[OpenLayers-Commits] r11469 - trunk/openlayers/theme/default/img
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Feb 25 04:28:33 EST 2011
Author: crschmidt
Date: 2011-02-25 01:28:33 -0800 (Fri, 25 Feb 2011)
New Revision: 11469
   trunk/openlayers/theme/default/img/add_point_off.png
   trunk/openlayers/theme/default/img/drag-rectangle-off.png
   trunk/openlayers/theme/default/img/drag-rectangle-on.png
   trunk/openlayers/theme/default/img/draw_line_off.png
   trunk/openlayers/theme/default/img/draw_line_on.png
   trunk/openlayers/theme/default/img/draw_point_off.png
   trunk/openlayers/theme/default/img/draw_point_on.png
   trunk/openlayers/theme/default/img/draw_polygon_off.png
   trunk/openlayers/theme/default/img/draw_polygon_on.png
   trunk/openlayers/theme/default/img/editing_tool_bar.png
   trunk/openlayers/theme/default/img/move_feature_off.png
   trunk/openlayers/theme/default/img/move_feature_on.png
   trunk/openlayers/theme/default/img/navigation_history.png
   trunk/openlayers/theme/default/img/pan-panel-NOALPHA.png
   trunk/openlayers/theme/default/img/pan-panel.png
   trunk/openlayers/theme/default/img/pan_on.png
   trunk/openlayers/theme/default/img/panning-hand-off.png
   trunk/openlayers/theme/default/img/panning-hand-on.png
   trunk/openlayers/theme/default/img/remove_point_on.png
   trunk/openlayers/theme/default/img/save_features_off.png
   trunk/openlayers/theme/default/img/save_features_on.png
   trunk/openlayers/theme/default/img/view_next_off.png
   trunk/openlayers/theme/default/img/view_previous_off.png
   trunk/openlayers/theme/default/img/zoom-panel.png
pngcrush theme images. On the most common images (editing tooolbar,
pan-panel), this saves us an additional 3k of bits to transfer.
Modified: trunk/openlayers/theme/default/img/add_point_off.png
(Binary files differ)
Modified: trunk/openlayers/theme/default/img/drag-rectangle-off.png
Modified: trunk/openlayers/theme/default/img/drag-rectangle-on.png
Modified: trunk/openlayers/theme/default/img/draw_line_off.png
Modified: trunk/openlayers/theme/default/img/draw_line_on.png
Modified: trunk/openlayers/theme/default/img/draw_point_off.png
Modified: trunk/openlayers/theme/default/img/draw_point_on.png
Modified: trunk/openlayers/theme/default/img/draw_polygon_off.png
Modified: trunk/openlayers/theme/default/img/draw_polygon_on.png
Modified: trunk/openlayers/theme/default/img/editing_tool_bar.png
Modified: trunk/openlayers/theme/default/img/move_feature_off.png
Modified: trunk/openlayers/theme/default/img/move_feature_on.png
Modified: trunk/openlayers/theme/default/img/navigation_history.png
Modified: trunk/openlayers/theme/default/img/pan-panel-NOALPHA.png
Modified: trunk/openlayers/theme/default/img/pan-panel.png
Modified: trunk/openlayers/theme/default/img/pan_on.png
Modified: trunk/openlayers/theme/default/img/panning-hand-off.png
Modified: trunk/openlayers/theme/default/img/panning-hand-on.png
Modified: trunk/openlayers/theme/default/img/remove_point_on.png
Modified: trunk/openlayers/theme/default/img/save_features_off.png
Modified: trunk/openlayers/theme/default/img/save_features_on.png
Modified: trunk/openlayers/theme/default/img/view_next_off.png
Modified: trunk/openlayers/theme/default/img/view_previous_off.png
Modified: trunk/openlayers/theme/default/img/zoom-panel.png
More information about the Commits mailing list
