[OpenLayers-Commits] r11025 - in sandbox/tschaub/xdomain/tests: . Protocol
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Jan 10 11:28:58 EST 2011
Author: pgiraud
Date: 2011-01-10 08:28:57 -0800 (Mon, 10 Jan 2011)
New Revision: 11025
Added:
   sandbox/tschaub/xdomain/tests/Protocol/FilterSerializer.html
   sandbox/tschaub/xdomain/tests/Protocol/HTTP.html
   sandbox/tschaub/xdomain/tests/list-tests.html
FilterSerializer deserves its own unit tests, moving some tests from HTTP to FilterSerializer
Added: sandbox/tschaub/xdomain/tests/Protocol/FilterSerializer.html
--- sandbox/tschaub/xdomain/tests/Protocol/FilterSerializer.html	                        (rev 0)
+++ sandbox/tschaub/xdomain/tests/Protocol/FilterSerializer.html	2011-01-10 16:28:57 UTC (rev 11025)
@@ -0,0 +1,296 @@
+<html>
+<head>
+  <script src="../../lib/OpenLayers.js"></script>
+  <script type="text/javascript">
+    function test_filterToParams(t) {
+        t.plan(30);
+        // setup
+        var protocol, filter, params;
+        protocol = OpenLayers.Protocol.FilterSerializer;
+        // 1 test
+        var filter = new OpenLayers.Filter.Spatial({
+            type: OpenLayers.Filter.Spatial.BBOX,
+            value: new OpenLayers.Bounds(0, 1, 2, 3)
+        params = protocol.filterToParams(filter);
+        t.eq(params.bbox, [0, 1, 2, 3],
+             "filterToParams sets correct bbox param if passed a BBOX filter");
+        // 3 tests
+        var lon = 100, lat = 200, tolerance = 10;
+        filter = new OpenLayers.Filter.Spatial({
+            type: OpenLayers.Filter.Spatial.DWITHIN,
+            value: new OpenLayers.Geometry.Point(lon, lat),
+            distance: tolerance
+        t.eq(params.lon, lon,
+             "filterToParams sets correct lon param if passed a DWITHIN filter");
+        t.eq(params.lat, lat,
+             "filterToParams sets correct lat param if passed a DWITHIN filter");
+        t.eq(params.tolerance, tolerance,
+             "filterToParams sets correct tolerance param if passed a DWITHIN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Spatial.WITHIN,
+             "filterToParams sets correct lon param if passed a WITHIN filter");
+             "filterToParams sets correct lat param if passed a WITHIN filter");
+        // Some bbox filters used in the next tests.
+        var bboxFilter1 = new OpenLayers.Filter.Spatial({
+            value:  new OpenLayers.Bounds(0, 0, 10, 10)
+        var bboxFilter2 = new OpenLayers.Filter.Spatial({
+            value:  new OpenLayers.Bounds(0, 0, 20, 20)
+        // 1 test
+        filter = new OpenLayers.Filter.Logical({
+            type: OpenLayers.Filter.Logical.AND,
+            filters: []
+        t.eq(params, {},
+             "filterToParams returns empty object if given empty AND Logical filter");
+        // 1 test
+            type: OpenLayers.Filter.Logical.OR,
+            filters: [
+                bboxFilter1
+        t.eq(params, {},
+             "filterToParams does not support OR Logical filter");
+        // 1 test
+            filters: [
+                bboxFilter1
+        t.eq(params.bbox, [0, 0, 10, 10],
+             "filterToParams sets correct bbox param if passed " +
+             "a Logical filter containing a BBOX");
+        // 1 test
+            filters: [
+                bboxFilter1, bboxFilter2
+        t.eq(params.bbox, [0, 0, 20, 20],
+             "multiple BBOX filter in a Logical filter");
+        // 2 tests
+        filter = new OpenLayers.Filter.Comparison({
+            type: OpenLayers.Filter.Comparison.EQUAL_TO,
+            property: "foo",
+            value: "bar"
+        t.eq(params.queryable[0], "foo",
+             "filterToParams sets correct queryable param if passed an EQUAL_TO filter");
+        t.eq(params["foo__eq"], "bar",
+             "filterToParams sets correct param key and value if passed an EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed an NOT_EQUAL_TO filter");
+        t.eq(params["foo__ne"], "bar",
+             "filterToParams sets correct param key and value if passed an NOT_EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.LESS_THAN,
+            property: "foo",
+            value: "bar"
+        var params = protocol.filterToParams(filter);
+             "filterToParams sets correct queryable param if passed an LESS_THAN filter");
+        t.eq(params["foo__lt"], "bar",
+             "filterToParams sets correct param key and value if passed an LESS_THAN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed an LESS_THAN_OR_EQUAL_TO filter");
+        t.eq(params["foo__lte"], "bar",
+             "filterToParams sets correct param key and value if passed an LESS_THAN_OR_EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.GREATER_THAN,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed an GREATER_THAN filter");
+        t.eq(params["foo__gt"], "bar",
+             "filterToParams sets correct param key and value if passed an GREATER_THAN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed an GREATER_THAN_OR_EQUAL_TO filter");
+        t.eq(params["foo__gte"], "bar",
+             "filterToParams sets correct param key and value if passed an GREATER_THAN_OR_EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.LIKE,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed a LIKE filter");
+        t.eq(params["foo__ilike"], "bar",
+             "filterToParams sets correct param key and value if passed an LIKE filter");
+        // 4 tests
+            filters: [
+                new OpenLayers.Filter.Comparison({
+                    property: "foo",
+                    value: "bar"
+                    property: "foo2",
+                    value: "baz"
+             "filterToParams sets correct queryable param if passed an EQUAL_TO filter within a AND filter");
+             "filterToParams sets correct param key and value if passed an EQUAL_TO filter within a AND filter");
+        t.eq(params.queryable[1], "foo2",
+             "filterToParams sets correct queryable param if passed a LESS_THAN filter within a AND filter");
+        t.eq(params["foo2__lt"], "baz",
+             "filterToParams sets correct param key and value if passed a LESS_THAN filter within a AND filter");
+        // 2 tests
+        protocol = new OpenLayers.Protocol.HTTP({wildcarded: true});
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed a LIKE filter (wildcarded true)");
+        t.eq(params["foo__ilike"], "%bar%",
+             "filterToParams sets correct param key and value if passed an LIKE filter (wildcarded true)");
+    function test_regex2value(t) {
+        t.plan(16);
+        // setup
+        var protocol = new OpenLayers.Protocol.HTTP();
+        var value;
+        // test
+        value = protocol.regex2value("foo");
+        t.eq(value, "foo", 'regex2value converts "foo" to "foo"');
+        value = protocol.regex2value("foo%");
+        t.eq(value, "foo\\%", 'regex2value converts "foo%" to "foo\\%"');
+        value = protocol.regex2value("foo.*");
+        t.eq(value, "foo%", 'regex2value converts "foo.*" to "foo%"');
+        value = protocol.regex2value("f.*oo.*");
+        t.eq(value, "f%oo%", 'regex2value converts "f.*oo.*" to "f%oo%"');
+        value = protocol.regex2value("foo.");
+        t.eq(value, "foo_", 'regex2value converts "foo." to "foo_"');
+        value = protocol.regex2value("f.oo.");
+        t.eq(value, "f_oo_", 'regex2value converts "f.oo." to "f_oo_"');
+        value = protocol.regex2value("f.oo.*");
+        t.eq(value, "f_oo%", 'regex2value converts "f.oo.*" to "f_oo%"');
+        value = protocol.regex2value("foo\\\\");
+        t.eq(value, "foo\\\\", 'regex2value converts "foo\\\\" to "foo\\\\"');
+        value = protocol.regex2value("foo\\.");
+        t.eq(value, "foo.", 'regex2value converts "foo\\." to "foo."');
+        value = protocol.regex2value("foo\\\\.");
+        t.eq(value, "foo\\\\_", 'regex2value converts "foo\\\\." to "foo\\\\_"');
+        value = protocol.regex2value("foo\\*");
+        t.eq(value, "foo*", 'regex2value converts "foo\\*" to "foo*"');
+        value = protocol.regex2value("foo\\\\*");
+        t.eq(value, "foo\\\\*", 'regex2value converts "foo\\\\*" to "foo\\\\*"');
+        value = protocol.regex2value("foo\\\\.*");
+        t.eq(value, "foo\\\\%", 'regex2value converts "foo\\\\.*" to "foo\\\\%"');
+        value = protocol.regex2value("fo\\.o.*");
+        t.eq(value, "fo.o%", 'regex2value converts from "fo\\.o.*" to "fo.o%"');
+        value = protocol.regex2value("fo.*o\\.");
+        t.eq(value, "fo%o.", 'regex2value converts from "fo.*o\\." to "to%o."');
+        value = protocol.regex2value("\\*\\..*.\\\\.*\\\\.%");
+        t.eq(value, "*.%_\\\\%\\\\_\\%",
+             'regex2value converts from "\\*\\..*.\\\\.*\\\\.%" ' +
+             'to "*.%_\\\\%\\\\_\\%"');
+  </script>
+</head>
+<body>
+</body>
+</html>
Modified: sandbox/tschaub/xdomain/tests/Protocol/HTTP.html
--- sandbox/tschaub/xdomain/tests/Protocol/HTTP.html	2011-01-10 16:09:51 UTC (rev 11024)
+++ sandbox/tschaub/xdomain/tests/Protocol/HTTP.html	2011-01-10 16:28:57 UTC (rev 11025)
@@ -273,291 +273,6 @@
         t.eq(ret, null, 'parseFeatures returns expected value');
-    function test_filterToParams(t) {
-        t.plan(30);
-        // setup
-        var protocol, filter, params;
-        protocol = new OpenLayers.Protocol.HTTP();
-        // 1 test
-        var filter = new OpenLayers.Filter.Spatial({
-            type: OpenLayers.Filter.Spatial.BBOX,
-            value: new OpenLayers.Bounds(0, 1, 2, 3)
-        params = protocol.filterToParams(filter);
-        t.eq(params.bbox, [0, 1, 2, 3],
-             "filterToParams sets correct bbox param if passed a BBOX filter");
-        // 3 tests
-        var lon = 100, lat = 200, tolerance = 10;
-        filter = new OpenLayers.Filter.Spatial({
-            type: OpenLayers.Filter.Spatial.DWITHIN,
-            value: new OpenLayers.Geometry.Point(lon, lat),
-            distance: tolerance
-        t.eq(params.lon, lon,
-             "filterToParams sets correct lon param if passed a DWITHIN filter");
-        t.eq(params.lat, lat,
-             "filterToParams sets correct lat param if passed a DWITHIN filter");
-        t.eq(params.tolerance, tolerance,
-             "filterToParams sets correct tolerance param if passed a DWITHIN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Spatial.WITHIN,
-             "filterToParams sets correct lon param if passed a WITHIN filter");
-             "filterToParams sets correct lat param if passed a WITHIN filter");
-        // Some bbox filters used in the next tests.
-        var bboxFilter1 = new OpenLayers.Filter.Spatial({
-            value:  new OpenLayers.Bounds(0, 0, 10, 10)
-        var bboxFilter2 = new OpenLayers.Filter.Spatial({
-            value:  new OpenLayers.Bounds(0, 0, 20, 20)
-        // 1 test
-        filter = new OpenLayers.Filter.Logical({
-            type: OpenLayers.Filter.Logical.AND,
-            filters: []
-        t.eq(params, {},
-             "filterToParams returns empty object if given empty AND Logical filter");
-        // 1 test
-            type: OpenLayers.Filter.Logical.OR,
-            filters: [
-                bboxFilter1
-        t.eq(params, {},
-             "filterToParams does not support OR Logical filter");
-        // 1 test
-            filters: [
-                bboxFilter1
-        t.eq(params.bbox, [0, 0, 10, 10],
-             "filterToParams sets correct bbox param if passed " +
-             "a Logical filter containing a BBOX");
-        // 1 test
-            filters: [
-                bboxFilter1, bboxFilter2
-        t.eq(params.bbox, [0, 0, 20, 20],
-             "multiple BBOX filter in a Logical filter");
-        // 2 tests
-        filter = new OpenLayers.Filter.Comparison({
-            type: OpenLayers.Filter.Comparison.EQUAL_TO,
-            property: "foo",
-            value: "bar"
-        t.eq(params.queryable[0], "foo",
-             "filterToParams sets correct queryable param if passed an EQUAL_TO filter");
-        t.eq(params["foo__eq"], "bar",
-             "filterToParams sets correct param key and value if passed an EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an NOT_EQUAL_TO filter");
-        t.eq(params["foo__ne"], "bar",
-             "filterToParams sets correct param key and value if passed an NOT_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LESS_THAN,
-            property: "foo",
-            value: "bar"
-        var params = protocol.filterToParams(filter);
-             "filterToParams sets correct queryable param if passed an LESS_THAN filter");
-        t.eq(params["foo__lt"], "bar",
-             "filterToParams sets correct param key and value if passed an LESS_THAN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an LESS_THAN_OR_EQUAL_TO filter");
-        t.eq(params["foo__lte"], "bar",
-             "filterToParams sets correct param key and value if passed an LESS_THAN_OR_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.GREATER_THAN,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an GREATER_THAN filter");
-        t.eq(params["foo__gt"], "bar",
-             "filterToParams sets correct param key and value if passed an GREATER_THAN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an GREATER_THAN_OR_EQUAL_TO filter");
-        t.eq(params["foo__gte"], "bar",
-             "filterToParams sets correct param key and value if passed an GREATER_THAN_OR_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LIKE,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed a LIKE filter");
-        t.eq(params["foo__ilike"], "bar",
-             "filterToParams sets correct param key and value if passed an LIKE filter");
-        // 4 tests
-            filters: [
-                new OpenLayers.Filter.Comparison({
-                    property: "foo",
-                    value: "bar"
-                    property: "foo2",
-                    value: "baz"
-             "filterToParams sets correct queryable param if passed an EQUAL_TO filter within a AND filter");
-             "filterToParams sets correct param key and value if passed an EQUAL_TO filter within a AND filter");
-        t.eq(params.queryable[1], "foo2",
-             "filterToParams sets correct queryable param if passed a LESS_THAN filter within a AND filter");
-        t.eq(params["foo2__lt"], "baz",
-             "filterToParams sets correct param key and value if passed a LESS_THAN filter within a AND filter");
-        // 2 tests
-        protocol = new OpenLayers.Protocol.HTTP({wildcarded: true});
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed a LIKE filter (wildcarded true)");
-        t.eq(params["foo__ilike"], "%bar%",
-             "filterToParams sets correct param key and value if passed an LIKE filter (wildcarded true)");
-    function test_regex2value(t) {
-        t.plan(16);
-        // setup
-        var protocol = new OpenLayers.Protocol.HTTP();
-        var value;
-        // test
-        value = protocol.regex2value("foo");
-        t.eq(value, "foo", 'regex2value converts "foo" to "foo"');
-        value = protocol.regex2value("foo%");
-        t.eq(value, "foo\\%", 'regex2value converts "foo%" to "foo\\%"');
-        value = protocol.regex2value("foo.*");
-        t.eq(value, "foo%", 'regex2value converts "foo.*" to "foo%"');
-        value = protocol.regex2value("f.*oo.*");
-        t.eq(value, "f%oo%", 'regex2value converts "f.*oo.*" to "f%oo%"');
-        value = protocol.regex2value("foo.");
-        t.eq(value, "foo_", 'regex2value converts "foo." to "foo_"');
-        value = protocol.regex2value("f.oo.");
-        t.eq(value, "f_oo_", 'regex2value converts "f.oo." to "f_oo_"');
-        value = protocol.regex2value("f.oo.*");
-        t.eq(value, "f_oo%", 'regex2value converts "f.oo.*" to "f_oo%"');
-        value = protocol.regex2value("foo\\\\");
-        t.eq(value, "foo\\\\", 'regex2value converts "foo\\\\" to "foo\\\\"');
-        value = protocol.regex2value("foo\\.");
-        t.eq(value, "foo.", 'regex2value converts "foo\\." to "foo."');
-        value = protocol.regex2value("foo\\\\.");
-        t.eq(value, "foo\\\\_", 'regex2value converts "foo\\\\." to "foo\\\\_"');
-        value = protocol.regex2value("foo\\*");
-        t.eq(value, "foo*", 'regex2value converts "foo\\*" to "foo*"');
-        value = protocol.regex2value("foo\\\\*");
-        t.eq(value, "foo\\\\*", 'regex2value converts "foo\\\\*" to "foo\\\\*"');
-        value = protocol.regex2value("foo\\\\.*");
-        t.eq(value, "foo\\\\%", 'regex2value converts "foo\\\\.*" to "foo\\\\%"');
-        value = protocol.regex2value("fo\\.o.*");
-        t.eq(value, "fo.o%", 'regex2value converts from "fo\\.o.*" to "fo.o%"');
-        value = protocol.regex2value("fo.*o\\.");
-        t.eq(value, "fo%o.", 'regex2value converts from "fo.*o\\." to "to%o."');
-        value = protocol.regex2value("\\*\\..*.\\\\.*\\\\.%");
-        t.eq(value, "*.%_\\\\%\\\\_\\%",
-             'regex2value converts from "\\*\\..*.\\\\.*\\\\.%" ' +
-             'to "*.%_\\\\%\\\\_\\%"');
     function test_create(t) {
         t.plan(10);
         var protocol = new OpenLayers.Protocol.HTTP({
Modified: sandbox/tschaub/xdomain/tests/list-tests.html
--- sandbox/tschaub/xdomain/tests/list-tests.html	2011-01-10 16:09:51 UTC (rev 11024)
+++ sandbox/tschaub/xdomain/tests/list-tests.html	2011-01-10 16:28:57 UTC (rev 11025)
@@ -166,6 +166,7 @@
     <li>Popup/FramedCloud.html</li>
     <li>Projection.html</li>
     <li>Protocol.html</li>
+    <li>Protocol/FilterSerializer.html</li>
     <li>Protocol/HTTP.html</li>
     <li>Protocol/SQL.html</li>
     <li>Protocol/SQL/Gears.html</li>
More information about the Commits mailing list
