[OpenLayers-Commits] r11030 - sandbox/elemoine/draw-feature/lib/OpenLayers/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Jan 13 09:09:04 EST 2011
Author: erilem
Date: 2011-01-13 06:09:03 -0800 (Thu, 13 Jan 2011)
New Revision: 11030
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Polygon.js
draw first point on activate and on finalize
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js	2011-01-12 13:06:30 UTC (rev 11029)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js	2011-01-13 14:09:03 UTC (rev 11030)
@@ -79,8 +79,8 @@
      *     feature.
     createFeature: function(pixel) {
-        if(this.persist) {
-            this.destroyFeature();
+        if(!pixel) {
+            pixel = new OpenLayers.Pixel(-50, -50);
         var lonlat = this.control.map.getLonLatFromPixel(pixel);
         this.point = new OpenLayers.Feature.Vector(
@@ -92,6 +92,9 @@
         this.callback("create", [this.point.geometry, this.getSketch()]);
         this.point.geometry.clearBounds();
         this.layer.addFeatures([this.line, this.point], {silent: true});
+        if(this.persist) {
+            this.destroyFeature();
@@ -233,13 +236,12 @@
      * {Boolean} Allow event propagation
     mousemove: function (evt) {
-        if(this.drawing) {
+        if(this.drawing) {
             if(this.mouseDown && this.freehandMode(evt)) {
                 this.addPoint(evt.xy);
-            } else {
-                this.modifyFeature(evt.xy);
+        this.modifyFeature(evt.xy);
         return true;
@@ -261,9 +263,6 @@
                 this.finalize();
             } else {
                 if(this.lastDown.equals(evt.xy)) {
-                    if(this.lastUp == null) {
-                        this.createFeature(evt.xy);
                     this.drawing = true;
                     this.lastUp = evt.xy;
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js	2011-01-12 13:06:30 UTC (rev 11029)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js	2011-01-13 14:09:03 UTC (rev 11030)
@@ -144,6 +144,7 @@
         }, this.layerOptions);
         this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
         this.map.addLayer(this.layer);
+        this.createFeature();
         return true;
@@ -155,12 +156,18 @@
      * pixel - {<OpenLayers.Pixel>} A pixel location on the map.
+        if(!pixel) {
         var lonlat = this.map.getLonLatFromPixel(pixel);
             new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat)
         this.callback("create", [this.point.geometry, this.point]);
         this.layer.addFeatures([this.point], {silent: true});
@@ -218,6 +225,7 @@
         if(cancel || !this.persist) {
@@ -332,15 +340,8 @@
         if(this.lastDown && this.lastDown.equals(evt.xy)) {
             return true;
-        this.drawing = true;
-        if(this.lastDown == null) {
-        } else {
+        this.drawing = true; // FIXME is this necessary?
         this.lastDown = evt.xy;
         return !this.stopDown;
@@ -357,9 +358,7 @@
         return true;
@@ -375,7 +374,7 @@
     mouseup: function (evt) {
+        if(this.lastDown.equals(evt.xy)) {
             this.finalize();
             return !this.stopUp;
         } else {
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Polygon.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Polygon.js	2011-01-12 13:06:30 UTC (rev 11029)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Polygon.js	2011-01-13 14:09:03 UTC (rev 11030)
@@ -75,6 +75,9 @@
      *     feature.
+        if(!pixel) {
@@ -85,7 +88,7 @@
         // check for hole digitizing
         var polygon;
-        if (this.holeModifier && (this.evt[this.holeModifier])) {
+        if (this.holeModifier && this.evt && this.evt[this.holeModifier]) {
             var geometry = this.point.geometry;
             var features = this.control.layer.features;
             var candidate;
More information about the Commits mailing list
