[OpenLayers-Commits] r11388 - in sandbox/crschmidt/pan-tap: . build examples lib/OpenLayers lib/OpenLayers/Control lib/OpenLayers/Handler tests tests/BaseTypes tests/Control tests/Handler tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 24 04:58:10 EST 2011
Author: crschmidt
Date: 2011-02-24 01:58:10 -0800 (Thu, 24 Feb 2011)
New Revision: 11388
   sandbox/crschmidt/pan-tap/
   sandbox/crschmidt/pan-tap/build/build.py
   sandbox/crschmidt/pan-tap/build/lite.cfg
   sandbox/crschmidt/pan-tap/examples/controls.html
   sandbox/crschmidt/pan-tap/examples/draw-feature.html
   sandbox/crschmidt/pan-tap/examples/geolocation.html
   sandbox/crschmidt/pan-tap/examples/geolocation.js
   sandbox/crschmidt/pan-tap/examples/mobile-navigation.html
   sandbox/crschmidt/pan-tap/examples/style.css
   sandbox/crschmidt/pan-tap/lib/OpenLayers/BaseTypes.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Geolocate.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Measure.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Drag.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Path.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Point.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Polygon.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Kinetic.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Map.js
   sandbox/crschmidt/pan-tap/tests/BaseTypes/Bounds.html
   sandbox/crschmidt/pan-tap/tests/BaseTypes/LonLat.html
   sandbox/crschmidt/pan-tap/tests/BaseTypes/Pixel.html
   sandbox/crschmidt/pan-tap/tests/Control/DrawFeature.html
   sandbox/crschmidt/pan-tap/tests/Control/Geolocate.html
   sandbox/crschmidt/pan-tap/tests/Control/Measure.html
   sandbox/crschmidt/pan-tap/tests/Control/PanZoom.html
   sandbox/crschmidt/pan-tap/tests/Control/Scale.html
   sandbox/crschmidt/pan-tap/tests/Control/Split.html
   sandbox/crschmidt/pan-tap/tests/Handler/Click.html
   sandbox/crschmidt/pan-tap/tests/Handler/Drag.html
   sandbox/crschmidt/pan-tap/tests/Handler/Path.html
   sandbox/crschmidt/pan-tap/tests/Handler/Point.html
   sandbox/crschmidt/pan-tap/tests/Handler/Polygon.html
   sandbox/crschmidt/pan-tap/tests/Layer/EventPane.html
   sandbox/crschmidt/pan-tap/tests/Map.html
   sandbox/crschmidt/pan-tap/tests/run-tests.html
Merge trunk to branch; remove alert() from Click handler
Property changes on: sandbox/crschmidt/pan-tap
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11269-11387
Modified: sandbox/crschmidt/pan-tap/build/build.py
--- sandbox/crschmidt/pan-tap/build/build.py	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/build/build.py	2011-02-24 09:58:10 UTC (rev 11388)
@@ -3,40 +3,46 @@
 import sys
 sys.path.append("../tools")
 import mergejs
+import optparse
-def build():
-    have_compressor = None
+def build(config_file = None, output_file = None, options = None):
+    have_compressor = []
     try:
         import jsmin
-        have_compressor = "jsmin"
+        have_compressor.append("jsmin")
     except ImportError:
-        try:
-            import minimize
-            have_compressor = "minimize"
-        except Exception, E:
-            print E
-            pass
+        print "No jsmin"
+    try:
+        import minimize
+        have_compressor.append("minimize")
+    except ImportError:
+        print "No minimize"
+    use_compressor = None
+    if options.compressor and options.compressor in have_compressor:
+        use_compressor = options.compressor
     sourceDirectory = "../lib"
     configFilename = "full.cfg"
     outputFilename = "OpenLayers.js"
-    if len(sys.argv) > 1:
-        configFilename = sys.argv[1]
+    if config_file:
+        configFilename = config_file
         extension = configFilename[-4:]
         if extension  != ".cfg":
-            configFilename = sys.argv[1] + ".cfg"
+            configFilename = config_file + ".cfg"
-    if len(sys.argv) > 2:
-        outputFilename = sys.argv[2]
+    if output_file:
+        outputFilename = output_file
     print "Merging libraries."
     merged = mergejs.run(sourceDirectory, None, configFilename)
-    if have_compressor == "jsmin":
+    if use_compressor == "jsmin":
         print "Compressing using jsmin."
         minimized = jsmin.jsmin(merged)
-    elif have_compressor == "minimize":
+    elif use_compressor == "minimize":
         print "Compressing using minimize."
         minimized = minimize.minimize(merged)
     else: # fallback
@@ -51,4 +57,7 @@
     print "Done."
 if __name__ == '__main__':
-  build()
\ No newline at end of file
+  opt = optparse.OptionParser(usage="%s [options] [config_file] [output_file]\n  Default config_file is 'full.cfg', Default output_file is 'OpenLayers.js'")
+  opt.add_option("-c", "--compressor", dest="compressor", help="compression method: one of 'jsmin', 'minimize', or 'none'", default="jsmin")
+  (options, args) = opt.parse_args()
+  build(*args, options=options)
Modified: sandbox/crschmidt/pan-tap/build/lite.cfg
--- sandbox/crschmidt/pan-tap/build/lite.cfg	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/build/lite.cfg	2011-02-24 09:58:10 UTC (rev 11388)
@@ -11,6 +11,16 @@
 [include]
 OpenLayers/Map.js
 OpenLayers/Layer/WMS.js
+OpenLayers/Control/Navigation.js
+OpenLayers/Control/TouchNavigation.js
+OpenLayers/Layer/XYZ.js
+OpenLayers/Layer/Vector.js
+OpenLayers/Renderer/VML.js
+OpenLayers/Renderer/SVG.js
+OpenLayers/Kinetic.js
+OpenLayers/Control/ZoomPanel.js
+OpenLayers/Control/Attribution.js
 [exclude]
Modified: sandbox/crschmidt/pan-tap/examples/controls.html
--- sandbox/crschmidt/pan-tap/examples/controls.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/examples/controls.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -64,8 +64,8 @@
             Attach zooming, panning, layer switcher, overview map, and permalink map controls to an OpenLayers window.
         </p>
-        <a style="float:right" href="" id="permalink">Permalink</a>
         <div id="map" class="smallmap"></div>
+        <a href="#" id="permalink">Permalink</a>
         <div id="docs"></div>
     </body>
Modified: sandbox/crschmidt/pan-tap/examples/draw-feature.html
--- sandbox/crschmidt/pan-tap/examples/draw-feature.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/examples/draw-feature.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -64,6 +64,14 @@
+            function allowPan(element) {
+                var stop = !element.checked;
+                for(var key in drawControls) {
+                    drawControls[key].handler.stopDown = stop;
+                    drawControls[key].handler.stopUp = stop;
         </script>
     </head>
     <body onload="init()">
@@ -97,15 +105,20 @@
                 <input type="radio" name="type" value="polygon" id="polygonToggle" onclick="toggleControl(this);" />
                 <label for="polygonToggle">draw polygon</label>
             </li>
+            <li>
+                <input type="checkbox" name="allow-pan" value="allow-pan" id="allowPanCheckbox" checked=true onclick="allowPan(this);" />
+                <label for="allowPanCheckbox">allow pan while drawing</label>
+            </li>
         </ul>
         <div id="docs">
-            <p>With the point drawing control active, click on the map to add a point.  You can drag the point
-            before letting the mouse up if you want to adjust the position.</p>
+            <p>With the point drawing control active, click on the map to add a point.</p>
             <p>With the line drawing control active, click on the map to add the points that make up your line.
             Double-click to finish drawing.</p>
             <p>With the polygon drawing control active, click on the map to add the points that make up your
             polygon.  Double-click to finish drawing.</p>
+            <p>With any drawing control active, paning the map can still be achieved.  Drag the map as
+            usual for that.</p>
             <p>Hold down the shift key while drawing to activate freehand mode.  While drawing lines or polygons
             in freehand mode, hold the mouse down and a point will be added with every mouse movement.<p>
         </div>
Modified: sandbox/crschmidt/pan-tap/examples/geolocation.html
--- sandbox/crschmidt/pan-tap/examples/geolocation.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/examples/geolocation.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -13,7 +13,7 @@
         </style>
     </head>
-    <body onload="init()">
+    <body>
         <h1 id="title">Geolocation Example</h1>
         <div id="tags">
Modified: sandbox/crschmidt/pan-tap/examples/geolocation.js
--- sandbox/crschmidt/pan-tap/examples/geolocation.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/examples/geolocation.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -1,8 +1,7 @@
 var style = {
+    fillColor: '#000',
     fillOpacity: 0.1,
-    fillColor: '#000',
-    strokeColor: '#f00',
-    strokeOpacity: 0.6
+    strokeWidth: 0
 var map = new OpenLayers.Map('map');
@@ -17,6 +16,34 @@
     ), 12
+var pulsate = function(feature) {
+    var point = feature.geometry.getCentroid(),
+        bounds = feature.geometry.getBounds(),
+        radius = Math.abs((bounds.right - bounds.left)/2),
+        count = 0,
+        grow = 'up';
+    var resize = function(){
+        if (count>16) clearInterval(window.resizeInterval);
+        var interval = radius * 0.03;
+        var ratio = interval/radius;
+        switch(count) {
+            case 4:
+            case 12:
+                grow = 'down'; break;
+            case 8:
+                grow = 'up'; break;
+        if (grow!=='up') {
+            ratio = - Math.abs(ratio);
+        feature.geometry.resize(1+ratio, point);
+        vector.drawFeature(feature);
+        count++;
+    window.resizeInterval = window.setInterval(resize, 50, point, radius);
 var geolocate = new OpenLayers.Control.Geolocate({
     geolocationOptions: {
         enableHighAccuracy: false,
@@ -27,6 +54,16 @@
 map.addControl(geolocate);
 geolocate.events.register("locationupdated",this,function(e) {
     vector.removeAllFeatures();
+    var circle = new OpenLayers.Feature.Vector(
+        OpenLayers.Geometry.Polygon.createRegularPolygon(
+            new OpenLayers.Geometry.Point(e.point.x, e.point.y),
+            e.position.coords.accuracy/2,
+            40,
+            0
+        style
     vector.addFeatures([
             e.point,
@@ -39,34 +76,28 @@
                 pointRadius: 10
-        new OpenLayers.Feature.Vector(
-            OpenLayers.Geometry.Polygon.createRegularPolygon(
-                new OpenLayers.Geometry.Point(e.point.x, e.point.y),
-                e.position.coords.accuracy/2,
-                50,
-                0
-            style
+        circle
     map.zoomToExtent(vector.getDataExtent());
+    pulsate(circle);
 geolocate.events.register("locationfailed",this,function() {
     OpenLayers.Console.log('Location detection failed');
 $('locate').onclick = function() {
+    vector.removeAllFeatures();
     geolocate.deactivate();
     $('track').checked = false;
     geolocate.watch = false;
     geolocate.activate();
 $('track').onclick = function() {
     if (this.checked) {
         geolocate.watch = true;
-$('track').checked = false;
+$('track').checked = false;
Modified: sandbox/crschmidt/pan-tap/examples/mobile-navigation.html
--- sandbox/crschmidt/pan-tap/examples/mobile-navigation.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/examples/mobile-navigation.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -3,7 +3,7 @@
   <head>
     <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
     <meta name="apple-mobile-web-app-capable" content="yes" />
-    <title>OpenLayers TouchNavigation Control</title>
+    <title>Mobile Navigation Example</title>
     <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
     <link rel="stylesheet" href="style.mobile.css" type="text/css" />
     <link rel="stylesheet" href="style.css" type="text/css" />
Modified: sandbox/crschmidt/pan-tap/examples/style.css
--- sandbox/crschmidt/pan-tap/examples/style.css	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/examples/style.css	2011-02-24 09:58:10 UTC (rev 11388)
@@ -121,3 +121,19 @@
         display : none;
+ at media only screen and (orientation: landscape) and (max-width: 600px) {
+    #shortdesc {
+       float: right;
+       width: 25%;
+    #map {
+        width: 70%;
+    #docs {
+        font-size: 12px;
+body {
+    -webkit-text-size-adjust: none;
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/BaseTypes.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/BaseTypes.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/BaseTypes.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -632,9 +632,11 @@
      * APIMethod: parse
      * Generate a date object from a string.  The format for the string follows
      *     the profile of ISO 8601 for date and time on the Internet (see
-     *     http://tools.ietf.org/html/rfc3339).  If the parse method on
-     *     the Date constructor returns a valid date for the given string,
-     *     that method is used.
+     *     http://tools.ietf.org/html/rfc3339).  We don't call the native
+     *     Date.parse because of inconsistency between implmentations.  In
+     *     Chrome, calling Date.parse with a string that doesn't contain any
+     *     indication of the timezone (e.g. "2011"), the date is interpreted
+     *     in local time.  On Firefox, the assumption is UTC.
      * Parameters:
      * str - {String} A string representing the date (e.g.
@@ -647,37 +649,31 @@
     parse: function(str) {
         var date;
-        // first check if the native parse method can parse it
-        var elapsed = Date.parse(str);
-        if (!isNaN(elapsed)) {
-            date = new Date(elapsed);
-        } else {
-            var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
-            if (match && (match[1] || match[7])) { // must have at least year or time
-                var year = parseInt(match[1], 10) || 0;
-                var month = (parseInt(match[2], 10) - 1) || 0;
-                var day = parseInt(match[3], 10) || 1;
-                date = new Date(Date.UTC(year, month, day));
-                // optional time
-                var type = match[7];
-                if (type) {
-                    var hours = parseInt(match[4], 10);
-                    var minutes = parseInt(match[5], 10);
-                    var secFrac = parseFloat(match[6]);
-                    var seconds = secFrac | 0;
-                    var milliseconds = Math.round(1000 * (secFrac - seconds));
-                    date.setUTCHours(hours, minutes, seconds, milliseconds);
-                    // check offset
-                    if (type !== "Z") {
-                        var hoursOffset = parseInt(type, 10);
-                        var minutesOffset = parseInt(match[8], 10) || 0;
-                        var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
-                        date = new Date(date.getTime() + offset);
+        var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
+        if (match && (match[1] || match[7])) { // must have at least year or time
+            var year = parseInt(match[1], 10) || 0;
+            var month = (parseInt(match[2], 10) - 1) || 0;
+            var day = parseInt(match[3], 10) || 1;
+            date = new Date(Date.UTC(year, month, day));
+            // optional time
+            var type = match[7];
+            if (type) {
+                var hours = parseInt(match[4], 10);
+                var minutes = parseInt(match[5], 10);
+                var secFrac = parseFloat(match[6]);
+                var seconds = secFrac | 0;
+                var milliseconds = Math.round(1000 * (secFrac - seconds));
+                date.setUTCHours(hours, minutes, seconds, milliseconds);
+                // check offset
+                if (type !== "Z") {
+                    var hoursOffset = parseInt(type, 10);
+                    var minutesOffset = parseInt(match[8], 10) || 0;
+                    var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
+                    date = new Date(date.getTime() + offset);
-            } else {
-                date = new Date("invalid");
+        } else {
+            date = new Date("invalid");
         return date;
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Geolocate.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Geolocate.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Geolocate.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -85,7 +85,7 @@
             this.events.triggerEvent("locationuncapable");
             return false;
-        if (!this.active) {
+        if (OpenLayers.Control.prototype.activate.apply(this, arguments)) {
             if (this.watch) {
                 this.watchId = this.geolocation.watchPosition(
                     OpenLayers.Function.bind(this.geolocate, this),
@@ -93,16 +93,11 @@
                     this.geolocationOptions
             } else {
-                this.geolocation.getCurrentPosition(
-                    OpenLayers.Function.bind(this.geolocate, this),
-                    OpenLayers.Function.bind(this.failure, this),
-                    this.geolocationOptions
+                this.getCurrentLocation();
+            return true;
-        return OpenLayers.Control.prototype.activate.apply(
-            this, arguments
+        return false;
@@ -146,6 +141,25 @@
+     * APIMethod: getCurrentLocation
+     * Returns:
+     * {Boolean} Returns true if a event will be fired (successfull
+     * registration)
+    getCurrentLocation: function() {
+        if (!this.active || this.watch) {
+            return false;
+        this.geolocation.getCurrentPosition(
+            OpenLayers.Function.bind(this.geolocate, this),
+            OpenLayers.Function.bind(this.failure, this),
+            this.geolocationOptions
+        return true;
      * Method: failure
      * method called on browser's geolocation failure
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Measure.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Measure.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Measure.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -237,8 +237,8 @@
      * Parameters: point - {<OpenLayers.Geometry.Point>} The point at the
      * mouseposition. feature - {<OpenLayers.Feature.Vector>} The sketch feature.
-    measureImmediate : function(point, feature) {
-        if (this.delayedTrigger === null &&
+    measureImmediate : function(point, feature, drawing) {
+        if (drawing && this.delayedTrigger === null &&
                                 !this.handler.freehandMode(this.handler.evt)) {
             this.measure(feature.geometry, "measurepartial");
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -142,7 +142,6 @@
     initialize: function(control, callbacks, options) {
         OpenLayers.Handler.prototype.initialize.apply(this, arguments);
-        // optionally register for mouseup and mousedown
     mouseover: function(evt) {
@@ -323,7 +322,6 @@
             // same location.
             } else if (this.firstMouseOver && this.firstMouseOver.equals(evt.xy)) {
                 this.tap = true;
-                alert('tap true');
             // IE on WP7 (and possibly others) -- move->down->up all happen at almost
             // exactly the same time (within tapTolerance) means this was a tap. Setting
@@ -331,10 +329,8 @@
             // desktop browsers.
             } else if (this.lastMove < this.lastDown && this.lastDown < this.lastUp && ((this.lastUp - this.lastMove) < this.tapTolerance)) {
                 this.tap = true;
             } else {
                 this.tap = false;
-                alert('tap false');
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Drag.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Drag.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Drag.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -156,9 +156,7 @@
             this.down(evt);
             this.callback("down", [evt.xy]);
-            if (evt.type === "mousedown") {
-                OpenLayers.Event.stop(evt);
+            OpenLayers.Event.stop(evt);
             if(!this.oldOnselectstart) {
                 this.oldOnselectstart = document.onselectstart ?
@@ -204,9 +202,7 @@
                     this.interval);
             this.dragging = true;
-            if (evt.type === "touchmove") {
             this.move(evt);
             this.callback("move", [evt.xy]);
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Path.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Path.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Path.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -79,6 +79,9 @@
      *     feature.
     createFeature: function(pixel) {
+        if(!pixel) {
+            pixel = new OpenLayers.Pixel(-50, -50);
         var lonlat = this.control.map.getLonLatFromPixel(pixel);
         this.point = new OpenLayers.Feature.Vector(
             new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat)
@@ -101,6 +104,17 @@
+     * Method: destroyPersistedFeature
+     * Destroy the persisted feature.
+    destroyPersistedFeature: function() {
+        var layer = this.layer;
+        if(layer && layer.features.length > 2) {
+            this.layer.features[0].destroy();
      * Method: removePoint
      * Destroy the temporary point.
@@ -151,12 +165,13 @@
      * Parameters:
      * pixel - {<OpenLayers.Pixel>} The updated pixel location for the latest
      *     point.
+     * drawing - {Boolean} Indicate if we're currently drawing.
-    modifyFeature: function(pixel) {
+    modifyFeature: function(pixel, drawing) {
         this.point.geometry.x = lonlat.lon;
         this.point.geometry.y = lonlat.lat;
-        this.callback("modify", [this.point.geometry, this.getSketch()]);
+        this.callback("modify", [this.point.geometry, this.getSketch(), drawing]);
         this.point.geometry.clearBounds();
         this.drawFeature();
@@ -209,22 +224,17 @@
      * {Boolean} Allow event propagation
     mousedown: function(evt) {
-        // ignore double-clicks
-        if (this.lastDown && this.lastDown.equals(evt.xy)) {
-            return false;
+        var stopDown = this.stopDown;
+        if(this.freehandMode(evt)) {
+            stopDown = true;
-        if(this.lastDown == null) {
-            if(this.persist) {
-                this.destroyFeature();
-            this.createFeature(evt.xy);
-        } else if((this.lastUp == null) || !this.lastUp.equals(evt.xy)) {
-            this.addPoint(evt.xy);
+        if(!this.lastDown || !this.lastDown.equals(evt.xy)) {
+            this.modifyFeature(evt.xy, !!this.lastUp);
         this.mouseDown = true;
         this.lastDown = evt.xy;
-        this.drawing = true;
-        return false;
+        this.stoppedDown = stopDown;
+        return !stopDown;
@@ -239,13 +249,16 @@
     mousemove: function (evt) {
-        if(this.drawing) {
-            if(this.mouseDown && this.freehandMode(evt)) {
-            } else {
-                this.modifyFeature(evt.xy);
+        if(this.stoppedDown && this.freehandMode(evt)) {
+            if(this.persist) {
+                this.destroyPersistedFeature();
+            this.addPoint(evt.xy);
+            return false;
+        if(!this.mouseDown || this.stoppedDown) {
         return true;
@@ -261,20 +274,23 @@
     mouseup: function (evt) {
-        this.mouseDown = false;
-            if(this.freehandMode(evt)) {
+        if(this.mouseDown && (!this.lastUp || !this.lastUp.equals(evt.xy))) {
                 this.removePoint();
                 this.finalize();
             } else {
-                if(this.lastUp == null) {
+                if(this.lastDown.equals(evt.xy)) {
+                    if(this.lastUp == null && this.persist) {
+                    this.lastUp = evt.xy;
-                this.lastUp = evt.xy;
-            return false;
-        return true;
+        this.stoppedDown = this.stopDown;
+        this.mouseDown = false;
+        return !this.stopUp;
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Point.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Point.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Point.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -11,9 +11,9 @@
  * Class: OpenLayers.Handler.Point
- * Handler to draw a point on the map.  Point is displayed on mouse down,
- *     moves on mouse move, and is finished on mouse up.  The handler triggers
- *     callbacks for 'done', 'cancel', and 'modify'.  The modify callback is
+ * Handler to draw a point on the map. Point is displayed on activation,
+ *     moves on mouse move, and is finished on mouse up. The handler triggers
+ *     callbacks for 'done', 'cancel', and 'modify'. The modify callback is
  *     called with each change in the sketch and will receive the latest point
  *     drawn.  Create a new instance with the <OpenLayers.Handler.Point>
  *     constructor.
@@ -43,18 +43,19 @@
     multi: false,
-     * Property: drawing
-     * {Boolean} A point is being drawn
-    drawing: false,
      * Property: mouseDown
      * {Boolean} The mouse is down
     mouseDown: false,
+     * Property: stoppedDown
+     * {Boolean} Indicate whether the last mousedown stopped the event
+     * propagation.
+    stoppedDown: null,
      * Property: lastDown
      * {<OpenLayers.Pixel>} Location of the last mouse down
@@ -76,6 +77,20 @@
     persist: false,
+     * APIProperty: stopDown
+     * {Boolean} Stop event propagation on mousedown. Must be false to
+     *     allow "pan while drawing". Defaults to false.
+    stopDown: false,
+     * APIPropery: stopUp
+     * {Boolean} Stop event propagation on mouse. Must be false to
+     *     allow "pan while dragging". Defaults to fase.
+    stopUp: false,
      * Property: layerOptions
      * {Object} Any optional properties to be set on the sketch layer.
@@ -130,6 +145,7 @@
         }, this.layerOptions);
         this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
         this.map.addLayer(this.layer);
+        this.createFeature();
         return true;
@@ -141,6 +157,9 @@
      * pixel - {<OpenLayers.Pixel>} A pixel location on the map.
+        if(!pixel) {
         var lonlat = this.map.getLonLatFromPixel(pixel);
@@ -158,17 +177,14 @@
         if(!OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
             return false;
-        // call the cancel callback if mid-drawing
-            this.cancel();
+        this.cancel(true);
         // If a layer's map property is set to null, it means that that layer
         // isn't added to the map. Since we ourself added the layer to the map
         // in activate(), we can assume that if this.layer.map is null it means
         // that the layer has been destroyed (as a result of map.destroy() for
         // example.
         if (this.layer.map != null) {
+            this.destroyFeature();
             this.layer.destroy(false);
         this.layer = null;
@@ -187,14 +203,27 @@
+        if(layer && layer.features.length > 1) {
      * Method: finalize
      * Finish the geometry and call the "done" callback.
      * Parameters:
      * cancel - {Boolean} Call cancel instead of done callback.  Default is
      *     false.
+     * noNew - {Boolean} Do not create a new feature after
+     *     finalization.  Default is false.
-    finalize: function(cancel) {
+    finalize: function(cancel, noNew) {
         var key = cancel ? "cancel" : "done";
         this.drawing = false;
@@ -204,14 +233,21 @@
         if(cancel || !this.persist) {
+        if(!noNew) {
      * APIMethod: cancel
      * Finish the geometry and call the "cancel" callback.
+     * Parameters:
+     *     cancelation.  Default is false.
-    cancel: function() {
-        this.finalize(true);
+    cancel: function(noNew) {
+        this.finalize(true, noNew);
@@ -257,7 +293,7 @@
-        this.callback("modify", [this.point.geometry, this.point]);
+        this.callback("modify", [this.point.geometry, this.point, false]);
         this.drawFeature();
@@ -310,25 +346,11 @@
-        // check keyboard modifiers
-        if(!this.checkModifiers(evt)) {
-            return true;
-        if(this.lastDown && this.lastDown.equals(evt.xy)) {
-            return true;
-        } else {
+        this.mouseDown = true;
-        return false;
+        this.modifyFeature(evt.xy);
+        return !this.stopDown;
@@ -343,7 +365,7 @@
         return true;
@@ -361,13 +383,42 @@
+        // check keyboard modifiers
+        if(!this.checkModifiers(evt)) {
+            return true;
+        // ignore double-clicks
+        if(this.lastUp && this.lastUp.equals(evt.xy)) {
+            return true;
+        if(this.lastDown && this.lastDown.equals(evt.xy)) {
             this.finalize();
-            return false;
         } else {
             return true;
+     * Method: mouseout
+     * Handle mouse out.  For better user experience reset mouseDown
+     * and stoppedDown when the mouse leaves the map viewport.
+     * Parameters:
+     * evt - {Event} The browser event
+    mouseout: function(evt) {
+        if(OpenLayers.Util.mouseLeft(evt, this.map.viewPortDiv)) {
     CLASS_NAME: "OpenLayers.Handler.Point"
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Polygon.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Polygon.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Polygon.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -75,6 +75,9 @@
      *     feature.
+        if(!pixel) {
@@ -82,13 +85,27 @@
         this.line = new OpenLayers.Feature.Vector(
             new OpenLayers.Geometry.LinearRing([this.point.geometry])
-        // check for hole digitizing
-        var polygon;
-        if (this.holeModifier && (this.evt[this.holeModifier])) {
+        this.polygon = new OpenLayers.Feature.Vector(
+            new OpenLayers.Geometry.Polygon([this.line.geometry])
+        this.callback("create", [this.point.geometry, this.getSketch()]);
+        this.point.geometry.clearBounds();
+        this.layer.addFeatures([this.polygon, this.point], {silent: true});
+     * Method: addPoint
+     * Add point to geometry.
+     * Parameters:
+     * pixel - {<OpenLayers.Pixel>} The pixel location for the new point.
+    addPoint: function(pixel) {
+        if(!this.drawingHole && this.holeModifier &&
+           this.evt && this.evt[this.holeModifier]) {
             var geometry = this.point.geometry;
             var features = this.control.layer.features;
-            var candidate;
+            var candidate, polygon;
             // look for intersections, last drawn gets priority
             for (var i=features.length-1; i>=0; --i) {
                 candidate = features[i].geometry;
@@ -110,15 +127,7 @@
-        if (!polygon) {
-            this.polygon = new OpenLayers.Feature.Vector(
-                new OpenLayers.Geometry.Polygon([this.line.geometry])
-        this.callback("create", [this.point.geometry, this.getSketch()]);
-        this.point.geometry.clearBounds();
-        this.layer.addFeatures([this.polygon, this.point], {silent: true});
+        OpenLayers.Handler.Path.prototype.addPoint.apply(this, arguments);
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Kinetic.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Kinetic.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Kinetic.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -63,7 +63,6 @@
      * Method: begin
      * Begins the dragging.
     begin: function() {
@@ -74,8 +73,10 @@
      * Method: update
+     * Updates during the dragging.
-     * Updates during the dragging.
+     * Parameters:
+     * xy - {<OpenLayers.Pixel>} The new position.
     update: function(xy) {
         this.points.unshift({xy: xy, tick: new Date().getTime()});
@@ -86,8 +87,15 @@
      * Method: end
+     * Ends the dragging, start the kinetic.
-     * Ends the dragging, start the kinetic.
+     * Parameters:
+     * xy - {<OpenLayers.Pixel>} The last position.
+     * Returns:
+     * {Object} An object with two properties: "speed", and "theta". The
+     *     "speed" and "theta" values are to be passed to the move
+     *     function when starting the animation.
     end: function(xy) {
         var last, now = new Date().getTime();
@@ -117,12 +125,13 @@
      * Method: move
      * Launch the kinetic move pan.
      * Parameters:
-     * info - {Object}
-     * callback - arguments x, y (values to pan), end (is the last point)
+     * info - {Object} An object with two properties, "speed", and "theta".
+     *     These values are those returned from the "end" call.
+     * callback - {Function} Function called on every step of the animation,
+     *     receives x, y (values to pan), end (is the last point).
     move: function(info, callback) {
         var v0 = info.speed;
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Map.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Map.js	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Map.js	2011-02-24 09:58:10 UTC (rev 11388)
@@ -507,18 +507,27 @@
         this.viewPortDiv.className = "olMapViewport";
         this.div.appendChild(this.viewPortDiv);
+        // the eventsDiv is where we listen for all map events
+        var eventsDiv = document.createElement("div");
+        eventsDiv.id = this.id + "_events";
+        eventsDiv.style.position = "absolute";
+        eventsDiv.style.width = "100%";
+        eventsDiv.style.height = "100%";
+        eventsDiv.style.zIndex = this.Z_INDEX_BASE.Control - 1;
+        this.viewPortDiv.appendChild(eventsDiv);
+        this.eventsDiv = eventsDiv;
+        this.events = new OpenLayers.Events(
+            this, this.eventsDiv, this.EVENT_TYPES, this.fallThrough,
+            {includeXY: true}
         // the layerContainerDiv is the one that holds all the layers
         id = this.id + "_OpenLayers_Container";
         this.layerContainerDiv = OpenLayers.Util.createDiv(id);
         this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;
-        this.viewPortDiv.appendChild(this.layerContainerDiv);
+        this.eventsDiv.appendChild(this.layerContainerDiv);
-        this.events = new OpenLayers.Events(this,
-                                            this.viewPortDiv,
-                                            this.EVENT_TYPES,
-                                            this.fallThrough,
-                                            {includeXY: true});
         this.updateSize();
         if(this.eventListeners instanceof Object) {
             this.events.on(this.eventListeners);
Modified: sandbox/crschmidt/pan-tap/tests/BaseTypes/Bounds.html
--- sandbox/crschmidt/pan-tap/tests/BaseTypes/Bounds.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/BaseTypes/Bounds.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -606,6 +606,7 @@
         t.ok( bounds.equals(b), "bounds is set correctly");
     //null values
+        OpenLayers.Lang.setCode('en');
         var desiredMsg = "You must pass both x and y values to the add function.";
         OpenLayers.Console.error = function(msg) {
             t.eq(msg, desiredMsg, "error correctly reported");
Modified: sandbox/crschmidt/pan-tap/tests/BaseTypes/LonLat.html
--- sandbox/crschmidt/pan-tap/tests/BaseTypes/LonLat.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/BaseTypes/LonLat.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -64,6 +64,7 @@
         t.ok( addpx.equals(ll), "addpx is set correctly");
     //null values
         var desiredMsg = "You must pass both lon and lat values to the add function.";
Modified: sandbox/crschmidt/pan-tap/tests/BaseTypes/Pixel.html
--- sandbox/crschmidt/pan-tap/tests/BaseTypes/Pixel.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/BaseTypes/Pixel.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -74,6 +74,7 @@
         t.ok( pixel.equals(px), "returned pixel is correct");
     //null values
Modified: sandbox/crschmidt/pan-tap/tests/Control/DrawFeature.html
--- sandbox/crschmidt/pan-tap/tests/Control/DrawFeature.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Control/DrawFeature.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -60,7 +60,7 @@
     function test_sketch_events(t) {
-        t.plan(6);
+        t.plan(12);
         var map = new OpenLayers.Map("map", {
             resolutions: [1]
@@ -69,37 +69,62 @@
             isBaseLayer: true
         var control = new OpenLayers.Control.DrawFeature(
-            layer, OpenLayers.Handler.Point
+            layer, OpenLayers.Handler.Path, {
+                handlerOptions: {persist: true}
         map.addLayer(layer);
         map.addControl(control);
         map.zoomToMaxExtent();
-        control.activate();
-        var log = {};
+        var log;
         layer.events.on({
             sketchstarted: function(event) {
-                log.event = event;
+                log['sketchstarted'] = event;
             sketchmodified: function(event) {
+                log['sketchmodified'] = event;
             sketchcomplete: function(event) {
+                log['sketchcomplete'] = event;
         // mock up draw/modify of a point
+        log = {};
+        control.activate();
+        t.eq(log.sketchstarted.type, "sketchstarted", "[activate] sketchstarted triggered");
+        t.geom_eq(log.sketchstarted.vertex, new OpenLayers.Geometry.Point(-250, 175), "[activate] correct vertex");
+        log = {};
+        map.events.triggerEvent("mousemove", {xy: new OpenLayers.Pixel(0, 0)});
+        t.eq(log.sketchmodified.type, "sketchmodified", "[mousemove] sketchmodified triggered");
+        t.geom_eq(log.sketchmodified.vertex, new OpenLayers.Geometry.Point(-200, 125), "[mousemove] correct vertex");
         map.events.triggerEvent("mousedown", {xy: new OpenLayers.Pixel(0, 0)});
-        t.eq(log.event.type, "sketchstarted", "[mousedown] sketchstarted triggered");
-        t.geom_eq(log.event.vertex, new OpenLayers.Geometry.Point(-200, 125), "[mousedown] correct vertex");
+        log = {};
+        map.events.triggerEvent("mouseup", {xy: new OpenLayers.Pixel(0, 0)});
+        t.eq(log.sketchmodified.type, "sketchmodified", "[mouseup] sketchmodified triggered");
+        t.geom_eq(log.sketchmodified.vertex, new OpenLayers.Geometry.Point(-200, 125), "[mouseup] correct vertex");
+        log = {};
         map.events.triggerEvent("mousemove", {xy: new OpenLayers.Pixel(10, 10)});
-        t.eq(log.event.type, "sketchmodified", "[mousemove] sketchmodified triggered");
-        t.geom_eq(log.event.vertex, new OpenLayers.Geometry.Point(-190, 115), "[mousemove] correct vertex");
-        map.events.triggerEvent("mouseup", {xy: new OpenLayers.Pixel(10, 10)});
-        t.eq(log.event.type, "sketchcomplete", "[mouseup] sketchcomplete triggered");
-        t.geom_eq(log.event.feature.geometry, new OpenLayers.Geometry.Point(-190, 115), "[mouseup] correct geometry");
+        t.geom_eq(log.sketchmodified.vertex, new OpenLayers.Geometry.Point(-190, 115), "[mousemove] correct vertex");
+        log = {};
+        map.events.triggerEvent("dblclick", {xy: new OpenLayers.Pixel(10, 10)});
+        t.eq(log.sketchcomplete.type, "sketchcomplete", "[dblclick] sketchcomplete triggered");
+        t.geom_eq(log.sketchcomplete.feature.geometry,
+                  new OpenLayers.Geometry.LineString([
+                      new OpenLayers.Geometry.Point(-200, 125),
+                      new OpenLayers.Geometry.Point(-190, 115)
+                  "[dblclick] correct geometry");
+        t.eq(log.sketchstarted.type, "sketchstarted", "[dblclick] sketchstarted triggered");
+        t.geom_eq(log.sketchstarted.vertex, new OpenLayers.Geometry.Point(-250, 175), "[dblclick] correct vertex");
         map.destroy();
Modified: sandbox/crschmidt/pan-tap/tests/Control/Geolocate.html
--- sandbox/crschmidt/pan-tap/tests/Control/Geolocate.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Control/Geolocate.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -62,6 +62,31 @@
         map.removeControl(control);
         map.setCenter(centerLL);
+    function test_getCurrentLocation(t) {
+        t.plan(5);
+        var control = new OpenLayers.Control.Geolocate({
+            geolocation: geolocation
+        map.addControl(control);
+        t.eq(control.getCurrentLocation(), false, 'getCurrentLocation return false if control hasnt been activated');
+        map.setCenter(centerLL);
+        t.eq(control.getCurrentLocation(), true, 'getCurrentLocation return true if control has been activated');
+        var center = map.getCenter();
+        t.eq(center.lon, 10, 'bound control sets the map lon when calling getCurrentLocation');
+        t.eq(center.lat, 10, 'bound control sets the map lat when calling getCurrentLocation');
+        control.deactivate();
+        map.removeControl(control);
+        var control2 = new OpenLayers.Control.Geolocate({
+        map.addControl(control2);
+        t.eq(control2.getCurrentLocation(), false, 'getCurrentLocation return false if control is in watch mode');
+        control2.deactivate();
+        map.removeControl(control2);
     function test_watch(t) {
         t.plan(2);
Modified: sandbox/crschmidt/pan-tap/tests/Control/Measure.html
--- sandbox/crschmidt/pan-tap/tests/Control/Measure.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Control/Measure.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -52,6 +52,7 @@
                 xy: new OpenLayers.Pixel(x, y)
+        trigger("mousemove", 0, 0);
         trigger("mousedown", 0, 0);
         trigger("mouseup", 0, 0);
         trigger("mousemove", 10, 10);
@@ -60,9 +61,10 @@
         // confirm that the sketch persists
         t.eq(control.handler.layer.features.length, 1, "feature persists");
-        // cancel and see that sketch is gone
+        // cancel and see that sketch is gone (do not forget that
+        // cancel will create the new feature)
         control.cancel();
-        t.eq(control.handler.layer.features.length, 0, "feature is gone after cancel");
+        t.eq(control.handler.layer.features.length, 2, "feature is gone after cancel");
         map.destroy();
@@ -112,6 +114,7 @@
         var delay = control.partialDelay / 1000;
         // establish first point
@@ -187,6 +190,7 @@
                 log = [];
                 // f) establish first freehand point
                 t.eq(log.length, 0, "f) no event fired yet")
@@ -203,14 +207,14 @@
                 t.eq(log.length, 2, "h) event logged");
                 t.ok(log[1] && log[1].type == "measurepartial", "h) correct type");
                 t.ok(log[1] && log[1].measure == 20, "h) correct measure");
                 // i) mouse up to finish
                 trigger("mouseup", 20, 0);
                 t.eq(log.length, 3, "i) event logged");
                 t.ok(log[2] && log[2].type == "measure", "i) correct type");
                 t.ok(log[2] && log[2].measure == 20, "i) correct measure");
                 // j) clean up
                 log = [];
                 map.destroy();
@@ -224,7 +228,7 @@
     function test_immediate(t) {
-        t.plan(29);
+        t.plan(32);
         var map = new OpenLayers.Map({
             div: "map",
@@ -237,7 +241,7 @@
             center: new OpenLayers.LonLat(0, 0)
         var log = [];
         var control = new OpenLayers.Control.Measure(
@@ -255,7 +259,7 @@
         control.activate();
         // convenience function to trigger mouse events
         function trigger(type, x, y) {
             map.events.triggerEvent(type, {
@@ -267,6 +271,7 @@
         // a) establish first point
@@ -274,7 +279,7 @@
         trigger("mousemove", 0, 10);
         t.eq(log.length, 0, "a) no event fired yet");
         t.delay_call(
             delay, function() {
                 // confirm measurepartial is fired
@@ -334,18 +339,21 @@
                 // i) double click to finish
                 trigger("mousedown", 0, 60);
+                t.eq(log.length, 7, "i) event logged");
+                t.eq(log[6] && log[6].type, "measurepartial", "i) correct type");
+                t.eq(log[6] && log[6].measure, 60, "i) correct measure");
                 trigger("mouseup", 0, 60);
-                t.eq(log.length, 6, "i) no event fired yet");
+                t.eq(log.length, 7, "i) no event fired yet");
             delay, function() {
-                t.eq(log.length, 7, "i) event logged");
-                t.ok(log[6] && log[6].type == "measurepartial", "i) correct type");
-                t.ok(log[6] && log[6].measure == 60, "i) correct measure");
+                t.eq(log.length, 8, "i) event logged");
+                t.eq(log[7] && log[7].type, "measurepartial", "i) correct type");
+                t.eq(log[7] && log[7].measure, 60, "i) correct measure");
                 trigger("dblclick", 0, 60);
-                t.eq(log.length, 8, "i) event logged");
-                t.ok(log[7] && log[7].type == "measure", "i) correct type");
-                t.ok(log[7] && log[7].measure == 60, "i) correct measure");
+                t.eq(log.length, 9, "i) event logged");
+                t.eq(log[8] && log[8].type, "measure", "i) correct type");
+                t.eq(log[8] && log[8].measure, 60, "i) correct measure");
                 // clear log
                 log = [];
Modified: sandbox/crschmidt/pan-tap/tests/Control/PanZoom.html
--- sandbox/crschmidt/pan-tap/tests/Control/PanZoom.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Control/PanZoom.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -72,65 +72,65 @@
                     simulateClick(wnd, wnd.control.buttons[0]);
                     t.delay_call(2, function() {
-                        t.ok( wnd.mapper.getCenter().lat > wnd.centerLL.lat, "Pan up works correctly" );
-                        t.ok(!flag.mousedown, "mousedown does not get to the map");
-                        t.ok(flag.mouseup, "mouseup does get to the map");
-                        t.ok(!flag.click, "click does not get to the map");
-                        t.ok(!flag.dblclick, "dblclick does not get to the map");
+                        t.ok( wnd.mapper.getCenter().lat > wnd.centerLL.lat, "1) Pan up works correctly" );
+                        t.ok(!flag.mousedown, "1) mousedown does not get to the map");
+                        t.ok(!flag.mouseup, "1) mouseup does not get to the map");
+                        t.ok(!flag.click, "1) click does not get to the map");
+                        t.ok(!flag.dblclick, "1) dblclick does not get to the map");
                         resetFlags();
                         simulateClick(wnd, wnd.control.buttons[1]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lon < wnd.centerLL.lon, "Pan left works correctly" );
+                    t.ok( wnd.mapper.getCenter().lon < wnd.centerLL.lon, "2) Pan left works correctly" );
+                    t.ok(!flag.mousedown, "2) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "2) mouseup does not get to the map");
+                    t.ok(!flag.click, "2) click does not get to the map");
+                    t.ok(!flag.dblclick, "2) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[2]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lon == wnd.centerLL.lon, "Pan right works correctly" );
+                    t.ok( wnd.mapper.getCenter().lon == wnd.centerLL.lon, "3) Pan right works correctly" );
+                    t.ok(!flag.mousedown, "3) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "3) mouseup does not get to the map");
+                    t.ok(!flag.click, "3) click does not get to the map");
+                    t.ok(!flag.dblclick, "3) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[3]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lat == wnd.centerLL.lat, "Pan down works correctly" );
+                    t.ok( wnd.mapper.getCenter().lat == wnd.centerLL.lat, "4) Pan down works correctly" );
+                    t.ok(!flag.mousedown, "4) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "4) mouseup does not get to the map");
+                    t.ok(!flag.click, "4) click does not get to the map");
+                    t.ok(!flag.dblclick, "4) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[4]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 6, "zoomin works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 6, "5) zoomin works correctly" );
+                    t.ok(!flag.mousedown, "5) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "5) mouseup does not get to the map");
+                    t.ok(!flag.click, "5) click does not get to the map");
+                    t.ok(!flag.dblclick, "5) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[6]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 5, "zoomout works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 5, "6) zoomout works correctly" );
+                    t.ok(!flag.mousedown, "6) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "6) mouseup does not get to the map");
+                    t.ok(!flag.click, "6) click does not get to the map");
+                    t.ok(!flag.dblclick, "6) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[5]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 2, "zoomworld works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 2, "7) zoomworld works correctly" );
+                    t.ok(!flag.mousedown, "7) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "7) mouseup does not get to the map");
+                    t.ok(!flag.click, "7) click does not get to the map");
+                    t.ok(!flag.dblclick, "7) dblclick does not get to the map");
                     resetFlags();
Modified: sandbox/crschmidt/pan-tap/tests/Control/Scale.html
--- sandbox/crschmidt/pan-tap/tests/Control/Scale.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Control/Scale.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -2,6 +2,7 @@
 <head>
   <script src="../OLLoader.js"></script>
   <script type="text/javascript">
     var map;
     function test_Control_Scale_constructor (t) {
         t.plan( 2 );
Modified: sandbox/crschmidt/pan-tap/tests/Control/Split.html
--- sandbox/crschmidt/pan-tap/tests/Control/Split.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Control/Split.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -35,13 +35,20 @@
     function test_setSource(t) {
         t.plan(5);
-        var layer1 = new OpenLayers.Layer.Vector();
-        var layer2 = new OpenLayers.Layer.Vector();
+        var layer1 = new OpenLayers.Layer.Vector("foo", {
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+            isBaseLayer: true
+        var layer2 = new OpenLayers.Layer.Vector("foo", {
+            isBaseLayer: true
         var control = new OpenLayers.Control.Split({layer: layer1});
         var map = new OpenLayers.Map("map");
         map.addLayers([layer1, layer2]);
+        map.zoomToMaxExtent();
         control.activate();
@@ -64,12 +71,16 @@
     function test_activate(t) {
         t.plan(8);
-        var layer = new OpenLayers.Layer.Vector();
+        var layer = new OpenLayers.Layer.Vector("foo", {
+            isBaseLayer: true
         var control = new OpenLayers.Control.Split({layer: layer});
         // test activation with no source layer
         control.activate();
         t.eq(control.active, true, "control is active");
@@ -93,12 +104,16 @@
         t.plan(7);
+            isBaseLayer: true
         // activate and check sketch handler
         control.activate();
         t.ok(control.handler, "sketch handler present");
Modified: sandbox/crschmidt/pan-tap/tests/Handler/Click.html
--- sandbox/crschmidt/pan-tap/tests/Handler/Click.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Handler/Click.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -50,7 +50,8 @@
             map: map
         map.events.registerPriority = function(type, obj, func) {
-            var r = func();
+            var f = OpenLayers.Function.bind(func, obj)
+            var r = f({xy:null});
             if(typeof r == "string") {
                 // this is one of the mock handler methods
                 t.eq(OpenLayers.Util.indexOf(nonevents, type), -1,
Modified: sandbox/crschmidt/pan-tap/tests/Handler/Drag.html
--- sandbox/crschmidt/pan-tap/tests/Handler/Drag.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Handler/Drag.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -294,7 +294,7 @@
         // "touchend" events set expected states in the drag handler.
         // We also verify that we stop event bubbling as appropriate.
-        t.plan(12);
+        t.plan(14);
         // set up
@@ -302,37 +302,44 @@
         var c = new OpenLayers.Control();
         m.addControl(c);
         var h = new OpenLayers.Handler.Drag(c, {
-            done: function(px) { log = px; }});
+            done: function(px) {
+                log.push(px);
         h.activate();
         var _stop = OpenLayers.Event.stop;
-        OpenLayers.Event.stop = function(e) { log = e; };
+        OpenLayers.Event.stop = function(e) {
+            log.push(e);
-        var Px = OpenLayers.Pixel, e, log;
+        var Px = OpenLayers.Pixel, e;
+        var log = [];
         // test
         e = {touches: [{}], xy: new Px(0, 0)};
         m.events.triggerEvent('touchstart', e);
         t.eq(h.started, true, '[touchstart] started is set');
         t.eq(h.start.x, 0, '[touchstart] start.x is correct');
         t.eq(h.start.y, 0, '[touchstart] start.y is correct');
-        t.eq(log, undefined, '[touchstart] event is not stopped');
+        t.eq(log.length, 1, '[touchstart] one item in log');
+        t.ok(log[0] === e, "touchstart", '[touchstart] event is stopped');
         e = {xy: new Px(1, 1)};
         m.events.triggerEvent('touchmove', e);
         t.eq(h.dragging, true, '[touchmove] dragging is set');
-        t.eq(h.last.x, 1, '[touchstart] last.x is correct');
-        t.eq(h.last.y, 1, '[touchstart] last.y is correct');
-        t.ok(log == e, '[touchmove] event is stopped');
+        t.eq(h.last.x, 1, '[touchmove] last.x is correct');
+        t.eq(h.last.y, 1, '[touchmove] last.y is correct');
+        t.eq(log.length, 1, '[touchmove] one item in log (event is not stopped)');
         e = {xy: new Px(2, 2)};
         m.events.triggerEvent('touchend', e);
         t.eq(h.started, false, '[touchend] started is reset');
         // the "done" callback gets the position of the last touchmove
-        t.eq(log.x, 1, '[touchend] done callback got correct x position');
-        t.eq(log.y, 1, '[touchend] done callback got correct y position');
+        t.eq(log.length, 2, '[touchend] two items in log');
+        t.ok(log[1] instanceof Px, '[touchend] got');
+        t.ok(log[1].equals(e.xy), '[touchend] done callback got correct position');
         // tear down
Modified: sandbox/crschmidt/pan-tap/tests/Handler/Path.html
--- sandbox/crschmidt/pan-tap/tests/Handler/Path.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Handler/Path.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -25,12 +25,27 @@
     function test_Handler_Path_activation(t) {
-        t.plan(3);
-        var map = new OpenLayers.Map('map');
+        t.plan(12);
+        var log = [];
+        var map = new OpenLayers.Map("map", {
+            resolutions: [1]
+            isBaseLayer: true
+        map.addLayer(layer);
         var control = new OpenLayers.Control();
+        var handler = new OpenLayers.Handler.Path(control, {
+            "create": function(g, f) {
+                log.push({geometry: g, feature: f});
+        control.handler = handler;
-        var handler = new OpenLayers.Handler.Path(control);
+        map.setCenter(new OpenLayers.LonLat(0, 0), 0);
         handler.active = true;
         var activated = handler.activate();
         t.ok(!activated,
              "activate returns false if the handler was already active");
@@ -38,39 +53,72 @@
         t.ok(activated,
              "activate returns true if the handler was not already active");
+        t.ok(handler.layer instanceof OpenLayers.Layer.Vector,
+             "activate creates a vector layer");
+        t.ok(handler.layer.map == map,
+             "activate adds the vector layer to the map");
+        t.ok(handler.point instanceof OpenLayers.Feature.Vector,
+             "activate creates a point feature");
+        t.ok(handler.point.layer == handler.layer,
+             "activate adds the point feature to the layer");
+        t.ok(handler.line instanceof OpenLayers.Feature.Vector,
+             "acttivates creates a line feature");
+        t.ok(handler.line.layer == handler.layer,
+             "activate adds the line feature to the layer");
+             "activate calls \"create\" once");
+        t.geom_eq(log[0].geometry, handler.point.geometry,
+                  "\"create\" called with expected geometry");
+        t.ok(log[0].feature == handler.line,
+             "\"create\" called with expected feature");
         activated = handler.deactivate();
         t.ok(activated,
              "deactivate returns true if the handler was active already");
-        map.destroy();
+        map.destroy();
-    function test_Handler_Path_bounds(t) {
+    function test_bounds(t) {
         t.plan(2);
+        var geometry;
         map.addLayer(new OpenLayers.Layer.WMS("", "", {}));
-        var handler = new OpenLayers.Handler.Path(control, {});
+        var handler = new OpenLayers.Handler.Path(control, {},
+            {stopDown: true, stopUp: true});
+        // click on (150, 75)
         var evt = {xy: new OpenLayers.Pixel(150, 75), which: 1};
+        handler.mousemove(evt);
         handler.mousedown(evt);
         handler.mouseup(evt);
-        var evt = {xy: new OpenLayers.Pixel(175, 100), which: 1};
+        // click on (175, 100)
+        evt = {xy: new OpenLayers.Pixel(175, 100), which: 1};
-        t.ok(handler.line.geometry.getBounds().equals(new OpenLayers.Bounds(0,-35.15625,35.15625,0)), "Correct bounds");
+        t.ok(handler.line.geometry.getBounds().equals(
+                    new OpenLayers.Bounds(0,-35.15625,35.15625,0)),
+             "Correct bounds");
+        // mousedown on (175, 100)
-        var evt = {xy: new OpenLayers.Pixel(125, 100), which: 1};
+        // mousemove to (125, 100)
+        evt = {xy: new OpenLayers.Pixel(125, 100), which: 1};
-        t.ok(!handler.line.geometry.getBounds().equals(new OpenLayers.Bounds(0,-35.15625,35.15625,0)), "Correct bounds after dragging without letting go. (Came out as "+handler.line.geometry.getBounds().toBBOX() + ".)");
+        // test that the bounds have changed
+        t.ok(!handler.line.geometry.getBounds().equals(
+             "Correct bounds after dragging without letting go. " +
+             "(Came out as " + handler.line.geometry.getBounds().toBBOX() +
         map.destroy();
     function test_callbacks(t) {
-        t.plan(15);
+        t.plan(45);
             resolutions: [1]
@@ -79,74 +127,347 @@
             isBaseLayer: true
-        var control = new OpenLayers.Control({
-        var log = {};
+        var control = new OpenLayers.Control({});
+        var logs = [], log;
             create: function() {
-                log.type = "create",
-                log.args = arguments
+                logs.push({type: "create", args: arguments});
+            point: function() {
+                logs.push({type: "point", args: arguments});
             modify: function() {
-                log.type = "modify",
+                logs.push({type: "modify", args: arguments});
             done: function() {
-                log.type = "done",
+                logs.push({type: "done", args: arguments});
-                log.type = "cancel",
+                logs.push({type: "cancel", args: arguments});
-        // mock up feature drawing
+        // create line
         handler.activate();
-        handler.mousedown({type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
-        t.eq(log.type, "create", "[mousedown] create called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75), "[mousedown] correct vertex");
-        t.ok(log.args[1] === handler.line, "[mousedown] correct sketch feature");
+        t.eq(logs.length, 1, "[activate] called back");
+        log = logs.shift();
+        t.eq(log.type, "create", "[activate] create called");
+        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-200, 125),
+                  "[activate] correct point");
+        t.ok(log.args[1] == handler.line,
+             "[activate] correct feature");
+        // mouse move
+            {type: "mousemove", xy: new OpenLayers.Pixel(0, 0)});
+        t.eq(logs.length, 1, "[mousemove] called back");
+        t.eq(log.type, "modify", "[mousemove] modify called");
+        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75),
+                  "[mousemove] correct point");
+        t.ok(log.args[1] === handler.line,
+             "[mousemove] correct feature");
+        // mouse down
+        handler.mousedown(
+            {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
+        t.eq(logs.length, 1, "[mousedown] called back");
+        t.eq(log.type, "modify", "[mousedown] modify called");
+                  "[mousedown] correct point");
+             "[mousedown] correct feature");
+        // mouse up
         handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
+        t.eq(logs.length, 2, "[mouseup] called back twice");
+        t.eq(log.type, "point", "[mouseup] point called");
+                  "[mouseup] correct point");
+        t.geom_eq(log.args[1],
+                      new OpenLayers.Geometry.Point(-150, 75),
+                  ]), "[mouseup] correct line");
         t.eq(log.type, "modify", "[mouseup] modify called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75), "[mouseup] correct vertex");
-        t.ok(log.args[1] === handler.line, "[mouseup] correct sketch feature");
-        handler.mousemove({type: "mousemove", xy: new OpenLayers.Pixel(1, 1)});
+             "[mouseup] correct feature");
+        // mouse move
+        handler.mousemove({type: "mousemove",
+                           xy: new OpenLayers.Pixel(1, 1)});
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-149, 74), "[mousemove] correct vertex");
-        t.ok(log.args[1] === handler.line, "[mousemove] correct sketch feature");
-        handler.mousemove({type: "mousemove", xy: new OpenLayers.Pixel(10, 10)});
+        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-149, 74),
+        // mouse move
+                           xy: new OpenLayers.Pixel(10, 10)});
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-140, 65), "[mousemove] correct vertex");
-        handler.mousedown({type: "mousedown", xy: new OpenLayers.Pixel(10, 10)});
-        handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(10, 10)});
-        handler.dblclick({type: "dblclick", xy: new OpenLayers.Pixel(10, 10)});
+        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-140, 65),
+        // mouse down
+        handler.mousedown({type: "mousedown",
+        // mouse up ("point", "modify")
+        handler.mouseup({type: "mouseup",
+        // mouse down
+        t.eq(logs.length, 0, "[mousedown] called back");
+        // mouse up
+        t.eq(logs.length, 0, "[mouseup] not called back");
+        // double click
+        handler.dblclick({type: "dblclick",
+        t.eq(logs.length, 2, "[dblclick] called back twice");
         t.eq(log.type, "done", "[dblclick] done called");
-        t.geom_eq(
-            log.args[0],
             "[dblclick] correct linestring"
-        // mock up sketch cancel
-        handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
-        handler.deactivate();
-        t.eq(log.type, "cancel", "[deactivate while drawing] cancel called");
+        t.eq(log.type, "create", "[dblclick] create called");
+                  "[dblclick] correct point");
+             "[dblclick] correct feature");
+        // cancel
+        handler.cancel();
+        t.eq(logs.length, 2, "[cancel] called back");
+        t.eq(log.type, "cancel", "[cancel] canced called");
+            "[cancel] correct linestring"
+        t.eq(log.type, "create", "[cancel] create called");
+                  "[cancel] correct point");
         map.destroy();
+    function test_toggle_freehand(t) {
+        t.plan(2);
+            resolutions: [1]
+            isBaseLayer: true
+            done: function(g) {
+                log++;
+        }, {persist: true});
+        handler.activate();
+        log = 0;
+            {type: "mousedown", xy: new OpenLayers.Pixel(0, 0), shiftKey: true});
+            {type: "mousemove", xy: new OpenLayers.Pixel(1, 1), shiftKey: true});
+            {type: "mousemove", xy: new OpenLayers.Pixel(2, 2), shiftKey: true});
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(0, 0), shiftKey: true});
+        t.eq(log, 1, "feature drawn when shift pressed on mousedown");
+        log = 0;
+            {type: "mousedown", xy: new OpenLayers.Pixel(0, 0), shiftKey: false});
+        handler.mouseup(
+        t.eq(log, 0, "feature not drawn when shift not pressed on mousedown");
+    function test_persist(t) {
+        t.plan(4);
+            resolutions: [1]
+            isBaseLayer: true
+        var handler = new OpenLayers.Handler.Path(control, {});
+        handler.persist = false;
+        var feature1 = handler.line;
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
+            {type: "mousemove", xy: new OpenLayers.Pixel(1, 1)});
+        handler.dblclick(
+            {type: "dblclick", xy: new OpenLayers.Pixel(1, 1)});
+        t.ok(feature1.layer == null, "a) feature1 destroyed");
+        handler.persist = true;
+        var feature2 = handler.line;
+        handler.mouseup(
+        handler.dblclick(
+        t.ok(feature2.layer != null, "b) feature2 not destroyed");
+        var feature3 = handler.line;
+        handler.mouseup(
+        handler.dblclick(
+        t.ok(feature3.layer != null, "c) feature3 not destroyed");
+        t.ok(feature2.layer == null, "c) feature2 destroyed");
+        map.destroy();
+    function test_persist_freehand(t) {
+        t.plan(6);
+            resolutions: [1]
+            isBaseLayer: true
+        handler.mouseup(
+        feature2 = handler.line;
+        handler.mouseup(
+        feature3 = handler.line;
+        handler.mouseup(
+        feature4 = handler.line;
+        handler.mouseup(
+        t.ok(feature4.layer != null, "d) feature4 not destroyed");
+        t.ok(feature3.layer == null, "c) feature3 destroyed");
+        map.destroy();
     function test_Handler_Path_destroy(t) {
         t.plan(6);
@@ -175,9 +496,251 @@
              "handler.line is null after destroy");
         map.destroy();
+    // Sequence tests
+    // Sequence tests basically involve executing a sequence of events
+    // and testing the resulting geometry.
+    // Below are tests for various drawing sequences. Tests can be
+    // added here each a non-working sequence is found.
+    // stopDown:true, stopUp:true
+    // a) click on (0, 0)
+    // b) mousedown on (0.5, 0.5)
+    // c) mouseup on (1, 1)
+    // d) dblclick on (10, 10)
+    function test_sequence1(t) {
+        t.plan(1);
+            resolutions: [1]
+            isBaseLayer: true
+            {done: function(g) { log.geometry = g; }},
+        log = {};
+        handler.mouseup(
+            {type: "mousemove", xy: new OpenLayers.Pixel(0.5, 0.5)});
+            {type: "mousedown", xy: new OpenLayers.Pixel(0.5, 0.5)});
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(1, 1)});
+            {type: "mousemove", xy: new OpenLayers.Pixel(10, 10)});
+            {type: "mousedown", xy: new OpenLayers.Pixel(10, 10)});
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(10, 10)});
+        handler.dblclick(
+            {type: "dblclick", xy: new OpenLayers.Pixel(10, 10)});
+        t.geom_eq(log.geometry,
+                new OpenLayers.Geometry.Point(-150, 75), // (0, 0)
+                new OpenLayers.Geometry.Point(-140, 65)  // (10, 10)
+            ]), "geometry is correct");
+    // stopDown:false, stopUp:false
+    function test_sequence2(t) {
+        t.plan(1);
+            resolutions: [1]
+            isBaseLayer: true
+            {stopDown: false, stopUp: false}
+        log = {};
+        handler.mouseup(
+        handler.mouseup(
+        handler.mouseup(
+        handler.dblclick(
+    // a) click
+    // b) dblclick
+    // c) mousedown holding shift key
+    // d) mousemove holding shift key
+    function test_sequence3(t) {
+        t.plan(1);
+            resolutions: [1]
+            isBaseLayer: true
+        handler.mouseup(
+        // b) click on (1, 1)
+            {type: "mousedown", xy: new OpenLayers.Pixel(1, 1)});
+        handler.mouseup(
+        // c) click on (1, 1)
+        handler.mouseup(
+        // d) mousemove to (10, 10)
+            {type: "mousemove", xy: new OpenLayers.Pixel(10, 10), shiftKey: true});
+        t.geom_eq(handler.line.geometry,
+                new OpenLayers.Geometry.Point(-149, 74), // (1, 1)
+            ]), "geometry is correct after mousemove");
+    // a) click
+    // b) dblclick
+    function test_sequence4(t) {
+        t.plan(2);
+            resolutions: [1]
+            isBaseLayer: true
+        log = {};
+        handler.mouseup(
+        // b) dblclick on (1, 1)
+        handler.mouseup(
+        handler.dblclick(
+                new OpenLayers.Geometry.Point(-149, 74)  // (1, 1)
+            ]), "geometry is correct after dblclick");
+        // c) mousedown holding shift key on (1, 1)
+            {type: "mousedown", xy: new OpenLayers.Pixel(1, 1), shiftKey: true});
+        // d) mousemove holding shift key to (10, 10)
   </script>
 </head>
 <body>
Modified: sandbox/crschmidt/pan-tap/tests/Handler/Point.html
--- sandbox/crschmidt/pan-tap/tests/Handler/Point.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Handler/Point.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -25,11 +25,26 @@
     function test_Handler_Point_activation(t) {
-        t.plan(3);
+        t.plan(10);
+        var log = [];
+            resolutions: [1]
+            isBaseLayer: true
+        var handler = new OpenLayers.Handler.Point(control, {
-        var handler = new OpenLayers.Handler.Point(control);
         t.ok(!activated,
@@ -38,24 +53,52 @@
         t.ok(activated,
+             "activate creates a feature");
+             "activate adds the feature to the layer");
+        t.ok(log[0].feature == handler.point,
         t.ok(activated,
+        map.destroy();
     function test_Handler_Point_events(t) {
-        t.plan(29);
-        var control = {
-            map: map
+        t.plan(34);
+        var log = [];
+            resolutions: [1]
+            isBaseLayer: true
+        var control = new OpenLayers.Control();
         // list below events that should be handled (events) and those
         // that should not be handled (nonevents) by the handler
-        var events = ["click", "dblclick", "mousedown", "mouseup", "mousemove"];
-        var nonevents = ["mouseout", "resize", "focus", "blur"];
+        var events = ["click", "dblclick", "mousedown", "mouseup", "mousemove", "mouseout"];
+        var nonevents = ["resize", "focus", "blur"];
             var r = func();
@@ -99,7 +142,7 @@
-        t.plan(10);
+        t.plan(28);
             resolutions: [1]
@@ -108,68 +151,189 @@
             isBaseLayer: true
-        var log = {};
             done: function() {
+        // create point
         handler.activate();
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75), "[mousedown] correct point");
-        t.geom_eq(log.args[1].geometry, new OpenLayers.Geometry.Point(-150, 75), "[mousedown] correct sketch feature");
-        handler.mousemove({type: "mousemove", xy: new OpenLayers.Pixel(1, 0)});
+        // mouse down
+        t.geom_eq(log.args[1].geometry,
+        // mouse move
+            {type: "mousemove", xy: new OpenLayers.Pixel(1, 0)});
+        t.eq(logs.length, 0, "[mousemove] not called back");
+        // mouse up (no finalize - we moved)
+        handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(1, 0)});
+        // mouse move
+            {type: "mousemove", xy: new OpenLayers.Pixel(2, 0)});
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-149, 75), "[mousemove] correct point");
-        t.geom_eq(log.args[1].geometry, new OpenLayers.Geometry.Point(-149, 75), "[mousemove] correct sketch feature");
-        handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(1, 0)});
+        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-148, 75),
+                  new OpenLayers.Geometry.Point(-148, 75),
+        // mouse down
+            {type: "mousedown", xy: new OpenLayers.Pixel(2, 0)});
+        // mouse up
+        handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(2, 0)});
         t.eq(log.type, "done", "[mouseup] done called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-149, 75), "[mouseup] correct point");
+        t.eq(log.type, "create", "[mouseup] create called");
+        // mouse up on same pixel
+        // cancel
+        handler.cancel();
-        // mock up feature drawing with a cancel
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75), "[deactivate while drawing] correct point");
+        map.destroy();
+        t.plan(3);
+            resolutions: [1]
+            isBaseLayer: true
+        var handler = new OpenLayers.Handler.Point(control, {});
+        handler.mouseup(
+        t.eq(handler.layer.features.length, 1,
+             "feature destroyed on mouseup when persist is false");
+            {type: "mousedown", xy: new OpenLayers.Pixel(1, 0)});
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(1, 0)});
+        t.eq(handler.layer.features.length, 2,
+             "feature not destroyed on mouseup when persist is true");
+        var feature = handler.layer.features[0];
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(2, 0)});
+        t.ok(handler.layer.features[0] !== feature,
+             "persisted feature destroyed on next mouseup");
         map.destroy();
     function test_Handler_Point_deactivation(t) {
-        t.plan(1);
+        t.plan(5);
+        var log = [];
+            resolutions: [1]
+            isBaseLayer: true
+            "cancel": function(g) {
+                log.push({geometry: g});
-        var handler = new OpenLayers.Handler.Point(control, {foo: 'bar'});
         handler.activate();
+        var _layer = handler.layer;
+        var _geometry = handler.point.geometry;
+        handler.deactivate();
+        t.eq(_layer.map, null,
+             "deactivates removes the layer from the map");
+        t.eq(handler.layer, null,
+             "deactivates sets its \"layer\" property to null");
+             "deactivates calls \"cancel\" once");
+        t.ok(log[0].geometry.equals(_geometry),
+             "\"cancel\" called with expected geometry");
         handler.layer.destroy();
              "deactivate doesn't throw an error if layer was" +
              " previously destroyed");
+        map.destroy();
     function test_Handler_Point_bounds(t) {
@@ -183,7 +347,7 @@
         var px = new OpenLayers.Pixel(150, 75);
         var evt = {xy: px, which: 1};
-        handler.mousedown(evt);
         var lonlat = map.getLonLatFromPixel(px);
         t.eq(handler.point.geometry.x, lonlat.lon, "X is correct");
         t.eq(handler.point.geometry.y, lonlat.lat, "Y is correct");
@@ -203,8 +367,6 @@
         handler.activate();
-        var evt = {xy: new OpenLayers.Pixel(150, 75), which: 1};
         t.ok(handler.layer,
              "handler has a layer prior to destroy");
Modified: sandbox/crschmidt/pan-tap/tests/Handler/Polygon.html
--- sandbox/crschmidt/pan-tap/tests/Handler/Polygon.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Handler/Polygon.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -25,12 +25,27 @@
     function test_Handler_Polygon_activation(t) {
-        t.plan(3);
+        t.plan(13);
+        var log = [];
+            resolutions: [1]
+            isBaseLayer: true
+        var handler = new OpenLayers.Handler.Polygon(control, {
-        var handler = new OpenLayers.Handler.Polygon(control);
         t.ok(!activated,
@@ -38,41 +53,68 @@
         t.ok(activated,
+             "activates creates a line feature");
+        t.ok(handler.polygon instanceof OpenLayers.Feature.Vector,
+             "acttivates creates a polygon feature");
+        t.ok(handler.polygon.layer == handler.layer,
+             "activate adds the polygin feature to the layer");
+        t.ok(log[0].feature == handler.polygon,
         t.ok(activated,
-        map.destroy();
+        map.destroy();
-    function test_Handler_Polygon_bounds(t) {
+    function test_bounds_stopDown_true(t) {
         t.plan(2);
-        var handler = new OpenLayers.Handler.Polygon(control, {});
+        var handler = new OpenLayers.Handler.Polygon(control, {},
         t.ok(!handler.polygon.geometry.getBounds().equals(new OpenLayers.Bounds(0,-35.15625,35.15625,0)),
         map.destroy();
-        t.plan(15);
+        t.plan(45);
             resolutions: [1]
@@ -83,57 +125,141 @@
-        var log = {};
             done: function() {
+        // create polygon
         handler.activate();
-        // click at 0, 0
-        t.ok(log.args[1] === handler.polygon, "[mousedown] correct sketch feature");
+        t.ok(log.args[1] == handler.polygon,
+        t.ok(log.args[1] === handler.polygon,
+        // mouse down
+        // mouse up
+        handler.mouseup(
+        var geom = new OpenLayers.Geometry.Polygon([
+            new OpenLayers.Geometry.LinearRing([
+        geom.components[0].addComponent(
+            geom.components[0].components.length
+        t.geom_eq(log.args[1], geom, "[mouseup] correct polygon");
-        t.ok(log.args[1] === handler.polygon, "[mouseup] correct sketch feature");
-        // move to 10, 10 and click
+        // mouse move
+        // mouse down
+        // mouse up
+        handler.mouseup(
         // move to 0, 10 and double click
-        handler.mousemove({type: "mousemove", xy: new OpenLayers.Pixel(0, 10)});
+        // mouse move
+            {type: "mousemove", xy: new OpenLayers.Pixel(0, 10)});
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 65), "[mousemove] correct vertex");
-        handler.mousedown({type: "mousedown", xy: new OpenLayers.Pixel(0, 10)});
-        handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(0, 10)});
-        handler.dblclick({type: "dblclick", xy: new OpenLayers.Pixel(0, 10)});
+        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 65),
+        // mouse down
+            {type: "mousedown", xy: new OpenLayers.Pixel(0, 10)});
+        t.eq(logs.length, 1, "[mousedown] not called back");
+        // mouse up
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(0, 10)});
+        t.eq(logs.length, 2, "[mouseup] called back");
+        // mouse down
+        t.eq(logs.length, 0, "[mousedown] not called back");
+        // mouse up
+        handler.mouseup(
+        // dblclick
+        handler.dblclick(
+            {type: "dblclick", xy: new OpenLayers.Pixel(0, 10)});
         t.geom_eq(
             log.args[0],
@@ -147,17 +273,232 @@
             "[dblclick] correct polygon"
+        // cancel
+        handler.cancel();
         map.destroy();
+        t.plan(2);
+            resolutions: [1]
+            isBaseLayer: true
+                log++;
+        log = 0;
+        handler.mouseup(
+        log = 0;
+        handler.mouseup(
+        t.plan(4);
+            resolutions: [1]
+            isBaseLayer: true
+        var handler = new OpenLayers.Handler.Polygon(control, {});
+        var feature1 = handler.polygon;
+        handler.mouseup(
+        handler.mouseup(
+            {type: "mousemove", xy: new OpenLayers.Pixel(2, 2)});
+        handler.dblclick(
+            {type: "dblclick", xy: new OpenLayers.Pixel(2, 2)});
+        var feature2 = handler.polygon;
+        handler.mouseup(
+        handler.mouseup(
+        handler.dblclick(
+        var feature3 = handler.polygon;
+        handler.mouseup(
+        handler.mouseup(
+        handler.dblclick(
+        map.destroy();
+        t.plan(6);
+            resolutions: [1]
+            isBaseLayer: true
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(2, 2), shiftKey: true});
+        handler.mouseup(
+        handler.mouseup(
+        feature4 = handler.polygon;
+        handler.mouseup(
+        map.destroy();
     function test_rings(t) {
         t.plan(12);
@@ -204,6 +545,7 @@
         log = [];
         // start at -9, 9
         event = {xy: new OpenLayers.Pixel(-9, 9)};
+        trigger("mousemove", event);
         trigger("mousedown", event);
         trigger("mouseup", event);
         // draw to -1, 9
@@ -228,7 +570,7 @@
         trigger("dblclick", event);
         // make assertions
-        t.eq(log.length, 9, "a) correct number of events");
+        t.eq(log.length, 14, "a) correct number of events");
         t.eq(log[log.length-1].type, "featureadded", "a) featureadded event last");
         t.eq(log[log.length-1].feature.geometry.getArea(), 64, "a) correct polygon area");
@@ -236,6 +578,7 @@
         log = [];
         // start at -6, 6
         event = {xy: new OpenLayers.Pixel(-6, 6), altKey: true};
         // draw to -3, 6
@@ -260,7 +603,7 @@
         // make assertions
-        t.eq(log.length, 8, "b) correct number of events");
+        t.eq(log.length, 13, "b) correct number of events");
         t.eq(log[log.length-1].type, "sketchcomplete", "b) sketchcomplete event last");
         t.eq(log[log.length-1].feature.geometry.getArea(), 55, "b) correct polygon area");
@@ -269,6 +612,7 @@
         log = [];
         // start at -2, 2
         event = {xy: new OpenLayers.Pixel(-2, 2)};
         // draw to 2, 2
@@ -293,7 +637,7 @@
         // make assertions
-        t.eq(log.length, 9, "c) correct number of events");
+        t.eq(log.length, 14, "c) correct number of events");
         t.eq(log[log.length-1].type, "featureadded", "c) featureadded event last");
         t.eq(log[log.length-1].feature.geometry.getArea(), 16, "c) correct polygon area");
@@ -301,6 +645,7 @@
         log = [];
         // start at -1, 1
         event = {xy: new OpenLayers.Pixel(-1, 1), altKey: true};
         // draw to 1, 1
@@ -330,7 +675,7 @@
         // make assertions
-        t.eq(log.length, 11, "d) correct number of events");
+        t.eq(log.length, 18, "d) correct number of events");
         t.eq(log[log.length-1].type, "sketchcomplete", "d) sketchcomplete event last");
         t.eq(log[log.length-1].feature.geometry.getArea(), 12, "d) correct polygon area");
@@ -338,7 +683,6 @@
         map.destroy();
     function test_Handler_Polygon_destroy(t) {
         t.plan(8);
@@ -372,8 +716,158 @@
         map.destroy();
+    // Sequence tests
+    // d) click on (0, 10)
+    // e) dblclick on (10, 10)
+        t.plan(1);
+            resolutions: [1]
+            isBaseLayer: true
+        log = {};
+        handler.mouseup(
+        handler.mouseup(
+        handler.mouseup(
+        handler.mouseup(
+        handler.dblclick(
+                    new OpenLayers.Geometry.Point(-150, 65), // (0, 10)
+        t.plan(1);
+            resolutions: [1]
+            isBaseLayer: true
+        log = {};
+        handler.mouseup(
+        handler.mouseup(
+        handler.mouseup(
+        handler.mouseup(
+        handler.dblclick(
   </script>
 </head>
 <body>
Modified: sandbox/crschmidt/pan-tap/tests/Layer/EventPane.html
--- sandbox/crschmidt/pan-tap/tests/Layer/EventPane.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Layer/EventPane.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -58,11 +58,11 @@
 //         t.plan( 2 );
         if (OpenLayers.BROWSER_NAME != "firefox" && OpenLayers.BROWSER_NAME != "mozilla") {
-          t.plan(4);
+            t.plan(4);
         } else {
-          t.plan(0);
-          t.debug_print("Firefox gives different results for different browsers on setMap on EventPane, so just don't run it for now.")
-          return;
+            t.plan(0);
+            t.debug_print("Firefox gives different results for different browsers on setMap on EventPane, so just don't run it for now.")
+            return;
@@ -84,19 +84,23 @@
         layer2.getWarningHTML = function() { this.warning = true; return ""; }
         map.addLayer(layer2);
-        t.ok( !layer2.warning, "warning not registered on mapObject load" );
+        t.ok(!layer2.warning, "warning not registered on mapObject load");
-        map.events.register("mousemove", map, function () {
-            t.ok(true, "got mouse move");
+        var log = [];
+        map.events.register("mousemove", map, function(event) {
+            log.push(event);
-        if( document.createEvent ) { // Mozilla
-          var evObj = document.createEvent('MouseEvents');
-          evObj.initEvent( 'mousemove', true, false );
-          layer.pane.dispatchEvent(evObj);
-        } else if( document.createEventObject ) { // IE
-          layer.pane.fireEvent('onmousemove');
+        if (document.createEvent) { // Mozilla
+            var evObj = document.createEvent('MouseEvents');
+            evObj.initEvent('mousemove', true, false);
+            map.eventsDiv.dispatchEvent(evObj);
+        } else if(document.createEventObject) { // IE
+            map.eventsDiv.fireEvent('onmousemove');
+        t.eq(log.length, 1, "got one event");
     function test_Layer_EventPane_setVisibility (t) {
Modified: sandbox/crschmidt/pan-tap/tests/Map.html
--- sandbox/crschmidt/pan-tap/tests/Map.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/Map.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -1667,7 +1667,26 @@
         map.destroy();
+    function test_pixel_lonlat(t) {
+        t.plan(4);
+        var map = new OpenLayers.Map({
+            div: "map",
+            layers: [
+                new OpenLayers.Layer("name", {isBaseLayer:true})
+        var px = map.getPixelFromLonLat(map.getLonLatFromPixel(new OpenLayers.Pixel(100, 100)));
+        t.eq(px.x, 100, "x is the same in and ot");
+        t.eq(px.y, 100, "y is the same in and out");
+        var ll = map.getLonLatFromPixel(map.getPixelFromLonLat(new OpenLayers.LonLat(100, 100)));
+        t.ok((ll.lon > (100 -map.getResolution()) && (ll.lon < (100 + map.getResolution()))), "lon is the same in and ot");
+        t.ok((ll.lat > (100 -map.getResolution()) && (ll.lat < (100 + map.getResolution()))), "lat is the same in and ot");
+        map.destroy();
   </script>
 </head>
 <body>
Modified: sandbox/crschmidt/pan-tap/tests/run-tests.html
--- sandbox/crschmidt/pan-tap/tests/run-tests.html	2011-02-24 09:37:47 UTC (rev 11387)
+++ sandbox/crschmidt/pan-tap/tests/run-tests.html	2011-02-24 09:58:10 UTC (rev 11388)
@@ -686,7 +686,7 @@
 		timeout_seconds=4;
 	var no_close=document.getElementById( "dont_close_test_windows" );
-	var action={ action_kind: "window", wnd_url: url.toString(), wnd_wnd: null, wnd_fn: fn, wnd_timeout_milliseconds: timeout_seconds*1000, wnd_no_close: no_close.checked };
+	var action={ action_kind: "window", wnd_url: url.toString() + (window.location.search || ""), wnd_wnd: null, wnd_fn: fn, wnd_timeout_milliseconds: timeout_seconds*1000, wnd_no_close: no_close.checked };
 	this.delay_total_milliseconds_left+=Test.AnotherWay._action_estimate_milliseconds( action );
 	this.delay_actions.push( action );
@@ -2410,4 +2410,10 @@
 </div>
 </span>
+<script>
+    if (/noscroll/.test(location.href)) {
+        document.getElementById('scroller').style.height='auto';
+        document.getElementById('right_frame').style.height='auto';
+</script>
 </body></html>
More information about the Commits mailing list
