[OpenLayers-Commits] r11292 - trunk/openlayers/tests/Control
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 05:28:28 EST 2011
Author: tschaub
Date: 2011-02-23 02:28:27 -0800 (Wed, 23 Feb 2011)
New Revision: 11292
   trunk/openlayers/tests/Control/PanZoom.html
Adding detail to the messages for easier failure detection.
Modified: trunk/openlayers/tests/Control/PanZoom.html
--- trunk/openlayers/tests/Control/PanZoom.html	2011-02-23 10:27:33 UTC (rev 11291)
+++ trunk/openlayers/tests/Control/PanZoom.html	2011-02-23 10:28:27 UTC (rev 11292)
@@ -72,65 +72,65 @@
                     simulateClick(wnd, wnd.control.buttons[0]);
                     t.delay_call(2, function() {
-                        t.ok( wnd.mapper.getCenter().lat > wnd.centerLL.lat, "Pan up works correctly" );
-                        t.ok(!flag.mousedown, "mousedown does not get to the map");
-                        t.ok(flag.mouseup, "mouseup does get to the map");
-                        t.ok(!flag.click, "click does not get to the map");
-                        t.ok(!flag.dblclick, "dblclick does not get to the map");
+                        t.ok( wnd.mapper.getCenter().lat > wnd.centerLL.lat, "1) Pan up works correctly" );
+                        t.ok(!flag.mousedown, "1) mousedown does not get to the map");
+                        t.ok(flag.mouseup, "1) mouseup does get to the map");
+                        t.ok(!flag.click, "1) click does not get to the map");
+                        t.ok(!flag.dblclick, "1) dblclick does not get to the map");
                         resetFlags();
                         simulateClick(wnd, wnd.control.buttons[1]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lon < wnd.centerLL.lon, "Pan left works correctly" );
+                    t.ok( wnd.mapper.getCenter().lon < wnd.centerLL.lon, "2) Pan left works correctly" );
+                    t.ok(!flag.mousedown, "2) mousedown does not get to the map");
+                    t.ok(flag.mouseup, "2) mouseup does get to the map");
+                    t.ok(!flag.click, "2) click does not get to the map");
+                    t.ok(!flag.dblclick, "2) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[2]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lon == wnd.centerLL.lon, "Pan right works correctly" );
+                    t.ok( wnd.mapper.getCenter().lon == wnd.centerLL.lon, "3) Pan right works correctly" );
+                    t.ok(!flag.mousedown, "3) mousedown does not get to the map");
+                    t.ok(flag.mouseup, "3) mouseup does get to the map");
+                    t.ok(!flag.click, "3) click does not get to the map");
+                    t.ok(!flag.dblclick, "3) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[3]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lat == wnd.centerLL.lat, "Pan down works correctly" );
+                    t.ok( wnd.mapper.getCenter().lat == wnd.centerLL.lat, "4) Pan down works correctly" );
+                    t.ok(!flag.mousedown, "4) mousedown does not get to the map");
+                    t.ok(flag.mouseup, "4) mouseup does get to the map");
+                    t.ok(!flag.click, "4) click does not get to the map");
+                    t.ok(!flag.dblclick, "4) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[4]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 6, "zoomin works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 6, "5) zoomin works correctly" );
+                    t.ok(!flag.mousedown, "5) mousedown does not get to the map");
+                    t.ok(flag.mouseup, "5) mouseup does get to the map");
+                    t.ok(!flag.click, "5) click does not get to the map");
+                    t.ok(!flag.dblclick, "5) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[6]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 5, "zoomout works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 5, "6) zoomout works correctly" );
+                    t.ok(!flag.mousedown, "6) mousedown does not get to the map");
+                    t.ok(flag.mouseup, "6) mouseup does get to the map");
+                    t.ok(!flag.click, "6) click does not get to the map");
+                    t.ok(!flag.dblclick, "6) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[5]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 2, "zoomworld works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 2, "7) zoomworld works correctly" );
+                    t.ok(!flag.mousedown, "7) mousedown does not get to the map");
+                    t.ok(flag.mouseup, "7) mouseup does get to the map");
+                    t.ok(!flag.click, "7) click does not get to the map");
+                    t.ok(!flag.dblclick, "7) dblclick does not get to the map");
                     resetFlags();
More information about the Commits mailing list
