[OpenLayers-Commits] r12147 - trunk/openlayers/lib/OpenLayers/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Jul 3 03:33:25 EDT 2011
Author: ahocevar
Date: 2011-07-03 00:33:24 -0700 (Sun, 03 Jul 2011)
New Revision: 12147
   trunk/openlayers/lib/OpenLayers/Layer/MapGuide.js
   trunk/openlayers/lib/OpenLayers/Layer/MapServer.js
   trunk/openlayers/lib/OpenLayers/Layer/WMS.js
fixing error in comments. Non-functional change (closes #3387)
Modified: trunk/openlayers/lib/OpenLayers/Layer/MapGuide.js
--- trunk/openlayers/lib/OpenLayers/Layer/MapGuide.js	2011-06-30 15:15:28 UTC (rev 12146)
+++ trunk/openlayers/lib/OpenLayers/Layer/MapGuide.js	2011-07-03 07:33:24 UTC (rev 12147)
@@ -168,7 +168,7 @@
      *       groups to hide eg: 'cvc-xcv34,453-345-345sdf'
      *   - selectionXml - {String} A selection xml string Some server plumbing
      *       is required to read such a value.
-     * options - {Ojbect} Hashtable of extra options to tag onto the layer;
+     * options - {Object} Hashtable of extra options to tag onto the layer;
      *          will vary depending if tiled or untiled maps are being requested
     initialize: function(name, url, params, options) {
Modified: trunk/openlayers/lib/OpenLayers/Layer/MapServer.js
--- trunk/openlayers/lib/OpenLayers/Layer/MapServer.js	2011-06-30 15:15:28 UTC (rev 12146)
+++ trunk/openlayers/lib/OpenLayers/Layer/MapServer.js	2011-07-03 07:33:24 UTC (rev 12147)
@@ -36,7 +36,7 @@
      *       (e.g. http://www2.dmsolutions.ca/cgi-bin/mapserv)
      * params - {Object} An object with key/value pairs representing the
      *          GetMap query string parameters and parameter values.
         var newArguments = [];
Modified: trunk/openlayers/lib/OpenLayers/Layer/WMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/WMS.js	2011-06-30 15:15:28 UTC (rev 12146)
+++ trunk/openlayers/lib/OpenLayers/Layer/WMS.js	2011-07-03 07:33:24 UTC (rev 12147)
@@ -36,7 +36,7 @@
      * *Deprecated*. See http://trac.openlayers.org/wiki/SphericalMercator
      * for information on the replacement for this functionality.
      * {Boolean} Try to reproject this layer if its coordinate reference system
-     *           is different than that of the base layer.  Default is true.
+     *           is different than that of the base layer.  Default is false.
      *           Set this in the layer options.  Should be set to false in
      *           most cases.
@@ -114,7 +114,7 @@
      *                (e.g. http://wms.jpl.nasa.gov/wms.cgi)
-     * options - {Ojbect} Hashtable of extra options to tag onto the layer.
+     * options - {Object} Hashtable of extra options to tag onto the layer.
      *     These options include all properties listed above, plus the ones
      *     inherited from superclasses.
@@ -143,7 +143,7 @@
             // jpegs can never be transparent, so intelligently switch the
-            //  format, depending on teh browser's capabilities
+            //  format, depending on the browser's capabilities
             if (this.params.FORMAT == "image/jpeg") {
                 this.params.FORMAT = OpenLayers.Util.alphaHack() ? "image/gif"
        : "image/png";
More information about the Commits mailing list
