[OpenLayers-Commits] r11492 - in sandbox/ahocevar/layercontainer: lib/OpenLayers tests/Layer/Google
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Feb 25 08:36:34 EST 2011
Author: ahocevar
Date: 2011-02-25 05:36:33 -0800 (Fri, 25 Feb 2011)
New Revision: 11492
   sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
   sandbox/ahocevar/layercontainer/tests/Layer/Google/v3.html
re-adding custom precision
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js	2011-02-25 13:34:59 UTC (rev 11491)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js	2011-02-25 13:36:33 UTC (rev 11492)
@@ -221,7 +221,7 @@
      * {<OpenLayers.LonLat>} The current center of the map
     center: null,
      * Property: resolution
      * {Float} The resolution of the map.
Modified: sandbox/ahocevar/layercontainer/tests/Layer/Google/v3.html
--- sandbox/ahocevar/layercontainer/tests/Layer/Google/v3.html	2011-02-25 13:34:59 UTC (rev 11491)
+++ sandbox/ahocevar/layercontainer/tests/Layer/Google/v3.html	2011-02-25 13:36:33 UTC (rev 11492)
@@ -266,6 +266,12 @@
          t.plan(8);
+         var origPrecision = OpenLayers.Util.DEFAULT_PRECISION;
+         // GMaps v3 seems to use a default precision of 13, which is lower
+         // than what we use in OpenLayers.
+         // See http://trac.osgeo.org/openlayers/ticket/3059
+         OpenLayers.Util.DEFAULT_PRECISION = 13;
          var map = new OpenLayers.Map('map', {allOverlays: true});
          var gmap = new OpenLayers.Layer.Google("Google Streets");
@@ -310,6 +316,7 @@
          t.eq(center.lat, origin.lat, "y panning with Google invisible " + (-dx) + ", " + (-dy));
          map.destroy();
+         OpenLayers.Util.DEFAULT_PRECISION = origPrecision;
      function test_wrapDateLine(t) {
More information about the Commits mailing list
