[OpenLayers-Commits] r11064 - in sandbox/tschaub/xdomain: examples lib lib/OpenLayers/Protocol tests tests/Protocol
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Jan 27 15:49:34 EST 2011
Author: tschaub
Date: 2011-01-27 12:49:34 -0800 (Thu, 27 Jan 2011)
New Revision: 11064
Removed:
   sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/FilterSerializer.js
   sandbox/tschaub/xdomain/tests/Protocol/FilterSerializer.html
   sandbox/tschaub/xdomain/examples/cross-origin.js
   sandbox/tschaub/xdomain/lib/OpenLayers.js
   sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/HTTP.js
   sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/Script.js
   sandbox/tschaub/xdomain/tests/Protocol/HTTP.html
   sandbox/tschaub/xdomain/tests/Protocol/Script.html
   sandbox/tschaub/xdomain/tests/list-tests.html
Addresssing the MapFish specific parts in #3032.
Modified: sandbox/tschaub/xdomain/examples/cross-origin.js
--- sandbox/tschaub/xdomain/examples/cross-origin.js	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/examples/cross-origin.js	2011-01-27 20:49:34 UTC (rev 11064)
@@ -19,6 +19,16 @@
                     request: "GetFeature",
                     typeName: "world:cities",
                     outputFormat: "json"
+                filterToParams: function(filter, params) {
+                    // example to demonstrate BBOX serialization
+                    if (filter.type === OpenLayers.Filter.Spatial.BBOX) {
+                        params.bbox = filter.value.toArray();
+                        if (filter.projection) {
+                            params.bbox.push(filter.projection.getCode());
+                    return params;
Deleted: sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/FilterSerializer.js
--- sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/FilterSerializer.js	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/FilterSerializer.js	2011-01-27 20:49:34 UTC (rev 11064)
@@ -1,133 +0,0 @@
-/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
- * full list of contributors). Published under the Clear BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Protocol.js
- * Class: OpenLayers.Protocol.FilterSerializer
- * A mixin for protocols that need to serialize filter parameters.
-OpenLayers.Protocol.FilterSerializer = {
-     * Method: filterToParams
-     * Convert an <OpenLayers.Filter> object to parameters.
-     * Parameters:
-     * filter - {OpenLayers.Filter} filter to convert.
-     * params - {Object} The parameters object.
-     * Returns:
-     * {Object} The resulting parameters object.
-    filterToParams: function(filter, params) {
-        params = params || {};
-        var className = filter.CLASS_NAME;
-        var filterType = className.substring(className.lastIndexOf(".") + 1);
-        switch(filterType) {
-            case "Spatial":
-                switch(filter.type) {
-                    case OpenLayers.Filter.Spatial.BBOX:
-                        params.bbox = filter.value.toArray();
-                        if (this.srsInBBOX && filter.projection) {
-                            params.bbox.push(filter.projection.getCode());
-                        break;
-                    case OpenLayers.Filter.Spatial.DWITHIN:
-                        params.tolerance = filter.distance;
-                        // no break here
-                    case OpenLayers.Filter.Spatial.WITHIN:
-                        params.lon = filter.value.x;
-                        params.lat = filter.value.y;
-                        break;
-                    default:
-                        OpenLayers.Console.warn(
-                            "Unknown spatial filter type " + filter.type);
-                break;
-            case "Comparison":
-                var op = OpenLayers.Protocol.HTTP.COMP_TYPE_TO_OP_STR[filter.type];
-                if(op !== undefined) {
-                    var value = filter.value;
-                    if(filter.type == OpenLayers.Filter.Comparison.LIKE) {
-                        value = this.regex2value(value);
-                        if(this.wildcarded) {
-                            value = "%" + value + "%";
-                    params[filter.property + "__" + op] = value;
-                    params.queryable = params.queryable || [];
-                    params.queryable.push(filter.property);
-                } else {
-                        "Unknown comparison filter type " + filter.type);
-                break;
-            case "Logical":
-                if(filter.type === OpenLayers.Filter.Logical.AND) {
-                    for(var i=0,len=filter.filters.length; i<len; i++) {
-                        params = this.filterToParams(filter.filters[i], params);
-                } else {
-                        "Unsupported logical filter type " + filter.type);
-                break;
-            default:
-                OpenLayers.Console.warn("Unknown filter type " + filterType);
-        return params;
-     * Method: regex2value
-     * Convert the value from a regular expression string to a LIKE/ILIKE
-     * string known to the web service.
-     * Parameters:
-     * value - {String} The regex string.
-     * Returns:
-     * {String} The converted string.
-    regex2value: function(value) {
-        // highly sensitive!! Do not change this without running the
-        // Protocol/HTTP.html unit tests
-        // convert % to \%
-        value = value.replace(/%/g, "\\%");
-        // convert \\. to \\_ (\\.* occurences converted later)
-        value = value.replace(/\\\\\.(\*)?/g, function($0, $1) {
-            return $1 ? $0 : "\\\\_";
-        // convert \\.* to \\%
-        value = value.replace(/\\\\\.\*/g, "\\\\%");
-        // convert . to _ (\. and .* occurences converted later)
-        value = value.replace(/(\\)?\.(\*)?/g, function($0, $1, $2) {
-            return $1 || $2 ? $0 : "_";
-        // convert .* to % (\.* occurnces converted later)
-        value = value.replace(/(\\)?\.\*/g, function($0, $1) {
-            return $1 ? $0 : "%";
-        // convert \. to .
-        value = value.replace(/\\\./g, ".");
-        // replace \* with * (watching out for \\*)
-        value = value.replace(/(\\)?\\\*/g, function($0, $1) {
-            return $1 ? $0 : "*";
-        return value;
Modified: sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/HTTP.js
--- sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/HTTP.js	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/HTTP.js	2011-01-27 20:49:34 UTC (rev 11064)
@@ -109,10 +109,6 @@
         this.params = {};
         this.headers = {};
         OpenLayers.Protocol.prototype.initialize.apply(this, arguments);
-        if (OpenLayers.Protocol.FilterSerializer) {
-            OpenLayers.Util.extend(this, OpenLayers.Protocol.FilterSerializer);
@@ -153,7 +149,6 @@
         options.params = OpenLayers.Util.applyDefaults(
             options.params, this.options.params);
         if(options.filter) {
-            // requires the OpenLayers.Protocol.FilterSerializer mixin
             options.params = this.filterToParams(
                 options.filter, options.params);
@@ -195,6 +190,124 @@
+     * Method: filterToParams
+     * Convert an <OpenLayers.Filter> object to parameters.
+     * Parameters:
+     * filter - {OpenLayers.Filter} filter to convert.
+     * params - {Object} The parameters object.
+     * Returns:
+     * {Object} The resulting parameters object.
+        params = params || {};
+        var className = filter.CLASS_NAME;
+        var filterType = className.substring(className.lastIndexOf(".") + 1);
+        switch(filterType) {
+            case "Spatial":
+                switch(filter.type) {
+                    case OpenLayers.Filter.Spatial.BBOX:
+                        if (this.srsInBBOX && filter.projection) {
+                        break;
+                    case OpenLayers.Filter.Spatial.DWITHIN:
+                        params.tolerance = filter.distance;
+                        // no break here
+                    case OpenLayers.Filter.Spatial.WITHIN:
+                        params.lon = filter.value.x;
+                        params.lat = filter.value.y;
+                        break;
+                    default:
+                        OpenLayers.Console.warn(
+                            "Unknown spatial filter type " + filter.type);
+                break;
+            case "Comparison":
+                var op = OpenLayers.Protocol.HTTP.COMP_TYPE_TO_OP_STR[filter.type];
+                if(op !== undefined) {
+                    var value = filter.value;
+                    if(filter.type == OpenLayers.Filter.Comparison.LIKE) {
+                        value = this.regex2value(value);
+                        if(this.wildcarded) {
+                            value = "%" + value + "%";
+                    params[filter.property + "__" + op] = value;
+                    params.queryable = params.queryable || [];
+                    params.queryable.push(filter.property);
+                } else {
+                        "Unknown comparison filter type " + filter.type);
+                break;
+            case "Logical":
+                if(filter.type === OpenLayers.Filter.Logical.AND) {
+                    for(var i=0,len=filter.filters.length; i<len; i++) {
+                        params = this.filterToParams(filter.filters[i], params);
+                } else {
+                        "Unsupported logical filter type " + filter.type);
+                break;
+            default:
+                OpenLayers.Console.warn("Unknown filter type " + filterType);
+        return params;
+     * Method: regex2value
+     * Convert the value from a regular expression string to a LIKE/ILIKE
+     * string known to the web service.
+     * Parameters:
+     * value - {String} The regex string.
+     * Returns:
+     * {String} The converted string.
+    regex2value: function(value) {
+        // highly sensitive!! Do not change this without running the
+        // Protocol/HTTP.html unit tests
+        // convert % to \%
+        value = value.replace(/%/g, "\\%");
+        // convert \\. to \\_ (\\.* occurences converted later)
+        value = value.replace(/\\\\\.(\*)?/g, function($0, $1) {
+            return $1 ? $0 : "\\\\_";
+        // convert \\.* to \\%
+        value = value.replace(/\\\\\.\*/g, "\\\\%");
+        // convert . to _ (\. and .* occurences converted later)
+        value = value.replace(/(\\)?\.(\*)?/g, function($0, $1, $2) {
+            return $1 || $2 ? $0 : "_";
+        // convert .* to % (\.* occurnces converted later)
+        value = value.replace(/(\\)?\.\*/g, function($0, $1) {
+            return $1 ? $0 : "%";
+        // convert \. to .
+        value = value.replace(/\\\./g, ".");
+        // replace \* with * (watching out for \\*)
+        value = value.replace(/(\\)?\\\*/g, function($0, $1) {
+            return $1 ? $0 : "*";
+        return value;
      * APIMethod: create
      * Construct a request for writing newly created features.
Modified: sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/Script.js
--- sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/Script.js	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/lib/OpenLayers/Protocol/Script.js	2011-01-27 20:49:34 UTC (rev 11064)
@@ -113,9 +113,6 @@
         if (!this.format) {
             this.format = new OpenLayers.Format.GeoJSON();
@@ -144,8 +141,7 @@
-        if (options.filter) {
+        if (options.filter && this.filterToParams) {
@@ -156,14 +152,28 @@
             options.params,
             OpenLayers.Function.bind(function(data) {
                 response.data = data;
-                this.handleRead(response, options)
+                this.handleRead(response, options);
             }, this)
         response.priv = request;
         return response;
+     * APIMethod: filterToParams
+     * Optional method to translate an <OpenLayers.Filter> object into an object
+     *     that can be serialized as request query string provided.  If a custom
+     *     method is not provided, any filter will not be serialized.
+     * Parameters:
+     * filter - {<OpenLayers.Filter>} filter to convert.
+     * Returns:
      * Method: createRequest
      * Issues a request for features by creating injecting a script in the
      *     document head.
@@ -343,6 +353,6 @@
         var callback = registry[id];
         o.unregister(id);
         return callback;
Modified: sandbox/tschaub/xdomain/lib/OpenLayers.js
--- sandbox/tschaub/xdomain/lib/OpenLayers.js	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/lib/OpenLayers.js	2011-01-27 20:49:34 UTC (rev 11064)
@@ -215,7 +215,6 @@
             "OpenLayers/Filter/Comparison.js",
             "OpenLayers/Filter/Spatial.js",
             "OpenLayers/Protocol.js",
-            "OpenLayers/Protocol/FilterSerializer.js",
             "OpenLayers/Protocol/HTTP.js",
             "OpenLayers/Protocol/Script.js",
             "OpenLayers/Protocol/SQL.js",
Deleted: sandbox/tschaub/xdomain/tests/Protocol/FilterSerializer.html
--- sandbox/tschaub/xdomain/tests/Protocol/FilterSerializer.html	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/tests/Protocol/FilterSerializer.html	2011-01-27 20:49:34 UTC (rev 11064)
@@ -1,296 +0,0 @@
-<html>
-<head>
-  <script src="../../lib/OpenLayers.js"></script>
-  <script type="text/javascript">
-    function test_filterToParams(t) {
-        t.plan(30);
-        // setup
-        var protocol, filter, params;
-        protocol = OpenLayers.Protocol.FilterSerializer;
-        // 1 test
-        var filter = new OpenLayers.Filter.Spatial({
-            type: OpenLayers.Filter.Spatial.BBOX,
-            value: new OpenLayers.Bounds(0, 1, 2, 3)
-        params = protocol.filterToParams(filter);
-        t.eq(params.bbox, [0, 1, 2, 3],
-             "filterToParams sets correct bbox param if passed a BBOX filter");
-        // 3 tests
-        var lon = 100, lat = 200, tolerance = 10;
-        filter = new OpenLayers.Filter.Spatial({
-            type: OpenLayers.Filter.Spatial.DWITHIN,
-            value: new OpenLayers.Geometry.Point(lon, lat),
-            distance: tolerance
-        t.eq(params.lon, lon,
-             "filterToParams sets correct lon param if passed a DWITHIN filter");
-        t.eq(params.lat, lat,
-             "filterToParams sets correct lat param if passed a DWITHIN filter");
-        t.eq(params.tolerance, tolerance,
-             "filterToParams sets correct tolerance param if passed a DWITHIN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Spatial.WITHIN,
-             "filterToParams sets correct lon param if passed a WITHIN filter");
-             "filterToParams sets correct lat param if passed a WITHIN filter");
-        // Some bbox filters used in the next tests.
-        var bboxFilter1 = new OpenLayers.Filter.Spatial({
-            value:  new OpenLayers.Bounds(0, 0, 10, 10)
-        var bboxFilter2 = new OpenLayers.Filter.Spatial({
-            value:  new OpenLayers.Bounds(0, 0, 20, 20)
-        // 1 test
-        filter = new OpenLayers.Filter.Logical({
-            type: OpenLayers.Filter.Logical.AND,
-            filters: []
-        t.eq(params, {},
-             "filterToParams returns empty object if given empty AND Logical filter");
-        // 1 test
-            type: OpenLayers.Filter.Logical.OR,
-            filters: [
-                bboxFilter1
-        t.eq(params, {},
-             "filterToParams does not support OR Logical filter");
-        // 1 test
-            filters: [
-                bboxFilter1
-        t.eq(params.bbox, [0, 0, 10, 10],
-             "filterToParams sets correct bbox param if passed " +
-             "a Logical filter containing a BBOX");
-        // 1 test
-            filters: [
-                bboxFilter1, bboxFilter2
-        t.eq(params.bbox, [0, 0, 20, 20],
-             "multiple BBOX filter in a Logical filter");
-        // 2 tests
-        filter = new OpenLayers.Filter.Comparison({
-            type: OpenLayers.Filter.Comparison.EQUAL_TO,
-            property: "foo",
-            value: "bar"
-        t.eq(params.queryable[0], "foo",
-             "filterToParams sets correct queryable param if passed an EQUAL_TO filter");
-        t.eq(params["foo__eq"], "bar",
-             "filterToParams sets correct param key and value if passed an EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an NOT_EQUAL_TO filter");
-        t.eq(params["foo__ne"], "bar",
-             "filterToParams sets correct param key and value if passed an NOT_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LESS_THAN,
-            property: "foo",
-            value: "bar"
-        var params = protocol.filterToParams(filter);
-             "filterToParams sets correct queryable param if passed an LESS_THAN filter");
-        t.eq(params["foo__lt"], "bar",
-             "filterToParams sets correct param key and value if passed an LESS_THAN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an LESS_THAN_OR_EQUAL_TO filter");
-        t.eq(params["foo__lte"], "bar",
-             "filterToParams sets correct param key and value if passed an LESS_THAN_OR_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.GREATER_THAN,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an GREATER_THAN filter");
-        t.eq(params["foo__gt"], "bar",
-             "filterToParams sets correct param key and value if passed an GREATER_THAN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an GREATER_THAN_OR_EQUAL_TO filter");
-        t.eq(params["foo__gte"], "bar",
-             "filterToParams sets correct param key and value if passed an GREATER_THAN_OR_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LIKE,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed a LIKE filter");
-        t.eq(params["foo__ilike"], "bar",
-             "filterToParams sets correct param key and value if passed an LIKE filter");
-        // 4 tests
-            filters: [
-                new OpenLayers.Filter.Comparison({
-                    property: "foo",
-                    value: "bar"
-                    property: "foo2",
-                    value: "baz"
-             "filterToParams sets correct queryable param if passed an EQUAL_TO filter within a AND filter");
-             "filterToParams sets correct param key and value if passed an EQUAL_TO filter within a AND filter");
-        t.eq(params.queryable[1], "foo2",
-             "filterToParams sets correct queryable param if passed a LESS_THAN filter within a AND filter");
-        t.eq(params["foo2__lt"], "baz",
-             "filterToParams sets correct param key and value if passed a LESS_THAN filter within a AND filter");
-        // 2 tests
-        protocol = new OpenLayers.Protocol.HTTP({wildcarded: true});
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed a LIKE filter (wildcarded true)");
-        t.eq(params["foo__ilike"], "%bar%",
-             "filterToParams sets correct param key and value if passed an LIKE filter (wildcarded true)");
-    function test_regex2value(t) {
-        t.plan(16);
-        // setup
-        var protocol = new OpenLayers.Protocol.HTTP();
-        var value;
-        // test
-        value = protocol.regex2value("foo");
-        t.eq(value, "foo", 'regex2value converts "foo" to "foo"');
-        value = protocol.regex2value("foo%");
-        t.eq(value, "foo\\%", 'regex2value converts "foo%" to "foo\\%"');
-        value = protocol.regex2value("foo.*");
-        t.eq(value, "foo%", 'regex2value converts "foo.*" to "foo%"');
-        value = protocol.regex2value("f.*oo.*");
-        t.eq(value, "f%oo%", 'regex2value converts "f.*oo.*" to "f%oo%"');
-        value = protocol.regex2value("foo.");
-        t.eq(value, "foo_", 'regex2value converts "foo." to "foo_"');
-        value = protocol.regex2value("f.oo.");
-        t.eq(value, "f_oo_", 'regex2value converts "f.oo." to "f_oo_"');
-        value = protocol.regex2value("f.oo.*");
-        t.eq(value, "f_oo%", 'regex2value converts "f.oo.*" to "f_oo%"');
-        value = protocol.regex2value("foo\\\\");
-        t.eq(value, "foo\\\\", 'regex2value converts "foo\\\\" to "foo\\\\"');
-        value = protocol.regex2value("foo\\.");
-        t.eq(value, "foo.", 'regex2value converts "foo\\." to "foo."');
-        value = protocol.regex2value("foo\\\\.");
-        t.eq(value, "foo\\\\_", 'regex2value converts "foo\\\\." to "foo\\\\_"');
-        value = protocol.regex2value("foo\\*");
-        t.eq(value, "foo*", 'regex2value converts "foo\\*" to "foo*"');
-        value = protocol.regex2value("foo\\\\*");
-        t.eq(value, "foo\\\\*", 'regex2value converts "foo\\\\*" to "foo\\\\*"');
-        value = protocol.regex2value("foo\\\\.*");
-        t.eq(value, "foo\\\\%", 'regex2value converts "foo\\\\.*" to "foo\\\\%"');
-        value = protocol.regex2value("fo\\.o.*");
-        t.eq(value, "fo.o%", 'regex2value converts from "fo\\.o.*" to "fo.o%"');
-        value = protocol.regex2value("fo.*o\\.");
-        t.eq(value, "fo%o.", 'regex2value converts from "fo.*o\\." to "to%o."');
-        value = protocol.regex2value("\\*\\..*.\\\\.*\\\\.%");
-        t.eq(value, "*.%_\\\\%\\\\_\\%",
-             'regex2value converts from "\\*\\..*.\\\\.*\\\\.%" ' +
-             'to "*.%_\\\\%\\\\_\\%"');
-  </script>
-</head>
-<body>
-</body>
-</html>
Modified: sandbox/tschaub/xdomain/tests/Protocol/HTTP.html
--- sandbox/tschaub/xdomain/tests/Protocol/HTTP.html	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/tests/Protocol/HTTP.html	2011-01-27 20:49:34 UTC (rev 11064)
@@ -287,6 +287,291 @@
         t.eq(ret, null, 'parseFeatures returns expected value');
+    function test_filterToParams(t) {
+        t.plan(30);
+        // setup
+        var protocol, filter, params;
+        protocol = new OpenLayers.Protocol.HTTP();
+        // 1 test
+        var filter = new OpenLayers.Filter.Spatial({
+            type: OpenLayers.Filter.Spatial.BBOX,
+            value: new OpenLayers.Bounds(0, 1, 2, 3)
+        params = protocol.filterToParams(filter);
+        t.eq(params.bbox, [0, 1, 2, 3],
+             "filterToParams sets correct bbox param if passed a BBOX filter");
+        // 3 tests
+        var lon = 100, lat = 200, tolerance = 10;
+        filter = new OpenLayers.Filter.Spatial({
+            type: OpenLayers.Filter.Spatial.DWITHIN,
+            value: new OpenLayers.Geometry.Point(lon, lat),
+            distance: tolerance
+        t.eq(params.lon, lon,
+             "filterToParams sets correct lon param if passed a DWITHIN filter");
+        t.eq(params.lat, lat,
+             "filterToParams sets correct lat param if passed a DWITHIN filter");
+        t.eq(params.tolerance, tolerance,
+             "filterToParams sets correct tolerance param if passed a DWITHIN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Spatial.WITHIN,
+             "filterToParams sets correct lon param if passed a WITHIN filter");
+             "filterToParams sets correct lat param if passed a WITHIN filter");
+        // Some bbox filters used in the next tests.
+        var bboxFilter1 = new OpenLayers.Filter.Spatial({
+            value:  new OpenLayers.Bounds(0, 0, 10, 10)
+        var bboxFilter2 = new OpenLayers.Filter.Spatial({
+            value:  new OpenLayers.Bounds(0, 0, 20, 20)
+        // 1 test
+        filter = new OpenLayers.Filter.Logical({
+            type: OpenLayers.Filter.Logical.AND,
+            filters: []
+        t.eq(params, {},
+             "filterToParams returns empty object if given empty AND Logical filter");
+        // 1 test
+            type: OpenLayers.Filter.Logical.OR,
+            filters: [
+                bboxFilter1
+        t.eq(params, {},
+             "filterToParams does not support OR Logical filter");
+        // 1 test
+            filters: [
+                bboxFilter1
+        t.eq(params.bbox, [0, 0, 10, 10],
+             "filterToParams sets correct bbox param if passed " +
+             "a Logical filter containing a BBOX");
+        // 1 test
+            filters: [
+                bboxFilter1, bboxFilter2
+        t.eq(params.bbox, [0, 0, 20, 20],
+             "multiple BBOX filter in a Logical filter");
+        // 2 tests
+        filter = new OpenLayers.Filter.Comparison({
+            type: OpenLayers.Filter.Comparison.EQUAL_TO,
+            property: "foo",
+            value: "bar"
+        t.eq(params.queryable[0], "foo",
+             "filterToParams sets correct queryable param if passed an EQUAL_TO filter");
+        t.eq(params["foo__eq"], "bar",
+             "filterToParams sets correct param key and value if passed an EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed an NOT_EQUAL_TO filter");
+        t.eq(params["foo__ne"], "bar",
+             "filterToParams sets correct param key and value if passed an NOT_EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.LESS_THAN,
+            property: "foo",
+            value: "bar"
+        var params = protocol.filterToParams(filter);
+             "filterToParams sets correct queryable param if passed an LESS_THAN filter");
+        t.eq(params["foo__lt"], "bar",
+             "filterToParams sets correct param key and value if passed an LESS_THAN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed an LESS_THAN_OR_EQUAL_TO filter");
+        t.eq(params["foo__lte"], "bar",
+             "filterToParams sets correct param key and value if passed an LESS_THAN_OR_EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.GREATER_THAN,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed an GREATER_THAN filter");
+        t.eq(params["foo__gt"], "bar",
+             "filterToParams sets correct param key and value if passed an GREATER_THAN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed an GREATER_THAN_OR_EQUAL_TO filter");
+        t.eq(params["foo__gte"], "bar",
+             "filterToParams sets correct param key and value if passed an GREATER_THAN_OR_EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.LIKE,
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed a LIKE filter");
+        t.eq(params["foo__ilike"], "bar",
+             "filterToParams sets correct param key and value if passed an LIKE filter");
+        // 4 tests
+            filters: [
+                new OpenLayers.Filter.Comparison({
+                    property: "foo",
+                    value: "bar"
+                    property: "foo2",
+                    value: "baz"
+             "filterToParams sets correct queryable param if passed an EQUAL_TO filter within a AND filter");
+             "filterToParams sets correct param key and value if passed an EQUAL_TO filter within a AND filter");
+        t.eq(params.queryable[1], "foo2",
+             "filterToParams sets correct queryable param if passed a LESS_THAN filter within a AND filter");
+        t.eq(params["foo2__lt"], "baz",
+             "filterToParams sets correct param key and value if passed a LESS_THAN filter within a AND filter");
+        // 2 tests
+        protocol = new OpenLayers.Protocol.HTTP({wildcarded: true});
+            property: "foo",
+            value: "bar"
+             "filterToParams sets correct queryable param if passed a LIKE filter (wildcarded true)");
+        t.eq(params["foo__ilike"], "%bar%",
+             "filterToParams sets correct param key and value if passed an LIKE filter (wildcarded true)");
+    function test_regex2value(t) {
+        t.plan(16);
+        // setup
+        var protocol = new OpenLayers.Protocol.HTTP();
+        var value;
+        // test
+        value = protocol.regex2value("foo");
+        t.eq(value, "foo", 'regex2value converts "foo" to "foo"');
+        value = protocol.regex2value("foo%");
+        t.eq(value, "foo\\%", 'regex2value converts "foo%" to "foo\\%"');
+        value = protocol.regex2value("foo.*");
+        t.eq(value, "foo%", 'regex2value converts "foo.*" to "foo%"');
+        value = protocol.regex2value("f.*oo.*");
+        t.eq(value, "f%oo%", 'regex2value converts "f.*oo.*" to "f%oo%"');
+        value = protocol.regex2value("foo.");
+        t.eq(value, "foo_", 'regex2value converts "foo." to "foo_"');
+        value = protocol.regex2value("f.oo.");
+        t.eq(value, "f_oo_", 'regex2value converts "f.oo." to "f_oo_"');
+        value = protocol.regex2value("f.oo.*");
+        t.eq(value, "f_oo%", 'regex2value converts "f.oo.*" to "f_oo%"');
+        value = protocol.regex2value("foo\\\\");
+        t.eq(value, "foo\\\\", 'regex2value converts "foo\\\\" to "foo\\\\"');
+        value = protocol.regex2value("foo\\.");
+        t.eq(value, "foo.", 'regex2value converts "foo\\." to "foo."');
+        value = protocol.regex2value("foo\\\\.");
+        t.eq(value, "foo\\\\_", 'regex2value converts "foo\\\\." to "foo\\\\_"');
+        value = protocol.regex2value("foo\\*");
+        t.eq(value, "foo*", 'regex2value converts "foo\\*" to "foo*"');
+        value = protocol.regex2value("foo\\\\*");
+        t.eq(value, "foo\\\\*", 'regex2value converts "foo\\\\*" to "foo\\\\*"');
+        value = protocol.regex2value("foo\\\\.*");
+        t.eq(value, "foo\\\\%", 'regex2value converts "foo\\\\.*" to "foo\\\\%"');
+        value = protocol.regex2value("fo\\.o.*");
+        t.eq(value, "fo.o%", 'regex2value converts from "fo\\.o.*" to "fo.o%"');
+        value = protocol.regex2value("fo.*o\\.");
+        t.eq(value, "fo%o.", 'regex2value converts from "fo.*o\\." to "to%o."');
+        value = protocol.regex2value("\\*\\..*.\\\\.*\\\\.%");
+        t.eq(value, "*.%_\\\\%\\\\_\\%",
+             'regex2value converts from "\\*\\..*.\\\\.*\\\\.%" ' +
+             'to "*.%_\\\\%\\\\_\\%"');
     function test_create(t) {
         t.plan(10);
         var protocol = new OpenLayers.Protocol.HTTP({
Modified: sandbox/tschaub/xdomain/tests/Protocol/Script.html
--- sandbox/tschaub/xdomain/tests/Protocol/Script.html	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/tests/Protocol/Script.html	2011-01-27 20:49:34 UTC (rev 11064)
@@ -92,25 +92,6 @@
             'response priv property set to what the createRequest method returns');
-    function test_read_bbox(t) {
-        t.plan(1);
-        var protocol = new OpenLayers.Protocol.Script();
-        var bounds = new OpenLayers.Bounds(1, 2, 3, 4);
-            value: bounds,
-            projection: "foo"
-        protocol.createRequest = function(url, params, callback) {
-            t.eq(params['bbox'].toString(), bounds.toArray().toString(),
-                'createRequest called with bbox filter in params');
-        var resp = protocol.read({filter: filter});
     function test_createRequest(t) {
         t.plan(3);
         var protocol = new OpenLayers.Protocol.Script({
Modified: sandbox/tschaub/xdomain/tests/list-tests.html
--- sandbox/tschaub/xdomain/tests/list-tests.html	2011-01-27 20:43:53 UTC (rev 11063)
+++ sandbox/tschaub/xdomain/tests/list-tests.html	2011-01-27 20:49:34 UTC (rev 11064)
@@ -168,7 +168,6 @@
     <li>Popup/FramedCloud.html</li>
     <li>Projection.html</li>
     <li>Protocol.html</li>
-    <li>Protocol/FilterSerializer.html</li>
     <li>Protocol/HTTP.html</li>
     <li>Protocol/Script.html</li>
     <li>Protocol/SQL.html</li>
More information about the Commits mailing list
