[OpenLayers-Commits] r11339 - in sandbox/bartvde/sencha/openlayers/examples: . img
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 10:53:53 EST 2011
Author: bartvde
Date: 2011-02-23 07:53:52 -0800 (Wed, 23 Feb 2011)
New Revision: 11339
Added:
   sandbox/bartvde/sencha/openlayers/examples/img/check-round-green.png
   sandbox/bartvde/sencha/openlayers/examples/img/check-round-grey.png
   sandbox/bartvde/sencha/openlayers/examples/img/check-square-green.png
   sandbox/bartvde/sencha/openlayers/examples/img/check-square-grey.png
   sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.js
   sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.html
   sandbox/bartvde/sencha/openlayers/examples/mobile.js
more work on Sencha example, now has layer switcher
Added: sandbox/bartvde/sencha/openlayers/examples/img/check-round-green.png
(Binary files differ)
Property changes on: sandbox/bartvde/sencha/openlayers/examples/img/check-round-green.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: sandbox/bartvde/sencha/openlayers/examples/img/check-round-grey.png
Property changes on: sandbox/bartvde/sencha/openlayers/examples/img/check-round-grey.png
Added: sandbox/bartvde/sencha/openlayers/examples/img/check-square-green.png
Property changes on: sandbox/bartvde/sencha/openlayers/examples/img/check-square-green.png
Added: sandbox/bartvde/sencha/openlayers/examples/img/check-square-grey.png
Property changes on: sandbox/bartvde/sencha/openlayers/examples/img/check-square-grey.png
Modified: sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.html
--- sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.html	2011-02-23 15:50:48 UTC (rev 11338)
+++ sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.html	2011-02-23 15:53:52 UTC (rev 11339)
@@ -6,9 +6,12 @@
         <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
         <title>OpenLayers with Sencha Touch</title>
         <script src="../lib/OpenLayers.js"></script>
+        <script src="http://maps.google.com/maps/api/js?v=3.3&amp;sensor=false"></script>
         <link rel="stylesheet" href="style.mobile.css" type="text/css">
         <link rel="stylesheet" href="http://dev.sencha.com/deploy/touch/resources/css/sencha-touch.css">
+        <link rel="stylesheet" href="../theme/default/google.css" type="text/css">
         <script src="http://dev.sencha.com/deploy/touch/sencha-touch.js"></script>
+        <script src="mobile-sencha.js"></script>
         <script src="mobile.js"></script>
         <style>
             #map {
@@ -26,99 +29,123 @@
         </style>
         <script>
-        new Ext.Application({
+        var app = new Ext.Application({
+            getStore: function() {
+                Ext.regModel('Layer', {
+                    fields: ['id', 'name', 'visibility', 'zindex', 'cls']
+                var data = [];
+                Ext.each(map.layers, function(layer) {
+                    if (layer.displayInLayerSwitcher === true) {
+                        var visibility, cls;
+                        if (layer.isBaseLayer === true) {
+                            cls = 'baselayer';
+                            visibility = (map.baseLayer == layer) && layer.getVisibility();
+                        } else {
+                            cls = 'overlay';
+                            visibility = layer.getVisibility();
+                        data.push({id: layer.id, name: layer.name, cls: cls, visibility: visibility, zindex: layer.getZIndex()});
+                return new Ext.data.Store({
+                    model: 'Layer',
+                    sorters: 'zindex',
+                    data: data
             launch: function() {
                 this.viewport = new Ext.Panel({
                     fullscreen: true,
                     dockedItems: [{
-                        dock: "top",
+                        dock: "bottom",
                         xtype: "toolbar",
                         ui: "light",
                         layout: {
                             pack: "center"
-                        defaults: {
-                            ui: "plain",
-                            iconMask: true
                         items: [{
-                            iconCls: "arrow_left",
-                            handler: function() {
-                                pan(-0.25, 0);
+                            xtype: "segmentedbutton",
+                            items: [{
+                                iconCls: "search",
+                                iconMask: true,
+                                id: "search"
+                                iconCls: "locate",
+                                iconMask: true,
+                                id: "locate",
+                                handler: function() {
+                                    var geolocate = map.getControlsByClass('OpenLayers.Control.Geolocate')[0];
+                                    if (geolocate.active) {
+                                        geolocate.getCurrentLocation();
+                                    } else {
+                                        geolocate.activate();
+                                scope: app
-                            iconCls: "arrow_up",
-                                pan(0, -0.25);
+                            xtype: "spacer"
-                            iconCls: "arrow_down",
-                                pan(0, 0.25);
-                            iconCls: "arrow_right",
-                                pan(0.25, 0);
-                        dock: "bottom",
-                        xtype: "toolbar",
-                        ui: "light",
-                        layout: {
-                            pack: "center"
-                        items: [{
                             items: [{
-                                text: "navigate",
-                                pressed: true
+                                iconMask: true,
+                                iconCls: "add",
+                                id: 'zoomin',
+                                    map.zoomIn();
-                                text: "point",
-                                id: "point"
-                                text: "line",
-                                id: "line"
-                                text: "poly",
-                                id: "poly"
-                                text: "modify",
-                                id: "mod"
-                            listeners: {
-                                toggle: function(container, button, pressed) {
-                                    Ext.each(map.getControlsByClass(/DrawFeature/), function(control) {
-                                        control.deactivate();
+                                iconMask: true,
+                                iconCls: "add",
+                                id: 'zoomout',
+                                    map.zoomOut();
+                            xtype: "spacer"
+                            text: "Layers",
+                                var store = this.getStore();
+                                if (!this.popup) {
+                                    this.popup = new Ext.Panel({
+                                        floating: true,
+                                        modal: true,
+                                        centered: true,
+                                        hideOnMaskTap: true,
+                                        width: 200,
+                                        items: [{
+                                            xtype: 'gx_layerlist',
+                                            map: map
+                                        scroll: 'vertical'
-                                    map.getControlsBy("id", "mod-control")[0].deactivate();
-                                    if (pressed) {
-                                        var id = button.id + "-control";
-                                        var control = map.getControlsBy("id", id)[0];
-                                        if (control) {
-                                            control.activate();
+                                this.popup.show('pop');
+                            scope: app
-                    items: [{
-                        xtype: "component",
-                        scroll: false,
-                        monitorResize: true,
-                        id: "map",
-                        listeners: {
-                            render: init,
-                            resize: function() {
-                                if (window.map) {
-                                    map.updateSize();
+                    items: [
+                            xtype: "component",
+                            scroll: false,
+                            monitorResize: true,
+                            id: "map",
+                            listeners: {
+                                render: init,
+                                resize: function() {
+                                    if (window.map) {
+                                        map.updateSize();
Added: sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.js
--- sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.js	                        (rev 0)
+++ sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.js	2011-02-23 15:53:52 UTC (rev 11339)
@@ -0,0 +1,80 @@
+Ext.ns('GeoExt');
+GeoExt.LayerList = Ext.extend(Ext.List, {
+    map: null,
+    createStore: function() {
+        var data = [];
+        Ext.each(this.map.layers, function(layer) {
+                } else {
+                    cls = 'overlay';
+            model: 'Layer',
+            data: data
+    initComponent: function() {
+        this.store = this.createStore();
+        this.itemTpl = new Ext.XTemplate('<span class="{cls}">',
+            '<tpl if="visibility == true">',
+            '<img width="20" src="img/check-round-green.png">',
+            '</tpl>',
+            '<tpl if="visibility == false">',
+            '<img width="20" src="img/check-round-grey.png">',
+            '</tpl>',
+            '{name}</span>');
+        this.listeners = {
+            itemtap: function(dataview, index, item, e) {
+                var record = dataview.getStore().getAt(index);
+                var layer = this.map.getLayersBy("id", record.get("id"))[0];
+                if (layer.isBaseLayer) {
+                    this.map.setBaseLayer(layer);
+                } else {
+                    layer.setVisibility(!layer.getVisibility());
+                record.set("visibility", layer.getVisibility());
+        this.map.events.on({
+            "changelayer": this.onChangeLayer,
+            scope: this
+        GeoExt.LayerList.superclass.initComponent.call(this);
+    findLayerRecord: function(layer) {
+        var found;
+        this.store.each(function(record) {
+            if (record.get("id") === layer.id) {
+                found = record;
+        }, this);
+        return found;
+    onChangeLayer: function(evt) {
+        if (evt.property == "visibility") {
+            var record = this.findLayerRecord(evt.layer);
+            record.set("visibility", evt.layer.getVisibility());
+Ext.reg('gx_layerlist', GeoExt.LayerList);
Modified: sandbox/bartvde/sencha/openlayers/examples/mobile.js
--- sandbox/bartvde/sencha/openlayers/examples/mobile.js	2011-02-23 15:50:48 UTC (rev 11338)
+++ sandbox/bartvde/sencha/openlayers/examples/mobile.js	2011-02-23 15:53:52 UTC (rev 11339)
@@ -6,11 +6,23 @@
 function init() {
     // layer for drawn features
-    var vector = new OpenLayers.Layer.Vector();
+    var styleMap = new OpenLayers.StyleMap({
+        graphicName: "star",
+        fillColor: "yellow",
+        strokeColor: "orange",
+        pointRadius: 10
+    var vector = new OpenLayers.Layer.Vector("Features", {styleMap: styleMap});
+    var point = new OpenLayers.Geometry.Point(6.6667, 46.6333);
+    point.transform(new OpenLayers.Projection("EPSG:4326"), new OpenLayers.Projection("EPSG:900913"));
+    var pointFeature = new OpenLayers.Feature.Vector(point,null);
+    vector.addFeatures([pointFeature]);
     // create map
     map = new OpenLayers.Map({
         div: "map",
+        theme: null,
         projection: sm,
         units: "m",
         numZoomLevels: 18,
@@ -19,28 +31,42 @@
             -20037508.34, -20037508.34, 20037508.34, 20037508.34
         controls: [
+            new OpenLayers.Control.Attribution(),
             new OpenLayers.Control.TouchNavigation({
                 dragPanOptions: {
                     interval: 0, // non-zero kills performance on some mobile phones
                     enableKinetic: true
-            new OpenLayers.Control.Attribution(),
-            new OpenLayers.Control.DrawFeature(
-                vector, OpenLayers.Handler.Point, {id: "point-control"}
+            new OpenLayers.Control.Geolocate({
+                 geolocationOptions: {
+                     enableHighAccuracy: false,
+                     maximumAge: 0,
+                     timeout: 7000
+        layers: [new OpenLayers.Layer.OSM(),
+            new OpenLayers.Layer.Google(
+                "Google Physical",
+                {type: google.maps.MapTypeId.TERRAIN}
-                vector, OpenLayers.Handler.Path, {id: "line-control"}
+                "Google Streets", // the default
+                {numZoomLevels: 20}
-                vector, OpenLayers.Handler.Polygon, {id: "poly-control"}
+                "Google Hybrid",
+                {type: google.maps.MapTypeId.HYBRID, numZoomLevels: 20}
-            new OpenLayers.Control.ModifyFeature(vector, {id: "mod-control"}),
-            new OpenLayers.Control.ZoomPanel()
+                "Google Satellite",
+                {type: google.maps.MapTypeId.SATELLITE, numZoomLevels: 22}
+            vector
-        layers: [new OpenLayers.Layer.OSM(), vector],
         center: new OpenLayers.LonLat(0, 0),
-        zoom: 1
+        zoom: 5
     // attempt to get position
More information about the Commits mailing list
