[OpenLayers-Commits] r11263 - trunk/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Feb 22 17:00:59 EST 2011
Author: tschaub
Date: 2011-02-22 14:00:59 -0800 (Tue, 22 Feb 2011)
New Revision: 11263
Added:
   trunk/openlayers/examples/geolocation.js
   trunk/openlayers/examples/geolocation.html
Linking to example source code.  Setting watch checkbox to match initial control state.
Modified: trunk/openlayers/examples/geolocation.html
--- trunk/openlayers/examples/geolocation.html	2011-02-22 21:25:35 UTC (rev 11262)
+++ trunk/openlayers/examples/geolocation.html	2011-02-22 22:00:59 UTC (rev 11263)
@@ -1,89 +1,17 @@
-<html xmlns="http://www.w3.org/1999/xhtml">
+<!DOCTYPE html>
+<html>
     <head>
-        <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
-        <meta name="apple-mobile-web-app-capable" content="yes" />
+        <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;">
+        <meta name="apple-mobile-web-app-capable" content="yes">
         <title>OpenLayers Geolocation</title>
-        <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
-        <link rel="stylesheet" href="style.css" type="text/css" />
-        <script src="../lib/OpenLayers.js"></script>
-        <script type="text/javascript">
-            var map, layer, vector, watchId;
-            function init(){
-                var style = {
-                    fillOpacity: 0.1,
-                    fillColor: '#000',
-                    strokeColor: '#f00',
-                    strokeOpacity: 0.6
-                map = new OpenLayers.Map('map');
-                layer = new OpenLayers.Layer.OSM( "Simple OSM Map");
-                vector = new OpenLayers.Layer.Vector('vector');
-                map.addLayers([layer, vector]);
-                map.setCenter(
-                    new OpenLayers.LonLat(-71.147, 42.472).transform(
-                        new OpenLayers.Projection("EPSG:4326"),
-                        map.getProjectionObject()
-                    ), 12
-                var geolocate = new OpenLayers.Control.Geolocate({
-                    geolocationOptions: {
-                        enableHighAccuracy: false,
-                        maximumAge: 0,
-                        timeout: 7000
-                map.addControl(geolocate);
-                geolocate.events.register("locationupdated",this,function(e) {
-                    vector.removeAllFeatures();
-                    vector.addFeatures([
-                        new OpenLayers.Feature.Vector(
-                            e.point,
-                                graphicName: 'cross',
-                                strokeWidth: 2,
-                                fillOpacity: 0,
-                                pointRadius: 10
-                            OpenLayers.Geometry.Polygon.createRegularPolygon(
-                                new OpenLayers.Geometry.Point(e.point.x, e.point.y),
-                                e.position.coords.accuracy/2,
-                                50,
-                                0
-                            style
-                    map.zoomToExtent(vector.getDataExtent());
-                geolocate.events.register("locationfailed",this,function() {
-                    console.log('Location detection failed');
-                window.geolocate = geolocate;
-                $('locate').onclick = function() {
-                    geolocate.deactivate();
-                    $('track').checked = false;
-                    geolocate.watch = false;
-                    geolocate.activate();
-                $('track').onclick = function() {
-                    if (this.checked) {
-                        geolocate.watch = true;
+        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+        <link rel="stylesheet" href="style.css" type="text/css">
+        <style>
+            .olControlAttribution {
+                bottom: 3px;
-        </script>
+        </style>
     </head>
     <body onload="init()">
         <h1 id="title">Geolocation Example</h1>
@@ -97,13 +25,16 @@
         </p>
         <div id="map" class="smallmap"></div>
+        <button id="locate">Locate me!</button>
+        <input type="checkbox" name="track" id="track">
+        <label for="track">Track my position</label>
         <div id="docs">
-            <button id="locate">Locate me!</button>
-            <label>
-                <input type="checkbox" name="track" id="track" />
-                Track my position
-            </label>&nbsp;
+            <p>
+                View the <a href="geolocation.js" target="_blank">geolocation.js source</a>
+                to see how this is done.
+            </p>
         </div>
+        <script src="../lib/OpenLayers.js"></script>
+        <script src="geolocation.js"></script>
     </body>
 </html>
Added: trunk/openlayers/examples/geolocation.js
--- trunk/openlayers/examples/geolocation.js	                        (rev 0)
+++ trunk/openlayers/examples/geolocation.js	2011-02-22 22:00:59 UTC (rev 11263)
@@ -0,0 +1,72 @@
+var style = {
+    fillOpacity: 0.1,
+    fillColor: '#000',
+    strokeColor: '#f00',
+    strokeOpacity: 0.6
+var map = new OpenLayers.Map('map');
+var layer = new OpenLayers.Layer.OSM( "Simple OSM Map");
+var vector = new OpenLayers.Layer.Vector('vector');
+map.addLayers([layer, vector]);
+map.setCenter(
+    new OpenLayers.LonLat(-71.147, 42.472).transform(
+        new OpenLayers.Projection("EPSG:4326"),
+        map.getProjectionObject()
+    ), 12
+var geolocate = new OpenLayers.Control.Geolocate({
+    geolocationOptions: {
+        enableHighAccuracy: false,
+        maximumAge: 0,
+        timeout: 7000
+map.addControl(geolocate);
+geolocate.events.register("locationupdated",this,function(e) {
+    vector.removeAllFeatures();
+    vector.addFeatures([
+        new OpenLayers.Feature.Vector(
+            e.point,
+                graphicName: 'cross',
+                strokeWidth: 2,
+                fillOpacity: 0,
+                pointRadius: 10
+            OpenLayers.Geometry.Polygon.createRegularPolygon(
+                new OpenLayers.Geometry.Point(e.point.x, e.point.y),
+                e.position.coords.accuracy/2,
+                50,
+                0
+            style
+    map.zoomToExtent(vector.getDataExtent());
+geolocate.events.register("locationfailed",this,function() {
+    OpenLayers.Console.log('Location detection failed');
+$('locate').onclick = function() {
+    geolocate.deactivate();
+    $('track').checked = false;
+    geolocate.watch = false;
+    geolocate.activate();
+$('track').onclick = function() {
+    if (this.checked) {
+        geolocate.watch = true;
+$('track').checked = false;
\ No newline at end of file
More information about the Commits mailing list
