[OpenLayers-Commits] r11440 - in sandbox/jennier/openlayers: examples lib/OpenLayers/Layer lib/OpenLayers/Protocol lib/OpenLayers/Tile
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 24 12:22:52 EST 2011
Author: jennier
Date: 2011-02-24 09:22:52 -0800 (Thu, 24 Feb 2011)
New Revision: 11440
   sandbox/jennier/openlayers/examples/local-storage-wms-simple.html
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcIMS.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/Grid.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMap.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapGuide.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapServer.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/TMS.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/TileCache.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMS.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMTS.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/WorldWind.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/XYZ.js
   sandbox/jennier/openlayers/lib/OpenLayers/Layer/Zoomify.js
   sandbox/jennier/openlayers/lib/OpenLayers/Protocol/BrowserStorage.js
   sandbox/jennier/openlayers/lib/OpenLayers/Tile/Image.js
Local Storage should now only use a proxy for the tiles it stores. Also should properly retrieve and draw tiles now.
Modified: sandbox/jennier/openlayers/examples/local-storage-wms-simple.html
--- sandbox/jennier/openlayers/examples/local-storage-wms-simple.html	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/examples/local-storage-wms-simple.html	2011-02-24 17:22:52 UTC (rev 11440)
@@ -25,8 +25,8 @@
             map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
             map.addControl( new OpenLayers.Control.LayerSwitcher() );
-            // Set the cache counter.
-            layerOSGeo.countCache(updateCacheCount);
+            // Set the cache counter, checks every second.
+            window.setInterval(function(){layerOSGeo.countCache(updateCacheCount)},1000);
@@ -53,8 +53,8 @@
         tiles currently being viewed in local storage. Also allows the store to be cleared.
         <br/>
         <br/>
-        <a href="#" onclick="layerOSGeo.cacheAreaViewed();layerOSGeo.countCache(updateCacheCount);return false;">Cache the area being viewed.</a><br/><br/>
-        <a href="#" onclick="layerOSGeo.clearCache();layerOSGeo.countCache(updateCacheCount);return false;">Clear the cache.</a><br/><br/>
+        <a href="#" onclick="layerOSGeo.cacheAreaViewed();return false;">Cache the area being viewed.</a><br/><br/>
+        <a href="#" onclick="layerOSGeo.clearCache();return false;">Clear the cache.</a><br/><br/>
         Tiles Stored: <em id="count">0</em>.
     </div>
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -175,7 +175,7 @@
         var url = this.getFullRequestString(newParams);
         // Check to see if the Image has been stored locally
-        return OpenLayers.Layer.Grid.prototype.getURL.apply(this, [url]);
+        return OpenLayers.Layer.Grid.prototype.getCacheURL.apply(this, [url]);
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcIMS.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcIMS.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcIMS.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -206,7 +206,7 @@
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/Grid.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -853,38 +853,19 @@
      * {String} a GetMap query string for this layer or the data URI for this
      * image from local storage. To be used as the img src.
-     getURL: function (url) {
+     getCacheURL: function (url, tile) {
     	// If we want to use the local cache, check to see if they exist and
     	// use those values if they do.
-        if (this.params.ENABLELOCALCACHE) {
-        	// Check if the map being requested is on the same domain/port
-	        var sameOrigin = !(url.indexOf("http") == 0);
-	        var urlParts = !sameOrigin && url.match(this.URL_SPLIT_REGEX);
-	        if (urlParts) {
-	            var location = window.location;
-	            sameOrigin =
-	                urlParts[1] == location.protocol &&
-	                urlParts[3] == location.hostname;
-	            var uPort = urlParts[4], lPort = location.port;
-	            if (uPort != 80 && uPort != "" || lPort != "80" && lPort != "") {
-	                sameOrigin = sameOrigin && uPort == lPort;
-	        // For proxy need to url encode the params.
-	        if (!sameOrigin && OpenLayers.ProxyHost) {
-	        	url = OpenLayers.ProxyHost+encodeURIComponent(url);
-	        } else if (!sameOrigin){
-	            OpenLayers.Console.warn(
-	                    OpenLayers.i18n("proxyNeeded"), {url: url});
+        if (this.params.ENABLELOCALCACHE) {
 	        // check to see if the tile exists in the cache
-	        var imageCached = this.store.get(url);
+	        var imageCached = this.store.get(url, tile.imgDiv);
+	        if (imageCached) {
+	        	return imageCached;
         return url;
@@ -897,35 +878,73 @@
     cacheAreaViewed:function() {
-	    	var tileImageCount = 0;
 	    	// Go through all the tiles in the current view and get their URL.
 	    	for (var i=0; i<this.grid.length; i++) {
 	    		for (var j=0; j<this.grid[i].length; j++) {
-	    			var canvas = document.createElement("canvas");
-	    			canvas.width = this.tileSize.w;
-	    			canvas.height = this.tileSize.h;
-	    			var ctx = canvas.getContext("2d");
-	    			ctx.drawImage(this.grid[i][j].imgDiv, 0, 0);
-	    			// Below does not work in FireFox
-	    			//var imageData = canvas.toDataURL(this.params.FORMAT,'quality=20');
-	    			var imageData = canvas.toDataURL();
-	    			this.store.set(this.grid[i][j].url,imageData);
-	    			tileImageCount++;
+	    			// before we can store the image we need to proxy to if it comes
+	    			// from another domain.
+	    			var proxiedURL = this.getProxiedURL(this.grid[i][j].url);
+	    			this.grid[i][j].imgDiv.onload = OpenLayers.Function.bindAsEventListener(this.cacheTile ,this.grid[i][j]);
+	    			this.grid[i][j].imgDiv.src = proxiedURL;
-	    	console.log("Stored "+tileImageCount+" Tiles");
     	return false;
+    getProxiedURL: function(url) {
+    	// Check if the map being requested is on the same domain/port
+        var sameOrigin = !(url.indexOf("http") == 0);
+        var urlParts = !sameOrigin && url.match(this.URL_SPLIT_REGEX);
+        if (urlParts) {
+            var location = window.location;
+            sameOrigin =
+                urlParts[1] == location.protocol &&
+                urlParts[3] == location.hostname;
+            var uPort = urlParts[4], lPort = location.port;
+            if (uPort != 80 && uPort != "" || lPort != "80" && lPort != "") {
+                sameOrigin = sameOrigin && uPort == lPort;
+        var proxiedURL;
+        // For proxy need to url encode the params.
+        if (!sameOrigin && OpenLayers.ProxyHost) {
+        	proxiedURL = OpenLayers.ProxyHost+encodeURIComponent(url);
+        } else if (!sameOrigin){
+            OpenLayers.Console.warn(
+                    OpenLayers.i18n("proxyNeeded"), {url: url});
+        return proxiedURL;
+    cacheTile: function(e) {
+		var canvas = document.createElement("canvas");
+		canvas.width = this.size.w;
+		canvas.height = this.size.h;
+		var ctx = canvas.getContext("2d");
+		ctx.drawImage(this.imgDiv, 0, 0);
+		// Below does not work in FireFox
+		//var imageData = canvas.toDataURL(this.params.FORMAT,'quality=20');
+		var imageData = canvas.toDataURL();
+		// store under original URL
+		this.layer.store.set(this.url,imageData);
+		this.imgDiv.onload = {};
-    clearCache:function() {
+    clearCache: function() {
     	if (this.store) {
     		this.store.clear();
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMap.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMap.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMap.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -94,7 +94,7 @@
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapGuide.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapGuide.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapGuide.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -322,7 +322,7 @@
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapServer.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapServer.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapServer.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -124,7 +124,7 @@
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/TMS.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/TMS.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/TMS.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -131,7 +131,7 @@
         url = url + path;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/TileCache.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/TileCache.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/TileCache.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -145,7 +145,7 @@
         url = url + path;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMS.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMS.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMS.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -186,7 +186,7 @@
      *          passed-in bounds and appropriate tile size specified as
      *          parameters.
-    getURL: function (bounds) {
+    getURL: function (bounds, tile) {
         bounds = this.adjustBounds(bounds);
         var imageSize = this.getImageSize();
@@ -199,9 +199,9 @@
         newParams.WIDTH = imageSize.w;
         newParams.HEIGHT = imageSize.h;
         var url= this.getFullRequestString(newParams);
+        console.log("in get URL");
+        return OpenLayers.Layer.Grid.prototype.getCacheURL.apply(this, [url, tile]);
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMTS.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMTS.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMTS.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -439,7 +439,7 @@
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/WorldWind.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/WorldWind.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/WorldWind.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -116,7 +116,7 @@
     CLASS_NAME: "OpenLayers.Layer.WorldWind"
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/XYZ.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/XYZ.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/XYZ.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -128,7 +128,7 @@
         url = OpenLayers.String.format(url, xyz);
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/Zoomify.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/Zoomify.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/Zoomify.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -211,7 +211,7 @@
         url = url + path;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Protocol/BrowserStorage.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Protocol/BrowserStorage.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Protocol/BrowserStorage.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -8,7 +8,7 @@
- * Class: OpenLayers.Protocol.BroswerStorage
+ * Class: OpenLayers.Protocol.BrowserStorage
  * Class for access to SQL Web Storage or Web (local) Storage.
  * Allows you to store, retrieve and get information about what
  * is stored.
@@ -22,8 +22,8 @@
 	    var store;
 	    // Default to Web SQL Storage
 	    try {
-	    	store = this.sqlStore;
-	    	return store.initialize(name, version, description, size);
+	 ///   	store = this.sqlStore;
+	 //   	return store.initialize(name, version, description, size);
 	    } catch (e) {
 	    	/* Does not support Web SQL Storage */
@@ -71,8 +71,9 @@
-	get: function(key) {
-		return localStorage.getItem(key);
+	get: function(key, imgDiv) {
+		imgDiv.src = localStorage.getItem(key);
+		return imgDiv.src;
 	clear: function() {
 		localStorage.clear();
@@ -119,7 +120,6 @@
 	set: function(key, value) {
-		var name = this.name;
 		// TODO Check for existing entries to prevent duplicates.
 		this.db.transaction(
 			function(tx) {
@@ -132,16 +132,16 @@
+	get: function(key, tile) {
 			function(tx) {
-				console.log("Select value from OLTable where key=?");
+				console.log("Select value from OLTable where key="+key);
 				tx.executeSql("Select value from OLTable where key=?",
 				[key],
 				function(tx, result) {
 				  if(result.rows.length){
-					return result.rows.item(0).data;
+					tile.src = result.rows.item(0).value;
+					return tile.src;
 			    }, function(tx, error) {
 		        	console.debug(error);
@@ -167,7 +167,7 @@
 				function(tx) {
-					console.log("Select count(*) as count from OLTable");
+				//	console.log("Select count(*) as count from OLTable");
 					tx.executeSql("Select count(*) as count from OLTable",
@@ -177,11 +177,6 @@
-			function(tx, result) {
-				console.debug(tx);
-			    }, function(tx, error) {
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Tile/Image.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Tile/Image.js	2011-02-24 17:11:44 UTC (rev 11439)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Tile/Image.js	2011-02-24 17:22:52 UTC (rev 11440)
@@ -298,11 +298,13 @@
         } else {
             // syncronous image requests get the url and position the frame immediately,
             // and don't wait for an image request to come back.
-            this.url = this.layer.getURL(this.bounds);
+        	this.initImgDiv();
+            this.url = this.layer.getURL(this.bounds, this);
+            this.imgDiv.src = this.url;
-            this.initImgDiv();
             // position the frame immediately
             this.positionImage();
More information about the Commits mailing list
