[OpenLayers-Commits] r11060 - in sandbox/sonxurxo/sos: examples lib/OpenLayers/Format lib/OpenLayers/Format/OWSCommon lib/OpenLayers/Protocol/SOS
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Jan 26 06:32:44 EST 2011
Author: sonxurxo
Date: 2011-01-26 03:32:44 -0800 (Wed, 26 Jan 2011)
New Revision: 11060
   sandbox/sonxurxo/sos/examples/sosClass.html
   sandbox/sonxurxo/sos/lib/OpenLayers/Format/OWSCommon/v1.js
   sandbox/sonxurxo/sos/lib/OpenLayers/Format/SOSGetObservation.js
   sandbox/sonxurxo/sos/lib/OpenLayers/Protocol/SOS/v1_0_0_2.js
Changed for (var v in ...) by for (var i=0... statements
Modified: sandbox/sonxurxo/sos/examples/sosClass.html
--- sandbox/sonxurxo/sos/examples/sosClass.html	2011-01-24 21:45:44 UTC (rev 11059)
+++ sandbox/sonxurxo/sos/examples/sosClass.html	2011-01-26 11:32:44 UTC (rev 11060)
@@ -11,6 +11,7 @@
     <script type="text/javascript">
         var map;
+        //OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
         OpenLayers.ProxyHost = "proxy.cgi?url=";
         OpenLayers.Util.extend(OpenLayers.Lang.en,
Modified: sandbox/sonxurxo/sos/lib/OpenLayers/Format/OWSCommon/v1.js
--- sandbox/sonxurxo/sos/lib/OpenLayers/Format/OWSCommon/v1.js	2011-01-24 21:45:44 UTC (rev 11059)
+++ sandbox/sonxurxo/sos/lib/OpenLayers/Format/OWSCommon/v1.js	2011-01-26 11:32:44 UTC (rev 11060)
@@ -250,8 +250,8 @@
             "AcceptVersions": function(acceptVersions) {
                 var node = this.createElementNSPlus("ows:AcceptVersions");
-                for (var version in acceptVersions) {
-                    this.writeNode("Version", acceptVersions[version], node);
+                for (var i=0, len=acceptVersions.length; i<len; i++) {
+                    this.writeNode("Version", acceptVersions[i], node);
                 return node;
@@ -261,15 +261,15 @@
             "AcceptFormats": function(acceptFormats) {
                 var node = this.createElementNSPlus("ows:AcceptFormats");
-                for (var outputFormat in acceptFormats) {
-                    this.writeNode("OutputFormat", acceptFormats[outputFormat], node);
+                for (var i=0, len=acceptFormats.length; i<len; i++) {
+                    this.writeNode("OutputFormat", acceptFormats[i], node);
                 return node;
             "Sections": function(sections) {
                 var node = this.createElementNSPlus("ows:Sections");
-                for (var section in sections) {
-                    this.writeNode("Section", sections[section], node);
+                for (var i=0, len=sections.length; i<len; i++) {
+                    this.writeNode("Section", sections[i], node);
                 return node;
Modified: sandbox/sonxurxo/sos/lib/OpenLayers/Format/SOSGetObservation.js
--- sandbox/sonxurxo/sos/lib/OpenLayers/Format/SOSGetObservation.js	2011-01-24 21:45:44 UTC (rev 11059)
+++ sandbox/sonxurxo/sos/lib/OpenLayers/Format/SOSGetObservation.js	2011-01-26 11:32:44 UTC (rev 11060)
@@ -2,302 +2,304 @@
  * full list of contributors). Published under the Clear BSD license.
  * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
  * full text of the license. */
- * @requires OpenLayers/Format/XML.js
- * @requires OpenLayers/Format/GML.js
- * @requires OpenLayers/Format/GML/v3.js
- * Class: OpenLayers.Format.SOSGetObservation
- * Read and write SOS GetObersation (to get the actual values from a sensor)
- *     version 1.0.0
- * Inherits from:
- *  - <OpenLayers.Format.XML>
-OpenLayers.Format.SOSGetObservation = OpenLayers.Class(OpenLayers.Format.XML, {
-     * Property: namespaces
-     * {Object} Mapping of namespace aliases to namespace URIs.
-    namespaces: {
-        ows: "http://www.opengis.net/ows",
-        gml: "http://www.opengis.net/gml",
-        sos: "http://www.opengis.net/sos/1.0",
-        ogc: "http://www.opengis.net/ogc",
-        om: "http://www.opengis.net/om/1.0",
-        xlink: "http://www.w3.org/1999/xlink",
+ * @requires OpenLayers/Format/XML.js
+ * @requires OpenLayers/Format/GML.js
+ * @requires OpenLayers/Format/GML/v3.js
+ * Class: OpenLayers.Format.SOSGetObservation
+ * Read and write SOS GetObersation (to get the actual values from a sensor)
+ *     version 1.0.0
+ * Inherits from:
+ *  - <OpenLayers.Format.XML>
+OpenLayers.Format.SOSGetObservation = OpenLayers.Class(OpenLayers.Format.XML, {
+     * Property: namespaces
+     * {Object} Mapping of namespace aliases to namespace URIs.
+    namespaces: {
+        ows: "http://www.opengis.net/ows",
+        gml: "http://www.opengis.net/gml",
+        sos: "http://www.opengis.net/sos/1.0",
+        ogc: "http://www.opengis.net/ogc",
+        om: "http://www.opengis.net/om/1.0",
+        xlink: "http://www.w3.org/1999/xlink",
         xsi: "http://www.w3.org/2001/XMLSchema-instance",
-        sa: "http://www.opengis.net/sampling/1.0"
-     * Property: regExes
-     * Compiled regular expressions for manipulating strings.
-    regExes: {
-        trimSpace: (/^\s*|\s*$/g),
-        removeSpace: (/\s*/g),
-        splitSpace: (/\s+/),
-        trimComma: (/\s*,\s*/g)
-     * Constant: VERSION
-     * {String} 1.0.0
-    VERSION: "1.0.0",
-     * Property: schemaLocation
-     * {String} Schema location
-    schemaLocation: "http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",
-     * Property: defaultPrefix
-    defaultPrefix: "sos",
-     * Constructor: OpenLayers.Format.SOSGetObservation
-     * Parameters:
-     * options - {Object} An optional object whose properties will be set on
-     *     this instance.
-    initialize: function(options) {
-        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
-     * Method: read
-     * Parameters:
-     * data - {String} or {DOMElement} data to read/parse.
-     * Returns:
-     * {Object} An object containing the measurements
-    read: function(data) {
-        if(typeof data == "string") {
-            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
-        if(data && data.nodeType == 9) {
-            data = data.documentElement;
-        var info = {measurements: [], observations: []};
-        this.readNode(data, info);
-        return info;
-     * Method: write
-     * Parameters:
-     * options - {Object} Optional object.
-     * Returns:
-     * {String} An SOS GetObservation request XML string.
-    write: function(options) {
-        var node = this.writeNode("sos:GetObservation", options);
+        sa: "http://www.opengis.net/sampling/1.0"
+     * Property: regExes
+     * Compiled regular expressions for manipulating strings.
+    regExes: {
+        trimSpace: (/^\s*|\s*$/g),
+        removeSpace: (/\s*/g),
+        splitSpace: (/\s+/),
+        trimComma: (/\s*,\s*/g)
+     * Constant: VERSION
+     * {String} 1.0.0
+    VERSION: "1.0.0",
+     * Property: schemaLocation
+     * {String} Schema location
+    schemaLocation: "http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",
+     * Property: defaultPrefix
+    defaultPrefix: "sos",
+     * Constructor: OpenLayers.Format.SOSGetObservation
+     * Parameters:
+     * options - {Object} An optional object whose properties will be set on
+     *     this instance.
+    initialize: function(options) {
+        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
+     * Method: read
+     * Parameters:
+     * data - {String} or {DOMElement} data to read/parse.
+     * Returns:
+     * {Object} An object containing the measurements
+    read: function(data) {
+        if(typeof data == "string") {
+            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
+        if(data && data.nodeType == 9) {
+            data = data.documentElement;
+        var info = {measurements: [], observations: []};
+        this.readNode(data, info);
+        return info;
+     * Method: write
+     * Parameters:
+     * options - {Object} Optional object.
+     * Returns:
+     * {String} An SOS GetObservation request XML string.
+    write: function(options) {
+        var node = this.writeNode("sos:GetObservation", options);
         node.setAttribute("xmlns:om", this.namespaces.om);
-        this.setAttributeNS(
-            node, this.namespaces.xsi,
-            "xsi:schemaLocation", this.schemaLocation
-        return OpenLayers.Format.XML.prototype.write.apply(this, [node]);
-     * Property: readers
-     * Contains public functions, grouped by namespace prefix, that will
-     *     be applied when a namespaced node is found matching the function
-     *     name.  The function will be applied in the scope of this parser
-     *     with two arguments: the node being read and a context object passed
-     *     from the parent.
-    readers: {
-        "om": {
-            "ObservationCollection": function(node, obj) {
-                obj.id = this.getAttributeNS(node, this.namespaces.gml, "id");
-                this.readChildNodes(node, obj);
-            "member": function(node, observationCollection) {
-                this.readChildNodes(node, observationCollection);
-            "Measurement": function(node, observationCollection) {
-                var measurement = {};
-                observationCollection.measurements.push(measurement);
-                this.readChildNodes(node, measurement);
-            "Observation": function(node, observationCollection) {
-                var observation = {};
-                observationCollection.observations.push(observation);
-                this.readChildNodes(node, observation);
-            "samplingTime": function(node, measurement) {
-                var samplingTime = {};
-                measurement.samplingTime = samplingTime;
-                this.readChildNodes(node, samplingTime);
-            "observedProperty": function(node, measurement) {
-                measurement.observedProperty =
-                    this.getAttributeNS(node, this.namespaces.xlink, "href");
-            "procedure": function(node, measurement) {
-                measurement.procedure =
-            "featureOfInterest": function(node, observation) {
+        this.setAttributeNS(
+            node, this.namespaces.xsi,
+            "xsi:schemaLocation", this.schemaLocation
+        return OpenLayers.Format.XML.prototype.write.apply(this, [node]);
+     * Property: readers
+     * Contains public functions, grouped by namespace prefix, that will
+     *     be applied when a namespaced node is found matching the function
+     *     name.  The function will be applied in the scope of this parser
+     *     with two arguments: the node being read and a context object passed
+     *     from the parent.
+    readers: {
+        "om": {
+            "ObservationCollection": function(node, obj) {
+                obj.id = this.getAttributeNS(node, this.namespaces.gml, "id");
+                this.readChildNodes(node, obj);
+            "member": function(node, observationCollection) {
+                this.readChildNodes(node, observationCollection);
+            "Measurement": function(node, observationCollection) {
+                var measurement = {};
+                observationCollection.measurements.push(measurement);
+                this.readChildNodes(node, measurement);
+            "Observation": function(node, observationCollection) {
+                var observation = {};
+                observationCollection.observations.push(observation);
+                this.readChildNodes(node, observation);
+            "samplingTime": function(node, measurement) {
+                var samplingTime = {};
+                measurement.samplingTime = samplingTime;
+                this.readChildNodes(node, samplingTime);
+            "observedProperty": function(node, measurement) {
+                measurement.observedProperty =
+                    this.getAttributeNS(node, this.namespaces.xlink, "href");
+            "procedure": function(node, measurement) {
+                measurement.procedure =
+            "featureOfInterest": function(node, observation) {
                 var foi = {};
-                observation.fois = [];
-                observation.fois.push(foi);
-                this.readChildNodes(node, foi);
-            "result": function(node, measurement) {
-                var result = {};
-                measurement.result = result;
-                if (this.getChildValue(node) !== '') {
-                    result.value = this.getChildValue(node);
-                    result.uom = node.getAttribute("uom");
-                } else {
-                    this.readChildNodes(node, result);
-        "sa": {
-            "SamplingPoint": function(node, foi) {
-                foi.id = this.getAttributeNS(node, this.namespaces.gml, "id");
-            "position" : function(node, foi) {
-        "gml": OpenLayers.Util.applyDefaults({
-            "TimeInstant": function(node, samplingTime) {
-               var timeInstant = {};
-                samplingTime.timeInstant = timeInstant;
-                this.readChildNodes(node, timeInstant);
-            "timePosition": function(node, timeInstant) {
-                timeInstant.timePosition = this.getChildValue(node);
+                observation.fois = [];
+                observation.fois.push(foi);
+                this.readChildNodes(node, foi);
-            "FeatureCollection": function(node, foi) {
-            "featureMember": function(node, foi) {
-        }, OpenLayers.Format.GML.v3.prototype.readers.gml)
-     * Property: writers
-     * As a compliment to the readers property, this structure contains public
-     *     writing functions grouped by namespace alias and named like the
-     *     node names they produce.
-    writers: {
-        "sos": {
-            "GetObservation": function(options) {
-                var node = this.createElementNSPlus("GetObservation", {
-                    attributes: {
-                        version: this.VERSION,
-                        service: 'SOS'
-                this.writeNode("offering", options, node);
-                if (options.eventTime) {
-                    this.writeNode("eventTime", options, node);
+            "result": function(node, measurement) {
+                var result = {};
+                measurement.result = result;
+                if (this.getChildValue(node) !== '') {
+                    result.value = this.getChildValue(node);
+                    result.uom = node.getAttribute("uom");
+                } else {
+                    this.readChildNodes(node, result);
-                for (var procedure in options.procedures) {
-                    this.writeNode("procedure", options.procedures[procedure], node);
+        "sa": {
+            "SamplingPoint": function(node, foi) {
+                foi.id = this.getAttributeNS(node, this.namespaces.gml, "id");
+            "position" : function(node, foi) {
+        "gml": OpenLayers.Util.applyDefaults({
+            "TimeInstant": function(node, samplingTime) {
+               var timeInstant = {};
+                samplingTime.timeInstant = timeInstant;
+                this.readChildNodes(node, timeInstant);
+            "timePosition": function(node, timeInstant) {
+                timeInstant.timePosition = this.getChildValue(node);
+            "FeatureCollection": function(node, foi) {
+            "featureMember": function(node, foi) {
+        }, OpenLayers.Format.GML.v3.prototype.readers.gml)
+     * Property: writers
+     * As a compliment to the readers property, this structure contains public
+     *     writing functions grouped by namespace alias and named like the
+     *     node names they produce.
+    writers: {
+        "sos": {
+            "GetObservation": function(options) {
+                var node = this.createElementNSPlus("GetObservation", {
+                    attributes: {
+                        version: this.VERSION,
+                        service: 'SOS'
+                this.writeNode("offering", options, node);
+                if (options.eventTime) {
+                    this.writeNode("eventTime", options, node);
-                for (var observedProperty in options.observedProperties) {
-                    this.writeNode("observedProperty", options.observedProperties[observedProperty], node);
+                if (options.procedures) {
+                    for (var i=0, len=options.procedures.length; i<len; i++) {
+                        this.writeNode("procedure", options.procedures[i], node);
-                this.writeNode("responseFormat", options, node);
-                if (options.resultModel) {
-                    this.writeNode("resultModel", options, node);
-                if (options.responseMode) {
-                    this.writeNode("responseMode", options, node);
-                return node;
-            "responseFormat": function(options) {
-                return this.createElementNSPlus("responseFormat",
-                    {value: options.responseFormat});
-            "procedure": function(procedure) {
-                return this.createElementNSPlus("procedure",
-                    {value: procedure});
-            "offering": function(options) {
-                return this.createElementNSPlus("offering", {value:
-                    options.offering});
-            "observedProperty": function(observedProperty) {
-                return this.createElementNSPlus("observedProperty",
-                    {value: observedProperty});
-            "eventTime": function(options) {
-                var node = this.createElementNSPlus("eventTime");
-                if (options.eventTime === 'latest') {
-                    this.writeNode("ogc:TM_Equals", options, node);
-                return node;
-            "resultModel": function(options) {
-                return this.createElementNSPlus("resultModel", {value:
-                    options.resultModel});
-            "responseMode": function(options) {
-                return this.createElementNSPlus("responseMode", {value:
-                    options.responseMode});
-        "ogc": {
-            "TM_Equals": function(options) {
-                var node = this.createElementNSPlus("ogc:TM_Equals");
-                this.writeNode("ogc:PropertyName", {property:
-                    "urn:ogc:data:time:iso8601"}, node);
-                    this.writeNode("gml:TimeInstant", {value: 'latest'}, node);
-                return node;
-            "PropertyName": function(options) {
-                return this.createElementNSPlus("ogc:PropertyName",
-                    {value: options.property});
-        "gml": {
-            "TimeInstant": function(options) {
-                var node = this.createElementNSPlus("gml:TimeInstant");
-                this.writeNode("gml:timePosition", options, node);
-                return node;
-            "timePosition": function(options) {
-                var node = this.createElementNSPlus("gml:timePosition",
-                    {value: options.value});
-                return node;
+                for (var i=0, len=options.observedProperties.length; i<len; i++) {
+                    this.writeNode("observedProperty", options.observedProperties[i], node);
+                this.writeNode("responseFormat", options, node);
+                if (options.resultModel) {
+                    this.writeNode("resultModel", options, node);
+                if (options.responseMode) {
+                    this.writeNode("responseMode", options, node);
+                return node;
-            "ObjectID": function(options) {
-                return this.createElementNSPlus("ObjectID",
-                    {value: options});
-    CLASS_NAME: "OpenLayers.Format.SOSGetObservation"
+            "responseFormat": function(options) {
+                return this.createElementNSPlus("responseFormat",
+                    {value: options.responseFormat});
+            "procedure": function(procedure) {
+                return this.createElementNSPlus("procedure",
+                    {value: procedure});
+            "offering": function(options) {
+                return this.createElementNSPlus("offering", {value:
+                    options.offering});
+            "observedProperty": function(observedProperty) {
+                return this.createElementNSPlus("observedProperty",
+                    {value: observedProperty});
+            "eventTime": function(options) {
+                var node = this.createElementNSPlus("eventTime");
+                if (options.eventTime === 'latest') {
+                    this.writeNode("ogc:TM_Equals", options, node);
+                return node;
+            "resultModel": function(options) {
+                return this.createElementNSPlus("resultModel", {value:
+                    options.resultModel});
+            "responseMode": function(options) {
+                return this.createElementNSPlus("responseMode", {value:
+                    options.responseMode});
+        "ogc": {
+            "TM_Equals": function(options) {
+                var node = this.createElementNSPlus("ogc:TM_Equals");
+                this.writeNode("ogc:PropertyName", {property:
+                    "urn:ogc:data:time:iso8601"}, node);
+                    this.writeNode("gml:TimeInstant", {value: 'latest'}, node);
+                return node;
+            "PropertyName": function(options) {
+                return this.createElementNSPlus("ogc:PropertyName",
+                    {value: options.property});
+        "gml": {
+            "TimeInstant": function(options) {
+                var node = this.createElementNSPlus("gml:TimeInstant");
+                this.writeNode("gml:timePosition", options, node);
+                return node;
+            "timePosition": function(options) {
+                var node = this.createElementNSPlus("gml:timePosition",
+                    {value: options.value});
+                return node;
+            "ObjectID": function(options) {
+                return this.createElementNSPlus("ObjectID",
+                    {value: options});
+    CLASS_NAME: "OpenLayers.Format.SOSGetObservation"
Modified: sandbox/sonxurxo/sos/lib/OpenLayers/Protocol/SOS/v1_0_0_2.js
--- sandbox/sonxurxo/sos/lib/OpenLayers/Protocol/SOS/v1_0_0_2.js	2011-01-24 21:45:44 UTC (rev 11059)
+++ sandbox/sonxurxo/sos/lib/OpenLayers/Protocol/SOS/v1_0_0_2.js	2011-01-26 11:32:44 UTC (rev 11060)
@@ -135,14 +135,14 @@
         var oAM = this.format.read(doc);
         var features = [];
-        for (var m in oAM.measurements) {
-            var foi = oAM.measurements[m].fois[0].components[0];
+        for (var i=0, len=oAM.measurements.length; i < len; i++) {
+            var foi = oAM.measurements[i].fois[0].components[0];
             var geometry = new OpenLayers.Geometry.Point(foi.x, foi.y);
             var feature = new OpenLayers.Feature.Vector(geometry, {
-                value: oAM.measurements[m].result.value,
-                uom: oAM.measurements[m].result.uom,
-                time: oAM.measurements[m].samplingTime.timeInstant.timePosition.substring(0,10) + ', ' +
-                    oAM.measurements[m].samplingTime.timeInstant.timePosition.substring(11,16)
+                value: oAM.measurements[i].result.value,
+                uom: oAM.measurements[i].result.uom,
+                time: oAM.measurements[i].samplingTime.timeInstant.timePosition.substring(0,10) + ', ' +
+                    oAM.measurements[i].samplingTime.timeInstant.timePosition.substring(11,16)
             features.push(feature);
More information about the Commits mailing list
