[OpenLayers-Commits] r11365 - in trunk/openlayers: lib/OpenLayers lib/OpenLayers/Handler tests/Control tests/Handler tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 12:59:37 EST 2011
Author: tschaub
Date: 2011-02-23 09:59:37 -0800 (Wed, 23 Feb 2011)
New Revision: 11365
   trunk/openlayers/lib/OpenLayers/Handler/Drag.js
   trunk/openlayers/lib/OpenLayers/Map.js
   trunk/openlayers/tests/Control/PanZoom.html
   trunk/openlayers/tests/Handler/Drag.html
   trunk/openlayers/tests/Layer/EventPane.html
Arrange elements so we can get mouse events on controls while preventing the default (scroll) behavior on touch devices.  r=elemoine (closes #3091)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Drag.js
--- trunk/openlayers/lib/OpenLayers/Handler/Drag.js	2011-02-23 17:29:13 UTC (rev 11364)
+++ trunk/openlayers/lib/OpenLayers/Handler/Drag.js	2011-02-23 17:59:37 UTC (rev 11365)
@@ -156,9 +156,7 @@
             this.down(evt);
             this.callback("down", [evt.xy]);
-            if (evt.type === "mousedown") {
-                OpenLayers.Event.stop(evt);
+            OpenLayers.Event.stop(evt);
             if(!this.oldOnselectstart) {
                 this.oldOnselectstart = document.onselectstart ?
@@ -204,9 +202,7 @@
                     this.interval);
             this.dragging = true;
-            if (evt.type === "touchmove") {
             this.move(evt);
             this.callback("move", [evt.xy]);
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js	2011-02-23 17:29:13 UTC (rev 11364)
+++ trunk/openlayers/lib/OpenLayers/Map.js	2011-02-23 17:59:37 UTC (rev 11365)
@@ -507,18 +507,27 @@
         this.viewPortDiv.className = "olMapViewport";
         this.div.appendChild(this.viewPortDiv);
+        // the eventsDiv is where we listen for all map events
+        var eventsDiv = document.createElement("div");
+        eventsDiv.id = this.id + "_events";
+        eventsDiv.style.position = "absolute";
+        eventsDiv.style.width = "100%";
+        eventsDiv.style.height = "100%";
+        eventsDiv.style.zIndex = this.Z_INDEX_BASE.Control - 1;
+        this.viewPortDiv.appendChild(eventsDiv);
+        this.eventsDiv = eventsDiv;
+        this.events = new OpenLayers.Events(
+            this, this.eventsDiv, this.EVENT_TYPES, this.fallThrough,
+            {includeXY: true}
         // the layerContainerDiv is the one that holds all the layers
         id = this.id + "_OpenLayers_Container";
         this.layerContainerDiv = OpenLayers.Util.createDiv(id);
         this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;
-        this.viewPortDiv.appendChild(this.layerContainerDiv);
+        this.eventsDiv.appendChild(this.layerContainerDiv);
-        this.events = new OpenLayers.Events(this,
-                                            this.viewPortDiv,
-                                            this.EVENT_TYPES,
-                                            this.fallThrough,
-                                            {includeXY: true});
         this.updateSize();
         if(this.eventListeners instanceof Object) {
             this.events.on(this.eventListeners);
Modified: trunk/openlayers/tests/Control/PanZoom.html
--- trunk/openlayers/tests/Control/PanZoom.html	2011-02-23 17:29:13 UTC (rev 11364)
+++ trunk/openlayers/tests/Control/PanZoom.html	2011-02-23 17:59:37 UTC (rev 11365)
@@ -74,7 +74,7 @@
                     t.delay_call(2, function() {
                         t.ok( wnd.mapper.getCenter().lat > wnd.centerLL.lat, "1) Pan up works correctly" );
                         t.ok(!flag.mousedown, "1) mousedown does not get to the map");
-                        t.ok(flag.mouseup, "1) mouseup does get to the map");
+                        t.ok(!flag.mouseup, "1) mouseup does not get to the map");
                         t.ok(!flag.click, "1) click does not get to the map");
                         t.ok(!flag.dblclick, "1) dblclick does not get to the map");
                         resetFlags();
@@ -83,7 +83,7 @@
                     }, 2, function() {
                     t.ok( wnd.mapper.getCenter().lon < wnd.centerLL.lon, "2) Pan left works correctly" );
                     t.ok(!flag.mousedown, "2) mousedown does not get to the map");
-                    t.ok(flag.mouseup, "2) mouseup does get to the map");
+                    t.ok(!flag.mouseup, "2) mouseup does not get to the map");
                     t.ok(!flag.click, "2) click does not get to the map");
                     t.ok(!flag.dblclick, "2) dblclick does not get to the map");
                     resetFlags();
@@ -92,7 +92,7 @@
                     }, 2, function() {
                     t.ok( wnd.mapper.getCenter().lon == wnd.centerLL.lon, "3) Pan right works correctly" );
                     t.ok(!flag.mousedown, "3) mousedown does not get to the map");
-                    t.ok(flag.mouseup, "3) mouseup does get to the map");
+                    t.ok(!flag.mouseup, "3) mouseup does not get to the map");
                     t.ok(!flag.click, "3) click does not get to the map");
                     t.ok(!flag.dblclick, "3) dblclick does not get to the map");
                     resetFlags();
@@ -101,7 +101,7 @@
                     }, 2, function() {
                     t.ok( wnd.mapper.getCenter().lat == wnd.centerLL.lat, "4) Pan down works correctly" );
                     t.ok(!flag.mousedown, "4) mousedown does not get to the map");
-                    t.ok(flag.mouseup, "4) mouseup does get to the map");
+                    t.ok(!flag.mouseup, "4) mouseup does not get to the map");
                     t.ok(!flag.click, "4) click does not get to the map");
                     t.ok(!flag.dblclick, "4) dblclick does not get to the map");
                     resetFlags();
@@ -110,7 +110,7 @@
                     }, 2, function() {
                     t.eq( wnd.mapper.getZoom(), 6, "5) zoomin works correctly" );
                     t.ok(!flag.mousedown, "5) mousedown does not get to the map");
-                    t.ok(flag.mouseup, "5) mouseup does get to the map");
+                    t.ok(!flag.mouseup, "5) mouseup does not get to the map");
                     t.ok(!flag.click, "5) click does not get to the map");
                     t.ok(!flag.dblclick, "5) dblclick does not get to the map");
                     resetFlags();
@@ -119,7 +119,7 @@
                     }, 2, function() {
                     t.eq( wnd.mapper.getZoom(), 5, "6) zoomout works correctly" );
                     t.ok(!flag.mousedown, "6) mousedown does not get to the map");
-                    t.ok(flag.mouseup, "6) mouseup does get to the map");
+                    t.ok(!flag.mouseup, "6) mouseup does not get to the map");
                     t.ok(!flag.click, "6) click does not get to the map");
                     t.ok(!flag.dblclick, "6) dblclick does not get to the map");
                     resetFlags();
@@ -128,7 +128,7 @@
                     }, 2, function() {
                     t.eq( wnd.mapper.getZoom(), 2, "7) zoomworld works correctly" );
                     t.ok(!flag.mousedown, "7) mousedown does not get to the map");
-                    t.ok(flag.mouseup, "7) mouseup does get to the map");
+                    t.ok(!flag.mouseup, "7) mouseup does not get to the map");
                     t.ok(!flag.click, "7) click does not get to the map");
                     t.ok(!flag.dblclick, "7) dblclick does not get to the map");
                     resetFlags();
Modified: trunk/openlayers/tests/Handler/Drag.html
--- trunk/openlayers/tests/Handler/Drag.html	2011-02-23 17:29:13 UTC (rev 11364)
+++ trunk/openlayers/tests/Handler/Drag.html	2011-02-23 17:59:37 UTC (rev 11365)
@@ -294,7 +294,7 @@
         // "touchend" events set expected states in the drag handler.
         // We also verify that we stop event bubbling as appropriate.
-        t.plan(12);
+        t.plan(14);
         // set up
@@ -302,37 +302,44 @@
         var c = new OpenLayers.Control();
         m.addControl(c);
         var h = new OpenLayers.Handler.Drag(c, {
-            done: function(px) { log = px; }});
+            done: function(px) {
+                log.push(px);
         h.activate();
         var _stop = OpenLayers.Event.stop;
-        OpenLayers.Event.stop = function(e) { log = e; };
+        OpenLayers.Event.stop = function(e) {
+            log.push(e);
-        var Px = OpenLayers.Pixel, e, log;
+        var Px = OpenLayers.Pixel, e;
+        var log = [];
         // test
         e = {touches: [{}], xy: new Px(0, 0)};
         m.events.triggerEvent('touchstart', e);
         t.eq(h.started, true, '[touchstart] started is set');
         t.eq(h.start.x, 0, '[touchstart] start.x is correct');
         t.eq(h.start.y, 0, '[touchstart] start.y is correct');
-        t.eq(log, undefined, '[touchstart] event is not stopped');
+        t.eq(log.length, 1, '[touchstart] one item in log');
+        t.ok(log[0] === e, "touchstart", '[touchstart] event is stopped');
         e = {xy: new Px(1, 1)};
         m.events.triggerEvent('touchmove', e);
         t.eq(h.dragging, true, '[touchmove] dragging is set');
-        t.eq(h.last.x, 1, '[touchstart] last.x is correct');
-        t.eq(h.last.y, 1, '[touchstart] last.y is correct');
-        t.ok(log == e, '[touchmove] event is stopped');
+        t.eq(h.last.x, 1, '[touchmove] last.x is correct');
+        t.eq(h.last.y, 1, '[touchmove] last.y is correct');
+        t.eq(log.length, 1, '[touchmove] one item in log (event is not stopped)');
         e = {xy: new Px(2, 2)};
         m.events.triggerEvent('touchend', e);
         t.eq(h.started, false, '[touchend] started is reset');
         // the "done" callback gets the position of the last touchmove
-        t.eq(log.x, 1, '[touchend] done callback got correct x position');
-        t.eq(log.y, 1, '[touchend] done callback got correct y position');
+        t.eq(log.length, 2, '[touchend] two items in log');
+        t.ok(log[1] instanceof Px, '[touchend] got');
+        t.ok(log[1].equals(e.xy), '[touchend] done callback got correct position');
         // tear down
Modified: trunk/openlayers/tests/Layer/EventPane.html
--- trunk/openlayers/tests/Layer/EventPane.html	2011-02-23 17:29:13 UTC (rev 11364)
+++ trunk/openlayers/tests/Layer/EventPane.html	2011-02-23 17:59:37 UTC (rev 11365)
@@ -94,9 +94,9 @@
         if (document.createEvent) { // Mozilla
             var evObj = document.createEvent('MouseEvents');
             evObj.initEvent('mousemove', true, false);
-            layer.pane.dispatchEvent(evObj);
+            map.eventsDiv.dispatchEvent(evObj);
         } else if(document.createEventObject) { // IE
-            layer.pane.fireEvent('onmousemove');
+            map.eventsDiv.fireEvent('onmousemove');
         t.eq(log.length, 1, "got one event");
More information about the Commits mailing list
