[OpenLayers-Commits] r11319 - sandbox/camptocamp/mobile/openlayers/build
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 09:00:08 EST 2011
Author: pgiraud
Date: 2011-02-23 06:00:08 -0800 (Wed, 23 Feb 2011)
New Revision: 11319
   sandbox/camptocamp/mobile/openlayers/build/OpenLayers.js
Built file
Modified: sandbox/camptocamp/mobile/openlayers/build/OpenLayers.js
--- sandbox/camptocamp/mobile/openlayers/build/OpenLayers.js	2011-02-23 13:48:49 UTC (rev 11318)
+++ sandbox/camptocamp/mobile/openlayers/build/OpenLayers.js	2011-02-23 14:00:08 UTC (rev 11319)
@@ -504,7 +504,275 @@
 if(toUpdate.length>0){nRequests++;opt=OpenLayers.Util.applyDefaults({"callback":callback,"scope":this},options.update);resp.push(this.update(toUpdate,opt));}
 if(toDelete.length>0){nRequests++;opt=OpenLayers.Util.applyDefaults({"callback":callback,"scope":this},options["delete"]);resp.push(this["delete"](toDelete,opt));}
 return resp;},clear:function(){this.db.execute("DELETE FROM "+this.tableName);},callUserCallback:function(options,resp){var opt=options[resp.requestType];if(opt&&opt.callback){opt.callback.call(opt.scope,resp);}
-if(resp.last&&options.callback){options.callback.call(options.scope);}},CLASS_NAME:"OpenLayers.Protocol.SQL.Gears"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
+if(resp.last&&options.callback){options.callback.call(options.scope);}},CLASS_NAME:"OpenLayers.Protocol.SQL.Gears"});OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
+if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
+this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
+if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
+window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
+var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
+this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
+if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,O
 verlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,initialize:function(div,options){if(argu
 ments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
+this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
+OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.viewPortDiv.appendChild(this.layerContainerDiv);this.events=new OpenLayers.Events(this,this.viewPortDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
+if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0,len=nodes.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
+if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
+if(this.controls==null){if(OpenLayers.Control!=null){this.controls=[new OpenLayers.Control.Navigation(),new OpenLayers.Control.PanZoom(),new OpenLayers.Control.ArgParser(),new OpenLayers.Control.Attribution()];}else{this.controls=[];}}
+for(var i=0,len=this.controls.length;i<len;i++){this.addControlToMap(this.controls[i]);}
+this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);if(options&&options.layers){this.addLayers(options.layers);if(options.center){this.setCenter(options.center,options.zoom);}}},render:function(div){this.div=OpenLayers.Util.getElement(div);OpenLayers.Element.addClass(this.div,'olMap');this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize();},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
+if(this.panTween){this.panTween.stop();this.panTween=null;}
+OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
+this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
+this.controls=null;}
+if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
+this.layers=null;}
+if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
+this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
+this.events.destroy();this.events=null;},setOptions:function(options){OpenLayers.Util.extend(this,options);},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
+return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
++zIdx*5);},resetLayersZIndex:function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0,len=this.layers.length;i<len;i++){if(this.layers[i]==layer){var msg=OpenLayers.i18n('layerAlreadyAdded',{'layerName':layer.name});OpenLayers.Console.warn(msg);return false;}}
+if(this.allOverlays){layer.isBaseLayer=false;}
+if(this.events.triggerEvent("preaddlayer",{layer:layer})===false){return;}
+layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
+this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer||(this.allOverlays&&!this.baseLayer)){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
+this.events.triggerEvent("addlayer",{layer:layer});layer.events.triggerEvent("added",{map:this,layer:layer});layer.afterAdd();},addLayers:function(layers){for(var i=0,len=layers.length;i<len;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
+OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0,len=this.layers.length;i<len;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer||this.allOverlays){this.setBaseLayer(iLayer);break;}}}}
+this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});layer.events.triggerEvent("removed",{map:this,layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
+if(base!=idx){this.layers.splice(base,1);this.layers.splice(idx,0,layer);for(var i=0,len=this.layers.length;i<len;i++){this.setLayerZIndex(this.layers[i],i);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"order"});if(this.allOverlays){if(idx===0){this.setBaseLayer(layer);}else if(this.baseLayer!==this.layers[0]){this.setBaseLayer(this.layers[0]);}}}},raiseLayer:function(layer,delta){var idx=this.getLayerIndex(layer)+delta;this.setLayerIndex(layer,idx);},setBaseLayer:function(newBaseLayer){if(newBaseLayer!=this.baseLayer){if(OpenLayers.Util.indexOf(this.layers,newBaseLayer)!=-1){var center=this.getCenter();var newResolution=OpenLayers.Util.getResolutionFromScale(this.getScale(),newBaseLayer.units);if(this.baseLayer!=null&&!this.allOverlays){this.baseLayer.setVisibility(false);}
+this.baseLayer=newBaseLayer;this.viewRequestID++;if(!this.allOverlays||this.baseLayer.visibility){this.baseLayer.setVisibility(true);}
+if(center!=null){var newZoom=this.getZoomForResolution(newResolution||this.resolution,true);this.setCenter(center,newZoom,false,true);}
+this.events.triggerEvent("changebaselayer",{layer:this.baseLayer});}}},addControl:function(control,px){this.controls.push(control);this.addControlToMap(control,px);},addControls:function(controls,pixels){var pxs=(arguments.length===1)?[]:pixels;for(var i=0,len=controls.length;i<len;i++){var ctrl=controls[i];var px=(pxs[i])?pxs[i]:null;this.addControl(ctrl,px);}},addControlToMap:function(control,px){control.outsideViewport=(control.div!=null);if(this.displayProjection&&!control.displayProjection){control.displayProjection=this.displayProjection;}
+control.setMap(this);var div=control.draw(px);if(div){if(!control.outsideViewport){div.style.zIndex=this.Z_INDEX_BASE['Control']+
+this.controls.length;this.viewPortDiv.appendChild(div);}}
+if(control.autoActivate){control.activate();}},getControl:function(id){var returnControl=null;for(var i=0,len=this.controls.length;i<len;i++){var control=this.controls[i];if(control.id==id){returnControl=control;break;}}
+return returnControl;},removeControl:function(control){if((control)&&(control==this.getControl(control.id))){if(control.div&&(control.div.parentNode==this.viewPortDiv)){this.viewPortDiv.removeChild(control.div);}
+OpenLayers.Util.removeItem(this.controls,control);}},addPopup:function(popup,exclusive){if(exclusive){for(var i=this.popups.length-1;i>=0;--i){this.removePopup(this.popups[i]);}}
+popup.map=this;this.popups.push(popup);var popupDiv=popup.draw();if(popupDiv){popupDiv.style.zIndex=this.Z_INDEX_BASE['Popup']+
+this.popups.length;this.layerContainerDiv.appendChild(popupDiv);}},removePopup:function(popup){OpenLayers.Util.removeItem(this.popups,popup);if(popup.div){try{this.layerContainerDiv.removeChild(popup.div);}
+catch(e){}}
+popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
+return size;},updateSize:function(){var newSize=this.getCurrentSize();if(newSize&&!isNaN(newSize.h)&&!isNaN(newSize.w)){this.events.clearMouseCache();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
+if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0,len=this.layers.length;i<len;i++){this.layers[i].onMapResize();}
+var center=this.getCenter();if(this.baseLayer!=null&&center!=null){var zoom=this.getZoom();this.zoom=null;this.setCenter(center,zoom);}}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=this.div.offsetWidth;size.h=this.div.offsetHeight;}
+if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
+return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCenter();}
+if(resolution==null){resolution=this.getResolution();}
+if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
+return extent;},getCenter:function(){var center=null;if(this.center){center=this.center.clone();}
+return center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
+var center=this.getCenter();if(lonlat.lon==center.lon&&lonlat.lat==center.lat){return;}
+var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,this.panDuration,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
+if(zoom!=null){zoom=parseFloat(zoom);if(!this.fractionalZoom){zoom=Math.round(zoom);}}
+var dragging=options.dragging;var forceZoomChange=options.forceZoomChange;var noEvent=options.noEvent;if(this.panTween&&options.caller=="setCenter"){this.panTween.stop();}
+if(!this.center&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();}
+if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.getCenter();}
+if(zoom==null){zoom=this.getZoom();}
+var resolution=this.getResolutionForZoom(zoom);var extent=this.calculateBounds(lonlat,resolution);if(!this.restrictedExtent.containsBounds(extent)){var maxCenter=this.restrictedExtent.getCenterLonLat();if(extent.getWidth()>this.restrictedExtent.getWidth()){lonlat=new OpenLayers.LonLat(maxCenter.lon,lonlat.lat);}else if(extent.left<this.restrictedExtent.left){lonlat=lonlat.add(this.restrictedExtent.left-
+extent.left,0);}else if(extent.right>this.restrictedExtent.right){lonlat=lonlat.add(this.restrictedExtent.right-
+extent.right,0);}
+if(extent.getHeight()>this.restrictedExtent.getHeight()){lonlat=new OpenLayers.LonLat(lonlat.lon,maxCenter.lat);}else if(extent.bottom<this.restrictedExtent.bottom){lonlat=lonlat.add(0,this.restrictedExtent.bottom-
+extent.bottom);}
+else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
+extent.top);}}}
+var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||!dragging){if(!this.dragging&&!noEvent){this.events.triggerEvent("movestart");}
+if(centerChanged){if((!zoomChanged)&&(this.center)){this.centerLayerContainer(lonlat);}
+this.center=lonlat.clone();}
+if((zoomChanged)||(this.layerContainerOrigin==null)){this.layerContainerOrigin=this.center.clone();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";}
+if(zoomChanged){this.zoom=zoom;this.resolution=this.getResolutionForZoom(zoom);this.viewRequestID++;}
+var bounds=this.getExtent();if(this.baseLayer.visibility){this.baseLayer.moveTo(bounds,zoomChanged,dragging);if(dragging){this.baseLayer.events.triggerEvent("move");}else{this.baseLayer.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});}}
+bounds=this.baseLayer.getExtent();for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer!==this.baseLayer&&!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
+if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,dragging);if(dragging){layer.events.triggerEvent("move");}else{layer.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});}}}}
+if(zoomChanged){for(var i=0,len=this.popups.length;i<len;i++){this.popups[i].updatePosition();}}
+this.events.triggerEvent("move");if(zoomChanged){this.events.triggerEvent("zoomend");}}
+if(!dragging&&!noEvent){this.events.triggerEvent("moveend");}
+this.dragging=!!dragging;},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){this.layerContainerDiv.style.left=Math.round(originPx.x-newPx.x)+"px";this.layerContainerDiv.style.top=Math.round(originPx.y-newPx.y)+"px";}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=this.getRestrictedMinZoom())&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
+return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
+return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
+return maxResolution;},getMaxExtent:function(options){var maxExtent=null;if(options&&options.restricted&&this.restrictedExtent){maxExtent=this.restrictedExtent;}else if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
+return maxExtent;},getRestrictedMinZoom:function(){var minZoom=null;if(this.baseLayer!=null){minZoom=this.baseLayer.restrictedMinZoom;}
+return minZoom;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
+return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
+return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}else if(this.allOverlays===true&&this.layers.length>0){resolution=this.layers[0].getResolution();}
+return resolution;},getUnits:function(){var units=null;if(this.baseLayer!=null){units=this.baseLayer.units;}
+return units;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
+return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
+return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
+return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds,closest){var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
+center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
+this.setCenter(center,this.getZoomForExtent(bounds,closest));},zoomToMaxExtent:function(options){var restricted=(options)?options.restricted:true;var maxExtent=this.getMaxExtent({'restricted':restricted});this.zoomToExtent(maxExtent);},zoomToScale:function(scale,closest){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var size=this.getSize();var w_deg=size.w*res;var h_deg=size.h*res;var center=this.getCenter();var extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);this.zoomToExtent(extent,closest);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
+return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
+return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
+return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(window.Proj4js&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p
 .getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Projection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
+return equals;},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
+OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
+return point;};OpenLayers.Projection.nullTransform=function(point){return point;};OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,restrictedMinZoom:0,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=n
 ame;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
+if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
+this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();}
+this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.getOptions());}
+OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},getOptions:function(){var options={};for(var o in this.options){options[o]=this[o];}
+return options;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions){if(this.options==null){this.options={};}
+OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+if(this.projection&&this.projection.getUnits()){this.units=this.projection.getUnits();}
+if(this.map){var properties=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]);for(var o in newOptions){if(newOptions.hasOwnProperty(o)&&OpenLayers.Util.indexOf(properties,o)>=0){this.initResolutions();break;}}}},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){var zoomChanged=true;this.moveTo(extent,zoomChanged,false);this.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});redrawn=true;}}
+return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
+this.display(display);},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
+this.setTileSize();}},afterAdd:function(){},removeMap:function(map){},getImageSize:function(bounds){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
+this.events.triggerEvent("visibilitychanged");}},display:function(display){if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&this.calculateInRange())?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.alwaysInRange){inRange=true;}else{if(this.map){var resolution=this.map.getResolution();inRange=(this.map.getZoom()>=this.restrictedMinZoom&&(resolution>=this.minResolution)&&(resolution<=this.maxResolution));}}
+return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var i,len;var props={},alwaysInRange=true;for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){var p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p];if(alwaysInRange&&this.options[p]){alwaysInRange=false;}}
+if(this.alwaysInRange==null){this.alwaysInRange=alwaysInRange;}
+if(props.resolutions==null){props.resolutions=this.resolutionsFromScales(props.scales);}
+if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}
+if(props.resolutions==null){for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){var p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p]!=null?this.options[p]:this.map[p];}
+if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}}
+var maxResolution;if(this.options.maxResolution&&this.options.maxResolution!=="auto"){maxResolution=this.options.maxResolution;}
+if(this.options.minScale){maxResolution=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units);}
+var minResolution;if(this.options.minResolution&&this.options.minResolution!=="auto"){minResolution=this.options.minResolution;}
+if(this.options.maxScale){minResolution=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units);}
+if(props.resolutions){props.resolutions.sort(function(a,b){return(b-a);});if(!maxResolution){maxResolution=props.resolutions[0];}
+if(!minResolution){var lastIdx=props.resolutions.length-1;minResolution=props.resolutions[lastIdx];}}
+this.resolutions=props.resolutions;if(this.resolutions){len=this.resolutions.length;this.scales=new Array(len);for(i=0;i<len;i++){this.scales[i]=OpenLayers.Util.getScaleFromResolution(this.resolutions[i],this.units);}
+this.numZoomLevels=len;}
+this.minResolution=minResolution;if(minResolution){this.maxScale=OpenLayers.Util.getScaleFromResolution(minResolution,this.units);}
+this.maxResolution=maxResolution;if(maxResolution){this.minScale=OpenLayers.Util.getScaleFromResolution(maxResolution,this.units);}},resolutionsFromScales:function(scales){if(scales==null){return;}
+var resolutions,i,len;len=scales.length;resolutions=new Array(len);for(i=0;i<len;i++){resolutions[i]=OpenLayers.Util.getResolutionFromScale(scales[i],this.units);}
+return resolutions;},calculateResolutions:function(props){var maxResolution=props.maxResolution;if(props.minScale!=null){maxResolution=OpenLayers.Util.getResolutionFromScale(props.minScale,this.units);}else if(maxResolution=="auto"&&this.maxExtent!=null){var viewSize=this.map.getSize();var wRes=this.maxExtent.getWidth()/viewSize.w;var hRes=this.maxExtent.getHeight()/viewSize.h;maxResolution=Math.max(wRes,hRes);}
+var minResolution=props.minResolution;if(props.maxScale!=null){minResolution=OpenLayers.Util.getResolutionFromScale(props.maxScale,this.units);}else if(props.minResolution=="auto"&&this.minExtent!=null){var viewSize=this.map.getSize();var wRes=this.minExtent.getWidth()/viewSize.w;var hRes=this.minExtent.getHeight()/viewSize.h;minResolution=Math.max(wRes,hRes);}
+var maxZoomLevel=props.maxZoomLevel;var numZoomLevels=props.numZoomLevels;if(typeof minResolution==="number"&&typeof maxResolution==="number"&&numZoomLevels===undefined){var ratio=maxResolution/minResolution;numZoomLevels=Math.floor(Math.log(ratio)/Math.log(2))+1;}else if(numZoomLevels===undefined&&maxZoomLevel!=null){numZoomLevels=maxZoomLevel+1;}
+if(typeof numZoomLevels!=="number"||numZoomLevels<=0||(typeof maxResolution!=="number"&&typeof minResolution!=="number")){return;}
+var resolutions=new Array(numZoomLevels);var base=2;if(typeof minResolution=="number"&&typeof maxResolution=="number"){base=Math.pow((maxResolution/minResolution),(1/(numZoomLevels-1)));}
+var i;if(typeof maxResolution==="number"){for(i=0;i<numZoomLevels;i++){resolutions[i]=maxResolution/Math.pow(base,i);}}else{for(i=0;i<numZoomLevels;i++){resolutions[numZoomLevels-1-i]=minResolution*Math.pow(base,i);}}
+return resolutions;},getResolution:function(){var zoom=this.map.getZoom();return this.getResolutionForZoom(zoom);},getExtent:function(){return this.map.calculateBounds();},getZoomForExtent:function(extent,closest){var viewSize=this.map.getSize();var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);return this.getZoomForResolution(idealResolution,closest);},getDataExtent:function(){},getResolutionForZoom:function(zoom){zoom=Math.max(0,Math.min(zoom,this.resolutions.length-1));var resolution;if(this.map.fractionalZoom){var low=Math.floor(zoom);var high=Math.ceil(zoom);resolution=this.resolutions[low]-
+((zoom-low)*(this.resolutions[low]-this.resolutions[high]));}else{resolution=this.resolutions[Math.round(zoom)];}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom;if(this.map.fractionalZoom){var lowZoom=0;var highZoom=this.resolutions.length-1;var highRes=this.resolutions[lowZoom];var lowRes=this.resolutions[highZoom];var res;for(var i=0,len=this.resolutions.length;i<len;++i){res=this.resolutions[i];if(res>=resolution){highRes=res;lowZoom=i;}
+if(res<=resolution){lowRes=res;highZoom=i;break;}}
+var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((highRes-resolution)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(var i=0,len=this.resolutions.length;i<len;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
+minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
+zoom=Math.max(0,i-1);}
+return Math.max(this.restrictedMinZoom,zoom);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(viewPortPx!=null){var size=this.map.getSize();var center=this.map.getCenter();if(center){var res=this.map.getResolution();var delta_x=viewPortPx.x-(size.w/2);var delta_y=viewPortPx.y-(size.h/2);lonlat=new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(lonlat!=null){var resolution=this.map.getResolution();var extent=this.map.getExtent();px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
+return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.div.childNodes.length;i<len;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}
+if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}}},getZIndex:function(){return this.div.style.zIndex;},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
+if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
+return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
+return extent;},getLonLatFromViewPortPx:function(viewPortPx){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments);},getViewPortPxFromLonLat:function(lonlat){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments);},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.03390625;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
+this.units="m";this.projection=this.projection||"EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};(function(){var codes=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"];var add=OpenLayers.Projection.addTransform;var merc=OpenLayers.Layer.SphericalMercator;var same=OpenLayers.Projection.nullTransform;var i,len,code,oth
 er,j;for(i=0,len=codes.length;i<len;++i){code=codes[i];add("EPSG:4326",code,merc.projectForward);add(code,"EPSG:4326",merc.projectInverse);for(j=i+1;j<len;++j){other=codes[j];add(code,other,same);add(other,code,same);}}})();OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;this.pane=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.BROWSER_NAME=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLo
 cation()+"blank.gif)";}
+if(this.isFixed){this.map.viewPortDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
+this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);}
+OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.ap
 ply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(dragging&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFr
 omMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
+return viewPortPx;},getOLLonLatFromMapObjectLonLat:function(moLonLat){var olLonLat=null;if(moLonLat!=null){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);olLonLat=new OpenLayers.LonLat(lon,lat);}
+return olLonLat;},getMapObjectLonLatFromOLLonLat:function(olLonLat){var moLatLng=null;if(olLonLat!=null){moLatLng=this.getMapObjectLonLatFromLonLat(olLonLat.lon,olLonLat.lat);}
+return moLatLng;},getOLPixelFromMapObjectPixel:function(moPixel){var olPixel=null;if(moPixel!=null){var x=this.getXFromMapObjectPixel(moPixel);var y=this.getYFromMapObjectPixel(moPixel);olPixel=new OpenLayers.Pixel(x,y);}
+return olPixel;},getMapObjectPixelFromOLPixel:function(olPixel){var moPixel=null;if(olPixel!=null){moPixel=this.getMapObjectPixelFromXY(olPixel.x,olPixel.y);}
+return moPixel;},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){var props=new Array('minZoomLevel','maxZoomLevel','numZoomLevels');for(var i=0,len=props.length;i<len;i++){var property=props[i];this[property]=(this.options[property]!=null)?this.options[property]:this.map[property];}
+if((this.minZoomLevel==null)||(this.minZoomLevel<this.MIN_ZOOM_LEVEL)){this.minZoomLevel=this.MIN_ZOOM_LEVEL;}
+var desiredZoomLevels;var limitZoomLevels=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;if(((this.options.numZoomLevels==null)&&(this.options.maxZoomLevel!=null))||((this.numZoomLevels==null)&&(this.maxZoomLevel!=null))){desiredZoomLevels=this.maxZoomLevel-this.minZoomLevel+1;}else{desiredZoomLevels=this.numZoomLevels;}
+if(desiredZoomLevels!=null){this.numZoomLevels=Math.min(desiredZoomLevels,limitZoomLevels);}else{this.numZoomLevels=limitZoomLevels;}
+this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
+this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
+return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
+return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;}
+return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;}
+return zoom;},CLASS_NAME:"OpenLayers.Layer.FixedZoomLevels"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515],type:null,wrapDateLine:true,sphericalMercator:false,animationEnabled:true,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var
  sz=this.map.getSize();veDiv.style.width=sz.w+"px";veDiv.style.height=sz.h+"px";this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
+if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",OpenLayers.Function.True);}catch(e){}
+this.mapObject.HideDashboard();if(typeof this.mapObject.SetAnimationEnabled=="function"){this.mapObject.SetAnimationEnabled(this.animationEnabled);}}
+if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},onMapResize:function(){this.mapObject.Resize(this.map.size.w,this.map.size.h);},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return(typeof VEPixel!='undefined')?this.mapObject.PixelToLatLong(moPixel):this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:f
 unction(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
+return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return(typeof VEPixel!='undefined')?new VEPixel(x,y):new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
+if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
+this.handlers=null;}
+if(this.map){this.map.removeControl(this);this.map=null;}},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
+if(this.title!=""){this.div.title=this.title;}}
+if(px!=null){this.position=px.clone();}
+this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
+if(this.handler){this.handler.activate();}
+this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
+this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("deactivate");return true;}
+return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,autoPan:false,handlers:null,resolutionFactor:1,maximized:false,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
+if(this.handlers.click){this.handlers.click.destroy();}
+if(this.handlers.drag){this.handlers.drag.destroy();}
+this.ovmap&&this.ovmap.viewPortDiv.removeChild(this.extentRectangle);this.extentRectangle=null;if(this.rectEvents){this.rectEvents.destroy();this.rectEvents=null;}
+if(this.ovmap){this.ovmap.destroy();this.ovmap=null;}
+this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
+if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
+this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
+this.element=document.createElement('div');this.element.className=this.displayClass+'Element';this.element.style.display='none';this.mapDiv=document.createElement('div');this.mapDiv.style.width=this.size.w+'px';this.mapDiv.style.height=this.size.h+'px';this.mapDiv.style.position='relative';this.mapDiv.style.overflow='hidden';this.mapDiv.id=OpenLayers.Util.createUniqueID('overviewMap');this.extentRectangle=document.createElement('div');this.extentRectangle.style.position='absolute';this.extentRectangle.style.zIndex=1000;this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(!this.outsideViewport){this.div.className+=" "+this.displayClass+'Container';var imgLocation=OpenLayers.Util.getImagesLocation();var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+'MaximizeButton',null,new OpenLayers.Size(18,18),img,'absolute');this.m
 aximizeDiv.style.display='none';this.maximizeDiv.className=this.displayClass+'MaximizeButton';OpenLayers.Event.observe(this.maximizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv('OpenLayers_Control_minimizeDiv',null,new OpenLayers.Size(18,18),img,'absolute');this.minimizeDiv.style.display='none';this.minimizeDiv.className=this.displayClass+'MinimizeButton';OpenLayers.Event.observe(this.minimizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);var eventsToStop=['dblclick','mousedown'];for(var i=0,len=eventsToStop.length;i<len;i++){OpenLayers.Event.observe(this.maximizeDiv,eventsToStop[i],OpenLayers.Event.stop);OpenLayers.Event.observe(this.minimizeDiv,eventsToStop[i],OpenLayers.Event.stop);}
+this.minimizeControl();}else{this.element.style.display='';}
+if(this.map.getExtent()){this.update();}
+this.map.events.register('moveend',this,this.update);if(this.maximized){this.maximizeControl();}
+return this.div;},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw);},rectDrag:function(px){var deltaX=this.handlers.drag.last.x-px.x;var deltaY=this.handlers.drag.last.y-px.y;if(deltaX!=0||deltaY!=0){var rectTop=this.rectPxBounds.top;var rectLeft=this.rectPxBounds.left;var rectHeight=Math.abs(this.rectPxBounds.getHeight());var rectWidth=this.rectPxBounds.getWidth();var newTop=Math.max(0,(rectTop-deltaY));newTop=Math.min(newTop,this.ovmap.size.h-this.hComp-rectHeight);var newLeft=Math.max(0,(rectLeft-deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-this.wComp-rectWidth);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+rectHeight,newLeft+rectWidth,newTop));}},mapDivClick:function(evt){var pxCenter=this.rectPxBounds.getCenterPixel();var deltaX=evt.xy.x-pxCenter.x;var deltaY=evt.xy.y-pxCenter.y;var top=this.rectPxBounds.top;var left=this.rectPxBounds.left;var height=Math.abs(this.rectPxBounds.getHeight());var
 width=this.rectPxBounds.getWidth();var newTop=Math.max(0,(top+deltaY));newTop=Math.min(newTop,this.ovmap.size.h-height);var newLeft=Math.max(0,(left+deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-width);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+height,newLeft+width,newTop));this.updateMapToRect();},maximizeControl:function(e){this.element.style.display='';this.showToggle(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.element.style.display='none';this.showToggle(true);if(e!=null){OpenLayers.Event.stop(e);}},showToggle:function(minimize){this.maximizeDiv.style.display=minimize?'':'none';this.minimizeDiv.style.display=minimize?'none':'';},update:function(){if(this.ovmap==null){this.createMap();}
+if(this.autoPan||!this.isSuitableOverview()){this.updateOverview();}
+this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));if(this.ovmap.getProjection()!=this.map.getProjection()){testExtent=testExtent.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}
+var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
+var center;if(this.ovmap.getProjection()!=this.map.getProjection()){center=this.map.center.clone();center.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}else{center=this.map.center;}
+this.ovmap.setCenter(center,this.ovmap.getZoomForResolution(targetRes*this.resolutionFactor));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);this.ovmap.viewPortDiv.appendChild(this.extentRectangle);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});if(this.ovmap.getProjection()!=this.map.getProjection()){var sourceUnits=this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units;var targetUnits=this.ovmap.getProjectionObject
 ().getUnits()||this.ovmap.units||this.ovmap.baseLayer.units;this.resolutionFactor=sourceUnits&&targetUnits?OpenLayers.INCHES_PER_UNIT[sourceUnits]/OpenLayers.INCHES_PER_UNIT[targetUnits]:1;}},updateRectToMap:function(){var bounds;if(this.ovmap.getProjection()!=this.map.getProjection()){bounds=this.map.getExtent().transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}else{bounds=this.map.getExtent();}
+var pxBounds=this.getRectBoundsFromMapBounds(bounds);if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);if(this.ovmap.getProjection()!=this.map.getProjection()){lonLatBounds=lonLatBounds.transform(this.ovmap.getProjectionObject(),this.map.getProjectionObject());}
+this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
+this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
+this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
+return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat))
+return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:21,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257,0.0000013411045074462891,0.00000067055225372314453],type:null,wrapDateLine:true,sphericalMercator:false,version:null,initialize:function(name,options){options=options||{};if(!options.version){options.version=typeof GMap2==="function"?"2":"3";}
+var mixin=OpenLayers.Layer.Google["v"+
+options.version.replace(/\./g,"_")];if(mixin){OpenLayers.Util.applyDefaults(options,mixin);}else{throw"Unsupported Google Maps API version: "+options.version;}
+OpenLayers.Util.applyDefaults(options,mixin.DEFAULTS);if(options.maxExtent){options.maxExtent=options.maxExtent.clone();}
+OpenLayers.Layer.EventPane.prototype.initialize.apply(this,[name,options]);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,[name,options]);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},clone:function(){return new OpenLayers.Layer.Google(this.name,this.getOptions());},setVisibility:function(visible){var opacity=this.opacity==null?1:this.opacity;OpenLayers.Layer.EventPane.prototype.setVisibility.apply(this,arguments);this.setOpacity(opacity);},display:function(visible){if(!this._dragging){this.setGMapVisibility(visible);}
+OpenLayers.Layer.EventPane.prototype.display.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){this._dragging=dragging;OpenLayers.Layer.EventPane.prototype.moveTo.apply(this,arguments);delete this._dragging;},setOpacity:function(opacity){if(opacity!==this.opacity){if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}
+this.opacity=opacity;}
+if(this.getVisibility()){var container=this.getMapContainer();OpenLayers.Util.modifyDOMElement(container,null,null,null,null,null,null,opacity);}},destroy:function(){if(this.map){this.setGMapVisibility(false);var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache&&cache.count<=1){this.removeGMapElements();}}
+OpenLayers.Layer.EventPane.prototype.destroy.apply(this,arguments);},removeGMapElements:function(){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject&&this.getMapContainer();if(container&&container.parentNode){container.parentNode.removeChild(container);}
+var termsOfUse=cache.termsOfUse;if(termsOfUse&&termsOfUse.parentNode){termsOfUse.parentNode.removeChild(termsOfUse);}
+var poweredBy=cache.poweredBy;if(poweredBy&&poweredBy.parentNode){poweredBy.parentNode.removeChild(poweredBy);}}},removeMap:function(map){if(this.visibility&&this.mapObject){this.setGMapVisibility(false);}
+var cache=OpenLayers.Layer.Google.cache[map.id];if(cache){if(cache.count<=1){this.removeGMapElements();delete OpenLayers.Layer.Google.cache[map.id];}else{--cache.count;}}
+delete this.termsOfUse;delete this.poweredBy;delete this.mapObject;delete this.dragObject;OpenLayers.Layer.EventPane.prototype.removeMap.apply(this,arguments);},getOLBoundsFromMapObjectBounds:function(moBounds){var olBounds=null;if(moBounds!=null){var sw=moBounds.getSouthWest();var ne=moBounds.getNorthEast();if(this.sphericalMercator){sw=this.forwardMercator(sw.lng(),sw.lat());ne=this.forwardMercator(ne.lng(),ne.lat());}else{sw=new OpenLayers.LonLat(sw.lng(),sw.lat());ne=new OpenLayers.LonLat(ne.lng(),ne.lat());}
+olBounds=new OpenLayers.Bounds(sw.lon,sw.lat,ne.lon,ne.lat);}
+return olBounds;},getWarningHTML:function(){return OpenLayers.i18n("googleWarning");},getMapObjectCenter:function(){return this.mapObject.getCenter();},getMapObjectZoom:function(){return this.mapObject.getZoom();},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lon:moLonLat.lng();},getLatitudeFromMapObjectLonLat:function(moLonLat){var lat=this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lat:moLonLat.lat();return lat;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Google.cache={};OpenLayers.Layer.Google.v2={termsOfUse:null,poweredBy:null,dragObject:null,loadMapObject:function(){if(!this.type){this.type=G_NORMAL_MAP;}
+var mapObject,termsOfUse,poweredBy;var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){mapObject=cache.mapObject;termsOfUse=cache.termsOfUse;poweredBy=cache.poweredBy;++cache.count;}else{var container=this.map.viewPortDiv;var div=document.createElement("div");div.id=this.map.id+"_GMap2Container";div.style.position="absolute";div.style.width="100%";div.style.height="100%";container.appendChild(div);try{mapObject=new GMap2(div);termsOfUse=div.lastChild;container.appendChild(termsOfUse);termsOfUse.style.zIndex="1100";termsOfUse.style.right="";termsOfUse.style.bottom="";termsOfUse.className="olLayerGoogleCopyright";poweredBy=div.lastChild;container.appendChild(poweredBy);poweredBy.style.zIndex="1100";poweredBy.style.right="";poweredBy.style.bottom="";poweredBy.className="olLayerGooglePoweredBy gmnoprint";}catch(e){throw(e);}
+OpenLayers.Layer.Google.cache[this.map.id]={mapObject:mapObject,termsOfUse:termsOfUse,poweredBy:poweredBy,count:1};}
+this.mapObject=mapObject;this.termsOfUse=termsOfUse;this.poweredBy=poweredBy;if(OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)===-1){this.mapObject.addMapType(this.type);}
+if(typeof mapObject.getDragObject=="function"){this.dragObject=mapObject.getDragObject();}else{this.dragPanMapObject=null;}
+if(this.isBaseLayer===false){this.setGMapVisibility(this.div.style.display!=="none");}},onMapResize:function(){if(this.visibility&&this.mapObject.isLoaded()){this.mapObject.checkResize();}else{if(!this._resized){var layer=this;var handle=GEvent.addListener(this.mapObject,"load",function(){GEvent.removeListener(handle);delete layer._resized;layer.mapObject.checkResize();layer.moveTo(layer.map.getCenter(),layer.map.getZoom());});}
+this._resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject.getContainer();if(visible===true){this.mapObject.setMapType(this.type);container.style.display="";this.termsOfUse.style.left="";this.termsOfUse.style.display="";this.poweredBy.style.display="";cache.displayed=this.id;}else{if(cache.displayed===this.id){delete cache.displayed;}
+if(!cache.displayed){container.style.display="none";this.termsOfUse.style.display="none";this.termsOfUse.style.left="-9999px";this.poweredBy.style.display="none";}}}},getMapContainer:function(){return this.mapObject.getContainer();},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
+return moBounds;},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
+return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);}};OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:false,propertyStyles:null,initialize:function(style,options){OpenLayers.Util.extend(this,options);this.rules=[];if(options&&options.rules){this.addRules(options.rules);}
+this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();this.rules[i]=null;}
+this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0,len=rules.length;i<len;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
+if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0,len=elseRules.length;i<len;i++){this.applySymbolizer(elseRules[i],style,feature);}}
+if(rules.length>0&&appliedRules==false){style.display="none";}
+return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;if(this.defaultsPerSymbolizer===true){var defaults=this.defaultStyle;OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:defaults.pointRadius});if(symbolizer.stroke===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{strokeWidth:defaults.strokeWidth,strokeColor:defaults.strokeColor,strokeOpacity:defaults.strokeOpacity,strokeDashstyle:defaults.strokeDashstyle,strokeLinecap:defaults.strokeLinecap});}
+if(symbolizer.fill===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{fillColor:defaults.fillColor,fillOpacity:defaults.fillOpacity});}
+if(symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset});}}
+return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=OpenLayers.Util.extend({},feature.attributes||feature.data);OpenLayers.Util.extend(context,this.context);for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature,i);}
+return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0,len=rules.length;i<len;i++){symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
+return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
+return propertyStyles;},addRules:function(rules){Array.prototype.push.apply(this.rules,rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=prefixes.length;i<len;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.rules){options.rules=[];for(var i=0,len=this.rules.length;i<len;++i){options.rules.push(this.rules[i].clone());}}
+options.context=this.context&&OpenLayers.Util.extend({},this.context);var defaultStyle=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(defaultStyle,options);},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature,property){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature,property]);value=(isNaN(value)||!value)?value:parseFloat(value);}
+return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon','Text','Raster'];OpenLayers.Symbolizer=OpenLayers.Class({zIndex:0,initialize:function(config){OpenLayers.Util.extend(this,config);},clone:function(){var Type=eval(this.CLASS_NAME);return new Type(OpenLayers.Util.extend({},this));},CLASS_NAME:"OpenLayers.Symbolizer"});OpenLayers.Symbolizer.Point=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Point"});OpenLayers.Symbolizer.Line=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Line"});OpenLayers.Symbolizer.Polygon=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Polygon"});OpenLayers.Symbolizer.T
 ext=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Text"});OpenLayers.Symbolizer.Raster=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Raster"});OpenLayers.Rule=OpenLayers.Class({id:null,name:null,title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,symbolizers:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.symbolizer={};OpenLayers.Util.extend(this,options);if(this.symbolizers){delete this.symbolizer;}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
+this.symbolizer=null;delete this.symbolizers;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
+if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
+if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
+if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
+return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
+if(typeof this.context=="function"){context=this.context(feature);}
+return context;},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.symbolizers){var len=this.symbolizers.length;options.symbolizers=new Array(len);for(var i=0;i<len;++i){options.symbolizers[i]=this.symbolizers[i].clone();}}else{options.symbolizer={};var value,type;for(var key in this.symbolizer){value=this.symbolizer[key];type=typeof value;if(type==="object"){options.symbolizer[key]=OpenLayers.Util.extend({},value);}else if(type==="string"){options.symbolizer[key]=value;}}}
+options.filter=this.filter&&this.filter.clone();options.context=this.context&&OpenLayers.Util.extend({},this.context);return new OpenLayers.Rule(options);},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
 OpenLayers.Format.prototype.initialize.apply(this,[options]);this.namespaces=OpenLayers.Util.extend({},this.namespaces);this.namespaceAlias={};for(var alias in this.namespaces){this.namespaceAlias[this.namespaces[alias]]=alias;}},destroy:function(){this.xmldom=null;OpenLayers.Format.prototype.destroy.apply(this,arguments);},setNamespace:function(alias,uri){this.namespaces[alias]=uri;this.namespaceAlias[uri]=alias;},read:function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
 var node=OpenLayers.Util.Try(OpenLayers.Function.bind((function(){var xmldom;if(window.ActiveXObject&&!this.xmldom){xmldom=new ActiveXObject("Microsoft.XMLDOM");}else{xmldom=this.xmldom;}
 xmldom.loadXML(text);return xmldom;}),this),function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
@@ -543,7 +811,28 @@
 return sibling||null;},lookupNamespaceURI:function(node,prefix){var uri=null;if(node){if(node.lookupNamespaceURI){uri=node.lookupNamespaceURI(prefix);}else{outer:switch(node.nodeType){case 1:if(node.namespaceURI!==null&&node.prefix===prefix){uri=node.namespaceURI;break outer;}
 var len=node.attributes.length;if(len){var attr;for(var i=0;i<len;++i){attr=node.attributes[i];if(attr.prefix==="xmlns"&&attr.name==="xmlns:"+prefix){uri=attr.value||null;break outer;}else if(attr.name==="xmlns"&&prefix===null){uri=attr.value||null;break outer;}}}
 uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;case 2:uri=this.lookupNamespaceURI(node.ownerElement,prefix);break outer;case 9:uri=this.lookupNamespaceURI(node.documentElement,prefix);break outer;case 6:case 12:case 10:case 11:break outer;default:uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;}}}
-return uri;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
+return uri;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},clone:function(){return null;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0,len=this.fids.length;i<len;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
+return false;},clone:function(){var filter=new OpenLayers.Filter.FeatureId();OpenLayers.Util.extend(filter,this);filter.fids=this.fids.slice();return filter;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){var i,len;switch(this.type){case OpenLayers.Filter.Logical.AND:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==false){return false;}}
+return true;case OpenLayers.Filter.Logical.OR:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==true){return true;}}
+return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}
+return undefined;},clone:function(){var filters=[];for(var i=0,len=this.filters.length;i<len;++i){filters.push(this.filters[i].clone());}
+return new OpenLayers.Filter.Logical({type:this.type,filters:filters});},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:true,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(context){if(context instanceof OpenLayers.Feature.Vector){context=context.attributes;}
+var result=false;var got=context[this.property];var exp;switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()==exp.toUpperCase());}else{result=(got==exp);}
+break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()!=exp.toUpperCase());}else{result=(got!=exp);}
+break;case OpenLayers.Filter.Comparison.LESS_THAN:result=got<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:result=got>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:result=got<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:result=got>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:result=(got>=this.lowerBoundary)&&(got<=this.upperBoundary);break;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");result=regexp.test(got);break;}
+return result;},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
+wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
 QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
+if(feature.geometry.intersects(geom)){intersect=true;}}
+break;default:OpenLayers.Console.error(OpenLayers.i18n("filterEvaluateNotImplemented"));break;}
+return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,namedLayersAsArray:false,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(sld,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
+version;}
+this.parser=new format(this.options);}
+var root=this.parser.write(sld);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
+if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
+version;}
+var sld=this.parser.read(data,options);return sld;},CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
 return this.bounds;},calculateBounds:function(){},distanceTo:function(geometry,options){},getVertices:function(nodes){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
 return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},getCentroid:function(){return null;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(wkt){var format=arguments.callee.format;if(!format){format=new OpenLayers.Format.WKT();arguments.callee.format=format;}
 var geom;var result=format.read(wkt);if(result instanceof OpenLayers.Feature.Vector){geom=result.geometry;}else if(result instanceof Array){var len=result.length;var components=new Array(len);for(var i=0;i<len;++i){components[i]=result[i].geometry;}
@@ -620,7 +909,22 @@
 if(maxDistance>tolerance&&indexFarthest!=firstPoint){pointIndexsToKeep.push(indexFarthest);douglasPeuckerReduction(points,firstPoint,indexFarthest,tolerance);douglasPeuckerReduction(points,indexFarthest,lastPoint,tolerance);}};var perpendicularDistance=function(point1,point2,point){var area=Math.abs(0.5*(point1.x*point2.y+point2.x*point.y+point.x*point1.y-point2.x*point1.y-point.x*point2.y-point1.x*point.y));var bottom=Math.sqrt(Math.pow(point1.x-point2.x,2)+Math.pow(point1.y-point2.y,2));var height=area/bottom*2;return height;};var firstPoint=0;var lastPoint=points.length-1;var pointIndexsToKeep=[];pointIndexsToKeep.push(firstPoint);pointIndexsToKeep.push(lastPoint);while(points[firstPoint].equals(points[lastPoint])){lastPoint--;pointIndexsToKeep.push(lastPoint);}
 douglasPeuckerReduction(points,firstPoint,lastPoint,tolerance);var returnPoints=[];pointIndexsToKeep.sort(compareNumbers);for(var index=0;index<pointIndexsToKeep.length;index++){returnPoints.push(points[pointIndexsToKeep[index]]);}
 return new OpenLayers.Geometry.LineString(returnPoints);}
-else{return this;}},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
+else{return this;}},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];sourceSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.MultiLineString([sourceLines[k]]));}}
+sourceSplit=true;splits=splits[1];}
+if(splits.length){splits.unshift(j,1);Array.prototype.splice.apply(targetParts,splits);break;}}}
+if(!sourceSplit){if(sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLine.clone());}else{sourceParts=[new OpenLayers.Geometry.MultiLineString(sourceLine.clone())];}}}
+if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
+if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
+if(sourceSplit||targetSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
+return results;},splitWith:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,targetLine,sourceLines,sourceSplit,targetSplit,sourceParts,targetParts;if(geometry instanceof OpenLayers.Geometry.LineString){targetParts=[];sourceParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){targetSplit=false;targetLine=this.components[i];for(var j=0;j<sourceParts.length;++j){splits=sourceParts[j].split(targetLine,options);if(splits){if(mutual){sourceLines=splits[0];if(sourceLines.length){sourceLines.unshift(j,1);Array.prototype.splice.apply(sourceParts,sourceLines);j+=sourceLines.length-2;}
+splits=splits[1];if(splits.length===0){splits=[targetLine.clone()];}}
+for(var k=0,klen=splits.length;k<klen;++k){if(k===0&&targetParts.length){targetParts[targetParts.length-1].addComponent(splits[k]);}else{targetParts.push(new OpenLayers.Geometry.MultiLineString([splits[k]]));}}
+targetSplit=true;}}
+if(!targetSplit){if(targetParts.length){targetParts[targetParts.length-1].addComponent(targetLine.clone());}else{targetParts=[new OpenLayers.Geometry.MultiLineString([targetLine.clone()])];}}}}else{results=geometry.split(this);}
+return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
 var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){if(this.components.length>4){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}},move:function(x,y){for(var i=0,len=this.components.length;i<len-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].resize(scale,origin,ratio);}
 return this;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len-1;i++){var component=this.components[i];component.transform(source,dest);}
 this.bounds=null;}
@@ -649,146 +953,7 @@
 return intersect;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var result;if(!edge&&this.intersects(geometry)){result=0;}else{result=OpenLayers.Geometry.Collection.prototype.distanceTo.apply(this,[geometry,options]);}
 return result;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
 var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
-var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this,null,["complete","success","failure"]),issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var request=new OpenLayers.Request.XMLHttpRequest();var url=OpenLayers.Util.urlAppend(config.url,OpenLayers.Util.getParameterString(config.params||{}));var sameOrigin=!(url.indexOf("http")==0);var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protoco
 l&&urlParts[3]==location.hostname;var uPort=urlParts[4],lPort=location.port;if(uPort!=80&&uPort!=""||lPort!="80"&&lPort!=""){sameOrigin=sameOrigin&&uPort==lPort;}}
-if(!sameOrigin){if(config.proxy){if(typeof config.proxy=="function"){url=config.proxy(url);}else{url=config.proxy+encodeURIComponent(url);}}else{OpenLayers.Console.warn(OpenLayers.i18n("proxyNeeded"),{url:url});}}
-request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
-var events=this.events;var self=this;request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){var proceed=events.triggerEvent("complete",{request:request,config:config,requestUrl:url});if(proceed!==false){self.runCallbacks({request:request,config:config,requestUrl:url});}}};if(config.async===false){request.send(config.data);}else{window.setTimeout(function(){if(request.readyState!==0){request.send(config.data);}},0);}
-return request;},runCallbacks:function(options){var request=options.request;var config=options.config;var complete=(config.scope)?OpenLayers.Function.bind(config.callback,config.scope):config.callback;var success;if(config.success){success=(config.scope)?OpenLayers.Function.bind(config.success,config.scope):config.success;}
-var failure;if(config.failure){failure=(config.scope)?OpenLayers.Function.bind(config.failure,config.scope):config.failure;}
-complete(request);if(!request.status||(request.status>=200&&request.status<300)){this.events.triggerEvent("success",options);if(success){success(request);}}
-if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("failure",options);if(failure){failure(request);}}},GET:function(config){config=OpenLayers.Util.extend(config,{method:"GET"});return OpenLayers.Request.issue(config);},POST:function(config){config=OpenLayers.Util.extend(config,{method:"POST"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
-return OpenLayers.Request.issue(config);},PUT:function(config){config=OpenLayers.Util.extend(config,{method:"PUT"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
-return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}};(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera,bIE7=bIE&&window.navigator.userAgent.match(/MSIE 7.0/);function fXMLHttpRequest(){this._object=oXMLHttpRequest&&!bIE7?new oXMLHttpRequest:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[];};function cXMLHttpRequest(){return new fXMLHttpRequest;};cXMLHttpRequest.prototype=fXMLHttpRequest.prototype;if(bGecko&&oXMLHttpRequest.wrapped)
-cXMLHttpRequest.wrapped=oXMLHttpRequest.wrapped;cXMLHttpRequest.UNSENT=0;cXMLHttpRequest.OPENED=1;cXMLHttpRequest.HEADERS_RECEIVED=2;cXMLHttpRequest.LOADING=3;cXMLHttpRequest.DONE=4;cXMLHttpRequest.prototype.readyState=cXMLHttpRequest.UNSENT;cXMLHttpRequest.prototype.responseText='';cXMLHttpRequest.prototype.responseXML=null;cXMLHttpRequest.prototype.status=0;cXMLHttpRequest.prototype.statusText='';cXMLHttpRequest.prototype.priority="NORMAL";cXMLHttpRequest.prototype.onreadystatechange=null;cXMLHttpRequest.onreadystatechange=null;cXMLHttpRequest.onopen=null;cXMLHttpRequest.onsend=null;cXMLHttpRequest.onabort=null;cXMLHttpRequest.prototype.open=function(sMethod,sUrl,bAsync,sUser,sPassword){delete this._headers;if(arguments.length<3)
-bAsync=true;this._async=bAsync;var oRequest=this,nState=this.readyState,fOnUnload;if(bIE&&bAsync){fOnUnload=function(){if(nState!=cXMLHttpRequest.DONE){fCleanTransport(oRequest);oRequest.abort();}};window.attachEvent("onunload",fOnUnload);}
-if(cXMLHttpRequest.onopen)
-cXMLHttpRequest.onopen.apply(this,arguments);if(arguments.length>4)
-this._object.open(sMethod,sUrl,bAsync,sUser,sPassword);else
-if(arguments.length>3)
-this._object.open(sMethod,sUrl,bAsync,sUser);else
-this._object.open(sMethod,sUrl,bAsync);this.readyState=cXMLHttpRequest.OPENED;fReadyStateChange(this);this._object.onreadystatechange=function(){if(bGecko&&!bAsync)
-return;oRequest.readyState=oRequest._object.readyState;fSynchronizeValues(oRequest);if(oRequest._aborted){oRequest.readyState=cXMLHttpRequest.UNSENT;return;}
-if(oRequest.readyState==cXMLHttpRequest.DONE){delete oRequest._data;fCleanTransport(oRequest);if(bIE&&bAsync)
-window.detachEvent("onunload",fOnUnload);}
-if(nState!=oRequest.readyState)
-fReadyStateChange(oRequest);nState=oRequest.readyState;}};function fXMLHttpRequest_send(oRequest){oRequest._object.send(oRequest._data);if(bGecko&&!oRequest._async){oRequest.readyState=cXMLHttpRequest.OPENED;fSynchronizeValues(oRequest);while(oRequest.readyState<cXMLHttpRequest.DONE){oRequest.readyState++;fReadyStateChange(oRequest);if(oRequest._aborted)
-return;}}};cXMLHttpRequest.prototype.send=function(vData){if(cXMLHttpRequest.onsend)
-cXMLHttpRequest.onsend.apply(this,arguments);if(!arguments.length)
-vData=null;if(vData&&vData.nodeType){vData=window.XMLSerializer?new window.XMLSerializer().serializeToString(vData):vData.xml;if(!oRequest._headers["Content-Type"])
-oRequest._object.setRequestHeader("Content-Type","application/xml");}
-this._data=vData;fXMLHttpRequest_send(this);};cXMLHttpRequest.prototype.abort=function(){if(cXMLHttpRequest.onabort)
-cXMLHttpRequest.onabort.apply(this,arguments);if(this.readyState>cXMLHttpRequest.UNSENT)
-this._aborted=true;this._object.abort();fCleanTransport(this);this.readyState=cXMLHttpRequest.UNSENT;delete this._data;};cXMLHttpRequest.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders();};cXMLHttpRequest.prototype.getResponseHeader=function(sName){return this._object.getResponseHeader(sName);};cXMLHttpRequest.prototype.setRequestHeader=function(sName,sValue){if(!this._headers)
-this._headers={};this._headers[sName]=sValue;return this._object.setRequestHeader(sName,sValue);};cXMLHttpRequest.prototype.addEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
-if(oListener[0]==sName&&oListener[1]==fHandler&&oListener[2]==bUseCapture)
-return;this._listeners.push([sName,fHandler,bUseCapture]);};cXMLHttpRequest.prototype.removeEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
-break;if(oListener)
-this._listeners.splice(nIndex,1);};cXMLHttpRequest.prototype.dispatchEvent=function(oEvent){var oEventPseudo={'type':oEvent.type,'target':this,'currentTarget':this,'eventPhase':2,'bubbles':oEvent.bubbles,'cancelable':oEvent.cancelable,'timeStamp':oEvent.timeStamp,'stopPropagation':function(){},'preventDefault':function(){},'initEvent':function(){}};if(oEventPseudo.type=="readystatechange"&&this.onreadystatechange)
-(this.onreadystatechange.handleEvent||this.onreadystatechange).apply(this,[oEventPseudo]);for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
-if(oListener[0]==oEventPseudo.type&&!oListener[2])
-(oListener[1].handleEvent||oListener[1]).apply(this,[oEventPseudo]);};cXMLHttpRequest.prototype.toString=function(){return'['+"object"+' '+"XMLHttpRequest"+']';};cXMLHttpRequest.toString=function(){return'['+"XMLHttpRequest"+']';};function fReadyStateChange(oRequest){if(cXMLHttpRequest.onreadystatechange)
-cXMLHttpRequest.onreadystatechange.apply(oRequest);oRequest.dispatchEvent({'type':"readystatechange",'bubbles':false,'cancelable':false,'timeStamp':new Date+0});};function fGetDocument(oRequest){var oDocument=oRequest.responseXML,sResponse=oRequest.responseText;if(bIE&&sResponse&&oDocument&&!oDocument.documentElement&&oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)){oDocument=new window.ActiveXObject("Microsoft.XMLDOM");oDocument.async=false;oDocument.validateOnParse=false;oDocument.loadXML(sResponse);}
-if(oDocument)
-if((bIE&&oDocument.parseError!=0)||!oDocument.documentElement||(oDocument.documentElement&&oDocument.documentElement.tagName=="parsererror"))
-return null;return oDocument;};function fSynchronizeValues(oRequest){try{oRequest.responseText=oRequest._object.responseText;}catch(e){}
-try{oRequest.responseXML=fGetDocument(oRequest._object);}catch(e){}
-try{oRequest.status=oRequest._object.status;}catch(e){}
-try{oRequest.statusText=oRequest._object.statusText;}catch(e){}};function fCleanTransport(oRequest){oRequest._object.onreadystatechange=new window.Function;};if(!window.Function.prototype.apply){window.Function.prototype.apply=function(oRequest,oArguments){if(!oArguments)
-oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(window.Proj4js&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p.getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Proj
 ection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
-return equals;},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
-OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
-return point;};OpenLayers.Projection.nullTransform=function(point){return point;};OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{kml:"http://www.opengis.net/kml/2.2",gx:"http://www.google.com/kml/ext/2.2"},kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date(),extractAttributes:true,extractStyles:false,extractTracks:false,trackAttributes:null,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),kmlColor:(/(\w{2})(\w{2})(\w{2})(\w{2})/),kmlIconPalette:(/root:\/\/icons\/palette-(\d+)(\.\w+)/),straightBracket:(/\$\[(.*?)\]/g)};this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){this.features=[];this.sty
 les={};this.fetched={};var options={depth:0,styleBaseUrl:this.styleBaseUrl};return this.parseData(data,options);},parseData:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var types=["Link","NetworkLink","Style","StyleMap","Placemark"];for(var i=0,len=types.length;i<len;++i){var type=types[i];var nodes=this.getElementsByTagNameNS(data,"*",type);if(nodes.length==0){continue;}
-switch(type.toLowerCase()){case"link":case"networklink":this.parseLinks(nodes,options);break;case"style":if(this.extractStyles){this.parseStyles(nodes,options);}
-break;case"stylemap":if(this.extractStyles){this.parseStyleMaps(nodes,options);}
-break;case"placemark":this.parseFeatures(nodes,options);break;}}
-return this.features;},parseLinks:function(nodes,options){if(options.depth>=this.maxDepth){return false;}
-var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;for(var i=0,len=nodes.length;i<len;i++){var href=this.parseProperty(nodes[i],"*","href");if(href&&!this.fetched[href]){this.fetched[href]=true;var data=this.fetchLink(href);if(data){this.parseData(data,newOptions);}}}},fetchLink:function(href){var request=OpenLayers.Request.GET({url:href,async:false});if(request){return request.responseText;}},parseStyles:function(nodes,options){for(var i=0,len=nodes.length;i<len;i++){var style=this.parseStyle(nodes[i]);if(style){var styleName=(options.styleBaseUrl||"")+"#"+style.id;this.styles[styleName]=style;}}},parseKmlColor:function(kmlColor){var color=null;if(kmlColor){var matches=kmlColor.match(this.regExes.kmlColor);if(matches){color={color:'#'+matches[4]+matches[3]+matches[2],opacity:parseInt(matches[1],16)/255};}}
-return color;},parseStyle:function(node){var style={};var types=["LineStyle","PolyStyle","IconStyle","BalloonStyle","LabelStyle"];var type,styleTypeNode,nodeList,geometry,parser;for(var i=0,len=types.length;i<len;++i){type=types[i];styleTypeNode=this.getElementsByTagNameNS(node,"*",type)[0];if(!styleTypeNode){continue;}
-switch(type.toLowerCase()){case"linestyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["strokeColor"]=color.color;style["strokeOpacity"]=color.opacity;}
-var width=this.parseProperty(styleTypeNode,"*","width");if(width){style["strokeWidth"]=width;}
-break;case"polystyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["fillOpacity"]=color.opacity;style["fillColor"]=color.color;}
-var fill=this.parseProperty(styleTypeNode,"*","fill");if(fill=="0"){style["fillColor"]="none";}
-var outline=this.parseProperty(styleTypeNode,"*","outline");if(outline=="0"){style["strokeWidth"]="0";}
-break;case"iconstyle":var scale=parseFloat(this.parseProperty(styleTypeNode,"*","scale")||1);var width=32*scale;var height=32*scale;var iconNode=this.getElementsByTagNameNS(styleTypeNode,"*","Icon")[0];if(iconNode){var href=this.parseProperty(iconNode,"*","href");if(href){var w=this.parseProperty(iconNode,"*","w");var h=this.parseProperty(iconNode,"*","h");var google="http://maps.google.com/mapfiles/kml";if(OpenLayers.String.startsWith(href,google)&&!w&&!h){w=64;h=64;scale=scale/2;}
-w=w||h;h=h||w;if(w){width=parseInt(w)*scale;}
-if(h){height=parseInt(h)*scale;}
-var matches=href.match(this.regExes.kmlIconPalette);if(matches){var palette=matches[1];var file_extension=matches[2];var x=this.parseProperty(iconNode,"*","x");var y=this.parseProperty(iconNode,"*","y");var posX=x?x/32:0;var posY=y?(7-y/32):7;var pos=posY*8+posX;href="http://maps.google.com/mapfiles/kml/pal"
-+palette+"/icon"+pos+file_extension;}
-style["graphicOpacity"]=1;style["externalGraphic"]=href;}}
-var hotSpotNode=this.getElementsByTagNameNS(styleTypeNode,"*","hotSpot")[0];if(hotSpotNode){var x=parseFloat(hotSpotNode.getAttribute("x"));var y=parseFloat(hotSpotNode.getAttribute("y"));var xUnits=hotSpotNode.getAttribute("xunits");if(xUnits=="pixels"){style["graphicXOffset"]=-x*scale;}
-else if(xUnits=="insetPixels"){style["graphicXOffset"]=-width+(x*scale);}
-else if(xUnits=="fraction"){style["graphicXOffset"]=-width*x;}
-var yUnits=hotSpotNode.getAttribute("yunits");if(yUnits=="pixels"){style["graphicYOffset"]=-height+(y*scale)+1;}
-else if(yUnits=="insetPixels"){style["graphicYOffset"]=-(y*scale)+1;}
-else if(yUnits=="fraction"){style["graphicYOffset"]=-height*(1-y)+1;}}
-style["graphicWidth"]=width;style["graphicHeight"]=height;break;case"balloonstyle":var balloonStyle=OpenLayers.Util.getXmlNodeValue(styleTypeNode);if(balloonStyle){style["balloonStyle"]=balloonStyle.replace(this.regExes.straightBracket,"${$1}");}
-break;case"labelstyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["fontColor"]=color.color;style["fontOpacity"]=color.opacity;}
-break;default:}}
-if(!style["strokeColor"]&&style["fillColor"]){style["strokeColor"]=style["fillColor"];}
-var id=node.getAttribute("id");if(id&&style){style.id=id;}
-return style;},parseStyleMaps:function(nodes,options){for(var i=0,len=nodes.length;i<len;i++){var node=nodes[i];var pairs=this.getElementsByTagNameNS(node,"*","Pair");var id=node.getAttribute("id");for(var j=0,jlen=pairs.length;j<jlen;j++){var pair=pairs[j];var key=this.parseProperty(pair,"*","key");var styleUrl=this.parseProperty(pair,"*","styleUrl");if(styleUrl&&key=="normal"){this.styles[(options.styleBaseUrl||"")+"#"+id]=this.styles[(options.styleBaseUrl||"")+styleUrl];}
-if(styleUrl&&key=="highlight"){}}}},parseFeatures:function(nodes,options){var features=[];for(var i=0,len=nodes.length;i<len;i++){var featureNode=nodes[i];var feature=this.parseFeature.apply(this,[featureNode]);if(feature){if(this.extractStyles&&feature.attributes&&feature.attributes.styleUrl){feature.style=this.getStyle(feature.attributes.styleUrl,options);}
-if(this.extractStyles){var inlineStyleNode=this.getElementsByTagNameNS(featureNode,"*","Style")[0];if(inlineStyleNode){var inlineStyle=this.parseStyle(inlineStyleNode);if(inlineStyle){feature.style=OpenLayers.Util.extend(feature.style,inlineStyle);}}}
-if(this.extractTracks){var tracks=this.getElementsByTagNameNS(featureNode,this.namespaces.gx,"Track");if(tracks&&tracks.length>0){var track=tracks[0];var container={features:[],feature:feature};this.readNode(track,container);if(container.features.length>0){features.push.apply(features,container.features);}}}else{features.push(feature);}}else{throw"Bad Placemark: "+i;}}
-this.features=this.features.concat(features);},readers:{"kml":{"when":function(node,container){container.whens.push(OpenLayers.Date.parse(this.getChildValue(node)));},"_trackPointAttribute":function(node,container){var name=node.nodeName.split(":").pop();container.attributes[name].push(this.getChildValue(node));}},"gx":{"Track":function(node,container){var obj={whens:[],points:[],angles:[]};if(this.trackAttributes){var name;obj.attributes={};for(var i=0,ii=this.trackAttributes.length;i<ii;++i){name=this.trackAttributes[i];obj.attributes[name]=[];if(!(name in this.readers.kml)){this.readers.kml[name]=this.readers.kml._trackPointAttribute;}}}
-this.readChildNodes(node,obj);if(obj.whens.length!==obj.points.length){throw new Error("gx:Track with unequal number of when ("+obj.whens.length+") and gx:coord ("+obj.points.length+") elements.");}
-var hasAngles=obj.angles.length>0;if(hasAngles&&obj.whens.length!==obj.angles.length){throw new Error("gx:Track with unequal number of when ("+obj.whens.length+") and gx:angles ("+obj.angles.length+") elements.");}
-var feature,point,angles;for(var i=0,ii=obj.whens.length;i<ii;++i){feature=container.feature.clone();feature.fid=container.feature.fid||container.feature.id;point=obj.points[i];feature.geometry=point;if("z"in point){feature.attributes.altitude=point.z;}
-if(this.internalProjection&&this.externalProjection){feature.geometry.transform(this.externalProjection,this.internalProjection);}
-if(this.trackAttributes){for(var j=0,jj=this.trackAttributes.length;j<jj;++j){feature.attributes[name]=obj.attributes[this.trackAttributes[j]][i];}}
-feature.attributes.when=obj.whens[i];feature.attributes.trackId=container.feature.id;if(hasAngles){angles=obj.angles[i];feature.attributes.heading=parseFloat(angles[0]);feature.attributes.tilt=parseFloat(angles[1]);feature.attributes.roll=parseFloat(angles[2]);}
-container.features.push(feature);}},"coord":function(node,container){var str=this.getChildValue(node);var coords=str.replace(this.regExes.trimSpace,"").split(/\s+/);var point=new OpenLayers.Geometry.Point(coords[0],coords[1]);if(coords.length>2){point.z=parseFloat(coords[2]);}
-container.points.push(point);},"angles":function(node,container){var str=this.getChildValue(node);var parts=str.replace(this.regExes.trimSpace,"").split(/\s+/);container.angles.push(parts);}}},parseFeature:function(node){var order=["MultiGeometry","Polygon","LineString","Point"];var type,nodeList,geometry,parser;for(var i=0,len=order.length;i<len;++i){type=order[i];this.internalns=node.namespaceURI?node.namespaceURI:this.kmlns;nodeList=this.getElementsByTagNameNS(node,this.internalns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var attributes;if(this.extractAttributes){attributes=this.parseAttributes(node);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);var fid=node.getAttribute("id")||node.getAttribute("name");if(fid!=null){feature.fid=fid;}
-return feature;},getStyle:function(styleUrl,options){var styleBaseUrl=OpenLayers.Util.removeTail(styleUrl);var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;newOptions.styleBaseUrl=styleBaseUrl;if(!this.styles[styleUrl]&&!OpenLayers.String.startsWith(styleUrl,"#")&&newOptions.depth<=this.maxDepth&&!this.fetched[styleBaseUrl]){var data=this.fetchLink(styleBaseUrl);if(data){this.parseData(data,newOptions);}}
-var style=OpenLayers.Util.extend({},this.styles[styleUrl]);return style;},parseGeometry:{point:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var coords=[];if(nodeList.length>0){var coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}
-var point=null;if(coords.length>1){if(coords.length==2){coords[2]=null;}
-point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad coordinate string: "+coordString;}
-return point;},linestring:function(node,ring){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var line=null;if(nodeList.length>0){var coordString=this.getChildValue(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);var numPoints=pointList.length;var points=new Array(numPoints);var coords,numCoords;for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");numCoords=coords.length;if(numCoords>1){if(coords.length==2){coords[2]=null;}
-points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad LineString point coordinates: "+
-pointList[i];}}
-if(numPoints){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}else{throw"Bad LineString coordinates: "+coordString;}}
-return line;},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"LinearRing");var numRings=nodeList.length;var components=new Array(numRings);if(numRings>0){var ring;for(var i=0,len=nodeList.length;i<len;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components[i]=ring;}else{throw"Bad LinearRing geometry: "+i;}}}
-return new OpenLayers.Geometry.Polygon(components);},multigeometry:function(node){var child,parser;var parts=[];var children=node.childNodes;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){var type=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var parser=this.parseGeometry[type.toLowerCase()];if(parser){parts.push(parser.apply(this,[child]));}}}
-return new OpenLayers.Geometry.Collection(parts);}},parseAttributes:function(node){var attributes={};var edNodes=node.getElementsByTagName("ExtendedData");if(edNodes.length){attributes=this.parseExtendedData(edNodes[0]);}
-var child,grandchildren,grandchild;var children=node.childNodes;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length>=1&&grandchildren.length<=3){var grandchild;switch(grandchildren.length){case 1:grandchild=grandchildren[0];break;case 2:var c1=grandchildren[0];var c2=grandchildren[1];grandchild=(c1.nodeType==3||c1.nodeType==4)?c1:c2;break;case 3:default:grandchild=grandchildren[1];break;}
-if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=OpenLayers.Util.getXmlNodeValue(grandchild);if(value){value=value.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseExtendedData:function(node){var attributes={};var i,len,data,key;var dataNodes=node.getElementsByTagName("Data");for(i=0,len=dataNodes.length;i<len;i++){data=dataNodes[i];key=data.getAttribute("name");var ed={};var valueNode=data.getElementsByTagName("value");if(valueNode.length){ed['value']=this.getChildValue(valueNode[0]);}
-var nameNode=data.getElementsByTagName("displayName");if(nameNode.length){ed['displayName']=this.getChildValue(nameNode[0]);}
-attributes[key]=ed;}
-var simpleDataNodes=node.getElementsByTagName("SimpleData");for(i=0,len=simpleDataNodes.length;i<len;i++){var ed={};data=simpleDataNodes[i];key=data.getAttribute("name");ed['value']=this.getChildValue(data);ed['displayName']=key;attributes[key]=ed;}
-return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
-return value;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0,len=features.length;i<len;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
-kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folder=this.createElementNS(this.kmlns,"Folder");if(this.foldersName){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);folder.appendChild(folderName);}
-if(this.foldersDesc){var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);folder.appendChild(folderDesc);}
-return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=feature.style&&feature.style.label?feature.style.label:feature.attributes.name||feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=feature.attributes.description||this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
-placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
-return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0,len=rings.length;i<len;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[
 i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
-return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0,len=geometry.components.length;i<len;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
-return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=point.x+","+point.y;}
-path=parts.join(" ");}else{path=geometry.x+","+geometry.y;}
-var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];sourceSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.Mult
-sourceSplit=true;splits=splits[1];}
-if(splits.length){splits.unshift(j,1);Array.prototype.splice.apply(targetParts,splits);break;}}}
-if(!sourceSplit){if(sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLine.clone());}else{sourceParts=[new OpenLayers.Geometry.MultiLineString(sourceLine.clone())];}}}
-if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
-if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
-if(sourceSplit||targetSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
-return results;},splitWith:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,targetLine,sourceLines,sourceSplit,targetSplit,sourceParts,targetParts;if(geometry instanceof OpenLayers.Geometry.LineString){targetParts=[];sourceParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){targetSplit=false;targetLine=this.components[i];for(var j=0;j<sourceParts.length;++j){splits=sourceParts[j].split(targetLine,options);if(splits){if(mutual){sourceLines=splits[0];if(sourceLines.length){sourceLines.unshift(j,1);Array.prototype.splice.apply(sourceParts,sourceLines);j+=sourceLines.length-2;}
-splits=splits[1];if(splits.length===0){splits=[targetLine.clone()];}}
-for(var k=0,klen=splits.length;k<klen;++k){if(k===0&&targetParts.length){targetParts[targetParts.length-1].addComponent(splits[k]);}else{targetParts.push(new OpenLayers.Geometry.MultiLineString([splits[k]]));}}
-targetSplit=true;}}
-if(!targetSplit){if(targetParts.length){targetParts[targetParts.length-1].addComponent(targetLine.clone());}else{targetParts=[new OpenLayers.Geometry.MultiLineString([targetLine.clone()])];}}}}else{results=geometry.split(this);}
-return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply
 (this,[data]);}
 var featureNodes=this.getElementsByTagNameNS(data.documentElement,this.gmlns,this.featureName);var features=[];for(var i=0;i<featureNodes.length;i++){var feature=this.parseFeature(featureNodes[i]);if(feature){features.push(feature);}}
 return features;},parseFeature:function(node){var order=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];nodeList=this.getElementsByTagNameNS(node,this.gmlns,type);if(nodeList.length>0){parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
 break;}}
@@ -864,52 +1029,9 @@
 if(point.z!=undefined){parts[i]+=","+point.z;}}
 return this.createElementNSPlus("gml:coordinates",{attributes:{decimal:".",cs:",",ts:" "},value:(numPoints==1)?parts[0]:parts.join(" ")});},"LineString":function(geometry){var node=this.createElementNSPlus("gml:LineString");this.writeNode("coordinates",geometry.components,node);return node;},"Polygon":function(geometry){var node=this.createElementNSPlus("gml:Polygon");this.writeNode("outerBoundaryIs",geometry.components[0],node);for(var i=1;i<geometry.components.length;++i){this.writeNode("innerBoundaryIs",geometry.components[i],node);}
 return node;},"outerBoundaryIs":function(ring){var node=this.createElementNSPlus("gml:outerBoundaryIs");this.writeNode("LinearRing",ring,node);return node;},"innerBoundaryIs":function(ring){var node=this.createElementNSPlus("gml:innerBoundaryIs");this.writeNode("LinearRing",ring,node);return node;},"LinearRing":function(ring){var node=this.createElementNSPlus("gml:LinearRing");this.writeNode("coordinates",ring.components,node);return node;},"Box":function(bounds){var node=this.createElementNSPlus("gml:Box");this.writeNode("coordinates",[{x:bounds.left,y:bounds.bottom},{x:bounds.right,y:bounds.top}],node);if(this.srsName){node.setAttribute("srsName",this.srsName);}
-return node;}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},CLASS_NAME:"OpenLayers.Format.GML.v2"});OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:false,propertyStyles:null,initialize:function(style,options){OpenLayers.Util.extend(this,options);this.rules=[];if(options&&options.rules){this.addRules(options.rules);}
-this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();this.rules[i]=null;}
-this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0,len=rules.length;i<len;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
-if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0,len=elseRules.length;i<len;i++){this.applySymbolizer(elseRules[i],style,feature);}}
-if(rules.length>0&&appliedRules==false){style.display="none";}
-return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;if(this.defaultsPerSymbolizer===true){var defaults=this.defaultStyle;OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:defaults.pointRadius});if(symbolizer.stroke===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{strokeWidth:defaults.strokeWidth,strokeColor:defaults.strokeColor,strokeOpacity:defaults.strokeOpacity,strokeDashstyle:defaults.strokeDashstyle,strokeLinecap:defaults.strokeLinecap});}
-if(symbolizer.fill===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{fillColor:defaults.fillColor,fillOpacity:defaults.fillOpacity});}
-if(symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset});}}
-return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=OpenLayers.Util.extend({},feature.attributes||feature.data);OpenLayers.Util.extend(context,this.context);for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature,i);}
-return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0,len=rules.length;i<len;i++){symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
-return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
-return propertyStyles;},addRules:function(rules){Array.prototype.push.apply(this.rules,rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=prefixes.length;i<len;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.rules){options.rules=[];for(var i=0,len=this.rules.length;i<len;++i){options.rules.push(this.rules[i].clone());}}
-options.context=this.context&&OpenLayers.Util.extend({},this.context);var defaultStyle=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(defaultStyle,options);},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature,property){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature,property]);value=(isNaN(value)||!value)?value:parseFloat(value);}
-return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon','Text','Raster'];OpenLayers.Symbolizer=OpenLayers.Class({zIndex:0,initialize:function(config){OpenLayers.Util.extend(this,config);},clone:function(){var Type=eval(this.CLASS_NAME);return new Type(OpenLayers.Util.extend({},this));},CLASS_NAME:"OpenLayers.Symbolizer"});OpenLayers.Symbolizer.Point=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Point"});OpenLayers.Symbolizer.Line=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Line"});OpenLayers.Symbolizer.Polygon=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Polygon"});OpenLayers.Symbolizer.T
 ext=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Text"});OpenLayers.Symbolizer.Raster=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Raster"});OpenLayers.Rule=OpenLayers.Class({id:null,name:null,title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,symbolizers:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.symbolizer={};OpenLayers.Util.extend(this,options);if(this.symbolizers){delete this.symbolizer;}
-this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
-this.symbolizer=null;delete this.symbolizers;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
-if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
-if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
-if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
-return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
-if(typeof this.context=="function"){context=this.context(feature);}
-return context;},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.symbolizers){var len=this.symbolizers.length;options.symbolizers=new Array(len);for(var i=0;i<len;++i){options.symbolizers[i]=this.symbolizers[i].clone();}}else{options.symbolizer={};var value,type;for(var key in this.symbolizer){value=this.symbolizer[key];type=typeof value;if(type==="object"){options.symbolizer[key]=OpenLayers.Util.extend({},value);}else if(type==="string"){options.symbolizer[key]=value;}}}
-options.filter=this.filter&&this.filter.clone();options.context=this.context&&OpenLayers.Util.extend({},this.context);return new OpenLayers.Rule(options);},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},clone:function(){return null;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0,len=this.fids.length;i<len;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
-return false;},clone:function(){var filter=new OpenLayers.Filter.FeatureId();OpenLayers.Util.extend(filter,this);filter.fids=this.fids.slice();return filter;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){var i,len;switch(this.type){case OpenLayers.Filter.Logical.AND:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==false){return false;}}
-return true;case OpenLayers.Filter.Logical.OR:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==true){return true;}}
-return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}
-return undefined;},clone:function(){var filters=[];for(var i=0,len=this.filters.length;i<len;++i){filters.push(this.filters[i].clone());}
-return new OpenLayers.Filter.Logical({type:this.type,filters:filters});},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:true,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(context){if(context instanceof OpenLayers.Feature.Vector){context=context.attributes;}
-var result=false;var got=context[this.property];var exp;switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()==exp.toUpperCase());}else{result=(got==exp);}
-break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()!=exp.toUpperCase());}else{result=(got!=exp);}
-break;case OpenLayers.Filter.Comparison.LESS_THAN:result=got<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:result=got>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:result=got<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:result=got>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:result=(got>=this.lowerBoundary)&&(got<=this.upperBoundary);break;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");result=regexp.test(got);break;}
-return result;},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
-wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
 QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
-if(feature.geometry.intersects(geom)){intersect=true;}}
-break;default:OpenLayers.Console.error(OpenLayers.i18n("filterEvaluateNotImplemented"));break;}
-return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,namedLayersAsArray:false,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(sld,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
+return node;}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},CLASS_NAME:"OpenLayers.Format.GML.v2"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(filter,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.Filter["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a Filter parser for version "+
 version;}
 this.parser=new format(this.options);}
-var root=this.parser.write(sld);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-this.parser=new format(this.options);}
-var sld=this.parser.read(data,options);return sld;},CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(filter,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.Filter["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a Filter parser for version "+
-version;}
 return this.parser.write(filter);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 var version=this.version;if(!version){version=this.defaultVersion;}
@@ -989,265 +1111,7 @@
 return node;},"ExternalGraphic":function(symbolizer){var node=this.createElementNSPlus("sld:ExternalGraphic");this.writeNode("OnlineResource",symbolizer.externalGraphic,node);var format=symbolizer.graphicFormat||this.getGraphicFormat(symbolizer.externalGraphic);this.writeNode("Format",format,node);return node;},"Mark":function(symbolizer){var node=this.createElementNSPlus("sld:Mark");if(symbolizer.graphicName){this.writeNode("WellKnownName",symbolizer.graphicName,node);}
 if(symbolizer.fill!==false){this.writeNode("Fill",symbolizer,node);}
 if(symbolizer.stroke!==false){this.writeNode("Stroke",symbolizer,node);}
-return node;},"WellKnownName":function(name){return this.createElementNSPlus("sld:WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("sld:Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("sld:Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("sld:Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("sld:OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("sld:Format",{value:format});}}},OpenLayers.Format.Filter.v1_0_0.prototype.writers),CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[option
 s]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Format.Context=OpenLayers.Class({version:null,layerOptions:null,layerParams:null,parser:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");}
-var parser=this.getParser(version);var context=parser.read(data,options);var map;if(options&&options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{var mapOptions=options.map;if(OpenLayers.Util.isElement(mapOptions)||typeof mapOptions=="string"){mapOptions={div:mapOptions};}
-map=this.contextToMap(context,mapOptions);}}else{map=context;}
-return map;},getLayerFromContext:function(layerContext){var i,len;var options={queryable:layerContext.queryable,visibility:layerContext.visibility,maxExtent:layerContext.maxExtent,metadata:OpenLayers.Util.applyDefaults(layerContext.metadata,{styles:layerContext.styles}),numZoomLevels:layerContext.numZoomLevels,units:layerContext.units,isBaseLayer:layerContext.isBaseLayer,opacity:layerContext.opacity,displayInLayerSwitcher:layerContext.displayInLayerSwitcher,singleTile:layerContext.singleTile,tileSize:(layerContext.tileSize)?new OpenLayers.Size(layerContext.tileSize.width,layerContext.tileSize.height):undefined,minScale:layerContext.minScale||layerContext.maxScaleDenominator,maxScale:layerContext.maxScale||layerContext.minScaleDenominator};if(this.layerOptions){OpenLayers.Util.applyDefaults(options,this.layerOptions);}
-var params={layers:layerContext.name,transparent:layerContext.transparent,version:layerContext.version};if(layerContext.formats&&layerContext.formats.length>0){params.format=layerContext.formats[0].value;for(i=0,len=layerContext.formats.length;i<len;i++){var format=layerContext.formats[i];if(format.current==true){params.format=format.value;break;}}}
-if(layerContext.styles&&layerContext.styles.length>0){for(i=0,len=layerContext.styles.length;i<len;i++){var style=layerContext.styles[i];if(style.current==true){if(style.href){params.sld=style.href;}else if(style.body){params.sld_body=style.body;}else{params.styles=style.name;}
-break;}}}
-if(this.layerParams){OpenLayers.Util.applyDefaults(params,this.layerParams);}
-var layer=null;var service=layerContext.service;if(service==OpenLayers.Format.Context.serviceTypes.WFS){options.strategies=[new OpenLayers.Strategy.BBOX()];options.protocol=new OpenLayers.Protocol.WFS({url:layerContext.url,featurePrefix:layerContext.name.split(":")[0],featureType:layerContext.name.split(":").pop()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.KML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.KML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.GML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.GML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.na
 me,options);}else if(layerContext.features){layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);layer.addFeatures(layerContext.features);}else if(layerContext.categoryLayer!==true){layer=new OpenLayers.Layer.WMS(layerContext.title||layerContext.name,layerContext.url,params,options);}
-return layer;},getLayersFromContext:function(layersContext){var layers=[];for(var i=0,len=layersContext.length;i<len;i++){var layer=this.getLayerFromContext(layersContext[i]);if(layer!==null){layers.push(layer);}}
-return layers;},contextToMap:function(context,options){options=OpenLayers.Util.applyDefaults({maxExtent:context.maxExtent,projection:context.projection},options);var map=new OpenLayers.Map(options);map.addLayers(this.getLayersFromContext(context.layersContext));map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(this.getLayersFromContext(context.layersContext));return map;},write:function(obj,options){obj=this.toContext(obj);var version=options&&options.version;var parser=this.getParser(version);var context=parser.write(obj,options);return context;},CLASS_NAME:"OpenLayers.Format.Context"});OpenLayers.Format.Context.serviceTypes={"WMS":"urn:ogc:serviceType:WMS","WFS":"urn:ogc:serviceType:WFS","WCS":"urn:ogc:serviceType:WCS","GML":"urn:ogc:serviceType:GML","SLD":"urn:ogc:serviceType:SLD","FES":"urn:ogc:serviceType:FES","KML":"urn:ogc:serviceType:KML"};OpenLayers.Format.OWSC
 ontext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getParser:function(version){var v=version||this.version||this.defaultVersion;if(v==="0.3.0"){v=this.defaultVersion;}
-if(!this.parser||this.parser.VERSION!=v){var format=OpenLayers.Format.OWSContext["v"+v.replace(/\./g,"_")];if(!format){throw"Can't find a OWSContext parser for version "+v;}
-return this.parser;},toContext:function(obj){var context={};if(obj.CLASS_NAME=="OpenLayers.Map"){context.bounds=obj.getExtent();context.maxExtent=obj.maxExtent;context.projection=obj.projection;context.size=obj.getSize();context.layers=obj.layers;}
-return context;},CLASS_NAME:"OpenLayers.Format.OWSContext"});if(!OpenLayers.Format.OWSCommon){OpenLayers.Format.OWSCommon={};}
-OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},readers:{"ows":{"ServiceIdentification":function(node,obj){obj.serviceIdentification={};this.readChildNodes(node,obj.serviceIdentification);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,serviceIdentification){serviceIdentification["abstract"]=this.getChildValue(node);},"Keywords":function(node,serviceIdentification){serviceIdentification.keywords={};this.readChildNodes(node,serviceIdentification.keywords);},"Keyword":function(node,keywords){keywords[this.getChildValue(node)]=true;},"ServiceType":function(node,serviceIdentification){serviceIdentification.serviceType={codeSpace:node.getAttribute('codeSpace'),value:this.getChildValue(node)};},"ServiceTypeVersion":function(node,serviceIdentification){serviceIdentification.serviceTypeVersion=this.getChildValue(node);},"
 Fees":function(node,serviceIdentification){serviceIdentification.fees=this.getChildValue(node);},"AccessConstraints":function(node,serviceIdentification){serviceIdentification.accessConstraints=this.getChildValue(node);},"ServiceProvider":function(node,obj){obj.serviceProvider={};this.readChildNodes(node,obj.serviceProvider);},"ProviderName":function(node,serviceProvider){serviceProvider.providerName=this.getChildValue(node);},"ProviderSite":function(node,serviceProvider){serviceProvider.providerSite=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ServiceContact":function(node,serviceProvider){serviceProvider.serviceContact={};this.readChildNodes(node,serviceProvider.serviceContact);},"IndividualName":function(node,serviceContact){serviceContact.individualName=this.getChildValue(node);},"PositionName":function(node,serviceContact){serviceContact.positionName=this.getChildValue(node);},"ContactInfo":function(node,serviceContact){serviceContact.contactInfo={};this.re
 adChildNodes(node,serviceContact.contactInfo);},"Phone":function(node,contactInfo){contactInfo.phone={};this.readChildNodes(node,contactInfo.phone);},"Voice":function(node,phone){phone.voice=this.getChildValue(node);},"Address":function(node,contactInfo){contactInfo.address={};this.readChildNodes(node,contactInfo.address);},"DeliveryPoint":function(node,address){address.deliveryPoint=this.getChildValue(node);},"City":function(node,address){address.city=this.getChildValue(node);},"AdministrativeArea":function(node,address){address.administrativeArea=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);},"Country":function(node,address){address.country=this.getChildValue(node);},"ElectronicMailAddress":function(node,address){address.electronicMailAddress=this.getChildValue(node);},"Role":function(node,serviceContact){serviceContact.role=this.getChildValue(node);},"OperationsMetadata":function(node,obj){obj.operationsMetadat
 a={};this.readChildNodes(node,obj.operationsMetadata);},"Operation":function(node,operationsMetadata){var name=node.getAttribute("name");operationsMetadata[name]={};this.readChildNodes(node,operationsMetadata[name]);},"DCP":function(node,operation){operation.dcp={};this.readChildNodes(node,operation.dcp);},"HTTP":function(node,dcp){dcp.http={};this.readChildNodes(node,dcp.http);},"Get":function(node,http){http.get=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Post":function(node,http){http.post=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Parameter":function(node,operation){if(!operation.parameters){operation.parameters={};}
-var name=node.getAttribute("name");operation.parameters[name]={};this.readChildNodes(node,operation.parameters[name]);},"Value":function(node,allowedValues){allowedValues[this.getChildValue(node)]=true;},"OutputFormat":function(node,obj){obj.formats.push({value:this.getChildValue(node)});this.readChildNodes(node,obj);},"WGS84BoundingBox":function(node,obj){var boundingBox={};boundingBox.crs=node.getAttribute("crs");if(obj.BoundingBox){obj.BoundingBox.push(boundingBox);}else{obj.projection=boundingBox.crs;boundingBox=obj;}
-this.readChildNodes(node,boundingBox);},"BoundingBox":function(node,obj){this.readers['ows']['WGS84BoundingBox'].apply(this,[node,obj]);},"LowerCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.left=pointList[0];obj.bottom=pointList[1];},"UpperCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.right=pointList[0];obj.top=pointList[1];obj.bounds=new OpenLayers.Bounds(obj.left,obj.bottom,obj.right,obj.top);delete obj.left;delete obj.bottom;delete obj.right;delete obj.top;}}},writers:{"ows":{"BoundingBox":function(options){var node=this.createElementNSPlus("ows:BoundingBox",{attributes:{crs:options.projection}});this.writeNode("ows:LowerCorner",options,node);this.writeNode("ows:UpperCorner",options,no
 de);return node;},"LowerCorner":function(options){var node=this.createElementNSPlus("ows:LowerCorner",{value:options.bounds.left+" "+options.bounds.bottom});return node;},"UpperCorner":function(options){var node=this.createElementNSPlus("ows:UpperCorner",{value:options.bounds.right+" "+options.bounds.top});return node;},"Title":function(title){var node=this.createElementNSPlus("ows:Title",{value:title});return node;},"OutputFormat":function(format){var node=this.createElementNSPlus("ows:OutputFormat",{value:format});return node;}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.0",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"]},writers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.writers["ows"]},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Format.OWSContext.v0_3_1=Open
 Layers.Class(OpenLayers.Format.XML,{namespaces:{owc:"http://www.opengis.net/ows-context",gml:"http://www.opengis.net/gml",kml:"http://www.opengis.net/kml/2.2",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},VERSION:"0.3.1",schemaLocation:"http://www.opengis.net/ows-context http://www.ogcnetwork.net/schemas/owc/0.3.1/owsContext.xsd",defaultPrefix:"owc",extractAttributes:true,xy:true,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},featureNS:"http://mapserver.gis.umn.edu/mapserver",featureType:'vector',geometryName:'geometry',nestingLayerLookup:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);OpenLayers.Format.GML.v2.prototype.setGeometryTypes.call(this);},setNestingPath:function(l){if(l.layersContext){for(var i=0,len=l.layersContext.length;i<le
 n;i++){var layerContext=l.layersContext[i];var nPath=[];var nTitle=l.title||"";if(l.metadata&&l.metadata.nestingPath){nPath=l.metadata.nestingPath.slice();}
-if(nTitle!=""){nPath.push(nTitle);}
-layerContext.metadata.nestingPath=nPath;if(layerContext.layersContext){this.setNestingPath(layerContext);}}}},decomposeNestingPath:function(nPath){var a=[];if(nPath instanceof Array){while(nPath.length>0){a.push(nPath.slice());nPath.pop();}
-a.reverse();}
-return a;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var context={};this.readNode(data,context);this.setNestingPath({layersContext:context.layersContext});var layers=[];this.processLayer(layers,context);delete context.layersContext;context.layersContext=layers;return context;},processLayer:function(layerArray,layer){if(layer.layersContext){for(var i=0,len=layer.layersContext.length;i<len;i++){var l=layer.layersContext[i];layerArray.push(l);if(l.layersContext){this.processLayer(layerArray,l);}}}},write:function(context,options){var name="OWSContext";this.nestingLayerLookup={};options=options||{};OpenLayers.Util.applyDefaults(options,context);var root=this.writeNode(name,options);this.nestingLayerLookup=null;this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},readers:{"kml":{"Document":function(node,obj){obj.features=new OpenLayers.Format.KML({kmlns:this.namespaces.kml,extractStyles:true}).read(node);}},"owc":{"OWSContext":fun
 ction(node,obj){this.readChildNodes(node,obj);},"General":function(node,obj){this.readChildNodes(node,obj);},"ResourceList":function(node,obj){this.readChildNodes(node,obj);},"Layer":function(node,obj){var layerContext={metadata:{},visibility:(node.getAttribute("hidden")!="1"),queryable:(node.getAttribute("queryable")=="1"),opacity:((node.getAttribute("opacity")!=null)?parseFloat(node.getAttribute("opacity")):null),name:node.getAttribute("name"),categoryLayer:(node.getAttribute("name")==null),formats:[],styles:[]};if(!obj.layersContext){obj.layersContext=[];}
-obj.layersContext.push(layerContext);this.readChildNodes(node,layerContext);},"InlineGeometry":function(node,obj){obj.features=[];var elements=this.getElementsByTagNameNS(node,this.namespaces.gml,"featureMember");var el;if(elements.length>=1){el=elements[0];}
-if(el&&el.firstChild){var featurenode=(el.firstChild.nextSibling)?el.firstChild.nextSibling:el.firstChild;this.setNamespace("feature",featurenode.namespaceURI);this.featureType=featurenode.localName||featurenode.nodeName.split(":").pop();this.readChildNodes(node,obj);}},"Server":function(node,obj){if((!obj.service&&!obj.version)||(obj.service!=OpenLayers.Format.Context.serviceTypes.WMS)){obj.service=node.getAttribute("service");obj.version=node.getAttribute("version");this.readChildNodes(node,obj);}},"Name":function(node,obj){obj.name=this.getChildValue(node);this.readChildNodes(node,obj);},"Title":function(node,obj){obj.title=this.getChildValue(node);this.readChildNodes(node,obj);},"StyleList":function(node,obj){this.readChildNodes(node,obj.styles);},"Style":function(node,obj){var style={};obj.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={};obj.legend=legend;this.readChildNodes(node,legend);},"OnlineResource":function(node,obj){obj
 .url=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,obj);}},"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows,"gml":OpenLayers.Format.GML.v2.prototype.readers.gml,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.readers.sld,"feature":OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{"owc":{"OWSContext":function(options){var node=this.createElementNSPlus("OWSContext",{attributes:{version:this.VERSION,id:options.id||OpenLayers.Util.createUniqueID("OpenLayers_OWSContext_")}});this.writeNode("General",options,node);this.writeNode("ResourceList",options,node);return node;},"General":function(options){var node=this.createElementNSPlus("General");this.writeNode("ows:BoundingBox",options,node);this.writeNode("ows:Title",options.title||'OpenLayers OWSContext',node);return node;},"ResourceList":function(options){var node=this.createElementNSPlus("ResourceList");for(var i=0,len=options.layers.length;i<len;i++){var layer=options.layer
 s[i];var decomposedPath=this.decomposeNestingPath(layer.metadata.nestingPath);this.writeNode("_Layer",{layer:layer,subPaths:decomposedPath},node);}
-return node;},"Server":function(options){var node=this.createElementNSPlus("Server",{attributes:{version:options.version,service:options.service}});this.writeNode("OnlineResource",options,node);return node;},"OnlineResource":function(options){var node=this.createElementNSPlus("OnlineResource",{attributes:{"xlink:href":options.url}});return node;},"InlineGeometry":function(layer){var node=this.createElementNSPlus("InlineGeometry");this.writeNode("gml:boundedBy",layer.getDataExtent(),node);for(var i=0,len=layer.features.length;i<len;i++){this.writeNode("gml:featureMember",layer.features[i],node);}
-return node;},"StyleList":function(styles){var node=this.createElementNSPlus("StyleList");for(var i=0,len=styles.length;i<len;i++){this.writeNode("Style",styles[i],node);}
-return node;},"Style":function(style){var node=this.createElementNSPlus("Style");this.writeNode("Name",style,node);this.writeNode("Title",style,node);this.writeNode("LegendURL",style,node);return node;},"Name":function(obj){var node=this.createElementNSPlus("Name",{value:obj.name});return node;},"Title":function(obj){var node=this.createElementNSPlus("Title",{value:obj.title});return node;},"LegendURL":function(style){var node=this.createElementNSPlus("LegendURL");this.writeNode("OnlineResource",style.legend,node);return node;},"_WMS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.params.LAYERS,queryable:layer.queryable?"1":"0",hidden:layer.visibility?"0":"1",opacity:layer.opacity?layer.opacity:null}});this.writeNode("ows:Title",layer.name,node);this.writeNode("ows:OutputFormat",layer.params.FORMAT,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WMS,version:layer.params.VERSION,url:layer.url},node);if(layer.met
 adata.styles&&layer.metadata.styles.length>0){this.writeNode("StyleList",layer.metadata.styles,node);}
-return node;},"_Layer":function(options){var layer,subPaths,node,title;layer=options.layer;subPaths=options.subPaths;node=null;title=null;if(subPaths.length>0){var path=subPaths[0].join("/");var index=path.lastIndexOf("/");node=this.nestingLayerLookup[path];title=(index>0)?path.substring(index+1,path.length):path;if(!node){node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",title,node);this.nestingLayerLookup[path]=node;}
-options.subPaths.shift();this.writeNode("_Layer",options,node);return node;}else{if(layer instanceof OpenLayers.Layer.WMS){node=this.writeNode("_WMS",layer);}else if(layer instanceof OpenLayers.Layer.Vector){if(layer.protocol instanceof OpenLayers.Protocol.WFS.v1){node=this.writeNode("_WFS",layer);}else if(layer.protocol instanceof OpenLayers.Protocol.HTTP){if(layer.protocol.format instanceof OpenLayers.Format.GML){layer.protocol.format.version="2.1.2";node=this.writeNode("_GML",layer);}else if(layer.protocol.format instanceof OpenLayers.Format.KML){layer.protocol.format.version="2.2";node=this.writeNode("_KML",layer);}}else{this.setNamespace("feature",this.featureNS);node=this.writeNode("_InlineGeometry",layer);}}
-if(layer.options.maxScale){this.writeNode("sld:MinScaleDenominator",layer.options.maxScale,node);}
-if(layer.options.minScale){this.writeNode("sld:MaxScaleDenominator",layer.options.minScale,node);}
-this.nestingLayerLookup[layer.name]=node;return node;}},"_WFS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.protocol.featurePrefix+":"+layer.protocol.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WFS,version:layer.protocol.version,url:layer.protocol.url},node);return node;},"_InlineGeometry":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:this.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("InlineGeometry",layer,node);return node;},"_GML":function(layer){var node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.GML,url:layer.protocol.url,version:layer.protocol.format.version},node);return node;},"_KML":function(layer){var node=this.createE
 lementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.KML,version:layer.protocol.format.version,url:layer.protocol.url},node);return node;}},"gml":OpenLayers.Util.applyDefaults({"boundedBy":function(bounds){var node=this.createElementNSPlus("gml:boundedBy");this.writeNode("gml:Box",bounds,node);return node;}},OpenLayers.Format.GML.v2.prototype.writers.gml),"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.writers.ows,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld,"feature":OpenLayers.Format.GML.v2.prototype.writers.feature},CLASS_NAME:"OpenLayers.Format.OWSContext.v0_3_1"});OpenLayers.Format.CSWGetRecords=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.CSWGetRecords.DEFAULTS);var cls=OpenLayers.Format.CSWGetRecords["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported CSWGetRecords version: "+options.version;}
-return new cls(options);};OpenLayers.Format.CSWGetRecords.DEFAULTS={"version":"2.0.2"};OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},createGeometryFromItem:function(item){var point=this.getElementsByTagNameNS(item,this.georssns,"point");var lat=this.getElementsByTagNameNS(item,this.geons,'lat');var lon=this.getElementsByTagNameNS(item,this.geons,'long');var line=this.getElementsByTagNameNS(item,this.georssns,"line");var polygon=this.getElementsByTagNameNS(item,this.georssns,"polygon");var where=this.getElementsByTagNameNS(item,this.georssns,"where");var box=this.getElementsByTagNameNS(item,this.georssn
 s,"box");if(point.length>0||(lat.length>0&&lon.length>0)){var location;if(point.length>0){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s+/);if(location.length!=2){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s*,\s*/);}}else{location=[parseFloat(lat[0].firstChild.nodeValue),parseFloat(lon[0].firstChild.nodeValue)];}
-var geometry=new OpenLayers.Geometry.Point(parseFloat(location[1]),parseFloat(location[0]));}else if(line.length>0){var coords=OpenLayers.String.trim(this.concatChildValues(line[0])).split(/\s+/);var components=[];var point;for(var i=0,len=coords.length;i<len;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.LineString(components);}else if(polygon.length>0){var coords=OpenLayers.String.trim(this.concatChildValues(polygon[0])).split(/\s+/);var components=[];var point;for(var i=0,len=coords.length;i<len;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);}else if(where.length>0){if(!this.gmlParser){this.gmlParser=new OpenLayers.Format.GML({'xy':this.xy});}
-var feature=this.gmlParser.parseFeature(where[0]);geometry=feature.geometry;}else if(box.length>0){var coords=OpenLayers.String.trim(box[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;if(coords.length>3){point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[0]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[2]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[3]),parseFloat(coords[2]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[3]),parseFloat(coords[0]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[0]));components.push(point);}
-if(geometry&&this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},createFeatureFromItem:function(item){var geometry=this.createGeometryFromItem(item);var title=this.getChildValue(item,"*","title",this.featureTitle);var description=this.getChildValue(item,"*","description",this.getChildValue(item,"*","content",this.getChildValue(item,"*","summary",this.featureDescription)));var link=this.getChildValue(item,"*","link");if(!link){try{link=this.getElementsByTagNameNS(item,"*","link")[0].getAttribute("href");}catch(e){link=null;}}
-var id=this.getChildValue(item,"*","id",null);var data={"title":title,"description":description,"link":link};var feature=new OpenLayers.Feature.Vector(geometry,data);feature.fid=id;return feature;},getChildValue:function(node,nsuri,name,def){var value;var eles=this.getElementsByTagNameNS(node,nsuri,name);if(eles&&eles[0]&&eles[0].firstChild&&eles[0].firstChild.nodeValue){value=eles[0].firstChild.nodeValue;}else{value=(def==undefined)?"":def;}
-return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
-var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
-return features;},write:function(features){var georss;if(features instanceof Array){georss=this.createElementNS(this.rssns,"rss");for(var i=0,len=features.length;i<len;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
-return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
-for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
-var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureNode.appendChild(attrContainer);}
-featureNode.appendChild(geometryNode);return featureNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var node;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){node=this.createElementNS(this.georssns,'georss:polygon');node.appendChild(this.buildCoordinatesNode(geometry.components[0]));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){node=this.createElementNS(this.georssns,'georss:line');node.appendChild(this.buildCoordinatesNode(geometry));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){node=this.createElementNS(this.georssns,'georss:point');node.appendChild(this.buildCoordinatesNode(geometry));}else{throw"Couldn't parse "+geometry.CLASS_NAME;}
-return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
-var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
-path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
-return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
-if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
-this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
-if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
-window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
-var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
-this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
-if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,O
 verlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,initialize:function(div,options){if(argu
 ments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
-this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
-OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.viewPortDiv.appendChild(this.layerContainerDiv);this.events=new OpenLayers.Events(this,this.viewPortDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
-if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0,len=nodes.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
-if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
-if(this.controls==null){if(OpenLayers.Control!=null){this.controls=[new OpenLayers.Control.Navigation(),new OpenLayers.Control.PanZoom(),new OpenLayers.Control.ArgParser(),new OpenLayers.Control.Attribution()];}else{this.controls=[];}}
-for(var i=0,len=this.controls.length;i<len;i++){this.addControlToMap(this.controls[i]);}
-this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);if(options&&options.layers){this.addLayers(options.layers);if(options.center){this.setCenter(options.center,options.zoom);}}},render:function(div){this.div=OpenLayers.Util.getElement(div);OpenLayers.Element.addClass(this.div,'olMap');this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize();},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
-if(this.panTween){this.panTween.stop();this.panTween=null;}
-OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
-this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
-this.controls=null;}
-if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
-this.layers=null;}
-if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
-this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
-this.events.destroy();this.events=null;},setOptions:function(options){OpenLayers.Util.extend(this,options);},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
-return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
-+zIdx*5);},resetLayersZIndex:function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0,len=this.layers.length;i<len;i++){if(this.layers[i]==layer){var msg=OpenLayers.i18n('layerAlreadyAdded',{'layerName':layer.name});OpenLayers.Console.warn(msg);return false;}}
-if(this.allOverlays){layer.isBaseLayer=false;}
-if(this.events.triggerEvent("preaddlayer",{layer:layer})===false){return;}
-layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
-this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer||(this.allOverlays&&!this.baseLayer)){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
-this.events.triggerEvent("addlayer",{layer:layer});layer.events.triggerEvent("added",{map:this,layer:layer});layer.afterAdd();},addLayers:function(layers){for(var i=0,len=layers.length;i<len;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
-if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
-OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0,len=this.layers.length;i<len;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer||this.allOverlays){this.setBaseLayer(iLayer);break;}}}}
-this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});layer.events.triggerEvent("removed",{map:this,layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
-if(base!=idx){this.layers.splice(base,1);this.layers.splice(idx,0,layer);for(var i=0,len=this.layers.length;i<len;i++){this.setLayerZIndex(this.layers[i],i);}
-this.events.triggerEvent("changelayer",{layer:layer,property:"order"});if(this.allOverlays){if(idx===0){this.setBaseLayer(layer);}else if(this.baseLayer!==this.layers[0]){this.setBaseLayer(this.layers[0]);}}}},raiseLayer:function(layer,delta){var idx=this.getLayerIndex(layer)+delta;this.setLayerIndex(layer,idx);},setBaseLayer:function(newBaseLayer){if(newBaseLayer!=this.baseLayer){if(OpenLayers.Util.indexOf(this.layers,newBaseLayer)!=-1){var center=this.getCenter();var newResolution=OpenLayers.Util.getResolutionFromScale(this.getScale(),newBaseLayer.units);if(this.baseLayer!=null&&!this.allOverlays){this.baseLayer.setVisibility(false);}
-this.baseLayer=newBaseLayer;this.viewRequestID++;if(!this.allOverlays||this.baseLayer.visibility){this.baseLayer.setVisibility(true);}
-if(center!=null){var newZoom=this.getZoomForResolution(newResolution||this.resolution,true);this.setCenter(center,newZoom,false,true);}
-this.events.triggerEvent("changebaselayer",{layer:this.baseLayer});}}},addControl:function(control,px){this.controls.push(control);this.addControlToMap(control,px);},addControls:function(controls,pixels){var pxs=(arguments.length===1)?[]:pixels;for(var i=0,len=controls.length;i<len;i++){var ctrl=controls[i];var px=(pxs[i])?pxs[i]:null;this.addControl(ctrl,px);}},addControlToMap:function(control,px){control.outsideViewport=(control.div!=null);if(this.displayProjection&&!control.displayProjection){control.displayProjection=this.displayProjection;}
-control.setMap(this);var div=control.draw(px);if(div){if(!control.outsideViewport){div.style.zIndex=this.Z_INDEX_BASE['Control']+
-this.controls.length;this.viewPortDiv.appendChild(div);}}
-if(control.autoActivate){control.activate();}},getControl:function(id){var returnControl=null;for(var i=0,len=this.controls.length;i<len;i++){var control=this.controls[i];if(control.id==id){returnControl=control;break;}}
-return returnControl;},removeControl:function(control){if((control)&&(control==this.getControl(control.id))){if(control.div&&(control.div.parentNode==this.viewPortDiv)){this.viewPortDiv.removeChild(control.div);}
-OpenLayers.Util.removeItem(this.controls,control);}},addPopup:function(popup,exclusive){if(exclusive){for(var i=this.popups.length-1;i>=0;--i){this.removePopup(this.popups[i]);}}
-popup.map=this;this.popups.push(popup);var popupDiv=popup.draw();if(popupDiv){popupDiv.style.zIndex=this.Z_INDEX_BASE['Popup']+
-this.popups.length;this.layerContainerDiv.appendChild(popupDiv);}},removePopup:function(popup){OpenLayers.Util.removeItem(this.popups,popup);if(popup.div){try{this.layerContainerDiv.removeChild(popup.div);}
-catch(e){}}
-popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
-return size;},updateSize:function(){var newSize=this.getCurrentSize();if(newSize&&!isNaN(newSize.h)&&!isNaN(newSize.w)){this.events.clearMouseCache();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
-if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0,len=this.layers.length;i<len;i++){this.layers[i].onMapResize();}
-var center=this.getCenter();if(this.baseLayer!=null&&center!=null){var zoom=this.getZoom();this.zoom=null;this.setCenter(center,zoom);}}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=this.div.offsetWidth;size.h=this.div.offsetHeight;}
-if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
-return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCenter();}
-if(resolution==null){resolution=this.getResolution();}
-if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
-return extent;},getCenter:function(){var center=null;if(this.center){center=this.center.clone();}
-return center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
-var center=this.getCenter();if(lonlat.lon==center.lon&&lonlat.lat==center.lat){return;}
-var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,this.panDuration,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
-if(zoom!=null){zoom=parseFloat(zoom);if(!this.fractionalZoom){zoom=Math.round(zoom);}}
-var dragging=options.dragging;var forceZoomChange=options.forceZoomChange;var noEvent=options.noEvent;if(this.panTween&&options.caller=="setCenter"){this.panTween.stop();}
-if(!this.center&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();}
-if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.getCenter();}
-if(zoom==null){zoom=this.getZoom();}
-var resolution=this.getResolutionForZoom(zoom);var extent=this.calculateBounds(lonlat,resolution);if(!this.restrictedExtent.containsBounds(extent)){var maxCenter=this.restrictedExtent.getCenterLonLat();if(extent.getWidth()>this.restrictedExtent.getWidth()){lonlat=new OpenLayers.LonLat(maxCenter.lon,lonlat.lat);}else if(extent.left<this.restrictedExtent.left){lonlat=lonlat.add(this.restrictedExtent.left-
-extent.left,0);}else if(extent.right>this.restrictedExtent.right){lonlat=lonlat.add(this.restrictedExtent.right-
-extent.right,0);}
-if(extent.getHeight()>this.restrictedExtent.getHeight()){lonlat=new OpenLayers.LonLat(lonlat.lon,maxCenter.lat);}else if(extent.bottom<this.restrictedExtent.bottom){lonlat=lonlat.add(0,this.restrictedExtent.bottom-
-extent.bottom);}
-else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
-extent.top);}}}
-var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||!dragging){if(!this.dragging&&!noEvent){this.events.triggerEvent("movestart");}
-if(centerChanged){if((!zoomChanged)&&(this.center)){this.centerLayerContainer(lonlat);}
-this.center=lonlat.clone();}
-if((zoomChanged)||(this.layerContainerOrigin==null)){this.layerContainerOrigin=this.center.clone();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";}
-if(zoomChanged){this.zoom=zoom;this.resolution=this.getResolutionForZoom(zoom);this.viewRequestID++;}
-var bounds=this.getExtent();if(this.baseLayer.visibility){this.baseLayer.moveTo(bounds,zoomChanged,dragging);if(dragging){this.baseLayer.events.triggerEvent("move");}else{this.baseLayer.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});}}
-bounds=this.baseLayer.getExtent();for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer!==this.baseLayer&&!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
-this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
-if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,dragging);if(dragging){layer.events.triggerEvent("move");}else{layer.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});}}}}
-if(zoomChanged){for(var i=0,len=this.popups.length;i<len;i++){this.popups[i].updatePosition();}}
-this.events.triggerEvent("move");if(zoomChanged){this.events.triggerEvent("zoomend");}}
-if(!dragging&&!noEvent){this.events.triggerEvent("moveend");}
-this.dragging=!!dragging;},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){this.layerContainerDiv.style.left=Math.round(originPx.x-newPx.x)+"px";this.layerContainerDiv.style.top=Math.round(originPx.y-newPx.y)+"px";}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=this.getRestrictedMinZoom())&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
-return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
-return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
-return maxResolution;},getMaxExtent:function(options){var maxExtent=null;if(options&&options.restricted&&this.restrictedExtent){maxExtent=this.restrictedExtent;}else if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
-return maxExtent;},getRestrictedMinZoom:function(){var minZoom=null;if(this.baseLayer!=null){minZoom=this.baseLayer.restrictedMinZoom;}
-return minZoom;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
-return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
-return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}else if(this.allOverlays===true&&this.layers.length>0){resolution=this.layers[0].getResolution();}
-return resolution;},getUnits:function(){var units=null;if(this.baseLayer!=null){units=this.baseLayer.units;}
-return units;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
-return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
-return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
-return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
-return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds,closest){var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
-center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
-this.setCenter(center,this.getZoomForExtent(bounds,closest));},zoomToMaxExtent:function(options){var restricted=(options)?options.restricted:true;var maxExtent=this.getMaxExtent({'restricted':restricted});this.zoomToExtent(maxExtent);},zoomToScale:function(scale,closest){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var size=this.getSize();var w_deg=size.w*res;var h_deg=size.h*res;var center=this.getCenter();var extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);this.zoomToExtent(extent,closest);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
-return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
-return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
-return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
-return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution
 :null,numZoomLevels:null,restrictedMinZoom:0,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
-if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
-if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
-this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
-this.events.destroy();}
-this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.getOptions());}
-OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},getOptions:function(){var options={};for(var o in this.options){options[o]=this[o];}
-return options;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions){if(this.options==null){this.options={};}
-OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
-if(this.projection&&this.projection.getUnits()){this.units=this.projection.getUnits();}
-if(this.map){var properties=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]);for(var o in newOptions){if(newOptions.hasOwnProperty(o)&&OpenLayers.Util.indexOf(properties,o)>=0){this.initResolutions();break;}}}},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){var zoomChanged=true;this.moveTo(extent,zoomChanged,false);this.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});redrawn=true;}}
-return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
-this.display(display);},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
-this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
-this.setTileSize();}},afterAdd:function(){},removeMap:function(map){},getImageSize:function(bounds){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
-this.events.triggerEvent("visibilitychanged");}},display:function(display){if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&this.calculateInRange())?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.alwaysInRange){inRange=true;}else{if(this.map){var resolution=this.map.getResolution();inRange=(this.map.getZoom()>=this.restrictedMinZoom&&(resolution>=this.minResolution)&&(resolution<=this.maxResolution));}}
-return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var i,len;var props={},alwaysInRange=true;for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){var p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p];if(alwaysInRange&&this.options[p]){alwaysInRange=false;}}
-if(this.alwaysInRange==null){this.alwaysInRange=alwaysInRange;}
-if(props.resolutions==null){props.resolutions=this.resolutionsFromScales(props.scales);}
-if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}
-if(props.resolutions==null){for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){var p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p]!=null?this.options[p]:this.map[p];}
-if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}}
-var maxResolution;if(this.options.maxResolution&&this.options.maxResolution!=="auto"){maxResolution=this.options.maxResolution;}
-if(this.options.minScale){maxResolution=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units);}
-var minResolution;if(this.options.minResolution&&this.options.minResolution!=="auto"){minResolution=this.options.minResolution;}
-if(this.options.maxScale){minResolution=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units);}
-if(props.resolutions){props.resolutions.sort(function(a,b){return(b-a);});if(!maxResolution){maxResolution=props.resolutions[0];}
-if(!minResolution){var lastIdx=props.resolutions.length-1;minResolution=props.resolutions[lastIdx];}}
-this.resolutions=props.resolutions;if(this.resolutions){len=this.resolutions.length;this.scales=new Array(len);for(i=0;i<len;i++){this.scales[i]=OpenLayers.Util.getScaleFromResolution(this.resolutions[i],this.units);}
-this.numZoomLevels=len;}
-this.minResolution=minResolution;if(minResolution){this.maxScale=OpenLayers.Util.getScaleFromResolution(minResolution,this.units);}
-this.maxResolution=maxResolution;if(maxResolution){this.minScale=OpenLayers.Util.getScaleFromResolution(maxResolution,this.units);}},resolutionsFromScales:function(scales){if(scales==null){return;}
-var resolutions,i,len;len=scales.length;resolutions=new Array(len);for(i=0;i<len;i++){resolutions[i]=OpenLayers.Util.getResolutionFromScale(scales[i],this.units);}
-return resolutions;},calculateResolutions:function(props){var maxResolution=props.maxResolution;if(props.minScale!=null){maxResolution=OpenLayers.Util.getResolutionFromScale(props.minScale,this.units);}else if(maxResolution=="auto"&&this.maxExtent!=null){var viewSize=this.map.getSize();var wRes=this.maxExtent.getWidth()/viewSize.w;var hRes=this.maxExtent.getHeight()/viewSize.h;maxResolution=Math.max(wRes,hRes);}
-var minResolution=props.minResolution;if(props.maxScale!=null){minResolution=OpenLayers.Util.getResolutionFromScale(props.maxScale,this.units);}else if(props.minResolution=="auto"&&this.minExtent!=null){var viewSize=this.map.getSize();var wRes=this.minExtent.getWidth()/viewSize.w;var hRes=this.minExtent.getHeight()/viewSize.h;minResolution=Math.max(wRes,hRes);}
-var maxZoomLevel=props.maxZoomLevel;var numZoomLevels=props.numZoomLevels;if(typeof minResolution==="number"&&typeof maxResolution==="number"&&numZoomLevels===undefined){var ratio=maxResolution/minResolution;numZoomLevels=Math.floor(Math.log(ratio)/Math.log(2))+1;}else if(numZoomLevels===undefined&&maxZoomLevel!=null){numZoomLevels=maxZoomLevel+1;}
-if(typeof numZoomLevels!=="number"||numZoomLevels<=0||(typeof maxResolution!=="number"&&typeof minResolution!=="number")){return;}
-var resolutions=new Array(numZoomLevels);var base=2;if(typeof minResolution=="number"&&typeof maxResolution=="number"){base=Math.pow((maxResolution/minResolution),(1/(numZoomLevels-1)));}
-var i;if(typeof maxResolution==="number"){for(i=0;i<numZoomLevels;i++){resolutions[i]=maxResolution/Math.pow(base,i);}}else{for(i=0;i<numZoomLevels;i++){resolutions[numZoomLevels-1-i]=minResolution*Math.pow(base,i);}}
-return resolutions;},getResolution:function(){var zoom=this.map.getZoom();return this.getResolutionForZoom(zoom);},getExtent:function(){return this.map.calculateBounds();},getZoomForExtent:function(extent,closest){var viewSize=this.map.getSize();var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);return this.getZoomForResolution(idealResolution,closest);},getDataExtent:function(){},getResolutionForZoom:function(zoom){zoom=Math.max(0,Math.min(zoom,this.resolutions.length-1));var resolution;if(this.map.fractionalZoom){var low=Math.floor(zoom);var high=Math.ceil(zoom);resolution=this.resolutions[low]-
-((zoom-low)*(this.resolutions[low]-this.resolutions[high]));}else{resolution=this.resolutions[Math.round(zoom)];}
-return resolution;},getZoomForResolution:function(resolution,closest){var zoom;if(this.map.fractionalZoom){var lowZoom=0;var highZoom=this.resolutions.length-1;var highRes=this.resolutions[lowZoom];var lowRes=this.resolutions[highZoom];var res;for(var i=0,len=this.resolutions.length;i<len;++i){res=this.resolutions[i];if(res>=resolution){highRes=res;lowZoom=i;}
-if(res<=resolution){lowRes=res;highZoom=i;break;}}
-var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((highRes-resolution)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(var i=0,len=this.resolutions.length;i<len;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
-minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
-zoom=Math.max(0,i-1);}
-return Math.max(this.restrictedMinZoom,zoom);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(viewPortPx!=null){var size=this.map.getSize();var center=this.map.getCenter();if(center){var res=this.map.getResolution();var delta_x=viewPortPx.x-(size.w/2);var delta_y=viewPortPx.y-(size.h/2);lonlat=new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(lonlat!=null){var resolution=this.map.getResolution();var extent=this.map.getExtent();px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
-return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.div.childNodes.length;i<len;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}
-if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}}},getZIndex:function(){return this.div.style.zIndex;},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
-if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
-return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
-return extent;},getLonLatFromViewPortPx:function(viewPortPx){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments);},getViewPortPxFromLonLat:function(lonlat){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments);},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.03390625;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
-this.units="m";this.projection=this.projection||"EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};(function(){var codes=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"];var add=OpenLayers.Projection.addTransform;var merc=OpenLayers.Layer.SphericalMercator;var same=OpenLayers.Projection.nullTransform;var i,len,code,oth
 er,j;for(i=0,len=codes.length;i<len;++i){code=codes[i];add("EPSG:4326",code,merc.projectForward);add(code,"EPSG:4326",merc.projectInverse);for(j=i+1;j<len;++j){other=codes[j];add(code,other,same);add(other,code,same);}}})();OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;this.pane=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.BROWSER_NAME=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLo
 cation()+"blank.gif)";}
-if(this.isFixed){this.map.viewPortDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
-this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);}
-OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.ap
 ply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(dragging&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFr
 omMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
-return viewPortPx;},getOLLonLatFromMapObjectLonLat:function(moLonLat){var olLonLat=null;if(moLonLat!=null){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);olLonLat=new OpenLayers.LonLat(lon,lat);}
-return olLonLat;},getMapObjectLonLatFromOLLonLat:function(olLonLat){var moLatLng=null;if(olLonLat!=null){moLatLng=this.getMapObjectLonLatFromLonLat(olLonLat.lon,olLonLat.lat);}
-return moLatLng;},getOLPixelFromMapObjectPixel:function(moPixel){var olPixel=null;if(moPixel!=null){var x=this.getXFromMapObjectPixel(moPixel);var y=this.getYFromMapObjectPixel(moPixel);olPixel=new OpenLayers.Pixel(x,y);}
-return olPixel;},getMapObjectPixelFromOLPixel:function(olPixel){var moPixel=null;if(olPixel!=null){moPixel=this.getMapObjectPixelFromXY(olPixel.x,olPixel.y);}
-return moPixel;},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){var props=new Array('minZoomLevel','maxZoomLevel','numZoomLevels');for(var i=0,len=props.length;i<len;i++){var property=props[i];this[property]=(this.options[property]!=null)?this.options[property]:this.map[property];}
-if((this.minZoomLevel==null)||(this.minZoomLevel<this.MIN_ZOOM_LEVEL)){this.minZoomLevel=this.MIN_ZOOM_LEVEL;}
-var desiredZoomLevels;var limitZoomLevels=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;if(((this.options.numZoomLevels==null)&&(this.options.maxZoomLevel!=null))||((this.numZoomLevels==null)&&(this.maxZoomLevel!=null))){desiredZoomLevels=this.maxZoomLevel-this.minZoomLevel+1;}else{desiredZoomLevels=this.numZoomLevels;}
-if(desiredZoomLevels!=null){this.numZoomLevels=Math.min(desiredZoomLevels,limitZoomLevels);}else{this.numZoomLevels=limitZoomLevels;}
-this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
-this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
-return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
-return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;}
-return zoom;},CLASS_NAME:"OpenLayers.Layer.FixedZoomLevels"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:21,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257,0.0000013411045074462891,0.00000067055225372314453],type:null,wrapDateLine:true,sphericalMercator:false,version:null,initialize:function(name,options){options=options||{};if(!options.version){options.version=typeof GMap2==="function"?"2":"3";}
-var mixin=OpenLayers.Layer.Google["v"+
-options.version.replace(/\./g,"_")];if(mixin){OpenLayers.Util.applyDefaults(options,mixin);}else{throw"Unsupported Google Maps API version: "+options.version;}
-OpenLayers.Util.applyDefaults(options,mixin.DEFAULTS);if(options.maxExtent){options.maxExtent=options.maxExtent.clone();}
-OpenLayers.Layer.EventPane.prototype.initialize.apply(this,[name,options]);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,[name,options]);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},clone:function(){return new OpenLayers.Layer.Google(this.name,this.getOptions());},setVisibility:function(visible){var opacity=this.opacity==null?1:this.opacity;OpenLayers.Layer.EventPane.prototype.setVisibility.apply(this,arguments);this.setOpacity(opacity);},display:function(visible){if(!this._dragging){this.setGMapVisibility(visible);}
-OpenLayers.Layer.EventPane.prototype.display.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){this._dragging=dragging;OpenLayers.Layer.EventPane.prototype.moveTo.apply(this,arguments);delete this._dragging;},setOpacity:function(opacity){if(opacity!==this.opacity){if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}
-this.opacity=opacity;}
-if(this.getVisibility()){var container=this.getMapContainer();OpenLayers.Util.modifyDOMElement(container,null,null,null,null,null,null,opacity);}},destroy:function(){if(this.map){this.setGMapVisibility(false);var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache&&cache.count<=1){this.removeGMapElements();}}
-OpenLayers.Layer.EventPane.prototype.destroy.apply(this,arguments);},removeGMapElements:function(){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject&&this.getMapContainer();if(container&&container.parentNode){container.parentNode.removeChild(container);}
-var termsOfUse=cache.termsOfUse;if(termsOfUse&&termsOfUse.parentNode){termsOfUse.parentNode.removeChild(termsOfUse);}
-var poweredBy=cache.poweredBy;if(poweredBy&&poweredBy.parentNode){poweredBy.parentNode.removeChild(poweredBy);}}},removeMap:function(map){if(this.visibility&&this.mapObject){this.setGMapVisibility(false);}
-var cache=OpenLayers.Layer.Google.cache[map.id];if(cache){if(cache.count<=1){this.removeGMapElements();delete OpenLayers.Layer.Google.cache[map.id];}else{--cache.count;}}
-delete this.termsOfUse;delete this.poweredBy;delete this.mapObject;delete this.dragObject;OpenLayers.Layer.EventPane.prototype.removeMap.apply(this,arguments);},getOLBoundsFromMapObjectBounds:function(moBounds){var olBounds=null;if(moBounds!=null){var sw=moBounds.getSouthWest();var ne=moBounds.getNorthEast();if(this.sphericalMercator){sw=this.forwardMercator(sw.lng(),sw.lat());ne=this.forwardMercator(ne.lng(),ne.lat());}else{sw=new OpenLayers.LonLat(sw.lng(),sw.lat());ne=new OpenLayers.LonLat(ne.lng(),ne.lat());}
-olBounds=new OpenLayers.Bounds(sw.lon,sw.lat,ne.lon,ne.lat);}
-return olBounds;},getWarningHTML:function(){return OpenLayers.i18n("googleWarning");},getMapObjectCenter:function(){return this.mapObject.getCenter();},getMapObjectZoom:function(){return this.mapObject.getZoom();},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lon:moLonLat.lng();},getLatitudeFromMapObjectLonLat:function(moLonLat){var lat=this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lat:moLonLat.lat();return lat;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Google.cache={};OpenLayers.Layer.Google.v2={termsOfUse:null,poweredBy:null,dragObject:null,loadMapObject:function(){if(!this.type){this.type=G_NORMAL_MAP;}
-var mapObject,termsOfUse,poweredBy;var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){mapObject=cache.mapObject;termsOfUse=cache.termsOfUse;poweredBy=cache.poweredBy;++cache.count;}else{var container=this.map.viewPortDiv;var div=document.createElement("div");div.id=this.map.id+"_GMap2Container";div.style.position="absolute";div.style.width="100%";div.style.height="100%";container.appendChild(div);try{mapObject=new GMap2(div);termsOfUse=div.lastChild;container.appendChild(termsOfUse);termsOfUse.style.zIndex="1100";termsOfUse.style.right="";termsOfUse.style.bottom="";termsOfUse.className="olLayerGoogleCopyright";poweredBy=div.lastChild;container.appendChild(poweredBy);poweredBy.style.zIndex="1100";poweredBy.style.right="";poweredBy.style.bottom="";poweredBy.className="olLayerGooglePoweredBy gmnoprint";}catch(e){throw(e);}
-OpenLayers.Layer.Google.cache[this.map.id]={mapObject:mapObject,termsOfUse:termsOfUse,poweredBy:poweredBy,count:1};}
-this.mapObject=mapObject;this.termsOfUse=termsOfUse;this.poweredBy=poweredBy;if(OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)===-1){this.mapObject.addMapType(this.type);}
-if(typeof mapObject.getDragObject=="function"){this.dragObject=mapObject.getDragObject();}else{this.dragPanMapObject=null;}
-if(this.isBaseLayer===false){this.setGMapVisibility(this.div.style.display!=="none");}},onMapResize:function(){if(this.visibility&&this.mapObject.isLoaded()){this.mapObject.checkResize();}else{if(!this._resized){var layer=this;var handle=GEvent.addListener(this.mapObject,"load",function(){GEvent.removeListener(handle);delete layer._resized;layer.mapObject.checkResize();layer.moveTo(layer.map.getCenter(),layer.map.getZoom());});}
-this._resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject.getContainer();if(visible===true){this.mapObject.setMapType(this.type);container.style.display="";this.termsOfUse.style.left="";this.termsOfUse.style.display="";this.poweredBy.style.display="";cache.displayed=this.id;}else{if(cache.displayed===this.id){delete cache.displayed;}
-if(!cache.displayed){container.style.display="none";this.termsOfUse.style.display="none";this.termsOfUse.style.left="-9999px";this.poweredBy.style.display="none";}}}},getMapContainer:function(){return this.mapObject.getContainer();},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
-return moBounds;},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
-return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);}};OpenLayers.Format.WFST=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WFST.DEFAULTS);var cls=OpenLayers.Format.WFST["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFST version: "+options.version;}
+return node;},"WellKnownName":function(name){return this.createElementNSPlus("sld:WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("sld:Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("sld:Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("sld:Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("sld:OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("sld:Format",{value:format});}}},OpenLayers.Format.Filter.v1_0_0.prototype.writers),CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Format.WFST=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WFST.DEFAULTS);var cls=OpenLayers.Format.WFST["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFST version: "+options.version;}
 return new cls(options);};OpenLayers.Format.WFST.DEFAULTS={"version":"1.0.0"};OpenLayers.Format.WFST.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs",gml:"http://www.opengis.net/gml",ogc:"http://www.opengis.net/ogc"},defaultPrefix:"wfs",version:null,schemaLocations:null,srsName:null,extractAttributes:true,xy:true,stateName:null,initialize:function(options){this.stateName={};this.stateName[OpenLayers.State.INSERT]="wfs:Insert";this.stateName[OpenLayers.State.UPDATE]="wfs:Update";this.stateName[OpenLayers.State.DELETE]="wfs:Delete";OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},getSrsName:function(feature,options){var srsName=options&&options.srsName;if(!srsName){if(feature&&feature.layer){srsName=feature.layer.projection.getCode();}else{srsName=this.srsName;}}
 return srsName;},read:function(data,options){options=options||{};OpenLayers.Util.applyDefaults(options,{output:"features"});if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
@@ -1287,26 +1151,8 @@
 options.featureType,srsName:options.srsName}});if(options.featureNS){node.setAttribute("xmlns:"+options.featurePrefix,options.featureNS);}
 if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("wfs:PropertyName",{property:options.propertyNames[i]},node);}}
 if(options.filter){this.setFilterProperty(options.filter);this.writeNode("ogc:Filter",options.filter,node);}
-return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515],type:null,wrapDateLine:true,sphericalMercator:false,animationEnabled:true,initialize:function(name,options){OpenLay
 ers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var sz=this.map.getSize();veDiv.style.width=sz.w+"px";veDiv.style.height=sz.h+"px";this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
-if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",OpenLayers.Function.True);}catch(e){}
-this.mapObject.HideDashboard();if(typeof this.mapObject.SetAnimationEnabled=="function"){this.mapObject.SetAnimationEnabled(this.animationEnabled);}}
-if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},onMapResize:function(){this.mapObject.Resize(this.map.size.w,this.map.size.h);},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return(typeof VEPixel!='undefined')?this.mapObject.PixelToLatLong(moPixel):this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:f
 unction(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
-return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return(typeof VEPixel!='undefined')?new VEPixel(x,y):new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
-this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
-if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
-this.handlers=null;}
-if(this.map){this.map.removeControl(this);this.map=null;}},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
-if(this.title!=""){this.div.title=this.title;}}
-if(px!=null){this.position=px.clone();}
-this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
-if(this.handler){this.handler.activate();}
-this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
-this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
-this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
-this.events.triggerEvent("deactivate");return true;}
-return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var i=this.controls.length-1;i>=0;i--){if(this.controls[i].events){this.controls[i].events.un({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
+return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Format.CSWGetRecords=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.CSWGetRecords.DEFAULTS);var cls=OpenLayers.Format.CSWGetRecords["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported CSWGetRecords version: "+options.version;}
+return new cls(options);};OpenLayers.Format.CSWGetRecords.DEFAULTS={"version":"2.0.2"};OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var i=this.controls.length-1;i>=0;i--){if(this.controls[i].events){this.controls[i].events.un({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
 OpenLayers.Event.stopObservingElement(this.controls[i].panel_div);this.controls[i].panel_div=null;}
 this.activeState=null;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];if(control===this.defaultControl||(this.saveState&&this.activeState[control.id])){control.activate();}}
 if(this.saveState===true){this.defaultControl=null;}
@@ -1458,7 +1304,16 @@
 return attributes;},parsePointGeometry:function(node){var ringPoints=[];var coords=node.getElementsByTagName("COORDS");if(coords.length>0){var coordArr=this.getChildValue(coords[0]);coordArr=coordArr.split(/;/);for(var cn=0;cn<coordArr.length;cn++){var coordItems=coordArr[cn].split(/ /);ringPoints.push(new OpenLayers.Geometry.Point(parseFloat(coordItems[0]),parseFloat(coordItems[1])));}
 coords=null;}else{var point=node.getElementsByTagName("POINT");if(point.length>0){for(var pn=0;pn<point.length;pn++){ringPoints.push(new OpenLayers.Geometry.Point(parseFloat(point[pn].getAttribute("x")),parseFloat(point[pn].getAttribute("y"))));}}
 point=null;}
-return new OpenLayers.Geometry.LinearRing(ringPoints);},CLASS_NAME:"OpenLayers.Format.ArcXML"});OpenLayers.Format.ArcXML.Request=OpenLayers.Class({initialize:function(params){var defaults={get_image:{properties:{background:null,draw:true,envelope:{minx:0,miny:0,maxx:0,maxy:0},featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},imagesize:{height:0,width:0,dpi:96,printheight:0,printwidth:0,scalesymbols:false},layerlist:[],output:{baseurl:"",legendbaseurl:"",legendname:"",legendpath:"",legendurl:"",name:"",path:"",type:"jpg",url:""}}},get_feature:{layer:"",query:{isspatial:false,featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},buffer:0,where:"",spatialfilter:{relation:"envelope_intersection",envelope:null}}},environment:{separators:{cs:" ",ts:";"}},layer:[],workspaces:[]};return O
 penLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Request"});OpenLayers.Format.ArcXML.Response=OpenLayers.Class({initialize:function(params){var defaults={image:{envelope:null,output:''},features:{featurecount:0,envelope:null,feature:[]},error:''};return OpenLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Response"});OpenLayers.Layer.ArcIMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{ClientVersion:"9.2",ServiceName:''},tileSize:null,featureCoordSys:"4326",filterCoordSys:"4326",layers:null,async:true,name:"ArcIMS",isBaseLayer:true,DEFAULT_OPTIONS:{tileSize:new OpenLayers.Size(512,512),featureCoordSys:"4326",filterCoordSys:"4326",layers:null,isBaseLayer:true,async:true,name:"ArcIMS"},initialize:function(name,url,options){this.tileSize=new OpenLayers.Size(512,512);this.params=OpenLayers.Util.applyDefaults({ServiceName:options.serviceName},this.DEFAULT_PARAMS);this.options=OpenLayers.Util.applyDefaults(options,this.D
 EFAULT_OPTIONS);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,this.params,options]);if(this.transparent){if(!this.isBaseLayer){this.isBaseLayer=false;}
+return new OpenLayers.Geometry.LinearRing(ringPoints);},CLASS_NAME:"OpenLayers.Format.ArcXML"});OpenLayers.Format.ArcXML.Request=OpenLayers.Class({initialize:function(params){var defaults={get_image:{properties:{background:null,draw:true,envelope:{minx:0,miny:0,maxx:0,maxy:0},featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},imagesize:{height:0,width:0,dpi:96,printheight:0,printwidth:0,scalesymbols:false},layerlist:[],output:{baseurl:"",legendbaseurl:"",legendname:"",legendpath:"",legendurl:"",name:"",path:"",type:"jpg",url:""}}},get_feature:{layer:"",query:{isspatial:false,featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},buffer:0,where:"",spatialfilter:{relation:"envelope_intersection",envelope:null}}},environment:{separators:{cs:" ",ts:";"}},layer:[],workspaces:[]};return O
 penLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Request"});OpenLayers.Format.ArcXML.Response=OpenLayers.Class({initialize:function(params){var defaults={image:{envelope:null,output:''},features:{featurecount:0,envelope:null,feature:[]},error:''};return OpenLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Response"});OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this,null,["complete","success","failure"]),issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var request=new OpenLayers.Request.XMLHttpRequest();var url=Open
 Layers.Util.urlAppend(config.url,OpenLayers.Util.getParameterString(config.params||{}));var sameOrigin=!(url.indexOf("http")==0);var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protocol&&urlParts[3]==location.hostname;var uPort=urlParts[4],lPort=location.port;if(uPort!=80&&uPort!=""||lPort!="80"&&lPort!=""){sameOrigin=sameOrigin&&uPort==lPort;}}
+if(!sameOrigin){if(config.proxy){if(typeof config.proxy=="function"){url=config.proxy(url);}else{url=config.proxy+encodeURIComponent(url);}}else{OpenLayers.Console.warn(OpenLayers.i18n("proxyNeeded"),{url:url});}}
+request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
+var events=this.events;var self=this;request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){var proceed=events.triggerEvent("complete",{request:request,config:config,requestUrl:url});if(proceed!==false){self.runCallbacks({request:request,config:config,requestUrl:url});}}};if(config.async===false){request.send(config.data);}else{window.setTimeout(function(){if(request.readyState!==0){request.send(config.data);}},0);}
+return request;},runCallbacks:function(options){var request=options.request;var config=options.config;var complete=(config.scope)?OpenLayers.Function.bind(config.callback,config.scope):config.callback;var success;if(config.success){success=(config.scope)?OpenLayers.Function.bind(config.success,config.scope):config.success;}
+var failure;if(config.failure){failure=(config.scope)?OpenLayers.Function.bind(config.failure,config.scope):config.failure;}
+complete(request);if(!request.status||(request.status>=200&&request.status<300)){this.events.triggerEvent("success",options);if(success){success(request);}}
+if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("failure",options);if(failure){failure(request);}}},GET:function(config){config=OpenLayers.Util.extend(config,{method:"GET"});return OpenLayers.Request.issue(config);},POST:function(config){config=OpenLayers.Util.extend(config,{method:"POST"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},PUT:function(config){config=OpenLayers.Util.extend(config,{method:"PUT"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}};OpenLayers.Layer.ArcIMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{ClientVersion:"9.2",ServiceName:''},tileSize:null,featureCoordSys:"4326",filterCoordSys:"4326",layers:null,async:true,name:"ArcIMS",isBaseLayer:true,DEFAULT_OPTIONS:{tileSize:new OpenLayers.Size(512,512),featureCoordSys:"4326",filterCoordSys:"4326",layers:null,isBaseLayer:true,async:true,name:"ArcIMS"},initialize:function(name,url,options){this.tileSize=new OpenLayers.Size(512,512);this.params=OpenLayers.Util.applyDefaults({ServiceName:options.serviceName},this.DEFAULT_PARAMS);this.options=OpenLay
 ers.Util.applyDefaults(options,this.DEFAULT_OPTIONS);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,this.params,options]);if(this.transparent){if(!this.isBaseLayer){this.isBaseLayer=false;}
 if(this.format=="image/jpeg"){this.format=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}
 if(this.options.layers===null){this.options.layers=[];}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},getURL:function(bounds){var url="";bounds=this.adjustBounds(bounds);var axlReq=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:bounds.toArray(),tileSize:this.tileSize}));var req=new OpenLayers.Request.POST({url:this.getFullRequestString(),data:axlReq.write(),async:false});if(req!=null){var doc=req.responseXML;if(!doc||!doc.documentElement){doc=req.responseText;}
 var axlResp=new OpenLayers.Format.ArcXML();var arcxml=axlResp.read(doc);url=this.getUrlOrImage(arcxml.image.output);}
@@ -1473,11 +1328,7 @@
 return false;},CLASS_NAME:"OpenLayers.Strategy"});OpenLayers.Strategy.Filter=OpenLayers.Class(OpenLayers.Strategy,{filter:null,cache:null,caching:false,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.apply(this,arguments);if(activated){this.cache=[];this.layer.events.on({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
 return activated;},deactivate:function(){this.cache=null;if(this.layer&&this.layer.events){this.layer.events.un({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
 return OpenLayers.Strategy.prototype.deactivate.apply(this,arguments);},handleAdd:function(event){if(!this.caching&&this.filter){var features=event.features;event.features=[];var feature;for(var i=0,ii=features.length;i<ii;++i){feature=features[i];if(this.filter.evaluate(feature)){event.features.push(feature);}else{this.cache.push(feature);}}}},handleRemove:function(event){if(!this.caching){this.cache=[];}},setFilter:function(filter){this.filter=filter;var previousCache=this.cache;this.cache=[];this.handleAdd({features:this.layer.features});if(this.cache.length>0){this.caching=true;this.layer.removeFeatures(this.cache.slice(),{silent:true});this.caching=false;}
-if(previousCache.length>0){var event={features:previousCache};this.handleAdd(event);this.caching=true;this.layer.addFeatures(event.features,{silent:true});this.caching=false;}},CLASS_NAME:"OpenLayers.Strategy.Filter"});OpenLayers.Format.WFSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.0",version:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-var constr=OpenLayers.Format.WFSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw"Can't find a WFS capabilities parser for version "+version;}
-var parser=new constr(this.options);var capabilities=parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.WFSCapabilities"});OpenLayers.Format.WFSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.WFSCapabilities,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var capabilities={};var root=data.documentElement;this.runChildNodes(capabilities,root);return capabilities;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){processor=this["read_cap_"+childNode.nodeName];if(processor){processor.apply(this,[obj,childNode]);}}}},read_cap_FeatureTypeList:function(request,node){var featureTypeList={featureTypes:[]};this.runChildNodes(featureTypeList,node);request.featureTypeList=featureTypeList;},read_cap_FeatureType:function(featureTypeList,node,parentLayer){var featureType={};this.runChildNodes(featureType,node);featureTypeList.featureTypes.push(featureType);},read_cap_Name:function(obj,node){var name=this.getChildValue(node);if(name){var parts=name.split(":");obj.name=parts.pop();if(parts.length>0){obj.featureNS=this.lookupNamespaceURI(node,parts[0]);}}},read_cap_Title:function(obj,node){var title=this.getChildValue(node);
 if(title){obj.title=title;}},read_cap_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1"});OpenLayers.Format.WFSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(options){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_1_0"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:true,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(name,url,extent,size,options){this.url=url;this.extent=extent;this.maxExtent=extent;this.size=size;OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.aspectRatio=(this.extent.getHeight()/this.size.h)/(this.extent.getWidth()/this.size.w);},destroy:function(){if(this.tile){this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;}
+if(previousCache.length>0){var event={features:previousCache};this.handleAdd(event);this.caching=true;this.layer.addFeatures(event.features,{silent:true});this.caching=false;}},CLASS_NAME:"OpenLayers.Strategy.Filter"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:true,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(name,url,extent,size,options){this.url=url;this.extent=extent;this.maxExtent=extent;this.size=size;OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.aspectRatio=(this.extent.getHeight()/this.size.h)/(this.extent.getWidth()/this.size.w);},destroy:function(){if(this.tile){this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;}
 OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.getOptions());}
 obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setMap:function(map){if(this.options.maxResolution==null){this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;}
 OpenLayers.Layer.prototype.setMap.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var firstRendering=(this.tile==null);if(zoomChanged||firstRendering){this.setTileSize();var ul=new OpenLayers.LonLat(this.extent.left,this.extent.top);var ulPx=this.map.getLayerPxFromLonLat(ul);if(firstRendering){this.tile=new OpenLayers.Tile.Image(this,ulPx,this.extent,null,this.tileSize);this.addTileMonitoringHooks(this.tile);}else{this.tile.size=this.tileSize.clone();this.tile.position=ulPx.clone();}
@@ -1501,14 +1352,42 @@
 return features;},extractSegment:function(segment,segmentType){var points=this.getElementsByTagNameNS(segment,segment.namespaceURI,segmentType);var point_features=[];for(var i=0,len=points.length;i<len;i++){point_features.push(new OpenLayers.Geometry.Point(points[i].getAttribute("lon"),points[i].getAttribute("lat")));}
 return new OpenLayers.Geometry.LineString(point_features);},parseAttributes:function(node){var attributes={};var attrNode=node.firstChild,value,name;while(attrNode){if(attrNode.nodeType==1){value=attrNode.firstChild;if(value.nodeType==3||value.nodeType==4){name=(attrNode.prefix)?attrNode.nodeName.split(":")[1]:attrNode.nodeName;if(name!="trkseg"&&name!="rtept"){attributes[name]=value.nodeValue;}}}
 attrNode=attrNode.nextSibling;}
-return attributes;},CLASS_NAME:"OpenLayers.Format.GPX"});OpenLayers.Format.WFSDescribeFeatureType=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xsd:"http://www.w3.org/2001/XMLSchema"},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},readers:{"xsd":{"schema":function(node,obj){var complexTypes=[];var customTypes={};var schema={complexTypes:complexTypes,customTypes:customTypes};this.readChildNodes(node,schema);var attributes=node.attributes;var attr,name;for(var i=0,len=attributes.length;i<len;++i){attr=attributes[i];name=attr.name;if(name.indexOf("xmlns")==0){this.setNamespace(name.split(":")[1]||"",attr.value);}else{obj[name]=attr.value;}}
-obj.featureTypes=complexTypes;obj.targetPrefix=this.namespaceAlias[obj.targetNamespace];var complexType,customType;for(var i=0,len=complexTypes.length;i<len;++i){complexType=complexTypes[i];customType=customTypes[complexType.typeName];if(customTypes[complexType.typeName]){complexType.typeName=customType.name;}}},"complexType":function(node,obj){var complexType={"typeName":node.getAttribute("name")};this.readChildNodes(node,complexType);obj.complexTypes.push(complexType);},"complexContent":function(node,obj){this.readChildNodes(node,obj);},"extension":function(node,obj){this.readChildNodes(node,obj);},"sequence":function(node,obj){var sequence={elements:[]};this.readChildNodes(node,sequence);obj.properties=sequence.elements;},"element":function(node,obj){if(obj.elements){var element={};var attributes=node.attributes;var attr;for(var i=0,len=attributes.length;i<len;++i){attr=attributes[i];element[attr.name]=attr.value;}
-var type=element.type;if(!type){type={};this.readChildNodes(node,type);element.restriction=type;element.type=type.base;}
-var fullType=type.base||type;element.localType=fullType.split(":").pop();obj.elements.push(element);}
-if(obj.complexTypes){var type=node.getAttribute("type");var localType=type.split(":").pop();obj.customTypes[localType]={"name":node.getAttribute("name"),"type":type};}},"simpleType":function(node,obj){this.readChildNodes(node,obj);},"restriction":function(node,obj){obj.base=node.getAttribute("base");this.readRestriction(node,obj);}}},readRestriction:function(node,obj){var children=node.childNodes;var child,nodeName,value;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){nodeName=child.nodeName.split(":").pop();value=child.getAttribute("value");if(!obj[nodeName]){obj[nodeName]=value;}else{if(typeof obj[nodeName]=="string"){obj[nodeName]=[obj[nodeName]];}
-obj[nodeName].push(value);}}}},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var schema={};this.readNode(data,schema);return schema;},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(resolutionChanged){this.resolution=null;}},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
+return attributes;},CLASS_NAME:"OpenLayers.Format.GPX"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
+var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
+this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,drawing:false,mouseDown:false,lastDown:null,lastUp:null,persist:false,layerOptions:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.
 style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
+var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
+if(this.drawing){this.cancel();}
+this.destroyFeature();if(this.layer.map!=null){this.layer.destroy(false);}
+this.layer=null;return true;},destroyFeature:function(){if(this.layer){this.layer.destroyFeatures();}
+this.point=null;},finalize:function(cancel){var key=cancel?"cancel":"done";this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback(key,[this.geometryClone()]);if(cancel||!this.persist){this.destroyFeature();}},cancel:function(){this.finalize(true);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
+return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){if(!this.checkModifiers(evt)){return true;}
+if(this.lastDown&&this.lastDown.equals(evt.xy)){return true;}
+this.drawing=true;if(this.lastDown==null){if(this.persist){this.destroyFeature();}
+this.createFeature(evt.xy);}else{this.modifyFeature(evt.xy);}
+this.lastDown=evt.xy;return false;},mousemove:function(evt){if(this.drawing){this.modifyFeature(evt.xy);}
+return true;},mouseup:function(evt){if(this.drawing){this.finalize();return false;}else{return true;}},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,freehand:false,freehandToggle:'shiftKey',initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);this.line=null;},removePoint:function(){if(this.point){this.layer.removeFeatures([thi
 s.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return
 this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
+return geometry;},mousedown:function(evt){if(this.lastDown&&this.lastDown.equals(evt.xy)){return false;}
+if(this.lastDown==null){if(this.persist){this.destroyFeature();}
+this.createFeature(evt.xy);}else if((this.lastUp==null)||!this.lastUp.equals(evt.xy)){this.addPoint(evt.xy);}
+this.mouseDown=true;this.lastDown=evt.xy;this.drawing=true;return false;},mousemove:function(evt){if(this.drawing){if(this.mouseDown&&this.freehandMode(evt)){this.addPoint(evt.xy);}else{this.modifyFeature(evt.xy);}}
+return true;},mouseup:function(evt){this.mouseDown=false;if(this.drawing){if(this.freehandMode(evt)){this.removePoint();this.finalize();}else{if(this.lastUp==null){this.addPoint(evt.xy);}
+this.lastUp=evt.xy;}
+return false;}
+return true;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
+return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));var polygon;if(this.holeModifier&&(this.evt[this.holeModifier])){var geometry=this.point.geometry;var features=this.control.layer.features;var candidate;for(var i=features.length-1;i>=0;--i){candidate=features[i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([poly
 gon],{silent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
+if(!polygon){this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));}
+this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
+if(modified){var target;outer:for(var i=rings.length-2;i>0;--i){var points=rings[i].components;for(var j=0,jj=points.length;j<jj;++j){if(ring.containsPoint(points[j])){modified=false;break outer;}}}}}
+if(modified){if(this.polygon.state!==OpenLayers.State.INSERT){this.polygon.state=OpenLayers.State.UPDATE;}}else{this.polygon.geometry.removeComponent(ring);}
+this.restoreFeature();return false;},cancel:function(){if(this.drawingHole){this.polygon.geometry.removeComponent(this.line.geometry);this.restoreFeature(true);}
+return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments);},restoreFeature:function(cancel){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:true});this.control.layer.addFeatures([this.polygon],{silent:true});this.drawingHole=false;if(!cancel){this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon});}},destroyFeature:function(){OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);this.polygon=null;},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.polygon;},getGeometry:function(){var geometry=this.polygon&&this.polygon.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPolygon([geometry]);}
+return geometry;},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();}
+return false;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(resolutionChanged){this.resolution=null;}},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
 if(feature.geometry){var bounds=feature.geometry.getBounds();if(bounds){if(!bounds.intersectsBounds(this.extent)){style={display:"none"};}
 var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(style.display!="none"&&style.label&&rendered!==false){var location=feature.geometry.getCentroid();if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
 this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
@@ -1562,7 +1441,121 @@
 var way=this.createElementNS(null,"way");way.setAttribute("id",id);for(var i=0;i<geometry.components.length;i++){var node=this.createXML['point'].apply(this,[geometry.components[i]]);if(node.length){node=node[0];var node_ref=node.getAttribute("id");nodes.push(node);}else{node_ref=geometry.components[i].osm_id;node=this.created_nodes[node_ref];}
 this.setState(feature,node);var nd_dom=this.createElementNS(null,"nd");nd_dom.setAttribute("ref",node_ref);way.appendChild(nd_dom);}
 this.serializeTags(feature,way);nodes.push(way);return nodes;},polygon:function(feature){var attrs=OpenLayers.Util.extend({'area':'yes'},feature.attributes);var feat=new OpenLayers.Feature.Vector(feature.geometry.components[0],attrs);feat.osm_id=feature.osm_id;return this.createXML['linestring'].apply(this,[feat]);}},serializeTags:function(feature,node){for(var key in feature.attributes){var tag=this.createElementNS(null,"tag");tag.setAttribute("k",key);tag.setAttribute("v",feature.attributes[key]);node.appendChild(tag);}},setState:function(feature,node){if(feature.state){var state=null;switch(feature.state){case OpenLayers.State.UPDATE:state="modify";case OpenLayers.State.DELETE:state="delete";}
-if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
+if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===true){var me=this;this._docMove=function(evt){me.mousemove({xy:{x:evt.clientX,y:evt.clientY},element:document});};this._docUp=function(evt){me.mouseup({xy:{x:evt.clientX,y:evt.clientY}});};}},dragstart:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt))){this.started=true;this.start=evt.xy;this.last=evt.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",[evt.xy]);if(evt.type==="mousedown"){OpenLayers.Ev
 ent.stop(evt);}
+if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;}
+document.onselectstart=OpenLayers.Function.False;propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+return propagate;},dragmove:function(evt){if(this.started&&!this.timeoutId&&(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y)){if(this.documentDrag===true&&this.documentEvents){if(evt.element===document){this.adjustXY(evt);this.setEvent(evt);}else{this.removeDocumentEvents();}}
+if(this.interval>0){this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);}
+this.dragging=true;if(evt.type==="touchmove"){OpenLayers.Event.stop(evt);}
+this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False;}
+this.last=this.evt.xy;}
+return true;},dragend:function(evt){if(this.started){if(this.documentDrag===true&&this.documentEvents){this.adjustXY(evt);this.removeDocumentEvents();}
+var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
+document.onselectstart=this.oldOnselectstart;}
+return true;},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){return this.dragstart(evt);},touchstart:function(evt){return this.dragstart(evt);},mousemove:function(evt){return this.dragmove(evt);},touchmove:function(evt){return this.dragmove(evt);},removeTimeout:function(){this.timeoutId=null;},mouseup:function(evt){return this.dragend(evt);},touchend:function(evt){evt.xy=this.last;return this.dragend(evt);},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.viewPortDiv)){if(this.documentDrag===true){this.addDocumentEvents();}else{var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
+if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}}
+return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
+return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null}},feature:null,lastFeature:null,down:null,up:null,clickTolerance:4,geomet
 ryTypes:null,stopClick:true,stopDown:true,stopUp:false,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){if(!this.callbacks['over']&&!this.callbacks['out']){return true;}
+this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){if(this.feature&&!this.feature.layer){this.feature=null;}
+var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature&&!this.feature.layer){this.feature=null;}
+if(this.lastFeature&&!this.lastFeature.layer){this.lastFeature=null;}
+if(this.feature){var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){if(this.lastFeature){this.triggerCallback(type,'out',[this.lastFeature]);}
+this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
+this.lastFeature=this.feature;handled=true;}else{if(this.lastFeature&&(previouslyIn&&inNew||click)){this.triggerCallback(type,'out',[this.lastFeature]);}
+this.feature=null;}}else{if(this.lastFeature&&(previouslyIn||click)){this.triggerCallback(type,'out',[this.lastFeature]);}}
+return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
+Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
+return deactivated;},handleMapEvents:function(evt){if(!evt.property||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={drag:new Op
 enLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){if(!this.handlers.drag.dragging){this.feature=feature;this.
 handlers.drag.activate();this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");this.onLeave(feature);this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function()
 {this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;this.styles["delete"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles
 [key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style);this.styles["delete"]=new OpenLayers.Style(style);break;}}}
+OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
+this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
+if(!this.styles[intent]){intent="default";}
+feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
+return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers,context){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],context:context,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
+this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","beforefeaturesadded","featureadded","featuresadded","beforefeatureremoved","beforefeaturesremoved","featureremoved","featuresremoved","beforefeatureselected","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified","vertexmodified","vertexremoved","sketchstarted","sketchmodified","sketchcomplete","refresh"],isBaseLayer:false,isFixed:false,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:true,style:null,styleMap:null,strategies:null,protocol:null,renderers:['SVG','VML','Canvas'],renderer:null,rendererOptions:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply
 (this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
+if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
+if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
+this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies){for(var i=0,len=this.strategies.length;i<len;i++){this.strategies[i].setLayer(this);}}},destroy:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoDestroy){strategy.destroy();}}
+this.strategies=null;}
+if(this.protocol){if(this.protocol.autoDestroy){this.protocol.destroy();}
+this.protocol=null;}
+this.destroyFeatures();this.features=null;this.selectedFeatures=null;this.unrenderedFeatures=null;if(this.renderer){this.renderer.destroy();}
+this.renderer=null;this.geometryType=null;this.drawn=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Vector(this.name,this.getOptions());}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);var features=this.features;var len=features.length;var clonedFeatures=new Array(len);for(var i=0;i<len;++i){clonedFeatures[i]=features[i].clone();}
+obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){
 strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility="visible";if(OpenLayers.IS_GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
+if(!zoomChanged&&coordSysUnchanged){for(var i in this.unrenderedFeatures){var feature=this.unrenderedFeatures[i];this.drawFeature(feature);}}}
+if(!this.drawn||zoomChanged||!coordSysUnchanged){this.drawn=true;var feature;for(var i=0,len=this.features.length;i<len;i++){this.renderer.locked=(i!==(len-1));feature=this.features[i];this.drawFeature(feature);}}},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(features instanceof Array)){features=[features];}
+var notify=!options||!options.silent;if(notify){var event={features:features};var ret=this.events.triggerEvent("beforefeaturesadded",event);if(ret===false){return;}
+features=event.features;}
+var featuresAdded=[];for(var i=0,len=features.length;i<len;i++){if(i!=(features.length-1)){this.renderer.locked=true;}else{this.renderer.locked=false;}
+var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
+feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
+if(notify){if(this.events.triggerEvent("beforefeatureadded",{feature:feature})===false){continue;};this.preFeatureInsert(feature);}
+featuresAdded.push(feature);this.features.push(feature);this.drawFeature(feature);if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
+if(notify){this.events.triggerEvent("featuresadded",{features:featuresAdded});}},removeFeatures:function(features,options){if(!features||features.length===0){return;}
+if(features===this.features){return this.removeAllFeatures(options);}
+if(!(features instanceof Array)){features=[features];}
+if(features===this.selectedFeatures){features=features.slice();}
+var notify=!options||!options.silent;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
+for(var i=features.length-1;i>=0;i--){if(i!=0&&features[i-1].geometry){this.renderer.locked=true;}else{this.renderer.locked=false;}
+var feature=features[i];delete this.unrenderedFeatures[feature.id];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
+this.features=OpenLayers.Util.removeItem(this.features,feature);feature.layer=null;if(feature.geometry){this.renderer.eraseFeatures(feature);}
+if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
+if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
+if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},removeAllFeatures:function(options){var notify=!options||!options.silent;var features=this.features;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
+var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
+feature.layer=null;if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
+this.renderer.clear();this.features=[];this.unrenderedFeatures={};this.selectedFeatures=[];if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},destroyFeatures:function(features,options){var all=(features==undefined);if(all){features=this.features;}
+if(features){this.removeFeatures(features,options);for(var i=features.length-1;i>=0;i--){features[i].destroy();}}},drawFeature:function(feature,style){if(!this.drawn){return;}
+if(typeof style!="object"){if(!style&&feature.state===OpenLayers.State.DELETE){style="delete";}
+var renderIntent=style||feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
+if(!this.renderer.drawFeature(feature,style)){this.unrenderedFeatures[feature.id]=feature;}else{delete this.unrenderedFeatures[feature.id];};},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
+var featureId=this.renderer.getFeatureIdFromEvent(evt);return this.getFeatureById(featureId);},getFeatureBy:function(property,value){var feature=null;for(var i=0,len=this.features.length;i<len;++i){if(this.features[i][property]==value){feature=this.features[i];break;}}
+return feature;},getFeatureById:function(featureId){return this.getFeatureBy('id',featureId);},getFeatureByFid:function(featureFid){return this.getFeatureBy('fid',featureFid);},getFeaturesByAttribute:function(attrName,attrValue){var i,feature,len=this.features.length,foundFeatures=[];for(i=0;i<len;i++){feature=this.features[i];if(feature&&feature.attributes){if(feature.attributes[attrName]===attrValue){foundFeatures.push(feature);}}}
+return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){maxExtent=new OpenLayers.Bounds();var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){maxExtent.extend(geometry.getBounds());}}}
+return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer
 .moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){layer=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforefeaturehighlighted","featurehighlighted","featureunhighlighted"],multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){this.EVENT_TYPES=OpenLayers.Control.Select
 Feature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
+this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
+this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(layers instanceof Array){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
+this.handlers.feature.activate();if(this.box&&this.handlers.box){this.handlers.box.activate();}}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){this.handlers.feature.deactivate();if(this.handlers.box){this.handlers.box.deactivate();}
+if(this.layers){this.map.removeLayer(this.layer);}}
+return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},unselectAll:function(options){var layers=this.layers||[this.layer];var layer,feature;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=layer.selectedFeatures.length-1;i>=0;--i){feature=layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(feature.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
+this.select(feature);}}},multipleSelect:function(){return this.multiple||(this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]);},toggleSelect:function(){return this.toggle||(this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]);},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){var layer=feature.layer;if(this.hover){if(this.highlightOnly){this.highlight(feature);}else if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}},outFeature:function(feature){if(this.hover){if(this.highlightOnly){if(feature._lastHighlighter==this.id){if(feature._prevHighlighter&&feature._prevHighlighter!=this.id){delete feature._lastHighlighter;var control=this.map.getControl(feature._prevHighlighter);if(control){control.highlight(feature);}}else{this.unhighlight(feature);}}}else{this.unselect(feature);}}},highlight:function(feature){var layer=feature.layer;var cont
 =this.events.triggerEvent("beforefeaturehighlighted",{feature:feature});if(cont!==false){feature._prevHighlighter=feature._lastHighlighter;feature._lastHighlighter=this.id;var style=this.selectStyle||this.renderIntent;layer.drawFeature(feature,style);this.events.triggerEvent("featurehighlighted",{feature:feature});}},unhighlight:function(feature){var layer=feature.layer;feature._lastHighlighter=feature._prevHighlighter;delete feature._prevHighlighter;layer.drawFeature(feature,feature.style||feature.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:feature});},select:function(feature){var cont=this.onBeforeSelect.call(this.scope,feature);var layer=feature.layer;if(cont!==false){cont=layer.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){layer.selectedFeatures.push(feature);this.highlight(feature);if(!this.handlers.feature.lastFeature){this.handlers.feature.lastFeature=layer.selectedFeatures[0];}
+layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect.call(this.scope,feature);}}},unselect:function(feature){var layer=feature.layer;this.unhighlight(feature);OpenLayers.Util.removeItem(layer.selectedFeatures,feature);layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect.call(this.scope,feature);},selectBox:function(position){if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);if(!this.multipleSelect()){this.unselectAll();}
+var prevMultiple=this.multiple;this.multiple=true;var layers=this.layers||[this.layer];var layer;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=0,len=layer.features.length;i<len;++i){var feature=layer.features[i];if(!feature.getVisibility()){continue;}
+if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1){if(bounds.toGeometry().intersects(feature.geometry)){if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}}}}
+this.multiple=prevMultiple;}},setMap:function(map){this.handlers.feature.setMap(map);if(this.box){this.handlers.box.setMap(map);}
+OpenLayers.Control.prototype.setMap.apply(this,arguments);},setLayer:function(layers){var isActive=this.active;this.unselectAll();this.deactivate();if(this.layers){this.layer.destroy();this.layers=null;}
+this.initLayer(layers);this.handlers.feature.layer=this.layer;if(isActive){this.activate();}},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.observe(document,this.KEY_EVENTS[i],this.eventListener);}
+return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.stopObserving(document,this.KEY_EVENTS[i],this.eventListener);}
+deactivated=true;}
+return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,standalone:false,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,modified:false,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){options=options||{};this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,options.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Control.ModifyFeature
 .RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(this.deleteCodes instanceof Array)){this.deleteCodes=[this.deleteCodes];}
+var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,onBeforeSelect:this.beforeSelectFeature,onSelect:this.selectFeature,onUnselect:this.unselectFeature,scope:this};if(this.standalone===false){this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);}
+var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature,pixel){control.dragVertex.apply(control,[feature,pixel]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);},featureCallbacks:{over:function(feature){if(control.standalone!==true||feature._sketch||control.feature===feature){control.dragControl.overFeature.apply(control.dragControl,[feature]);}}}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keydown:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer=null;this.standalone||this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return((this.standalone||this.selectControl.activate())&&this.handlers.keyb
 oard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices,{silent:true});this.layer.removeFeatures(this.virtualVertices,{silent:true});this.vertices=[];this.dragControl.deactivate();var feature=this.feature;var valid=feature&&feature.geometry&&feature.layer;if(this.standalone===false){if(valid){this.selectControl.unselect.apply(this.selectControl,[feature]);}
+this.selectControl.deactivate();}else{if(valid){this.unselectFeature(feature);}}
+this.handlers.keyboard.deactivate();deactivated=true;}
+return deactivated;},beforeSelectFeature:function(feature){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});},selectFeature:function(feature){if(!this.standalone||this.beforeSelectFeature(feature)!==false){this.feature=feature;this.modified=false;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);}},unselectFeature:function(feature){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});delete this.dragHandle;}
+if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});delete this.radiusHandle;}
+this.feature=null;this.dragControl.deactivate();this.onModificationEnd(feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:feature,modified:this.modified});this.modified=false;},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
+if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex,pixel){this.modified=true;if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}
+this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}}else if(vertex!==this.radiusHandle){this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}
+if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
+this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);}
+this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE){this.feature.state=OpenLayers.State.UPDATE;}},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
+if(this.vertices.length>0){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];}
+if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
+if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});this.dragHandle=null;}
+if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}
+if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
+if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
+if(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE){if(!(this.mode&OpenLayers.Control.ModifyFeature.RESIZE)){this.collectVertices();}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.events.triggerEvent("vertexremoved",{vertex:vertex.geometry,feature:this.feature,pixel:evt.xy});this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vertex,component,l
 en;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
+for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{collectComponentVertices(component);}}
+if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0,len=geometry.components.length;i<len-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;point._sketch=true;control.virtualVertices.push(point);}}}}}
+collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:true});this.layer.addFeatures(this.vertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};origin._sketch=true;this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&O
 penLayers.Control.ModifyFeature.RESIZE);var reshape=(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
+if(resize){var scale,ratio;if(reshape){scale=dy1/dy0;ratio=(dx1/dx0)/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
+geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.standalone||this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:9009
 13"},options);}
 url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(url instanceof Array){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
 return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;return{'x':x,'y':y,'z':z};},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(o
 bj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
@@ -1574,31 +1567,153 @@
 var quadKey=quadDigits.join("");var url=this.selectUrl(''+x+y+z,this.url);return OpenLayers.String.format(url,{'quadkey':quadKey});},updateAttribution:function(){var metadata=this.metadata;if(!metadata||!this.map||!this.map.center){return;}
 var res=metadata.resourceSets[0].resources[0];var extent=this.map.getExtent().transform(this.map.getProjectionObject(),new OpenLayers.Projection("EPSG:4326"));var providers=res.imageryProviders,zoom=this.map.getZoom()+1,copyrights="",provider,i,ii,j,jj,bbox,coverage;for(i=0,ii=providers.length;i<ii;++i){provider=providers[i];for(j=0,jj=provider.coverageAreas.length;j<jj;++j){coverage=provider.coverageAreas[j];bbox=OpenLayers.Bounds.fromArray(coverage.bbox);if(extent.intersectsBounds(bbox)&&zoom<=coverage.zoomMax&&zoom>=coverage.zoomMin){copyrights+=provider.attribution+" ";}}}
 this.attribution=OpenLayers.String.format(this.attributionTemplate,{type:this.type.toLowerCase(),logo:metadata.brandLogoUri,copyrights:copyrights});this.map&&this.map.events.triggerEvent("changelayer",{layer:this});},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.updateAttribution();this.map.events.register("moveend",this,this.updateAttribution);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Bing(this.options);}
-obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},destroy:function(){this.map&&this.map.events.unregister("moveend",this,this.updateAttribution);OpenLayers.Layer.XYZ.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.Bing"});OpenLayers.Layer.Bing.processMetadata=function(metadata){this.metadata=metadata;this.initLayer();var script=document.getElementById(this._callbackId);script.parentNode.removeChild(script);window[this._callbackId]=undefined;delete this._callbackId;};OpenLayers.Format.SOSGetFeatureOfInterest=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",sa:"http://www.opengis.net/sampling/1.0",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosAll.xsd",defaultPrefix:"sos",regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\
 s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},destroy:function(){this.map&&this.map.events.unregister("moveend",this,this.updateAttribution);OpenLayers.Layer.XYZ.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.Bing"});OpenLayers.Layer.Bing.processMetadata=function(metadata){this.metadata=metadata;this.initLayer();var script=document.getElementById(this._callbackId);script.parentNode.removeChild(script);window[this._callbackId]=undefined;delete this._callbackId;};(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera,bIE7=bIE&&window.navigator.userAgent.match(/MSIE 7.0/);function fXMLHttpRequest(){this._object=oXMLHttpRequest&&!bIE7?new oXMLHttpRequest:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[];};function cXMLHttpRequest(){return new fXMLHttpRequest;};cXMLHttpRequest.prototype=fXMLHttpRequest.prototype;if(bGecko&&oXMLHttpRequest.wrapped)
+cXMLHttpRequest.wrapped=oXMLHttpRequest.wrapped;cXMLHttpRequest.UNSENT=0;cXMLHttpRequest.OPENED=1;cXMLHttpRequest.HEADERS_RECEIVED=2;cXMLHttpRequest.LOADING=3;cXMLHttpRequest.DONE=4;cXMLHttpRequest.prototype.readyState=cXMLHttpRequest.UNSENT;cXMLHttpRequest.prototype.responseText='';cXMLHttpRequest.prototype.responseXML=null;cXMLHttpRequest.prototype.status=0;cXMLHttpRequest.prototype.statusText='';cXMLHttpRequest.prototype.priority="NORMAL";cXMLHttpRequest.prototype.onreadystatechange=null;cXMLHttpRequest.onreadystatechange=null;cXMLHttpRequest.onopen=null;cXMLHttpRequest.onsend=null;cXMLHttpRequest.onabort=null;cXMLHttpRequest.prototype.open=function(sMethod,sUrl,bAsync,sUser,sPassword){delete this._headers;if(arguments.length<3)
+bAsync=true;this._async=bAsync;var oRequest=this,nState=this.readyState,fOnUnload;if(bIE&&bAsync){fOnUnload=function(){if(nState!=cXMLHttpRequest.DONE){fCleanTransport(oRequest);oRequest.abort();}};window.attachEvent("onunload",fOnUnload);}
+if(cXMLHttpRequest.onopen)
+cXMLHttpRequest.onopen.apply(this,arguments);if(arguments.length>4)
+this._object.open(sMethod,sUrl,bAsync,sUser,sPassword);else
+if(arguments.length>3)
+this._object.open(sMethod,sUrl,bAsync,sUser);else
+this._object.open(sMethod,sUrl,bAsync);this.readyState=cXMLHttpRequest.OPENED;fReadyStateChange(this);this._object.onreadystatechange=function(){if(bGecko&&!bAsync)
+return;oRequest.readyState=oRequest._object.readyState;fSynchronizeValues(oRequest);if(oRequest._aborted){oRequest.readyState=cXMLHttpRequest.UNSENT;return;}
+if(oRequest.readyState==cXMLHttpRequest.DONE){delete oRequest._data;fCleanTransport(oRequest);if(bIE&&bAsync)
+window.detachEvent("onunload",fOnUnload);}
+if(nState!=oRequest.readyState)
+fReadyStateChange(oRequest);nState=oRequest.readyState;}};function fXMLHttpRequest_send(oRequest){oRequest._object.send(oRequest._data);if(bGecko&&!oRequest._async){oRequest.readyState=cXMLHttpRequest.OPENED;fSynchronizeValues(oRequest);while(oRequest.readyState<cXMLHttpRequest.DONE){oRequest.readyState++;fReadyStateChange(oRequest);if(oRequest._aborted)
+return;}}};cXMLHttpRequest.prototype.send=function(vData){if(cXMLHttpRequest.onsend)
+cXMLHttpRequest.onsend.apply(this,arguments);if(!arguments.length)
+vData=null;if(vData&&vData.nodeType){vData=window.XMLSerializer?new window.XMLSerializer().serializeToString(vData):vData.xml;if(!oRequest._headers["Content-Type"])
+oRequest._object.setRequestHeader("Content-Type","application/xml");}
+this._data=vData;fXMLHttpRequest_send(this);};cXMLHttpRequest.prototype.abort=function(){if(cXMLHttpRequest.onabort)
+cXMLHttpRequest.onabort.apply(this,arguments);if(this.readyState>cXMLHttpRequest.UNSENT)
+this._aborted=true;this._object.abort();fCleanTransport(this);this.readyState=cXMLHttpRequest.UNSENT;delete this._data;};cXMLHttpRequest.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders();};cXMLHttpRequest.prototype.getResponseHeader=function(sName){return this._object.getResponseHeader(sName);};cXMLHttpRequest.prototype.setRequestHeader=function(sName,sValue){if(!this._headers)
+this._headers={};this._headers[sName]=sValue;return this._object.setRequestHeader(sName,sValue);};cXMLHttpRequest.prototype.addEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+if(oListener[0]==sName&&oListener[1]==fHandler&&oListener[2]==bUseCapture)
+return;this._listeners.push([sName,fHandler,bUseCapture]);};cXMLHttpRequest.prototype.removeEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+break;if(oListener)
+this._listeners.splice(nIndex,1);};cXMLHttpRequest.prototype.dispatchEvent=function(oEvent){var oEventPseudo={'type':oEvent.type,'target':this,'currentTarget':this,'eventPhase':2,'bubbles':oEvent.bubbles,'cancelable':oEvent.cancelable,'timeStamp':oEvent.timeStamp,'stopPropagation':function(){},'preventDefault':function(){},'initEvent':function(){}};if(oEventPseudo.type=="readystatechange"&&this.onreadystatechange)
+(this.onreadystatechange.handleEvent||this.onreadystatechange).apply(this,[oEventPseudo]);for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+if(oListener[0]==oEventPseudo.type&&!oListener[2])
+(oListener[1].handleEvent||oListener[1]).apply(this,[oEventPseudo]);};cXMLHttpRequest.prototype.toString=function(){return'['+"object"+' '+"XMLHttpRequest"+']';};cXMLHttpRequest.toString=function(){return'['+"XMLHttpRequest"+']';};function fReadyStateChange(oRequest){if(cXMLHttpRequest.onreadystatechange)
+cXMLHttpRequest.onreadystatechange.apply(oRequest);oRequest.dispatchEvent({'type':"readystatechange",'bubbles':false,'cancelable':false,'timeStamp':new Date+0});};function fGetDocument(oRequest){var oDocument=oRequest.responseXML,sResponse=oRequest.responseText;if(bIE&&sResponse&&oDocument&&!oDocument.documentElement&&oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)){oDocument=new window.ActiveXObject("Microsoft.XMLDOM");oDocument.async=false;oDocument.validateOnParse=false;oDocument.loadXML(sResponse);}
+if(oDocument)
+if((bIE&&oDocument.parseError!=0)||!oDocument.documentElement||(oDocument.documentElement&&oDocument.documentElement.tagName=="parsererror"))
+return null;return oDocument;};function fSynchronizeValues(oRequest){try{oRequest.responseText=oRequest._object.responseText;}catch(e){}
+try{oRequest.responseXML=fGetDocument(oRequest._object);}catch(e){}
+try{oRequest.status=oRequest._object.status;}catch(e){}
+try{oRequest.statusText=oRequest._object.statusText;}catch(e){}};function fCleanTransport(oRequest){oRequest._object.onreadystatechange=new window.Function;};if(!window.Function.prototype.apply){window.Function.prototype.apply=function(oRequest,oArguments){if(!oArguments)
+oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{kml:"http://www.opengis.net/kml/2.2",gx:"http://www.google.com/kml/ext/2.2"},kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date(),extractAttributes:true,extractStyles:false,extractTracks:false,trackAttributes:null,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),kmlColor:(/(\w{2})(\w{2})(\w{2})(\w{2})/),kmlIconPalette:(/root:\/\/icons\/palette-(\d+)(\.\w+)/),straightBracket:(/\$\[(.*?)\]/g)};this.externalProjection=new OpenLayers.Projection("EP
 SG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){this.features=[];this.styles={};this.fetched={};var options={depth:0,styleBaseUrl:this.styleBaseUrl};return this.parseData(data,options);},parseData:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var types=["Link","NetworkLink","Style","StyleMap","Placemark"];for(var i=0,len=types.length;i<len;++i){var type=types[i];var nodes=this.getElementsByTagNameNS(data,"*",type);if(nodes.length==0){continue;}
+switch(type.toLowerCase()){case"link":case"networklink":this.parseLinks(nodes,options);break;case"style":if(this.extractStyles){this.parseStyles(nodes,options);}
+break;case"stylemap":if(this.extractStyles){this.parseStyleMaps(nodes,options);}
+break;case"placemark":this.parseFeatures(nodes,options);break;}}
+return this.features;},parseLinks:function(nodes,options){if(options.depth>=this.maxDepth){return false;}
+var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;for(var i=0,len=nodes.length;i<len;i++){var href=this.parseProperty(nodes[i],"*","href");if(href&&!this.fetched[href]){this.fetched[href]=true;var data=this.fetchLink(href);if(data){this.parseData(data,newOptions);}}}},fetchLink:function(href){var request=OpenLayers.Request.GET({url:href,async:false});if(request){return request.responseText;}},parseStyles:function(nodes,options){for(var i=0,len=nodes.length;i<len;i++){var style=this.parseStyle(nodes[i]);if(style){var styleName=(options.styleBaseUrl||"")+"#"+style.id;this.styles[styleName]=style;}}},parseKmlColor:function(kmlColor){var color=null;if(kmlColor){var matches=kmlColor.match(this.regExes.kmlColor);if(matches){color={color:'#'+matches[4]+matches[3]+matches[2],opacity:parseInt(matches[1],16)/255};}}
+return color;},parseStyle:function(node){var style={};var types=["LineStyle","PolyStyle","IconStyle","BalloonStyle","LabelStyle"];var type,styleTypeNode,nodeList,geometry,parser;for(var i=0,len=types.length;i<len;++i){type=types[i];styleTypeNode=this.getElementsByTagNameNS(node,"*",type)[0];if(!styleTypeNode){continue;}
+switch(type.toLowerCase()){case"linestyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["strokeColor"]=color.color;style["strokeOpacity"]=color.opacity;}
+var width=this.parseProperty(styleTypeNode,"*","width");if(width){style["strokeWidth"]=width;}
+break;case"polystyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["fillOpacity"]=color.opacity;style["fillColor"]=color.color;}
+var fill=this.parseProperty(styleTypeNode,"*","fill");if(fill=="0"){style["fillColor"]="none";}
+var outline=this.parseProperty(styleTypeNode,"*","outline");if(outline=="0"){style["strokeWidth"]="0";}
+break;case"iconstyle":var scale=parseFloat(this.parseProperty(styleTypeNode,"*","scale")||1);var width=32*scale;var height=32*scale;var iconNode=this.getElementsByTagNameNS(styleTypeNode,"*","Icon")[0];if(iconNode){var href=this.parseProperty(iconNode,"*","href");if(href){var w=this.parseProperty(iconNode,"*","w");var h=this.parseProperty(iconNode,"*","h");var google="http://maps.google.com/mapfiles/kml";if(OpenLayers.String.startsWith(href,google)&&!w&&!h){w=64;h=64;scale=scale/2;}
+w=w||h;h=h||w;if(w){width=parseInt(w)*scale;}
+if(h){height=parseInt(h)*scale;}
+var matches=href.match(this.regExes.kmlIconPalette);if(matches){var palette=matches[1];var file_extension=matches[2];var x=this.parseProperty(iconNode,"*","x");var y=this.parseProperty(iconNode,"*","y");var posX=x?x/32:0;var posY=y?(7-y/32):7;var pos=posY*8+posX;href="http://maps.google.com/mapfiles/kml/pal"
++palette+"/icon"+pos+file_extension;}
+style["graphicOpacity"]=1;style["externalGraphic"]=href;}}
+var hotSpotNode=this.getElementsByTagNameNS(styleTypeNode,"*","hotSpot")[0];if(hotSpotNode){var x=parseFloat(hotSpotNode.getAttribute("x"));var y=parseFloat(hotSpotNode.getAttribute("y"));var xUnits=hotSpotNode.getAttribute("xunits");if(xUnits=="pixels"){style["graphicXOffset"]=-x*scale;}
+else if(xUnits=="insetPixels"){style["graphicXOffset"]=-width+(x*scale);}
+else if(xUnits=="fraction"){style["graphicXOffset"]=-width*x;}
+var yUnits=hotSpotNode.getAttribute("yunits");if(yUnits=="pixels"){style["graphicYOffset"]=-height+(y*scale)+1;}
+else if(yUnits=="insetPixels"){style["graphicYOffset"]=-(y*scale)+1;}
+else if(yUnits=="fraction"){style["graphicYOffset"]=-height*(1-y)+1;}}
+style["graphicWidth"]=width;style["graphicHeight"]=height;break;case"balloonstyle":var balloonStyle=OpenLayers.Util.getXmlNodeValue(styleTypeNode);if(balloonStyle){style["balloonStyle"]=balloonStyle.replace(this.regExes.straightBracket,"${$1}");}
+break;case"labelstyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["fontColor"]=color.color;style["fontOpacity"]=color.opacity;}
+break;default:}}
+if(!style["strokeColor"]&&style["fillColor"]){style["strokeColor"]=style["fillColor"];}
+var id=node.getAttribute("id");if(id&&style){style.id=id;}
+return style;},parseStyleMaps:function(nodes,options){for(var i=0,len=nodes.length;i<len;i++){var node=nodes[i];var pairs=this.getElementsByTagNameNS(node,"*","Pair");var id=node.getAttribute("id");for(var j=0,jlen=pairs.length;j<jlen;j++){var pair=pairs[j];var key=this.parseProperty(pair,"*","key");var styleUrl=this.parseProperty(pair,"*","styleUrl");if(styleUrl&&key=="normal"){this.styles[(options.styleBaseUrl||"")+"#"+id]=this.styles[(options.styleBaseUrl||"")+styleUrl];}
+if(styleUrl&&key=="highlight"){}}}},parseFeatures:function(nodes,options){var features=[];for(var i=0,len=nodes.length;i<len;i++){var featureNode=nodes[i];var feature=this.parseFeature.apply(this,[featureNode]);if(feature){if(this.extractStyles&&feature.attributes&&feature.attributes.styleUrl){feature.style=this.getStyle(feature.attributes.styleUrl,options);}
+if(this.extractStyles){var inlineStyleNode=this.getElementsByTagNameNS(featureNode,"*","Style")[0];if(inlineStyleNode){var inlineStyle=this.parseStyle(inlineStyleNode);if(inlineStyle){feature.style=OpenLayers.Util.extend(feature.style,inlineStyle);}}}
+if(this.extractTracks){var tracks=this.getElementsByTagNameNS(featureNode,this.namespaces.gx,"Track");if(tracks&&tracks.length>0){var track=tracks[0];var container={features:[],feature:feature};this.readNode(track,container);if(container.features.length>0){features.push.apply(features,container.features);}}}else{features.push(feature);}}else{throw"Bad Placemark: "+i;}}
+this.features=this.features.concat(features);},readers:{"kml":{"when":function(node,container){container.whens.push(OpenLayers.Date.parse(this.getChildValue(node)));},"_trackPointAttribute":function(node,container){var name=node.nodeName.split(":").pop();container.attributes[name].push(this.getChildValue(node));}},"gx":{"Track":function(node,container){var obj={whens:[],points:[],angles:[]};if(this.trackAttributes){var name;obj.attributes={};for(var i=0,ii=this.trackAttributes.length;i<ii;++i){name=this.trackAttributes[i];obj.attributes[name]=[];if(!(name in this.readers.kml)){this.readers.kml[name]=this.readers.kml._trackPointAttribute;}}}
+this.readChildNodes(node,obj);if(obj.whens.length!==obj.points.length){throw new Error("gx:Track with unequal number of when ("+obj.whens.length+") and gx:coord ("+obj.points.length+") elements.");}
+var hasAngles=obj.angles.length>0;if(hasAngles&&obj.whens.length!==obj.angles.length){throw new Error("gx:Track with unequal number of when ("+obj.whens.length+") and gx:angles ("+obj.angles.length+") elements.");}
+var feature,point,angles;for(var i=0,ii=obj.whens.length;i<ii;++i){feature=container.feature.clone();feature.fid=container.feature.fid||container.feature.id;point=obj.points[i];feature.geometry=point;if("z"in point){feature.attributes.altitude=point.z;}
+if(this.internalProjection&&this.externalProjection){feature.geometry.transform(this.externalProjection,this.internalProjection);}
+if(this.trackAttributes){for(var j=0,jj=this.trackAttributes.length;j<jj;++j){feature.attributes[name]=obj.attributes[this.trackAttributes[j]][i];}}
+feature.attributes.when=obj.whens[i];feature.attributes.trackId=container.feature.id;if(hasAngles){angles=obj.angles[i];feature.attributes.heading=parseFloat(angles[0]);feature.attributes.tilt=parseFloat(angles[1]);feature.attributes.roll=parseFloat(angles[2]);}
+container.features.push(feature);}},"coord":function(node,container){var str=this.getChildValue(node);var coords=str.replace(this.regExes.trimSpace,"").split(/\s+/);var point=new OpenLayers.Geometry.Point(coords[0],coords[1]);if(coords.length>2){point.z=parseFloat(coords[2]);}
+container.points.push(point);},"angles":function(node,container){var str=this.getChildValue(node);var parts=str.replace(this.regExes.trimSpace,"").split(/\s+/);container.angles.push(parts);}}},parseFeature:function(node){var order=["MultiGeometry","Polygon","LineString","Point"];var type,nodeList,geometry,parser;for(var i=0,len=order.length;i<len;++i){type=order[i];this.internalns=node.namespaceURI?node.namespaceURI:this.kmlns;nodeList=this.getElementsByTagNameNS(node,this.internalns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
+break;}}
+var attributes;if(this.extractAttributes){attributes=this.parseAttributes(node);}
+var feature=new OpenLayers.Feature.Vector(geometry,attributes);var fid=node.getAttribute("id")||node.getAttribute("name");if(fid!=null){feature.fid=fid;}
+return feature;},getStyle:function(styleUrl,options){var styleBaseUrl=OpenLayers.Util.removeTail(styleUrl);var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;newOptions.styleBaseUrl=styleBaseUrl;if(!this.styles[styleUrl]&&!OpenLayers.String.startsWith(styleUrl,"#")&&newOptions.depth<=this.maxDepth&&!this.fetched[styleBaseUrl]){var data=this.fetchLink(styleBaseUrl);if(data){this.parseData(data,newOptions);}}
+var style=OpenLayers.Util.extend({},this.styles[styleUrl]);return style;},parseGeometry:{point:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var coords=[];if(nodeList.length>0){var coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}
+var point=null;if(coords.length>1){if(coords.length==2){coords[2]=null;}
+point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad coordinate string: "+coordString;}
+return point;},linestring:function(node,ring){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var line=null;if(nodeList.length>0){var coordString=this.getChildValue(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);var numPoints=pointList.length;var points=new Array(numPoints);var coords,numCoords;for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");numCoords=coords.length;if(numCoords>1){if(coords.length==2){coords[2]=null;}
+points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad LineString point coordinates: "+
+pointList[i];}}
+if(numPoints){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}else{throw"Bad LineString coordinates: "+coordString;}}
+return line;},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"LinearRing");var numRings=nodeList.length;var components=new Array(numRings);if(numRings>0){var ring;for(var i=0,len=nodeList.length;i<len;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components[i]=ring;}else{throw"Bad LinearRing geometry: "+i;}}}
+return new OpenLayers.Geometry.Polygon(components);},multigeometry:function(node){var child,parser;var parts=[];var children=node.childNodes;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){var type=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var parser=this.parseGeometry[type.toLowerCase()];if(parser){parts.push(parser.apply(this,[child]));}}}
+return new OpenLayers.Geometry.Collection(parts);}},parseAttributes:function(node){var attributes={};var edNodes=node.getElementsByTagName("ExtendedData");if(edNodes.length){attributes=this.parseExtendedData(edNodes[0]);}
+var child,grandchildren,grandchild;var children=node.childNodes;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length>=1&&grandchildren.length<=3){var grandchild;switch(grandchildren.length){case 1:grandchild=grandchildren[0];break;case 2:var c1=grandchildren[0];var c2=grandchildren[1];grandchild=(c1.nodeType==3||c1.nodeType==4)?c1:c2;break;case 3:default:grandchild=grandchildren[1];break;}
+if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=OpenLayers.Util.getXmlNodeValue(grandchild);if(value){value=value.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
+return attributes;},parseExtendedData:function(node){var attributes={};var i,len,data,key;var dataNodes=node.getElementsByTagName("Data");for(i=0,len=dataNodes.length;i<len;i++){data=dataNodes[i];key=data.getAttribute("name");var ed={};var valueNode=data.getElementsByTagName("value");if(valueNode.length){ed['value']=this.getChildValue(valueNode[0]);}
+var nameNode=data.getElementsByTagName("displayName");if(nameNode.length){ed['displayName']=this.getChildValue(nameNode[0]);}
+attributes[key]=ed;}
+var simpleDataNodes=node.getElementsByTagName("SimpleData");for(i=0,len=simpleDataNodes.length;i<len;i++){var ed={};data=simpleDataNodes[i];key=data.getAttribute("name");ed['value']=this.getChildValue(data);ed['displayName']=key;attributes[key]=ed;}
+return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
+return value;},write:function(features){if(!(features instanceof Array)){features=[features];}
+var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0,len=features.length;i<len;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
+kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folder=this.createElementNS(this.kmlns,"Folder");if(this.foldersName){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);folder.appendChild(folderName);}
+if(this.foldersDesc){var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);folder.appendChild(folderDesc);}
+return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=feature.style&&feature.style.label?feature.style.label:feature.attributes.name||feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=feature.attributes.description||this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
+placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
+return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0,len=rings.length;i<len;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[
 i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
+return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0,len=geometry.components.length;i<len;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
+return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=point.x+","+point.y;}
+path=parts.join(" ");}else{path=geometry.x+","+geometry.y;}
+var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Format.Context=OpenLayers.Class({version:null,layerOptions:null,layerParams:null,parser:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");}
+var parser=this.getParser(version);var context=parser.read(data,options);var map;if(options&&options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{var mapOptions=options.map;if(OpenLayers.Util.isElement(mapOptions)||typeof mapOptions=="string"){mapOptions={div:mapOptions};}
+map=this.contextToMap(context,mapOptions);}}else{map=context;}
+return map;},getLayerFromContext:function(layerContext){var i,len;var options={queryable:layerContext.queryable,visibility:layerContext.visibility,maxExtent:layerContext.maxExtent,metadata:OpenLayers.Util.applyDefaults(layerContext.metadata,{styles:layerContext.styles}),numZoomLevels:layerContext.numZoomLevels,units:layerContext.units,isBaseLayer:layerContext.isBaseLayer,opacity:layerContext.opacity,displayInLayerSwitcher:layerContext.displayInLayerSwitcher,singleTile:layerContext.singleTile,tileSize:(layerContext.tileSize)?new OpenLayers.Size(layerContext.tileSize.width,layerContext.tileSize.height):undefined,minScale:layerContext.minScale||layerContext.maxScaleDenominator,maxScale:layerContext.maxScale||layerContext.minScaleDenominator};if(this.layerOptions){OpenLayers.Util.applyDefaults(options,this.layerOptions);}
+var params={layers:layerContext.name,transparent:layerContext.transparent,version:layerContext.version};if(layerContext.formats&&layerContext.formats.length>0){params.format=layerContext.formats[0].value;for(i=0,len=layerContext.formats.length;i<len;i++){var format=layerContext.formats[i];if(format.current==true){params.format=format.value;break;}}}
+if(layerContext.styles&&layerContext.styles.length>0){for(i=0,len=layerContext.styles.length;i<len;i++){var style=layerContext.styles[i];if(style.current==true){if(style.href){params.sld=style.href;}else if(style.body){params.sld_body=style.body;}else{params.styles=style.name;}
+break;}}}
+if(this.layerParams){OpenLayers.Util.applyDefaults(params,this.layerParams);}
+var layer=null;var service=layerContext.service;if(service==OpenLayers.Format.Context.serviceTypes.WFS){options.strategies=[new OpenLayers.Strategy.BBOX()];options.protocol=new OpenLayers.Protocol.WFS({url:layerContext.url,featurePrefix:layerContext.name.split(":")[0],featureType:layerContext.name.split(":").pop()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.KML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.KML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.GML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.GML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.na
 me,options);}else if(layerContext.features){layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);layer.addFeatures(layerContext.features);}else if(layerContext.categoryLayer!==true){layer=new OpenLayers.Layer.WMS(layerContext.title||layerContext.name,layerContext.url,params,options);}
+return layer;},getLayersFromContext:function(layersContext){var layers=[];for(var i=0,len=layersContext.length;i<len;i++){var layer=this.getLayerFromContext(layersContext[i]);if(layer!==null){layers.push(layer);}}
+return layers;},contextToMap:function(context,options){options=OpenLayers.Util.applyDefaults({maxExtent:context.maxExtent,projection:context.projection},options);var map=new OpenLayers.Map(options);map.addLayers(this.getLayersFromContext(context.layersContext));map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(this.getLayersFromContext(context.layersContext));return map;},write:function(obj,options){obj=this.toContext(obj);var version=options&&options.version;var parser=this.getParser(version);var context=parser.write(obj,options);return context;},CLASS_NAME:"OpenLayers.Format.Context"});OpenLayers.Format.Context.serviceTypes={"WMS":"urn:ogc:serviceType:WMS","WFS":"urn:ogc:serviceType:WFS","WCS":"urn:ogc:serviceType:WCS","GML":"urn:ogc:serviceType:GML","SLD":"urn:ogc:serviceType:SLD","FES":"urn:ogc:serviceType:FES","KML":"urn:ogc:serviceType:KML"};OpenLayers.Format.OWSC
 ontext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getParser:function(version){var v=version||this.version||this.defaultVersion;if(v==="0.3.0"){v=this.defaultVersion;}
+if(!this.parser||this.parser.VERSION!=v){var format=OpenLayers.Format.OWSContext["v"+v.replace(/\./g,"_")];if(!format){throw"Can't find a OWSContext parser for version "+v;}
+this.parser=new format(this.options);}
+return this.parser;},toContext:function(obj){var context={};if(obj.CLASS_NAME=="OpenLayers.Map"){context.bounds=obj.getExtent();context.maxExtent=obj.maxExtent;context.projection=obj.projection;context.size=obj.getSize();context.layers=obj.layers;}
+return context;},CLASS_NAME:"OpenLayers.Format.OWSContext"});if(!OpenLayers.Format.OWSCommon){OpenLayers.Format.OWSCommon={};}
+OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},readers:{"ows":{"ServiceIdentification":function(node,obj){obj.serviceIdentification={};this.readChildNodes(node,obj.serviceIdentification);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,serviceIdentification){serviceIdentification["abstract"]=this.getChildValue(node);},"Keywords":function(node,serviceIdentification){serviceIdentification.keywords={};this.readChildNodes(node,serviceIdentification.keywords);},"Keyword":function(node,keywords){keywords[this.getChildValue(node)]=true;},"ServiceType":function(node,serviceIdentification){serviceIdentification.serviceType={codeSpace:node.getAttribute('codeSpace'),value:this.getChildValue(node)};},"ServiceTypeVersion":function(node,serviceIdentification){serviceIdentification.serviceTypeVersion=this.getChildValue(node);},"
 Fees":function(node,serviceIdentification){serviceIdentification.fees=this.getChildValue(node);},"AccessConstraints":function(node,serviceIdentification){serviceIdentification.accessConstraints=this.getChildValue(node);},"ServiceProvider":function(node,obj){obj.serviceProvider={};this.readChildNodes(node,obj.serviceProvider);},"ProviderName":function(node,serviceProvider){serviceProvider.providerName=this.getChildValue(node);},"ProviderSite":function(node,serviceProvider){serviceProvider.providerSite=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ServiceContact":function(node,serviceProvider){serviceProvider.serviceContact={};this.readChildNodes(node,serviceProvider.serviceContact);},"IndividualName":function(node,serviceContact){serviceContact.individualName=this.getChildValue(node);},"PositionName":function(node,serviceContact){serviceContact.positionName=this.getChildValue(node);},"ContactInfo":function(node,serviceContact){serviceContact.contactInfo={};this.re
 adChildNodes(node,serviceContact.contactInfo);},"Phone":function(node,contactInfo){contactInfo.phone={};this.readChildNodes(node,contactInfo.phone);},"Voice":function(node,phone){phone.voice=this.getChildValue(node);},"Address":function(node,contactInfo){contactInfo.address={};this.readChildNodes(node,contactInfo.address);},"DeliveryPoint":function(node,address){address.deliveryPoint=this.getChildValue(node);},"City":function(node,address){address.city=this.getChildValue(node);},"AdministrativeArea":function(node,address){address.administrativeArea=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);},"Country":function(node,address){address.country=this.getChildValue(node);},"ElectronicMailAddress":function(node,address){address.electronicMailAddress=this.getChildValue(node);},"Role":function(node,serviceContact){serviceContact.role=this.getChildValue(node);},"OperationsMetadata":function(node,obj){obj.operationsMetadat
 a={};this.readChildNodes(node,obj.operationsMetadata);},"Operation":function(node,operationsMetadata){var name=node.getAttribute("name");operationsMetadata[name]={};this.readChildNodes(node,operationsMetadata[name]);},"DCP":function(node,operation){operation.dcp={};this.readChildNodes(node,operation.dcp);},"HTTP":function(node,dcp){dcp.http={};this.readChildNodes(node,dcp.http);},"Get":function(node,http){http.get=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Post":function(node,http){http.post=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Parameter":function(node,operation){if(!operation.parameters){operation.parameters={};}
+var name=node.getAttribute("name");operation.parameters[name]={};this.readChildNodes(node,operation.parameters[name]);},"Value":function(node,allowedValues){allowedValues[this.getChildValue(node)]=true;},"OutputFormat":function(node,obj){obj.formats.push({value:this.getChildValue(node)});this.readChildNodes(node,obj);},"WGS84BoundingBox":function(node,obj){var boundingBox={};boundingBox.crs=node.getAttribute("crs");if(obj.BoundingBox){obj.BoundingBox.push(boundingBox);}else{obj.projection=boundingBox.crs;boundingBox=obj;}
+this.readChildNodes(node,boundingBox);},"BoundingBox":function(node,obj){this.readers['ows']['WGS84BoundingBox'].apply(this,[node,obj]);},"LowerCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.left=pointList[0];obj.bottom=pointList[1];},"UpperCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.right=pointList[0];obj.top=pointList[1];obj.bounds=new OpenLayers.Bounds(obj.left,obj.bottom,obj.right,obj.top);delete obj.left;delete obj.bottom;delete obj.right;delete obj.top;}}},writers:{"ows":{"BoundingBox":function(options){var node=this.createElementNSPlus("ows:BoundingBox",{attributes:{crs:options.projection}});this.writeNode("ows:LowerCorner",options,node);this.writeNode("ows:UpperCorner",options,no
 de);return node;},"LowerCorner":function(options){var node=this.createElementNSPlus("ows:LowerCorner",{value:options.bounds.left+" "+options.bounds.bottom});return node;},"UpperCorner":function(options){var node=this.createElementNSPlus("ows:UpperCorner",{value:options.bounds.right+" "+options.bounds.top});return node;},"Title":function(title){var node=this.createElementNSPlus("ows:Title",{value:title});return node;},"OutputFormat":function(format){var node=this.createElementNSPlus("ows:OutputFormat",{value:format});return node;}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.0",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"]},writers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.writers["ows"]},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Format.OWSContext.v0_3_1=Open
 Layers.Class(OpenLayers.Format.XML,{namespaces:{owc:"http://www.opengis.net/ows-context",gml:"http://www.opengis.net/gml",kml:"http://www.opengis.net/kml/2.2",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},VERSION:"0.3.1",schemaLocation:"http://www.opengis.net/ows-context http://www.ogcnetwork.net/schemas/owc/0.3.1/owsContext.xsd",defaultPrefix:"owc",extractAttributes:true,xy:true,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},featureNS:"http://mapserver.gis.umn.edu/mapserver",featureType:'vector',geometryName:'geometry',nestingLayerLookup:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);OpenLayers.Format.GML.v2.prototype.setGeometryTypes.call(this);},setNestingPath:function(l){if(l.layersContext){for(var i=0,len=l.layersContext.length;i<le
 n;i++){var layerContext=l.layersContext[i];var nPath=[];var nTitle=l.title||"";if(l.metadata&&l.metadata.nestingPath){nPath=l.metadata.nestingPath.slice();}
+if(nTitle!=""){nPath.push(nTitle);}
+layerContext.metadata.nestingPath=nPath;if(layerContext.layersContext){this.setNestingPath(layerContext);}}}},decomposeNestingPath:function(nPath){var a=[];if(nPath instanceof Array){while(nPath.length>0){a.push(nPath.slice());nPath.pop();}
+a.reverse();}
+return a;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
-var info={features:[]};this.readNode(data,info);var features=[];for(var i=0,len=info.features.length;i<len;i++){var container=info.features[i];if(this.internalProjection&&this.externalProjection&&container.components[0]){container.components[0].transform(this.externalProjection,this.internalProjection);}
-var feature=new OpenLayers.Feature.Vector(container.components[0],container.attributes);features.push(feature);}
-return features;},readers:{"sa":{"SamplingPoint":function(node,obj){if(!obj.attributes){var feature={attributes:{}};obj.features.push(feature);obj=feature;}
-obj.attributes.id=this.getAttributeNS(node,this.namespaces.gml,"id");this.readChildNodes(node,obj);},"position":function(node,obj){this.readChildNodes(node,obj);}},"gml":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);},"featureMember":function(node,obj){var feature={attributes:{}};obj.features.push(feature);this.readChildNodes(node,feature);},"name":function(node,obj){obj.attributes.name=this.getChildValue(node);},"pos":function(node,obj){if(!this.externalProjection){this.externalProjection=new OpenLayers.Projection(node.getAttribute("srsName"));}
-OpenLayers.Format.GML.v3.prototype.readers.gml.pos.apply(this,[node,obj]);}},OpenLayers.Format.GML.v3.prototype.readers.gml)},writers:{"sos":{"GetFeatureOfInterest":function(options){var node=this.createElementNSPlus("GetFeatureOfInterest",{attributes:{version:this.VERSION,service:'SOS',"xsi:schemaLocation":this.schemaLocation}});for(var i=0,len=options.fois.length;i<len;i++){this.writeNode("FeatureOfInterestId",{foi:options.fois[i]},node);}
-return node;},"FeatureOfInterestId":function(options){var node=this.createElementNSPlus("FeatureOfInterestId",{value:options.foi});return node;}}},CLASS_NAME:"OpenLayers.Format.SOSGetFeatureOfInterest"});OpenLayers.Format.SOSGetObservation=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows",gml:"http://www.opengis.net/gml",sos:"http://www.opengis.net/sos/1.0",ogc:"http://www.opengis.net/ogc",om:"http://www.opengis.net/om/1.0",sa:"http://www.opengis.net/sampling/1.0",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",defaultPrefix:"sos",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.
-if(data&&data.nodeType==9){data=data.documentElement;}
-var info={measurements:[],observations:[]};this.readNode(data,info);return info;},write:function(options){var node=this.writeNode("sos:GetObservation",options);node.setAttribute("xmlns:om",this.namespaces.om);node.setAttribute("xmlns:ogc",this.namespaces.ogc);this.setAttributeNS(node,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},readers:{"om":{"ObservationCollection":function(node,obj){obj.id=this.getAttributeNS(node,this.namespaces.gml,"id");this.readChildNodes(node,obj);},"member":function(node,observationCollection){this.readChildNodes(node,observationCollection);},"Measurement":function(node,observationCollection){var measurement={};observationCollection.measurements.push(measurement);this.readChildNodes(node,measurement);},"Observation":function(node,observationCollection){var observation={};observationCollection.observations.push(observation);this.readChildNodes(node,observation);},"sampl
 ingTime":function(node,measurement){var samplingTime={};measurement.samplingTime=samplingTime;this.readChildNodes(node,samplingTime);},"observedProperty":function(node,measurement){measurement.observedProperty=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,measurement);},"procedure":function(node,measurement){measurement.procedure=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,measurement);},"featureOfInterest":function(node,observation){var foi={features:[]};observation.fois=[];observation.fois.push(foi);this.readChildNodes(node,foi);var features=[];for(var i=0,len=foi.features.length;i<len;i++){var feature=foi.features[i];features.push(new OpenLayers.Feature.Vector(feature.components[0],feature.attributes));}
-foi.features=features;},"result":function(node,measurement){var result={};measurement.result=result;if(this.getChildValue(node)!==''){result.value=this.getChildValue(node);result.uom=node.getAttribute("uom");}else{this.readChildNodes(node,result);}}},"sa":OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.sa,"gml":OpenLayers.Util.applyDefaults({"TimeInstant":function(node,samplingTime){var timeInstant={};samplingTime.timeInstant=timeInstant;this.readChildNodes(node,timeInstant);},"timePosition":function(node,timeInstant){timeInstant.timePosition=this.getChildValue(node);}},OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.gml)},writers:{"sos":{"GetObservation":function(options){var node=this.createElementNSPlus("GetObservation",{attributes:{version:this.VERSION,service:'SOS'}});this.writeNode("offering",options,node);if(options.eventTime){this.writeNode("eventTime",options,node);}
-for(var procedure in options.procedures){this.writeNode("procedure",options.procedures[procedure],node);}
-for(var observedProperty in options.observedProperties){this.writeNode("observedProperty",options.observedProperties[observedProperty],node);}
-if(options.foi){this.writeNode("featureOfInterest",options.foi,node);}
-this.writeNode("responseFormat",options,node);if(options.resultModel){this.writeNode("resultModel",options,node);}
-if(options.responseMode){this.writeNode("responseMode",options,node);}
-return node;},"featureOfInterest":function(foi){var node=this.createElementNSPlus("featureOfInterest");this.writeNode("ObjectID",foi.objectId,node);return node;},"ObjectID":function(options){return this.createElementNSPlus("ObjectID",{value:options});},"responseFormat":function(options){return this.createElementNSPlus("responseFormat",{value:options.responseFormat});},"procedure":function(procedure){return this.createElementNSPlus("procedure",{value:procedure});},"offering":function(options){return this.createElementNSPlus("offering",{value:options.offering});},"observedProperty":function(observedProperty){return this.createElementNSPlus("observedProperty",{value:observedProperty});},"eventTime":function(options){var node=this.createElementNSPlus("eventTime");if(options.eventTime==='latest'){this.writeNode("ogc:TM_Equals",options,node);}
-return node;},"resultModel":function(options){return this.createElementNSPlus("resultModel",{value:options.resultModel});},"responseMode":function(options){return this.createElementNSPlus("responseMode",{value:options.responseMode});}},"ogc":{"TM_Equals":function(options){var node=this.createElementNSPlus("ogc:TM_Equals");this.writeNode("ogc:PropertyName",{property:"urn:ogc:data:time:iso8601"},node);if(options.eventTime==='latest'){this.writeNode("gml:TimeInstant",{value:'latest'},node);}
-return node;},"PropertyName":function(options){return this.createElementNSPlus("ogc:PropertyName",{value:options.property});}},"gml":{"TimeInstant":function(options){var node=this.createElementNSPlus("gml:TimeInstant");this.writeNode("gml:timePosition",options,node);return node;},"timePosition":function(options){var node=this.createElementNSPlus("gml:timePosition",{value:options.value});return node;}}},CLASS_NAME:"OpenLayers.Format.SOSGetObservation"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
-this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
-var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
-this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
-this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListe
 ner(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
+var context={};this.readNode(data,context);this.setNestingPath({layersContext:context.layersContext});var layers=[];this.processLayer(layers,context);delete context.layersContext;context.layersContext=layers;return context;},processLayer:function(layerArray,layer){if(layer.layersContext){for(var i=0,len=layer.layersContext.length;i<len;i++){var l=layer.layersContext[i];layerArray.push(l);if(l.layersContext){this.processLayer(layerArray,l);}}}},write:function(context,options){var name="OWSContext";this.nestingLayerLookup={};options=options||{};OpenLayers.Util.applyDefaults(options,context);var root=this.writeNode(name,options);this.nestingLayerLookup=null;this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},readers:{"kml":{"Document":function(node,obj){obj.features=new OpenLayers.Format.KML({kmlns:this.namespaces.kml,extractStyles:true}).read(node);}},"owc":{"OWSContext":fun
 ction(node,obj){this.readChildNodes(node,obj);},"General":function(node,obj){this.readChildNodes(node,obj);},"ResourceList":function(node,obj){this.readChildNodes(node,obj);},"Layer":function(node,obj){var layerContext={metadata:{},visibility:(node.getAttribute("hidden")!="1"),queryable:(node.getAttribute("queryable")=="1"),opacity:((node.getAttribute("opacity")!=null)?parseFloat(node.getAttribute("opacity")):null),name:node.getAttribute("name"),categoryLayer:(node.getAttribute("name")==null),formats:[],styles:[]};if(!obj.layersContext){obj.layersContext=[];}
+obj.layersContext.push(layerContext);this.readChildNodes(node,layerContext);},"InlineGeometry":function(node,obj){obj.features=[];var elements=this.getElementsByTagNameNS(node,this.namespaces.gml,"featureMember");var el;if(elements.length>=1){el=elements[0];}
+if(el&&el.firstChild){var featurenode=(el.firstChild.nextSibling)?el.firstChild.nextSibling:el.firstChild;this.setNamespace("feature",featurenode.namespaceURI);this.featureType=featurenode.localName||featurenode.nodeName.split(":").pop();this.readChildNodes(node,obj);}},"Server":function(node,obj){if((!obj.service&&!obj.version)||(obj.service!=OpenLayers.Format.Context.serviceTypes.WMS)){obj.service=node.getAttribute("service");obj.version=node.getAttribute("version");this.readChildNodes(node,obj);}},"Name":function(node,obj){obj.name=this.getChildValue(node);this.readChildNodes(node,obj);},"Title":function(node,obj){obj.title=this.getChildValue(node);this.readChildNodes(node,obj);},"StyleList":function(node,obj){this.readChildNodes(node,obj.styles);},"Style":function(node,obj){var style={};obj.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={};obj.legend=legend;this.readChildNodes(node,legend);},"OnlineResource":function(node,obj){obj
 .url=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,obj);}},"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows,"gml":OpenLayers.Format.GML.v2.prototype.readers.gml,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.readers.sld,"feature":OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{"owc":{"OWSContext":function(options){var node=this.createElementNSPlus("OWSContext",{attributes:{version:this.VERSION,id:options.id||OpenLayers.Util.createUniqueID("OpenLayers_OWSContext_")}});this.writeNode("General",options,node);this.writeNode("ResourceList",options,node);return node;},"General":function(options){var node=this.createElementNSPlus("General");this.writeNode("ows:BoundingBox",options,node);this.writeNode("ows:Title",options.title||'OpenLayers OWSContext',node);return node;},"ResourceList":function(options){var node=this.createElementNSPlus("ResourceList");for(var i=0,len=options.layers.length;i<len;i++){var layer=options.layer
 s[i];var decomposedPath=this.decomposeNestingPath(layer.metadata.nestingPath);this.writeNode("_Layer",{layer:layer,subPaths:decomposedPath},node);}
+return node;},"Server":function(options){var node=this.createElementNSPlus("Server",{attributes:{version:options.version,service:options.service}});this.writeNode("OnlineResource",options,node);return node;},"OnlineResource":function(options){var node=this.createElementNSPlus("OnlineResource",{attributes:{"xlink:href":options.url}});return node;},"InlineGeometry":function(layer){var node=this.createElementNSPlus("InlineGeometry");this.writeNode("gml:boundedBy",layer.getDataExtent(),node);for(var i=0,len=layer.features.length;i<len;i++){this.writeNode("gml:featureMember",layer.features[i],node);}
+return node;},"StyleList":function(styles){var node=this.createElementNSPlus("StyleList");for(var i=0,len=styles.length;i<len;i++){this.writeNode("Style",styles[i],node);}
+return node;},"Style":function(style){var node=this.createElementNSPlus("Style");this.writeNode("Name",style,node);this.writeNode("Title",style,node);this.writeNode("LegendURL",style,node);return node;},"Name":function(obj){var node=this.createElementNSPlus("Name",{value:obj.name});return node;},"Title":function(obj){var node=this.createElementNSPlus("Title",{value:obj.title});return node;},"LegendURL":function(style){var node=this.createElementNSPlus("LegendURL");this.writeNode("OnlineResource",style.legend,node);return node;},"_WMS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.params.LAYERS,queryable:layer.queryable?"1":"0",hidden:layer.visibility?"0":"1",opacity:layer.opacity?layer.opacity:null}});this.writeNode("ows:Title",layer.name,node);this.writeNode("ows:OutputFormat",layer.params.FORMAT,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WMS,version:layer.params.VERSION,url:layer.url},node);if(layer.met
 adata.styles&&layer.metadata.styles.length>0){this.writeNode("StyleList",layer.metadata.styles,node);}
+return node;},"_Layer":function(options){var layer,subPaths,node,title;layer=options.layer;subPaths=options.subPaths;node=null;title=null;if(subPaths.length>0){var path=subPaths[0].join("/");var index=path.lastIndexOf("/");node=this.nestingLayerLookup[path];title=(index>0)?path.substring(index+1,path.length):path;if(!node){node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",title,node);this.nestingLayerLookup[path]=node;}
+options.subPaths.shift();this.writeNode("_Layer",options,node);return node;}else{if(layer instanceof OpenLayers.Layer.WMS){node=this.writeNode("_WMS",layer);}else if(layer instanceof OpenLayers.Layer.Vector){if(layer.protocol instanceof OpenLayers.Protocol.WFS.v1){node=this.writeNode("_WFS",layer);}else if(layer.protocol instanceof OpenLayers.Protocol.HTTP){if(layer.protocol.format instanceof OpenLayers.Format.GML){layer.protocol.format.version="2.1.2";node=this.writeNode("_GML",layer);}else if(layer.protocol.format instanceof OpenLayers.Format.KML){layer.protocol.format.version="2.2";node=this.writeNode("_KML",layer);}}else{this.setNamespace("feature",this.featureNS);node=this.writeNode("_InlineGeometry",layer);}}
+if(layer.options.maxScale){this.writeNode("sld:MinScaleDenominator",layer.options.maxScale,node);}
+if(layer.options.minScale){this.writeNode("sld:MaxScaleDenominator",layer.options.minScale,node);}
+this.nestingLayerLookup[layer.name]=node;return node;}},"_WFS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.protocol.featurePrefix+":"+layer.protocol.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WFS,version:layer.protocol.version,url:layer.protocol.url},node);return node;},"_InlineGeometry":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:this.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("InlineGeometry",layer,node);return node;},"_GML":function(layer){var node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.GML,url:layer.protocol.url,version:layer.protocol.format.version},node);return node;},"_KML":function(layer){var node=this.createE
 lementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.KML,version:layer.protocol.format.version,url:layer.protocol.url},node);return node;}},"gml":OpenLayers.Util.applyDefaults({"boundedBy":function(bounds){var node=this.createElementNSPlus("gml:boundedBy");this.writeNode("gml:Box",bounds,node);return node;}},OpenLayers.Format.GML.v2.prototype.writers.gml),"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.writers.ows,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld,"feature":OpenLayers.Format.GML.v2.prototype.writers.feature},CLASS_NAME:"OpenLayers.Format.OWSContext.v0_3_1"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.
 var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
 overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
 if(!overLayerDiv){for(var i=0,len=this.map.layers.length;i<len;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
@@ -1608,7 +1723,20 @@
 this.delta=this.delta+delta;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(e);},this),this.interval);}else{this.wheelZoom(e);}}
 OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=this.delta;this.delta=0;if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
 if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
-if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Format.WFST.v1_0_0=OpenLayers.Class(OpenLayers.For
 mat.Filter.v1_0_0,OpenLayers.Format.WFST.v1,{version:"1.0.0",srsNameInQuery:false,schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"WFS_TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"InsertResult":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);},"TransactionResult":function(node,obj){this.readChildNodes(node,obj);},"Status":function(node,obj){this.readChildNodes(node,obj);},"SUCCESS":function(node,obj){obj.success=true;}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"],"ogc":OpenL
 ayers.Format.Filter.v1_0_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},options);var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(options.featureNS?options.featurePrefix+":":"")+
+if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers
 .Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',layerOptions:null,persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:{};},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
+if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
+this.layer=null;this.feature=null;deactivated=true;}
+return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.map.getLonLatFromPixel(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
+if(this.persist){this.clear();}
+this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.map.getLonLatFromPixel(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
+this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
+this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
+this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();if(this.start==this.last){this.callback("done",[evt.xy]);}},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
+this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
+for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){if(this.layer){this.layer.renderer.clear();this.layer.destroyFeatures();}},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
+if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Format.WFST.v1_0_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,OpenLayers.Format.WFST.v1,{version:"1.0.0",srsNameInQuery:false,schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"WFS_TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"InsertResult":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);},"TransactionResult":function(node,obj){this.readChildNodes(node,obj);},"Status":function(node,obj){this.readChildNodes(node,obj);},"SUCCESS":function(node,obj){obj.success=true;}},OpenLay
 ers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},options);var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(options.featureNS?options.featurePrefix+":":"")+
 options.featureType}});if(options.srsNameInQuery&&options.srsName){node.setAttribute("srsName",options.srsName);}
 if(options.featureNS){node.setAttribute("xmlns:"+options.featurePrefix,options.featureNS);}
 if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("ogc:PropertyName",{property:options.propertyNames[i]},node);}}
@@ -1657,54 +1785,11 @@
 return false;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"refresh":this.load,"visibilitychanged":this.load,scope:this});}
 return deactivated;},load:function(options){var layer=this.layer;layer.events.triggerEvent("loadstart");layer.protocol.read(OpenLayers.Util.applyDefaults({callback:OpenLayers.Function.bind(this.merge,this,layer.map.getProjectionObject()),filter:layer.filter},options));layer.events.un({"visibilitychanged":this.load,scope:this});},merge:function(mapProjection,resp){var layer=this.layer;layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){if(!mapProjection.equals(layer.projection)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(layer.projection,mapProjection);}}}
 layer.addFeatures(features);}
-layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.Fixed"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;this.styles["delete"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temp
 orary"]=new OpenLayers.Style(style);this.styles["delete"]=new OpenLayers.Style(style);break;}}}
-OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
-this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
-if(!this.styles[intent]){intent="default";}
-feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
-return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers,context){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],context:context,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
-this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","beforefeaturesadded","featureadded","featuresadded","beforefeatureremoved","beforefeaturesremoved","featureremoved","featuresremoved","beforefeatureselected","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified","vertexmodified","vertexremoved","sketchstarted","sketchmodified","sketchcomplete","refresh"],isBaseLayer:false,isFixed:false,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:true,style:null,styleMap:null,strategies:null,protocol:null,renderers:['SVG','VML','Canvas'],renderer:null,rendererOptions:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply
 (this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
-if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
-if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
-this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies){for(var i=0,len=this.strategies.length;i<len;i++){this.strategies[i].setLayer(this);}}},destroy:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoDestroy){strategy.destroy();}}
-this.strategies=null;}
-if(this.protocol){if(this.protocol.autoDestroy){this.protocol.destroy();}
-this.protocol=null;}
-this.destroyFeatures();this.features=null;this.selectedFeatures=null;this.unrenderedFeatures=null;if(this.renderer){this.renderer.destroy();}
-this.renderer=null;this.geometryType=null;this.drawn=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Vector(this.name,this.getOptions());}
-obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);var features=this.features;var len=features.length;var clonedFeatures=new Array(len);for(var i=0;i<len;++i){clonedFeatures[i]=features[i].clone();}
-obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){
 strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility="visible";if(OpenLayers.IS_GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
-if(!zoomChanged&&coordSysUnchanged){for(var i in this.unrenderedFeatures){var feature=this.unrenderedFeatures[i];this.drawFeature(feature);}}}
-if(!this.drawn||zoomChanged||!coordSysUnchanged){this.drawn=true;var feature;for(var i=0,len=this.features.length;i<len;i++){this.renderer.locked=(i!==(len-1));feature=this.features[i];this.drawFeature(feature);}}},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(features instanceof Array)){features=[features];}
-var notify=!options||!options.silent;if(notify){var event={features:features};var ret=this.events.triggerEvent("beforefeaturesadded",event);if(ret===false){return;}
-features=event.features;}
-var featuresAdded=[];for(var i=0,len=features.length;i<len;i++){if(i!=(features.length-1)){this.renderer.locked=true;}else{this.renderer.locked=false;}
-var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
-feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
-if(notify){if(this.events.triggerEvent("beforefeatureadded",{feature:feature})===false){continue;};this.preFeatureInsert(feature);}
-featuresAdded.push(feature);this.features.push(feature);this.drawFeature(feature);if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
-if(notify){this.events.triggerEvent("featuresadded",{features:featuresAdded});}},removeFeatures:function(features,options){if(!features||features.length===0){return;}
-if(features===this.features){return this.removeAllFeatures(options);}
-if(!(features instanceof Array)){features=[features];}
-if(features===this.selectedFeatures){features=features.slice();}
-var notify=!options||!options.silent;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
-for(var i=features.length-1;i>=0;i--){if(i!=0&&features[i-1].geometry){this.renderer.locked=true;}else{this.renderer.locked=false;}
-var feature=features[i];delete this.unrenderedFeatures[feature.id];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
-this.features=OpenLayers.Util.removeItem(this.features,feature);feature.layer=null;if(feature.geometry){this.renderer.eraseFeatures(feature);}
-if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
-if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
-if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},removeAllFeatures:function(options){var notify=!options||!options.silent;var features=this.features;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
-var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
-feature.layer=null;if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
-this.renderer.clear();this.features=[];this.unrenderedFeatures={};this.selectedFeatures=[];if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},destroyFeatures:function(features,options){var all=(features==undefined);if(all){features=this.features;}
-if(features){this.removeFeatures(features,options);for(var i=features.length-1;i>=0;i--){features[i].destroy();}}},drawFeature:function(feature,style){if(!this.drawn){return;}
-if(typeof style!="object"){if(!style&&feature.state===OpenLayers.State.DELETE){style="delete";}
-var renderIntent=style||feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
-if(!this.renderer.drawFeature(feature,style)){this.unrenderedFeatures[feature.id]=feature;}else{delete this.unrenderedFeatures[feature.id];};},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
-var featureId=this.renderer.getFeatureIdFromEvent(evt);return this.getFeatureById(featureId);},getFeatureBy:function(property,value){var feature=null;for(var i=0,len=this.features.length;i<len;++i){if(this.features[i][property]==value){feature=this.features[i];break;}}
-return feature;},getFeatureById:function(featureId){return this.getFeatureBy('id',featureId);},getFeatureByFid:function(featureFid){return this.getFeatureBy('fid',featureFid);},getFeaturesByAttribute:function(attrName,attrValue){var i,feature,len=this.features.length,foundFeatures=[];for(i=0;i<len;i++){feature=this.features[i];if(feature&&feature.attributes){if(feature.attributes[attrName]===attrValue){foundFeatures.push(feature);}}}
-return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){maxExtent=new OpenLayers.Bounds();var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){maxExtent.extend(geometry.getBounds());}}}
-return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},addNodes:function(pointFeatures){if(pointFeatures.length<2){OpenLayers.Console.error("At least two point features have to be added to create"+"a line from");return;}
+layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.Fixed"});OpenLayers.Format.WFSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.0",version:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
+var constr=OpenLayers.Format.WFSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw"Can't find a WFS capabilities parser for version "+version;}
+var parser=new constr(this.options);var capabilities=parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.WFSCapabilities"});OpenLayers.Format.WFSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.WFSCapabilities,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var capabilities={};var root=data.documentElement;this.runChildNodes(capabilities,root);return capabilities;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){processor=this["read_cap_"+childNode.nodeName];if(processor){processor.apply(this,[obj,childNode]);}}}},read_cap_FeatureTypeList:function(request,node){var featureTypeList={featureTypes:[]};this.runChildNodes(featureTypeList,node);request.featureTypeList=featureTypeList;},read_cap_FeatureType:function(featureTypeList,node,parentLayer){var featureType={};this.runChildNodes(featureType,node);featureTypeList.featureTypes.push(featureType);},read_cap_Name:function(obj,node){var name=this.getChildValue(node);if(name){var parts=name.split(":");obj.name=parts.pop();if(parts.length>0){obj.featureNS=this.lookupNamespaceURI(node,parts[0]);}}},read_cap_Title:function(obj,node){var title=this.getChildValue(node);
 if(title){obj.title=title;}},read_cap_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1"});OpenLayers.Format.WFSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(options){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_1_0"});OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},addNodes:function(pointFeatures){if(pointFeatures.length<2){OpenLayers.Console.error("At least two point features have to be added to create"+"a line from");return;}
 var lines=new Array(pointFeatures.length-1);var pointFeature,startPoint,endPoint;for(var i=0,len=pointFeatures.length;i<len;i++){pointFeature=pointFeatures[i];endPoint=pointFeature.geometry;if(!endPoint){var lonlat=pointFeature.lonlat;endPoint=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else if(endPoint.CLASS_NAME!="OpenLayers.Geometry.Point"){OpenLayers.Console.error("Only features with point geometries are supported.");return;}
 if(i>0){var attributes=(this.dataFrom!=null)?(pointFeatures[i+this.dataFrom].data||pointFeatures[i+this.dataFrom].attributes):null;var line=new OpenLayers.Geometry.LineString([startPoint,endPoint]);lines[i-1]=new OpenLayers.Feature.Vector(line,attributes);}
 startPoint=endPoint;}
@@ -1753,53 +1838,7 @@
 this.layer.events.triggerEvent("loadstart");this.response=this.layer.protocol.read({filter:this.createFilter(),callback:this.merge,scope:this});},createFilter:function(){var filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,value:this.bounds,projection:this.layer.projection});if(this.layer.filter){filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.layer.filter,filter]});}
 return filter;},merge:function(resp){this.layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(remote,local);}}}
 this.layer.addFeatures(features);}
-this.response=null;this.layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null}},feature:null,lastFeature:null,down:null,up:null,clickTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:false,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){if(!this.callbacks['over']&&!this.callbacks['out']){return true;}
-this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){if(this.feature&&!this.feature.layer){this.feature=null;}
-var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature&&!this.feature.layer){this.feature=null;}
-if(this.lastFeature&&!this.lastFeature.layer){this.lastFeature=null;}
-if(this.feature){var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){if(this.lastFeature){this.triggerCallback(type,'out',[this.lastFeature]);}
-this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
-this.lastFeature=this.feature;handled=true;}else{if(this.lastFeature&&(previouslyIn&&inNew||click)){this.triggerCallback(type,'out',[this.lastFeature]);}
-this.feature=null;}}else{if(this.lastFeature&&(previouslyIn||click)){this.triggerCallback(type,'out',[this.lastFeature]);}}
-return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
-Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
-return deactivated;},handleMapEvents:function(evt){if(!evt.property||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap
 .apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer.moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){layer=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforefeatu
 rehighlighted","featurehighlighted","featureunhighlighted"],multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){this.EVENT_TYPES=OpenLayers.Control.SelectFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
-this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
-this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(layers instanceof Array){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
-this.handlers.feature.activate();if(this.box&&this.handlers.box){this.handlers.box.activate();}}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){this.handlers.feature.deactivate();if(this.handlers.box){this.handlers.box.deactivate();}
-if(this.layers){this.map.removeLayer(this.layer);}}
-return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},unselectAll:function(options){var layers=this.layers||[this.layer];var layer,feature;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=layer.selectedFeatures.length-1;i>=0;--i){feature=layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(feature.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
-this.select(feature);}}},multipleSelect:function(){return this.multiple||(this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]);},toggleSelect:function(){return this.toggle||(this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]);},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){var layer=feature.layer;if(this.hover){if(this.highlightOnly){this.highlight(feature);}else if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}},outFeature:function(feature){if(this.hover){if(this.highlightOnly){if(feature._lastHighlighter==this.id){if(feature._prevHighlighter&&feature._prevHighlighter!=this.id){delete feature._lastHighlighter;var control=this.map.getControl(feature._prevHighlighter);if(control){control.highlight(feature);}}else{this.unhighlight(feature);}}}else{this.unselect(feature);}}},highlight:function(feature){var layer=feature.layer;var cont
 =this.events.triggerEvent("beforefeaturehighlighted",{feature:feature});if(cont!==false){feature._prevHighlighter=feature._lastHighlighter;feature._lastHighlighter=this.id;var style=this.selectStyle||this.renderIntent;layer.drawFeature(feature,style);this.events.triggerEvent("featurehighlighted",{feature:feature});}},unhighlight:function(feature){var layer=feature.layer;feature._lastHighlighter=feature._prevHighlighter;delete feature._prevHighlighter;layer.drawFeature(feature,feature.style||feature.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:feature});},select:function(feature){var cont=this.onBeforeSelect.call(this.scope,feature);var layer=feature.layer;if(cont!==false){cont=layer.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){layer.selectedFeatures.push(feature);this.highlight(feature);if(!this.handlers.feature.lastFeature){this.handlers.feature.lastFeature=layer.selectedFeatures[0];}
-layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect.call(this.scope,feature);}}},unselect:function(feature){var layer=feature.layer;this.unhighlight(feature);OpenLayers.Util.removeItem(layer.selectedFeatures,feature);layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect.call(this.scope,feature);},selectBox:function(position){if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);if(!this.multipleSelect()){this.unselectAll();}
-var prevMultiple=this.multiple;this.multiple=true;var layers=this.layers||[this.layer];var layer;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=0,len=layer.features.length;i<len;++i){var feature=layer.features[i];if(!feature.getVisibility()){continue;}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1){if(bounds.toGeometry().intersects(feature.geometry)){if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}}}}
-this.multiple=prevMultiple;}},setMap:function(map){this.handlers.feature.setMap(map);if(this.box){this.handlers.box.setMap(map);}
-OpenLayers.Control.prototype.setMap.apply(this,arguments);},setLayer:function(layers){var isActive=this.active;this.unselectAll();this.deactivate();if(this.layers){this.layer.destroy();this.layers=null;}
-this.initLayer(layers);this.handlers.feature.layer=this.layer;if(isActive){this.activate();}},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,drawing:false,mouseDown:false,lastDown:null,lastUp:null,persist:false,layerOptions:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
-OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
-var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
-if(this.drawing){this.cancel();}
-this.destroyFeature();if(this.layer.map!=null){this.layer.destroy(false);}
-this.layer=null;return true;},destroyFeature:function(){if(this.layer){this.layer.destroyFeatures();}
-this.point=null;},finalize:function(cancel){var key=cancel?"cancel":"done";this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback(key,[this.geometryClone()]);if(cancel||!this.persist){this.destroyFeature();}},cancel:function(){this.finalize(true);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
-return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){if(!this.checkModifiers(evt)){return true;}
-if(this.lastDown&&this.lastDown.equals(evt.xy)){return true;}
-this.drawing=true;if(this.lastDown==null){if(this.persist){this.destroyFeature();}
-this.createFeature(evt.xy);}else{this.modifyFeature(evt.xy);}
-this.lastDown=evt.xy;return false;},mousemove:function(evt){if(this.drawing){this.modifyFeature(evt.xy);}
-return true;},mouseup:function(evt){if(this.drawing){this.finalize();return false;}else{return true;}},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,freehand:false,freehandToggle:'shiftKey',initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);this.line=null;},removePoint:function(){if(this.point){this.layer.removeFeatures([thi
 s.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return
 this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
-return geometry;},mousedown:function(evt){if(this.lastDown&&this.lastDown.equals(evt.xy)){return false;}
-if(this.lastDown==null){if(this.persist){this.destroyFeature();}
-this.createFeature(evt.xy);}else if((this.lastUp==null)||!this.lastUp.equals(evt.xy)){this.addPoint(evt.xy);}
-this.mouseDown=true;this.lastDown=evt.xy;this.drawing=true;return false;},mousemove:function(evt){if(this.drawing){if(this.mouseDown&&this.freehandMode(evt)){this.addPoint(evt.xy);}else{this.modifyFeature(evt.xy);}}
-return true;},mouseup:function(evt){this.mouseDown=false;if(this.drawing){if(this.freehandMode(evt)){this.removePoint();this.finalize();}else{if(this.lastUp==null){this.addPoint(evt.xy);}
-this.lastUp=evt.xy;}
-return false;}
-return true;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},loadGML:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.url,success:this.requestSuccess,failure:this.requestFailure,scope:this});this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.loadGML();},requestSuccess:function(request){var do
 c=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+this.response=null;this.layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},loadGML:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.url,success:this.requestSuccess,failure:this.requestFailure,scope:this});this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.lo
 adGML();},requestSuccess:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
 var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
 var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){OpenLayers.Console.userError(OpenLayers.i18n("errorLoadingGML",{'url':this.url}));this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",getParser:function(version){var v=version||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=v){var format=OpenLayers.Format.WMC["v"+v.replace(/\./g,"_")];if(!format){throw"Can't find a WMC parser for version "+v;}
 this.parser=new format(this.options);}
@@ -1868,52 +1907,31 @@
 var feature=new OpenLayers.Feature(this,location,data);this.features.push(feature);var marker=feature.createMarker();marker.events.register('click',feature,this.markerClick);this.addMarker(marker);}
 this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
 if(!sameMarkerClicked){var popup=this.createPopup();OpenLayers.Event.observe(popup.div,"click",OpenLayers.Function.bind(function(){for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}},this));this.layer.map.addPopup(popup);}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Format.SOSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.SOSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw"Can't find a SOS capabilities parser for version "+version;}
-var parser=new constr(this.options);}
-var capabilities=parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.SOSCapabilities"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===true){var me=this;this._docMove=function(evt){me.mousemove({xy:{x:evt.clientX,y:evt.clientY},element:document});};this._docUp=function(evt){me.mouseup({xy:{x:evt.clientX,y:evt.clientY}});};}},dragstart:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt))){this.started=true;this.start=evt.xy;this.last=evt.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",
 [evt.xy]);if(evt.type==="mousedown"){OpenLayers.Event.stop(evt);}
-if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;}
-document.onselectstart=OpenLayers.Function.False;propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
-return propagate;},dragmove:function(evt){if(this.started&&!this.timeoutId&&(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y)){if(this.documentDrag===true&&this.documentEvents){if(evt.element===document){this.adjustXY(evt);this.setEvent(evt);}else{this.removeDocumentEvents();}}
-if(this.interval>0){this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);}
-this.dragging=true;if(evt.type==="touchmove"){OpenLayers.Event.stop(evt);}
-this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False;}
-this.last=this.evt.xy;}
-return true;},dragend:function(evt){if(this.started){if(this.documentDrag===true&&this.documentEvents){this.adjustXY(evt);this.removeDocumentEvents();}
-var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
-document.onselectstart=this.oldOnselectstart;}
-return true;},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){return this.dragstart(evt);},touchstart:function(evt){return this.dragstart(evt);},mousemove:function(evt){return this.dragmove(evt);},touchmove:function(evt){return this.dragmove(evt);},removeTimeout:function(){this.timeoutId=null;},mouseup:function(evt){return this.dragend(evt);},touchend:function(evt){evt.xy=this.last;return this.dragend(evt);},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.viewPortDiv)){if(this.documentDrag===true){this.addDocumentEvents();}else{var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
-if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}}
-return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
-return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxCharacteristics:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.move
 Box,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.viewPortDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";this.zoomBox.style.left=xy.x<startX?xy.x+"px":startX+"px";this.
 zoomBox.style.top=xy.y<startY?xy.y+"px":startY+"px";var box=this.getBoxCharacteristics();if(box.newBoxModel){if(xy.x>startX){this.zoomBox.style.width=Math.max(1,deltaX-box.xOffset)+"px";}
-if(xy.y>startY){this.zoomBox.style.height=Math.max(1,deltaY-box.yOffset)+"px";}}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
-this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxCharacteristics=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},getBoxCharacteristics:function(){if(!this.boxCharacteristics){var xOffset=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"))+1;var yOffset=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"))+1;var newBoxModel=OpenLayers.BROWSER_NAME=="msie"?document.compatMode!="BackCompa
 t":true;this.boxCharacteristics={xOffset:xOffset,yOffset:yOffset,newBoxModel:newBoxModel};}
-return this.boxCharacteristics;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;
 var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
-var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:25,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
-this.kinetic=new OpenLayers.Kinetic(config);}
-this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
-this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
-this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
-this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,last:null,touch:false,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt;return true;};}},mousedown:null,touchstart:function(evt){this.touch=true;this.down=evt;this.last=null;return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
-return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
-return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}
-return!this.stopSingle;},dblclick:function(evt){if(this.passesTolerance(evt)&&(!evt.lastTouches||evt.lastTouches.length==1)){if(this["double"]){this.callback('dblclick',[evt]);}
-this.clearTimer();}
-return!this.stopDouble;},touchmove:function(evt){this.last=evt;},touchend:function(evt){var last=this.last||this.down;if(!evt||!last){return false;}
-evt.xy=last.xy;evt.lastTouches=last.touches;return evt.xy?this.click(evt):false;},click:function(evt){if(this.touch===true&&evt.type==="click"){return!this.stopSingle;}
-if(this.passesTolerance(evt)){if(this.timerId!=null){if(evt.lastTouches){this.dblclick(evt);}else{this.clearTimer();}}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
-return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){var dpx=Math.sqrt(Math.pow(this.down.xy.x-evt.xy.x,2)+
-Math.pow(this.down.xy.y-evt.xy.y,2));if(dpx>this.pixelTolerance){passes=false;}}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
-if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback('click',[evt]);}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.last=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
-this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
-this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
-this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
-var clickCallbacks={'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+
 Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis
 .net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerContext,node){var minScaleDenominator=parseFloat(this.getChildValue(node));if(minScaleDenominator>0){layerContext.maxScale=minScaleDenominator;}},read_sld_MaxScaleDenominator:function(layerContext,node){layerContext.minScale=parseFloat(this.getChildValue(node));},write_wmc_Layer:function(context){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[context]);if(context.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(context.maxScale.toPrecision(16)));node.appendChild(minSD);}
+OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Format.WMSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.1",version:null,profile:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;var profile=this.profile?"_"+this.profile:"";if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.WMSCapabilities["v"+version.replace(/\./g,"_")+profile];if(!constr){throw"Can't find a WMS capabilities parser for version "+
+version+profile;}
+this.parser=new constr(this.options);}
+var capabilities=this.parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.WMSCapabilities"});OpenLayers.Format.WMSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{wms:"http://www.opengis.net/wms",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"wms",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var capabilities={};this.readNode(data,capabilities);this.postProcessLayers(capabilities);return capabilities;},postProcessLayers:function(capabilities){if(capabilities.capability){capabilities.capability.layers=[];var layers=capabilities.capability.nestedLayers;for(var i=0,len=layers.length;i<len;++i){var layer=layers[i];this.processLayer(capabilities.capability,layer);}}},processLayer:function(capability,layer,parentLayer){if(layer.formats===undefined){layer.formats=capability.request.getmap.formats;}
+if(parentLayer){layer.styles=layer.styles.concat(parentLayer.styles);var attributes=["queryable","cascaded","fixedWidth","fixedHeight","opaque","noSubsets","llbbox","minScale","maxScale","attribution"];var complexAttr=["srs","bbox","dimensions","authorityURLs"];var key;for(var j=0;j<attributes.length;j++){key=attributes[j];if(key in parentLayer){if(layer[key]==null){layer[key]=parentLayer[key];}
+if(layer[key]==null){var intAttr=["cascaded","fixedWidth","fixedHeight"];var boolAttr=["queryable","opaque","noSubsets"];if(OpenLayers.Util.indexOf(intAttr,key)!=-1){layer[key]=0;}
+if(OpenLayers.Util.indexOf(boolAttr,key)!=-1){layer[key]=false;}}}}
+for(var j=0;j<complexAttr.length;j++){key=complexAttr[j];layer[key]=OpenLayers.Util.extend(layer[key],parentLayer[key]);}}
+for(var i=0,len=layer.nestedLayers.length;i<len;i++){var childLayer=layer.nestedLayers[i];this.processLayer(capability,childLayer,layer);}
+if(layer.name){capability.layers.push(layer);}},readers:{"wms":{"Service":function(node,obj){obj.service={};this.readChildNodes(node,obj.service);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj["abstract"]=this.getChildValue(node);},"BoundingBox":function(node,obj){var bbox={};bbox.bbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];var res={x:parseFloat(node.getAttribute("resx")),y:parseFloat(node.getAttribute("resy"))};if(!(isNaN(res.x)&&isNaN(res.y))){bbox.res=res;}
+return bbox;},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ContactInformation":function(node,obj){obj.contactInformation={};this.readChildNodes(node,obj.contactInformation);},"ContactPersonPrimary":function(node,obj){obj.personPrimary={};this.readChildNodes(node,obj.personPrimary);},"ContactPerson":function(node,obj){obj.person=this.getChildValue(node);},"ContactOrganization":function(node,obj){obj.organization=this.getChildValue(node);},"ContactPosition":function(node,obj){obj.position=this.getChildValue(node);},"ContactAddress":function(node,obj){obj.contactAddress={};this.readChildNodes(node,obj.contactAddress);},"AddressType":function(node,obj){obj.type=this.getChildValue(node);},"Address":function(node,obj){obj.address=this.getChildValue(node);},"City":function(node,obj){obj.city=this.getChildValue(node);},"StateOrProvince":function(node,obj){obj.stateOrProvince=this.getChildValue(node);},"PostCode":function(node
 ,obj){obj.postcode=this.getChildValue(node);},"Country":function(node,obj){obj.country=this.getChildValue(node);},"ContactVoiceTelephone":function(node,obj){obj.phone=this.getChildValue(node);},"ContactFacsimileTelephone":function(node,obj){obj.fax=this.getChildValue(node);},"ContactElectronicMailAddress":function(node,obj){obj.email=this.getChildValue(node);},"Fees":function(node,obj){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){obj.fees=fees;}},"AccessConstraints":function(node,obj){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){obj.accessConstraints=constraints;}},"Capability":function(node,obj){obj.capability={nestedLayers:[]};this.readChildNodes(node,obj.capability);},"Request":function(node,obj){obj.request={};this.readChildNodes(node,obj.request);},"GetCapabilities":function(node,obj){obj.getcapabilities={formats:[]};this.readChildNodes(node,obj.getcapabilities);},"Format":function(node,obj){if(obj
 .formats instanceof Array){obj.formats.push(this.getChildValue(node));}else{obj.format=this.getChildValue(node);}},"DCPType":function(node,obj){this.readChildNodes(node,obj);},"HTTP":function(node,obj){this.readChildNodes(node,obj);},"Get":function(node,obj){this.readChildNodes(node,obj);},"Post":function(node,obj){this.readChildNodes(node,obj);},"GetMap":function(node,obj){obj.getmap={formats:[]};this.readChildNodes(node,obj.getmap);},"GetFeatureInfo":function(node,obj){obj.getfeatureinfo={formats:[]};this.readChildNodes(node,obj.getfeatureinfo);},"Exception":function(node,obj){obj.exception={formats:[]};this.readChildNodes(node,obj.exception);},"Layer":function(node,obj){var attrNode=node.getAttributeNode("queryable");var queryable=(attrNode&&attrNode.specified)?node.getAttribute("queryable"):null;attrNode=node.getAttributeNode("cascaded");var cascaded=(attrNode&&attrNode.specified)?node.getAttribute("cascaded"):null;attrNode=node.getAttributeNode("opaque");var opaque=(att
 rNode&&attrNode.specified)?node.getAttribute('opaque'):null;var noSubsets=node.getAttribute('noSubsets');var fixedWidth=node.getAttribute('fixedWidth');var fixedHeight=node.getAttribute('fixedHeight');var layer={nestedLayers:[],styles:[],srs:{},metadataURLs:[],bbox:{},dimensions:{},authorityURLs:{},identifiers:{},keywords:[],queryable:(queryable&&queryable!=="")?(queryable==="1"||queryable==="true"):null,cascaded:(cascaded!==null)?parseInt(cascaded):null,opaque:opaque?(opaque==="1"||opaque==="true"):null,noSubsets:(noSubsets!==null)?(noSubsets==="1"||noSubsets==="true"):null,fixedWidth:(fixedWidth!=null)?parseInt(fixedWidth):null,fixedHeight:(fixedHeight!=null)?parseInt(fixedHeight):null};obj.nestedLayers.push(layer);this.readChildNodes(node,layer);if(layer.name){var parts=layer.name.split(":");if(parts.length>0){layer.prefix=parts[0];}}},"Attribution":function(node,obj){obj.attribution={};this.readChildNodes(node,obj.attribution);},"LogoURL":function(node,obj){obj.logo={wid
 th:node.getAttribute("width"),height:node.getAttribute("height")};this.readChildNodes(node,obj.logo);},"Style":function(node,obj){var style={};obj.styles.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={width:node.getAttribute("width"),height:node.getAttribute("height")};obj.legend=legend;this.readChildNodes(node,legend);},"MetadataURL":function(node,obj){var metadataURL={type:node.getAttribute("type")};obj.metadataURLs.push(metadataURL);this.readChildNodes(node,metadataURL);},"DataURL":function(node,obj){obj.dataURL={};this.readChildNodes(node,obj.dataURL);},"FeatureListURL":function(node,obj){obj.featureListURL={};this.readChildNodes(node,obj.featureListURL);},"AuthorityURL":function(node,obj){var name=node.getAttribute("name");var authority={};this.readChildNodes(node,authority);obj.authorityURLs[name]=authority.href;},"Identifier":function(node,obj){var authority=node.getAttribute("authority");obj.identifiers[authority]=this.getChi
 ldValue(node);},"KeywordList":function(node,obj){this.readChildNodes(node,obj);},"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1"});OpenLayers.Format.WMSCapabilities.v1_3=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"LayerLimit":function(node,obj){obj.layerLimit=parseInt(this.getChildValue(node));},"MaxWidth":function(node,obj){obj.maxWidth=parseInt(this.getChildValue(node));},"MaxHeight":function(node,obj){obj.maxHeight=parseInt(this.getChildValue(node));},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("CRS");obj.bbox[bbox.srs]=bbox;},"CRS":function(node,obj){this.readers.wms.SRS.apply(this,[node,obj]);},"EX_GeographicBoundingBox":function(node,obj){obj.llbbox=[];th
 is.readChildNodes(node,obj.llbbox);},"westBoundLongitude":function(node,obj){obj[0]=this.getChildValue(node);},"eastBoundLongitude":function(node,obj){obj[2]=this.getChildValue(node);},"southBoundLatitude":function(node,obj){obj[1]=this.getChildValue(node);},"northBoundLatitude":function(node,obj){obj[3]=this.getChildValue(node);},"MinScaleDenominator":function(node,obj){obj.maxScale=parseFloat(this.getChildValue(node)).toPrecision(16);},"MaxScaleDenominator":function(node,obj){obj.minScale=parseFloat(this.getChildValue(node)).toPrecision(16);},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol"),nearestVal:node.getAttribute("nearestValue")==="1",multipleVal:node.getAttribute("multipleValues")==="1","default":node.getAttribute("default")||"",current:node.getAttribute("current")==="1",values:this.getChildValue(node).split(",")};obj.dimensions[dim.name]=dim
 ;},"Keyword":function(node,obj){var keyword={value:this.getChildValue(node),vocabulary:node.getAttribute("vocabulary")};if(obj.keywords){obj.keywords.push(keyword);}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"]),"sld":{"UserDefinedSymbolization":function(node,obj){this.readers.wms.UserDefinedSymbolization.apply(this,[node,obj]);obj.userSymbols.inlineFeature=parseInt(node.getAttribute("InlineFeature"))==1;obj.userSymbols.remoteWCS=parseInt(node.getAttribute("RemoteWCS"))==1;},"DescribeLayer":function(node,obj){this.readers.wms.DescribeLayer.apply(this,[node,obj]);},"GetLegendGraphic":function(node,obj){this.readers.wms.GetLegendGraphic.apply(this,[node,obj]);}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3"});OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:false,positionBlocks:null,blocks:null,fixedRelativePosition:false,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,
 closeBoxCallback){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition){this.updateRelativePosition();this.calculateRelativePosition=function(px){return this.relativePosition;};}
+this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(closeBox){this.closeDiv.style.zIndex=1;}
+this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%";},destroy:function(){this.imageSrc=null;this.imageSize=null;this.isAlphaImage=null;this.fixedRelativePosition=false;this.positionBlocks=null;for(var i=0;i<this.blocks.length;i++){var block=this.blocks[i];if(block.image){block.div.removeChild(block.image);}
+block.image=null;if(block.div){this.groupDiv.removeChild(block.div);}
+block.div=null;}
+this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,arguments);},setBackgroundColor:function(color){},setBorder:function(){},setOpacity:function(opacity){},setSize:function(contentSize){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks();},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+
+this.padding.right+"px";this.closeDiv.style.top=contentDivPadding.top+
+this.padding.top+"px";}
+this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
+var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
+if(this.size&&this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=(w<0?0:w)+'px';block.div.style.height=(h<0?0:h)+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
+this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerContext,node){var minScaleDenominator=parseFloat(this.getChildValue(node));if(minScaleDenominator>0){layerContext.maxScale=minScaleDenominator;}},read_sld_MaxScaleDenominator:function(layerContext,node){layerContext.minScale=parseFloat(this.getChildValue(node));},write_wmc_Layer:function(context){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[context]);if(context.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(c
 if(context.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(context.minScale.toPrecision(16)));node.appendChild(maxSD);}
 node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));node.appendChild(this.write_wmc_LayerExtension(context));return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15000,translationParameters:null,symbolMetrics:null,initialize:function(containerID){if(!this.supported()){return;}
 OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.symbolMetrics={};},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y,xyOnly){var left=x+(xyOnly?0:this.translationParameters.x);var top=y+(xyOnly?0:this.translationParameters.y);return(left>=-this.MAX_PIXEL&&left<=this.MAX_PIXEL&&top>=-this.MAX_PIXEL&&top<=this.MAX_PIXEL);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=-extent.left/resolution;var top=extent.top/resolution;if(resolutionChanged)
 {this.left=left;this.top=top;var extentString="0 0 "+this.size.w+" "+this.size.h;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.translate(0,0);return true;}else{var inRange=this.translate(left-this.left,top-this.top);if(!inRange){this.setExtent(extent,true);}
@@ -1986,18 +2004,23 @@
 var start=(this.num-1)*this.length;changed=this.page(start);}
 return changed;},page:function(start,event){var changed=false;if(this.features){if(start>=0&&start<this.features.length){var num=Math.floor(start/this.length);if(num!=this.num){this.paging=true;var features=this.features.slice(start,start+this.length);this.layer.removeFeatures(this.layer.features);this.num=num;if(event&&event.features){event.features=features;}else{this.layer.addFeatures(features);}
 this.paging=false;changed=true;}}}
-return changed;},CLASS_NAME:"OpenLayers.Strategy.Paging"});OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:false,positionBlocks:null,blocks:null,fixedRelativePosition:false,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition){this.updateRelativePosition();this.calculateRelativePosition=function(px){return this.relativePosition;};}
-this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(closeBox){this.closeDiv.style.zIndex=1;}
-this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%";},destroy:function(){this.imageSrc=null;this.imageSize=null;this.isAlphaImage=null;this.fixedRelativePosition=false;this.positionBlocks=null;for(var i=0;i<this.blocks.length;i++){var block=this.blocks[i];if(block.image){block.div.removeChild(block.image);}
-block.image=null;if(block.div){this.groupDiv.removeChild(block.div);}
-block.div=null;}
-this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,arguments);},setBackgroundColor:function(color){},setBorder:function(){},setOpacity:function(opacity){},setSize:function(contentSize){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks();},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+
-this.padding.right+"px";this.closeDiv.style.top=contentDivPadding.top+
-this.padding.top+"px";}
-this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
-var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
-if(this.size&&this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=(w<0?0:w)+'px';block.div.style.height=(h<0?0:h)+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
-this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,formatSuffixMap:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png","png":"png","image/jpeg":"jpg","image/jpg":"jpg","jpeg":"jpg","jpg":"jpg"},matrix:null,initialize:function(config){var required={url:true,layer:true,style:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
+return changed;},CLASS_NAME:"OpenLayers.Strategy.Paging"});OpenLayers.Control.TransformFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesetfeature","setfeature","beforetransform","transform","transformcomplete"],geometryTypes:null,layer:null,preserveAspectRatio:false,rotate:true,feature:null,renderIntent:"temporary",rotationHandleSymbolizer:null,box:null,center:null,scale:1,ratio:1,rotation:0,handles:null,rotationHandles:null,dragControl:null,initialize:function(layer,options){this.EVENT_TYPES=OpenLayers.Control.TransformFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;if(!this.rotationHandleSymbolizer){this.rotationHandleSymbolizer={stroke:false,pointRadius:10,fillOpacity:0,cursor:"pointer"};}
+this.createBox();this.createControl();},activate:function(){var activated=false;if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragControl.activate();this.layer.addFeatures([this.box]);this.rotate&&this.layer.addFeatures(this.rotationHandles);this.layer.addFeatures(this.handles);activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.handles);this.rotate&&this.layer.removeFeatures(this.rotationHandles);this.layer.removeFeatures([this.box]);this.dragControl.deactivate();deactivated=true;}
+return deactivated;},setMap:function(map){this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},setFeature:function(feature,initialParams){initialParams=OpenLayers.Util.applyDefaults(initialParams,{rotation:0,scale:1,ratio:1});var evt={feature:feature};var oldRotation=this.rotation;var oldCenter=this.center;OpenLayers.Util.extend(this,initialParams);if(this.events.triggerEvent("beforesetfeature",evt)===false){return;}
+this.feature=feature;this.activate();this._setfeature=true;var featureBounds=this.feature.geometry.getBounds();this.box.move(featureBounds.getCenterLonLat());this.box.geometry.rotate(-oldRotation,oldCenter);this._angle=0;var ll;if(this.rotation){var geom=feature.geometry.clone();geom.rotate(-this.rotation,this.center);var box=new OpenLayers.Feature.Vector(geom.getBounds().toGeometry());box.geometry.rotate(this.rotation,this.center);this.box.geometry.rotate(this.rotation,this.center);this.box.move(box.geometry.getBounds().getCenterLonLat());var llGeom=box.geometry.components[0].components[0];ll=llGeom.getBounds().getCenterLonLat();}else{ll=new OpenLayers.LonLat(featureBounds.left,featureBounds.bottom);}
+this.handles[0].move(ll);delete this._setfeature;this.events.triggerEvent("setfeature",evt);},createBox:function(){var control=this;this.center=new OpenLayers.Geometry.Point(0,0);var box=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([new OpenLayers.Geometry.Point(-1,-1),new OpenLayers.Geometry.Point(0,-1),new OpenLayers.Geometry.Point(1,-1),new OpenLayers.Geometry.Point(1,0),new OpenLayers.Geometry.Point(1,1),new OpenLayers.Geometry.Point(0,1),new OpenLayers.Geometry.Point(-1,1),new OpenLayers.Geometry.Point(-1,0),new OpenLayers.Geometry.Point(-1,-1)]),null,typeof this.renderIntent=="string"?null:this.renderIntent);box.geometry.move=function(x,y){control._moving=true;OpenLayers.Geometry.LineString.prototype.move.apply(this,arguments);control.center.move(x,y);delete control._moving;};var vertexMoveFn=function(x,y){OpenLayers.Geometry.Point.prototype.move.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.move(x,y);this._handle.geometr
 y.move(x,y);};var vertexResizeFn=function(scale,center,ratio){OpenLayers.Geometry.Point.prototype.resize.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.resize(scale,center,ratio);this._handle.geometry.resize(scale,center,ratio);};var vertexRotateFn=function(angle,center){OpenLayers.Geometry.Point.prototype.rotate.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.rotate(angle,center);this._handle.geometry.rotate(angle,center);};var handleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
+var evt=control.dragControl.handlers.drag.evt;var preserveAspectRatio=!control._setfeature&&control.preserveAspectRatio;var reshape=!preserveAspectRatio&&!(evt&&evt.shiftKey);var oldGeom=new OpenLayers.Geometry.Point(oldX,oldY);var centerGeometry=control.center;this.rotate(-control.rotation,centerGeometry);oldGeom.rotate(-control.rotation,centerGeometry);var dx1=this.x-centerGeometry.x;var dy1=this.y-centerGeometry.y;var dx0=dx1-(this.x-oldGeom.x);var dy0=dy1-(this.y-oldGeom.y);this.x=oldX;this.y=oldY;var scale,ratio=1;if(reshape){scale=Math.abs(dy0)<0.00001?1:dy1/dy0;ratio=(Math.abs(dx0)<0.00001?1:(dx1/dx0))/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
+control._moving=true;control.box.geometry.rotate(-control.rotation,centerGeometry);delete control._moving;control.box.geometry.resize(scale,centerGeometry,ratio);control.box.geometry.rotate(control.rotation,centerGeometry);control.transformFeature({scale:scale,ratio:ratio});};var rotationHandleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
+var evt=control.dragControl.handlers.drag.evt;var constrain=(evt&&evt.shiftKey)?45:1;var centerGeometry=control.center;var dx1=this.x-centerGeometry.x;var dy1=this.y-centerGeometry.y;var dx0=dx1-x;var dy0=dy1-y;this.x=oldX;this.y=oldY;var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;control._angle=(control._angle+angle)%360;var diff=control.rotation%constrain;if(Math.abs(control._angle)>=constrain||diff!==0){angle=Math.round(control._angle/constrain)*constrain-
+diff;control._angle=0;control.box.geometry.rotate(angle,centerGeometry);control.transformFeature({rotation:angle});}};var handles=new Array(8);var rotationHandles=new Array(4);var geom,handle,rotationHandle;for(var i=0;i<8;++i){geom=box.geometry.components[i];handle=new OpenLayers.Feature.Vector(geom.clone(),null,typeof this.renderIntent=="string"?null:this.renderIntent);if(i%2==0){rotationHandle=new OpenLayers.Feature.Vector(geom.clone(),null,typeof this.rotationHandleSymbolizer=="string"?null:this.rotationHandleSymbolizer);rotationHandle.geometry.move=rotationHandleMoveFn;geom._rotationHandle=rotationHandle;rotationHandles[i/2]=rotationHandle;}
+geom.move=vertexMoveFn;geom.resize=vertexResizeFn;geom.rotate=vertexRotateFn;handle.geometry.move=handleMoveFn;geom._handle=handle;handles[i]=handle;}
+this.box=box;this.rotationHandles=rotationHandles;this.handles=handles;},createControl:function(){var control=this;this.dragControl=new OpenLayers.Control.DragFeature(this.layer,{documentDrag:true,moveFeature:function(pixel){if(this.feature===control.feature){this.feature=control.box;}
+OpenLayers.Control.DragFeature.prototype.moveFeature.apply(this,arguments);},onDrag:function(feature,pixel){if(feature===control.box){control.transformFeature({center:control.center});control.drawHandles();}},onStart:function(feature,pixel){var eligible=!control.geometryTypes||OpenLayers.Util.indexOf(control.geometryTypes,feature.geometry.CLASS_NAME)!==-1;var i=OpenLayers.Util.indexOf(control.handles,feature);i+=OpenLayers.Util.indexOf(control.rotationHandles,feature);if(feature!==control.feature&&feature!==control.box&&i==-2&&eligible){control.setFeature(feature);}},onComplete:function(feature,pixel){control.events.triggerEvent("transformcomplete",{feature:control.feature});}});},drawHandles:function(){var layer=this.layer;for(var i=0;i<8;++i){if(this.rotate&&i%2===0){layer.drawFeature(this.rotationHandles[i/2],this.rotationHandleSymbolizer);}
+layer.drawFeature(this.handles[i],this.renderIntent);}},transformFeature:function(mods){if(!this._setfeature){this.scale*=(mods.scale||1);this.ratio*=(mods.ratio||1);var oldRotation=this.rotation;this.rotation=(this.rotation+(mods.rotation||0))%360;if(this.events.triggerEvent("beforetransform",mods)!==false){var feature=this.feature;var geom=feature.geometry;var center=this.center;geom.rotate(-oldRotation,center);if(mods.scale||mods.ratio){geom.resize(mods.scale,center,mods.ratio);}else if(mods.center){feature.move(mods.center.getBounds().getCenterLonLat());}
+geom.rotate(this.rotation,center);this.layer.drawFeature(feature);feature.toState(OpenLayers.State.UPDATE);this.events.triggerEvent("transform",mods);}}
+this.layer.drawFeature(this.box,this.renderIntent);this.drawHandles();},destroy:function(){var geom;for(var i=0;i<8;++i){geom=this.box.geometry.components[i];geom._handle.destroy();geom._handle=null;geom._rotationHandle&&geom._rotationHandle.destroy();geom._rotationHandle=null;}
+this.box.destroy();this.box=null;this.layer=null;this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.TransformFeature"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,formatSuffixMap:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png","png":"png","image/jpeg":"jpg","image/jpg":"jpg","jpeg":"jpg","jpg":"jpg"},matrix:null,initialize:function(config){var required={url:true,layer:true,style:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
 config.params=OpenLayers.Util.upperCaseObject(config.params);var args=[config.name,config.url,config.params,config];OpenLayers.Layer.Grid.prototype.initialize.apply(this,args);if(!this.formatSuffix){this.formatSuffix=this.formatSuffixMap[this.format]||this.format.split("/").pop();}
 if(this.matrixIds){var len=this.matrixIds.length;if(len&&typeof this.matrixIds[0]==="string"){var ids=this.matrixIds;this.matrixIds=new Array(len);for(var i=0;i<len;++i){this.matrixIds[i]={identifier:ids[i]};}}}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.updateMatrixProperties();},updateMatrixProperties:function(){this.matrix=this.getMatrix();if(this.matrix){if(this.matrix.topLeftCorner){this.tileOrigin=this.matrix.topLeftCorner;}
 if(this.matrix.tileWidth&&this.matrix.tileHeight){this.tileSize=new OpenLayers.Size(this.matrix.tileWidth,this.matrix.tileHeight);}
@@ -2009,17 +2032,36 @@
 path=path+this.matrixSet+"/"+this.matrix.identifier+"/"+info.row+"/"+info.col+"."+this.formatSuffix;if(this.url instanceof Array){url=this.selectUrl(path,this.url);}else{url=this.url;}
 if(!url.match(/\/$/)){url=url+"/";}
 url=url+path;}else if(this.requestEncoding.toUpperCase()==="KVP"){var params={SERVICE:"WMTS",REQUEST:"GetTile",VERSION:this.version,LAYER:this.layer,STYLE:this.style,TILEMATRIXSET:this.matrixSet,TILEMATRIX:this.matrix.identifier,TILEROW:info.row,TILECOL:info.col,FORMAT:this.format};url=OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,[params]);}}
-return url;},mergeNewParams:function(newParams){if(this.requestEncoding.toUpperCase()==="KVP"){return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(newParams)]);}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.WMTS"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,EVENT_TYPES:["featureadded"],multi:false,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){this.EVENT_TYPES=OpenLayers.Control.DrawFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.tr
 iggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
+return url;},mergeNewParams:function(newParams){if(this.requestEncoding.toUpperCase()==="KVP"){return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(newParams)]);}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.WMTS"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxCharacteristics:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(thi
 s.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.viewPortDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";this.zoomBox.style.left=xy.x<startX?xy.x+"px":startX+"px";this.zoomBox.style.top=xy.y<startY?xy.y+"px":startY+"px";var box=this.getBoxCharacteristics();if(box.newBoxModel){if(xy.x>startX){this.zoomBox.style.width=Math.max(1,deltaX-box.xOffset)+"px";}
+if(xy.y>startY){this.zoomBox.style.height=Math.max(1,deltaY-box.yOffset)+"px";}}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
+this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxCharacteristics=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},getBoxCharacteristics:function(){if(!this.boxCharacteristics){var xOffset=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"))+1;var yOffset=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"))+1;var newBoxModel=OpenLayers.BROWSER_NAME=="msie"?document.compatMode!="BackCompa
+return this.boxCharacteristics;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;
+var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:25,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
+this.kinetic=new OpenLayers.Kinetic(config);}
+this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
+this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
+this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
+this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,last:null,touch:false,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt;return true;};}},mousedown:null,touchstart:function(evt){this.touch=true;this.down=evt;this.last=null;return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
+return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
+return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}
+return!this.stopSingle;},dblclick:function(evt){if(this.passesTolerance(evt)&&(!evt.lastTouches||evt.lastTouches.length==1)){if(this["double"]){this.callback('dblclick',[evt]);}
+this.clearTimer();}
+return!this.stopDouble;},touchmove:function(evt){this.last=evt;},touchend:function(evt){var last=this.last||this.down;if(!evt||!last){return false;}
+evt.xy=last.xy;evt.lastTouches=last.touches;return evt.xy?this.click(evt):false;},click:function(evt){if(this.touch===true&&evt.type==="click"){return!this.stopSingle;}
+if(this.passesTolerance(evt)){if(this.timerId!=null){if(evt.lastTouches){this.dblclick(evt);}else{this.clearTimer();}}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
+return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){var dpx=Math.sqrt(Math.pow(this.down.xy.x-evt.xy.x,2)+
+Math.pow(this.down.xy.y-evt.xy.y,2));if(dpx>this.pixelTolerance){passes=false;}}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
+if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback('click',[evt]);}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.last=null;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
+this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
+this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
+var clickCallbacks={'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,EVENT_TYPES:["featureadded"]
 ,multi:false,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){this.EVENT_TYPES=OpenLayers.Control.DrawFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.triggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
 var sketchStyle=this.layer.styleMap&&this.layer.styleMap.styles.temporary;if(sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":sketchStyle})});}
-this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));var polygon;if(this.
 holeModifier&&(this.evt[this.holeModifier])){var geometry=this.point.geometry;var features=this.control.layer.features;var candidate;for(var i=features.length-1;i>=0;--i){candidate=features[i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([polygon],{silent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
-if(!polygon){this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));}
-this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
-if(modified){var target;outer:for(var i=rings.length-2;i>0;--i){var points=rings[i].components;for(var j=0,jj=points.length;j<jj;++j){if(ring.containsPoint(points[j])){modified=false;break outer;}}}}}
-if(modified){if(this.polygon.state!==OpenLayers.State.INSERT){this.polygon.state=OpenLayers.State.UPDATE;}}else{this.polygon.geometry.removeComponent(ring);}
-this.restoreFeature();return false;},cancel:function(){if(this.drawingHole){this.polygon.geometry.removeComponent(this.line.geometry);this.restoreFeature(true);}
-return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments);},restoreFeature:function(cancel){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:true});this.control.layer.addFeatures([this.polygon],{silent:true});this.drawingHole=false;if(!cancel){this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon});}},destroyFeature:function(){OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);this.polygon=null;},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.polygon;},getGeometry:function(){var geometry=this.polygon&&this.polygon.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPolygon([geometry]);}
-return geometry;},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:false,initialize:function(options){OpenLayer
 s.Format.JSON.prototype.initialize.apply(this,[options]);},read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
+this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.
 Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:false,initialize:function(options){OpenLayers.Format.JSON.prototype.initialize.apply(this,[options]);},read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
 if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
 break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
 break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
@@ -2109,7 +2151,17 @@
 if(inMap){var delta=0;if(!e){e=window.event;}
 if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
 if(delta){e.xy=this.mousePosition;if(delta<0){this.defaultWheelDown(e);}else{this.defaultWheelUp(e);}}
-OpenLayers.Event.stop(e);}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",ows:"http://www.opengis.net/ows"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(
 this,[data]);}
+OpenLayers.Event.stop(e);}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoombarDiv:null,divEvents:null,zoomWorldIcon:false,forceFixedZoomLevel:false,mouseDragStart:null,deltaY:null,zoomStart:null,initialize:function(){OpenLayers.Control.PanZoom.prototype.initialize.apply(this,arguments);},destroy:function(){this._removeZoomBar();this.map.events.un({"changebaselayer":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);delete this.mouseDragStart;delete this.zoomStart;},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.register("changebaselayer",this,this.redraw);},redraw:function(){if(this.div!=null){this.removeButtons();this._removeZoomBar();}
+this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
+this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
+this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImagesLocation();var id=this.id+"_"+this.map.id;var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),new OpenLayers.Size(20,9),imgLocation+"slider.png","absolute");slider.style.cursor="move";this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true,{includeXY:true});this.sliderEvents.on({"touchstart":this.zoomBarDown,"touchmove":this.zoomBarDrag,"touchend":this.zoomBarUp,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.z
 oomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});var sz=new OpenLayers.Size();sz.h=this.zoomStopHeight*this.map.getNumZoomLevels();sz.w=this.zoomStopWidth;var div=null;if(OpenLayers.Util.alphaHack()){var id=this.id+"_"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,new OpenLayers.Size(sz.w,this.zoomStopHeight),imgLocation+"zoombar.png","absolute",null,"crop");div.style.height=sz.h+"px";}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation+"zoombar.png");}
+div.style.cursor="pointer";this.zoombarDiv=div;this.divEvents=new OpenLayers.Events(this,div,null,true,{includeXY:true});this.divEvents.on({"touchmove":this.passEventToSlider,"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*this.map.getNumZoomLevels());return centered;},_removeZoomBar:function(){this.sliderEvents.un({"touchmove":this.zoomBarDrag,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});this.sliderEvents.destroy();this.divEvents.un({"touchmove":this.passEventToSlider,"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.divEvents.destroy();this.div.removeChi
 ld(this.zoombarDiv);this.zoombarDiv=null;this.div.removeChild(this.slider);this.slider=null;this.map.events.unregister("zoomend",this,this.moveZoomBar);},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},divClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+var levels=evt.xy.y/this.zoomStopHeight;if(this.forceFixedZoomLevel||!this.map.fractionalZoom){levels=Math.floor(levels);}
+var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);OpenLayers.Event.stop(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&!OpenLayers.Event.isSingleTouch(evt)){return;}
+this.map.events.on({"touchmove":this.passEventToSlider,"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";this.mouseDragStart=evt.xy.clone();}
+this.deltaY=this.zoomStart.y-evt.xy.y;OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&evt.type!=="touchend"){return;}
+if(this.mouseDragStart){this.div.style.cursor="";this.map.events.un({"touchmove":this.passEventToSlider,"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var zoomLevel=this.map.zoom;if(!this.forceFixedZoomLevel&&this.map.fractionalZoom){zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.max(Math.round(zoomLevel),0);}
+this.map.zoomTo(zoomLevel);this.mouseDragStart=null;this.zoomStart=null;this.deltaY=0;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",ows:"http://www.opengis.net/ows"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpac
 e:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
 var obj={};this.readNode(data,obj);return obj;},readers:{"csw":{"GetRecordsResponse":function(node,obj){obj.records=[];this.readChildNodes(node,obj);var version=this.getAttributeNS(node,"",'version');if(version!=""){obj.version=version;}},"RequestId":function(node,obj){obj.RequestId=this.getChildValue(node);},"SearchStatus":function(node,obj){obj.SearchStatus={};var timestamp=this.getAttributeNS(node,"",'timestamp');if(timestamp!=""){obj.SearchStatus.timestamp=timestamp;}},"SearchResults":function(node,obj){this.readChildNodes(node,obj);var attrs=node.attributes;var SearchResults={};for(var i=0,len=attrs.length;i<len;++i){if((attrs[i].name=="numberOfRecordsMatched")||(attrs[i].name=="numberOfRecordsReturned")||(attrs[i].name=="nextRecord")){SearchResults[attrs[i].name]=parseInt(attrs[i].nodeValue);}else{SearchResults[attrs[i].name]=attrs[i].nodeValue;}}
 obj.SearchResults=SearchResults;},"SummaryRecord":function(node,obj){var record={type:"SummaryRecord"};this.readChildNodes(node,record);obj.records.push(record);},"BriefRecord":function(node,obj){var record={type:"BriefRecord"};this.readChildNodes(node,record);obj.records.push(record);},"DCMIRecord":function(node,obj){var record={type:"DCMIRecord"};this.readChildNodes(node,record);obj.records.push(record);},"Record":function(node,obj){var record={type:"Record"};this.readChildNodes(node,record);obj.records.push(record);}},"dc":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(obj[name]instanceof Array)){obj[name]=new Array();}
@@ -2140,30 +2192,29 @@
 this.addMarker(marker);}
 this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
 if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Format.WMSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.1",version:null,profile:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;var profile=this.profile?"_"+this.profile:"";if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.WMSCapabilities["v"+version.replace(/\./g,"_")+profile];if(!constr){throw"Can't find a WMS capabilities parser for version "+
-version+profile;}
-this.parser=new constr(this.options);}
-var capabilities=this.parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.WMSCapabilities"});OpenLayers.Format.WMSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{wms:"http://www.opengis.net/wms",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"wms",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var capabilities={};this.readNode(data,capabilities);this.postProcessLayers(capabilities);return capabilities;},postProcessLayers:function(capabilities){if(capabilities.capability){capabilities.capability.layers=[];var layers=capabilities.capability.nestedLayers;for(var i=0,len=layers.length;i<len;++i){var layer=layers[i];this.processLayer(capabilities.capability,layer);}}},processLayer:function(capability,layer,parentLayer){if(layer.formats===undefined){layer.formats=capability.request.getmap.formats;}
-if(parentLayer){layer.styles=layer.styles.concat(parentLayer.styles);var attributes=["queryable","cascaded","fixedWidth","fixedHeight","opaque","noSubsets","llbbox","minScale","maxScale","attribution"];var complexAttr=["srs","bbox","dimensions","authorityURLs"];var key;for(var j=0;j<attributes.length;j++){key=attributes[j];if(key in parentLayer){if(layer[key]==null){layer[key]=parentLayer[key];}
-if(layer[key]==null){var intAttr=["cascaded","fixedWidth","fixedHeight"];var boolAttr=["queryable","opaque","noSubsets"];if(OpenLayers.Util.indexOf(intAttr,key)!=-1){layer[key]=0;}
-if(OpenLayers.Util.indexOf(boolAttr,key)!=-1){layer[key]=false;}}}}
-for(var j=0;j<complexAttr.length;j++){key=complexAttr[j];layer[key]=OpenLayers.Util.extend(layer[key],parentLayer[key]);}}
-for(var i=0,len=layer.nestedLayers.length;i<len;i++){var childLayer=layer.nestedLayers[i];this.processLayer(capability,childLayer,layer);}
-if(layer.name){capability.layers.push(layer);}},readers:{"wms":{"Service":function(node,obj){obj.service={};this.readChildNodes(node,obj.service);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj["abstract"]=this.getChildValue(node);},"BoundingBox":function(node,obj){var bbox={};bbox.bbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];var res={x:parseFloat(node.getAttribute("resx")),y:parseFloat(node.getAttribute("resy"))};if(!(isNaN(res.x)&&isNaN(res.y))){bbox.res=res;}
-return bbox;},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ContactInformation":function(node,obj){obj.contactInformation={};this.readChildNodes(node,obj.contactInformation);},"ContactPersonPrimary":function(node,obj){obj.personPrimary={};this.readChildNodes(node,obj.personPrimary);},"ContactPerson":function(node,obj){obj.person=this.getChildValue(node);},"ContactOrganization":function(node,obj){obj.organization=this.getChildValue(node);},"ContactPosition":function(node,obj){obj.position=this.getChildValue(node);},"ContactAddress":function(node,obj){obj.contactAddress={};this.readChildNodes(node,obj.contactAddress);},"AddressType":function(node,obj){obj.type=this.getChildValue(node);},"Address":function(node,obj){obj.address=this.getChildValue(node);},"City":function(node,obj){obj.city=this.getChildValue(node);},"StateOrProvince":function(node,obj){obj.stateOrProvince=this.getChildValue(node);},"PostCode":function(node
 ,obj){obj.postcode=this.getChildValue(node);},"Country":function(node,obj){obj.country=this.getChildValue(node);},"ContactVoiceTelephone":function(node,obj){obj.phone=this.getChildValue(node);},"ContactFacsimileTelephone":function(node,obj){obj.fax=this.getChildValue(node);},"ContactElectronicMailAddress":function(node,obj){obj.email=this.getChildValue(node);},"Fees":function(node,obj){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){obj.fees=fees;}},"AccessConstraints":function(node,obj){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){obj.accessConstraints=constraints;}},"Capability":function(node,obj){obj.capability={nestedLayers:[]};this.readChildNodes(node,obj.capability);},"Request":function(node,obj){obj.request={};this.readChildNodes(node,obj.request);},"GetCapabilities":function(node,obj){obj.getcapabilities={formats:[]};this.readChildNodes(node,obj.getcapabilities);},"Format":function(node,obj){if(obj
 .formats instanceof Array){obj.formats.push(this.getChildValue(node));}else{obj.format=this.getChildValue(node);}},"DCPType":function(node,obj){this.readChildNodes(node,obj);},"HTTP":function(node,obj){this.readChildNodes(node,obj);},"Get":function(node,obj){this.readChildNodes(node,obj);},"Post":function(node,obj){this.readChildNodes(node,obj);},"GetMap":function(node,obj){obj.getmap={formats:[]};this.readChildNodes(node,obj.getmap);},"GetFeatureInfo":function(node,obj){obj.getfeatureinfo={formats:[]};this.readChildNodes(node,obj.getfeatureinfo);},"Exception":function(node,obj){obj.exception={formats:[]};this.readChildNodes(node,obj.exception);},"Layer":function(node,obj){var attrNode=node.getAttributeNode("queryable");var queryable=(attrNode&&attrNode.specified)?node.getAttribute("queryable"):null;attrNode=node.getAttributeNode("cascaded");var cascaded=(attrNode&&attrNode.specified)?node.getAttribute("cascaded"):null;attrNode=node.getAttributeNode("opaque");var opaque=(att
 rNode&&attrNode.specified)?node.getAttribute('opaque'):null;var noSubsets=node.getAttribute('noSubsets');var fixedWidth=node.getAttribute('fixedWidth');var fixedHeight=node.getAttribute('fixedHeight');var layer={nestedLayers:[],styles:[],srs:{},metadataURLs:[],bbox:{},dimensions:{},authorityURLs:{},identifiers:{},keywords:[],queryable:(queryable&&queryable!=="")?(queryable==="1"||queryable==="true"):null,cascaded:(cascaded!==null)?parseInt(cascaded):null,opaque:opaque?(opaque==="1"||opaque==="true"):null,noSubsets:(noSubsets!==null)?(noSubsets==="1"||noSubsets==="true"):null,fixedWidth:(fixedWidth!=null)?parseInt(fixedWidth):null,fixedHeight:(fixedHeight!=null)?parseInt(fixedHeight):null};obj.nestedLayers.push(layer);this.readChildNodes(node,layer);if(layer.name){var parts=layer.name.split(":");if(parts.length>0){layer.prefix=parts[0];}}},"Attribution":function(node,obj){obj.attribution={};this.readChildNodes(node,obj.attribution);},"LogoURL":function(node,obj){obj.logo={wid
 th:node.getAttribute("width"),height:node.getAttribute("height")};this.readChildNodes(node,obj.logo);},"Style":function(node,obj){var style={};obj.styles.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={width:node.getAttribute("width"),height:node.getAttribute("height")};obj.legend=legend;this.readChildNodes(node,legend);},"MetadataURL":function(node,obj){var metadataURL={type:node.getAttribute("type")};obj.metadataURLs.push(metadataURL);this.readChildNodes(node,metadataURL);},"DataURL":function(node,obj){obj.dataURL={};this.readChildNodes(node,obj.dataURL);},"FeatureListURL":function(node,obj){obj.featureListURL={};this.readChildNodes(node,obj.featureListURL);},"AuthorityURL":function(node,obj){var name=node.getAttribute("name");var authority={};this.readChildNodes(node,authority);obj.authorityURLs[name]=authority.href;},"Identifier":function(node,obj){var authority=node.getAttribute("authority");obj.identifiers[authority]=this.getChi
 ldValue(node);},"KeywordList":function(node,obj){this.readChildNodes(node,obj);},"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1"});OpenLayers.Format.WMSCapabilities.v1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMT_MS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Keyword":function(node,obj){if(obj.keywords){obj.keywords.push(this.getChildValue(node));}},"DescribeLayer":function(node,obj){obj.describelayer={formats:[]};this.readChildNodes(node,obj.describelayer);},"GetLegendGraphic":function(node,obj){obj.getlegendgraphic={formats:[]};this.readChildNodes(node,obj.getlegendgraphic);},"GetStyles":function(node,obj){obj.getstyles={formats:[]};this.readChildNodes(node,obj.getstyles);},"PutStyles":function(node,obj){obj.putstyles={formats:[]};this.readChildNodes(node,obj.putstyles);},"UserDefinedSymbolization":function(node,obj){var
  userSymbols={supportSLD:parseInt(node.getAttribute("SupportSLD"))==1,userLayer:parseInt(node.getAttribute("UserLayer"))==1,userStyle:parseInt(node.getAttribute("UserStyle"))==1,remoteWFS:parseInt(node.getAttribute("RemoteWFS"))==1};obj.userSymbols=userSymbols;},"LatLonBoundingBox":function(node,obj){obj.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("SRS");obj.bbox[bbox.srs]=bbox;},"ScaleHint":function(node,obj){var min=node.getAttribute("min");var max=node.getAttribute("max");var rad2=Math.pow(2,0.5);var ipm=OpenLayers.INCHES_PER_UNIT["m"];obj.maxScale=parseFloat(((min/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecision(13));obj.minScale=parseFloat(((max/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecisio
 n(13));},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol")};obj.dimensions[dim.name]=dim;},"Extent":function(node,obj){var name=node.getAttribute("name").toLowerCase();if(name in obj["dimensions"]){var extent=obj.dimensions[name];extent.nearestVal=node.getAttribute("nearestValue")==="1";extent.multipleVal=node.getAttribute("multipleValues")==="1";extent.current=node.getAttribute("current")==="1";extent["default"]=node.getAttribute("default")||"";var values=this.getChildValue(node);extent.values=values.split(",");}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,geodesic:false,initialize:function(element,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getEle
 ment(element);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("div");this.div.appendChild(this.element);}
+OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Control.SLDSelect=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["selected"],clearOnDeactivate:false,layers:null,callbacks:null,selectionSymbolizer:{'Polygon':{fillColor:'#FF0000',stroke:false},'Line':{strokeColor:'#FF0000',strokeWidth:2},'Point':{graphicName:'square',fillColor:'#FF0000',pointRadius:5}},layerOptions:null,handlerOptions:null,sketchStyle:null,wfsCache:{},layerCache:{},initialize:function(handler,options){this.EVENT_TYPES=OpenLayers.Control.SLDSelect.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.select,click:this.select},this.callbacks);this.handlerOptions=this.handlerOpti
 ons||{};this.layerOptions=OpenLayers.Util.applyDefaults(this.layerOptions,{displayInLayerSwitcher:false,tileOptions:{maxGetUrlLength:2048}});if(this.sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":this.sketchStyle})});}
+this.handler=new handler(this,this.callbacks,this.handlerOptions);},destroy:function(){for(var key in this.layerCache){delete this.layerCache[key];}
+for(var key in this.wfsCache){delete this.wfsCache[key];}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);},coupleLayerVisiblity:function(evt){this.setVisibility(evt.object.getVisibility());},createSelectionLayer:function(source){var selectionLayer;if(!this.layerCache[source.id]){selectionLayer=new OpenLayers.Layer.WMS(source.name,source.url,source.params,OpenLayers.Util.applyDefaults(this.layerOptions,source.getOptions()));this.layerCache[source.id]=selectionLayer;if(this.layerOptions.displayInLayerSwitcher===false){source.events.on({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});}
+this.map.addLayer(selectionLayer);}else{selectionLayer=this.layerCache[source.id];}
+return selectionLayer;},createSLD:function(layer,filters,geometryAttributes){var sld={version:"1.0.0",namedLayers:{}};var layerNames=[layer.params.LAYERS].join(",").split(",");for(var i=0,len=layerNames.length;i<len;i++){var name=layerNames[i];sld.namedLayers[name]={name:name,userStyles:[]};var symbolizer=this.selectionSymbolizer;var geometryAttribute=geometryAttributes[i];if(geometryAttribute.type.indexOf('Polygon')>=0){symbolizer={Polygon:this.selectionSymbolizer['Polygon']};}else if(geometryAttribute.type.indexOf('LineString')>=0){symbolizer={Line:this.selectionSymbolizer['Line']};}else if(geometryAttribute.type.indexOf('Point')>=0){symbolizer={Point:this.selectionSymbolizer['Point']};}
+var filter=filters[i];sld.namedLayers[name].userStyles.push({name:'default',rules:[new OpenLayers.Rule({symbolizer:symbolizer,filter:filter,maxScaleDenominator:layer.options.minScale})]});}
+return new OpenLayers.Format.SLD().write(sld);},parseDescribeLayer:function(request){var format=new OpenLayers.Format.WMSDescribeLayer();var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+var describeLayer=format.read(doc);var typeNames=[];var url=null;for(var i=0,len=describeLayer.length;i<len;i++){if(describeLayer[i].owsType=="WFS"){typeNames.push(describeLayer[i].typeName);url=describeLayer[i].owsURL;}}
+var options={url:url,params:{SERVICE:"WFS",TYPENAME:typeNames.toString(),REQUEST:"DescribeFeatureType",VERSION:"1.0.0"},callback:function(request){var format=new OpenLayers.Format.WFSDescribeFeatureType();var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+var describeFeatureType=format.read(doc);this.control.wfsCache[this.layer.id]=describeFeatureType;this.control._queue&&this.control.applySelection();},scope:this};OpenLayers.Request.GET(options);},getGeometryAttributes:function(layer){var result=[];var cache=this.wfsCache[layer.id];for(var i=0,len=cache.featureTypes.length;i<len;i++){var typeName=cache.featureTypes[i];var properties=typeName.properties;for(var j=0,lenj=properties.length;j<lenj;j++){var property=properties[j];var type=property.type;if((type.indexOf('LineString')>=0)||(type.indexOf('GeometryAssociationType')>=0)||(type.indexOf('GeometryPropertyType')>=0)||(type.indexOf('Point')>=0)||(type.indexOf('Polygon')>=0)){result.push(property);}}}
+return result;},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer&&!this.wfsCache[layer.id]){var options={url:layer.url,params:{SERVICE:"WMS",VERSION:layer.params.VERSION,LAYERS:layer.params.LAYERS,REQUEST:"DescribeLayer"},callback:this.parseDescribeLayer,scope:{layer:layer,control:this}};OpenLayers.Request.GET(options);}}}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer&&this.clearOnDeactivate===true){var layerCache=this.layerCache;var selectionLayer=layerCache[layer.id];if(selectionLayer){layer.events.un({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});selectionLayer.destroy();delete layerCache[layer.id];}}}}
+return deactivated;},setLayers:function(layers){if(this.active){this.deactivate();this.layers=layers;this.activate();}else{this.layers=layers;}},createFilter:function(geometryAttribute,geometry){var filter=null;if(this.handler instanceof OpenLayers.Handler.RegularPolygon){if(this.handler.irregular===true){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:geometryAttribute.name,value:geometry.getBounds()});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}}else if(this.handler instanceof OpenLayers.Handler.Polygon){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}else if(this.handler instanceof OpenLayers.Handler.Path){if(geometryAttribute.type.indexOf('Point')>=0){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:geometryAttribute.name,distanc
 e:this.map.getExtent().getWidth()*0.01,distanceUnits:this.map.getUnits(),value:geometry});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}}else if(this.handler instanceof OpenLayers.Handler.Click){if(geometryAttribute.type.indexOf('Polygon')>=0){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:geometryAttribute.name,distance:this.map.getExtent().getWidth()*0.01,distanceUnits:this.map.getUnits(),value:geometry});}}
+return filter;},select:function(geometry){this._queue=function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];var geometryAttributes=this.getGeometryAttributes(layer);var filters=[];for(var j=0,lenj=geometryAttributes.length;j<lenj;j++){var geometryAttribute=geometryAttributes[j];if(geometryAttribute!==null){if(!(geometry instanceof OpenLayers.Geometry)){var point=this.map.getLonLatFromPixel(geometry.xy);geometry=new OpenLayers.Geometry.Point(point.lon,point.lat);}
+var filter=this.createFilter(geometryAttribute,geometry);if(filter!==null){filters.push(filter);}}}
+var selectionLayer=this.createSelectionLayer(layer);var sld=this.createSLD(layer,filters,geometryAttributes);this.events.triggerEvent("selected",{layer:layer,filters:filters});selectionLayer.mergeNewParams({SLD_BODY:sld});delete this._queue;}};this.applySelection();},applySelection:function(){var canApply=true;for(var i=0,len=this.layers.length;i<len;i++){if(!this.wfsCache[this.layers[i].id]){canApply=false;break;}}
+canApply&&this._queue.call(this);},CLASS_NAME:"OpenLayers.Control.SLDSelect"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,geodesic:false,initialize:function(element,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("div");this.div.appendChild(this.element);}
 this.map.events.register('moveend',this,this.updateScale);this.updateScale();return this.div;},updateScale:function(){var scale;if(this.geodesic===true){var units=this.map.getUnits();if(!units){return;}
 var inches=OpenLayers.INCHES_PER_UNIT;scale=(this.map.getGeodesicPixelSize().w||0.000001)*inches["km"]*OpenLayers.DOTS_PER_INCH;}else{scale=this.map.getScale();}
 if(!scale){return;}
 if(scale>=9500&&scale<=950000){scale=Math.round(scale/1000)+"K";}else if(scale>=950000){scale=Math.round(scale/1000000)+"M";}else{scale=Math.round(scale);}
-this.element.innerHTML=OpenLayers.i18n("scale",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Protocol.SOS=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.SOS.DEFAULTS);var cls=OpenLayers.Protocol.SOS["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported SOS version: "+options.version;}
-return new cls(options);};OpenLayers.Protocol.SOS.DEFAULTS={"version":"1.0.0"};OpenLayers.Protocol.SOS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol,{fois:null,formatOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.format){this.format=new OpenLayers.Format.SOSGetFeatureOfInterest(this.formatOptions);}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
-this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var format=this.format;var data=OpenLayers.Format.XML.prototype.write.apply(format,[format.writeNode("sos:GetFeatureOfInterest",{fois:this.fois})]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),data:data});return response;},handleRead:function(response,options){if(options.callback){var request=response.priv;if(request.status>=200&&request.status<300){response.features=this.parseFeatures(request);response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
-options.callback.call(options.scope,response);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-if(!doc||doc.length<=0){return null;}
-return this.format.read(doc);},CLASS_NAME:"OpenLayers.Protocol.SOS.v1_0_0"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,useHttpTile:false,singleTile:false,useOverlay:false,useAsyncOverlay:true,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},OVERLAY_PARAMS:{operation:'GETDYNAMICMAPOVERLAYIMAGE',format:'PNG',locale:'en',clip:'1',version:'2.0.0'},FOLDER_PARAMS:{tileColumnsPerFolder:30,tileRowsPerFolder:30,format:'png',querystring:null},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.t
 ransparent!=true));}
+this.element.innerHTML=OpenLayers.i18n("scale",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,useHttpTile:false,singleTile:false,useOverlay:false,useAsyncOverlay:true,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},OVERLAY_PARAMS:{operation:'GETDYNAMICMAPOVERLAYIMAGE',format:'PNG',locale:'en',clip:'1',version:'2.0.0'},FOLDER_PARAMS:{tileColumnsPerFolder:30,tileRowsPerFolder:30,format:'png',querystring:null},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((
 this.transparent!="true")&&(this.transparent!=true));}
 if(options&&options.useOverlay!=null){this.useOverlay=options.useOverlay;}
 if(this.singleTile){if(this.useOverlay){OpenLayers.Util.applyDefaults(this.params,this.OVERLAY_PARAMS);if(!this.useAsyncOverlay){this.params.version="1.0.0";}}else{OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}}else{if(this.useHttpTile){OpenLayers.Util.applyDefaults(this.params,this.FOLDER_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);}
 this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.getOptions());}
@@ -2201,27 +2252,44 @@
 this.imgDiv.viewRequestID=this.layer.map.viewRequestID;}else{OpenLayers.Tile.Image.prototype.initImgDiv.apply(this,arguments);}},createIFrame:function(){var id=this.id+'_iFrame';var iframe;if(OpenLayers.BROWSER_NAME=="msie"){iframe=document.createElement('<iframe name="'+id+'">');iframe.style.backgroundColor='#FFFFFF';iframe.style.filter='chroma(color=#FFFFFF)';}
 else{iframe=document.createElement('iframe');iframe.style.backgroundColor='transparent';iframe.name=id;}
 iframe.id=id;iframe.scrolling='no';iframe.marginWidth='0px';iframe.marginHeight='0px';iframe.frameBorder='0';OpenLayers.Util.modifyDOMElement(iframe,id,new OpenLayers.Pixel(0,0),this.layer.getImageSize(),"absolute");var onload=function(){this.show();if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};OpenLayers.Event.observe(iframe,'load',OpenLayers.Function.bind(onload,this));return iframe;},createRequestForm:function(){var form=document.createElement('form');form.method='POST';var cacheId=this.layer.params["_OLSALT"];cacheId=(cacheId?cacheId+"_":"")+this.bounds.toBBOX();form.action=OpenLayers.Util.urlAppend(this.layer.url,cacheId);this.imgDiv.insertBefore(this.createIFrame(),this.imgDiv.firstChild);form.target=this.id+'_iFrame';var imageSize=this.layer.getImageSize();var params=OpenLayers.Util.getParameters(this.url);for(var par in params){var field=document.createElement('input');field.type='hidden';field.name=par;field.value=params[par];form.ap
 pendChild(field);}
-return form;}};OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.prototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();thi
 s.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
+return form;}};OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:false,interval:0,timer:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.layer.visibility===true){this.start();}
+this.layer.events.on({"visibilitychanged":this.reset,scope:this});}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.stop();}
+return deactivated;},reset:function(){if(this.layer.visibility===true){this.start();}else{this.stop();}},start:function(){if(this.interval&&typeof this.interval==="number"&&this.interval>0){this.timer=window.setInterval(OpenLayers.Function.bind(this.refresh,this),this.interval);}},refresh:function(){if(this.layer&&this.layer.refresh&&typeof this.layer.refresh=="function"){this.layer.refresh({force:this.force});}},stop:function(){if(this.timer!==null){window.clearInterval(this.timer);this.timer=null;}},CLASS_NAME:"OpenLayers.Strategy.Refresh"});OpenLayers.Format.SOSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.SOSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw"Can't find a SOS capabilities parser for version "+version;}
+var parser=new constr(this.options);}
+var capabilities=parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.SOSCapabilities"});OpenLayers.Format.SOSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.SOSCapabilities,{namespaces:{ows:"http://www.opengis.net/ows/1.1",sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var capabilities={};this.readNode(data,capabilities);return capabilities;},readers:{"gml":OpenLayers.Util.applyDefaults({"name":function(node,obj){obj.name=this.getChildValue(node);},"TimePeriod":function(node,obj){obj.timePeriod={};this.readChildNodes(node,obj.timePeriod);},"beginPosition":function(node,timePeriod){timePeriod.beginPosition=this.getChildValue(node);},"endPosition":function(node,timePeriod){timePeriod.endPosition=this.getChildValue(node);}},OpenLayers.Format.GML.v3.prototype.readers["gml"]),"sos":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};this.readChildNodes(node,obj.contents);},"ObservationOfferingList":function(node,contents){contents.offeringList={};this.readChildNodes(node,contents.offeringList);},"ObservationOffering":function(node,offeringList){var id=this.getAttributeNS(node,this.namespaces.gml,"id");offeringList[id]={procedures:[],observedProperties:[],featureOfInterestIds:[],respon
 seFormats:[],resultModels:[],responseModes:[]};this.readChildNodes(node,offeringList[id]);},"time":function(node,offering){offering.time={};this.readChildNodes(node,offering.time);},"procedure":function(node,offering){offering.procedures.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"observedProperty":function(node,offering){offering.observedProperties.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"featureOfInterest":function(node,offering){offering.featureOfInterestIds.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"responseFormat":function(node,offering){offering.responseFormats.push(this.getChildValue(node));},"resultModel":function(node,offering){offering.resultModels.push(this.getChildValue(node));},"responseMode":function(node,offering){offering.responseModes.push(this.getChildValue(node));;}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.SOSCapabilities.v1_0_0"});OpenL
 ayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Format.WFSDescribeFeatureType=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xsd:"http://www.w3.org/2001/XMLSchema"},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},readers:{"xsd":{"schema":function(node,obj){var complexTypes=[];var customTypes={};var schema={complexTypes:complexTypes,customTypes:customTypes};this.readChildNodes(node,schema);var attributes=node.attributes;var attr,name;for(var i=0,len=attributes.length;i<len;++i){attr=attributes[i];name=attr.name;if(name.indexOf("x
 mlns")==0){this.setNamespace(name.split(":")[1]||"",attr.value);}else{obj[name]=attr.value;}}
+obj.featureTypes=complexTypes;obj.targetPrefix=this.namespaceAlias[obj.targetNamespace];var complexType,customType;for(var i=0,len=complexTypes.length;i<len;++i){complexType=complexTypes[i];customType=customTypes[complexType.typeName];if(customTypes[complexType.typeName]){complexType.typeName=customType.name;}}},"complexType":function(node,obj){var complexType={"typeName":node.getAttribute("name")};this.readChildNodes(node,complexType);obj.complexTypes.push(complexType);},"complexContent":function(node,obj){this.readChildNodes(node,obj);},"extension":function(node,obj){this.readChildNodes(node,obj);},"sequence":function(node,obj){var sequence={elements:[]};this.readChildNodes(node,sequence);obj.properties=sequence.elements;},"element":function(node,obj){if(obj.elements){var element={};var attributes=node.attributes;var attr;for(var i=0,len=attributes.length;i<len;++i){attr=attributes[i];element[attr.name]=attr.value;}
+var type=element.type;if(!type){type={};this.readChildNodes(node,type);element.restriction=type;element.type=type.base;}
+var fullType=type.base||type;element.localType=fullType.split(":").pop();obj.elements.push(element);}
+if(obj.complexTypes){var type=node.getAttribute("type");var localType=type.split(":").pop();obj.customTypes[localType]={"name":node.getAttribute("name"),"type":type};}},"simpleType":function(node,obj){this.readChildNodes(node,obj);},"restriction":function(node,obj){obj.base=node.getAttribute("base");this.readRestriction(node,obj);}}},readRestriction:function(node,obj){var children=node.childNodes;var child,nodeName,value;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){nodeName=child.nodeName.split(":").pop();value=child.getAttribute("value");if(!obj[nodeName]){obj[nodeName]=value;}else{if(typeof obj[nodeName]=="string"){obj[nodeName]=[obj[nodeName]];}
+obj[nodeName].push(value);}}}},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var schema={};this.readNode(data,schema);return schema;},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.prototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();this.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
 this.loadFeaturesForRegion(this.requestSuccess);}},loadFeaturesForRegion:function(success,failure){if(this.request){this.request.abort();}
 this.request=OpenLayers.Request.GET({url:this.url,success:success,failure:failure,scope:this});},requestSuccess:function(request){if(this.features){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
 if(this.layer.vectorMode){this.layer.addFeatures(this.layer.formatObject.read(doc));}else{var xml=new OpenLayers.Format.XML();if(typeof doc=="string"){doc=xml.read(doc);}
 var resultFeatures=xml.getElementsByTagNameNS(doc,"http://www.opengis.net/gml","featureMember");this.addResults(resultFeatures);}}
 if(this.events){this.events.triggerEvent("loadend");}
-this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Format.SOSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.SOSCapabilities,{namespaces:{ows:"http://www.opengis.net/ows/1.1",sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var capabilities={};this.readNode(data,capabilities);return capabilities;},readers:{"gml":OpenLayers.Util.applyDefaults({"name":function(node,obj){obj.name=this.getChildValue(node);},"TimePeriod":function(node,obj){obj.timePeriod={};this.readChildNodes(node,obj.timePeriod);},"beginPosition":function(node,timePeriod){timePeriod.beginPosition=this.getChildValue(node);},"endPosition":function(node,timePeriod){timePeriod.endPosition=this.getChildValue(node);}},OpenLayers.Format.GML.v3.prototype.readers["gml"]),"sos":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};this.readChildNodes(node,obj.contents);},"ObservationOfferingList":function(node,contents){contents.offeringList={};this.readChildNodes(node,contents.offeringList);},"ObservationOffering":function(node,offeringList){var id=this.getAttributeNS(node,this.namespaces.gml,"id");offeringList[id]={procedures:[],observedProperties:[],featureOfInterestIds:[],respon
 ayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:false,interval:0,timer:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.layer.visibility===true){this.start();}
-this.layer.events.on({"visibilitychanged":this.reset,scope:this});}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.stop();}
-return deactivated;},reset:function(){if(this.layer.visibility===true){this.start();}else{this.stop();}},start:function(){if(this.interval&&typeof this.interval==="number"&&this.interval>0){this.timer=window.setInterval(OpenLayers.Function.bind(this.refresh,this),this.interval);}},refresh:function(){if(this.layer&&this.layer.refresh&&typeof this.layer.refresh=="function"){this.layer.refresh({force:this.force});}},stop:function(){if(this.timer!==null){window.clearInterval(this.timer);this.timer=null;}},CLASS_NAME:"OpenLayers.Strategy.Refresh"});OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["locationupdated","locationfailed","locationuncapable"],geolocation:navigator.geolocation,bind:true,watch:false,options:null,initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.Geolocate.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);},activate:function(){if(!t
 his.geolocation){this.events.triggerEvent("locationuncapable");return false;}
-var options=this.options||{};if(!this.active){if(this.watch){this.watchId=this.geolocation.watchPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),options);}else{this.geolocation.getCurrentPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),options);}}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active&&this.watchId!==null){this.geolocation.clearWatch(this.watchId);}
+this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["locationupdated","locationfailed","locationuncapable"],geolocation:navigator.geolocation,bind:true,watch:false,options:null,initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.Geolocate.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);},activate:function(){if(!this.geolocation){this.events.triggerEvent("locationuncapable");return false;}
+if(OpenLayers.Control.prototype.activate.apply(this,arguments)){if(this.watch){this.watchId=this.geolocation.watchPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),options);}else{this.getCurrentLocation();}
+return true;}
+return false;},deactivate:function(){if(this.active&&this.watchId!==null){this.geolocation.clearWatch(this.watchId);}
 return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},geolocate:function(position){var center=new OpenLayers.LonLat(position.coords.longitude,position.coords.latitude).transform(new OpenLayers.Projection("EPSG:4326"),this.map.getProjectionObject());if(this.bind){map.setCenter(center);}
-this.events.triggerEvent("locationupdated",{position:position,point:new OpenLayers.Geometry.Point(center.lon,center.lat)});},failure:function(error){this.events.triggerEvent("locationfailed",{error:error});},CLASS_NAME:"OpenLayers.Control.Geolocate"});OpenLayers.Layer.ArcGIS93Rest=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{format:"png"},isBaseLayer:true,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
+this.events.triggerEvent("locationupdated",{position:position,point:new OpenLayers.Geometry.Point(center.lon,center.lat)});},getCurrentLocation:function(){if(!this.active||this.watch){return false;}
+this.geolocation.getCurrentPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);return true;},failure:function(error){this.events.triggerEvent("locationfailed",{error:error});},CLASS_NAME:"OpenLayers.Control.Geolocate"});OpenLayers.Layer.ArcGIS93Rest=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{format:"png"},isBaseLayer:true,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
 if(this.params.FORMAT=="jpg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"gif":"png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcGIS93Rest(this.name,this.url,this.params,this.getOptions());}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var projWords=this.projection.getCode().split(":");var srid=projWords[projWords.length-1];var imageSize=this.getImageSize();var newParams={'BBOX':bounds.toBBOX(),'SIZE':imageSize.w+","+imageSize.h,'F':"image",'BBOXSR':srid,'IMAGESR':srid};if(this.layerDefs){var layerDefStrList=[];var layerID;for(layerID in this.layerDefs){if(this.layerDefs.hasOwnProperty(layerID)){if(this.layerDefs[layerID]){layerDefStrList.push(layerID);layerDefStrList.push(":");layerDefStrList.push(this.layerDefs[layerID]);layerDefStrList.push(";");}}}
 if(layerDefStrList.length>0){newParams['LAYERDEFS']=layerDefStrList.join("");}}
 var requestString=this.getFullRequestString(newParams);return requestString;},setLayerFilter:function(id,queryDef){if(!this.layerDefs){this.layerDefs={};}
-if(queryDef){this.layerDefs[id]=queryDef;}else{delete this.layerDefs[id];}},clearLayerFilter:function(id){if(id){delete this.layerDefs[id];}else{delete this.layerDefs;}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.ArcGIS93Rest"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delay
 edCall,this,evt),this.delay);}
+if(queryDef){this.layerDefs[id]=queryDef;}else{delete this.layerDefs[id];}},clearLayerFilter:function(id){if(id){delete this.layerDefs[id];}else{delete this.layerDefs;}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.ArcGIS93Rest"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="tr
 ue")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
+var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
+return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
 return!this.stopMove;},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.div)){this.clearTimer();this.callback('move',[evt]);}
 return true;},passesTolerance:function(px){var passes=true;if(this.pixelTolerance&&this.px){var dpx=Math.sqrt(Math.pow(this.px.x-px.x,2)+
 Math.pow(this.px.y-px.y,2));if(dpx<this.pixelTolerance){passes=false;}}
@@ -2290,92 +2358,68 @@
 this.layer.removeAllFeatures();if(clusters.length>0){if(this.threshold>1){var clone=clusters.slice();clusters=[];var candidate;for(var i=0,len=clone.length;i<len;++i){candidate=clone[i];if(candidate.attributes.count<this.threshold){Array.prototype.push.apply(clusters,candidate.cluster);}else{clusters.push(candidate);}}}
 this.clustering=true;this.layer.addFeatures(clusters);this.clustering=false;}
 this.clusters=clusters;}}},clustersExist:function(){var exist=false;if(this.clusters&&this.clusters.length>0&&this.clusters.length==this.layer.features.length){exist=true;for(var i=0;i<this.clusters.length;++i){if(this.clusters[i]!=this.layer.features[i]){exist=false;break;}}}
-return exist;},shouldCluster:function(cluster,feature){var cc=cluster.geometry.getBounds().getCenterLonLat();var fc=feature.geometry.getBounds().getCenterLonLat();var distance=(Math.sqrt(Math.pow((cc.lon-fc.lon),2)+Math.pow((cc.lat-fc.lat),2))/this.resolution);return(distance<=this.distance);},addToCluster:function(cluster,feature){cluster.cluster.push(feature);cluster.attributes.count+=1;},createCluster:function(feature){var center=feature.geometry.getBounds().getCenterLonLat();var cluster=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(center.lon,center.lat),{count:1});cluster.cluster=[feature];return cluster;},CLASS_NAME:"OpenLayers.Strategy.Cluster"});OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,autoPan:false,handlers:null,resolutionFactor:1,maximized:false,initialize:function(o
 ptions){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
-if(this.handlers.click){this.handlers.click.destroy();}
-if(this.handlers.drag){this.handlers.drag.destroy();}
-this.ovmap&&this.ovmap.viewPortDiv.removeChild(this.extentRectangle);this.extentRectangle=null;if(this.rectEvents){this.rectEvents.destroy();this.rectEvents=null;}
-if(this.ovmap){this.ovmap.destroy();this.ovmap=null;}
-this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
-if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
-this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
-this.element=document.createElement('div');this.element.className=this.displayClass+'Element';this.element.style.display='none';this.mapDiv=document.createElement('div');this.mapDiv.style.width=this.size.w+'px';this.mapDiv.style.height=this.size.h+'px';this.mapDiv.style.position='relative';this.mapDiv.style.overflow='hidden';this.mapDiv.id=OpenLayers.Util.createUniqueID('overviewMap');this.extentRectangle=document.createElement('div');this.extentRectangle.style.position='absolute';this.extentRectangle.style.zIndex=1000;this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(!this.outsideViewport){this.div.className+=" "+this.displayClass+'Container';var imgLocation=OpenLayers.Util.getImagesLocation();var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+'MaximizeButton',null,new OpenLayers.Size(18,18),img,'absolute');this.m
 aximizeDiv.style.display='none';this.maximizeDiv.className=this.displayClass+'MaximizeButton';OpenLayers.Event.observe(this.maximizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv('OpenLayers_Control_minimizeDiv',null,new OpenLayers.Size(18,18),img,'absolute');this.minimizeDiv.style.display='none';this.minimizeDiv.className=this.displayClass+'MinimizeButton';OpenLayers.Event.observe(this.minimizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);var eventsToStop=['dblclick','mousedown'];for(var i=0,len=eventsToStop.length;i<len;i++){OpenLayers.Event.observe(this.maximizeDiv,eventsToStop[i],OpenLayers.Event.stop);OpenLayers.Event.observe(this.minimizeDiv,eventsToStop[i],OpenLayers.Event.stop);}
-this.minimizeControl();}else{this.element.style.display='';}
-if(this.map.getExtent()){this.update();}
-this.map.events.register('moveend',this,this.update);if(this.maximized){this.maximizeControl();}
-return this.div;},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw);},rectDrag:function(px){var deltaX=this.handlers.drag.last.x-px.x;var deltaY=this.handlers.drag.last.y-px.y;if(deltaX!=0||deltaY!=0){var rectTop=this.rectPxBounds.top;var rectLeft=this.rectPxBounds.left;var rectHeight=Math.abs(this.rectPxBounds.getHeight());var rectWidth=this.rectPxBounds.getWidth();var newTop=Math.max(0,(rectTop-deltaY));newTop=Math.min(newTop,this.ovmap.size.h-this.hComp-rectHeight);var newLeft=Math.max(0,(rectLeft-deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-this.wComp-rectWidth);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+rectHeight,newLeft+rectWidth,newTop));}},mapDivClick:function(evt){var pxCenter=this.rectPxBounds.getCenterPixel();var deltaX=evt.xy.x-pxCenter.x;var deltaY=evt.xy.y-pxCenter.y;var top=this.rectPxBounds.top;var left=this.rectPxBounds.left;var height=Math.abs(this.rectPxBounds.getHeight());var
 width=this.rectPxBounds.getWidth();var newTop=Math.max(0,(top+deltaY));newTop=Math.min(newTop,this.ovmap.size.h-height);var newLeft=Math.max(0,(left+deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-width);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+height,newLeft+width,newTop));this.updateMapToRect();},maximizeControl:function(e){this.element.style.display='';this.showToggle(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.element.style.display='none';this.showToggle(true);if(e!=null){OpenLayers.Event.stop(e);}},showToggle:function(minimize){this.maximizeDiv.style.display=minimize?'':'none';this.minimizeDiv.style.display=minimize?'none':'';},update:function(){if(this.ovmap==null){this.createMap();}
-if(this.autoPan||!this.isSuitableOverview()){this.updateOverview();}
-this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));if(this.ovmap.getProjection()!=this.map.getProjection()){testExtent=testExtent.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}
-var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
-var center;if(this.ovmap.getProjection()!=this.map.getProjection()){center=this.map.center.clone();center.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}else{center=this.map.center;}
-this.ovmap.setCenter(center,this.ovmap.getZoomForResolution(targetRes*this.resolutionFactor));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);this.ovmap.viewPortDiv.appendChild(this.extentRectangle);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});if(this.ovmap.getProjection()!=this.map.getProjection()){var sourceUnits=this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units;var targetUnits=this.ovmap.getProjectionObject
 ().getUnits()||this.ovmap.units||this.ovmap.baseLayer.units;this.resolutionFactor=sourceUnits&&targetUnits?OpenLayers.INCHES_PER_UNIT[sourceUnits]/OpenLayers.INCHES_PER_UNIT[targetUnits]:1;}},updateRectToMap:function(){var bounds;if(this.ovmap.getProjection()!=this.map.getProjection()){bounds=this.map.getExtent().transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}else{bounds=this.map.getExtent();}
-var pxBounds=this.getRectBoundsFromMapBounds(bounds);if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);if(this.ovmap.getProjection()!=this.map.getProjection()){lonLatBounds=lonLatBounds.transform(this.ovmap.getProjectionObject(),this.map.getProjectionObject());}
-this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
-this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
-this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
-return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat))
-return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+return exist;},shouldCluster:function(cluster,feature){var cc=cluster.geometry.getBounds().getCenterLonLat();var fc=feature.geometry.getBounds().getCenterLonLat();var distance=(Math.sqrt(Math.pow((cc.lon-fc.lon),2)+Math.pow((cc.lat-fc.lat),2))/this.resolution);return(distance<=this.distance);},addToCluster:function(cluster,feature){cluster.cluster.push(feature);cluster.attributes.count+=1;},createCluster:function(feature){var center=feature.geometry.getBounds().getCenterLonLat();var cluster=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(center.lon,center.lat),{count:1});cluster.cluster=[feature];return cluster;},CLASS_NAME:"OpenLayers.Strategy.Cluster"});OpenLayers.Protocol.SOS=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.SOS.DEFAULTS);var cls=OpenLayers.Protocol.SOS["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported SOS version: "+options.version;}
+return new cls(options);};OpenLayers.Protocol.SOS.DEFAULTS={"version":"1.0.0"};OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},createGeometryFromItem:function(item){var point=this.getElementsByTagNameNS(item,this.georssns,"point");var lat=this.getElementsByTagNameNS(item,this.geons,'lat');var lon=this.getElementsByTagNameNS(item,this.geons,'long');var line=this.getElementsByTagNameNS(item,this.georssns,"line");var polygon=this.getElementsByTagNameNS(item,this.georssns,"polygon");var where=this.getElementsByTagNameNS(item,this.georssns,"where");var box=this.getElementsByTagNameNS(item,this.georssns,"box")
 ;if(point.length>0||(lat.length>0&&lon.length>0)){var location;if(point.length>0){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s+/);if(location.length!=2){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s*,\s*/);}}else{location=[parseFloat(lat[0].firstChild.nodeValue),parseFloat(lon[0].firstChild.nodeValue)];}
+var geometry=new OpenLayers.Geometry.Point(parseFloat(location[1]),parseFloat(location[0]));}else if(line.length>0){var coords=OpenLayers.String.trim(this.concatChildValues(line[0])).split(/\s+/);var components=[];var point;for(var i=0,len=coords.length;i<len;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
+geometry=new OpenLayers.Geometry.LineString(components);}else if(polygon.length>0){var coords=OpenLayers.String.trim(this.concatChildValues(polygon[0])).split(/\s+/);var components=[];var point;for(var i=0,len=coords.length;i<len;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
+geometry=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);}else if(where.length>0){if(!this.gmlParser){this.gmlParser=new OpenLayers.Format.GML({'xy':this.xy});}
+var feature=this.gmlParser.parseFeature(where[0]);geometry=feature.geometry;}else if(box.length>0){var coords=OpenLayers.String.trim(box[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;if(coords.length>3){point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[0]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[2]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[3]),parseFloat(coords[2]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[3]),parseFloat(coords[0]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[0]));components.push(point);}
+if(geometry&&this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
+return geometry;},createFeatureFromItem:function(item){var geometry=this.createGeometryFromItem(item);var title=this.getChildValue(item,"*","title",this.featureTitle);var description=this.getChildValue(item,"*","description",this.getChildValue(item,"*","content",this.getChildValue(item,"*","summary",this.featureDescription)));var link=this.getChildValue(item,"*","link");if(!link){try{link=this.getElementsByTagNameNS(item,"*","link")[0].getAttribute("href");}catch(e){link=null;}}
+var id=this.getChildValue(item,"*","id",null);var data={"title":title,"description":description,"link":link};var feature=new OpenLayers.Feature.Vector(geometry,data);feature.fid=id;return feature;},getChildValue:function(node,nsuri,name,def){var value;var eles=this.getElementsByTagNameNS(node,nsuri,name);if(eles&&eles[0]&&eles[0].firstChild&&eles[0].firstChild.nodeValue){value=eles[0].firstChild.nodeValue;}else{value=(def==undefined)?"":def;}
+return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
+var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
+return features;},write:function(features){var georss;if(features instanceof Array){georss=this.createElementNS(this.rssns,"rss");for(var i=0,len=features.length;i<len;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
+return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
+for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
+var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
+var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureNode.appendChild(attrContainer);}
+featureNode.appendChild(geometryNode);return featureNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var node;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){node=this.createElementNS(this.georssns,'georss:polygon');node.appendChild(this.buildCoordinatesNode(geometry.components[0]));}
+else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){node=this.createElementNS(this.georssns,'georss:line');node.appendChild(this.buildCoordinatesNode(geometry));}
+else if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){node=this.createElementNS(this.georssns,'georss:point');node.appendChild(this.buildCoordinatesNode(geometry));}else{throw"Couldn't parse "+geometry.CLASS_NAME;}
+return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
+var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
+path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
+return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
 this.dragPan=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragPan.activate();this.handlers.click.activate();return true;}
 return false;},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.dragPan.deactivate();this.handlers.click.deactivate();return true;}
 return false;},draw:function(){var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});OpenLayers.Style2=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,initialize:function(config){OpenLayers.Util.extend(this,config);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;
 i++){this.rules[i].destroy();}
 delete this.rules;},clone:function(){var config=OpenLayers.Util.extend({},this);if(this.rules){config.rules=[];for(var i=0,len=this.rules.length;i<len;++i){config.rules.push(this.rules[i].clone());}}
-return new OpenLayers.Style2(config);},CLASS_NAME:"OpenLayers.Style2"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={drag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},destroy:function(){this.layer=null;OpenLayer
 s.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPi
 xel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");this.onLeave(feature);this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.i
 nitialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.observe(document,this.KEY_EVENTS[i],this.eventListener);}
-return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.stopObserving(document,this.KEY_EVENTS[i],this.eventListener);}
-deactivated=true;}
-return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,standalone:false,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,modified:false,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){options=options||{};this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,options.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Control.ModifyFeature
 .RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(this.deleteCodes instanceof Array)){this.deleteCodes=[this.deleteCodes];}
-var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,onBeforeSelect:this.beforeSelectFeature,onSelect:this.selectFeature,onUnselect:this.unselectFeature,scope:this};if(this.standalone===false){this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);}
-var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature,pixel){control.dragVertex.apply(control,[feature,pixel]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);},featureCallbacks:{over:function(feature){if(control.standalone!==true||feature._sketch||control.feature===feature){control.dragControl.overFeature.apply(control.dragControl,[feature]);}}}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keydown:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer=null;this.standalone||this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return((this.standalone||this.selectControl.activate())&&this.handlers.keyb
 oard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices,{silent:true});this.layer.removeFeatures(this.virtualVertices,{silent:true});this.vertices=[];this.dragControl.deactivate();var feature=this.feature;var valid=feature&&feature.geometry&&feature.layer;if(this.standalone===false){if(valid){this.selectControl.unselect.apply(this.selectControl,[feature]);}
-this.selectControl.deactivate();}else{if(valid){this.unselectFeature(feature);}}
-this.handlers.keyboard.deactivate();deactivated=true;}
-return deactivated;},beforeSelectFeature:function(feature){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});},selectFeature:function(feature){if(!this.standalone||this.beforeSelectFeature(feature)!==false){this.feature=feature;this.modified=false;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);}},unselectFeature:function(feature){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});delete this.dragHandle;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});delete this.radiusHandle;}
-this.feature=null;this.dragControl.deactivate();this.onModificationEnd(feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:feature,modified:this.modified});this.modified=false;},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex,pixel){this.modified=true;if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}
-this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}}else if(vertex!==this.radiusHandle){this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}
-if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
-this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);}
-this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE){this.feature.state=OpenLayers.State.UPDATE;}},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
-if(this.vertices.length>0){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];}
-if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
-if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});this.dragHandle=null;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}
-if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
-if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
-if(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE){if(!(this.mode&OpenLayers.Control.ModifyFeature.RESIZE)){this.collectVertices();}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.events.triggerEvent("vertexremoved",{vertex:vertex.geometry,feature:this.feature,pixel:evt.xy});this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vertex,component,l
 en;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
-for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{collectComponentVertices(component);}}
-if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0,len=geometry.components.length;i<len-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;point._sketch=true;control.virtualVertices.push(point);}}}}}
-collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:true});this.layer.addFeatures(this.vertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};origin._sketch=true;this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&O
 penLayers.Control.ModifyFeature.RESIZE);var reshape=(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
-if(resize){var scale,ratio;if(reshape){scale=dy1/dy0;ratio=(dx1/dx0)/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
-geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.standalone||this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Format.WFSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(options){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[options]);},read_cap_Service:function(capabilities,node){var service={};this.runChildNodes(service,node);capabilities.service=service;},read_cap_Fees:function(service,node){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){service.fees=fees;}},read
 _cap_AccessConstraints:function(service,node){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){service.accessConstraints=constraints;}},read_cap_OnlineResource:function(service,node){var onlineResource=this.getChildValue(node);if(onlineResource&&onlineResource.toLowerCase()!="none"){service.onlineResource=onlineResource;}},read_cap_Keywords:function(service,node){var keywords=this.getChildValue(node);if(keywords&&keywords.toLowerCase()!="none"){service.keywords=keywords.split(', ');}},read_cap_Capability:function(capabilities,node){var capability={};this.runChildNodes(capability,node);capabilities.capability=capability;},read_cap_Request:function(obj,node){var request={};this.runChildNodes(request,node);obj.request=request;},read_cap_GetFeature:function(request,node){var getfeature={href:{},formats:[]};this.runChildNodes(getfeature,node);request.getfeature=getfeature;},read_cap_ResultFormat:function(obj,node){var children=node.child
 Nodes;var childNode;for(var i=0;i<children.length;i++){childNode=children[i];if(childNode.nodeType==1){obj.formats.push(childNode.nodeName);}}},read_cap_DCPType:function(obj,node){this.runChildNodes(obj,node);},read_cap_HTTP:function(obj,node){this.runChildNodes(obj.href,node);},read_cap_Get:function(obj,node){obj.get=node.getAttribute("onlineResource");},read_cap_Post:function(obj,node){obj.post=node.getAttribute("onlineResource");},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_0_0"});OpenLayers.Format.WMSCapabilities.v1_3=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"LayerLimit":function(node,obj){obj.layerLimit=parseInt(this.getChildValue(node));},"MaxWidth":function(node,obj){obj.maxWidth=parseInt(this.getChildValue(node));},"MaxHeight":function(node,obj){obj.maxHeight=parseInt(this.getChildValue(node));},"BoundingBox":function(node,obj){var bb
 ox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("CRS");obj.bbox[bbox.srs]=bbox;},"CRS":function(node,obj){this.readers.wms.SRS.apply(this,[node,obj]);},"EX_GeographicBoundingBox":function(node,obj){obj.llbbox=[];this.readChildNodes(node,obj.llbbox);},"westBoundLongitude":function(node,obj){obj[0]=this.getChildValue(node);},"eastBoundLongitude":function(node,obj){obj[2]=this.getChildValue(node);},"southBoundLatitude":function(node,obj){obj[1]=this.getChildValue(node);},"northBoundLatitude":function(node,obj){obj[3]=this.getChildValue(node);},"MinScaleDenominator":function(node,obj){obj.maxScale=parseFloat(this.getChildValue(node)).toPrecision(16);},"MaxScaleDenominator":function(node,obj){obj.minScale=parseFloat(this.getChildValue(node)).toPrecision(16);},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:no
 de.getAttribute("unitSymbol"),nearestVal:node.getAttribute("nearestValue")==="1",multipleVal:node.getAttribute("multipleValues")==="1","default":node.getAttribute("default")||"",current:node.getAttribute("current")==="1",values:this.getChildValue(node).split(",")};obj.dimensions[dim.name]=dim;},"Keyword":function(node,obj){var keyword={value:this.getChildValue(node),vocabulary:node.getAttribute("vocabulary")};if(obj.keywords){obj.keywords.push(keyword);}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"]),"sld":{"UserDefinedSymbolization":function(node,obj){this.readers.wms.UserDefinedSymbolization.apply(this,[node,obj]);obj.userSymbols.inlineFeature=parseInt(node.getAttribute("InlineFeature"))==1;obj.userSymbols.remoteWCS=parseInt(node.getAttribute("RemoteWCS"))==1;},"DescribeLayer":function(node,obj){this.readers.wms.DescribeLayer.apply(this,[node,obj]);},"GetLegendGraphic":function(node,obj){this.readers.wms.GetLegendGraphic.apply(this,[node,obj]);}}},CLASS_N
 AME:"OpenLayers.Format.WMSCapabilities.v1_3"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:'_layer',featureIdentifier:'_feature',regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},gmlFormat:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,arguments);OpenLayers.Util.extend(this,options);this.options=options;},read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;if(root){var scope=this;var read=this["read_"+root.nodeName];if(read){result=read.call(this,root);}else{result=new OpenLayers.Format.GML((this.options?this.options:{})).read(data);}}else{result=data;}
-return result;},read_msGMLOutput:function(data){var response=[];var layerNodes=this.getSiblingNodesByTagCriteria(data,this.layerIdentifier);if(layerNodes){for(var i=0,len=layerNodes.length;i<len;++i){var node=layerNodes[i];var layerName=node.nodeName;if(node.prefix){layerName=layerName.split(':')[1];}
-var layerName=layerName.replace(this.layerIdentifier,'');var featureNodes=this.getSiblingNodesByTagCriteria(node,this.featureIdentifier);if(featureNodes){for(var j=0;j<featureNodes.length;j++){var featureNode=featureNodes[j];var geomInfo=this.parseGeometry(featureNode);var attributes=this.parseAttributes(featureNode);var feature=new OpenLayers.Feature.Vector(geomInfo.geometry,attributes,null);feature.bounds=geomInfo.bounds;feature.type=layerName;response.push(feature);}}}}
-return response;},read_FeatureInfoResponse:function(data){var response=[];var featureNodes=this.getElementsByTagNameNS(data,'*','FIELDS');for(var i=0,len=featureNodes.length;i<len;i++){var featureNode=featureNodes[i];var geom=null;var attributes={};for(var j=0,jlen=featureNode.attributes.length;j<jlen;j++){var attribute=featureNode.attributes[j];attributes[attribute.nodeName]=attribute.nodeValue;}
-response.push(new OpenLayers.Feature.Vector(geom,attributes,null));}
-return response;},getSiblingNodesByTagCriteria:function(node,criteria){var nodes=[];var children,tagName,n,matchNodes,child;if(node&&node.hasChildNodes()){children=node.childNodes;n=children.length;for(var k=0;k<n;k++){child=children[k];while(child&&child.nodeType!=1){child=child.nextSibling;k++;}
-tagName=(child?child.nodeName:'');if(tagName.length>0&&tagName.indexOf(criteria)>-1){nodes.push(child);}else{matchNodes=this.getSiblingNodesByTagCriteria(child,criteria);if(matchNodes.length>0){(nodes.length==0)?nodes=matchNodes:nodes.push(matchNodes);}}}}
-return nodes;},parseAttributes:function(node){var attributes={};if(node.nodeType==1){var children=node.childNodes;var n=children.length;for(var i=0;i<n;++i){var child=children[i];if(child.nodeType==1){var grandchildren=child.childNodes;if(grandchildren.length==1){var grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseGeometry:function(node){if(!this.gmlFormat){this.gmlFormat=new OpenLayers.Format.GML();}
-var feature=this.gmlFormat.parseFeature(node);var geometry,bounds=null;if(feature){geometry=feature.geometry&&feature.geometry.clone();bounds=feature.bounds&&feature.bounds.clone();feature.destroy();}
-return{geometry:geometry,bounds:bounds};},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Control.WMTSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,requestEncoding:"KVP",drillDown:false,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:true,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,EVENT_TYPES:["beforegetfeatureinfo","getfeatureinfo","exception"],pending:0,initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.WMTSGetFeatureInfo.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options=options||{};options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
-if(this.drillDown===true){this.hover=false;}
-if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},getInfoForClick:function(evt){this.request(evt.xy,{});},getInfoForHover:function(evt){this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
-this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer;for(var i=candidates.length-1;i>=0;--i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMTS&&layer.requestEncoding===this.requestEncoding&&(!this.queryVisible||layer.getVisibility())){layers.push(layer);if(!this.drillDown||this.hover){break;}}}
-return layers;},buildRequestOptions:function(layer,xy){var loc=this.map.getLonLatFromPixel(xy);var getTileUrl=layer.getURL(new OpenLayers.Bounds(loc.lon,loc.lat,loc.lon,loc.lat));var params=OpenLayers.Util.getParameters(getTileUrl);var tileInfo=layer.getTileInfo(loc);OpenLayers.Util.extend(params,{service:"WMTS",version:layer.version,request:"GetFeatureInfo",infoFormat:this.infoFormat,i:tileInfo.i,j:tileInfo.j});OpenLayers.Util.applyDefaults(params,this.vendorParams);return{url:layer.url instanceof Array?layer.url[0]:layer.url,params:OpenLayers.Util.upperCaseObject(params),callback:function(request){this.handleResponse(xy,request,layer);},scope:this};},request:function(xy,options){options=options||{};var layers=this.findLayers();if(layers.length>0){var issue,layer;for(var i=0,len=layers.length;i<len;i++){layer=layers[i];issue=this.events.triggerEvent("beforegetfeatureinfo",{xy:xy,layer:layer});if(issue!==false){++this.pending;var requestOptions=this.buildRequestOptions(layer
 ,xy);var request=OpenLayers.Request.GET(requestOptions);if(options.hover===true){this.hoverRequest=request;}}}
-if(this.pending>0){OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");}}},handleResponse:function(xy,request,layer){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
-if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("exception",{xy:xy,request:request,layer:layer});}else{var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var features,except;try{features=this.format.read(doc);}catch(error){except=true;this.events.triggerEvent("exception",{xy:xy,request:request,error:error,layer:layer});}
-if(!except){this.events.triggerEvent("getfeatureinfo",{text:request.responseText,features:features,request:request,xy:xy,layer:layer});}}},CLASS_NAME:"OpenLayers.Control.WMTSGetFeatureInfo"});OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031],type:null,wrapDateLine:true,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();
 }},loadMapObject:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,size);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||(typeof this.mapObject.moveByXY!="function")){this.dragPanMapObject=null;}}catch(e){}},onMapResize:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject.resizeTo(size);}catch(e){}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane);},fixYahooEventPane:function(){var yahooEventPane=OpenLayers.Util.getElement("ygddfdiv");if(yahooEventPane!=null){if(yahooEventPane.parentNode!=null){yahooEventPane.parentNode.removeChild(yahooEventPane);}
+return new OpenLayers.Style2(config);},CLASS_NAME:"OpenLayers.Style2"});OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(options,layer){OpenLayers.Format.GML.prototype.initialize.apply(this,[options]);this.layer=layer;if(this.layer.featureNS){this.featureNS=this.layer.featureNS;}
+if(this.layer.options.geometry_column){this.geometryName=this.layer.options.geometry_column;}
+if(this.layer.options.typename){this.featureName=this.layer.options.typename;}},write:function(features){var transaction=this.createElementNS(this.wfsns,'wfs:Transaction');transaction.setAttribute("version","1.0.0");transaction.setAttribute("service","WFS");for(var i=0;i<features.length;i++){switch(features[i].state){case OpenLayers.State.INSERT:transaction.appendChild(this.insert(features[i]));break;case OpenLayers.State.UPDATE:transaction.appendChild(this.update(features[i]));break;case OpenLayers.State.DELETE:transaction.appendChild(this.remove(features[i]));break;}}
+return OpenLayers.Format.XML.prototype.write.apply(this,[transaction]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var geomContainer=this.createElementNS(this.featureNS,"feature:"+this.geometryName);geomContainer.appendChild(geometryNode);var featureContainer=this.createElementNS(this.featureNS,"feature:"+this.featureName);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
+var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
+return featureContainer;},insert:function(feature){var insertNode=this.createElementNS(this.wfsns,'wfs:Insert');insertNode.appendChild(this.createFeatureXML(feature));return insertNode;},update:function(feature){if(!feature.fid){OpenLayers.Console.userError(OpenLayers.i18n("noFID"));}
+var updateNode=this.createElementNS(this.wfsns,'wfs:Update');updateNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);updateNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var propertyNode=this.createElementNS(this.wfsns,'wfs:Property');var nameNode=this.createElementNS(this.wfsns,'wfs:Name');var txtNode=this.createTextNode(this.geometryName);nameNode.appendChild(txtNode);propertyNode.appendChild(nameNode);var valueNode=this.createElementNS(this.wfsns,'wfs:Value');var geometryNode=this.buildGeometryNode(feature.geometry);if(feature.layer){geometryNode.setAttribute("srsName",feature.layer.projection.getCode());}
+valueNode.appendChild(geometryNode);propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);for(var propName in feature.attributes){propertyNode=this.createElementNS(this.wfsns,'wfs:Property');nameNode=this.createElementNS(this.wfsns,'wfs:Name');nameNode.appendChild(this.createTextNode(propName));propertyNode.appendChild(nameNode);valueNode=this.createElementNS(this.wfsns,'wfs:Value');valueNode.appendChild(this.createTextNode(feature.attributes[propName]));propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);}
+var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);updateNode.appendChild(filterNode);return updateNode;},remove:function(feature){if(!feature.fid){OpenLayers.Console.userError(OpenLayers.i18n("noFID"));return false;}
+var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);deleteNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Format.WFSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(options){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[options]);},read_cap_Service:function(capabilities,node){var service={};this.runChildNodes(service,node);capabilities.service=service;},read_cap_Fees:function(service,node){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){service
 .fees=fees;}},read_cap_AccessConstraints:function(service,node){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){service.accessConstraints=constraints;}},read_cap_OnlineResource:function(service,node){var onlineResource=this.getChildValue(node);if(onlineResource&&onlineResource.toLowerCase()!="none"){service.onlineResource=onlineResource;}},read_cap_Keywords:function(service,node){var keywords=this.getChildValue(node);if(keywords&&keywords.toLowerCase()!="none"){service.keywords=keywords.split(', ');}},read_cap_Capability:function(capabilities,node){var capability={};this.runChildNodes(capability,node);capabilities.capability=capability;},read_cap_Request:function(obj,node){var request={};this.runChildNodes(request,node);obj.request=request;},read_cap_GetFeature:function(request,node){var getfeature={href:{},formats:[]};this.runChildNodes(getfeature,node);request.getfeature=getfeature;},read_cap_ResultFormat:function(obj,node){var c
 hildren=node.childNodes;var childNode;for(var i=0;i<children.length;i++){childNode=children[i];if(childNode.nodeType==1){obj.formats.push(childNode.nodeName);}}},read_cap_DCPType:function(obj,node){this.runChildNodes(obj,node);},read_cap_HTTP:function(obj,node){this.runChildNodes(obj.href,node);},read_cap_Get:function(obj,node){obj.get=node.getAttribute("onlineResource");},read_cap_Post:function(obj,node){obj.post=node.getAttribute("onlineResource");},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_0_0"});OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031],type:null,wrapDateLine:true,spher
 icalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,size);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||(typeof this.mapObject.moveByXY!="function")){this.dragPanMapObject=null;}}catch(e){}},onMapResize:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject.resizeTo(size);}catch(e){}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane);},fixYahooEventPane:function(){var yahooEventPane=OpenLayers.
 this.map.events.unregister("moveend",this,this.fixYahooEventPane);}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'Yahoo','layerLib':'Yahoo'});},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[moZoom]);zoom=18-zoom;}
 return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[olZoom]);zoom=18-zoom;}
 return zoom;},setMapObjectCenter:function(center,zoom){this.mapObject.drawZoomAndCenter(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon();},dragPanMapObject:function(dX,dY){this.mapObject.moveByXY({'x':-dX,'y':dY});},getMapObjectZoom:function(){return this.mapObject.getZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.convertXYLatLon(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.convertLatLonXY(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lon:moLonLat.Lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lat:moLonLat.Lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var yLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);yLatLong=new YGeoPoint(lonlat.lat,lon
 lat.lon);}else{yLatLong=new YGeoPoint(lat,lon);}
-return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
-var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Layer.Zoomify=OpenLayers.Class(OpenLayers.Layer.Grid,{url:null,size:null,isBaseLayer:true,standardTileSize:256,numberOfTiers:0,tileCountUpToTier:new Array(),tierSizeInTiles:new Array(),tierImageSize:new Array(),initialize:function(name,url,size,options){this.initializeZoomify(size);var newArguments=[];newArguments.push(name,url,size,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},initializeZoomify:function(size){var imageSize=size.clone();var tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);while(imageSize.w>this.standardTileSize||imageSize.h>this.standardTileSize){imageSize=new OpenLayers.Size(Math.floor(imageSize.w/2),Math.floor(imageSize.h/2));tiles=new OpenLayers.Size
 (Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);}
+return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Format.SOSGetFeatureOfInterest=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",sa:"http://www.opengis.net/sampling/1.0",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosAll.xsd",defaultPrefix:"sos",regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.
+if(data&&data.nodeType==9){data=data.documentElement;}
+var info={features:[]};this.readNode(data,info);var features=[];for(var i=0,len=info.features.length;i<len;i++){var container=info.features[i];if(this.internalProjection&&this.externalProjection&&container.components[0]){container.components[0].transform(this.externalProjection,this.internalProjection);}
+var feature=new OpenLayers.Feature.Vector(container.components[0],container.attributes);features.push(feature);}
+return features;},readers:{"sa":{"SamplingPoint":function(node,obj){if(!obj.attributes){var feature={attributes:{}};obj.features.push(feature);obj=feature;}
+obj.attributes.id=this.getAttributeNS(node,this.namespaces.gml,"id");this.readChildNodes(node,obj);},"position":function(node,obj){this.readChildNodes(node,obj);}},"gml":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);},"featureMember":function(node,obj){var feature={attributes:{}};obj.features.push(feature);this.readChildNodes(node,feature);},"name":function(node,obj){obj.attributes.name=this.getChildValue(node);},"pos":function(node,obj){if(!this.externalProjection){this.externalProjection=new OpenLayers.Projection(node.getAttribute("srsName"));}
+OpenLayers.Format.GML.v3.prototype.readers.gml.pos.apply(this,[node,obj]);}},OpenLayers.Format.GML.v3.prototype.readers.gml)},writers:{"sos":{"GetFeatureOfInterest":function(options){var node=this.createElementNSPlus("GetFeatureOfInterest",{attributes:{version:this.VERSION,service:'SOS',"xsi:schemaLocation":this.schemaLocation}});for(var i=0,len=options.fois.length;i<len;i++){this.writeNode("FeatureOfInterestId",{foi:options.fois[i]},node);}
+return node;},"FeatureOfInterestId":function(options){var node=this.createElementNSPlus("FeatureOfInterestId",{value:options.foi});return node;}}},CLASS_NAME:"OpenLayers.Format.SOSGetFeatureOfInterest"});OpenLayers.Format.SOSGetObservation=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows",gml:"http://www.opengis.net/gml",sos:"http://www.opengis.net/sos/1.0",ogc:"http://www.opengis.net/ogc",om:"http://www.opengis.net/om/1.0",sa:"http://www.opengis.net/sampling/1.0",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",defaultPrefix:"sos",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.
+var info={measurements:[],observations:[]};this.readNode(data,info);return info;},write:function(options){var node=this.writeNode("sos:GetObservation",options);node.setAttribute("xmlns:om",this.namespaces.om);node.setAttribute("xmlns:ogc",this.namespaces.ogc);this.setAttributeNS(node,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},readers:{"om":{"ObservationCollection":function(node,obj){obj.id=this.getAttributeNS(node,this.namespaces.gml,"id");this.readChildNodes(node,obj);},"member":function(node,observationCollection){this.readChildNodes(node,observationCollection);},"Measurement":function(node,observationCollection){var measurement={};observationCollection.measurements.push(measurement);this.readChildNodes(node,measurement);},"Observation":function(node,observationCollection){var observation={};observationCollection.observations.push(observation);this.readChildNodes(node,observation);},"sampl
 ingTime":function(node,measurement){var samplingTime={};measurement.samplingTime=samplingTime;this.readChildNodes(node,samplingTime);},"observedProperty":function(node,measurement){measurement.observedProperty=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,measurement);},"procedure":function(node,measurement){measurement.procedure=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,measurement);},"featureOfInterest":function(node,observation){var foi={features:[]};observation.fois=[];observation.fois.push(foi);this.readChildNodes(node,foi);var features=[];for(var i=0,len=foi.features.length;i<len;i++){var feature=foi.features[i];features.push(new OpenLayers.Feature.Vector(feature.components[0],feature.attributes));}
+foi.features=features;},"result":function(node,measurement){var result={};measurement.result=result;if(this.getChildValue(node)!==''){result.value=this.getChildValue(node);result.uom=node.getAttribute("uom");}else{this.readChildNodes(node,result);}}},"sa":OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.sa,"gml":OpenLayers.Util.applyDefaults({"TimeInstant":function(node,samplingTime){var timeInstant={};samplingTime.timeInstant=timeInstant;this.readChildNodes(node,timeInstant);},"timePosition":function(node,timeInstant){timeInstant.timePosition=this.getChildValue(node);}},OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.gml)},writers:{"sos":{"GetObservation":function(options){var node=this.createElementNSPlus("GetObservation",{attributes:{version:this.VERSION,service:'SOS'}});this.writeNode("offering",options,node);if(options.eventTime){this.writeNode("eventTime",options,node);}
+for(var procedure in options.procedures){this.writeNode("procedure",options.procedures[procedure],node);}
+for(var observedProperty in options.observedProperties){this.writeNode("observedProperty",options.observedProperties[observedProperty],node);}
+if(options.foi){this.writeNode("featureOfInterest",options.foi,node);}
+this.writeNode("responseFormat",options,node);if(options.resultModel){this.writeNode("resultModel",options,node);}
+if(options.responseMode){this.writeNode("responseMode",options,node);}
+return node;},"featureOfInterest":function(foi){var node=this.createElementNSPlus("featureOfInterest");this.writeNode("ObjectID",foi.objectId,node);return node;},"ObjectID":function(options){return this.createElementNSPlus("ObjectID",{value:options});},"responseFormat":function(options){return this.createElementNSPlus("responseFormat",{value:options.responseFormat});},"procedure":function(procedure){return this.createElementNSPlus("procedure",{value:procedure});},"offering":function(options){return this.createElementNSPlus("offering",{value:options.offering});},"observedProperty":function(observedProperty){return this.createElementNSPlus("observedProperty",{value:observedProperty});},"eventTime":function(options){var node=this.createElementNSPlus("eventTime");if(options.eventTime==='latest'){this.writeNode("ogc:TM_Equals",options,node);}
+return node;},"resultModel":function(options){return this.createElementNSPlus("resultModel",{value:options.resultModel});},"responseMode":function(options){return this.createElementNSPlus("responseMode",{value:options.responseMode});}},"ogc":{"TM_Equals":function(options){var node=this.createElementNSPlus("ogc:TM_Equals");this.writeNode("ogc:PropertyName",{property:"urn:ogc:data:time:iso8601"},node);if(options.eventTime==='latest'){this.writeNode("gml:TimeInstant",{value:'latest'},node);}
+return node;},"PropertyName":function(options){return this.createElementNSPlus("ogc:PropertyName",{value:options.property});}},"gml":{"TimeInstant":function(options){var node=this.createElementNSPlus("gml:TimeInstant");this.writeNode("gml:timePosition",options,node);return node;},"timePosition":function(options){var node=this.createElementNSPlus("gml:timePosition",{value:options.value});return node;}}},CLASS_NAME:"OpenLayers.Format.SOSGetObservation"});OpenLayers.Layer.Zoomify=OpenLayers.Class(OpenLayers.Layer.Grid,{url:null,size:null,isBaseLayer:true,standardTileSize:256,numberOfTiers:0,tileCountUpToTier:new Array(),tierSizeInTiles:new Array(),tierImageSize:new Array(),initialize:function(name,url,size,options){this.initializeZoomify(size);var newArguments=[];newArguments.push(name,url,size,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},initializeZoomify:function(size){var imageSize=size.clone();var tiles=new OpenLayers.Size(Math.ceil(imag
 eSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);while(imageSize.w>this.standardTileSize||imageSize.h>this.standardTileSize){imageSize=new OpenLayers.Size(Math.floor(imageSize.w/2),Math.floor(imageSize.h/2));tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);}
 this.tierSizeInTiles.reverse();this.tierImageSize.reverse();this.numberOfTiers=this.tierSizeInTiles.length;this.tileCountUpToTier[0]=0;for(var i=1;i<this.numberOfTiers;i++){this.tileCountUpToTier.push(this.tierSizeInTiles[i-1].w*this.tierSizeInTiles[i-1].h+
 this.tileCountUpToTier[i-1]);}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);this.tileCountUpToTier.length=0;this.tierSizeInTiles.length=0;this.tierImageSize.length=0;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Zoomify(this.name,this.url,this.size,this.options);}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));var z=this.map.getZoom();var tileIndex=x+y*this.tierSizeInTiles[z].w+this.tileCountUpToTier[z];var path="TileGroup"+Math.floor((tileIndex)/256)+"/"+z+"-"+x+"-"+y+".jpg";var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
@@ -2449,37 +2493,26 @@
 switch(this.mode){case"zoombox":this.zoomBoxEnd(evt);if(this.startViaKeyboard){this.leaveMode();}
 break;case"pan":if(this.performedDrag){this.map.setCenter(this.map.center);}}
 document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="default";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();if(this.startViaKeyboard){this.leaveMode();}}
-this.mouseDragStart=null;this.map.div.style.cursor="default";}},defaultClick:function(evt){if(this.performedDrag){this.performedDrag=false;return false;}},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;OpenLayers.Protocol.WFS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFS.v1_0_0"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',layerOptions:null,persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
-OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:{};},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
-if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
-this.layer=null;this.feature=null;deactivated=true;}
-return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.map.getLonLatFromPixel(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
-if(this.persist){this.clear();}
-this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.map.getLonLatFromPixel(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
-this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
-this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
-this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();if(this.start==this.last){this.callback("done",[evt.xy]);}},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
-this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
-for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){if(this.layer){this.layer.renderer.clear();this.layer.destroyFeatures();}},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
-if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Control.SLDSelect=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["selected"],clearOnDeactivate:false,layers:null,callbacks:null,selectionSymbolizer:{'Polygon':{fillColor:'#FF0000',stroke:false},'Line':{strokeColor:'#FF0000',strokeWidth:2},'Point':{graphicName:'square',fillColor:'#FF0000',pointRadius:5}},layerOptions:null,handlerOptions:null,sketchStyle:null,wfsCache:{},layerCache:{},initialize:function(handler,options){this.EVENT_TYPES=OpenLayers.Control.SLDSelect.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.select,click:this.select},this.callbacks);this.handlerOptions=this.handlerOptions||{};this.layerOptions=OpenLayers.Util.applyDefaults(this.layerOptions,{displayInLayerSwitcher:false,tileOptions:{maxGetUrlLengt
 h:2048}});if(this.sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":this.sketchStyle})});}
-this.handler=new handler(this,this.callbacks,this.handlerOptions);},destroy:function(){for(var key in this.layerCache){delete this.layerCache[key];}
-for(var key in this.wfsCache){delete this.wfsCache[key];}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);},coupleLayerVisiblity:function(evt){this.setVisibility(evt.object.getVisibility());},createSelectionLayer:function(source){var selectionLayer;if(!this.layerCache[source.id]){selectionLayer=new OpenLayers.Layer.WMS(source.name,source.url,source.params,OpenLayers.Util.applyDefaults(this.layerOptions,source.getOptions()));this.layerCache[source.id]=selectionLayer;if(this.layerOptions.displayInLayerSwitcher===false){source.events.on({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});}
-this.map.addLayer(selectionLayer);}else{selectionLayer=this.layerCache[source.id];}
-return selectionLayer;},createSLD:function(layer,filters,geometryAttributes){var sld={version:"1.0.0",namedLayers:{}};var layerNames=[layer.params.LAYERS].join(",").split(",");for(var i=0,len=layerNames.length;i<len;i++){var name=layerNames[i];sld.namedLayers[name]={name:name,userStyles:[]};var symbolizer=this.selectionSymbolizer;var geometryAttribute=geometryAttributes[i];if(geometryAttribute.type.indexOf('Polygon')>=0){symbolizer={Polygon:this.selectionSymbolizer['Polygon']};}else if(geometryAttribute.type.indexOf('LineString')>=0){symbolizer={Line:this.selectionSymbolizer['Line']};}else if(geometryAttribute.type.indexOf('Point')>=0){symbolizer={Point:this.selectionSymbolizer['Point']};}
-var filter=filters[i];sld.namedLayers[name].userStyles.push({name:'default',rules:[new OpenLayers.Rule({symbolizer:symbolizer,filter:filter,maxScaleDenominator:layer.options.minScale})]});}
-return new OpenLayers.Format.SLD().write(sld);},parseDescribeLayer:function(request){var format=new OpenLayers.Format.WMSDescribeLayer();var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var describeLayer=format.read(doc);var typeNames=[];var url=null;for(var i=0,len=describeLayer.length;i<len;i++){if(describeLayer[i].owsType=="WFS"){typeNames.push(describeLayer[i].typeName);url=describeLayer[i].owsURL;}}
-var options={url:url,params:{SERVICE:"WFS",TYPENAME:typeNames.toString(),REQUEST:"DescribeFeatureType",VERSION:"1.0.0"},callback:function(request){var format=new OpenLayers.Format.WFSDescribeFeatureType();var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var describeFeatureType=format.read(doc);this.control.wfsCache[this.layer.id]=describeFeatureType;this.control._queue&&this.control.applySelection();},scope:this};OpenLayers.Request.GET(options);},getGeometryAttributes:function(layer){var result=[];var cache=this.wfsCache[layer.id];for(var i=0,len=cache.featureTypes.length;i<len;i++){var typeName=cache.featureTypes[i];var properties=typeName.properties;for(var j=0,lenj=properties.length;j<lenj;j++){var property=properties[j];var type=property.type;if((type.indexOf('LineString')>=0)||(type.indexOf('GeometryAssociationType')>=0)||(type.indexOf('GeometryPropertyType')>=0)||(type.indexOf('Point')>=0)||(type.indexOf('Polygon')>=0)){result.push(property);}}}
-return result;},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer&&!this.wfsCache[layer.id]){var options={url:layer.url,params:{SERVICE:"WMS",VERSION:layer.params.VERSION,LAYERS:layer.params.LAYERS,REQUEST:"DescribeLayer"},callback:this.parseDescribeLayer,scope:{layer:layer,control:this}};OpenLayers.Request.GET(options);}}}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer&&this.clearOnDeactivate===true){var layerCache=this.layerCache;var selectionLayer=layerCache[layer.id];if(selectionLayer){layer.events.un({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});selectionLayer.destroy();delete layerCache[layer.id];}}}}
-return deactivated;},setLayers:function(layers){if(this.active){this.deactivate();this.layers=layers;this.activate();}else{this.layers=layers;}},createFilter:function(geometryAttribute,geometry){var filter=null;if(this.handler instanceof OpenLayers.Handler.RegularPolygon){if(this.handler.irregular===true){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:geometryAttribute.name,value:geometry.getBounds()});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}}else if(this.handler instanceof OpenLayers.Handler.Polygon){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}else if(this.handler instanceof OpenLayers.Handler.Path){if(geometryAttribute.type.indexOf('Point')>=0){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:geometryAttribute.name,distanc
 e:this.map.getExtent().getWidth()*0.01,distanceUnits:this.map.getUnits(),value:geometry});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}}else if(this.handler instanceof OpenLayers.Handler.Click){if(geometryAttribute.type.indexOf('Polygon')>=0){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:geometryAttribute.name,distance:this.map.getExtent().getWidth()*0.01,distanceUnits:this.map.getUnits(),value:geometry});}}
-return filter;},select:function(geometry){this._queue=function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];var geometryAttributes=this.getGeometryAttributes(layer);var filters=[];for(var j=0,lenj=geometryAttributes.length;j<lenj;j++){var geometryAttribute=geometryAttributes[j];if(geometryAttribute!==null){if(!(geometry instanceof OpenLayers.Geometry)){var point=this.map.getLonLatFromPixel(geometry.xy);geometry=new OpenLayers.Geometry.Point(point.lon,point.lat);}
-var filter=this.createFilter(geometryAttribute,geometry);if(filter!==null){filters.push(filter);}}}
-var selectionLayer=this.createSelectionLayer(layer);var sld=this.createSLD(layer,filters,geometryAttributes);this.events.triggerEvent("selected",{layer:layer,filters:filters});selectionLayer.mergeNewParams({SLD_BODY:sld});delete this._queue;}};this.applySelection();},applySelection:function(){var canApply=true;for(var i=0,len=this.layers.length;i<len;i++){if(!this.wfsCache[this.layers[i].id]){canApply=false;break;}}
-canApply&&this._queue.call(this);},CLASS_NAME:"OpenLayers.Control.SLDSelect"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);},drawMarker:function(marker){var bounds=marker.bounds;var topleft=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.left,bounds.top));var botright=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.right,bounds.bottom));if(botright==null||topleft==null){marker.display(false);}else{var sz=new OpenLayers.Size(Math.max(1,botright.x-topleft.x),Math.max(1,botright.y-topleft.y));var markerDiv=marker.draw(topleft,sz);if(!marker.drawn){this.div.appendChild(markerDiv);marker.drawn=true;}}},removeMarker:function(marker){OpenLayers.Util.removeItem(this.markers,marker);if((marker.div!=null)&&(marker.div.parentNode==this.div)){this.div.removeChild(marker.div);}},CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Control.Graticule
 =OpenLayers.Class(OpenLayers.Control,{autoActivate:true,intervals:[45,30,20,10,5,2,1,0.5,0.2,0.1,0.05,0.01,0.005,0.002,0.001],displayInLayerSwitcher:true,visible:true,numPoints:50,targetSize:200,layerName:null,labelled:true,labelFormat:'dm',lineSymbolizer:{strokeColor:"#333",strokeWidth:1,strokeOpacity:0.5},labelSymbolizer:{},gratLayer:null,initialize:function(options){options=options||{};options.layerName=options.layerName||OpenLayers.i18n("graticule");OpenLayers.Control.prototype.initialize.apply(this,[options]);this.labelSymbolizer.stroke=false;this.labelSymbolizer.fill=false;this.labelSymbolizer.label="${label}";this.labelSymbolizer.labelAlign="${labelAlign}";this.labelSymbolizer.labelXOffset="${xOffset}";this.labelSymbolizer.labelYOffset="${yOffset}";},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.gratLayer){this.gratLayer.destroy();this.gratLayer=null;}},draw:function(){OpenLayers.Control.prototype.draw.apply(th
 is,arguments);if(!this.gratLayer){var gratStyle=new OpenLayers.Style({},{rules:[new OpenLayers.Rule({'symbolizer':{"Point":this.labelSymbolizer,"Line":this.lineSymbolizer}})]});this.gratLayer=new OpenLayers.Layer.Vector(this.layerName,{styleMap:new OpenLayers.StyleMap({'default':gratStyle}),visibility:this.visible,displayInLayerSwitcher:this.displayInLayerSwitcher});}
+this.mouseDragStart=null;this.map.div.style.cursor="default";}},defaultClick:function(evt){if(this.performedDrag){this.performedDrag=false;return false;}},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;OpenLayers.Protocol.WFS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFS.v1_0_0"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:'_layer',featureIdentifier:'_feature',regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},gmlFormat:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,arguments);OpenLayers.Util.extend(this,options);this.options=options;},read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;if(root){var scope=this;var read=this["read_"+root.nodeName];if(read){result=read.call(this,root);}else{result=new OpenLayers.Format.GML((this.options?this.options:{})).read(data);}}else{result=data;}
+return result;},read_msGMLOutput:function(data){var response=[];var layerNodes=this.getSiblingNodesByTagCriteria(data,this.layerIdentifier);if(layerNodes){for(var i=0,len=layerNodes.length;i<len;++i){var node=layerNodes[i];var layerName=node.nodeName;if(node.prefix){layerName=layerName.split(':')[1];}
+var layerName=layerName.replace(this.layerIdentifier,'');var featureNodes=this.getSiblingNodesByTagCriteria(node,this.featureIdentifier);if(featureNodes){for(var j=0;j<featureNodes.length;j++){var featureNode=featureNodes[j];var geomInfo=this.parseGeometry(featureNode);var attributes=this.parseAttributes(featureNode);var feature=new OpenLayers.Feature.Vector(geomInfo.geometry,attributes,null);feature.bounds=geomInfo.bounds;feature.type=layerName;response.push(feature);}}}}
+return response;},read_FeatureInfoResponse:function(data){var response=[];var featureNodes=this.getElementsByTagNameNS(data,'*','FIELDS');for(var i=0,len=featureNodes.length;i<len;i++){var featureNode=featureNodes[i];var geom=null;var attributes={};for(var j=0,jlen=featureNode.attributes.length;j<jlen;j++){var attribute=featureNode.attributes[j];attributes[attribute.nodeName]=attribute.nodeValue;}
+response.push(new OpenLayers.Feature.Vector(geom,attributes,null));}
+return response;},getSiblingNodesByTagCriteria:function(node,criteria){var nodes=[];var children,tagName,n,matchNodes,child;if(node&&node.hasChildNodes()){children=node.childNodes;n=children.length;for(var k=0;k<n;k++){child=children[k];while(child&&child.nodeType!=1){child=child.nextSibling;k++;}
+tagName=(child?child.nodeName:'');if(tagName.length>0&&tagName.indexOf(criteria)>-1){nodes.push(child);}else{matchNodes=this.getSiblingNodesByTagCriteria(child,criteria);if(matchNodes.length>0){(nodes.length==0)?nodes=matchNodes:nodes.push(matchNodes);}}}}
+return nodes;},parseAttributes:function(node){var attributes={};if(node.nodeType==1){var children=node.childNodes;var n=children.length;for(var i=0;i<n;++i){var child=children[i];if(child.nodeType==1){var grandchildren=child.childNodes;if(grandchildren.length==1){var grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
+return attributes;},parseGeometry:function(node){if(!this.gmlFormat){this.gmlFormat=new OpenLayers.Format.GML();}
+var feature=this.gmlFormat.parseFeature(node);var geometry,bounds=null;if(feature){geometry=feature.geometry&&feature.geometry.clone();bounds=feature.bounds&&feature.bounds.clone();feature.destroy();}
+return{geometry:geometry,bounds:bounds};},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Control.WMTSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,requestEncoding:"KVP",drillDown:false,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:true,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,EVENT_TYPES:["beforegetfeatureinfo","getfeatureinfo","exception"],pending:0,initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.WMTSGetFeatureInfo.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options=options||{};options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
+if(this.drillDown===true){this.hover=false;}
+if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},getInfoForClick:function(evt){this.request(evt.xy,{});},getInfoForHover:function(evt){this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
+this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer;for(var i=candidates.length-1;i>=0;--i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMTS&&layer.requestEncoding===this.requestEncoding&&(!this.queryVisible||layer.getVisibility())){layers.push(layer);if(!this.drillDown||this.hover){break;}}}
+return layers;},buildRequestOptions:function(layer,xy){var loc=this.map.getLonLatFromPixel(xy);var getTileUrl=layer.getURL(new OpenLayers.Bounds(loc.lon,loc.lat,loc.lon,loc.lat));var params=OpenLayers.Util.getParameters(getTileUrl);var tileInfo=layer.getTileInfo(loc);OpenLayers.Util.extend(params,{service:"WMTS",version:layer.version,request:"GetFeatureInfo",infoFormat:this.infoFormat,i:tileInfo.i,j:tileInfo.j});OpenLayers.Util.applyDefaults(params,this.vendorParams);return{url:layer.url instanceof Array?layer.url[0]:layer.url,params:OpenLayers.Util.upperCaseObject(params),callback:function(request){this.handleResponse(xy,request,layer);},scope:this};},request:function(xy,options){options=options||{};var layers=this.findLayers();if(layers.length>0){var issue,layer;for(var i=0,len=layers.length;i<len;i++){layer=layers[i];issue=this.events.triggerEvent("beforegetfeatureinfo",{xy:xy,layer:layer});if(issue!==false){++this.pending;var requestOptions=this.buildRequestOptions(layer
+if(this.pending>0){OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");}}},handleResponse:function(xy,request,layer){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
+if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("exception",{xy:xy,request:request,layer:layer});}else{var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+var features,except;try{features=this.format.read(doc);}catch(error){except=true;this.events.triggerEvent("exception",{xy:xy,request:request,error:error,layer:layer});}
+if(!except){this.events.triggerEvent("getfeatureinfo",{text:request.responseText,features:features,request:request,xy:xy,layer:layer});}}},CLASS_NAME:"OpenLayers.Control.WMTSGetFeatureInfo"});OpenLayers.Format.WMSCapabilities.v1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMT_MS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Keyword":function(node,obj){if(obj.keywords){obj.keywords.push(this.getChildValue(node));}},"DescribeLayer":function(node,obj){obj.describelayer={formats:[]};this.readChildNodes(node,obj.describelayer);},"GetLegendGraphic":function(node,obj){obj.getlegendgraphic={formats:[]};this.readChildNodes(node,obj.getlegendgraphic);},"GetStyles":function(node,obj){obj.getstyles={formats:[]};this.readChildNodes(node,obj.getstyles);},"PutStyles":function(node,obj){obj.putstyles={formats:[]};this.readChildNodes(node,obj.putstyles);},"UserDefinedSymbolization":function(node,obj){var userSymb
 ols={supportSLD:parseInt(node.getAttribute("SupportSLD"))==1,userLayer:parseInt(node.getAttribute("UserLayer"))==1,userStyle:parseInt(node.getAttribute("UserStyle"))==1,remoteWFS:parseInt(node.getAttribute("RemoteWFS"))==1};obj.userSymbols=userSymbols;},"LatLonBoundingBox":function(node,obj){obj.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("SRS");obj.bbox[bbox.srs]=bbox;},"ScaleHint":function(node,obj){var min=node.getAttribute("min");var max=node.getAttribute("max");var rad2=Math.pow(2,0.5);var ipm=OpenLayers.INCHES_PER_UNIT["m"];obj.maxScale=parseFloat(((min/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecision(13));obj.minScale=parseFloat(((max/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecision(13));},
 "Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol")};obj.dimensions[dim.name]=dim;},"Extent":function(node,obj){var name=node.getAttribute("name").toLowerCase();if(name in obj["dimensions"]){var extent=obj.dimensions[name];extent.nearestVal=node.getAttribute("nearestValue")==="1";extent.multipleVal=node.getAttribute("multipleValues")==="1";extent.current=node.getAttribute("current")==="1";extent["default"]=node.getAttribute("default")||"";var values=this.getChildValue(node);extent.values=values.split(",");}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);},drawMarker:function(marker){var bounds=marker.bounds;var toplef
 t=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.left,bounds.top));var botright=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.right,bounds.bottom));if(botright==null||topleft==null){marker.display(false);}else{var sz=new OpenLayers.Size(Math.max(1,botright.x-topleft.x),Math.max(1,botright.y-topleft.y));var markerDiv=marker.draw(topleft,sz);if(!marker.drawn){this.div.appendChild(markerDiv);marker.drawn=true;}}},removeMarker:function(marker){OpenLayers.Util.removeItem(this.markers,marker);if((marker.div!=null)&&(marker.div.parentNode==this.div)){this.div.removeChild(marker.div);}},CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Control.Graticule=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,intervals:[45,30,20,10,5,2,1,0.5,0.2,0.1,0.05,0.01,0.005,0.002,0.001],displayInLayerSwitcher:true,visible:true,numPoints:50,targetSize:200,layerName:null,labelled:true,labelFormat:'dm',lineSymbolizer:{strokeColor:"#333",strokeWidth:1,strokeOpacity:0.5},lab
 elSymbolizer:{},gratLayer:null,initialize:function(options){options=options||{};options.layerName=options.layerName||OpenLayers.i18n("graticule");OpenLayers.Control.prototype.initialize.apply(this,[options]);this.labelSymbolizer.stroke=false;this.labelSymbolizer.fill=false;this.labelSymbolizer.label="${label}";this.labelSymbolizer.labelAlign="${labelAlign}";this.labelSymbolizer.labelXOffset="${xOffset}";this.labelSymbolizer.labelYOffset="${yOffset}";},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.gratLayer){this.gratLayer.destroy();this.gratLayer=null;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.gratLayer){var gratStyle=new OpenLayers.Style({},{rules:[new OpenLayers.Rule({'symbolizer':{"Point":this.labelSymbolizer,"Line":this.lineSymbolizer}})]});this.gratLayer=new OpenLayers.Layer.Vector(this.layerName,{styleMap:new OpenLayers.StyleMap({'default':gratStyle}),visibility:this.visi
 return this.div;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.map.addLayer(this.gratLayer);this.map.events.register('moveend',this,this.update);this.update();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.map.events.unregister('moveend',this,this.update);this.map.removeLayer(this.gratLayer);return true;}else{return false;}},update:function(){var mapBounds=this.map.getExtent();if(!mapBounds){return;}
 this.gratLayer.destroyFeatures();var llProj=new OpenLayers.Projection("EPSG:4326");var mapProj=this.map.getProjectionObject();var mapRes=this.map.getResolution();if(mapProj.proj&&mapProj.proj.projName=="longlat"){this.numPoints=1;}
 var mapCenter=this.map.getCenter();var mapCenterLL=new OpenLayers.Pixel(mapCenter.lon,mapCenter.lat);OpenLayers.Projection.transform(mapCenterLL,mapProj,llProj);var testSq=this.targetSize*mapRes;testSq*=testSq;var llInterval;for(var i=0;i<this.intervals.length;++i){llInterval=this.intervals[i];var delta=llInterval/2;var p1=mapCenterLL.offset(new OpenLayers.Pixel(-delta,-delta));var p2=mapCenterLL.offset(new OpenLayers.Pixel(delta,delta));OpenLayers.Projection.transform(p1,llProj,mapProj);OpenLayers.Projection.transform(p2,llProj,mapProj);var distSq=(p1.x-p2.x)*(p1.x-p2.x)+(p1.y-p2.y)*(p1.y-p2.y);if(distSq<=testSq){break;}}
@@ -2490,23 +2523,7 @@
 var pointList=[];var lonStart=centerLatPoints[0].x;var lonEnd=centerLatPoints[centerLatPoints.length-1].x;var lonDelta=(lonEnd-lonStart)/this.numPoints;var lon=lonStart;var labelPoint=null;for(var i=0;i<=this.numPoints;++i){var gridPoint=new OpenLayers.Geometry.Point(lon,lat);gridPoint.transform(llProj,mapProj);pointList.push(gridPoint);lon+=lonDelta;if(gridPoint.x<mapBounds.right){labelPoint=gridPoint;}}
 if(this.labelled){var labelPos=new OpenLayers.Geometry.Point(mapBounds.right,labelPoint.y);var labelAttrs={value:lat,label:this.labelled?OpenLayers.Util.getFormattedLonLat(lat,"lat",this.labelFormat):"",labelAlign:"rb",xOffset:-2,yOffset:2};this.gratLayer.addFeatures(new OpenLayers.Feature.Vector(labelPos,labelAttrs));}
 var geom=new OpenLayers.Geometry.LineString(pointList);lines.push(new OpenLayers.Feature.Vector(geom));}
-this.gratLayer.addFeatures(lines);},CLASS_NAME:"OpenLayers.Control.Graticule"});OpenLayers.Layer.WMS.Post=OpenLayers.Class(OpenLayers.Layer.WMS,{unsupportedBrowsers:["mozilla","firefox","opera"],SUPPORTED_TRANSITIONS:[],usePost:null,initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.WMS.prototype.initialize.apply(this,newArguments);this.usePost=OpenLayers.Util.indexOf(this.unsupportedBrowsers,OpenLayers.BROWSER_NAME)==-1;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,{maxGetUrlLength:this.usePost?0:null});},CLASS_NAME:'OpenLayers.Layer.WMS.Post'});OpenLayers.Control.TransformFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesetfeature","setfeature","beforetransform","transform","transformcomplete"],geometryTypes:null,layer:null,preserveAspectRatio:false,rotate:true,feature:null,renderIntent:"temporary",rotationHandleSymbolizer
 :null,box:null,center:null,scale:1,ratio:1,rotation:0,handles:null,rotationHandles:null,dragControl:null,initialize:function(layer,options){this.EVENT_TYPES=OpenLayers.Control.TransformFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;if(!this.rotationHandleSymbolizer){this.rotationHandleSymbolizer={stroke:false,pointRadius:10,fillOpacity:0,cursor:"pointer"};}
-this.createBox();this.createControl();},activate:function(){var activated=false;if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragControl.activate();this.layer.addFeatures([this.box]);this.rotate&&this.layer.addFeatures(this.rotationHandles);this.layer.addFeatures(this.handles);activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.handles);this.rotate&&this.layer.removeFeatures(this.rotationHandles);this.layer.removeFeatures([this.box]);this.dragControl.deactivate();deactivated=true;}
-return deactivated;},setMap:function(map){this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},setFeature:function(feature,initialParams){initialParams=OpenLayers.Util.applyDefaults(initialParams,{rotation:0,scale:1,ratio:1});var evt={feature:feature};var oldRotation=this.rotation;var oldCenter=this.center;OpenLayers.Util.extend(this,initialParams);if(this.events.triggerEvent("beforesetfeature",evt)===false){return;}
-this.feature=feature;this.activate();this._setfeature=true;var featureBounds=this.feature.geometry.getBounds();this.box.move(featureBounds.getCenterLonLat());this.box.geometry.rotate(-oldRotation,oldCenter);this._angle=0;var ll;if(this.rotation){var geom=feature.geometry.clone();geom.rotate(-this.rotation,this.center);var box=new OpenLayers.Feature.Vector(geom.getBounds().toGeometry());box.geometry.rotate(this.rotation,this.center);this.box.geometry.rotate(this.rotation,this.center);this.box.move(box.geometry.getBounds().getCenterLonLat());var llGeom=box.geometry.components[0].components[0];ll=llGeom.getBounds().getCenterLonLat();}else{ll=new OpenLayers.LonLat(featureBounds.left,featureBounds.bottom);}
-this.handles[0].move(ll);delete this._setfeature;this.events.triggerEvent("setfeature",evt);},createBox:function(){var control=this;this.center=new OpenLayers.Geometry.Point(0,0);var box=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([new OpenLayers.Geometry.Point(-1,-1),new OpenLayers.Geometry.Point(0,-1),new OpenLayers.Geometry.Point(1,-1),new OpenLayers.Geometry.Point(1,0),new OpenLayers.Geometry.Point(1,1),new OpenLayers.Geometry.Point(0,1),new OpenLayers.Geometry.Point(-1,1),new OpenLayers.Geometry.Point(-1,0),new OpenLayers.Geometry.Point(-1,-1)]),null,typeof this.renderIntent=="string"?null:this.renderIntent);box.geometry.move=function(x,y){control._moving=true;OpenLayers.Geometry.LineString.prototype.move.apply(this,arguments);control.center.move(x,y);delete control._moving;};var vertexMoveFn=function(x,y){OpenLayers.Geometry.Point.prototype.move.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.move(x,y);this._handle.geometr
 y.move(x,y);};var vertexResizeFn=function(scale,center,ratio){OpenLayers.Geometry.Point.prototype.resize.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.resize(scale,center,ratio);this._handle.geometry.resize(scale,center,ratio);};var vertexRotateFn=function(angle,center){OpenLayers.Geometry.Point.prototype.rotate.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.rotate(angle,center);this._handle.geometry.rotate(angle,center);};var handleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
-var evt=control.dragControl.handlers.drag.evt;var preserveAspectRatio=!control._setfeature&&control.preserveAspectRatio;var reshape=!preserveAspectRatio&&!(evt&&evt.shiftKey);var oldGeom=new OpenLayers.Geometry.Point(oldX,oldY);var centerGeometry=control.center;this.rotate(-control.rotation,centerGeometry);oldGeom.rotate(-control.rotation,centerGeometry);var dx1=this.x-centerGeometry.x;var dy1=this.y-centerGeometry.y;var dx0=dx1-(this.x-oldGeom.x);var dy0=dy1-(this.y-oldGeom.y);this.x=oldX;this.y=oldY;var scale,ratio=1;if(reshape){scale=Math.abs(dy0)<0.00001?1:dy1/dy0;ratio=(Math.abs(dx0)<0.00001?1:(dx1/dx0))/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
-control._moving=true;control.box.geometry.rotate(-control.rotation,centerGeometry);delete control._moving;control.box.geometry.resize(scale,centerGeometry,ratio);control.box.geometry.rotate(control.rotation,centerGeometry);control.transformFeature({scale:scale,ratio:ratio});};var rotationHandleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
-var evt=control.dragControl.handlers.drag.evt;var constrain=(evt&&evt.shiftKey)?45:1;var centerGeometry=control.center;var dx1=this.x-centerGeometry.x;var dy1=this.y-centerGeometry.y;var dx0=dx1-x;var dy0=dy1-y;this.x=oldX;this.y=oldY;var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;control._angle=(control._angle+angle)%360;var diff=control.rotation%constrain;if(Math.abs(control._angle)>=constrain||diff!==0){angle=Math.round(control._angle/constrain)*constrain-
-diff;control._angle=0;control.box.geometry.rotate(angle,centerGeometry);control.transformFeature({rotation:angle});}};var handles=new Array(8);var rotationHandles=new Array(4);var geom,handle,rotationHandle;for(var i=0;i<8;++i){geom=box.geometry.components[i];handle=new OpenLayers.Feature.Vector(geom.clone(),null,typeof this.renderIntent=="string"?null:this.renderIntent);if(i%2==0){rotationHandle=new OpenLayers.Feature.Vector(geom.clone(),null,typeof this.rotationHandleSymbolizer=="string"?null:this.rotationHandleSymbolizer);rotationHandle.geometry.move=rotationHandleMoveFn;geom._rotationHandle=rotationHandle;rotationHandles[i/2]=rotationHandle;}
-geom.move=vertexMoveFn;geom.resize=vertexResizeFn;geom.rotate=vertexRotateFn;handle.geometry.move=handleMoveFn;geom._handle=handle;handles[i]=handle;}
-this.box=box;this.rotationHandles=rotationHandles;this.handles=handles;},createControl:function(){var control=this;this.dragControl=new OpenLayers.Control.DragFeature(this.layer,{documentDrag:true,moveFeature:function(pixel){if(this.feature===control.feature){this.feature=control.box;}
-OpenLayers.Control.DragFeature.prototype.moveFeature.apply(this,arguments);},onDrag:function(feature,pixel){if(feature===control.box){control.transformFeature({center:control.center});control.drawHandles();}},onStart:function(feature,pixel){var eligible=!control.geometryTypes||OpenLayers.Util.indexOf(control.geometryTypes,feature.geometry.CLASS_NAME)!==-1;var i=OpenLayers.Util.indexOf(control.handles,feature);i+=OpenLayers.Util.indexOf(control.rotationHandles,feature);if(feature!==control.feature&&feature!==control.box&&i==-2&&eligible){control.setFeature(feature);}},onComplete:function(feature,pixel){control.events.triggerEvent("transformcomplete",{feature:control.feature});}});},drawHandles:function(){var layer=this.layer;for(var i=0;i<8;++i){if(this.rotate&&i%2===0){layer.drawFeature(this.rotationHandles[i/2],this.rotationHandleSymbolizer);}
-layer.drawFeature(this.handles[i],this.renderIntent);}},transformFeature:function(mods){if(!this._setfeature){this.scale*=(mods.scale||1);this.ratio*=(mods.ratio||1);var oldRotation=this.rotation;this.rotation=(this.rotation+(mods.rotation||0))%360;if(this.events.triggerEvent("beforetransform",mods)!==false){var feature=this.feature;var geom=feature.geometry;var center=this.center;geom.rotate(-oldRotation,center);if(mods.scale||mods.ratio){geom.resize(mods.scale,center,mods.ratio);}else if(mods.center){feature.move(mods.center.getBounds().getCenterLonLat());}
-geom.rotate(this.rotation,center);this.layer.drawFeature(feature);feature.toState(OpenLayers.State.UPDATE);this.events.triggerEvent("transform",mods);}}
-this.layer.drawFeature(this.box,this.renderIntent);this.drawHandles();},destroy:function(){var geom;for(var i=0;i<8;++i){geom=this.box.geometry.components[i];geom._handle.destroy();geom._handle=null;geom._rotationHandle&&geom._rotationHandle.destroy();geom._rotationHandle=null;}
-this.box.destroy();this.box=null;this.layer=null;this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.TransformFeature"});OpenLayers.Control.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,drillDown:false,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:false,url:null,layerUrls:null,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,EVENT_TYPES:["beforegetfeatureinfo","nogetfeatureinfo","getfeatureinfo"],initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.WMSGetFeatureInfo.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options=options||{};options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
+this.gratLayer.addFeatures(lines);},CLASS_NAME:"OpenLayers.Control.Graticule"});OpenLayers.Layer.WMS.Post=OpenLayers.Class(OpenLayers.Layer.WMS,{unsupportedBrowsers:["mozilla","firefox","opera"],SUPPORTED_TRANSITIONS:[],usePost:null,initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.WMS.prototype.initialize.apply(this,newArguments);this.usePost=OpenLayers.Util.indexOf(this.unsupportedBrowsers,OpenLayers.BROWSER_NAME)==-1;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,{maxGetUrlLength:this.usePost?0:null});},CLASS_NAME:'OpenLayers.Layer.WMS.Post'});OpenLayers.Control.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,drillDown:false,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:false,url:null,layerUrls:null,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,ho
 if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{'move':this.cancelHover,'pause':this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{'delay':250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},activate:function(){if(!this.active){this.handler.activate();}
 return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},getInfoForClick:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");this.request(evt.xy,{});},getInfoForHover:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer,url;for(var i=0,len=candidates.length;i<len;++i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMS&&(!this.queryVisible||layer.getVisibility())){url=layer.url instanceof Array?layer.url[0]:layer.url;if(this.drillDown===false&&!this.url){this.url=url;}
@@ -2572,25 +2589,16 @@
 this.layer.destroyFeatures(destroys,{silent:true});for(var i=0,len=additions.length;i<len;++i){additions[i].state=OpenLayers.State.INSERT;}}else{this.layer.destroyFeatures(removals,{silent:true});}
 this.layer.addFeatures(additions,{silent:true});this.events.triggerEvent("aftersplit",{source:feature,features:additions});}}
 return sourceSplit;},geomsToFeatures:function(feature,geoms){var clone=feature.clone();delete clone.geometry;var newFeature;for(var i=0,len=geoms.length;i<len;++i){newFeature=clone.clone();newFeature.geometry=geoms[i];newFeature.state=OpenLayers.State.INSERT;geoms[i]=newFeature;}},destroy:function(){if(this.active){this.deactivate();}
-OpenLayers.Control.prototype.destroy.call(this);},CLASS_NAME:"OpenLayers.Control.Split"});OpenLayers.Layer.KaMapCache=OpenLayers.Class(OpenLayers.Layer.KaMap,{IMAGE_EXTENSIONS:{'jpeg':'jpg','gif':'gif','png':'png','png8':'png','png24':'png','dithered':'png'},DEFAULT_FORMAT:'jpeg',initialize:function(name,url,params,options){OpenLayers.Layer.KaMap.prototype.initialize.apply(this,arguments);this.extension=this.IMAGE_EXTENSIONS[this.params.i.toLowerCase()||DEFAULT_FORMAT];},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);var metaX=Math.floor(pX/this.tileSize.w/this.params.metaTileSize.w)*this.tileSize.w*this.params.metaTileSize.w;var metaY=Math.floor(pY/this.tileSize.h/this.params.metaTileSize.h)*this.tileSize.h*this.params.metaTileSize.h;var url=this.url;if(url instanceof Array){url=this.selectUrl(param
 sString,url);}
-var components=[url,"/",this.params.map,"/",scale,"/",this.params.g.replace(/\s/g,'_'),"/def/t",metaY,"/l",metaX,"/t",pY,"l",pX,".",this.extension];return components.join("");},CLASS_NAME:"OpenLayers.Layer.KaMapCache"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(options){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat){if(this.outputFormat.toLowerCase()=="gml2"){this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});}else if(this.outputFormat.toLowerCase()=="json"){this.readFormat=new OpenLayers.Format.GeoJSON();}}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoombarDiv:null,divEvents:null,zoomWorldIcon:false,forceFixedZoomLevel:fa
 lse,mouseDragStart:null,deltaY:null,zoomStart:null,initialize:function(){OpenLayers.Control.PanZoom.prototype.initialize.apply(this,arguments);},destroy:function(){this._removeZoomBar();this.map.events.un({"changebaselayer":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);delete this.mouseDragStart;delete this.zoomStart;},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.register("changebaselayer",this,this.redraw);},redraw:function(){if(this.div!=null){this.removeButtons();this._removeZoomBar();}
-this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
-this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
-this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImagesLocation();var id=this.id+"_"+this.map.id;var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),new OpenLayers.Size(20,9),imgLocation+"slider.png","absolute");slider.style.cursor="move";this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true,{includeXY:true});this.sliderEvents.on({"touchstart":this.zoomBarDown,"touchmove":this.zoomBarDrag,"touchend":this.zoomBarUp,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.z
 oomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});var sz=new OpenLayers.Size();sz.h=this.zoomStopHeight*this.map.getNumZoomLevels();sz.w=this.zoomStopWidth;var div=null;if(OpenLayers.Util.alphaHack()){var id=this.id+"_"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,new OpenLayers.Size(sz.w,this.zoomStopHeight),imgLocation+"zoombar.png","absolute",null,"crop");div.style.height=sz.h+"px";}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation+"zoombar.png");}
-div.style.cursor="pointer";this.zoombarDiv=div;this.divEvents=new OpenLayers.Events(this,div,null,true,{includeXY:true});this.divEvents.on({"touchmove":this.passEventToSlider,"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*this.map.getNumZoomLevels());return centered;},_removeZoomBar:function(){this.sliderEvents.un({"touchmove":this.zoomBarDrag,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});this.sliderEvents.destroy();this.divEvents.un({"touchmove":this.passEventToSlider,"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.divEvents.destroy();this.div.removeChi
 ld(this.zoombarDiv);this.zoombarDiv=null;this.div.removeChild(this.slider);this.slider=null;this.map.events.unregister("zoomend",this,this.moveZoomBar);},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},divClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var levels=evt.xy.y/this.zoomStopHeight;if(this.forceFixedZoomLevel||!this.map.fractionalZoom){levels=Math.floor(levels);}
-var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);OpenLayers.Event.stop(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&!OpenLayers.Event.isSingleTouch(evt)){return;}
-this.map.events.on({"touchmove":this.passEventToSlider,"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";this.mouseDragStart=evt.xy.clone();}
-this.deltaY=this.zoomStart.y-evt.xy.y;OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&evt.type!=="touchend"){return;}
-if(this.mouseDragStart){this.div.style.cursor="";this.map.events.un({"touchmove":this.passEventToSlider,"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var zoomLevel=this.map.zoom;if(!this.forceFixedZoomLevel&&this.map.fractionalZoom){zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.max(Math.round(zoomLevel),0);}
-this.map.zoomTo(zoomLevel);this.mouseDragStart=null;this.zoomStart=null;this.deltaY=0;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,format:'image/png',serverResolutions:null,initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this.extension=this.format.split('/')[1].toLowerCase();this.extension=(this.extension=='jpg')?'jpeg':this.extension;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.getOptions());}
+OpenLayers.Control.prototype.destroy.call(this);},CLASS_NAME:"OpenLayers.Control.Split"});OpenLayers.Protocol.SOS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol,{fois:null,formatOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.format){this.format=new OpenLayers.Format.SOSGetFeatureOfInterest(this.formatOptions);}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
+this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var format=this.format;var data=OpenLayers.Format.XML.prototype.write.apply(format,[format.writeNode("sos:GetFeatureOfInterest",{fois:this.fois})]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),data:data});return response;},handleRead:function(response,options){if(options.callback){var request=response.priv;if(request.status>=200&&request.status<300){response.features=this.parseFeatures(request);response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
+options.callback.call(options.scope,response);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+if(!doc||doc.length<=0){return null;}
+return this.format.read(doc);},CLASS_NAME:"OpenLayers.Protocol.SOS.v1_0_0"});OpenLayers.Layer.KaMapCache=OpenLayers.Class(OpenLayers.Layer.KaMap,{IMAGE_EXTENSIONS:{'jpeg':'jpg','gif':'gif','png':'png','png8':'png','png24':'png','dithered':'png'},DEFAULT_FORMAT:'jpeg',initialize:function(name,url,params,options){OpenLayers.Layer.KaMap.prototype.initialize.apply(this,arguments);this.extension=this.IMAGE_EXTENSIONS[this.params.i.toLowerCase()||DEFAULT_FORMAT];},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);var metaX=Math.floor(pX/this.tileSize.w/this.params.metaTileSize.w)*this.tileSize.w*this.params.metaTileSize.w;var metaY=Math.floor(pY/this.tileSize.h/this.params.metaTileSize.h)*this.tileSize.h*this.params.metaTileSize.h;var url=this.url;if(url instanceof Array){url=this.selectUrl(paramsString,url);
+var components=[url,"/",this.params.map,"/",scale,"/",this.params.g.replace(/\s/g,'_'),"/def/t",metaY,"/l",metaX,"/t",pY,"l",pX,".",this.extension];return components.join("");},CLASS_NAME:"OpenLayers.Layer.KaMapCache"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(options){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat){if(this.outputFormat.toLowerCase()=="gml2"){this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});}else if(this.outputFormat.toLowerCase()=="json"){this.readFormat=new OpenLayers.Format.GeoJSON();}}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,format:'image/png',serverResolutions:null,initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Lay
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var res=this.map.getResolution();var bbox=this.maxExtent;var size=this.tileSize;var tileX=Math.round((bounds.left-bbox.left)/(res*size.w));var tileY=Math.round((bounds.bottom-bbox.bottom)/(res*size.h));var tileZ=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom();function zeroPad(number,length){number=String(number);var zeros=[];for(var i=0;i<length;++i){zeros.push('0');}
 return zeros.join('').substring(0,length-number.length)+number;}
 var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Format.WMSCapabilities.v1_1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.1",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.applyDefaults({"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1"});OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1_1,{version:"1.1.1",profile:"WMSC",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.
 applyDefaults({"VendorSpecificCapabilities":function(node,obj){obj.vendorSpecific={tileSets:[]};this.readChildNodes(node,obj.vendorSpecific);},"TileSet":function(node,vendorSpecific){var tileset={srs:{},bbox:{},resolutions:[]};this.readChildNodes(node,tileset);vendorSpecific.tileSets.push(tileset);},"Resolutions":function(node,tileset){var res=this.getChildValue(node).split(" ");for(var i=0,len=res.length;i<len;i++){if(res[i]!=""){tileset.resolutions.push(parseFloat(res[i]));}}},"Width":function(node,tileset){tileset.width=parseInt(this.getChildValue(node));},"Height":function(node,tileset){tileset.height=parseInt(this.getChildValue(node));},"Layers":function(node,tileset){tileset.layers=this.getChildValue(node);},"Styles":function(node,tileset){tileset.styles=this.getChildValue(node);}},OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC"});OpenLayers.Format.WMSCapabilities.v1_1_0=OpenLayers.Class(Ope
 nLayers.Format.WMSCapabilities.v1_1,{version:"1.1.0",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.applyDefaults({"SRS":function(node,obj){var srs=this.getChildValue(node);var values=srs.split(/ +/);for(var i=0,len=values.length;i<len;i++){obj.srs[values[i]]=true;}}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_0"});OpenLayers.Format.WMTSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1_1_0,{version:"1.0.0",namespaces:{ows:"http://www.opengis.net/ows/1.1",wmts:"http://www.opengis.net/wmts/1.0",xlink:"http://www.w3.org/1999/xlink"},yx:null,defaultPrefix:"wmts",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;var yx=OpenLayers.Util.extend({},OpenLayers.Format.WMTSCapabilities.prototype.yx);this.yx=OpenLayers.Util.extend(yx,this
 .yx);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var capabilities={};this.readNode(data,capabilities);capabilities.version=this.version;return capabilities;},readers:{"wmts":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};obj.contents.layers=[];obj.contents.tileMatrixSets={};this.readChildNodes(node,obj.contents);},"Layer":function(node,obj){var layer={styles:[],formats:[],tileMatrixSetLinks:[]};layer.layers=[];this.readChildNodes(node,layer);obj.layers.push(layer);},"Style":function(node,obj){var style={};style.isDefault=(node.getAttribute("isDefault")==="true");this.readChildNodes(node,style);obj.styles.push(style);},"Format":function(node,obj){obj.formats.push(this.getChildValue(node));},"TileMatrixSetLink":function(node,obj){var tileMatrixSetLink={};this.readChildNodes(node,tileMatrixSetLink);obj.tileMatrixSetLinks.push(tileMatrixSetLink);},"TileMatrixSet":function(node,obj){if(obj.layers){var tileMatrixSet={matrixIds:[]};this.readChildNodes(node,tileMatr
 ixSet);obj.tileMatrixSets[tileMatrixSet.identifier]=tileMatrixSet;}else{obj.tileMatrixSet=this.getChildValue(node);}},"TileMatrix":function(node,obj){var tileMatrix={supportedCRS:obj.supportedCRS};this.readChildNodes(node,tileMatrix);obj.matrixIds.push(tileMatrix);},"ScaleDenominator":function(node,obj){obj.scaleDenominator=parseFloat(this.getChildValue(node));},"TopLeftCorner":function(node,obj){var topLeftCorner=this.getChildValue(node);var coords=topLeftCorner.split(" ");var yx;if(obj.supportedCRS){var crs=obj.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2");yx=!!this.yx[crs];}
-if(yx){obj.topLeftCorner=new OpenLayers.LonLat(coords[1],coords[0]);}else{obj.topLeftCorner=new OpenLayers.LonLat(coords[0],coords[1]);}},"TileWidth":function(node,obj){obj.tileWidth=parseInt(this.getChildValue(node));},"TileHeight":function(node,obj){obj.tileHeight=parseInt(this.getChildValue(node));},"MatrixWidth":function(node,obj){obj.matrixWidth=parseInt(this.getChildValue(node));},"MatrixHeight":function(node,obj){obj.matrixHeight=parseInt(this.getChildValue(node));},"ResourceURL":function(node,obj){obj.resourceUrl=obj.resourceUrl||{};obj.resourceUrl[node.getAttribute("resourceType")]={format:node.getAttribute("format"),template:node.getAttribute("template")};},"WSDL":function(node,obj){obj.wsdl={};obj.wsdl.href=node.getAttribute("xlink:href");},"ServiceMetadataURL":function(node,obj){obj.serviceMetadataUrl={};obj.serviceMetadataUrl.href=node.getAttribute("xlink:href");}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.W
 MTSCapabilities.v1_0_0"});OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector,OpenLayers.Layer.Markers,{isBaseLayer:false,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:true,encodeBBOX:false,extractAttributes:false,initialize:function(name,url,params,options){if(options==undefined){options={};}
+url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Format.WMSCapabilities.v1_1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.1",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.applyDefaults({"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1"});OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1_1,{version:"1.1.1",profile:"WMSC",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.
 nLayers.Format.WMSCapabilities.v1_1,{version:"1.1.0",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.applyDefaults({"SRS":function(node,obj){var srs=this.getChildValue(node);var values=srs.split(/ +/);for(var i=0,len=values.length;i<len;i++){obj.srs[values[i]]=true;}}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_0"});OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector,OpenLayers.Layer.Markers,{isBaseLayer:false,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:true,encodeBBOX:false,extractAttributes:false,initialize:function(name,url,params,options){if(options==undefined){options={};}
 if(options.featureClass||!OpenLayers.Layer.Vector||!OpenLayers.Feature.Vector){this.vectorMode=false;}
 params=OpenLayers.Util.upperCaseObject(params);OpenLayers.Util.extend(options,{'reportError':false});var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);if(!this.renderer||!this.vectorMode){this.vectorMode=false;if(!options.featureClass){options.featureClass=OpenLayers.Feature.WFS;}
 OpenLayers.Layer.Markers.prototype.initialize.apply(this,newArguments);}
@@ -2629,16 +2637,7 @@
 OpenLayers.Event.stop(e);},onLayerClick:function(e){this.updateMap();},updateMap:function(){for(var i=0,len=this.baseLayers.length;i<len;i++){var layerEntry=this.baseLayers[i];if(layerEntry.inputElem.checked){this.map.setBaseLayer(layerEntry.layer,false);}}
 for(var i=0,len=this.dataLayers.length;i<len;i++){var layerEntry=this.dataLayers[i];layerEntry.layer.setVisibility(layerEntry.inputElem.checked);}},maximizeControl:function(e){this.div.style.width="";this.div.style.height="";this.showControls(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);if(e!=null){OpenLayers.Event.stop(e);}},showControls:function(minimize){this.maximizeDiv.style.display=minimize?"":"none";this.minimizeDiv.style.display=minimize?"none":"";this.layersDiv.style.display=minimize?"none":"";},loadContents:function(){OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layers
 Div=document.createElement("div");this.layersDiv.id=this.id+"_layersDiv";OpenLayers.Element.addClass(this.layersDiv,"layersDiv");this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("baseLayer");OpenLayers.Element.addClass(this.baseLbl,"baseLbl");this.baseLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.baseLayersDiv,"baseLayersDiv");this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("overlays");OpenLayers.Element.addClass(this.dataLbl,"dataLbl");this.dataLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.dataLayersDiv,"dataLayersDiv");if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layers
 Div.appendChild(this.baseLayersDiv);}
 this.div.appendChild(this.layersDiv);if(this.roundedCorner){OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",bgColor:"transparent",color:this.roundedCornerColor,blend:false});OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75);}
-var imgLocation=OpenLayers.Util.getImagesLocation();var sz=new OpenLayers.Size(18,18);var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,sz,img,"absolute");OpenLayers.Element.addClass(this.maximizeDiv,"maximizeDiv");this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';var sz=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,sz,img,"absolute");OpenLayers.Element.addClass(this.minimizeDiv,"minimizeDiv");this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);},ignoreEvent:function(evt){OpenLayers.
 Event.stop(evt);},mouseDown:function(evt){this.isMouseDown=true;this.ignoreEvent(evt);},mouseUp:function(evt){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(evt);}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(options,layer){OpenLayers.Format.GML.prototype.initialize.apply(this,[options]);this.layer=layer;if(this.layer.featureNS){this.featureNS=this.layer.featureNS;}
-if(this.layer.options.geometry_column){this.geometryName=this.layer.options.geometry_column;}
-if(this.layer.options.typename){this.featureName=this.layer.options.typename;}},write:function(features){var transaction=this.createElementNS(this.wfsns,'wfs:Transaction');transaction.setAttribute("version","1.0.0");transaction.setAttribute("service","WFS");for(var i=0;i<features.length;i++){switch(features[i].state){case OpenLayers.State.INSERT:transaction.appendChild(this.insert(features[i]));break;case OpenLayers.State.UPDATE:transaction.appendChild(this.update(features[i]));break;case OpenLayers.State.DELETE:transaction.appendChild(this.remove(features[i]));break;}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[transaction]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var geomContainer=this.createElementNS(this.featureNS,"feature:"+this.geometryName);geomContainer.appendChild(geometryNode);var featureContainer=this.createElementNS(this.featureNS,"feature:"+this.featureName);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-return featureContainer;},insert:function(feature){var insertNode=this.createElementNS(this.wfsns,'wfs:Insert');insertNode.appendChild(this.createFeatureXML(feature));return insertNode;},update:function(feature){if(!feature.fid){OpenLayers.Console.userError(OpenLayers.i18n("noFID"));}
-var updateNode=this.createElementNS(this.wfsns,'wfs:Update');updateNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);updateNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var propertyNode=this.createElementNS(this.wfsns,'wfs:Property');var nameNode=this.createElementNS(this.wfsns,'wfs:Name');var txtNode=this.createTextNode(this.geometryName);nameNode.appendChild(txtNode);propertyNode.appendChild(nameNode);var valueNode=this.createElementNS(this.wfsns,'wfs:Value');var geometryNode=this.buildGeometryNode(feature.geometry);if(feature.layer){geometryNode.setAttribute("srsName",feature.layer.projection.getCode());}
-valueNode.appendChild(geometryNode);propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);for(var propName in feature.attributes){propertyNode=this.createElementNS(this.wfsns,'wfs:Property');nameNode=this.createElementNS(this.wfsns,'wfs:Name');nameNode.appendChild(this.createTextNode(propName));propertyNode.appendChild(nameNode);valueNode=this.createElementNS(this.wfsns,'wfs:Value');valueNode.appendChild(this.createTextNode(feature.attributes[propName]));propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);}
-var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);updateNode.appendChild(filterNode);return updateNode;},remove:function(feature){if(!feature.fid){OpenLayers.Console.userError(OpenLayers.i18n("noFID"));return false;}
-var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);deleteNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Format.Atom=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{atom:"http://www.w3.org/2005/Atom",georss:"http://www.georss.org/georss"},feedTitle:"untitled",defaultEntryTitle:"untitled",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+var imgLocation=OpenLayers.Util.getImagesLocation();var sz=new OpenLayers.Size(18,18);var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,sz,img,"absolute");OpenLayers.Element.addClass(this.maximizeDiv,"maximizeDiv");this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';var sz=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,sz,img,"absolute");OpenLayers.Element.addClass(this.minimizeDiv,"minimizeDiv");this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);},ignoreEvent:function(evt){OpenLayers.
 Event.stop(evt);},mouseDown:function(evt){this.isMouseDown=true;this.ignoreEvent(evt);},mouseUp:function(evt){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(evt);}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Format.Atom=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{atom:"http://www.w3.org/2005/Atom",georss:"http://www.georss.org/georss"},feedTitle:"untitled",defaultEntryTitle:"untitled",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
 return this.parseFeatures(doc);},write:function(features){var doc;if(features instanceof Array){doc=this.createElementNSPlus("atom:feed");doc.appendChild(this.createElementNSPlus("atom:title",{value:this.feedTitle}));for(var i=0,ii=features.length;i<ii;i++){doc.appendChild(this.buildEntryNode(features[i]));}}
 else{doc=this.buildEntryNode(features);}
 return OpenLayers.Format.XML.prototype.write.apply(this,[doc]);},buildContentNode:function(content){var node=this.createElementNSPlus("atom:content",{attributes:{type:content.type||null}});if(content.src){node.setAttribute("src",content.src);}else{if(content.type=="text"||content.type==null){node.appendChild(this.createTextNode(content.value));}else if(content.type=="html"){if(typeof content.value!="string"){throw"HTML content must be in form of an escaped string";}
@@ -2686,4 +2685,7 @@
 persons.push(value);}
 if(persons.length>0){data[name+"s"]=persons;}},CLASS_NAME:"OpenLayers.Format.Atom"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,slideFactor:75,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
 this.handler=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keydown":this.defaultKeyPress});},defaultKeyPress:function(evt){switch(evt.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.Feature.WFS=O
 penLayers.Class(OpenLayers.Feature,{initialize:function(layer,xmlNode){var newArguments=arguments;var data=this.processXMLNode(xmlNode);newArguments=new Array(layer,data.lonlat,data);OpenLayers.Feature.prototype.initialize.apply(this,newArguments);this.createMarker();this.layer.addMarker(this.marker);},destroy:function(){if(this.marker!=null){this.layer.removeMarker(this.marker);}
-OpenLayers.Feature.prototype.destroy.apply(this,arguments);},processXMLNode:function(xmlNode){var point=OpenLayers.Ajax.getElementsByTagNameNS(xmlNode,"http://www.opengis.net/gml","gml","Point");var text=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0],"http://www.opengis.net/gml","gml","coordinates")[0]);var floats=text.split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(floats[0]),parseFloat(floats[1])),id:null};},CLASS_NAME:"OpenLayers.Feature.WFS"});
\ No newline at end of file
+OpenLayers.Feature.prototype.destroy.apply(this,arguments);},processXMLNode:function(xmlNode){var point=OpenLayers.Ajax.getElementsByTagNameNS(xmlNode,"http://www.opengis.net/gml","gml","Point");var text=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0],"http://www.opengis.net/gml","gml","coordinates")[0]);var floats=text.split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(floats[0]),parseFloat(floats[1])),id:null};},CLASS_NAME:"OpenLayers.Feature.WFS"});OpenLayers.Format.WMTSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1_1_0,{version:"1.0.0",namespaces:{ows:"http://www.opengis.net/ows/1.1",wmts:"http://www.opengis.net/wmts/1.0",xlink:"http://www.w3.org/1999/xlink"},yx:null,defaultPrefix:"wmts",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;var yx=OpenLayers.Util.extend({},OpenLayers.Format.WMTSCapabilities.prototype.yx);this.yx=OpenLayers.Util.extend(
 yx,this.yx);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var capabilities={};this.readNode(data,capabilities);capabilities.version=this.version;return capabilities;},readers:{"wmts":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};obj.contents.layers=[];obj.contents.tileMatrixSets={};this.readChildNodes(node,obj.contents);},"Layer":function(node,obj){var layer={styles:[],formats:[],tileMatrixSetLinks:[]};layer.layers=[];this.readChildNodes(node,layer);obj.layers.push(layer);},"Style":function(node,obj){var style={};style.isDefault=(node.getAttribute("isDefault")==="true");this.readChildNodes(node,style);obj.styles.push(style);},"Format":function(node,obj){obj.formats.push(this.getChildValue(node));},"TileMatrixSetLink":function(node,obj){var tileMatrixSetLink={};this.readChildNodes(node,tileMatrixSetLink);obj.tileMatrixSetLinks.push(tileMatrixSetLink);},"TileMatrixSet":function(node,obj){if(obj.layers){var tileMatrixSet={matrixIds:[]};this.readChildNodes(node,tileMatr
+if(yx){obj.topLeftCorner=new OpenLayers.LonLat(coords[1],coords[0]);}else{obj.topLeftCorner=new OpenLayers.LonLat(coords[0],coords[1]);}},"TileWidth":function(node,obj){obj.tileWidth=parseInt(this.getChildValue(node));},"TileHeight":function(node,obj){obj.tileHeight=parseInt(this.getChildValue(node));},"MatrixWidth":function(node,obj){obj.matrixWidth=parseInt(this.getChildValue(node));},"MatrixHeight":function(node,obj){obj.matrixHeight=parseInt(this.getChildValue(node));},"ResourceURL":function(node,obj){obj.resourceUrl=obj.resourceUrl||{};obj.resourceUrl[node.getAttribute("resourceType")]={format:node.getAttribute("format"),template:node.getAttribute("template")};},"WSDL":function(node,obj){obj.wsdl={};obj.wsdl.href=node.getAttribute("xlink:href");},"ServiceMetadataURL":function(node,obj){obj.serviceMetadataUrl={};obj.serviceMetadataUrl.href=node.getAttribute("xlink:href");}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.W
More information about the Commits mailing list
