[OpenLayers-Commits] r11551 - in trunk/openlayers/tests: . node.js
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sat Feb 26 19:39:40 EST 2011
Author: crschmidt
Date: 2011-02-26 16:39:39 -0800 (Sat, 26 Feb 2011)
New Revision: 11551
Added:
   trunk/openlayers/tests/node.js/
   trunk/openlayers/tests/node.js/mockdom.js
   trunk/openlayers/tests/node.js/node-tests.cfg
   trunk/openlayers/tests/node.js/node.js
   trunk/openlayers/tests/node.js/run-test.js
   trunk/openlayers/tests/node.js/run.sh
Some node.js test hacking.
Added: trunk/openlayers/tests/node.js/mockdom.js
--- trunk/openlayers/tests/node.js/mockdom.js	                        (rev 0)
+++ trunk/openlayers/tests/node.js/mockdom.js	2011-02-27 00:39:39 UTC (rev 11551)
@@ -0,0 +1,106 @@
+XMLHttpRequest = function() {
+    return {
+    'open': function() {  },
+    'send': function() {  }
+alert = print;
+navigator = {
+  'appName': 'mockdom',
+  'userAgent': 'mockdom',
+  'appVersion': '0.1',
+  'language': 'en',
+  'userLanguage': 'en'
+element = function(type) {
+    type = type || "";
+    return {
+        'childNodes': [],
+        'className': '',
+        'tagName': type.toUpperCase(),
+        'style': {},
+        'setAttribute': function(attr, value) {
+            this[attr] = value;
+        'appendChild': function(element) {
+            if (this.childNodes.length) {
+                this.childNodes[this.childNodes.length - 1].nextSibling = element;
+            }  else {
+                this.firstChild = element;
+            element.parentNode = this;
+            this.childNodes.push(element);
+        'removeChild': function(element) {
+            var i = this.childNodes.indexOf(element);
+            this.childNodes.splice(i, 1);
+        'addEventListener': function() {
+        'removeEventListener': function() {
+        'getElementsByTagName': function(name, externalList) {
+            var uc = name.toUpperCase();
+            var list = externalList || [];
+            for(var i = 0; i < this.childNodes.length; i++) {
+                if (this.childNodes[i].tagName == uc) {
+                    list.push(this.childNodes[i]);
+                this.childNodes[i].getElementsByTagName(name, list);
+            return list;
+        'getElementById': function(id) {
+                if (this.childNodes[i].id == id) {
+                    return this.childNodes[i];
+                } else {
+                    var elem = this.childNodes[i].getElementById(id);
+                    if (elem) {
+                        return elem
+document = element();
+document.createElement = function(type) {
+     return element(type);
+document.createTextNode = function(text) {
+    var e = element("Text");
+    e.innerHTML = text;
+document.appendChild(element("head"));
+document.body = element("body");
+document.appendChild(document.body);
+window = {
+    'getSelection': function() {
+        return {
+            collapseToStart: function() {}
+    document: document,
+    navigator: navigator,
+    location: {
+        href: '#',
+        port: '',
+        hostname: 'openlayers.org',
+        host: 'openlayers.org',
+        proto: 'https'
+document.location = window.location;
+window.Function = Function;
Added: trunk/openlayers/tests/node.js/node-tests.cfg
--- trunk/openlayers/tests/node.js/node-tests.cfg	                        (rev 0)
+++ trunk/openlayers/tests/node.js/node-tests.cfg	2011-02-27 00:39:39 UTC (rev 11551)
@@ -0,0 +1,12 @@
+# This build config is supposed to be used for the units tests with "mode=build"
+[first]
+mockdom.js
+[last]
+node.js
+[include]
+[exclude]
+OpenLayers.js
+Firebug/firebug.js
Added: trunk/openlayers/tests/node.js/node.js
--- trunk/openlayers/tests/node.js/node.js	                        (rev 0)
+++ trunk/openlayers/tests/node.js/node.js	2011-02-27 00:39:39 UTC (rev 11551)
@@ -0,0 +1 @@
+exports.OpenLayers = OpenLayers;
Added: trunk/openlayers/tests/node.js/run-test.js
--- trunk/openlayers/tests/node.js/run-test.js	                        (rev 0)
+++ trunk/openlayers/tests/node.js/run-test.js	2011-02-27 00:39:39 UTC (rev 11551)
@@ -0,0 +1,26 @@
+// Requires:
+/// 0. nodejs
+//  1. jsdom installed (npm install jsdom)
+//  2. A build profile with mockdom.js included in [first], and node.js
+//     inclded in [last], at ../../build/OpenLayers.js , like node-tests.js.
+//  3. Run with node run-tests.js
+//  Missing: integration with a solid node.js testrunner.
+var jsdom = require('jsdom');
+jsdom.env('<html><body></body></html>', function(errors, window) {
+    for (var i in window) {
+        if (i == "console") {
+            continue;
+        eval(i+"=window['"+i+"'];");
+    OpenLayers = require("../../build/OpenLayers.js")['OpenLayers'];
+    var map = new OpenLayers.Map(document.createElement("map"));
+    map.addLayer(new OpenLayers.Layer("", {isBaseLayer:true}));
+    map.setCenter(new OpenLayers.LonLat(-71,42), 10);
+    var px = map.getPixelFromLonLat(map.getLonLatFromPixel(new OpenLayers.Pixel(100,100)));
+    console.log(px);
+    var px = map.getLonLatFromPixel(map.getPixelFromLonLat(new OpenLayers.LonLat(10,10)));
+    console.log(px);
Added: trunk/openlayers/tests/node.js/run.sh
--- trunk/openlayers/tests/node.js/run.sh	                        (rev 0)
+++ trunk/openlayers/tests/node.js/run.sh	2011-02-27 00:39:39 UTC (rev 11551)
@@ -0,0 +1,10 @@
+#!/bin/sh
+cp mockdom.js node.js ../../lib
+cp node-tests.cfg ../../build
+cd ../../build
+python build.py -c none node-tests
+cd ../tests/node.js/
+node run-test.js
+rm ../../lib/mockdom.js
+rm ../../lib/node.js
Property changes on: trunk/openlayers/tests/node.js/run.sh
___________________________________________________________________
Added: svn:executable
More information about the Commits mailing list
