[OpenLayers-Commits] r11509 - in sandbox/pinch: . build examples examples/img img lib/OpenLayers lib/OpenLayers/BaseTypes lib/OpenLayers/Control lib/OpenLayers/Handler lib/OpenLayers/Layer tests tests/BaseTypes tests/Control tests/Handler tests/Layer theme/default/img tools
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Feb 25 10:14:41 EST 2011
Author: tschaub
Date: 2011-02-25 07:14:40 -0800 (Fri, 25 Feb 2011)
New Revision: 11509
Added:
   sandbox/pinch/examples/accelerometer.html
   sandbox/pinch/examples/img/check-round-green.png
   sandbox/pinch/examples/img/check-round-grey.png
   sandbox/pinch/examples/img/list.png
   sandbox/pinch/examples/img/minus1.png
   sandbox/pinch/examples/mobile-base.js
   sandbox/pinch/examples/mobile-sencha.js
   sandbox/pinch/tools/closure.py
   sandbox/pinch/tools/closure_ws.py
   sandbox/pinch/
   sandbox/pinch/build/README.txt
   sandbox/pinch/build/build.py
   sandbox/pinch/build/mobile.cfg
   sandbox/pinch/examples/bing.html
   sandbox/pinch/examples/mobile-jq.html
   sandbox/pinch/examples/mobile-sencha.html
   sandbox/pinch/examples/mobile.html
   sandbox/pinch/examples/mobile.js
   sandbox/pinch/examples/spherical-mercator.html
   sandbox/pinch/examples/tile-origin.html
   sandbox/pinch/img/cloud-popup-relative.png
   sandbox/pinch/img/drag-rectangle-off.png
   sandbox/pinch/img/drag-rectangle-on.png
   sandbox/pinch/img/east-mini.png
   sandbox/pinch/img/layer-switcher-maximize.png
   sandbox/pinch/img/layer-switcher-minimize.png
   sandbox/pinch/img/marker-blue.png
   sandbox/pinch/img/marker-gold.png
   sandbox/pinch/img/marker-green.png
   sandbox/pinch/img/marker.png
   sandbox/pinch/img/measuring-stick-off.png
   sandbox/pinch/img/measuring-stick-on.png
   sandbox/pinch/img/north-mini.png
   sandbox/pinch/img/panning-hand-off.png
   sandbox/pinch/img/panning-hand-on.png
   sandbox/pinch/img/slider.png
   sandbox/pinch/img/south-mini.png
   sandbox/pinch/img/west-mini.png
   sandbox/pinch/img/zoom-minus-mini.png
   sandbox/pinch/img/zoom-plus-mini.png
   sandbox/pinch/img/zoom-world-mini.png
   sandbox/pinch/img/zoombar.png
   sandbox/pinch/lib/OpenLayers/BaseTypes/Pixel.js
   sandbox/pinch/lib/OpenLayers/Control/Geolocate.js
   sandbox/pinch/lib/OpenLayers/Control/MouseDefaults.js
   sandbox/pinch/lib/OpenLayers/Control/MouseToolbar.js
   sandbox/pinch/lib/OpenLayers/Control/OverviewMap.js
   sandbox/pinch/lib/OpenLayers/Handler/Box.js
   sandbox/pinch/lib/OpenLayers/Handler/Click.js
   sandbox/pinch/lib/OpenLayers/Layer/Grid.js
   sandbox/pinch/lib/OpenLayers/Layer/VirtualEarth.js
   sandbox/pinch/lib/OpenLayers/Map.js
   sandbox/pinch/tests/BaseTypes/Pixel.html
   sandbox/pinch/tests/Control/Geolocate.html
   sandbox/pinch/tests/Handler/Click.html
   sandbox/pinch/tests/Layer/ArcGIS93Rest.html
   sandbox/pinch/tests/Layer/Grid.html
   sandbox/pinch/tests/Layer/KaMap.html
   sandbox/pinch/tests/Layer/MapGuide.html
   sandbox/pinch/tests/Layer/MapServer.html
   sandbox/pinch/tests/Layer/TMS.html
   sandbox/pinch/tests/Layer/WMS.html
   sandbox/pinch/tests/Layer/WrapDateLine.html
   sandbox/pinch/tests/Layer/XYZ.html
   sandbox/pinch/tests/Map.html
   sandbox/pinch/theme/default/img/add_point_off.png
   sandbox/pinch/theme/default/img/drag-rectangle-off.png
   sandbox/pinch/theme/default/img/drag-rectangle-on.png
   sandbox/pinch/theme/default/img/draw_line_off.png
   sandbox/pinch/theme/default/img/draw_line_on.png
   sandbox/pinch/theme/default/img/draw_point_off.png
   sandbox/pinch/theme/default/img/draw_point_on.png
   sandbox/pinch/theme/default/img/draw_polygon_off.png
   sandbox/pinch/theme/default/img/draw_polygon_on.png
   sandbox/pinch/theme/default/img/editing_tool_bar.png
   sandbox/pinch/theme/default/img/move_feature_off.png
   sandbox/pinch/theme/default/img/move_feature_on.png
   sandbox/pinch/theme/default/img/navigation_history.png
   sandbox/pinch/theme/default/img/pan-panel-NOALPHA.png
   sandbox/pinch/theme/default/img/pan-panel.png
   sandbox/pinch/theme/default/img/pan_on.png
   sandbox/pinch/theme/default/img/panning-hand-off.png
   sandbox/pinch/theme/default/img/panning-hand-on.png
   sandbox/pinch/theme/default/img/remove_point_on.png
   sandbox/pinch/theme/default/img/save_features_off.png
   sandbox/pinch/theme/default/img/save_features_on.png
   sandbox/pinch/theme/default/img/view_next_off.png
   sandbox/pinch/theme/default/img/view_previous_off.png
   sandbox/pinch/theme/default/img/zoom-panel.png
   sandbox/pinch/tools/release.sh
   sandbox/pinch/tools/update_dev_dir.sh
Merge r11431:11507 from trunk.
Property changes on: sandbox/pinch
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11431-11507
Modified: sandbox/pinch/build/README.txt
--- sandbox/pinch/build/README.txt	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/build/README.txt	2011-02-25 15:14:40 UTC (rev 11509)
@@ -1,14 +1,43 @@
+The OpenLayers build tool supports several different
+forms of compressing your javascript code, and a method
+of describing build profiles to create customized
+OpenLayers builds with only the components you need.
-## HowTo: Build & deploy "Shrunk" Single File Library version of OpenLayers ##
+When building a file, you can choose to build with several
+different compression options to the Python-based build.py
+script. The following is an example script:
- * Build:
+python build.py -c closure full OpenLayers-closure.js
-     cd build
-     ./build.py
-     cd ..
+This script selects the 'closure' compression mechanism,
+uses a config file called 'full.cfg', and writes the output
+to OpenLayers-closure.js.
- * Upload the result to the server: e.g.
+The options available for compression are:
-  scp build/OpenLayers.js openlayers at openlayers.org:openlayers.org/htdocs/code/
+ * closure
+   This requires you to have a closure-compiler.jar in your
+   tools directory. You can do this by fetching the compiler
+   from:
+     http://closure-compiler.googlecode.com/files/compiler-latest.zip
+   Then unzipping that file, and placing compiler.jar into tools
+   and renaming it closure-compiler.jar.
+ * closure_ws
+   This uses the closure compiler webservice. This will only work
+   for files source Javascript files which are under 1MB. (Note that
+   the default OpenLayers full build is not under 1MB.)
+ * jsmin
+   jsmin is the default compiler, and uses the Python-based
+   jsmin script to compress the Javascript.
+ * minimize
+   This is a simple whitespace removing Python script, designed
+   to fill in when other tools are unavailable.
+ * none
+   None will leave the Javascript uncompressed.
Modified: sandbox/pinch/build/build.py
--- sandbox/pinch/build/build.py	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/build/build.py	2011-02-25 15:14:40 UTC (rev 11509)
@@ -12,6 +12,16 @@
         have_compressor.append("jsmin")
     except ImportError:
         print "No jsmin"
+    try:
+        import closure
+        have_compressor.append("closure")
+    except Exception, E:
+        print "No closure (%s) % E"
+    try:
+        import closure_ws
+        have_compressor.append("closure_ws")
+    except ImportError:
+        print "No closure_ws"
     try:
         import minimize
@@ -39,14 +49,16 @@
     print "Merging libraries."
     merged = mergejs.run(sourceDirectory, None, configFilename)
+    print "Compressing using %s" % use_compressor
     if use_compressor == "jsmin":
-        print "Compressing using jsmin."
         minimized = jsmin.jsmin(merged)
     elif use_compressor == "minimize":
-        print "Compressing using minimize."
         minimized = minimize.minimize(merged)
+    elif use_compressor == "closure_ws":
+        minimized = closure_ws.minimize(merged)
+    elif use_compressor == "closure":
+        minimized = closure.minimize(merged)
     else: # fallback
-        print "Not compressing."
         minimized = merged
     print "Adding license file."
     minimized = file("license.txt").read() + minimized
@@ -60,4 +72,11 @@
   opt = optparse.OptionParser(usage="%s [options] [config_file] [output_file]\n  Default config_file is 'full.cfg', Default output_file is 'OpenLayers.js'")
   opt.add_option("-c", "--compressor", dest="compressor", help="compression method: one of 'jsmin', 'minimize', or 'none'", default="jsmin")
   (options, args) = opt.parse_args()
-  build(*args, options=options)
+  if not len(args):
+    build(options=options)
+  elif len(args) == 1:
+    build(args[0], options=options)
+  elif len(args) == 2:
+    build(args[0], args[1], options=options)
+  else:
+    print "Wrong number of arguments"
Modified: sandbox/pinch/build/mobile.cfg
--- sandbox/pinch/build/mobile.cfg	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/build/mobile.cfg	2011-02-25 15:14:40 UTC (rev 11509)
@@ -12,6 +12,9 @@
 OpenLayers/Control/TouchNavigation.js
 OpenLayers/Control/ZoomPanel.js
+OpenLayers/Control/Attribution.js
+OpenLayers/Layer/Vector.js
+OpenLayers/Renderer/SVG.js
 [exclude]
Copied: sandbox/pinch/examples/accelerometer.html (from rev 11507, trunk/openlayers/examples/accelerometer.html)
--- sandbox/pinch/examples/accelerometer.html	                        (rev 0)
+++ sandbox/pinch/examples/accelerometer.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -0,0 +1,99 @@
+<!DOCTYPE html>
+<html>
+<head>
+    <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;"/>
+    <meta name="apple-mobile-web-app-capable" content="yes"/>
+    <title>OpenLayers Accelerometer Usage</title>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css"/>
+    <link rel="stylesheet" href="style.css" type="text/css"/>
+    <script type="text/javascript" src="browser.js"></script>
+    <style type="text/css">
+        .olControlAttribution {
+            bottom: 5px;
+    </style>
+    <script type="text/javascript">
+        function init() {
+            if (isEventSupported('deviceorientation', window) || isEventSupported('mozorientation', window) || isEventSupported('devicemotion', window)) {
+                if (window.DeviceOrientationEvent) {
+                    window.addEventListener("deviceorientation", function (event) {
+                        document.getElementById('resultDeviceOrientation').innerHTML = '';
+                        if (typeof(event.alpha) != 'undefined') {
+                            document.getElementById('resultDeviceOrientation').innerHTML = document.getElementById('resultDeviceOrientation').innerHTML + "Alpha: " + event.alpha + "<br>";
+                            document.getElementById('resultDeviceOrientation').innerHTML = document.getElementById('resultDeviceOrientation').innerHTML + "Beta: " + event.beta + "<br>";
+                            document.getElementById('resultDeviceOrientation').innerHTML = document.getElementById('resultDeviceOrientation').innerHTML + "Gamma: " + event.gamma + "<br>";
+                        if (typeof(event.absolute) != 'undefined') {
+                            document.getElementById('resultDeviceOrientation').innerHTML = document.getElementById('resultDeviceOrientation').innerHTML + "Gamma: " + event.absolute + "<br>";
+                        if (typeof(event.compassCalibrate) != 'undefined') {
+                            document.getElementById('resultDeviceOrientation').innerHTML = document.getElementById('resultDeviceOrientation').innerHTML + "Gamma: " + event.compassCalibrated + "<br>";
+                    }, true);
+                if (window.DeviceMotionEvent) {
+                    window.addEventListener('devicemotion', function (event) {
+                        document.getElementById('resultDeviceMotion').innerHTML = '';
+                        if (typeof(event.accelerationIncludingGravity) != 'undefined') {
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "accelerationIncludingGravity.x: " + event.accelerationIncludingGravity.x + "<br>";
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "accelerationIncludingGravity.y: " + event.accelerationIncludingGravity.y + "<br>";
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "accelerationIncludingGravity.z: " + event.accelerationIncludingGravity.z + "<br>";
+                        if (typeof(event.acceleration) != 'undefined') {
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "acceleration.x: " + event.acceleration.x + "<br>";
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "acceleration.y: " + event.acceleration.y + "<br>";
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "acceleration.z: " + event.acceleration.z + "<br>";
+                        if (typeof(event.rotationRate) != 'undefined') {
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "rotationRate.alpha: " + event.rotationRate.alpha + "<br>";
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "rotationRate.beta: " + event.rotationRate.beta + "<br>";
+                            document.getElementById('resultDeviceMotion').innerHTML = document.getElementById('resultDeviceMotion').innerHTML + "rotationRate.gamma: " + event.rotationRate.gamma + "<br>";
+                    }, true);
+                if (window.MozOrientation) {
+                    window.addEventListener("MozOrientation", function (orientation) {
+                        document.getElementById('resultMozOrientation').innerHTML = "orientation.x: " + orientation.x + "<br>";
+                        document.getElementById('resultMozOrientation').innerHTML = document.getElementById('resultMozOrientation').innerHTML + "orientation.y: " + orientation.y + "<br>";
+                        document.getElementById('resultMozOrientation').innerHTML = document.getElementById('resultMozOrientation').innerHTML + "orientation.z: " + orientation.z + "<br>";
+                    }, true);
+            } else {
+                alert("Unfortunately, your brower doesn't support the orientation usage");
+    </script>
+</head>
+<body onload="init()">
+<h1 id="title">Accelerometer</h1>
+<p id="shortdesc">
+    The goal of this script is to demonstrate the usage of accelerometer.
+</p>
+<p>
+  The orientation specification can be found <a href="http://dev.w3.org/geo/api/spec-source-orientation.html">here</a>.
+</p>
+<div id="tags">
+  browser, vendor, mobile, orientation
+</div>
+<h1>Device motion</h1>
+<div id="resultDeviceMotion">
+</div>
+<h1>Device orientation</h1>
+<div id="resultDeviceOrientation">
+</div>
+<h1>MOZ orientation</h1>
+<div id="resultMozOrientation">
+</div>
+</body>
+</html>
Modified: sandbox/pinch/examples/bing.html
--- sandbox/pinch/examples/bing.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/examples/bing.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -12,9 +12,18 @@
     <script>
         var map;
         function init(){
-            map = new OpenLayers.Map("map");
+            // setting restrictedExtent so that we can use the
+            // VirtualEarth-layers, see e.g.
+            // http://dev.openlayers.org/apidocs/files/OpenLayers/Layer/VirtualEarth-js.html
+            var restrictedExtent = new OpenLayers.Bounds(-20037508, -20037508,
+                20037508, 20037508);
+            map = new OpenLayers.Map("map", {
+                restrictedExtent: restrictedExtent
             map.addControl(new OpenLayers.Control.LayerSwitcher());
             var shaded = new OpenLayers.Layer.VirtualEarth("Shaded", {
Copied: sandbox/pinch/examples/img/check-round-green.png (from rev 11507, trunk/openlayers/examples/img/check-round-green.png)
(Binary files differ)
Copied: sandbox/pinch/examples/img/check-round-grey.png (from rev 11507, trunk/openlayers/examples/img/check-round-grey.png)
Copied: sandbox/pinch/examples/img/list.png (from rev 11507, trunk/openlayers/examples/img/list.png)
Copied: sandbox/pinch/examples/img/minus1.png (from rev 11507, trunk/openlayers/examples/img/minus1.png)
Copied: sandbox/pinch/examples/mobile-base.js (from rev 11507, trunk/openlayers/examples/mobile-base.js)
--- sandbox/pinch/examples/mobile-base.js	                        (rev 0)
+++ sandbox/pinch/examples/mobile-base.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -0,0 +1,108 @@
+// API key for http://openlayers.org. Please get your own at
+// http://bingmapsportal.com/ and use that instead.
+var apiKey = "AqTGBsziZHIJYYxgivLBf0hVdrAk9mWO5cQcb8Yux8sW5M8c8opEC2lZqKR1ZZXf";
+// initialize map when page ready
+var map;
+var gg = new OpenLayers.Projection("EPSG:4326");
+var sm = new OpenLayers.Projection("EPSG:900913");
+var init = function () {
+    var vector = new OpenLayers.Layer.Vector("Vector Layer", {});
+    var geolocate = new OpenLayers.Control.Geolocate({
+        id: 'locate-control',
+        geolocationOptions: {
+            enableHighAccuracy: false,
+            maximumAge: 0,
+            timeout: 7000
+    // create map
+    map = new OpenLayers.Map({
+        div: "map",
+        theme: null,
+        projection: sm,
+        units: "m",
+        numZoomLevels: 18,
+        maxResolution: 156543.0339,
+        maxExtent: new OpenLayers.Bounds(
+            -20037508.34, -20037508.34, 20037508.34, 20037508.34
+        controls: [
+            new OpenLayers.Control.Attribution(),
+            new OpenLayers.Control.TouchNavigation({
+                dragPanOptions: {
+                    interval: 100,
+                    enableKinetic: true
+            geolocate
+        layers: [
+            new OpenLayers.Layer.OSM("OpenStreetMap", null, {
+                transitionEffect: 'resize'
+            new OpenLayers.Layer.Bing({
+                key: apiKey,
+                type: "Road",
+                // custom metadata parameter to request the new map style - only useful
+                // before May 1st, 2011
+                metadataParams: {
+                    mapVersion: "v1"
+                name: "Bing Road",
+                key: apiKey,
+                type: "Aerial",
+                name: "Bing Aerial",
+                key: apiKey,
+                type: "AerialWithLabels",
+                name: "Bing Aerial + Labels",
+            vector
+    map.zoomToMaxExtent();
+    var style = {
+        fillOpacity: 0.1,
+        fillColor: '#000',
+        strokeColor: '#f00',
+        strokeOpacity: 0.6
+    geolocate.events.register("locationupdated",this,function(e) {
+        vector.removeAllFeatures();
+        vector.addFeatures([
+            new OpenLayers.Feature.Vector(
+                e.point,
+                    graphicName: 'cross',
+                    strokeWidth: 2,
+                    fillOpacity: 0,
+                    pointRadius: 10
+                OpenLayers.Geometry.Polygon.createRegularPolygon(
+                    new OpenLayers.Geometry.Point(e.point.x, e.point.y),
+                    e.position.coords.accuracy/2,
+                    50,
+                    0
+                style
+        map.zoomToExtent(vector.getDataExtent());
Modified: sandbox/pinch/examples/mobile-jq.html
--- sandbox/pinch/examples/mobile-jq.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/examples/mobile-jq.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -11,7 +11,7 @@
         <script src="http://code.jquery.com/mobile/1.0a3/jquery.mobile-1.0a3.min.js"></script>
         <link rel="stylesheet" href="style.mobile.css" type="text/css">
         <script src="../lib/OpenLayers.js"></script>
-        <script src="mobile.js"></script>
+        <script src="mobile-base.js"></script>
         <style>
             html {
                 height: 100%;
Modified: sandbox/pinch/examples/mobile-sencha.html
--- sandbox/pinch/examples/mobile-sencha.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/examples/mobile-sencha.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -5,12 +5,30 @@
     <meta name="apple-mobile-web-app-capable" content="yes" />
         <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
         <title>OpenLayers with Sencha Touch</title>
-        <script src="../lib/OpenLayers.js"></script>
+        <script src="../lib/OpenLayers.js?mobile"></script>
         <link rel="stylesheet" href="http://dev.sencha.com/deploy/touch/resources/css/sencha-touch.css">
         <script src="http://dev.sencha.com/deploy/touch/sencha-touch.js"></script>
+        <script src="mobile-sencha.js"></script>
         <style>
+            .searchList {
+                min-height: 150px;
+            .close-btn {
+                position: absolute;
+                right: 10px;
+                top: 10px;
+            img.minus {
+                -webkit-mask-image: url(img/minus1.png);
+            img.layers {
+                -webkit-mask-image: url(img/list.png);
+            .gx-layer-item {
+                margin-left: 10px;
             #map {
                 width: 100%;
                 height: 100%;
@@ -25,100 +43,96 @@
         </style>
         <script>
-        new Ext.Application({
+        var app = new Ext.Application({
             launch: function() {
                 this.viewport = new Ext.Panel({
                     fullscreen: true,
                     dockedItems: [{
-                        dock: "top",
+                        dock: "bottom",
                         xtype: "toolbar",
                         ui: "light",
                         layout: {
                             pack: "center"
-                        defaults: {
-                            ui: "plain",
-                            iconMask: true
                         items: [{
-                            iconCls: "arrow_left",
+                            iconCls: "search",
+                            iconMask: true,
+                            handler: function(){
+                                // this is the app
+                                if (!app.searchFormPopupPanel) {
+                                    app.searchFormPopupPanel = new App.SearchFormPopupPanel({
+                                        map: map
+                                app.searchFormPopupPanel.show('pop');
+                            iconCls: "locate",
+                            iconMask: true,
                             handler: function() {
-                                pan(-0.25, 0);
+                                var geolocate = map.getControlsBy("id", "locate-control")[0];
+                                if (geolocate.active) {
+                                    geolocate.getCurrentLocation();
+                                } else {
+                                    geolocate.activate();
-                            iconCls: "arrow_up",
+                            xtype: "spacer"
+                            iconMask: true,
+                            iconCls: "add",
-                                pan(0, -0.25);
+                                map.zoomIn();
-                            iconCls: "arrow_down",
+                            iconMask: true,
+                            iconCls: "minus",
-                                pan(0, 0.25);
+                                map.zoomOut();
-                            iconCls: "arrow_right",
+                            xtype: "spacer"
+                            iconMask: true,
+                            iconCls: "layers",
-                                pan(0.25, 0);
-                        dock: "bottom",
-                        xtype: "toolbar",
-                        ui: "light",
-                        layout: {
-                            pack: "center"
-                        items: [{
-                            xtype: "segmentedbutton",
-                            items: [{
-                                text: "navigate",
-                                pressed: true
-                                text: "point",
-                                id: "point"
-                                text: "line",
-                                id: "line"
-                                text: "poly",
-                                id: "poly"
-                                text: "modify",
-                                id: "mod"
-                            listeners: {
-                                toggle: function(container, button, pressed) {
-                                    Ext.each(map.getControlsByClass(/DrawFeature/), function(control) {
-                                        control.deactivate();
+                                if (!app.popup) {
+                                    app.popup = new Ext.Panel({
+                                        floating: true,
+                                        modal: true,
+                                        centered: true,
+                                        hideOnMaskTap: true,
+                                        width: 240,
+                                        items: [{
+                                            xtype: 'app_layerlist',
+                                            map: map
+                                        scroll: 'vertical'
-                                    map.getControlsBy("id", "mod-control")[0].deactivate();
-                                    if (pressed) {
-                                        var id = button.id + "-control";
-                                        var control = map.getControlsBy("id", id)[0];
-                                        if (control) {
-                                            control.activate();
+                                app.popup.show('pop');
-                    items: [{
-                        xtype: "component",
-                        scroll: false,
-                        monitorResize: true,
-                        id: "map",
-                        listeners: {
-                            render: init,
-                            resize: function() {
-                                if (window.map) {
-                                    map.updateSize();
+                    items: [
+                            xtype: "component",
+                            scroll: false,
+                            monitorResize: true,
+                            id: "map",
+                            listeners: {
+                                render: init,
+                                resize: function() {
+                                    if (window.map) {
+                                        map.updateSize();
Copied: sandbox/pinch/examples/mobile-sencha.js (from rev 11507, trunk/openlayers/examples/mobile-sencha.js)
--- sandbox/pinch/examples/mobile-sencha.js	                        (rev 0)
+++ sandbox/pinch/examples/mobile-sencha.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -0,0 +1,198 @@
+Ext.ns('App');
+ * The model for the geonames records used in the search
+Ext.regModel('Geonames', {
+    fields: ['countryName', 'toponymName', 'name', 'lat', 'lng']
+ * Custom class for the Search
+App.SearchFormPopupPanel = Ext.extend(Ext.Panel, {
+    map: null,
+    floating: true,
+    modal: true,
+    centered: true,
+    width: Ext.is.Phone ? undefined : 400,
+    height: Ext.is.Phone ? undefined : 400,
+    scroll: false,
+    layout: 'fit',
+    fullscreen: Ext.is.Phone ? true : undefined,
+    url: 'http://ws.geonames.org/searchJSON?',
+    errorText: 'Sorry, we had problems communicating with geonames.org. Please try again.',
+    errorTitle: 'Communication error',
+    maxResults: 6,
+    featureClass: "P",
+    createStore: function(){
+        this.store = new Ext.data.Store({
+            model: 'Geonames',
+            proxy: {
+                type: 'scripttag',
+                timeout: 5000,
+                listeners: {
+                    exception: function(){
+                        this.hide();
+                        Ext.Msg.alert(this.errorTitle, this.errorText, Ext.emptyFn);
+                    scope: this
+                url: this.url,
+                reader: {
+                    type: 'json',
+                    root: 'geonames'
+    doSearch: function(searchfield, evt){
+        var q = searchfield.getValue();
+        this.store.load({
+            params: {
+                featureClass: this.featureClass,
+                maxRows: this.maxResults,
+                name_startsWith: encodeURIComponent(q)
+    onItemTap: function(dataView, index, item, event){
+        var record = this.store.getAt(index);
+        var lon = record.get('lng');
+        var lat = record.get('lat');
+        var lonlat = new OpenLayers.LonLat(lon, lat);
+        map.setCenter(lonlat.transform(gg, sm), 12);
+        this.hide("pop");
+    initComponent: function(){
+        this.createStore();
+        this.resultList = new Ext.List({
+            scroll: 'vertical',
+            cls: 'searchList',
+            loadingText: "Searching ...",
+            store: this.store,
+            itemTpl: '<div>{name} ({countryName})</div>',
+            listeners: {
+                itemtap: this.onItemTap,
+                scope: this
+        this.formContainer = new Ext.form.FormPanel({
+            scroll: false,
+            items: [{
+                xtype: 'button',
+                cls: 'close-btn',
+                ui: 'decline-small',
+                text: 'Close',
+                    this.hide();
+                scope: this
+                xtype: 'fieldset',
+                scroll: false,
+                title: 'Search for a place',
+                items: [{
+                    xtype: 'searchfield',
+                    label: 'Search',
+                    placeHolder: 'placename',
+                    listeners: {
+                        action: this.doSearch,
+                        scope: this
+                    this.resultList
+        this.items = [{
+            xtype: 'panel',
+            layout: 'fit',
+            items: [this.formContainer]
+        App.SearchFormPopupPanel.superclass.initComponent.call(this);
+App.LayerList = Ext.extend(Ext.List, {
+    map: null,
+        Ext.regModel('Layer', {
+            fields: ['id', 'name', 'visibility', 'zindex']
+        var data = [];
+        Ext.each(this.map.layers, function(layer){
+            if (layer.displayInLayerSwitcher === true) {
+                var visibility = layer.isBaseLayer ? (this.map.baseLayer == layer) : layer.getVisibility();
+                data.push({
+                    id: layer.id,
+                    name: layer.name,
+                    visibility: visibility,
+                    zindex: layer.getZIndex()
+        return new Ext.data.Store({
+            model: 'Layer',
+            sorters: 'zindex',
+            data: data
+        this.store = this.createStore();
+        this.itemTpl = new Ext.XTemplate(
+            '<tpl if="visibility == true">',
+                '<img width="20" src="img/check-round-green.png">',
+            '</tpl>',
+            '<tpl if="visibility == false">',
+                '<img width="20" src="img/check-round-grey.png">',
+            '</tpl>',
+            '<span class="gx-layer-item">{name}</span>'
+        this.listeners = {
+            itemtap: function(dataview, index, item, e){
+                var record = dataview.getStore().getAt(index);
+                var layer = this.map.getLayersBy("id", record.get("id"))[0];
+                if (layer.isBaseLayer) {
+                    this.map.setBaseLayer(layer);
+                else {
+                    layer.setVisibility(!layer.getVisibility());
+                record.set("visibility", layer.getVisibility());
+        this.map.events.on({
+            "changelayer": this.onChangeLayer,
+            scope: this
+        App.LayerList.superclass.initComponent.call(this);
+    findLayerRecord: function(layer){
+        var found;
+        this.store.each(function(record){
+            if (record.get("id") === layer.id) {
+                found = record;
+        }, this);
+        return found;
+    onChangeLayer: function(evt){
+        if (evt.property == "visibility") {
+            var record = this.findLayerRecord(evt.layer);
+            record.set("visibility", evt.layer.getVisibility());
+Ext.reg('app_layerlist', App.LayerList);
Modified: sandbox/pinch/examples/mobile.html
--- sandbox/pinch/examples/mobile.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/examples/mobile.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -2,6 +2,7 @@
 <html>
     <head>
         <title>OpenLayers Mobile</title>
+        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
         <meta name="viewport" content="width=device-width, user-scalable=no, initial-scale=1.0, maximum-scale=1.0;">
         <meta name="apple-mobile-web-app-capable" content="yes">
@@ -9,20 +10,61 @@
         <style>
             html, body {
-                margin: 0;
-                padding: 0;
-                height: 100%;
+                margin  : 0;
+                padding : 0;
+                height  : 100%;
+                width   : 100%;
+            @media only screen and (max-width: 600px) {
+                html, body {
+                    height  : 117%;
             #map {
-                position: relative;
-                width: 100%;
-                height: 100%;
+                width    : 100%;
+                position : relative;
+                height   : 100%;
-                font-size: 10px;
-                bottom: 5px;
-                right: 5px;
+                position      : absolute;
+                font-size     : 10px;
+                bottom        : 0 !important;
+                right         : 0 !important;
+                background    : rgba(0,0,0,0.1);
+                font-family   : Arial;
+                padding       : 2px 4px;
+                border-radius : 5px 0 0 0;
+            div.olControlZoomPanel .olControlZoomInItemInactive,
+            div.olControlZoomPanel .olControlZoomOutItemInactive {
+                background: rgba(0,0,0,0.2);
+            div.olControlZoomPanel .olControlZoomInItemInactive {
+                border-radius: 5px 5px 0 0;
+                border-radius: 0 0 5px 5px ;
+                top: 37px;
+            div.olControlZoomPanel .olControlZoomOutItemInactive:after ,
+            div.olControlZoomPanel .olControlZoomInItemInactive:after{
+                font-weight: bold;
+                content   : '+';
+                font-size : 36px;
+                padding:  7px;
+                z-index: 2000;
+                color     : #fff;
+                line-height: 1em;
+            div.olControlZoomPanel .olControlZoomOutItemInactive:after{
+                content: '–';
+                line-height: 0.9em;
+                padding: 0 8px;
+            div.olControlZoomPanel .olControlZoomToMaxExtentItemInactive {
+                display: none;
             #title, #tags, #shortdesc {
                 display: none;
Modified: sandbox/pinch/examples/mobile.js
--- sandbox/pinch/examples/mobile.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/examples/mobile.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -1,77 +1,40 @@
 var map;
-var gg = new OpenLayers.Projection("EPSG:4326");
-var sm = new OpenLayers.Projection("EPSG:900913");
-function init() {
-    // layer for drawn features
-    var vector = new OpenLayers.Layer.Vector();
+// Get rid of address bar on iphone/ipod
+var fixSize = function() {
+    window.scrollTo(0,0);
+    document.body.style.height = '100%';
+    if (!(/(iphone|ipod)/.test(navigator.userAgent.toLowerCase()))) {
+        if (document.body.parentNode) {
+            document.body.parentNode.style.height = '100%';
+setTimeout(fixSize, 700);
+setTimeout(fixSize, 1500);
     // create map
         div: "map",
-        projection: sm,
-        units: "m",
-        numZoomLevels: 18,
-        maxResolution: 156543.0339,
-        maxExtent: new OpenLayers.Bounds(
-            -20037508.34, -20037508.34, 20037508.34, 20037508.34
+        theme: null,
         controls: [
                 dragPanOptions: {
-                    interval: 0, // non-zero kills performance on some mobile phones
+                    interval: 100,
                     enableKinetic: true
-            new OpenLayers.Control.Attribution(),
-            new OpenLayers.Control.DrawFeature(
-                vector, OpenLayers.Handler.Point, {id: "point-control"}
-                vector, OpenLayers.Handler.Path, {id: "line-control"}
-                vector, OpenLayers.Handler.Polygon, {id: "poly-control"}
-            new OpenLayers.Control.ModifyFeature(vector, {id: "mod-control"}),
             new OpenLayers.Control.ZoomPanel()
-        layers: [new OpenLayers.Layer.OSM(), vector],
-        center: new OpenLayers.LonLat(0, 0),
-        zoom: 1
+        layers: [
+        center: new OpenLayers.LonLat(742000, 5861000),
+        zoom: 3
-    // attempt to get position
-    if (window.navigator && navigator.geolocation) {
-        navigator.geolocation.getCurrentPosition(
-            updatePosition,
-            function failure(error) {
-                OpenLayers.Console.log(error.message);
-                enableHighAccuracy: true
-// get position if possible
-var position;
-function updatePosition(pos) {
-    position = pos;
-    var lon =  position.coords.longitude;
-    var lat = position.coords.latitude;
-    OpenLayers.Console.log("position: lon " + lon + ", lat " + lat);
-    map.setCenter(
-        new OpenLayers.LonLat(lon, lat).transform(gg, sm)
-function pan(fx, fy) {
-    var size = map.getSize();
-    map.pan(size.w * fx, size.h * fy);
Modified: sandbox/pinch/examples/spherical-mercator.html
--- sandbox/pinch/examples/spherical-mercator.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/examples/spherical-mercator.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -24,107 +24,111 @@
-        // make map available for easy debugging
-        var map;
+// make map available for easy debugging
+var map;
-        // increase reload attempts
-        OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
+// increase reload attempts
+OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
-        function init(){
-            var options = {
-                projection: new OpenLayers.Projection("EPSG:900913"),
-                displayProjection: new OpenLayers.Projection("EPSG:4326"),
-                units: "m",
-                maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
-                                                 20037508, 20037508.34)
-            map = new OpenLayers.Map('map', options);
+function init(){
+    var maxExtent = new OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508),
+        restrictedExtent = maxExtent.clone(-20037508, -20037508, 20037508, 20037508),
+        maxResolution = 156543.0339;
+    var options = {
+        projection: new OpenLayers.Projection("EPSG:900913"),
+        displayProjection: new OpenLayers.Projection("EPSG:4326"),
+        units: "m",
+        maxResolution: maxResolution,
+        maxExtent: maxExtent,
+    map = new OpenLayers.Map('map', options);
-            // create Google Mercator layers
-            var gmap = new OpenLayers.Layer.Google(
-                "Google Streets",
-                {'sphericalMercator': true}
-            var gsat = new OpenLayers.Layer.Google(
-                "Google Satellite",
-                {type: G_SATELLITE_MAP, 'sphericalMercator': true, numZoomLevels: 22}
-            var ghyb = new OpenLayers.Layer.Google(
-                "Google Hybrid",
-                {type: G_HYBRID_MAP, 'sphericalMercator': true}
+    // create Google Mercator layers
+    var gmap = new OpenLayers.Layer.Google(
+        "Google Streets",
+        {sphericalMercator: true}
+    var gsat = new OpenLayers.Layer.Google(
+        "Google Satellite",
+        {type: G_SATELLITE_MAP, sphericalMercator: true, numZoomLevels: 22}
+    var ghyb = new OpenLayers.Layer.Google(
+        "Google Hybrid",
+        {type: G_HYBRID_MAP, sphericalMercator: true}
-            // create Virtual Earth layers
-            var veroad = new OpenLayers.Layer.VirtualEarth(
-                "Virtual Earth Roads",
-                {'type': VEMapStyle.Road, 'sphericalMercator': true}
-            var veaer = new OpenLayers.Layer.VirtualEarth(
-                "Virtual Earth Aerial",
-                {'type': VEMapStyle.Aerial, 'sphericalMercator': true}
-            var vehyb = new OpenLayers.Layer.VirtualEarth(
-                "Virtual Earth Hybrid",
-                {'type': VEMapStyle.Hybrid, 'sphericalMercator': true}
+    // create Virtual Earth layers
+    var veroad = new OpenLayers.Layer.VirtualEarth(
+        "Virtual Earth Roads",
+        {'type': VEMapStyle.Road, sphericalMercator: true}
+    var veaer = new OpenLayers.Layer.VirtualEarth(
+        "Virtual Earth Aerial",
+        {'type': VEMapStyle.Aerial, sphericalMercator: true}
+    var vehyb = new OpenLayers.Layer.VirtualEarth(
+        "Virtual Earth Hybrid",
+        {'type': VEMapStyle.Hybrid, sphericalMercator: true}
-            // create Yahoo layer
-            var yahoo = new OpenLayers.Layer.Yahoo(
-                "Yahoo Street",
-            var yahoosat = new OpenLayers.Layer.Yahoo(
-                "Yahoo Satellite",
-                {'type': YAHOO_MAP_SAT, 'sphericalMercator': true}
-            var yahoohyb = new OpenLayers.Layer.Yahoo(
-                "Yahoo Hybrid",
-                {'type': YAHOO_MAP_HYB, 'sphericalMercator': true}
+    // create Yahoo layer
+    var yahoo = new OpenLayers.Layer.Yahoo(
+        "Yahoo Street",
+    var yahoosat = new OpenLayers.Layer.Yahoo(
+        "Yahoo Satellite",
+        {'type': YAHOO_MAP_SAT, sphericalMercator: true}
+    var yahoohyb = new OpenLayers.Layer.Yahoo(
+        "Yahoo Hybrid",
+        {'type': YAHOO_MAP_HYB, sphericalMercator: true}
-            // create OSM layer
-            var mapnik = new OpenLayers.Layer.OSM();
-            // create OAM layer
-            var oam = new OpenLayers.Layer.XYZ(
-                "OpenAerialMap",
-                "http://tile.openaerialmap.org/tiles/1.0.0/openaerialmap-900913/${z}/${x}/${y}.png",
-                    sphericalMercator: true
+    // create OSM layer
+    var mapnik = new OpenLayers.Layer.OSM();
+    // create OAM layer
+    var oam = new OpenLayers.Layer.XYZ(
+        "OpenAerialMap",
+        "http://tile.openaerialmap.org/tiles/1.0.0/openaerialmap-900913/${z}/${x}/${y}.png",
+            sphericalMercator: true
-            var osmarender = new OpenLayers.Layer.OSM(
-                "OpenStreetMap (Tiles at Home)",
-                "http://tah.openstreetmap.org/Tiles/tile/${z}/${x}/${y}.png"
+    var osmarender = new OpenLayers.Layer.OSM(
+        "OpenStreetMap (Tiles at Home)",
+        "http://tah.openstreetmap.org/Tiles/tile/${z}/${x}/${y}.png"
-            // create WMS layer
-            var wms = new OpenLayers.Layer.WMS(
-                "World Map",
-                "http://world.freemap.in/tiles/",
-                {'layers': 'factbook-overlay', 'format':'png'},
-                    'opacity': 0.4, visibility: false,
-                    'isBaseLayer': false,'wrapDateLine': true
+    // create WMS layer
+    var wms = new OpenLayers.Layer.WMS(
+        "World Map",
+        "http://world.freemap.in/tiles/",
+        {'layers': 'factbook-overlay', 'format':'png'},
+            'opacity': 0.4, visibility: false,
+            'isBaseLayer': false,'wrapDateLine': true
-            // create a vector layer for drawing
-            var vector = new OpenLayers.Layer.Vector("Editable Vectors");
+    // create a vector layer for drawing
+    var vector = new OpenLayers.Layer.Vector("Editable Vectors");
-            map.addLayers([gmap, gsat, ghyb, veroad, veaer, vehyb,
-                           yahoo, yahoosat, yahoohyb, oam, mapnik, osmarender,
-                           wms, vector]);
-            map.addControl(new OpenLayers.Control.LayerSwitcher());
-            map.addControl(new OpenLayers.Control.EditingToolbar(vector));
-            map.addControl(new OpenLayers.Control.Permalink());
-            map.addControl(new OpenLayers.Control.MousePosition());
-            if (!map.getCenter()) {map.zoomToMaxExtent()}
+    map.addLayers([gmap, gsat, ghyb, veroad, veaer, vehyb,
+                   yahoo, yahoosat, yahoohyb, oam, mapnik, osmarender,
+                   wms, vector]);
+    map.addControl(new OpenLayers.Control.LayerSwitcher());
+    map.addControl(new OpenLayers.Control.EditingToolbar(vector));
+    map.addControl(new OpenLayers.Control.Permalink());
+    map.addControl(new OpenLayers.Control.MousePosition());
+    if (!map.getCenter()) {map.zoomToMaxExtent()}
     </script>
   </head>
Modified: sandbox/pinch/examples/tile-origin.html
--- sandbox/pinch/examples/tile-origin.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/examples/tile-origin.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -5,7 +5,6 @@
         <title>OpenLayers Tile Origin Example</title>
         <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
-        <link rel="stylesheet" href="../theme/default/google.css" type="text/css">
         <link rel="stylesheet" href="style.css" type="text/css">
     </head>
     <body>
Modified: sandbox/pinch/img/cloud-popup-relative.png
Modified: sandbox/pinch/img/drag-rectangle-off.png
Modified: sandbox/pinch/img/drag-rectangle-on.png
Modified: sandbox/pinch/img/east-mini.png
Modified: sandbox/pinch/img/layer-switcher-maximize.png
Modified: sandbox/pinch/img/layer-switcher-minimize.png
Modified: sandbox/pinch/img/marker-blue.png
Modified: sandbox/pinch/img/marker-gold.png
Modified: sandbox/pinch/img/marker-green.png
Modified: sandbox/pinch/img/marker.png
Modified: sandbox/pinch/img/measuring-stick-off.png
Modified: sandbox/pinch/img/measuring-stick-on.png
Modified: sandbox/pinch/img/north-mini.png
Modified: sandbox/pinch/img/panning-hand-off.png
Modified: sandbox/pinch/img/panning-hand-on.png
Modified: sandbox/pinch/img/slider.png
Modified: sandbox/pinch/img/south-mini.png
Modified: sandbox/pinch/img/west-mini.png
Modified: sandbox/pinch/img/zoom-minus-mini.png
Modified: sandbox/pinch/img/zoom-plus-mini.png
Modified: sandbox/pinch/img/zoom-world-mini.png
Modified: sandbox/pinch/img/zoombar.png
Modified: sandbox/pinch/lib/OpenLayers/BaseTypes/Pixel.js
--- sandbox/pinch/lib/OpenLayers/BaseTypes/Pixel.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/BaseTypes/Pixel.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -86,6 +86,24 @@
+     * APIMethod: distanceTo
+     * Returns the distance to the pixel point passed in as a parameter.
+     * Parameters:
+     * px - {<OpenLayers.Pixel>}
+     * Returns:
+     * {Float} The pixel point passed in as parameter to calculate the
+     *     distance to.
+    distanceTo:function(px) {
+        return Math.sqrt(
+            Math.pow(this.x - px.x, 2) +
+            Math.pow(this.y - px.y, 2)
      * APIMethod: add
      * Parameters:
Modified: sandbox/pinch/lib/OpenLayers/Control/Geolocate.js
--- sandbox/pinch/lib/OpenLayers/Control/Geolocate.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Control/Geolocate.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -74,6 +74,14 @@
+     * Method: destroy
+    destroy: function() {
+        this.deactivate();
+        OpenLayers.Control.prototype.destroy.apply(this, arguments);
      * Method: activate
      * Activates the control.
Modified: sandbox/pinch/lib/OpenLayers/Control/MouseDefaults.js
--- sandbox/pinch/lib/OpenLayers/Control/MouseDefaults.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Control/MouseDefaults.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -165,7 +165,7 @@
             this.zoomBox.style.opacity = "0.50";
             this.zoomBox.style.fontSize = "1px";
             this.zoomBox.style.zIndex = this.map.Z_INDEX_BASE["Popup"] - 1;
-            this.map.viewPortDiv.appendChild(this.zoomBox);
+            this.map.eventsDiv.appendChild(this.zoomBox);
         document.onselectstart = OpenLayers.Function.False;
         OpenLayers.Event.stop(evt);
@@ -302,7 +302,7 @@
      * Remove the zoombox from the screen and nullify our reference to it.
     removeZoomBox: function() {
-        this.map.viewPortDiv.removeChild(this.zoomBox);
+        this.map.eventsDiv.removeChild(this.zoomBox);
         this.zoomBox = null;
Modified: sandbox/pinch/lib/OpenLayers/Control/MouseToolbar.js
--- sandbox/pinch/lib/OpenLayers/Control/MouseToolbar.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Control/MouseToolbar.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -207,7 +207,7 @@
                 this.performedDrag = true;
                 break;
             case "measure":
Modified: sandbox/pinch/lib/OpenLayers/Control/OverviewMap.js
--- sandbox/pinch/lib/OpenLayers/Control/OverviewMap.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Control/OverviewMap.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -157,7 +157,7 @@
             this.handlers.drag.destroy();
-        this.ovmap && this.ovmap.viewPortDiv.removeChild(this.extentRectangle);
+        this.ovmap && this.ovmap.eventsDiv.removeChild(this.extentRectangle);
         this.extentRectangle = null;
         if (this.rectEvents) {
@@ -489,7 +489,7 @@
                         {controls: [], maxResolution: 'auto',
                          fallThrough: false}, this.mapOptions);
         this.ovmap = new OpenLayers.Map(this.mapDiv, options);
-        this.ovmap.viewPortDiv.appendChild(this.extentRectangle);
+        this.ovmap.eventsDiv.appendChild(this.extentRectangle);
         // prevent ovmap from being destroyed when the page unloads, because
         // the OverviewMap control has to do this (and does it).
Modified: sandbox/pinch/lib/OpenLayers/Handler/Box.js
--- sandbox/pinch/lib/OpenLayers/Handler/Box.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Handler/Box.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -96,10 +96,10 @@
              new OpenLayers.Pixel(-9999, -9999));
         this.zoomBox.className = this.boxDivClassName;
         OpenLayers.Element.addClass(
-            this.map.viewPortDiv, "olDrawBox"
+            this.map.eventsDiv, "olDrawBox"
@@ -157,11 +157,11 @@
     removeBox: function() {
         this.boxCharacteristics = null;
         OpenLayers.Element.removeClass(
Modified: sandbox/pinch/lib/OpenLayers/Handler/Click.js
--- sandbox/pinch/lib/OpenLayers/Handler/Click.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Handler/Click.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -85,24 +85,23 @@
      * Property: down
-     * {<OpenLayers.Pixel>} The pixel location of the last mousedown.
+     * {Object} Object that store relevant information about the last
+     *     mousedown or touchstart. Its 'xy' OpenLayers.Pixel property gives
+     *     the average location of the mouse/touch event. Its 'touches'
+     *     property records clientX/clientY of each touches.
     down: null,
      * Property: last
-     * {<OpenLayers.Pixel>} The pixel for the last touchmove. This is
-     * used to
+     *     touchmove. Its 'xy' OpenLayers.Pixel property gives
     last: null,
-     * Property: touch
-     * {Boolean} Are we on a touch enabled device? Default is false.
-    touch: false,
      * Property: rightclickTimerId
      * {Number} The id of the right mouse timeout waiting to clear the
      *     <delayedEvent>.
@@ -130,7 +129,7 @@
         // optionally register for mouseup and mousedown
         if(this.pixelTolerance != null) {
             this.mousedown = function(evt) {
-                this.down = evt;
+                this.down = this.getEventInfo(evt);
                 return true;
@@ -154,8 +153,7 @@
      * {Boolean} Continue propagating this event.
     touchstart: function(evt) {
-        this.touch = true;
-        this.down = evt;
         this.last = null;
         return true;
@@ -244,8 +242,9 @@
     dblclick: function(evt) {
         // for touch devices trigger dblclick only for
         // "one finger" touch
-        if(this.passesTolerance(evt) &&
-           (!evt.lastTouches || evt.lastTouches.length == 1)) {
+        var last = this.down || this.last;
+        if (this.passesTolerance(evt) &&
+            (!last || !last.touches || last.touches.length == 1)) {
             if(this["double"]) {
                 this.callback('dblclick', [evt]);
@@ -260,7 +259,7 @@
      *    an empty "touches" property.
     touchmove: function(evt) {
-        this.last = evt;
+        this.last = this.getEventInfo(evt);
@@ -287,13 +286,14 @@
         // Sencha Touch emulates click events, see ticket 3079 for more info
-        if (this.touch === true && evt.type === "click") {
+        if (this.down && this.down.touches && evt.type === "click") {
             return !this.stopSingle;
         if(this.passesTolerance(evt)) {
             if(this.timerId != null) {
                 // already received a click
-                if(evt.lastTouches) {
+                if (last && last.touches && last.touches.length > 0) {
                     // touch device - we may trigger dblclick
                     this.dblclick(evt);
                 } else {
@@ -367,6 +367,35 @@
+     * Method: getEventInfo
+     * This method allows us to store event information without storing the
+     *     actual event.  In touch devices (at least), the same event is
+     *     modified between touchstart, touchmove, and touchend.
+     * Returns:
+     * {Object} An object with event related info.
+    getEventInfo: function(evt) {
+        var touches;
+        if (evt.touches) {
+            var len = evt.touches.length;
+            touches = new Array(len);
+            var touch;
+            for (var i=0; i<len; i++) {
+                touch = evt.touches[i];
+                touches[i] = {
+                    clientX: touch.clientX,
+                    clientY: touch.clientY
+        return {
+            xy: evt.xy,
+            touches: touches
      * APIMethod: deactivate
      * Deactivate the handler.
Modified: sandbox/pinch/lib/OpenLayers/Layer/Grid.js
--- sandbox/pinch/lib/OpenLayers/Layer/Grid.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Layer/Grid.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -78,8 +78,11 @@
      * {Integer} Used only when in gridded mode, this specifies the number of
      *           extra rows and colums of tiles on each side which will
      *           surround the minimum grid tiles to cover the map.
+     *           For very slow loading layers, a larger value may increase
+     *           performance somewhat when dragging, but will increase bandwidth
+     *           use significantly.
-    buffer: 2,
+    buffer: 0,
      * APIProperty: numLoadingTiles
@@ -129,6 +132,20 @@
+     * Method: removeMap
+     * Called when the layer is removed from the map.
+     * Parameters:
+     * map - {<OpenLayers.Map>} The map.
+    removeMap: function(map) {
+        if(this.timerId != null) {
+            window.clearTimeout(this.timerId);
+            this.timerId = null;
      * APIMethod: destroy
      * Deconstruct the layer and clear the grid.
Modified: sandbox/pinch/lib/OpenLayers/Layer/VirtualEarth.js
--- sandbox/pinch/lib/OpenLayers/Layer/VirtualEarth.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Layer/VirtualEarth.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -13,7 +13,11 @@
  * Class: OpenLayers.Layer.VirtualEarth
+ * Instances of OpenLayers.Layer.VirtualEarth are used to display the data from
+ *     the Bing Maps AJAX Control (see e.g.
+ *     http://msdn.microsoft.com/library/bb429619.aspx). Create a VirtualEarth
+ *     layer with the <OpenLayers.Layer.VirtualEarth> constructor.
  * Inherits from:
  *  - <OpenLayers.Layer.EventPane>
  *  - <OpenLayers.Layer.FixedZoomLevels>
@@ -94,7 +98,23 @@
      * Constructor: OpenLayers.Layer.VirtualEarth
+     * Creates a new instance of a OpenLayers.Layer.VirtualEarth. If you use an
+     *     instance of OpenLayers.Layer.VirtualEarth in you map, you should set
+     *     the <OpenLayers.Map> option restrictedExtent to a meaningful value,
+     *     e.g.:
+     * (code)
+     * var map = new OpenLayers.Map( 'map', {
+     *     // other map options
+     *     restrictedExtent : OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508)
+     * var veLayer = new OpenLayers.Layer.VirtualEarth (
+     *     "Virtual Earth Layer"
+     * map.addLayer( veLayer );
+     * (end)
      * Parameters:
      * name - {String}
      * options - {Object}
Modified: sandbox/pinch/lib/OpenLayers/Map.js
--- sandbox/pinch/lib/OpenLayers/Map.js	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/lib/OpenLayers/Map.js	2011-02-25 15:14:40 UTC (rev 11509)
@@ -600,6 +600,14 @@
         // add any initial layers
         if (options && options.layers) {
+             * If you have set options.center, the map center property will be
+             * set at this point.  However, since setCenter has not been caleld,
+             * addLayers gets confused.  So we delete the map center in this
+             * case.  Because the check below uses options.center, it will
+             * be properly set below.
+            delete this.center;
             this.addLayers(options.layers);
             // set center (and optionally zoom)
             if (options.center) {
@@ -643,7 +651,15 @@
-     * Destroy this map
+     * Destroy this map.
+     *    Note that if you are using an application which removes a container
+     *    of the map from the DOM, you need to ensure that you destroy the
+     *    map *before* this happens; otherwise, the page unload handler
+     *    will fail because the DOM elements that map.destroy() wants
+     *    to clean up will be gone. (See
+     *    http://trac.osgeo.org/openlayers/ticket/2277 for more information).
+     *    This will apply to GeoExt and also to other applications which
+     *    modify the DOM of the container of the OpenLayers Map.
     destroy:function() {
         // if unloadDestroy is null, we've already been destroyed
Modified: sandbox/pinch/tests/BaseTypes/Pixel.html
--- sandbox/pinch/tests/BaseTypes/Pixel.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/BaseTypes/Pixel.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -40,11 +40,22 @@
         t.eq( pixel.x, 5, "changing oldPixel.x doesn't change pixel.x");
+    function test_Pixel_distanceTo(t) {
+        t.plan( 2 );
+        var px = new OpenLayers.Pixel(0,-2);
+        pixel = new OpenLayers.Pixel(0,0);
+        t.eq( pixel.distanceTo(px), 2, "(0,0) distanceTo (0,-2) = 2");
+        px = new OpenLayers.Pixel(-4,6);
+        pixel = new OpenLayers.Pixel(4,6);
+        t.eq( pixel.distanceTo(px), 8, "(4,6) distanceTo (-4,6) = 8");
     function test_Pixel_equals(t) {
         t.plan( 5 );
         pixel = new OpenLayers.Pixel(5,6);
-        px = new OpenLayers.Pixel(5,6);
+        var px = new OpenLayers.Pixel(5,6);
         t.eq( pixel.equals(px), true, "(5,6) equals (5,6)");
         px = new OpenLayers.Pixel(1,6);
Modified: sandbox/pinch/tests/Control/Geolocate.html
--- sandbox/pinch/tests/Control/Geolocate.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Control/Geolocate.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -1,6 +1,6 @@
 <html>
 <head>
-  <script src="../../lib/OpenLayers.js"></script>
+  <script src="../OLLoader.js"></script>
     var map, control, centerLL
         watch = null,
@@ -113,6 +113,17 @@
         map.addControl(control);
         control.activate();
+    function test_destroy(t) {
+        t.plan(1);
+        var control = new OpenLayers.Control.Geolocate({
+            geolocation: geolocation,
+            watch: true
+        control.activate();
+        control.destroy();
+        t.ok(control.active === false, "control deactivated before being destroyed");
     function loader() {
         map = new OpenLayers.Map('map');
         var layer = new OpenLayers.Layer.WMS("Test Layer",
Modified: sandbox/pinch/tests/Handler/Click.html
--- sandbox/pinch/tests/Handler/Click.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Handler/Click.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -316,14 +316,14 @@
         log = null;
         handler.touchstart({xy: {x: 1, y: 1}, touches: ["foo"]});
-        handler.touchend({});
+        handler.touchend({touches: ["foo"]});
         t.delay_call(1, function() {
             t.ok(log != null, "click callback called");
             if(log != null) {
                 t.eq(log.x, 1, "evt.xy.x as expected");
                 t.eq(log.y, 1, "evt.xy.y as expected");
-                t.eq(log.lastTouches, ["foo"], "evt.lastTouches as expected");
+                t.ok(log.lastTouches, "evt.lastTouches as expected");
             // tear down
             map.destroy();
@@ -359,7 +359,7 @@
         handler.touchend({type: "click"});
-        t.eq(handler.touch, true, "Touch property should be true");
+        t.eq(!!handler.down.touches, true, "Handler down touches property should be truthy");
         t.ok(log.dblclick == undefined, "dblclick callback not called with simulated click");
@@ -395,9 +395,9 @@
         // test
         log = {};
-        handler.touchstart({xy: {x: 1, y: 1}, touches: ["foo"]});
+        handler.touchstart({xy: {x: 1, y: 1}, touches: [{clientX:0, clientY:10}]});
         t.eq(log.click, undefined, "click callback not called");
@@ -405,7 +405,7 @@
         if(log.dblclick != undefined) {
             t.eq(log.dblclick.x, 1, "evt.xy.x as expected");
             t.eq(log.dblclick.y, 1, "evt.xy.y as expected");
-            t.eq(log.dblclick.lastTouches, ["foo"], "evt.lastTouches as expected");
+            t.ok(log.dblclick.lastTouches, "evt.lastTouches on evt");
         // tear down
Modified: sandbox/pinch/tests/Layer/ArcGIS93Rest.html
--- sandbox/pinch/tests/Layer/ArcGIS93Rest.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/ArcGIS93Rest.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -94,7 +94,7 @@
         var params = {layers: "show:0,2"};
         t.plan( 2 );
         var map = new OpenLayers.Map('map');
-        layer = new OpenLayers.Layer.ArcGIS93Rest(name, url, params);
+        layer = new OpenLayers.Layer.ArcGIS93Rest(name, url, params, {buffer: 2});
         map.addLayer(layer);
         map.setCenter(new OpenLayers.LonLat(0,0),5);
         t.eq( layer.grid.length, 7, "Grid rows is correct." );
Modified: sandbox/pinch/tests/Layer/Grid.html
--- sandbox/pinch/tests/Layer/Grid.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/Grid.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -27,7 +27,7 @@
         layer = new OpenLayers.Layer.Grid(name, url, params, null);
         t.ok( layer instanceof OpenLayers.Layer.Grid, "returns OpenLayers.Layer.Grid object" );
-        t.eq( layer.buffer, 2, "buffer default is 2");
+        t.eq( layer.buffer, 0, "buffer default is 0");
         t.eq( layer.ratio, 1.5, "ratio default is 1.5");
         t.eq( layer.numLoadingTiles, 0, "numLoadingTiles starts at 0");
         t.ok( layer.events.listeners["tileloaded"] != null, "'tileloaded' event added to layer's event types");
@@ -47,7 +47,7 @@
     function test_Layer_Grid_inittiles (t) {
         t.plan( 2 );
-        layer = new OpenLayers.Layer.WMS(name, url, params);
+        layer = new OpenLayers.Layer.WMS(name, url, params, {buffer:2});
@@ -593,7 +593,7 @@
     function test_Layer_Grid_destroy (t) {
-        t.plan( 7 );
+        t.plan( 8 );
         layer = new OpenLayers.Layer.Grid(name, url, params);
@@ -608,6 +608,7 @@
         map.setCenter(new OpenLayers.LonLat(0,0), 10);
+        map.setCenter(new OpenLayers.LonLat(1,1));
         //grab a reference to one of the tiles
@@ -616,6 +617,7 @@
         layer.destroy();
         t.eq( tile.imgDiv, null, "Tile destroyed" );
+        t.eq( layer.timerId, null, "Tile loading timeout cleared");
         t.ok( layer.grid == null, "tiles appropriately destroyed")
Modified: sandbox/pinch/tests/Layer/KaMap.html
--- sandbox/pinch/tests/Layer/KaMap.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/KaMap.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -65,8 +65,8 @@
         layer = new OpenLayers.Layer.KaMap(name, url, params, units);
-        t.eq( layer.grid.length, 8, "KaMap rows is correct." );
-        t.eq( layer.grid[0].length, 6, "KaMap cols is correct." );
+        t.eq( layer.grid.length, 4, "KaMap rows is correct." );
+        t.eq( layer.grid[0].length, 3, "KaMap cols is correct." );
         map.destroy();
Modified: sandbox/pinch/tests/Layer/MapGuide.html
--- sandbox/pinch/tests/Layer/MapGuide.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/MapGuide.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -69,7 +69,7 @@
         layer = new OpenLayers.Layer.MapGuide(name, url, paramsTiled);
         map.setCenter(new OpenLayers.LonLat(0,400000),5);
-        t.eq( layer.grid.length, 6, "Grid rows is correct." );
+        t.eq( layer.grid.length, 3, "Grid rows is correct." );
         // t.eq( layer.grid[0].length, 6, "Grid cols is correct." );
         map.destroy();
Modified: sandbox/pinch/tests/Layer/MapServer.html
--- sandbox/pinch/tests/Layer/MapServer.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/MapServer.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -74,11 +74,11 @@
     function test_Layer_MapServer_inittiles (t) {
         t.plan( 2 );
-        layer = new OpenLayers.Layer.MapServer(name, url, params);
+        layer = new OpenLayers.Layer.MapServer(name, url, params, {buffer: 0});
-        t.eq( layer.grid.length, 7, "Grid rows is correct." );
-        t.eq( layer.grid[0].length, 6, "Grid cols is correct." );
+        t.eq( layer.grid.length, 4, "Grid rows is correct." );
+        t.eq( layer.grid[0].length, 3, "Grid cols is correct." );
         map.destroy();
@@ -234,7 +234,7 @@
             var layer = new OpenLayers.Layer.Google("Google");
-            layer = new OpenLayers.Layer.MapServer(name, url, params, {isBaseLayer: false, reproject: true});
+            layer = new OpenLayers.Layer.MapServer(name, url, params, {isBaseLayer: false, reproject: true, buffer: 2});
             layer.isBaseLayer=false;
             map.setCenter(new OpenLayers.LonLat(0,0), 5);
@@ -251,7 +251,7 @@
+        layer = new OpenLayers.Layer.MapServer(name, url, params, {buffer:2});
         var tile = layer.grid[0][0];
Modified: sandbox/pinch/tests/Layer/TMS.html
--- sandbox/pinch/tests/Layer/TMS.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/TMS.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -134,7 +134,7 @@
         t.plan(1);
             m = new OpenLayers.Map("map", {'maxExtent':new OpenLayers.Bounds(-122.6579,37.4901,-122.0738,37.8795)});
             layer = new OpenLayers.Layer.TMS( "TMS",
-                    "http://labs.metacarta.com/wms-c/Basic.py/", {layername: 'basic', type:'png', resolutions:[0.000634956337608418]} );
+                    "http://labs.metacarta.com/wms-c/Basic.py/", {layername: 'basic', type:'png', resolutions:[0.000634956337608418], buffer: 2} );
             m.addLayer(layer);
             m.zoomToMaxExtent();
             t.eq(layer.getURL(layer.grid[3][3].bounds), "http://labs.metacarta.com/wms-c/Basic.py/1.0.0/basic/0/1/1.png", "TMS tiles around rounded properly.");
Modified: sandbox/pinch/tests/Layer/WMS.html
--- sandbox/pinch/tests/Layer/WMS.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/WMS.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -146,7 +146,7 @@
     function test_Layer_WMS_inittiles (t) {
         t.plan( 2 );
@@ -312,7 +312,7 @@
             var wmslayer = new OpenLayers.Layer.WMS(name, url, params,
-                                                    {isBaseLayer: false, reproject:true});
+                                                    {isBaseLayer: false, reproject:true, buffer: 2});
             wmslayer.isBaseLayer=false;
             map.addLayer(wmslayer);
@@ -329,7 +329,7 @@
+        layer = new OpenLayers.Layer.WMS(name, url, params, {buffer: 2});
Modified: sandbox/pinch/tests/Layer/WrapDateLine.html
--- sandbox/pinch/tests/Layer/WrapDateLine.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/WrapDateLine.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -130,7 +130,7 @@
         t.plan( 3 );
         var url = "http://octo.metacarta.com/cgi-bin/mapserv";
-        layer = new OpenLayers.Layer.WMS(name, url, params, {'wrapDateLine':true,encodeBBOX:true});
+        layer = new OpenLayers.Layer.WMS(name, url, params, {'wrapDateLine':true,encodeBBOX:true, buffer: 2});
         var m = new OpenLayers.Map('map');
         m.addLayer(layer);
@@ -146,7 +146,7 @@
         var layer = new OpenLayers.Layer.KaMap( "Blue Marble NG",
              "http://www.openlayers.org/world/index.php",
              {g: "satellite", map: "world"},
-             {wrapDateLine: true} );
+             {wrapDateLine: true, buffer: 2} );
         m.addLayer(layer);
@@ -158,13 +158,13 @@
     function test_Layer_WrapDateLine_WMS_Overlay (t) {
         t.plan( 3 );
-        baselayer = new OpenLayers.Layer.WMS(name, url, params, {'wrapDateLine':true});
+        baselayer = new OpenLayers.Layer.WMS(name, url, params, {'wrapDateLine':true, buffer: 2});
         var layer = new OpenLayers.Layer.WMS( "DM Solutions Demo",
             "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap",
             {layers: "bathymetry,land_fn,park,drain_fn,drainage," +
                      "prov_bound,fedlimit,rail,road,popplace",
              transparent: "true", format: "image/png"},
-            {wrapDateLine: true, reproject: false,encodeBBOX:true});
+            {wrapDateLine: true, reproject: false,encodeBBOX:true, buffer:2});
         m.addLayers([baselayer,layer]);
Modified: sandbox/pinch/tests/Layer/XYZ.html
--- sandbox/pinch/tests/Layer/XYZ.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Layer/XYZ.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -126,7 +126,7 @@
         t.plan(1);
             layer = new OpenLayers.Layer.XYZ( "XYZ",
-                    url, {layername: 'basic', type:'png', resolutions:[0.000634956337608418]} );
+                    url, {layername: 'basic', type:'png', resolutions:[0.000634956337608418], buffer: 2} );
             m.addLayer(layer);
             m.zoomToMaxExtent()
             t.eq(layer.getURL(layer.grid[3][3].bounds), "http://labs.metacarta.com/wms-c/Basic.py/1.0.0/basic/0/1/0.png", "XYZ tiles around rounded properly.");
Modified: sandbox/pinch/tests/Map.html
--- sandbox/pinch/tests/Map.html	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tests/Map.html	2011-02-25 15:14:40 UTC (rev 11509)
@@ -352,6 +352,8 @@
         valid = OpenLayers.Map.prototype.isValidZoomLevel.apply(map, [19]);
         t.eq(valid, false, "19 is not a valid zoomLevel when baseLayer has restrictedMinZoom of 1");
+        map.destroy();
     function test_Map_isValidLonLat(t) {
@@ -977,6 +979,8 @@
         map.addControls(controls2, pixels2);
         t.eq(map.controls.length, 5, "three additional controls were added by map.addControls with a px-array");
         t.eq(map.controls[3].position.toString(), pixels2[1].toString(), "control 'fourthctrl' has position set to given px");
+        map.destroy();
     function test_Map_getControl(t) {
@@ -1598,11 +1602,13 @@
         t.eq(map.layers.length, 2, "multiple layers added from options");
         t.ok(map.baseLayer, "map has a base layer");
+        map.destroy();
     function test_center_option(t) {
-        t.plan(6);
+        t.plan(7);
         var map, msg;
@@ -1625,6 +1631,12 @@
             map.destroy();
+        var log = [];
+        var meth = OpenLayers.Layer.prototype.moveTo;
+        OpenLayers.Layer.prototype.moveTo = function() {
+            log.push(arguments);
+            meth.apply(this, arguments);
         // set center without zoom
         var center = new OpenLayers.LonLat(1, 2);
@@ -1635,8 +1647,10 @@
         t.ok(center.equals(map.getCenter()), "map center set without zoom");
+        t.eq(log.length, 1, "moveTo called once");
         map.destroy();
+        OpenLayers.Layer.prototype.moveTo = meth;
         // set center and zoom
         var zoom = 3;
Modified: sandbox/pinch/theme/default/img/add_point_off.png
Modified: sandbox/pinch/theme/default/img/drag-rectangle-off.png
Modified: sandbox/pinch/theme/default/img/drag-rectangle-on.png
Modified: sandbox/pinch/theme/default/img/draw_line_off.png
Modified: sandbox/pinch/theme/default/img/draw_line_on.png
Modified: sandbox/pinch/theme/default/img/draw_point_off.png
Modified: sandbox/pinch/theme/default/img/draw_point_on.png
Modified: sandbox/pinch/theme/default/img/draw_polygon_off.png
Modified: sandbox/pinch/theme/default/img/draw_polygon_on.png
Modified: sandbox/pinch/theme/default/img/editing_tool_bar.png
Modified: sandbox/pinch/theme/default/img/move_feature_off.png
Modified: sandbox/pinch/theme/default/img/move_feature_on.png
Modified: sandbox/pinch/theme/default/img/navigation_history.png
Modified: sandbox/pinch/theme/default/img/pan-panel-NOALPHA.png
Modified: sandbox/pinch/theme/default/img/pan-panel.png
Modified: sandbox/pinch/theme/default/img/pan_on.png
Modified: sandbox/pinch/theme/default/img/panning-hand-off.png
Modified: sandbox/pinch/theme/default/img/panning-hand-on.png
Modified: sandbox/pinch/theme/default/img/remove_point_on.png
Modified: sandbox/pinch/theme/default/img/save_features_off.png
Modified: sandbox/pinch/theme/default/img/save_features_on.png
Modified: sandbox/pinch/theme/default/img/view_next_off.png
Modified: sandbox/pinch/theme/default/img/view_previous_off.png
Modified: sandbox/pinch/theme/default/img/zoom-panel.png
Property changes on: sandbox/pinch/tools
Modified: svn:ignore
   - *.pyc
   + *.pyc
Copied: sandbox/pinch/tools/closure.py (from rev 11507, trunk/openlayers/tools/closure.py)
--- sandbox/pinch/tools/closure.py	                        (rev 0)
+++ sandbox/pinch/tools/closure.py	2011-02-25 15:14:40 UTC (rev 11509)
@@ -0,0 +1,21 @@
+import sys
+import os
+import tempfile
+path = os.path.abspath(os.path.join(os.path.dirname(__file__), "closure-compiler.jar"))
+if not os.path.exists(path):
+    raise Exception("No closure-compiler.jar at %s; read README.txt!" % path)
+def minimize(code):
+    ntf = tempfile.NamedTemporaryFile()
+    ntf.write(code)
+    ntf.flush()
+    ntf2 = tempfile.NamedTemporaryFile()
+    os.system("java -jar %s --js %s --js_output_file %s" % (path, ntf.name, ntf2.name))
+    ntf2.seek(0)
+    data = ntf2.read()
+    ntf.close()
+    ntf2.close()
+    return data
Copied: sandbox/pinch/tools/closure_ws.py (from rev 11507, trunk/openlayers/tools/closure_ws.py)
--- sandbox/pinch/tools/closure_ws.py	                        (rev 0)
+++ sandbox/pinch/tools/closure_ws.py	2011-02-25 15:14:40 UTC (rev 11509)
@@ -0,0 +1,28 @@
+#!/usr/bin/python
+import httplib, urllib, sys
+import time
+# Define the parameters for the POST request and encode them in
+# a URL-safe format.
+    params = urllib.urlencode([
+        ('js_code', code),
+        ('compilation_level', 'SIMPLE_OPTIMIZATIONS'),
+        ('output_format', 'text'),
+        ('output_info', 'compiled_code'),
+    t = time.time()
+    # Always use the following value for the Content-type header.
+    headers = { "Content-type": "application/x-www-form-urlencoded" }
+    conn = httplib.HTTPConnection('closure-compiler.appspot.com')
+    conn.request('POST', '/compile', params, headers)
+    response = conn.getresponse()
+    data = response.read()
+    conn.close()
+    if data.startswith("Error"):
+        raise Exception(data)
+    print "%.3f seconds to compile" % (time.time() - t)
+    return data
Modified: sandbox/pinch/tools/release.sh
--- sandbox/pinch/tools/release.sh	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tools/release.sh	2011-02-25 15:14:40 UTC (rev 11509)
@@ -2,13 +2,22 @@
 VERSION=$1
+wget -c http://closure-compiler.googlecode.com/files/compiler-latest.zip
+unzip compiler-latest.zip
 svn export http://svn.openlayers.org/tags/openlayers/release-$VERSION OpenLayers-$VERSION
 cd OpenLayers-$VERSION/build
-./build.py full
+mv ../../compiler.jar ../tools/closure-compiler.jar
+./build.py -c closure full
 cp OpenLayers.js ..
+rm ../tools/closure-compiler.jar
 cd ..
+for i in google ie6-style style; do
+    csstidy theme/default/$i.css --template=highest theme/default/$i.tidy.css
+done
 mkdir doc/devdocs
 mkdir doc/apidocs
 rm tools/*.pyc
Modified: sandbox/pinch/tools/update_dev_dir.sh
--- sandbox/pinch/tools/update_dev_dir.sh	2011-02-25 15:13:53 UTC (rev 11508)
+++ sandbox/pinch/tools/update_dev_dir.sh	2011-02-25 15:14:40 UTC (rev 11509)
@@ -18,11 +18,15 @@
     cd /osgeo/openlayers/docs/dev/tools/
     python exampleparser.py
     cd /osgeo/openlayers/docs/dev/build
-    ./build.py tests.cfg
+    ./build.py -c closure tests.cfg
     cp OpenLayers.js ..
     cd ..
+    for i in google ie6-style style; do
+        cp theme/default/$i.tidy.css theme/default/$i.css
+    done
     sed -i -e 's!../lib/OpenLayers.js!../OpenLayers.js!' examples/*.html
     naturaldocs -i /osgeo/openlayers/docs/dev/lib -o HTML /osgeo/openlayers/dev/apidocs -p /osgeo/openlayers/docs/dev/apidoc_config -s Default OL >/dev/null
     naturaldocs -i /osgeo/openlayers/docs/dev/lib -o HTML /osgeo/openlayers/dev/docs -p /osgeo/openlayers/docs/dev/doc_config -s Default OL >/dev/null
More information about the Commits mailing list
