[OpenLayers-Commits] r10979 - sandbox/tschaub/uncircular/tools
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sat Jan 1 15:28:19 EST 2011
Author: tschaub
Date: 2011-01-01 12:28:19 -0800 (Sat, 01 Jan 2011)
New Revision: 10979
   sandbox/tschaub/uncircular/tools/toposort.py
Simpler toposort.
Modified: sandbox/tschaub/uncircular/tools/toposort.py
--- sandbox/tschaub/uncircular/tools/toposort.py	2011-01-01 19:07:43 UTC (rev 10978)
+++ sandbox/tschaub/uncircular/tools/toposort.py	2011-01-01 20:28:19 UTC (rev 10979)
@@ -1,260 +1,35 @@
-# According to <http://www.vrplumber.com/programming/> this file
-# is licensed under a BSD-style license. We only use the section
-# originally by Tim Peters.
-# TODO: The use of this code needs to be okayed by someone.
+toposort.py
+Sorts dictionary keys based on lists of dependencies.
-class RecursionError( OverflowError, ValueError ):
-    '''Unable to calculate result because of recursive structure'''
+class MissingDependency(Exception):
+    """Exception raised when a listed dependency is not in the dictionary."""
-def sort(nodes, routes, noRecursion=1):
-    '''Passed a list of node IDs and a list of source,dest ID routes
-    attempt to create a list of stages where each sub list
-    is one stage in a process.
-    children, parents = _buildChildrenLists(routes)
-    # first stage is those nodes
-    # having no incoming routes...
-    stage = []
-    stages = [stage]
-    taken = []
-    for node in nodes:
-        if (not parents.get(node)):
-            stage.append (node)
-    if nodes and not stage:
-        # there is no element which does not depend on
-        # some other element!!!
-        stage.append( nodes[0])
-    taken.extend( stage )
-    nodes = filter ( lambda x, l=stage: x not in l, nodes )
-    while nodes:
-        previousStageChildren = []
-        nodelen = len(nodes)
-        # second stage are those nodes
-        # which are direct children of the first stage
-        for node in stage:
-            for child in children.get (node, []):
-                if child not in previousStageChildren and child not in taken:
-                    previousStageChildren.append(child)
-                elif child in taken and noRecursion:
-                    raise RecursionError( (child, node) )
-        # unless they are children of other direct children...
-        # TODO, actually do that...
-        stage = previousStageChildren
-        removes = []
-        for current in stage:
-            currentParents = parents.get( current, [] )
-            for parent in currentParents:
-                if parent in stage and parent != current:
-                    # might wind up removing current...
-                    if not current in parents.get(parent, []):
-                        # is not mutually dependent...
-                        removes.append( current )
-        for remove in removes:
-            while remove in stage:
-                stage.remove( remove )
-        stages.append( stage)
-        if nodelen == len(nodes):
-            if noRecursion:
-                raise RecursionError( nodes )
-            else:
-                stages.append( nodes[:] )
-                nodes = []
-    return stages
-def _buildChildrenLists (routes):
-    childrenTable = {}
-    parentTable = {}
-    for sourceID,destinationID in routes:
-        currentChildren = childrenTable.get( sourceID, [])
-        currentParents = parentTable.get( destinationID, [])
-        if not destinationID in currentChildren:
-            currentChildren.append ( destinationID)
-        if not sourceID in currentParents:
-            currentParents.append ( sourceID)
-        childrenTable[sourceID] = currentChildren
-        parentTable[destinationID] = currentParents
-    return childrenTable, parentTable
-def toposort (nodes, routes, noRecursion=1):
-    '''Topological sort from Tim Peters, fairly efficient
-    in comparison (it seems).'''
-    #first calculate the recursion depth
+class Sorter(object):
+    def __init__(self, dependencies):
+        self.dependencies = dependencies
+        self.visited = set()
+        self.sorted = ()
-    dependencies = {}
-    inversedependencies = {}
-    if not nodes:
-        return []
-    if not routes:
-        return [nodes]
-        dependencies[ node ] = (0, node)
-        inversedependencies[ node ] = []
+    def sort(self):
+        for key in self.dependencies:
+            self._visit(key)
+        return self.sorted
-    for depended, depends in routes:
-        # is it a null rule
-        try:
-            newdependencylevel, object = dependencies.get ( depends, (0, depends))
-        except TypeError:
-            print depends
-            raise
-        dependencies[ depends ] = (newdependencylevel + 1,  depends)
-        # "dependency (existence) of depended-on"
-        newdependencylevel,object = dependencies.get ( depended, (0, depended) )
-        dependencies[ depended ] = (newdependencylevel, depended)
-        # Inverse dependency set up
-        dependencieslist = inversedependencies.get ( depended, [])
-        dependencieslist.append (depends)
-        inversedependencies[depended] = dependencieslist
-    ### Now we do the actual sorting
-    # The first task is to create the sortable
-    # list of dependency-levels
-    sortinglist = dependencies.values()
-    sortinglist.sort ()
-    output = []
-    while sortinglist:
-        deletelist = []
-        generation = []
-        output.append( generation)
-        while sortinglist and sortinglist[0][0] == 0:
-            number, object = sortinglist[0]
-            generation.append ( object )
-            deletelist.append( object )
-            for inverse in inversedependencies.get(object, () ):
-                try:
-                    oldcount, inverse = dependencies [ inverse]
-                    if oldcount > 0:
-                        # will be dealt with on later pass
-                        dependencies [ inverse] = (oldcount-1, inverse)
-                    else:
-                        # will be dealt with on this pass,
-                        # so needs not to be in the sorting list next time
-                        deletelist.append( inverse )
-                    # just in case a loop comes through
-                    inversedependencies[object] = []
-                except KeyError:
-                    # dealing with a recursion-breaking run...
-                    pass
-            del sortinglist [0]
-        # if no elements could be deleted, then
-        # there is something which depends upon itself
-        if not deletelist:
-            if noRecursion:
-                raise RecursionError( sortinglist )
-            else:
-                # hack so that something gets deleted...
-##                import pdb
-##                pdb.set_trace()
-                dependencies[sortinglist[0][1]] = (0,sortinglist[0][1])
-        # delete the items that were dealt with
-        for item in deletelist:
-            try:
-                del dependencies [ item ]
-            except KeyError:
-                pass
-        # need to recreate the sortinglist
-        if not generation:
-            output.remove( generation )
-    return output
+    def _visit(self, key):
+        if key not in self.visited:
+            self.visited.add(key)
+            if not self.dependencies.has_key(key):
+                raise MissingDependency(key)
+            for depends in self.dependencies[key]:
+                self._visit(depends)
+            self.sorted += (key,)
-if __name__ == "__main__":
-    nodes = ['a', 'b', 'c', 'd', 'e', 'f']
-    route = [('a', 'b'), ('b', 'c'), ('b', 'd'), ('e','f')]
-    for x in  toposort( nodes, route):
-        for a in x:
-            print a
-    raise SystemExit
-    import pprint, traceback
-    nodes= [ 0,1,2,3,4,5 ]
-    testingValues = [
-        [ (0,1),(1,2),(2,3),(3,4),(4,5)],
-        [ (0,1),(0,2),(1,2),(3,4),(4,5)],
-        (0,1),
-        (0,2),
-        (0,2),
-                    (2,4),
-                    (2,5),
-                (3,2),
-        (0,3)],
-        (0,1), # 3-element cycle test, no orphan nodes
-        (1,2),
-        (2,0),
-                    (2,4),
-                    (2,5),
-                (3,2),
-        (0,3)],
-        (0,1),
-        (1,1),
-        (1,1),
-                (1,4),
-                (1,5),
-                (1,2),
-        (3,1),
-        (2,1),
-        (2,0)],
-            (0,1),
-            (1,0),
-            (0,2),
-            (0,3),
-            (0,1),
-            (1,0),
-            (0,2),
-            (3,1),
-    print 'sort, no recursion allowed'
-    for index in range(len(testingValues)):
-##        print '    %s -- %s'%( index, testingValues[index])
-        try:
-            print '        ', sort( nodes, testingValues[index] )
-        except:
-            print 'exception raised'
-    print 'toposort, no recursion allowed'
-        try:
-            print '        ', toposort( nodes, testingValues[index] )
-        except:
-    print 'sort, recursion allowed'
-        try:
-            print '        ', sort( nodes, testingValues[index],0 )
-        except:
-    print 'toposort, recursion allowed'
-        try:
-            print '        ', toposort( nodes, testingValues[index],0 )
-        except:
+def toposort(dependencies):
+    """Returns a tuple of the dependencies dictionary keys sorted by entries
+    in the dependency lists.  Given circular dependencies, sort will impose
+    an order.  Raises MissingDependency if a key is not found.
+    s = Sorter(dependencies)
+    return s.sort()
More information about the Commits mailing list
