[OpenLayers-Commits] r11562 - in sandbox/ahocevar/3072: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Feb 27 09:54:34 EST 2011
Author: ahocevar
Date: 2011-02-27 06:54:33 -0800 (Sun, 27 Feb 2011)
New Revision: 11562
   sandbox/ahocevar/3072/lib/OpenLayers/Handler/Path.js
   sandbox/ahocevar/3072/lib/OpenLayers/Handler/Point.js
   sandbox/ahocevar/3072/lib/OpenLayers/Handler/Polygon.js
   sandbox/ahocevar/3072/tests/Handler/Polygon.html
doc and test improvements
Modified: sandbox/ahocevar/3072/lib/OpenLayers/Handler/Path.js
--- sandbox/ahocevar/3072/lib/OpenLayers/Handler/Path.js	2011-02-27 13:59:09 UTC (rev 11561)
+++ sandbox/ahocevar/3072/lib/OpenLayers/Handler/Path.js	2011-02-27 14:54:33 UTC (rev 11562)
@@ -298,7 +298,7 @@
-     * APIMethod: finishGeometry
+     * Method: finishTouchGeometry
      * Finish the geometry and send it back to the control.
     finishTouchGeometry: function() {
Modified: sandbox/ahocevar/3072/lib/OpenLayers/Handler/Point.js
--- sandbox/ahocevar/3072/lib/OpenLayers/Handler/Point.js	2011-02-27 13:59:09 UTC (rev 11561)
+++ sandbox/ahocevar/3072/lib/OpenLayers/Handler/Point.js	2011-02-27 14:54:33 UTC (rev 11562)
@@ -257,7 +257,7 @@
@@ -421,6 +421,8 @@
         if (this.timerId &&
                 this.passesTolerance(last, evt.xy, this.dblclickTolerance)) {
             this.isDblclick = true;
+            // a valid touch immediately adds a component and leaves us with a
+            // complete geometry
             this.finishTouchGeometry();
             window.clearTimeout(this.timerId);
             this.timerId = null;
Modified: sandbox/ahocevar/3072/lib/OpenLayers/Handler/Polygon.js
--- sandbox/ahocevar/3072/lib/OpenLayers/Handler/Polygon.js	2011-02-27 13:59:09 UTC (rev 11561)
+++ sandbox/ahocevar/3072/lib/OpenLayers/Handler/Polygon.js	2011-02-27 14:54:33 UTC (rev 11562)
@@ -150,7 +150,7 @@
Modified: sandbox/ahocevar/3072/tests/Handler/Polygon.html
--- sandbox/ahocevar/3072/tests/Handler/Polygon.html	2011-02-27 13:59:09 UTC (rev 11561)
+++ sandbox/ahocevar/3072/tests/Handler/Polygon.html	2011-02-27 14:54:33 UTC (rev 11562)
@@ -880,7 +880,7 @@
     function test_sequence_touch_1(t) {
-        t.plan(17);
+        t.plan(19);
         log = [];
         var map = new OpenLayers.Map("map", { // 300 x 150
@@ -902,36 +902,38 @@
         map.addControl(control);
         map.setCenter(new OpenLayers.LonLat(0, 0), 5);
         handler.activate();
         handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(49, 75)});
         t.eq(log.length, 0, "touch start 1");
+        var expectedRing = new OpenLayers.Geometry.LinearRing([
+            new OpenLayers.Geometry.Point(-100, 0),
         handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(50, 75)});
         t.eq(log.length, 0, "touch move");
         handler.touchend({type: "touchend"});
         t.eq(log.length, 0, "touch end");
-        /*t.geom_eq(handler.polygon.geometry,
-            new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([
-                new OpenLayers.Geometry.Point(-100, 0),
-            ])]), "geometry is correct");*/
+        expectedRing.addComponent(new OpenLayers.Geometry.Point(-100,0), 1);
+        t.geom_eq(handler.polygon.geometry.components[0], expectedRing, "geometry is correct");
         handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(100, 75)});
         t.eq(log.length, 0, "touch start 2");
         handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(250, 75)});
         t.eq(log.length, 0, "touch start 3");
More information about the Commits mailing list
