[OpenLayers-Commits] r11390 - sandbox/bartvde/sencha/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 24 05:08:20 EST 2011
Author: bartvde
Date: 2011-02-24 02:08:20 -0800 (Thu, 24 Feb 2011)
New Revision: 11390
   sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.html
   sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.js
adding the search from Marc Jansen
Modified: sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.html
--- sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.html	2011-02-24 10:05:49 UTC (rev 11389)
+++ sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.html	2011-02-24 10:08:20 UTC (rev 11390)
@@ -52,7 +52,17 @@
                         items: [{
                             iconCls: "search",
-                            iconMask: true
+                            iconMask: true,
+                            handler: function(){
+                                // this is the app
+                                if (!this.searchFormPopupPanel) {
+                                    this.searchFormPopupPanel = new GeoExt.SearchFormPopupPanel({
+                                        map: map
+                                this.searchFormPopupPanel.show('pop');
+                            scope: app
                             iconCls: "locate",
                             iconMask: true,
Modified: sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.js
--- sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.js	2011-02-24 10:05:49 UTC (rev 11389)
+++ sandbox/bartvde/sencha/openlayers/examples/mobile-sencha.js	2011-02-24 10:08:20 UTC (rev 11390)
@@ -1,18 +1,118 @@
 Ext.ns('GeoExt');
+Ext.regModel('Geonames', {
+    fields: ['countryName', 'toponymName', 'name', 'lat', 'lng']
+GeoExt.SearchFormPopupPanel = Ext.extend(Ext.Panel, {
+    map: null,
+    floating: true,
+    modal: true,
+    centered: true,
+    hideOnMaskTap: true,
+    width: Ext.is.Phone ? undefined : 400,
+    height: Ext.is.Phone ? undefined : 400,
+    scroll: false,
+    layout: 'fit',
+    fullscreen: Ext.is.Phone ? true : undefined,
+    url: 'http://ws.geonames.org/searchJSON?',
+    errorText: 'Sorry, we had problems communicating with geonames.org. Please try again.',
+    errorTitle: 'Communication error',
+    maxResults: 6,
+    featureClass: "P",
+    createStore: function() {
+        this.store = new Ext.data.Store({
+            model: 'Geonames',
+            proxy: {
+                type: 'scripttag',
+                timeout: 5000,
+                listeners: {
+                    exception: function() {
+                        Ext.Msg.alert(this.errorTitle, this.errorText, Ext.emptyFn);
+                    scope: this
+                url: this.url,
+                reader: {
+                    type: 'json',
+                    root: 'geonames'
+    doSearch: function(searchfield, evt){
+        var q = searchfield.getValue();
+        if (q.length > 3) {
+            this.store.load({
+                params: {
+                    featureClass: this.featureClass,
+                    maxRows: this.maxResults,
+                    name_startsWith: encodeURIComponent(q)
+    onItemTap: function(dataView, index, item, event){
+        var record = this.store.getAt(index);
+        var lon = record.get('lng');
+        var lat = record.get('lat');
+        var ll = new OpenLayers.LonLat(lon, lat);
+        var center = ll.transform(new OpenLayers.Projection('EPSG:4326'),
+            this.map.getProjectionObject());
+        this.map.setCenter(center);
+        this.hide("pop");
+    initComponent: function() {
+        this.createStore();
+        this.resultList = new Ext.List({
+            scroll: 'vertical',
+            store: this.store,
+            itemTpl: '<div>{name} ({countryName})</div>',
+            listeners: {
+                itemtap: this.onItemTap,
+                scope: this
+        this.formContainer = new Ext.form.FormPanel({
+            scroll: false,
+            items: [{
+                xtype: 'fieldset',
+                scroll: false,
+                title: 'Search for a place',
+                items: [{
+                    xtype: 'searchfield',
+                    label: 'Search',
+                    placeHolder: 'placename',
+                    listeners: {
+                        action: this.doSearch,
+                        scope: this
+                }, this.resultList]
+        this.items = [this.formContainer];
+        GeoExt.SearchFormPopupPanel.superclass.initComponent.call(this);
 GeoExt.LayerList = Ext.extend(Ext.List, {
     map: null,
-    createStore: function() {
+    createStore: function(){
         Ext.regModel('Layer', {
             fields: ['id', 'name', 'visibility', 'zindex']
         var data = [];
-        Ext.each(this.map.layers, function(layer) {
+        Ext.each(this.map.layers, function(layer){
             if (layer.displayInLayerSwitcher === true) {
                 var visibility = layer.isBaseLayer ? (this.map.baseLayer == layer) : layer.getVisibility();
-                data.push({id: layer.id, name: layer.name, visibility: visibility, zindex: layer.getZIndex()});
+                data.push({
+                    id: layer.id,
+                    name: layer.name,
+                    visibility: visibility,
+                    zindex: layer.getZIndex()
         return new Ext.data.Store({
@@ -21,24 +121,18 @@
             data: data
-    initComponent: function() {
+    initComponent: function(){
         this.store = this.createStore();
-        this.itemTpl = new Ext.XTemplate(
-            '<tpl if="visibility == true">',
-            '<img width="20" src="img/check-round-green.png">',
-            '</tpl>',
-            '<tpl if="visibility == false">',
-            '<img width="20" src="img/check-round-grey.png">',
-            '</tpl>',
-            '<span class="gx-layer-item">{name}</span>');
+        this.itemTpl = new Ext.XTemplate('<tpl if="visibility == true">', '<img width="20" src="img/check-round-green.png">', '</tpl>', '<tpl if="visibility == false">', '<img width="20" src="img/check-round-grey.png">', '</tpl>', '<span class="gx-layer-item">{name}</span>');
         this.listeners = {
-            itemtap: function(dataview, index, item, e) {
+            itemtap: function(dataview, index, item, e){
                 var record = dataview.getStore().getAt(index);
                 var layer = this.map.getLayersBy("id", record.get("id"))[0];
                 if (layer.isBaseLayer) {
                     this.map.setBaseLayer(layer);
-                } else {
+                else {
                     layer.setVisibility(!layer.getVisibility());
                 record.set("visibility", layer.getVisibility());
@@ -50,24 +144,24 @@
         GeoExt.LayerList.superclass.initComponent.call(this);
-    findLayerRecord: function(layer) {
+    findLayerRecord: function(layer){
         var found;
-        this.store.each(function(record) {
+        this.store.each(function(record){
             if (record.get("id") === layer.id) {
                 found = record;
         }, this);
         return found;
-    onChangeLayer: function(evt) {
+    onChangeLayer: function(evt){
         if (evt.property == "visibility") {
             var record = this.findLayerRecord(evt.layer);
-            record.set("visibility", evt.layer.getVisibility());
+            record.set("visibility", evt.layer.getVisibility());
 Ext.reg('gx_layerlist', GeoExt.LayerList);
More information about the Commits mailing list
