[OpenLayers-Commits] r11053 - trunk/openlayers/build
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Jan 23 09:38:25 EST 2011
Author: erilem
Date: 2011-01-23 06:38:25 -0800 (Sun, 23 Jan 2011)
New Revision: 11053
   trunk/openlayers/build/library.cfg
remove incorrect comment in library.cfg, thanks rodo for reporting the issues (closes #3023)
Modified: trunk/openlayers/build/library.cfg
--- trunk/openlayers/build/library.cfg	2011-01-22 12:04:40 UTC (rev 11052)
+++ trunk/openlayers/build/library.cfg	2011-01-23 14:38:25 UTC (rev 11053)
@@ -1,6 +1,5 @@
 # This file includes the OpenLayers code to create a build for everything that
-# does not require vector support. build.py uses this profile if no other one
-# is specified.
+# does not require vector support.
 [first]
More information about the Commits mailing list
