parse JSON returned by Server."}if(!c){throw"Ext.data.JsonReader.getResponseData: JSON object not found"}return c},buildExtractors:function(){Ext.data.JsonReader.superclass.buildExtractors.apply(this,arguments);if(this.root){this.getRoot=this.createAccessor(this.root)}else{this.getRoot=function(a){return a}}},extractData:function(a,c){var f=this.record,e=[],d,b;if(f){d=a.length;for(b=0;b<d;b++){e[b]=a[b][f]}}else{e=a}return Ext.data.XmlReader.superclass.extractData.call(this,e,c)},createAccessor:function(){var a=/[\[\.]/;return function(c){if(Ext.isEmpty(c)){return Ext.emptyFn}if(Ext.isFunction(c)){return c}var b=String(c).search(a);if(b>=0){return new Function("obj","return obj"+(b>0?".":"")+c)}return function(d){return d[c]}}}()});Ext.data.ReaderMgr.registerType("json",Ext.data.JsonReader);Ext.data.TreeReader=Ext.extend(Ext.data.JsonReader,{ex
 tractData:function(b,e){var c=Ext.data.TreeReader.superclass.extractData.call(this,b,e),f=c.length,d=0,a;if(e){for(;d<f;d++){a=c[d];a.doPreload=!!this.getRoot(a.raw)}}return c}});Ext.data.ReaderMgr.registerType("tree",Ext.data.TreeReader);Ext.data.ArrayReader=Ext.extend(Ext.data.JsonReader,{buildExtractors:function(){Ext.data.ArrayReader.superclass.buildExtractors.apply(this,arguments);var a=this.model.prototype.fields.items,c=a.length,d=[],b;for(b=0;b<c;b++){d.push(function(e){return function(f){return f[e]}}(a[b].mapping||b))}this.extractorFunctions=d}});Ext.data.ReaderMgr.registerType("array",Ext.data.ArrayReader);Ext.data.ArrayStore=Ext.extend(Ext.data.Store,{constructor:function(a){a=a||{};Ext.applyIf(a,{proxy:{type:"memory",reader:"array"}});Ext.data.ArrayStore.superclass.constructor.call(this,a)},loadData:function(e,a){if(this.expandData===true){var d=[],b=0,c=e.length;for(;b<c;b++){d[d.length]=[e[b]]}e=d}Ext.data.ArrayStore.superclass.loadData.call(this,e,a)}});Ext.r
 eg("arraystore",Ext.data.ArrayStore);Ext.data.SimpleStore=Ext.data.ArrayStore;Ext.reg("simplestore",Ext.data.SimpleStore);Ext.data.JsonStore=Ext.extend(Ext.data.Store,{constructor:function(a){a=a||{};Ext.applyIf(a,{proxy:{type:"ajax",reader:"json",writer:"json"}});Ext.data.JsonStore.superclass.constructor.call(this,a)}});Ext.reg("jsonstore",Ext.data.JsonStore);Ext.data.JsonPStore=Ext.extend(Ext.data.Store,{constructor:function(a){Ext.data.JsonPStore.superclass.constructor.call(this,Ext.apply(a,{reader:new Ext.data.JsonReader(a),proxy:new Ext.data.ScriptTagProxy(a)}))}});Ext.reg("jsonpstore",Ext.data.JsonPStore);Ext.data.XmlWriter=Ext.extend(Ext.data.Writer,{documentRoot:"xmlData",header:"",record:"record",writeRecords:function(b,c){var a=this.buildTpl(b,c);b.xmlData=a.apply(c);return b},buildTpl:function(e,f){if(this.tpl){return this.tpl}var c=[],b=this.documentRoot,a=this.record,g,d;if(this.header){c.push(this.header)}c.push("<",b,">");if(f.length>0){c.push('<tpl for="."><'
 ,a,">");g=f[0];for(d in g){if(g.hasOwnProperty(d)){c.push("<",d,">{",d,"}</",d,">")}}c.push("</",a,"></tpl>")}c.push("</",b,">");this.tpl=new Ext.XTemplate(c.join(""));return this.tpl}});Ext.data.WriterMgr.registerType("xml",Ext.data.XmlWriter);Ext.data.XmlReader=Ext.extend(Ext.data.Reader,{createAccessor:function(){var a=function(d,c,b){var e=Ext.DomQuery.selectNode(d,c),f;if(e&&e.firstChild){f=e.firstChild.nodeValue}return Ext.isEmpty(f)?b:f};return function(b){var c;if(b==this.totalProperty){c=function(e,d){var f=a(b,e,d);return parseFloat(f)}}else{if(b==this.successProperty){c=function(e,d){var f=a(b,e,true);return(f!==false&&f!=="false")}}else{c=function(e,d){return a(b,e,d)}}}return c}}(),getResponseData:function(a){var b=a.responseXML;if(!b){throw {message:"Ext.data.XmlReader.read: XML data not found"}}return b},getData:function(a){return a.documentElement||a},getRoot:function(b){var c=b.nodeName,a=this.root;if(!a||(c&&c==a)){return b}else{return Ext.DomQuery.selectNo
 de(a,b)}},constructor:function(a){a=a||{};Ext.applyIf(a,{idProperty:a.idPath||a.id,successProperty:a.success});Ext.data.XmlReader.superclass.constructor.call(this,a)},extractData:function(a,b){var c=this.record;if(c!=a.nodeName){a=Ext.DomQuery.select(c,a)}else{a=[a]}return Ext.data.XmlReader.superclass.extractData.call(this,a,b)},getAssociatedDataRoot:function(b,a){return Ext.DomQuery.select(a,b)[0]},readRecords:function(a){if(Ext.isArray(a)){a=a[0]}this.xmlData=a;return Ext.data.XmlReader.superclass.readRecords.call(this,a)}});Ext.data.ReaderMgr.registerType("xml",Ext.data.XmlReader);Ext.data.XmlStore=Ext.extend(Ext.data.Store,{constructor:function(a){a=a||{};a=a||{};Ext.applyIf(a,{proxy:{type:"ajax",reader:"xml",writer:"xml"}});Ext.data.XmlStore.superclass.constructor.call(this,a)}});Ext.reg("xmlstore",Ext.data.XmlStore);Ext.History=new Ext.util.Observable({constructor:function(){Ext.History.superclass.constructor.call(this,config);this.addEvents("change")},init:function()
 {var a=this;a.setToken(window.location.hash);if(Ext.supports.History){window.addEventListener("hashchange",this.onChange)}else{setInterval(function(){var c=a.cleanToken(window.location.hash),b=a.getToken();if(c!=b){a.onChange()}},50)}},onChange:function(){var b=Ext.History,a=b.cleanToken(window.location.hash);if(b.token!=a){b.fireEvent("change",a)}b.setToken(a)},setToken:function(a){return this.token=this.cleanToken(a)},cleanToken:function(a){return a[0]=="#"?a.substr(1):a},getToken:function(){return this.token},add:function(a){window.location.hash=this.setToken(a);if(!Ext.supports.History){this.onChange()}}});Ext.ControllerManager=new Ext.AbstractManager({register:function(c,b){b.id=c;Ext.applyIf(b,{application:Ext.ApplicationManager.currentApplication});var a=new Ext.Controller(b);if(a.init){a.init()}this.all.add(a);return a}});Ext.regController=function(){return Ext.ControllerManager.register.apply(Ext.ControllerManager,arguments)};Ext.Controller=Ext.extend(Ext.util.Obser
 vable,{constructor:function(a){this.addEvents("instance-created","instance-creation-failed","instance-updated","instance-update-failed","instance-destroyed","instance-destruction-failed");Ext.Controller.superclass.constructor.call(this,a);Ext.apply(this,a||{});if(typeof this.model=="string"){this.model=Ext.ModelMgr.getModel(this.model)}},index:function(){this.render("index",{listeners:{scope:this,edit:this.edit,build:this.build,create:this.onCreateInstance,destroy:this.onDestroyInstance}})},edit:function(a){var b=this.render("edit",{listeners:this.getEditListeners()});b.loadModel(a)},build:function(){this.render("build",{listeners:this.getBuildListeners()})},create:function(f,c){c=c||{};var b=this.getModel(),a=new b(f),e=c.success,g=c.failure,d=c.scope||this;a.save({scope:this,success:function(h){if(typeof e=="function"){e.call(d,h)}this.fireEvent("instance-created",h)},failure:function(h,i){if(typeof g=="function"){g.call(d,h,i)}this.fireEvent("instance-creation-failed",h,i
 )}})},update:function(a,e,b){b=b||{};var d=b.success,f=b.failure,c=b.scope||this;if(Ext.isObject(e)){a.set(e)}a.save({scope:this,success:function(g){if(typeof d=="function"){d.call(c,g)}this.fireEvent("instance-updated",g)},failure:function(g,h){if(typeof f=="function"){f.call(c,g,h)}this.fireEvent("instance-update-failed",g,h)}})},destroy:function(a,b){b=b||{};var d=b.success,e=b.failure,c=b.scope||this;a.destroy({scope:this,success:function(f){if(typeof d=="function"){d.call(c,f)}this.fireEvent("instance-destroyed",f)},failure:function(f,g){if(typeof e=="function"){e.call(c,f,g)}this.fireEvent("instance-destruction-failed",f,g)}})},getBuildListeners:function(){return{scope:this,save:this.onCreateInstance,cancel:this.onCancelBuild}},getEditListeners:function(){return{scope:this,save:this.onUpdateInstance,cancel:this.onCancelEdit}},onCancelEdit:function(a){return this.closeView(a)},onCancelBuild:function(a){return this.closeView(a)},onCreateInstance:function(a){this.create(a
 .getValues(),{scope:this,success:function(b){this.closeView(a)},failure:function(b,c){console.log("fail")}})},onUpdateInstance:function(a){this.update(a.getRecord(),a.getValues(),{scope:this,success:function(b){this.closeView(a)},failure:function(b,c){}})},onDestroyInstance:function(a,b){this.destroy(a,{scope:this,success:function(c){},failure:function(c,d){}})},setRenderTarget:function(a){Ext.Controller.renderTarget=a},render:function(c,g){var f=Ext.Controller,b=this.application,d=b?b.currentProfile:undefined,e,a;Ext.applyIf(c,{profile:d});a=Ext.ComponentMgr.create(c);if(g!==false){e=d?d.getRenderTarget(c,b):g;if(g==undefined){g=e||(b?b.defaultTarget:undefined)}if(typeof g=="string"){g=Ext.getCmp(g)}if(g!=undefined&&g.add){if(d){d.beforeLayout(a,g,b)}g.add(a);if(g.layout&&g.layout.setActiveItem){g.layout.setActiveItem(a)}g.doComponentLayout();if(d){d.afterLayout(a,g,b)}}}return a},control:function(e,d,i){if(!e||!e.isView){throw"Trying to control a view that doesnt exist"}va
 r h=i?e.refs[i]:e,g,f,a,b,c;if(!h){throw"No item called "+i+" found inside the "+e.name+" view."}for(g in d){f=d[g];if(Ext.isObject(f)&&!f.fn){this.control(e,f,g)}else{if(h.refs){for(a in h.refs){b=h.refs[a];if(b.isObservable&&b.events[g]){b.enableBubble(g)}}}if(!f.fn){c={};c[g]=f;c.scope=this}else{c=f;if(c.scope===undefined){c.scope=this}}h.addListener(c)}}return e},getModel:function(){return Ext.ModelMgr.getModel(this.model)},closeView:function(a){var b=a.ownerCt;if(b){b.remove(a);b.doLayout();b.setActiveItem(b.items.last())}}});Ext.util.Dispatcher=Ext.extend(Ext.util.Observable,{constructor:function(a){this.addEvents("before-dispatch","dispatch");Ext.util.Dispatcher.superclass.constructor.call(this,a)},dispatch:function(c){var b=new Ext.Interaction(c),a=b.controller,e=b.action,d=Ext.History;if(this.fireEvent("before-dispatch",b)!==false){if(d&&c.historyUrl){d.suspendEvents(false);d.add(c.historyUrl);Ext.defer(d.resumeEvents,100,d)}if(a&&e){a[e].call(a,b);b.dispatched=true
 }this.fireEvent("dispatch",b)}},redirect:function(b){if(b instanceof Ext.data.Model){}else{if(typeof b=="string"){var a=Ext.Router.recognize(b);if(a){return this.dispatch(a)}}}return null},createRedirect:function(a){return function(){Ext.Dispatcher.redirect(a)}}});Ext.Dispatcher=new Ext.util.Dispatcher();Ext.dispatch=function(){return Ext.Dispatcher.dispatch.apply(Ext.Dispatcher,arguments)};Ext.redirect=function(){return Ext.Dispatcher.redirect.apply(Ext.Dispatcher,arguments)};Ext.createRedirect=Ext.Dispatcher.createRedirect;Ext.util.Router=Ext.extend(Ext.util.Observable,{constructor:function(a){a=a||{};Ext.apply(this,a,{defaults:{action:"index"}});this.routes=[];Ext.util.Router.superclass.constructor.call(this,a)},connect:function(b,c){c=Ext.apply({url:b},c||{},this.defaults);var a=new Ext.util.Route(c);this.routes.push(a);return a},recognize:function(c){var b=this.routes,e=b.length,d,a;for(d=0;d<e;d++){a=b[d].recognize(c);if(a!=undefined){return a}}return undefined},draw:f
 unction(a){a.call(this,this)}});Ext.Router=new Ext.util.Router();Ext.util.Route=Ext.extend(Object,{constructor:function(a){Ext.apply(this,a,{conditions:{}});this.paramMatchingRegex=new RegExp(/:([0-9A-Za-z\_]*)/g);this.paramsInMatchString=this.url.match(this.paramMatchingRegex)||[];this.matcherRegex=this.createMatcherRegex(this.url)},recognize:function(a){if(this.recognizes(a)){var b=this.matchesFor(a);return Ext.applyIf(b,{controller:this.controller,action:this.action,historyUrl:a})}},recognizes:function(a){return this.matcherRegex.test(a)},matchesFor:function(b){var f={},e=this.paramsInMatchString,a=b.match(this.matcherRegex),d=e.length,c;a.shift();for(c=0;c<d;c++){f[e[c].replace(":","")]=a[c]}return f},urlFor:function(a){},createMatcherRegex:function(a){var e=this.paramsInMatchString,d=e.length,b,c,f;for(b=0;b<d;b++){c=this.conditions[e[b]];f=Ext.util.Format.format("({0})",c||"[%a-zA-Z0-9\\_\\s,]+");a=a.replace(new RegExp(e[b]),f)}return new RegExp("^"+a+"$")}});Ext.Inter
 action=Ext.extend(Ext.util.Observable,{controller:"",action:"",dispatched:false,constructor:function(a){Ext.Interaction.superclass.constructor.apply(this,arguments);a=a||{};Ext.applyIf(a,{scope:this});Ext.apply(this,a);if(typeof this.controller=="string"){this.controller=Ext.ControllerManager.get(this.controller)}}});Ext.Application=Ext.extend(Ext.util.Observable,{scope:undefined,useHistory:true,autoUpdateComponentProfiles:true,setProfilesOnLaunch:true,constructor:function(b){this.addEvents("launch","beforeprofilechange","profilechange");Ext.Application.superclass.constructor.call(this,b);this.bindReady();var a=this.name;if(a){window[a]=this;Ext.ns(a,a+".views",a+".stores",a+".models",a+".controllers")}if(Ext.addMetaTags){Ext.addMetaTags(b)}},bindReady:function(){Ext.onReady(this.onReady,this)},launch:Ext.emptyFn,useLoadMask:false,loadMaskFadeDuration:1000,loadMaskRemoveDuration:1050,autoInitViewport:true,dispatch:function(a){return Ext.dispatch(a)},initLoadMask:function(){v
 ar c=this.useLoadMask,a="loading-mask",b=typeof c=="string"?c:a;if(c){if(b==a){Ext.getBody().createChild({id:a})}var e=Ext.get("loading-mask"),d=this.loadMaskFadeDuration,f=this.loadMaskRemoveDuration;Ext.defer(function(){e.addCls("fadeout");Ext.defer(function(){e.remove()},f)},d)}},onBeforeLaunch:function(){var d=Ext.History,c=d&&this.useHistory,b=this.determineProfile(true);if(c){this.historyForm=Ext.getBody().createChild({id:"history-form",cls:"x-hide-display",style:"display: none;",tag:"form",action:"#",children:[{tag:"div",children:[{tag:"input",id:d.fieldId,type:"hidden"},{tag:"iframe",id:d.iframeId}]}]});d.init();d.on("change",this.onHistoryChange,this);var a=d.getToken();if(this.launch.call(this.scope||this,b)!==false){Ext.redirect(a||this.defaultUrl||{controller:"application",action:"index"})}}else{this.launch.call(this.scope||this,b)}this.launched=true;this.fireEvent("launch",this);if(this.setProfilesOnLaunch){this.updateComponentProfiles(b)}},onReady:function(){if
 (this.useLoadMask){this.initLoadMask()}Ext.EventManager.onOrientationChange(this.determineProfile,this);if(this.autoInitViewport){Ext.Viewport.init(this.onBeforeLaunch,this)}else{this.onBeforeLaunch()}return this},determineProfile:function(b){var d=this.currentProfile,a=this.profiles,c;for(c in a){if(a[c]()===true){if(c!=d&&this.fireEvent("beforeprofilechange",c,d)!==false){if(this.autoUpdateComponentProfiles){this.updateComponentProfiles(c)}if(b!==true){this.fireEvent("profilechange",c,d)}}this.currentProfile=c;break}}return this.currentProfile},updateComponentProfiles:function(a){Ext.ComponentMgr.each(function(c,b){if(b.setProfile){b.setProfile(a)}})},getProfile:function(){return this.currentProfile},onHistoryChange:function(a){return Ext.redirect(a)}});Ext.ApplicationManager=new Ext.AbstractManager({register:function(c,b){if(Ext.isObject(c)){b=c}else{b.name=c}var a=new Ext.Application(b);this.all.add(a);this.currentApplication=a;return a}});Ext.regApplication=function(){r
 eturn Ext.ApplicationManager.register.apply(Ext.ApplicationManager,arguments)};(function(){var c=Ext.Element=Ext.extend(Object,{defaultUnit:"px",constructor:function(d,e){var f=typeof d=="string"?document.getElementById(d):d,g;if(!f){return null}g=f.id;if(!e&&g&&Ext.cache[g]){return Ext.cache[g].el}this.dom=f;this.id=g||Ext.id(f);return this},set:function(h,e){var f=this.dom,d,g;for(d in h){if(h.hasOwnProperty(d)){g=h[d];if(d=="style"){this.applyStyles(g)}else{if(d=="cls"){f.className=g}else{if(e!==false){f.setAttribute(d,g)}else{f[d]=g}}}}}return this},is:function(d){return Ext.DomQuery.is(this.dom,d)},getValue:function(d){var e=this.dom.value;return d?parseInt(e,10):e},addListener:function(d,g,f,e){Ext.EventManager.on(this.dom,d,g,f||this,e);return this},removeListener:function(d,f,e){Ext.EventManager.un(this.dom,d,f,e);return this},removeAllListeners:function(){Ext.EventManager.removeAll(this.dom);return this},purgeAllListeners:function(){Ext.EventManager.purgeElement(thi
 s,true);return this},remove:function(){var d=this,e=d.dom;if(e){delete d.dom;Ext.removeNode(e)}},isAncestor:function(e){var d=this.dom;e=Ext.getDom(e);if(d&&e){return d.contains(e)}return false},isDescendent:function(d){return Ext.fly(d,"_internal").isAncestor(this)},contains:function(d){return !d?false:this.isAncestor(d)},getAttribute:function(e,f){var g=this.dom;return g.getAttributeNS(f,e)||g.getAttribute(f+":"+e)||g.getAttribute(e)||g[e]},setHTML:function(d){if(this.dom){this.dom.innerHTML=d}return this},getHTML:function(){return this.dom?this.dom.innerHTML:""},hide:function(){this.setVisible(false);return this},show:function(){this.setVisible(true);return this},setVisible:function(h,d){var e=this,g=e.dom,f=this.getVisibilityMode();switch(f){case c.VISIBILITY:this.removeCls(["x-hidden-display","x-hidden-offsets"]);this[h?"removeCls":"addCls"]("x-hidden-visibility");break;case c.DISPLAY:this.removeCls(["x-hidden-visibility","x-hidden-offsets"]);this[h?"removeCls":"addCls"
 ]("x-hidden-display");break;case c.OFFSETS:this.removeCls(["x-hidden-visibility","x-hidden-display"]);this[h?"removeCls":"addCls"]("x-hidden-offsets");break}return e},getVisibilityMode:function(){var e=this.dom,d=c.data(e,"visibilityMode");if(d===undefined){c.data(e,"visibilityMode",d=c.DISPLAY)}return d},setDisplayMode:function(d){c.data(this.dom,"visibilityMode",d);return this}});var a=c.prototype;c.VISIBILITY=1;c.DISPLAY=2;c.OFFSETS=3;c.addMethods=function(d){Ext.apply(a,d)};a.on=a.addListener;a.un=a.removeListener;a.update=a.setHTML;c.get=function(d){var g,f,h;if(!d){return null}if(typeof d=="string"){if(!(f=document.getElementById(d))){return null}if(Ext.cache[d]&&Ext.cache[d].el){g=Ext.cache[d].el;g.dom=f}else{g=c.addToCache(new c(f))}return g}else{if(d.tagName){if(!(h=d.id)){h=Ext.id(d)}if(Ext.cache[h]&&Ext.cache[h].el){g=Ext.cache[h].el;g.dom=d}else{g=c.addToCache(new c(d))}return g}else{if(d instanceof c){if(d!=c.docEl){d.dom=document.getElementById(d.id)||d.dom}ret
 urn d}else{if(d.isComposite){return d}else{if(Ext.isArray(d)){return c.select(d)}else{if(d==document){if(!c.docEl){var e=function(){};e.prototype=a;c.docEl=new e();c.docEl.dom=document;c.docEl.id=Ext.id(document)}return c.docEl}}}}}}return null};c.addToCache=function(d,e){e=e||d.id;Ext.cache[e]={el:d,data:{},events:{}};return d};c.data=function(e,d,f){e=c.get(e);if(!e){return null}var g=Ext.cache[e.id].data;if(arguments.length==2){return g[d]}else{return(g[d]=f)}};c.garbageCollect=function(){if(!Ext.enableGarbageCollector){clearInterval(c.collectorThreadId)}else{var f,e,d=Ext.cache;for(f in d){if(!d.hasOwnProperty(f)){continue}if(d[f].skipGarbageCollection){continue}e=d[f].el.dom;if(!e||!e.parentNode||(!e.offsetParent&&!document.getElementById(f))){if(Ext.enableListenerCollection){Ext.EventManager.removeAll(e)}delete d[f]}}}};c.Flyweight=function(d){this.dom=d};var b=function(){};b.prototype=a;c.Flyweight.prototype=new b;c.Flyweight.prototype.isFlyweight=true;c._flyweights={
 };c.fly=function(f,d){var e=null;d=d||"_global";f=Ext.getDom(f);if(f){(c._flyweights[d]=c._flyweights[d]||new c.Flyweight()).dom=f;e=c._flyweights[d]}return e};Ext.get=c.get;Ext.fly=c.fly})();Ext.applyIf(Ext.Element,{unitRe:/\d+(px|em|%|en|ex|pt|in|cm|mm|pc)$/i,camelRe:/(-[a-z])/gi,opacityRe:/alpha\(opacity=(.*)\)/i,propertyCache:{},defaultUnit:"px",borders:{l:"border-left-width",r:"border-right-width",t:"border-top-width",b:"border-bottom-width"},paddings:{l:"padding-left",r:"padding-right",t:"padding-top",b:"padding-bottom"},margins:{l:"margin-left",r:"margin-right",t:"margin-top",b:"margin-bottom"},addUnits:function(b,a){if(b===""||b=="auto"||b===null||b===undefined){b=b||""}else{if(!isNaN(b)||!this.unitRe.test(b)){b=b+(a||this.defaultUnit||"px")}}return b},parseBox:function(b){if(typeof b!="string"){b=b.toString()}var c=b.split(" "),a=c.length;if(a==1){c[1]=c[2]=c[3]=c[0]}else{if(a==2){c[2]=c[0];c[3]=c[1]}else{if(a==3){c[3]=c[1]}}}return{top:parseFloat(c[0])||0,right:par
 seFloat(c[1])||0,bottom:parseFloat(c[2])||0,left:parseFloat(c[3])||0}},unitizeBox:function(c,b){var a=this.addUnits,d=this.parseBox(c);return a(d.top,b)+" "+a(d.right,b)+" "+a(d.bottom,b)+" "+a(d.left,b)},camelReplaceFn:function(b,c){return c.charAt(1).toUpperCase()},normalize:function(a){return this.propertyCache[a]||(this.propertyCache[a]=a=="float"?"cssFloat":a.replace(this.camelRe,this.camelReplaceFn))},getDocumentHeight:function(){return Math.max(!Ext.isStrict?document.body.scrollHeight:document.documentElement.scrollHeight,this.getViewportHeight())},getDocumentWidth:function(){return Math.max(!Ext.isStrict?document.body.scrollWidth:document.documentElement.scrollWidth,this.getViewportWidth())},getViewportHeight:function(){return window.innerHeight},getViewportWidth:function(){return window.innerWidth},getViewSize:function(){return{width:window.innerWidth,height:window.innerHeight}},getOrientation:function(){if(Ext.supports.OrientationChange){return(window.orientation==
 0)?"portrait":"landscape"}return(window.innerHeight>window.innerWidth)?"portrait":"landscape"},fromPoint:function(a,b){return Ext.get(document.elementFromPoint(a,b))}});Ext.applyIf(Ext.Element,{getComputedTransformOffset:function(c){if(c instanceof Ext.Element){c=c.dom}var a=window.getComputedStyle(c).webkitTransform,b=a!="none"?new WebKitCSSMatrix(a):new WebKitCSSMatrix();if(typeof b.m41!="undefined"){return new Ext.util.Offset(b.m41,b.m42)}else{if(typeof b.d!="undefined"){return new Ext.util.Offset(b.d,b.e)}}return new Ext.util.Offset(0,0)},cssTransform:function(c,b){if(c instanceof Ext.Element){c=c.dom}var a=new WebKitCSSMatrix();Ext.iterate(b,function(e,d){d=Ext.isArray(d)?d:[d];a=a[e].apply(a,d)});if(Ext.supports.CSS3DTransform){c.style.webkitTransform="matrix3d("+a.m11+", "+a.m12+", "+a.m13+", "+a.m14+", "+a.m21+", "+a.m22+", "+a.m23+", "+a.m24+", "+a.m31+", "+a.m32+", "+a.m33+", "+a.m34+", "+a.m41+", "+a.m42+", "+a.m43+", "+a.m44+")"}else{c.style.webkitTransform=a}},c
 ssTranslate:function(a,b){if(a instanceof Ext.Element){a=a.dom}if(Ext.supports.CSS3DTransform){a.style.webkitTransform="translate3d("+b.x+"px, "+b.y+"px, 0px)"}else{a.style.webkitTransform="translate("+b.x+"px, "+b.y+"px)"}}});Ext.Element.addMethods({getY:function(a){return this.getXY(a)[1]},getX:function(a){return this.getXY(a)[0]},getXY:function(){var a=window.webkitConvertPointFromNodeToPage(this.dom,new WebKitPoint(0,0));return[a.x,a.y]},getOffsetsTo:function(a){var c=this.getXY(),b=Ext.fly(a,"_internal").getXY();return[c[0]-b[0],c[1]-b[1]]},setXY:function(d){var b=this;if(arguments.length>1){d=[d,arguments[1]]}var c=b.translatePoints(d),a=b.dom.style;for(d in c){if(!c.hasOwnProperty(d)){continue}if(!isNaN(c[d])){a[d]=c[d]+"px"}}return b},setX:function(a){return this.setXY([a,this.getY()])},setY:function(a){return this.setXY([this.getX(),a])},setLeft:function(a){this.setStyle("left",Ext.Element.addUnits(a));return this},setTop:function(a){this.setStyle("top",Ext.Element.
 addUnits(a));return this},setTopLeft:function(c,b){var a=Ext.Element.addUnits;this.setStyle("top",a(c));this.setStyle("left",a(b));return this},setRight:function(a){this.setStyle("right",Ext.Element.addUnits(a));return this},setBottom:function(a){this.setStyle("bottom",Ext.Element.addUnits(a));return this},getLeft:function(a){return parseInt(this.getStyle("left"),10)||0},getRight:function(a){return parseInt(this.getStyle("right"),10)||0},getTop:function(a){return parseInt(this.getStyle("top"),10)||0},getBottom:function(a){return parseInt(this.getStyle("bottom"),10)||0},setBox:function(d,c,b,a){var e;if(Ext.isObject(d)){b=d.width;a=d.height;c=d.top;d=d.left}if(d!==e){this.setLeft(d)}if(c!==e){this.setTop(c)}if(b!==e){this.setWidth(b)}if(a!==e){this.setHeight(a)}return this},getBox:function(g,j){var h=this,e=h.dom,c=e.offsetWidth,k=e.offsetHeight,n,f,d,a,m,i;if(!j){n=h.getXY()}else{if(g){n=[0,0]}else{n=[parseInt(h.getStyle("left"),10)||0,parseInt(h.getStyle("top"),10)||0]}}if(
 !g){f={x:n[0],y:n[1],0:n[0],1:n[1],width:c,height:k}}else{d=h.getBorderWidth.call(h,"l")+h.getPadding.call(h,"l");a=h.getBorderWidth.call(h,"r")+h.getPadding.call(h,"r");m=h.getBorderWidth.call(h,"t")+h.getPadding.call(h,"t");i=h.getBorderWidth.call(h,"b")+h.getPadding.call(h,"b");f={x:n[0]+d,y:n[1]+m,0:n[0]+d,1:n[1]+m,width:c-(d+a),height:k-(m+i)}}f.left=f.x;f.top=f.y;f.right=f.x+f.width;f.bottom=f.y+f.height;return f},getPageBox:function(e){var g=this,c=g.dom,j=c.offsetWidth,f=c.offsetHeight,m=g.getXY(),k=m[1],a=m[0]+j,i=m[1]+f,d=m[0];if(!c){return new Ext.util.Region()}if(e){return new Ext.util.Region(k,a,i,d)}else{return{left:d,top:k,width:j,height:f,right:a,bottom:i}}},translatePoints:function(a,g){g=isNaN(a[1])?g:a[1];a=isNaN(a[0])?a:a[0];var d=this,e=d.isStyle("position","relative"),f=d.getXY(),b=parseInt(d.getStyle("left"),10),c=parseInt(d.getStyle("top"),10);b=!isNaN(b)?b:(e?0:d.dom.offsetLeft);c=!isNaN(c)?c:(e?0:d.dom.offsetTop);return{left:(a-f[0]+b),top:(g-f[1]+c
 )}}});(function(){Ext.Element.classReCache={};var b=Ext.Element,a=document.defaultView;b.addMethods({marginRightRe:/marginRight/i,trimRe:/^\s+|\s+$/g,spacesRe:/\s+/,addCls:function(g){var h=this,f,c,e,d=[];if(!Ext.isArray(g)){if(g&&!this.hasCls(g)){h.dom.className+=" "+g}}else{for(f=0,c=g.length;f<c;f++){e=g[f];if(e&&!h.hasCls(e)){d.push(e)}}if(d.length){h.dom.className+=" "+d.join(" ")}}return h},addClass:function(){throw new Error("Component: addClass has been deprecated. Please use addCls.")},removeCls:function(h){var j=this,g,d,c,f,e;if(!Ext.isArray(h)){h=[h]}if(j.dom&&j.dom.className){e=j.dom.className.replace(this.trimRe,"").split(this.spacesRe);for(g=0,c=h.length;g<c;g++){f=h[g];if(typeof f=="string"){f=f.replace(this.trimRe,"");d=e.indexOf(f);if(d!=-1){e.splice(d,1)}}}j.dom.className=e.join(" ")}return j},removeClass:function(){throw new Error("Component: removeClass has been deprecated. Please use removeCls.")},mask:function(d,f,i){var g=this,e=g.dom,c=Ext.Element.d
 ata(e,"mask"),k,j,h="";g.addCls("x-masked");if(g.getStyle("position")=="static"){g.addCls("x-masked-relative")}if(c){c.remove()}if(Ext.isString(f)&&!Ext.isEmpty(f)){h=" "+f}else{if(f){h=" x-mask-gray"}}k=g.createChild({cls:"x-mask"+((i!==false)?"":" x-mask-gray"),html:d?('<div class="'+(f||"x-mask-message")+'">'+d+"</div>"):""});j=g.getSize();Ext.Element.data(e,"mask",k);if(e===document.body){j.height=window.innerHeight;if(g.orientationHandler){Ext.EventManager.unOrientationChange(g.orientationHandler,g)}g.orientationHandler=function(){j=g.getSize();j.height=window.innerHeight;k.setSize(j)};Ext.EventManager.onOrientationChange(g.orientationHandler,g)}k.setSize(j);if(Ext.is.iPad){Ext.repaint()}},unmask:function(){var d=this,e=d.dom,c=Ext.Element.data(e,"mask");if(c){c.remove();Ext.Element.data(e,"mask",undefined)}d.removeCls(["x-masked","x-masked-relative"]);if(e===document.body){Ext.EventManager.unOrientationChange(d.orientationHandler,d);delete d.orientationHandler}},radioC
 ls:function(f){var g=this.dom.parentNode.childNodes,d;f=Ext.isArray(f)?f:[f];for(var e=0,c=g.length;e<c;e++){d=g[e];if(d&&d.nodeType==1){Ext.fly(d,"_internal").removeCls(f)}}return this.addCls(f)},radioClass:function(){throw new Error("Component: radioClass has been deprecated. Please use radioCls.")},toggleCls:function(c){return this.hasCls(c)?this.removeCls(c):this.addCls(c)},toggleClass:function(){throw new Error("Component: toggleClass has been deprecated. Please use toggleCls.")},hasCls:function(c){return c&&(" "+this.dom.className+" ").indexOf(" "+c+" ")!=-1},hasClass:function(){throw new Error("Element: hasClass has been deprecated. Please use hasCls.");return this.hasCls.apply(this,arguments)},replaceCls:function(d,c){return this.removeCls(d).addCls(c)},replaceClass:function(){throw new Error("Component: replaceClass has been deprecated. Please use replaceCls.")},isStyle:function(c,d){return this.getStyle(c)==d},getStyle:function(i){var h=this.dom,d,g,f,c=Ext.is,e=h.
 style;i=b.normalize(i);f=(a)?a.getComputedStyle(h,""):h.currentStyle;d=(f)?f[i]:null;if(d&&!c.correctRightMargin&&this.marginRightRe.test(i)&&e.position!="absolute"&&d!="0px"){g=e.display;e.display="inline-block";d=a.getComputedStyle(h,null)[i];e.display=g}d||(d=e[i]);if(!c.correctTransparentColor&&d=="rgba(0, 0, 0, 0)"){d="transparent"}return d},setStyle:function(f,e){var c,d;if(typeof f=="string"){c={};c[f]=e;f=c}for(d in f){if(f.hasOwnProperty(d)){this.dom.style[b.normalize(d)]=f[d]}}return this},applyStyles:function(e){if(e){var d,c,f=this.dom;if(typeof e=="function"){e=e.call()}if(typeof e=="string"){e=Ext.util.Format.trim(e).split(/\s*(?::|;)\s*/);for(d=0,c=e.length;d<c;){f.style[b.normalize(e[d++])]=e[d++]}}else{if(typeof e=="object"){this.setStyle(e)}}}},getHeight:function(d){var e=this.dom,c=d?(e.clientHeight-this.getPadding("tb")):e.offsetHeight;return c>0?c:0},getWidth:function(c){var e=this.dom,d=c?(e.clientWidth-this.getPadding("lr")):e.offsetWidth;return d>0?d:
 0},setWidth:function(c){var d=this;d.dom.style.width=b.addUnits(c);return d},setHeight:function(c){var d=this;d.dom.style.height=b.addUnits(c);return d},setSize:function(e,c){var f=this,d=f.dom.style;if(Ext.isObject(e)){c=e.height;e=e.width}d.width=b.addUnits(e);d.height=b.addUnits(c);return f},getBorderWidth:function(c){return this.sumStyles(c,b.borders)},getPadding:function(c){return this.sumStyles(c,b.paddings)},getMargin:function(c){return this.sumStyles(c,b.margins)},getViewSize:function(){var c=document,d=this.dom;if(d==c||d==c.body){return{width:b.getViewportWidth(),height:b.getViewportHeight()}}else{return{width:d.clientWidth,height:d.clientHeight}}},getSize:function(d){var c=this.dom;return{width:Math.max(0,d?(c.clientWidth-this.getPadding("lr")):c.offsetWidth),height:Math.max(0,d?(c.clientHeight-this.getPadding("tb")):c.offsetHeight)}},repaint:function(){var c=this.dom;this.addCls("x-repaint");c.style.background="transparent none";setTimeout(function(){c.style.back
 ground=null;Ext.get(c).removeCls("x-repaint")},1);return this},getOuterWidth:function(){return this.getWidth()+this.getMargin("lr")},getOuterHeight:function(){return this.getHeight()+this.getMargin("tb")},sumStyles:function(h,g){var j=0,d=h.match(/\w/g),c=d.length,f,e;for(e=0;e<c;e++){f=d[e]&&parseFloat(this.getStyle(g[d[e]]))||0;if(f){j+=Math.abs(f)}}return j}})})();Ext.Element.addMethods({findParent:function(h,g,c){var e=this.dom,a=document.body,f=0,d;g=g||50;if(isNaN(g)){d=Ext.getDom(g);g=Number.MAX_VALUE}while(e&&e.nodeType==1&&f<g&&e!=a&&e!=d){if(Ext.DomQuery.is(e,h)){return c?Ext.get(e):e}f++;e=e.parentNode}return null},findParentNode:function(d,c,a){var b=Ext.fly(this.dom.parentNode,"_internal");return b?b.findParent(d,c,a):null},up:function(b,a){return this.findParentNode(b,a,true)},select:function(a,b){return Ext.Element.select(a,this.dom,b)},query:function(a){return Ext.DomQuery.select(a,this.dom)},down:function(a,b){var c=Ext.DomQuery.selectNode(a,this.dom);return
  b?c:Ext.get(c)},child:function(a,b){var d,c=this,e;e=Ext.get(c).id;e=e.replace(/[\.:]/g,"\\$0");d=Ext.DomQuery.selectNode("#"+e+" > "+a,c.dom);return b?d:Ext.get(d)},parent:function(a,b){return this.matchNode("parentNode","parentNode",a,b)},next:function(a,b){return this.matchNode("nextSibling","nextSibling",a,b)},prev:function(a,b){return this.matchNode("previousSibling","previousSibling",a,b)},first:function(a,b){return this.matchNode("nextSibling","firstChild",a,b)},last:function(a,b){return this.matchNode("previousSibling","lastChild",a,b)},matchNode:function(b,e,a,c){if(!this.dom){return null}var d=this.dom[e];while(d){if(d.nodeType==1&&(!a||Ext.DomQuery.is(d,a))){return !c?Ext.get(d):d}d=d[b]}return null}});Ext.Element.addMethods({getScrollParent:function(){var b=this.dom,a;while(b&&b!=document.body){if(b.id&&(a=Ext.ScrollManager.get(b.id))){return a}b=b.parentNode}return null}});Ext.Element.addMethods({appendChild:function(a){return Ext.get(a).appendTo(this)},appendT
 o:function(a){Ext.getDom(a).appendChild(this.dom);return this},insertBefore:function(a){a=Ext.getDom(a);a.parentNode.insertBefore(this.dom,a);return this},insertAfter:function(a){a=Ext.getDom(a);a.parentNode.insertBefore(this.dom,a.nextSibling);return this},insertFirst:function(b,a){b=b||{};if(b.nodeType||b.dom||typeof b=="string"){b=Ext.getDom(b);this.dom.insertBefore(b,this.dom.firstChild);return !a?Ext.get(b):b}else{return this.createChild(b,this.dom.firstChild,a)}},insertSibling:function(e,c,d){var f=this,b,a=(c||"before").toLowerCase()=="after",g;if(Ext.isArray(e)){g=f;Ext.each(e,function(h){b=Ext.fly(g,"_internal").insertSibling(h,c,d);if(a){g=b}});return b}e=e||{};if(e.nodeType||e.dom){b=f.dom.parentNode.insertBefore(Ext.getDom(e),a?f.dom.nextSibling:f.dom);if(!d){b=Ext.get(b)}}else{if(a&&!f.dom.nextSibling){b=Ext.DomHelper.append(f.dom.parentNode,e,!d)}else{b=Ext.DomHelper[a?"insertAfter":"insertBefore"](f.dom,e,!d)}}return b},replace:function(a){a=Ext.get(a);this.in
 sertBefore(a);a.remove();return this},replaceWith:function(a){var b=this;if(a.nodeType||a.dom||typeof a=="string"){a=Ext.get(a);b.dom.parentNode.insertBefore(a,b.dom)}else{a=Ext.DomHelper.insertBefore(b.dom,a)}delete Ext.cache[b.id];Ext.removeNode(b.dom);b.id=Ext.id(b.dom=a);Ext.Element.addToCache(b.isFlyweight?new Ext.Element(b.dom):b);return b},createChild:function(b,a,c){b=b||{tag:"div"};if(a){return Ext.DomHelper.insertBefore(a,b,c!==true)}else{return Ext.DomHelper[!this.dom.firstChild?"overwrite":"append"](this.dom,b,c!==true)}},wrap:function(a,b){var c=Ext.DomHelper.insertBefore(this.dom,a||{tag:"div"},!b);c.dom?c.dom.appendChild(this.dom):c.appendChild(this.dom);return c},insertHtml:function(b,c,a){var d=Ext.DomHelper.insertHtml(b,this.dom,c);return a?Ext.get(d):d}});Ext.Element.addMethods({getAnchorXY:function(f,j,m){f=(f||"tl").toLowerCase();m=m||{};var i=this,a=i.dom==document.body||i.dom==document,b=m.width||a?window.innerWidth:i.getWidth(),k=m.height||a?window.in
 nerHeight:i.getHeight(),l,c=Math.round,d=i.getXY(),h=a?0:!j?d[0]:0,g=a?0:!j?d[1]:0,e={c:[c(b*0.5),c(k*0.5)],t:[c(b*0.5),0],l:[0,c(k*0.5)],r:[b,c(k*0.5)],b:[c(b*0.5),k],tl:[0,0],bl:[0,k],br:[b,k],tr:[b,0]};l=e[f];return[l[0]+h,l[1]+g]},getAlignToXY:function(e,w,h){e=Ext.get(e);if(!e||!e.dom){throw new Error("Element.alignToXY with an element that doesn't exist")}h=h||[0,0];if(!w||w=="?"){w="tl-bl?"}else{if(!(/-/).test(w)&&w!==""){w="tl-"+w}}w=w.toLowerCase();var u=this,d=w.match(/^([a-z]+)-([a-z]+)(\?)?$/),m=window.innerWidth,t=window.innerHeight,c="",a="",z,v,l,k,p,n,f,b,j,i,q,o,g,s;if(!d){throw"Element.alignTo with an invalid alignment "+w}c=d[1];a=d[2];s=!!d[3];z=u.getAnchorXY(c,true);v=e.getAnchorXY(a,false);l=v[0]-z[0]+h[0];k=v[1]-z[1]+h[1];if(s){q=u.getWidth();o=u.getHeight();g=e.getPageBox();b=c.charAt(0);f=c.charAt(c.length-1);i=a.charAt(0);j=a.charAt(a.length-1);n=((b=="t"&&i=="b")||(b=="b"&&i=="t"));p=((f=="r"&&j=="l")||(f=="l"&&j=="r"));if(l+q>m){l=p?g.left-q:m-q}i
 f(l<0){l=p?g.right:0}if(k+o>t){k=n?g.top-o:t-o}if(k<0){k=n?g.bottom:0}}return[l,k]}});Ext.CompositeElement=function(b,a){this.elements=[];this.add(b,a);this.el=new Ext.Element.Flyweight()};Ext.CompositeElement.prototype={isComposite:true,getElement:function(a){var b=this.el;b.dom=a;b.id=a.id;return b},transformElement:function(a){return Ext.getDom(a)},getCount:function(){return this.elements.length},add:function(d,b){var e=this,f=e.elements;if(!d){return this}if(typeof d=="string"){d=Ext.Element.selectorFunction(d,b)}else{if(d.isComposite){d=d.elements}else{if(!Ext.isIterable(d)){d=[d]}}}for(var c=0,a=d.length;c<a;++c){f.push(e.transformElement(d[c]))}return e},invoke:function(f,b){var g=this,d=g.elements,a=d.length,h,c;for(c=0;c<a;c++){h=d[c];if(h){Ext.Element.prototype[f].apply(g.getElement(h),b)}}return g},item:function(b){var d=this,c=d.elements[b],a=null;if(c){a=d.getElement(c)}return a},addListener:function(b,h,g,f){var d=this.elements,a=d.length,c,j;for(c=0;c<a;c++){j
 =d[c];if(j){Ext.EventManager.on(j,b,h,g||j,f)}}return this},each:function(f,d){var g=this,c=g.elements,a=c.length,b,h;for(b=0;b<a;b++){h=c[b];if(h){h=this.getElement(h);if(f.call(d||h,h,g,b)){break}}}return g},fill:function(a){var b=this;b.elements=[];b.add(a);return b},filter:function(a){var b=[],d=this,e=d.elements,c=Ext.isFunction(a)?a:function(f){return f.is(a)};d.each(function(h,f,g){if(c(h,g)!==false){b[b.length]=d.transformElement(h)}});d.elements=b;return d},first:function(){return this.item(0)},last:function(){return this.item(this.getCount()-1)},contains:function(a){return this.indexOf(a)!=-1},indexOf:function(a){return this.elements.indexOf(this.transformElement(a))},clear:function(){this.elements=[]}};Ext.CompositeElement.prototype.on=Ext.CompositeElement.prototype.addListener;(function(){var c,b=Ext.Element.prototype,a=Ext.CompositeElement.prototype;for(c in b){if(Ext.isFunction(b[c])){(function(d){a[d]=a[d]||function(){return this.invoke(d,arguments)}}).call(a,
 c)}}})();if(Ext.DomQuery){Ext.Element.selectorFunction=Ext.DomQuery.select}Ext.Element.select=function(a,b,d){var c;d=(d===false)?false:true;if(typeof a=="string"){c=Ext.Element.selectorFunction(a,b)}else{if(a.length!==undefined){c=a}else{throw new Error("Invalid selector")}}return d?new Ext.CompositeElement(c):c};Ext.select=Ext.Element.select;Ext.CompositeElementLite=Ext.CompositeElement;Ext.apply(Ext.CompositeElementLite.prototype,{addElements:function(c,a){if(!c){return this}if(typeof c=="string"){c=Ext.Element.selectorFunction(c,a)}var b=this.elements;Ext.each(c,function(d){b.push(Ext.get(d))});return this},removeElement:function(d,e){var c=this,a=this.elements,b;Ext.each(d,function(f){if((b=(a[f]||a[f=c.indexOf(f)]))){if(e){if(b.dom){b.remove()}else{Ext.removeNode(b)}}a.splice(f,1)}});return this},replaceElement:function(e,c,a){var b=!isNaN(e)?e:this.indexOf(e),f;if(b>-1){c=Ext.getDom(c);if(a){f=this.elements[b];f.parentNode.insertBefore(c,f);Ext.removeNode(f)}this.elem
 ents.splice(b,1,c)}return this}});Ext.DomHelper={emptyTags:/^(?:br|frame|hr|img|input|link|meta|range|spacer|wbr|area|param|col)$/i,confRe:/tag|children|cn|html$/i,endRe:/end/i,markup:function(h){var d="",c,g,f,a,j;if(typeof h=="string"){d=h}else{if(Ext.isArray(h)){for(var e=0;e<h.length;e++){if(h[e]){d+=this.markup(h[e])}}}else{d+="<"+(h.tag=h.tag||"div");for(c in h){if(!h.hasOwnProperty(c)){continue}g=h[c];if(!this.confRe.test(c)){if(typeof g=="object"){d+=" "+c+'="';for(f in g){if(!g.hasOwnProperty(f)){continue}d+=f+":"+g[f]+";"}d+='"'}else{d+=" "+({cls:"class",htmlFor:"for"}[c]||c)+'="'+g+'"'}}}if(this.emptyTags.test(h.tag)){d+="/>"}else{d+=">";if((j=h.children||h.cn)){d+=this.markup(j)}else{if(h.html){d+=h.html}}d+="</"+h.tag+">"}}}return d},applyStyles:function(d,e){if(e){var b=0,a,c;d=Ext.fly(d);if(typeof e=="function"){e=e.call()}if(typeof e=="string"){e=Ext.util.Format.trim(e).split(/\s*(?::|;)\s*/);for(a=e.length;b<a;){d.setStyle(e[b++],e[b++])}}else{if(Ext.isObjec
 t(e)){d.setStyle(e)}}}},insertHtml:function(f,a,g){var e={},c,i,h,j,d,b;f=f.toLowerCase();e.beforebegin=["BeforeBegin","previousSibling"];e.afterend=["AfterEnd","nextSibling"];h=a.ownerDocument.createRange();i="setStart"+(this.endRe.test(f)?"After":"Before");if(e[f]){h[i](a);j=h.createContextualFragment(g);a.parentNode.insertBefore(j,f=="beforebegin"?a:a.nextSibling);return a[(f=="beforebegin"?"previous":"next")+"Sibling"]}else{d=(f=="afterbegin"?"first":"last")+"Child";if(a.firstChild){h[i](a[d]);j=h.createContextualFragment(g);if(f=="afterbegin"){a.insertBefore(j,a.firstChild)}else{a.appendChild(j)}}else{a.innerHTML=g}return a[d]}throw'Illegal insertion point -> "'+f+'"'},insertBefore:function(a,c,b){return this.doInsert(a,c,b,"beforebegin")},insertAfter:function(a,c,b){return this.doInsert(a,c,b,"afterend","nextSibling")},insertFirst:function(a,c,b){return this.doInsert(a,c,b,"afterbegin","firstChild")},append:function(a,c,b){return this.doInsert(a,c,b,"beforeend","",true
 )},overwrite:function(a,c,b){a=Ext.getDom(a);a.innerHTML=this.markup(c);return b?Ext.get(a.firstChild):a.firstChild},doInsert:function(d,f,e,g,c,a){var b=this.insertHtml(g,Ext.getDom(d),this.markup(f));return e?Ext.get(b,true):b}};Ext.DomQuery={select:function(h,b){var g=[],d,f,e,c,a;b=b||document;if(typeof b=="string"){b=document.getElementById(b)}h=h.split(",");for(f=0,c=h.length;f<c;f++){if(typeof h[f]=="string"){d=b.querySelectorAll(h[f]);for(e=0,a=d.length;e<a;e++){g.push(d[e])}}}return g},selectNode:function(b,a){return Ext.DomQuery.select(b,a)[0]},is:function(a,b){if(typeof a=="string"){a=document.getElementById(a)}return Ext.DomQuery.select(b).indexOf(a)!==-1}};Ext.Element.selectorFunction=Ext.DomQuery.select;Ext.query=Ext.DomQuery.select;Ext.Anim=Ext.extend(Object,{isAnim:true,disableAnimations:false,defaultConfig:{from:{},to:{},duration:250,delay:0,easing:"ease-in-out",autoClear:true,out:true,direction:null,reverse:false},opposites:{left:"right",right:"left",up:"do
 wn",down:"up"},constructor:function(a){a=Ext.apply({},a||{},this.defaultConfig);this.config=a;Ext.Anim.superclass.constructor.call(this);this.running=[]},initConfig:function(c,b){var e=this,d={},a=Ext.apply({},b||{},e.config);a.el=c=Ext.get(c);if(a.reverse&&e.opposites[a.direction]){a.direction=e.opposites[a.direction]}if(e.config.before){e.config.before.call(a,c,a)}if(b.before){b.before.call(a.scope||a,c,a)}return a},run:function(c,a){c=Ext.get(c);a=a||{};var d=this,b=c.dom.style,e,f=a.after;a=this.initConfig(c,a);if(this.disableAnimations){for(e in a.to){if(!a.to.hasOwnProperty(e)){continue}b[e]=a.to[e]}this.onTransitionEnd(null,c,{config:a,after:f});return d}c.un("webkitTransitionEnd",d.onTransitionEnd,d);b.webkitTransitionDuration="0ms";for(e in a.from){if(!a.from.hasOwnProperty(e)){continue}b[e]=a.from[e]}setTimeout(function(){if(!c.dom){return}if(a.is3d===true){c.parent().setStyle({"-webkit-perspective":"1200","-webkit-transform-style":"preserve-3d"})}b.webkitTransitio
 nDuration=a.duration+"ms";b.webkitTransitionProperty="all";b.webkitTransitionTimingFunction=a.easing;c.on("webkitTransitionEnd",d.onTransitionEnd,d,{single:true,config:a,after:f});for(e in a.to){if(!a.to.hasOwnProperty(e)){continue}b[e]=a.to[e]}},a.delay||5);d.running[c.id]=a;return d},onTransitionEnd:function(e,c,g){c=Ext.get(c);var b=c.dom.style,a=g.config,f,d=this;if(a.autoClear){for(f in a.to){if(!a.to.hasOwnProperty(f)){continue}b[f]=""}}b.webkitTransitionDuration=null;b.webkitTransitionProperty=null;b.webkitTransitionTimingFunction=null;if(a.is3d){c.parent().setStyle({"-webkit-perspective":"","-webkit-transform-style":""})}if(d.config.after){d.config.after.call(a,c,a)}if(g.after){g.after.call(a.scope||d,c,a)}delete d.running[c.id]}});Ext.Anim.seed=1000;Ext.Anim.run=function(b,c,a){if(b.isComponent){b=b.el}a=a||{};if(c.isAnim){c.run(b,a)}else{if(Ext.isObject(c)){if(a.before&&c.before){a.before=Ext.createInterceptor(a.before,c.before,c.scope)}if(a.after&&c.after){a.after
 =Ext.createInterceptor(a.after,c.after,c.scope)}a=Ext.apply({},a,c);c=c.type}if(!Ext.anims[c]){throw c+" is not a valid animation type."}else{if(b&&b.dom){Ext.anims[c].run(b,a)}}}};Ext.anims={fade:new Ext.Anim({before:function(b){var c=1,a=1,e=b.getStyle("z-index")=="auto"?0:b.getStyle("z-index"),d=e;if(this.out){a=0}else{d=e+1;c=0}this.from={opacity:c,"z-index":d};this.to={opacity:a,"z-index":d}}}),slide:new Ext.Anim({direction:"left",cover:false,reveal:false,before:function(b){var a=b.getStyle("z-index")=="auto"?0:b.getStyle("z-index"),e=a+1,h=0,f=0,i=0,g=0,c=b.getHeight(),d=b.getWidth();if(this.direction=="left"||this.direction=="right"){if(this.out==true){h=-d}else{i=d}}else{if(this.direction=="up"||this.direction=="down"){if(this.out==true){f=-c}else{g=c}}}if(this.direction=="right"||this.direction=="down"){f*=-1;h*=-1;g*=-1;i*=-1}if(this.cover&&this.out){h=0;f=0;e=a}else{if(this.reveal&&!this.out){i=0;g=0;e=a}}this.from={"-webkit-transform":"translate3d("+i+"px, "+g+"p
 x, 0)","z-index":e,opacity:0.99};this.to={"-webkit-transform":"translate3d("+h+"px, "+f+"px, 0)","z-index":e,opacity:1}}}),pop:new Ext.Anim({scaleOnExit:true,before:function(d){var b=1,c=1,g=1,a=1,h=d.getStyle("z-index")=="auto"?0:d.getStyle("z-index"),f=h,e=h;if(!this.out){b=0.01;f=h+1;e=h+1;g=0}else{if(this.scaleOnExit){c=0.01;a=0}else{a=0.8}}this.from={"-webkit-transform":"scale("+b+")","-webkit-transform-origin":"50% 50%",opacity:g,"z-index":f};this.to={"-webkit-transform":"scale("+c+")","-webkit-transform-origin":"50% 50%",opacity:a,"z-index":e}}})};Ext.apply(Ext.anims,{flip:new Ext.Anim({is3d:true,direction:"left",before:function(c){var f="Y",a=1,b=1,e=0,d=0;if(this.out){d=-180;b=0.8}else{e=180;a=0.8}if(this.direction=="up"||this.direction=="down"){f="X"}if(this.direction=="right"||this.direction=="left"){d*=-1;e*=-1}this.from={"-webkit-transform":"rotate"+f+"("+e+"deg) scale("+a+")","-webkit-backface-visibility":"hidden"};this.to={"-webkit-transform":"rotate"+f+"("+d+
 "deg) scale("+b+")","-webkit-backface-visibility":"hidden"}}}),cube:new Ext.Anim({is3d:true,direction:"left",style:"outer",before:function(b){var n="0% 0%",o=0,a=0,k="Y",h=0,i=0,l=1,e=1,g,f=b.getWidth(),d=b.getHeight(),m=true,c=" translateX(0)",j="";if(this.direction=="left"||this.direction=="right"){if(this.out){n="100% 100%";i=f;e=0.5;a=-90}else{n="0% 0%";h=f;l=0.5;o=90}}else{if(this.direction=="up"||this.direction=="down"){k="X";if(this.out){n="100% 100%";i=d;a=90}else{n="0% 0%";h=d;o=-90}}}if(this.direction=="down"||this.direction=="right"){o*=-1;a*=-1;n=(n=="0% 0%")?"100% 100%":"0% 0%"}if(this.style=="inner"){h*=-1;i*=-1;o*=-1;a*=-1;if(!this.out){j=" translateX(0px)";n="0% 50%"}else{j=c;n="100% 50%"}}this.from={"-webkit-transform":"rotate"+k+"("+o+"deg)"+(m?" translateZ("+h+"px)":"")+c,"-webkit-transform-origin":n};this.to={"-webkit-transform":"rotate"+k+"("+a+"deg) translateZ("+i+"px)"+j,"-webkit-transform-origin":n}},duration:250}),wipe:new Ext.Anim({before:function(d
 ){var e=d.getStyle("z-index"),a="",b="100%",c="100%";if(!this.out){zIndex=e+1;a="-webkit-gradient(linear, left bottom, right bottom, from(transparent), to(#000), color-stop(66%, #000), color-stop(33%, transparent))";b=d.getHeight()*100+"px";c=d.getHeight();this.from={"-webkit-mask-image":a,"-webkit-mask-size":d.getWidth()*3+"px "+d.getHeight()+"px","z-index":zIndex,"-webkit-mask-position-x":0};this.to={"-webkit-mask-image":a,"-webkit-mask-size":d.getWidth()*3+"px "+d.getHeight()+"px","z-index":zIndex,"-webkit-mask-position-x":-d.getWidth()*2+"px"}}},duration:500})});Ext.apply(Ext,{version:"1.0.1",versionDetail:{major:1,minor:0,patch:1},setup:function(a){if(a&&typeof a=="object"){if(a.addMetaTags!==false){this.addMetaTags(a)}if(Ext.isFunction(a.onReady)){var b=this;Ext.onReady(function(){var c=arguments;if(a.fullscreen!==false){Ext.Viewport.init(function(){a.onReady.apply(b,c)})}else{a.onReady.apply(this,c)}},a.scope)}}},getDom:function(a){if(!a||!document){return null}return
  a.dom?a.dom:(typeof a=="string"?document.getElementById(a):a)},removeNode:function(a){if(a&&a.parentNode&&a.tagName!="BODY"){Ext.EventManager.removeAll(a);a.parentNode.removeChild(a);delete Ext.cache[a.id]}},addMetaTags:function(b){if(!Ext.isObject(b)){return}var c=Ext.get(document.getElementsByTagName("head")[0]),a,d;if(!Ext.is.Desktop){a=Ext.get(document.createElement("meta"));a.set({name:"viewport",content:"width=device-width, user-scalable=no, initial-scale=1.0, maximum-scale=1.0;"});c.appendChild(a)}if(Ext.is.iOS){if(b.fullscreen!==false){a=Ext.get(document.createElement("meta"));a.set({name:"apple-mobile-web-app-capable",content:"yes"});c.appendChild(a);if(Ext.isString(b.statusBarStyle)){a=Ext.get(document.createElement("meta"));a.set({name:"apple-mobile-web-app-status-bar-style",content:b.statusBarStyle});c.appendChild(a)}}if(b.tabletStartupScreen&&Ext.is.iPad){a=Ext.get(document.createElement("link"));a.set({rel:"apple-touch-startup-image",href:b.tabletStartupScreen
 });c.appendChild(a)}if(b.phoneStartupScreen&&!Ext.is.iPad){a=Ext.get(document.createElement("link"));a.set({rel:"apple-touch-startup-image",href:b.phoneStartupScreen});c.appendChild(a)}if(b.icon){b.phoneIcon=b.tabletIcon=b.icon}d=(b.glossOnIcon===false)?"-precomposed":"";if(Ext.is.iPad&&Ext.isString(b.tabletIcon)){a=Ext.get(document.createElement("link"));a.set({rel:"apple-touch-icon"+d,href:b.tabletIcon});c.appendChild(a)}else{if(!Ext.is.iPad&&Ext.isString(b.phoneIcon)){a=Ext.get(document.createElement("link"));a.set({rel:"apple-touch-icon"+d,href:b.phoneIcon});c.appendChild(a)}}}}});(function(){var a=function(){var c=Ext.getBody(),b=[];if(!c){return false}var d=Ext.is;if(d.Phone){b.push("x-phone")}else{if(d.Tablet){b.push("x-tablet")}else{if(d.Desktop){b.push("x-desktop")}}}if(d.iPad){b.push("x-ipad")}if(d.iOS){b.push("x-ios")}if(d.Android){b.push("x-android")}if(d.Blackberry){b.push("x-bb")}if(d.Standalone){b.push("x-standalone")}if(b.length){c.addCls(b)}return true};if(!
 a()){Ext.onReady(a)}})();Ext.Viewport=new (Ext.extend(Ext.util.Observable,{constructor:function(){var a=this;this.addEvents("orientationchange","resize");this.stretchSizes={};if(Ext.supports.OrientationChange){window.addEventListener("orientationchange",Ext.createDelegate(a.onOrientationChange,a),false)}else{window.addEventListener("resize",Ext.createDelegate(a.onResize,a),false)}if(!Ext.desktop){document.addEventListener("touchstart",Ext.createDelegate(a.onTouchStartCapturing,a),true)}},init:function(c,b){var d=this,e=Math.max(window.innerHeight,window.innerWidth)*2,a=Ext.getBody();d.updateOrientation();this.initialHeight=window.innerHeight;this.initialOrientation=this.orientation;a.setHeight(e);Ext.gesture.Manager.freeze();this.scrollToTop();setTimeout(function(){d.scrollToTop();setTimeout(function(){d.scrollToTop();d.initialHeight=Math.max(d.initialHeight,window.innerHeight);if(c){c.apply(b||window)}d.updateBodySize();Ext.gesture.Manager.thaw()},500)},500)},scrollToTop:fu
 nction(){if(Ext.is.iOS){document.body.scrollTop=document.body.scrollHeight}else{window.scrollTo(0,1)}},updateBodySize:function(){Ext.getBody().setSize(window.innerWidth,window.innerHeight)},updateOrientation:function(){this.lastSize=this.getSize();this.orientation=this.getOrientation()},onTouchStartCapturing:function(a){if(!Ext.currentlyFocusedField&&Ext.is.iOS){this.scrollToTop()}},onOrientationChange:function(){var b=this,a=Ext.getBody();Ext.gesture.Manager.freeze();a.setHeight(a.getWidth());this.updateOrientation();this.fireEvent("orientationchange",this,this.orientation);setTimeout(function(){b.scrollToTop();setTimeout(function(){b.updateBodySize();b.fireResizeEvent();Ext.gesture.Manager.thaw()},200)},200)},fireResizeEvent:function(){var a=this;if(!Ext.is.iOS){if(this.resizeEventTimer){clearTimeout(this.resizeEventTimer)}this.resizeEventTimer=setTimeout(function(){a.fireEvent("resize",a,a.getSize())},500)}else{a.fireEvent("resize",a,a.getSize())}},onResize:function(){if(
 this.orientation!=this.getOrientation()){this.onOrientationChange()}else{var a=this.getSize();if(!Ext.is.iOS&&!Ext.is.Desktop){if((a.width==this.lastSize.width&&a.height>this.lastSize.height)||(a.height==this.lastSize.height&&a.width>this.lastSize.width)){this.fireEvent("resize",this,a)}}else{this.fireEvent("resize",this,a)}}},getSize:function(){var a={width:window.innerWidth,height:window.innerHeight};if(!Ext.is.Desktop){a.height=(this.orientation==this.initialOrientation)?Math.max(this.initialHeight,a.height):a.height}return a},getOffset:function(){return{x:window.pageXOffset,y:window.pageYOffset}},getOrientation:function(){var a=this.getSize();if(window.hasOwnProperty("orientation")){return(window.orientation==0||window.orientation==180)?"portrait":"landscape"}else{if(!Ext.is.iOS&&!Ext.is.Desktop){if((a.width==this.lastSize.width&&a.height<this.lastSize.height)||(a.height==this.lastSize.height&&a.width<this.lastSize.width)){return this.orientation}}return(window.innerHeig
 ht>window.innerWidth)?"portrait":"landscape"}}}));Ext.util.TapRepeater=Ext.extend(Ext.util.Observable,{constructor:function(b,a){this.el=Ext.get(b);Ext.apply(this,a);this.addEvents("touchstart","tap","touchend");this.el.on({touchstart:this.onTouchStart,touchend:this.onTouchEnd,scope:this});if(this.preventDefault||this.stopDefault){this.el.on("tap",this.eventOptions,this)}Ext.util.TapRepeater.superclass.constructor.call(this)},interval:10,delay:250,preventDefault:true,stopDefault:false,timer:0,eventOptions:function(a){if(this.preventDefault){a.preventDefault()}if(this.stopDefault){a.stopEvent()}},destroy:function(){Ext.destroy(this.el);this.clearListeners()},onTouchStart:function(a){clearTimeout(this.timer);if(this.pressClass){this.el.addCls(this.pressClass)}this.tapStartTime=new Date();this.fireEvent("touchstart",this,a);this.fireEvent("tap",this,a);if(this.accelerate){this.delay=400}this.timer=Ext.defer(this.tap,this.delay||this.interval,this,[a])},tap:function(a){this.fire
 Event("tap",this,a);this.timer=Ext.defer(this.tap,this.accelerate?this.easeOutExpo(Ext.util.Date.getElapsed(this.tapStartTime),400,-390,12000):this.interval,this,[a])},easeOutExpo:function(e,a,g,f){return(e==f)?a+g:g*(-Math.pow(2,-10*e/f)+1)+a},onTouchEnd:function(a){clearTimeout(this.timer);this.el.removeCls(this.pressClass);this.fireEvent("touchend",this,a)}});if(!this.JSON){this.JSON={}}(function(){function f(n){return n<10?"0"+n:n}if(typeof Date.prototype.toJSON!=="function"){Date.prototype.toJSON=function(key){return isFinite(this.valueOf())?this.getUTCFullYear()+"-"+f(this.getUTCMonth()+1)+"-"+f(this.getUTCDate())+"T"+f(this.getUTCHours())+":"+f(this.getUTCMinutes())+":"+f(this.getUTCSeconds())+"Z":null};String.prototype.toJSON=Number.prototype.toJSON=Boolean.prototype.toJSON=function(key){return this.valueOf()}}var cx=/[\u0000\u00ad\u0600-\u0604\u070f\u17b4\u17b5\u200c-\u200f\u2028-\u202f\u2060-\u206f\ufeff\ufff0-\uffff]/g,escapable=/[\\\"\x00-\x1f\x7f-\x9f\u00ad\u060
 0-\u0604\u070f\u17b4\u17b5\u200c-\u200f\u2028-\u202f\u2060-\u206f\ufeff\ufff0-\uffff]/g,gap,indent,meta={"\b":"\\b","\t":"\\t","\n":"\\n","\f":"\\f","\r":"\\r",'"':'\\"',"\\":"\\\\"},rep;function quote(string){escapable.lastIndex=0;return escapable.test(string)?'"'+string.replace(escapable,function(a){var c=meta[a];return typeof c==="string"?c:"\\u"+("0000"+a.charCodeAt(0).toString(16)).slice(-4)})+'"':'"'+string+'"'}function str(key,holder){var i,k,v,length,mind=gap,partial,value=holder[key];if(value&&typeof value==="object"&&typeof value.toJSON==="function"){value=value.toJSON(key)}if(typeof rep==="function"){value=rep.call(holder,key,value)}switch(typeof value){case"string":return quote(value);case"number":return isFinite(value)?String(value):"null";case"boolean":case"null":return String(value);case"object":if(!value){return"null"}gap+=indent;partial=[];if(Object.prototype.toString.apply(value)==="[object Array]"){length=value.length;for(i=0;i<length;i+=1){partial[i]=str(
 i,value)||"null"}v=partial.length===0?"[]":gap?"[\n"+gap+partial.join(",\n"+gap)+"\n"+mind+"]":"["+partial.join(",")+"]";gap=mind;return v}if(rep&&typeof rep==="object"){length=rep.length;for(i=0;i<length;i+=1){k=rep[i];if(typeof k==="string"){v=str(k,value);if(v){partial.push(quote(k)+(gap?": ":":")+v)}}}}else{for(k in value){if(Object.hasOwnProperty.call(value,k)){v=str(k,value);if(v){partial.push(quote(k)+(gap?": ":":")+v)}}}}v=partial.length===0?"{}":gap?"{\n"+gap+partial.join(",\n"+gap)+"\n"+mind+"}":"{"+partial.join(",")+"}";gap=mind;return v}return v}if(typeof JSON.stringify!=="function"){JSON.stringify=function(value,replacer,space){var i;gap="";indent="";if(typeof space==="number"){for(i=0;i<space;i+=1){indent+=" "}}else{if(typeof space==="string"){indent=space}}rep=replacer;if(replacer&&typeof replacer!=="function"&&(typeof replacer!=="object"||typeof replacer.length!=="number")){throw new Error("JSON.stringify")}return str("",{"":value})}}if(typeof JSON.parse!=="f
 unction"){JSON.parse=function(text,reviver){var j;function walk(holder,key){var k,v,value=holder[key];if(value&&typeof value==="object"){for(k in value){if(Object.hasOwnProperty.call(value,k)){v=walk(value,k);if(v!==undefined){value[k]=v}else{delete value[k]}}}}return reviver.call(holder,key,value)}text=String(text);cx.lastIndex=0;if(cx.test(text)){text=text.replace(cx,function(a){return"\\u"+("0000"+a.charCodeAt(0).toString(16)).slice(-4)})}if(/^[\],:{}\s]*$/.test(text.replace(/\\(?:["\\\/bfnrt]|u[0-9a-fA-F]{4})/g,"@").replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,"]").replace(/(?:^|:|,)(?:\s*\[)+/g,""))){j=eval("("+text+")");return typeof reviver==="function"?walk({"":j},""):j}throw new SyntaxError("JSON.parse")}}}());Ext.util.JSON={encode:function(a){return JSON.stringify(a)},decode:function(a){return JSON.parse(a)}};Ext.encode=Ext.util.JSON.encode;Ext.decode=Ext.util.JSON.decode;Ext.util.JSONP={queue:[],current:null,request:function(d){d=d||{
 };if(!d.url){return}var b=this;d.params=d.params||{};if(d.callbackKey){d.params[d.callbackKey]="Ext.util.JSONP.callback"}var c=Ext.urlEncode(d.params);var a=document.createElement("script");a.type="text/javascript";this.queue.push({url:d.url,script:a,callback:d.callback||function(){},scope:d.scope||window,params:c||null});if(!this.current){this.next()}},next:function(){this.current=null;if(this.queue.length){this.current=this.queue.shift();this.current.script.src=this.current.url+(this.current.params?("?"+this.current.params):"");document.getElementsByTagName("head")[0].appendChild(this.current.script)}},callback:function(a){this.current.callback.call(this.current.scope,a);document.getElementsByTagName("head")[0].removeChild(this.current.script);this.next()}};Ext.util.Draggable=Ext.extend(Ext.util.Observable,{baseCls:"x-draggable",draggingCls:"x-dragging",proxyCls:"x-draggable-proxy",outOfBoundRestrictFactor:1,direction:"both",constrain:window,threshold:0,delay:0,cancelSelec
 tor:null,disabled:false,revert:false,group:"base",useCssTransform:true,grid:null,snap:null,proxy:null,stack:false,animationDuration:300,updateBoundaryOnTouchStart:true,offsetBoundary:null,dragging:false,vertical:false,horizontal:false,monitorOrientation:true,constructor:function(b,a){this.el=Ext.get(b);this.id=b.id;a=a||{};Ext.apply(this,a);this.addEvents("offsetchange");Ext.util.Draggable.superclass.constructor.call(this,a);if(this.eventTarget==="parent"){this.eventTarget=this.el.parent()}else{this.eventTarget=(this.eventTarget)?Ext.get(this.eventTarget):this.el}if(this.direction=="both"){this.horizontal=true;this.vertical=true}else{if(this.direction=="horizontal"){this.horizontal=true}else{this.vertical=true}}this.el.addCls(this.baseCls);if(this.proxy){this.getProxyEl().addCls(this.proxyCls)}this.startEventName=(this.delay>0)?"taphold":"dragstart";this.dragOptions=(this.delay>0)?{holdThreshold:this.delay}:{direction:this.direction,dragThreshold:this.threshold};this.contain
 er=window;if(this.constrain){if(this.constrain==="parent"){this.container=this.el.parent()}else{if(this.constrain!==window){this.container=Ext.get(this.constrain)}}}this.offset=new Ext.util.Offset();this.linearAnimation={x:new Ext.util.Draggable.Animation.Linear(),y:new Ext.util.Draggable.Animation.Linear()};this.updateBoundary(true);this.setDragging(false);if(!this.disabled){this.enable()}return this},enable:function(){return this.setEnabled(true)},disable:function(){return this.setEnabled(false)},setEnabled:function(a){this.eventTarget[a?"on":"un"](this.startEventName,this.onStart,this,this.dragOptions);this.eventTarget[a?"on":"un"]("drag",this.onDrag,this,this.dragOptions);this.eventTarget[a?"on":"un"]("dragend",this.onDragEnd,this,this.dragOptions);this.eventTarget[a?"on":"un"]("touchstart",this.onTouchStart,this);if(a){Ext.EventManager.onOrientationChange(this.onOrientationChange,this)}else{Ext.EventManager.orientationEvent.removeListener(this.onOrientationChange,this)}
 this.disabled=!a;return this},setUseCssTransform:function(a){if(typeof a=="undefined"){a=true}if(a!=this.useCssTransform){this.useCssTransform=a;var b=new Ext.util.Offset();if(a==false){this.setStyleOffset(this.offset);this.setTransformOffset(b,true)}else{this.setTransformOffset(this.offset);this.setStyleOffset(b)}}return this},setOffset:function(b,a){if(!this.horizontal){b.x=0}if(!this.vertical){b.y=0}if(!(b instanceof Ext.util.Offset)){b=Ext.util.Offset.fromObject(b)}b.round();if(!this.offset.equals(b)){if(a){this.startAnimation(b,a)}else{this.offset=b;this.region=new Ext.util.Region(this.initialRegion.top+b.y,this.initialRegion.right+b.x,this.initialRegion.bottom+b.y,this.initialRegion.left+b.x);if(this.useCssTransform){this.setTransformOffset(b)}else{this.setStyleOffset(b)}this.fireEvent("offsetchange",this,this.offset)}}return this},setTransformOffset:function(b,a){if(a){this.getProxyEl().dom.style.webkitTransform=""}else{Ext.Element.cssTranslate(this.getProxyEl(),b)}re
 turn this},setStyleOffset:function(a){this.getProxyEl().setLeft(a.x);this.getProxyEl().setTop(a.y);return this},startAnimation:function(c,a){this.stopAnimation();var b=Date.now();a=Ext.isNumber(a)?a:this.animationDuration;this.linearAnimation.x.set({startOffset:this.offset.x,endOffset:c.x,startTime:b,duration:a});this.linearAnimation.y.set({startOffset:this.offset.y,endOffset:c.y,startTime:b,duration:a});this.isAnimating=true;this.animationTimer=Ext.defer(this.handleAnimationFrame,0,this);return this},stopAnimation:function(){if(this.isAnimating){clearTimeout(this.animationTimer);this.isAnimating=false;this.setDragging(false)}return this},handleAnimationFrame:function(){if(!this.isAnimating){return}var a=new Ext.util.Offset();a.x=this.linearAnimation.x.getOffset();a.y=this.linearAnimation.y.getOffset();this.setOffset(a);this.animationTimer=Ext.defer(this.handleAnimationFrame,10,this);if((a.x===this.linearAnimation.x.endOffset)&&(a.y===this.linearAnimation.y.endOffset)){this.
 stopAnimation()}},getOffset:function(){var a=this.offset.copy();a.y=-a.y;a.x=-a.x;return a},updateBoundary:function(f){var h;if(typeof f=="undefined"){f=false}this.size={width:this.el.dom.scrollWidth,height:this.el.dom.scrollHeight};if(this.container===window){this.containerBox={left:0,top:0,right:this.container.innerWidth,bottom:this.container.innerHeight,width:this.container.innerWidth,height:this.container.innerHeight}}else{this.containerBox=this.container.getPageBox()}var a=this.el.getXY();this.elBox={left:a[0]-this.offset.x,top:a[1]-this.offset.y,width:this.size.width,height:this.size.height};this.elBox.bottom=this.elBox.top+this.elBox.height;this.elBox.right=this.elBox.left+this.elBox.width;this.initialRegion=this.region=new Ext.util.Region(a[1],a[0]+this.elBox.width,a[1]+this.elBox.height,a[0]);var e=0,c=0,b=0,d=0;if(this.elBox.left<this.containerBox.left){c+=this.containerBox.left-this.elBox.left}else{d-=this.elBox.left-this.containerBox.left}if(this.elBox.right>this
 .containerBox.right){d-=this.elBox.right-this.containerBox.right}else{c+=this.containerBox.right-this.elBox.right}if(this.elBox.top<this.containerBox.top){b+=this.containerBox.top-this.elBox.top}else{e-=this.elBox.top-this.containerBox.top}if(this.elBox.bottom>this.containerBox.bottom){e-=this.elBox.bottom-this.containerBox.bottom}else{b+=this.containerBox.bottom-this.elBox.bottom}h=new Ext.util.Region(e,c,b,d).round();if(this.offsetBoundary&&this.offsetBoundary.equals(h)){return this}this.offsetBoundary=h;var g;if(this.useCssTransform){g=Ext.Element.getComputedTransformOffset(this.getProxyEl())}else{g=new Ext.util.Offset(this.getProxyEl().getLeft(),this.getProxyEl().getTop())}if(!this.offset.equals(g)||f){this.setOffset(g)}return this},onTouchStart:function(){},onStart:function(a){if(this.updateBoundaryOnTouchStart){this.updateBoundary()}this.stopAnimation();if(this.dragging){this.onDragEnd(a)}this.setDragging(true);this.startTouchPoint=new Ext.util.Point(a.startX,a.startY)
 ;this.startOffset=this.offset.copy();this.fireEvent("dragstart",this,a);return true},getNewOffsetFromTouchPoint:function(a){var c=a.x-this.startTouchPoint.x,b=a.y-this.startTouchPoint.y,d=this.offset.copy();if(c==0&&b==0){return d}if(this.horizontal){d.x=this.startOffset.x+c}if(this.vertical){d.y=this.startOffset.y+b}return d},onDrag:function(a){if(!this.dragging){return}this.lastTouchPoint=Ext.util.Point.fromEvent(a);var b=this.getNewOffsetFromTouchPoint(this.lastTouchPoint);if(this.offsetBoundary!=null){b=this.offsetBoundary.restrict(b,this.outOfBoundRestrictFactor)}this.setOffset(b);this.fireEvent("drag",this,a);return true},onDragEnd:function(a){if(this.dragging){this.fireEvent("beforedragend",this,a);if(this.revert&&!this.cancelRevert){this.setOffset(this.startOffset,true)}else{this.setDragging(false)}this.fireEvent("dragend",this,a)}return true},onOrientationChange:function(){this.updateBoundary()},setDragging:function(a){if(a){if(!this.dragging){this.dragging=true;thi
 s.getProxyEl().addCls(this.draggingCls)}}else{if(this.dragging){this.dragging=false;this.getProxyEl().removeCls(this.draggingCls)}}return this},getProxyEl:function(){return this.proxy||this.el},destroy:function(){this.el.removeCls(this.baseCls);this.getProxyEl().removeCls(this.proxyCls);this.clearListeners();this.disable()},reset:function(){this.startOffset=new Ext.util.Offset(0,0);this.setOffset(this.startOffset);var a=this.initialRegion.copy();this.updateBoundary();this.initialRegion=this.region=this.getProxyEl().getPageBox(true);this.startTouchPoint.x+=this.initialRegion.left-a.left;this.startTouchPoint.y+=this.initialRegion.top-a.top},moveTo:function(a,b){this.setOffset(new Ext.util.Offset(a-this.initialRegion.left,b-this.initialRegion.top));return this},isDragging:function(){return this.dragging},isVertical:function(){return this.vertical},isHorizontal:function(){return this.horizontal}});Ext.util.Draggable.Animation={};Ext.util.Draggable.Animation.Abstract=Ext.extend(O
 bject,{startTime:null,startOffset:0,constructor:function(a){a=a||{};this.set(a);if(!this.startTime){this.startTime=Date.now()}},set:function(a,b){if(Ext.isObject(a)){Ext.apply(this,a)}else{this[a]=b}return this},getOffset:Ext.emptyFn});Ext.util.Draggable.Animation.Linear=Ext.extend(Ext.util.Draggable.Animation.Abstract,{duration:0,endOffset:0,getOffset:function(){var c=this.endOffset-this.startOffset,a=Date.now()-this.startTime,b=Math.min(1,(a/this.duration));return this.startOffset+(b*c)}});Ext.util.Droppable=Ext.extend(Ext.util.Observable,{baseCls:"x-droppable",activeCls:"x-drop-active",invalidCls:"x-drop-invalid",hoverCls:"x-drop-hover",validDropMode:"intersect",disabled:false,group:"base",tolerance:null,monitoring:false,constructor:function(b,a){a=a||{};Ext.apply(this,a);this.addEvents("dropactivate","dropdeactivate","dropenter","dropleave","drop");this.el=Ext.get(b);Ext.util.Droppable.superclass.constructor.call(this);if(!this.disabled){this.enable()}this.el.addCls(this
 .baseCls)},onDragStart:function(a,b){if(a.group===this.group){this.monitoring=true;this.el.addCls(this.activeCls);this.region=this.el.getPageBox(true);a.on({drag:this.onDrag,beforedragend:this.onBeforeDragEnd,dragend:this.onDragEnd,scope:this});if(this.isDragOver(a)){this.setCanDrop(true,a,b)}this.fireEvent("dropactivate",this,a,b)}else{a.on({dragend:function(){this.el.removeCls(this.invalidCls)},scope:this,single:true});this.el.addCls(this.invalidCls)}},isDragOver:function(a,b){return this.region[this.validDropMode](a.region)},onDrag:function(a,b){this.setCanDrop(this.isDragOver(a),a,b)},setCanDrop:function(c,a,b){if(c&&!this.canDrop){this.canDrop=true;this.el.addCls(this.hoverCls);this.fireEvent("dropenter",this,a,b)}else{if(!c&&this.canDrop){this.canDrop=false;this.el.removeCls(this.hoverCls);this.fireEvent("dropleave",this,a,b)}}},onBeforeDragEnd:function(a,b){a.cancelRevert=this.canDrop},onDragEnd:function(a,b){this.monitoring=false;this.el.removeCls(this.activeCls);a.u
 n({drag:this.onDrag,beforedragend:this.onBeforeDragEnd,dragend:this.onDragEnd,scope:this});if(this.canDrop){this.canDrop=false;this.el.removeCls(this.hoverCls);this.fireEvent("drop",this,a,b)}this.fireEvent("dropdeactivate",this,a,b)},enable:function(){if(!this.mgr){this.mgr=Ext.util.Observable.observe(Ext.util.Draggable)}this.mgr.on({dragstart:this.onDragStart,scope:this});this.disabled=false},disable:function(){this.mgr.un({dragstart:this.onDragStart,scope:this});this.disabled=true},isDisabled:function(){return this.disabled},isMonitoring:function(){return this.monitoring}});(function(){Ext.ScrollManager=new Ext.AbstractManager();Ext.util.ScrollView=Ext.extend(Ext.util.Observable,{useIndicators:true,indicatorConfig:{},indicatorMargin:4,constructor:function(b,a){var c=[],d=["vertical","horizontal"];Ext.util.ScrollView.superclass.constructor.call(this);["useIndicators","indicatorConfig","indicatorMargin"].forEach(function(e){if(a.hasOwnProperty(e)){this[e]=a[e];delete a[e]}}
 ,this);a.scrollView=this;this.scroller=new Ext.util.Scroller(b,a);if(this.useIndicators===true){d.forEach(function(e){if(this.scroller[e]){c.push(e)}},this)}else{if(d.indexOf(this.useIndicators)!==-1){c.push(this.useIndicators)}}this.indicators={};c.forEach(function(e){this.indicators[e]=new Ext.util.Scroller.Indicator(this.scroller.container,Ext.apply({},this.indicatorConfig,{type:e}))},this);this.mon(this.scroller,{scrollstart:this.onScrollStart,scrollend:this.onScrollEnd,scroll:this.onScroll,scope:this})},onScrollStart:function(){this.showIndicators()},onScrollEnd:function(){this.hideIndicators()},onScroll:function(a){if(a.offsetBoundary==null||(!this.indicators.vertical&&!this.indicators.horizontal)){return}var c,b,e,f=a.offsetBoundary,d=a.offset;this.containerSize=a.containerBox;this.scrollerSize=a.size;this.outOfBoundOffset=f.getOutOfBoundOffset(d);this.restrictedOffset=f.restrict(d);this.boundarySize=f.getSize();if(!this.indicatorSizes){this.indicatorSizes={vertical:0
 ,horizontal:0}}if(!this.indicatorOffsets){this.indicatorOffsets={vertical:0,horizontal:0}}Ext.iterate(this.indicators,function(h,g){c=(h=="vertical")?"height":"width";b=(h=="vertical")?"y":"x";e=(h=="vertical")?"bottom":"right";if(this.scrollerSize[c]<this.containerSize[c]){this.indicatorSizes[h]=this.containerSize[c]*(this.scrollerSize[c]/this.containerSize[c])}else{this.indicatorSizes[h]=this.containerSize[c]*(this.containerSize[c]/this.scrollerSize[c])}this.indicatorSizes[h]-=Math.abs(this.outOfBoundOffset[b]);this.indicatorSizes[h]=Math.max(this.indicatorMargin*4,this.indicatorSizes[h]);if(this.boundarySize[c]!=0){this.indicatorOffsets[h]=(((f[e]-this.restrictedOffset[b])/this.boundarySize[c])*(this.containerSize[c]-this.indicatorSizes[h]))}else{if(d[b]<f[e]){this.indicatorOffsets[h]=this.containerSize[c]-this.indicatorSizes[h]}else{this.indicatorOffsets[h]=0}}g.setOffset(this.indicatorOffsets[h]+this.indicatorMargin);g.setSize(this.indicatorSizes[h]-(this.indicatorMargi
 n*2))},this)},showIndicators:function(){Ext.iterate(this.indicators,function(b,a){a.show()},this);return this},hideIndicators:function(){Ext.iterate(this.indicators,function(b,a){a.hide()},this)},destroy:function(){this.scroller.destroy();if(this.indicators){Ext.iterate(this.indicators,function(b,a){a.destroy()},this)}return Ext.util.ScrollView.superclass.destroy.apply(this,arguments)}});Ext.util.Scroller=Ext.extend(Ext.util.Draggable,{baseCls:"",draggingCls:"",direction:"both",constrain:"parent",outOfBoundRestrictFactor:0.5,acceleration:30,fps:Ext.is.Blackberry?22:80,autoAdjustFps:!Ext.is.Blackberry,friction:0.5,startMomentumResetTime:350,springTension:0.3,minVelocityForAnimation:1,bounces:true,momentum:true,cancelRevert:true,threshold:5,constructor:function(f,d){f=Ext.get(f);var a=Ext.ScrollManager.get(f.id);if(a){return Ext.apply(a,d)}Ext.util.Scroller.superclass.constructor.apply(this,arguments);this.addEvents("scrollstart","scroll","scrollend","bouncestart","bounceend")
 ;this.on({dragstart:this.onDragStart,offsetchange:this.onOffsetChange,scope:this});Ext.ScrollManager.register(this);this.el.addCls("x-scroller");this.container.addCls("x-scroller-parent");if(this.bounces!==false){var e=this.bounces==="both"||this.bounces===true,b=e||this.bounces==="horizontal",c=e||this.bounces==="vertical";this.bounces={x:b,y:c}}this.theta=Math.log(1-(this.friction/10));if(!this.decelerationAnimation){this.decelerationAnimation={}}if(!this.bouncingAnimation){this.bouncingAnimation={}}["x","y"].forEach(function(g){if(!this.decelerationAnimation[g]){this.decelerationAnimation[g]=new Ext.util.Scroller.Animation.Deceleration({acceleration:this.acceleration,theta:this.theta})}if(!this.bouncingAnimation[g]){this.bouncingAnimation[g]=new Ext.util.Scroller.Animation.Bouncing({acceleration:this.acceleration,springTension:this.springTension})}},this);return this},getFrameDuration:function(){return 1000/this.fps},updateBoundary:function(){Ext.util.Scroller.superclass.
 updateBoundary.apply(this,arguments);this.snapToBoundary();return this},onOffsetChange:function(a,b){this.fireEvent("scroll",a,{x:-b.x,y:-b.y})},onTouchStart:function(a){Ext.util.Scroller.superclass.onTouchStart.apply(this,arguments);this.stopMomentumAnimation()},onDragStart:function(a){this.fireEvent("scrollstart",this,a)},setStartTime:function(a){this.startTime=a.time;this.originalStartTime=(a.event.originalTimeStamp)?a.event.originalTimeStamp:a.time},onStart:function(a){if(Ext.util.Scroller.superclass.onStart.apply(this,arguments)!==true){return}this.setStartTime(a);this.lastEventTime=a.time;this.startTimeOffset=this.offset.copy();this.isScrolling=true;this.momentumAnimationFramesHandled=0},onDrag:function(a){if(Ext.util.Scroller.superclass.onDrag.apply(this,arguments)!==true){return}this.lastEventTime=a.time;if(this.lastEventTime-this.startTime>this.startMomentumResetTime){this.setStartTime(a);this.startTimeOffset=this.offset.copy()}},onDragEnd:function(a){if(Ext.util.Sc
 roller.superclass.onDragEnd.apply(this,arguments)!==true){return}if(!this.startMomentumAnimation(a)){this.fireScrollEndEvent()}},onOrientationChange:function(){Ext.util.Scroller.superclass.onOrientationChange.apply(this,arguments);this.snapToBoundary()},fireScrollEndEvent:function(){this.isScrolling=false;this.isMomentumAnimating=false;this.snapToBoundary();this.fireEvent("scrollend",this,this.getOffset());this.snapToSlot()},getLastActualFps:function(){var a=(this.momentumAnimationEndTime-this.momentumAnimationStartTime-this.momentumAnimationProcessingTime)/1000;return this.momentumAnimationFramesHandled/a},scrollTo:function(c,a){this.stopMomentumAnimation();var b=this.offsetBoundary.restrict(new Ext.util.Offset(-c.x,-c.y));this.setOffset(b,a);return this},scrollBy:function(b,a){this.stopMomentumAnimation();var c=this.offset.copy();c.x+=b.x;c.y+=b.y;this.setOffset(c,a);return this},setSnap:function(a){this.snap=a},snapToBoundary:function(){var a=this.offsetBoundary.restrict(
 this.offset);this.setOffset(a);return this},snapToSlot:function(){var a=this.offsetBoundary.restrict(this.offset);a.round();if(this.snap){if(this.snap===true){this.snap={x:50,y:50}}else{if(Ext.isNumber(this.snap)){this.snap={x:this.snap,y:this.snap}}}if(this.snap.y){a.y=Math.round(a.y/this.snap.y)*this.snap.y}if(this.snap.x){a.x=Math.round(a.x/this.snap.x)*this.snap.x}if(!this.offset.equals(a)){this.scrollTo({x:-a.x,y:-a.y},this.snapDuration)}}},startMomentumAnimation:function(h){var g=(h.event.originalTimeStamp)?h.event.originalTimeStamp:h.time,f=g-this.originalStartTime;if((!this.momentum||!(f<=this.startMomentumResetTime))&&!this.offsetBoundary.isOutOfBound(this.offset)){return false}var d=this.minVelocityForAnimation,b,c=this.offset.copy(),a;this.isBouncing={x:false,y:false};this.isDecelerating={x:false,y:false};this.momentumAnimationStartTime=h.time;this.momentumAnimationProcessingTime=0;this.momentumAnimationStartVelocity={x:(this.offset.x-this.startTimeOffset.x)/(f/th
 is.acceleration),y:(this.offset.y-this.startTimeOffset.y)/(f/this.acceleration)};this.momentumAnimationStartOffset=c;["x","y"].forEach(function(e){this.isDecelerating[e]=(Math.abs(this.momentumAnimationStartVelocity[e])>d);if(this.bounces&&this.bounces[e]){a=this.offsetBoundary.restrict(e,c[e]);if(a!=c[e]){b=(c[e]-a)*this.springTension*Math.E;this.bouncingAnimation[e].set({startTime:this.momentumAnimationStartTime-((1/this.springTension)*this.acceleration),startOffset:a,startVelocity:b});this.isBouncing[e]=true;this.fireEvent("bouncestart",this,{axis:e,offset:a,time:this.momentumAnimationStartTime,velocity:b});this.isDecelerating[e]=false}}if(this.isDecelerating[e]){this.decelerationAnimation[e].set({startVelocity:this.momentumAnimationStartVelocity[e],startOffset:this.momentumAnimationStartOffset[e],startTime:this.momentumAnimationStartTime})}},this);if(this.isDecelerating.x||this.isDecelerating.y||this.isBouncing.x||this.isBouncing.y){this.isMomentumAnimating=true;this.mom
 entumAnimationFramesHandled=0;this.fireEvent("momentumanimationstart");this.momentumAnimationTimer=Ext.defer(this.handleMomentumAnimationFrame,this.getFrameDuration(),this);return true}return false},stopMomentumAnimation:function(){if(this.isMomentumAnimating){if(this.momentumAnimationTimer){clearTimeout(this.momentumAnimationTimer)}this.momentumAnimationEndTime=Date.now();var a=this.getLastActualFps();if(!this.maxFps||a>this.maxFps){this.maxFps=a}if(this.autoAdjustFps){this.fps=this.maxFps}this.isDecelerating={};this.isBouncing={};this.fireEvent("momentumanimationend");this.fireScrollEndEvent()}return this},handleMomentumAnimationFrame:function(){if(!this.isMomentumAnimating){return}this.momentumAnimationTimer=Ext.defer(this.handleMomentumAnimationFrame,this.getFrameDuration(),this);var c=Date.now(),e=this.offset.copy(),b,a,d;["x","y"].forEach(function(f){if(this.isDecelerating[f]){e[f]=this.decelerationAnimation[f].getOffset();b=this.momentumAnimationStartVelocity[f]*this.
 decelerationAnimation[f].getFrictionFactor();d=this.offsetBoundary.getOutOfBoundOffset(f,e[f]);if(d!=0){a=this.offsetBoundary.restrict(f,e[f]);if(this.bounces&&this.bounces[f]){this.bouncingAnimation[f].set({startTime:c,startOffset:a,startVelocity:b});this.isBouncing[f]=true;this.fireEvent("bouncestart",this,{axis:f,offset:a,time:c,velocity:b})}this.isDecelerating[f]=false}else{if(Math.abs(b)<=1){this.isDecelerating[f]=false}}}else{if(this.isBouncing[f]){e[f]=this.bouncingAnimation[f].getOffset();a=this.offsetBoundary.restrict(f,e[f]);if(Math.abs(e[f]-a)<=1){this.isBouncing[f]=false;this.fireEvent("bounceend",this,{axis:f,offset:a,time:c,velocity:0});e[f]=a}}}},this);if(!this.isDecelerating.x&&!this.isDecelerating.y&&!this.isBouncing.x&&!this.isBouncing.y){this.stopMomentumAnimation();return}this.momentumAnimationFramesHandled++;this.momentumAnimationProcessingTime+=Date.now()-c;this.setOffset(e)},destroy:function(){return Ext.util.Scroller.superclass.destroy.apply(this,argu
 ments)}});Ext.util.Scroller.Animation={};Ext.util.Scroller.Animation.Deceleration=Ext.extend(Ext.util.Draggable.Animation.Abstract,{acceleration:30,theta:null,startVelocity:null,getOffset:function(){return this.startOffset-this.startVelocity*(1-this.getFrictionFactor())/this.theta},getFrictionFactor:function(){var a=Date.now()-this.startTime;return Math.exp(a/this.acceleration*this.theta)}});Ext.util.Scroller.Animation.Bouncing=Ext.extend(Ext.util.Draggable.Animation.Abstract,{springTension:0.3,acceleration:30,startVelocity:null,getOffset:function(){var b=(Date.now()-this.startTime),a=(b/this.acceleration)*Math.pow(Math.E,-this.springTension*(b/this.acceleration));return this.startOffset+(this.startVelocity*a)}});Ext.util.Scroller.Indicator=Ext.extend(Object,{baseCls:"x-scrollbar",ui:"dark",type:"horizontal",constructor:function(a,b){this.container=a;Ext.apply(this,b);this.el=this.container.createChild({cls:[this.baseCls,this.baseCls+"-"+this.type,this.baseCls+"-"+this.ui].j
 oin(" ")});this.offset=new Ext.util.Offset();this.hide()},hide:function(){var a=this;if(this.hideTimer){clearTimeout(this.hideTimer)}this.hideTimer=setTimeout(function(){a.el.setStyle("opacity",0)},100);return this},show:function(){if(this.hideTimer){clearTimeout(this.hideTimer)}this.el.setStyle("opacity",1);return this},setVisibility:function(a){return this[a?"show":"hide"]()},setSize:function(a){if(this.size&&a>this.size){a=Math.round(a)}this.el.dom.style[(this.type=="horizontal")?"width":"height"]=a+"px";this.size=a;return this},setOffset:function(a){if(this.type=="vertical"){this.offset.y=a}else{this.offset.x=a}if(!Ext.is.iOS&&!Ext.is.Desktop){if(this.type=="vertical"){this.el.dom.style.top=this.offset.y+"px"}else{this.el.dom.style.left=this.offset.x+"px"}}else{Ext.Element.cssTranslate(this.el,this.offset)}return this}})})();Ext.util.Sortable=Ext.extend(Ext.util.Observable,{baseCls:"x-sortable",direction:"vertical",cancelSelector:null,constrain:window,group:"base",revert
 :true,itemSelector:null,handleSelector:null,disabled:false,delay:0,sorting:false,vertical:false,vertical:false,constructor:function(b,a){a=a||{};Ext.apply(this,a);this.addEvents("sortstart","sortend","sortchange");this.el=Ext.get(b);Ext.util.Sortable.superclass.constructor.call(this);if(this.direction=="horizontal"){this.horizontal=true}else{if(this.direction=="vertical"){this.vertical=true}else{this.horizontal=this.vertical=true}}this.el.addCls(this.baseCls);if(!this.disabled){this.enable()}},onTouchStart:function(b,a){if(this.cancelSelector&&b.getTarget(this.cancelSelector)){return}if(this.handleSelector&&!b.getTarget(this.handleSelector)){return}if(!this.sorting){this.onSortStart(b,a)}},onSortStart:function(c,b){this.sorting=true;var a=new Ext.util.Draggable(b,{delay:this.delay,revert:this.revert,direction:this.direction,constrain:this.constrain===true?this.el:this.constrain,animationDuration:100});a.on({dragThreshold:0,drag:this.onDrag,dragend:this.onDragEnd,scope:this})
 ;this.dragEl=b;this.calculateBoxes();if(!a.dragging){a.onStart(c)}this.fireEvent("sortstart",this,c)},calculateBoxes:function(){this.items=[];var b=this.el.select(this.itemSelector,false),f=b.length,a,e,c,d;for(a=0;a<f;a++){c=b[a];if(c!=this.dragEl){e=Ext.fly(c).getPageBox(true);e.el=c;this.items.push(e)}}},onDrag:function(l,c){var g=this.items,f=g.length,h=l.region,d=false,b,a,j,k;for(b=0;b<f;b++){k=g[b];a=h.intersect(k);if(a){if(this.vertical&&Math.abs(a.top-a.bottom)>(h.bottom-h.top)/2){if(h.bottom>k.top&&k.top>h.top){l.el.insertAfter(k.el)}else{l.el.insertBefore(k.el)}d=true}else{if(this.horizontal&&Math.abs(a.left-a.right)>(h.right-h.left)/2){if(h.right>k.left&&k.left>h.left){l.el.insertAfter(k.el)}else{l.el.insertBefore(k.el)}d=true}}if(d){l.reset();l.moveTo(h.left,h.top);this.calculateBoxes();this.fireEvent("sortchange",this,l.el,this.el.select(this.itemSelector,false).indexOf(l.el.dom));return}}}},onDragEnd:function(a,b){a.destroy();this.sorting=false;this.fireEvent(
 "sortend",this,a,b)},enable:function(){this.el.on("touchstart",this.onTouchStart,this,{delegate:this.itemSelector});this.disabled=false},disable:function(){this.el.un("touchstart",this.onTouchStart,this);this.disabled=true},isDisabled:function(){return this.disabled},isSorting:function(){return this.sorting},isVertical:function(){return this.vertical},isHorizontal:function(){return this.horizontal}});(function(){Date.useStrict=false;function b(d){var c=Array.prototype.slice.call(arguments,1);return d.replace(/\{(\d+)\}/g,function(e,f){return c[f]})}Date.formatCodeToRegex=function(d,c){var e=Date.parseCodes[d];if(e){e=typeof e=="function"?e():e;Date.parseCodes[d]=e}return e?Ext.applyIf({c:e.c?b(e.c,c||"{0}"):e.c},e):{g:0,c:null,s:Ext.util.Format.escapeRegex(d)}};var a=Date.formatCodeToRegex;Ext.apply(Date,{parseFunctions:{"M$":function(d,c){var e=new RegExp("\\/Date\\(([-+])?(\\d+)(?:[+-]\\d{4})?\\)\\/");var f=(d||"").match(e);return f?new Date(((f[1]||"")+f[2])*1):null}},par
 seRegexes:[],formatFunctions:{"M$":function(){return"\\/Date("+this.getTime()+")\\/"}},y2kYear:50,MILLI:"ms",SECOND:"s",MINUTE:"mi",HOUR:"h",DAY:"d",MONTH:"mo",YEAR:"y",defaults:{},dayNames:["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"],monthNames:["January","February","March","April","May","June","July","August","September","October","November","December"],monthNumbers:{Jan:0,Feb:1,Mar:2,Apr:3,May:4,Jun:5,Jul:6,Aug:7,Sep:8,Oct:9,Nov:10,Dec:11},getShortMonthName:function(c){return Date.monthNames[c].substring(0,3)},getShortDayName:function(c){return Date.dayNames[c].substring(0,3)},getMonthNumber:function(c){return Date.monthNumbers[c.substring(0,1).toUpperCase()+c.substring(1,3).toLowerCase()]},formatCodes:{d:"Ext.util.Format.leftPad(this.getDate(), 2, '0')",D:"Date.getShortDayName(this.getDay())",j:"this.getDate()",l:"Date.dayNames[this.getDay()]",N:"(this.getDay() ? this.getDay() : 7)",S:"this.getSuffix()",w:"this.getDay()",z:"this.getDayOfYear()
 ",W:"Ext.util.Format.leftPad(this.getWeekOfYear(), 2, '0')",F:"Date.monthNames[this.getMonth()]",m:"Ext.util.Format.leftPad(this.getMonth() + 1, 2, '0')",M:"Date.getShortMonthName(this.getMonth())",n:"(this.getMonth() + 1)",t:"this.getDaysInMonth()",L:"(this.isLeapYear() ? 1 : 0)",o:"(this.getFullYear() + (this.getWeekOfYear() == 1 && this.getMonth() > 0 ? +1 : (this.getWeekOfYear() >= 52 && this.getMonth() < 11 ? -1 : 0)))",Y:"this.getFullYear()",y:"('' + this.getFullYear()).substring(2, 4)",a:"(this.getHours() < 12 ? 'am' : 'pm')",A:"(this.getHours() < 12 ? 'AM' : 'PM')",g:"((this.getHours() % 12) ? this.getHours() % 12 : 12)",G:"this.getHours()",h:"Ext.util.Format.leftPad((this.getHours() % 12) ? this.getHours() % 12 : 12, 2, '0')",H:"Ext.util.Format.leftPad(this.getHours(), 2, '0')",i:"Ext.util.Format.leftPad(this.getMinutes(), 2, '0')",s:"Ext.util.Format.leftPad(this.getSeconds(), 2, '0')",u:"Ext.util.Format.leftPad(this.getMilliseconds(), 3, '0')",O:"this.getGMTOffset(
 )",P:"this.getGMTOffset(true)",T:"this.getTimezone()",Z:"(this.getTimezoneOffset() * -60)",c:function(){for(var j="Y-m-dTH:i:sP",g=[],f=0,d=j.length;f<d;++f){var h=j.charAt(f);g.push(h=="T"?"'T'":Date.getFormatCode(h))}return g.join(" + ")},U:"Math.round(this.getTime() / 1000)"},isValid:function(n,c,l,j,f,g,e){j=j||0;f=f||0;g=g||0;e=e||0;var k=new Date(n,c-1,l,j,f,g,e);return n==k.getFullYear()&&c==k.getMonth()+1&&l==k.getDate()&&j==k.getHours()&&f==k.getMinutes()&&g==k.getSeconds()&&e==k.getMilliseconds()},parseDate:function(d,f,c){var e=Date.parseFunctions;if(e[f]==null){Date.createParser(f)}return e[f](d,Ext.isDefined(c)?c:Date.useStrict)},getFormatCode:function(d){var c=Date.formatCodes[d];if(c){c=typeof c=="function"?c():c;Date.formatCodes[d]=c}return c||("'"+Ext.util.Format.escape(d)+"'")},createFormat:function(g){var f=[],c=false,e="";for(var d=0;d<g.length;++d){e=g.charAt(d);if(!c&&e=="\\"){c=true}else{if(c){c=false;f.push("'"+Ext.util.Format.escape(e)+"'")}else{f.pu
 sh(Date.getFormatCode(e))}}}Date.formatFunctions[g]=new Function("return "+f.join("+"))},createParser:function(){var c=["var dt, y, m, d, h, i, s, ms, o, z, zz, u, v,","def = Date.defaults,","results = String(input).match(Date.parseRegexes[{0}]);","if(results){","{1}","if(u != null){","v = new Date(u * 1000);","}else{","dt = (new Date()).clearTime();","y = Ext.num(y, Ext.num(def.y, dt.getFullYear()));","m = Ext.num(m, Ext.num(def.m - 1, dt.getMonth()));","d = Ext.num(d, Ext.num(def.d, dt.getDate()));","h  = Ext.num(h, Ext.num(def.h, dt.getHours()));","i  = Ext.num(i, Ext.num(def.i, dt.getMinutes()));","s  = Ext.num(s, Ext.num(def.s, dt.getSeconds()));","ms = Ext.num(ms, Ext.num(def.ms, dt.getMilliseconds()));","if(z >= 0 && y >= 0){","v = new Date(y, 0, 1, h, i, s, ms);","v = !strict? v : (strict === true && (z <= 364 || (v.isLeapYear() && z <= 365))? v.add(Date.DAY, z) : null);","}else if(strict === true && !Date.isValid(y, m + 1, d, h, i, s, ms)){","v = null;","}else{","v
 = new Date(y, m, d, h, i, s, ms);","}","}","}","if(v){","if(zz != null){","v = v.add(Date.SECOND, -v.getTimezoneOffset() * 60 - zz);","}else if(o){","v = v.add(Date.MINUTE, -v.getTimezoneOffset() + (sn == '+'? -1 : 1) * (hr * 60 + mn));","}","}","return v;"].join("\n");return function(l){var e=Date.parseRegexes.length,n=1,f=[],k=[],j=false,d="",h=0,g,m;for(;h<l.length;++h){d=l.charAt(h);if(!j&&d=="\\"){j=true}else{if(j){j=false;k.push(Ext.util.Format.escape(d))}else{g=a(d,n);n+=g.g;k.push(g.s);if(g.g&&g.c){if(g.last){m=g}else{f.push(g.c)}}}}}if(m){f.push(m)}Date.parseRegexes[e]=new RegExp("^"+k.join("")+"$");Date.parseFunctions[l]=new Function("input","strict",b(c,e,f.join("")))}}(),parseCodes:{d:{g:1,c:"d = parseInt(results[{0}], 10);\n",s:"(\\d{2})"},j:{g:1,c:"d = parseInt(results[{0}], 10);\n",s:"(\\d{1,2})"},D:function(){for(var c=[],d=0;d<7;c.push(Date.getShortDayName(d)),++d){}return{g:0,c:null,s:"(?:"+c.join("|")+")"}},l:function(){return{g:0,c:null,s:"(?:"+Date.dayNa
 mes.join("|")+")"}},N:{g:0,c:null,s:"[1-7]"},S:{g:0,c:null,s:"(?:st|nd|rd|th)"},w:{g:0,c:null,s:"[0-6]"},z:{g:1,c:"z = parseInt(results[{0}], 10);\n",s:"(\\d{1,3})"},W:{g:0,c:null,s:"(?:\\d{2})"},F:function(){return{g:1,c:"m = parseInt(Date.getMonthNumber(results[{0}]), 10);\n",s:"("+Date.monthNames.join("|")+")"}},M:function(){for(var c=[],d=0;d<12;c.push(Date.getShortMonthName(d)),++d){}return Ext.applyIf({s:"("+c.join("|")+")"},a("F"))},m:{g:1,c:"m = parseInt(results[{0}], 10) - 1;\n",s:"(\\d{2})"},n:{g:1,c:"m = parseInt(results[{0}], 10) - 1;\n",s:"(\\d{1,2})"},t:{g:0,c:null,s:"(?:\\d{2})"},L:{g:0,c:null,s:"(?:1|0)"},o:function(){return a("Y")},Y:{g:1,c:"y = parseInt(results[{0}], 10);\n",s:"(\\d{4})"},y:{g:1,c:"var ty = parseInt(results[{0}], 10);\ny = ty > Date.y2kYear ? 1900 + ty : 2000 + ty;\n",s:"(\\d{1,2})"},a:function(){return a("A")},A:{calcLast:true,g:1,c:"if (results[{0}] == 'AM') {\nif (!h || h == 12) { h = 0; }\n} else { if (!h || h < 12) { h = (h || 0) + 12;
  }}",s:"(AM|PM)"},g:function(){return a("G")},G:{g:1,c:"h = parseInt(results[{0}], 10);\n",s:"(\\d{1,2})"},h:function(){return a("H")},H:{g:1,c:"h = parseInt(results[{0}], 10);\n",s:"(\\d{2})"},i:{g:1,c:"i = parseInt(results[{0}], 10);\n",s:"(\\d{2})"},s:{g:1,c:"s = parseInt(results[{0}], 10);\n",s:"(\\d{2})"},u:{g:1,c:"ms = results[{0}]; ms = parseInt(ms, 10)/Math.pow(10, ms.length - 3);\n",s:"(\\d+)"},O:{g:1,c:["o = results[{0}];","var sn = o.substring(0,1),","hr = o.substring(1,3)*1 + Math.floor(o.substring(3,5) / 60),","mn = o.substring(3,5) % 60;","o = ((-12 <= (hr*60 + mn)/60) && ((hr*60 + mn)/60 <= 14))? (sn + Ext.util.Format.leftPad(hr, 2, '0') + Ext.util.Format.leftPad(mn, 2, '0')) : null;\n"].join("\n"),s:"([+-]\\d{4})"},P:{g:1,c:["o = results[{0}];","var sn = o.substring(0,1),","hr = o.substring(1,3)*1 + Math.floor(o.substring(4,6) / 60),","mn = o.substring(4,6) % 60;","o = ((-12 <= (hr*60 + mn)/60) && ((hr*60 + mn)/60 <= 14))? (sn + Ext.util.Format.leftPad(hr, 2,
  '0') + Ext.util.Format.leftPad(mn, 2, '0')) : null;\n"].join("\n"),s:"([+-]\\d{2}:\\d{2})"},T:{g:0,c:null,s:"[A-Z]{1,4}"},Z:{g:1,c:"zz = results[{0}] * 1;\nzz = (-43200 <= zz && zz <= 50400)? zz : null;\n",s:"([+-]?\\d{1,5})"},c:function(){var e=[],c=[a("Y",1),a("m",2),a("d",3),a("h",4),a("i",5),a("s",6),{c:"ms = results[7] || '0'; ms = parseInt(ms, 10)/Math.pow(10, ms.length - 3);\n"},{c:["if(results[8]) {","if(results[8] == 'Z'){","zz = 0;","}else if (results[8].indexOf(':') > -1){",a("P",8).c,"}else{",a("O",8).c,"}","}"].join("\n")}];for(var f=0,d=c.length;f<d;++f){e.push(c[f].c)}return{g:1,c:e.join(""),s:[c[0].s,"(?:","-",c[1].s,"(?:","-",c[2].s,"(?:","(?:T| )?",c[3].s,":",c[4].s,"(?::",c[5].s,")?","(?:(?:\\.|,)(\\d+))?","(Z|(?:[-+]\\d{2}(?::)?\\d{2}))?",")?",")?",")?"].join("")}},U:{g:1,c:"u = parseInt(results[{0}], 10);\n",s:"(-?\\d+)"}}})}());Ext.apply(Date.prototype,{dateFormat:function(a){if(Date.formatFunctions[a]==null){Date.createFormat(a)}return Date.formatFunc
 tions[a].call(this)},getTimezone:function(){return this.toString().replace(/^.* (?:\((.*)\)|([A-Z]{1,4})(?:[\-+][0-9]{4})?(?: -?\d+)?)$/,"$1$2").replace(/[^A-Z]/g,"")},getGMTOffset:function(a){return(this.getTimezoneOffset()>0?"-":"+")+Ext.util.Format.leftPad(Math.floor(Math.abs(this.getTimezoneOffset())/60),2,"0")+(a?":":"")+Ext.util.Format.leftPad(Math.abs(this.getTimezoneOffset()%60),2,"0")},getDayOfYear:function(){var b=0,e=this.clone(),a=this.getMonth(),c;for(c=0,e.setDate(1),e.setMonth(0);c<a;e.setMonth(++c)){b+=e.getDaysInMonth()}return b+this.getDate()-1},getWeekOfYear:function(){var a=86400000,b=7*a;return function(){var d=Date.UTC(this.getFullYear(),this.getMonth(),this.getDate()+3)/a,c=Math.floor(d/7),e=new Date(c*b).getUTCFullYear();return c-Math.floor(Date.UTC(e,0,7)/b)+1}}(),isLeapYear:function(){var a=this.getFullYear();return !!((a&3)==0&&(a%100||(a%400==0&&a)))},getFirstDayOfMonth:function(){var a=(this.getDay()-(this.getDate()-1))%7;return(a<0)?(a+7):a},get
 LastDayOfMonth:function(){return this.getLastDateOfMonth().getDay()},getFirstDateOfMonth:function(){return new Date(this.getFullYear(),this.getMonth(),1)},getLastDateOfMonth:function(){return new Date(this.getFullYear(),this.getMonth(),this.getDaysInMonth())},getDaysInMonth:function(){var a=[31,28,31,30,31,30,31,31,30,31,30,31];return function(){var b=this.getMonth();return b==1&&this.isLeapYear()?29:a[b]}}(),getSuffix:function(){switch(this.getDate()){case 1:case 21:case 31:return"st";case 2:case 22:return"nd";case 3:case 23:return"rd";default:return"th"}},clone:function(){return new Date(this.getTime())},isDST:function(){return new Date(this.getFullYear(),0,1).getTimezoneOffset()!=this.getTimezoneOffset()},clearTime:function(f){if(f){return this.clone().clearTime()}var b=this.getDate();this.setHours(0);this.setMinutes(0);this.setSeconds(0);this.setMilliseconds(0);if(this.getDate()!=b){for(var a=1,e=this.add(Date.HOUR,a);e.getDate()!=b;a++,e=this.add(Date.HOUR,a)){}this.set
 Date(b);this.setHours(e.getHours())}return this},add:function(b,c){var e=this.clone();if(!b||c===0){return e}switch(b.toLowerCase()){case Date.MILLI:e.setMilliseconds(this.getMilliseconds()+c);break;case Date.SECOND:e.setSeconds(this.getSeconds()+c);break;case Date.MINUTE:e.setMinutes(this.getMinutes()+c);break;case Date.HOUR:e.setHours(this.getHours()+c);break;case Date.DAY:e.setDate(this.getDate()+c);break;case Date.MONTH:var a=this.getDate();if(a>28){a=Math.min(a,this.getFirstDateOfMonth().add("mo",c).getLastDateOfMonth().getDate())}e.setDate(a);e.setMonth(this.getMonth()+c);break;case Date.YEAR:e.setFullYear(this.getFullYear()+c);break}return e},between:function(c,a){var b=this.getTime();return c.getTime()<=b&&b<=a.getTime()}});Date.prototype.format=Date.prototype.dateFormat;Ext.data.Connection=Ext.extend(Ext.util.Observable,{method:"post",url:null,disableCaching:true,disableCachingParam:"_dc",timeout:30000,useDefaultHeader:true,defaultPostHeader:"application/x-www-form-
 urlencoded; charset=UTF-8",useDefaultXhrHeader:true,defaultXhrHeader:"XMLHttpRequest",constructor:function(a){a=a||{};Ext.apply(this,a);this.addEvents("beforerequest","requestcomplete","requestexception");this.requests={};Ext.data.Connection.superclass.constructor.call(this)},request:function(d){var m=this;if(m.fireEvent("beforerequest",m,d)!==false){var h=d.params,c=d.url||m.url,f=d.urlParams,l=m.extraParams,i,j,g,b,q,s;if(Ext.isFunction(h)){h=h.call(d.scope||window,d)}if(Ext.isFunction(c)){c=c.call(d.scope||window,d)}j=d.rawData||d.xmlData||d.jsonData||null;if(d.jsonData&&!Ext.isPrimitive(d.jsonData)){j=Ext.encode(j)}h=Ext.urlEncode(l,Ext.isObject(h)?Ext.urlEncode(h):h);f=Ext.isObject(f)?Ext.urlEncode(f):f;b=(d.method||((h||j)?"POST":"GET")).toUpperCase();if(b==="GET"&&d.disableCaching!==false&&m.disableCaching){c=Ext.urlAppend(c,d.disableCachingParam||m.disableCachingParam+"="+(new Date().getTime()))}if((b=="GET"||j)&&h){c=Ext.urlAppend(c,h);h=null}if(f){c=Ext.urlAppend(c
 ,f)}if(d.autoAbort===true||m.autoAbort){m.abort()}s=this.getXhrInstance();s.open(b.toUpperCase(),c,true);g=Ext.apply({},d.headers||{},m.defaultHeaders||{});if(!g["Content-Type"]&&(j||h)){var p=m.defaultPostHeader,n=d.jsonData,a=d.xmlData;if(j){if(d.rawData){p="text/plain"}else{if(a&&Ext.isDefined(a)){p="text/xml"}else{if(n&&Ext.isDefined(n)){p="application/json"}}}}g["Content-Type"]=p}if(m.useDefaultXhrHeader&&!g["X-Requested-With"]){g["X-Requested-With"]=m.defaultXhrHeader}for(q in g){if(g.hasOwnProperty(q)){try{s.setRequestHeader(q,g[q])}catch(k){m.fireEvent("exception",q,g[q])}}}i={id:++Ext.data.Connection.requestId,xhr:s,headers:g,options:d,timeout:setTimeout(function(){i.timedout=true;m.abort(i)},d.timeout||m.timeout)};m.requests[i.id]=i;s.onreadystatechange=Ext.createDelegate(m.onStateChange,m,[i]);s.send(j||h||null);return i}else{return d.callback?d.callback.apply(d.scope,[d,undefined,undefined]):null}},getXhrInstance:function(){return new XMLHttpRequest()},isLoading:
 function(a){return a&&!{0:true,4:true}[a.xhr.readyState]},abort:function(a){if(a&&this.isLoading(a)){a.xhr.abort();clearTimeout(a.timeout);delete (a.timeout);a.aborted=true;this.onComplete(a)}else{if(!a){var b;for(b in this.requests){if(!this.requests.hasOwnProperty(b)){continue}this.abort(this.requests[b])}}}},onStateChange:function(a){if(a.xhr.readyState==4){clearTimeout(a.timeout);delete a.timeout;this.onComplete(a)}},onComplete:function(d){var a=d.xhr.status,c=d.options,e=true,b;if((a>=200&&a<300)||a==304){b=this.createResponse(d);this.fireEvent("requestcomplete",this,b,c);if(c.success){if(!c.scope){c.success(b,c)}else{c.success.call(c.scope,b,c)}}}else{e=false;switch(a){case 12002:case 12029:case 12030:case 12031:case 12152:case 13030:b=this.createException(d);break;default:b=this.createResponse(d)}this.fireEvent("requestexception",this,b,c);if(c.failure){if(!c.scope){c.failure(b,c)}else{c.failure.call(c.scope,b,c)}}}if(c.callback){if(!c.scope){c.callback(c,e,b)}else{c.
 callback.call(c.scope,c,e,b)}}delete this.requests[d.id]},createResponse:function(a){var g=a.xhr,b={},h=g.getAllResponseHeaders().replace(/\r\n/g,"\n").split("\n"),c=h.length,i,d,f,e;while(c--){i=h[c];d=i.indexOf(":");if(d>=0){f=i.substr(0,d).toLowerCase();if(i.charAt(d+1)==" "){++d}b[f]=i.substr(d+1)}}delete a.xhr;return{request:a,requestId:a.id,status:g.status,statusText:g.statusText,getResponseHeader:function(j){return b[j.toLowerCase()]},getAllResponseHeaders:function(){return b},responseText:g.responseText,responseXML:g.responseXML}},createException:function(a){return{request:a,requestId:a.id,status:a.aborted?-1:0,statusText:a.aborted?"transaction aborted":"communication failure",aborted:a.aborted,timedout:a.timedout}}});Ext.data.Connection.requestId=0;Ext.Ajax=new Ext.data.Connection({autoAbort:false});Ext.util.EventSimulator=Ext.extend(Object,{supportedEvents:{touch:["touchstart","touchmove","touchend","gesturestart","gesturechange","gestureend"],mouse:["mousedown","m
 ousemove","mouseup","click"]},getEventTypeByName:function(b){var a=null;Ext.iterate(this.supportedEvents,function(d,c){if(c.indexOf(b)!=-1){a=d}});return a},fire:function(b,c,a){b=b.toLowerCase();if(arguments.length==2){a=c;c=document}switch(this.getEventTypeByName(b)){case"touch":this.fireTouchEvent.call(this,b,c,a);break;case"mouse":this.fireMouseEvent.call(this,b,c,a);break;default:throw new Error("Event type "+b+" is currently not supported")}return this},createEvent:function(b,a){},createEventData:function(b,a){switch(this.getEventTypeByName(b.type)){case"touch":return this.createTouchEventData(b.type,b.target,b,a);break;case"mouse":return this.createMouseEventData(b.type,b.target,b,a);break;default:throw new Error("Event type "+b.type+" is currently not supported")}},fireTouchEvent:function(c,d,b){var e=this.createTouchEventData(c,d,b);var a=this.createTouchEvent(c,e);a.isSimulated=true;return d.dispatchEvent(a)},createTouchEventData:function(c,d,a,b){var e={type:c,tim
 eStamp:Date.now(),bubbles:true,cancelable:true,detail:1,screenX:0,screenY:0,pageX:0,pageY:0,clientX:0,clientY:0,ctrlKey:false,altKey:false,shiftKey:false,metaKey:false,scale:1,rotation:0};if(!b){e.target=d;e.view=document.defaultView}if(a){Ext.iterate(e,function(f,g){if(a.hasOwnProperty(f)){e[f]=a[f]}})}["touches","targetTouches","changedTouches"].forEach(function(f){if(a.hasOwnProperty(f)){e[f]=this.createTouchList(a[f],d,b)}else{e[f]=this.createTouchList(e,d,b)}},this);return e},createTouchEvent:function(b,c){if(typeof b!="string"){c=b;b=b.type}var a=document.createEvent("TouchEvent");if(a.initTouchEvent.length==9){a.initTouchEvent(c.touches,c.targetTouches,c.changedTouches,b,c.view,c.screenX,c.screenY,c.clientX,c.clientY)}else{a.initTouchEvent(b,c.bubbles,c.cancelable,c.view,c.detail,c.screenX,c.screenY,c.pageX,c.pageY,c.ctrlKey,c.altKey,c.shiftKey,c.metaKey,c.touches,c.targetTouches,c.changedTouches,c.scale,c.rotation)}return a},createTouch:function(c,a,b){if(!document.c
 reateTouch||b){return{pageX:a.pageX,pageY:a.pageY,clientX:a.pageX,clientY:a.pageY,screenX:a.pageX,screenY:a.pageY,identifier:+a.identifier||0}}return document.createTouch(document.defaultView,c,+a.identifier||0,+a.pageX||0,+a.pageY||0,+a.screenX||0,+a.screenY||0)},createTouchList:function(c,e,b){var f,d=[];if(Ext.isObject(c)&&typeof c.target!="undefined"){c=[c]}if(c){for(var a=0;a<c.length;a++){if(!b&&!c[a].target){c[a].target=e}f=this.createTouch(c[a].target,c[a],b);d.push(f)}}if(!document.createTouchList||b){return d}return document.createTouchList.apply(document,d)},fireMouseEvent:function(b,e,a){var d=this.createMouseEventData(b,e,a);var c=this.createMouseEvent(b,d);c.isSimulated=true;c.originalTimeStamp=d.timeStamp;return e.dispatchEvent(c)},createMouseEventData:function(c,g,a,b){var f={type:c,timeStamp:Date.now(),bubbles:true,cancelable:(c!="mousemove"),detail:1,screenX:0,screenY:0,pageX:0,pageY:0,clientX:0,clientY:0,ctrlKey:false,altKey:false,shiftKey:false,metaKey:fa
 lse,button:0,relatedTarget:null},e=["screen","client","page"],d={x:0,y:0};if(!b){f.target=g;f.view=window}if(a){Ext.iterate(f,function(h,i){if(a.hasOwnProperty(h)){f[h]=a[h]}})}e.forEach(function(h){if(f[h+"X"]!=0){d.x=f[h+"X"]}if(f[h+"Y"]!=0){d.y=f[h+"Y"]}});e.forEach(function(h){if(f[h+"X"]==0&&d.x!=0){f[h+"X"]=d.x}if(f[h+"Y"]==0&&d.y!=0){f[h+"Y"]=d.y}});return f},createMouseEvent:function(a,b){var c=document.createEvent("MouseEvents");c.initMouseEvent(a,b.bubbles,b.cancelable,b.view,b.detail,b.screenX,b.screenY,b.clientX,b.clientY,b.ctrlKey,b.altKey,b.shiftKey,b.metaKey,b.button,b.relatedTarget);return c}});Ext.util.EventRecorder=Ext.extend(Ext.util.Observable,{eventCollection:null,currentEventSetName:null,constructor:function(){this.addEvents("replaystart","beforecalculatetarget","beforefire","afterfire","aftercalculatetarget","replayend","interrupted");this.eventSets={};this.interruptedIndexes={};return this},getEventSet:function(a){if(typeof a!="string"){if(this.curren
 tEventSetName==null){throw new Error("No EventSet is currently used")}a=this.currentEventSetName}if(typeof this.eventSets[a]=="undefined"){this.eventSets[a]=[]}return this.eventSets[a]},start:function(a){this.currentEventSetName=a},record:function(a,c){if(typeof a!="string"){if(this.currentEventSetName==null){return}c=a;a=this.currentEventSetName}var b=this.getEventSimulator().createEventData(c,true);this.getEventSet(a).push(b)},setEventSet:function(a,b){this.eventSets[a]=b},erase:function(a){this.getEventSet(a).length=0},stopReplay:function(){this.interruptFlag=true},resumeReplay:function(b){var a=this.interruptedIndexes[b]||0;this.replay(b,a)},replay:function(c,j){var l=this.getEventSimulator(),k=this.getEventSet(c),i,d=0,e=0,b,h,f,a=["touchmove","touchend","mousemove","mouseup"],g=this;if(typeof j=="undefined"){j=0}e=j;i=k.length;this.interruptFlag=false;if(i>0){this.fireEvent("replaystart",c,j);setTimeout(function(){b=k[e];if(b){if(a.indexOf(b.type)===-1){g.fireEvent("be
 forecalculatetarget",b.type,b);h=Ext.util.Point.fromEvent(b);f=document.elementFromPoint(h.x,h.y);g.fireEvent("aftercalculatetarget",b.type,f,b)}if(f){if(g.interruptFlag===true){g.interruptFlag=false;g.interruptedIndexes[c]=e;g.fireEvent("interrupted",e);g.fireEvent("replayend",c,true);return}g.fireEvent("beforefire",b.type,f,b);l.fire(b.type,f,b);g.fireEvent("afterfire",b.type,f,b)}if(++e<i){setTimeout(arguments.callee,k[e].timeStamp-b.timeStamp)}else{g.fireEvent("replayend",c,false)}}},d)}},end:function(){this.currentEventSetName=null},getEventSimulator:function(){if(!this._eventSimulator){this._eventSimulator=new Ext.util.EventSimulator()}return this._eventSimulator},setEventSimulator:function(a){if(!(a instanceof Ext.util.EventSimulator)){throw new Error("eventSimulator must be an instance of Ext.util.EventSimulator")}this._eventSimulator=a},save:function(a){}});Ext.gesture.Manager=new Ext.AbstractManager({eventNames:{start:"touchstart",move:"touchmove",end:"touchend"},d
 efaultPreventedMouseEvents:["click"],clickMoveThreshold:5,init:function(){this.targets=[];this.followTouches=[];this.currentGestures=[];this.currentTargets=[];if(!Ext.supports.Touch){Ext.apply(this.eventNames,{start:"mousedown",move:"mousemove",end:"mouseup"})}this.listenerWrappers={start:Ext.createDelegate(this.onTouchStart,this),move:Ext.createDelegate(this.onTouchMove,this),end:Ext.createDelegate(this.onTouchEnd,this),mouse:Ext.createDelegate(this.onMouseEvent,this)};this.attachListeners()},freeze:function(){this.isFrozen=true},thaw:function(){this.isFrozen=false},getEventSimulator:function(){if(!this.eventSimulator){this.eventSimulator=new Ext.util.EventSimulator()}return this.eventSimulator},attachListeners:function(){Ext.iterate(this.eventNames,function(b,a){document.body.addEventListener(a,this.listenerWrappers[b],false)},this);if(Ext.supports.Touch){this.defaultPreventedMouseEvents.forEach(function(a){document.body.addEventListener(a,this.listenerWrappers.mouse,true)
 },this)}},detachListeners:function(){Ext.iterate(this.eventNames,function(b,a){document.body.removeEventListener(a,this.listenerWrappers[b],false)},this);if(Ext.supports.Touch){this.defaultPreventedMouseEvents.forEach(function(a){document.body.removeEventListener(a,this.listenerWrappers.mouse,true)},this)}},onMouseEvent:function(a){if(!a.isSimulated){a.preventDefault();a.stopPropagation()}},onTouchStart:function(d){var a=[],c=d.target,b=this;if(d.stopped===true){return}if(!Ext.is.iOS){if(!(c.tagName&&["input","textarea","select"].indexOf(c.tagName.toLowerCase())!==-1)){d.preventDefault()}}if(this.isFrozen){return}if(this.startEvent){this.onTouchEnd(d)}this.locks={};this.currentTargets=[c];while(c){if(this.targets.indexOf(c)!==-1){a.unshift(c)}c=c.parentNode;this.currentTargets.push(c)}this.startEvent=d;this.startPoint=Ext.util.Point.fromEvent(d);this.lastMovePoint=null;this.isClick=true;this.handleTargets(a,d)},onTouchMove:function(c){if(!this.startEvent){return}if(Ext.is.De
 sktop){c.target=this.startEvent.target}if(Ext.is.iOS){c.preventDefault()}if(this.isFrozen){return}var d=this.currentGestures,b,f=c.changedTouches?c.changedTouches[0]:c;this.lastMovePoint=Ext.util.Point.fromEvent(c);if(Ext.supports.Touch&&this.isClick&&!this.lastMovePoint.isWithin(this.startPoint,this.clickMoveThreshold)){this.isClick=false}for(var a=0;a<d.length;a++){if(c.stopped){break}b=d[a];if(b.listenForMove){b.onTouchMove(c,f)}}},onTouchEnd:function(g){if(this.isFrozen){return}var h=this.currentGestures.slice(0),d=h.length,c,b,a,f=false,j=g.changedTouches?g.changedTouches[0]:g;if(this.startPoint){a=Ext.util.Point.fromEvent(g);if(!(this.lastMovePoint||this.startPoint)["equals"](a)){f=true}}for(c=0;c<d;c++){b=h[c];if(!g.stopped&&b.listenForEnd){if(f){b.onTouchMove(g,j)}b.onTouchEnd(g,j)}this.stopGesture(b)}if(Ext.supports.Touch&&this.isClick){this.isClick=false;this.getEventSimulator().fire("click",this.startEvent.target,j)}this.lastMovePoint=null;this.followTouches=[];th
 is.startedChangedTouch=false;this.currentTargets=[];this.startEvent=null;this.startPoint=null},handleTargets:function(a,d){var c=a.length,b;this.startedChangedTouch=false;this.startedTouches=Ext.supports.Touch?d.touches:[d];for(b=0;b<c;b++){if(d.stopped){break}this.handleTarget(a[b],d,true)}for(b=c-1;b>=0;b--){if(d.stopped){break}this.handleTarget(a[b],d,false)}if(this.startedChangedTouch){this.followTouches=this.followTouches.concat((Ext.supports.Touch&&d.targetTouches)?Ext.toArray(d.targetTouches):[d])}},handleTarget:function(g,f,a){var h=Ext.Element.data(g,"x-gestures")||[],d=h.length,c,b;for(c=0;c<d;c++){b=h[c];if((!!b.capture===!!a)&&(this.followTouches.length<b.touches)&&((Ext.supports.Touch&&f.targetTouches)?(f.targetTouches.length===b.touches):true)){this.startedChangedTouch=true;this.startGesture(b);if(b.listenForStart){b.onTouchStart(f,f.changedTouches?f.changedTouches[0]:f)}if(f.stopped){break}}}},startGesture:function(a){a.started=true;this.currentGestures.push(a
 )},stopGesture:function(a){a.started=false;this.currentGestures.remove(a)},addEventListener:function(g,b,f,d){g=Ext.getDom(g);var a=this.targets,c=this.getGestureName(b),h=Ext.Element.data(g,"x-gestures"),e;if(!h){h=[];Ext.Element.data(g,"x-gestures",h)}if(!c){throw new Error("Trying to subscribe to unknown event "+b)}if(a.indexOf(g)===-1){this.targets.push(g)}e=this.get(g.id+"-"+c);if(!e){e=this.create(Ext.apply({},d||{},{target:g,type:c}));h.push(e)}e.addListener(b,f);if(this.startedChangedTouch&&this.currentTargets.contains(g)&&!e.started&&!d.subsequent){this.startGesture(e);if(e.listenForStart){e.onTouchStart(this.startEvent,this.startedTouches[0])}}},removeEventListener:function(e,a,d){e=Ext.getDom(e);var b=this.getGestureName(a),f=Ext.Element.data(e,"x-gestures")||[],c;c=this.get(e.id+"-"+b);if(c){c.removeListener(a,d);for(b in c.listeners){return}c.destroy();f.remove(c);Ext.Element.data(e,"x-gestures",f)}},getGestureName:function(a){return this.names&&this.names[a]},r
 egisterType:function(d,a){var c=a.prototype.handles,b,e;this.types[d]=a;a[this.typeName]=d;if(!c){c=a.prototype.handles=[d]}this.names=this.names||{};for(b=0,e=c.length;b<e;b++){this.names[c[b]]=d}}});Ext.regGesture=function(){return Ext.gesture.Manager.registerType.apply(Ext.gesture.Manager,arguments)};Ext.TouchEventObjectImpl=Ext.extend(Object,{constructor:function(b,a){if(b){this.setEvent(b,a)}},setEvent:function(b,a){Ext.apply(this,{event:b,time:b.timeStamp});this.touches=b.touches||[b];this.changedTouches=b.changedTouches||[b];this.targetTouches=b.targetTouches||[b];if(a){this.target=a.target;Ext.apply(this,a)}else{this.target=b.target}return this},stopEvent:function(){this.stopPropagation();this.preventDefault()},stopPropagation:function(){this.event.stopped=true},preventDefault:function(){this.event.preventDefault()},getTarget:function(b,c,a){if(b){return Ext.fly(this.target).findParent(b,c,a)}else{return a?Ext.get(this.target):this.target}}});Ext.TouchEventObject=new
  Ext.TouchEventObjectImpl();Ext.gesture.Gesture=Ext.extend(Object,{listenForStart:true,listenForEnd:true,listenForMove:true,disableLocking:false,touches:1,constructor:function(a){a=a||{};Ext.apply(this,a);this.target=Ext.getDom(this.target);this.listeners={};if(!this.target){throw new Error("Trying to bind a "+this.type+" event to element that does'nt exist: "+this.target)}this.id=this.target.id+"-"+this.type;Ext.gesture.Gesture.superclass.constructor.call(this);Ext.gesture.Manager.register(this)},addListener:function(a,b){this.listeners[a]=this.listeners[a]||[];this.listeners[a].push(b)},removeListener:function(a,c){var b=this.listeners[a];if(b){b.remove(c);if(b.length==0){delete this.listeners[a]}for(a in this.listeners){if(this.listeners.hasOwnProperty(a)){return}}this.listeners={}}},fire:function(d,g,a){var c=this.listeners[d],f=c&&c.length,b;if(!this.disableLocking&&this.isLocked(d)){return false}if(f){a=Ext.apply(a||{},{time:g.timeStamp,type:d,gesture:this,target:(g.ta
 rget.nodeType==3)?g.target.parentNode:g.target});for(b=0;b<f;b++){c[b](g,a)}}return true},stop:function(){Ext.gesture.Manager.stopGesture(this)},lock:function(){if(!this.disableLocking){var a=arguments,c=a.length,b;for(b=0;b<c;b++){Ext.gesture.Manager.locks[a[b]]=this.id}}},unlock:function(){if(!this.disableLocking){var a=arguments,c=a.length,b;for(b=0;b<c;b++){if(Ext.gesture.Manager.locks[a[b]]==this.id){delete Ext.gesture.Manager.locks[a[b]]}}}},isLocked:function(b){var a=Ext.gesture.Manager.locks[b];return !!(a&&a!==this.id)},getLockingGesture:function(b){var a=Ext.gesture.Manager.locks[b];if(a){return Ext.gesture.Manager.get(a)||null}return null},onTouchStart:Ext.emptyFn,onTouchMove:Ext.emptyFn,onTouchEnd:Ext.emptyFn,destroy:function(){this.stop();this.listeners=null;Ext.gesture.Manager.unregister(this)}});Ext.gesture.Touch=Ext.extend(Ext.gesture.Gesture,{handles:["touchstart","touchmove","touchend","touchdown"],touchDownInterval:500,onTouchStart:function(a,b){this.start
 X=this.previousX=b.pageX;this.startY=this.previousY=b.pageY;this.startTime=this.previousTime=a.timeStamp;this.fire("touchstart",a);this.lastEvent=a;if(this.listeners&&this.listeners.touchdown){this.touchDownIntervalId=setInterval(Ext.createDelegate(this.touchDownHandler,this),this.touchDownInterval)}},onTouchMove:function(a,b){this.fire("touchmove",a,this.getInfo(b));this.lastEvent=a},onTouchEnd:function(a){this.fire("touchend",a,this.lastInfo);clearInterval(this.touchDownIntervalId)},touchDownHandler:function(){this.fire("touchdown",this.lastEvent,this.lastInfo)},getInfo:function(e){var d=Date.now(),b=e.pageX-this.startX,a=e.pageY-this.startY,c={startX:this.startX,startY:this.startY,previousX:this.previousX,previousY:this.previousY,pageX:e.pageX,pageY:e.pageY,deltaX:b,deltaY:a,absDeltaX:Math.abs(b),absDeltaY:Math.abs(a),previousDeltaX:e.pageX-this.previousX,previousDeltaY:e.pageY-this.previousY,time:d,startTime:this.startTime,previousTime:this.previousTime,deltaTime:d-this.
 startTime,previousDeltaTime:d-this.previousTime};this.previousTime=c.time;this.previousX=c.pageX;this.previousY=c.pageY;this.lastInfo=c;return c}});Ext.regGesture("touch",Ext.gesture.Touch);Ext.gesture.Tap=Ext.extend(Ext.gesture.Gesture,{handles:["tapstart","tapcancel","tap","doubletap","taphold","singletap"],cancelThreshold:10,doubleTapThreshold:800,singleTapThreshold:400,holdThreshold:1000,fireClickEvent:false,onTouchStart:function(b,c){var a=this;a.startX=c.pageX;a.startY=c.pageY;a.fire("tapstart",b,a.getInfo(c));if(this.listeners.taphold){a.timeout=setTimeout(function(){a.fire("taphold",b,a.getInfo(c));delete a.timeout},a.holdThreshold)}a.lastTouch=c},onTouchMove:function(b,c){var a=this;if(a.isCancel(c)){a.fire("tapcancel",b,a.getInfo(c));if(a.timeout){clearTimeout(a.timeout);delete a.timeout}a.stop()}a.lastTouch=c},onTouchEnd:function(c){var a=this,b=a.getInfo(a.lastTouch);this.fireTapEvent(c,b);if(a.lastTapTime&&c.timeStamp-a.lastTapTime<=a.doubleTapThreshold){a.lastT
 apTime=null;c.preventDefault();a.fire("doubletap",c,b)}else{a.lastTapTime=c.timeStamp}if(a.listeners&&a.listeners.singletap&&a.singleTapThreshold&&!a.preventSingleTap){a.fire("singletap",c,b);a.preventSingleTap=true;setTimeout(function(){a.preventSingleTap=false},a.singleTapThreshold)}if(a.timeout){clearTimeout(a.timeout);delete a.timeout}},fireTapEvent:function(d,c){this.fire("tap",d,c);if(d.event){d=d.event}var b=(d.changedTouches?d.changedTouches[0]:d).target;if(!b.disabled&&this.fireClickEvent){var a=document.createEvent("MouseEvent");a.initMouseEvent("click",d.bubbles,d.cancelable,document.defaultView,d.detail,d.screenX,d.screenY,d.clientX,d.clientY,d.ctrlKey,d.altKey,d.shiftKey,d.metaKey,d.metaKey,d.button,d.relatedTarget);a.isSimulated=true;b.dispatchEvent(a)}},getInfo:function(a){return{pageX:a.pageX,pageY:a.pageY}},isCancel:function(b){var a=this;return(Math.abs(b.pageX-a.startX)>=a.cancelThreshold||Math.abs(b.pageY-a.startY)>=a.cancelThreshold)}});Ext.regGesture("t
 ap",Ext.gesture.Tap);Ext.gesture.Swipe=Ext.extend(Ext.gesture.Gesture,{listenForEnd:false,swipeThreshold:35,swipeTime:1000,onTouchStart:function(a,b){this.startTime=a.timeStamp;this.startX=b.pageX;this.startY=b.pageY;this.lock("scroll","scrollstart","scrollend")},onTouchMove:function(g,h){var b=h.pageY-this.startY,d=h.pageX-this.startX,a=Math.abs(b),c=Math.abs(d),f=g.timeStamp-this.startTime;if(a-c>3||f>this.swipeTime){this.unlock("scroll","scrollstart","scrollend");this.stop()}else{if(c>this.swipeThreshold&&c>a){this.fire("swipe",g,{direction:(d<0)?"left":"right",distance:c,deltaTime:f,deltaX:d});this.stop()}}}});Ext.regGesture("swipe",Ext.gesture.Swipe);Ext.gesture.Drag=Ext.extend(Ext.gesture.Touch,{handles:["dragstart","drag","dragend"],dragThreshold:5,direction:"both",horizontal:false,vertical:false,constructor:function(){Ext.gesture.Drag.superclass.constructor.apply(this,arguments);if(this.direction=="both"){this.horizontal=true;this.vertical=true}else{if(this.direction
 =="horizontal"){this.horizontal=true}else{this.vertical=true}}return this},onTouchStart:function(a,b){this.startX=this.previousX=b.pageX;this.startY=this.previousY=b.pageY;this.startTime=this.previousTime=a.timeStamp;this.dragging=false},onTouchMove:function(b,c){if(this.isLocked("drag")){return}var a=this.getInfo(c);if(!this.dragging){if(this.isDragging(a)&&this.fire("dragstart",b,a)){this.dragging=true;this.lock("drag","dragstart","dragend")}}else{this.fire("drag",b,a)}},onTouchEnd:function(a){if(this.dragging){this.fire("dragend",a,this.lastInfo)}this.dragging=false},isDragging:function(a){return((this.horizontal&&a.absDeltaX>=this.dragThreshold)||(this.vertical&&a.absDeltaY>=this.dragThreshold))},isVertical:function(){return this.vertical},isHorizontal:function(){return this.horizontal}});Ext.regGesture("drag",Ext.gesture.Drag);Ext.gesture.Pinch=Ext.extend(Ext.gesture.Gesture,{handles:["pinchstart","pinch","pinchend"],touches:2,onTouchStart:function(f){var b=this;if(Ext.
 supports.Touch&&f.targetTouches.length>=2){b.lock("swipe","scroll","scrollstart","scrollend","touchmove","touchend","touchstart","tap","tapstart","taphold","tapcancel","doubletap");b.pinching=true;var c=f.targetTouches,d=b.firstTouch=c[0],a=b.secondTouch=c[1];b.previousDistance=b.startDistance=b.getDistance();b.previousScale=1;b.fire("pinchstart",f,{distance:b.startDistance,scale:b.previousScale})}else{if(b.pinching){b.unlock("swipe","scroll","scrollstart","scrollend","touchmove","touchend","touchstart","tap","tapstart","taphold","tapcancel","doubletap");b.pinching=false}}},onTouchMove:function(a){if(this.pinching){this.fire("pinch",a,this.getPinchInfo())}},onTouchEnd:function(a){if(this.pinching){this.fire("pinchend",a,this.getPinchInfo())}},getPinchInfo:function(){var b=this,f=b.getDistance(),e=f/b.startDistance,d=b.firstTouch,a=b.secondTouch,c={scale:e,deltaScale:e-1,previousScale:b.previousScale,previousDeltaScale:e-b.previousScale,distance:f,deltaDistance:f-b.startDista
 nce,startDistance:b.startDistance,previousDistance:b.previousDistance,previousDeltaDistance:f-b.previousDistance,firstTouch:d,secondTouch:a,firstPageX:d.pageX,firstPageY:d.pageY,secondPageX:a.pageX,secondPageY:a.pageY,midPointX:(d.pageX+a.pageX)/2,midPointY:(d.pageY+a.pageY)/2};b.previousScale=e;b.previousDistance=f;return c},getDistance:function(){var a=this;return Math.sqrt(Math.pow(Math.abs(a.firstTouch.pageX-a.secondTouch.pageX),2)+Math.pow(Math.abs(a.firstTouch.pageY-a.secondTouch.pageY),2))}});Ext.regGesture("pinch",Ext.gesture.Pinch);Ext.lib.Component=Ext.extend(Ext.util.Observable,{isComponent:true,renderTpl:null,tplWriteMode:"overwrite",baseCls:"x-component",disabledCls:"x-item-disabled",hidden:false,disabled:false,draggable:false,floating:false,styleHtmlContent:false,styleHtmlCls:"x-html",allowDomMove:true,autoShow:false,autoRender:false,needsLayout:false,rendered:false,constructor:function(b){b=b||{};this.initialConfig=b;Ext.apply(this,b);this.addEvents("beforeact
 ivate","activate","beforedeactivate","deactivate","added","disable","enable","beforeshow","show","beforehide","hide","removed","beforerender","render","afterrender","beforedestroy","destroy","resize","move","beforestaterestore","staterestore","beforestatesave","statesave");this.getId();this.mons=[];this.additionalCls=[];this.renderData=this.renderData||{};this.renderSelectors=this.renderSelectors||{};this.initComponent();Ext.ComponentMgr.register(this);Ext.lib.Component.superclass.constructor.call(this);if(this.plugins){this.plugins=[].concat(this.plugins);for(var c=0,a=this.plugins.length;c<a;c++){this.plugins[c]=this.initPlugin(this.plugins[c])}}if(this.applyTo){this.applyToMarkup(this.applyTo);delete this.applyTo}else{if(this.renderTo){this.render(this.renderTo);delete this.renderTo}}if(Ext.isDefined(this.disabledClass)){throw"Component: disabledClass has been deprecated. Please use disabledCls."}},initComponent:Ext.emptyFn,applyToMarkup:Ext.emptyFn,show:Ext.emptyFn,onSho
 w:function(){var a=this.needsLayout;if(Ext.isObject(a)){this.doComponentLayout(a.width,a.height,a.isSetSize)}},initPlugin:function(a){if(a.ptype&&typeof a.init!="function"){a=Ext.PluginMgr.create(a)}else{if(typeof a=="string"){a=Ext.PluginMgr.create({ptype:a})}}a.init(this);return a},render:function(b,a){if(!this.rendered&&this.fireEvent("beforerender",this)!==false){if(this.el){this.el=Ext.get(this.el)}b=this.initContainer(b);this.onRender(b,a);this.fireEvent("render",this);this.initContent();this.afterRender(b);this.fireEvent("afterrender",this);this.initEvents();if(this.autoShow){this.show()}if(this.hidden){this.onHide(false)}if(this.disabled){this.disable(true)}}return this},onRender:function(b,a){var c=this.el,e,d;a=this.getInsertPosition(a);if(!c){if(a){c=Ext.DomHelper.insertBefore(a,this.getElConfig(),true)}else{c=Ext.DomHelper.append(b,this.getElConfig(),true)}}else{if(this.allowDomMove!==false){b.dom.insertBefore(c.dom,a)}}c.addCls(this.initCls());c.setStyle(this.in
 itStyles());e=this.initRenderTpl();if(e){d=this.initRenderData();e.append(c,d)}this.el=c;this.applyRenderSelectors();this.rendered=true},initCls:function(){var a=[this.baseCls];if(this.componentCls){a.push(this.componentCls)}else{this.componentCls=this.baseCls}if(this.cls){a.push(this.cls);delete this.cls}if(this.ui){a.push(this.componentCls+"-"+this.ui)}return a.concat(this.additionalCls)},afterRender:function(){this.getComponentLayout();if(this.x||this.y){this.setPosition(this.x,this.y)}if(this.styleHtmlContent){this.getTargetEl().addCls(this.styleHtmlCls)}if(!this.ownerCt){this.setSize(this.width,this.height)}},getElConfig:function(){return{tag:"div",id:this.id}},getInsertPosition:function(a){if(a!==undefined){if(Ext.isNumber(a)){a=this.container.dom.childNodes[a]}else{a=Ext.getDom(a)}}return a},initContainer:function(a){if(!a&&this.el){a=this.el.dom.parentNode;this.allowDomMove=false}this.container=Ext.get(a);if(this.ctCls){this.container.addCls(this.ctCls)}return this.c
 ontainer},initRenderData:function(){return Ext.applyIf(this.renderData,{baseCls:this.baseCls,componentCls:this.componentCls})},initRenderTpl:function(){var a=this.renderTpl;if(a){if(this.proto.renderTpl!==a){if(Ext.isArray(a)||typeof a==="string"){a=new Ext.XTemplate(a)}}else{if(Ext.isArray(this.proto.renderTpl)){a=this.proto.renderTpl=new Ext.XTemplate(a)}}}return a},initStyles:function(){var d={},a=Ext.Element,c,e,b,f;if(Ext.isString(this.style)){b=this.style.split(";");for(c=0,e=b.length;c<e;c++){if(!Ext.isEmpty(b[c])){f=b[c].split(":");d[Ext.util.Format.trim(f[0])]=Ext.util.Format.trim(f[1])}}}else{d=Ext.apply({},this.style)}if(this.padding!=undefined){d.padding=a.unitizeBox((this.padding===true)?5:this.padding)}if(this.margin!=undefined){d.margin=a.unitizeBox((this.margin===true)?5:this.margin)}if(this.border!=undefined){d.borderWidth=a.unitizeBox((this.border===true)?1:this.border)}delete this.style;return d},initContent:function(){var b=this.getTargetEl();if(this.html
 ){b.update(Ext.DomHelper.markup(this.html));delete this.html}if(this.contentEl){var a=Ext.get(this.contentEl);a.show();b.appendChild(a.dom)}if(this.tpl){if(!this.tpl.isTemplate){this.tpl=new Ext.XTemplate(this.tpl)}if(this.data){this.tpl[this.tplWriteMode](b,this.data);delete this.data}}},initEvents:function(){var c=this.afterRenderEvents,b,a;if(c){for(b in c){if(!c.hasOwnProperty(b)){continue}a=c[b];if(this[b]&&this[b].on){this.mon(this[b],a)}}}},applyRenderSelectors:function(){var b=this.renderSelectors||{},c=this.el.dom,a;for(a in b){if(!b.hasOwnProperty(a)){continue}this[a]=Ext.get(Ext.DomQuery.selectNode(b[a],c))}},is:function(a){return Ext.ComponentQuery.is(this,a)},up:function(b){var a=this.ownerCt;if(b){for(;a;a=a.ownerCt){if(Ext.ComponentQuery.is(a,b)){return a}}}return a},nextSibling:function(b){var f=this.ownerCt,d,e,a,g;if(f){d=f.items;a=d.indexOf(this)+1;if(a){if(b){for(e=d.getCount();a<e;a++){if((g=d.getAt(a)).is(b)){return g}}}else{if(a<d.getCount()){return d.
 getAt(a)}}}}return null},previousSibling:function(b){var e=this.ownerCt,d,a,f;if(e){d=e.items;a=d.indexOf(this);if(a!=-1){if(b){for(--a;a>=0;a--){if((f=d.getAt(a)).is(b)){return f}}}else{if(a){return d.getAt(--a)}}}}return null},getId:function(){return this.id||(this.id="ext-comp-"+(++Ext.lib.Component.AUTO_ID))},getItemId:function(){return this.itemId||this.id},getEl:function(){return this.el},getTargetEl:function(){return this.el},isXType:function(b,a){if(Ext.isFunction(b)){b=b.xtype}else{if(Ext.isObject(b)){b=b.constructor.xtype}}return !a?("/"+this.getXTypes()+"/").indexOf("/"+b+"/")!=-1:this.constructor.xtype==b},getXTypes:function(){var a=this.constructor,b=[],d=this,c;if(!a.xtypes){while(d){c=d.constructor.xtype;if(c!=undefined){b.unshift(c)}d=d.constructor.superclass}a.xtypeChain=b;a.xtypes=b.join("/")}return a.xtypes},update:function(b,c,a){if(this.tpl&&!Ext.isString(b)){this.data=b;if(this.rendered){this.tpl[this.tplWriteMode](this.getTargetEl(),b||{})}}else{this.h
 tml=Ext.isObject(b)?Ext.DomHelper.markup(b):b;if(this.rendered){this.getTargetEl().update(this.html,c,a)}}if(this.rendered){this.doComponentLayout()}},setVisible:function(a){return this[a?"show":"hide"]()},isVisible:function(){var b=!this.hidden,a=this.ownerCt;this.hiddenOwnerCt=false;if(this.destroyed){return false}if(b&&this.rendered&&a){while(a){if(a.hidden||a.collapsed){this.hiddenOwnerCt=a;b=false;break}a=a.ownerCt}}return b},enable:function(a){if(this.rendered){this.el.removeCls(this.disabledCls);this.el.dom.disabled=false;this.onEnable()}this.disabled=false;if(a!==true){this.fireEvent("enable",this)}return this},disable:function(a){if(this.rendered){this.el.addCls(this.disabledCls);this.el.dom.disabled=true;this.onDisable()}this.disabled=true;if(a!==true){this.fireEvent("disable",this)}return this},isDisabled:function(){return this.disabled},setDisabled:function(a){return this[a?"disable":"enable"]()},isHidden:function(){return this.hidden},addCls:function(){var b=thi
 s,a=Ext.toArray(arguments);if(b.rendered){b.el.addCls(a)}else{b.additionalCls=b.additionalCls.concat(a)}return b},addClass:function(){throw"Component: addClass has been deprecated. Please use addCls."},removeCls:function(){var b=this,a=Ext.toArray(arguments);if(b.rendered){b.el.removeCls(a)}else{if(b.additionalCls.length){Ext.each(a,function(c){b.additionalCls.remove(c)})}}return b},removeClass:function(){throw"Component: removeClass has been deprecated. Please use removeCls."},addListener:function(b,f,e,a){if(Ext.isString(b)&&(Ext.isObject(f)||a&&a.element)){if(a.element){var d=f,c;f={};f[b]=d;b=a.element;if(e){f.scope=e}for(c in a){if(!a.hasOwnProperty(c)){continue}if(this.eventOptionsRe.test(c)){f[c]=a[c]}}}if(this[b]&&this[b].on){this.mon(this[b],f)}else{this.afterRenderEvents=this.afterRenderEvents||{};this.afterRenderEvents[b]=f}}return Ext.lib.Component.superclass.addListener.apply(this,arguments)},getBubbleTarget:function(){return this.ownerCt},isFloating:function(){
 return this.floating},isDraggable:function(){return !!this.draggable},isDroppable:function(){return !!this.droppable},onAdded:function(a,b){this.ownerCt=a;this.fireEvent("added",this,a,b)},onRemoved:function(){this.fireEvent("removed",this,this.ownerCt);delete this.ownerCt},onEnable:Ext.emptyFn,onDisable:Ext.emptyFn,beforeDestroy:Ext.emptyFn,onResize:Ext.emptyFn,setSize:function(b,a){if(Ext.isObject(b)){a=b.height;b=b.width}if(!this.rendered||!this.isVisible()){if(this.hiddenOwnerCt){var c=this.hiddenOwnerCt.layoutOnShow;c.remove(this);c.add(this)}this.needsLayout={width:b,height:a,isSetSize:true};if(!this.rendered){this.width=(b!==undefined)?b:this.width;this.height=(a!==undefined)?a:this.height}return this}this.doComponentLayout(b,a,true);return this},setCalculatedSize:function(b,a){if(Ext.isObject(b)){a=b.height;b=b.width}if(!this.rendered||!this.isVisible()){if(this.hiddenOwnerCt){var c=this.hiddenOwnerCt.layoutOnShow;c.remove(this);c.add(this)}this.needsLayout={width:b,
 height:a,isSetSize:false};return this}this.doComponentLayout(b,a);return this},doComponentLayout:function(d,a,b){var c=this.getComponentLayout();if(this.rendered&&c){d=(d!==undefined||this.collapsed===true)?d:this.width;a=(a!==undefined||this.collapsed===true)?a:this.height;if(b){this.width=d;this.height=a}c.layout(d,a)}return this},setComponentLayout:function(b){var a=this.componentLayout;if(a&&a.isLayout&&a!=b){a.setOwner(null)}this.componentLayout=b;b.setOwner(this)},getComponentLayout:function(){if(!this.componentLayout||!this.componentLayout.isLayout){this.setComponentLayout(Ext.layout.LayoutManager.create(this.componentLayout,"autocomponent"))}return this.componentLayout},afterComponentLayout:Ext.emptyFn,setPosition:function(a,b){if(Ext.isObject(a)){b=a.y;a=a.x}if(!this.rendered){return this}if(a!==undefined||b!==undefined){this.el.setBox(a,b);this.onPosition(a,b);this.fireEvent("move",this,a,b)}return this},onPosition:Ext.emptyFn,setWidth:function(a){return this.setSi
 ze(a)},setHeight:function(a){return this.setSize(undefined,a)},getSize:function(){return this.el.getSize()},getWidth:function(){return this.el.getWidth()},getHeight:function(){return this.el.getHeight()},setLoading:function(a,b){if(this.rendered){if(a){this.loadMask=this.loadMask||new Ext.LoadMask(b?this.getTargetEl():this.el,Ext.applyIf(Ext.isObject(a)?a:{}));this.loadMask.show()}else{Ext.destroy(this.loadMask);this.loadMask=null}}return this.loadMask},setDocked:function(a,b){this.dock=a;if(b&&this.ownerCt&&this.rendered){this.ownerCt.doComponentLayout()}return this},onDestroy:function(){if(this.monitorResize&&Ext.EventManager.resizeEvent){Ext.EventManager.resizeEvent.removeListener(this.setSize,this)}Ext.destroy(this.componentLayout,this.loadMask)},destroy:function(){if(!this.isDestroyed){if(this.fireEvent("beforedestroy",this)!==false){this.destroying=true;this.beforeDestroy();if(this.ownerCt&&this.ownerCt.remove){this.ownerCt.remove(this,false)}if(this.rendered){this.el.
 remove()}this.onDestroy();Ext.ComponentMgr.unregister(this);this.fireEvent("destroy",this);this.clearListeners();this.destroying=false;this.isDestroyed=true}}}});Ext.lib.Component.prototype.on=Ext.lib.Component.prototype.addListener;Ext.lib.Component.prototype.prev=Ext.lib.Component.prototype.previousSibling;Ext.lib.Component.prototype.next=Ext.lib.Component.prototype.nextSibling;Ext.lib.Component.AUTO_ID=1000;Ext.Component=Ext.extend(Ext.lib.Component,{});Ext.reg("component",Ext.Component);Ext.Component=Ext.extend(Ext.lib.Component,{showAnimation:null,monitorOrientation:false,floatingCls:"x-floating",hideOnMaskTap:true,stopMaskTapEvent:true,centered:false,modal:false,fullscreen:false,layoutOnOrientationChange:null,initComponent:function(){this.addEvents("beforeorientationchange","orientationchange");if(this.fullscreen||this.floating){this.monitorOrientation=true;this.autoRender=true}if(this.fullscreen){var a=Ext.Viewport.getSize();this.width=a.width;this.height=a.height;thi
 s.cls=(this.cls||"")+" x-fullscreen";this.renderTo=document.body}},onRender:function(){Ext.Component.superclass.onRender.apply(this,arguments);if(this.monitorOrientation){this.el.addCls("x-"+Ext.Viewport.orientation)}if(this.floating){this.setFloating(true)}if(this.draggable){this.setDraggable(this.draggable)}if(this.scroll){this.setScrollable(this.scroll)}},afterRender:function(){if(this.fullscreen){this.layoutOrientation(Ext.Viewport.orientation,this.width,this.height)}Ext.Component.superclass.afterRender.call(this)},initEvents:function(){Ext.Component.superclass.initEvents.call(this);if(this.monitorOrientation){Ext.EventManager.onOrientationChange(this.setOrientation,this)}},afterComponentLayout:function(){var c=this.scrollEl,a=this.scroller,b;if(c){b=c.parent();if(a.horizontal){c.setStyle("min-width",b.getWidth(true)+"px");c.setHeight(b.getHeight(true)||null)}if(a.vertical){c.setStyle("min-height",b.getHeight(true)+"px");c.setWidth(b.getWidth(true)||null)}a.updateBoundar
 y(true)}if(this.fullscreen&&Ext.is.iPad){Ext.repaint()}},layoutOrientation:Ext.emptyFn,update:function(){Ext.Component.superclass.update.apply(this,arguments);var a=this.scroller;if(a&&a.updateBoundary){a.updateBoundary(true)}},show:function(a){var b=this.rendered;if((this.hidden||!b)&&this.fireEvent("beforeshow",this)!==false){if(this.anchorEl){this.anchorEl.hide()}if(!b&&this.autoRender){this.render(Ext.isBoolean(this.autoRender)?Ext.getBody():this.autoRender)}this.hidden=false;if(this.rendered){this.onShow(a);this.fireEvent("show",this)}}return this},showBy:function(b,c,d,a){if(!this.floating){return this}if(b.isComponent){b=b.el}else{b=Ext.get(b)}this.x=0;this.y=0;this.show(c);if(a!==false){if(!this.anchorEl){this.anchorEl=this.el.createChild({cls:"x-anchor"})}this.anchorEl.show()}this.alignTo(b,d,20)},alignTo:function(f,e,g){var b=f.getPageBox(),q={width:window.innerWidth,height:window.innerHeight},l=this.getSize(),a={width:Math.min(l.width,q.width),height:Math.min(l.he
 ight,q.height)},s,j=2,d=["tl-bl","t-b","tr-br","l-r","l-r","r-l","bl-tl","b-t","br-tr"],p=this.anchorEl,h=[0,g],i,c,k=false,n=[0,0],o=b.left+(b.width/2),m=b.top+(b.height/2);if(o<=q.width*(1/3)){j=1;n[0]=25}else{if(o>=q.width*(2/3)){j=3;n[0]=-30}}if(m>=q.height*(2/3)){j+=6;h=[0,-g];n[1]=-10}else{if(e!==false&&m>=q.height*(1/3)){j+=3;h=(j<=5)?[g,0]:[-g,0];n=(j<=5)?[10,0]:[-10,0];k=true}else{n[1]=10}}s=d[j-1];i=this.el.getAlignToXY(f,s,h);if(k){if(i[0]<0){a.width=b.left-g}else{if(i[0]+a.width>q.width){a.width=q.width-b.right-g}}}else{if(i[1]<0){a.height=b.top-g}else{if(i[1]+a.height>q.height){a.height=q.height-b.bottom-g}}}if(a.width!=l.width){this.setSize(a.width)}else{if(a.height!=l.height){this.setSize(undefined,a.height)}}i=this.el.getAlignToXY(f,s,h);this.setPosition(i[0],i[1]);if(p){p.removeCls(["x-anchor-bottom","x-anchor-left","x-anchor-right","x-anchor-top"]);if(h[1]==g){c="x-anchor-top"}else{if(h[1]==-g){c="x-anchor-bottom"}else{if(h[0]==g){c="x-anchor-left"}else{c="
 x-anchor-right"}}}i=p.getAlignToXY(f,s,n);p.setXY(i);p.addCls(c)}return s},setCentered:function(b,d){this.centered=b;if(this.rendered&&d){var a,c;if(!this.ownerCt){a=(Ext.Element.getViewportWidth()/2)-(this.getWidth()/2);c=(Ext.Element.getViewportHeight()/2)-(this.getHeight()/2)}else{a=(this.ownerCt.getTargetEl().getWidth()/2)-(this.getWidth()/2);c=(this.ownerCt.getTargetEl().getHeight()/2)-(this.getHeight()/2)}this.setPosition(a,c)}return this},hide:function(a){if(!this.hidden&&this.fireEvent("beforehide",this)!==false){this.hidden=true;if(this.rendered){this.onHide(a,true)}}return this},onShow:function(a){this.el.show();Ext.Component.superclass.onShow.call(this,a);if(a===undefined||a===true){a=this.showAnimation}if(this.floating){this.el.dom.parentNode||this.el.appendTo(document.body);if(a){this.el.setStyle("opacity",0.01)}if(this.centered){this.setCentered(true,true)}else{this.setPosition(this.x,this.y)}if(this.modal){this.el.parent().mask(null,"x-mask-gray")}if(this.hide
 OnMaskTap){Ext.getDoc().on("touchstart",this.onFloatingTouchStart,this,{capture:true,subsequent:true})}}if(a){Ext.Anim.run(this,a,{out:false,autoClear:true});this.showAnimation=a}},onFloatingTouchStart:function(a){if(!this.el.contains(a.target)){this.hide();if(this.stopMaskTapEvent||Ext.fly(a.target).hasCls("x-mask")){a.stopEvent()}}},onHide:function(b,a){if(b===undefined||b===true){b=this.showAnimation}if(this.hideOnMaskTap&&this.floating){Ext.getDoc().un("touchstart",this.onFloatingTouchStart,this,{capture:true,subsequent:true})}if(b){Ext.Anim.run(this,b,{out:true,reverse:true,autoClear:true,scope:this,fireHideEvent:a,after:this.doHide})}else{this.doHide(null,{fireHideEvent:a})}},doHide:function(c,a){var b=this.el.parent();this.el.hide();if(b&&this.floating&&this.modal){b.unmask()}if(a&&a.fireHideEvent){this.fireEvent("hide",this)}},setScrollable:function(a){if(!this.rendered){this.scroll=a;return}Ext.destroy(this.scroller);this.scroller=null;if(a!==false){var b=Ext.isObje
 ct(a)?a.direction:a;a=Ext.apply({},Ext.isObject(a)?a:{},{direction:b});if(!this.scrollEl){this.scrollEl=this.getTargetEl().createChild();this.originalGetTargetEl=this.getTargetEl;this.getTargetEl=function(){return this.scrollEl}}this.scroller=(new Ext.util.ScrollView(this.scrollEl,a)).scroller}else{this.getTargetEl=this.originalGetTargetEl}},setFloating:function(b,a){this.floating=!!b;this.hidden=true;if(this.rendered){if(b!==false){this.el.addCls(this.floatingCls);if(a){this.show()}}else{this.el.removeCls(this.floatingCls);Ext.getDoc().un("touchstart",this.onFloatingTouchStart,this)}}else{if(b!==false){if(this.layoutOnOrientationChange!==false){this.layoutOnOrientationChange=true}this.autoRender=true}}},setDraggable:function(a,b){this.isDraggable=a;if(this.rendered){if(a===false){if(this.dragObj){this.dragObj.disable()}}else{if(b){this.show()}if(this.dragObj){this.dragObj.enable()}else{this.dragObj=new Ext.util.Draggable(this.el,Ext.apply({},this.draggable||{}));this.relayE
 vents(this.dragObj,["dragstart","beforedragend","drag","dragend"])}}}},setOrientation:function(b,a,c){if(this.fireEvent("beforeorientationchange",this,b,a,c)!==false){if(this.orientation!=b){this.el.removeCls("x-"+this.orientation);this.el.addCls("x-"+b)}this.orientation=b;this.layoutOrientation(b,a,c);if(this.fullscreen){this.setSize(a,c)}else{if(this.layoutOnOrientationChange){this.doComponentLayout()}}if(this.floating&&this.centered){this.setCentered(true,true)}this.onOrientationChange(b,a,c);this.fireEvent("orientationchange",this,b,a,c)}},onOrientationChange:Ext.emptyFn,beforeDestroy:function(){if(this.floating&&this.modal&&!this.hidden){this.el.parent().unmask()}Ext.destroy(this.scroller);Ext.Component.superclass.beforeDestroy.call(this)},onDestroy:function(){if(this.monitorOrientation&&Ext.EventManager.orientationEvent){Ext.EventManager.orientationEvent.removeListener(this.setOrientation,this)}Ext.Component.superclass.onDestroy.call(this)}});Ext.BoxComponent=Ext.Compo
 nent;Ext.reg("component",Ext.Component);Ext.reg("box",Ext.BoxComponent);Ext.lib.Container=Ext.extend(Ext.Component,{autoDestroy:true,defaultType:"panel",isContainer:true,baseCls:"x-container",bubbleEvents:["add","remove"],initComponent:function(){this.addEvents("afterlayout","beforeadd","beforeremove","add","remove","beforecardswitch","cardswitch");this.layoutOnShow=new Ext.util.MixedCollection();Ext.lib.Container.superclass.initComponent.call(this);this.initItems()},initItems:function(){var a=this.items;this.items=new Ext.util.MixedCollection(false,this.getComponentId);if(a){if(!Ext.isArray(a)){a=[a]}this.add(a)}},afterRender:function(){this.getLayout();Ext.lib.Container.superclass.afterRender.apply(this,arguments)},setLayout:function(b){var a=this.layout;if(a&&a.isLayout&&a!=b){a.setOwner(null)}this.layout=b;b.setOwner(this)},getLayout:function(){if(!this.layout||!this.layout.isLayout){this.setLayout(Ext.layout.LayoutManager.create(this.layout,"autocontainer"))}return this
 .layout},doLayout:function(){var a=this.getLayout();if(this.rendered&&a){a.layout()}return this},afterLayout:function(a){this.fireEvent("afterlayout",this,a)},prepareItems:function(a,c){if(!Ext.isArray(a)){a=[a]}var e,b,d;for(b=0,d=a.length;b<d;b++){e=a[b];if(c){e=this.applyDefaults(e)}a[b]=this.lookupComponent(e)}return a},applyDefaults:function(a){var b=this.defaults;if(b){if(Ext.isFunction(b)){b=b.call(this,a)}if(Ext.isString(a)){a=Ext.ComponentMgr.get(a);Ext.apply(a,b)}else{if(!a.isComponent){Ext.applyIf(a,b)}else{Ext.apply(a,b)}}}return a},lookupComponent:function(a){if(Ext.isString(a)){return Ext.ComponentMgr.get(a)}else{return this.createComponent(a)}return a},createComponent:function(a,b){if(a.isComponent){return a}return Ext.create(a,b||this.defaultType)},getComponentId:function(a){return a.getItemId()},add:function(){var f=Array.prototype.slice.call(arguments),d=-1;if(typeof f[0]=="number"){d=f.shift()}var a=f.length>1;if(a||Ext.isArray(f[0])){var g=a?f:f[0],b=[],c
 ,e,j;for(c=0,e=g.length;c<e;c++){j=g[c];if(!j){throw"Trying to add a null item as a child of Container with itemId/id: "+this.getItemId()}if(d!=-1){j=this.add(d+c,j)}else{j=this.add(j)}b.push(j)}return b}var h=this.prepareItems(f[0],true)[0];d=(d!==-1)?d:this.items.length;if(this.fireEvent("beforeadd",this,h,d)!==false&&this.onBeforeAdd(h)!==false){this.items.insert(d,h);h.onAdded(this,d);this.onAdd(h,d);this.fireEvent("add",this,h,d)}return h},onAdd:Ext.emptyFn,onRemove:Ext.emptyFn,insert:function(b,a){return this.add(b,a)},onBeforeAdd:function(a){if(a.ownerCt){a.ownerCt.remove(a,false)}if(this.hideBorders===true){a.border=(a.border===true)}},remove:function(a,b){var d=this.getComponent(a);if(!d){console.warn("Attempted to remove a component that does not exist. Ext.Container: remove takes an argument of the component to remove. cmp.remove() is incorrect usage.")}if(d&&this.fireEvent("beforeremove",this,d)!==false){this.doRemove(d,b);this.fireEvent("remove",this,d)}return d
 },doRemove:function(c,b){var d=this.layout,a=d&&this.rendered;this.items.remove(c);c.onRemoved();if(a){d.onRemove(c)}this.onRemove(c,b);if(b===true||(b!==false&&this.autoDestroy)){c.destroy()}if(a&&!b){d.afterRemove(c)}},removeAll:function(b){var f,d=this.items.items.slice(),a=[],e=d.length,c;for(c=0;c<e;c++){f=d[c];this.remove(f,b);if(f.ownerCt!==this){a.push(f)}}return a},getRefItems:function(a){var b=this.items.items.slice(),e=b.length,c,d;if(a){for(c=0;c<e;c++){d=b[c];if(d.getRefItems){b=b.concat(d.getRefItems(true))}}}return b},getComponent:function(a){if(Ext.isObject(a)){a=a.getItemId()}return this.items.get(a)},query:function(a){return Ext.ComponentQuery.query(a,this)},child:function(a){return this.query("> "+a)[0]||null},down:function(a){return this.query(a)[0]||null},show:function(){Ext.lib.Container.superclass.show.apply(this,arguments);var e=this.layoutOnShow,d=e.getCount(),b=0,a,c;for(;b<d;b++){c=e.get(b);a=c.needsLayout;if(Ext.isObject(a)){c.doComponentLayout(a.
 width,a.height,a.isSetSize)}}e.clear()},beforeDestroy:function(){var a=this.items,b;if(a){while((b=a.first())){this.doRemove(b,true)}}Ext.destroy(this.layout);Ext.lib.Container.superclass.beforeDestroy.call(this)}});Ext.Container=Ext.extend(Ext.lib.Container,{});Ext.reg("container",Ext.Container);Ext.Container=Ext.extend(Ext.lib.Container,{cardSwitchAnimation:null,initComponent:function(){if(this.scroll){this.fields=new Ext.util.MixedCollection();this.fields.on({add:this.onFieldAdd,remove:this.onFieldRemove,scope:this});this.on({add:this.onItemAdd,remove:this.onItemRemove,scope:this})}Ext.Container.superclass.initComponent.apply(this,arguments)},afterRender:function(){Ext.Container.superclass.afterRender.apply(this,arguments);if(this.scroller){if(Ext.is.Android&&this.containsFormFields){this.scroller.setUseCssTransform(false)}this.scroller.on("scrollstart",this.onFieldScrollStart,this)}},onFieldScrollStart:function(){var a=this.focusedField;if(a&&Ext.is.iOS){a.blur()}},onIte
 mAdd:function(b,a){this.fields.addAll(Ext.ComponentQuery.query("[isField]",a))},onItemRemove:function(b,a){this.fields.removeAll(Ext.ComponentQuery.query("[isField]",a))},onFieldAdd:function(a,b){this.handleFieldEventListener(true,b)},onFieldRemove:function(a,b){this.handleFieldEventListener(false,b)},handleFieldEventListener:function(b,a){if(!this.fieldEventWrap){this.fieldEventWrap={}}if(["textfield","passwordfield","emailfield","textareafield","searchfield","urlfield","numberfield","spinnerfield"].indexOf(a.xtype)!==-1){if(b){this.fieldEventWrap[a.id]={beforefocus:function(c){this.onFieldBeforeFocus(a,c)},focus:function(c){this.onFieldFocus(a,c)},blur:function(c){this.onFieldBlur(a,c)},keyup:function(c){this.onFieldKeyUp(a,c)},scope:this};this.containsFormFields=true}a[b?"on":"un"](this.fieldEventWrap[a.id]);if(!b){delete this.fieldEventWrap[a.id]}}},onFieldKeyUp:function(b,a){this.resetLastWindowScroll()},onFieldBeforeFocus:function(b,a){this.focusingField=b},getLastWind
 owScroll:function(){if(!this.lastWindowScroll){this.resetLastWindowScroll()}return{x:this.lastWindowScroll.x,y:this.lastWindowScroll.y}},resetLastWindowScroll:function(){this.lastWindowScroll={x:window.pageXOffset,y:window.pageYOffset}},adjustScroller:function(b){var a=this.getClosestScroller(),c=this.getLastWindowScroll();a.setOffset(b);if(Ext.is.iOS){window.scrollTo(c.x,c.y)}this.resetLastWindowScroll()},onFieldFocus:function(g,f){var d=this.getClosestScroller(),h=Ext.util.Region.from(d.containerBox),k=g.fieldEl.getPageBox(true);if(this.focusingField==g||!Ext.is.iOS){if(Ext.is.iOS&&window.pageYOffset==0){window.scrollTo(0,0)}var i=new Ext.util.Offset();if(k.left<h.left){i.x=h.left-k.left}if(k.top<h.top){i.y=h.top-k.top}if(!i.isZero()){var j=this.getLastWindowScroll();d.scrollBy(i);if(Ext.is.iOS){window.scrollTo(j.x,j.y)}this.resetLastWindowScroll()}}else{if(this.lastFocusedField){var a=k.top-this.lastFocusedField.fieldEl.getY(),b=d.offset.y-a,c=false;if(!h.contains(k)&&(b!
 =0||(b==0&&d.offset.y!=0))){c=true}if(b>0){b=0}if(c){this.adjustScroller(new Ext.util.Offset(d.offset.x,b))}}}this.resetLastWindowScroll();this.lastFocusedField=g;this.focusedField=g;this.focusingField=null},getClosestScroller:function(){if(!this.closestScroller){this.closestScroller=this.scroller||this.el.getScrollParent()}return this.closestScroller},onFieldBlur:function(b,a){if(this.focusingField==b){this.focusingField=null}if(this.focusedField==b){this.focusedField=null}},afterLayout:function(a){if(this.floating&&this.centered){this.setCentered(true,true)}if(this.scroller){this.scroller.updateBoundary()}Ext.Container.superclass.afterLayout.call(this,a)},getActiveItem:function(){if(this.layout&&this.layout.type=="card"){return this.layout.activeItem}else{return null}},setActiveItem:function(a,b){this.layout.setActiveItem(a,b);return this},onBeforeCardSwitch:function(a,c,b,d){return this.fireEvent("beforecardswitch",this,a,c,b,d)},onCardSwitch:function(a,c,b,d){return this
 .fireEvent("cardswitch",this,a,c,b,d)},disable:function(){Ext.Container.superclass.disable.call(this);this.el.mask(null,"x-mask-gray")},enable:function(){Ext.Container.superclass.enable.call(this);this.el.unmask()}});Ext.reg("container",Ext.Container);Ext.lib.Panel=Ext.extend(Ext.Container,{baseCls:"x-panel",isPanel:true,componentLayout:"dock",renderTpl:['<div class="{baseCls}-body<tpl if="bodyCls"> {bodyCls}</tpl>"<tpl if="bodyStyle"> style="{bodyStyle}"</tpl>></div>'],initComponent:function(){this.addEvents("bodyresize");Ext.applyIf(this.renderSelectors,{body:"."+this.baseCls+"-body"});Ext.lib.Panel.superclass.initComponent.call(this)},initItems:function(){Ext.lib.Panel.superclass.initItems.call(this);var a=this.dockedItems;this.dockedItems=new Ext.util.MixedCollection(false,this.getComponentId);if(a){this.addDocked(a)}},getDockedComponent:function(a){if(Ext.isObject(a)){a=a.getItemId()}return this.dockedItems.get(a)},getComponent:function(a){var b=Ext.lib.Panel.superclass
 .getComponent.call(this,a);if(b==undefined){b=this.getDockedComponent(a)}return b},initBodyStyles:function(){var a=Ext.isString(this.bodyStyle)?this.bodyStyle.split(";"):[],b=Ext.Element;if(this.bodyPadding!=undefined){a.push("padding: "+b.unitizeBox((this.bodyPadding===true)?5:this.bodyPadding))}if(this.bodyMargin!=undefined){a.push("margin: "+b.unitizeBox((this.bodyMargin===true)?5:this.bodyMargin))}if(this.bodyBorder!=undefined){a.push("border-width: "+b.unitizeBox((this.bodyBorder===true)?1:this.bodyBorder))}delete this.bodyStyle;return a.length?a.join(";"):undefined},initRenderData:function(){return Ext.applyIf(Ext.lib.Panel.superclass.initRenderData.call(this),{bodyStyle:this.initBodyStyles(),bodyCls:this.bodyCls})},addDocked:function(a,e){a=this.prepareItems(a);var d,b,c;for(b=0,c=a.length;b<c;b++){d=a[b];d.dock=d.dock||"top";if(e!==undefined){this.dockedItems.insert(e+b,d)}else{this.dockedItems.add(d)}d.onAdded(this,b);this.onDockedAdd(d)}if(this.rendered){this.doCom
 ponentLayout()}},onDockedAdd:Ext.emptyFn,onDockedRemove:Ext.emptyFn,insertDocked:function(b,a){this.addDocked(a,b)},removeDocked:function(d,b){if(!this.dockedItems.contains(d)){return d}var c=this.componentLayout,a=c&&this.rendered;if(a){c.onRemove(d)}this.dockedItems.remove(d);d.onRemoved();this.onDockedRemove(d);if(b===true||(b!==false&&this.autoDestroy)){d.destroy()}if(a&&!b){c.afterRemove(d)}this.doComponentLayout();return d},getDockedItems:function(){if(this.dockedItems&&this.dockedItems.items.length){return this.dockedItems.items.slice()}return[]},getTargetEl:function(){return this.body},getRefItems:function(a){var f=Ext.lib.Panel.superclass.getRefItems.call(this,a),c=this.getDockedItems(),e=c.length,b=0,d;f=f.concat(c);if(a){for(;b<e;b++){d=c[b];if(d.getRefItems){f=f.concat(d.getRefItems(true))}}}return f},beforeDestroy:function(){var b=this.dockedItems,a;if(b){while((a=b.first())){this.removeDocked(a,true)}}Ext.lib.Panel.superclass.beforeDestroy.call(this)}});Ext.Pan
 el=Ext.extend(Ext.lib.Panel,{});Ext.reg("panel",Ext.Panel);Ext.Panel=Ext.extend(Ext.lib.Panel,{scroll:false});Ext.reg("panel",Ext.Panel);Ext.Button=Ext.extend(Ext.Component,{initComponent:function(){this.addEvents("tap","beforetap");Ext.Button.superclass.initComponent.call(this);this.createAutoHandler()},iconAlign:"left",baseCls:"x-button",pressedCls:"x-button-pressed",badgeText:"",badgeCls:"x-badge",hasBadgeCls:"x-hasbadge",labelCls:"x-button-label",ui:"normal",isButton:true,pressedDelay:0,iconMaskCls:"x-icon-mask",iconMask:false,afterRender:function(c,a){var e=this;Ext.Button.superclass.afterRender.call(e,c,a);var g=e.text,d=e.icon,b=e.iconCls,f=e.badgeText;e.text=e.icon=e.iconCls=e.badgeText=null;e.setText(g);e.setIcon(d);e.setIconClass(b);if(e.iconMask&&e.iconEl){e.iconEl.addCls(e.iconMaskCls)}e.setBadge(f)},initEvents:function(){var a=this;Ext.Button.superclass.initEvents.call(a);a.mon(a.el,{scope:a,tap:a.onPress,tapstart:a.onTapStart,tapcancel:a.onTapCancel})},onTapSta
 rt:function(){var a=this;if(!a.disabled){if(a.pressedDelay){a.pressedTimeout=setTimeout(function(){a.el.addCls(a.pressedCls)},Ext.isNumber(a.pressedDelay)?a.pressedDelay:100)}else{a.el.addCls(a.pressedCls)}}},onTapCancel:function(){var a=this;if(a.pressedTimeout){clearTimeout(a.pressedTimeout);delete a.pressedTimeout}a.el.removeCls(a.pressedCls)},setHandler:function(b,a){this.handler=b;this.scope=a;return this},setText:function(b){var a=this;if(a.rendered){if(!a.textEl&&b){a.textEl=a.el.createChild({tag:"span",html:b,cls:this.labelCls})}else{if(a.textEl&&b!=a.text){if(b){a.textEl.setHTML(b)}else{a.textEl.remove();a.textEl=null}}}}a.text=b;return a},setIcon:function(a){var b=this;if(b.rendered){if(!b.iconEl&&a){b.iconEl=b.el.createChild({tag:"img",src:Ext.BLANK_IMAGE_URL,style:"background-image: "+(a?"url("+a+")":"")});b.setIconAlign(b.iconAlign)}else{if(b.iconEl&&a!=b.icon){if(a){b.iconEl.setStyle("background-image",a?"url("+a+")":"");b.setIconAlign(b.iconAlign)}else{b.setIc
 onAlign(false);b.iconEl.remove();b.iconEl=null}}}}b.icon=a;return b},setIconClass:function(a){var b=this;if(b.rendered){if(!b.iconEl&&a){b.iconEl=b.el.createChild({tag:"img",src:Ext.BLANK_IMAGE_URL,cls:a});b.setIconAlign(b.iconAlign)}else{if(b.iconEl&&a!=b.iconCls){if(a){if(b.iconCls){b.iconEl.removeCls(b.iconCls)}b.iconEl.addCls(a);b.setIconAlign(b.iconAlign)}else{b.setIconAlign(false);b.iconEl.remove();b.iconEl=null}}}}b.iconCls=a;return b},setIconAlign:function(d){var c=this,a=["top","right","bottom","left"],d=((a.indexOf(d)==-1||!d)&&d!==false)?c.iconAlign:d,b;if(c.rendered&&c.iconEl){c.el.removeCls("x-iconalign-"+c.iconAlign);if(d){c.el.addCls("x-iconalign-"+d)}}c.iconAlign=(d===false)?c.iconAlign:d;return c},setBadge:function(b){var a=this;if(a.rendered){if(!a.badgeEl&&b){a.badgeEl=a.el.createChild({tag:"span",cls:a.badgeCls,html:b});a.el.addCls(a.hasBadgeCls)}else{if(a.badgeEl&&b!=a.badgeText){if(b){a.badgeEl.setHTML(b);a.el.addCls(a.hasBadgeCls)}else{a.badgeEl.remove
 ();a.badgeEl=null;a.el.removeCls(a.hasBadgeCls)}}}}a.badgeText=b;return a},getText:function(){return this.text},getBadgeText:function(){return this.badgeText},onDisable:function(){this.onDisableChange(true)},onEnable:function(){this.onDisableChange(false)},onDisableChange:function(a){var b=this;if(b.el){b.el[a?"addCls":"removeCls"](b.disabledCls);b.el.dom.disabled=a}b.disabled=a},onPress:function(b){var a=this;if(!a.disabled&&this.fireEvent("beforetap")!==false){setTimeout(function(){if(!a.preventCancel){a.onTapCancel()}a.callHandler(b);a.fireEvent("tap",a,b)},10)}},callHandler:function(b){var a=this;if(a.handler){a.handler.call(a.scope||a,a,b)}},createAutoHandler:function(){var a=this,b=a.autoEvent;if(b){if(typeof b=="string"){b={name:b,scope:a.scope||a}}a.addEvents(b.name);a.setHandler(function(){b.scope.fireEvent(b.name,b.scope,a)},b.scope)}}});Ext.reg("button",Ext.Button);Ext.SegmentedButton=Ext.extend(Ext.Container,{defaultType:"button",componentCls:"x-segmentedbutton",
 pressedCls:"x-button-pressed",allowMultiple:false,initComponent:function(){this.layout=Ext.apply({},this.layout||{},{type:"hbox",align:"stretch"});Ext.SegmentedButton.superclass.initComponent.call(this);if(this.allowDepress===undefined){this.allowDepress=this.allowMultiple}this.addEvents("toggle")},initEvents:function(){Ext.SegmentedButton.superclass.initEvents.call(this);this.mon(this.el,{tap:this.onTap,capture:true,scope:this})},afterLayout:function(b){var a=this;Ext.SegmentedButton.superclass.afterLayout.call(a,b);if(!a.initialized){a.items.each(function(d,c){a.setPressed(d,!!d.pressed,true)});if(a.allowMultiple){a.pressedButtons=a.getPressedButtons()}a.initialized=true}},onTap:function(b,a){if(!this.disabled&&(a=b.getTarget(".x-button"))){this.setPressed(a.id,this.allowDepress?undefined:true)}},getPressed:function(){return this.allowMultiple?this.getPressedButtons():this.pressedButton},setPressed:function(a,d,b){var c=this;a=c.getComponent(a);if(!a||!a.isButton||a.disabl
 ed){if(!c.allowMultiple&&c.pressedButton){c.setPressed(c.pressedButton,false)}return}if(!Ext.isBoolean(d)){d=!a.pressed}if(d){if(!c.allowMultiple){if(c.pressedButton&&c.pressedButton!==a){c.pressedButton.el.removeCls(c.pressedCls);c.pressedButton.pressed=false;if(b!==true){c.fireEvent("toggle",c,c.pressedButton,false)}}c.pressedButton=a}a.el.addCls(c.pressedCls);a.pressed=true;a.preventCancel=true;if(c.initialized&&b!==true){c.fireEvent("toggle",c,a,true)}}else{if(!d){if(!c.allowMultiple&&a===c.pressedButton){c.pressedButton=null}if(a.pressed){a.el.removeCls(c.pressedCls);a.pressed=false;if(b!==true){c.fireEvent("toggle",c,a,false)}}}}if(c.allowMultiple&&c.initialized){c.pressedButtons=c.getPressedButtons()}},getPressedButtons:function(b){var a=this.items.filterBy(function(c){return c.isButton&&!c.disabled&&c.pressed});return a.items},disable:function(){this.items.each(function(a){a.disable()});Ext.SegmentedButton.superclass.disable.apply(this,arguments)},enable:function(){t
 his.items.each(function(a){a.enable()},this);Ext.SegmentedButton.superclass.enable.apply(this,arguments)}});Ext.reg("segmentedbutton",Ext.SegmentedButton);Ext.AbstractStoreSelectionModel=Ext.extend(Ext.util.Observable,{allowDeselect:false,selected:null,constructor:function(a){a=a||{};Ext.apply(this,a);this.modes={SINGLE:true,SIMPLE:true,MULTI:true};this.setSelectionMode(a.mode);this.selected=new Ext.util.MixedCollection();Ext.AbstractStoreSelectionModel.superclass.constructor.call(this,a)},bind:function(a,b){if(!b&&this.store){if(a!==this.store&&this.store.autoDestroy){this.store.destroy()}else{this.store.un("add",this.onStoreAdd,this);this.store.un("clear",this.onStoreClear,this);this.store.un("remove",this.onStoreRemove,this);this.store.un("update",this.onStoreUpdate,this)}}if(a){a=Ext.StoreMgr.lookup(a);a.on({add:this.onStoreAdd,clear:this.onStoreClear,remove:this.onStoreRemove,update:this.onStoreUpdate,scope:this})}this.store=a;if(a&&!b){this.refresh()}},selectAll:functi
 on(a){var c=this.store.getRange();for(var b=0,d=c.length;b<d;b++){this.doSelect(c[b],true,a)}},deselectAll:function(){var b=this.getSelection();for(var a=0,c=b.length;a<c;a++){this.doDeselect(b[a])}},selectWithEvent:function(a,b){switch(this.selectionMode){case"MULTI":if(b.ctrlKey&&this.isSelected(a)){this.doDeselect(a,false)}else{if(b.shiftKey&&this.lastFocused){this.selectRange(this.lastFocused,a,b.ctrlKey)}else{if(b.ctrlKey){this.doSelect(a,true,false)}else{if(this.isSelected(a)&&!b.shiftKey&&!b.ctrlKey&&this.selected.getCount()>1){this.doSelect(a,false,false)}else{this.doSelect(a,false)}}}}break;case"SIMPLE":if(this.isSelected(a)){this.doDeselect(a)}else{this.doSelect(a,true)}break;case"SINGLE":if(this.allowDeselect&&this.isSelected(a)){this.doDeselect(a)}else{this.doSelect(a,false)}break}},selectRange:function(g,h,k,b){var e,j=this.store.indexOf(g),d=this.store.indexOf(h),f,c=0,a;if(this.isLocked()){return}if(j>d){f=d;d=j;j=f}for(e=j;e<=d;e++){if(this.isSelected(this.st
 ore.getAt(e))){c++}}if(!b){a=-1}else{a=(b=="up")?j:d}for(e=j;e<=d;e++){if(c==(d-j+1)){if(e!=a){this.doDeselect(e,true)}}else{this.doSelect(e,true)}}},select:function(b,c,a){this.doSelect(b,c,a)},deselect:function(b,a){this.doDeselect(b,a)},doSelect:function(c,d,b){if(this.locked){return}if(typeof c==="number"){c=[this.store.getAt(c)]}if(this.selectionMode=="SINGLE"&&c){var a=c.length?c[0]:c;this.doSingleSelect(a,b)}else{this.doMultiSelect(c,d,b)}},doMultiSelect:function(c,g,b){if(this.locked){return}var e=this.selected,h=false,a;c=!Ext.isArray(c)?[c]:c;if(!g&&e.getCount()>0){h=true;this.doDeselect(this.getSelection(),true)}for(var d=0,f=c.length;d<f;d++){a=c[d];if(g&&this.isSelected(a)){continue}h=true;this.lastSelected=a;e.add(a);if(!b){this.setLastFocused(a)}this.onSelectChange(a,true,b)}this.maybeFireSelectionChange(h&&!b)},doDeselect:function(c,b){if(this.locked){return}if(typeof c==="number"){c=[this.store.getAt(c)]}var g=false,e=this.selected,a;c=!Ext.isArray(c)?[c]:c;
 for(var d=0,f=c.length;d<f;d++){a=c[d];if(e.remove(a)){if(this.lastSelected==a){this.lastSelected=e.last()}this.onSelectChange(a,false,b);g=true}}this.maybeFireSelectionChange(g&&!b)},doSingleSelect:function(a,b){if(this.locked){return}if(this.isSelected(a)){return}var c=this.selected;if(c.getCount()>0){this.doDeselect(this.lastSelected,b)}c.add(a);this.lastSelected=a;this.onSelectChange(a,true,b);this.setLastFocused(a);this.maybeFireSelectionChange(!b)},setLastFocused:function(b){var a=this.lastFocused;this.lastFocused=b;this.onLastFocusChanged(a,b)},maybeFireSelectionChange:function(a){if(a){this.fireEvent("selectionchange",this,this.getSelection())}},getLastSelected:function(){return this.lastSelected},getLastFocused:function(){return this.lastFocused},getSelection:function(){return this.selected.getRange()},getSelectionMode:function(){return this.selectionMode},setSelectionMode:function(a){a=a?a.toUpperCase():"SINGLE";this.selectionMode=this.modes[a]?a:"SINGLE"},isLocked
 :function(){return this.locked},setLocked:function(a){this.locked=!!a},isSelected:function(a){a=Ext.isNumber(a)?this.store.getAt(a):a;return this.selected.indexOf(a)!==-1},hasSelection:function(){return this.selected.getCount()>0},refresh:function(){var a=[],e=this.getSelection(),d=e.length,c,f,b=0;for(;b<d;b++){c=e[b];if(this.store.indexOf(c)!=-1){a.push(c)}}if(this.selected.getCount()!=a.length){f=true}this.clearSelections();if(a.length){this.doSelect(a,false,true)}this.maybeFireSelectionChange(f)},clearSelections:function(){this.selected.clear();this.lastSelected=null;this.setLastFocused(null)},onStoreAdd:function(){},onStoreClear:function(){var a=this.selected;if(a.getCount>0){a.clear();this.lastSelected=null;this.setLastFocused(null);this.maybeFireSelectionChange(true)}},onStoreRemove:function(b,a){if(this.locked){return}var c=this.selected;if(c.remove(a)){if(this.lastSelected==a){this.lastSelected=null}if(this.getLastFocused()==a){this.setLastFocused(null)}this.maybeFi
 reSelectionChange(true)}},getCount:function(){return this.selected.getCount()},destroy:function(){},onStoreUpdate:function(){},onSelectChange:function(a,c,b){},onLastFocusChanged:function(b,a){},onEditorKey:function(b,a){},bindComponent:function(a){}});Ext.DataViewSelectionModel=Ext.extend(Ext.AbstractStoreSelectionModel,{deselectOnContainerClick:true,bindComponent:function(a){this.view=a;this.bind(a.getStore());var b={refresh:this.refresh,scope:this,el:{scope:this}};b.el[a.triggerEvent]=this.onItemClick;b.el[a.triggerCtEvent]=this.onContainerClick;a.on(b)},onItemClick:function(c){var a=this.view,b=a.findTargetByEvent(c);if(b){this.selectWithEvent(a.getRecord(b),c)}else{return false}},onContainerClick:function(){if(this.deselectOnContainerClick){this.deselectAll()}},onSelectChange:function(b,d,c){var a=this.view;if(d){a.onItemSelect(b);if(!c){this.fireEvent("select",this,b)}}else{a.onItemDeselect(b);if(!c){this.fireEvent("deselect",this,b)}}}});Ext.DataView=Ext.extend(Ext.Co
 mponent,{loadingText:"Loading...",selectedItemCls:"x-item-selected",emptyText:"",deferEmptyText:true,trackOver:false,blockRefresh:false,last:false,triggerEvent:"click",triggerCtEvent:"containerclick",addCmpEvents:function(){},initComponent:function(){var a=Ext.isDefined;if(!a(this.tpl)||!a(this.store)||!a(this.itemSelector)){throw"DataView requires tpl, store and itemSelector configurations to be defined."}Ext.DataView.superclass.initComponent.call(this);if(Ext.isString(this.tpl)||Ext.isArray(this.tpl)){this.tpl=new Ext.XTemplate(this.tpl)}if(Ext.isDefined(this.overCls)||Ext.isDefined(this.overClass)){this.overItemCls=this.overCls||this.overClass;delete this.overCls;delete this.overClass;throw"Using the deprecated overCls or overClass configuration. Use overItemCls."}if(Ext.isDefined(this.selectedCls)||Ext.isDefined(this.selectedClass)){this.selectedItemCls=this.selectedCls||this.selectedClass;delete this.selectedCls;delete this.selectedClass;throw"Using the deprecated selec
 tedCls or selectedClass configuration. Use selectedItemCls."}this.addCmpEvents();this.store=Ext.StoreMgr.lookup(this.store);this.all=new Ext.CompositeElementLite();this.getSelectionModel().bindComponent(this)},onRender:function(){Ext.DataView.superclass.onRender.apply(this,arguments);if(this.loadingText){this.loadMask=new Ext.LoadMask(this.el,{msg:this.loadingText})}},getSelectionModel:function(){if(!this.selModel){this.selModel={}}var a;switch(true){case this.simpleSelect:a="SIMPLE";break;case this.multiSelect:a="MULTI";break;case this.singleSelect:default:a="SINGLE";break}Ext.applyIf(this.selModel,{allowDeselect:this.allowDeselect,mode:a});if(!this.selModel.events){this.selModel=new Ext.DataViewSelectionModel(this.selModel)}if(!this.selModel.hasRelaySetup){this.relayEvents(this.selModel,["selectionchange","select","deselect"]);this.selModel.hasRelaySetup=true}if(this.disableSelection){this.selModel.locked=true}return this.selModel},refresh:function(){if(!this.rendered){ret
 urn}var b=this.getTargetEl(),a=this.store.getRange();b.update("");if(a.length<1){if(!this.deferEmptyText||this.hasSkippedEmptyText){b.update(this.emptyText)}this.all.clear()}else{this.tpl.overwrite(b,this.collectData(a,0));this.all.fill(Ext.query(this.itemSelector,b.dom));this.updateIndexes(0)}this.hasSkippedEmptyText=true;this.fireEvent("refresh")},prepareData:function(c,b,a){if(a){Ext.apply(c,this.prepareAssociatedData(a))}return c},prepareAssociatedData:function(m,b){b=b||[];var g=m.associations.items,k=g.length,d={},e,a,f,o,p,c,n,l,h;for(l=0;l<k;l++){c=g[l];e=m[c.storeName];d[c.name]=[];if(e&&e.data.length>0){f=e.data.items;p=f.length;for(h=0;h<p;h++){o=f[h];n=o.internalId;if(b.indexOf(n)==-1){b.push(n);d[c.name][h]=o.data;Ext.apply(d[c.name][h],this.prepareAssociatedData(o,b))}}}}return d},collectData:function(b,e){var d=[],c=0,a=b.length;for(;c<a;c++){d[d.length]=this.prepareData(b[c].data,e+c,b[c])}return d},bufferRender:function(a,b){var c=document.createElement("div
 ");this.tpl.overwrite(c,this.collectData(a,b));return Ext.query(this.itemSelector,c)},onUpdate:function(e,a){var b=this.store.indexOf(a),c,d;if(b>-1){c=this.all.elements[b];d=this.bufferRender([a],b)[0];this.all.replaceElement(b,d,true);this.updateIndexes(b,b);this.selModel.refresh()}},onAdd:function(f,d,e){if(this.all.getCount()===0){this.refresh();return}var c=this.bufferRender(d,e),g,b=this.all.elements;if(e<this.all.getCount()){g=this.all.item(e).insertSibling(c,"before",true);b.splice.apply(b,[e,0].concat(c))}else{g=this.all.last().insertSibling(c,"after",true);b.push.apply(b,c)}this.updateIndexes(e)},onRemove:function(c,a,b){this.all.removeElement(b,true);this.updateIndexes(b);if(this.store.getCount()===0){this.refresh()}},refreshNode:function(a){this.onUpdate(this.store,this.store.getAt(a))},updateIndexes:function(d,c){var b=this.all.elements;d=d||0;c=c||((c===0)?0:(b.length-1));for(var a=d;a<=c;a++){b[a].viewIndex=a}},getStore:function(){return this.store},bindStore:
 function(a,b){if(!b&&this.store){if(a!==this.store&&this.store.autoDestroy){this.store.destroy()}else{this.mun(this.store,{scope:this,beforeload:this.onBeforeLoad,datachanged:this.onDataChanged,add:this.onAdd,remove:this.onRemove,update:this.onUpdate,clear:this.refresh})}if(!a){if(this.loadMask){this.loadMask.bindStore(null)}this.store=null}}if(a){a=Ext.StoreMgr.lookup(a);this.mon(a,{scope:this,beforeload:this.onBeforeLoad,datachanged:this.onDataChanged,add:this.onAdd,remove:this.onRemove,update:this.onUpdate,clear:this.refresh});if(this.loadMask){this.loadMask.bindStore(a)}}this.store=a;this.getSelectionModel().bind(a);if(a){this.refresh()}},onDataChanged:function(){if(this.blockRefresh!==true){this.refresh.apply(this,arguments)}},findItemByChild:function(a){return Ext.fly(a).findParent(this.itemSelector,this.getTargetEl())},findTargetByEvent:function(a){return a.getTarget(this.itemSelector,this.getTargetEl())},getSelectedNodes:function(){var b=[],a=this.selModel.getSelecti
 on(),d=a.length,c=0;for(;c<d;c++){b.push(this.getNode(a[c]))}return b},getRecords:function(c){var b=[],d=0,a=c.length;for(;d<a;d++){b[b.length]=this.store.getAt(c[d].viewIndex)}return r},getRecord:function(a){return this.store.getAt(a.viewIndex)},isSelected:function(b){var a=this.getRecord(b);return this.selModel.isSelected(a)},select:function(b,c,a){this.selModel.select(b,c,a)},deselect:function(b,a){this.selModel.deselect(b,a)},getNode:function(b){if(Ext.isString(b)){return document.getElementById(b)}else{if(Ext.isNumber(b)){return this.all.elements[b]}else{if(b instanceof Ext.data.Model){var a=this.store.indexOf(b);return this.all.elements[a]}}}return b},getNodes:function(e,a){var d=this.all.elements,b=[],c;e=e||0;a=!Ext.isDefined(a)?Math.max(d.length-1,0):a;if(e<=a){for(c=e;c<=a&&d[c];c++){b.push(d[c])}}else{for(c=e;c>=a&&d[c];c--){b.push(d[c])}}return b},indexOf:function(a){a=this.getNode(a);if(Ext.isNumber(a.viewIndex)){return a.viewIndex}return this.all.indexOf(a)},on
 BeforeLoad:function(){if(this.loadingText){this.getTargetEl().update("");this.all.clear()}},onDestroy:function(){this.all.clear();Ext.DataView.superclass.onDestroy.call(this);this.bindStore(null);this.selModel.destroy()},onItemSelect:function(a){var b=this.getNode(a);Ext.fly(b).addCls(this.selectedItemCls)},onItemDeselect:function(a){var b=this.getNode(a);Ext.fly(b).removeCls(this.selectedItemCls)},select:function(a,b,d){console.warn("DataView: select will be removed, please access select through a DataView's SelectionModel, ie: view.getSelectionModel().select()");var c=this.getSelectionModel();return c.select.apply(c,arguments)},clearSelections:function(){console.warn("DataView: clearSelections will be removed, please access deselectAll through DataView's SelectionModel, ie: view.getSelectionModel().deselectAll()");var a=this.getSelectionModel();return a.deselectAll()}});Ext.reg("dataview",Ext.DataView);Ext.DataView.override({getSelectionCount:function(){return this.selMode
 l.getSelection().length},getSelectedRecords:function(){return this.selModel.getSelection()}});Ext.DataView.override({scroll:"vertical",pressedCls:"x-item-pressed",pressedDelay:100,allowDeselect:true,triggerEvent:"singletap",triggerCtEvent:"containertap",addCmpEvents:function(){this.addEvents("itemtap","itemdoubletap","itemswipe","containertap","selectionchange","beforeselect")},afterRender:function(){var a=this;Ext.DataView.superclass.afterRender.call(a);var b={tapstart:a.onTapStart,tapcancel:a.onTapCancel,touchend:a.onTapCancel,doubletap:a.onDoubleTap,swipe:a.onSwipe,scope:a};b[this.triggerEvent]=a.onTap;a.mon(a.getTargetEl(),b);if(this.store){this.bindStore(this.store,true)}},onTap:function(c){var b=this.findTargetByEvent(c);if(b){Ext.fly(b).removeCls(this.pressedCls);var a=this.indexOf(b);if(this.onItemTap(b,a,c)!==false){this.fireEvent("itemtap",this,a,b,c)}}else{if(this.fireEvent("containertap",this,c)!==false){this.onContainerTap(c)}}},onTapStart:function(d,a){var c=th
 is,b=this.findTargetByEvent(d);if(b){if(c.pressedDelay){if(c.pressedTimeout){clearTimeout(c.pressedTimeout)}c.pressedTimeout=setTimeout(function(){Ext.fly(b).addCls(c.pressedCls)},Ext.isNumber(c.pressedDelay)?c.pressedDelay:100)}else{Ext.fly(b).addCls(c.pressedCls)}}},onTapCancel:function(d,a){var c=this,b=this.findTargetByEvent(d);if(c.pressedTimeout){clearTimeout(c.pressedTimeout);delete c.pressedTimeout}if(b){Ext.fly(b).removeCls(c.pressedCls)}},onContainerTap:function(a){},onDoubleTap:function(b){var a=this.findTargetByEvent(b);if(a){this.fireEvent("itemdoubletap",this,this.indexOf(a),a,b)}},onSwipe:function(b){var a=this.findTargetByEvent(b);if(a){this.fireEvent("itemswipe",this,this.indexOf(a),a,b)}},onItemTap:function(b,a,c){if(this.pressedTimeout){clearTimeout(this.pressedTimeout);delete this.pressedTimeout}return true}});Ext.List=Ext.extend(Ext.DataView,{componentCls:"x-list",pinHeaders:Ext.is.iOS||Ext.is.Desktop,indexBar:false,grouped:false,clearSelectionOnDeactiva
 te:true,renderTpl:['<tpl if="grouped"><h3 class="x-list-header x-list-header-swap x-hidden-display"></h3></tpl>'],groupTpl:['<tpl for=".">','<div class="x-list-group x-group-{id}">','<h3 class="x-list-header">{group}</h3>','<div class="x-list-group-items">',"{items}","</div>","</div>","</tpl>"],itemSelector:".x-list-item",onItemDisclosure:false,preventSelectionOnDisclose:true,initComponent:function(){var a={};if(Ext.isArray(this.itemTpl)){this.itemTpl=this.itemTpl.join("")}else{if(this.itemTpl&&this.itemTpl.html){Ext.apply(a,this.itemTpl.initialConfig);this.itemTpl=this.itemTpl.html}}if(!Ext.isDefined(this.itemTpl)){throw new Error("Ext.List: itemTpl is a required configuration.")}if(this.itemTpl&&this.itemTpl.indexOf('"x-list-item"')!==-1){throw new Error("Ext.List: Using a CSS class of x-list-item within your own tpl will break Ext.Lists. Remove the x-list-item from the tpl/itemTpl")}this.tpl='<tpl for="."><div class="x-list-item"><div class="x-list-item-body">'+this.itemT
 pl+"</div>";if(this.onItemDisclosure){this.tpl+='<div class="x-list-disclosure"></div>'}this.tpl+="</div></tpl>";this.tpl=new Ext.XTemplate(this.tpl,a);if(this.grouped){this.listItemTpl=this.tpl;if(Ext.isString(this.listItemTpl)||Ext.isArray(this.listItemTpl)){this.listItemTpl=new Ext.XTemplate(this.listItemTpl,a)}if(Ext.isString(this.groupTpl)||Ext.isArray(this.groupTpl)){this.tpl=new Ext.XTemplate(this.groupTpl)}}else{this.indexBar=false}if(this.scroll!==false){this.scroll={direction:"vertical",useIndicators:!this.indexBar}}Ext.List.superclass.initComponent.call(this);if(this.onItemDisclosure){if(Ext.isFunction(this.onItemDisclosure)){this.onItemDisclosure={scope:this,handler:this.onItemDisclosure}}}this.on("deactivate",this.onDeactivate,this);this.addEvents("disclose")},onRender:function(){if(this.grouped){Ext.applyIf(this.renderData,{grouped:true});if(this.scroll){Ext.applyIf(this.renderSelectors,{header:".x-list-header-swap"})}}Ext.List.superclass.onRender.apply(this,ar
 guments)},onDeactivate:function(){if(this.clearSelectionOnDeactivate){this.getSelectionModel().deselectAll()}},afterRender:function(){if(!this.grouped){this.el.addCls("x-list-flat")}this.getTargetEl().addCls("x-list-parent");if(this.indexBar){this.indexBar=new Ext.IndexBar(Ext.apply({},Ext.isObject(this.indexBar)?this.indexBar:{},{xtype:"indexbar",alphabet:true,renderTo:this.el}));this.addCls("x-list-indexed")}Ext.List.superclass.afterRender.call(this);if(this.onItemDisclosure){this.mon(this.getTargetEl(),"singletap",this.handleItemDisclosure,this,{delegate:".x-list-disclosure"})}},initEvents:function(){Ext.List.superclass.initEvents.call(this);if(this.grouped){if(this.pinHeaders&&this.scroll){this.mon(this.scroller,{scrollstart:this.onScrollStart,scroll:this.onScroll,scope:this})}if(this.indexBar){this.mon(this.indexBar,{index:this.onIndex,scope:this})}}},handleItemDisclosure:function(f,c){var d=this.findItemByChild(c),a,b;if(d){a=this.getRecord(d);b=this.indexOf(d);if(this
 .preventSelectionOnDisclose){f.stopEvent()}this.fireEvent("disclose",a,d,b,f);if(Ext.isObject(this.onItemDisclosure)&&this.onItemDisclosure.handler){this.onItemDisclosure.handler.call(this,a,d,b)}}},setActiveGroup:function(b){var a=this;if(b){if(!a.activeGroup||a.activeGroup.header!=b.header){a.header.setHTML(b.header.getHTML());a.header.show()}}else{a.header.hide()}this.activeGroup=b},getClosestGroups:function(g){if(!this.groupOffsets){this.updateOffsets()}var a=this.groupOffsets,d=a.length,f,b,e,c;for(b=0;b<d;b++){f=a[b];if(f.offset>g.y){c=f;break}e=f}return{current:e,next:c}},updateIndexes:function(){Ext.List.superclass.updateIndexes.apply(this,arguments);this.updateOffsets()},afterComponentLayout:function(){Ext.List.superclass.afterComponentLayout.apply(this,arguments);this.updateOffsets()},updateOffsets:function(){if(this.grouped){this.groupOffsets=[];var c=this.getTargetEl().query("h3.x-list-header"),b=c.length,d,a;for(a=0;a<b;a++){d=Ext.get(c[a]);d.setDisplayMode(Ext.
 Element.VISIBILITY);this.groupOffsets.push({header:d,offset:d.dom.offsetTop})}}},onScrollStart:function(){var a=this.scroller.getOffset();this.closest=this.getClosestGroups(a);this.setActiveGroup(this.closest.current)},onScroll:function(a,d,c){if(!this.closest){this.closest=this.getClosestGroups(d)}if(!this.headerHeight){this.headerHeight=this.header.getHeight()}if(d.y<=0){if(this.activeGroup){this.setActiveGroup(false);this.closest.next=this.closest.current}return}else{if((this.closest.next&&d.y>this.closest.next.offset)||(d.y<this.closest.current.offset)){this.closest=this.getClosestGroups(d);this.setActiveGroup(this.closest.current)}}if(this.closest.next&&d.y>0&&this.closest.next.offset-d.y<=this.headerHeight){var b=this.headerHeight-(this.closest.next.offset-d.y);Ext.Element.cssTranslate(this.header,{x:0,y:-b});this.transformed=true}else{if(this.transformed){this.header.setStyle("-webkit-transform",null);this.transformed=false}}},onIndex:function(e,g,f){var k=e.get("key"
 ).toLowerCase(),c=this.store.getGroups(),h=c.length,j,d,b,a;for(d=0;d<h;d++){j=c[d];a=this.getGroupId(j);if(a==k||a>k){b=a;break}else{b=a}}b=this.getTargetEl().down(".x-group-"+a);if(b){this.scroller.scrollTo({x:0,y:b.getOffsetsTo(this.scrollEl)[1]},false,null,true)}},getGroupId:function(a){return a.name.toLowerCase()},collectData:function(e,l){if(!this.grouped){return Ext.List.superclass.collectData.call(this,e,l)}var g=[],d=this.store.getGroups(),h=d.length,b,a,j,k,f;for(f=0,h=d.length;f<h;f++){k=d[f];b=k.children;for(j=0,a=b.length;j<a;j++){b[j]=b[j].data}g.push({group:k.name,id:this.getGroupId(k),items:this.listItemTpl.apply(b)})}return g},onUpdate:function(b,a){if(this.grouped){this.refresh()}else{Ext.List.superclass.onUpdate.apply(this,arguments)}},onAdd:function(c,a,b){if(this.grouped){this.refresh()}else{Ext.List.superclass.onAdd.apply(this,arguments)}},onRemove:function(c,a,b){if(this.grouped){this.refresh()}else{Ext.List.superclass.onRemove.apply(this,arguments)}}}
 );Ext.reg("list",Ext.List);Ext.IndexBar=Ext.extend(Ext.DataView,{componentCls:"x-indexbar",direction:"vertical",tpl:'<tpl for="."><div class="x-indexbar-item">{value}</div></tpl>',itemSelector:"div.x-indexbar-item",letters:["A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","W","X","Y","Z"],listPrefix:"",componentLayout:"autocomponent",scroll:false,initComponent:function(){this.componentLayout=this.getComponentLayout();if(!this.store){this.store=new Ext.data.Store({model:"IndexBarModel"})}if(this.alphabet==true){this.ui=this.ui||"alphabet"}if(this.direction=="horizontal"){this.horizontal=true}else{this.vertical=true}this.addEvents("index");Ext.apply(this.renderData,{componentCls:this.componentCls});Ext.apply(this.renderSelectors,{body:"."+this.componentCls+"-body"});Ext.IndexBar.superclass.initComponent.call(this)},renderTpl:['<div class="{componentCls}-body"></div>'],getTargetEl:function(){return this.body},afterRender:function(){Ext.Ind
 exBar.superclass.afterRender.call(this);if(this.alphabet===true){this.loadAlphabet()}if(this.vertical){this.el.addCls(this.componentCls+"-vertical")}else{if(this.horizontal){this.el.addCls(this.componentCls+"-horizontal")}}},loadAlphabet:function(){var e=this.letters,a=e.length,d=[],b,c;for(b=0;b<a;b++){c=e[b];d.push({key:c.toLowerCase(),value:c})}this.store.loadData(d)},refresh:function(){var b=this.getTargetEl(),a=this.store.getRange();b.update("");if(a.length<1){if(!this.deferEmptyText||this.hasSkippedEmptyText){b.update(this.emptyText)}this.all.clear()}else{this.tpl.overwrite(b,this.collectData(a,0));this.all.fill(Ext.query(this.itemSelector,b.dom));this.updateIndexes(0)}this.hasSkippedEmptyText=true;this.fireEvent("refresh")},collectData:function(){var a=Ext.IndexBar.superclass.collectData.apply(this,arguments);if(this.listPrefix.length>0){a.unshift({key:"",value:this.listPrefix})}return a},initEvents:function(){Ext.IndexBar.superclass.initEvents.call(this);this.mon(thi
 s.el,{touchstart:this.onTouchStart,touchend:this.onTouchEnd,touchmove:this.onTouchMove,scope:this})},onTouchStart:function(b,a){b.stopEvent();this.el.addCls(this.componentCls+"-pressed");this.pageBox=this.el.getPageBox();this.onTouchMove(b)},onTouchEnd:function(b,a){b.stopEvent();this.el.removeCls(this.componentCls+"-pressed")},onTouchMove:function(d){d.stopPropagation();var a=Ext.util.Point.fromEvent(d),c,b,f=this.pageBox;if(!f){f=this.pageBox=this.el.getPageBox()}if(this.vertical){if(a.y>f.bottom||a.y<f.top){return}c=Ext.Element.fromPoint(f.left+(f.width/2),a.y)}else{if(this.horizontal){if(a.x>f.right||a.x<f.left){return}c=Ext.Element.fromPoint(a.x,f.top+(f.height/2))}}if(c){b=this.getRecord(c.dom);if(b){this.fireEvent("index",b,c,this.indexOf(c))}}},isVertical:function(){return this.vertical},isHorizontal:function(){return this.horizontal}});Ext.reg("indexbar",Ext.IndexBar);Ext.regModel("IndexBarModel",{fields:["key","value"]});Ext.Toolbar=Ext.extend(Ext.Container,{isTool
 bar:true,defaultType:"button",baseCls:"x-toolbar",titleCls:"x-toolbar-title",ui:"dark",layout:null,titleEl:null,initComponent:function(){this.layout=Ext.apply({},this.layout||{},{type:"hbox",align:"center"});Ext.Toolbar.superclass.initComponent.call(this)},afterRender:function(){Ext.Toolbar.superclass.afterRender.call(this);if(this.title){this.titleEl=this.el.createChild({cls:this.titleCls,html:this.title})}},setTitle:function(a){this.title=a;if(this.rendered){if(!this.titleEl){this.titleEl=this.el.createChild({cls:this.titleCls,html:this.title})}this.titleEl.setHTML(a)}},showTitle:function(){if(this.titleEl){this.titleEl.show()}},hideTitle:function(){if(this.titleEl){this.titleEl.hide()}}});Ext.reg("toolbar",Ext.Toolbar);Ext.Spacer=Ext.extend(Ext.Component,{initComponent:function(){if(!this.width){this.flex=1}Ext.Spacer.superclass.initComponent.call(this)},onRender:function(){Ext.Spacer.superclass.onRender.apply(this,arguments);if(this.flex){this.el.setStyle("-webkit-box-fl
 ex",this.flex)}}});Ext.reg("spacer",Ext.Spacer);Ext.Sheet=Ext.extend(Ext.Panel,{baseCls:"x-sheet",centered:false,floating:true,modal:true,draggable:false,monitorOrientation:true,hidden:true,hideOnMaskTap:false,enter:"bottom",exit:"bottom",enterAnimation:"slide",exitAnimation:"slide",transitions:{bottom:"up",top:"down",right:"left",left:"right"},animSheet:function(a){var d=null,b=this,c=b.transitions,e=Ext.Anim.prototype.opposites||{};if(a&&this[a]){if(a=="enter"){d=(typeof b.enterAnimation=="string")?{type:b.enterAnimation||"slide",direction:c[b.enter]||"up"}:b.enterAnimation}else{if(a=="exit"){d=(typeof b.exitAnimation=="string")?{type:b.exitAnimation||"slide",direction:c[b.exit]||"down"}:b.exitAnimation}}}return d},orient:function(a,j,d){if(!this.container||this.centered||!this.floating){return this}var g=this,e=g.initialConfig||{},k={width:e.width,height:e.height},i={x:e.x,y:e.y},c=g.el.getPageBox(),f,b=0;if(g.container.dom==document.body){f={width:window.innerWidth,heigh
 t:window.innerHeight};b=document.body.scrollTop}else{f=g.container.getPageBox()}f.centerY=f.height/2;f.centerX=f.width/2;if(i.x!=undefined||i.y!=undefined){i.x=i.x||0;i.y=i.y||0}else{if(/^(bottom|top)/i.test(g.enter)){k.width=g.stretchX?f.width:Math.min(200,Math.max(k.width||c.width||f.width,f.width));k.height=Math.min(k.height||0,f.height)||undefined;k=g.setSize(k).getSize();i.x=f.centerX-k.width/2;i.y=g.enter=="top"?0:f.height-k.height+b}else{if(/^(left|right)/i.test(g.enter)){k.height=g.stretchY?f.height:Math.min(200,Math.max(k.height||c.height||f.height,f.height));k.width=Math.min(k.width||0,f.width)||undefined;k=g.setSize(k).getSize();i.y=0;i.x=g.enter=="left"?0:f.width-k.width}}}g.setPosition(i);return this},afterRender:function(){Ext.Sheet.superclass.afterRender.apply(this,arguments);this.el.setDisplayMode(Ext.Element.OFFSETS)},onShow:function(a){this.orient();return Ext.Sheet.superclass.onShow.call(this,a||this.animSheet("enter"))},onOrientationChange:function(b,a,c)
 {this.orient();Ext.Sheet.superclass.onOrientationChange.apply(this,arguments)},beforeDestroy:function(){delete this.showAnimation;this.hide(false);Ext.Sheet.superclass.beforeDestroy.call(this)}});Ext.reg("sheet",Ext.Sheet);Ext.ActionSheet=Ext.extend(Ext.Sheet,{componentCls:"x-sheet-action",stretchY:true,stretchX:true,defaultType:"button",constructor:function(a){a=a||{};Ext.ActionSheet.superclass.constructor.call(this,Ext.applyIf({floating:true},a))}});Ext.reg("actionsheet",Ext.ActionSheet);Ext.TabBar=Ext.extend(Ext.Panel,{componentCls:"x-tabbar",activeTab:null,defaultType:"tab",sortable:false,sortHoldThreshold:350,initComponent:function(){this.addEvents("change");this.layout=Ext.apply({},this.layout||{},{type:"hbox",align:"middle"});Ext.TabBar.superclass.initComponent.call(this)},initEvents:function(){if(this.sortable){this.sortable=new Ext.util.Sortable(this.el,{itemSelector:".x-tab",direction:"horizontal",delay:this.sortHoldThreshold,constrain:true});this.mon(this.sortable
 ,"sortchange",this.onSortChange,this)}this.mon(this.el,{touchstart:this.onTouchStart,scope:this});Ext.TabBar.superclass.initEvents.call(this)},onTouchStart:function(b,a){a=b.getTarget(".x-tab");if(a){this.onTabTap(Ext.getCmp(a.id))}},onSortChange:function(c,b,a){},onTabTap:function(a){if(!a.disabled){if(this.cardLayout){if(this.cardSwitchAnimation){var b={reverse:(this.items.indexOf(a)<this.items.indexOf(this.activeTab))?true:false};if(Ext.isObject(this.cardSwitchAnimation)){Ext.apply(b,this.cardSwitchAnimation)}else{Ext.apply(b,{type:this.cardSwitchAnimation})}}this.cardLayout.setActiveItem(a.card,b||this.cardSwitchAnimation)}this.activeTab=a;this.fireEvent("change",this,a,a.card)}},getCardLayout:function(){return this.cardLayout}});Ext.reg("tabbar",Ext.TabBar);Ext.Tab=Ext.extend(Ext.Button,{isTab:true,baseCls:"x-tab",pressedCls:"x-tab-pressed",activeCls:"x-tab-active",active:false,initComponent:function(){this.addEvents("activate","deactivate");Ext.Tab.superclass.initCompo
 nent.call(this);var a=this.card;if(a){this.card=null;this.setCard(a)}},setCard:function(a){if(this.card){this.mun(this.card,{activate:this.activate,deactivate:this.deactivate,scope:this})}this.card=a;if(a){Ext.apply(this,a.tab||{});this.setText(this.title||a.title||this.text);this.setIconClass(this.iconCls||a.iconCls);this.setBadge(this.badgeText||a.badgeText);this.mon(a,{beforeactivate:this.activate,beforedeactivate:this.deactivate,scope:this})}},onRender:function(){Ext.Tab.superclass.onRender.apply(this,arguments);if(this.active){this.el.addCls(this.activeCls)}},getCard:function(){return this.card},activate:function(){this.active=true;if(this.el){this.el.addCls(this.activeCls)}this.fireEvent("activate",this)},deactivate:function(){this.active=false;if(this.el){this.el.removeCls(this.activeCls)}this.fireEvent("deactivate",this)}});Ext.reg("tab",Ext.Tab);Ext.TabPanel=Ext.extend(Ext.Panel,{cardSwitchAnimation:"slide",tabBarDock:"top",componentCls:"x-tabpanel",ui:"dark",initCo
 mponent:function(){var a=new Ext.layout.CardLayout(this.layout||{});this.layout=null;this.setLayout(a);this.tabBar=new Ext.TabBar(Ext.apply({},this.tabBar||{},{cardLayout:a,cardSwitchAnimation:this.cardSwitchAnimation,dock:this.tabBarDock,ui:this.ui,sortable:this.sortable}));if(this.dockedItems&&!Ext.isArray(this.dockedItems)){this.dockedItems=[this.dockedItems]}else{if(!this.dockedItems){this.dockedItems=[]}}this.dockedItems.push(this.tabBar);Ext.TabPanel.superclass.initComponent.call(this)},getTabBar:function(){return this.tabBar},onAdd:function(c,b){var a=this.tabBar;c.tab=a.insert(b,{xtype:"tab",card:c});a.doLayout()},onRemove:function(b,a){this.tabBar.remove(b.tab,a);this.tabBar.doLayout()}});Ext.reg("tabpanel",Ext.TabPanel);Ext.Carousel=Ext.extend(Ext.Panel,{baseCls:"x-carousel",indicator:true,ui:"dark",direction:"horizontal",horizontal:false,vertical:false,initComponent:function(){this.layout={type:"card",sizeAllCards:true,hideInactive:false,itemCls:"x-carousel-item",
 targetCls:"x-carousel-body",setOwner:function(b){Ext.layout.CardLayout.superclass.setOwner.call(this,b)}};if(this.indicator){var a=Ext.isObject(this.indicator)?this.indicator:{};this.indicator=new Ext.Carousel.Indicator(Ext.apply({},a,{direction:this.direction,carousel:this,ui:this.ui}))}if(this.direction=="horizontal"){this.horizontal=true}else{this.vertical=true}Ext.Carousel.superclass.initComponent.call(this)},afterRender:function(){Ext.Carousel.superclass.afterRender.call(this);this.mon(this.body,{drag:this.onDrag,dragThreshold:5,dragend:this.onDragEnd,direction:this.direction,scope:this});this.el.addCls(this.baseCls+"-"+this.direction)},onAdd:function(){Ext.Carousel.superclass.onAdd.apply(this,arguments);var a=this.indicator;if(a){a.onCardAdd()}},onRemove:function(){Ext.Carousel.superclass.onRemove.apply(this,arguments);var a=this.indicator;if(a){a.onCardRemove()}},afterLayout:function(){Ext.Carousel.superclass.afterLayout.apply(this,arguments);this.currentSize=this.bod
 y.getSize();this.currentScroll={x:0,y:0};this.updateCardPositions();var a=this.layout.getActiveItem();if(a&&this.indicator){this.indicator.onBeforeCardSwitch(this,a,null,this.items.indexOf(a))}},onDrag:function(b){this.currentScroll={x:b.deltaX,y:b.deltaY};var a=this.items.items.indexOf(this.layout.activeItem);if(this.horizontal){if((a==0&&b.deltaX>0)||(a==this.items.length-1&&b.deltaX<0)){this.currentScroll.x=b.deltaX/2}}else{if(this.vertical){if((a==0&&b.deltaY>0)||(a==this.items.length-1&&b.deltaY<0)){this.currentScroll.y=b.deltaY/2}}}this.updateCardPositions()},updateCardPositions:function(a){var g=this.items.items,f=g.length,h,c,b,e,d;for(c=0;c<f;c++){b=g[c];if(this.isCardInRange(b)){if(b.hidden){b.show()}e=b.el;d=e.dom.style;if(a){if(b===this.layout.activeItem){e.on("webkitTransitionEnd",this.onTransitionEnd,this,{single:true})}d.webkitTransitionDuration="300ms"}else{d.webkitTransitionDuration="0ms"}h=this.getCardOffset(b);if(this.horizontal){Ext.Element.cssTransform(e
 ,{translate:[h,0]})}else{Ext.Element.cssTransform(e,{translate:[0,h]})}}else{if(!b.hidden){b.hide()}}}},getCardOffset:function(c){var d=this.getCardIndexOffset(c),b=this.currentSize,a=this.currentScroll;return this.horizontal?(d*b.width)+a.x:(d*b.height)+a.y},getCardIndexOffset:function(a){return this.items.items.indexOf(a)-this.getActiveIndex()},isCardInRange:function(a){return Math.abs(this.getCardIndexOffset(a))<=2},getActiveIndex:function(){return this.items.indexOf(this.layout.activeItem)},onDragEnd:function(d,b){var a,c;if(this.horizontal){c=d.deltaX;a=d.previousDeltaX}else{c=d.deltaY;a=d.previousDeltaY}if(c<0&&Math.abs(c)>3&&a<=0&&this.layout.getNext()){this.next()}else{if(c>0&&Math.abs(c)>3&&a>=0&&this.layout.getPrev()){this.prev()}else{this.scrollToCard(this.layout.activeItem)}}},onBeforeCardSwitch:function(a){if(!this.customDrag&&this.items.indexOf(a)!=-1){var b=a.el.dom.style;b.webkitTransitionDuration=null;b.webkitTransform=null}return Ext.Carousel.superclass.onB
 eforeCardSwitch.apply(this,arguments)},scrollToCard:function(a){this.currentScroll={x:0,y:0};this.oldCard=this.layout.activeItem;if(a!=this.oldCard&&this.isCardInRange(a)&&this.onBeforeCardSwitch(a,this.oldCard,this.items.indexOf(a),true)!==false){this.layout.activeItem=a;if(this.horizontal){this.currentScroll.x=-this.getCardOffset(a)}else{this.currentScroll.y=-this.getCardOffset(a)}}this.updateCardPositions(true)},onTransitionEnd:function(b,a){this.customDrag=false;this.currentScroll={x:0,y:0};if(this.oldCard&&this.layout.activeItem!=this.oldCard){this.onCardSwitch(this.layout.activeItem,this.oldCard,this.items.indexOf(this.layout.activeItem),true)}delete this.oldCard},onCardSwitch:function(a,c,b,d){this.currentScroll={x:0,y:0};this.updateCardPositions();Ext.Carousel.superclass.onCardSwitch.apply(this,arguments);a.fireEvent("activate",a)},next:function(){var a=this.layout.getNext();if(a){this.customDrag=true;this.scrollToCard(a)}return this},prev:function(){var a=this.layou
 t.getPrev();if(a){this.customDrag=true;this.scrollToCard(a)}return this},isVertical:function(){return this.vertical},isHorizontal:function(){return this.horizontal},beforeDestroy:function(){Ext.destroy(this.indicator);Ext.Carousel.superclass.beforeDestroy.call(this)}});Ext.reg("carousel",Ext.Carousel);Ext.Carousel.Indicator=Ext.extend(Ext.Component,{baseCls:"x-carousel-indicator",initComponent:function(){if(this.carousel.rendered){this.render(this.carousel.body);this.onBeforeCardSwitch(null,null,this.carousel.items.indexOf(this.carousel.layout.getActiveItem()))}else{this.carousel.on("render",function(){this.render(this.carousel.body)},this,{single:true})}Ext.Carousel.Indicator.superclass.initComponent.call(this)},onRender:function(){Ext.Carousel.Indicator.superclass.onRender.apply(this,arguments);for(var a=0,b=this.carousel.items.length;a<b;a++){this.createIndicator()}this.mon(this.carousel,{beforecardswitch:this.onBeforeCardSwitch,scope:this});this.mon(this.el,{tap:this.onT
 ap,scope:this});this.el.addCls(this.baseCls+"-"+this.direction)},onTap:function(g,a){var b=this.el.getPageBox(),f=b.left+(b.width/2),c=b.top+(b.height/2),d=this.carousel;if((d.isHorizontal()&&g.pageX>f)||(d.isVertical()&&g.pageY>c)){this.carousel.next()}else{this.carousel.prev()}},createIndicator:function(){this.indicators=this.indicators||[];this.indicators.push(this.el.createChild({tag:"span"}))},onBeforeCardSwitch:function(d,c,a,b){if(Ext.isNumber(b)&&b!=-1&&this.indicators[b]){this.indicators[b].radioCls("x-carousel-indicator-active")}},onCardAdd:function(){if(this.rendered){this.createIndicator()}},onCardRemove:function(){if(this.rendered){this.indicators.pop().remove()}}});Ext.reg("carouselindicator",Ext.Carousel.Indicator);Ext.Map=Ext.extend(Ext.Component,{baseCls:"x-map",useCurrentLocation:false,monitorResize:true,map:null,geo:null,maskMap:false,maskMapCls:"x-mask-map",initComponent:function(){this.mapOptions=this.mapOptions||{};this.scroll=false;if(!(window.google||
 {}).maps){this.html="Google Maps API is required"}else{if(this.useCurrentLocation){this.geo=this.geo||new Ext.util.GeoLocation({autoLoad:false});this.geo.on({locationupdate:this.onGeoUpdate,locationerror:this.onGeoError,scope:this})}}Ext.Map.superclass.initComponent.call(this);this.addEvents("maprender","centerchange","typechange","zoomchange");if(this.geo){this.on({activate:this.onUpdate,scope:this,single:true});this.geo.updateLocation()}},onRender:function(b,a){Ext.Map.superclass.onRender.apply(this,arguments);this.el.setDisplayMode(Ext.Element.OFFSETS)},afterRender:function(){Ext.Map.superclass.afterRender.apply(this,arguments);this.renderMap()},onResize:function(a,b){Ext.Map.superclass.onResize.apply(this,arguments);if(this.map){google.maps.event.trigger(this.map,"resize")}},afterComponentLayout:function(){if(this.maskMap&&!this.mask){this.el.mask(null,this.maskMapCls);this.mask=true}},renderMap:function(){var b=this,c=(window.google||{}).maps;if(c){if(Ext.is.iPad){Ext.a
 pplyIf(b.mapOptions,{navigationControlOptions:{style:c.NavigationControlStyle.ZOOM_PAN}})}Ext.applyIf(b.mapOptions,{center:new c.LatLng(37.381592,-122.135672),zoom:12,mapTypeId:c.MapTypeId.ROADMAP});if(b.maskMap&&!b.mask){b.el.mask(null,this.maskMapCls);b.mask=true}if(b.el&&b.el.dom&&b.el.dom.firstChild){Ext.fly(b.el.dom.firstChild).remove()}if(b.map){c.event.clearInstanceListeners(b.map)}b.map=new c.Map(b.el.dom,b.mapOptions);var a=c.event;a.addListener(b.map,"zoom_changed",Ext.createDelegate(b.onZoom,b));a.addListener(b.map,"maptypeid_changed",Ext.createDelegate(b.onTypeChange,b));a.addListener(b.map,"center_changed",Ext.createDelegate(b.onCenterChange,b));b.fireEvent("maprender",b,b.map)}},onGeoUpdate:function(b){var a;if(b){a=this.mapOptions.center=new google.maps.LatLng(b.latitude,b.longitude)}if(this.rendered){this.update(a)}else{this.on("activate",this.onUpdate,this,{single:true,data:a})}},onGeoError:function(a){},onUpdate:function(c,b,a){this.update((a||{}).data)},up
 date:function(c){var a=this,b=(window.google||{}).maps;if(b){c=c||a.coords||new b.LatLng(37.381592,-122.135672);if(c&&!(c instanceof b.LatLng)&&"longitude" in c){c=new b.LatLng(c.latitude,c.longitude)}if(!a.hidden&&a.rendered){a.map||a.renderMap();if(a.map&&c instanceof b.LatLng){a.map.panTo(c)}}else{a.on("activate",a.onUpdate,a,{single:true,data:c})}}},onZoom:function(){this.mapOptions.zoom=(this.map&&this.map.getZoom?this.map.getZoom():this.mapOptions.zoom)||10;this.fireEvent("zoomchange",this,this.map,this.mapOptions.zoom)},onTypeChange:function(){this.mapOptions.mapTypeId=this.map&&this.map.getMapTypeId?this.map.getMapTypeId():this.mapOptions.mapTypeId;this.fireEvent("typechange",this,this.map,this.mapOptions.mapTypeId)},onCenterChange:function(){this.mapOptions.center=this.map&&this.map.getCenter?this.map.getCenter():this.mapOptions.center;this.fireEvent("centerchange",this,this.map,this.mapOptions.center)},getState:function(){return this.mapOptions},onDestroy:function(
 ){Ext.destroy(this.geo);if(this.maskMap&&this.mask){this.el.unmask()}if(this.map&&(window.google||{}).maps){google.maps.event.clearInstanceListeners(this.map)}Ext.Map.superclass.onDestroy.call(this)}});Ext.reg("map",Ext.Map);Ext.NestedList=Ext.extend(Ext.Panel,{componentCls:"x-nested-list",layout:"card",cardSwitchAnimation:"slide",backButton:null,backText:"Back",useTitleAsBackText:true,updateTitleText:true,displayField:"text",loadingText:"Loading...",emptyText:"No items available.",onItemDisclosure:false,clearSelectionDelay:200,allowDeselect:false,getItemTextTpl:function(a){return"{"+this.displayField+"}"},getTitleTextTpl:function(a){return"{"+this.displayField+"}"},renderTitleText:function(b){if(!b.titleTpl){b.titleTpl=new Ext.XTemplate(this.getTitleTextTpl(b))}var a=b.getRecord();if(a){return b.titleTpl.applyTemplate(a.data)}else{if(b.isRoot){return this.title||this.backText}else{throw new Error("No RecordNode passed into renderTitleText")}}},useToolbar:true,getDetailCard:
 function(b,a){return false},initComponent:function(){var b=Ext.StoreMgr.lookup(this.store),a=b.getRootNode(),c=a.getRecord()?this.renderTitleText(a):this.title||"";this.store=b;if(this.useToolbar){this.backButton=new Ext.Button({text:this.backText,ui:"back",handler:this.onBackTap,scope:this,hidden:true});if(!this.toolbar||!this.toolbar.isComponent){this.toolbar=Ext.apply({},this.toolbar||{},{dock:"top",xtype:"toolbar",ui:"light",title:c,items:[]});this.toolbar.items.unshift(this.backButton);this.toolbar=new Ext.Toolbar(this.toolbar);this.dockedItems=this.dockedItems||[];this.dockedItems.push(this.toolbar)}else{this.toolbar.insert(0,this.backButton)}}this.items=[this.getSubList(a)];Ext.NestedList.superclass.initComponent.call(this);this.on("itemtap",this.onItemTap,this);this.addEvents("listchange","leafitemtap")},getListConfig:function(b){var c=b.internalId,a=this.emptyText;return{itemId:c,xtype:"list",autoDestroy:true,recordNode:b,store:this.store.getSubStore(b),loadingText:
 this.loadingText,onItemDisclosure:this.onItemDisclosure,displayField:this.displayField,singleSelect:true,clearSelectionOnDeactivate:false,bubbleEvents:["itemtap","containertap","beforeselect","itemdoubletap","selectionchange"],itemTpl:'<span<tpl if="leaf == true"> class="x-list-item-leaf"</tpl>>'+this.getItemTextTpl(b)+"</span>",deferEmptyText:true,allowDeselect:this.allowDeselect,refresh:function(){if(this.hasSkippedEmptyText){this.emptyText=a}Ext.List.prototype.refresh.apply(this,arguments)}}},getSubList:function(b){var a=this.items,c,d=b.internalId;if(a&&a.get){c=a.get(d)}if(c){return c}else{return this.getListConfig(b)}},addNextCard:function(b,e){var c,a=b?b.parentNode:null,d;if(b.leaf){d=this.getDetailCard(b,a);if(d){c=this.add(d)}}else{c=this.getSubList(b);c=this.add(c)}return c},setActivePath:function(o){var n=o.substr(0,1)==="/",h=0,e=this.store,p=e.tree,f,g,c,m,b;if(n){o=o.substr(1)}m=Ext.toArray(o.split("/"));b=m.length;if(n){var l=this.items,a=this.items.items,k=l
 .length;for(;k>1;k--){this.remove(a[k-1],true)}var d=a[0].recordNode;if(d.id!==m[0]){throw new Error("rootNode doesn't match!")}h=1}for(;h<b;h++){if(m[h]!==""){f=p.getNodeById(m[h]);g=this.addNextCard(f);if(g){c=g}}}if(!c){throw new Error("Card was not found when trying to add to NestedList.")}this.setActiveItem(c,false);this.fireEvent("listchange",this,c);this.syncToolbar()},syncToolbar:function(e){var g=e||this.getActiveItem(),h=this.items.indexOf(g),b=g.recordNode,a=b?b.parentNode:null,d=this.backButton,c=this.useTitleAsBackText&&a?this.renderTitleText(a):this.backText,f=(h!==0)?"show":"hide";if(d){d[f]();if(a){d.setText(c)}}if(this.toolbar&&this.updateTitleText){this.toolbar.setTitle(b&&b.getRecord()?this.renderTitleText(b):this.title||"");this.toolbar.doLayout()}},onItemTap:function(l,d,a,i){var k=l.getStore(),f=k.getAt(d),m=f.node,g=m?m.parentNode:null,h=this.displayField,c,b,j;j=this.addNextCard(m);if(m.leaf){this.fireEvent("leafitemtap",l,d,a,i,j)}if(j){b=this.items.
 indexOf(j);this.setActiveItem(j,{type:this.cardSwitchAnimation});this.syncToolbar(j)}},onBackTap:function(){var g=this.getActiveItem(),h=this.items.indexOf(g);if(h!=0){var a=h-1,c=this.items.getAt(a),j=c.recordNode,d=j.getRecord(),e=j?j.parentNode:null,f=this.backButton,b=(a!==0)?"show":"hide",i;this.on("cardswitch",function(k,m){var l=c.getSelectionModel();this.remove(g);if(this.clearSelectionDelay){Ext.defer(l.deselectAll,this.clearSelectionDelay,l)}},this,{single:true});this.setActiveItem(c,{type:this.cardSwitchAnimation,reverse:true,scope:this});this.syncToolbar(c)}}});Ext.reg("nestedlist",Ext.NestedList);Ext.Picker=Ext.extend(Ext.Sheet,{componentCls:"x-picker",stretchX:true,stretchY:true,hideOnMaskTap:false,doneButton:"Done",cancelButton:"Cancel",height:220,useTitles:false,defaultType:"pickerslot",initComponent:function(){this.addEvents("pick","change","cancel");this.layout={type:"hbox",align:"stretch"};if(this.slots){this.items=this.items?(Ext.isArray(this.items)?this.
 items:[this.items]):[];this.items=this.items.concat(this.slots)}if(this.useTitles){this.defaults=Ext.applyIf(this.defaults||{},{title:""})}this.on("slotpick",this.onSlotPick,this);if(this.doneButton||this.cancelButton){var a=[];if(this.cancelButton){a.push(Ext.apply({ui:"decline",handler:this.onCancelButtonTap,scope:this},((Ext.isObject(this.cancelButton)?this.cancelButton:{text:String(this.cancelButton)}))))}a.push({xtype:"spacer"});if(this.doneButton){a.push(Ext.apply({ui:"action",handler:this.onDoneButtonTap,scope:this},((Ext.isObject(this.doneButton)?this.doneButton:{text:String(this.doneButton)}))))}this.toolbar=new Ext.Toolbar(Ext.applyIf(this.buttonBar||{dock:"top",items:a,defaults:{xtype:"button"}}));this.dockedItems=this.dockedItems?(Ext.isArray(this.dockedItems)?this.dockedItems:[this.dockedItems]):[];this.dockedItems.push(this.toolbar)}Ext.Picker.superclass.initComponent.call(this)},afterRender:function(){Ext.Picker.superclass.afterRender.apply(this,arguments);if(
 this.value){this.setValue(this.value,false)}},onDoneButtonTap:function(){var a=this.animSheet("exit");Ext.apply(a,{after:function(){this.fireEvent("change",this,this.getValue())},scope:this});this.hide(a)},onCancelButtonTap:function(){var a=this.animSheet("exit");Ext.apply(a,{after:function(){this.setValue(this.values);this.fireEvent("cancel",this)},scope:this});this.hide(a)},onSlotPick:function(c,b,a){this.fireEvent("pick",this,this.getValue(),c);return false},setValue:function(b,e){var f,a=this.items.items,d=a.length;if(!b){for(var c=0;c<d;c++){a[c].setSelectedNode(0)}return this}Ext.iterate(b,function(g,h){f=this.child("[name="+g+"]");if(f){f.setValue(h,e)}},this);this.values=b;return this},getValue:function(){var b={},a=this.items.items,e=a.length,d,c;for(c=0;c<e;c++){d=a[c];b[d.name]=d.getValue()}return b}});Ext.regModel("x-textvalue",{fields:["text","value"]});Ext.Picker.Slot=Ext.extend(Ext.DataView,{isSlot:true,flex:1,name:null,displayField:"text",valueField:"value",a
 lign:"center",itemSelector:"div.x-picker-item",componentCls:"x-picker-slot",renderTpl:['<div class="x-picker-mask">','<div class="x-picker-bar"></div>',"</div>"],selectedIndex:0,getElConfig:function(){return{tag:"div",id:this.id,cls:"x-picker-"+this.align}},initComponent:function(){if(!this.name){throw new Error("Each picker slot is required to have a name.")}Ext.apply(this.renderSelectors,{mask:".x-picker-mask",bar:".x-picker-bar"});this.scroll={direction:"vertical",useIndicators:false,friction:0.7,acceleration:25,snapDuration:200,animationDuration:200};this.tpl=new Ext.XTemplate(['<tpl for=".">','<div class="x-picker-item {cls} <tpl if="extra">x-picker-invalid</tpl>">{'+this.displayField+"}</div>","</tpl>"]);var d=this.data,f=[],c=d&&d.length,a,b,e;if(d&&Ext.isArray(d)&&c){for(a=0;a<c;a++){b=d[a];e={};if(Ext.isArray(b)){e[this.valueField]=b[0];e[this.displayField]=b[1]}else{if(Ext.isString(b)){e[this.valueField]=b;e[this.displayField]=b}else{if(Ext.isObject(b)){e=b}}}f.pus
 h(e)}this.store=new Ext.data.Store({model:"x-textvalue",data:f});this.tempStore=true}else{if(this.store){this.store=Ext.StoreMgr.lookup(this.store)}}this.enableBubble("slotpick");if(this.title){this.title=new Ext.Component({dock:"top",componentCls:"x-picker-slot-title",html:this.title});this.dockedItems=this.title}Ext.Picker.Slot.superclass.initComponent.call(this);if(this.value!==undefined){this.setValue(this.value,false)}},setupBar:function(){this.el.setStyle({padding:""});var a=this.bar.getY()-this.el.getY();this.barHeight=this.bar.getHeight();this.el.setStyle({padding:a+"px 0"});this.slotPadding=a;this.scroller.updateBoundary();this.scroller.setSnap(this.barHeight);this.setSelectedNode(this.selectedIndex,false)},afterComponentLayout:function(){Ext.defer(this.setupBar,200,this)},initEvents:function(){this.mon(this.scroller,{scrollend:this.onScrollEnd,scope:this})},onScrollEnd:function(a,b){this.selectedNode=this.getNode(Math.round(b.y/this.barHeight));this.selectedIndex=t
 his.indexOf(this.selectedNode);this.fireEvent("slotpick",this,this.getValue(),this.selectedNode)},scrollToNode:function(c,a){var b=Ext.fly(c).getOffsetsTo(this.scrollEl)[1];this.scroller.scrollTo({y:b},a!==false?true:false)},onItemTap:function(a){Ext.Picker.Slot.superclass.onItemTap.apply(this,arguments);this.setSelectedNode(a)},getSelectedNode:function(){return this.selectedNode},setSelectedNode:function(b,a){if(Ext.isNumber(b)){b=this.getNode(b)}else{if(b.isModel){b=this.getNode(this.store.indexOf(b))}}if(b){this.selectedNode=b;this.selectedIndex=this.indexOf(b);this.scrollToNode(b,a)}},getValue:function(){var a=this.store.getAt(this.selectedIndex);return a?a.get(this.valueField):null},setValue:function(c,a){var b=this.store.find(this.valueField,c);if(b!=-1){if(!this.rendered){this.selectedIndex=b;return}this.setSelectedNode(b,a)}},onDestroy:function(){if(this.tempStore){this.store.destroyStore();this.store=null}Ext.Picker.Slot.superclass.onDestroy.call(this)}});Ext.reg("p
 ickerslot",Ext.Picker.Slot);Ext.DatePicker=Ext.extend(Ext.Picker,{yearFrom:1980,yearTo:new Date().getFullYear(),monthText:"Month",dayText:"Day",yearText:"Year",slotOrder:["month","day","year"],initComponent:function(){var j=this.yearFrom,e=this.yearTo,f=[],h=[],b=[],g,c,d,a;if(j>e){c=j;j=e;e=c}for(d=j;d<=e;d++){f.push({text:d,value:d})}a=this.getDaysInMonth(1,new Date().getFullYear());for(d=0;d<a;d++){h.push({text:d+1,value:d+1})}for(d=0,g=Date.monthNames.length;d<g;d++){b.push({text:Date.monthNames[d],value:d+1})}this.slots=[];this.slotOrder.forEach(function(i){this.slots.push(this.createSlot(i,h,b,f))},this);Ext.DatePicker.superclass.initComponent.call(this)},afterRender:function(){Ext.DatePicker.superclass.afterRender.apply(this,arguments);this.setValue(this.value)},createSlot:function(b,d,a,c){switch(b){case"year":return{name:"year",align:"center",data:c,title:this.useTitles?this.yearText:false,flex:3};case"month":return{name:b,align:"right",data:a,title:this.useTitles?t
 his.monthText:false,flex:4};case"day":return{name:"day",align:"center",data:d,title:this.useTitles?this.dayText:false,flex:2}}},onSlotPick:function(f,e){var c=f.name,b,a,d;if(c==="month"||c==="year"){d=this.child("[name=day]");b=this.getValue();a=this.getDaysInMonth(b.getMonth()+1,b.getFullYear());d.store.clearFilter();d.store.filter({fn:function(g){return g.get("extra")===true||g.get("value")<=a}});d.scroller.updateBoundary(true)}Ext.DatePicker.superclass.onSlotPick.apply(this,arguments)},getValue:function(){var c=Ext.DatePicker.superclass.getValue.call(this),b=this.getDaysInMonth(c.month,c.year),a=Math.min(c.day,b);return new Date(c.year,c.month-1,a)},setValue:function(b,a){if(!Ext.isDate(b)&&!Ext.isObject(b)){b=null}if(Ext.isDate(b)){this.value={day:b.getDate(),year:b.getFullYear(),month:b.getMonth()+1}}else{this.value=b}return Ext.DatePicker.superclass.setValue.call(this,this.value,a)},getDaysInMonth:function(c,b){var a=[31,28,31,30,31,30,31,31,30,31,30,31];return c==2&&
 this.isLeapYear(b)?29:a[c-1]},isLeapYear:function(a){return !!((a&3)===0&&(a%100||(a%400===0&&a)))}});Ext.reg("datepicker",Ext.DatePicker);Ext.Media=Ext.extend(Ext.Component,{url:"",enableControls:true,autoResume:false,autoPause:true,preload:true,playing:false,afterRender:function(){var a=this.getConfiguration();Ext.apply(a,{src:this.url,preload:this.preload?"auto":"none"});if(this.enableControls){a.controls="controls"}if(this.loop){a.loop="loop"}this.media=this.el.createChild(a);Ext.Media.superclass.afterRender.call(this);this.on({scope:this,activate:this.onActivate,beforedeactivate:this.onDeactivate})},onActivate:function(){if(this.autoResume&&!this.playing){this.play()}},onDeactivate:function(){if(this.autoPause&&this.playing){this.pause()}},play:function(){this.media.dom.play();this.playing=true},pause:function(){this.media.dom.pause();this.playing=false},toggle:function(){if(this.playing){this.pause()}else{this.play()}}});Ext.reg("media",Ext.Media);Ext.Video=Ext.extend(
 Ext.Media,{posterUrl:"",componentCls:"x-video",afterRender:function(){Ext.Video.superclass.afterRender.call(this);if(this.posterUrl){this.media.hide();this.ghost=this.el.createChild({cls:"x-video-ghost",style:"width: 100%; height: 100%; background: #000 url("+this.posterUrl+") center center no-repeat; -webkit-background-size: 100% auto;"});this.ghost.on("tap",this.onGhostTap,this,{single:true})}},onGhostTap:function(){this.media.show();this.ghost.hide();this.play()},getConfiguration:function(){return{tag:"video",width:"100%",height:"100%"}}});Ext.reg("video",Ext.Video);Ext.Audio=Ext.extend(Ext.Media,{componentCls:"x-audio",onActivate:function(){Ext.Audio.superclass.onActivate.call(this);if(Ext.is.Phone){this.media.show()}},onDeactivate:function(){Ext.Audio.superclass.onDeactivate.call(this);if(Ext.is.Phone){this.media.hide()}},getConfiguration:function(){var a=!this.enableControls;if(!Ext.supports.AudioTag){return{tag:"embed",type:"audio/mpeg",target:"myself",controls:"true"
 ,hidden:a}}else{return{tag:"audio",hidden:a}}}});Ext.reg("audio",Ext.Audio);Ext.MessageBox=Ext.extend(Ext.Sheet,{centered:true,renderHidden:true,ui:"dark",componentCls:"x-msgbox",enterAnimation:"pop",exitAnimation:"pop",defaultTextHeight:75,constructor:function(a){a=a||{};var c=a.ui||this.ui||"",b=a.componentCls||this.componentCls;delete a.html;this.titleBar=Ext.create({xtype:"toolbar",ui:c,dock:"top",cls:b+"-title",title:"&#160;"});this.buttonBar=Ext.create({xtype:"toolbar",ui:c,dock:"bottom",layout:{pack:"center"},cls:b+"-buttons"});a=Ext.apply({ui:c,dockedItems:[this.titleBar,this.buttonBar],renderSelectors:{body:"."+b+"-body",iconEl:"."+b+"-icon",msgContentEl:"."+b+"-content",msgEl:"."+b+"-text",inputsEl:"."+b+"-inputs",inputEl:"."+b+"-input-single",multiLineEl:"."+b+"-input-textarea"}},a||{});Ext.MessageBox.superclass.constructor.call(this,a)},renderTpl:['<div class="{componentCls}-body"<tpl if="bodyStyle"> style="{bodyStyle}"</tpl>>','<div class="{componentCls}-icon x-
 hidden-display"></div>','<div class="{componentCls}-content">','<div class="{componentCls}-text"></div>','<div class="{componentCls}-inputs x-hidden-display">','<input type="text" class="{componentCls}-input {componentCls}-input-single" />','<textarea class="{componentCls}-input {componentCls}-input-textarea"></textarea>',"</div>","</div>","</div>"],onClick:function(b){if(b){var a=b.config||{};if(typeof a.fn=="function"){a.fn.call(a.scope||null,b.itemId||b.text,a.input?a.input.dom.value:null,a)}if(a.cls){this.el.removeCls(a.cls)}if(a.input){a.input.dom.blur()}}this.hide()},show:function(c){var e,d,g={autocomplete:"off",autocapitalize:"off",autocorrect:"off",maxlength:0,autofocus:true,placeholder:"",type:"text"},a=/true|on/i;this.rendered||this.render(document.body);c=Ext.applyIf(c||{},{multiLine:false,prompt:false,value:"",modal:true});if(c.title){this.titleBar.setTitle(c.title);this.titleBar.show()}else{this.titleBar.hide()}if(this.inputsEl&&(c.multiLine||c.prompt)){this.in
 putsEl.show();if(this.multiLineEl&&c.multiLine){this.inputEl&&this.inputEl.hide();this.multiLineEl.show().setHeight(Ext.isNumber(c.multiLine)?parseFloat(c.multiLine):this.defaultTextHeight);c.input=this.multiLineEl}else{if(this.inputEl){this.inputEl.show();this.multiLineEl&&this.multiLineEl.hide();c.input=this.inputEl}}if(Ext.isObject(c.prompt)){Ext.apply(g,c.prompt)}for(d in g){if(g.hasOwnProperty(d)){e=g[d];c.input.dom.setAttribute(d.toLowerCase(),/^auto/i.test(d)?(a.test(e+"")?"on":"off"):e)}}}else{this.inputsEl&&this.inputsEl.hide()}this.setIcon(c.icon||"",false);this.updateText(c.msg,false);if(c.cls){this.el.addCls(c.cls)}this.modal=!!c.modal;var f=this.buttonBar,b=[];f.removeAll();Ext.each([].concat(c.buttons||Ext.MessageBox.OK),function(h){if(h){b.push(Ext.applyIf({config:c,scope:this,handler:this.onClick},h))}},this);f.add(b);if(f.rendered){f.doLayout()}Ext.MessageBox.superclass.show.call(this,c.animate);if(c.input){c.input.dom.value=c.value||"";if(a.test(g.autofocus
 +"")&&!("autofocus" in c.input.dom)){c.input.dom.focus()}}return this},onOrientationChange:function(){this.doComponentLayout();Ext.MessageBox.superclass.onOrientationChange.apply(this,arguments)},adjustScale:function(){Ext.apply(this,{maxWidth:window.innerWidth,maxHeight:window.innerHeight,minWidth:window.innerWidth*0.5,minHeight:window.innerHeight*0.5})},doComponentLayout:function(){this.adjustScale();return Ext.MessageBox.superclass.doComponentLayout.apply(this,arguments)},alert:function(d,c,b,a){return this.show({title:d,msg:c,buttons:Ext.MessageBox.OK,fn:b,scope:a,icon:Ext.MessageBox.INFO})},confirm:function(d,c,b,a){return this.show({title:d,msg:c,buttons:Ext.MessageBox.YESNO,fn:function(e){b.call(a,e)},scope:a,icon:Ext.MessageBox.QUESTION})},prompt:function(g,f,c,b,e,d,a){return this.show({title:g,msg:f,buttons:Ext.MessageBox.OKCANCEL,fn:function(i,h){c.call(b,i,h)},scope:b,icon:Ext.MessageBox.QUESTION,prompt:a||true,multiLine:e,value:d})},updateText:function(b,a){if(t
 his.msgEl){this.msgEl.update(b?String(b):"&#160;");if(a!==false){this.doComponentLayout()}}return this},setIcon:function(a,b){if(a){this.iconEl.show();this.iconEl.replaceCls(this.iconCls,a)}else{this.iconEl.replaceCls(this.iconCls,"x-hidden-display")}if(b!==false){this.doComponentLayout()}this.iconCls=a;return this}});(function(){var a=Ext.MessageBox;Ext.apply(a,{OK:{text:"OK",itemId:"ok",ui:"action"},CANCEL:{text:"Cancel",itemId:"cancel"},YES:{text:"Yes",itemId:"yes",ui:"action"},NO:{text:"No",itemId:"no"},INFO:"x-msgbox-info",WARNING:"x-msgbox-warning",QUESTION:"x-msgbox-question",ERROR:"x-msgbox-error"});Ext.apply(a,{OKCANCEL:[a.CANCEL,a.OK],YESNOCANCEL:[a.CANCEL,a.NO,a.YES],YESNO:[a.NO,a.YES]})})();Ext.reg("messagebox",Ext.MessageBox);Ext.reg("msgbox",Ext.MessageBox);Ext.Msg=new Ext.MessageBox();Ext.form.FormPanel=Ext.extend(Ext.Panel,{standardSubmit:false,componentCls:"x-form",url:undefined,baseParams:undefined,waitTpl:new Ext.XTemplate('<div class="{cls}">{message}&hel
 lip;</div>'),submitOnAction:true,getElConfig:function(){return Ext.apply(Ext.form.FormPanel.superclass.getElConfig.call(this),{tag:"form"})},initComponent:function(){this.addEvents("submit","beforesubmit","exception");Ext.form.FormPanel.superclass.initComponent.call(this);this.on("action",this.onFieldAction,this)},afterRender:function(){Ext.form.FormPanel.superclass.afterRender.call(this);this.el.on("submit",this.onSubmit,this)},onSubmit:function(b,a){if(!this.standardSubmit||this.fireEvent("beforesubmit",this,this.getValues(true))===false){if(b){b.stopEvent()}}},onFieldAction:function(a){if(this.submitOnAction){a.blur();this.submit()}},submit:function(a){var b=this.el.dom||{},c;a=Ext.apply({url:this.url||b.action,submitDisabled:false,method:b.method||"post",autoAbort:false,params:null,waitMsg:null,headers:null,success:null,failure:null},a||{});c=this.getValues(this.standardSubmit||!a.submitDisabled);if(this.standardSubmit){if(b){if(a.url&&Ext.isEmpty(b.action)){b.action=a.u
 rl}b.method=(a.method||b.method).toLowerCase();if(this.fireEvent("beforesubmit",this,c,a)!==false){b.submit()}}return null}if(this.fireEvent("beforesubmit",this,c,a)!==false){if(a.waitMsg){this.showMask(a.waitMsg)}return Ext.Ajax.request({url:a.url,method:a.method,rawData:Ext.urlEncode(Ext.apply(Ext.apply({},this.baseParams||{}),a.params||{},c)),autoAbort:a.autoAbort,headers:Ext.apply({"Content-Type":"application/x-www-form-urlencoded; charset=UTF-8"},a.headers||{}),scope:this,callback:function(d,g,e){var f=e.responseText;this.hideMask();if(g){e=Ext.decode(f);g=!!e.success;if(g){if(Ext.isFunction(a.success)){a.success.call(a.scope||this,this,e,f)}this.fireEvent("submit",this,e);return}}if(Ext.isFunction(a.failure)){a.failure.call(a.scope||this,this,e,f)}this.fireEvent("exception",this,e)}})}},loadRecord:function(a){if(a&&a.data){this.setValues(a.data);this.record=a}return this},loadModel:function(){return this.loadRecord.apply(this,arguments)},getRecord:function(){return thi
 s.record},updateRecord:function(b,e){var a,c,d;if(b&&(a=b.fields)){c=this.getValues(e);for(d in c){if(c.hasOwnProperty(d)&&a.containsKey(d)){b.set(d,c[d])}}}return this},setValues:function(b){var a=this.getFields(),c,e,d;b=b||{};for(c in b){if(b.hasOwnProperty(c)){e=a[c];d=b[c];if(e){if(Ext.isArray(e)){e.forEach(function(f){if(Ext.isArray(b[c])){f.setChecked((d.indexOf(f.getValue())!=-1))}else{f.setChecked((d==f.getValue()))}})}else{if(e.setChecked){e.setChecked(d)}else{e.setValue(d)}}}}}return this},getValues:function(d){var a=this.getFields(),e,b={},c;for(c in a){if(a.hasOwnProperty(c)){if(Ext.isArray(a[c])){b[c]=[];a[c].forEach(function(f){if(f.isChecked()&&!(d&&f.disabled)){if(f instanceof Ext.form.Radio){b[c]=f.getValue()}else{b[c].push(f.getValue())}}})}else{e=a[c];if(!(d&&e.disabled)){if(e instanceof Ext.form.Checkbox){b[c]=(e.isChecked())?e.getValue():null}else{b[c]=e.getValue()}}}}}return b},reset:function(){this.getFieldsAsArray().forEach(function(a){a.reset()});re
 turn this},enable:function(){this.getFieldsAsArray().forEach(function(a){a.enable()});return this},disable:function(){this.getFieldsAsArray().forEach(function(a){a.disable()});return this},getFieldsAsArray:function(){var a=[];var b=function(c){if(c.isField){a.push(c)}if(c.isContainer){c.items.each(b)}};this.items.each(b);return a},getFields:function(b){var a={},d;var c=function(e){if(e.isField){d=e.getName();if((b&&d==b)||typeof b=="undefined"){if(a.hasOwnProperty(d)){if(!Ext.isArray(a[d])){a[d]=[a[d]]}a[d].push(e)}else{a[d]=e}}}if(e.isContainer){e.items.each(c)}};this.items.each(c);return(b)?(a[b]||[]):a},getFieldsFromItem:function(){},showMask:function(a,b){a=Ext.isString(a)?{message:a}:a;if(a&&this.waitTpl){this.maskTarget=b=Ext.get(b||a.target)||this.el;b&&b.mask(this.waitTpl.apply(a))}return this},hideMask:function(){if(this.maskTarget){this.maskTarget.unmask();delete this.maskTarget}return this}});Ext.form.FormPanel.prototype.load=Ext.form.FormPanel.prototype.loadModel
 ;Ext.reg("formpanel",Ext.form.FormPanel);Ext.reg("form",Ext.form.FormPanel);Ext.form.FieldSet=Ext.extend(Ext.Panel,{componentCls:"x-form-fieldset",initComponent:function(){this.componentLayout=this.getLayout();Ext.form.FieldSet.superclass.initComponent.call(this)},afterLayout:function(a){Ext.form.FieldSet.superclass.afterLayout.call(this,a);if(this.title&&!this.titleEl){this.setTitle(this.title)}else{if(this.titleEl){this.el.insertFirst(this.titleEl)}}if(this.instructions&&!this.instructionsEl){this.setInstructions(this.instructions)}else{if(this.instructionsEl){this.el.appendChild(this.instructionsEl)}}},setTitle:function(a){if(this.rendered){if(!this.titleEl){this.titleEl=this.el.insertFirst({cls:this.componentCls+"-title"})}this.titleEl.setHTML(a)}else{this.title=a}return this},setInstructions:function(a){if(this.rendered){if(!this.instructionsEl){this.instructionsEl=this.el.createChild({cls:this.componentCls+"-instructions"})}this.instructionsEl.setHTML(a)}else{this.inst
 ructions=a}return this}});Ext.reg("fieldset",Ext.form.FieldSet);Ext.form.Field=Ext.extend(Ext.Component,{isField:true,fieldCls:"x-form-field",baseCls:"x-field",inputCls:undefined,disabled:false,renderTpl:['<tpl if="label">','<div class="x-form-label"><span>{label}</span></div>',"</tpl>",'<tpl if="fieldEl">','<div class="x-form-field-container"><input id="{inputId}" type="{inputType}" name="{name}" class="{fieldCls}"','<tpl if="tabIndex">tabIndex="{tabIndex}" </tpl>','<tpl if="placeHolder">placeholder="{placeHolder}" </tpl>','<tpl if="style">style="{style}" </tpl>','<tpl if="maxlength">maxlength="{maxlength}" </tpl>','<tpl if="autoComplete">autocomplete="{autoComplete}" </tpl>','<tpl if="autoCapitalize">autocapitalize="{autoCapitalize}" </tpl>','<tpl if="autoCorrect">autocorrect="{autoCorrect}" </tpl> />','<tpl if="useMask"><div class="x-field-mask"></div></tpl>',"</div>",'<tpl if="useClearIcon"><div class="x-field-clear-container"><div class="x-field-clear x-hidden-visibilit
 y">&#215;</div></div></tpl>',"</tpl>"],isFormField:true,autoCreateField:true,inputType:"text",label:null,labelWidth:"30%",labelAlign:"left",required:false,useMask:false,initComponent:function(){Ext.form.Field.superclass.initComponent.call(this)},getName:function(){return this.name||this.id||""},applyRenderSelectors:function(){this.renderSelectors=Ext.applyIf(this.renderSelectors||{},{mask:".x-field-mask",labelEl:".x-form-label",fieldEl:"."+Ext.util.Format.trim(this.renderData.fieldCls).replace(/ /g,".")});Ext.form.Field.superclass.applyRenderSelectors.call(this)},initRenderData:function(){Ext.form.Field.superclass.initRenderData.apply(this,arguments);Ext.applyIf(this.renderData,{disabled:this.disabled,fieldCls:"x-input-"+this.inputType+(this.inputCls?" "+this.inputCls:""),fieldEl:!this.fieldEl&&this.autoCreateField,inputId:Ext.id(),label:this.label,labelAlign:"x-label-align-"+this.labelAlign,name:this.getName(),required:this.required,style:this.style,tabIndex:this.tabIndex,i
 nputType:this.inputType,useMask:this.useMask});return this.renderData},initEvents:function(){Ext.form.Field.superclass.initEvents.apply(this,arguments);if(this.fieldEl){if(this.useMask&&this.mask){this.mon(this.mask,{tap:this.onMaskTap,scope:this})}}},onRender:function(){Ext.form.Field.superclass.onRender.apply(this,arguments);var a=[];if(this.required){a.push("x-field-required")}if(this.label){a.push("x-label-align-"+this.labelAlign)}this.el.addCls(a)},afterRender:function(){Ext.form.Field.superclass.afterRender.apply(this,arguments);if(this.label){this.setLabelWidth(this.labelWidth)}this.initValue()},isDisabled:function(){return this.disabled},onEnable:function(){this.fieldEl.dom.disabled=false},onDisable:function(){this.fieldEl.dom.disabled=true},initValue:function(){this.setValue(this.value||"",true);this.originalValue=this.getValue()},isDirty:function(){if(this.disabled||!this.rendered){return false}return String(this.getValue())!==String(this.originalValue)},onMaskTap:
 function(a){if(this.disabled){return false}if(Ext.is.iOS&&a.browserEvent&&!a.browserEvent.isSimulated&&!a.browserEvent.isSimulated){console.log("onMaskTap prevented");a.preventDefault();a.stopPropagation();return false}return true},showMask:function(a){if(this.mask){this.mask.setStyle("display","block")}},hideMask:function(a){if(this.mask){this.mask.setStyle("display","none")}},reset:function(){this.setValue(this.originalValue)},getValue:function(){if(!this.rendered||!this.fieldEl){return this.value}return this.fieldEl.getValue()},setValue:function(a){this.value=a;if(this.rendered&&this.fieldEl){this.fieldEl.dom.value=(Ext.isEmpty(a)?"":a)}return this},setLabelWidth:function(a){if(this.labelEl){this.labelEl.setWidth(a)}return this}});Ext.reg("field",Ext.form.Field);Ext.form.Slider=Ext.extend(Ext.form.Field,{ui:"slider",inputCls:"x-slider",inputType:"slider",minValue:0,maxValue:100,animationDuration:200,value:0,trackWidth:null,monitorOrientation:true,renderTpl:['<tpl if="labe
 l">','<div class="x-form-label"><span>{label}</span></div>',"</tpl>",'<tpl if="fieldEl">','<div id="{inputId}" name="{name}" class="{fieldCls}"','<tpl if="tabIndex">tabIndex="{tabIndex}"</tpl>','<tpl if="style">style="{style}" </tpl>',"/></tpl>"],increment:1,constructor:function(a){this.addEvents("beforechange","change","drag","dragend");Ext.form.Slider.superclass.constructor.call(this,a)},initComponent:function(){this.tabIndex=-1;if(this.increment==0){this.increment=1}this.increment=Math.abs(this.increment);this.values=[this.value];Ext.form.Slider.superclass.initComponent.apply(this,arguments);if(this.thumbs==undefined){var a=[],b=this.values,d=b.length,c,e=this.getThumbClass();for(c=0;c<d;c++){a[a.length]=new e({value:b[c],slider:this,listeners:{scope:this,drag:this.onDrag,dragend:this.onThumbDragEnd}})}this.thumbs=a}},initValue:function(){var a=this.getThumb();if(a.dragObj){a.dragObj.updateBoundary()}Ext.form.Slider.superclass.initValue.apply(this,arguments)},onOrientatio
 nChange:function(){Ext.form.Slider.superclass.onOrientationChange.apply(this,arguments);var a=this.getThumb();if(a.dragObj){a.dragObj.updateBoundary();this.moveThumb(a,this.getPixelValue(a.getValue(),a),0)}},getThumbClass:function(){return Ext.form.Slider.Thumb},setValue:function(e,d,c){if(typeof c=="undefined"){c=true}c=!!c;var a=this.getThumb(),b=a.getValue(),f=this.constrain(e);if(this.fireEvent("beforechange",this,a,f,b)!==false){if(c){this.moveThumb(a,this.getPixelValue(f,a),d)}a.setValue(f);this.doComponentLayout();this.fireEvent("change",this,a,f,b)}return this},constrain:function(b){var a=b%this.increment;b-=a;if(Math.abs(a)>=(this.increment/2)){b+=(a>0)?this.increment:-this.increment}b=Math.max(this.minValue,b);b=Math.min(this.maxValue,b);return b},getValue:function(){return this.getThumb().getValue()},getThumb:function(){return this.thumbs[0]},getSliderValue:function(b,d){var a=d.dragObj.offsetBoundary.right,c=this.maxValue-this.minValue,e;this.trackWidth=(a>0)?a:t
 his.trackWidth;e=c/this.trackWidth;return this.minValue+(e*(b))},getPixelValue:function(e,c){var a=c.dragObj.offsetBoundary.right,b=this.maxValue-this.minValue,d;this.trackWidth=(a>0)?a:this.trackWidth;d=this.trackWidth/b;return(d*(e-this.minValue))},renderThumbs:function(){var a=this.thumbs,c=a.length,b;for(b=0;b<c;b++){a[b].render(this.fieldEl)}},onThumbDragEnd:function(a){var b=this.getThumbValue(a);this.setValue(b);this.fireEvent("dragend",this,a.thumb,this.constrain(b))},getThumbValue:function(a){var b=a.thumb;return this.getSliderValue(-a.getOffset().x,b)},onDrag:function(a){var b=this.getThumbValue(a);this.fireEvent("drag",this,a.thumb,this.constrain(b))},onTap:function(f){if(!this.disabled){var c=this.fieldEl.getPageBox(),d=f.pageX-c.left,b=this.getNearest(d),a=b.dragObj.size.width/2;this.setValue(this.getSliderValue(d-a,b),this.animationDuration,true)}},moveThumb:function(a,b,c){a.dragObj.setOffset(new Ext.util.Offset(b,0),c)},afterRender:function(a){var b=this;b.re
 nderThumbs();Ext.form.Slider.superclass.afterRender.apply(b,arguments);b.fieldEl.on({scope:b,tap:b.onTap})},getNearest:function(a){return this.thumbs[0]},setThumbsDisabled:function(b){var a=this.thumbs,d=a.length,c=0;for(;c<d;c++){a[c].dragObj[b?"disable":"enable"]()}},disable:function(){Ext.form.Slider.superclass.disable.call(this);this.setThumbsDisabled(true)},enable:function(){Ext.form.Slider.superclass.enable.call(this);this.setThumbsDisabled(false)}});Ext.reg("sliderfield",Ext.form.Slider);Ext.form.Slider.Thumb=Ext.extend(Ext.form.Field,{isField:false,baseCls:"x-thumb",autoCreateField:false,draggable:true,value:0,onRender:function(){this.draggable={direction:"horizontal",constrain:this.slider.fieldEl,revert:false,thumb:this};Ext.form.Slider.Thumb.superclass.onRender.apply(this,arguments)},setValue:function(a){this.value=a;return this},getValue:function(){return this.value}});Ext.reg("sliderthumb",Ext.form.Slider.Thumb);Ext.form.Toggle=Ext.extend(Ext.form.Slider,{minValu
 e:0,maxValue:1,ui:"toggle",inputType:"toggle",minValueCls:"x-toggle-off",maxValueCls:"x-toggle-on",animationDuration:70,toggle:function(){var a=this.thumbs[0],b=a.getValue();this.setValue(b==this.minValue?this.maxValue:this.minValue,this.animationDuration)},setValue:function(a){Ext.form.Toggle.superclass.setValue.call(this,a,this.animationDuration);var b=this.fieldEl;if(this.constrain(a)===this.minValue){b.addCls(this.minValueCls);b.removeCls(this.maxValueCls)}else{b.addCls(this.maxValueCls);b.removeCls(this.minValueCls)}},onTap:function(){if(!this.disabled){this.toggle()}},getThumbClass:function(){return Ext.form.Toggle.Thumb}});Ext.reg("togglefield",Ext.form.Toggle);Ext.form.Toggle.Thumb=Ext.extend(Ext.form.Slider.Thumb,{onRender:function(){Ext.form.Toggle.Thumb.superclass.onRender.apply(this,arguments);Ext.DomHelper.append(this.el,[{cls:"x-toggle-thumb-off",html:"<span>OFF</span>"},{cls:"x-toggle-thumb-on",html:"<span>ON</span>"},{cls:"x-toggle-thumb-thumb"}])}});Ext.form
 .Text=Ext.extend(Ext.form.Field,{ui:"text",focusCls:"x-field-focus",maxLength:0,placeHolder:undefined,autoComplete:undefined,autoCapitalize:undefined,autoCorrect:undefined,isFocused:false,isClearIconVisible:false,useMask:Ext.is.iOS,initComponent:function(){this.addEvents("focus","blur","keyup","change","action");this.enableBubble("action");Ext.form.Text.superclass.initComponent.apply(this,arguments)},applyRenderSelectors:function(){this.renderSelectors=Ext.applyIf(this.renderSelectors||{},{clearIconEl:".x-field-clear",clearIconContainerEl:".x-field-clear-container"});Ext.form.Text.superclass.applyRenderSelectors.call(this)},initRenderData:function(){var e=Ext.form.Text.superclass.initRenderData.call(this),d=this.autoComplete,c=this.autoCapitalize,b=this.autoCorrect;Ext.applyIf(e,{placeHolder:this.placeHolder,maxlength:this.maxLength,useClearIcon:this.useClearIcon});var a=[true,"on"];if(d!==undefined){e.autoComplete=(a.indexOf(d)!==-1)?"on":"off"}if(c!==undefined){e.autoCapit
 alize=(a.indexOf(c)!==-1)?"on":"off"}if(b!==undefined){e.autoCorrect=(a.indexOf(b)!==-1)?"on":"off"}this.renderData=e;return e},initEvents:function(){Ext.form.Text.superclass.initEvents.call(this);if(this.fieldEl){this.mon(this.fieldEl,{focus:this.onFocus,blur:this.onBlur,keyup:this.onKeyUp,paste:this.updateClearIconVisibility,mousedown:this.onBeforeFocus,scope:this});if(this.clearIconEl){this.mon(this.clearIconContainerEl,{scope:this,tap:this.onClearIconTap})}}},onEnable:function(){Ext.form.Text.superclass.onEnable.apply(this,arguments);this.disabled=false;this.updateClearIconVisibility()},onDisable:function(){Ext.form.Text.superclass.onDisable.apply(this,arguments);this.blur();this.hideClearIcon()},onClearIconTap:function(){if(!this.disabled){this.setValue("")}},updateClearIconVisibility:function(){var a=this.getValue();if(!a){a=""}if(a.length<1){this.hideClearIcon()}else{this.showClearIcon()}return this},showClearIcon:function(){if(!this.disabled&&this.fieldEl&&this.clear
 IconEl&&!this.isClearIconVisible){this.isClearIconVisible=true;this.fieldEl.addCls("x-field-clearable");this.clearIconEl.removeCls("x-hidden-visibility")}return this},hideClearIcon:function(){if(this.fieldEl&&this.clearIconEl&&this.isClearIconVisible){this.isClearIconVisible=false;this.fieldEl.removeCls("x-field-clearable");this.clearIconEl.addCls("x-hidden-visibility")}return this},afterRender:function(){Ext.form.Text.superclass.afterRender.call(this);this.updateClearIconVisibility()},onBeforeFocus:function(a){this.fireEvent("beforefocus",a)},beforeFocus:Ext.emptyFn,onMaskTap:function(a){if(Ext.form.Text.superclass.onMaskTap.apply(this,arguments)!==true){return false}this.maskCorrectionTimer=Ext.defer(this.showMask,1000,this);this.hideMask()},onFocus:function(a){if(this.mask){if(this.maskCorrectionTimer){clearTimeout(this.maskCorrectionTimer)}this.hideMask()}this.beforeFocus();if(this.focusCls){this.el.addCls(this.focusCls)}if(!this.isFocused){this.isFocused=true;this.start
 Value=this.getValue();this.fireEvent("focus",this,a)}Ext.currentlyFocusedField=this},beforeBlur:Ext.emptyFn,onBlur:function(b){this.beforeBlur();if(this.focusCls){this.el.removeCls(this.focusCls)}this.isFocused=false;var a=this.getValue();if(String(a)!=String(this.startValue)){this.fireEvent("change",this,a,this.startValue)}this.fireEvent("blur",this,b);this.updateClearIconVisibility();this.showMask();this.afterBlur();Ext.currentlyFocusedField=null},afterBlur:Ext.emptyFn,focus:function(){if(this.rendered&&this.fieldEl&&this.fieldEl.dom.focus){this.fieldEl.dom.focus()}return this},blur:function(){if(this.rendered&&this.fieldEl&&this.fieldEl.dom.blur){this.fieldEl.dom.blur()}return this},setValue:function(){Ext.form.Text.superclass.setValue.apply(this,arguments);this.updateClearIconVisibility()},onKeyUp:function(a){this.updateClearIconVisibility();this.fireEvent("keyup",this,a);if(a.browserEvent.keyCode===13){this.blur();this.fireEvent("action",this,a)}}});Ext.reg("textfield",
 Ext.form.Text);Ext.form.TextField=Ext.extend(Ext.form.Text,{constructor:function(){console.warn("Ext.form.TextField has been deprecated and will be removed in Sencha Touch 1.0. Please use Ext.form.Text instead");Ext.form.TextField.superclass.constructor.apply(this,arguments)}});Ext.form.Password=Ext.extend(Ext.form.Text,{inputType:"password",autoCapitalize:false});Ext.reg("passwordfield",Ext.form.Password);Ext.form.Email=Ext.extend(Ext.form.Text,{inputType:"email",autoCapitalize:false});Ext.reg("emailfield",Ext.form.Email);Ext.form.Url=Ext.extend(Ext.form.Text,{inputType:"url",autoCapitalize:false});Ext.reg("urlfield",Ext.form.Url);Ext.form.Search=Ext.extend(Ext.form.Text,{inputType:"search"});Ext.reg("searchfield",Ext.form.Search);Ext.form.Number=Ext.extend(Ext.form.Text,{ui:"number",inputType:"number",minValue:undefined,maxValue:undefined,stepValue:undefined,renderTpl:['<tpl if="label"><div class="x-form-label"><span>{label}</span></div></tpl>','<tpl if="fieldEl"><div clas
 s="x-form-field-container">','<input id="{inputId}" type="{inputType}" name="{name}" class="{fieldCls}"','<tpl if="tabIndex">tabIndex="{tabIndex}" </tpl>','<tpl if="placeHolder">placeholder="{placeHolder}" </tpl>','<tpl if="style">style="{style}" </tpl>','<tpl if="minValue != undefined">min="{minValue}" </tpl>','<tpl if="maxValue != undefined">max="{maxValue}" </tpl>','<tpl if="stepValue != undefined">step="{stepValue}" </tpl>','<tpl if="autoComplete">autocomplete="{autoComplete}" </tpl>','<tpl if="autoCapitalize">autocapitalize="{autoCapitalize}" </tpl>','<tpl if="autoFocus">autofocus="{autoFocus}" </tpl>',"/>",'<tpl if="useMask"><div class="x-field-mask"></div></tpl>',"</div></tpl>",'<tpl if="useClearIcon"><div class="x-field-clear-container"><div class="x-field-clear x-hidden-visibility">&#215;</div><div></tpl>'],onRender:function(){Ext.apply(this.renderData,{maxValue:this.maxValue,minValue:this.minValue,stepValue:this.stepValue});Ext.form.Number.superclass.onRender.apply
 (this,arguments)}});Ext.reg("numberfield",Ext.form.Number);Ext.form.Spinner=Ext.extend(Ext.form.Number,{componentCls:"x-spinner",minValue:Number.NEGATIVE_INFINITY,maxValue:Number.MAX_VALUE,incrementValue:1,accelerateOnTapHold:true,defaultValue:0,cycle:false,disableInput:false,useClearIcon:false,autoCapitalize:false,renderTpl:['<tpl if="label"><div class="x-form-label"><span>{label}</span></div></tpl>','<tpl if="fieldEl">','<div class="{componentCls}-body">','<div class="{componentCls}-down"><span>-</span></div>','<div class="x-form-field-container">','<input id="{inputId}" type="{type}" name="{name}" class="{fieldCls}"','<tpl if="tabIndex">tabIndex="{tabIndex}" </tpl>','<tpl if="placeHolder">placeholder="{placeHolder}" </tpl>','<tpl if="style">style="{style}" </tpl>','<tpl if="minValue != undefined">min="{minValue}" </tpl>','<tpl if="maxValue != undefined">max="{maxValue}" </tpl>','<tpl if="stepValue != undefined">step="{stepValue}" </tpl>','<tpl if="autoComplete">autocomple
 te="{autoComplete}" </tpl>','<tpl if="autoFocus">autofocus="{autoFocus}" </tpl>',"/>",'<tpl if="useMask"><div class="x-field-mask"></div></tpl>',"</div>",'<div class="{componentCls}-up"><span>+</span></div>',"</div>","</tpl>"],initComponent:function(){this.addEvents("spin","spindown","spinup");Ext.form.Spinner.superclass.initComponent.call(this)},onRender:function(){this.renderData.disableInput=this.disableInput;Ext.applyIf(this.renderSelectors,{spinUpEl:".x-spinner-up",spinDownEl:".x-spinner-down"});Ext.form.Spinner.superclass.onRender.apply(this,arguments);this.downRepeater=this.createRepeater(this.spinDownEl,this.onSpinDown);this.upRepeater=this.createRepeater(this.spinUpEl,this.onSpinUp)},initValue:function(){if(isNaN(this.defaultValue)){this.defaultValue=0}if(!this.value){this.value=this.defaultValue}Ext.form.Spinner.superclass.initValue.apply(this,arguments)},createRepeater:function(b,a){var c=new Ext.util.TapRepeater(b,{accelerate:this.accelerateOnTapHold});this.mon(c
 ,{tap:a,touchstart:this.onTouchStart,touchend:this.onTouchEnd,preventDefault:true,scope:this});return c},onSpinDown:function(){if(!this.disabled){this.spin(true)}},onSpinUp:function(){if(!this.disabled){this.spin(false)}},onKeyUp:function(a){Ext.form.Spinner.superclass.onKeyUp.apply(this,arguments)},onTouchStart:function(a){if(!this.disabled){a.el.addCls("x-button-pressed")}},onTouchEnd:function(a){a.el.removeCls("x-button-pressed")},setValue:function(a){a=parseFloat(a);if(isNaN(a)){a=this.defaultValue}Ext.form.Spinner.superclass.setValue.call(this,a)},spin:function(g){var e=parseFloat(this.getValue()),b=this.incrementValue,d=this.cycle,c=this.minValue,a=this.maxValue,f=g?"down":"up";if(g){e-=b}else{e+=b}e=(isNaN(e))?this.defaultValue:e;if(e<c){e=d?a:c}else{if(e>a){e=d?c:a}}this.setValue(e);this.fireEvent("spin"+f,this,e);this.fireEvent("spin",this,e,f)},destroy:function(){Ext.destroy(this.downRepeater,this.upRepeater);Ext.form.Spinner.superclass.destroy.call(this,arguments)
 }});Ext.reg("spinnerfield",Ext.form.Spinner);Ext.form.Hidden=Ext.extend(Ext.form.Field,{ui:"hidden",inputType:"hidden",tabIndex:-1});Ext.reg("hiddenfield",Ext.form.Hidden);Ext.form.HiddenField=Ext.extend(Ext.form.Hidden,{constructor:function(){console.warn("Ext.form.HiddenField has been deprecated and will be removed in Sencha Touch 1.0. Please use Ext.form.Hidden instead");Ext.form.HiddenField.superclass.constructor.apply(this,arguments)}});Ext.form.Checkbox=Ext.extend(Ext.form.Field,{ui:"checkbox",inputType:"checkbox",checked:false,value:"",constructor:function(a){this.addEvents("check","uncheck");Ext.form.Checkbox.superclass.constructor.call(this,a)},renderTpl:['<tpl if="label"><div class="x-form-label"><span>{label}</span></div></tpl>','<tpl if="fieldEl"><input id="{inputId}" type="{inputType}" name="{name}" class="{fieldCls}" tabIndex="-1" ','<tpl if="checked"> checked </tpl>','<tpl if="style">style="{style}" </tpl> value="{inputValue}" />',"</tpl>"],onRender:function()
 {var a=this.getBooleanIsChecked(this.checked);Ext.apply(this.renderData,{inputValue:String(this.value),checked:a});Ext.form.Checkbox.superclass.onRender.apply(this,arguments);if(this.fieldEl){this.mon(this.fieldEl,{click:this.onChange,scope:this});this.setChecked(a);this.originalState=this.isChecked()}},onChange:function(a){if(a){if(a.browserEvent){a=a.browserEvent}if(!a.isSimulated){a.preventDefault();a.stopPropagation();return}}if(this.isChecked()){this.fireEvent("check",this)}else{this.fireEvent("uncheck",this)}},isChecked:function(){if(this.rendered){return this.fieldEl.dom.checked||false}else{return !!this.checked}},setChecked:function(b){var d=this.getBooleanIsChecked(b),e=this.rendered,a,c;if(e){c=this.fieldEl.dom;a=c.checked}else{a=!!this.checked}if(a!=d){if(e){c.checked=d}else{this.checked=d}this.onChange()}return this},check:function(){return this.setChecked(true)},uncheck:function(){return this.setChecked(false)},reset:function(){Ext.form.Checkbox.superclass.reset
 .apply(this,arguments);this.setChecked(this.originalState);return this},getBooleanIsChecked:function(a){return/^(true|1|on)/i.test(String(a))},getSameGroupFields:function(){var b=this.el.up("form"),c=Ext.getCmp(b.id),a=[];if(c){a=c.getFields(this.getName())}return a},getGroupValues:function(){var a=[];this.getSameGroupFields().forEach(function(b){if(b.isChecked()){a.push(b.getValue())}});return a},setGroupValues:function(a){this.getSameGroupFields().forEach(function(b){b.setChecked((a.indexOf(b.getValue())!==-1))});return this},setValue:function(a){a=String(a);Ext.form.Checkbox.superclass.setValue.call(this,a)}});Ext.reg("checkboxfield",Ext.form.Checkbox);Ext.form.Radio=Ext.extend(Ext.form.Checkbox,{inputType:"radio",ui:"radio",getGroupValue:function(){var c,a=this.getSameGroupFields();for(var b=0;b<a.length;b++){c=a[b];if(c.isChecked()){return c.getValue()}}return null},setGroupValue:function(d){var e,b=this.getSameGroupFields(),c=0,a=b.length;for(;c<a;c++){e=b[c];if(e.getV
 alue()==d){e.check();return}}}});Ext.reg("radiofield",Ext.form.Radio);Ext.form.Select=Ext.extend(Ext.form.Text,{ui:"select",valueField:"value",displayField:"text",tabIndex:-1,useMask:true,monitorOrientation:true,initComponent:function(){var a=this.options;if(this.store){this.store=Ext.StoreMgr.lookup(this.store)}else{this.store=new Ext.data.Store({fields:[this.valueField,this.displayField]});if(a&&Ext.isArray(a)&&a.length>0){this.setOptions(this.options)}}Ext.form.Select.superclass.initComponent.call(this);this.addEvents("change")},onRender:function(){Ext.form.Select.superclass.onRender.apply(this,arguments);var a=this.hiddenName;if(a){this.hiddenField=this.el.insertSibling({name:a,tag:"input",type:"hidden"},"after")}},getPicker:function(){if(!this.picker){this.picker=new Ext.Picker({slots:[{align:"center",name:this.name,valueField:this.valueField,displayField:this.displayField,value:this.getValue(),store:this.store}],listeners:{change:this.onPickerChange,scope:this}})}retur
 n this.picker},getListPanel:function(){if(!this.listPanel){this.listPanel=new Ext.Panel({floating:true,stopMaskTapEvent:false,hideOnMaskTap:true,cls:"x-select-overlay",scroll:"vertical",items:{xtype:"list",store:this.store,itemId:"list",scroll:false,itemTpl:['<span class="x-list-label">{'+this.displayField+"}</span>",'<span class="x-list-selected"></span>'],listeners:{select:this.onListSelect,scope:this}}})}return this.listPanel},onOrientationChange:function(){if(this.isActive&&!Ext.is.Phone){this.listPanel.showBy(this.el,false,false)}},onMaskTap:function(){if(this.disabled){return}this.showComponent()},showComponent:function(){if(Ext.is.Phone){this.getPicker().show()}else{var b=this.getListPanel(),a=this.store.findExact(this.valueField,this.value);b.showBy(this.el,"fade",false);b.down("#list").getSelectionModel().select(a!=-1?a:0,false,true)}this.isActive=true},onListSelect:function(a,b){if(b){this.setValue(b.get(this.valueField));this.fireEvent("change",this,this.getValue(
 ))}this.listPanel.hide({type:"fade",out:true,scope:this});this.isActive=false},onPickerChange:function(a,c){var b=this.getValue(),d=c[this.name];if(d!=b){this.setValue(d);this.fireEvent("change",this,d)}this.isActive=false},setValue:function(d){var b=0,a=this.hiddenField,c;if(d){b=this.store.findExact(this.valueField,d)}c=this.store.getAt(b);if(c&&this.rendered){this.fieldEl.dom.value=c.get(this.displayField);this.value=c.get(this.valueField);if(a){a.dom.value=this.value}}else{if(this.rendered){this.fieldEl.dom.value=d}this.value=d}if(this.picker){var e={};e[this.name]=this.value;this.picker.setValue(e)}return this},getValue:function(){return this.value},setOptions:function(b,a){if(!b){this.store.clearData();this.setValue(null)}else{this.store.loadData(b,a)}},destroy:function(){Ext.form.Select.superclass.destroy.apply(this,arguments);Ext.destroy(this.listPanel,this.picker,this.hiddenField)}});Ext.reg("selectfield",Ext.form.Select);Ext.form.TextArea=Ext.extend(Ext.form.Text,{
 ui:"textarea",maxRows:undefined,autoCapitalize:false,renderTpl:['<tpl if="label"><div class="x-form-label"><span>{label}</span></div></tpl>','<tpl if="fieldEl"><div class="x-form-field-container">','<textarea id="{inputId}" type="{type}" name="{name}" class="{fieldCls}"','<tpl if="tabIndex">tabIndex="{tabIndex}" </tpl>','<tpl if="placeHolder">placeholder="{placeHolder}" </tpl>','<tpl if="style">style="{style}" </tpl>','<tpl if="maxRows != undefined">rows="{maxRows}" </tpl>','<tpl if="maxlength">maxlength="{maxlength}" </tpl>','<tpl if="autoComplete">autocomplete="{autoComplete}" </tpl>','<tpl if="autoCapitalize">autocapitalize="{autoCapitalize}" </tpl>','<tpl if="autoFocus">autofocus="{autoFocus}" </tpl>',"></textarea>",'<tpl if="useMask"><div class="x-field-mask"></div></tpl>',"</div></tpl>"],onRender:function(){this.renderData.maxRows=this.maxRows;Ext.form.TextArea.superclass.onRender.apply(this,arguments)},onKeyUp:function(a){this.fireEvent("keyup",this,a)}});Ext.reg("tex
 tareafield",Ext.form.TextArea);Ext.form.DatePicker=Ext.extend(Ext.form.Field,{ui:"select",picker:null,destroyPickerOnHide:false,initComponent:function(){this.addEvents("select");this.tabIndex=-1;this.useMask=true;Ext.form.Text.superclass.initComponent.apply(this,arguments)},getDatePicker:function(){if(!this.datePicker){if(this.picker instanceof Ext.DatePicker){this.datePicker=this.picker}else{this.datePicker=new Ext.DatePicker(Ext.apply(this.picker||{}))}this.datePicker.setValue(this.value||null);this.datePicker.on({scope:this,change:this.onPickerChange,hide:this.onPickerHide})}return this.datePicker},onMaskTap:function(){if(Ext.form.DatePicker.superclass.onMaskTap.apply(this,arguments)!==true){return false}this.getDatePicker().show()},onPickerChange:function(a,b){this.setValue(b);this.fireEvent("select",this,this.getValue())},onPickerHide:function(){if(this.destroyPickerOnHide&&this.datePicker){this.datePicker.destroy()}},setValue:function(b,a){if(this.datePicker){this.date
 Picker.setValue(b,a);this.value=(b!=null)?this.datePicker.getValue():null}else{if(!Ext.isDate(b)&&!Ext.isObject(b)){b=null}if(Ext.isObject(b)){this.value=new Date(b.year,b.month-1,b.day)}else{this.value=b}}if(this.rendered){this.fieldEl.dom.value=this.getValue(true)}return this},getValue:function(b){var a=this.value||null;return(b&&Ext.isDate(a))?a.format(Ext.util.Format.defaultDateFormat):a},onDestroy:function(){if(this.datePicker){this.datePicker.destroy()}Ext.form.DatePicker.superclass.onDestroy.call(this)}});Ext.reg("datepickerfield",Ext.form.DatePicker);Ext.layout.LayoutManager=new Ext.AbstractManager({create:function(a,b){if(!a){a=b}if(Ext.isString(a)){return new this.types[a||b]}else{if(Ext.isObject(a)){if(a.isLayout){return a}else{return new this.types[a.type||b](a)}}}}});Ext.regLayout=function(){return Ext.layout.LayoutManager.registerType.apply(Ext.layout.LayoutManager,arguments)};Ext.layout.Layout=Ext.extend(Object,{isLayout:true,initialized:false,constructor:func
 tion(a){this.id=Ext.id(null,"ext-layout-"+this.type+"-");Ext.apply(this,a)},layout:function(){var a=this;a.layoutBusy=true;a.initLayout();if(a.beforeLayout.apply(a,arguments)!==false){a.onLayout.apply(a,arguments);a.afterLayout();a.owner.needsLayout=false;a.layoutBusy=false}},beforeLayout:function(){this.renderItems(this.getLayoutItems(),this.getTarget());return true},renderItems:function(a,e){var d=a.length,b=0,c;for(;b<d;b++){c=a[b];if(c&&!c.rendered){this.renderItem(c,b,e)}else{if(!this.isValidParent(c,e)){this.moveItem(c,b,e)}}}},renderItem:function(b,a,c){if(!b.rendered){b.render(c,a);this.configureItem(b,a);this.childrenChanged=true}},moveItem:function(b,a,c){if(typeof a=="number"){a=c.dom.childNodes[a]}c=c.dom||c;c.insertBefore(b.el.dom,a||null);b.container=c;this.configureItem(b,a);this.childrenChanged=true},initLayout:function(){if(!this.initialized&&!Ext.isEmpty(this.targetCls)){this.getTarget().addCls(this.targetCls)}this.initialized=true},setOwner:function(a){thi
 s.owner=a},getLayoutItems:function(){return[]},isValidParent:function(a,b){var c=a.el?a.el.dom:Ext.getDom(a);return b&&(c.parentNode==(b.dom||b))},configureItem:function(b,a){if(this.itemCls){b.el.addCls(this.itemCls)}},onLayout:Ext.emptyFn,afterLayout:Ext.emptyFn,onRemove:Ext.emptyFn,onDestroy:Ext.emptyFn,afterRemove:function(a){if(this.itemCls&&a.rendered){a.el.removeCls(this.itemCls)}},destroy:function(){if(!Ext.isEmpty(this.targetCls)){var a=this.getTarget();if(a){a.removeCls(this.targetCls)}}this.onDestroy()}});Ext.layout.ComponentLayout=Ext.extend(Ext.layout.Layout,{type:"component",monitorChildren:true,beforeLayout:function(d,c){Ext.layout.ComponentLayout.superclass.beforeLayout.call(this);var b=this.owner,a=b.isVisible(),e;if(!a&&b.hiddenOwnerCt){e=b.hiddenOwnerCt.layoutOnShow;e.remove(b);e.add(b);b.needsLayout={width:d,height:c,isSetSize:false}}return a&&this.needsLayout(d,c)},needsLayout:function(c,a){this.lastComponentSize=this.lastComponentSize||{width:-Infinity,
 height:-Infinity};var b=this.childrenChanged;this.childrenChanged=false;return(b||this.lastComponentSize.width!==c||this.lastComponentSize.height!==a)},setElementSize:function(c,b,a){if(b!==undefined&&a!==undefined){c.setSize(b,a)}else{if(a!==undefined){c.setHeight(a)}else{if(b!==undefined){c.setWidth(b)}}}},getTarget:function(){return this.owner.el},setTargetSize:function(b,a){this.setElementSize(this.owner.el,b,a);this.lastComponentSize={width:b,height:a}},afterLayout:function(){var b=this.owner,e=b.layout,d=b.ownerCt,h,g,f,c,a;b.afterComponentLayout(this);if(e&&e.isLayout){e.layout()}if(d&&d.componentLayout&&d.componentLayout.monitorChildren&&!d.componentLayout.layoutBusy){d.componentLayout.childrenChanged=true;if(d.layout&&!d.layout.layoutBusy){if(d.layout.type=="autocontainer"){d.doComponentLayout(c,a)}else{d.layout.layout()}}}}});Ext.layout.AutoComponentLayout=Ext.extend(Ext.layout.ComponentLayout,{type:"autocomponent",onLayout:function(b,a){this.setTargetSize(b,a)}});
 Ext.regLayout("autocomponent",Ext.layout.AutoComponentLayout);Ext.layout.DockLayout=Ext.extend(Ext.layout.ComponentLayout,{type:"dock",itemCls:"x-docked",onLayout:function(a,p){var m=this,b=m.owner,j=b.body,d=b.ownerCt,i=b.layout,f=b.collapsed,e=b.contracted,k=b.expanded,h=m.headerItem,l=m.getTarget(),n=false,o=false,g;var c=m.info={boxes:[],size:{width:a,height:p},padding:{top:l.getPadding("t"),right:l.getPadding("r"),bottom:l.getPadding("b"),left:l.getPadding("l")},border:{top:l.getBorderWidth("t"),right:l.getBorderWidth("r"),bottom:l.getBorderWidth("b"),left:l.getBorderWidth("l")},bodyMargin:{top:j.getMargin("t"),right:j.getMargin("r"),bottom:j.getMargin("b"),left:j.getMargin("l")},bodyBox:{}};if(p===undefined||p===null||a===undefined||a===null||e){if((p===undefined||p===null)&&(a===undefined||a===null)){o=true;n=true;if(!b.animCollapse||(!k&&!e)){m.setTargetSize(null,null)}m.setBodyBox({width:null,height:null})}else{if(p===undefined||p===null){o=true;if(!b.animCollapse||
 (!k&&!e)){m.setTargetSize(a,null)}m.setBodyBox({width:a,height:null})}else{n=true;if(!b.animCollapse||(!k&&!e)){m.setTargetSize(null,p)}m.setBodyBox({width:null,height:p})}}if(!f&&i&&i.isLayout){i.layout()}m.dockItems(n,o);if(f){if(h){if(h.dock=="top"||h.dock=="bottom"){c.size.height=h.getHeight()}else{c.size.width=h.getWidths()}}else{c.size.height=0}}if(k||e){if(b.animCollapse){Ext.createDelegate(b.animCollapseFn,b,[c.size.width,c.size.height])()}else{Ext.createDelegate(b["after"+(k?"Expand":"Collapse")],b)();m.setTargetSize(c.size.width,c.size.height)}}else{m.setTargetSize(c.size.width,c.size.height)}}else{if(k||e){if(b.animCollapse){Ext.createDelegate(b.animCollapseFn,b,[a,p])()}else{Ext.createDelegate(b["after"+(k?"Expand":"Collapse")],b)();m.setTargetSize(a,p)}}else{m.setTargetSize(a,p);m.dockItems()}}Ext.layout.DockLayout.superclass.onLayout.call(m,a,p)},afterLayout:function(){Ext.layout.DockLayout.superclass.afterLayout.call(this)},dockItems:function(h,a){this.calcula
 teDockBoxes(h,a);var f=this.info,g=this.owner.collapsed,c=f.boxes,e=c.length,d,b;for(b=0;b<e;b++){d=c[b];if(g===true&&!d.isHeader){continue}d.item.setPosition(d.x,d.y)}if(h){f.bodyBox.width=null}if(a){f.bodyBox.height=null}this.setBodyBox(f.bodyBox)},calculateDockBoxes:function(m,p){var x=this,y=x.getTarget(),l=x.getLayoutItems(),a=x.owner,b=a.contracted,o=a.expanded,f=a.body,t=x.info,k=t.size,c=l.length,g=t.padding,n=t.border,u,q,d,e,s,v,j;if(p){k.height=f.getHeight()+g.top+n.top+g.bottom+n.bottom}else{k.height=y.getHeight()-y.getMargin("tb")}if(m){k.width=f.getWidth()+g.left+n.left+g.right+n.right}else{k.width=y.getWidth()-y.getMargin("lr")}t.bodyBox={x:n.left+g.left,y:n.top+g.top,width:k.width-g.left-n.left-g.right-n.right,height:k.height-n.top-g.top-n.bottom-g.bottom};for(q=0;q<c;q++){u=l[q];if(u.isHeader){x.headerItem=u}d=x.initBox(u);if(p===true){d=x.adjustAutoBox(d,q)}else{d=x.adjustSizedBox(d,q)}t.boxes.push(d)}},adjustSizedBox:function(c,b){var a=this.info.bodyBox;s
 witch(c.type){case"top":c.y=a.y;break;case"left":c.x=a.x;break;case"bottom":c.y=(a.y+a.height)-c.height;break;case"right":c.x=(a.x+a.width)-c.width;break}if(!c.overlay){switch(c.type){case"top":a.y+=c.height;a.height-=c.height;break;case"left":a.x+=c.width;a.width-=c.width;break;case"bottom":a.height-=c.height;break;case"right":a.width-=c.width;break}}return c},adjustAutoBox:function(c,f){var a=this.info,g=a.bodyBox,j=a.size,d=a.boxes,h=c.type,b,e;if(h=="top"||h=="bottom"){for(b=0;b<f;b++){e=d[b];if(e.stretched&&e.type=="left"||e.type=="right"){e.height+=c.height}else{if(e.type=="bottom"){e.y+=c.height}}}}switch(h){case"top":c.y=g.y;if(!c.overlay){g.y+=c.height}j.height+=c.height;break;case"bottom":c.y=(g.y+g.height);j.height+=c.height;break;case"left":c.x=g.x;if(!c.overlay){g.x+=c.width;g.width-=c.width}break;case"right":if(!c.overlay){g.width-=c.width}c.x=(g.x+g.width);break}return c},initBox:function(d){var b=this.info.bodyBox,a=(d.dock=="top"||d.dock=="bottom"),c={item:d
 ,overlay:d.overlay,type:d.dock};if(d.stretch!==false){c.stretched=true;if(a){c.x=b.x;c.width=b.width;d.doComponentLayout(c.width-d.el.getMargin("lr"))}else{c.y=b.y;c.height=b.height;d.doComponentLayout(undefined,c.height-d.el.getMargin("tb"))}}else{d.doComponentLayout();c.width=d.getWidth();c.height=d.getHeight();if(a){c.x=(d.align=="right")?b.width-c.width:b.x}}if(c.width==undefined){c.width=d.getWidth()+d.el.getMargin("lr")}if(c.height==undefined){c.height=d.getHeight()+d.el.getMargin("tb")}return c},getLayoutItems:function(){return this.owner.getDockedItems()},setBodyBox:function(f){var i=this,a=i.owner,g=a.body,e=a.contracted,h=a.expanded,b=i.info,d=b.bodyMargin,j=b.padding,c=b.border;if(Ext.isNumber(f.width)){f.width-=d.left+d.right}if(Ext.isNumber(f.height)){f.height-=d.top+d.bottom}i.setElementSize(g,f.width,f.height);g.setLeft(f.x-j.left-c.left);g.setTop(f.y-j.top-c.top)},configureItem:function(b,c){Ext.layout.DockLayout.superclass.configureItem.call(this,b,c);var a=
 b.el||Ext.get(b);if(this.itemCls){a.addCls(this.itemCls+"-"+b.dock)}},afterRemove:function(a){Ext.layout.DockLayout.superclass.afterRemove.call(this,a);if(this.itemCls){a.el.removeCls(this.itemCls+"-"+a.dock)}var b=a.el.dom;if(b){b.parentNode.removeChild(b)}this.childrenChanged=true}});Ext.regLayout("dock",Ext.layout.DockLayout);Ext.layout.FieldLayout=Ext.extend(Ext.layout.ComponentLayout,{type:"field",onLayout:function(b,a){Ext.layout.FieldLayout.superclass.onLayout.call(this,owner,target);this.setTargetSize(b,a)},handleLabel:function(){this.owner.labelEl.setWidth(this.owner.labelWidth)}});Ext.regLayout("field",Ext.layout.FieldLayout);Ext.layout.ContainerLayout=Ext.extend(Ext.layout.Layout,{type:"container",getLayoutItems:function(){return this.owner&&this.owner.items&&this.owner.items.items||[]},afterLayout:function(){this.owner.afterLayout(this)},getTarget:function(){return this.owner.getTargetEl()}});Ext.layout.AutoContainerLayout=Ext.extend(Ext.layout.ContainerLayout,{t
 ype:"autocontainer",onLayout:function(a,e){var b=this.getLayoutItems(),d=b.length,c;for(c=0;c<d;c++){b[c].doComponentLayout()}}});Ext.regLayout("auto",Ext.layout.AutoContainerLayout);Ext.regLayout("autocontainer",Ext.layout.AutoContainerLayout);Ext.layout.FitLayout=Ext.extend(Ext.layout.ContainerLayout,{itemCls:"x-fit-item",targetCls:"x-layout-fit",type:"fit",onLayout:function(){Ext.layout.FitLayout.superclass.onLayout.call(this);if(this.owner.items.length){var b=this.getTargetBox(),a=this.owner.items.get(0);this.setItemBox(a,b);a.cancelAutoSize=true}},getTargetBox:function(){var d=this.getTarget(),b=d.getSize(),c={left:d.getPadding("l"),right:d.getPadding("r"),top:d.getPadding("t"),bottom:d.getPadding("b")},a={left:d.getBorderWidth("l"),right:d.getBorderWidth("r"),top:d.getBorderWidth("t"),bottom:d.getBorderWidth("b")};return{width:b.width-c.left-c.right-a.left-a.right,height:b.height-c.top-c.bottom-a.top-a.bottom,x:c.left+a.left,y:c.top+a.top}},setItemBox:function(b,a){if(
 b&&a.height>0){a.width-=b.el.getMargin("lr");a.height-=b.el.getMargin("tb");b.setCalculatedSize(a);b.setPosition(a)}}});Ext.regLayout("fit",Ext.layout.FitLayout);Ext.layout.CardLayout=Ext.extend(Ext.layout.FitLayout,{type:"card",sizeAllCards:false,hideInactive:true,beforeLayout:function(){this.activeItem=this.getActiveItem();return Ext.layout.CardLayout.superclass.beforeLayout.apply(this,arguments)},onLayout:function(){Ext.layout.FitLayout.superclass.onLayout.apply(this,arguments);var f=this.activeItem,b=this.getLayoutItems(),e=b.length,a=this.getTargetBox(),c,d;for(c=0;c<e;c++){d=b[c];this.setItemBox(d,a)}if(!this.firstActivated&&f){if(f.fireEvent("beforeactivate",f)!==false){f.fireEvent("activate",f)}this.firstActivated=true}},getActiveItem:function(){if(!this.activeItem&&this.owner){this.activeItem=this.parseActiveItem(this.owner.activeItem)}if(this.activeItem&&this.owner.items.items.indexOf(this.activeItem)!=-1){return this.activeItem}return null},parseActiveItem:functio
 n(a){if(a&&a.isComponent){return a}else{if(typeof a=="number"||a==undefined){return this.getLayoutItems()[a||0]}else{return this.owner.getComponent(a)}}},configureItem:function(b,a){Ext.layout.FitLayout.superclass.configureItem.call(this,b,a);if(this.hideInactive&&this.activeItem!==b){b.hide()}else{b.show()}},onRemove:function(a){if(a===this.activeItem){this.activeItem=null;if(this.owner.items.getCount()==0){this.firstActivated=false}}},getAnimation:function(b,a){var c=(b||{}).cardSwitchAnimation;if(c===false){return false}return c||a.cardSwitchAnimation},setActiveItem:function(b,f){var e=this,a=e.owner,g=Ext.getDoc(),d=e.activeItem,c;f=(f==undefined)?this.getAnimation(b,a):f;b=e.parseActiveItem(b);c=a.items.indexOf(b);if(c==-1){a.add(b)}if(b&&d!=b&&a.onBeforeCardSwitch(b,d,c,!!f)!==false){if(!b.rendered){this.layout()}if(b.fireEvent("beforeactivate",b,d)===false){return false}if(d&&d.fireEvent("beforedeactivate",d,b)===false){return false}if(b.hidden){b.show()}e.activeItem=
 b;if(f){g.on("click",Ext.emptyFn,e,{single:true,preventDefault:true});Ext.Anim.run(b,f,{out:false,autoClear:true,scope:e,after:function(){Ext.defer(function(){g.un("click",Ext.emptyFn,e)},50,e);b.fireEvent("activate",b,d);if(!d){a.onCardSwitch(b,d,c,true)}}});if(d){Ext.Anim.run(d,f,{out:true,autoClear:true,after:function(){d.fireEvent("deactivate",d,b);if(e.hideInactive&&e.activeItem!=d){d.hide()}a.onCardSwitch(b,d,c,true)}})}}else{b.fireEvent("activate",b,d);if(d){d.fireEvent("deactivate",d,b);if(e.hideInactive){d.hide()}}a.onCardSwitch(b,d,c,false)}return b}return false},getNext:function(c){var a=this.getLayoutItems(),b=a.indexOf(this.activeItem);return a[b+1]||(c?a[0]:false)},next:function(b,a){return this.setActiveItem(this.getNext(a),b)},getPrev:function(c){var a=this.getLayoutItems(),b=a.indexOf(this.activeItem);return a[b-1]||(c?a[a.length-1]:false)},prev:function(b,a){return this.setActiveItem(this.getPrev(a),b)}});Ext.regLayout("card",Ext.layout.CardLayout);Ext.layo
 ut.BoxLayout=Ext.extend(Ext.layout.ContainerLayout,{type:"box",targetCls:"x-layout-box",innerCls:"x-layout-box-inner",pack:"start",align:"center",direction:"normal",onLayout:function(){Ext.layout.BoxLayout.superclass.onLayout.call(this);if(this.pack==="left"||this.pack==="top"){this.pack="start"}else{if(this.pack==="right"||this.pack==="bottom"){this.pack="end"}}var d=this.getTarget(),c=d.parent(),b=(c.getWidth()-c.getPadding("lr")-c.getBorderWidth("lr"))+"px",a=(c.getHeight()-c.getPadding("tb")-c.getBorderWidth("tb"))+"px";d.setStyle({"-webkit-box-orient":this.orientation,"-webkit-box-direction":this.direction,"-webkit-box-pack":this.pack,"-webkit-box-align":this.align});if(this.orientation=="horizontal"){d.setStyle({"min-width":b,height:a})}else{d.setStyle({"min-height":a,width:b})}this.prepareFlexedItems();this.setFlexedItems()},prepareFlexedItems:function(){var a=this.getLayoutItems(),d=a.length,c,b;for(b=0;b<d;b++){c=a[b];if(c.flex!=undefined){c.el.setStyle("position","
 absolute");c.boxEl=this.createBoxEl(c)}else{c.doComponentLayout()}}},setFlexedItems:function(){var a=this.getLayoutItems(),d=a.length,c,b;for(b=0;b<d;b++){c=a[b];if(c.flex!=undefined){c.boxSize=c.boxEl.getSize()}}for(b=0;b<d;b++){c=a[b];if(c.flex!=undefined){c.el.setStyle("position","");if(this.align=="stretch"){c.setSize(c.boxSize)}else{if(this.orientation=="horizontal"){c.setWidth(c.boxSize.width)}else{c.setHeight(c.boxSize.height)}}c.boxEl.remove();delete c.boxEl;delete c.boxSize}}},getTarget:function(){var a=this.owner,b=this.innerCt;if(!b){if(a.scrollEl){b=a.scrollEl.addCls(this.innerCls)}else{b=a.getTargetEl().createChild({cls:this.innerCls})}this.innerCt=b}return b},createBoxEl:function(b){var a=b.el;return a.insertSibling({style:"margin-top: "+a.getMargin("tb")+"px; margin-left: "+a.getMargin("lr")+"px; -webkit-box-flex: "+b.flex})}});Ext.layout.HBoxLayout=Ext.extend(Ext.layout.BoxLayout,{orientation:"horizontal"});Ext.regLayout("hbox",Ext.layout.HBoxLayout);Ext.layo
 ut.VBoxLayout=Ext.extend(Ext.layout.BoxLayout,{orientation:"vertical"});Ext.regLayout("vbox",Ext.layout.VBoxLayout);
\ No newline at end of file
Modified: sandbox/bartvde/adapters/openlayers/tests/OLLoader.js
--- sandbox/bartvde/adapters/openlayers/tests/OLLoader.js	2011-02-22 16:19:07 UTC (rev 11256)
+++ sandbox/bartvde/adapters/openlayers/tests/OLLoader.js	2011-02-22 16:42:30 UTC (rev 11257)
@@ -15,7 +15,6 @@
     var regex = new RegExp( "[\\?&]mode=([^&#]*)" );
     var href = window.parent.location.href;
     var results = regex.exec( href );
@@ -23,4 +22,6 @@
         "../build/OpenLayers.js" : "../lib/OpenLayers.js";
     scriptTag = "<script src='" + l + "'></script>";
     document.write(scriptTag);
+    document.write('<script src="../adapters/ext-core.js"></script>');
+    document.write('<script src="../adapters/ext-bridge.js"></script>');
Modified: sandbox/bartvde/adapters/openlayers/tests/Util.html
--- sandbox/bartvde/adapters/openlayers/tests/Util.html	2011-02-22 16:19:07 UTC (rev 11256)
+++ sandbox/bartvde/adapters/openlayers/tests/Util.html	2011-02-22 16:42:30 UTC (rev 11257)
@@ -72,10 +72,23 @@
     function test_Util_pagePosition(t) {
-        t.plan( 1 );
+        t.plan( 2 );
         var pp = OpenLayers.Util.pagePosition(window);
         t.eq( pp.toString(), "0,0", "Page position doesn't bail if passed 'window'")
+        var id = "boo";
+        var px = new OpenLayers.Pixel(5,5);
+        var sz = new OpenLayers.Size(10,10);
+        var img = "http://www.openlayers.org/images/OpenLayers.trac.png";
+        var position = "absolute";
+        var border = "13px solid";
+        var overflow = "hidden";
+        var opacity = 0.5;
+        var div = OpenLayers.Util.createDiv(id, px, sz, img, position, border, overflow, opacity);
+        document.body.appendChild(div);
+        var pp = OpenLayers.Util.pagePosition(div);
+        t.eq( pp.toString(), "5,5", "Page position reports [5,5]");
+        document.body.removeChild(div);
     function test_Util_createDiv(t) {
More information about the Commits mailing list
