[OpenLayers-Commits] r11398 - in sandbox/crschmidt/pan-tap/lib/OpenLayers: Control Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 24 05:49:14 EST 2011
Author: crschmidt
Date: 2011-02-24 02:49:14 -0800 (Thu, 24 Feb 2011)
New Revision: 11398
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Navigation.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js
Improving documentation on new code.
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Navigation.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Navigation.js	2011-02-24 10:38:14 UTC (rev 11397)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Navigation.js	2011-02-24 10:49:14 UTC (rev 11398)
@@ -201,11 +201,22 @@
                                     this.mouseWheelOptions );
+     * Method: handleClick
+     * On tap devices (usually mobile devices with no touch support), when
+     *     receiving a click, pan to the event pixel. To override automatic
+     *     tap detection, pass clickOptions: {tap:false} to the control
+     *     options.
+     * Parameters:
+     * evt - {Event}
     handleClick: function(evt) {
         if (this.handlers.click.tap) {
             map.panTo(map.getLonLatFromPixel(evt.xy));
      * Method: defaultDblClick
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js	2011-02-24 10:38:14 UTC (rev 11397)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js	2011-02-24 10:49:14 UTC (rev 11398)
@@ -117,7 +117,32 @@
     tapTolerance: 50,
+     * Property: lastMove
+     * Timestamp for last move event. Used in a click handler to determine
+     *     whether the move/down/up are happening at very close to the same
+     *     time, and if so, setting the tap property on the control.
+    lastMove: null,
+     * Property: lastDown
+     * Timestamp for last down event. Used in a click handler to determine
+    lastDown: null,
+     * Property: lastUp
+     * Timestamp for last up event. Used in a click handler to determine
+    lastUp: null,
      * Property: rightclickTimerId
      * {Number} The id of the right mouse timeout waiting to clear the
      *     <delayedEvent>.
@@ -143,7 +168,14 @@
     initialize: function(control, callbacks, options) {
         OpenLayers.Handler.prototype.initialize.apply(this, arguments);
+     * Method: mouseover
+     * Handle mouseover. Record the firstMouseOver property on the
+     *    control, then unregister to save processing on further
+     *    mousemoves. This is designed primarily to support the 'tap'
+     *    property detection.
     mouseover: function(evt) {
         this.firstMouseOver = evt.xy;
         this.unregister("mouseover", this.mouseover);
@@ -166,7 +198,8 @@
      * Method: mousemove
-     * Handle mousemove. This is simply used to record
+     * Handle mousemove. This is simply used to record the last
+     *    time the mousemove event was triggered.
     mousemove: function(evt) {
More information about the Commits mailing list
