[OpenLayers-Commits] r11039 - in sandbox/elemoine/draw-feature: . examples lib lib/OpenLayers/BaseTypes lib/OpenLayers/Format/WFST lib/OpenLayers/Layer tests/BaseTypes tests/Format/WFST tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Jan 18 07:16:22 EST 2011
Author: erilem
Date: 2011-01-18 04:16:21 -0800 (Tue, 18 Jan 2011)
New Revision: 11039
Added:
   sandbox/elemoine/draw-feature/examples/tile-origin.html
   sandbox/elemoine/draw-feature/examples/tile-origin.js
Removed:
   sandbox/elemoine/draw-feature/examples/tile-extent.html
   sandbox/elemoine/draw-feature/examples/tile-extent.js
   sandbox/elemoine/draw-feature/examples/bing-tiles.js
   sandbox/elemoine/draw-feature/lib/OpenLayers.js
   sandbox/elemoine/draw-feature/lib/OpenLayers/BaseTypes/Bounds.js
   sandbox/elemoine/draw-feature/lib/OpenLayers/Format/WFST/v1.js
   sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Bing.js
   sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Grid.js
   sandbox/elemoine/draw-feature/tests/BaseTypes/Bounds.html
   sandbox/elemoine/draw-feature/tests/Format/WFST/v1.html
   sandbox/elemoine/draw-feature/tests/Layer/Bing.html
   sandbox/elemoine/draw-feature/tests/Layer/WMS.html
svn merge -r 11026:HEAD http://svn.openlayers.org/trunk/openlayers/.
Property changes on: sandbox/elemoine/draw-feature
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11027-11037
Modified: sandbox/elemoine/draw-feature/examples/bing-tiles.js
--- sandbox/elemoine/draw-feature/examples/bing-tiles.js	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/examples/bing-tiles.js	2011-01-18 12:16:21 UTC (rev 11039)
@@ -6,7 +6,10 @@
 var road = new OpenLayers.Layer.Bing({
     key: apiKey,
-    type: "Road"
+    type: "Road",
+    // custom metadata parameter to request the new map style - only useful
+    // before May 1st, 2011
+    metadataParams: {mapVersion: "v1"}
 var aerial = new OpenLayers.Layer.Bing({
     key: apiKey,
Deleted: sandbox/elemoine/draw-feature/examples/tile-extent.html
--- sandbox/elemoine/draw-feature/examples/tile-extent.html	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/examples/tile-extent.html	2011-01-18 12:16:21 UTC (rev 11039)
@@ -1,36 +0,0 @@
-<!DOCTYPE html>
-<html>
-    <head>
-        <title>OpenLayers Tile Extent Example</title>
-        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
-        <link rel="stylesheet" href="../theme/default/google.css" type="text/css">
-        <link rel="stylesheet" href="style.css" type="text/css">
-    </head>
-    <body>
-        <h1 id="title">Tile Extent</h1>
-        <div id="tags">
-            grid, tileExtent
-        </div>
-        <p id="shortdesc">
-            Demonstrates the use of the tileExtent property to differentiate
-            between the maximum extent and the tile extent for a layer.
-        </p>
-        <div id="map" class="smallmap"></div>
-        <div id="docs">
-            <p>
-                This example uses a layer that requests map tiles from a WMS
-                that only generates image responses for requests that align with
-                a particular tile lattice.  In this case, the layer's
-                <code>maxExtent</code> does not align with that tile lattice.
-                To configure the layer with a tile extent that conforms to the
-                tile extent configured on the server, use the layer's
-                <code>tileExtent</code> property.
-            </p><p>
-                View the <a href="tile-extent.js" target="_blank">tile-extent.js</a>
-                source to see how this is done
-            </p>
-        </div>
-        <script src="../lib/OpenLayers.js"></script>
-        <script src="tile-extent.js"></script>
-    </body>
-</html>
Deleted: sandbox/elemoine/draw-feature/examples/tile-extent.js
--- sandbox/elemoine/draw-feature/examples/tile-extent.js	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/examples/tile-extent.js	2011-01-18 12:16:21 UTC (rev 11039)
@@ -1,16 +0,0 @@
-var map = new OpenLayers.Map({
-    div: "map",
-    maxExtent: new OpenLayers.Bounds(-130, 30, -80, 55),
-    maxResolution: 360 / 256 / Math.pow(2, 4),
-    numZoomLevels: 12,
-    layers: [
-        new OpenLayers.Layer.WMS(
-            "Global Imagery",
-            "http://maps.opengeo.org/geowebcache/service/wms",
-            {layers: "bluemarble"},
-            {tileExtent: new OpenLayers.Bounds(-180, -90, 180, 90)}
-    center: new OpenLayers.LonLat(-110, 45),
-    zoom: 0
Copied: sandbox/elemoine/draw-feature/examples/tile-origin.html (from rev 11037, trunk/openlayers/examples/tile-origin.html)
--- sandbox/elemoine/draw-feature/examples/tile-origin.html	                        (rev 0)
+++ sandbox/elemoine/draw-feature/examples/tile-origin.html	2011-01-18 12:16:21 UTC (rev 11039)
@@ -0,0 +1,36 @@
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>OpenLayers Tile Origin Example</title>
+        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+        <link rel="stylesheet" href="../theme/default/google.css" type="text/css">
+        <link rel="stylesheet" href="style.css" type="text/css">
+    </head>
+    <body>
+        <h1 id="title">Tile Origin</h1>
+        <div id="tags">
+            grid, tileOrigin
+        </div>
+        <p id="shortdesc">
+            Demonstrates the use of the tileExtent property to differentiate
+            between the maximum extent and the tile extent for a layer.
+        </p>
+        <div id="map" class="smallmap"></div>
+        <div id="docs">
+            <p>
+                This example uses a layer that requests map tiles from a WMS
+                that only generates image responses for requests that align with
+                a particular tile lattice.  In this case, the layer's
+                <code>maxExtent</code> does not align with that tile lattice.
+                To configure the layer with a tile extent that conforms to the
+                tile origin configured on the server, use the layer's
+                <code>tileOrigin</code> property.
+            </p><p>
+                View the <a href="tile-origin.js" target="_blank">tile-origin.js</a>
+                source to see how this is done
+            </p>
+        </div>
+        <script src="../lib/OpenLayers.js"></script>
+        <script src="tile-origin.js"></script>
+    </body>
+</html>
Copied: sandbox/elemoine/draw-feature/examples/tile-origin.js (from rev 11037, trunk/openlayers/examples/tile-origin.js)
--- sandbox/elemoine/draw-feature/examples/tile-origin.js	                        (rev 0)
+++ sandbox/elemoine/draw-feature/examples/tile-origin.js	2011-01-18 12:16:21 UTC (rev 11039)
@@ -0,0 +1,16 @@
+var map = new OpenLayers.Map({
+    div: "map",
+    maxExtent: new OpenLayers.Bounds(-130, 30, -80, 55),
+    maxResolution: 360 / 256 / Math.pow(2, 4),
+    numZoomLevels: 12,
+    layers: [
+        new OpenLayers.Layer.WMS(
+            "Global Imagery",
+            "http://maps.opengeo.org/geowebcache/service/wms",
+            {layers: "bluemarble"},
+            {tileOrigin: new OpenLayers.LonLat(-180, -90)}
+    center: new OpenLayers.LonLat(-110, 45),
+    zoom: 0
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/BaseTypes/Bounds.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/BaseTypes/Bounds.js	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/BaseTypes/Bounds.js	2011-01-18 12:16:21 UTC (rev 11039)
@@ -615,14 +615,15 @@
  * Parameters:
  * str - {String}Comma-separated bounds string. (ex. <i>"5,42,10,45"</i>)
+ * reverseAxisOrder - {Boolean} Does the string use reverse axis order?
  * Returns:
  * {<OpenLayers.Bounds>} New bounds object built from the
  *                       passed-in String.
-OpenLayers.Bounds.fromString = function(str) {
+OpenLayers.Bounds.fromString = function(str, reverseAxisOrder) {
     var bounds = str.split(",");
-    return OpenLayers.Bounds.fromArray(bounds);
+    return OpenLayers.Bounds.fromArray(bounds, reverseAxisOrder);
@@ -632,12 +633,18 @@
  * Parameters:
  * bbox - {Array(Float)} Array of bounds values (ex. <i>[5,42,10,45]</i>)
+ * reverseAxisOrder - {Boolean} Does the array use reverse axis order?
  * Returns:
  * {<OpenLayers.Bounds>} New bounds object built from the passed-in Array.
-OpenLayers.Bounds.fromArray = function(bbox) {
-    return new OpenLayers.Bounds(parseFloat(bbox[0]),
+OpenLayers.Bounds.fromArray = function(bbox, reverseAxisOrder) {
+    return reverseAxisOrder === true ?
+           new OpenLayers.Bounds(parseFloat(bbox[1]),
+                                 parseFloat(bbox[0]),
+                                 parseFloat(bbox[3]),
+                                 parseFloat(bbox[2])) :
+           new OpenLayers.Bounds(parseFloat(bbox[0]),
                                  parseFloat(bbox[2]),
                                  parseFloat(bbox[3]));
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Format/WFST/v1.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Format/WFST/v1.js	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Format/WFST/v1.js	2011-01-18 12:16:21 UTC (rev 11039)
@@ -253,8 +253,9 @@
                 // add in geometry
                 if (this.geometryName !== null) {
+                    this.srsName = this.getSrsName(feature);
                     this.writeNode(
-                        "Property", {name: this.geometryName, value: feature}, node
+                        "Property", {name: this.geometryName, value: feature.geometry}, node
@@ -287,10 +288,9 @@
             "Value": function(obj) {
                 var node;
-                if(obj instanceof OpenLayers.Feature.Vector) {
+                if(obj instanceof OpenLayers.Geometry) {
                     node = this.createElementNSPlus("wfs:Value");
-                    this.srsName = this.getSrsName(obj);
-                    var geom = this.writeNode("feature:_geometry", obj.geometry).firstChild;
+                    var geom = this.writeNode("feature:_geometry", obj).firstChild;
                     node.appendChild(geom);
                 } else {
                     node = this.createElementNSPlus("wfs:Value", {value: obj});
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Bing.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Bing.js	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Bing.js	2011-01-18 12:16:21 UTC (rev 11039)
@@ -42,6 +42,13 @@
      *     used.  Default is "Road".
     type: "Road",
+     * APIProperty: metadataParams
+     * {Object} Optional url parameters for the Get Imagery Metadata request
+     * as described here: http://msdn.microsoft.com/en-us/library/ff701716.aspx
+    metadataParams: null,
      * Constant: EVENT_TYPES
@@ -106,25 +113,26 @@
         var newArgs = [name, null, options];
         OpenLayers.Layer.XYZ.prototype.initialize.apply(this, newArgs);
-        this.loadMetadata(this.type);
+        this.loadMetadata();
      * Method: loadMetadata
-     * Parameters:
-     * imageryType - {String}
-    loadMetadata: function(imageryType) {
+    loadMetadata: function() {
         this._callbackId = "_callback_" + this.id.replace(/\./g, "_");
         // link the processMetadata method to the global scope and bind it
         // to this instance
         window[this._callbackId] = OpenLayers.Function.bind(
             OpenLayers.Layer.Bing.processMetadata, this
+        var params = OpenLayers.Util.applyDefaults({
+            key: this.key,
+            jsonp: this._callbackId,
+            include: "ImageryProviders"
+        }, this.metadataParams);
         var url = "http://dev.virtualearth.net/REST/v1/Imagery/Metadata/" +
-            imageryType + "?key=" + this.key + "&jsonp=" + this._callbackId +
-            "&include=ImageryProviders";
+            this.type + "?" + OpenLayers.Util.getParameterString(params);
         var script = document.createElement("script");
         script.type = "text/javascript";
         script.src = url;
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Grid.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Grid.js	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Grid.js	2011-01-18 12:16:21 UTC (rev 11039)
@@ -24,12 +24,26 @@
      * {<OpenLayers.Size>}
     tileSize: null,
+     * Property: tileOriginCorner
+     * {String} If the <tileOrigin> property is not provided, the tile origin
+     *     will be derived from the layer's <maxExtent>.  The corner of the
+     *     <maxExtent> used is determined by this property.  Acceptable values
+     *     are "tl" (top left), "tr" (top right), "bl" (bottom left), and "br"
+     *     (bottom right).  Default is "bl".
+    tileOriginCorner: "bl",
-     * APIProperty: tileExtent
-     * {<OpenLayers.Bounds>}
+     * APIProperty: tileOrigin
+     * {<OpenLayers.LonLat>} Optional origin for aligning the grid of tiles.
+     *     If provided, requests for tiles at all resolutions will be aligned
+     *     with this location (no tiles shall overlap this location).  If
+     *     not provided, the grid of tiles will be aligned with the layer's
+     *     <maxExtent>.  Default is ``null``.
-    tileExtent: null,
+    tileOrigin: null,
     /** APIProperty: tileOptions
      *  {Object} optional configuration options for <OpenLayers.Tile> instances
@@ -315,32 +329,32 @@
      * Method: calculateGridLayout
-     * Generate parameters for the grid layout. This
+     * Generate parameters for the grid layout.
      * Parameters:
      * bounds - {<OpenLayers.Bound>}
-     * extent - {<OpenLayers.Bounds>}
+     * origin - {<OpenLayers.LonLat>}
      * resolution - {Number}
      * Returns:
      * Object containing properties tilelon, tilelat, tileoffsetlat,
      * tileoffsetlat, tileoffsetx, tileoffsety
-    calculateGridLayout: function(bounds, extent, resolution) {
+    calculateGridLayout: function(bounds, origin, resolution) {
         var tilelon = resolution * this.tileSize.w;
         var tilelat = resolution * this.tileSize.h;
-        var offsetlon = bounds.left - extent.left;
+        var offsetlon = bounds.left - origin.lon;
         var tilecol = Math.floor(offsetlon/tilelon) - this.buffer;
         var tilecolremain = offsetlon/tilelon - tilecol;
         var tileoffsetx = -tilecolremain * this.tileSize.w;
-        var tileoffsetlon = extent.left + tilecol * tilelon;
+        var tileoffsetlon = origin.lon + tilecol * tilelon;
-        var offsetlat = bounds.top - (extent.bottom + tilelat);
+        var offsetlat = bounds.top - (origin.lat + tilelat);
         var tilerow = Math.ceil(offsetlat/tilelat) + this.buffer;
         var tilerowremain = tilerow - offsetlat/tilelat;
         var tileoffsety = -tilerowremain * this.tileSize.h;
-        var tileoffsetlat = extent.bottom + tilerow * tilelat;
+        var tileoffsetlat = origin.lat + tilerow * tilelat;
         return {
           tilelon: tilelon, tilelat: tilelat,
@@ -349,6 +363,32 @@
+     * Method: getTileOrigin
+     * Determine the origin for aligning the grid of tiles.  If a <tileOrigin>
+     *     property is supplied, that will be returned.  Otherwise, the origin
+     *     will be derived from the layer's <maxExtent> property.  In this case,
+     *     the tile origin will be the corner of the <maxExtent> given by the
+     *     <tileOriginCorner> property.
+     * Returns:
+     * {<OpenLayers.LonLat>} The tile origin.
+    getTileOrigin: function() {
+        var origin = this.tileOrigin;
+        if (!origin) {
+            var extent = this.getMaxExtent();
+            var edges = ({
+                "tl": ["left", "top"],
+                "tr": ["right", "top"],
+                "bl": ["left", "bottom"],
+                "br": ["right", "bottom"]
+            })[this.tileOriginCorner];
+            origin = new OpenLayers.LonLat(extent[edges[0]], extent[edges[1]]);
+        return origin;
      * Method: initGriddedTiles
@@ -367,10 +407,10 @@
         var minCols = Math.ceil(viewSize.w/this.tileSize.w) +
                       Math.max(1, 2 * this.buffer);
-        var extent = this.getMaxExtent();
+        var origin = this.getTileOrigin();
         var resolution = this.map.getResolution();
-        var tileLayout = this.calculateGridLayout(bounds, extent, resolution);
+        var tileLayout = this.calculateGridLayout(bounds, origin, resolution);
         var tileoffsetx = Math.round(tileLayout.tileoffsetx); // heaven help us
         var tileoffsety = Math.round(tileLayout.tileoffsety);
@@ -452,7 +492,7 @@
      * {OpenLayers.Bounds}
     getMaxExtent: function() {
-        return this.tileExtent || this.maxExtent;
+        return this.maxExtent;
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers.js	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers.js	2011-01-18 12:16:21 UTC (rev 11039)
@@ -314,28 +314,15 @@
             "OpenLayers/Lang/en.js"
         ); // etc.
-        var agent = navigator.userAgent;
-        var docWrite = (agent.match("MSIE") || agent.match("Safari"));
-        if(docWrite) {
-            var allScriptTags = new Array(jsfiles.length);
+        // use "parser-inserted scripts" for guaranteed execution order
+        // http://hsivonen.iki.fi/script-execution/
+        var allScriptTags = new Array(jsfiles.length);
         var host = OpenLayers._getScriptLocation() + "lib/";
         for (var i=0, len=jsfiles.length; i<len; i++) {
-            if (docWrite) {
-                allScriptTags[i] = "<script src='" + host + jsfiles[i] +
+            allScriptTags[i] = "<script src='" + host + jsfiles[i] +
                                    "'></script>";
-            } else {
-                var s = document.createElement("script");
-                s.src = host + jsfiles[i];
-                var h = document.getElementsByTagName("head").length ?
-                           document.getElementsByTagName("head")[0] :
-                           document.body;
-                h.appendChild(s);
-        if (docWrite) {
-            document.write(allScriptTags.join(""));
+        document.write(allScriptTags.join(""));
Modified: sandbox/elemoine/draw-feature/tests/BaseTypes/Bounds.html
--- sandbox/elemoine/draw-feature/tests/BaseTypes/Bounds.html	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/tests/BaseTypes/Bounds.html	2011-01-18 12:16:21 UTC (rev 11039)
@@ -126,7 +126,7 @@
     function test_Bounds_fromString(t) {
-       t.plan( 10 );
+       t.plan( 12 );
        bounds = OpenLayers.Bounds.fromString("1,2,3,4");
        t.ok( bounds instanceof OpenLayers.Bounds, "new OpenLayers.Bounds returns Bounds object" );
        t.eq( bounds.left, 1, "bounds.left is set correctly" );
@@ -134,13 +134,18 @@
        t.eq( bounds.right, 3, "bounds.right is set correctly" );
        t.eq( bounds.top, 4, "bounds.top is set correctly" );
+       // reverse axis order
+       var reverseBbox = bounds.toBBOX(null, true);
+       t.eq(reverseBbox, "2,1,4,3", "toBBOX with reverseAxisOrder set to true works as expected");
+       var boundsFromReverse = OpenLayers.Bounds.fromString(reverseBbox, true);
+       t.ok(bounds.equals(boundsFromReverse), "Bounds created from string with reverseAxisOrder are correct");
        bounds = OpenLayers.Bounds.fromString("1.1,2.2,3.3,4.4");
        t.eq( bounds.left, 1.1, "bounds.left is set correctly" );
        t.eq( bounds.bottom, 2.2, "bounds.bottom is set correctly" );
        t.eq( bounds.right, 3.3, "bounds.right is set correctly" );
        t.eq( bounds.top, 4.4, "bounds.top is set correctly" );
     function test_Bounds_getSize(t) {
@@ -358,7 +363,7 @@
     function test_Bounds_fromArray(t) {
-       t.plan( 5 );
+       t.plan( 7 );
        var bbox = [1,2,3,4];
        bounds = OpenLayers.Bounds.fromArray(bbox);
@@ -367,6 +372,12 @@
        t.eq( bounds.bottom, 2, "bounds.bottom is set correctly" );
+       var reverseBbox = bounds.toArray(true);
+       t.eq(reverseBbox, [2,1,4,3], "toArray with reverseAxisOrder set to true works as expected");
+       var boundsFromReverse = OpenLayers.Bounds.fromArray(reverseBbox, true);
+       t.ok(bounds.equals(boundsFromReverse), "Bounds created from array with reverseAxisOrder are correct");
     function test_Bounds_fromSize(t) {
Modified: sandbox/elemoine/draw-feature/tests/Format/WFST/v1.html
--- sandbox/elemoine/draw-feature/tests/Format/WFST/v1.html	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/tests/Format/WFST/v1.html	2011-01-18 12:16:21 UTC (rev 11039)
@@ -89,6 +89,32 @@
+    function test_update_null_geometry(t) {
+        var format = new OpenLayers.Format.WFST({
+            featureNS: "http://www.openplans.org/topp",
+            featureType: "states",
+            featurePrefix: "topp",
+            geometryName: "the_geom"
+        var feature = new OpenLayers.Feature.Vector(null, {foo: "bar"});
+        feature.state = OpenLayers.State.UPDATE;
+        feature.fid = "fid.36";
+        t.plan(1);
+        var snippets = {
+            "UpdateNullGeometry": feature
+        var arg;
+        for (var snippet in snippets) {
+            arg = snippets[snippet]
+            var expected = readXML(snippet);
+            var got = format.writers["wfs"]["Update"].apply(format, [arg]);
+            t.xml_eq(got, expected, snippet + " request with null geometry created correctly");
     function test_write_multiple(t) {
@@ -232,5 +258,19 @@
     </ogc:Filter>
 </wfs:Update>
 --></div>
+<div id="UpdateNullGeometry"><!--
+<wfs:Update xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
+    <wfs:Property>
+        <wfs:Name>the_geom</wfs:Name>
+    </wfs:Property>
+    <wfs:Property>
+        <wfs:Name>foo</wfs:Name>
+        <wfs:Value>bar</wfs:Value>
+    </wfs:Property>
+    <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
+        <ogc:FeatureId fid="fid.36"/>
+    </ogc:Filter>
+</wfs:Update>
+--></div>
 </body>
 </html>
Modified: sandbox/elemoine/draw-feature/tests/Layer/Bing.html
--- sandbox/elemoine/draw-feature/tests/Layer/Bing.html	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/tests/Layer/Bing.html	2011-01-18 12:16:21 UTC (rev 11039)
@@ -13,18 +13,20 @@
     function test_constructor(t) {
-        t.plan(2);
+        t.plan(3);
         var origProcessMetadata = OpenLayers.Layer.Bing.processMetadata;
         var log = [];
         OpenLayers.Layer.Bing.processMetadata = function(metadata) {
-            log.push(metadata);
+            var script = document.getElementById(this._callbackId);
+            log.push(script.src);
             origProcessMetadata.apply(this, arguments);
-        layer = new OpenLayers.Layer.Bing(options);
+        layer = new OpenLayers.Layer.Bing({metadataParams: {foo: "bar"}});
         t.ok(layer instanceof OpenLayers.Layer.Bing, "returns OpenLayers.Layer.Bing object" );
         t.delay_call(2, function() {
             t.eq(log.length, 1, "processMetadata called");
+            t.eq(OpenLayers.Util.getParameters(log[0]).foo, "bar", "metadataParams passed to url correctly.");
             OpenLayers.Layer.Bing.processMetadata = origProcessMetadata;
             layer.destroy();
Modified: sandbox/elemoine/draw-feature/tests/Layer/WMS.html
--- sandbox/elemoine/draw-feature/tests/Layer/WMS.html	2011-01-18 00:13:35 UTC (rev 11038)
+++ sandbox/elemoine/draw-feature/tests/Layer/WMS.html	2011-01-18 12:16:21 UTC (rev 11039)
@@ -380,7 +380,7 @@
-    function test_tileExtent(t) {
+    function test_tileOrigin(t) {
         t.plan(4);
         var dummy = new OpenLayers.Layer(null, {isBaseLayer: true});
@@ -392,7 +392,7 @@
         var constrained = new OpenLayers.Layer.WMS(
             null, "http://example.com/wms-c",
             {layers: "constrained"},
-            {buffer: 0, isBaseLayer: false, tileExtent: new OpenLayers.Bounds(-180, -90, 180, 90)}
+            {buffer: 0, isBaseLayer: false, tileOrigin: new OpenLayers.LonLat(-180, -90)}
             div: "map",
More information about the Commits mailing list
