[OpenLayers-Commits] r11539 - trunk/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Feb 25 14:20:21 EST 2011
Author: crschmidt
Date: 2011-02-25 11:20:19 -0800 (Fri, 25 Feb 2011)
New Revision: 11539
   trunk/openlayers/examples/browser.html
   trunk/openlayers/examples/browser.js
Update the browser.html example to support further testing. patch by cmoullet,
simple example change, (Closes #3108)
Modified: trunk/openlayers/examples/browser.html
--- trunk/openlayers/examples/browser.html	2011-02-25 19:06:58 UTC (rev 11538)
+++ trunk/openlayers/examples/browser.html	2011-02-25 19:20:19 UTC (rev 11539)
@@ -11,6 +11,10 @@
         .olControlAttribution {
             bottom: 5px;
+        .tester {
+            margin: 3px;
     </style>
     <script type="text/javascript">
         function init() {
@@ -79,12 +83,15 @@
 </head>
 <body onload="init()">
 <h1 id="title">Browser detection</h1>
 <div id="tags">
-  browser, vendor, mobile, events, HTML5, gesture, touch
-</div>
+    browser, vendor, mobile, events, HTML5, gesture, touch
+</div>
 <p id="shortdesc">
     The goal of this script is to inform about the capacity of the browser used by the user.
 </p>
 <div id="docs">
     <p>
         See the <a href="browser.js" target="_blank">
@@ -95,7 +102,50 @@
 <h1>Your browser information</h1>
 <div id="result">
+</div>
+<h1>Click or touch the red square to get information about the selected events</h1>
+<div>
+    <div class="tester">
+        <INPUT TYPE=CHECKBOX ID="clickID" checked>click<BR>
+        <INPUT TYPE=CHECKBOX ID="dblclickID">dblclick<BR>
+        <INPUT TYPE=CHECKBOX ID="mousedownID">mousedown<BR>
+        <INPUT TYPE=CHECKBOX ID="mouseupID">mouseup<BR>
+        <INPUT TYPE=CHECKBOX ID="mouseoverID">mouseover<BR>
+        <INPUT TYPE=CHECKBOX ID="mousemoveID">mousemove<BR>
+        <INPUT TYPE=CHECKBOX ID="mouseoutID">mouseout<BR>
+        <INPUT TYPE=CHECKBOX ID="touchstartID">touchstart<BR>
+        <INPUT TYPE=CHECKBOX ID="touchendID">touchend<BR>
+        <INPUT TYPE=CHECKBOX ID="touchmoveID">touchmove<BR>
+        <INPUT TYPE=CHECKBOX ID="touchcancelID">touchcancel<BR>
+        <INPUT TYPE=CHECKBOX ID="gesturestartID">gesturestart<BR>
+        <INPUT TYPE=CHECKBOX ID="gesturechangeID">gesturechange<BR>
+        <INPUT TYPE=CHECKBOX ID="gestureendID">gestureend<BR>
+    </div>
+    <div style="height: 200px;width: 200px;" class="tester">
+        <div id="box" style="height: 200px; width: 200px; background: none repeat scroll 0% 0% red; "
+             onclick="click(event)"
+             ondblclick="dblclick(event)"
+             onmousedown="mousedown(event)"
+             onmouseup="mouseup(event)"
+             onmouseover="mouseover(event)"
+             onmousemove="mousemove(event)"
+             onmouseout="mouseout(event)"
+             ontouchstart="touchstart(event)"
+             ontouchend="touchend(event)"
+             ontouchmove="touchmove(event)"
+             ontouchcancel="touchcancel(event)"
+             ongesturestart="gesturestart(event)"
+             ongesturechange="gesturechange(event)"
+             ongestureend="gestureend(event)">
+        </div>
+    </div>
+    <div id="log" class="tester"></div>
 </div>
 </body>
 </html>
Modified: trunk/openlayers/examples/browser.js
--- trunk/openlayers/examples/browser.js	2011-02-25 19:06:58 UTC (rev 11538)
+++ trunk/openlayers/examples/browser.js	2011-02-25 19:20:19 UTC (rev 11539)
@@ -49,4 +49,193 @@
     div.innerHTML = div.innerHTML + "<br>";
+var counter = 1;
+function log(title, detail) {
+    var logDiv = document.getElementById("log");
+    idString = "'id" + counter + "'";
+    var newlink = document.createElement('a');
+    newlink.setAttribute('href', "javascript:toggle_visibility(" + idString + ")");
+    newlink.innerHTML = counter + ". " + title;
+    var br1 = document.createElement('br');
+    logDiv.appendChild(newlink);
+    logDiv.appendChild(br1);
+    var childDiv = document.createElement('div');
+    childDiv.setAttribute("id", idString.replace("'", "").replace("'", ""));
+    childDiv.setAttribute("style", 'display: none; margin-left : 5px;');
+    childDiv.innerHTML = detail;
+    var br2 = document.createElement('br');
+    logDiv.appendChild(childDiv);
+    counter = counter + 1;
+function inspect(obj) {
+    if (typeof obj === "undefined") {
+        return "undefined";
+    var _props = [];
+    for (var i in obj) {
+        _props.push(i + " : " + obj[i]);
+    return " {" + _props.join(",<br>") + "} ";
+function click(e) {
+    if (document.getElementById("clickID").checked) {
+        var box = document.getElementById("box");
+        log(e.type, inspect(e));
+        if (e.preventDefault) e.preventDefault();
+    return false;
+function dblclick(e) {
+    if (document.getElementById("dblclickID").checked) {
+    return false;
+function mousedown(e) {
+    if (document.getElementById("mousedownID").checked) {
+    return false;
+function mouseup(e) {
+    if (document.getElementById("mouseupID").checked) {
+    return false;
+function mouseover(e) {
+    if (document.getElementById("mouseoverID").checked) {
+    return false;
+function mousemove(e) {
+    if (document.getElementById("mousemoveID").checked) {
+    return false;
+function mouseout(e) {
+    if (document.getElementById("mouseoutID").checked) {
+    return false;
+function touchstart(e) {
+    if (document.getElementById("touchstartID").checked) {
+        var result = inspect(e);
+        for (var i = 0; i < e.touches.length; i++) {
+            result = result + "<br> Touches nr." + i + " <br>" + inspect(e.touches[i]);
+        log(e.type, result);
+    return false;
+function touchend(e) {
+    if (document.getElementById("touchendID").checked) {
+    return false;
+function touchmove(e) {
+    if (document.getElementById("touchmoveID").checked) {
+        var targetEvent = e.touches.item(0);
+        box.style.left = targetEvent.clientX + "px";
+        box.style.top = targetEvent.clientY + "px";
+    return false;
+function touchcancel(e) {
+    if (document.getElementById("touchcancelID").checked) {
+    return false;
+function gesturestart(e) {
+    if (document.getElementById("gesturestartID").checked) {
+    return false;
+function gesturechange(e) {
+    if (document.getElementById("gesturechangeID").checked) {
+    return false;
+function gestureend(e) {
+    if (document.getElementById("gestureendID").checked) {
+    return false;
+function toggle_visibility(id) {
+    var e = document.getElementById(id);
+    if (e.style.display == 'block') {
+        e.style.display = 'none';
+    } else {
+        e.style.display = 'block';
More information about the Commits mailing list
