[OpenLayers-Commits] r12149 - in trunk/openlayers: lib/OpenLayers/Control lib/OpenLayers/Feature lib/OpenLayers/Format/WFST tests/Control tests/Format/WFST
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Jul 4 04:37:56 EDT 2011
Author: ahocevar
Date: 2011-07-04 01:37:55 -0700 (Mon, 04 Jul 2011)
New Revision: 12149
   trunk/openlayers/lib/OpenLayers/Control/ModifyFeature.js
   trunk/openlayers/lib/OpenLayers/Feature/Vector.js
   trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js
   trunk/openlayers/tests/Control/ModifyFeature.html
   trunk/openlayers/tests/Format/WFST/v1.html
adding a feature.modified property, making the ModifyFeature control set it and the WFST format check for it so only modified attributes and a modified geometry need to be included in an Update transaction. r=bartvde (closes #3400)
Modified: trunk/openlayers/lib/OpenLayers/Control/ModifyFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/ModifyFeature.js	2011-07-03 09:20:47 UTC (rev 12148)
+++ trunk/openlayers/lib/OpenLayers/Control/ModifyFeature.js	2011-07-04 08:37:55 UTC (rev 12149)
@@ -368,6 +368,11 @@
             this.dragControl.activate();
             this.onModificationStart(this.feature);
+        // keep track of geometry modifications
+        var modified = feature.modified;
+        if (feature.geometry && !(modified && modified.geometry)) {
+            this._originalGeometry = feature.geometry.clone();
@@ -539,6 +544,13 @@
         if(this.feature.state != OpenLayers.State.INSERT &&
            this.feature.state != OpenLayers.State.DELETE) {
             this.feature.state = OpenLayers.State.UPDATE;
+            if (this.modified && this._originalGeometry) {
+                var feature = this.feature;
+                feature.modified = OpenLayers.Util.extend(feature.modified, {
+                    geometry: this._originalGeometry
+                delete this._originalGeometry;
Modified: trunk/openlayers/lib/OpenLayers/Feature/Vector.js
--- trunk/openlayers/lib/OpenLayers/Feature/Vector.js	2011-07-03 09:20:47 UTC (rev 12148)
+++ trunk/openlayers/lib/OpenLayers/Feature/Vector.js	2011-07-04 08:37:55 UTC (rev 12149)
@@ -81,6 +81,42 @@
      * {String} rendering intent currently being used
     renderIntent: "default",
+     * APIProperty: modified
+     * {Object} An object with the originals of the geometry and attributes of
+     * the feature, if they were changed. Currently this property is only read
+     * by <OpenLayers.Format.WFST.v1>, and written by
+     * <OpenLayers.Control.ModifyFeature>, which sets the geometry property.
+     * Applications can set the originals of modified attributes in the
+     * attributes property. Note that applications have to check if this
+     * object and the attributes property is already created before using it.
+     * After a change made with ModifyFeature, this object could look like
+     * (code)
+     *     geometry: >Object
+     * (end)
+     * When an application has made changes to feature attributes, it could
+     * have set the attributes to something like this:
+     * (code)
+     *     attributes: {
+     *         myAttribute: "original"
+     * (end)
+     * Note that <OpenLayers.Format.WFST.v1> only checks for truthy values in
+     * *modified.geometry* and the attribute names in *modified.attributes*,
+     * but it is recommended to set the original values (and not just true) as
+     * attribute value, so applications could use this information to undo
+     * changes.
+    modified: null,
      * Constructor: OpenLayers.Feature.Vector
Modified: trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js	2011-07-03 09:20:47 UTC (rev 12148)
+++ trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js	2011-07-04 08:37:55 UTC (rev 12149)
@@ -172,9 +172,24 @@
      *     type - insert, update, or delete.
      * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>)} A list of features.
+     * features - {Array(<OpenLayers.Feature.Vector>)} A list of features. See
+     *     below for a more detailed description of the influence of the
+     *     feature's *modified* property.
      * options - {Object}
+     * feature.modified rules:
+     * If a feature has a modified property set, the following checks will be
+     * made before a feature's geometry or attribute is included in an Update
+     * transaction:
+     * - *modified* is not set at all: The geometry and all attributes will be
+     *     included.
+     * - *modified.geometry* is truthy: The geometry will be
+     *     included. If *modified.attributes* is not set, all attributes will
+     *     be included.
+     * - *modified.attributes* is set: Only the attributes with a truthy value
+     *     in *modified.attributes* will be included. If *modified.geometry*
+     *     is not set, the geometry will not be included.
      * Returns:
      * {String} A serialized WFS transaction.
@@ -276,7 +291,8 @@
                 // add in geometry
-                if (this.geometryName !== null) {
+                if (this.geometryName !== null && (!modified || modified.geometry)) {
                     this.srsName = this.getSrsName(feature);
                     this.writeNode(
                         "Property", {name: this.geometryName, value: feature.geometry}, node
@@ -285,7 +301,9 @@
                 // add in attributes
                 for(var key in feature.attributes) {
-                    if(feature.attributes[key] !== undefined) {
+                    if(feature.attributes[key] !== undefined &&
+                                (!modified || !modified.attributes ||
+                                (modified.attributes && modified.attributes[key]))) {
                         this.writeNode(
                             "Property", {name: key, value: feature.attributes[key]}, node
Modified: trunk/openlayers/tests/Control/ModifyFeature.html
--- trunk/openlayers/tests/Control/ModifyFeature.html	2011-07-03 09:20:47 UTC (rev 12148)
+++ trunk/openlayers/tests/Control/ModifyFeature.html	2011-07-04 08:37:55 UTC (rev 12149)
@@ -736,9 +736,31 @@
         map.destroy();
+    function test_setFeatureState(t) {
+        t.plan(4);
+        var map = new OpenLayers.Map("map");
+        var layer = new OpenLayers.Layer.Vector("vector", {isBaseLayer: true});
+        map.addLayer(layer);
+        var feature = new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(1,2));
+        layer.addFeatures([feature]);
+        var control = new OpenLayers.Control.ModifyFeature(layer, {standalone: true});
+        map.addControl(control);
+        control.selectFeature(feature);
+        var originalGeometry = feature.geometry;
+        t.ok(control._originalGeometry, "original geometry stored for later use in setFeatureState");
+        feature.geometry = new OpenLayers.Geometry.Point(2,3);
+        control.modified = true;
+        control.setFeatureState();
+        t.eq(feature.state, OpenLayers.State.UPDATE, "feature state set to UPDATE");
+        t.geom_eq(feature.modified.geometry, originalGeometry, "original geometry stored on the modified property");
+        t.eq(control._originalGeometry, undefined, "original geometry deleted once it is set on the modified property");
     </script>
 </head>
 <body>
Modified: trunk/openlayers/tests/Format/WFST/v1.html
--- trunk/openlayers/tests/Format/WFST/v1.html	2011-07-03 09:20:47 UTC (rev 12148)
+++ trunk/openlayers/tests/Format/WFST/v1.html	2011-07-04 08:37:55 UTC (rev 12149)
@@ -45,7 +45,7 @@
         deleteFeature.state = OpenLayers.State.DELETE;
         deleteFeature.fid = "fid.37";
-        t.plan(5);
+        t.plan(7);
         var snippets = {
             "GetFeature": {maxFeatures: 1, outputFormat: 'json'},
             "Transaction": null,
@@ -61,6 +61,19 @@
             var got = format.writers["wfs"][snippet].apply(format, [arg]);
             t.xml_eq(got, expected, snippet + " request created correctly");
+        updateFeature.modified = {geometry: updateFeature.geometry.clone()};
+        updateFeature.geometry = new OpenLayers.Geometry.Point(2,3);
+        var expected = readXML("UpdateModified");
+        var got = format.writers["wfs"]["Update"].apply(format, [updateFeature]);
+        t.xml_eq(got, expected, "Update request for feature with modified geometry created correctly");
+        updateFeature.modified.attributes = {foo: "bar"};
+        updateFeature.attributes.foo = "baz";
+        delete updateFeature.modified.geometry;
+        var expected = readXML("UpdateModifiedNoGeometry");
+        t.xml_eq(got, expected, "Update request for feature with no modified geometry but modified attributes created correctly");
     function test_writeNative(t) {
@@ -264,6 +277,39 @@
     </ogc:Filter>
 </wfs:Update>
 --></div>
+<div id="UpdateModified"><!--
+<wfs:Update xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
+    <wfs:Property>
+        <wfs:Name>the_geom</wfs:Name>
+        <wfs:Value>
+            <gml:Point xmlns:gml="http://www.opengis.net/gml">
+                <gml:coordinates decimal="." cs="," ts=" ">2,3</gml:coordinates>
+            </gml:Point>
+        </wfs:Value>
+    </wfs:Property>
+    <wfs:Property>
+        <wfs:Name>foo</wfs:Name>
+        <wfs:Value>bar</wfs:Value>
+    </wfs:Property>
+    <wfs:Property>
+        <wfs:Name>nul</wfs:Name>
+    </wfs:Property>
+    <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
+        <ogc:FeatureId fid="fid.42"/>
+    </ogc:Filter>
+</wfs:Update>
+--></div>
+<div id="UpdateModifiedNoGeometry"><!--
+    <wfs:Property>
+        <wfs:Value>baz</wfs:Value>
+    </wfs:Property>
+    </ogc:Filter>
+</wfs:Update>
+--></div>
 <div id="Delete"><!--
 <wfs:Delete xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
More information about the Commits mailing list
