[OpenLayers-Commits] r11418 - in sandbox/ahocevar/layercontainer: lib/OpenLayers tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 24 09:13:35 EST 2011
Author: ahocevar
Date: 2011-02-24 06:13:35 -0800 (Thu, 24 Feb 2011)
New Revision: 11418
   sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js
   sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
   sandbox/ahocevar/layercontainer/tests/Map.html
reverted whitespace and doc changes
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js	2011-02-24 14:08:25 UTC (rev 11417)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js	2011-02-24 14:13:35 UTC (rev 11418)
@@ -77,8 +77,7 @@
      * loadcancel - Triggered when layer loading is canceled.
      * visibilitychanged - Triggered when layer visibility is changed.
      * move - Triggered when layer moves (triggered with every mousemove
-     *     during a drag). If available, the delta of the movement will be
-     *     passed in an argument as dx and dy properties.
+     *     during a drag).
      * moveend - Triggered when layer is done moving, object passed as
      *     argument has a zoomChanged boolean property which tells that the
      *     zoom has changed.
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js	2011-02-24 14:08:25 UTC (rev 11417)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js	2011-02-24 14:13:35 UTC (rev 11418)
@@ -1886,7 +1886,7 @@
      * lonlat - {<OpenLayers.LonLat>}
     centerLayerContainer: function (lonlat) {
         var originPx = this.getViewPortPxFromLonLat(this.layerContainerOrigin);
         var newPx = this.getViewPortPxFromLonLat(lonlat);
Modified: sandbox/ahocevar/layercontainer/tests/Map.html
--- sandbox/ahocevar/layercontainer/tests/Map.html	2011-02-24 14:08:25 UTC (rev 11417)
+++ sandbox/ahocevar/layercontainer/tests/Map.html	2011-02-24 14:13:35 UTC (rev 11418)
@@ -1318,8 +1318,8 @@
         var m = {
             'baseLayer': { 'units': {} },
-            'getSize': function() {return {'w': 10, 'h': 15}; },
-            'getCenter': function() {return {'lon': -5, 'lat': -25}; },
+            'getSize': function() { return {'w': 10, 'h': 15}; },
+            'getCenter': function() { return {'lon': -5, 'lat': -25}; },
             'zoomToExtent': function(extent, closest) {
                 t.ok(extent.equals(g_ExpectedExtent), "extent correctly calculated for zoomToExtent()");
                 t.ok(closest == g_Closest, "closest correctly passed on to zoomToExtent()");
More information about the Commits mailing list
