[OpenLayers-Commits] r11309 - trunk/openlayers/lib/OpenLayers
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 07:13:53 EST 2011
Author: erilem
Date: 2011-02-23 04:13:53 -0800 (Wed, 23 Feb 2011)
New Revision: 11309
   trunk/openlayers/lib/OpenLayers/Kinetic.js
better API doc strings in the Kinetic class, no functional change
Modified: trunk/openlayers/lib/OpenLayers/Kinetic.js
--- trunk/openlayers/lib/OpenLayers/Kinetic.js	2011-02-23 12:00:51 UTC (rev 11308)
+++ trunk/openlayers/lib/OpenLayers/Kinetic.js	2011-02-23 12:13:53 UTC (rev 11309)
@@ -63,7 +63,6 @@
      * Method: begin
      * Begins the dragging.
     begin: function() {
@@ -74,8 +73,10 @@
      * Method: update
+     * Updates during the dragging.
-     * Updates during the dragging.
+     * Parameters:
+     * xy - {<OpenLayers.Pixel>} The new position.
     update: function(xy) {
         this.points.unshift({xy: xy, tick: new Date().getTime()});
@@ -86,8 +87,15 @@
      * Method: end
+     * Ends the dragging, start the kinetic.
-     * Ends the dragging, start the kinetic.
+     * Parameters:
+     * xy - {<OpenLayers.Pixel>} The last position.
+     * Returns:
+     * {Object} An object with two properties: "speed", and "theta". The
+     *     "speed" and "theta" values are to be passed to the move
+     *     function when starting the animation.
     end: function(xy) {
         var last, now = new Date().getTime();
@@ -117,12 +125,13 @@
      * Method: move
      * Launch the kinetic move pan.
      * Parameters:
-     * info - {Object}
-     * callback - arguments x, y (values to pan), end (is the last point)
+     * info - {Object} An object with two properties, "speed", and "theta".
+     *     These values are those returned from the "end" call.
+     * callback - {Function} Function called on every step of the animation,
+     *     receives x, y (values to pan), end (is the last point).
     move: function(info, callback) {
         var v0 = info.speed;
More information about the Commits mailing list
