[OpenLayers-Commits] r11575 - trunk/openlayers/lib/OpenLayers/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Feb 28 03:12:07 EST 2011
Author: fredj
Date: 2011-02-28 00:12:05 -0800 (Mon, 28 Feb 2011)
New Revision: 11575
   trunk/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
   trunk/openlayers/lib/OpenLayers/Layer/ArcIMS.js
   trunk/openlayers/lib/OpenLayers/Layer/Grid.js
   trunk/openlayers/lib/OpenLayers/Layer/KaMap.js
   trunk/openlayers/lib/OpenLayers/Layer/MapGuide.js
   trunk/openlayers/lib/OpenLayers/Layer/MapServer.js
   trunk/openlayers/lib/OpenLayers/Layer/TMS.js
   trunk/openlayers/lib/OpenLayers/Layer/TileCache.js
   trunk/openlayers/lib/OpenLayers/Layer/WMS.js
   trunk/openlayers/lib/OpenLayers/Layer/WMTS.js
   trunk/openlayers/lib/OpenLayers/Layer/WorldWind.js
   trunk/openlayers/lib/OpenLayers/Layer/XYZ.js
   trunk/openlayers/lib/OpenLayers/Layer/Zoomify.js
move addTile code to the base class (OpenLayers.Layer.Grid). r=crschmidt (closes #2904)
Modified: trunk/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
--- trunk/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -232,22 +232,5 @@
                                                              newArguments);
-     * Method: addTile
-     * addTile creates a tile, initializes it, and adds it to the layer div.
-     * Parameters:
-     * bounds - {<OpenLayers.Bounds>}
-     * position - {<OpenLayers.Pixel>}
-     * Returns:
-     * {<OpenLayers.Tile.Image>} The added OpenLayers.Tile.Image
-    addTile:function(bounds,position) {
-        return new OpenLayers.Tile.Image(this, position, bounds,
-                                         null, this.tileSize);
     CLASS_NAME: "OpenLayers.Layer.ArcGIS93Rest"
Modified: trunk/openlayers/lib/OpenLayers/Layer/ArcIMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/ArcIMS.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/ArcIMS.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -445,22 +445,5 @@
         return obj;
-     * Method: addTile
-     * Parameters:
-     * Returns:
-     * {<OpenLayers.Tile.Image>} The added image tile.
-            this, position, bounds, null, this.tileSize
     CLASS_NAME: "OpenLayers.Layer.ArcIMS"
Modified: trunk/openlayers/lib/OpenLayers/Layer/Grid.js
--- trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -629,9 +629,7 @@
      * APIMethod: addTile
-     * Gives subclasses of Grid the opportunity to create an
-     * OpenLayer.Tile of their choosing. The implementer should initialize
-     * the new tile and take whatever steps necessary to display it.
+     * Create a tile, initialize it, and add it to the layer div.
      * Parameters
@@ -641,7 +639,8 @@
      * {<OpenLayers.Tile>} The added OpenLayers.Tile
     addTile:function(bounds, position) {
-        // Should be implemented by subclasses
+        return new OpenLayers.Tile.Image(this, position, bounds, null,
+                                         this.tileSize, this.tileOptions);
Modified: trunk/openlayers/lib/OpenLayers/Layer/KaMap.js
--- trunk/openlayers/lib/OpenLayers/Layer/KaMap.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/KaMap.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -94,22 +94,6 @@
-     * Method: addTile
-     * Parameters:
-     * Returns:
-        var url = this.getURL(bounds);
-                                             url, this.tileSize);
      * Method: calculateGridLayout
      * ka-Map uses the center point of the map as an origin for
Modified: trunk/openlayers/lib/OpenLayers/Layer/MapGuide.js
--- trunk/openlayers/lib/OpenLayers/Layer/MapGuide.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/MapGuide.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -234,22 +234,6 @@
-     * Method: addTile
-     * Creates a tile, initializes it, and adds it to the layer div.
-     * Parameters:
-     * Returns:
      * Method: getURL
      * Return a query string for this layer
Modified: trunk/openlayers/lib/OpenLayers/Layer/MapServer.js
--- trunk/openlayers/lib/OpenLayers/Layer/MapServer.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/MapServer.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -76,22 +76,6 @@
         return obj;
-     * Method: addTile
-     * Parameters:
-     * Returns:
      * Method: getURL
Modified: trunk/openlayers/lib/OpenLayers/Layer/TMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/TMS.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/TMS.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -131,22 +131,6 @@
         return url + path;
-     * Method: addTile
-     * Parameters:
-     * Returns:
      * APIMethod: setMap
      * When the layer is added to a map, then we can fetch our origin
Modified: trunk/openlayers/lib/OpenLayers/Layer/TileCache.js
--- trunk/openlayers/lib/OpenLayers/Layer/TileCache.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/TileCache.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -144,23 +144,6 @@
         url = (url.charAt(url.length - 1) == '/') ? url : url + '/';
         return url + path;
-     * Method: addTile
-     * Create a tile, initialize it, and add it to the layer div.
-     * Parameters:
-     * Returns:
-     * {<OpenLayers.Tile.Image>} The added <OpenLayers.Tile.Image>
-    addTile:function(bounds, position) {
     CLASS_NAME: "OpenLayers.Layer.TileCache"
Modified: trunk/openlayers/lib/OpenLayers/Layer/WMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/WMS.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/WMS.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -203,22 +203,6 @@
-     * Method: addTile
-     * Parameters:
-     * Returns:
-                                         null, this.tileSize, this.tileOptions);
      * APIMethod: mergeNewParams
      * Catch changeParams and uppercase the new params to be merged in
      *     before calling changeParams on the super class.
Modified: trunk/openlayers/lib/OpenLayers/Layer/WMTS.js
--- trunk/openlayers/lib/OpenLayers/Layer/WMTS.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/WMTS.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -456,21 +456,5 @@
-     * Method: addTile
-     * Parameters:
-     * Returns:
-    addTile: function(bounds,position) {
     CLASS_NAME: "OpenLayers.Layer.WMTS"
Modified: trunk/openlayers/lib/OpenLayers/Layer/WorldWind.js
--- trunk/openlayers/lib/OpenLayers/Layer/WorldWind.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/WorldWind.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -59,20 +59,6 @@
             this.params, this.DEFAULT_PARAMS
-     * Method: addTile
-     * Parameters:
-     * Returns:
      * Method: getZoom
Modified: trunk/openlayers/lib/OpenLayers/Layer/XYZ.js
--- trunk/openlayers/lib/OpenLayers/Layer/XYZ.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/XYZ.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -151,22 +151,6 @@
         return {'x': x, 'y': y, 'z': z};
-     * Method: addTile
-     * Parameters:
-     * Returns:
     /* APIMethod: setMap
      *    (if we don't have one.)
Modified: trunk/openlayers/lib/OpenLayers/Layer/Zoomify.js
--- trunk/openlayers/lib/OpenLayers/Layer/Zoomify.js	2011-02-28 08:10:10 UTC (rev 11574)
+++ trunk/openlayers/lib/OpenLayers/Layer/Zoomify.js	2011-02-28 08:12:05 UTC (rev 11575)
@@ -239,22 +239,6 @@
-     * Method: addTile
-     * Parameters:
-     * Returns:
      * APIMethod: setMap
More information about the Commits mailing list
