[OpenLayers-Commits] r12161 - in sandbox/august/trunk: . lib lib/OpenLayers/Format lib/OpenLayers/Format/WFSTWithLock playground/wmts
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Jul 8 20:05:05 EDT 2011
Author: augusttown
Date: 2011-07-08 17:05:04 -0700 (Fri, 08 Jul 2011)
New Revision: 12161
   sandbox/august/trunk/OpenLayers.js
   sandbox/august/trunk/lib/OpenLayers.js
   sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock.js
   sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock/v1.js
   sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock/v1_1_0.js
   sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857.html
Add format VersionedOGC into the list of lib/OpenLayers.js
Add "@required..." reference in WFSTWithLock.js and WFSTWithLock/v.*.js for build process
Modified: sandbox/august/trunk/OpenLayers.js
--- sandbox/august/trunk/OpenLayers.js	2011-07-07 16:41:02 UTC (rev 12160)
+++ sandbox/august/trunk/OpenLayers.js	2011-07-09 00:05:04 UTC (rev 12161)
@@ -2,7 +2,7 @@
   OpenLayers.js -- OpenLayers Map Viewer Library
-  Copyright 2005-2011 OpenLayers Contributors, released under the Clear BSD
+  Copyright 2005-2011 OpenLayers Contributors, released under the FreeBSD
   license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
   for the full text of the license.
@@ -132,7 +132,7 @@
 OpenLayers.Util.extend(C.prototype,o);}};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
 var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty("toString")){destination.toString=source.toString;}}
 return destination;};OpenLayers.Protocol=OpenLayers.Class({format:null,options:null,autoDestroy:true,defaultFilter:null,initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;},mergeWithDefaultFilter:function(filter){var merged;if(filter&&this.defaultFilter){merged=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.defaultFilter,filter]});}else{merged=filter||this.defaultFilter||undefined;}
-return merged;},destroy:function(){this.options=null;this.format=null;},read:function(options){options=options||{};options.filter=this.mergeWithDefaultFilter(options.filter);},create:function(){},update:function(){},"delete":function(){},commit:function(){},abort:function(response){},createCallback:function(method,response,options){return OpenLayers.Function.bind(function(){method.apply(this,[response,options]);},this);},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:true,features:null,reqFeatures:null,priv:null,initialize:function(options){OpenLayers.Util.extend(this,options);},success:function(){return this.code>0;},CLASS_NAME:"OpenLayers.Protocol.Response"});OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Protocol.SQL=OpenLayers.Class(OpenLayers.Protocol,{databaseName:'ol',tableName:"ol_vector_features",postReadFiltering:true,initialize:function(options){OpenLayers.
 Protocol.prototype.initialize.apply(this,[options]);},destroy:function(){OpenLayers.Protocol.prototype.destroy.apply(this);},supported:function(){return false;},evaluateFilter:function(feature,filter){return filter&&this.postReadFiltering?filter.evaluate(feature):true;},CLASS_NAME:"OpenLayers.Protocol.SQL"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(error){alert(error);},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){var scripts=document.getElementsByTagName("script");for(var i=0,len=scripts.length;i<len;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Lang={code:null,defaultCode:"en",ge
 tCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
+return merged;},destroy:function(){this.options=null;this.format=null;},read:function(options){options=options||{};options.filter=this.mergeWithDefaultFilter(options.filter);},create:function(){},update:function(){},"delete":function(){},commit:function(){},abort:function(response){},createCallback:function(method,response,options){return OpenLayers.Function.bind(function(){method.apply(this,[response,options]);},this);},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:true,features:null,reqFeatures:null,priv:null,error:null,initialize:function(options){OpenLayers.Util.extend(this,options);},success:function(){return this.code>0;},CLASS_NAME:"OpenLayers.Protocol.Response"});OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Protocol.SQL=OpenLayers.Class(OpenLayers.Protocol,{databaseName:'ol',tableName:"ol_vector_features",postReadFiltering:true,initialize:function(options){
 OpenLayers.Protocol.prototype.initialize.apply(this,[options]);},destroy:function(){OpenLayers.Protocol.prototype.destroy.apply(this);},supported:function(){return false;},evaluateFilter:function(feature,filter){return filter&&this.postReadFiltering?filter.evaluate(feature):true;},CLASS_NAME:"OpenLayers.Protocol.SQL"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(error){alert(error);},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){var scripts=document.getElementsByTagName("script");for(var i=0,len=scripts.length;i<len;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Lang={code:null,defaultC
 ode:"en",getCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
 return OpenLayers.Lang.code;},setCode:function(code){var lang;if(!code){code=(OpenLayers.BROWSER_NAME=="msie")?navigator.userLanguage:navigator.language;}
 var parts=code.split('-');parts[0]=parts[0].toLowerCase();if(typeof OpenLayers.Lang[parts[0]]=="object"){lang=parts[0];}
 if(parts[1]){var testLang=parts[0]+'-'+parts[1].toUpperCase();if(typeof OpenLayers.Lang[testLang]=="object"){lang=testLang;}}
@@ -209,7 +209,7 @@
 return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.getElement=function(){var elements=[];for(var i=0,len=arguments.length;i<len;i++){var element=arguments[i];if(typeof element=='string'){element=document.getElementById(element);}
 if(arguments.length==1){return element;}
 elements.push(element);}
-return elements;};OpenLayers.Util.isElement=function(o){return!!(o&&o.nodeType===1);};if(typeof window.$==="undefined"){window.$=OpenLayers.Util.getElement;}
+return elements;};OpenLayers.Util.isElement=function(o){return!!(o&&o.nodeType===1);};OpenLayers.Util.isArray=function(a){return(Object.prototype.toString.call(a)==='[object Array]');};if(typeof window.$==="undefined"){window.$=OpenLayers.Util.getElement;}
 OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
 return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){if(typeof array.indexOf=="function"){return array.indexOf(obj);}else{for(var i=0,len=array.length;i<len;i++){if(array[i]==obj){return i;}}
 return-1;}};OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id;}
@@ -226,7 +226,7 @@
 OpenLayers.Util.modifyDOMElement(image,id,px,sz,position,border,null,opacity);if(delayDisplay){image.style.display="none";OpenLayers.Event.observe(image,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,image));OpenLayers.Event.observe(image,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,image));}
 image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
 return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||(this.map&&this.viewRequestID==this.map.viewRequestID)){this.style.display="";}
-OpenLayers.Element.removeClass(this,"olImageLoadError");};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){var urls=this.urls;if(urls&&urls instanceof Array&&urls.length>1){var src=this.src.toString();var current_url,k;for(k=0;current_url=urls[k];k++){if(src.indexOf(current_url)!=-1){break;}}
+OpenLayers.Element.removeClass(this,"olImageLoadError");};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){var urls=this.urls;if(urls&&OpenLayers.Util.isArray(urls)&&urls.length>1){var src=this.src.toString();var current_url,k;for(k=0;current_url=urls[k];k++){if(src.indexOf(current_url)!=-1){break;}}
 var guess=Math.floor(urls.length*Math.random());var new_url=urls[guess];k=0;while(new_url==current_url&&k++<4){guess=Math.floor(urls.length*Math.random());new_url=urls[guess];}
 this.src=src.replace(current_url,new_url);}else{this.src=this.src;}}else{OpenLayers.Element.addClass(this,"olImageLoadError");}
 this.style.display="";};OpenLayers.Util.alphaHackNeeded=null;OpenLayers.Util.alphaHack=function(){if(OpenLayers.Util.alphaHackNeeded==null){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
@@ -332,13 +332,13 @@
 return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){if(!this.popup){var anchor=(this.marker)?this.marker.icon:null;var popupClass=this.popupClass?this.popupClass:OpenLayers.Popup.AnchoredBubble;this.popup=new popupClass(this.id+"_popup",this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
 if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
 this.popup.feature=this;}
-return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry?geometry:null;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
+return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",modified:null,initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry?geometry:null;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
 this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
-this.geometry=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
+this.geometry=null;this.modified=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
 return onScreen;},getVisibility:function(){return!(this.style&&this.style.display=='none'||!this.layer||this.layer&&this.layer.styleMap&&this.layer.styleMap.createSymbolizer(this,this.renderIntent).display=='none'||this.layer&&!this.layer.getVisibility());},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
 return atPoint;},destroyPopup:function(){},move:function(location){if(!this.layer||!this.geometry.move){return undefined;}
 var pixel;if(location.CLASS_NAME=="OpenLayers.LonLat"){pixel=this.layer.getViewPortPxFromLonLat(location);}else{pixel=location;}
-var lastPixel=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat());var res=this.layer.map.getResolution();this.geometry.move(res*(pixel.x-lastPixel.x),res*(lastPixel.y-pixel.y));this.layer.drawFeature(this);return lastPixel;},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fil
 lOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit"},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},'temporary':{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,strokeLinecap:"round",strokeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvent
 s:"visiblePainted",cursor:"inherit"},'delete':{display:"none"}};OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
+var lastPixel=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat());var res=this.layer.map.getResolution();this.geometry.move(res*(pixel.x-lastPixel.x),res*(lastPixel.y-pixel.y));this.layer.drawFeature(this);return lastPixel;},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fil
 s:"visiblePainted",cursor:"inherit"},'delete':{display:"none"}};OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;wkt=wkt.replace(/[\n\r]/g," ");var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
 if(this.internalProjection&&this.externalProjection){if(features&&features.CLASS_NAME=="OpenLayers.Feature.Vector"){features.geometry.transform(this.externalProjection,this.internalProjection);}else if(features&&type!="geometrycollection"&&typeof features=="object"){for(var i=0,len=features.length;i<len;i++){var component=features[i];component.geometry.transform(this.externalProjection,this.internalProjection);}}}}
 return features;},write:function(features){var collection,geometry,type,data,isCollection;if(features.constructor==Array){collection=features;isCollection=true;}else{collection=[features];isCollection=false;}
 var pieces=[];if(isCollection){pieces.push('GEOMETRYCOLLECTION(');}
@@ -373,10 +373,10 @@
 feature.state=state;return feature;},extractFidFromField:function(field){if(!field.match(this.fidRegExp)&&this.typeOfFid=="number"){field=parseFloat(field);}
 return field;},create:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=this.createOrUpdate(features);resp.requestType="create";if(options&&options.callback){options.callback.call(options.scope,resp);}
 return resp;},update:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=this.createOrUpdate(features);resp.requestType="update";if(options&&options.callback){options.callback.call(options.scope,resp);}
-return resp;},createOrUpdate:function(features){if(!(features instanceof Array)){features=[features];}
+return resp;},createOrUpdate:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 var i,len=features.length,feature;var insertedFeatures=new Array(len);for(i=0;i<len;i++){feature=features[i];var params=this.freezeFeature(feature);this.db.execute("REPLACE INTO "+this.tableName+" (fid, geometry, properties, state)"+" VALUES (?, ?, ?, ?)",params);var clone=feature.clone();clone.fid=this.extractFidFromField(params[0]);insertedFeatures[i]=clone;}
 return new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,features:insertedFeatures,reqFeatures:features});},freezeFeature:function(feature){feature.fid=feature.fid!=null?""+feature.fid:OpenLayers.Util.createUniqueID(this.FID_PREFIX);var geometry=feature.geometry!=null?feature.geometry.toString():this.NULL_GEOMETRY;var properties=this.jsonParser.write(feature.attributes);var state=this.getFeatureStateForFreeze(feature);return[feature.fid,geometry,properties,state];},getFeatureStateForFreeze:function(feature){var state;if(!this.saveFeatureState){state=this.NULL_FEATURE_STATE;}else if(this.createdOffline(feature)){state=OpenLayers.State.INSERT;}else{state=feature.state;}
-return state;},"delete":function(features,options){if(!(features instanceof Array)){features=[features];}
+return state;},"delete":function(features,options){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 options=OpenLayers.Util.applyDefaults(options,this.options);var i,len,feature;for(i=0,len=features.length;i<len;i++){feature=features[i];if(this.saveFeatureState&&!this.createdOffline(feature)){var toDelete=feature.clone();toDelete.fid=feature.fid;if(toDelete.geometry){toDelete.geometry.destroy();toDelete.geometry=null;}
 toDelete.state=feature.state;this.createOrUpdate(toDelete);}else{this.db.execute("DELETE FROM "+this.tableName+" WHERE fid = ?",[feature.fid]);}}
 var resp=new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,requestType:"delete",reqFeatures:features});if(options&&options.callback){options.callback.call(options.scope,resp);}
@@ -426,10 +426,11 @@
 return sibling||null;},lookupNamespaceURI:function(node,prefix){var uri=null;if(node){if(node.lookupNamespaceURI){uri=node.lookupNamespaceURI(prefix);}else{outer:switch(node.nodeType){case 1:if(node.namespaceURI!==null&&node.prefix===prefix){uri=node.namespaceURI;break outer;}
 var len=node.attributes.length;if(len){var attr;for(var i=0;i<len;++i){attr=node.attributes[i];if(attr.prefix==="xmlns"&&attr.name==="xmlns:"+prefix){uri=attr.value||null;break outer;}else if(attr.name==="xmlns"&&prefix===null){uri=attr.value||null;break outer;}}}
 uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;case 2:uri=this.lookupNamespaceURI(node.ownerElement,prefix);break outer;case 9:uri=this.lookupNamespaceURI(node.documentElement,prefix);break outer;case 6:case 12:case 10:case 11:break outer;default:uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;}}}
-return uri;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
+return uri;},getXMLDoc:function(){if(!OpenLayers.Format.XML.document&&!this.xmldom){if(document.implementation&&document.implementation.createDocument){OpenLayers.Format.XML.document=document.implementation.createDocument("","",null);}else if(!this.xmldom&&window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}}
+return OpenLayers.Format.XML.document||this.xmldom;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Format.XML.document=null;OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
 return this.bounds;},calculateBounds:function(){},distanceTo:function(geometry,options){},getVertices:function(nodes){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
 return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},getCentroid:function(){return null;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(wkt){var format=arguments.callee.format;if(!format){format=new OpenLayers.Format.WKT();arguments.callee.format=format;}
-var geom;var result=format.read(wkt);if(result instanceof OpenLayers.Feature.Vector){geom=result.geometry;}else if(result instanceof Array){var len=result.length;var components=new Array(len);for(var i=0;i<len;++i){components[i]=result[i].geometry;}
+var geom;var result=format.read(wkt);if(result instanceof OpenLayers.Feature.Vector){geom=result.geometry;}else if(OpenLayers.Util.isArray(result)){var len=result.length;var components=new Array(len);for(var i=0;i<len;++i){components[i]=result[i].geometry;}
 geom=new OpenLayers.Geometry.Collection(components);}
 return geom;};OpenLayers.Geometry.segmentsIntersect=function(seg1,seg2,options){var point=options&&options.point;var tolerance=options&&options.tolerance;var intersection=false;var x11_21=seg1.x1-seg2.x1;var y11_21=seg1.y1-seg2.y1;var x12_11=seg1.x2-seg1.x1;var y12_11=seg1.y2-seg1.y1;var y22_21=seg2.y2-seg2.y1;var x22_21=seg2.x2-seg2.x1;var d=(y22_21*x12_11)-(x22_21*y12_11);var n1=(x22_21*y11_21)-(y22_21*x11_21);var n2=(x12_11*y11_21)-(y12_11*x11_21);if(d==0){if(n1==0&&n2==0){intersection=true;}}else{var along1=n1/d;var along2=n2/d;if(along1>=0&&along1<=1&&along2>=0&&along2<=1){if(!point){intersection=true;}else{var x=seg1.x1+(along1*x12_11);var y=seg1.y1+(along1*y12_11);intersection=new OpenLayers.Geometry.Point(x,y);}}}
 if(tolerance){var dist;if(intersection){if(point){var segs=[seg1,seg2];var seg,x,y;outer:for(var i=0;i<2;++i){seg=segs[i];for(var j=1;j<3;++j){x=seg["x"+j];y=seg["y"+j];dist=Math.sqrt(Math.pow(x-intersection.x,2)+
@@ -444,11 +445,12 @@
 return this;},getVertices:function(nodes){return[this];},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments);},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0,len=this.components.length;i<len;i++){geometry.addComponent(this.components[i].clone());}
 OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0,len=this.components.length;i<len;i++){strings.push(this.components[i].toShortString());}
 return strings.join(",");},calculateBounds:function(){this.bounds=null;var bounds=new OpenLayers.Bounds();var components=this.components;if(components){for(var i=0,len=components.length;i<len;i++){bounds.extend(components[i].getBounds());}}
-if(bounds.left!=null&&bounds.bottom!=null&&bounds.right!=null&&bounds.top!=null){this.setBounds(bounds);}},addComponents:function(components){if(!(components instanceof Array)){components=[components];}
+if(bounds.left!=null&&bounds.bottom!=null&&bounds.right!=null&&bounds.top!=null){this.setBounds(bounds);}},addComponents:function(components){if(!(OpenLayers.Util.isArray(components))){components=[components];}
 for(var i=0,len=components.length;i<len;i++){this.addComponent(components[i]);}},addComponent:function(component,index){var added=false;if(component){if(this.componentTypes==null||(OpenLayers.Util.indexOf(this.componentTypes,component.CLASS_NAME)>-1)){if(index!=null&&(index<this.components.length)){var components1=this.components.slice(0,index);var components2=this.components.slice(index,this.components.length);components1.push(component);this.components=components1.concat(components2);}else{this.components.push(component);}
 component.parent=this;this.clearBounds();added=true;}}
-return added;},removeComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=components.length-1;i>=0;--i){this.removeComponent(components[i]);}},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();},getLength:function(){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getLength();}
+return added;},removeComponents:function(components){var removed=false;if(!(OpenLayers.Util.isArray(components))){components=[components];}
+for(var i=components.length-1;i>=0;--i){removed=this.removeComponent(components[i])||removed;}
+return removed;},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();return true;},getLength:function(){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getLength();}
 return length;},getArea:function(){var area=0.0;for(var i=0,len=this.components.length;i<len;i++){area+=this.components[i].getArea();}
 return area;},getGeodesicArea:function(projection){var area=0.0;for(var i=0,len=this.components.length;i<len;i++){area+=this.components[i].getGeodesicArea(projection);}
 return area;},getCentroid:function(weighted){if(!weighted){return this.components.length&&this.components[0].getCentroid();}
@@ -462,7 +464,7 @@
 return new OpenLayers.Geometry.Point(xSum/areaSum,ySum/areaSum);},getGeodesicLength:function(projection){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getGeodesicLength(projection);}
 return length;},move:function(x,y){for(var i=0,len=this.components.length;i<len;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length;++i){this.components[i].resize(scale,origin,ratio);}
 return this;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var result,best,distance;var min=Number.POSITIVE_INFINITY;for(var i=0,len=this.components.length;i<len;++i){result=this.components[i].distanceTo(geometry,options);distance=details?result.distance:result;if(distance<min){min=distance;best=result;if(min==0){break;}}}
-return best;},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(geometry.components instanceof Array)||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0,len=this.components.length;i<len;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
+return best;},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(OpenLayers.Util.isArray(geometry.components))||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0,len=this.components.length;i<len;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
 return equivalent;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len;i++){var component=this.components[i];component.transform(source,dest);}
 this.bounds=null;}
 return this;},intersects:function(geometry){var intersect=false;for(var i=0,len=this.components.length;i<len;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
@@ -470,7 +472,8 @@
 return vertices;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments);},getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1,len=this.components.length;i<len;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
 return length;},getGeodesicLength:function(projection){var geom=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){geom=this.clone().transform(projection,gg);}}
 var length=0.0;if(geom.components&&(geom.components.length>1)){var p1,p2;for(var i=1,len=geom.components.length;i<len;i++){p1=geom.components[i-1];p2=geom.components[i];length+=OpenLayers.Util.distVincenty({lon:p1.x,lat:p1.y},{lon:p2.x,lat:p2.y});}}
-return length*1000;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){if(this.components&&(this.components.length>2)){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
+return length*1000;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){var removed=this.components&&(this.components.length>2);if(removed){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}
+return removed;},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
 var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0,len=segs1.length;i<len;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0,jlen=segs2.length;j<jlen;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
 if(seg2.x2<seg1x1){continue;}
 seg2y1=seg2.y1;seg2y2=seg2.y2;if(Math.min(seg2y1,seg2y2)>Math.max(seg1y1,seg1y2)){continue;}
@@ -504,7 +507,8 @@
 douglasPeuckerReduction(points,firstPoint,lastPoint,tolerance);var returnPoints=[];pointIndexsToKeep.sort(compareNumbers);for(var index=0;index<pointIndexsToKeep.length;index++){returnPoints.push(points[pointIndexsToKeep[index]]);}
 return new OpenLayers.Geometry.LineString(returnPoints);}
 else{return this;}},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
-var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){if(this.components.length>3){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}},move:function(x,y){for(var i=0,len=this.components.length;i<len-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].resize(scale,origin,ratio);}
+var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){var removed=this.components&&(this.components.length>3);if(removed){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}
+return removed;},move:function(x,y){for(var i=0,len=this.components.length;i<len-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].resize(scale,origin,ratio);}
 return this;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len-1;i++){var component=this.components[i];component.transform(source,dest);}
 this.bounds=null;}
 return this;},getCentroid:function(){if(this.components&&(this.components.length>2)){var sumX=0.0;var sumY=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sumX+=(b.x+c.x)*(b.x*c.y-c.x*b.y);sumY+=(b.y+c.y)*(b.x*c.y-c.x*b.y);}
@@ -682,7 +686,7 @@
 attributes[key]=ed;}
 var simpleDataNodes=node.getElementsByTagName("SimpleData");for(i=0,len=simpleDataNodes.length;i<len;i++){var ed={};data=simpleDataNodes[i];key=data.getAttribute("name");ed['value']=this.getChildValue(data);ed['displayName']=key;attributes[key]=ed;}
 return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
-return value;},write:function(features){if(!(features instanceof Array)){features=[features];}
+return value;},write:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0,len=features.length;i<len;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
 kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folder=this.createElementNS(this.kmlns,"Folder");if(this.foldersName){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);folder.appendChild(folderName);}
 if(this.foldersDesc){var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);folder.appendChild(folderDesc);}
@@ -740,7 +744,7 @@
 if(beginPoint!==null&&endPoint!==null){return new OpenLayers.Bounds(parseFloat(beginPoint[0]),parseFloat(beginPoint[1]),parseFloat(endPoint[0]),parseFloat(endPoint[1]));}}},parseAttributes:function(node){var attributes={};var childNode=node.firstChild;var children,i,child,grandchildren,grandchild,name,value;while(childNode){if(childNode.nodeType==1){children=childNode.childNodes;for(i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1){grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}else{attributes[child.nodeName.split(":").pop()]=null;}}}
 break;}
 childNode=childNode.nextSibling;}
-return attributes;},write:function(features){if(!(features instanceof Array)){features=[features];}
+return attributes;},write:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 var gml=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName);for(var i=0;i<features.length;i++){gml.appendChild(this.createFeatureXML(features[i]));}
 return OpenLayers.Format.XML.prototype.write.apply(this,[gml]);},createFeatureXML:function(feature){var geometry=feature.geometry;var geometryNode=this.buildGeometryNode(geometry);var geomContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
 this.geometryName);geomContainer.appendChild(geometryNode);var featureNode=this.createElementNS(this.gmlns,"gml:"+this.featureName);var featureContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
@@ -753,11 +757,13 @@
 return gml;},multipolygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPolygon");var polys=geometry.components;var polyMember,polyGeom;for(var i=0;i<polys.length;++i){polyMember=this.createElementNS(this.gmlns,"gml:polygonMember");polyGeom=this.buildGeometry.polygon.apply(this,[polys[i]]);polyMember.appendChild(polyGeom);gml.appendChild(polyMember);}
 return gml;},bounds:function(bounds){var gml=this.createElementNS(this.gmlns,"gml:Box");gml.appendChild(this.buildCoordinatesNode(bounds));return gml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.gmlns,"gml:coordinates");coordinatesNode.setAttribute("decimal",".");coordinatesNode.setAttribute("cs",",");coordinatesNode.setAttribute("ts"," ");var parts=[];if(geometry instanceof OpenLayers.Bounds){parts.push(geometry.left+","+geometry.bottom);parts.push(geometry.right+","+geometry.top);}else{var points=(geometry.components)?geometry.components:[geometry];for(var i=0;i<points.length;i++){parts.push(points[i].x+","+points[i].y);}}
 var txtNode=this.createTextNode(parts.join(" "));coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.GML"});if(!OpenLayers.Format.GML){OpenLayers.Format.GML={};}
-OpenLayers.Format.GML.Base=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs"},defaultPrefix:"gml",schemaLocation:null,featureType:null,featureNS:null,geometryName:"geometry",extractAttributes:true,srsName:null,xy:true,geometryTypes:null,singleFeatureType:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.setGeometryTypes();if(options&&options.featureNS){this.setNamespace("feature",options.featureNS);}
+OpenLayers.Format.GML.Base=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs"},defaultPrefix:"gml",schemaLocation:null,featureType:null,featureNS:null,geometryName:"geometry",extractAttributes:true,srsName:null,xy:true,geometryTypes:null,singleFeatureType:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),featureMember:(/^(.*:)?featureMembers?$/)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.setGeometryTypes();if(options&&options.featureNS){this.setNamespace("feature",options.featureNS);}
 this.singleFeatureType=!options||(typeof options.featureType==="string");},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
-var features=[];this.readNode(data,{features:features});if(features.length==0){var elements=this.getElementsByTagNameNS(data,this.namespaces.gml,"featureMember");if(elements.length){for(var i=0,len=elements.length;i<len;++i){this.readNode(elements[i],{features:features});}}else{var elements=this.getElementsByTagNameNS(data,this.namespaces.gml,"featureMembers");if(elements.length){this.readNode(elements[0],{features:features});}}}
-return features;},readers:{"gml":{"featureMember":function(node,obj){this.readChildNodes(node,obj);},"featureMembers":function(node,obj){this.readChildNodes(node,obj);},"name":function(node,obj){obj.name=this.getChildValue(node);},"boundedBy":function(node,obj){var container={};this.readChildNodes(node,container);if(container.components&&container.components.length>0){obj.bounds=container.components[0];}},"Point":function(node,container){var obj={points:[]};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
+var features=[];this.readNode(data,{features:features},true);if(features.length==0){var elements=this.getElementsByTagNameNS(data,this.namespaces.gml,"featureMember");if(elements.length){for(var i=0,len=elements.length;i<len;++i){this.readNode(elements[i],{features:features},true);}}else{var elements=this.getElementsByTagNameNS(data,this.namespaces.gml,"featureMembers");if(elements.length){this.readNode(elements[0],{features:features},true);}}}
+return features;},readNode:function(node,obj,first){if(first===true&&this.autoConfig===true){this.featureType=null;delete this.namespaceAlias[this.featureNS];delete this.namespaces["feature"];this.featureNS=null;}
+if(!this.featureNS&&(!(node.prefix in this.namespaces)&&node.parentNode.namespaceURI==this.namespaces["gml"]&&this.regExes.featureMember.test(node.parentNode.nodeName))){this.featureType=node.nodeName.split(":").pop();this.setNamespace("feature",node.namespaceURI);this.featureNS=node.namespaceURI;this.autoConfig=true;}
+return OpenLayers.Format.XML.prototype.readNode.apply(this,[node,obj]);},readers:{"gml":{"featureMember":function(node,obj){this.readChildNodes(node,obj);},"featureMembers":function(node,obj){this.readChildNodes(node,obj);},"name":function(node,obj){obj.name=this.getChildValue(node);},"boundedBy":function(node,obj){var container={};this.readChildNodes(node,container);if(container.components&&container.components.length>0){obj.bounds=container.components[0];}},"Point":function(node,container){var obj={points:[]};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
 container.components.push(obj.points[0]);},"coordinates":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);var coords;var numPoints=pointList.length;var points=new Array(numPoints);for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");if(this.xy){points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{points[i]=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
 obj.points=points;},"coord":function(node,obj){var coord={};this.readChildNodes(node,coord);if(!obj.points){obj.points=[];}
 obj.points.push(new OpenLayers.Geometry.Point(coord.x,coord.y,coord.z));},"X":function(node,coord){coord.x=this.getChildValue(node);},"Y":function(node,coord){coord.y=this.getChildValue(node);},"Z":function(node,coord){coord.z=this.getChildValue(node);},"MultiPoint":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.MultiPoint(obj.components)];},"pointMember":function(node,obj){this.readChildNodes(node,obj);},"LineString":function(node,container){var obj={};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
@@ -768,7 +774,8 @@
 var fid=node.getAttribute("fid")||this.getAttributeNS(node,this.namespaces["gml"],"id");if(fid){feature.fid=fid;}
 if(this.internalProjection&&this.externalProjection&&feature.geometry){feature.geometry.transform(this.externalProjection,this.internalProjection);}
 if(container.bounds){feature.bounds=container.bounds;}
-obj.features.push(feature);},"_geometry":function(node,obj){this.readChildNodes(node,obj);},"_attribute":function(node,obj){var local=node.localName||node.nodeName.split(":").pop();var value=this.getChildValue(node);obj.attributes[local]=value;}},"wfs":{"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);}}},write:function(features){var name;if(features instanceof Array){name="featureMembers";}else{name="featureMember";}
+obj.features.push(feature);},"_geometry":function(node,obj){if(!this.geometryName){this.geometryName=node.nodeName.split(":").pop();}
+this.readChildNodes(node,obj);},"_attribute":function(node,obj){var local=node.localName||node.nodeName.split(":").pop();var value=this.getChildValue(node);obj.attributes[local]=value;}},"wfs":{"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);}}},write:function(features){var name;if(OpenLayers.Util.isArray(features)){name="featureMembers";}else{name="featureMember";}
 var root=this.writeNode("gml:"+name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":{"featureMember":function(feature){var node=this.createElementNSPlus("gml:featureMember");this.writeNode("feature:_typeName",feature,node);return node;},"MultiPoint":function(geometry){var node=this.createElementNSPlus("gml:MultiPoint");for(var i=0;i<geometry.components.length;++i){this.writeNode("pointMember",geometry.components[i],node);}
 return node;},"pointMember":function(geometry){var node=this.createElementNSPlus("gml:pointMember");this.writeNode("Point",geometry,node);return node;},"MultiLineString":function(geometry){var node=this.createElementNSPlus("gml:MultiLineString");for(var i=0;i<geometry.components.length;++i){this.writeNode("lineStringMember",geometry.components[i],node);}
 return node;},"lineStringMember":function(geometry){var node=this.createElementNSPlus("gml:lineStringMember");this.writeNode("LineString",geometry,node);return node;},"MultiPolygon":function(geometry){var node=this.createElementNSPlus("gml:MultiPolygon");for(var i=0;i<geometry.components.length;++i){this.writeNode("polygonMember",geometry.components[i],node);}
@@ -779,7 +786,7 @@
 var node=this.createElementNSPlus("feature:"+this.geometryName);var type=this.geometryTypes[geometry.CLASS_NAME];var child=this.writeNode("gml:"+type,geometry,node);if(this.srsName){child.setAttribute("srsName",this.srsName);}
 return node;},"_attribute":function(obj){return this.createElementNSPlus("feature:"+obj.name,{value:obj.value});}},"wfs":{"FeatureCollection":function(features){var node=this.createElementNSPlus("wfs:FeatureCollection");for(var i=0,len=features.length;i<len;++i){this.writeNode("gml:featureMember",features[i],node);}
 return node;}}},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":"LineString","OpenLayers.Geometry.MultiLineString":"MultiLineString","OpenLayers.Geometry.Polygon":"Polygon","OpenLayers.Geometry.MultiPolygon":"MultiPolygon","OpenLayers.Geometry.Collection":"GeometryCollection"};},CLASS_NAME:"OpenLayers.Format.GML.Base"});OpenLayers.Format.GML.v2=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd",initialize:function(options){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[options]);},readers:{"gml":OpenLayers.Util.applyDefaults({"outerBoundaryIs":function(node,container){var obj={};this.readChildNodes(node,obj);container.outer=obj.components[0];},"innerBoundaryIs":function(node,container){var obj={};this.readChildNodes(node,obj);container.inner.push(obj.components[0]
 );},"Box":function(node,container){var obj={};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
-var min=obj.points[0];var max=obj.points[1];container.components.push(new OpenLayers.Bounds(min.x,min.y,max.x,max.y));}},OpenLayers.Format.GML.Base.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.readers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.readers["wfs"]},write:function(features){var name;if(features instanceof Array){name="wfs:FeatureCollection";}else{name="gml:featureMember";}
+var min=obj.points[0];var max=obj.points[1];container.components.push(new OpenLayers.Bounds(min.x,min.y,max.x,max.y));}},OpenLayers.Format.GML.Base.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.readers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.readers["wfs"]},write:function(features){var name;if(OpenLayers.Util.isArray(features)){name="wfs:FeatureCollection";}else{name="gml:featureMember";}
 var root=this.writeNode(name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":OpenLayers.Util.applyDefaults({"Point":function(geometry){var node=this.createElementNSPlus("gml:Point");this.writeNode("coordinates",[geometry],node);return node;},"coordinates":function(points){var numPoints=points.length;var parts=new Array(numPoints);var point;for(var i=0;i<numPoints;++i){point=points[i];if(this.xy){parts[i]=point.x+","+point.y;}else{parts[i]=point.y+","+point.x;}
 if(point.z!=undefined){parts[i]+=","+point.z;}}
 return this.createElementNSPlus("gml:coordinates",{attributes:{decimal:".",cs:",",ts:" "},value:(numPoints==1)?parts[0]:parts.join(" ")});},"LineString":function(geometry){var node=this.createElementNSPlus("gml:LineString");this.writeNode("coordinates",geometry.components,node);return node;},"Polygon":function(geometry){var node=this.createElementNSPlus("gml:Polygon");this.writeNode("outerBoundaryIs",geometry.components[0],node);for(var i=1;i<geometry.components.length;++i){this.writeNode("innerBoundaryIs",geometry.components[i],node);}
@@ -807,7 +814,15 @@
 return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
 if(typeof this.context=="function"){context=this.context(feature);}
 return context;},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.symbolizers){var len=this.symbolizers.length;options.symbolizers=new Array(len);for(var i=0;i<len;++i){options.symbolizers[i]=this.symbolizers[i].clone();}}else{options.symbolizer={};var value,type;for(var key in this.symbolizer){value=this.symbolizer[key];type=typeof value;if(type==="object"){options.symbolizer[key]=OpenLayers.Util.extend({},value);}else if(type==="string"){options.symbolizer[key]=value;}}}
-options.filter=this.filter&&this.filter.clone();options.context=this.context&&OpenLayers.Util.extend({},this.context);return new OpenLayers.Rule(options);},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},clone:function(){return null;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,type:"FID",initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0,len=this.fids.length;i<len;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
+options.filter=this.filter&&this.filter.clone();options.context=this.context&&OpenLayers.Util.extend({},this.context);return new OpenLayers.Rule(options);},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Format.OGCExceptionReport=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},defaultPrefix:"ogc",read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var exceptionInfo={exceptionReport:null};if(root){this.readChildNodes(data,exceptionInfo);if(exceptionInfo.exceptionReport===null){exceptionInfo=new OpenLayers.Format.OWSCommon().read(data);}}
+return exceptionInfo;},readers:{"ogc":{"ServiceExceptionReport":function(node,obj){obj.exceptionReport={exceptions:[]};this.readChildNodes(node,obj.exceptionReport);},"ServiceException":function(node,exceptionReport){var exception={code:node.getAttribute("code"),locator:node.getAttribute("locator"),text:this.getChildValue(node)};exceptionReport.exceptions.push(exception);}}},CLASS_NAME:"OpenLayers.Format.OGCExceptionReport"});OpenLayers.Format.XML.VersionedOGC=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:null,version:null,profile:null,errorProperty:null,name:null,stringifyOutput:false,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);var className=this.CLASS_NAME;this.name=className.substring(className.lastIndexOf(".")+1);},getVersion:function(root,options){var version;if(root){version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}}else{version=(optio
 ns&&options.version)||this.version||this.defaultVersion;}
+return version;},getParser:function(version){version=version||this.defaultVersion;var profile=this.profile?"_"+this.profile:"";if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format[this.name]["v"+version.replace(/\./g,"_")+profile];if(!format){throw"Can't find a "+this.name+" parser for version "+
+version+profile;}
+this.parser=new format(this.options);}
+return this.parser;},write:function(obj,options){var version=this.getVersion(null,options);this.parser=this.getParser(version);var root=this.parser.write(obj,options);if(this.stringifyOutput===false){return root;}else{return OpenLayers.Format.XML.prototype.write.apply(this,[root]);}},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.getVersion(root);this.parser=this.getParser(version);var obj=this.parser.read(data,options);if(this.errorProperty!==null&&obj[this.errorProperty]===undefined){var format=new OpenLayers.Format.OGCExceptionReport();obj.error=format.read(data);}
+obj.version=version;return obj;},CLASS_NAME:"OpenLayers.Format.XML.VersionedOGC"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},clone:function(){return null;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,type:"FID",initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0,len=this.fids.length;i<len;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
 return false;},clone:function(){var filter=new OpenLayers.Filter.FeatureId();OpenLayers.Util.extend(filter,this);filter.fids=this.fids.slice();return filter;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){var i,len;switch(this.type){case OpenLayers.Filter.Logical.AND:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==false){return false;}}
 return true;case OpenLayers.Filter.Logical.OR:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==true){return true;}}
 return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}
@@ -820,23 +835,7 @@
 wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
 QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
 if(feature.geometry.intersects(geom)){intersect=true;}}
 break;default:OpenLayers.Console.error(OpenLayers.i18n("filterEvaluateNotImplemented"));break;}
-return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,namedLayersAsArray:false,parser:null,write:function(sld,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-this.parser=new format(this.options);}
-var root=this.parser.write(sld);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-var sld=this.parser.read(data,options);return sld;},CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,write:function(filter,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.Filter["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a Filter parser for version "+
-version;}
-return this.parser.write(filter);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var version=this.version;if(!version){version=this.defaultVersion;}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.Filter["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a Filter parser for version "+
-version;}
-var filter=this.parser.read(data);return filter;},CLASS_NAME:"OpenLayers.Format.Filter"});OpenLayers.Filter.Function=OpenLayers.Class(OpenLayers.Filter,{name:null,params:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Filter.Function"});OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var obj={};this.readers.ogc["Filter"].apply(this,[data,obj]);return obj.filter;},readers:{"ogc":{"Filter":function(node,parent){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){parent.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters
 .length>0){parent.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);o
 bj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=OpenLayers.String.numericIf(this.getChildValue(node));},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"UpperBoundary":function(node,filter){filter.upperB
 oundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"Intersects":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.INTERSECTS);},"Within":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.WITHIN);},"Contains":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.CONTAINS);},"DWithin":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.DWITHIN);},"Distance":function(node,obj){obj.distance=parseInt(this.getChildValue(node));obj.distanceUnits=node.getAttribute("units");},"Function":function(node,obj){return;}}},readSpatial:function(node,obj,type){var filter=new OpenLayers.Filter.Spatial({type:type});this.readChildNodes(node,filter);filter.value=filter.components[0];delete filter.components;obj.filters.push(filter);},readOgcExpression:function(node){var obj={};this.readChildNodes(node,obj);var value=obj.value;if(value===undefined){value=this.getChildValue(node);}
+return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",stringifyOutput:true,namedLayersAsArray:false,CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.Filter"});OpenLayers.Filter.Function=OpenLayers.Class(OpenLayers.Filter,{name:null,params:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Filter.Function"}
 );OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var obj={};this.readers.ogc["Filter"].apply(this,[data,obj]);return obj.filter;},readers:{"ogc":{"Filter":function(node,parent){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){parent.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){parent.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":f
 unction(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new Op
 enLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=OpenLayers.String.numericIf(this.getChildValue(node));},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"UpperBoundary":function(node,filter){filter.upperBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"Intersects":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.INTERSECTS);},"Within":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.WITHIN);},"Contains":function(node,obj){this.readSpatial(node
 return value;},writeOgcExpression:function(value,node){if(value instanceof OpenLayers.Filter.Function){var child=this.writeNode("Function",value,node);node.appendChild(child);}else{this.writeNode("Literal",value,node);}
 return node;},write:function(filter){return this.writers.ogc["Filter"].apply(this,[filter]);},writeFeatureIdNodes:function(filter,node){for(var i=0,ii=filter.fids.length;i<ii;++i){this.writeNode("FeatureId",filter.fids[i],node);}},writers:{"ogc":{"Filter":function(filter){var node=this.createElementNSPlus("ogc:Filter");if(filter.type==="FID"){this.writeFeatureIdNodes(filter,node);}else{this.writeNode(this.getFilterType(filter),filter,node);}
 return node;},"FeatureId":function(fid){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:fid}});},"And":function(filter){var node=this.createElementNSPlus("ogc:And");var childFilter;for(var i=0,ii=filter.filters.length;i<ii;++i){childFilter=filter.filters[i];if(childFilter.type==="FID"){this.writeFeatureIdNodes(childFilter,node);}else{this.writeNode(this.getFilterType(childFilter),childFilter,node);}}
@@ -844,12 +843,12 @@
 return node;},"Not":function(filter){var node=this.createElementNSPlus("ogc:Not");var childFilter=filter.filters[0];if(childFilter.type==="FID"){this.writeFeatureIdNodes(childFilter,node);}else{this.writeNode(this.getFilterType(childFilter),childFilter,node);}
 return node;},"PropertyIsLessThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsGreaterThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLessThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsGreaterThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsBetween":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode("PropertyName",filter,no
 de);this.writeNode("LowerBoundary",filter,node);this.writeNode("UpperBoundary",filter,node);return node;},"PropertyName":function(filter){return this.createElementNSPlus("ogc:PropertyName",{value:filter.property});},"Literal":function(value){return this.createElementNSPlus("ogc:Literal",{value:value});},"LowerBoundary":function(filter){var node=this.createElementNSPlus("ogc:LowerBoundary");this.writeOgcExpression(filter.lowerBoundary,node);return node;},"UpperBoundary":function(filter){var node=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode("Literal",filter.upperBoundary,node);return node;},"INTERSECTS":function(filter){return this.writeSpatial(filter,"Intersects");},"WITHIN":function(filter){return this.writeSpatial(filter,"Within");},"CONTAINS":function(filter){return this.writeSpatial(filter,"Contains");},"DWITHIN":function(filter){var node=this.writeSpatial(filter,"DWithin");this.writeNode("Distance",filter,node);return node;},"Distance":function(filter){re
 turn this.createElementNSPlus("ogc:Distance",{attributes:{units:filter.distanceUnits},value:filter.distance});},"Function":function(filter){var node=this.createElementNSPlus("ogc:Function",{attributes:{name:filter.name}});var params=filter.params;for(var i=0,len=params.length;i<len;i++){this.writeOgcExpression(params[i],node);}
 return node;}}},getFilterType:function(filter){var filterType=this.filterMap[filter.type];if(!filterType){throw"Filter writing not supported for rule type: "+filter.type;}
-return filterType;},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike","BBOX":"BBOX","DWITHIN":"DWITHIN","WITHIN":"WITHIN","CONTAINS":"CONTAINS","INTERSECTS":"INTERSECTS","FID":"FeatureId"},CLASS_NAME:"OpenLayers.Format.Filter.v1"});OpenLayers.Format.Filter.v1_0_0=OpenLayers.Class(OpenLayers.Format.GML.v2,OpenLayers.Format.Filter.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.0.0/filter.xsd",initialize:function(options){OpenLayers.Format.GML.v2.prototype.initialize.apply(this,[options]);},readers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqual
 To":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escape");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);}},OpenLayers.Format.Filter.v1.prototype.readers["ogc"]),"gml":OpenLayers.Format.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"]},writers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsNotEqualTo":function(filter){va
 r node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Box",filter.value,node);if(filter.projection){box.setAttribute("srsName",filter.projection);}
+return filterType;},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike","BBOX":"BBOX","DWITHIN":"DWITHIN","WITHIN":"WITHIN","CONTAINS":"CONTAINS","INTERSECTS":"INTERSECTS","FID":"FeatureId"},CLASS_NAME:"OpenLayers.Format.Filter.v1"});OpenLayers.Format.Filter.v1_0_0=OpenLayers.Class(OpenLayers.Format.GML.v2,OpenLayers.Format.Filter.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.0.0/filter.xsd",initialize:function(options){OpenLayers.Format.GML.v2.prototype.initialize.apply(this,[options]);},readers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqual
 r node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");filter.property&&this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Box",filter.value,node);if(filter.projection){box.setAttribute("srsName",filter.projection);}
 return node;}},OpenLayers.Format.Filter.v1.prototype.writers["ogc"]),"gml":OpenLayers.Format.GML.v2.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.writers["feature"]},writeSpatial:function(filter,name){var node=this.createElementNSPlus("ogc:"+name);this.writeNode("PropertyName",filter,node);if(filter.value instanceof OpenLayers.Filter.Function){this.writeNode("Function",filter.value,node);}else{var child;if(filter.value instanceof OpenLayers.Geometry){child=this.writeNode("feature:_geometry",filter.value).firstChild;}else{child=this.writeNode("gml:Box",filter.value);}
 if(filter.projection){child.setAttribute("srsName",filter.projection);}
 return node;},CLASS_NAME:"OpenLayers.Format.Filter.v1_0_0"});OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,multipleSymbolizers:false,featureTypeCounter:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,strokeDashstyle:"solid",pointRadius:3,graphicName:"square"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var sld={namedLayers:options.namedLayersAsArray===true?[]:{}};this.readChildNodes(data,sld);return sld;},readers:OpenLayers.Util.applyDefaults({"sld":{"StyledLayerDescriptor":function(node,sld){sld.version=n
 ode.getAttribute("version");this.readChildNodes(node,sld);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj.description=this.getChildValue(node);},"NamedLayer":function(node,sld){var layer={userStyles:[],namedStyles:[]};this.readChildNodes(node,layer);for(var i=0,len=layer.userStyles.length;i<len;++i){layer.userStyles[i].layerName=layer.name;}
-if(sld.namedLayers instanceof Array){sld.namedLayers.push(layer);}else{sld.namedLayers[layer.name]=layer;}},"NamedStyle":function(node,layer){layer.namedStyles.push(this.getChildValue(node.firstChild));},"UserStyle":function(node,layer){var obj={defaultsPerSymbolizer:true,rules:[]};this.featureTypeCounter=-1;this.readChildNodes(node,obj);var style;if(this.multipleSymbolizers){delete obj.defaultsPerSymbolizer;style=new OpenLayers.Style2(obj);}else{style=new OpenLayers.Style(this.defaultSymbolizer,obj);}
+if(OpenLayers.Util.isArray(sld.namedLayers)){sld.namedLayers.push(layer);}else{sld.namedLayers[layer.name]=layer;}},"NamedStyle":function(node,layer){layer.namedStyles.push(this.getChildValue(node.firstChild));},"UserStyle":function(node,layer){var obj={defaultsPerSymbolizer:true,rules:[]};this.featureTypeCounter=-1;this.readChildNodes(node,obj);var style;if(this.multipleSymbolizers){delete obj.defaultsPerSymbolizer;style=new OpenLayers.Style2(obj);}else{style=new OpenLayers.Style(this.defaultSymbolizer,obj);}
 layer.userStyles.push(style);},"IsDefault":function(node,style){if(this.getChildValue(node)=="1"){style.isDefault=true;}},"FeatureTypeStyle":function(node,style){++this.featureTypeCounter;var obj={rules:this.multipleSymbolizers?style.rules:[]};this.readChildNodes(node,obj);if(!this.multipleSymbolizers){style.rules=obj.rules;}},"Rule":function(node,obj){var config;if(this.multipleSymbolizers){config={symbolizers:[]};}
 var rule=new OpenLayers.Rule(config);this.readChildNodes(node,rule);obj.rules.push(rule);},"ElseFilter":function(node,rule){rule.elseFilter=true;},"MinScaleDenominator":function(node,rule){rule.minScaleDenominator=parseFloat(this.getChildValue(node));},"MaxScaleDenominator":function(node,rule){rule.maxScaleDenominator=parseFloat(this.getChildValue(node));},"TextSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Text(config));}else{rule.symbolizer["Text"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Text"]);}},"Label":function(node,symbolizer){var obj={};this.readChildNodes(node,obj);if(obj.property){symbolizer.label="${"+obj.property+"}";}else{var value=this.readOgcExpression(node);if(value){symbolizer.label=value;}}},"Font":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"Halo":function(node,symbolizer){var
 obj={};this.readChildNodes(node,obj);symbolizer.haloRadius=obj.haloRadius;symbolizer.haloColor=obj.fillColor;symbolizer.haloOpacity=obj.fillOpacity;},"Radius":function(node,symbolizer){var radius=this.readOgcExpression(node);if(radius!=null){symbolizer.haloRadius=radius;}},"RasterSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Raster(config));}else{rule.symbolizer["Raster"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Raster"]);}},"Geometry":function(node,obj){obj.geometry={};this.readChildNodes(node,obj.geometry);},"ColorMap":function(node,symbolizer){symbolizer.colorMap=[];this.readChildNodes(node,symbolizer.colorMap);},"ColorMapEntry":function(node,colorMap){var q=node.getAttribute("quantity");var o=node.getAttribute("opacity");colorMap.push({color:node.getAttribute("color"),quantity:q!==null?parseFloat(q):undefined,lab
 el:node.getAttribute("label")||undefined,opacity:o!==null?parseFloat(o):undefined});},"LineSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Line(config));}else{rule.symbolizer["Line"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Line"]);}},"PolygonSymbolizer":function(node,rule){var config={fill:false,stroke:false};if(!this.multipleSymbolizers){config=rule.symbolizer["Polygon"]||config;}
 this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Polygon(config));}else{rule.symbolizer["Polygon"]=config;}},"PointSymbolizer":function(node,rule){var config={fill:false,stroke:false,graphic:false};if(!this.multipleSymbolizers){config=rule.symbolizer["Point"]||config;}
@@ -862,7 +861,7 @@
 return format||this.defautlGraphicFormat;},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(sld){return this.writers.sld.StyledLayerDescriptor.apply(this,[sld]);},writers:OpenLayers.Util.applyDefaults({"sld":{"StyledLayerDescriptor":function(sld){var root=this.createElementNSPlus("sld:StyledLayerDescriptor",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});root.setAttribute("xmlns:ogc",this.namespaces.ogc);root.setAttribute("xmlns:gml",this.namespaces.gml);if(sld.name){this.writeNode("Name",sld.name,root);}
 if(sld.title){this.writeNode("Title",sld.title,root);}
 if(sld.description){this.writeNode("Abstract",sld.description,root);}
-if(sld.namedLayers instanceof Array){for(var i=0,len=sld.namedLayers.length;i<len;++i){this.writeNode("NamedLayer",sld.namedLayers[i],root);}}else{for(var name in sld.namedLayers){this.writeNode("NamedLayer",sld.namedLayers[name],root);}}
+if(OpenLayers.Util.isArray(sld.namedLayers)){for(var i=0,len=sld.namedLayers.length;i<len;++i){this.writeNode("NamedLayer",sld.namedLayers[i],root);}}else{for(var name in sld.namedLayers){this.writeNode("NamedLayer",sld.namedLayers[name],root);}}
 return root;},"Name":function(name){return this.createElementNSPlus("sld:Name",{value:name});},"Title":function(title){return this.createElementNSPlus("sld:Title",{value:title});},"Abstract":function(description){return this.createElementNSPlus("sld:Abstract",{value:description});},"NamedLayer":function(layer){var node=this.createElementNSPlus("sld:NamedLayer");this.writeNode("Name",layer.name,node);if(layer.namedStyles){for(var i=0,len=layer.namedStyles.length;i<len;++i){this.writeNode("NamedStyle",layer.namedStyles[i],node);}}
 if(layer.userStyles){for(var i=0,len=layer.userStyles.length;i<len;++i){this.writeNode("UserStyle",layer.userStyles[i],node);}}
 return node;},"NamedStyle":function(name){var node=this.createElementNSPlus("sld:NamedStyle");this.writeNode("Name",name,node);return node;},"UserStyle":function(style){var node=this.createElementNSPlus("sld:UserStyle");if(style.name){this.writeNode("Name",style.name,node);}
@@ -914,9 +913,7 @@
 return node;},"ExternalGraphic":function(symbolizer){var node=this.createElementNSPlus("sld:ExternalGraphic");this.writeNode("OnlineResource",symbolizer.externalGraphic,node);var format=symbolizer.graphicFormat||this.getGraphicFormat(symbolizer.externalGraphic);this.writeNode("Format",format,node);return node;},"Mark":function(symbolizer){var node=this.createElementNSPlus("sld:Mark");if(symbolizer.graphicName){this.writeNode("WellKnownName",symbolizer.graphicName,node);}
 if(symbolizer.fill!==false){this.writeNode("Fill",symbolizer,node);}
 if(symbolizer.stroke!==false){this.writeNode("Stroke",symbolizer,node);}
-return node;},"WellKnownName":function(name){return this.createElementNSPlus("sld:WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("sld:Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("sld:Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("sld:Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("sld:OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("sld:Format",{value:format});}}},OpenLayers.Format.Filter.v1_0_0.prototype.writers),CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[option
 s]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Format.Context=OpenLayers.Class({version:null,layerOptions:null,layerParams:null,parser:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");}
-var parser=this.getParser(version);var context=parser.read(data,options);var map;if(options&&options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{var mapOptions=options.map;if(OpenLayers.Util.isElement(mapOptions)||typeof mapOptions=="string"){mapOptions={div:mapOptions};}
+return node;},"WellKnownName":function(name){return this.createElementNSPlus("sld:WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("sld:Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("sld:Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("sld:Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("sld:OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("sld:Format",{value:format});}}},OpenLayers.Format.Filter.v1_0_0.prototype.writers),CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[option
 s]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Format.Context=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{layerOptions:null,layerParams:null,read:function(data,options){var context=OpenLayers.Format.XML.VersionedOGC.prototype.read.apply(this,arguments);var map;if(options&&options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{var mapOptions=options.map;if(OpenLayers.Util.isElement(mapOptions)||typeof mapOptions=="string"){mapOptions={div:mapOptions};}
 map=this.contextToMap(context,mapOptions);}}else{map=context;}
 return map;},getLayerFromContext:function(layerContext){var i,len;var options={queryable:layerContext.queryable,visibility:layerContext.visibility,maxExtent:layerContext.maxExtent,metadata:OpenLayers.Util.applyDefaults(layerContext.metadata,{styles:layerContext.styles,formats:layerContext.formats,"abstract":layerContext["abstract"],dataURL:layerContext.dataURL}),numZoomLevels:layerContext.numZoomLevels,units:layerContext.units,isBaseLayer:layerContext.isBaseLayer,opacity:layerContext.opacity,displayInLayerSwitcher:layerContext.displayInLayerSwitcher,singleTile:layerContext.singleTile,tileSize:(layerContext.tileSize)?new OpenLayers.Size(layerContext.tileSize.width,layerContext.tileSize.height):undefined,minScale:layerContext.minScale||layerContext.maxScaleDenominator,maxScale:layerContext.maxScale||layerContext.minScaleDenominator,srs:layerContext.srs,dimensions:layerContext.dimensions,metadataURL:layerContext.metadataURL};if(this.layerOptions){OpenLayers.Util.applyDefaults(o
 ptions,this.layerOptions);}
 var params={layers:layerContext.name,transparent:layerContext.transparent,version:layerContext.version};if(layerContext.formats&&layerContext.formats.length>0){params.format=layerContext.formats[0].value;for(i=0,len=layerContext.formats.length;i<len;i++){var format=layerContext.formats[i];if(format.current==true){params.format=format.value;break;}}}
@@ -927,16 +924,15 @@
 return layer;},getLayersFromContext:function(layersContext){var layers=[];for(var i=0,len=layersContext.length;i<len;i++){var layer=this.getLayerFromContext(layersContext[i]);if(layer!==null){layers.push(layer);}}
 return layers;},contextToMap:function(context,options){options=OpenLayers.Util.applyDefaults({maxExtent:context.maxExtent,projection:context.projection,units:context.units},options);if(options.maxExtent){options.maxResolution=options.maxExtent.getWidth()/OpenLayers.Map.TILE_WIDTH;}
 var metadata={contactInformation:context.contactInformation,"abstract":context["abstract"],keywords:context.keywords,logo:context.logo,descriptionURL:context.descriptionURL}
-options.metadata=metadata;var map=new OpenLayers.Map(options);map.addLayers(this.getLayersFromContext(context.layersContext));map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(this.getLayersFromContext(context.layersContext));return map;},write:function(obj,options){obj=this.toContext(obj);var version=options&&options.version;var parser=this.getParser(version);var context=parser.write(obj,options);return context;},CLASS_NAME:"OpenLayers.Format.Context"});OpenLayers.Format.Context.serviceTypes={"WMS":"urn:ogc:serviceType:WMS","WFS":"urn:ogc:serviceType:WFS","WCS":"urn:ogc:serviceType:WCS","GML":"urn:ogc:serviceType:GML","SLD":"urn:ogc:serviceType:SLD","FES":"urn:ogc:serviceType:FES","KML":"urn:ogc:serviceType:KML"};OpenLayers.Format.OWSContext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getParser:function(version){var v=version||this.version||this.
 defaultVersion;if(v==="0.3.0"){v=this.defaultVersion;}
-if(!this.parser||this.parser.VERSION!=v){var format=OpenLayers.Format.OWSContext["v"+v.replace(/\./g,"_")];if(!format){throw"Can't find a OWSContext parser for version "+v;}
-return this.parser;},toContext:function(obj){var context={};if(obj.CLASS_NAME=="OpenLayers.Map"){context.bounds=obj.getExtent();context.maxExtent=obj.maxExtent;context.projection=obj.projection;context.size=obj.getSize();context.layers=obj.layers;}
-return context;},CLASS_NAME:"OpenLayers.Format.OWSContext"});if(!OpenLayers.Format.OWSCommon){OpenLayers.Format.OWSCommon={};}
-OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},readers:{"ows":{"ServiceIdentification":function(node,obj){obj.serviceIdentification={};this.readChildNodes(node,obj.serviceIdentification);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,serviceIdentification){serviceIdentification["abstract"]=this.getChildValue(node);},"Keywords":function(node,serviceIdentification){serviceIdentification.keywords={};this.readChildNodes(node,serviceIdentification.keywords);},"Keyword":function(node,keywords){keywords[this.getChildValue(node)]=true;},"ServiceType":function(node,serviceIdentification){serviceIdentification.serviceType={codeSpace:node.getAttribute('codeSpace'),value:this.getChildValue(node)};},"ServiceTypeVersion":function(node,serviceIdentification){serviceIdentification.serviceTypeVersion=this.getChildValue(node);},"
 Fees":function(node,serviceIdentification){serviceIdentification.fees=this.getChildValue(node);},"AccessConstraints":function(node,serviceIdentification){serviceIdentification.accessConstraints=this.getChildValue(node);},"ServiceProvider":function(node,obj){obj.serviceProvider={};this.readChildNodes(node,obj.serviceProvider);},"ProviderName":function(node,serviceProvider){serviceProvider.providerName=this.getChildValue(node);},"ProviderSite":function(node,serviceProvider){serviceProvider.providerSite=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ServiceContact":function(node,serviceProvider){serviceProvider.serviceContact={};this.readChildNodes(node,serviceProvider.serviceContact);},"IndividualName":function(node,serviceContact){serviceContact.individualName=this.getChildValue(node);},"PositionName":function(node,serviceContact){serviceContact.positionName=this.getChildValue(node);},"ContactInfo":function(node,serviceContact){serviceContact.contactInfo={};this.re
 adChildNodes(node,serviceContact.contactInfo);},"Phone":function(node,contactInfo){contactInfo.phone={};this.readChildNodes(node,contactInfo.phone);},"Voice":function(node,phone){phone.voice=this.getChildValue(node);},"Address":function(node,contactInfo){contactInfo.address={};this.readChildNodes(node,contactInfo.address);},"DeliveryPoint":function(node,address){address.deliveryPoint=this.getChildValue(node);},"City":function(node,address){address.city=this.getChildValue(node);},"AdministrativeArea":function(node,address){address.administrativeArea=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);},"Country":function(node,address){address.country=this.getChildValue(node);},"ElectronicMailAddress":function(node,address){address.electronicMailAddress=this.getChildValue(node);},"Role":function(node,serviceContact){serviceContact.role=this.getChildValue(node);},"OperationsMetadata":function(node,obj){obj.operationsMetadat
 a={};this.readChildNodes(node,obj.operationsMetadata);},"Operation":function(node,operationsMetadata){var name=node.getAttribute("name");operationsMetadata[name]={};this.readChildNodes(node,operationsMetadata[name]);},"DCP":function(node,operation){operation.dcp={};this.readChildNodes(node,operation.dcp);},"HTTP":function(node,dcp){dcp.http={};this.readChildNodes(node,dcp.http);},"Get":function(node,http){http.get=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Post":function(node,http){http.post=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Parameter":function(node,operation){if(!operation.parameters){operation.parameters={};}
+options.metadata=metadata;var map=new OpenLayers.Map(options);map.addLayers(this.getLayersFromContext(context.layersContext));map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(this.getLayersFromContext(context.layersContext));return map;},write:function(obj,options){obj=this.toContext(obj);return OpenLayers.Format.XML.VersionedOGC.prototype.write.apply(this,arguments);},CLASS_NAME:"OpenLayers.Format.Context"});OpenLayers.Format.Context.serviceTypes={"WMS":"urn:ogc:serviceType:WMS","WFS":"urn:ogc:serviceType:WFS","WCS":"urn:ogc:serviceType:WCS","GML":"urn:ogc:serviceType:GML","SLD":"urn:ogc:serviceType:SLD","FES":"urn:ogc:serviceType:FES","KML":"urn:ogc:serviceType:KML"};OpenLayers.Format.OWSContext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getVersion:function(root,options){var version=OpenLayers.Format.XML.VersionedOGC.prototype.getVersion.apply
 (this,arguments);if(version==="0.3.0"){version=this.defaultVersion;}
+return version;},toContext:function(obj){var context={};if(obj.CLASS_NAME=="OpenLayers.Map"){context.bounds=obj.getExtent();context.maxExtent=obj.maxExtent;context.projection=obj.projection;context.size=obj.getSize();context.layers=obj.layers;}
+return context;},CLASS_NAME:"OpenLayers.Format.OWSContext"});OpenLayers.Format.OWSCommon=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",getVersion:function(root,options){var version=this.version;if(!version){var uri=root.getAttribute("xmlns:ows");if(uri&&uri.substring(uri.lastIndexOf("/")+1)==="1.1"){version="1.1.0";}
+if(!version){version=this.defaultVersion;}}
+return version;},CLASS_NAME:"OpenLayers.Format.OWSCommon"});OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var ows={};this.readChildNodes(data,ows);return ows;},readers:{"ows":{"Exception":function(node,exceptionReport){var exception={code:node.getAttribute('exceptionCode'),locator:node.getAttribute('locator'),texts:[]};exceptionReport.exceptions.push(exception);this.readChildNodes(node,exception);},"ExceptionText":function(node,exception){var text=this.getChildValue(node);exception.texts.push(text);},"ServiceIdentification":function(node,obj){obj.serviceIdentification={};this.readChildNodes(node,obj.serviceIdentification);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,serviceIdentification){serviceIdentification["abstract"]=
 this.getChildValue(node);},"Keywords":function(node,serviceIdentification){serviceIdentification.keywords={};this.readChildNodes(node,serviceIdentification.keywords);},"Keyword":function(node,keywords){keywords[this.getChildValue(node)]=true;},"ServiceType":function(node,serviceIdentification){serviceIdentification.serviceType={codeSpace:node.getAttribute('codeSpace'),value:this.getChildValue(node)};},"ServiceTypeVersion":function(node,serviceIdentification){serviceIdentification.serviceTypeVersion=this.getChildValue(node);},"Fees":function(node,serviceIdentification){serviceIdentification.fees=this.getChildValue(node);},"AccessConstraints":function(node,serviceIdentification){serviceIdentification.accessConstraints=this.getChildValue(node);},"ServiceProvider":function(node,obj){obj.serviceProvider={};this.readChildNodes(node,obj.serviceProvider);},"ProviderName":function(node,serviceProvider){serviceProvider.providerName=this.getChildValue(node);},"ProviderSite":function(no
 de,serviceProvider){serviceProvider.providerSite=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ServiceContact":function(node,serviceProvider){serviceProvider.serviceContact={};this.readChildNodes(node,serviceProvider.serviceContact);},"IndividualName":function(node,serviceContact){serviceContact.individualName=this.getChildValue(node);},"PositionName":function(node,serviceContact){serviceContact.positionName=this.getChildValue(node);},"ContactInfo":function(node,serviceContact){serviceContact.contactInfo={};this.readChildNodes(node,serviceContact.contactInfo);},"Phone":function(node,contactInfo){contactInfo.phone={};this.readChildNodes(node,contactInfo.phone);},"Voice":function(node,phone){phone.voice=this.getChildValue(node);},"Address":function(node,contactInfo){contactInfo.address={};this.readChildNodes(node,contactInfo.address);},"DeliveryPoint":function(node,address){address.deliveryPoint=this.getChildValue(node);},"City":function(node,address){address.city=
 this.getChildValue(node);},"AdministrativeArea":function(node,address){address.administrativeArea=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);},"Country":function(node,address){address.country=this.getChildValue(node);},"ElectronicMailAddress":function(node,address){address.electronicMailAddress=this.getChildValue(node);},"Role":function(node,serviceContact){serviceContact.role=this.getChildValue(node);},"OperationsMetadata":function(node,obj){obj.operationsMetadata={};this.readChildNodes(node,obj.operationsMetadata);},"Operation":function(node,operationsMetadata){var name=node.getAttribute("name");operationsMetadata[name]={};this.readChildNodes(node,operationsMetadata[name]);},"DCP":function(node,operation){operation.dcp={};this.readChildNodes(node,operation.dcp);},"HTTP":function(node,dcp){dcp.http={};this.readChildNodes(node,dcp.http);},"Get":function(node,http){http.get=this.getAttributeNS(node,this.namespace
 var name=node.getAttribute("name");operation.parameters[name]={};this.readChildNodes(node,operation.parameters[name]);},"Value":function(node,allowedValues){allowedValues[this.getChildValue(node)]=true;},"OutputFormat":function(node,obj){obj.formats.push({value:this.getChildValue(node)});this.readChildNodes(node,obj);},"WGS84BoundingBox":function(node,obj){var boundingBox={};boundingBox.crs=node.getAttribute("crs");if(obj.BoundingBox){obj.BoundingBox.push(boundingBox);}else{obj.projection=boundingBox.crs;boundingBox=obj;}
-this.readChildNodes(node,boundingBox);},"BoundingBox":function(node,obj){this.readers['ows']['WGS84BoundingBox'].apply(this,[node,obj]);},"LowerCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.left=pointList[0];obj.bottom=pointList[1];},"UpperCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.right=pointList[0];obj.top=pointList[1];obj.bounds=new OpenLayers.Bounds(obj.left,obj.bottom,obj.right,obj.top);delete obj.left;delete obj.bottom;delete obj.right;delete obj.top;}}},writers:{"ows":{"BoundingBox":function(options){var node=this.createElementNSPlus("ows:BoundingBox",{attributes:{crs:options.projection}});this.writeNode("ows:LowerCorner",options,node);this.writeNode("ows:UpperCorner",options,no
 de);return node;},"LowerCorner":function(options){var node=this.createElementNSPlus("ows:LowerCorner",{value:options.bounds.left+" "+options.bounds.bottom});return node;},"UpperCorner":function(options){var node=this.createElementNSPlus("ows:UpperCorner",{value:options.bounds.right+" "+options.bounds.top});return node;},"Title":function(title){var node=this.createElementNSPlus("ows:Title",{value:title});return node;},"OutputFormat":function(format){var node=this.createElementNSPlus("ows:OutputFormat",{value:format});return node;},"Identifier":function(identifier){var node=this.createElementNSPlus("ows:Identifier",{attributes:{},value:identifier});return node;},"Version":function(version){var node=this.createElementNSPlus("ows:Version",{attributes:{},value:version});return node;}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.0",xlink:"http://www.
 w3.org/1999/xlink"},readers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"]},writers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.writers["ows"]},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Format.OWSContext.v0_3_1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{owc:"http://www.opengis.net/ows-context",gml:"http://www.opengis.net/gml",kml:"http://www.opengis.net/kml/2.2",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},VERSION:"0.3.1",schemaLocation:"http://www.opengis.net/ows-context http://www.ogcnetwork.net/schemas/owc/0.3.1/owsContext.xsd",defaultPrefix:"owc",extractAttributes:true,xy:true,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},featureNS:"http://mapserver.gis.umn.edu/mapserver",featureType:'vector',geometryName:'geometry',nestingLayerLookup:
 null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);OpenLayers.Format.GML.v2.prototype.setGeometryTypes.call(this);},setNestingPath:function(l){if(l.layersContext){for(var i=0,len=l.layersContext.length;i<len;i++){var layerContext=l.layersContext[i];var nPath=[];var nTitle=l.title||"";if(l.metadata&&l.metadata.nestingPath){nPath=l.metadata.nestingPath.slice();}
+this.readChildNodes(node,boundingBox);},"BoundingBox":function(node,obj){this.readers['ows']['WGS84BoundingBox'].apply(this,[node,obj]);},"LowerCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.left=pointList[0];obj.bottom=pointList[1];},"UpperCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.right=pointList[0];obj.top=pointList[1];obj.bounds=new OpenLayers.Bounds(obj.left,obj.bottom,obj.right,obj.top);delete obj.left;delete obj.bottom;delete obj.right;delete obj.top;},"Language":function(node,obj){obj.language=this.getChildValue(node);}}},writers:{"ows":{"BoundingBox":function(options){var node=this.createElementNSPlus("ows:BoundingBox",{attributes:{crs:options.projection}});this.writeNode("ows:
 LowerCorner",options,node);this.writeNode("ows:UpperCorner",options,node);return node;},"LowerCorner":function(options){var node=this.createElementNSPlus("ows:LowerCorner",{value:options.bounds.left+" "+options.bounds.bottom});return node;},"UpperCorner":function(options){var node=this.createElementNSPlus("ows:UpperCorner",{value:options.bounds.right+" "+options.bounds.top});return node;},"Identifier":function(identifier){var node=this.createElementNSPlus("ows:Identifier",{value:identifier});return node;},"Title":function(title){var node=this.createElementNSPlus("ows:Title",{value:title});return node;},"Abstract":function(abstractValue){var node=this.createElementNSPlus("ows:Abstract",{value:abstractValue});return node;},"OutputFormat":function(format){var node=this.createElementNSPlus("ows:OutputFormat",{value:format});return node;},"Identifier":function(identifier){var node=this.createElementNSPlus("ows:Identifier",{attributes:{},value:identifier});return node;},"Version":
 function(version){var node=this.createElementNSPlus("ows:Version",{attributes:{},value:version});return node;}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Util.applyDefaults({"ExceptionReport":function(node,obj){obj.success=false;obj.exceptionReport={version:node.getAttribute('version'),language:node.getAttribute('language'),exceptions:[]};this.readChildNodes(node,obj.exceptionReport);}},OpenLayers.Format.OWSCommon.v1.prototype.readers.ows)},writers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_0_0"});OpenLayers.Format.OWSContext.v0_3_1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{owc:"http://www.opengis.net/ows-context",gml:"http://www.opengis.net/gml",kml:"http://www.opengis.net/kml/2.2",ogc:"http://www.opengis.net/
 ogc",ows:"http://www.opengis.net/ows",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},VERSION:"0.3.1",schemaLocation:"http://www.opengis.net/ows-context http://www.ogcnetwork.net/schemas/owc/0.3.1/owsContext.xsd",defaultPrefix:"owc",extractAttributes:true,xy:true,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},featureNS:"http://mapserver.gis.umn.edu/mapserver",featureType:'vector',geometryName:'geometry',nestingLayerLookup:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);OpenLayers.Format.GML.v2.prototype.setGeometryTypes.call(this);},setNestingPath:function(l){if(l.layersContext){for(var i=0,len=l.layersContext.length;i<len;i++){var layerContext=l.layersContext[i];var nPath=[];var nTitle=l.title||"";if(l.metadata&&l.metadata.nestingPath){nPath=l.metadata.nestingPath.slice();}
 if(nTitle!=""){nPath.push(nTitle);}
-layerContext.metadata.nestingPath=nPath;if(layerContext.layersContext){this.setNestingPath(layerContext);}}}},decomposeNestingPath:function(nPath){var a=[];if(nPath instanceof Array){var path=nPath.slice();while(path.length>0){a.push(path.slice());path.pop();}
+layerContext.metadata.nestingPath=nPath;if(layerContext.layersContext){this.setNestingPath(layerContext);}}}},decomposeNestingPath:function(nPath){var a=[];if(OpenLayers.Util.isArray(nPath)){var path=nPath.slice();while(path.length>0){a.push(path.slice());path.pop();}
 a.reverse();}
 return a;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
@@ -1000,7 +996,7 @@
 window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
 var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
 this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
-if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,O
 verlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,initialize:functio
 n(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
+if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,O
 verlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","preremovelayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,i
 nitialize:function(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
 this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
 OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);var eventsDiv=document.createElement("div");eventsDiv.id=this.id+"_events";eventsDiv.style.position="absolute";eventsDiv.style.width="100%";eventsDiv.style.height="100%";eventsDiv.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(eventsDiv);this.eventsDiv=eventsDiv;this.events=new OpenLayers.Events(this,this.eventsDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.eventsDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object){this.ev
 ents.on(this.eventListeners);}
 this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
@@ -1020,11 +1016,12 @@
 this.events.destroy();this.events=null;},setOptions:function(options){var updatePxExtent=this.minPx&&options.restrictedExtent!=this.restrictedExtent;OpenLayers.Util.extend(this,options);updatePxExtent&&this.moveTo(this.getCachedCenter(),this.zoom,{forceZoomChange:true});},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(
 var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
 return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
 +zIdx*5);},resetLayersZIndex:function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0,len=this.layers.length;i<len;i++){if(this.layers[i]==layer){var msg=OpenLayers.i18n('layerAlreadyAdded',{'layerName':layer.name});OpenLayers.Console.warn(msg);return false;}}
+if(this.events.triggerEvent("preaddlayer",{layer:layer})===false){return;}
 if(this.allOverlays){layer.isBaseLayer=false;}
-if(this.events.triggerEvent("preaddlayer",{layer:layer})===false){return;}
 layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
 this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer||(this.allOverlays&&!this.baseLayer)){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
-this.events.triggerEvent("addlayer",{layer:layer});layer.events.triggerEvent("added",{map:this,layer:layer});layer.afterAdd();},addLayers:function(layers){for(var i=0,len=layers.length;i<len;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+this.events.triggerEvent("addlayer",{layer:layer});layer.events.triggerEvent("added",{map:this,layer:layer});layer.afterAdd();},addLayers:function(layers){for(var i=0,len=layers.length;i<len;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(this.events.triggerEvent("preremovelayer",{layer:layer})===false){return;}
+if(setNewBaseLayer==null){setNewBaseLayer=true;}
 if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
 OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0,len=this.layers.length;i<len;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer||this.allOverlays){this.setBaseLayer(iLayer);break;}}}}
 this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});layer.events.triggerEvent("removed",{map:this,layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
@@ -1053,9 +1050,8 @@
 return center;},getCachedCenter:function(){if(!this.center&&this.size){this.center=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(this.size.w/2,this.size.h/2));}
 return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});if(options.dragging){if(dx!=0||dy!=0){this.moveByPx(dx,dy);}}else{var centerPx=this.getViewPortPxFromLonLat(this.getCachedCenter());var newCenterPx=centerPx.add(dx,dy);if(this.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.moveTo(newCenterLonLat);this.dragging=false;this.events.triggerEvent("moveend");}}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
 var center=this.getCachedCenter();if(lonlat.equals(center)){return;}
-var from=this.getPixelFromLonLat(center);var to=this.getPixelFromLonLat(lonlat);var vector={x:to.x-from.x,y:to.y-from.y};var last={x:0,y:0};this.panTween.start({x:0,y:0},vector,this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(px){var x=px.x-last.x,y=px.y-last.y;this.moveByPx(x,y);last.x=Math.round(px.x);last.y=Math.round(px.y);},this),done:OpenLayers.Function.bind(function(px){this.moveTo(lonlat);this.dragging=false;this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.panTween&&this.panTween.stop();this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange});},moveByPx:function(dx,dy){dx=Math.round(dx);dy=Math.round(dy);var hw=this.size.w/2;var hh=this.size.h/2;var x=hw+dx;var y=hh+dy;var wrapDateLine=this.baseLayer.wrapDateLine;var xRestriction=0;var yRestriction=0;if(this.restrictedExtent){xRestriction=hw;yRestriction=hh;wrapDateLine=false;}
-var valid=y<=this.maxPx.y-yRestriction&&y>=this.minPx.y+yRestriction;var minX=this.minPx.x,maxX=this.maxPx.x;if(!wrapDateLine){valid=valid&&x<=this.maxPx.x-xRestriction&&x>=this.minPx.x+xRestriction;}
-if(valid){if(!this.dragging){this.dragging=true;this.events.triggerEvent("movestart");}
+var from=this.getPixelFromLonLat(center);var to=this.getPixelFromLonLat(lonlat);var vector={x:to.x-from.x,y:to.y-from.y};var last={x:0,y:0};this.panTween.start({x:0,y:0},vector,this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(px){var x=px.x-last.x,y=px.y-last.y;this.moveByPx(x,y);last.x=Math.round(px.x);last.y=Math.round(px.y);},this),done:OpenLayers.Function.bind(function(px){this.moveTo(lonlat);this.dragging=false;this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.panTween&&this.panTween.stop();this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange});},moveByPx:function(dx,dy){var hw=this.size.w/2;var hh=this.size.h/2;var x=hw+dx;var y=hh+dy;var wrapDateLine=this.baseLayer.wrapDateLine;var xRestriction=0;var yRestriction=0;if(this.restrictedExtent){xRestriction=hw;yRestriction=hh;wrapDateLine=false;}
+dx=wrapDateLine||x<=this.maxPx.x-xRestriction&&x>=this.minPx.x+xRestriction?Math.round(dx):0;dy=y<=this.maxPx.y-yRestriction&&y>=this.minPx.y+yRestriction?Math.round(dy):0;var minX=this.minPx.x,maxX=this.maxPx.x;if(dx||dy){if(!this.dragging){this.dragging=true;this.events.triggerEvent("movestart");}
 this.center=null;if(dx){this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-dx+"px";this.minPx.x-=dx;this.maxPx.x-=dx;if(wrapDateLine){if(this.maxPx.x>maxX){this.maxPx.x-=(maxX-minX);}
 if(this.minPx.x<minX){this.minPx.x+=(maxX-minX);}}}
 if(dy){this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-dy+"px";this.minPx.y-=dy;this.maxPx.y-=dy;}
@@ -1081,12 +1077,11 @@
 this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
 if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,options.dragging);options.dragging||layer.events.triggerEvent("moveend",{zoomChanged:zoomChanged});}}}
 this.events.triggerEvent("move");dragging||this.events.triggerEvent("moveend");if(zoomChanged){for(var i=0,len=this.popups.length;i<len;i++){this.popups[i].updatePosition();}
-this.events.triggerEvent("zoomend");}}},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){var oldLeft=parseInt(this.layerContainerDiv.style.left);var oldTop=parseInt(this.layerContainerDiv.style.top);var newLeft=Math.round(originPx.x-newPx.x);var newTop=Math.round(originPx.y-newPx.y);this.layerContainerDiv.style.left=newLeft+"px";this.layerContainerDiv.style.top=newTop+"px";var dx=oldLeft-newLeft;var dy=oldTop-newTop;this.minPx.x-=dx;this.maxPx.x-=dx;this.minPx.y-=dy;this.maxPx.y-=dy;}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=this.getRestrictedMinZoom())&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
+this.events.triggerEvent("zoomend");}}},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){var oldLeft=parseInt(this.layerContainerDiv.style.left);var oldTop=parseInt(this.layerContainerDiv.style.top);var newLeft=Math.round(originPx.x-newPx.x);var newTop=Math.round(originPx.y-newPx.y);this.layerContainerDiv.style.left=newLeft+"px";this.layerContainerDiv.style.top=newTop+"px";var dx=oldLeft-newLeft;var dy=oldTop-newTop;this.minPx.x-=dx;this.maxPx.x-=dx;this.minPx.y-=dy;this.maxPx.y-=dy;}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
 return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
 return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
 return maxResolution;},getMaxExtent:function(options){var maxExtent=null;if(options&&options.restricted&&this.restrictedExtent){maxExtent=this.restrictedExtent;}else if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
-return maxExtent;},getRestrictedMinZoom:function(){var minZoom=null;if(this.baseLayer!=null){minZoom=this.baseLayer.restrictedMinZoom;}
-return minZoom;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
+return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
 return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
 return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}else if(this.allOverlays===true&&this.layers.length>0){resolution=this.layers[0].getResolution();}
 return resolution;},getUnits:function(){var units=null;if(this.baseLayer!=null){units=this.baseLayer.units;}
@@ -1101,22 +1096,23 @@
 return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCachedCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
 return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
 return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
-return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution
 :null,numZoomLevels:null,restrictedMinZoom:0,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution
 :null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
 if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
 if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
 this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
 this.events.destroy();}
 this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.getOptions());}
 OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},getOptions:function(){var options={};for(var o in this.options){options[o]=this[o];}
-return options;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions){if(this.options==null){this.options={};}
+return options;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions,reinitialize){if(this.options==null){this.options={};}
 OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
 if(this.projection&&this.projection.getUnits()){this.units=this.projection.getUnits();}
-if(this.map){var properties=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]);for(var o in newOptions){if(newOptions.hasOwnProperty(o)&&OpenLayers.Util.indexOf(properties,o)>=0){this.initResolutions();break;}}}},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){var zoomChanged=true;this.moveTo(extent,zoomChanged,false);this.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});redrawn=true;}}
+if(this.map){var resolution=this.map.getResolution();var properties=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]);for(var o in newOptions){if(newOptions.hasOwnProperty(o)&&OpenLayers.Util.indexOf(properties,o)>=0){this.initResolutions();if(reinitialize&&this.map.baseLayer===this){this.map.setCenter(this.map.getCenter(),this.map.getZoomForResolution(resolution),false,true);this.map.events.triggerEvent("changebaselayer",{layer:this});}
+break;}}}},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){var zoomChanged=true;this.moveTo(extent,zoomChanged,false);this.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});redrawn=true;}}
 return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
 this.display(display);},moveByPx:function(dx,dy){},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
 this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
 this.setTileSize();}},afterAdd:function(){},removeMap:function(map){},getImageSize:function(bounds){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
-this.events.triggerEvent("visibilitychanged");}},display:function(display){if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&this.calculateInRange())?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.alwaysInRange){inRange=true;}else{if(this.map){var resolution=this.map.getResolution();inRange=(this.map.getZoom()>=this.restrictedMinZoom&&(resolution>=this.minResolution)&&(resolution<=this.maxResolution));}}
+this.events.triggerEvent("visibilitychanged");}},display:function(display){if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&this.calculateInRange())?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.alwaysInRange){inRange=true;}else{if(this.map){var resolution=this.map.getResolution();inRange=((resolution>=this.minResolution)&&(resolution<=this.maxResolution));}}
 return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var i,len,p;var props={},alwaysInRange=true;for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p];if(alwaysInRange&&this.options[p]){alwaysInRange=false;}}
 if(this.alwaysInRange==null){this.alwaysInRange=alwaysInRange;}
 if(props.resolutions==null){props.resolutions=this.resolutionsFromScales(props.scales);}
@@ -1148,7 +1144,7 @@
 var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((highRes-resolution)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(i=0,len=this.resolutions.length;i<len;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
 minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
 zoom=Math.max(0,i-1);}
-return Math.max(this.restrictedMinZoom,zoom);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;var map=this.map;if(viewPortPx!=null&&map.minPx){var res=map.getResolution();var maxExtent=map.getMaxExtent({restricted:true});var lon=(viewPortPx.x-map.minPx.x)*res+maxExtent.left;var lat=(map.minPx.y-viewPortPx.y)*res+maxExtent.top;lonlat=new OpenLayers.LonLat(lon,lat);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}
+return zoom;},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;var map=this.map;if(viewPortPx!=null&&map.minPx){var res=map.getResolution();var maxExtent=map.getMaxExtent({restricted:true});var lon=(viewPortPx.x-map.minPx.x)*res+maxExtent.left;var lat=(map.minPx.y-viewPortPx.y)*res+maxExtent.top;lonlat=new OpenLayers.LonLat(lon,lat);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}
 return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(lonlat!=null){var resolution=this.map.getResolution();var extent=this.map.getExtent();px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
 return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.div.childNodes.length;i<len;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}
 if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}}},getZIndex:function(){return this.div.style.zIndex;},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
@@ -1156,7 +1152,7 @@
 return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
 return extent;},getLonLatFromViewPortPx:function(viewPortPx){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments);},getViewPortPxFromLonLat:function(lonlat){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments);},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.03390625;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
 this.units="m";this.projection=this.projection||"EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};(function(){var codes=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"];var add=OpenLayers.Projection.addTransform;var merc=OpenLayers.Layer.SphericalMercator;var same=OpenLayers.Projection.nullTransform;var i,len,code,oth
 er,j;for(i=0,len=codes.length;i<len;++i){code=codes[i];add("EPSG:4326",code,merc.projectForward);add(code,"EPSG:4326",merc.projectInverse);for(j=i+1;j<len;++j){other=codes[j];add(code,other,same);add(other,code,same);}}})();OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;this.pane=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.BROWSER_NAME=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLo
 cation()+"blank.gif)";}
-if(this.isFixed){this.map.viewPortDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
+if(this.isFixed){this.map.eventsDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
 this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);}
 OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveByPx:function(dx,dy){OpenLayers.Layer.prototype.moveByPx.apply(this,arguments
 );if(this.dragPanMapObject){this.dragPanMapObject(dx,-dy);}else{this.moveTo(this.map.getCachedCenter());}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(!zoomChanged&&oldCenter&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromVie
 wPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFromMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
 return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
@@ -1171,8 +1167,8 @@
 this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
 this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
 return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
-return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;}
+return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;if(this.map.baseLayer!==this){zoom=this.map.baseLayer.getZoomForResolution(this.getResolutionForZoom(zoom))}}
+return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;if(this.map.baseLayer!==this){zoom=this.getZoomForResolution(this.map.baseLayer.getResolutionForZoom(zoom));}}
 return zoom;},CLASS_NAME:"OpenLayers.Layer.FixedZoomLevels"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:21,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257,0.0000013411045074462891,0.00000067055225372314453],type:null,wrapDateLine:true,sphericalMercator:false,version:null,initialize:function(name,options){options=options||{};if(!options.version){options.version=typeof GMap2==="function"?"2":"3";}
 var mixin=OpenLayers.Layer.Google["v"+
 options.version.replace(/\./g,"_")];if(mixin){OpenLayers.Util.applyDefaults(options,mixin);}else{throw"Unsupported Google Maps API version: "+options.version;}
@@ -1199,12 +1195,12 @@
 return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);}};OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());}
 obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);var ret=this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});}
 return ret;},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0,len=paramString.length;i<len;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
-return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
+return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(OpenLayers.Util.isArray(url)){url=this.selectUrl(paramsString,url);}
 var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 paramsString=OpenLayers.Util.getParameterString(allParams);return OpenLayers.Util.urlAppend(url,paramsString);},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,grid:null,singleTile:false,ratio:1.5,buffer:0,numLoadingTiles:0,tileLoadingDelay:100,timerId:null,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];this._moveGriddedTiles=OpenLayers.Function.bind(this.moveGriddedTiles,this);},removeMap:function(map){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0,len=this.grid.length;iRow<len;iRow++){var row=this.grid[i
 Row];for(var iCol=0,clen=row.length;iCol<clen;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
 this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions());}
 obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
-obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.scheduleMoveGriddedTiles();}}}},moveByPx:function(dx,dy){this.scheduleMoveGriddedTiles();},scheduleMoveGriddedTiles:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);}
+obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.scheduleMoveGriddedTiles();}}}},moveByPx:function(dx,dy){if(!this.singleTile){this.scheduleMoveGriddedTiles();}},scheduleMoveGriddedTiles:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);}
 this.timerId=window.setTimeout(this._moveGriddedTiles,this.tileLoadingDelay);},setTileSize:function(size){if(this.singleTile){size=this.map.getSize();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
 OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[size]);},getGridBounds:function(){var msg="The getGridBounds() function is deprecated. It will be "+"removed in 3.0. Please use getTilesBounds() instead.";OpenLayers.Console.warn(msg);return this.getTilesBounds();},getTilesBounds:function(){var bounds=null;if(this.grid.length){var bottom=this.grid.length-1;var bottomLeftTile=this.grid[bottom][0];var right=this.grid[0].length-1;var topRightTile=this.grid[0][right];bounds=new OpenLayers.Bounds(bottomLeftTile.bounds.left,bottomLeftTile.bounds.bottom,topRightTile.bounds.right,topRightTile.bounds.top);}
 return bounds;},initSingleTile:function(bounds){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var px=this.map.getLayerPxFromLonLat(ul);if(!this.grid.length){this.grid[0]=[];}
@@ -1223,7 +1219,8 @@
 if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0,len=this.grid.length;i<len;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
 while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
 maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
-maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,t
 his.url,this.size);}
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;if(size){this.size=size.clone();}
+this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
 OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));this.shouldDraw=(withinMaxExtent||this.layer.displayOutsideMaxExtent);this.clear();return this.shouldDraw;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
 this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
 var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:false,isFirstDraw:true,backBufferTile:null,maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}
@@ -1240,7 +1237,7 @@
 this.backBufferTile.hide();}},renderTile:function(){if(this.layer.async){this.initImgDiv();this.layer.getURLasync(this.bounds,this,"url",this.positionImage);}else{this.url=this.layer.getURL(this.bounds);this.initImgDiv();this.positionImage();}
 return true;},positionImage:function(){if(this.layer===null){return;}
 OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var imageSize=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack){OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,null,null,imageSize,this.url);}else{OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,imageSize);this.imgDiv.src=this.url;}},clear:function(){if(this.imgDiv){this.hide();if(OpenLayers.Tile.Image.useBlankTile){this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}}},initImgDiv:function(){if(this.imgDiv==null){var offset=this.layer.imageOffset;var size=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack){this.imgDiv=OpenLayers.Util.createAlphaImageDiv(null,offset,size,null,"relative",null,null,null,true);}else{this.imgDiv=OpenLayers.Util.createImage(null,offset,size,null,"relative",null,null,true);}
-if(this.layer.url instanceof Array){this.imgDiv.urls=this.layer.url.slice();}
+if(OpenLayers.Util.isArray(this.layer.url)){this.imgDiv.urls=this.layer.url.slice();}
 this.imgDiv.className='olTileImage';this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
 this.imgDiv.map=this.layer.map;var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};if(this.layerAlphaHack){OpenLayers.Event.observe(this.imgDiv.childNodes[0],'load',OpenLayers.Function.bind(onload,this));}else{OpenLayers.Event.observe(this.imgDiv,'load',OpenLayers.Function.bind(onload,this));}
 var onerror=function(){if(this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS){onload.call(this);}};OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(onerror,this));}
@@ -1250,7 +1247,7 @@
 if(ratio!=1){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
 OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(OpenLayers.IS_GECKO===true){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera");OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128
 *156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
 url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(url instanceof Array){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(OpenLayers.Util.isArray(url)){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
 return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var limit=Math.pow(2,z);if(this.wrapDateLine)
 {x=((x%limit)+limit)%limit;}
 return{'x':x,'y':y,'z':z};},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
@@ -1260,41 +1257,43 @@
 var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
 this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
 var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
-this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,dblclickTolerance:20,touch:false,lastTouchPx:null,initialize:function(co
 ntrol,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,touch:false,lastTouchPx:null,initialize:function(control,callbacks,optio
 OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
-var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);this.createFeature();return true;},createFeature:function(pixel){var geometry;if(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else{geometry=new OpenLayers.Geometry.Point();}
-this.point=new OpenLayers.Feature.Vector(geometry);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
-this.cancel(true);if(this.layer.map!=null){this.destroyFeature();this.layer.destroy(false);}
-this.layer=null;this.touch=false;return true;},destroyFeature:function(){if(this.layer){this.layer.destroyFeatures();}
-this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finalize:function(cancel,noNew){var key=cancel?"cancel":"done";this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.lastTouchPx=null;this.callback(key,[this.geometryClone()]);if(cancel||!this.persist){this.destroyFeature();}
-if(!noNew&&this.active){this.createFeature();}},cancel:function(noNew){this.finalize(true,noNew);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
+var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
+this.cancel();if(this.layer.map!=null){this.destroyFeature(true);this.layer.destroy(false);}
+this.layer=null;this.touch=false;return true;},destroyFeature:function(force){if(this.layer&&(force||!this.persist)){this.layer.destroyFeatures();}
+this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finalize:function(cancel){var key=cancel?"cancel":"done";this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.lastTouchPx=null;this.callback(key,[this.geometryClone()]);this.destroyFeature(cancel);},cancel:function(){this.finalize(true);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){if(!this.point){this.createFeature(pixel);}
+var lonlat=this.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
 return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){return this.down(evt);},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
 this.lastTouchPx=evt.xy;return this.down(evt);},mousemove:function(evt){return this.move(evt);},touchmove:function(evt){this.lastTouchPx=evt.xy;return this.move(evt);},mouseup:function(evt){return this.up(evt);},touchend:function(evt){evt.xy=this.lastTouchPx;return this.up(evt);},down:function(evt){this.mouseDown=true;this.lastDown=evt.xy;if(!this.touch){this.modifyFeature(evt.xy);}
 this.stoppedDown=this.stopDown;return!this.stopDown;},move:function(evt){if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy);}
 return true;},up:function(evt){this.mouseDown=false;this.stoppedDown=this.stopDown;if(!this.checkModifiers(evt)){return true;}
-if(this.lastUp&&this.passesTolerance(this.lastUp,evt.xy,this.dblclickTolerance)){return true;}
+if(this.lastUp&&this.lastUp.equals(evt.xy)){return true;}
 if(this.lastDown&&this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
 if(this.persist){this.destroyPersistedFeature();}
 this.lastUp=evt.xy;this.finalize();return!this.stopUp;}else{return true;}},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){this.stoppedDown=this.stopDown;this.mouseDown=false;}},passesTolerance:function(pixel1,pixel2,tolerance){var passes=true;if(tolerance!=null&&pixel1&&pixel2){var dist=pixel1.distanceTo(pixel2);if(dist>tolerance){passes=false;}}
-return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,freehand:false,freehandToggle:'shiftKey',timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var geometry;if(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else{geometry=new OpenLayers.Geometry.Point();}
-this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.layer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[th
 is.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel,drawing){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
-return geometry;},touchstart:function(evt){if(this.timerId&&this.passesTolerance(this.lastTouchPx,evt.xy,this.dblclickTolerance)){this.lastTouchPx=evt.xy;this.finishGeometry();window.clearTimeout(this.timerId);this.timerId=null;return false;}else{if(this.timerId){window.clearTimeout(this.timerId);this.timerId=null;}
+return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:false,freehandToggle:'shiftKey',timerId:null,redoStack:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(force){OpenLayers.Handler.Point.prototype.destroyFeature.call(this,force);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(lay
 er&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.layer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();delete this.redoStack;},insertXY:function(x,y){this.line.geometry.addComponent(new OpenLayers.Geometry.Point(x,y),this.getCurrentPointIndex());this.drawFeature();delete this.redoStack;},insertDeltaXY:function(dx,dy){var previousIndex=this.getCurrentPointIndex()-1;var p0=this.line.geometry.components[previousIndex];if(p0&&!isNaN(p0.x)&&!isNaN(p0.y)){this.
 insertXY(p0.x+dx,p0.y+dy);}},insertDirectionLength:function(direction,length){direction*=Math.PI/180;var dx=length*Math.cos(direction);var dy=length*Math.sin(direction);this.insertDeltaXY(dx,dy);},insertDeflectionLength:function(deflection,length){var previousIndex=this.getCurrentPointIndex()-1;if(previousIndex>0){var p1=this.line.geometry.components[previousIndex];var p0=this.line.geometry.components[previousIndex-1];var theta=Math.atan2(p1.y-p0.y,p1.x-p0.x);this.insertDirectionLength((theta*180/Math.PI)+deflection,length);}},getCurrentPointIndex:function(){return this.line.geometry.components.length-1;},undo:function(){var geometry=this.line.geometry;var components=geometry.components;var index=this.getCurrentPointIndex()-1;var target=components[index];var undone=geometry.removeComponent(target);if(undone){if(!this.redoStack){this.redoStack=[];}
+this.redoStack.push(target);this.drawFeature();}
+return undone;},redo:function(){var target=this.redoStack&&this.redoStack.pop();if(target){this.line.geometry.addComponent(target,this.getCurrentPointIndex());this.drawFeature();}
+return!!target;},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel,drawing){if(!this.line){this.createFeature(pixel);}
+var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
+return geometry;},touchstart:function(evt){if(this.timerId&&this.passesTolerance(this.lastTouchPx,evt.xy,this.doubleTouchTolerance)){this.finishGeometry();window.clearTimeout(this.timerId);this.timerId=null;return false;}else{if(this.timerId){window.clearTimeout(this.timerId);this.timerId=null;}
 this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null;},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,evt);}},down:function(evt){var stopDown=this.stopDown;if(this.freehandMode(evt)){stopDown=true;}
 if(!this.touch&&(!this.lastDown||!this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance))){this.modifyFeature(evt.xy,!!this.lastUp);}
 this.mouseDown=true;this.lastDown=evt.xy;this.stoppedDown=stopDown;return!stopDown;},move:function(evt){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
 this.addPoint(evt.xy);return false;}
 if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy,!!this.lastUp);}
-return true;},up:function(evt){if(this.mouseDown&&(!this.lastUp||!this.passesTolerance(this.lastUp,evt.xy,this.dblclickTolerance))){if(this.stoppedDown&&this.freehandMode(evt)){this.removePoint();this.finalize();}else{if(this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
+return true;},up:function(evt){if(this.mouseDown&&(!this.lastUp||!this.lastUp.equals(evt.xy))){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
+this.removePoint();this.finalize();}else{if(this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
 if(this.lastUp==null&&this.persist){this.destroyPersistedFeature();}
 this.addPoint(evt.xy);this.lastUp=evt.xy;if(this.line.geometry.components.length===this.maxVertices+1){this.finishGeometry();}}}}
 this.stoppedDown=this.stopDown;this.mouseDown=false;return!this.stopUp;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var geometry;if(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else{geometry=new OpenLayers.Geometry.Point();}
-this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},addPoint:function(pixel){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier]){var geometry=this.point.geometry;var features=this.control.layer.features;var candidate,polygon;for(var i=features.length-1;i>=0;--i){candidate=features[i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([polygon],{silent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorR
 ing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
-OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments);},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finishGeometry:function(){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
+return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},addPoint:function(pixel){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier]){var geometry=this.point.geometry;var featur
 es=this.control.layer.features;var candidate,polygon;for(var i=features.length-1;i>=0;--i){candidate=features[i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([polygon],{silent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
+OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments);},getCurrentPointIndex:function(){return this.line.geometry.components.length-2;},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finishGeometry:function(){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
 if(modified){var target;outer:for(var i=rings.length-2;i>0;--i){var points=rings[i].components;for(var j=0,jj=points.length;j<jj;++j){if(ring.containsPoint(points[j])){modified=false;break outer;}}}}}
 if(modified){if(this.polygon.state!==OpenLayers.State.INSERT){this.polygon.state=OpenLayers.State.UPDATE;}}else{this.polygon.geometry.removeComponent(ring);}
 this.restoreFeature();return false;},cancel:function(){if(this.drawingHole){this.polygon.geometry.removeComponent(this.line.geometry);this.restoreFeature(true);}
-return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments);},restoreFeature:function(cancel){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:true});this.control.layer.addFeatures([this.polygon],{silent:true});this.drawingHole=false;if(!cancel){this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon});}},destroyFeature:function(){OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);this.polygon=null;},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.polygon;},getGeometry:function(){var geometry=this.polygon&&this.polygon.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPolygon([geometry]);}
+return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments);},restoreFeature:function(cancel){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:true});this.control.layer.addFeatures([this.polygon],{silent:true});this.drawingHole=false;if(!cancel){this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon});}},destroyFeature:function(force){OpenLayers.Handler.Path.prototype.destroyFeature.call(this,force);this.polygon=null;},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.polygon;},getGeometry:function(){var geometry=this.polygon&&this.polygon.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPolygon([geometry]);}
 return geometry;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.AgsControl=OpenLayers.Class(OpenLayers.Control,{url:"",layer:null,mode:"select",asynchronous:false,adapter:null,handlers:null,displayResults:true,taskParameters:{},taskCallbacks:null,_resultFeatures:null,resultFeatureStyles:{},_resultImages:null,resultImageOptions:{},_resultsParser:null,selectControl:null,geometryTypes:null,clickout:false,toggle:true,multiple:false,drawControl:null,drawCtrlHandler:OpenLayers.Handler.Polygon,drawCtrlHandlerOptions:{},initialize:function(url,layer,callbacks,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.url=url;if(layer&&layer instanceof OpenLayers.Layer.Vector){this.layer=layer;}else{this.layer=new OpenLayers.Layer.Vector("__internal__",{displayInLayerSwitcher:false,isBaseLayer:false});}
 if(callbacks){this.taskCallbacks=callbacks;}
 var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,multiple:this.multiple,callbacks:{dblclick:dojo.hitch(this,this._execute)}};this.selectControl=new OpenLayers.Control.SelectFeature(this.layer,selectOptions);var drawOptions=OpenLayers.Util.extend({callbacks:{done:dojo.hitch(this,this._execute)}},this.drawCtrlHandlerOptions);this.drawControl=new OpenLayers.Control.DrawFeature(this.layer,this.drawCtrlHandler,drawOptions);this.handlers={};this.adapter=new OpenLayers.Format.AgsJsAdapter();this._resultFeatures=[];this._resultImages=[];OpenLayers.Util.applyDefaults(this.resultImageOptions,{opacity:1.0,});this._isDefined=OpenLayers.Util.AgsUtil.isDefined;this._isAgsGeometry=OpenLayers.Util.AgsUtil.isAgsGeometry;this._isOLGeometry=OpenLayers.Util.AgsUtil.isOLGeometry;this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;},destroy:function(){this.layer=null;this.selectControl.destroy();this.drawControl.destroy();OpenLayers.Control.prototy
 pe.destroy.apply(this,[]);},activate:function(){if(this.mode=="select"){return(this.selectControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));}else if(this.mode=="draw"){return(this.drawControl.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.drawControl.deactivate();this.selectControl.deactivate();deactivated=true;}
@@ -1319,18 +1318,19 @@
 var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsQueryTask=new esri.tasks.QueryTask(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{var agsQuery=this.adapter.encodeAgsQuery(_taskParameters);}
 catch(e){throw e;}
 agsQueryTask.execute(agsQuery,_onExecuteComplete,_onCompleteError);}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsQueryTask ...");throw"...'asynchronous' should always be set to 'false' for AgsQueryTask ...";}},CLASS_NAME:"OpenLayers.Control.AgsQueryTask"});OpenLayers.Format.WFST=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WFST.DEFAULTS);var cls=OpenLayers.Format.WFST["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFST version: "+options.version;}
-return new cls(options);};OpenLayers.Format.WFST.DEFAULTS={"version":"1.0.0"};OpenLayers.Format.WFST.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs",gml:"http://www.opengis.net/gml",ogc:"http://www.opengis.net/ogc"},defaultPrefix:"wfs",version:null,schemaLocations:null,srsName:null,extractAttributes:true,xy:true,stateName:null,initialize:function(options){this.stateName={};this.stateName[OpenLayers.State.INSERT]="wfs:Insert";this.stateName[OpenLayers.State.UPDATE]="wfs:Update";this.stateName[OpenLayers.State.DELETE]="wfs:Delete";OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},getSrsName:function(feature,options){var srsName=options&&options.srsName;if(!srsName){if(feature&&feature.layer){srsName=feature.layer.projection.getCode();}else{srsName=this.srsName;}}
+return new cls(options);};OpenLayers.Format.WFST.DEFAULTS={"version":"1.0.0"};OpenLayers.Format.WFST.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs",gml:"http://www.opengis.net/gml",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows"},defaultPrefix:"wfs",version:null,schemaLocations:null,srsName:null,extractAttributes:true,xy:true,stateName:null,initialize:function(options){this.stateName={};this.stateName[OpenLayers.State.INSERT]="wfs:Insert";this.stateName[OpenLayers.State.UPDATE]="wfs:Update";this.stateName[OpenLayers.State.DELETE]="wfs:Delete";OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},getSrsName:function(feature,options){var srsName=options&&options.srsName;if(!srsName){if(feature&&feature.layer){srsName=feature.layer.projection.getCode();}else{srsName=this.srsName;}}
 return srsName;},read:function(data,options){options=options||{};OpenLayers.Util.applyDefaults(options,{output:"features"});if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
-var obj={};if(data){this.readNode(data,obj);}
+var obj={};if(data){this.readNode(data,obj,true);}
 if(obj.features&&options.output==="features"){obj=obj.features;}
-return obj;},readers:{"wfs":{"FeatureCollection":function(node,obj){obj.features=[];this.readChildNodes(node,obj);}}},write:function(features){var node=this.writeNode("wfs:Transaction",features);var value=this.schemaLocationAttr();if(value){this.setAttributeNS(node,this.namespaces["xsi"],"xsi:schemaLocation",value);}
+return obj;},readers:{"wfs":{"FeatureCollection":function(node,obj){obj.features=[];this.readChildNodes(node,obj);}}},write:function(features,options){var node=this.writeNode("wfs:Transaction",{features:features,options:options});var value=this.schemaLocationAttr();if(value){this.setAttributeNS(node,this.namespaces["xsi"],"xsi:schemaLocation",value);}
 return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wfs":{"GetFeature":function(options){var node=this.createElementNSPlus("wfs:GetFeature",{attributes:{service:"WFS",version:this.version,outputFormat:options&&options.outputFormat,maxFeatures:options&&options.maxFeatures,"xsi:schemaLocation":this.schemaLocationAttr(options)}});if(typeof this.featureType=="string"){this.writeNode("Query",options,node);}else{for(var i=0,len=this.featureType.length;i<len;i++){options.featureType=this.featureType[i];this.writeNode("Query",options,node);}}
-return node;},"Transaction":function(features){var node=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version}});if(features){var name,feature;for(var i=0,len=features.length;i<len;++i){feature=features[i];name=this.stateName[feature.state];if(name){this.writeNode(name,feature,node);}}}
-return node;},"Insert":function(feature){var node=this.createElementNSPlus("wfs:Insert");this.srsName=this.getSrsName(feature);this.writeNode("feature:_typeName",feature,node);return node;},"Update":function(feature){var node=this.createElementNSPlus("wfs:Update",{attributes:{typeName:(this.featureNS?this.featurePrefix+":":"")+
+return node;},"Transaction":function(obj){var node=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version}});var i,len;var features=obj&&obj.features;var options=obj&&obj.options;if(features){var name,feature;for(i=0,len=features.length;i<len;++i){feature=features[i];name=this.stateName[feature.state];if(name){this.writeNode(name,feature,node);}}}
+if(options&&options.nativeElements){for(i=0,len=options.nativeElements.length;i<len;++i){this.writeNode("wfs:Native",options.nativeElements[i],node);}}
+return node;},"Native":function(nativeElement){var node=this.createElementNSPlus("wfs:Native",{attributes:{vendorId:nativeElement.vendorId,safeToIgnore:nativeElement.safeToIgnore},value:nativeElement.value});return node;},"Insert":function(feature){var node=this.createElementNSPlus("wfs:Insert");this.srsName=this.getSrsName(feature);this.writeNode("feature:_typeName",feature,node);return node;},"Update":function(feature){var node=this.createElementNSPlus("wfs:Update",{attributes:{typeName:(this.featureNS?this.featurePrefix+":":"")+
 this.featureType}});if(this.featureNS){node.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);}
-if(this.geometryName!==null){this.srsName=this.getSrsName(feature);this.writeNode("Property",{name:this.geometryName,value:feature.geometry},node);}
-for(var key in feature.attributes){if(feature.attributes[key]!==undefined){this.writeNode("Property",{name:key,value:feature.attributes[key]},node);}}
+var modified=feature.modified;if(this.geometryName!==null&&(!modified||modified.geometry)){this.srsName=this.getSrsName(feature);this.writeNode("Property",{name:this.geometryName,value:feature.geometry},node);}
+for(var key in feature.attributes){if(feature.attributes[key]!==undefined&&(!modified||!modified.attributes||(modified.attributes&&modified.attributes[key]))){this.writeNode("Property",{name:key,value:feature.attributes[key]},node);}}
 this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[feature.fid]}),node);return node;},"Property":function(obj){var node=this.createElementNSPlus("wfs:Property");this.writeNode("Name",obj.name,node);if(obj.value!==null){this.writeNode("Value",obj.value,node);}
 return node;},"Name":function(name){return this.createElementNSPlus("wfs:Name",{value:name});},"Value":function(obj){var node;if(obj instanceof OpenLayers.Geometry){node=this.createElementNSPlus("wfs:Value");var geom=this.writeNode("feature:_geometry",obj).firstChild;node.appendChild(geom);}else{node=this.createElementNSPlus("wfs:Value",{value:obj});}
 return node;},"Delete":function(feature){var node=this.createElementNSPlus("wfs:Delete",{attributes:{typeName:(this.featureNS?this.featurePrefix+":":"")+
@@ -1341,7 +1341,7 @@
 container.components.push(new OpenLayers.Geometry.LineString(obj.points));},"segments":function(node,obj){this.readChildNodes(node,obj);},"LineStringSegment":function(node,container){var obj={};this.readChildNodes(node,obj);if(obj.points){Array.prototype.push.apply(container.points,obj.points);}},"pos":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");var coords=str.split(this.regExes.splitSpace);var point;if(this.xy){point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{point=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}
 obj.points=[point];},"posList":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");var coords=str.split(this.regExes.splitSpace);var dim=parseInt(node.getAttribute("dimension"))||2;var j,x,y,z;var numPoints=coords.length/dim;var points=new Array(numPoints);for(var i=0,len=coords.length;i<len;i+=dim){x=coords[i];y=coords[i+1];z=(dim==2)?undefined:coords[i+2];if(this.xy){points[i/dim]=new OpenLayers.Geometry.Point(x,y,z);}else{points[i/dim]=new OpenLayers.Geometry.Point(y,x,z);}}
 obj.points=points;},"Surface":function(node,obj){this.readChildNodes(node,obj);},"patches":function(node,obj){this.readChildNodes(node,obj);},"PolygonPatch":function(node,obj){this.readers.gml.Polygon.apply(this,[node,obj]);},"exterior":function(node,container){var obj={};this.readChildNodes(node,obj);container.outer=obj.components[0];},"interior":function(node,container){var obj={};this.readChildNodes(node,obj);container.inner.push(obj.components[0]);},"MultiCurve":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);if(obj.components.length>0){container.components=[new OpenLayers.Geometry.MultiLineString(obj.components)];}},"curveMember":function(node,obj){this.readChildNodes(node,obj);},"MultiSurface":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);if(obj.components.length>0){container.components=[new OpenLayers.Geometry.MultiPolygon(obj.components)];}},"surfaceMember":function(node,obj){this.readChildNodes(node,obj
 );},"surfaceMembers":function(node,obj){this.readChildNodes(node,obj);},"pointMembers":function(node,obj){this.readChildNodes(node,obj);},"lineStringMembers":function(node,obj){this.readChildNodes(node,obj);},"polygonMembers":function(node,obj){this.readChildNodes(node,obj);},"geometryMembers":function(node,obj){this.readChildNodes(node,obj);},"Envelope":function(node,container){var obj={points:new Array(2)};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
-var min=obj.points[0];var max=obj.points[1];container.components.push(new OpenLayers.Bounds(min.x,min.y,max.x,max.y));},"lowerCorner":function(node,container){var obj={};this.readers.gml.pos.apply(this,[node,obj]);container.points[0]=obj.points[0];},"upperCorner":function(node,container){var obj={};this.readers.gml.pos.apply(this,[node,obj]);container.points[1]=obj.points[0];}},OpenLayers.Format.GML.Base.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.readers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.readers["wfs"]},write:function(features){var name;if(features instanceof Array){name="featureMembers";}else{name="featureMember";}
+var min=obj.points[0];var max=obj.points[1];container.components.push(new OpenLayers.Bounds(min.x,min.y,max.x,max.y));},"lowerCorner":function(node,container){var obj={};this.readers.gml.pos.apply(this,[node,obj]);container.points[0]=obj.points[0];},"upperCorner":function(node,container){var obj={};this.readers.gml.pos.apply(this,[node,obj]);container.points[1]=obj.points[0];}},OpenLayers.Format.GML.Base.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.readers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.readers["wfs"]},write:function(features){var name;if(OpenLayers.Util.isArray(features)){name="featureMembers";}else{name="featureMember";}
 var root=this.writeNode("gml:"+name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":OpenLayers.Util.applyDefaults({"featureMembers":function(features){var node=this.createElementNSPlus("gml:featureMembers");for(var i=0,len=features.length;i<len;++i){this.writeNode("feature:_typeName",features[i],node);}
 return node;},"Point":function(geometry){var node=this.createElementNSPlus("gml:Point");this.writeNode("pos",geometry,node);return node;},"pos":function(point){var pos=(this.xy)?(point.x+" "+point.y):(point.y+" "+point.x);return this.createElementNSPlus("gml:pos",{value:pos});},"LineString":function(geometry){var node=this.createElementNSPlus("gml:LineString");this.writeNode("posList",geometry.components,node);return node;},"Curve":function(geometry){var node=this.createElementNSPlus("gml:Curve");this.writeNode("segments",geometry,node);return node;},"segments":function(geometry){var node=this.createElementNSPlus("gml:segments");this.writeNode("LineStringSegment",geometry,node);return node;},"LineStringSegment":function(geometry){var node=this.createElementNSPlus("gml:LineStringSegment");this.writeNode("posList",geometry.components,node);return node;},"posList":function(points){var len=points.length;var parts=new Array(len);var point;for(var i=0;i<len;++i){point=points[i];if
 (this.xy){parts[i]=point.x+" "+point.y;}else{parts[i]=point.y+" "+point.x;}}
 return this.createElementNSPlus("gml:posList",{value:parts.join(" ")});},"Surface":function(geometry){var node=this.createElementNSPlus("gml:Surface");this.writeNode("patches",geometry,node);return node;},"patches":function(geometry){var node=this.createElementNSPlus("gml:patches");this.writeNode("PolygonPatch",geometry,node);return node;},"PolygonPatch":function(geometry){var node=this.createElementNSPlus("gml:PolygonPatch",{attributes:{interpolation:"planar"}});this.writeNode("exterior",geometry.components[0],node);for(var i=1,len=geometry.components.length;i<len;++i){this.writeNode("interior",geometry.components[i],node);}
@@ -1351,23 +1351,22 @@
 return node;},"MultiSurface":function(geometry){var node=this.createElementNSPlus("gml:MultiSurface");for(var i=0,len=geometry.components.length;i<len;++i){this.writeNode("surfaceMember",geometry.components[i],node);}
 return node;},"surfaceMember":function(polygon){var node=this.createElementNSPlus("gml:surfaceMember");if(this.surface){this.writeNode("Surface",polygon,node);}else{this.writeNode("Polygon",polygon,node);}
 return node;},"Envelope":function(bounds){var node=this.createElementNSPlus("gml:Envelope");this.writeNode("lowerCorner",bounds,node);this.writeNode("upperCorner",bounds,node);if(this.srsName){node.setAttribute("srsName",this.srsName);}
-return node;},"lowerCorner":function(bounds){var pos=(this.xy)?(bounds.left+" "+bounds.bottom):(bounds.bottom+" "+bounds.left);return this.createElementNSPlus("gml:lowerCorner",{value:pos});},"upperCorner":function(bounds){var pos=(this.xy)?(bounds.right+" "+bounds.top):(bounds.top+" "+bounds.right);return this.createElementNSPlus("gml:upperCorner",{value:pos});}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":(this.curve===true)?"Curve":"LineString","OpenLayers.Geometry.MultiLineString":(this.multiCurve===false)?"MultiLineString":"MultiCurve","OpenLayers.Geometry.Polygon":(this.surface===true)?"Surface":"Polygon","OpenLayers.Geometry.MultiPolygon":(this.multiSurface===false)?"MultiPoly
 gon":"MultiSurface","OpenLayers.Geometry.Collection":"GeometryCollection"};},CLASS_NAME:"OpenLayers.Format.GML.v3"});OpenLayers.Format.Filter.v1_1_0=OpenLayers.Class(OpenLayers.Format.GML.v3,OpenLayers.Format.Filter.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.1.0/filter.xsd",initialize:function(options){OpenLayers.Format.GML.v3.prototype.initialize.apply(this,[options]);},readers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(node,obj){var matchCase=node.getAttribute("matchCase");var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,matchCase:!(matchCase==="false"||matchCase==="0")});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,obj){var matchCase=node.getAttribute("matchCase");var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO,matchCase:!(matchCase==="false"||matchCase==="0")});this.readChildNodes(node,
 filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escapeChar");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);}},OpenLayers.Format.Filter.v1.prototype.readers["ogc"]),"gml":OpenLayers.Format.GML.v3.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"]},writers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo",{attributes:{matchCase:filter.matchCase}});this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo",{attributes:{matchCase:filter.matchCa
 se}});this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{matchCase:filter.matchCase,wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Envelope",filter.value);if(filter.projection){box.setAttribute("srsName",filter.projection);}
-node.appendChild(box);return node;}},OpenLayers.Format.Filter.v1.prototype.writers["ogc"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"]},writeSpatial:function(filter,name){var node=this.createElementNSPlus("ogc:"+name);this.writeNode("PropertyName",filter,node);if(filter.value instanceof OpenLayers.Filter.Function){this.writeNode("Function",filter.value,node);}else{var child;if(filter.value instanceof OpenLayers.Geometry){child=this.writeNode("feature:_geometry",filter.value).firstChild;}else{child=this.writeNode("gml:Envelope",filter.value);}
+return node;},"lowerCorner":function(bounds){var pos=(this.xy)?(bounds.left+" "+bounds.bottom):(bounds.bottom+" "+bounds.left);return this.createElementNSPlus("gml:lowerCorner",{value:pos});},"upperCorner":function(bounds){var pos=(this.xy)?(bounds.right+" "+bounds.top):(bounds.top+" "+bounds.right);return this.createElementNSPlus("gml:upperCorner",{value:pos});}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":(this.curve===true)?"Curve":"LineString","OpenLayers.Geometry.MultiLineString":(this.multiCurve===false)?"MultiLineString":"MultiCurve","OpenLayers.Geometry.Polygon":(this.surface===true)?"Surface":"Polygon","OpenLayers.Geometry.MultiPolygon":(this.multiSurface===false)?"MultiPoly
 se}});this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{matchCase:filter.matchCase,wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");filter.property&&this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Envelope",filter.value);if(filter.projection){box.setAttribute("srsName",filter.projection);}
+node.appendChild(box);return node;},"SortBy":function(sortProperties){var node=this.createElementNSPlus("ogc:SortBy");for(var i=0,l=sortProperties.length;i<l;i++){this.writeNode("ogc:SortProperty",sortProperties[i],node);}
+return node;},"SortProperty":function(sortProperty){var node=this.createElementNSPlus("ogc:SortProperty");this.writeNode("ogc:PropertyName",sortProperty,node);this.writeNode("ogc:SortOrder",(sortProperty.order=='DESC')?'DESC':'ASC',node);return node;},"SortOrder":function(value){var node=this.createElementNSPlus("ogc:SortOrder",{value:value});return node;}},OpenLayers.Format.Filter.v1.prototype.writers["ogc"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"]},writeSpatial:function(filter,name){var node=this.createElementNSPlus("ogc:"+name);this.writeNode("PropertyName",filter,node);if(filter.value instanceof OpenLayers.Filter.Function){this.writeNode("Function",filter.value,node);}else{var child;if(filter.value instanceof OpenLayers.Geometry){child=this.writeNode("feature:_geometry",filter.value).firstChild;}else{child=this.writeNode("gml:Envelope",filter.value);}
 if(filter.projection){child.setAttribute("srsName",filter.projection);}
 node.appendChild(child);}
-return node;},CLASS_NAME:"OpenLayers.Format.Filter.v1_1_0"});OpenLayers.Format.WFST.v1_1_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_1_0,OpenLayers.Format.WFST.v1,{version:"1.1.0",schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_1_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){obj.numberOfFeatures=parseInt(node.getAttribute("numberOfFeatures"));OpenLayers.Format.WFST.v1.prototype.readers["wfs"]["FeatureCollection"].apply(this,arguments);},"TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"TransactionSummary":function(node,obj){obj.success=true;},"InsertResults":function(node,obj){this.readChildNodes(node,obj);},"Feature":function(node,container){var obj={fids:[]};this.readChildNodes(nod
 e,obj);container.insertIds.push(obj.fids[0]);}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"GetFeature":function(options){var node=OpenLayers.Format.WFST.v1.prototype.writers["wfs"]["GetFeature"].apply(this,arguments);options&&this.setAttributes(node,{resultType:options.resultType,startIndex:options.startIndex,count:options.count});return node;},"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName},options);var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(options.featureNS?options.featurePrefix+":":"")+
-options.featureType,srsName:options.srsName}});if(options.featureNS){node.setAttribute("xmlns:"+options.featurePrefix,options.featureNS);}
+return node;},CLASS_NAME:"OpenLayers.Format.Filter.v1_1_0"});OpenLayers.Format.WFST.v1_1_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_1_0,OpenLayers.Format.WFST.v1,{version:"1.1.0",schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_1_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readNode:function(node,obj,first){return OpenLayers.Format.GML.v3.prototype.readNode.apply(this,[node,obj]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){obj.numberOfFeatures=parseInt(node.getAttribute("numberOfFeatures"));OpenLayers.Format.WFST.v1.prototype.readers["wfs"]["FeatureCollection"].apply(this,arguments);},"TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"TransactionSummary":function(node,obj){obj.success=true;},"InsertResults":function(node,obj
 ){this.readChildNodes(node,obj);},"Feature":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.readers["ogc"],"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers["ows"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"GetFeature":function(options){var node=OpenLayers.Format.WFST.v1.prototype.writers["wfs"]["GetFeature"].apply(this,arguments);options&&this.setAttributes(node,{resultType:options.resultType,startIndex:options.startIndex,count:options.count});return node;},"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName},options);var prefix=options.featurePrefix;var node=this.cre
 ateElementNSPlus("wfs:Query",{attributes:{typeName:(prefix?prefix+":":"")+
+options.featureType,srsName:options.srsName}});if(options.featureNS){node.setAttribute("xmlns:"+prefix,options.featureNS);}
 if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("wfs:PropertyName",{property:options.propertyNames[i]},node);}}
 if(options.filter){this.setFilterProperty(options.filter);this.writeNode("ogc:Filter",options.filter,node);}
-return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",getParser:function(version){var v=version||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=v){var format=OpenLayers.Format.WMC["v"+v.replace(/\./g,"_")];if(!format){throw"Can't find a WMC parser for version "+v;}
-this.parser=new format(this.options);}
-return this.parser;},layerToContext:function(layer){var parser=this.getParser();var layerContext={queryable:layer.queryable,visibility:layer.visibility,name:layer.params["LAYERS"],title:layer.name,"abstract":layer.metadata["abstract"],dataURL:layer.metadata.dataURL,metadataURL:layer.metadataURL,server:{version:layer.params["VERSION"],url:layer.url},maxExtent:layer.maxExtent,transparent:layer.params["TRANSPARENT"],numZoomLevels:layer.numZoomLevels,units:layer.units,isBaseLayer:layer.isBaseLayer,opacity:layer.opacity,displayInLayerSwitcher:layer.displayInLayerSwitcher,singleTile:layer.singleTile,tileSize:(layer.singleTile||!layer.tileSize)?undefined:{width:layer.tileSize.w,height:layer.tileSize.h},minScale:(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale)?layer.minScale:undefined,maxScale:(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale)?layer.maxScale:undefined,formats:[]
 ,styles:[],srs:layer.srs,dimensions:layer.dimensions};if(layer.metadata.servertitle){layerContext.server.title=layer.metadata.servertitle;}
+return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",layerToContext:function(layer){var parser=this.getParser();var layerContext={queryable:layer.queryable,visibility:layer.visibility,name:layer.params["LAYERS"],title:layer.name,"abstract":layer.metadata["abstract"],dataURL:layer.metadata.dataURL,metadataURL:layer.metadataURL,server:{version:layer.params["VERSION"],url:layer.url},maxExtent:layer.maxExtent,transparent:layer.params["TRANSPARENT"],numZoomLevels:layer.numZoomLevels,units:layer.units,isBaseLayer:layer.isBaseLayer,opacity:layer.opacity,
 displayInLayerSwitcher:layer.displayInLayerSwitcher,singleTile:layer.singleTile,tileSize:(layer.singleTile||!layer.tileSize)?undefined:{width:layer.tileSize.w,height:layer.tileSize.h},minScale:(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale)?layer.minScale:undefined,maxScale:(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale)?layer.maxScale:undefined,formats:[],styles:[],srs:layer.srs,dimensions:layer.dimensions};if(layer.metadata.servertitle){layerContext.server.title=layer.metadata.servertitle;}
 if(layer.metadata.formats&&layer.metadata.formats.length>0){for(var i=0,len=layer.metadata.formats.length;i<len;i++){var format=layer.metadata.formats[i];layerContext.formats.push({value:format.value,current:(format.value==layer.params["FORMAT"])});}}else{layerContext.formats.push({value:layer.params["FORMAT"],current:true});}
 if(layer.metadata.styles&&layer.metadata.styles.length>0){for(var i=0,len=layer.metadata.styles.length;i<len;i++){var style=layer.metadata.styles[i];if((style.href==layer.params["SLD"])||(style.body==layer.params["SLD_BODY"])||(style.name==layer.params["STYLES"])){style.current=true;}else{style.current=false;}
 layerContext.styles.push(style);}}else{layerContext.styles.push({href:layer.params["SLD"],body:layer.params["SLD_BODY"],name:layer.params["STYLES"]||parser.defaultStyleName,title:parser.defaultStyleTitle,current:true});}
 return layerContext;},toContext:function(obj){var context={};var layers=obj.layers;if(obj.CLASS_NAME=="OpenLayers.Map"){var metadata=obj.metadata||{};context.size=obj.getSize();context.bounds=obj.getExtent();context.projection=obj.projection;context.title=obj.title;context.keywords=metadata.keywords;context["abstract"]=metadata["abstract"];context.logo=metadata.logo;context.descriptionURL=metadata.descriptionURL;context.contactInformation=metadata.contactInformation;context.maxExtent=obj.maxExtent;}else{OpenLayers.Util.applyDefaults(context,obj);if(context.layers!=undefined){delete(context.layers);}}
 if(context.layersContext==undefined){context.layersContext=[];}
-if(layers!=undefined&&layers instanceof Array){for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer instanceof OpenLayers.Layer.WMS){context.layersContext.push(this.layerToContext(layer));}}}
+if(layers!=undefined&&OpenLayers.Util.isArray(layers)){for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer instanceof OpenLayers.Layer.WMS){context.layersContext.push(this.layerToContext(layer));}}}
 return context;},CLASS_NAME:"OpenLayers.Format.WMC"});OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){break;}}}
 return prefix;},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",defaultStyleTitle:"Default",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 var root=data.documentElement;this.rootPrefix=root.prefix;var context={version:root.getAttribute("version")};this.runChildNodes(context,root);return context;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor,prefix,local;for(var i=0,len=children.length;i<len;++i){childNode=children[i];if(childNode.nodeType==1){prefix=this.getNamespacePrefix(childNode.namespaceURI);local=childNode.nodeName.split(":").pop();processor=this["read_"+prefix+"_"+local];if(processor){processor.apply(this,[obj,childNode]);}}}},read_wmc_General:function(context,node){this.runChildNodes(context,node);},read_wmc_BoundingBox:function(context,node){context.projection=node.getAttribute("SRS");context.bounds=new OpenLayers.Bounds(parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy")));},read_wmc_LayerList:function(context,node){context.layersContext=[];this.runChildNodes(cont
 ext,node);},read_wmc_Layer:function(context,node){var layerContext={visibility:(node.getAttribute("hidden")!="1"),queryable:(node.getAttribute("queryable")=="1"),formats:[],styles:[],metadata:{}};this.runChildNodes(layerContext,node);context.layersContext.push(layerContext);},read_wmc_Extension:function(obj,node){this.runChildNodes(obj,node);},read_ol_units:function(layerContext,node){layerContext.units=this.getChildValue(node);},read_ol_maxExtent:function(obj,node){var bounds=new OpenLayers.Bounds(node.getAttribute("minx"),node.getAttribute("miny"),node.getAttribute("maxx"),node.getAttribute("maxy"));obj.maxExtent=bounds;},read_ol_transparent:function(layerContext,node){layerContext.transparent=this.getChildValue(node);},read_ol_numZoomLevels:function(layerContext,node){layerContext.numZoomLevels=parseInt(this.getChildValue(node));},read_ol_opacity:function(layerContext,node){layerContext.opacity=parseFloat(this.getChildValue(node));},read_ol_singleTile:function(layerContex
 t,node){layerContext.singleTile=(this.getChildValue(node)=="true");},read_ol_tileSize:function(layerContext,node){var obj={"width":node.getAttribute("width"),"height":node.getAttribute("height")};layerContext.tileSize=obj;},read_ol_isBaseLayer:function(layerContext,node){layerContext.isBaseLayer=(this.getChildValue(node)=="true");},read_ol_displayInLayerSwitcher:function(layerContext,node){layerContext.displayInLayerSwitcher=(this.getChildValue(node)=="true");},read_wmc_Server:function(layerContext,node){layerContext.version=node.getAttribute("version");layerContext.url=this.getOnlineResource_href(node);layerContext.metadata.servertitle=node.getAttribute("title");},read_wmc_FormatList:function(layerContext,node){this.runChildNodes(layerContext,node);},read_wmc_Format:function(layerContext,node){var format={value:this.getChildValue(node)};if(node.getAttribute("current")=="1"){format.current=true;}
@@ -1409,7 +1408,7 @@
 var values="";if(attributes.values){values=attributes.values.join(",");delete attributes.values;}
 node.appendChild(this.createElementDefaultNS("Dimension",values,attributes));}
 return node;},write_wmc_FormatList:function(context){var node=this.createElementDefaultNS("FormatList");for(var i=0,len=context.formats.length;i<len;i++){var format=context.formats[i];node.appendChild(this.createElementDefaultNS("Format",format.value,(format.current&&format.current==true)?{current:"1"}:null));}
-return node;},write_wmc_StyleList:function(layer){var node=this.createElementDefaultNS("StyleList");var styles=layer.styles;if(styles&&styles instanceof Array){var sld;for(var i=0,len=styles.length;i<len;i++){var s=styles[i];var style=this.createElementDefaultNS("Style",null,(s.current&&s.current==true)?{current:"1"}:null);if(s.href){sld=this.createElementDefaultNS("SLD");if(s.name){sld.appendChild(this.createElementDefaultNS("Name",s.name));}
+return node;},write_wmc_StyleList:function(layer){var node=this.createElementDefaultNS("StyleList");var styles=layer.styles;if(styles&&OpenLayers.Util.isArray(styles)){var sld;for(var i=0,len=styles.length;i<len;i++){var s=styles[i];var style=this.createElementDefaultNS("Style",null,(s.current&&s.current==true)?{current:"1"}:null);if(s.href){sld=this.createElementDefaultNS("SLD");if(s.name){sld.appendChild(this.createElementDefaultNS("Name",s.name));}
 if(s.title){sld.appendChild(this.createElementDefaultNS("Title",s.title));}
 if(s.legend){sld.appendChild(this.write_wmc_URLType("LegendURL",s.legend.href,s.legend));}
 var link=this.write_wmc_OnlineResource(s.href);sld.appendChild(link);style.appendChild(sld);}else if(s.body){sld=this.createElementDefaultNS("SLD");if(s.name){sld.appendChild(this.createElementDefaultNS("Name",s.name));}
@@ -1425,15 +1424,12 @@
 if(context.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(context.minScale.toPrecision(16)));node.appendChild(maxSD);}
 if(context.srs){for(var name in context.srs){node.appendChild(this.createElementDefaultNS("SRS",name));}}
 node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));if(context.dimensions){node.appendChild(this.write_wmc_DimensionList(context));}
-node.appendChild(this.write_wmc_LayerExtension(context));return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Format.WFSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.0",version:null,read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-var constr=OpenLayers.Format.WFSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw"Can't find a WFS capabilities parser for version "+version;}
-var parser=new constr(this.options);var capabilities=parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.WFSCapabilities"});OpenLayers.Format.WFSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.WFSCapabilities,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+node.appendChild(this.write_wmc_LayerExtension(context));return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Format.WFSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",errorProperty:"service",CLASS_NAME:"OpenLayers.Format.WFSCapabilities"});OpenLayers.Format.WFSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.WFSCapabilities,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 var capabilities={};var root=data.documentElement;this.runChildNodes(capabilities,root);return capabilities;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){processor=this["read_cap_"+childNode.nodeName];if(processor){processor.apply(this,[obj,childNode]);}}}},read_cap_FeatureTypeList:function(request,node){var featureTypeList={featureTypes:[]};this.runChildNodes(featureTypeList,node);request.featureTypeList=featureTypeList;},read_cap_FeatureType:function(featureTypeList,node,parentLayer){var featureType={};this.runChildNodes(featureType,node);featureTypeList.featureTypes.push(featureType);},read_cap_Name:function(obj,node){var name=this.getChildValue(node);if(name){var parts=name.split(":");obj.name=parts.pop();if(parts.length>0){obj.featureNS=this.lookupNamespaceURI(node,parts[0]);}}},read_cap_Title:function(obj,node){var title=this.getChildValue(node);
 if(title){obj.title=title;}},read_cap_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515],type:null,wrapDateLine:true,sphericalMercator:false,animationEnabled:true,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.Sphe
 ricalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var sz=this.map.getSize();veDiv.style.width=sz.w+"px";veDiv.style.height=sz.h+"px";this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
 if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",OpenLayers.Function.True);}catch(e){}
 this.mapObject.HideDashboard();if(typeof this.mapObject.SetAnimationEnabled=="function"){this.mapObject.SetAnimationEnabled(this.animationEnabled);}}
 if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},onMapResize:function(){this.mapObject.Resize(this.map.size.w,this.map.size.h);},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return(typeof VEPixel!='undefined')?this.mapObject.PixelToLatLong(moPixel):this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:f
 unction(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
-return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return(typeof VEPixel!='undefined')?new VEPixel(x,y):new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var ctl,i=this.controls.length-1;i>=0;i--){ctl=this.controls[i];if(ctl.events){ctl.events.un({activate:this.iconOn,deactivate:this.iconOff});}
+return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return(typeof VEPixel!='undefined')?new VEPixel(x,y):new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,allowDepress:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var ctl,i=this.controls.length-1;i>=0;i--){ctl=this.controls[i];if(ctl.events){ctl.events.un({activate:this.iconOn,deactivate:this.iconOff});}
 OpenLayers.Event.stopObservingElement(ctl.panel_div);ctl.panel_div=null;}
 this.activeState=null;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];if(control===this.defaultControl||(this.saveState&&this.activeState[control.id])){control.activate();}}
 if(this.saveState===true){this.defaultControl=null;}
@@ -1443,8 +1439,8 @@
 if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();return;}
 if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
 return;}
-var c;for(var i=0,len=this.controls.length;i<len;i++){c=this.controls[i];if(c!=control&&(c.type===OpenLayers.Control.TYPE_TOOL||c.type==null)){c.deactivate();}}
-control.activate();},addControls:function(controls){if(!(controls instanceof Array)){controls=[controls];}
+if(this.allowDepress&&control.active){control.deactivate();}else{var c;for(var i=0,len=this.controls.length;i<len;i++){c=this.controls[i];if(c!=control&&(c.type===OpenLayers.Control.TYPE_TOOL||c.type==null)){c.deactivate();}}
+control.activate();}},addControls:function(controls){if(!(OpenLayers.Util.isArray(controls))){controls=[controls];}
 this.controls=this.controls.concat(controls);for(var i=0,len=controls.length;i<len;i++){var element=document.createElement("div");element.className=controls[i].displayClass+"ItemInactive";controls[i].panel_div=element;if(controls[i].title!=""){controls[i].panel_div.title=controls[i].title;}
 OpenLayers.Event.observe(controls[i].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"dblclick",OpenLayers.Function.bind(this.onDoubleClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));}
 if(this.map){this.addControlsToMap(controls);this.redraw();}},addControlsToMap:function(controls){var control;for(var i=0,len=controls.length;i<len;i++){control=controls[i];if(control.autoActivate===true){control.autoActivate=false;this.map.addControl(control);control.autoActivate=true;}else{this.map.addControl(control);control.deactivate();}
@@ -1453,12 +1449,13 @@
 return new cls(options);};OpenLayers.Format.WPSCommon.Request=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WPSCommon.DEFAULTS);var cls=OpenLayers.Format.WPSCommon["v"+options.version.replace(/\./g,"_")].Request;if(!cls){throw"Unsupported WPSCommon.Request version: "+options.version;}
 return new cls(options);};OpenLayers.Format.WPSCommon.ProcessDescription=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WPSCommon.DEFAULTS);var cls=OpenLayers.Format.WPSCommon["v"+options.version.replace(/\./g,"_")].ProcessDescription;if(!cls){throw"Unsupported WPSCommon.ProcessDescription version: "+options.version;}
 return new cls(options);};OpenLayers.Format.WPSCommon.ExecuteResponse=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WPSCommon.DEFAULTS);var cls=OpenLayers.Format.WPSCommon["v"+options.version.replace(/\./g,"_")].ExecuteResponse;if(!cls){throw"Unsupported WPSCommon.ExecuteResponse version: "+options.version;}
-return new cls(options);};OpenLayers.Test=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},CLASS_NAME:"OpenLayers.Test"});OpenLayers.Test.AgsOgcRegression=OpenLayers.Class(OpenLayers.Test,{url:"",initialize:function(options){OpenLayers.Test.prototype.initialize.apply(this,[options]);},_run_get_:function(reqParams,resUrl,t){var xmlFormat=new OpenLayers.Format.XML();var caller=this;OpenLayers.Request.GET({url:this.url,params:reqParams,success:function(response){OpenLayers.loadURL(resUrl,null,caller,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...");});},failure:function(response){t.ok(false,"......");},scope:caller});},_run_post_:function(reqId,resUrl,t){var xmlFormat=new OpenLayers.Format.XML();var postReqXmlStr=document.getElementById(reqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(response){OpenLayers.loadURL(resUrl,null,caller,fu
 nction(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...");});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postReqXmlStr});},_run_post_wpsStoredResult:function(reqId,docRefUrl,refMimeType,resRefUrl,t){var postReqXmlStr=document.getElementById(reqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(response){OpenLayers.loadURL(docRefUrl,null,caller,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...");var doc=response.responseXML;if(!doc||!doc.documentElement){doc=response.responseText;}
+return new cls(options);};OpenLayers.Test=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},CLASS_NAME:"OpenLayers.Test"});OpenLayers.Test.AgsOgcRegression=OpenLayers.Class(OpenLayers.Test,{url:"",initialize:function(options){OpenLayers.Test.prototype.initialize.apply(this,[options]);},_run_get_:function(reqParams,resUrl,t){var xmlFormat=new OpenLayers.Format.XML();var caller=this;OpenLayers.Request.GET({url:this.url,params:reqParams,success:function(response){OpenLayers.loadURL(resUrl,null,caller,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...");});},failure:function(response){t.ok(false,"......");},scope:caller});},_run_get_mimeType:function(reqParams,refMimeType,t){var caller=this;OpenLayers.Request.GET({url:this.url,params:reqParams,success:function(response){if(response.statusText=="OK"&&response.status==200){t.ok(true,"...execute check result status...");}else{t.ok(false,"...
+var allResponesHeaders=response.getAllResponseHeaders();if(allResponesHeaders.indexOf(refMimeType)!=-1){t.ok(true,"...execute check result header content type...");}else{t.ok(false,"...execute check result header content type...");}},failure:function(response){t.ok(false,"......");},scope:caller});},_run_post_:function(reqId,resUrl,t){var xmlFormat=new OpenLayers.Format.XML();var postReqXmlStr=document.getElementById(reqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(response){OpenLayers.loadURL(resUrl,null,caller,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...");});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postReqXmlStr});},_run_post_wpsStoredResult:function(reqId,docRefUrl,refMimeType,resRefUrl,t){var postReqXmlStr=document.getElementById(reqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:funct
 var wpsFormat=new OpenLayers.Format.WPSCommon({});var executeResponse=wpsFormat.read(doc);var resUrl=executeResponse.processoutputs[0].data.complexData[0];if(resUrl&&resUrl!=""){t.ok(true,"...async execute check result reference url...");}else{t.ok(false,"...async execute check result reference url...");}
 var scope=this;OpenLayers.loadURL(resUrl,{},scope,function(response){if(response.statusText=="OK"&&response.status==200){t.ok(true,"...execute check result status...");}else{t.ok(false,"...execute check result status...");}
 if(resRefUrl&&resRefUrl!=""){OpenLayers.loadURL(resRefUrl,null,this,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...execute check result...");});}},function(response){t.ok(false,"...async execute check result...");});});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postReqXmlStr});},_verify_features_number:function(reqParams,featureType,expectedNumOfFeatures,t){var caller=this;OpenLayers.Request.GET({url:this.url,params:reqParams,success:function(response){var result_parser=new OpenLayers.Format.WFSTWithLock({version:"1.1.0",featureType:featureType,geometryName:"Shape",featureNS:"http://www.esri.com",featurePrefix:"esri",extractAttributes:false});var features=result_parser.read(response.responseXML);t.eq(features.length,expectedNumOfFeatures,"...verify features number...");},failure:function(response){t.ok(false,"......");},scope:caller});},_run_wfst_post_:function(lockReqId,lockResUrl,
 transactionReqId,transactionResUrl,t){var postLockReqXmlStr=document.getElementById(lockReqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(lockResponse){var lockId=lockResponse.responseXML.firstChild.getAttribute("lockId");if((!lockId)||lockId==""){t.ok(false,"...test failed...null or invalid lockId");}else{t.ok(true,"...test succeeded...valid lockId retrieved...");}
-var postTransReqXmlStr=document.getElementById(transactionReqId).firstChild.nodeValue;var xmlFormat=new OpenLayers.Format.XML({namespaces:{'wfs':"http://www.opengis.net/wfs"}});var postTransReqXmlDom=xmlFormat.read(postTransReqXmlStr);var lockIdNode=xmlFormat.createElementNSPlus("wfs:LockId",{'value':lockId});postTransReqXmlDom.firstChild.insertBefore(lockIdNode,postTransReqXmlDom.firstChild.firstChild);var postTransReqLockIdXmlStr=xmlFormat.write(postTransReqXmlDom);var innerCaller=caller;OpenLayers.Request.POST({url:caller.url,success:function(transResponse){OpenLayers.loadURL(transactionResUrl,null,innerCaller,function(transReference){t.html_eq(this._stripXmlDeclaration(transResponse.responseText),transReference.responseText,"...");});},failure:function(transResponse){t.ok(false,"......");},params:{},headers:{},data:postTransReqLockIdXmlStr});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postLockReqXmlStr});},_stripXmlDeclaration:function(x
 mlStr){var idx_l=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"utf-8\" ?>");var idx_u=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");if(idx_l>=0||idx_u>=0){return xmlStr.substring(39,xmlStr.length-1);}else{return xmlStr;}},CLASS_NAME:"OpenLayers.Test.AgsOgcRegression"});OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{fontStyleKeys:['antialiasing','blockout','font','fontcolor','fontsize','fontstyle','glowing','interval','outline','printmode','shadow','transparency'],request:null,response:null,initialize:function(options){this.request=new OpenLayers.Format.ArcXML.Request();this.response=new OpenLayers.Format.ArcXML.Response();if(options){if(options.requesttype=="feature"){this.request.get_image=null;var qry=this.request.get_feature.query;this.addCoordSys(qry.featurecoordsys,options.featureCoordSys);this.addCoordSys(qry.filtercoordsys,options.filterCoordSys);if(options.polygon){qry.isspatial=true;qry.spatialfilter.polygon=options.polygon;}else
 if(options.envelope){qry.isspatial=true;qry.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0};this.parseEnvelope(qry.spatialfilter.envelope,options.envelope);}}else if(options.requesttype=="image"){this.request.get_feature=null;var props=this.request.get_image.properties;this.parseEnvelope(props.envelope,options.envelope);this.addLayers(props.layerlist,options.layers);this.addImageSize(props.imagesize,options.tileSize);this.addCoordSys(props.featurecoordsys,options.featureCoordSys);this.addCoordSys(props.filtercoordsys,options.filterCoordSys);}else{this.request=null;}}
+var postTransReqXmlStr=document.getElementById(transactionReqId).firstChild.nodeValue;var xmlFormat=new OpenLayers.Format.XML({namespaces:{'wfs':"http://www.opengis.net/wfs"}});var postTransReqXmlDom=xmlFormat.read(postTransReqXmlStr);var lockIdNode=xmlFormat.createElementNSPlus("wfs:LockId",{'value':lockId});postTransReqXmlDom.firstChild.insertBefore(lockIdNode,postTransReqXmlDom.firstChild.firstChild);var postTransReqLockIdXmlStr=xmlFormat.write(postTransReqXmlDom);var innerCaller=caller;OpenLayers.Request.POST({url:caller.url,success:function(transResponse){OpenLayers.loadURL(transactionResUrl,null,innerCaller,function(transReference){t.html_eq(this._stripXmlDeclaration(transResponse.responseText),transReference.responseText,"...");});},failure:function(transResponse){t.ok(false,"......");},params:{},headers:{},data:postTransReqLockIdXmlStr});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postLockReqXmlStr});},_stripXmlDeclaration:function(x
 mlStr){var idx_l=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"utf-8\" ?>");var idx_u=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");if(idx_l>=0||idx_u>=0){OpenLayers.Console.debug("..."+xmlStr.substring(39,xmlStr.length-1));return xmlStr.substring(39,xmlStr.length-1);}else{OpenLayers.Console.debug(xmlStr);return xmlStr;}},CLASS_NAME:"OpenLayers.Test.AgsOgcRegression"});OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{fontStyleKeys:['antialiasing','blockout','font','fontcolor','fontsize','fontstyle','glowing','interval','outline','printmode','shadow','transparency'],request:null,response:null,initialize:function(options){this.request=new OpenLayers.Format.ArcXML.Request();this.response=new OpenLayers.Format.ArcXML.Response();if(options){if(options.requesttype=="feature"){this.request.get_image=null;var qry=this.request.get_feature.query;this.addCoordSys(qry.featurecoordsys,options.featureCoordSys);this.addCoordSys(qry.filtercoordsys,options.f
 ilterCoordSys);if(options.polygon){qry.isspatial=true;qry.spatialfilter.polygon=options.polygon;}else if(options.envelope){qry.isspatial=true;qry.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0};this.parseEnvelope(qry.spatialfilter.envelope,options.envelope);}}else if(options.requesttype=="image"){this.request.get_feature=null;var props=this.request.get_image.properties;this.parseEnvelope(props.envelope,options.envelope);this.addLayers(props.layerlist,options.layers);this.addImageSize(props.imagesize,options.tileSize);this.addCoordSys(props.featurecoordsys,options.featureCoordSys);this.addCoordSys(props.filtercoordsys,options.filterCoordSys);}else{this.request=null;}}
 OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},parseEnvelope:function(env,arr){if(arr&&arr.length==4){env.minx=arr[0];env.miny=arr[1];env.maxx=arr[2];env.maxy=arr[3];}},addLayers:function(ll,lyrs){for(var lind=0,len=lyrs.length;lind<len;lind++){ll.push(lyrs[lind]);}},addImageSize:function(imsize,olsize){if(olsize!==null){imsize.width=olsize.w;imsize.height=olsize.h;imsize.printwidth=olsize.w;imsize.printheight=olsize.h;}},addCoordSys:function(featOrFilt,fsys){if(typeof fsys=="string"){featOrFilt.id=parseInt(fsys);featOrFilt.string=fsys;}
 else if(typeof fsys=="object"&&fsys.proj!==null){featOrFilt.id=fsys.proj.srsProjNumber;featOrFilt.string=fsys.proj.srsCode;}else{featOrFilt=fsys;}},iserror:function(data){var ret=null;if(!data){ret=(this.response.error!=='');}else{data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);var errorNodes=data.documentElement.getElementsByTagName("ERROR");ret=(errorNodes!==null&&errorNodes.length>0);}
 return ret;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
@@ -1500,7 +1497,7 @@
 if(fquery.buffer>0){var bufElem=this.createElementNS("","BUFFER");bufElem.setAttribute("distance",fquery.buffer);qElem.appendChild(bufElem);}
 if(fquery.isspatial){var spfElem=this.createElementNS("","SPATIALFILTER");spfElem.setAttribute("relation",fquery.spatialfilter.relation);qElem.appendChild(spfElem);if(fquery.spatialfilter.envelope){var envElem=this.createElementNS("","ENVELOPE");envElem.setAttribute("minx",fquery.spatialfilter.envelope.minx);envElem.setAttribute("miny",fquery.spatialfilter.envelope.miny);envElem.setAttribute("maxx",fquery.spatialfilter.envelope.maxx);envElem.setAttribute("maxy",fquery.spatialfilter.envelope.maxy);spfElem.appendChild(envElem);}else if(typeof fquery.spatialfilter.polygon=="object"){spfElem.appendChild(this.writePolygonGeometry(fquery.spatialfilter.polygon));}}
 if(fquery.where!=null&&fquery.where.length>0){qElem.setAttribute("where",fquery.where);}}}
-root.appendChild(reqElem);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},addGroupRenderer:function(ldef,toprenderer){var topRelem=this.createElementNS("","GROUPRENDERER");ldef.appendChild(topRelem);for(var rind=0;rind<toprenderer.length;rind++){var renderer=toprenderer[rind];this.addRenderer(topRelem,renderer);}},addRenderer:function(topRelem,renderer){if(renderer instanceof Array){this.addGroupRenderer(topRelem,renderer);}else{var renderElem=this.createElementNS("",renderer.type.toUpperCase()+"RENDERER");topRelem.appendChild(renderElem);if(renderElem.tagName=="VALUEMAPRENDERER"){this.addValueMapRenderer(renderElem,renderer);}else if(renderElem.tagName=="VALUEMAPLABELRENDERER"){this.addValueMapLabelRenderer(renderElem,renderer);}else if(renderElem.tagName=="SIMPLELABELRENDERER"){this.addSimpleLabelRenderer(renderElem,renderer);}else if(renderElem.tagName=="SCALEDEPENDENTRENDERER"){this.addScaleDependentRenderer(renderElem,renderer);}}},addScaleDependentRen
 derer:function(renderElem,renderer){if(typeof renderer.lower=="string"||typeof renderer.lower=="number"){renderElem.setAttribute("lower",renderer.lower);}
+root.appendChild(reqElem);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},addGroupRenderer:function(ldef,toprenderer){var topRelem=this.createElementNS("","GROUPRENDERER");ldef.appendChild(topRelem);for(var rind=0;rind<toprenderer.length;rind++){var renderer=toprenderer[rind];this.addRenderer(topRelem,renderer);}},addRenderer:function(topRelem,renderer){if(OpenLayers.Util.isArray(renderer)){this.addGroupRenderer(topRelem,renderer);}else{var renderElem=this.createElementNS("",renderer.type.toUpperCase()+"RENDERER");topRelem.appendChild(renderElem);if(renderElem.tagName=="VALUEMAPRENDERER"){this.addValueMapRenderer(renderElem,renderer);}else if(renderElem.tagName=="VALUEMAPLABELRENDERER"){this.addValueMapLabelRenderer(renderElem,renderer);}else if(renderElem.tagName=="SIMPLELABELRENDERER"){this.addSimpleLabelRenderer(renderElem,renderer);}else if(renderElem.tagName=="SCALEDEPENDENTRENDERER"){this.addScaleDependentRenderer(renderElem,renderer);}}},addScaleDepe
 ndentRenderer:function(renderElem,renderer){if(typeof renderer.lower=="string"||typeof renderer.lower=="number"){renderElem.setAttribute("lower",renderer.lower);}
 if(typeof renderer.upper=="string"||typeof renderer.upper=="number"){renderElem.setAttribute("upper",renderer.upper);}
 this.addRenderer(renderElem,renderer.renderer);},addValueMapLabelRenderer:function(renderElem,renderer){renderElem.setAttribute("lookupfield",renderer.lookupfield);renderElem.setAttribute("labelfield",renderer.labelfield);if(typeof renderer.exacts=="object"){for(var ext=0,extlen=renderer.exacts.length;ext<extlen;ext++){var exact=renderer.exacts[ext];var eelem=this.createElementNS("","EXACT");if(typeof exact.value=="string"){eelem.setAttribute("value",exact.value);}
 if(typeof exact.label=="string"){eelem.setAttribute("label",exact.label);}
@@ -1551,7 +1548,18 @@
 this.options.layers.push({id:id,visible:true,query:querydef});},getFeatureInfo:function(geometry,layer,options){var buffer=options.buffer||1;var callback=options.callback||function(){};var scope=options.scope||window;var requestOptions={};OpenLayers.Util.extend(requestOptions,this.options);requestOptions.requesttype="feature";if(geometry instanceof OpenLayers.LonLat){requestOptions.polygon=null;requestOptions.envelope=[geometry.lon-buffer,geometry.lat-buffer,geometry.lon+buffer,geometry.lat+buffer];}else if(geometry instanceof OpenLayers.Geometry.Polygon){requestOptions.envelope=null;requestOptions.polygon=geometry;}
 var arcxml=new OpenLayers.Format.ArcXML(requestOptions);OpenLayers.Util.extend(arcxml.request.get_feature,options);arcxml.request.get_feature.layer=layer.id;if(typeof layer.query.accuracy=="number"){arcxml.request.get_feature.query.accuracy=layer.query.accuracy;}else{var mapCenter=this.map.getCenter();var viewPx=this.map.getViewPortPxFromLonLat(mapCenter);viewPx.x++;var mapOffCenter=this.map.getLonLatFromPixel(viewPx);arcxml.request.get_feature.query.accuracy=mapOffCenter.lon-mapCenter.lon;}
 arcxml.request.get_feature.query.where=layer.query.where;arcxml.request.get_feature.query.spatialfilter.relation="area_intersection";OpenLayers.Request.POST({url:this.getFullRequestString({'CustomService':'Query'}),data:arcxml.write(),callback:function(request){var response=arcxml.parseResponse(request.responseText);if(!arcxml.iserror()){callback.call(scope,response.features);}else{callback.call(scope,null);}}});},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcIMS(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.ArcIMS"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:true,autoDestroy:true,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;this.active=false;},destroy:function(){this.deactivate();this.layer=null;this.options=null;},setLayer:function(layer){this.layer=layer;},activate:function(){if(!this.active){this.active=true;return true;}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.ArcIMS"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:'_layer',featureIdentifier:'_feature',regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},gmlFormat:null,read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;if(root){var scope=this;var read=this["read_"+root.nodeName];if(read){result=read.call(this,root);}else{result=new OpenLayers.Format.GML((this.options?this.options:{})).read(data);}}else{result=data;}
+return result;},read_msGMLOutput:function(data){var response=[];var layerNodes=this.getSiblingNodesByTagCriteria(data,this.layerIdentifier);if(layerNodes){for(var i=0,len=layerNodes.length;i<len;++i){var node=layerNodes[i];var layerName=node.nodeName;if(node.prefix){layerName=layerName.split(':')[1];}
+var layerName=layerName.replace(this.layerIdentifier,'');var featureNodes=this.getSiblingNodesByTagCriteria(node,this.featureIdentifier);if(featureNodes){for(var j=0;j<featureNodes.length;j++){var featureNode=featureNodes[j];var geomInfo=this.parseGeometry(featureNode);var attributes=this.parseAttributes(featureNode);var feature=new OpenLayers.Feature.Vector(geomInfo.geometry,attributes,null);feature.bounds=geomInfo.bounds;feature.type=layerName;response.push(feature);}}}}
+return response;},read_FeatureInfoResponse:function(data){var response=[];var featureNodes=this.getElementsByTagNameNS(data,'*','FIELDS');for(var i=0,len=featureNodes.length;i<len;i++){var featureNode=featureNodes[i];var geom=null;var attributes={};var j;var jlen=featureNode.attributes.length;if(jlen>0){for(j=0;j<jlen;j++){var attribute=featureNode.attributes[j];attributes[attribute.nodeName]=attribute.nodeValue;}}else{var nodes=featureNode.childNodes;for(j=0,jlen=nodes.length;j<jlen;++j){var node=nodes[j];if(node.nodeType!=3){attributes[node.getAttribute("name")]=node.getAttribute("value");}}}
+response.push(new OpenLayers.Feature.Vector(geom,attributes,null));}
+return response;},getSiblingNodesByTagCriteria:function(node,criteria){var nodes=[];var children,tagName,n,matchNodes,child;if(node&&node.hasChildNodes()){children=node.childNodes;n=children.length;for(var k=0;k<n;k++){child=children[k];while(child&&child.nodeType!=1){child=child.nextSibling;k++;}
+tagName=(child?child.nodeName:'');if(tagName.length>0&&tagName.indexOf(criteria)>-1){nodes.push(child);}else{matchNodes=this.getSiblingNodesByTagCriteria(child,criteria);if(matchNodes.length>0){(nodes.length==0)?nodes=matchNodes:nodes.push(matchNodes);}}}}
+return nodes;},parseAttributes:function(node){var attributes={};if(node.nodeType==1){var children=node.childNodes;var n=children.length;for(var i=0;i<n;++i){var child=children[i];if(child.nodeType==1){var grandchildren=child.childNodes;var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;if(grandchildren.length==0){attributes[name]=null}else if(grandchildren.length==1){var grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){var value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
+return attributes;},parseGeometry:function(node){if(!this.gmlFormat){this.gmlFormat=new OpenLayers.Format.GML();}
+var feature=this.gmlFormat.parseFeature(node);var geometry,bounds=null;if(feature){geometry=feature.geometry&&feature.geometry.clone();bounds=feature.bounds&&feature.bounds.clone();feature.destroy();}
+return{geometry:geometry,bounds:bounds};},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:true,autoDestroy:true,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;this.active=false;},destroy:function(){this.deactivate();this.layer=null;this.options=null;},setLayer:function(layer){this.layer=layer;},activate:function(){if(!this.active){this.active=true;return true;}
 return false;},deactivate:function(){if(this.active){this.active=false;return true;}
 return false;},CLASS_NAME:"OpenLayers.Strategy"});OpenLayers.Strategy.Filter=OpenLayers.Class(OpenLayers.Strategy,{filter:null,cache:null,caching:false,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.apply(this,arguments);if(activated){this.cache=[];this.layer.events.on({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
 return activated;},deactivate:function(){this.cache=null;if(this.layer&&this.layer.events){this.layer.events.un({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
@@ -1587,16 +1595,18 @@
 if(feature.geometry){var bounds=feature.geometry.getBounds();if(bounds){if(!bounds.intersectsBounds(this.extent)){style={display:"none"};}
 var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(style.display!="none"&&style.label&&rendered!==false){var location=feature.geometry.getCentroid();if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
 this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
-return rendered;}}},drawGeometry:function(geometry,style,featureId){},drawText:function(featureId,style,location){},removeText:function(featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(features instanceof Array)){features=[features];}
+return rendered;}}},drawGeometry:function(geometry,style,featureId){},drawText:function(featureId,style,location){},removeText:function(featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 for(var i=0,len=features.length;i<len;++i){var feature=features[i];this.eraseGeometry(feature.geometry,feature.id);this.removeText(feature.id);}},eraseGeometry:function(geometry,featureId){},moveRoot:function(renderer){},getRenderLayerId:function(){return this.container.id;},applyDefaultSymbolizer:function(symbolizer){var result=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);if(symbolizer.stroke===false){delete result.strokeWidth;delete result.strokeColor;}
 if(symbolizer.fill===false){delete result.fillColor;}
-OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:true,hitOverflow:0,canvas:null,features:null,pendingRedraw:false,initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};if(this.hitDetection){this.hitCanvas=document.createElement("canvas");this.hitContext=this.hitCanvas.getContext("2d");}},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){var canvas=document.createElement("canvas");return!!canvas.getContext;},setSize:function(size){this.size=size.clone();var root=this.root;
 root.style.width=size.w+"px";root.style.height=size.h+"px";root.width=size.w;root.height=size.h;this.resolution=null;if(this.hitDetection){var hitCanvas=this.hitCanvas;hitCanvas.style.width=size.w+"px";hitCanvas.style.height=size.h+"px";hitCanvas.width=size.w;hitCanvas.height=size.h;}},drawFeature:function(feature,style){var rendered;if(feature.geometry){style=this.applyDefaultSymbolizer(style||feature.style);rendered=(style.display!=="none")&&feature.geometry.getBounds().intersectsBounds(this.extent);if(rendered){this.features[feature.id]=[feature,style];this.pendingRedraw=true;}}
+OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:true,hitOverflow:0,canvas:null,features:null,pendingRedraw:false,initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};if(this.hitDetection){this.hitCanvas=document.createElement("canvas");this.hitContext=this.hitCanvas.getContext("2d");}},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){var canvas=document.createElement("canvas");return!!canvas.getContext;},setSize:function(size){this.size=size.clone();var root=this.root;
 root.style.width=size.w+"px";root.style.height=size.h+"px";root.width=size.w;root.height=size.h;this.resolution=null;if(this.hitDetection){var hitCanvas=this.hitCanvas;hitCanvas.style.width=size.w+"px";hitCanvas.style.height=size.h+"px";hitCanvas.width=size.w;hitCanvas.height=size.h;}},drawFeature:function(feature,style){var rendered;if(feature.geometry){style=this.applyDefaultSymbolizer(style||feature.style);rendered=(style.display!=="none")&&feature.geometry.getBounds().intersectsBounds(this.extent);if(rendered){this.features[feature.id]=[feature,style];}
+else{delete(this.features[feature.id]);}
+this.pendingRedraw=true;}
 if(this.pendingRedraw&&!this.locked){this.redraw();this.pendingRedraw=false;}
 return rendered;},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
 return;}
 switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(geometry,style,featureId);break;case"OpenLayers.Geometry.LineString":this.drawLineString(geometry,style,featureId);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(geometry,style,featureId);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(geometry,style,featureId);break;default:break;}},drawExternalGraphic:function(geometry,style,featureId){var img=new Image();if(style.graphicTitle){img.title=style.graphicTitle;}
 var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;var onLoad=function(){if(!this.features[featureId]){return;}
-var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var x=p0+xOffset;var y=p1+yOffset;var canvas=this.canvas;canvas.globalAlpha=opacity;var factor=OpenLayers.Renderer.Canvas.drawImageScaleFactor||(OpenLayers.Renderer.Canvas.drawImageScaleFactor=/android 2.1/.test(navigator.userAgent.toLowerCase())?320/window.screen.width:1);canvas.drawImage(img,x*factor,y*factor,width*factor,height*factor);if(this.hitDetection){this.setHitContextStyle("fill",featureId);this.hitContext.fillRect(x,y,width,height);}}};img.onload=OpenLayers.Function.bind(onLoad,this);img.src=style.externalGraphic;},setCanvasStyle:function(type,style){if(type==="fill"){this.canvas.globalAlpha=style['fillOpacity'];this.canvas.fillStyle=style['fillColor'];}else if(type==="stroke"){this.canvas.globalAlpha=style['strokeOpacity'];this.canvas.strokeStyle=style['strokeColor'];this.canvas.lineWidth=style['strokeWidth'];}else{this.canvas.globalAlpha=0;this.canvas.lineWidth=1;}},featureIdT
 oHex:function(featureId){var id=Number(featureId.split("_").pop())+1;if(id>=16777216){this.hitOverflow=id-16777215;id=id%16777216+1;}
+var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var x=(p0+xOffset)|0;var y=(p1+yOffset)|0;var canvas=this.canvas;canvas.globalAlpha=opacity;var factor=OpenLayers.Renderer.Canvas.drawImageScaleFactor||(OpenLayers.Renderer.Canvas.drawImageScaleFactor=/android 2.1/.test(navigator.userAgent.toLowerCase())?320/window.screen.width:1);canvas.drawImage(img,x*factor,y*factor,width*factor,height*factor);if(this.hitDetection){this.setHitContextStyle("fill",featureId);this.hitContext.fillRect(x,y,width,height);}}};img.onload=OpenLayers.Function.bind(onLoad,this);img.src=style.externalGraphic;},setCanvasStyle:function(type,style){if(type==="fill"){this.canvas.globalAlpha=style['fillOpacity'];this.canvas.fillStyle=style['fillColor'];}else if(type==="stroke"){this.canvas.globalAlpha=style['strokeOpacity'];this.canvas.strokeStyle=style['strokeColor'];this.canvas.lineWidth=style['strokeWidth'];}else{this.canvas.globalAlpha=0;this.canvas.lineWidth=1;}},fe
 atureIdToHex:function(featureId){var id=Number(featureId.split("_").pop())+1;if(id>=16777216){this.hitOverflow=id-16777215;id=id%16777216+1;}
 var hex="000000"+id.toString(16);var len=hex.length;hex="#"+hex.substring(len-6,len);return hex;},setHitContextStyle:function(type,featureId,symbolizer){var hex=this.featureIdToHex(featureId);if(type=="fill"){this.hitContext.globalAlpha=1.0;this.hitContext.fillStyle=hex;}else if(type=="stroke"){this.hitContext.globalAlpha=1.0;this.hitContext.strokeStyle=hex;this.hitContext.lineWidth=symbolizer.strokeWidth+2;}else{this.hitContext.globalAlpha=0;this.hitContext.lineWidth=1;}},drawPoint:function(geometry,style,featureId){if(style.graphic!==false){if(style.externalGraphic){this.drawExternalGraphic(geometry,style,featureId);}else{var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var twoPi=Math.PI*2;var radius=style.pointRadius;if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.fill();if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.hitC
 ontext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.fill();}}
 if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.stroke();if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.hitContext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.stroke();}
 this.setCanvasStyle("reset");}}}}},drawLineString:function(geometry,style,featureId){style=OpenLayers.Util.applyDefaults({fill:false},style);this.drawLinearRing(geometry,style,featureId);},drawLinearRing:function(geometry,style,featureId){if(style.fill!==false){this.setCanvasStyle("fill",style);this.renderPath(this.canvas,geometry,style,featureId,"fill");if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"fill");}}
@@ -1609,7 +1619,7 @@
 var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
 var lineHeight=this.canvas.mozMeasureText('xx');pt[1]+=lineHeight*(1+(vfactor*numRows));for(var i=0;i<numRows;i++){var x=pt[0]+(hfactor*this.canvas.mozMeasureText(labelRows[i]));var y=pt[1]+(i*lineHeight);this.canvas.translate(x,y);this.canvas.mozDrawText(labelRows[i]);this.canvas.translate(-x,-y);}}
 this.setCanvasStyle("reset");},getLocalXY:function(point){var resolution=this.getResolution();var extent=this.extent;var x=(point.x/resolution+(-extent.left/resolution));var y=((extent.top/resolution)-point.y/resolution);return[x,y];},clear:function(){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);this.features={};if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}},getFeatureIdFromEvent:function(evt){var feature=null;if(this.hitDetection){if(!this.map.dragging){var xy=evt.xy;var x=xy.x|0;var y=xy.y|0;var data=this.hitContext.getImageData(x,y,1,1).data;if(data[3]===255){var id=data[2]+(256*(data[1]+(256*data[0])));if(id){feature=this.features["OpenLayers.Feature.Vector_"+(id-1+this.hitOverflow)][0];}}}}
-return feature;},eraseFeatures:function(features){if(!(features instanceof Array)){features=[features];}
+return feature;},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 for(var i=0;i<features.length;++i){delete this.features[features[i].id];}
 this.redraw();},redraw:function(){if(!this.locked){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}
 var labelMap=[];var feature,style;for(var id in this.features){if(!this.features.hasOwnProperty(id)){continue;}
@@ -1632,7 +1642,7 @@
 return return_ways;},getTags:function(dom_node,interesting_tags){var tag_list=dom_node.getElementsByTagName("tag");var tags={};var interesting=false;for(var j=0;j<tag_list.length;j++){var key=tag_list[j].getAttribute("k");tags[key]=tag_list[j].getAttribute("v");if(interesting_tags){if(!this.interestingTagsExclude[key]){interesting=true;}}}
 return interesting_tags?[tags,interesting]:tags;},isWayArea:function(way){var poly_shaped=false;var poly_tags=false;if(way.nodes[0]==way.nodes[way.nodes.length-1]){poly_shaped=true;}
 if(this.checkTags){for(var key in way.tags){if(this.areaTags[key]){poly_tags=true;break;}}}
-return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(features instanceof Array)){features=[features];}
+return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 this.osm_id=1;this.created_nodes={};var root_node=this.createElementNS(null,"osm");root_node.setAttribute("version","0.5");root_node.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var i=features.length-1;i>=0;i--){var nodes=this.createFeatureNodes(features[i]);for(var j=0;j<nodes.length;j++){root_node.appendChild(nodes[j]);}}
 return OpenLayers.Format.XML.prototype.write.apply(this,[root_node]);},createFeatureNodes:function(feature){var nodes=[];var className=feature.geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);type=type.toLowerCase();var builder=this.createXML[type];if(builder){nodes=builder.apply(this,[feature]);}
 return nodes;},createXML:{'point':function(point){var id=null;var geometry=point.geometry?point.geometry:point;if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
@@ -1658,7 +1668,7 @@
 return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.touch=false;this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
 return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null},'touchstart':{'in':'click','out':'clickout'}},feature:null,lastFeature:n
 ull,down:null,up:null,touch:false,clickTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:false,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
-return this.mousedown(evt);},touchmove:function(evt){OpenLayers.Event.stop(evt);},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){if(!this.callbacks['over']&&!this.callbacks['out']){return true;}
+return OpenLayers.Event.isMultiTouch(evt)?true:this.mousedown(evt);},touchmove:function(evt){OpenLayers.Event.stop(evt);},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){if(!this.callbacks['over']&&!this.callbacks['out']){return true;}
 this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){if(this.feature&&!this.feature.layer){this.feature=null;}
 var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick"||type=="touchstart");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature&&!this.feature.layer){this.feature=null;}
 if(this.lastFeature&&!this.lastFeature.layer){this.lastFeature=null;}
@@ -1670,7 +1680,7 @@
 return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
 Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.touch=false;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
-return deactivated;},handleMapEvents:function(evt){if(!evt.property||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={drag:new Op
 enLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},clickFeature:function(feature){if(!this.over&&this.overFeature(feature)){this.handlers.drag.dragstart(this.handlers.feature.evt);this.handlers.drag.stopDown=false;}},clickoutFeature:function(feature){if(this.over){this.outFeature(feature);this.handlers.drag.stopDown=true;}},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deactivate();th
 is.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){var activated=false;if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();activated=true;this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}
+return deactivated;},handleMapEvents:function(evt){if(evt.type=="removelayer"||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={d
 rag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},clickFeature:function(feature){if(!this.over&&this.overFeature(feature)){this.handlers.drag.dragstart(this.handlers.feature.evt);this.handlers.drag.stopDown=false;}},clickoutFeature:function(feature){if(this.over){this.outFeature(feature);this.handlers.drag.stopDown=true;}},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deact
 ivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){var activated=false;if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();activated=true;this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}
 return activated;},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");this.onLeave(feature);this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},
 CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;this.styles["delete"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style
 );this.styles["delete"]=new OpenLayers.Style(style);break;}}}
 OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
 this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
@@ -1690,7 +1700,7 @@
 obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){
 strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var ng=(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG);if(ng){zoomChanged&&this.renderer.updateDimensions();}else{var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility="visible";if(OpenLayers.IS
 _GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
 if(!zoomChanged&&coordSysUnchanged){for(var i in this.unrenderedFeatures){var feature=this.unrenderedFeatures[i];this.drawFeature(feature);}}}}
 if(!this.drawn||(!ng&&(zoomChanged||!coordSysUnchanged))){this.drawn=true;var feature;for(var i=0,len=this.features.length;i<len;i++){this.renderer.locked=(i!==(len-1));feature=this.features[i];this.drawFeature(feature);}}},redraw:function(){if(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG){this.drawn=false;}
-return OpenLayers.Layer.prototype.redraw.apply(this,arguments);},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(features instanceof Array)){features=[features];}
+return OpenLayers.Layer.prototype.redraw.apply(this,arguments);},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 var notify=!options||!options.silent;if(notify){var event={features:features};var ret=this.events.triggerEvent("beforefeaturesadded",event);if(ret===false){return;}
 features=event.features;}
 var featuresAdded=[];for(var i=0,len=features.length;i<len;i++){if(i!=(features.length-1)){this.renderer.locked=true;}else{this.renderer.locked=false;}
@@ -1700,7 +1710,7 @@
 featuresAdded.push(feature);this.features.push(feature);this.drawFeature(feature);if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
 if(notify){this.events.triggerEvent("featuresadded",{features:featuresAdded});}},removeFeatures:function(features,options){if(!features||features.length===0){return;}
 if(features===this.features){return this.removeAllFeatures(options);}
-if(!(features instanceof Array)){features=[features];}
+if(!(OpenLayers.Util.isArray(features))){features=[features];}
 if(features===this.selectedFeatures){features=features.slice();}
 var notify=!options||!options.silent;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
 for(var i=features.length-1;i>=0;i--){if(i!=0&&features[i-1].geometry){this.renderer.locked=true;}else{this.renderer.locked=false;}
@@ -1722,7 +1732,7 @@
 return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){maxExtent=new OpenLayers.Bounds();var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){maxExtent.extend(geometry.getBounds());}}}
 return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer
 .moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){layer=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforefeaturehighlighted","featurehighlighted","featureunhighlighted"],multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){this.EVENT_TYPES=OpenLayers.Control.Select
 Feature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
 this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
-this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(layers instanceof Array){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
+this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(OpenLayers.Util.isArray(layers)){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
 OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
 this.handlers.feature.activate();if(this.box&&this.handlers.box){this.handlers.box.activate();}}
 return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){this.handlers.feature.deactivate();if(this.handlers.box){this.handlers.box.deactivate();}
@@ -1738,19 +1748,20 @@
 this.initLayer(layers);this.handlers.feature.layer=this.layer;if(isActive){this.activate();}},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.observe(document,this.KEY_EVENTS[i],this.eventListener);}
 return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.stopObserving(document,this.KEY_EVENTS[i],this.eventListener);}
 deactivated=true;}
-return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,standalone:false,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,modified:false,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){options=options||{};this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,options.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Control.ModifyFeature
 .RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(this.deleteCodes instanceof Array)){this.deleteCodes=[this.deleteCodes];}
+return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,standalone:false,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,modified:false,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){options=options||{};this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,options.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Control.ModifyFeature
 .RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(OpenLayers.Util.isArray(this.deleteCodes))){this.deleteCodes=[this.deleteCodes];}
 var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,onBeforeSelect:this.beforeSelectFeature,onSelect:this.selectFeature,onUnselect:this.unselectFeature,scope:this};if(this.standalone===false){this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);}
 var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature,pixel){control.dragVertex.apply(control,[feature,pixel]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);},featureCallbacks:{over:function(feature){if(control.standalone!==true||feature._sketch||control.feature===feature){control.dragControl.overFeature.apply(control.dragControl,[feature]);}}}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keydown:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer=null;this.standalone||this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return((this.standalone||this.selectControl.activate())&&this.handlers.keyb
 oard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices,{silent:true});this.layer.removeFeatures(this.virtualVertices,{silent:true});this.vertices=[];this.dragControl.deactivate();var feature=this.feature;var valid=feature&&feature.geometry&&feature.layer;if(this.standalone===false){if(valid){this.selectControl.unselect.apply(this.selectControl,[feature]);}
 this.selectControl.deactivate();}else{if(valid){this.unselectFeature(feature);}}
 this.handlers.keyboard.deactivate();deactivated=true;}
-return deactivated;},beforeSelectFeature:function(feature){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});},selectFeature:function(feature){if(!this.standalone||this.beforeSelectFeature(feature)!==false){this.feature=feature;this.modified=false;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);}},unselectFeature:function(feature){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});delete this.dragHandle;}
+return deactivated;},beforeSelectFeature:function(feature){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});},selectFeature:function(feature){if(!this.standalone||this.beforeSelectFeature(feature)!==false){this.feature=feature;this.modified=false;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);}
+var modified=feature.modified;if(feature.geometry&&!(modified&&modified.geometry)){this._originalGeometry=feature.geometry.clone();}},unselectFeature:function(feature){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});delete this.dragHandle;}
 if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});delete this.radiusHandle;}
 this.feature=null;this.dragControl.deactivate();this.onModificationEnd(feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:feature,modified:this.modified});this.modified=false;},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
 if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex,pixel){this.modified=true;if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}
 this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}}else if(vertex!==this.radiusHandle){this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}
 if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
 this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);}
-this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE){this.feature.state=OpenLayers.State.UPDATE;}},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
+this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE){this.feature.state=OpenLayers.State.UPDATE;if(this.modified&&this._originalGeometry){var feature=this.feature;feature.modified=OpenLayers.Util.extend(feature.modified,{geometry:this._originalGeometry});delete this._originalGeometry;}}},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
 if(this.vertices.length>0){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];}
 if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
 if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});this.dragHandle=null;}
@@ -1762,14 +1773,14 @@
 if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0,len=geometry.components.length;i<len-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;point._sketch=true;control.virtualVertices.push(point);}}}}}
 collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:true});this.layer.addFeatures(this.vertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};origin._sketch=true;this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&O
 penLayers.Control.ModifyFeature.RESIZE);var reshape=(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
 if(resize){var scale,ratio;if(reshape){scale=dy1/dy0;ratio=(dx1/dx0)/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
-geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.standalone||this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Layer.Bing=OpenLayers.Class(OpenLayers.Layer.XYZ,{attributionTemplate:'<span class="olBingAttribution ${type}">'+'<div><a target="_blank" href="http://www.bing.com/maps/">'+'<img src="${logo}" /></a></div>${copyrights}'+'<a style="white-space: nowrap" target="_blank" '+'href="http://www.microsoft.com/maps/product/terms.html">'+'Terms of Use</a></span>',metadata:null,type:"Road",metadataParams:null,initialize:function(options){options=OpenLayers.Util
 .applyDefaults({restrictedMinZoom:1,sphericalMercator:true},options);var name=options.name||"Bing "+(options.type||this.type);var newArgs=[name,null,options];OpenLayers.Layer.XYZ.prototype.initialize.apply(this,newArgs);this.loadMetadata();},loadMetadata:function(){this._callbackId="_callback_"+this.id.replace(/\./g,"_");window[this._callbackId]=OpenLayers.Function.bind(OpenLayers.Layer.Bing.processMetadata,this);var params=OpenLayers.Util.applyDefaults({key:this.key,jsonp:this._callbackId,include:"ImageryProviders"},this.metadataParams);var url="http://dev.virtualearth.net/REST/v1/Imagery/Metadata/"+
-this.type+"?"+OpenLayers.Util.getParameterString(params);var script=document.createElement("script");script.type="text/javascript";script.src=url;script.id=this._callbackId;document.getElementsByTagName("head")[0].appendChild(script);},initLayer:function(){var res=this.metadata.resourceSets[0].resources[0];var url=res.imageUrl.replace("{quadkey}","${quadkey}");this.url=[];for(var i=0;i<res.imageUrlSubdomains.length;++i){this.url.push(url.replace("{subdomain}",res.imageUrlSubdomains[i]));};this.addOptions({restrictedMinZoom:res.zoomMin,numZoomLevels:res.zoomMax+1});this.updateAttribution();this.redraw();},getURL:function(bounds){if(!this.url){return OpenLayers.Util.getImagesLocation()+"blank.gif";}
+geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.standalone||this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Layer.Bing=OpenLayers.Class(OpenLayers.Layer.XYZ,{serverResolutions:[156543.03390625,78271.516953125,39135.7584765625,19567.87923828125,9783.939619140625,4891.9698095703125,2445.9849047851562,1222.9924523925781,611.4962261962891,305.74811309814453,152.87405654907226,76.43702827453613,38.218514137268066,19.109257068634033,9.554628534317017,4.777314267158508,2.388657133579254,1.194328566789627,0.5971642833948135,0.29858214169740677,0.14929107084870338
 ,0.07464553542435169],attributionTemplate:'<span class="olBingAttribution ${type}">'+'<div><a target="_blank" href="http://www.bing.com/maps/">'+'<img src="${logo}" /></a></div>${copyrights}'+'<a style="white-space: nowrap" target="_blank" '+'href="http://www.microsoft.com/maps/product/terms.html">'+'Terms of Use</a></span>',metadata:null,type:"Road",metadataParams:null,initialize:function(options){options=OpenLayers.Util.applyDefaults({sphericalMercator:true},options);var name=options.name||"Bing "+(options.type||this.type);var newArgs=[name,null,options];OpenLayers.Layer.XYZ.prototype.initialize.apply(this,newArgs);this.loadMetadata();},loadMetadata:function(){this._callbackId="_callback_"+this.id.replace(/\./g,"_");window[this._callbackId]=OpenLayers.Function.bind(OpenLayers.Layer.Bing.processMetadata,this);var params=OpenLayers.Util.applyDefaults({key:this.key,jsonp:this._callbackId,include:"ImageryProviders"},this.metadataParams);var url="http://dev.virtualearth.net/RES
+this.type+"?"+OpenLayers.Util.getParameterString(params);var script=document.createElement("script");script.type="text/javascript";script.src=url;script.id=this._callbackId;document.getElementsByTagName("head")[0].appendChild(script);},initLayer:function(){var res=this.metadata.resourceSets[0].resources[0];var url=res.imageUrl.replace("{quadkey}","${quadkey}");this.url=[];for(var i=0;i<res.imageUrlSubdomains.length;++i){this.url.push(url.replace("{subdomain}",res.imageUrlSubdomains[i]));};this.addOptions({maxResolution:Math.min(this.serverResolutions[res.zoomMin],this.maxResolution),zoomOffset:res.zoomMin,numZoomLevels:Math.min(res.zoomMax+1-res.zoomMin,this.numZoomLevels)},true);},getURL:function(bounds){if(!this.url){return OpenLayers.Util.getImagesLocation()+"blank.gif";}
 var xyz=this.getXYZ(bounds),x=xyz.x,y=xyz.y,z=xyz.z;var quadDigits=[];for(var i=z;i>0;--i){var digit='0';var mask=1<<(i-1);if((x&mask)!=0){digit++;}
 if((y&mask)!=0){digit++;digit++;}
 quadDigits.push(digit);}
 var quadKey=quadDigits.join("");var url=this.selectUrl(''+x+y+z,this.url);return OpenLayers.String.format(url,{'quadkey':quadKey});},updateAttribution:function(){var metadata=this.metadata;if(!metadata||!this.map||!this.map.center){return;}
 var res=metadata.resourceSets[0].resources[0];var extent=this.map.getExtent().transform(this.map.getProjectionObject(),new OpenLayers.Projection("EPSG:4326"));var providers=res.imageryProviders,zoom=this.map.getZoom()+1,copyrights="",provider,i,ii,j,jj,bbox,coverage;for(i=0,ii=providers.length;i<ii;++i){provider=providers[i];for(j=0,jj=provider.coverageAreas.length;j<jj;++j){coverage=provider.coverageAreas[j];bbox=OpenLayers.Bounds.fromArray(coverage.bbox);if(extent.intersectsBounds(bbox)&&zoom<=coverage.zoomMax&&zoom>=coverage.zoomMin){copyrights+=provider.attribution+" ";}}}
-this.attribution=OpenLayers.String.format(this.attributionTemplate,{type:this.type.toLowerCase(),logo:metadata.brandLogoUri,copyrights:copyrights});this.map&&this.map.events.triggerEvent("changelayer",{layer:this});},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.updateAttribution();this.map.events.register("moveend",this,this.updateAttribution);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Bing(this.options);}
+this.attribution=OpenLayers.String.format(this.attributionTemplate,{type:this.type.toLowerCase(),logo:metadata.brandLogoUri,copyrights:copyrights});this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"attribution"});},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.updateAttribution();this.map.events.register("moveend",this,this.updateAttribution);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Bing(this.options);}
 obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},destroy:function(){this.map&&this.map.events.unregister("moveend",this,this.updateAttribution);OpenLayers.Layer.XYZ.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.Bing"});OpenLayers.Layer.Bing.processMetadata=function(metadata){this.metadata=metadata;this.initLayer();var script=document.getElementById(this._callbackId);script.parentNode.removeChild(script);window[this._callbackId]=undefined;delete this._callbackId;};OpenLayers.Format.SOSGetFeatureOfInterest=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",sa:"http://www.opengis.net/sampling/1.0",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosAll.xsd",defaultPrefix:"sos",regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\
 s*,\s*/g)},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
 var info={features:[]};this.readNode(data,info);var features=[];for(var i=0,len=info.features.length;i<len;i++){var container=info.features[i];if(this.internalProjection&&this.externalProjection&&container.components[0]){container.components[0].transform(this.externalProjection,this.internalProjection);}
@@ -1798,12 +1809,12 @@
 this.delta=this.delta+delta;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(e);},this),this.interval);}else{this.wheelZoom(e);}}
 OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=this.delta;this.delta=0;if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
 if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
-if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Format.WFST.v1_0_0=OpenLayers.Class(OpenLayers.For
 mat.Filter.v1_0_0,OpenLayers.Format.WFST.v1,{version:"1.0.0",srsNameInQuery:false,schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"WFS_TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"InsertResult":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);},"TransactionResult":function(node,obj){this.readChildNodes(node,obj);},"Status":function(node,obj){this.readChildNodes(node,obj);},"SUCCESS":function(node,obj){obj.success=true;}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"],"ogc":OpenL
 ayers.Format.Filter.v1_0_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},options);var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(options.featureNS?options.featurePrefix+":":"")+
+if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Format.WFST.v1_0_0=OpenLayers.Class(OpenLayers.For
 mat.Filter.v1_0_0,OpenLayers.Format.WFST.v1,{version:"1.0.0",srsNameInQuery:false,schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readNode:function(node,obj,first){return OpenLayers.Format.GML.v2.prototype.readNode.apply(this,[node,obj]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"WFS_TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"InsertResult":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);},"TransactionResult":function(node,obj){this.readChildNodes(node,obj);},"Status":function(node,obj){this.readChildNodes(node,obj);},"SUCCESS":function(node,obj){obj.success=true;}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Form
 at.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},options);var prefix=options.featurePrefix;var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(prefix?prefix+":":"")+
 options.featureType}});if(options.srsNameInQuery&&options.srsName){node.setAttribute("srsName",options.srsName);}
-if(options.featureNS){node.setAttribute("xmlns:"+options.featurePrefix,options.featureNS);}
+if(options.featureNS){node.setAttribute("xmlns:"+prefix,options.featureNS);}
 if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("ogc:PropertyName",{property:options.propertyNames[i]},node);}}
 if(options.filter){this.setFilterProperty(options.filter);this.writeNode("ogc:Filter",options.filter,node);}
-return node;}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_0_0"});OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(yOrdering){this.compare=yOrdering?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.order=[];this.indices={};this.maxZIndex=0;},insert:function(newNode){if(this.exists(newNode)){this.remove(newNode);}
+return node;}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_0_0"});OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(yOrdering){this.compare=yOrdering?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.clear();},insert:function(newNode){if(this.exists(newNode)){this.remove(newNode);}
 var nodeId=newNode.id;this.determineZIndex(newNode);var leftIndex=-1;var rightIndex=this.order.length;var middle;while(rightIndex-leftIndex>1){middle=parseInt((leftIndex+rightIndex)/2);var placement=this.compare(this,newNode,OpenLayers.Util.getElement(this.order[middle]));if(placement>0){leftIndex=middle;}else{rightIndex=middle;}}
 this.order.splice(rightIndex,0,nodeId);this.indices[nodeId]=this.getZIndex(newNode);return this.getNextElement(rightIndex);},remove:function(node){var nodeId=node.id;var arrayIndex=OpenLayers.Util.indexOf(this.order,nodeId);if(arrayIndex>=0){this.order.splice(arrayIndex,1);delete this.indices[nodeId];if(this.order.length>0){var lastId=this.order[this.order.length-1];this.maxZIndex=this.indices[lastId];}else{this.maxZIndex=0;}}},clear:function(){this.order=[];this.indices={};this.maxZIndex=0;},exists:function(node){return(this.indices[node.id]!=null);},getZIndex:function(node){return node._style.graphicZIndex;},determineZIndex:function(node){var zIndex=node._style.graphicZIndex;if(zIndex==null){zIndex=this.maxZIndex;node._style.graphicZIndex=zIndex;}else if(zIndex>this.maxZIndex){this.maxZIndex=zIndex;}},getNextElement:function(index){var nextIndex=index+1;if(nextIndex<this.order.length){var nextElement=OpenLayers.Util.getElement(this.order[nextIndex]);if(nextElement==undefin
 ed){nextElement=this.getNextElement(nextIndex);}
 return nextElement;}else{return null;}},CLASS_NAME:"OpenLayers.ElementsIndexer"});OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(indexer,newNode,nextNode){var newZIndex=indexer.getZIndex(newNode);var returnVal=0;if(nextNode){var nextZIndex=indexer.getZIndex(nextNode);returnVal=newZIndex-nextZIndex;}
@@ -1835,13 +1846,13 @@
 else{OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);this.base=base||document.location.href;}},destroy:function(){if(this.element.parentNode==this.div){this.div.removeChild(this.element);}
 this.element=null;this.map.events.unregister('moveend',this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0,len=this.map.controls.length;i<len;i++){var control=this.map.controls[i];if(control.CLASS_NAME==this.argParserClass.CLASS_NAME){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
 break;}}
-if(i==this.map.controls.length){this.map.addControl(new this.argParserClass({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element&&!this.anchor){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("permalink");this.element.href="";this.div.appendChild(this.element);}
+if(i==this.map.controls.length){this.map.addControl(new this.argParserClass({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element&&!this.anchor){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("Permalink");this.element.href="";this.div.appendChild(this.element);}
 this.map.events.on({'moveend':this.updateLink,'changelayer':this.updateLink,'changebaselayer':this.updateLink,scope:this});this.updateLink();return this.div;},updateLink:function(){var separator=this.anchor?'#':'?';var href=this.base;if(href.indexOf(separator)!=-1){href=href.substring(0,href.indexOf(separator));}
 href+=separator+OpenLayers.Util.getParameterString(this.createParams());if(this.anchor&&!this.element){window.location.href=href;}
 else{this.element.href=href;}},createParams:function(center,zoom,layers){center=center||this.map.getCenter();var params=OpenLayers.Util.getParameters(this.base);if(center){params.zoom=zoom||this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
 params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;layers=layers||this.map.layers;params.layers='';for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}}
-return params;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
+return params;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(path,url);}
 return url+path;},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Protocol.AgsFeatureAccess=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.AgsFeatureAccess.DEFAULTS);var cls=OpenLayers.Protocol.AgsFeatureAccess["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported AgsFeatureAccess version: "+options.version;}
 return new cls(options);};OpenLayers.Protocol.AgsFeatureAccess.DEFAULTS={"version":"2.0"};OpenLayers.Format.AgsJsAdapter=(function(){var _AGS_UNITS={'UNIT_METER':9001,'UNIT_FOOT':9002,'UNIT_KILOMETER':9036,'UNIT_DEGREE':9102};var _AGS_SPATIALRELATIONSHIP={'INTERSECTS':"esriSpatialRelIntersects",'CONTAINS':"esriSpatialRelContains",'CROSSES':"esriSpatialRelCrosses",'ENVELOPE_INTERSECTS':"esriSpatialRelEnvelopeIntersects",'INDEX_INTERSECTS':"esriSpatialRelIndexIntersects",'OVERLAPS':"esriSpatialRelOverlaps",'TOUCHES':"esriSpatialRelTouches",'WITHIN':"esriSpatialRelWithin"};var _AGS_GEOMETRY_SPATIALRELATIONSHIP={'CROSS':"esriGeometryRelationCross",'DISJOINT':"esriGeometryRelationDisjoint",'IN':"esriGeometryRelationIn",'INTERIOR_INTERSECTION':"esriGeometryRelationInteriorIntersection",'INTERSECTION':"esriGeometryRelationIntersection",'LINE_COINCIDENCE':"esriGeometryRelationLineCoincidence",'LINE_TOUCHE':"esriGeometryRelationLineTouch",'OVERLAP':"esriGeometryRelationOverlap",'POIN
 T_TOUCH':"esriGeometryRelationPointTouch",'RELATION':"esriGeometryRelationRelation",'TOUCH':"esriGeometryRelationTouch",'WITHIN':"esriGeometryRelationWithin",};var _UNMATCH_AGS_WKID={'900913':"102113"};var _UNMATCH_OL_WKID={'102113':"900913"};var _OL_GEOMETRY_MAP={'OpenLayers.Geometry.Point':"point",'OpenLayers.Geometry.MultiLineString':"polyline",'OpenLayers.Geometry.LineString':"polyline",'OpenLayers.Geometry.MultiPolygon':"polygon",'OpenLayers.Geometry.Polygon':"polygon",'OpenLayers.Bounds':"extent"};var _AGS_OL_RENDERER_PARSER_MAP={'esri.renderer.SimpleRenderer':"SimpleRenderer",'esri.renderer.ClassBreaksRenderer':"ClassBreaksRenderer",'esri.renderer.UniqueValueRenderer':"UniqueValueRenderer"};var _OL_AGS_STYLE_MAP={'OpenLayers.Geometry.Point':"SimpleMarkerSymbol",'OpenLayers.Geometry.MultiLineString':"SimpleLineSymbol",'OpenLayers.Geometry.Polygon':"SimpleFillSymbol",'OpenLayers.Bounds':"SimpleFillSymbol",'simplemarkersymbol':"SimpleMarkerSymbol",'picturemarkersymbol':"
 PictureMarkerSymbol",'simplelinesymbol':"SimpleLineSymbol",'cartographiclinesymbol':"CartographicLineSymbol",'simplefillsymbol':"SimleFillSymbol",'picturefillsymbol':"PictureFillSymbol",};var _AGS_OL_SYMBOL_PARSER_MAP={'simplemarkersymbol':"SimpleMarkerSymbol",'picturemarkersymbol':"PictureMarkerSymbol",'simplelinesymbol':"SimpleLineSymbol",'cartographiclinesymbol':"CartographicLineSymbol",'simplefillsymbol':"SimpleFillSymbol",'picturefillsymbol':"PictureFillSymbol"};var _OL_AGS_SIMPLE_MARKERSYMBOL_MAP={'circle':"STYLE_CIRCLE",'cross':"STYLE_CROSS",'diamond':"STYLE_DIAMOND",'square':"STYLE_SQUARE",'x':"STYLE_X"};var _AGS_OL_SIMPLE_MARKERSYMBOL_MAP={'STYLE_CIRCLE':"circle",'STYLE_CROSS':"cross",'STYLE_DIAMOND':"diamond",'STYLE_SQUARE':"square",'STYLE_X':"x"};var _OL_AGS_SIMPLE_LINESYMBOL_MAP={'dash':"STYLE_DASH",'dashdot':"STYLE_DASHDOT",'longdashdot':"STYLE_DASHDOTDOT",'dot':"STYLE_DOT",'solid':"STYLE_NULL",'solid':"STYLE_SOLID"};var _AGS_OL_SIMPLE_LINESYMBOL_MAP={'STYLE_DAS
 H':"dash",'STYLE_DASHDOT':"dashdot",'STYLE_DASHDOTDOT':"longdashdot",'STYLE_DOT':"dot",'STYLE_NULL':"solid",'STYLE_SOLID':"solid"};var _OL_AGS_NAUTURN_MAP={'ALLOW_BACKTRACK':"allow_backtrack",'AT_DEAD_ENDS_ONLY':"at_dead_ends_only",'NO_BACKTRACK':"no_backtrack"};var _AGS_OL_NAUTURN_MAP={'allow_backtrack':"ALLOW_BACKTRACK",'at_dead_ends_only':"AT_DEAD_ENDS_ONLY",'no_backtrack':"NO_BACKTRACK"};var _OL_AGS_NAOUTPUTLINE_MAP={'NONE':"none",'STRAIGHT':"straight",'TRUE_SHAPE':"true_shape",'TRUE_SHAPE_WITH_MEASURE':"true_shape_with_measure"};var _AGS_OL_NAOUTPUTLINE_MAP={'none':"NONE",'straight':"STRAIGHT",'true_shape':"TRUE_SHAPE",'true_shape_with_measure':"TRUE_SHAPE_WITH_MEASURE"};var _OL_ROUTETASK_STYLE={'route':{strokeColor:"#00FF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",},'stop':{fillColor:"#FFFF00",fillOpacity:1,strokeColor:"#FF0000",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10,},'barrier':{fi
 llColor:"#FF0000",fillOpacity:1,strokeColor:"#FFFF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10,}};var _isDefined=OpenLayers.Util.AgsUtil.isDefined;var _isNumber=OpenLayers.Util.AgsUtil.isNumber;var _isBoolean=OpenLayers.Util.AgsUtil.isBoolean;var _isAgsGeometry=OpenLayers.Util.AgsUtil.isAgsGeometry;var _isOLGeometry=OpenLayers.Util.AgsUtil.isOLGeometry;var _isSameOLPoint=OpenLayers.Util.AgsUtil.isSameOLPoint;function _toAgsWkid(olWkid){if(_isDefined(_UNMATCH_AGS_WKID[olWkid])){return _UNMATCH_AGS_WKID[olWkid];}else{return olWkid;}};function _toOlWkid(agsWkid){if(_isDefined(_UNMATCH_OL_WKID[agsWkid])){return _UNMATCH_OL_WKID[agsWkid];}else{return agsWkid;}};function __bindFunction(func,scope){if(window.dojo!==undefined){return dojo.hitch(scope,func);}else{OpenLayers.Console.log("...dojo not found...use OpenLayers.Function.bind() to bind function to scope...");return OpenLayers.Function.bind(func,scope);}}
 return function(config){this.config={'defaultEncodeWkid':"EPSG:900913"};this.parseAgsGeometry={"point":function(agsPoint){var olPoint=null;if(agsPoint instanceof esri.geometry.Point&&_isNumber(agsPoint.x)&&_isNumber(agsPoint.y)){olPoint=new OpenLayers.Geometry.Point(agsPoint.x,agsPoint.y);return olPoint;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.point...invalid esri.geometry.Point...");throw"...AgsAdapter.parseAgsGeometry.point...invalid esri.geometry.Point..."+agsPoint;}},"coordinate":function(agsCoordinate){var olCoordinate=null;if(agsCoordinate instanceof Array&&_isNumber(agsCoordinate[0])&&_isNumber(agsCoordinate[1])){olCoordinate=new OpenLayers.Geometry.Point(agsCoordinate[0],agsCoordinate[1]);return olCoordinate;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.coordinate...invalid array [x, y]...");throw"...AgsAdapter.parseAgsGeometry.coordinate...invalid array [x, y]..."+agsCoordinate;}},"path":function(agsPointArray){var olLineString
 =null;if(agsPointArray instanceof Array){var olPoints=[];for(var i=0;i<agsPointArray.length;i++){var olPoint=null;try{olPoint=this.parseAgsGeometry['coordinate'].apply(this,[agsPointArray[i]]);olPoints.push(olPoint);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
@@ -2017,7 +2028,7 @@
 if(i>0){var attributes=(this.dataFrom!=null)?(pointFeatures[i+this.dataFrom].data||pointFeatures[i+this.dataFrom].attributes):null;var style=(this.styleFrom!=null)?(pointFeatures[i+this.styleFrom].style):null;var line=new OpenLayers.Geometry.LineString([startPoint,endPoint]);lines[i-1]=new OpenLayers.Feature.Vector(line,attributes,style);}
 startPoint=endPoint;}
 this.addFeatures(lines,options);},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.SOURCE_NODE=-1;OpenLayers.Layer.PointTrack.TARGET_NODE=0;OpenLayers.Layer.PointTrack.dataFrom={'SOURCE_NODE':-1,'TARGET_NODE':0};OpenLayers.Protocol.WFS=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.WFS.DEFAULTS);var cls=OpenLayers.Protocol.WFS["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFS version: "+options.version;}
-return new cls(options);};OpenLayers.Protocol.WFS.fromWMSLayer=function(layer,options){var typeName,featurePrefix;var param=layer.params["LAYERS"];var parts=(param instanceof Array?param[0]:param).split(":");if(parts.length>1){featurePrefix=parts[0];}
+return new cls(options);};OpenLayers.Protocol.WFS.fromWMSLayer=function(layer,options){var typeName,featurePrefix;var param=layer.params["LAYERS"];var parts=(OpenLayers.Util.isArray(param)?param[0]:param).split(":");if(parts.length>1){featurePrefix=parts[0];}
 typeName=parts.pop();var protocolOptions={url:layer.url,featureType:typeName,featurePrefix:featurePrefix,srsName:layer.projection&&layer.projection.getCode()||layer.map&&layer.map.getProjectionObject().getCode(),version:"1.1.0"};return new OpenLayers.Protocol.WFS(OpenLayers.Util.applyDefaults(options,protocolOptions));};OpenLayers.Protocol.WFS.DEFAULTS={"version":"1.0.0"};OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,markers:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[];},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.markers.length;i<len;i++){this.markers[i].setOpacity(this.opacity);}}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(zoomChanged
 ||!this.drawn){for(var i=0,len=this.markers.length;i<len;i++){this.drawMarker(this.markers[i]);}
 this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity!=null){marker.setOpacity(this.opacity);}
 if(this.map&&this.map.getExtent()){marker.map=this.map;this.drawMarker(marker);}},removeMarker:function(marker){if(this.markers&&this.markers.length){OpenLayers.Util.removeItem(this.markers,marker);marker.erase();}},clearMarkers:function(){if(this.markers!=null){while(this.markers.length>0){this.removeMarker(this.markers[0]);}}},drawMarker:function(marker){var px=this.map.getLayerPxFromLonLat(marker.lonlat);if(px==null){marker.display(false);}else{if(!marker.isDrawn()){var markerImg=marker.draw(px);this.div.appendChild(markerImg);}else if(marker.icon){marker.icon.moveTo(px);}}},getDataExtent:function(){var maxExtent=null;if(this.markers&&(this.markers.length>0)){var maxExtent=new OpenLayers.Bounds();for(var i=0,len=this.markers.length;i<len;i++){var marker=this.markers[i];maxExtent.extend(marker.lonlat);}}
@@ -2047,10 +2058,9 @@
 newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(!this.noMagic&&this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
 if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions());}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},reverseAxisOrder:function(){return(parseFloat(this.params.VERSION)>=1.3&&!!this.yx[this.map.getProjectionObject().getCode()]);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={};var reverseAxisOrder=this.reverseAxisOrder();newParams.BBOX=this.encodeBBOX?bounds.toBBOX(null,reverseAxisOrder):bounds.toArray(reverseAxisOrder);newParams.WIDTH=imageSize.w;newParams.HEIGHT=imageSize.h;var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,this.tileOptions);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var mapProjection=
 this.map.getProjectionObject();var projectionCode=this.projection&&this.projection.equals(mapProjection)?this.projection.getCode():mapProjection.getCode();var value=(projectionCode=="none")?null:projectionCode;if(parseFloat(this.params.VERSION)>=1.3){this.params.CRS=this.params.CRS||value;this.params.SRS=null;}else{this.params.SRS=this.params.SRS||value;this.params.CRS=null;}
+if(typeof this.params.TRANSPARENT=="boolean"){newParams.TRANSPARENT=this.params.TRANSPARENT?"TRUE":"FALSE";}
 return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.WMS.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.WMS class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Format.WFSTWithLock=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WFSTWithLock.DEFAULTS);var cls=OpenLayers.Format.WFSTWithLock["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFSTWithLock version: "+options.version;}
-OpenLayers.Format.WFSTWithLock.DEFAULTS={"version":"1.1.0"};OpenLayers.Format.ArcXML.Features=OpenLayers.Class(OpenLayers.Format.XML,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var axl=new OpenLayers.Format.ArcXML();var parsed=axl.read(data);return parsed.features.feature;}});OpenLayers.Control.Snapping=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesnap","snap","unsnap"],DEFAULTS:{tolerance:10,node:true,edge:true,vertex:true},greedy:true,precedence:["node","vertex","edge"],resolution:null,geoToleranceCache:null,layer:null,feature:null,point:null,initialize:function(options){Array.prototype.push.apply(this.EVENT_TYPES,OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.options=options||{};if(this.options.layer){this.setLayer(this.options.layer);}
+obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{initialize:function(){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Format.ArcXML.Features=OpenLayers.Class(OpenLayers.Format.XML,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var axl=new OpenLayers.Format.ArcXML();var parsed=axl.read(data);return parsed.features.feature;}});OpenLayers.Control.Snapping=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesnap","snap","unsnap"],DEFAULTS:{tolerance:10,node:true,edge:true,vertex:true},greedy:true,precedence:["node","vertex","edge"],resolution:null,geoToleranceCache:null,layer:null,feature:null,point:null,initialize:function(options){Array.prototype.push.apply(this.EVENT_TYPES,OpenLayers.Control.prototype
 var defaults=OpenLayers.Util.extend({},this.options.defaults);this.defaults=OpenLayers.Util.applyDefaults(defaults,this.DEFAULTS);this.setTargets(this.options.targets);if(this.targets.length===0&&this.layer){this.addTargetLayer(this.layer);}
 this.geoToleranceCache={};},setLayer:function(layer){if(this.active){this.deactivate();this.layer=layer;this.activate();}else{this.layer=layer;}},setTargets:function(targets){this.targets=[];if(targets&&targets.length){var target;for(var i=0,len=targets.length;i<len;++i){target=targets[i];if(target instanceof OpenLayers.Layer.Vector){this.addTargetLayer(target);}else{this.addTarget(target);}}}},addTargetLayer:function(layer){this.addTarget({layer:layer});},addTarget:function(target){target=OpenLayers.Util.applyDefaults(target,this.defaults);target.nodeTolerance=target.nodeTolerance||target.tolerance;target.vertexTolerance=target.vertexTolerance||target.tolerance;target.edgeTolerance=target.edgeTolerance||target.tolerance;this.targets.push(target);},removeTargetLayer:function(layer){var target;for(var i=this.targets.length-1;i>=0;--i){target=this.targets[i];if(target.layer===layer){this.removeTarget(target);}}},removeTarget:function(target){return OpenLayers.Util.removeItem(t
 his.targets,target);},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){if(this.layer&&this.layer.events){this.layer.events.on({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});}}
 return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){if(this.layer&&this.layer.events){this.layer.events.un({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});}}
@@ -2066,32 +2076,41 @@
 delete this.layer;delete this.targets;OpenLayers.Control.prototype.destroy.call(this);},CLASS_NAME:"OpenLayers.Control.Snapping"});OpenLayers.Format.CSWGetDomain=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.CSWGetDomain.DEFAULTS);var cls=OpenLayers.Format.CSWGetDomain["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported CSWGetDomain version: "+options.version;}
 return new cls(options);};OpenLayers.Format.CSWGetDomain.DEFAULTS={"version":"2.0.2"};OpenLayers.Format.CSWGetDomain.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",PropertyName:null,ParameterName:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var obj={};this.readNode(data,obj);return obj;},readers:{"csw":{"GetDomainResponse":function(node,obj){this.readChildNodes(node,obj);},"DomainValues":function(node,obj){if(!(obj.DomainValues instanceof Array)){obj.DomainValues=[];}
+var obj={};this.readNode(data,obj);return obj;},readers:{"csw":{"GetDomainResponse":function(node,obj){this.readChildNodes(node,obj);},"DomainValues":function(node,obj){if(!(OpenLayers.Util.isArray(obj.DomainValues))){obj.DomainValues=[];}
 var attrs=node.attributes;var domainValue={};for(var i=0,len=attrs.length;i<len;++i){domainValue[attrs[i].name]=attrs[i].nodeValue;}
-this.readChildNodes(node,domainValue);obj.DomainValues.push(domainValue);},"PropertyName":function(node,obj){obj.PropertyName=this.getChildValue(node);},"ParameterName":function(node,obj){obj.ParameterName=this.getChildValue(node);},"ListOfValues":function(node,obj){if(!(obj.ListOfValues instanceof Array)){obj.ListOfValues=[];}
+this.readChildNodes(node,domainValue);obj.DomainValues.push(domainValue);},"PropertyName":function(node,obj){obj.PropertyName=this.getChildValue(node);},"ParameterName":function(node,obj){obj.ParameterName=this.getChildValue(node);},"ListOfValues":function(node,obj){if(!(OpenLayers.Util.isArray(obj.ListOfValues))){obj.ListOfValues=[];}
 this.readChildNodes(node,obj.ListOfValues);},"Value":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
 value.value=this.getChildValue(node);obj.push({Value:value});},"ConceptualScheme":function(node,obj){obj.ConceptualScheme={};this.readChildNodes(node,obj.ConceptualScheme);},"Name":function(node,obj){obj.Name=this.getChildValue(node);},"Document":function(node,obj){obj.Document=this.getChildValue(node);},"Authority":function(node,obj){obj.Authority=this.getChildValue(node);},"RangeOfValues":function(node,obj){obj.RangeOfValues={};this.readChildNodes(node,obj.RangeOfValues);},"MinValue":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
 value.value=this.getChildValue(node);obj.MinValue=value;},"MaxValue":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
 value.value=this.getChildValue(node);obj.MaxValue=value;}}},write:function(options){var node=this.writeNode("csw:GetDomain",options);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"csw":{"GetDomain":function(options){var node=this.createElementNSPlus("csw:GetDomain",{attributes:{service:"CSW",version:this.version}});if(options.PropertyName||this.PropertyName){this.writeNode("csw:PropertyName",options.PropertyName||this.PropertyName,node);}else if(options.ParameterName||this.ParameterName){this.writeNode("csw:ParameterName",options.ParameterName||this.ParameterName,node);}
-this.readChildNodes(node,options);return node;},"PropertyName":function(value){var node=this.createElementNSPlus("csw:PropertyName",{value:value});return node;},"ParameterName":function(value){var node=this.createElementNSPlus("csw:ParameterName",{value:value});return node;}}},CLASS_NAME:"OpenLayers.Format.CSWGetDomain.v2_0_2"});OpenLayers.Control.AgsGeometryService=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,geometryServiceType:"buffer",initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={'bufferSpatialReference':null,'distances':[1],'features':null,'outSpatialReference':null,'unionResults':false,'unit':"UNIT_KILOMETER",'spatialRelationship':"INTERSECTION",'inSpatialReference':"EPSG:4326",'comparisonString':null};this._resultsParser={'parser':this.adapter.parseAgsGraphics,'context':this.adapter};this.execute=this._bindFunction(th
 is.execute,this);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsGeometryService=new esri.tasks.GeometryService(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{switch(this.geometryServiceType){case"buffer":_taskParameters['bufferSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['bufferSpatialReference'];_taskParameters['features']=olFeatures?olFeatures:_taskParameters['features'];var agsBufferParameters=this.adapter.encodeAgsBufferParameters(_taskParameters);
 agsGeometryService.buffer(agsBufferParameters,_onExecuteComplete,_onCompleteError);break;case"project":_taskParameters['inSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];_taskParameters['outSpatialReference']=_taskParameters['outSpatialReference']||_taskParameters['inSpatialReference'];var agsGraphics=this.adapter.encodeAgsGraphics(olFeatures,_taskParameters['inSpatialReference']);var agsSpatialReference=this.adapter.encodeAgsSpatialReference(_taskParameters['outSpatialReference']);agsGeometryService.project(agsGraphics,agsSpatialReference,_onExecuteComplete,_onCompleteError);break;case"relation":_taskParameters['inSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];var agsGraphics1=this.adapter.encodeAgsGraphics([olFeatures[0]],_taskParameters['inSpatialReference']);var agsGraphics2=this.adapter.encodeAgsGraphics([olFeatures[1]],_taskParameters['
 inSpatialReference']);var agsGeometryRelationship=this.adapter.encodeAgsGeometrySpatialRelationship(_taskParameters['spatialRelationship']);var agsComparisonString=_taskParameters['comparisonString'];agsGeometryService.relation(agsGraphics1,agsGraphics2,agsGeometryRelationship,agsComparisonString,_onExecuteComplete,_onCompleteError);break;case"areasAndLengths":case"lengths":case"simplify":case"labelPoints":_taskParameters['inSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];var agsGraphics=this.adapter.encodeAgsGraphics(olFeatures,_taskParameters['inSpatialReference']);agsGeometryService[this.geometryServiceType].apply(agsGeometryService,[agsGraphics,_onExecuteComplete,_onCompleteError]);break;default:OpenLayers.Console.error("...invalid geometryServiceType...please call setGeometryServiceType() with valid geometryServiceType...");return;}}catch(e){throw e;}}else{OpenLayers.Console.error("...'asynchronous' shou
 ld always be set to 'false' for AgsGeometryService...");throw"...'asynchronous' should always be set to 'false' for AgsGeometryService...";}},setGeometryServiceType:function(geometryServiceType){this.geometryServiceType=geometryServiceType||this.geometryServiceType;switch(this.geometryServiceType){case"buffer":case"labelPoints":case"project":case"simplify":this._resultsParser['parser']=this.adapter.parseAgsGraphics;break;case"relation":this._resultsParser['parser']=this.adapter.parseAgsResults.relations;break;case"areasAndLengths":case"lengths":this._resultsParser['parser']=this.adapter.parseAgsResults.areasAndLengths;break;default:OpenLayers.Console.error("...invalid geometryServiceType...please call setGeometryServiceType() with valid geometryServiceType...");return;}},CLASS_NAME:"OpenLayers.Control.AgsGeometryService"});OpenLayers.Control.AgsLocator=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:false,asynchronous:false,reverseGeocoding:false,initialize:function
 (url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={'address':{},'distance':50,'outFields':[],'location':null};if(this.reverseGeocoding==true){this._resultsParser={'parser':this.adapter.parseAgsResults['addressCandidate'],'context':this.adapter};}else{this._resultsParser={'parser':this.adapter.parseAgsResults['addressCandidates'],'context':this.adapter};}
+this.readChildNodes(node,options);return node;},"PropertyName":function(value){var node=this.createElementNSPlus("csw:PropertyName",{value:value});return node;},"ParameterName":function(value){var node=this.createElementNSPlus("csw:ParameterName",{value:value});return node;}}},CLASS_NAME:"OpenLayers.Format.CSWGetDomain.v2_0_2"});OpenLayers.Format.OWSCommon.v1_1_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.1",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Util.applyDefaults({"ExceptionReport":function(node,obj){obj.exceptionReport={version:node.getAttribute('version'),language:node.getAttribute('xml:lang'),exceptions:[]};this.readChildNodes(node,obj.exceptionReport);},"AllowedValues":function(node,parameter){parameter.allowedValues={};this.readChildNodes(node,parameter.allowedValues);},"AnyValue":function(node,parameter){parameter.anyValue=true;},"DataType":function(node,parameter){parameter.dataType=this.ge
 tChildValue(node);},"Range":function(node,allowedValues){allowedValues.range={};this.readChildNodes(node,allowedValues.range);},"MinimumValue":function(node,range){range.minValue=this.getChildValue(node);},"MaximumValue":function(node,range){range.maxValue=this.getChildValue(node);},"Identifier":function(node,obj){obj.identifier=this.getChildValue(node);},"SupportedCRS":function(node,obj){obj.supportedCRS=this.getChildValue(node);}},OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"])},writers:{"ows":OpenLayers.Util.applyDefaults({"Range":function(range){var node=this.createElementNSPlus("ows:Range",{attributes:{'ows:rangeClosure':range.closure}});this.writeNode("ows:MinimumValue",range.minValue,node);this.writeNode("ows:MaximumValue",range.maxValue,node);return node;},"MinimumValue":function(minValue){var node=this.createElementNSPlus("ows:MinimumValue",{value:minValue});return node;},"MaximumValue":function(maxValue){var node=this.createElementNSPlus("ows:MaximumValue"
 ,{value:maxValue});return node;},"Value":function(value){var node=this.createElementNSPlus("ows:Value",{value:value});return node;}},OpenLayers.Format.OWSCommon.v1.prototype.writers["ows"])},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Format.WCSGetCoverage=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",wcs:"http://www.opengis.net/wcs/1.1",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},VERSION:"1.1.2",schemaLocation:"http://www.opengis.net/wcs/1.1 http://schemas.opengis.net/wcs/1.1/wcsGetCoverage.xsd",write:function(options){var node=this.writeNode("wcs:GetCoverage",options);this.setAttributeNS(node,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wcs":{"GetCoverage":function(options){var node=th
 is.createElementNSPlus("wcs:GetCoverage",{attributes:{version:options.version||this.VERSION,service:'WCS'}});this.writeNode("ows:Identifier",options.identifier,node);this.writeNode("wcs:DomainSubset",options.domainSubset,node);this.writeNode("wcs:Output",options.output,node);return node;},"DomainSubset":function(domainSubset){var node=this.createElementNSPlus("wcs:DomainSubset",{});this.writeNode("ows:BoundingBox",domainSubset.boundingBox,node);if(domainSubset.temporalSubset){this.writeNode("wcs:TemporalSubset",domainSubset.temporalSubset,node);}
+return node;},"TemporalSubset":function(temporalSubset){var node=this.createElementNSPlus("wcs:TemporalSubset",{});for(var i=0,len=temporalSubset.timePeriods.length;i<len;++i){this.writeNode("wcs:TimePeriod",temporalSubset.timePeriods[i],node);}
+return node;},"TimePeriod":function(timePeriod){var node=this.createElementNSPlus("wcs:TimePeriod",{});this.writeNode("wcs:BeginPosition",timePeriod.begin,node);this.writeNode("wcs:EndPosition",timePeriod.end,node);if(timePeriod.resolution){this.writeNode("wcs:TimeResolution",timePeriod.resolution,node);}
+return node;},"BeginPosition":function(begin){var node=this.createElementNSPlus("wcs:BeginPosition",{value:begin});return node;},"EndPosition":function(end){var node=this.createElementNSPlus("wcs:EndPosition",{value:end});return node;},"TimeResolution":function(resolution){var node=this.createElementNSPlus("wcs:TimeResolution",{value:resolution});return node;},"Output":function(output){var node=this.createElementNSPlus("wcs:Output",{attributes:{format:output.format,store:output.store}});if(output.gridCRS){this.writeNode("wcs:GridCRS",output.gridCRS,node);}
+return node;},"GridCRS":function(gridCRS){var node=this.createElementNSPlus("wcs:GridCRS",{});this.writeNode("wcs:GridBaseCRS",gridCRS.baseCRS,node);if(gridCRS.type){this.writeNode("wcs:GridType",gridCRS.type,node);}
+if(gridCRS.origin){this.writeNode("wcs:GridOrigin",gridCRS.origin,node);}
+this.writeNode("wcs:GridOffsets",gridCRS.offsets,node);if(gridCRS.CS){this.writeNode("wcs:GridCS",gridCRS.CS,node);}
+return node;},"GridBaseCRS":function(baseCRS){return this.createElementNSPlus("wcs:GridBaseCRS",{value:baseCRS});},"GridOrigin":function(origin){return this.createElementNSPlus("wcs:GridOrigin",{value:origin});},"GridType":function(type){return this.createElementNSPlus("wcs:GridType",{value:type});},"GridOffsets":function(offsets){return this.createElementNSPlus("wcs:GridOffsets",{value:offsets});},"GridCS":function(CS){return this.createElementNSPlus("wcs:GridCS",{value:CS});}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.WCSGetCoverage"});OpenLayers.Control.AgsGeometryService=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,geometryServiceType:"buffer",initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={'bufferSpatialReference':null,'distances':[1],'features':null,'outSpatialReference
 ':null,'unionResults':false,'unit':"UNIT_KILOMETER",'spatialRelationship':"INTERSECTION",'inSpatialReference':"EPSG:4326",'comparisonString':null};this._resultsParser={'parser':this.adapter.parseAgsGraphics,'context':this.adapter};this.execute=this._bindFunction(this.execute,this);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsGeometryService=new esri.tasks.GeometryService(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{switch(this.geometryServiceType){case"buffer":_taskParameters['bufferSpatialRefer
 ence']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['bufferSpatialReference'];_taskParameters['features']=olFeatures?olFeatures:_taskParameters['features'];var agsBufferParameters=this.adapter.encodeAgsBufferParameters(_taskParameters);agsGeometryService.buffer(agsBufferParameters,_onExecuteComplete,_onCompleteError);break;case"project":_taskParameters['inSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];_taskParameters['outSpatialReference']=_taskParameters['outSpatialReference']||_taskParameters['inSpatialReference'];var agsGraphics=this.adapter.encodeAgsGraphics(olFeatures,_taskParameters['inSpatialReference']);var agsSpatialReference=this.adapter.encodeAgsSpatialReference(_taskParameters['outSpatialReference']);agsGeometryService.project(agsGraphics,agsSpatialReference,_onExecuteComplete,_onCompleteError);break;case"relation":_taskParameters['inSpatialReference']=this.layer.map[
 'projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];var agsGraphics1=this.adapter.encodeAgsGraphics([olFeatures[0]],_taskParameters['inSpatialReference']);var agsGraphics2=this.adapter.encodeAgsGraphics([olFeatures[1]],_taskParameters['inSpatialReference']);var agsGeometryRelationship=this.adapter.encodeAgsGeometrySpatialRelationship(_taskParameters['spatialRelationship']);var agsComparisonString=_taskParameters['comparisonString'];agsGeometryService.relation(agsGraphics1,agsGraphics2,agsGeometryRelationship,agsComparisonString,_onExecuteComplete,_onCompleteError);break;case"areasAndLengths":case"lengths":case"simplify":case"labelPoints":_taskParameters['inSpatialReference']=this.layer.map['projection']?this.layer.map['projection']:_taskParameters['inSpatialReference'];var agsGraphics=this.adapter.encodeAgsGraphics(olFeatures,_taskParameters['inSpatialReference']);agsGeometryService[this.geometryServiceType].apply(agsGeometryService,[agsGraphics,
 _onExecuteComplete,_onCompleteError]);break;default:OpenLayers.Console.error("...invalid geometryServiceType...please call setGeometryServiceType() with valid geometryServiceType...");return;}}catch(e){throw e;}}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsGeometryService...");throw"...'asynchronous' should always be set to 'false' for AgsGeometryService...";}},setGeometryServiceType:function(geometryServiceType){this.geometryServiceType=geometryServiceType||this.geometryServiceType;switch(this.geometryServiceType){case"buffer":case"labelPoints":case"project":case"simplify":this._resultsParser['parser']=this.adapter.parseAgsGraphics;break;case"relation":this._resultsParser['parser']=this.adapter.parseAgsResults.relations;break;case"areasAndLengths":case"lengths":this._resultsParser['parser']=this.adapter.parseAgsResults.areasAndLengths;break;default:OpenLayers.Console.error("...invalid geometryServiceType...please call setGeometrySe
 rviceType() with valid geometryServiceType...");return;}},CLASS_NAME:"OpenLayers.Control.AgsGeometryService"});OpenLayers.Control.AgsLocator=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:false,asynchronous:false,reverseGeocoding:false,initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={'address':{},'distance':50,'outFields':[],'location':null};if(this.reverseGeocoding==true){this._resultsParser={'parser':this.adapter.parseAgsResults['addressCandidate'],'context':this.adapter};}else{this._resultsParser={'parser':this.adapter.parseAgsResults['addressCandidates'],'context':this.adapter};}
 this.execute=this._bindFunction(this.execute,this);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsLocator=new esri.tasks.Locator(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;if(this.reverseGeocoding==true){if(olFeatures[0]instanceof OpenLayers.Feature.Vector&&olFeatures[0].geometry instanceof OpenLayers.Geometry.Point){_taskParameters['location']=olFeatures[0].geometry;}
 if(!_taskParameters['location']){OpenLayers.Console.error("...'location' missing or invalid...");throw"...'location' missing or invalid...";}
 if(!_taskParameters['distance']){OpenLayers.Console.error("...'distance' missing or invalid...");throw"...'distance' missing or invalid...";}
 var agsLocation=null;agsLocation=this.adapter.encodeAgsLocation(_taskParameters['location']);agsLocator.locationToAddress(agsLocation,_taskParameters['distance'],_onExecuteComplete,_onCompleteError);}else{if(!_taskParameters['address']){OpenLayers.Console.error("...'address' missing or invalid...");throw"...'address' missing or invalid...";}
 if(!_taskParameters['outFields']){OpenLayers.Console.error("...'outFields' missing or invalid...");throw"...'outFields' missing or invalid...";}
-agsLocator.addressToLocations(_taskParameters['address'],_taskParameters['outFields'],_onExecuteComplete,_onCompleteError);}}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsLocator...");throw"...'asynchronous' should always be set to 'false' for AgsLocator...";}},setReverseGeocoding:function(reverseGeocoding){if(reverseGeocoding==true){this.reverseGeocoding=true;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidate'];}else{this.reverseGeocoding=false;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidates'];}},CLASS_NAME:"OpenLayers.Control.AgsLocator"});OpenLayers.Protocol.WFS.v1=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",featureType:null,featureNS:null,geometryName:"the_geom",schema:null,featurePrefix:"feature",formatOptions:null,readFormat:null,readOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.for
 mat){this.format=OpenLayers.Format.WFST(OpenLayers.Util.extend({version:this.version,featureType:this.featureType,featureNS:this.featureNS,featurePrefix:this.featurePrefix,geometryName:this.geometryName,srsName:this.srsName,schema:this.schema},this.formatOptions));}
-if(!this.featureNS&&this.featurePrefix){var readNode=this.format.readNode;this.format.readNode=function(node,obj){if(!this.featureNS&&node.prefix==this.featurePrefix){this.featureNS=node.namespaceURI;this.setNamespace("feature",this.featureNS);}
-return readNode.apply(this,arguments);};}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
-this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[this.format.writeNode("wfs:GetFeature",options)]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),params:options.params,headers:options.headers,data:data});return response;},setFeatureType:function(featureType){this.featureType=featureType;this.format.featureType=featureType;},setGeometryName:function(geometryName){this.geometryName=geometryName;this.format.geometryName=geometryName;},handleRead:function(response,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);if(options.callb
 ack){var request=response.priv;if(request.status>=200&&request.status<300){if(options.readOptions&&options.readOptions.output=="object"){OpenLayers.Util.extend(response,this.parseResponse(request,options.readOptions));}else{response.features=this.parseResponse(request,options.readOptions);}
-response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
+agsLocator.addressToLocations(_taskParameters['address'],_taskParameters['outFields'],_onExecuteComplete,_onCompleteError);}}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsLocator...");throw"...'asynchronous' should always be set to 'false' for AgsLocator...";}},setReverseGeocoding:function(reverseGeocoding){if(reverseGeocoding==true){this.reverseGeocoding=true;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidate'];}else{this.reverseGeocoding=false;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidates'];}},CLASS_NAME:"OpenLayers.Control.AgsLocator"});OpenLayers.Protocol.WFS.v1=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",featureType:null,featureNS:null,geometryName:"the_geom",schema:null,featurePrefix:"feature",formatOptions:null,readFormat:null,readOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.geo
 metryName&&!options.featureNS){this.geometryName=null;}
+if(!options.format){this.format=OpenLayers.Format.WFST(OpenLayers.Util.extend({version:this.version,featureType:this.featureType,featureNS:this.featureNS,featurePrefix:this.featurePrefix,geometryName:this.geometryName,srsName:this.srsName,schema:this.schema},this.formatOptions));}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
+this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[this.format.writeNode("wfs:GetFeature",options)]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),params:options.params,headers:options.headers,data:data});return response;},setFeatureType:function(featureType){this.featureType=featureType;this.format.featureType=featureType;},setGeometryName:function(geometryName){this.geometryName=geometryName;this.format.geometryName=geometryName;},handleRead:function(response,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);if(options.callb
 ack){var request=response.priv;if(request.status>=200&&request.status<300){var result=this.parseResponse(request,options.readOptions);if(result&&result.success!==false){if(options.readOptions&&options.readOptions.output=="object"){OpenLayers.Util.extend(response,result);}else{response.features=result;}
+response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;response.error=result;}}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
 options.callback.call(options.scope,response);}},parseResponse:function(request,options){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
 if(!doc||doc.length<=0){return null;}
-return(this.readFormat!==null)?this.readFormat.read(doc):this.format.read(doc,options);},commit:function(features,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var response=new OpenLayers.Protocol.Response({requestType:"commit",reqFeatures:features});response.priv=OpenLayers.Request.POST({url:options.url,headers:options.headers,data:this.format.write(features,options),callback:this.createCallback(this.handleCommit,response,options)});return response;},handleCommit:function(response,options){if(options.callback){var request=response.priv;var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
-var obj=this.format.read(data)||{};response.insertIds=obj.insertIds||[];response.code=(obj.success)?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE;options.callback.call(options.scope,response);}},filterDelete:function(filter,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var response=new OpenLayers.Protocol.Response({requestType:"commit"});var root=this.format.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version}});var deleteNode=this.format.createElementNSPlus("wfs:Delete",{attributes:{typeName:(options.featureNS?this.featurePrefix+":":"")+
+var result=(this.readFormat!==null)?this.readFormat.read(doc):this.format.read(doc,options);if(!this.featureNS){var format=this.readFormat||this.format;this.featureNS=format.featureNS;format.autoConfig=false;if(!this.geometryName){this.setGeometryName(format.geometryName);}}
+return result;},commit:function(features,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var response=new OpenLayers.Protocol.Response({requestType:"commit",reqFeatures:features});response.priv=OpenLayers.Request.POST({url:options.url,headers:options.headers,data:this.format.write(features,options),callback:this.createCallback(this.handleCommit,response,options)});return response;},handleCommit:function(response,options){if(options.callback){var request=response.priv;var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
+var obj=this.format.read(data)||{};response.insertIds=obj.insertIds||[];if(obj.success){response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;response.error=obj;}
+options.callback.call(options.scope,response);}},filterDelete:function(filter,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var response=new OpenLayers.Protocol.Response({requestType:"commit"});var root=this.format.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version}});var deleteNode=this.format.createElementNSPlus("wfs:Delete",{attributes:{typeName:(options.featureNS?this.featurePrefix+":":"")+
 options.featureType}});if(options.featureNS){deleteNode.setAttribute("xmlns:"+this.featurePrefix,options.featureNS);}
 var filterNode=this.format.writeNode("ogc:Filter",filter);deleteNode.appendChild(filterNode);root.appendChild(deleteNode);var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[root]);return OpenLayers.Request.POST({url:this.url,callback:options.callback||function(){},data:data});},abort:function(response){if(response){response.priv.abort();}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this
 .loadGML();}},loadGML:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.url,success:this.requestSuccess,failure:this.requestFailure,scope:this});this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.loadGML();},requestSuccess:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
 var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){OpenLayers.Console.userError(OpenLayers.i18n("errorLoadingGML",{'url':this.url}));this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Format.OWSCommon.v1_1_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.1",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Util.applyDefaults({"AllowedValues":function(node,parameter){parameter.allowedValues={};this.readChildNodes(node,parameter.allowedValues);},"AnyValue":function(node,parameter){parameter.anyValue=true;},"DataType":function(node,parameter){parameter.dataType=this.getChildValue(node);},"Range":function(node,allowedValues){allowedValues.range={};this.readChildNodes(node,allowedValues.range);},"MinimumValue":function(node,range){range.minValue=this.getCh
 ildValue(node);},"MaximumValue":function(node,range){range.maxValue=this.getChildValue(node);},"Identifier":function(node,obj){obj.identifier=this.getChildValue(node);},"SupportedCRS":function(node,obj){obj.supportedCRS=this.getChildValue(node);}},OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"])},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Format.WFSTWithLock.v1=OpenLayers.Class(OpenLayers.Format.WFST.v1,{lockExpiry:"1",releaseAction:"ALL",attributes:{},attribute_alias:{},encodeAttributes:false,xy:false,initialize:function(options){if(options.featureNS){this.namespaces=OpenLayers.Util.extend({feature:options.featureNS},OpenLayers.Format.WFST.v1.prototype.namespaces);}
+var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){OpenLayers.Console.userError(OpenLayers.i18n("errorLoadingGML",{'url':this.url}));this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Format.WFSTWithLock=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WFSTWithLock.DEFAULTS);var cls=OpenLayers.Format.WFSTWithLock["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFSTWithLock version: "+options.version;}
+return new cls(options);};OpenLayers.Format.WFSTWithLock.DEFAULTS={"version":"1.1.0"};OpenLayers.Format.WFSTWithLock.v1=OpenLayers.Class(OpenLayers.Format.WFST.v1,{lockExpiry:"1",releaseAction:"ALL",attributes:{},attribute_alias:{},encodeAttributes:false,xy:false,initialize:function(options){if(options.featureNS){this.namespaces=OpenLayers.Util.extend({feature:options.featureNS},OpenLayers.Format.WFST.v1.prototype.namespaces);}
 OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);this.namespaces[this.featurePrefix]=this.featureNS;OpenLayers.Util.extend(this,{readOgcExpression:this.readOgcExpression||OpenLayers.Format.Filter.v1.prototype.readOgcExpression,getFilterType:this.getFilterType||OpenLayers.Format.Filter.v1.prototype.getFilterType,filterMap:this.filterMap||OpenLayers.Format.Filter.v1.prototype.filterMap,setGeometryTypes:this.setGeometryTypes||OpenLayers.Format.GML.Base.prototype.setGeometryTypes,regExes:this.regExes||OpenLayers.Format.GML.Base.prototype.regExes});OpenLayers.Format.GML.Base.prototype.setGeometryTypes.call(this);this.geometryTypes['OpenLayers.Geometry.MultiLineString']="MultiCurve";this.geometryTypes['OpenLayers.Geometry.MultiPolygon']="MultiSurface";if(this.schema&&this.schema!=""){OpenLayers.loadURL(this.schema,null,null,OpenLayers.Function.bind(function(request){var schema_format=new OpenLayers.Format.WFSDescribeFeatureType();var schema=schema_format.read(r
 equest.responseXML||request.responseText);this.attributes={};if(schema.targetNamespace==this.featureNS&&schema.targetPrefix==this.featurePrefix){for(var i=0;i<schema.featureTypes.length;i++){var featureType=schema.featureTypes[i];if(featureType.typeName==this.featureType){for(var j=0;j<featureType.properties.length;j++){if(featureType.properties[j].type.split(":")[0]!="gml"){this.attributes[featureType.properties[j].name]=featureType.properties[j];}}
 return;}}}},this));}},read:function(data,options){options=options||{};OpenLayers.Util.applyDefaults(options,{output:"features"});if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
@@ -2129,13 +2148,13 @@
 break;case"featureselected":if(evt.feature.lockId&&evt.feature.lockId!=""){evt.feature.style=this._lockedStyle.createSymbolizer(evt.feature);}
 break;default:break;}},createFeatureIdFilter:function(features){var fids=[];for(var i=0;i<features.length;i++){if(features[i].fid){fids.push(features[i].fid);}}
 var filter=new OpenLayers.Filter.FeatureId({fids:fids});return filter;},createBBOXFilter:function(bounds){},setStyleMap:function(styleMap){if(styleMap){this._defaultStyle=styleMap.styles['default']||this._defaultStyle;this._selectStyle=styleMap.styles['select']||this._selectStyle;this._lockedStyle=styleMap.styles['locked']||this._lockedStyle;}},CLASS_NAME:"OpenLayers.Strategy.Lock"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});thi
 s.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0,len=this.map.layers.length;i<len;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()){if(OpenLayers.Util.indexOf(attributions,layer.attribution)===-1){attributions.push(layer.attribution);}}}
-this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Renderer.NG=OpenLayers.Class(OpenLayers.Renderer.Elements,{labelNodeType:null,initialize:function(containerID,options){OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},updateDimensions:function(){var mapExtent=this.map.getExtent();var renderExtent=this.map.getMaxExtent();this.setExtent(renderExtent,true);var res=this.getResolution();var div=this.rendererRoot.parentNode;var layerLeft=parseFloat(div.parentNode.style.left);var layerTop=parseFloat(div.parentNode.style.top);div.style.left=((renderExtent.left-mapExtent.left)/res-layerLeft)+"px";div.style.top=((mapExtent.top-renderExtent.top)/res-layerTop)+"px";},setSize:function(){this.map.getExtent()&&this.updateDimensions();},drawFeature:function(feature,style){if(style==null){style=feature.style;}
+this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Renderer.NG=OpenLayers.Class(OpenLayers.Renderer.Elements,{labelNodeType:null,updateDimensions:function(){var mapExtent=this.map.getExtent();var renderExtent=this.map.getMaxExtent();this.setExtent(renderExtent,true);var res=this.getResolution();var div=this.rendererRoot.parentNode;var layerLeft=parseFloat(div.parentNode.style.left);var layerTop=parseFloat(div.parentNode.style.top);div.style.left=((renderExtent.left-mapExtent.left)/res-layerLeft)+"px";div.style.top=((mapExtent.top-renderExtent.top)/res-layerTop)+"px";},setSize:function(){this.map.getExtent()&&this.updateDimensions();},drawFeature:function(feature,style){if(style==null){style=feature.style;}
 if(feature.geometry){var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(rendered!==false&&style.label){var location=feature.geometry.getCentroid();this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
 return rendered;}},drawText:function(featureId,style,location){var label;if(typeof featureId!=="string"){label=featureId;}else{label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,this.labelNodeType);label._featureId=featureId;}
 label._style=style;label._x=location.x;label._y=location.y;if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
 if(label.parentNode!==this.textRoot){this.textRoot.appendChild(label);}
 return label;},CLASS_NAME:"OpenLayers.Renderer.NG"});OpenLayers.Renderer.SVG2=OpenLayers.Class(OpenLayers.Renderer.NG,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",symbolMetrics:null,labelNodeType:"g",initialize:function(containerID){if(!this.supported()){return;}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.symbolMetrics={};},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},updateDimensions:function(){OpenLayers.Renderer.NG.prototype.updateDimensions.apply(this,arguments);var res=this.getResolution();var width=this.extent.getWidth();var height=this.extent.getHeight();var extentString=[this.extent.left,-this.extent.top,width,height].join(" ");this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.rendererRoot.setAttributeNS(null,"width",width/res);this.rendererRoot.setAttributeNS(null,"height",height/res);var i,len;var nodes=this.vectorRoot.childNodes;for(i=0
 ,len=nodes.length;i<len;++i){this.setStyle(nodes[i]);}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.symbolMetrics={};},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},updateDimensions:function(){OpenLayers.Renderer.NG.prototype.updateDimensions.apply(this,arguments);var res=this.getResolution();var width=this.extent.getWidth();var height=this.extent.getHeight();var extentString=[this.extent.left,-this.extent.top,width,height].join(" ");this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.rendererRoot.setAttributeNS(null,"width",width/res);this.rendererRoot.setAttributeNS(null,"height",height/res);var i,len;var nodes=this.vectorRoot.childNodes;for(i=0,len=nodes.length;i<len;++i){this.setStyle(nodes[i]);}
 var textNodes=this.textRoot.childNodes;var label;for(i=0,len=textNodes.length;i<len;++i){label=textNodes[i];this.drawText(label,label._style,new OpenLayers.Geometry.Point(label._x,label._y));}},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
 break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
 return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var resolution=this.getResolution();var r=node._radius;var widthFactor=resolution;if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){node.style.visibility="";if(style.graphic===false){node.style.visibility="hidden";}else if(style.externalGraphic){if(style.graphicTitle){node.setAttributeNS(null,"title",style.graphicTitle);var label=this.nodeFactory(null,"title");label.textContent=style.graphicTitle;node.appendChild(label);}
@@ -2215,8 +2234,19 @@
 if(state=='Complete'){this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null;}},dispatchException:function(exception){var handler=this.options.onException;if(handler){handler(this,exception);OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{var listener=false;var responders=OpenLayers.Ajax.Responders.responders;for(var i=0;i<responders.length;i++){if(responders[i].onException){listener=true;break;}}
 if(listener){OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{throw exception;}}}});OpenLayers.Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:'',initialize:function(request){this.request=request;var transport=this.transport=request.transport,readyState=this.readyState=transport.readyState;if((readyState>2&&!(!!(window.attachEvent&&!window.opera)))||readyState==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=transport.responseText==null?'':String(transport.responseText);}
 if(readyState==4){var xml=transport.responseXML;this.responseXML=xml===undefined?null:xml;}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||'';}catch(e){return'';}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(name){return this.transport.getResponseHeader(name);}});OpenLayers.Ajax.getElementsByTagNameNS=function(parentnode,nsuri,nsprefix,tagname){var elem=null;if(parentnode.getElementsByTagNameNS){elem=parentnode.getElementsByTagNameNS(nsuri,tagname);}else{elem=parentnode.getElementsByTagName(nsprefix+':'+tagname);}
-return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Control.AgsFindTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:false,asynchronous:false,initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={"contains":false,"outSpatialReference":null,"returnGeometry":true,"layerIds":[],"searchFields":[],"searchText":""};this._resultsParser={'parser':this.adapter.parseAgsResults['findResults'],'context':this.adapter};this.execute=this._bindFunction(this.execute,this);this.active=false;this.activate=function(){return false;};this.deactivate=function(){return false;};},execute:function(taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCal
 lbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsFindTask=new esri.tasks.FindTask(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{var agsFindParameters=this.adapter.encodeAgsFindParameters(_taskParameters);}catch(e){throw e;}
-agsFindTask.execute(agsFindParameters,_onExecuteComplete,_onCompleteError);}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsFindTask ...");throw"...'asynchronous' should always be set to 'false' for AgsFindTask ...";}},CLASS_NAME:"OpenLayers.Control.AgsFindTask"});OpenLayers.Test.AgsRestAdmin=OpenLayers.Class(OpenLayers.Test,{url:"",_run_admin_createService_post_:function(reqId,options,t){var successMsg="...create service success...";var failureMsg="...create service failure...";var jsonFormat=new OpenLayers.Format.JSON();var postReqJsonStr=document.getElementById(reqId).firstChild.nodeValue;if(options.token){postReqJsonStr=postReqJsonStr+"&token="+options.token;}
+return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Format.WPSExecute=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",gml:"http://www.opengis.net/gml",wps:"http://www.opengis.net/wps/1.0.0",wfs:"http://www.opengis.net/wfs",ogc:"http://www.opengis.net/ogc",wcs:"http://www.opengis.net/wcs",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",schemaLocationAttr:function(options){return undefined;},write:function(options){var doc;if(window.ActiveXObject){doc=new ActiveXObject("Microsoft.XMLDOM");this.xmldom=doc;}else{doc=document.implementation.createDocument("","",null);}
+var node=this.writeNode("wps:Execute",options,doc);this.setAttributeNS(node,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wps":{"Execute":function(options){var node=this.createElementNSPlus("wps:Execute",{attributes:{version:this.VERSION,service:'WPS'}});this.writeNode("ows:Identifier",options.identifier,node);this.writeNode("wps:DataInputs",options.dataInputs,node);this.writeNode("wps:ResponseForm",options.responseForm,node);return node;},"ResponseForm":function(responseForm){var node=this.createElementNSPlus("wps:ResponseForm",{});if(responseForm.rawDataOutput){this.writeNode("wps:RawDataOutput",responseForm.rawDataOutput,node);}
+if(responseForm.responseDocument){this.writeNode("wps:ResponseDocument",responseForm.responseDocument,node);}
+return node;},"ResponseDocument":function(responseDocument){var node=this.createElementNSPlus("wps:ResponseDocument",{attributes:{storeExecuteResponse:responseDocument.storeExecuteResponse,lineage:responseDocument.lineage,status:responseDocument.status}});if(responseDocument.output){this.writeNode("wps:Output",responseDocument.output,node);}
+return node;},"Output":function(output){var node=this.createElementNSPlus("wps:Output",{attributes:{asReference:output.asReference}});this.writeNode("ows:Identifier",output.identifier,node);this.writeNode("ows:Title",output.title,node);this.writeNode("ows:Abstract",output["abstract"],node);return node;},"RawDataOutput":function(rawDataOutput){var node=this.createElementNSPlus("wps:RawDataOutput",{attributes:{mimeType:rawDataOutput.mimeType}});this.writeNode("ows:Identifier",rawDataOutput.identifier,node);return node;},"DataInputs":function(dataInputs){var node=this.createElementNSPlus("wps:DataInputs",{});for(var i=0,ii=dataInputs.length;i<ii;++i){this.writeNode("wps:Input",dataInputs[i],node);}
+return node;},"Input":function(input){var node=this.createElementNSPlus("wps:Input",{});this.writeNode("ows:Identifier",input.identifier,node);if(input.title){this.writeNode("ows:Title",input.title,node);}
+if(input.data){this.writeNode("wps:Data",input.data,node);}
+if(input.reference){this.writeNode("wps:Reference",input.reference,node);}
+return node;},"Data":function(data){var node=this.createElementNSPlus("wps:Data",{});if(data.literalData){this.writeNode("wps:LiteralData",data.literalData,node);}else if(data.complexData){this.writeNode("wps:ComplexData",data.complexData,node);}
+return node;},"LiteralData":function(literalData){var node=this.createElementNSPlus("wps:LiteralData",{attributes:{uom:literalData.uom},value:literalData.value});return node;},"ComplexData":function(complexData){var node=this.createElementNSPlus("wps:ComplexData",{attributes:{mimeType:complexData.mimeType,encoding:complexData.encoding,schema:complexData.schema}});node.appendChild(this.getXMLDoc().createCDATASection(complexData.value));return node;},"Reference":function(reference){var node=this.createElementNSPlus("wps:Reference",{attributes:{mimeType:reference.mimeType,"xlink:href":reference.href,method:reference.method,encoding:reference.encoding,schema:reference.schema}});if(reference.body){this.writeNode("wps:Body",reference.body,node);}
+return node;},"Body":function(body){var node=this.createElementNSPlus("wps:Body",{});if(body.wcs){this.writeNode("wcs:GetCoverage",body.wcs,node);}
+else if(body.wfs){this.featureType=body.wfs.featureType;this.version=body.wfs.version;this.writeNode("wfs:GetFeature",body.wfs,node);}else{this.writeNode("wps:Execute",body,node);}
+return node;}},"wcs":OpenLayers.Format.WCSGetCoverage.prototype.writers.wcs,"wfs":OpenLayers.Format.WFST.v1_1_0.prototype.writers.wfs,"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.WPSExecute"});OpenLayers.Test.AgsRestAdmin=OpenLayers.Class(OpenLayers.Test,{url:"",_run_admin_createService_post_:function(reqId,options,t){var successMsg="...create service success...";var failureMsg="...create service failure...";var jsonFormat=new OpenLayers.Format.JSON();var postReqJsonStr=document.getElementById(reqId).firstChild.nodeValue;if(options.token){postReqJsonStr=postReqJsonStr+"&token="+options.token;}
 var caller=this;OpenLayers.Request.POST({url:this.url+"/createService",success:function(response){if(response.responseText.indexOf("success")!=-1){t.ok(true,successMsg);}else{t.ok(false,failureMsg);}},failure:function(response){t.ok(false,failureMsg);},params:{'service':postReqJsonStr},headers:{}});},_run_admin_deleteService_post_:function(reqId,options,t){var successMsg="...delete service success...";var failureMsg="...delete service failure...";var serviceNameStr=document.getElementById(reqId).firstChild.nodeValue;var queryStr="json";if(options.token){queryStr=queryStr+"&token="+options.token;}
 var caller=this;OpenLayers.Request.POST({url:this.url+"/"+serviceNameStr+"/delete",success:function(response){if(response.responseText.indexOf("success")!=-1){t.ok(true,successMsg);}else{t.ok(false,failureMsg);}},failure:function(response){t.ok(false,failureMsg);},params:{'f':queryStr},headers:{}});},CLASS_NAME:"OpenLayers.Test.AgsRestAdmin"});OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:true,initialize:function(name,location,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[name,options]);this.location=location;this.features=[];},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadRSS:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.location,success:this.parseData,scope:this});this.loaded=true;}},moveTo:fu
 nction(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadRSS();}},parseData:function(ajaxRequest){var doc=ajaxRequest.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(ajaxRequest.responseText);}
 if(this.useFeedTitle){var name=null;try{name=doc.getElementsByTagNameNS('*','title')[0].firstChild.nodeValue;}
@@ -2245,10 +2275,7 @@
 this.map.events.on({"touchmove":this.passEventToSlider,"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";this.mouseDragStart=evt.xy.clone();}
 this.deltaY=this.zoomStart.y-evt.xy.y;OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&evt.type!=="touchend"){return;}
 if(this.mouseDragStart){this.div.style.cursor="";this.map.events.un({"touchmove":this.passEventToSlider,"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var zoomLevel=this.map.zoom;if(!this.forceFixedZoomLevel&&this.map.fractionalZoom){zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.max(Math.round(zoomLevel),0);}
-this.map.zoomTo(zoomLevel);this.mouseDragStart=null;this.zoomStart=null;this.deltaY=0;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.SOSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.SOSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw"Can't find a SOS capabilities parser for version "+version;}
-var parser=new constr(this.options);}
-var capabilities=parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.SOSCapabilities"});OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:'jpeg',map:''},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);return this.getFullRequestString({t:pY,l:pX,s:scale});},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left;v
 ar tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=tilecol*tilelon;var offsetlat=bounds.top;var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-(tilerowremain+1)*this.tileSize.h;var tileoffsetlat=tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.getOptions());}
+this.map.zoomTo(zoomLevel);this.mouseDragStart=null;this.zoomStart=null;this.deltaY=0;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.SOSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.SOSCapabilities"});OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:'jpeg',map:''},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var
 scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);return this.getFullRequestString({t:pY,l:pX,s:scale});},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=tilecol*tilelon;var offsetlat=bounds.top;var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-(tilerowremain+1)*this.tileSize.h;var tileoffsetlat=tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.getOptions())
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
 obj.grid=[];return obj;},getTileBounds:function(viewPortPx){var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=tileMapWidth*Math.floor(mapPoint.lon/tileMapWidth);var tileBottom=tileMapHeight*Math.floor(mapPoint.lat/tileMapHeight);return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Protocol.AgsFeatureAccess.v2_0=OpenLayers.Class(OpenLayers.Protocol.AgsFeatureAccess.v2,{version:"2.0",CLASS_NAME:"OpenLayers.Protocol.AgsFeatureAccess.v2_0"});OpenLayers.Layer.AgsTiled=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,tileOrigin:null,tileFullExtent:null,tileFormat:"",initialize:function(name,url,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this._isDefined=OpenLayers.Util.AgsUtil.isDefined;if(this._isD
 efined(options['tileFormat'])){this.tileFormat=options['tileFormat'];}else{OpenLayers.Console.error("...tileFormat missing or empty...");throw"...tileFormat missing or empty...";}
 if(this._isDefined(options['tileFullExtent'])&&options['tileFullExtent']instanceof OpenLayers.Bounds){this.tileFullExtent=options['tileFullExtent'];}
@@ -2257,24 +2284,16 @@
 var row=null;if(this.tileOrigin.lat>=bounds.top){row=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));}else if(this.tileOrigin.lat<=bounds.bottom){row=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));}else{return"";OpenLayers.Console.warn("...invalid tileOrigin...");}
 var scale=this.map.getZoom();path=scale+"/"+row+"/"+col+"."+this.tileFormat;url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
 return url+path;}else{return"";}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}
-if(!this.tileFullExtent){this.tileFullExtent=this.map.maxExtent;}},CLASS_NAME:"OpenLayers.Layer.AgsTiled"});OpenLayers.Format.XLS=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(request,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.XLS["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find an XLS parser for version "+
-version;}
-this.parser=new format(this.options);}
-var root=this.parser.write(request);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.XLS["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find an XLS parser for version "+
-version;}
-var xls=this.parser.read(data,options);return xls;},CLASS_NAME:"OpenLayers.Format.XLS"});OpenLayers.Format.XLS.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xls:"http://www.opengis.net/xls",gml:"http://www.opengis.net/gml",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},xy:true,defaultPrefix:"xls",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var xls={};this.readChildNodes(data,xls);return xls;},readers:{"xls":{"XLS":function(node,xls){xls.version=node.getAttribute("version");this.readChildNodes(node,xls);},"Response":function(node,xls){this.readChildNodes(node,xls);},"GeocodeResponse":function(node,xls){xls.responseLists=[];this.readChildNodes(node,xls);},"GeocodeResponseList":function(node,xls){var responseList=
 {features:[],numberOfGeocodedAddresses:parseInt(node.getAttribute("numberOfGeocodedAddresses"))};xls.responseLists.push(responseList);this.readChildNodes(node,responseList);},"GeocodedAddress":function(node,responseList){var feature=new OpenLayers.Feature.Vector();responseList.features.push(feature);this.readChildNodes(node,feature);feature.geometry=feature.components[0];},"GeocodeMatchCode":function(node,feature){feature.attributes.matchCode={accuracy:parseFloat(node.getAttribute("accuracy")),matchType:node.getAttribute("matchType")};},"Address":function(node,feature){var address={countryCode:node.getAttribute("countryCode"),addressee:node.getAttribute("addressee"),street:[],place:[]};feature.attributes.address=address;this.readChildNodes(node,address);},"freeFormAddress":function(node,address){address.freeFormAddress=this.getChildValue(node);},"StreetAddress":function(node,address){this.readChildNodes(node,address);},"Building":function(node,address){address.building={'num
 ber':node.getAttribute("number"),subdivision:node.getAttribute("subdivision"),buildingName:node.getAttribute("buildingName")};},"Street":function(node,address){address.street.push(this.getChildValue(node));},"Place":function(node,address){address.place[node.getAttribute("type")]=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);}},"gml":OpenLayers.Format.GML.v3.prototype.readers.gml},write:function(request){return this.writers.xls.XLS.apply(this,[request]);},writers:{"xls":{"XLS":function(request){var root=this.createElementNSPlus("xls:XLS",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});this.writeNode("RequestHeader",request.header,root);this.writeNode("Request",request,root);return root;},"RequestHeader":function(header){return this.createElementNSPlus("xls:RequestHeader");},"Request":function(request){var node=this.createElementNSPlus("xls:Request",{attributes:{methodName:"GeocodeRequ
 est",requestID:request.requestID||"",version:this.VERSION}});this.writeNode("GeocodeRequest",request.addresses,node);return node;},"GeocodeRequest":function(addresses){var node=this.createElementNSPlus("xls:GeocodeRequest");for(var i=0,len=addresses.length;i<len;i++){this.writeNode("Address",addresses[i],node);}
+if(!this.tileFullExtent){this.tileFullExtent=this.map.maxExtent;}},CLASS_NAME:"OpenLayers.Layer.AgsTiled"});OpenLayers.Format.XLS=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",stringifyOutput:true,CLASS_NAME:"OpenLayers.Format.XLS"});OpenLayers.Format.XLS.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xls:"http://www.opengis.net/xls",gml:"http://www.opengis.net/gml",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},xy:true,defaultPrefix:"xls",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var xls={};this.readChildNodes(data,xls);return xls;},readers:{"xls":{"XLS":function(node,xls){xls.version=node.getAttribute("version");this.readChildNodes(node,xls);},"Response":function(node,xls){this.
 readChildNodes(node,xls);},"GeocodeResponse":function(node,xls){xls.responseLists=[];this.readChildNodes(node,xls);},"GeocodeResponseList":function(node,xls){var responseList={features:[],numberOfGeocodedAddresses:parseInt(node.getAttribute("numberOfGeocodedAddresses"))};xls.responseLists.push(responseList);this.readChildNodes(node,responseList);},"GeocodedAddress":function(node,responseList){var feature=new OpenLayers.Feature.Vector();responseList.features.push(feature);this.readChildNodes(node,feature);feature.geometry=feature.components[0];},"GeocodeMatchCode":function(node,feature){feature.attributes.matchCode={accuracy:parseFloat(node.getAttribute("accuracy")),matchType:node.getAttribute("matchType")};},"Address":function(node,feature){var address={countryCode:node.getAttribute("countryCode"),addressee:node.getAttribute("addressee"),street:[],place:[]};feature.attributes.address=address;this.readChildNodes(node,address);},"freeFormAddress":function(node,address){address
 .freeFormAddress=this.getChildValue(node);},"StreetAddress":function(node,address){this.readChildNodes(node,address);},"Building":function(node,address){address.building={'number':node.getAttribute("number"),subdivision:node.getAttribute("subdivision"),buildingName:node.getAttribute("buildingName")};},"Street":function(node,address){address.street.push(this.getChildValue(node));},"Place":function(node,address){address.place[node.getAttribute("type")]=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);}},"gml":OpenLayers.Format.GML.v3.prototype.readers.gml},write:function(request){return this.writers.xls.XLS.apply(this,[request]);},writers:{"xls":{"XLS":function(request){var root=this.createElementNSPlus("xls:XLS",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});this.writeNode("RequestHeader",request.header,root);this.writeNode("Request",request,root);return root;},"RequestHeader":function(
 header){return this.createElementNSPlus("xls:RequestHeader");},"Request":function(request){var node=this.createElementNSPlus("xls:Request",{attributes:{methodName:"GeocodeRequest",requestID:request.requestID||"",version:this.VERSION}});this.writeNode("GeocodeRequest",request.addresses,node);return node;},"GeocodeRequest":function(addresses){var node=this.createElementNSPlus("xls:GeocodeRequest");for(var i=0,len=addresses.length;i<len;i++){this.writeNode("Address",addresses[i],node);}
 return node;},"Address":function(address){var node=this.createElementNSPlus("xls:Address",{attributes:{countryCode:address.countryCode}});if(address.freeFormAddress){this.writeNode("freeFormAddess",address.freeFormAddress,node);}else{if(address.street){this.writeNode("StreetAddress",address,node);}
 if(address.municipality){this.writeNode("Municipality",address.municipality,node);}
 if(address.countrySubdivision){this.writeNode("CountrySubdivision",address.countrySubdivision,node);}
 if(address.postalCode){this.writeNode("PostalCode",address.postalCode,node);}}
 return node;},"freeFormAddress":function(freeFormAddress){return this.createElementNSPlus("freeFormAddress",{value:freeFormAddress});},"StreetAddress":function(address){var node=this.createElementNSPlus("xls:StreetAddress");if(address.building){this.writeNode(node,"Building",address.building);}
-var street=address.street;if(!(street instanceof Array)){street=[street];}
+var street=address.street;if(!(OpenLayers.Util.isArray(street))){street=[street];}
 for(var i=0,len=street.length;i<len;i++){this.writeNode("Street",street[i],node);}
 return node;},"Building":function(building){return this.createElementNSPlus("xls:Building",{attributes:{"number":building["number"],"subdivision":building.subdivision,"buildingName":building.buildingName}});},"Street":function(street){return this.createElementNSPlus("xls:Street",{value:street});},"Municipality":function(municipality){return this.createElementNSPlus("xls:Place",{attributes:{type:"Municipality"},value:municipality});},"CountrySubdivision":function(countrySubdivision){return this.createElementNSPlus("xls:Place",{attributes:{type:"CountrySubdivision"},value:countrySubdivision});},"PostalCode":function(postalCode){return this.createElementNSPlus("xls:PostalCode",{value:postalCode});}}},CLASS_NAME:"OpenLayers.Format.XLS.v1"});OpenLayers.Format.XLS.v1_1_0=OpenLayers.Class(OpenLayers.Format.XLS.v1,{VERSION:"1.1",schemaLocation:"http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd",initialize:function(options){OpenLayers.Format.X
 LS.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.XLS.v1_1_0"});OpenLayers.Format.XLS.v1_1=OpenLayers.Format.XLS.v1_1_0;OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15000,translationParameters:null,symbolMetrics:null,initialize:function(containerID){if(!this.supported()){return;}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.symbolMetrics={};},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y,xyOnly){var left=x+(xyOnly?0:this.translationParameters.x);var top=y+(xyOnly?0:this.translationParameters.y);return(left>=-this.MAX_PIXEL&&left<=this.MAX_PIXEL&&top>=-this.MAX_PIXEL&&top<=this.MAX_PIXEL);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=-extent.left/resolution;var top=extent.top/resolution;if(resolutionChanged)
 {this.left=left;this.top=top;var extentString="0 0 "+this.size.w+" "+this.size.h;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.translate(0,0);return true;}else{var inRange=this.translate(left-this.left,top-this.top);if(!inRange){this.setExtent(extent,true);}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.symbolMetrics={};},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y,xyOnly){var left=x+(xyOnly?0:this.translationParameters.x);var top=y+(xyOnly?0:this.translationParameters.y);return(left>=-this.MAX_PIXEL&&left<=this.MAX_PIXEL&&top>=-this.MAX_PIXEL&&top<=this.MAX_PIXEL);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=-extent.left/resolution;var top=extent.top/resolution;if(resolutionChanged){this.left=left;this.top=top;var extentString="0 0 "+this.size.w+" "+this.size.h;this.rend
 return inRange;}},translate:function(x,y){if(!this.inValidRange(x,y,true)){return false;}else{var transformString="";if(x||y){transformString="translate("+x+","+y+")";}
 this.root.setAttributeNS(null,"transform",transformString);this.translationParameters={x:x,y:y};return true;}},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
@@ -2323,12 +2342,8 @@
 var symbol=OpenLayers.Renderer.symbol[graphicName];if(!symbol){throw new Error(graphicName+' is not a valid symbol name');}
 var symbolNode=this.nodeFactory(id,"symbol");var node=this.nodeFactory(null,"polygon");symbolNode.appendChild(node);var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var points=[];var x,y;for(var i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);points.push(x,",",y);}
 node.setAttributeNS(null,"points",points.join(" "));var width=symbolExtent.getWidth();var height=symbolExtent.getHeight();var viewBox=[symbolExtent.left-width,symbolExtent.bottom-height,width*3,height*3];symbolNode.setAttributeNS(null,"viewBox",viewBox.join(" "));this.symbolMetrics[id]=[Math.max(width,height),symbolExtent.getCenterLonLat().lon,symbolExtent.getCenterLonLat().lat];this.defs.appendChild(symbolNode);return symbolNode;},getFeatureIdFromEvent:function(evt){var featureId=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(!featureId){var target=evt.target;featureId=target.parentNode&&target!=this.rendererRoot&&target.parentNode._featureId;}
-return featureId;},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={"l":"start","r":"end","b":"bottom","t":"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={"t":"-70%","b":"0"};OpenLayers.Renderer.SVG.LABEL_VFACTOR={"t":0,"b":-1};OpenLayers.Renderer.SVG.preventDefault=function(e){e.preventDefault&&e.preventDefault();};OpenLayers.Format.WMSDescribeLayer=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.1",version:null,read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(version=="1.1.1"||version=="1.1.0"){version="1.1";}
-var constructor=OpenLayers.Format.WMSDescribeLayer["v"+version.replace(/\./g,"_")];if(!constructor){throw"Can't find a WMS DescribeLayer parser for version "+
-version;}
-var parser=new constructor(this.options);var describelayer=parser.read(data);describelayer.version=version;return describelayer;},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer"});OpenLayers.Format.WMSDescribeLayer.v1_1=OpenLayers.Class(OpenLayers.Format.WMSDescribeLayer,{initialize:function(options){OpenLayers.Format.WMSDescribeLayer.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+return featureId;},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={"l":"start","r":"end","b":"bottom","t":"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={"t":"-70%","b":"0"};OpenLayers.Renderer.SVG.LABEL_VFACTOR={"t":0,"b":-1};OpenLayers.Renderer.SVG.preventDefault=function(e){e.preventDefault&&e.preventDefault();};OpenLayers.Format.WMSDescribeLayer=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.1",getVersion:function(root,options){var version=OpenLayers.Format.XML.VersionedOGC.prototype.getVersion.apply(this,arguments);if(version=="1.1.1"||version=="1.1.0"){version="1.1";}
+return version;},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer"});OpenLayers.Format.WMSDescribeLayer.v1_1=OpenLayers.Class(OpenLayers.Format.WMSDescribeLayer,{initialize:function(options){OpenLayers.Format.WMSDescribeLayer.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 var root=data.documentElement;var children=root.childNodes;var describelayer=[];var childNode,nodeName;for(var i=0;i<children.length;++i){childNode=children[i];nodeName=childNode.nodeName;if(nodeName=='LayerDescription'){var layerName=childNode.getAttribute('name');var owsType='';var owsURL='';var typeName='';if(childNode.getAttribute('owsType')){owsType=childNode.getAttribute('owsType');owsURL=childNode.getAttribute('owsURL');}else{if(childNode.getAttribute('wfs')!=''){owsType='WFS';owsURL=childNode.getAttribute('wfs');}else if(childNode.getAttribute('wcs')!=''){owsType='WCS';owsURL=childNode.getAttribute('wcs');}}
 var query=childNode.getElementsByTagName('Query');if(query.length>0){typeName=query[0].getAttribute('typeName');if(!typeName){typeName=query[0].getAttribute('typename');}}
 describelayer.push({layerName:layerName,owsType:owsType,owsURL:owsURL,typeName:typeName});}}
@@ -2371,37 +2386,7 @@
 if((origTL.x+this.size.w)>(mapSize.w-this.map.paddingForPopups.right)){newTL.x=mapSize.w-this.map.paddingForPopups.right-this.size.w;}
 if(origTL.y<this.map.paddingForPopups.top){newTL.y=this.map.paddingForPopups.top;}else
 if((origTL.y+this.size.h)>(mapSize.h-this.map.paddingForPopups.bottom)){newTL.y=mapSize.h-this.map.paddingForPopups.bottom-this.size.h;}
-var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Handler.Box=OpenLayers.Class(OpenLaye
 rs.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxOffsets:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.eventsDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.eventsDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.
 start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);var offset=this.getBoxOffsets();this.zoomBox.style.width=(deltaX+offset.width+1)+"px";this.zoomBox.style.height=(deltaY+offset.height+1)+"px";this.zoomBox.style.left=(xy.x<startX?startX-deltaX-offset.left:startX-offset.left)+"px";this.zoomBox.style.top=(xy.y<startY?startY-deltaY-offset.top:startY-offset.top)+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
-this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxOffsets=null;OpenLayers.Element.removeClass(this.map.eventsDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.dragHandler.deactivate()){if(this.zoomBox){this.removeBox();}}
-return true;}else{return false;}},getBoxOffsets:function(){if(!this.boxOffsets){var testDiv=document.createElement("div");testDiv.style.position="absolute";testDiv.style.border="1px solid black";testDiv.style.width="3px";document.body.appendChild(testDiv);var w3cBoxModel=testDiv.clientWidth==3;document.body.removeChild(testDiv);var left=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"));var right=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"));var top=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"));var bottom=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:left,right:right,top:top,bottom:bottom,width:w3cBoxModel===false?left+right:0,height:w3cBoxModel===false?top+bottom:0};}
-return this.boxOffsets;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax
 =center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
-var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:25,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
-this.kinetic=new OpenLayers.Kinetic(config);}
-this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
-this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
-this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
-this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,dblclickTolerance:13,stopSingle:false,stopDouble:false,timerId:null,touch:false,down:null,last:null,first:null,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},touchstart:function(evt){if(!this.touch){this.unregisterMouseListeners();this.touch=true;}
-this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},touchmove:function(evt){this.last=this.getEventInfo(evt);return true;},touchend:function(evt){if(this.down){evt.xy=this.last.xy;evt.lastTouches=this.last.touches;this.handleSingle(evt);this.down=null;}
-return true;},unregisterMouseListeners:function(){this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,click:this.click,dblclick:this.dblclick,scope:this});},mousedown:function(evt){this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
-return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
-return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}},click:function(evt){if(!this.last){this.last=this.getEventInfo(evt);}
-this.handleSingle(evt);return!this.stopSingle;},dblclick:function(evt){this.handleDouble(evt);return!this.stopDouble;},handleDouble:function(evt){if(this["double"]&&this.passesDblclickTolerance(evt)){this.callback("dblclick",[evt]);}},handleSingle:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){if(this.last.touches&&this.last.touches.length===1){if(this["double"]){OpenLayers.Event.stop(evt);}
-this.handleDouble(evt);}
-if(!this.last.touches||this.last.touches.length!==2){this.clearTimer();}}else{this.first=this.getEventInfo(evt);var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.queuePotentialClick(clickEvent);}}},queuePotentialClick:function(evt){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){passes=this.pixelTolerance>=this.down.xy.distanceTo(evt.xy);if(passes&&this.touch&&this.down.touches.length===this.last.touches.length){for(var i=0,ii=this.down.touches.length;i<ii;++i){if(this.getTouchDistance(this.down.touches[i],this.last.touches[i])>this.pixelTolerance){passes=false;break;}}}}
-return passes;},getTouchDistance:function(from,to){return Math.sqrt(Math.pow(from.clientX-to.clientX,2)+
-Math.pow(from.clientY-to.clientY,2));},passesDblclickTolerance:function(evt){var passes=true;if(this.down&&this.first){passes=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance;}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
-if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback("click",[evt]);}},getEventInfo:function(evt){var touches;if(evt.touches){var len=evt.touches.length;touches=new Array(len);var touch;for(var i=0;i<len;i++){touch=evt.touches[i];touches[i]={clientX:touch.clientX,clientY:touch.clientY};}}
-return{xy:evt.xy,touches:touches};},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.first=null;this.last=null;this.touch=false;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
-this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
-this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
-this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
-var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCen
 ter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,EVENT_TYPES:["featureadded"]
 ,multi:false,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){this.EVENT_TYPES=OpenLayers.Control.DrawFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.triggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
-var sketchStyle=this.layer.styleMap&&this.layer.styleMap.styles.temporary;if(sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":sketchStyle})});}
-this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.
 Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,geodesic:false,draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
+var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Control.ScaleLine=OpenLayers.Class(Op
 this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
 this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
 return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
@@ -2430,9 +2415,9 @@
 feature=new OpenLayers.Feature.Vector(geometry,attributes);if(bbox){feature.bounds=OpenLayers.Bounds.fromArray(bbox);}
 if(obj.id){feature.fid=obj.id;}
 return feature;},parseGeometry:function(obj){if(obj==null){return null;}
-var geometry,collection=false;if(obj.type=="GeometryCollection"){if(!(obj.geometries instanceof Array)){throw"GeometryCollection must have geometries array: "+obj;}
+var geometry,collection=false;if(obj.type=="GeometryCollection"){if(!(OpenLayers.Util.isArray(obj.geometries))){throw"GeometryCollection must have geometries array: "+obj;}
 var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
-geometry=new OpenLayers.Geometry.Collection(components);collection=true;}else{if(!(obj.coordinates instanceof Array)){throw"Geometry must have coordinates array: "+obj;}
+geometry=new OpenLayers.Geometry.Collection(components);collection=true;}else{if(!(OpenLayers.Util.isArray(obj.coordinates))){throw"Geometry must have coordinates array: "+obj;}
 if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
 try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
 if(this.internalProjection&&this.externalProjection&&!collection){geometry.transform(this.externalProjection,this.internalProjection);}
@@ -2448,10 +2433,11 @@
 return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
 polys.push(p);}
 return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
-return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(obj instanceof Array){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
+return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(OpenLayers.Util.isArray(obj)){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
 geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
 return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"name","properties":{"name":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"name","properties":{"name":"EPSG:"+code}};}}
-return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);return{"type":"Feature","id":feature.fid==null?feature.id:feature.fid,"properties":feature.attributes,"geometry":geom};},'geometry':function(geometry){if(geometry==null){return null;}
+return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);var json={"type":"Feature","properties":feature.attributes,"geometry":geom};if(feature.fid!=null){json.id=feature.fid;}
+return json;},'geometry':function(geometry){if(geometry==null){return null;}
 if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
 var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
 return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
@@ -2483,22 +2469,45 @@
 if(this.size&&this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=(w<0?0:w)+'px';block.div.style.height=(h<0?0:h)+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
 this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
 url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(url instanceof Array){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(OpenLayers.Util.isArray(url)){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
 return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var limit=Math.pow(2,z);if(this.wrapDateLine)
 {x=((x%limit)+limit)%limit;}
 return{'x':x,'y':y,'z':z};},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},wrapDateLine:true,CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:'_layer',featureIdentifier:'_feature',regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},gmlFormat:null,read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;if(root){var scope=this;var read=this["read_"+root.nodeName];if(read){result=read.call(this,root);}else{result=new OpenLayers.Format.GML((this.options?this.options:{})).read(data);}}else{result=data;}
-return result;},read_msGMLOutput:function(data){var response=[];var layerNodes=this.getSiblingNodesByTagCriteria(data,this.layerIdentifier);if(layerNodes){for(var i=0,len=layerNodes.length;i<len;++i){var node=layerNodes[i];var layerName=node.nodeName;if(node.prefix){layerName=layerName.split(':')[1];}
-var layerName=layerName.replace(this.layerIdentifier,'');var featureNodes=this.getSiblingNodesByTagCriteria(node,this.featureIdentifier);if(featureNodes){for(var j=0;j<featureNodes.length;j++){var featureNode=featureNodes[j];var geomInfo=this.parseGeometry(featureNode);var attributes=this.parseAttributes(featureNode);var feature=new OpenLayers.Feature.Vector(geomInfo.geometry,attributes,null);feature.bounds=geomInfo.bounds;feature.type=layerName;response.push(feature);}}}}
-return response;},read_FeatureInfoResponse:function(data){var response=[];var featureNodes=this.getElementsByTagNameNS(data,'*','FIELDS');for(var i=0,len=featureNodes.length;i<len;i++){var featureNode=featureNodes[i];var geom=null;var attributes={};var j;var jlen=featureNode.attributes.length;if(jlen>0){for(j=0;j<jlen;j++){var attribute=featureNode.attributes[j];attributes[attribute.nodeName]=attribute.nodeValue;}}else{var nodes=featureNode.childNodes;for(j=0,jlen=nodes.length;j<jlen;++j){var node=nodes[j];if(node.nodeType!=3){attributes[node.getAttribute("name")]=node.getAttribute("value");}}}
-response.push(new OpenLayers.Feature.Vector(geom,attributes,null));}
-return response;},getSiblingNodesByTagCriteria:function(node,criteria){var nodes=[];var children,tagName,n,matchNodes,child;if(node&&node.hasChildNodes()){children=node.childNodes;n=children.length;for(var k=0;k<n;k++){child=children[k];while(child&&child.nodeType!=1){child=child.nextSibling;k++;}
-tagName=(child?child.nodeName:'');if(tagName.length>0&&tagName.indexOf(criteria)>-1){nodes.push(child);}else{matchNodes=this.getSiblingNodesByTagCriteria(child,criteria);if(matchNodes.length>0){(nodes.length==0)?nodes=matchNodes:nodes.push(matchNodes);}}}}
-return nodes;},parseAttributes:function(node){var attributes={};if(node.nodeType==1){var children=node.childNodes;var n=children.length;for(var i=0;i<n;++i){var child=children[i];if(child.nodeType==1){var grandchildren=child.childNodes;var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;if(grandchildren.length==0){attributes[name]=null}else if(grandchildren.length==1){var grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){var value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseGeometry:function(node){if(!this.gmlFormat){this.gmlFormat=new OpenLayers.Format.GML();}
-var feature=this.gmlFormat.parseFeature(node);var geometry,bounds=null;if(feature){geometry=feature.geometry&&feature.geometry.clone();bounds=feature.bounds&&feature.bounds.clone();feature.destroy();}
-return{geometry:geometry,bounds:bounds};},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Rico=OpenLayers.Rico||{};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((thi
 s.rgb.r+other.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
+obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},wrapDateLine:true,CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxOffsets:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.st
 yle.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.eventsDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.eventsDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);var offset=this.getBoxOffsets();this.zoomBox.style.width=(deltaX+offset.width+1)+"px";this.zoomBox.style.height=(deltaY+offset.height+1)+"px";this.zoomBox.style.left=(xy.x<startX?startX-deltaX-offset.left:startX-offset.left)+"px";this.zoomBox.style.top=(xy.y<startY?startY-deltaY-offset.top:startY-offset.top)+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dr
+this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxOffsets=null;OpenLayers.Element.removeClass(this.map.eventsDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.dragHandler.deactivate()){if(this.zoomBox){this.removeBox();}}
+return true;}else{return false;}},getBoxOffsets:function(){if(!this.boxOffsets){var testDiv=document.createElement("div");testDiv.style.position="absolute";testDiv.style.border="1px solid black";testDiv.style.width="3px";document.body.appendChild(testDiv);var w3cBoxModel=testDiv.clientWidth==3;document.body.removeChild(testDiv);var left=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"));var right=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"));var top=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"));var bottom=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:left,right:right,top:top,bottom:bottom,width:w3cBoxModel===false?left+right:0,height:w3cBoxModel===false?top+bottom:0};}
+return this.boxOffsets;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax
+var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:1,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
+this.kinetic=new OpenLayers.Kinetic(config);}
+this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
+this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
+this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
+this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,dblclickTolerance:13,stopSingle:false,stopDouble:false,timerId:null,touch:false,down:null,last:null,first:null,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},touchstart:function(evt){if(!this.touch){this.unregisterMouseListeners();this.touch=true;}
+this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},touchmove:function(evt){this.last=this.getEventInfo(evt);return true;},touchend:function(evt){if(this.down){evt.xy=this.last.xy;evt.lastTouches=this.last.touches;this.handleSingle(evt);this.down=null;}
+return true;},unregisterMouseListeners:function(){this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,click:this.click,dblclick:this.dblclick,scope:this});},mousedown:function(evt){this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
+return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
+return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}},click:function(evt){if(!this.last){this.last=this.getEventInfo(evt);}
+this.handleSingle(evt);return!this.stopSingle;},dblclick:function(evt){this.handleDouble(evt);return!this.stopDouble;},handleDouble:function(evt){if(this["double"]&&this.passesDblclickTolerance(evt)){this.callback("dblclick",[evt]);}},handleSingle:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){if(this.last.touches&&this.last.touches.length===1){if(this["double"]){OpenLayers.Event.stop(evt);}
+this.handleDouble(evt);}
+if(!this.last.touches||this.last.touches.length!==2){this.clearTimer();}}else{this.first=this.getEventInfo(evt);var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.queuePotentialClick(clickEvent);}}},queuePotentialClick:function(evt){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){passes=this.pixelTolerance>=this.down.xy.distanceTo(evt.xy);if(passes&&this.touch&&this.down.touches.length===this.last.touches.length){for(var i=0,ii=this.down.touches.length;i<ii;++i){if(this.getTouchDistance(this.down.touches[i],this.last.touches[i])>this.pixelTolerance){passes=false;break;}}}}
+return passes;},getTouchDistance:function(from,to){return Math.sqrt(Math.pow(from.clientX-to.clientX,2)+
+Math.pow(from.clientY-to.clientY,2));},passesDblclickTolerance:function(evt){var passes=true;if(this.down&&this.first){passes=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance;}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
+if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback("click",[evt]);}},getEventInfo:function(evt){var touches;if(evt.touches){var len=evt.touches.length;touches=new Array(len);var touch;for(var i=0;i<len;i++){touch=evt.touches[i];touches[i]={clientX:touch.clientX,clientY:touch.clientY};}}
+return{xy:evt.xy,touches:touches};},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.first=null;this.last=null;this.touch=false;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
+this.zoomBox=null;if(this.pinchZoom){this.pinchZoom.destroy();}
+this.pinchZoom=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
+this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
+if(this.pinchZoom){this.pinchZoom.activate();}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.pinchZoom){this.pinchZoom.deactivate();}
+this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
+var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);if(OpenLayers.Control.PinchZoom){this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));}},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(
 newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,EVENT_TYPES:["featureadded"]
+var sketchStyle=this.layer.styleMap&&this.layer.styleMap.styles.temporary;if(sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":sketchStyle})});}
+this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},insertXY:function(x,y){if(this.handler&&this.handler.line){this.handler.insertXY(x,y);}},insertDeltaXY:function(dx,dy){if(this.handler&&this.handler.line){this.handler.insertDeltaXY(dx,dy);}},insertDirectionLength:function(direction,length){if(this.handler&&this.handler.line){this.handler.insertDirectionLength(direction,length);}},insertDeflectionLength:function(deflection,length){if(this.handler&&this.handler.line){this.handler.insertDeflectionLength(deflection,length);}},undo:function(){return this.handler.undo&&this.handler.undo();},redo:function(){return this.handler.
 redo&&this.handler.redo();},finishSketch:function(){this.handler.finishGeometry();},cancel:function(){this.handler.cancel();},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);if(this.defaultControl===null){this.defaultControl=this.controls[0];}
+return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Rico=OpenLayers.Rico||{};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((this.rgb.r+other.rgb.r)/2);this.rg
 shortHexCode.charAt(i));}}
 if(hexCode.indexOf('#')==0){hexCode=hexCode.substring(1);}
 var red=hexCode.substring(0,2);var green=hexCode.substring(2,4);var blue=hexCode.substring(4,6);return new OpenLayers.Rico.Color(parseInt(red,16),parseInt(green,16),parseInt(blue,16));};OpenLayers.Rico.Color.createColorFromBackground=function(elem){var actualColor=OpenLayers.Element.getStyle(OpenLayers.Util.getElement(elem),"backgroundColor");if(actualColor=="transparent"&&elem.parentNode){return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);}
@@ -2544,7 +2553,7 @@
 this.layer.protocol.commit(features,{callback:this.onCommit,scope:this});},onCommit:function(response){var evt={"response":response};if(response.success()){var features=response.reqFeatures;var state,feature;var destroys=[];var insertIds=response.insertIds||[];var j=0;for(var i=0,len=features.length;i<len;++i){feature=features[i];feature=feature._original||feature;state=feature.state;if(state){if(state==OpenLayers.State.DELETE){destroys.push(feature);}else if(state==OpenLayers.State.INSERT){feature.fid=insertIds[j];++j;}
 feature.state=null;}}
 if(destroys.length>0){this.layer.destroyFeatures(destroys);}
-this.events.triggerEvent("success",evt);}else{this.events.triggerEvent("fail",evt);}},CLASS_NAME:"OpenLayers.Strategy.Save"});OpenLayers.Strategy.BBOX=OpenLayers.Class(OpenLayers.Strategy,{bounds:null,resolution:null,ratio:2,resFactor:null,response:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"moveend":this.update,scope:this});this.layer.events.on({"refresh":this.update,scope:this});if(this.layer.visibility==true){this.update();}else{this.layer.events.on({"visibilitychanged":this.update,scope:this});}}
+this.events.triggerEvent("success",evt);}else{this.events.triggerEvent("fail",evt);}},CLASS_NAME:"OpenLayers.Strategy.Save"});OpenLayers.Strategy.BBOX=OpenLayers.Class(OpenLayers.Strategy,{bounds:null,resolution:null,ratio:2,resFactor:null,response:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"moveend":this.update,scope:this});this.layer.events.on({"refresh":this.update,scope:this});if(this.layer.visibility===true&&this.layer.inRange===true){this.update();}else{this.layer.events.on({"visibilitychanged":this.update,scope:this});}}
 return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"moveend":this.update,"refresh":this.update,"visibilitychanged":this.update,scope:this});}
 return deactivated;},update:function(options){var mapBounds=this.getMapBounds();if(mapBounds!==null&&((options&&options.force)||this.invalidBounds(mapBounds))){this.calculateBounds(mapBounds);this.resolution=this.layer.map.getResolution();this.triggerRead(options);}},getMapBounds:function(){if(this.layer.map===null){return null;}
 var bounds=this.layer.map.getExtent();if(bounds&&!this.layer.projection.equals(this.layer.map.getProjectionObject())){bounds=bounds.clone().transform(this.layer.map.getProjectionObject(),this.layer.projection);}
@@ -2555,10 +2564,19 @@
 this.layer.events.triggerEvent("loadstart");this.response=this.layer.protocol.read(OpenLayers.Util.applyDefaults({filter:this.createFilter(),callback:this.merge,scope:this},options));},createFilter:function(){var filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,value:this.bounds,projection:this.layer.projection});if(this.layer.filter){filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.layer.filter,filter]});}
 return filter;},merge:function(resp){this.layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(remote,local);}}}
 this.layer.addFeatures(features);}
-this.response=null;this.layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Math.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=
 (this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(options){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat){if(this.outputFormat.toLowerCase()=="gml2"){this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});}else if(this.outputFormat.toLowerCase()=="json"){this.readFormat=new OpenLayers.Format.GeoJSON();}}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});OpenLayers.Format.WMTSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,yx:{"urn:ogc:def:crs:EPSG::4326":true},read:function(data){if(typeof data=="string"){data=OpenLayers.For
-var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.WMTSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw new Error("Can't find a WMTS capabilities parser for version "+version);}
-this.parser=new constr(this.options);}
-return this.parser.read(data);},createLayer:function(capabilities,config){var layer;var required={layer:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
+this.response=null;this.layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Tile.Google=OpenLayers.Class(OpenLayers.Tile,{node:null,initialize:function(layer,position,bounds,options){OpenLayers.Tile.prototype.initialize.apply(this,[layer,position,bounds,null,null,options]);},destroy:function(){this.node&&this.clear();this.node=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Google(this.layer,this.position,this.bounds);}
+OpenLayers.Util.applyDefaults(obj,this);obj.node=null;return obj;},draw:function(){var layerType=OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.layer.type];if(layerType&&OpenLayers.Tile.prototype.draw.apply(this,arguments)){var xyz=this.layer.getXYZ(this.bounds);var point=new google.maps.Point(xyz.x,xyz.y);var tempTile;if(this.layer.type===google.maps.MapTypeId.HYBRID){tempTile=layerType.getTile(point,xyz.z,document);}
+this.node=layerType.getTile(point,xyz.z,document);this.isLoading=true;this.events.triggerEvent("loadstart");this.layer.div.appendChild(this.node);OpenLayers.Util.modifyDOMElement(this.node,null,this.position,null,"absolute");window.setTimeout(OpenLayers.Function.bind(function(){this.isLoading=false;this.events&&this.events.triggerEvent("loadend");if(tempTile){layerType.releaseTile(tempTile);}},this),0);}
+return true;},clear:function(){if(this.node){this.node.parentNode&&this.node.parentNode.removeChild(this.node);OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.layer.type].releaseTile(this.node);}},CLASS_NAME:"OpenLayers.Tile.Google"});OpenLayers.Layer.GoogleNG=OpenLayers.Class(OpenLayers.Layer.XYZ,{SUPPORTED_TRANSITIONS:[],serverResolutions:[156543.03390625,78271.516953125,39135.7584765625,19567.87923828125,9783.939619140625,4891.9698095703125,2445.9849047851562,1222.9924523925781,611.4962261962891,305.74811309814453,152.87405654907226,76.43702827453613,38.218514137268066,19.109257068634033,9.554628534317017,4.777314267158508,2.388657133579254,1.194328566789627,0.5971642833948135,0.29858214169740677,0.14929107084870338,0.07464553542435169,0.037322767712175846],attributionTemplate:'<span class="olGoogleAttribution ${mapType}">'+'<div><a title="Click to see this area on Google Maps" '+'target="_blank" href="http://maps.google.com/maps?'+'ll=${center}&z=${zoom}&t=${t}"><img w
 idth="62" height="24" '+'src="http://maps.gstatic.com/mapfiles/google_white.png"/></a>'+'</div>${mapData}<a style="white-space: nowrap" target="_blank" '+'href="http://www.google.com/help/terms_maps.html">'+'Terms of Use</a></span>',mapTypes:{"roadmap":"m","satellite":"k","hybrid":"h","terrain":"p"},type:null,initialize:function(options){options=OpenLayers.Util.applyDefaults({sphericalMercator:true},options);if(!options.type){options.type=google.maps.MapTypeId.ROADMAP;}
+var newArgs=[options.name,null,options];OpenLayers.Layer.XYZ.prototype.initialize.apply(this,newArgs);if(!OpenLayers.Layer.GoogleNG.mapObject){OpenLayers.Layer.GoogleNG.mapObject=new google.maps.Map(document.createElement("div"));}
+if(OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.type]){this.initLayer();}else{google.maps.event.addListenerOnce(OpenLayers.Layer.GoogleNG.mapObject,"idle",OpenLayers.Function.bind(this.initLayer,this));}},initLayer:function(){var mapType=OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.type];if(!this.name){this.setName("Google "+mapType.name);}
+var minZoom=mapType.minZoom||0;this.addOptions({maxResolution:Math.min(this.serverResolutions[minZoom],this.maxResolution),zoomOffset:minZoom,numZoomLevels:Math.min(mapType.maxZoom+1-minZoom,this.numZoomLevels)},true);},addTile:function(bounds,position){return new OpenLayers.Tile.Google(this,position,bounds,this.tileOptions);},updateAttribution:function(copyrights){var myCopyrights;if(this.type==google.maps.MapTypeId.HYBRID){var candidates=[].concat(copyrights["h"],copyrights["k"],copyrights["m"]);myCopyrights=[];for(var i=candidates.length-1;i>=0;--i){if(OpenLayers.Util.indexOf(candidates,myCopyrights)==-1){myCopyrights.push(candidates[i]);}}}else{myCopyrights=copyrights[this.mapTypes[this.type]];}
+var mapData=myCopyrights.length==0?"":"Map Data &copy;"+new Date().getFullYear()+" "+
+myCopyrights.join(", ")+" - ";var center=this.map.getCenter();center&&center.transform(this.map.getProjectionObject(),new OpenLayers.Projection("EPSG:4326"));var size=this.map.getSize();this.attribution=OpenLayers.String.format(this.attributionTemplate,{t:this.mapTypes[this.type],zoom:this.map.getZoom(),center:center.lat+","+center.lon,mapType:this.type,mapData:mapData});this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"attribution"});},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.events.register("moveend",this,OpenLayers.Layer.GoogleNG.loadCopyrights);},removeMap:function(){OpenLayers.Layer.XYZ.prototype.removeMap.apply(this,arguments);this.events.unregister("moveend",this,OpenLayers.Layer.GoogleNG.loadCopyrights);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.GoogleNG(this.options);}
+obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.GoogleNG"});OpenLayers.Layer.GoogleNG.mapObject=null;OpenLayers.Layer.GoogleNG.loadCopyrights=function(){var me=OpenLayers.Layer.GoogleNG.loadCopyrights;if(me.numLoadingScripts==undefined){me.loadingScripts=[];me.numLoadingScripts=0;me.copyrights={"m":[],"k":[],"h":[],"p":[]};me.origGAddCopyright=window.GAddCopyright;me.origGVerify=window.GVerify;me.origGAppFeatures=window.GAppFeatures;window.GAddCopyright=function(){var copyright=arguments[7];var category=me.copyrights[arguments[0]];if(OpenLayers.Util.indexOf(category,copyright)==-1){copyright&&category.push(copyright);}};window.GVerify=OpenLayers.Function.True;window.GAppFeatures=OpenLayers.Function.bind(function(){me.numLoadingScripts--;if(me.numLoadingScripts==0){var script;for(var i=me.loadingScripts.length-1;i>=0;--i){script=me.loadingScripts[i][0];me.loadingScripts[i][1].updateAttribution(me.copyrights);script.parentNo
 de.removeChild(script);}
+window.GAddCopyright=me.origGAddCopyright;delete me.origGAddCopyright;window.GVerify=me.origGVerify;delete me.origGVerify;window.GAppFeatures=me.origGAppFeatures;delete me.origGAppFeatures;delete me.loadingScripts;delete me.numLoadingScripts;delete me.copyrights;}},this);}
+var mapProj=this.map.getProjectionObject();var llProj=new OpenLayers.Projection("EPSG:4326");var center=this.map.getCenter().transform(mapProj,llProj);var extent=this.map.getExtent().transform(mapProj,llProj);var params={spn:extent.getHeight()+","+extent.getWidth(),z:this.map.getZoom(),t:this.mapTypes[this.type],vp:center.lat+","+center.lon};var url="http://maps.google.com/maps?"+
+OpenLayers.Util.getParameterString(params);var script=document.createElement("script");script.type="text/javascript";script.src=url;me.numLoadingScripts++;me.loadingScripts.push([script,this]);document.getElementsByTagName("head")[0].appendChild(script);};OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Mat
 h.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=(this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(options){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat){if(this.outputFormat.toLowerCase()=="gml2"){this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});}else if(this.outputFormat.toLowerCase()=="json"){this.readFormat=new OpenLayers.Format.GeoJSON();}}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});OpenLayers.Format.WMTSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.
 VersionedOGC,{defaultVersion:"1.0.0",yx:{"urn:ogc:def:crs:EPSG::4326":true},createLayer:function(capabilities,config){var layer;var required={layer:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
 var contents=capabilities.contents;var matrixSet=contents.tileMatrixSets[config.matrixSet];var layers=contents.layers;var layerDef;for(var i=0,ii=contents.layers.length;i<ii;++i){if(contents.layers[i].identifier===config.layer){layerDef=contents.layers[i];break;}}
 if(layerDef&&matrixSet){var style;for(var i=0,ii=layerDef.styles.length;i<ii;++i){style=layerDef.styles[i];if(style.isDefault){break;}}
 layer=new OpenLayers.Layer.WMTS(OpenLayers.Util.applyDefaults(config,{url:capabilities.operationsMetadata.GetTile.dcp.http.get,name:layerDef.title,style:style.identifier,matrixIds:matrixSet.matrixIds}));}
@@ -2593,21 +2611,26 @@
 this.mapObject.setOptions({center:center,zoom:zoom});},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new google.maps.LatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new google.maps.LatLng(lat,lon);}
 return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new google.maps.Point(x,y);},destroy:function(){if(this.repositionListener){google.maps.event.removeListener(this.repositionListener);}
 if(this.repositionTimer){window.clearTimeout(this.repositionTimer);}
-OpenLayers.Layer.Google.prototype.destroy.apply(this,arguments);}};OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",ows:"http://www.opengis.net/ows"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[dat
 a]);}
+OpenLayers.Layer.Google.prototype.destroy.apply(this,arguments);}};OpenLayers.Format.WPSDescribeProcess=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{wps:"http://www.opengis.net/wps/1.0.0",ows:"http://www.opengis.net/ows/1.1",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",defaultPrefix:"wps",regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
+var info={};this.readNode(data,info);return info;},readers:{"wps":{"ProcessDescriptions":function(node,obj){obj.processDescriptions={};this.readChildNodes(node,obj.processDescriptions);},"ProcessDescription":function(node,processDescriptions){var processVersion=this.getAttributeNS(node,this.namespaces.wps,"processVersion");var processDescription={processVersion:processVersion,statusSupported:(node.getAttribute("statusSupported")==="true"),storeSupported:(node.getAttribute("storeSupported")==="true")};this.readChildNodes(node,processDescription);processDescriptions[processDescription.identifier]=processDescription;},"DataInputs":function(node,processDescription){processDescription.dataInputs=[];this.readChildNodes(node,processDescription.dataInputs);},"ProcessOutputs":function(node,processDescription){processDescription.processOutputs=[];this.readChildNodes(node,processDescription.processOutputs);},"Output":function(node,processOutputs){var output={};this.readChildNodes(node,
 output);processOutputs.push(output);},"ComplexOutput":function(node,output){output.complexOutput={};this.readChildNodes(node,output.complexOutput);},"Input":function(node,dataInputs){var input={maxOccurs:parseInt(node.getAttribute("maxOccurs")),minOccurs:parseInt(node.getAttribute("minOccurs"))};this.readChildNodes(node,input);dataInputs.push(input);},"BoundingBoxData":function(node,input){input.boundingBoxData={};this.readChildNodes(node,input.boundingBoxData);},"CRS":function(node,obj){if(!obj.CRSs){obj.CRSs={};}
+obj.CRSs[this.getChildValue(node)]=true;},"LiteralData":function(node,input){input.literalData={};this.readChildNodes(node,input.literalData);},"ComplexData":function(node,input){input.complexData={};this.readChildNodes(node,input.complexData);},"Default":function(node,complexData){complexData["default"]={};this.readChildNodes(node,complexData["default"]);},"Supported":function(node,complexData){complexData["supported"]={};this.readChildNodes(node,complexData["supported"]);},"Format":function(node,obj){var format={};this.readChildNodes(node,format);if(!obj.formats){obj.formats={};}
+obj.formats[format.mimeType]=true;},"MimeType":function(node,format){format.mimeType=this.getChildValue(node);}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.WPSDescribeProcess"});OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",geonet:"http://www.fao.org/geonetwork",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),split
 Space:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
 var obj={};this.readNode(data,obj);return obj;},readers:{"csw":{"GetRecordsResponse":function(node,obj){obj.records=[];this.readChildNodes(node,obj);var version=this.getAttributeNS(node,"",'version');if(version!=""){obj.version=version;}},"RequestId":function(node,obj){obj.RequestId=this.getChildValue(node);},"SearchStatus":function(node,obj){obj.SearchStatus={};var timestamp=this.getAttributeNS(node,"",'timestamp');if(timestamp!=""){obj.SearchStatus.timestamp=timestamp;}},"SearchResults":function(node,obj){this.readChildNodes(node,obj);var attrs=node.attributes;var SearchResults={};for(var i=0,len=attrs.length;i<len;++i){if((attrs[i].name=="numberOfRecordsMatched")||(attrs[i].name=="numberOfRecordsReturned")||(attrs[i].name=="nextRecord")){SearchResults[attrs[i].name]=parseInt(attrs[i].nodeValue);}else{SearchResults[attrs[i].name]=attrs[i].nodeValue;}}
-obj.SearchResults=SearchResults;},"SummaryRecord":function(node,obj){var record={type:"SummaryRecord"};this.readChildNodes(node,record);obj.records.push(record);},"BriefRecord":function(node,obj){var record={type:"BriefRecord"};this.readChildNodes(node,record);obj.records.push(record);},"DCMIRecord":function(node,obj){var record={type:"DCMIRecord"};this.readChildNodes(node,record);obj.records.push(record);},"Record":function(node,obj){var record={type:"Record"};this.readChildNodes(node,record);obj.records.push(record);}},"dc":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(obj[name]instanceof Array)){obj[name]=new Array();}
+obj.SearchResults=SearchResults;},"SummaryRecord":function(node,obj){var record={type:"SummaryRecord"};this.readChildNodes(node,record);obj.records.push(record);},"BriefRecord":function(node,obj){var record={type:"BriefRecord"};this.readChildNodes(node,record);obj.records.push(record);},"DCMIRecord":function(node,obj){var record={type:"DCMIRecord"};this.readChildNodes(node,record);obj.records.push(record);},"Record":function(node,obj){var record={type:"Record"};this.readChildNodes(node,record);obj.records.push(record);},"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();obj[name]=this.getChildValue(node);}},"geonet":{"info":function(node,obj){var gninfo={};this.readChildNodes(node,gninfo);obj.gninfo=gninfo;}},"dc":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(OpenLayers.Util.isArray(obj[name]))){obj[name]=new Array();}
 var dc_element={};var attrs=node.attributes;for(var i=0,len=attrs.length;i<len;++i){dc_element[attrs[i].name]=attrs[i].nodeValue;}
-dc_element.value=this.getChildValue(node);obj[name].push(dc_element);}},"dct":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(obj[name]instanceof Array)){obj[name]=new Array();}
+dc_element.value=this.getChildValue(node);obj[name].push(dc_element);}},"dct":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(OpenLayers.Util.isArray(obj[name]))){obj[name]=new Array();}
 obj[name].push(this.getChildValue(node));}},"ows":OpenLayers.Util.applyDefaults({"BoundingBox":function(node,obj){if(obj.bounds){obj.BoundingBox=[{crs:obj.projection,value:[obj.bounds.left,obj.bounds.bottom,obj.bounds.right,obj.bounds.top]}];delete obj.projection;delete obj.bounds;}
 OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers["ows"]["BoundingBox"].apply(this,arguments);}},OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers["ows"])},write:function(options){var node=this.writeNode("csw:GetRecords",options);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"csw":{"GetRecords":function(options){if(!options){options={};}
 var node=this.createElementNSPlus("csw:GetRecords",{attributes:{service:"CSW",version:this.version,requestId:options.requestId||this.requestId,resultType:options.resultType||this.resultType,outputFormat:options.outputFormat||this.outputFormat,outputSchema:options.outputSchema||this.outputSchema,startPosition:options.startPosition||this.startPosition,maxRecords:options.maxRecords||this.maxRecords}});if(options.DistributedSearch||this.DistributedSearch){this.writeNode("csw:DistributedSearch",options.DistributedSearch||this.DistributedSearch,node);}
-var ResponseHandler=options.ResponseHandler||this.ResponseHandler;if(ResponseHandler instanceof Array&&ResponseHandler.length>0){for(var i=0,len=ResponseHandler.length;i<len;i++){this.writeNode("csw:ResponseHandler",ResponseHandler[i],node);}}
+var ResponseHandler=options.ResponseHandler||this.ResponseHandler;if(OpenLayers.Util.isArray(ResponseHandler)&&ResponseHandler.length>0){for(var i=0,len=ResponseHandler.length;i<len;i++){this.writeNode("csw:ResponseHandler",ResponseHandler[i],node);}}
 this.writeNode("Query",options.Query||this.Query,node);return node;},"DistributedSearch":function(options){var node=this.createElementNSPlus("csw:DistributedSearch",{attributes:{hopCount:options.hopCount}});return node;},"ResponseHandler":function(options){var node=this.createElementNSPlus("csw:ResponseHandler",{value:options.value});return node;},"Query":function(options){if(!options){options={};}
-var node=this.createElementNSPlus("csw:Query",{attributes:{typeNames:options.typeNames||"csw:Record"}});var ElementName=options.ElementName;if(ElementName instanceof Array&&ElementName.length>0){for(var i=0,len=ElementName.length;i<len;i++){this.writeNode("csw:ElementName",ElementName[i],node);}}else{this.writeNode("csw:ElementSetName",options.ElementSetName||{value:'summary'},node);}
+var node=this.createElementNSPlus("csw:Query",{attributes:{typeNames:options.typeNames||"csw:Record"}});var ElementName=options.ElementName;if(OpenLayers.Util.isArray(ElementName)&&ElementName.length>0){for(var i=0,len=ElementName.length;i<len;i++){this.writeNode("csw:ElementName",ElementName[i],node);}}else{this.writeNode("csw:ElementSetName",options.ElementSetName||{value:'summary'},node);}
 if(options.Constraint){this.writeNode("csw:Constraint",options.Constraint,node);}
+if(options.SortBy){this.writeNode("ogc:SortBy",options.SortBy,node);}
 return node;},"ElementName":function(options){var node=this.createElementNSPlus("csw:ElementName",{value:options.value});return node;},"ElementSetName":function(options){var node=this.createElementNSPlus("csw:ElementSetName",{attributes:{typeNames:options.typeNames},value:options.value});return node;},"Constraint":function(options){var node=this.createElementNSPlus("csw:Constraint",{attributes:{version:options.version}});if(options.Filter){var format=new OpenLayers.Format.Filter({version:options.version});node.appendChild(format.write(options.Filter));}else if(options.CqlText){var child=this.createElementNSPlus("CqlText",{value:options.CqlText.value});node.appendChild(child);}
-return node;}}},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{initialize:function(){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
+return node;}},"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
 if(!width){width=2;}
 this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
 return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{defaultStyle:null,extractStyles:true,initialize:function(options){options=options||{};if(options.extractStyles!==false){options.defaultStyle={'externalGraphic':OpenLayers.Util.getImagesLocation()+"marker.png",'graphicWidth':21,'graphicHeight':25,'graphicXOffset':-10.5,'graphicYOffset':-12.5};}
@@ -2625,7 +2648,7 @@
 this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
 if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
 OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',layerOptions:null,persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
-OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:{};},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
+OpenLayers.Handler.Drag.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:{};},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.Drag.prototype.activate.apply(this,arguments)){var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
 if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
 this.layer=null;this.feature=null;deactivated=true;}
@@ -2659,7 +2682,7 @@
 var inches=OpenLayers.INCHES_PER_UNIT;scale=(this.map.getGeodesicPixelSize().w||0.000001)*inches["km"]*OpenLayers.DOTS_PER_INCH;}else{scale=this.map.getScale();}
 if(!scale){return;}
 if(scale>=9500&&scale<=950000){scale=Math.round(scale/1000)+"K";}else if(scale>=950000){scale=Math.round(scale/1000000)+"M";}else{scale=Math.round(scale);}
-this.element.innerHTML=OpenLayers.i18n("scale",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,useHttpTile:false,singleTile:false,useOverlay:false,useAsyncOverlay:true,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},OVERLAY_PARAMS:{operation:'GETDYNAMICMAPOVERLAYIMAGE',format:'PNG',locale:'en',clip:'1',version:'2.0.0'},FOLDER_PARAMS:{tileColumnsPerFolder:30,tileRowsPerFolder:30,format:'png',querystring:null},defaultSize:new OpenLayers.Size(300,300),tileOriginCorner:"tl",initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
+this.element.innerHTML=OpenLayers.i18n("Scale = 1 : ${scaleDenom}",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,useHttpTile:false,singleTile:false,useOverlay:false,useAsyncOverlay:true,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},OVERLAY_PARAMS:{operation:'GETDYNAMICMAPOVERLAYIMAGE',format:'PNG',locale:'en',clip:'1',version:'2.0.0'},FOLDER_PARAMS:{tileColumnsPerFolder:30,tileRowsPerFolder:30,format:'png',querystring:null},defaultSize:new OpenLayers.Size(300,300),tileOriginCorner:"tl",initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
 if(options&&options.useOverlay!=null){this.useOverlay=options.useOverlay;}
 if(this.singleTile){if(this.useOverlay){OpenLayers.Util.applyDefaults(this.params,this.OVERLAY_PARAMS);if(!this.useAsyncOverlay){this.params.version="1.0.0";}}else{OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}}else{if(this.useHttpTile){OpenLayers.Util.applyDefaults(this.params,this.FOLDER_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);}
 this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.getOptions());}
@@ -2696,19 +2719,7 @@
 node.appendChild(this.write_wmc_LayerExtension(context));},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Format.WMTSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1_1_0,{version:"1.0.0",namespaces:{ows:"http://www.opengis.net/ows/1.1",wmts:"http://www.opengis.net/wmts/1.0",xlink:"http://www.w3.org/1999/xlink"},yx:null,defaultPrefix:"wmts",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;var yx=OpenLayers.Util.extend({},OpenLayers.Format.WMTSCapabilities.prototype.yx);this.yx=OpenLayers.Util.extend(yx,this.yx);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 var capabilities={};this.readNode(data,capabilities);capabilities.version=this.version;return capabilities;},readers:{"wmts":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};obj.contents.layers=[];obj.contents.tileMatrixSets={};this.readChildNodes(node,obj.contents);},"Layer":function(node,obj){var layer={styles:[],formats:[],tileMatrixSetLinks:[]};layer.layers=[];this.readChildNodes(node,layer);obj.layers.push(layer);},"Style":function(node,obj){var style={};style.isDefault=(node.getAttribute("isDefault")==="true");this.readChildNodes(node,style);obj.styles.push(style);},"Format":function(node,obj){obj.formats.push(this.getChildValue(node));},"TileMatrixSetLink":function(node,obj){var tileMatrixSetLink={};this.readChildNodes(node,tileMatrixSetLink);obj.tileMatrixSetLinks.push(tileMatrixSetLink);},"TileMatrixSet":function(node,obj){if(obj.layers){var tileMatrixSet={matrixIds:[]};this.readChildNodes(node,tileMatr
 ixSet);obj.tileMatrixSets[tileMatrixSet.identifier]=tileMatrixSet;}else{obj.tileMatrixSet=this.getChildValue(node);}},"TileMatrix":function(node,obj){var tileMatrix={supportedCRS:obj.supportedCRS};this.readChildNodes(node,tileMatrix);obj.matrixIds.push(tileMatrix);},"ScaleDenominator":function(node,obj){obj.scaleDenominator=parseFloat(this.getChildValue(node));},"TopLeftCorner":function(node,obj){var topLeftCorner=this.getChildValue(node);var coords=topLeftCorner.split(" ");var yx;if(obj.supportedCRS){var crs=obj.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2");yx=!!this.yx[crs];}
-if(yx){obj.topLeftCorner=new OpenLayers.LonLat(coords[1],coords[0]);}else{obj.topLeftCorner=new OpenLayers.LonLat(coords[0],coords[1]);}},"TileWidth":function(node,obj){obj.tileWidth=parseInt(this.getChildValue(node));},"TileHeight":function(node,obj){obj.tileHeight=parseInt(this.getChildValue(node));},"MatrixWidth":function(node,obj){obj.matrixWidth=parseInt(this.getChildValue(node));},"MatrixHeight":function(node,obj){obj.matrixHeight=parseInt(this.getChildValue(node));},"ResourceURL":function(node,obj){obj.resourceUrl=obj.resourceUrl||{};obj.resourceUrl[node.getAttribute("resourceType")]={format:node.getAttribute("format"),template:node.getAttribute("template")};},"WSDL":function(node,obj){obj.wsdl={};obj.wsdl.href=node.getAttribute("xlink:href");},"ServiceMetadataURL":function(node,obj){obj.serviceMetadataUrl={};obj.serviceMetadataUrl.href=node.getAttribute("xlink:href");}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.W
 MTSCapabilities.v1_0_0"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,formatSuffixMap:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png","png":"png","image/jpeg":"jpg","image/jpg":"jpg","jpeg":"jpg","jpg":"jpg"},matrix:null,initialize:function(config){var required={url:true,layer:true,style:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
-config.params=OpenLayers.Util.upperCaseObject(config.params);var args=[config.name,config.url,config.params,config];OpenLayers.Layer.Grid.prototype.initialize.apply(this,args);if(!this.formatSuffix){this.formatSuffix=this.formatSuffixMap[this.format]||this.format.split("/").pop();}
-if(this.matrixIds){var len=this.matrixIds.length;if(len&&typeof this.matrixIds[0]==="string"){var ids=this.matrixIds;this.matrixIds=new Array(len);for(var i=0;i<len;++i){this.matrixIds[i]={identifier:ids[i]};}}}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.updateMatrixProperties();},updateMatrixProperties:function(){this.matrix=this.getMatrix();if(this.matrix){if(this.matrix.topLeftCorner){this.tileOrigin=this.matrix.topLeftCorner;}
-if(this.matrix.tileWidth&&this.matrix.tileHeight){this.tileSize=new OpenLayers.Size(this.matrix.tileWidth,this.matrix.tileHeight);}
-if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.top);}
-if(!this.tileFullExtent){this.tileFullExtent=this.maxExtent;}}},moveTo:function(bounds,zoomChanged,dragging){if(zoomChanged||!this.matrix){this.updateMatrixProperties();}
-return OpenLayers.Layer.Grid.prototype.moveTo.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMTS(this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getMatrix:function(){var matrix;if(!this.matrixIds||this.matrixIds.length===0){matrix={identifier:this.map.getZoom()+this.zoomOffset};}else{if("scaleDenominator"in this.matrixIds[0]){var denom=OpenLayers.METERS_PER_INCH*OpenLayers.INCHES_PER_UNIT[this.units]*this.map.getResolution()/0.28E-3;var diff=Number.POSITIVE_INFINITY;var delta;for(var i=0,ii=this.matrixIds.length;i<ii;++i){delta=Math.abs(1-(this.matrixIds[i].scaleDenominator/denom));if(delta<diff){diff=delta;matrix=this.matrixIds[i];}}}else{matrix=this.matrixIds[this.map.getZoom()+this.zoomOffset];}}
-return matrix;},getTileInfo:function(loc){var res=this.map.getResolution();var fx=(loc.lon-this.tileOrigin.lon)/(res*this.tileSize.w);var fy=(this.tileOrigin.lat-loc.lat)/(res*this.tileSize.h);var col=Math.floor(fx);var row=Math.floor(fy);return{col:col,row:row,i:Math.floor((fx-col)*this.tileSize.w),j:Math.floor((fy-row)*this.tileSize.h)};},getURL:function(bounds){bounds=this.adjustBounds(bounds);var url="";if(!this.tileFullExtent||this.tileFullExtent.intersectsBounds(bounds)){var center=bounds.getCenterLonLat();var info=this.getTileInfo(center);var matrixId=this.matrix.identifier;if(this.requestEncoding.toUpperCase()==="REST"){var path=this.version+"/"+this.layer+"/"+this.style+"/";if(this.dimensions){for(var i=0;i<this.dimensions.length;i++){if(this.params[this.dimensions[i]]){path=path+this.params[this.dimensions[i]]+"/";}}}
-path=path+this.matrixSet+"/"+this.matrix.identifier+"/"+info.row+"/"+info.col+"."+this.formatSuffix;if(this.url instanceof Array){url=this.selectUrl(path,this.url);}else{url=this.url;}
-if(!url.match(/\/$/)){url=url+"/";}
-url=url+path;}else if(this.requestEncoding.toUpperCase()==="KVP"){var params={SERVICE:"WMTS",REQUEST:"GetTile",VERSION:this.version,LAYER:this.layer,STYLE:this.style,TILEMATRIXSET:this.matrixSet,TILEMATRIX:this.matrix.identifier,TILEROW:info.row,TILECOL:info.col,FORMAT:this.format};url=OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,[params]);}}
-return url;},mergeNewParams:function(newParams){if(this.requestEncoding.toUpperCase()==="KVP"){return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(newParams)]);}},CLASS_NAME:"OpenLayers.Layer.WMTS"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{contentDisplayClass:"olFramedCloudPopupContent",autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(1276,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,18),an
 chor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-632)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-688)}]},"tr":{'offset':new OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,19),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-631)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-687)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':
 [{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers
 .Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(1200,660),initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className=this.contentDisplayClass;},destroy:function(){OpenLayers.Popup.Framed.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.AgsGeoprocessor=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,asynJobCompleteCallback:null,initialize:function(url,layer,callbacks,options){OpenL
 ayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.events.addEventType("asynjobcomplete");this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;var addAndShowResults=this._bindFunction(function(evt){this.cleanupResults();this.addResults(evt.results);this.showResults();},this);var _asynTaskCallbacks=[];_asynTaskCallbacks=_asynTaskCallbacks.concat(this.taskCallbacks);_asynTaskCallbacks=_asynTaskCallbacks.concat([addAndShowResults]);this.asynJobCompleteCallback=this._createCallbacks(this,_asynTaskCallbacks,{});this.events.on({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});this.execute=this._bindFunction(this.execute,this);},destroy:function(){this.events.un({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});OpenLayers.Control.AgsControl.prototype.destroy.apply(this,[]);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaul
 ts(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});this._resultsParser={'parser':this.geoprocessingResultsParser,'context':this};var agsFeatureSet=this.adapter.encodeAgsFeatureSet(olFeatures,this.layer.map['projection'],{});var agsGeoprocessor=new esri.tasks.Geoprocessor(this.url);var geoprocessingParams=this.geoprocessingParamsEnocoder(agsFeatureSet,_taskParameters);if(this.asynchronous==false){var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});agsGeoprocessor.execute(geoprocessingParams,_onExecuteComplete);}else{var _onExecuteAsynComplete=this._createCallbacks(this,[this.onExecuteAsynComplete],{agsGeoprocessor:agsGeoprocessor,});agsGeoprocessor.submitJob(geoprocessingParams,_onExecuteAsynComplete,null);}},geoprocessingParamsEnocoder:fu
 nction(agsFeatureSet,tasksParameters){var geoprocessingParams=tasksParameters;return geoprocessingParams;},geoprocessingResultsParser:function(agsResults,options){var olResults={};return olResults;},CLASS_NAME:"OpenLayers.Control.AgsGeoprocessor"});OpenLayers.Control.ModifyFeatureWithLock=OpenLayers.Class(OpenLayers.Control.ModifyFeature,{deleteFeatureCodes:null,initialize:function(layer,options){OpenLayers.Control.ModifyFeature.prototype.initialize.apply(this,[layer,options]);if(options){if(!options.deleteFeatureCodes){this.deleteFeatureCodes=[81];}else{this.deleteFeatureCodes=options.deleteFeatureCodes;}}
+if(yx){obj.topLeftCorner=new OpenLayers.LonLat(coords[1],coords[0]);}else{obj.topLeftCorner=new OpenLayers.LonLat(coords[0],coords[1]);}},"TileWidth":function(node,obj){obj.tileWidth=parseInt(this.getChildValue(node));},"TileHeight":function(node,obj){obj.tileHeight=parseInt(this.getChildValue(node));},"MatrixWidth":function(node,obj){obj.matrixWidth=parseInt(this.getChildValue(node));},"MatrixHeight":function(node,obj){obj.matrixHeight=parseInt(this.getChildValue(node));},"ResourceURL":function(node,obj){obj.resourceUrl=obj.resourceUrl||{};obj.resourceUrl[node.getAttribute("resourceType")]={format:node.getAttribute("format"),template:node.getAttribute("template")};},"WSDL":function(node,obj){obj.wsdl={};obj.wsdl.href=node.getAttribute("xlink:href");},"ServiceMetadataURL":function(node,obj){obj.serviceMetadataUrl={};obj.serviceMetadataUrl.href=node.getAttribute("xlink:href");}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.W
 MTSCapabilities.v1_0_0"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{contentDisplayClass:"olFramedCloudPopupContent",autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(1276,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,18),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-632)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-688)}]},"tr":{'offset':n
 ew OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,19),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-631)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-687)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLaye
 rs.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:
 new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(1200,660),initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className=this.contentDisplayClass;},destroy:function(){OpenLayers.Popup.Framed.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.AgsGeoprocessor=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,asynJobCompleteCallback:null,initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.events.addEventType("asynjobcomplete");this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;var addAndShowResults=this._bind
 Function(function(evt){this.cleanupResults();this.addResults(evt.results);this.showResults();},this);var _asynTaskCallbacks=[];_asynTaskCallbacks=_asynTaskCallbacks.concat(this.taskCallbacks);_asynTaskCallbacks=_asynTaskCallbacks.concat([addAndShowResults]);this.asynJobCompleteCallback=this._createCallbacks(this,_asynTaskCallbacks,{});this.events.on({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});this.execute=this._bindFunction(this.execute,this);},destroy:function(){this.events.un({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});OpenLayers.Control.AgsControl.prototype.destroy.apply(this,[]);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_t
 askCallbacks,{});this._resultsParser={'parser':this.geoprocessingResultsParser,'context':this};var agsFeatureSet=this.adapter.encodeAgsFeatureSet(olFeatures,this.layer.map['projection'],{});var agsGeoprocessor=new esri.tasks.Geoprocessor(this.url);var geoprocessingParams=this.geoprocessingParamsEnocoder(agsFeatureSet,_taskParameters);if(this.asynchronous==false){var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});agsGeoprocessor.execute(geoprocessingParams,_onExecuteComplete);}else{var _onExecuteAsynComplete=this._createCallbacks(this,[this.onExecuteAsynComplete],{agsGeoprocessor:agsGeoprocessor,});agsGeoprocessor.submitJob(geoprocessingParams,_onExecuteAsynComplete,null);}},geoprocessingParamsEnocoder:function(agsFeatureSet,tasksParameters){var geoprocessingParams=tasksParameters;return geoprocessingParams;},geoprocessingResultsParser:function(agsResults,options){var olResults={};return olResults;},CLASS_NAME:"OpenLayer
 this.layer.events.on({'transactionsucceeded':function(){this.deactivate();this.activate();},'transactionfailed':function(){this.deactivate();this.activate();},scope:this});},selectFeature:function(feature){this.feature=feature;if(feature.lockId&&feature.lockId!=""){if(this.mode==OpenLayers.Control.ModifyFeature.DELETE){OpenLayers.Console.log("...feature is locked...control in DELETE mode...it can only be deleted...");}else{this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);OpenLayers.Console.log("...feature is locked...so it can be modified...");}}else{OpenLayers.Console.log("...feature is not locked...so it can not be modified/deleted...");}},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
 if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){if(feature.lockId&&feature.lockId!=""){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);OpenLayers.Console.log("...feature is locked...drag start...");this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}else{OpenLayers.Console.log("...feature is not locked...drag not start...");}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.mode==OpenLayers.Control.ModifyFeatureWithLock.DELETE){if(this.feature&&OpenLayers.Util.indexOf(this.deleteFeatureCodes,code)!=-1){if(this.feature.lockId&&this.feature.lockId!=""){this.feature.state=OpenLayers.State.DELETE;this.layer.eraseFeatures([this.feature]);if(OpenLayers.Util.indexOf(this.layer.selectedFeatures,this.feature
 )!=-1){OpenLayers.Util.removeItem(this.layer.selectedFeatures,this.feature);}
 console.log("...delete feature at client side...");this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}else{console.log("...can not delete feature...feature must be locked first...");}}}else{if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}}},CLASS_NAME:"OpenLayers.Control.ModifyFeatureWithLock"});OpenLayers.Control.ModifyFeatureWithLock.RESHAPE=1;OpenLayers.Control.ModifyFeatureWithLock.RESIZE=2;OpenLayers.Control.ModifyFeatureWithLock.ROTATE=4;OpenLayers.Control.ModifyFeat
 ureWithLock.DRAG=8;OpenLayers.Control.ModifyFeatureWithLock.DELETE=16;OpenLayers.Tile.Image.IFrame={useIFrame:null,clear:function(){if(this.useIFrame){if(this.imgDiv){var iFrame=this.imgDiv.firstChild;OpenLayers.Event.stopObservingElement(iFrame);this.imgDiv.removeChild(iFrame);delete iFrame;}}else{OpenLayers.Tile.Image.prototype.clear.apply(this,arguments);}},renderTile:function(){if(OpenLayers.Tile.Image.prototype.renderTile.apply(this,arguments)&&this.useIFrame){var form=this.createRequestForm();this.imgDiv.appendChild(form);form.submit();this.imgDiv.removeChild(form);delete form;}
@@ -2718,7 +2729,7 @@
 this.imgDiv.map=this.layer.map;}
 this.imgDiv.viewRequestID=this.layer.map.viewRequestID;}else{OpenLayers.Tile.Image.prototype.initImgDiv.apply(this,arguments);}},createIFrame:function(){var id=this.id+'_iFrame';var iframe;if(OpenLayers.BROWSER_NAME=="msie"){iframe=document.createElement('<iframe name="'+id+'">');iframe.style.backgroundColor='#FFFFFF';iframe.style.filter='chroma(color=#FFFFFF)';}
 else{iframe=document.createElement('iframe');iframe.style.backgroundColor='transparent';iframe.name=id;}
-iframe.id=id;iframe.scrolling='no';iframe.marginWidth='0px';iframe.marginHeight='0px';iframe.frameBorder='0';OpenLayers.Util.modifyDOMElement(iframe,id,new OpenLayers.Pixel(0,0),this.layer.getImageSize(),"absolute");var onload=function(){this.show();if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};OpenLayers.Event.observe(iframe,'load',OpenLayers.Function.bind(onload,this));return iframe;},createRequestForm:function(){var form=document.createElement('form');form.method='POST';var cacheId=this.layer.params["_OLSALT"];cacheId=(cacheId?cacheId+"_":"")+this.bounds.toBBOX();form.action=OpenLayers.Util.urlAppend(this.layer.url,cacheId);this.imgDiv.insertBefore(this.createIFrame(),this.imgDiv.firstChild);form.target=this.id+'_iFrame';var imageSize=this.layer.getImageSize();var params=OpenLayers.Util.getParameters(this.url);for(var par in params){var field=document.createElement('input');field.type='hidden';field.name=par;field.value=params[par];form.ap
 pendChild(field);}
+iframe.id=id;iframe.scrolling='no';iframe.marginWidth='0px';iframe.marginHeight='0px';iframe.frameBorder='0';OpenLayers.Util.modifyDOMElement(iframe,id,new OpenLayers.Pixel(0,0),this.layer.getImageSize(),"absolute");var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};OpenLayers.Event.observe(iframe,'load',OpenLayers.Function.bind(onload,this));return iframe;},createRequestForm:function(){var form=document.createElement('form');form.method='POST';var cacheId=this.layer.params["_OLSALT"];cacheId=(cacheId?cacheId+"_":"")+this.bounds.toBBOX();form.action=OpenLayers.Util.urlAppend(this.layer.url,cacheId);this.imgDiv.insertBefore(this.createIFrame(),this.imgDiv.firstChild);form.target=this.id+'_iFrame';var imageSize=this.layer.getImageSize();var params=OpenLayers.Util.getParameters(this.url);for(var par in params){var field=document.createElement('input');field.type='hidden';field.name=par;field.value=params[par];form.appendChild(fi
 eld);}
 return form;}};OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:false,interval:0,timer:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.layer.visibility===true){this.start();}
 this.layer.events.on({"visibilitychanged":this.reset,scope:this});}
 return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.stop();}
@@ -2730,7 +2741,20 @@
 return true;},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.pinching=false;activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.pinching=false;this.start=null;this.last=null;deactivated=true;}
 return deactivated;},getDistance:function(touches){var t0=touches[0];var t1=touches[1];return Math.sqrt(Math.pow(t0.clientX-t1.clientX,2)+
-Math.pow(t0.clientY-t1.clientY,2));},getPinchData:function(evt){var distance=this.getDistance(evt.touches);var scale=distance/this.start.distance;return{distance:distance,delta:this.last.distance-distance,scale:scale};},CLASS_NAME:"OpenLayers.Handler.Pinch"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,containerOrigin:null,pinchOrigin:null,currentCenter:null,autoActivate:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new Op
 enLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions);},activate:function(){var activated=OpenLayers.Control.prototype.activate.apply(this,arguments);if(activated){this.map.events.on({moveend:this.updateContainerOrigin,scope:this});this.updateContainerOrigin();}
+Math.pow(t0.clientY-t1.clientY,2));},getPinchData:function(evt){var distance=this.getDistance(evt.touches);var scale=distance/this.start.distance;return{distance:distance,delta:this.last.distance-distance,scale:scale};},CLASS_NAME:"OpenLayers.Handler.Pinch"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);if(this.defaultControl===null){this.defaultControl=this.controls[0];}
+return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,formatSuffixMap:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png","png":"png","image/jpeg":"jpg","image/jpg":"jpg","jpeg":"jpg","jpg":"jpg"},matrix:null,initialize:function(config){var required={url:true,layer:true,style:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
+config.params=OpenLayers.Util.upperCaseObject(config.params);var args=[config.name,config.url,config.params,config];OpenLayers.Layer.Grid.prototype.initialize.apply(this,args);if(!this.formatSuffix){this.formatSuffix=this.formatSuffixMap[this.format]||this.format.split("/").pop();}
+if(this.matrixIds){var len=this.matrixIds.length;if(len&&typeof this.matrixIds[0]==="string"){var ids=this.matrixIds;this.matrixIds=new Array(len);for(var i=0;i<len;++i){this.matrixIds[i]={identifier:ids[i]};}}}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.updateMatrixProperties();},updateMatrixProperties:function(){this.matrix=this.getMatrix();if(this.matrix){if(this.matrix.topLeftCorner){this.tileOrigin=this.matrix.topLeftCorner;}
+if(this.matrix.tileWidth&&this.matrix.tileHeight){this.tileSize=new OpenLayers.Size(this.matrix.tileWidth,this.matrix.tileHeight);}
+if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.top);}
+if(!this.tileFullExtent){this.tileFullExtent=this.maxExtent;}}},moveTo:function(bounds,zoomChanged,dragging){if(zoomChanged||!this.matrix){this.updateMatrixProperties();}
+return OpenLayers.Layer.Grid.prototype.moveTo.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMTS(this.options);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getMatrix:function(){var matrix;if(!this.matrixIds||this.matrixIds.length===0){matrix={identifier:this.map.getZoom()+this.zoomOffset};}else{if("scaleDenominator"in this.matrixIds[0]){var denom=OpenLayers.METERS_PER_INCH*OpenLayers.INCHES_PER_UNIT[this.units]*this.map.getResolution()/0.28E-3;var diff=Number.POSITIVE_INFINITY;var delta;for(var i=0,ii=this.matrixIds.length;i<ii;++i){delta=Math.abs(1-(this.matrixIds[i].scaleDenominator/denom));if(delta<diff){diff=delta;matrix=this.matrixIds[i];}}}else{matrix=this.matrixIds[this.map.getZoom()+this.zoomOffset];}}
+return matrix;},getTileInfo:function(loc){var res=this.map.getResolution();var fx=(loc.lon-this.tileOrigin.lon)/(res*this.tileSize.w);var fy=(this.tileOrigin.lat-loc.lat)/(res*this.tileSize.h);var col=Math.floor(fx);var row=Math.floor(fy);return{col:col,row:row,i:Math.floor((fx-col)*this.tileSize.w),j:Math.floor((fy-row)*this.tileSize.h)};},getURL:function(bounds){bounds=this.adjustBounds(bounds);var url="";if(!this.tileFullExtent||this.tileFullExtent.intersectsBounds(bounds)){var center=bounds.getCenterLonLat();var info=this.getTileInfo(center);var matrixId=this.matrix.identifier;if(this.requestEncoding.toUpperCase()==="REST"){var path=this.version+"/"+this.layer+"/"+this.style+"/";if(this.dimensions){for(var i=0;i<this.dimensions.length;i++){if(this.params[this.dimensions[i]]){path=path+this.params[this.dimensions[i]]+"/";}}}
+path=path+this.matrixSet+"/"+this.matrix.identifier+"/"+info.row+"/"+info.col+"."+this.formatSuffix;if(OpenLayers.Util.isArray(this.url)){url=this.selectUrl(path,this.url);}else{url=this.url;}
+if(!url.match(/\/$/)){url=url+"/";}
+url=url+path;}else if(this.requestEncoding.toUpperCase()==="KVP"){var params={SERVICE:"WMTS",REQUEST:"GetTile",VERSION:this.version,LAYER:this.layer,STYLE:this.style,TILEMATRIXSET:this.matrixSet,TILEMATRIX:this.matrix.identifier,TILEROW:info.row,TILECOL:info.col,FORMAT:this.format};url=OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,[params]);}}
+return url;},mergeNewParams:function(newParams){if(this.requestEncoding.toUpperCase()==="KVP"){return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(newParams)]);}},CLASS_NAME:"OpenLayers.Layer.WMTS"});OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,containerOrigin:null,pinchOrigin:null,currentCenter:null,autoActivate:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions);},activate:function(){var activated=OpenLayers.Control.prototype.activate.apply(this,arguments);if(activated){this.map.events.on({moveend:this.updateContainerOrigin,scope:this});this.updateContainerOrigin();}
 return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.apply(this,arguments);if(this.map&&this.map.events){this.map.events.un({moveend:this.updateContainerOrigin,scope:this});}
 return deactivated;},updateContainerOrigin:function(){var container=this.map.layerContainerDiv;this.containerOrigin={x:parseInt(container.style.left,10),y:parseInt(container.style.top,10)};},pinchStart:function(evt,pinchData){this.pinchOrigin=evt.xy;this.currentCenter=evt.xy;},pinchMove:function(evt,pinchData){var scale=pinchData.scale;var containerOrigin=this.containerOrigin;var pinchOrigin=this.pinchOrigin;var current=evt.xy;var dx=Math.round((current.x-pinchOrigin.x)+(scale-1)*(containerOrigin.x-pinchOrigin.x));var dy=Math.round((current.y-pinchOrigin.y)+(scale-1)*(containerOrigin.y-pinchOrigin.y));this.applyTransform("translate("+dx+"px, "+dy+"px) scale("+scale+")");this.currentCenter=current;},applyTransform:function(transform){var style=this.map.layerContainerDiv.style;style['-webkit-transform']=transform;style['-moz-transform']=transform;},pinchDone:function(evt,start,last){this.applyTransform("");var zoom=this.map.getZoomForResolution(this.map.getResolution()/last.sc
 ale,true);if(zoom!==this.map.getZoom()||!this.currentCenter.equals(this.pinchOrigin)){var resolution=this.map.getResolutionForZoom(zoom);var location=this.map.getLonLatFromPixel(this.pinchOrigin);var zoomPixel=this.currentCenter;var size=this.map.getSize();location.lon+=resolution*((size.w/2)-zoomPixel.x);location.lat-=resolution*((size.h/2)-zoomPixel.y);this.map.setCenter(location,zoom);}},CLASS_NAME:"OpenLayers.Control.PinchZoom"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Control.AgsWFSTLockControl=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,layer:null,lockStrategy:null,lock:null,lockOptions:null,unlock:null,unlockOptions:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);if(layer instanceof OpenLayers.Layer.Vector){for(var i=0;i<layer.strategies.length;i++){if(laye
 r.strategies[i]instanceof OpenLayers.Strategy.Lock){this.layer=layer;this.lockStrategy=layer.strategies[i];}}}else{OpenLayers.Console.error("...lock control error...");}
 if(this.layer&&this.lockStrategy){var lockOptions={trigger:OpenLayers.Function.bind(this.lockTrigger,this)};OpenLayers.Util.extend(lockOptions,this.lockOptions);this.lock=new OpenLayers.Control.Button(lockOptions);var unlockOptions={trigger:OpenLayers.Function.bind(this.unlockTrigger,this)};OpenLayers.Util.extend(unlockOptions,this.unlockOptions);this.unlock=new OpenLayers.Control.Button(unlockOptions);var toggleButtonFunc=OpenLayers.Util.AgsUtil.bindFunction(function(evt){var feature=evt.feature;if(this.lockStrategy.isFeatureLocked(feature)){this.lock.deactivate();this.unlock.activate();}else{this.lock.activate();this.unlock.deactivate();}},this);var disableButtonFunc=OpenLayers.Util.AgsUtil.bindFunction(function(evt){this.lock.deactivate();this.unlock.deactivate();},this);this.layer.events.on({"featureselected":toggleButtonFunc,"featureunselected":disableButtonFunc,"afterfeatureslocked":disableButtonFunc,"afterfeaturesunlocked":disableButtonFunc});}else{OpenLayers.Console.
 error("...lock control error...");}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.lock.destroy();this.unlock.destroy();this.deactivate();},setMap:function(map){this.map=map;},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.lock.draw();this.unlock.draw();},activate:function(){return OpenLayers.Control.prototype.activate.apply(this);},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this);},lockTrigger:function(){if(this.layer.selectedFeatures.length>0){this.lockStrategy.lockFeatures(this.layer.selectedFeatures);}},unlockTrigger:function(){this.lockStrategy.unlockAllFeatures();},CLASS_NAME:"OpenLayers.Control.AgsWFSTLockControl"});OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.p
 rototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();this.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
@@ -2751,7 +2775,7 @@
 if(layerDefStrList.length>0){newParams['LAYERDEFS']=layerDefStrList.join("");}}
 var requestString=this.getFullRequestString(newParams);return requestString;},setLayerFilter:function(id,queryDef){if(!this.layerDefs){this.layerDefs={};}
 if(queryDef){this.layerDefs[id]=queryDef;}else{delete this.layerDefs[id];}},clearLayerFilter:function(id){if(id){delete this.layerDefs[id];}else{delete this.layerDefs;}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},CLASS_NAME:"OpenLayers.Layer.ArcGIS93Rest"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(OpenLayers.Util.isArray(url)){url=this.selectUrl(paramsString,url);}
 var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
 return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.getOptions());}
@@ -2769,7 +2793,7 @@
 this.setModifiers(this.handlers.box.dragHandler.evt);this.request(bounds);},selectHover:function(evt){var bounds=this.pixelToBounds(evt.xy);this.request(bounds,{single:true,hover:true});},cancelHover:function(){if(this.hoverResponse){this.protocol.abort(this.hoverResponse);this.hoverResponse=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");}},request:function(bounds,options){options=options||{};var filter=new OpenLayers.Filter.Spatial({type:this.filterType,value:bounds});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");var response=this.protocol.read({maxFeatures:options.single==true?this.maxFeatures:undefined,filter:filter,callback:function(result){if(result.success()){if(result.features.length){if(options.single==true){this.selectBestFeature(result.features,bounds.getCenterLonLat(),options);}else{this.select(result.features);}}else if(options.hover){this.hoverSelect();}else{this.events.triggerEvent("clickout");if(this.clickout){this.
 unselectAll();}}}
 OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");},scope:this});if(options.hover==true){this.hoverResponse=response;}},selectBestFeature:function(features,clickPosition,options){options=options||{};if(features.length){var point=new OpenLayers.Geometry.Point(clickPosition.lon,clickPosition.lat);var feature,resultFeature,dist;var minDist=Number.MAX_VALUE;for(var i=0;i<features.length;++i){feature=features[i];if(feature.geometry){dist=point.distanceTo(feature.geometry,{edge:false});if(dist<minDist){minDist=dist;resultFeature=feature;if(minDist==0){break;}}}}
 if(options.hover==true){this.hoverSelect(resultFeature);}else{this.select(resultFeature||features);}}},setModifiers:function(evt){this.modifiers={multiple:this.multiple||(this.multipleKey&&evt[this.multipleKey]),toggle:this.toggle||(this.toggleKey&&evt[this.toggleKey])};},select:function(features){if(!this.modifiers.multiple&&!this.modifiers.toggle){this.unselectAll();}
-if(!(features instanceof Array)){features=[features];}
+if(!(OpenLayers.Util.isArray(features))){features=[features];}
 var cont=this.events.triggerEvent("beforefeaturesselected",{features:features});if(cont!==false){var selectedFeatures=[];var feature;for(var i=0,len=features.length;i<len;++i){feature=features[i];if(this.features[feature.fid||feature.id]){if(this.modifiers.toggle){this.unselect(this.features[feature.fid||feature.id]);}}else{cont=this.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){this.features[feature.fid||feature.id]=feature;selectedFeatures.push(feature);this.events.triggerEvent("featureselected",{feature:feature});}}}
 this.events.triggerEvent("featuresselected",{features:selectedFeatures});}},hoverSelect:function(feature){var fid=feature?feature.fid||feature.id:null;var hfid=this.hoverFeature?this.hoverFeature.fid||this.hoverFeature.id:null;if(hfid&&hfid!=fid){this.events.triggerEvent("outfeature",{feature:this.hoverFeature});this.hoverFeature=null;}
 if(fid&&fid!=hfid){this.events.triggerEvent("hoverfeature",{feature:feature});this.hoverFeature=feature;}},unselect:function(feature){delete this.features[feature.fid||feature.id];this.events.triggerEvent("featureunselected",{feature:feature});},unselectAll:function(){for(var fid in this.features){this.unselect(this.features[fid]);}},setMap:function(map){for(var i in this.handlers){this.handlers[i].setMap(map);}
@@ -2826,7 +2850,7 @@
 return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
 var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
 var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
-return features;},write:function(features){var georss;if(features instanceof Array){georss=this.createElementNS(this.rssns,"rss");for(var i=0,len=features.length;i<len;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
+return features;},write:function(features){var georss;if(OpenLayers.Util.isArray(features)){georss=this.createElementNS(this.rssns,"rss");for(var i=0,len=features.length;i<len;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
 return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
 for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
 var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
@@ -2838,7 +2862,9 @@
 return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
 var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
 path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
-return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,clickHandlerOptions:null,documentDrag:false,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Format.WPSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.WPSCapabilities"});OpenLayers.Format.WPSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",wps:"http://www.opengis.net/wps/1.0.0",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+if(data&&data.nodeType==9){data=data.documentElement;}
+var capabilities={};this.readNode(data,capabilities);return capabilities;},readers:{"wps":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"ProcessOfferings":function(node,obj){obj.processOfferings={};this.readChildNodes(node,obj.processOfferings);},"Process":function(node,processOfferings){var processVersion=this.getAttributeNS(node,this.namespaces.wps,"processVersion");var process={processVersion:processVersion};this.readChildNodes(node,process);processOfferings[process.identifier]=process;},"Languages":function(node,obj){obj.languages=[];this.readChildNodes(node,obj.languages);},"Default":function(node,languages){var language={isDefault:true};this.readChildNodes(node,language);languages.push(language);},"Supported":function(node,languages){var language={};this.readChildNodes(node,language);languages.push(language);}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.WPSCapabilities.v1_0_0"});OpenLayers.Contr
 this.dragPan=null;if(this.pinchZoom){this.pinchZoom.destroy();delete this.pinchZoom;}
 OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragPan.activate();this.handlers.click.activate();this.pinchZoom.activate();return true;}
 return false;},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.dragPan.deactivate();this.handlers.click.deactivate();this.pinchZoom.deactivate();return true;}
@@ -2848,10 +2874,14 @@
 this.map.events.unregister("moveend",this,this.fixYahooEventPane);}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'Yahoo','layerLib':'Yahoo'});},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[moZoom]);zoom=18-zoom;}
 return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[olZoom]);zoom=18-zoom;}
 return zoom;},setMapObjectCenter:function(center,zoom){this.mapObject.drawZoomAndCenter(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon();},dragPanMapObject:function(dX,dY){this.mapObject.moveByXY({'x':-dX,'y':dY});},getMapObjectZoom:function(){return this.mapObject.getZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.convertXYLatLon(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.convertLatLonXY(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lon:moLonLat.Lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lat:moLonLat.Lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var yLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);yLatLong=new YGeoPoint(lonlat.lat,lon
 lat.lon);}else{yLatLong=new YGeoPoint(lat,lon);}
-return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Layer.Zoomify=OpenLayers.Class(OpenLayers.Layer.Grid,{url:null,size:null,isBaseLayer:true,standardTileSize:256,tileOriginCorner:"tl",numberOfTiers:0,tileCountUpToTier:new Array(),tierSizeInTiles:new Array(),tierImageSize:new Array(),initialize:function(name,url,size,options){this.initializeZoomify(size);var newArguments=[];newArguments.push(name,url,size,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},initializeZoomify:function(size){var imageSize=size.clone();var tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles)
 ;this.tierImageSize.push(imageSize);while(imageSize.w>this.standardTileSize||imageSize.h>this.standardTileSize){imageSize=new OpenLayers.Size(Math.floor(imageSize.w/2),Math.floor(imageSize.h/2));tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);}
+return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Layer.PointGrid=OpenLayers.Class(OpenLayers.Layer.Vector,{dx:null,dy:null,ratio:1.5,maxFeatures:250,rotation:0,origin:null,gridBounds:null,initialize:function(config){config=config||{};OpenLayers.Layer.Vector.prototype.initialize.apply(this,[config.name,config]);},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);map.events.register("moveend",this,this.onMoveEnd);},removeMap:function(map){map.events.unregister("moveend",this,this.onMoveEnd);OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},setRatio:function(ratio){this.ratio=ratio;this.updateGrid(true);},setMaxFeatures:function(maxFeatures){th
 is.maxFeatures=maxFeatures;this.updateGrid(true);},setSpacing:function(dx,dy){this.dx=dx;this.dy=dy||dx;this.updateGrid(true);},setOrigin:function(origin){this.origin=origin;this.updateGrid(true);},getOrigin:function(){if(!this.origin){this.origin=this.map.getExtent().getCenterLonLat();}
+return this.origin;},setRotation:function(rotation){this.rotation=rotation;this.updateGrid(true);},onMoveEnd:function(){this.updateGrid();},getViewBounds:function(){var bounds=this.map.getExtent();if(this.rotation){var origin=this.getOrigin();var rotationOrigin=new OpenLayers.Geometry.Point(origin.lon,origin.lat);var rect=bounds.toGeometry();rect.rotate(-this.rotation,rotationOrigin);bounds=rect.getBounds();}
+return bounds;},updateGrid:function(force){if(force||this.invalidBounds()){var viewBounds=this.getViewBounds();var origin=this.getOrigin();var rotationOrigin=new OpenLayers.Geometry.Point(origin.lon,origin.lat);var viewBoundsWidth=viewBounds.getWidth();var viewBoundsHeight=viewBounds.getHeight();var aspectRatio=viewBoundsWidth/viewBoundsHeight;var maxHeight=Math.sqrt(this.dx*this.dy*this.maxFeatures/aspectRatio);var maxWidth=maxHeight*aspectRatio;var gridWidth=Math.min(viewBoundsWidth*this.ratio,maxWidth);var gridHeight=Math.min(viewBoundsHeight*this.ratio,maxHeight);var center=viewBounds.getCenterLonLat();this.gridBounds=new OpenLayers.Bounds(center.lon-(gridWidth/2),center.lat-(gridHeight/2),center.lon+(gridWidth/2),center.lat+(gridHeight/2));var rows=Math.floor(gridHeight/this.dy);var cols=Math.floor(gridWidth/this.dx);var gridLeft=origin.lon+(this.dx*Math.ceil((this.gridBounds.left-origin.lon)/this.dx));var gridBottom=origin.lat+(this.dy*Math.ceil((this.gridBounds.bottom
 -origin.lat)/this.dy));var features=new Array(rows*cols);var x,y,point;for(var i=0;i<cols;++i){x=gridLeft+(i*this.dx);for(var j=0;j<rows;++j){y=gridBottom+(j*this.dy);point=new OpenLayers.Geometry.Point(x,y);if(this.rotation){point.rotate(this.rotation,rotationOrigin);}
+features[(i*rows)+j]=new OpenLayers.Feature.Vector(point);}}
+this.destroyFeatures(this.features,{silent:true});this.addFeatures(features,{silent:true});}},invalidBounds:function(){return!this.gridBounds||!this.gridBounds.containsBounds(this.getViewBounds());},CLASS_NAME:"OpenLayers.Layer.PointGrid"});OpenLayers.Layer.Zoomify=OpenLayers.Class(OpenLayers.Layer.Grid,{url:null,size:null,isBaseLayer:true,standardTileSize:256,tileOriginCorner:"tl",numberOfTiers:0,tileCountUpToTier:new Array(),tierSizeInTiles:new Array(),tierImageSize:new Array(),initialize:function(name,url,size,options){this.initializeZoomify(size);var newArguments=[];newArguments.push(name,url,size,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},initializeZoomify:function(size){var imageSize=size.clone();var tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);while(imageSize.w>this.standardTileSize||imageSiz
 this.tierSizeInTiles.reverse();this.tierImageSize.reverse();this.numberOfTiers=this.tierSizeInTiles.length;this.tileCountUpToTier[0]=0;for(var i=1;i<this.numberOfTiers;i++){this.tileCountUpToTier.push(this.tierSizeInTiles[i-1].w*this.tierSizeInTiles[i-1].h+
 this.tileCountUpToTier[i-1]);}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);this.tileCountUpToTier.length=0;this.tierSizeInTiles.length=0;this.tierImageSize.length=0;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Zoomify(this.name,this.url,this.size,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));var z=this.map.getZoom();var tileIndex=x+y*this.tierSizeInTiles[z].w+this.tileCountUpToTier[z];var path="TileGroup"+Math.floor((tileIndex)/256)+"/"+z+"-"+x+"-"+y+".jpg";var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));var z=this.map.getZoom();var tileIndex=x+y*this.tierSizeInTiles[z].w+this.tileCountUpToTier[z];var path="TileGroup"+Math.floor((tileIndex)/256)+"/"+z+"-"+x+"-"+y+".jpg";var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(path,url);}
 return url+path;},getImageSize:function(){if(arguments.length>0){var bounds=this.adjustBounds(arguments[0]);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));var z=this.map.getZoom();var w=this.standardTileSize;var h=this.standardTileSize;if(x==this.tierSizeInTiles[z].w-1){var w=this.tierImageSize[z].w%this.standardTileSize;};if(y==this.tierSizeInTiles[z].h-1){var h=this.tierImageSize[z].h%this.standardTileSize;};return(new OpenLayers.Size(w,h));}else{return this.tileSize;}},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.top);},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-origin.lon;var tilecol=Math.floor(offsetlon/tilelo
 n)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=origin.lon+tilecol*tilelon;var offsetlat=origin.lat-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=origin.lat-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.Zoomify"});OpenLayers.Format.CQL=(function(){var tokens=["PROPERTY","COMPARISON","VALUE","LOGICAL"],patterns={PROPERTY:/^[_a-zA-Z]\w*/,COMPARISON:/^(=|<>|<=|<|>=|>|LIKE)/i,COMMA:/^,/,LOGICAL:/^(AND|OR)/i,VALUE:/^('\w+'|\d+(\.\d*)?|\.\d+)/,LPAREN:/^\(/,RPAREN:/^\)/,SPATIAL:/^(BBOX|INTERSECTS|DWITHIN|WITHIN|CONTAINS)/i,NOT:/^NOT/i,BETWEEN:/^BETWEEN/i,GEOMETRY:function(text){var type=/^(POINT|LINESTRING|POLYGON|MULTIPOINT|MULTILI
 NESTRING|MULTIPOLYGON|GEOMETRYCOLLECTION)/.exec(text);if(type){var len=text.length;var idx=text.indexOf("(",type[0].length);if(idx>-1){var depth=1;while(idx<len&&depth>0){idx++;switch(text.charAt(idx)){case'(':depth++;break;case')':depth--;break;default:}}}
 return[text.substr(0,idx+1)];}},END:/^$/},follows={LPAREN:['GEOMETRY','SPATIAL','PROPERTY','VALUE','LPAREN'],RPAREN:['NOT','LOGICAL','END','RPAREN'],PROPERTY:['COMPARISON','BETWEEN','COMMA'],BETWEEN:['VALUE'],COMPARISON:['VALUE'],COMMA:['GEOMETRY','VALUE','PROPERTY'],VALUE:['LOGICAL','COMMA','RPAREN','END'],SPATIAL:['LPAREN'],LOGICAL:['NOT','VALUE','SPATIAL','PROPERTY','LPAREN'],NOT:['PROPERTY','LPAREN'],GEOMETRY:['COMMA','RPAREN']},operators={'=':OpenLayers.Filter.Comparison.EQUAL_TO,'<>':OpenLayers.Filter.Comparison.NOT_EQUAL_TO,'<':OpenLayers.Filter.Comparison.LESS_THAN,'<=':OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,'>':OpenLayers.Filter.Comparison.GREATER_THAN,'>=':OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,'LIKE':OpenLayers.Filter.Comparison.LIKE,'BETWEEN':OpenLayers.Filter.Comparison.BETWEEN},operatorReverse={},logicals={'AND':OpenLayers.Filter.Logical.AND,'OR':OpenLayers.Filter.Logical.OR},logicalReverse={},precedence={'RPAREN':3,'LOGICAL':2,'COMPA
 RISON':1};var i;for(i in operators){if(operators.hasOwnProperty(i)){operatorReverse[operators[i]]=i;}}
 for(i in logicals){if(logicals.hasOwnProperty(i)){logicalReverse[logicals[i]]=i;}}
@@ -2895,7 +2925,7 @@
 case undefined:if(typeof filter==="string"){return"'"+filter+"'";}else if(typeof filter==="number"){return String(filter);}
 default:throw new Error("Can't encode: "+filter.CLASS_NAME+" "+filter);}},CLASS_NAME:"OpenLayers.Format.CQL"});})();OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",symbolCache:{},offset:null,initialize:function(containerID){if(!this.supported()){return;}
 if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);var style=document.createStyleSheet();var shapes=['shape','rect','oval','fill','stroke','imagedata','group','textbox'];for(var i=0,len=shapes.length;i<len;i++){style.addRule('olv\\:'+shapes[i],"behavior: url(#default#VML); "+"position: absolute; display: inline-block;");}}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){return!!(document.namespaces);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=(extent.left/resolution)|0;var top=(extent.top/resolution-this.size.h)|0;if(resolutionChanged||!this.offset){this.offset={x:left,y:top};left=0;top=0;}else{left=left-this.offset.x;top=top-this.offset.y;}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},supported:function(){return!!(document.namespaces);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=(extent.left/resolution)|0;var top=(extent.top/resolution-this.size.h)|0;if(resolutionChanged||!this.offset){this.offset={x:left,y:top};left=0;top=0;}else{left=left-this.offset.x;top=top-this.offset.y;}
 var org=left+" "+top;this.root.coordorigin=org;var roots=[this.root,this.vectorRoot,this.textRoot];var root;for(var i=0,len=roots.length;i<len;++i){root=roots[i];var size=this.size.w+" "+this.size.h;root.coordsize=size;}
 this.root.style.flip="y";return true;},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);var roots=[this.rendererRoot,this.root,this.vectorRoot,this.textRoot];var w=this.size.w+"px";var h=this.size.h+"px";var root;for(var i=0,len=roots.length;i<len;++i){root=roots[i];root.style.width=w;root.style.height=h;}},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="olv:rect";}else if(this.isComplexSymbol(style.graphicName)){nodeType="olv:shape";}else{nodeType="olv:oval";}
 break;case"OpenLayers.Geometry.Rectangle":nodeType="olv:rect";break;case"OpenLayers.Geometry.LineString":case"OpenLayers.Geometry.LinearRing":case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="olv:shape";break;default:break;}
@@ -2947,24 +2977,21 @@
 if(this.drillDown===true){this.hover=false;}
 if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},getInfoForClick:function(evt){this.request(evt.xy,{});},getInfoForHover:function(evt){this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
 this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer;for(var i=candidates.length-1;i>=0;--i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMTS&&layer.requestEncoding===this.requestEncoding&&(!this.queryVisible||layer.getVisibility())){layers.push(layer);if(!this.drillDown||this.hover){break;}}}
-return layers;},buildRequestOptions:function(layer,xy){var loc=this.map.getLonLatFromPixel(xy);var getTileUrl=layer.getURL(new OpenLayers.Bounds(loc.lon,loc.lat,loc.lon,loc.lat));var params=OpenLayers.Util.getParameters(getTileUrl);var tileInfo=layer.getTileInfo(loc);OpenLayers.Util.extend(params,{service:"WMTS",version:layer.version,request:"GetFeatureInfo",infoFormat:this.infoFormat,i:tileInfo.i,j:tileInfo.j});OpenLayers.Util.applyDefaults(params,this.vendorParams);return{url:layer.url instanceof Array?layer.url[0]:layer.url,params:OpenLayers.Util.upperCaseObject(params),callback:function(request){this.handleResponse(xy,request,layer);},scope:this};},request:function(xy,options){options=options||{};var layers=this.findLayers();if(layers.length>0){var issue,layer;for(var i=0,len=layers.length;i<len;i++){layer=layers[i];issue=this.events.triggerEvent("beforegetfeatureinfo",{xy:xy,layer:layer});if(issue!==false){++this.pending;var requestOptions=this.buildRequestOptions(layer
 ,xy);var request=OpenLayers.Request.GET(requestOptions);if(options.hover===true){this.hoverRequest=request;}}}
+return layers;},buildRequestOptions:function(layer,xy){var loc=this.map.getLonLatFromPixel(xy);var getTileUrl=layer.getURL(new OpenLayers.Bounds(loc.lon,loc.lat,loc.lon,loc.lat));var params=OpenLayers.Util.getParameters(getTileUrl);var tileInfo=layer.getTileInfo(loc);OpenLayers.Util.extend(params,{service:"WMTS",version:layer.version,request:"GetFeatureInfo",infoFormat:this.infoFormat,i:tileInfo.i,j:tileInfo.j});OpenLayers.Util.applyDefaults(params,this.vendorParams);return{url:OpenLayers.Util.isArray(layer.url)?layer.url[0]:layer.url,params:OpenLayers.Util.upperCaseObject(params),callback:function(request){this.handleResponse(xy,request,layer);},scope:this};},request:function(xy,options){options=options||{};var layers=this.findLayers();if(layers.length>0){var issue,layer;for(var i=0,len=layers.length;i<len;i++){layer=layers[i];issue=this.events.triggerEvent("beforegetfeatureinfo",{xy:xy,layer:layer});if(issue!==false){++this.pending;var requestOptions=this.buildRequestOptio
 ns(layer,xy);var request=OpenLayers.Request.GET(requestOptions);if(options.hover===true){this.hoverRequest=request;}}}
 if(this.pending>0){OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");}}},handleResponse:function(xy,request,layer){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
 if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("exception",{xy:xy,request:request,layer:layer});}else{var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
 var features,except;try{features=this.format.read(doc);}catch(error){except=true;this.events.triggerEvent("exception",{xy:xy,request:request,error:error,layer:layer});}
-if(!except){this.events.triggerEvent("getfeatureinfo",{text:request.responseText,features:features,request:request,xy:xy,layer:layer});}}},CLASS_NAME:"OpenLayers.Control.WMTSGetFeatureInfo"});OpenLayers.Format.WMSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.1",version:null,profile:null,parser:null,read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;var profile=this.profile?"_"+this.profile:"";if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.WMSCapabilities["v"+version.replace(/\./g,"_")+profile];if(!constr){throw"Can't find a WMS capabilities parser for version "+
-version+profile;}
-this.parser=new constr(this.options);}
-var capabilities=this.parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.WMSCapabilities"});OpenLayers.Format.WMSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{wms:"http://www.opengis.net/wms",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"wms",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var capabilities={};this.readNode(data,capabilities);this.postProcessLayers(capabilities);return capabilities;},postProcessLayers:function(capabilities){if(capabilities.capability){capabilities.capability.layers=[];var layers=capabilities.capability.nestedLayers;for(var i=0,len=layers.length;i<len;++i){var layer=layers[i];this.processLayer(capabilities.capability,layer);}}},processLayer:function(capability,layer,parentLayer){if(layer.formats===undefined){layer.formats=capability.request.getmap.formats;}
+if(!except){this.events.triggerEvent("getfeatureinfo",{text:request.responseText,features:features,request:request,xy:xy,layer:layer});}}},CLASS_NAME:"OpenLayers.Control.WMTSGetFeatureInfo"});OpenLayers.Format.WMSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.1",profile:null,CLASS_NAME:"OpenLayers.Format.WMSCapabilities"});OpenLayers.Format.WMSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{wms:"http://www.opengis.net/wms",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"wms",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var raw=data;if(data&&data.nodeType==9){data=data.documentElement;}
+var capabilities={};this.readNode(data,capabilities);if(capabilities.service===undefined){var parser=new OpenLayers.Format.OGCExceptionReport();capabilities.error=parser.read(raw);}else{this.postProcessLayers(capabilities);}
+return capabilities;},postProcessLayers:function(capabilities){if(capabilities.capability){capabilities.capability.layers=[];var layers=capabilities.capability.nestedLayers;for(var i=0,len=layers.length;i<len;++i){var layer=layers[i];this.processLayer(capabilities.capability,layer);}}},processLayer:function(capability,layer,parentLayer){if(layer.formats===undefined){layer.formats=capability.request.getmap.formats;}
 if(parentLayer){layer.styles=layer.styles.concat(parentLayer.styles);var attributes=["queryable","cascaded","fixedWidth","fixedHeight","opaque","noSubsets","llbbox","minScale","maxScale","attribution"];var complexAttr=["srs","bbox","dimensions","authorityURLs"];var key;for(var j=0;j<attributes.length;j++){key=attributes[j];if(key in parentLayer){if(layer[key]==null){layer[key]=parentLayer[key];}
 if(layer[key]==null){var intAttr=["cascaded","fixedWidth","fixedHeight"];var boolAttr=["queryable","opaque","noSubsets"];if(OpenLayers.Util.indexOf(intAttr,key)!=-1){layer[key]=0;}
 if(OpenLayers.Util.indexOf(boolAttr,key)!=-1){layer[key]=false;}}}}
 for(var j=0;j<complexAttr.length;j++){key=complexAttr[j];layer[key]=OpenLayers.Util.extend(layer[key],parentLayer[key]);}}
 for(var i=0,len=layer.nestedLayers.length;i<len;i++){var childLayer=layer.nestedLayers[i];this.processLayer(capability,childLayer,layer);}
 if(layer.name){capability.layers.push(layer);}},readers:{"wms":{"Service":function(node,obj){obj.service={};this.readChildNodes(node,obj.service);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj["abstract"]=this.getChildValue(node);},"BoundingBox":function(node,obj){var bbox={};bbox.bbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];var res={x:parseFloat(node.getAttribute("resx")),y:parseFloat(node.getAttribute("resy"))};if(!(isNaN(res.x)&&isNaN(res.y))){bbox.res=res;}
-return bbox;},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ContactInformation":function(node,obj){obj.contactInformation={};this.readChildNodes(node,obj.contactInformation);},"ContactPersonPrimary":function(node,obj){obj.personPrimary={};this.readChildNodes(node,obj.personPrimary);},"ContactPerson":function(node,obj){obj.person=this.getChildValue(node);},"ContactOrganization":function(node,obj){obj.organization=this.getChildValue(node);},"ContactPosition":function(node,obj){obj.position=this.getChildValue(node);},"ContactAddress":function(node,obj){obj.contactAddress={};this.readChildNodes(node,obj.contactAddress);},"AddressType":function(node,obj){obj.type=this.getChildValue(node);},"Address":function(node,obj){obj.address=this.getChildValue(node);},"City":function(node,obj){obj.city=this.getChildValue(node);},"StateOrProvince":function(node,obj){obj.stateOrProvince=this.getChildValue(node);},"PostCode":function(node
 ,obj){obj.postcode=this.getChildValue(node);},"Country":function(node,obj){obj.country=this.getChildValue(node);},"ContactVoiceTelephone":function(node,obj){obj.phone=this.getChildValue(node);},"ContactFacsimileTelephone":function(node,obj){obj.fax=this.getChildValue(node);},"ContactElectronicMailAddress":function(node,obj){obj.email=this.getChildValue(node);},"Fees":function(node,obj){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){obj.fees=fees;}},"AccessConstraints":function(node,obj){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){obj.accessConstraints=constraints;}},"Capability":function(node,obj){obj.capability={nestedLayers:[]};this.readChildNodes(node,obj.capability);},"Request":function(node,obj){obj.request={};this.readChildNodes(node,obj.request);},"GetCapabilities":function(node,obj){obj.getcapabilities={formats:[]};this.readChildNodes(node,obj.getcapabilities);},"Format":function(node,obj){if(obj
 .formats instanceof Array){obj.formats.push(this.getChildValue(node));}else{obj.format=this.getChildValue(node);}},"DCPType":function(node,obj){this.readChildNodes(node,obj);},"HTTP":function(node,obj){this.readChildNodes(node,obj);},"Get":function(node,obj){this.readChildNodes(node,obj);},"Post":function(node,obj){this.readChildNodes(node,obj);},"GetMap":function(node,obj){obj.getmap={formats:[]};this.readChildNodes(node,obj.getmap);},"GetFeatureInfo":function(node,obj){obj.getfeatureinfo={formats:[]};this.readChildNodes(node,obj.getfeatureinfo);},"Exception":function(node,obj){obj.exception={formats:[]};this.readChildNodes(node,obj.exception);},"Layer":function(node,obj){var attrNode=node.getAttributeNode("queryable");var queryable=(attrNode&&attrNode.specified)?node.getAttribute("queryable"):null;attrNode=node.getAttributeNode("cascaded");var cascaded=(attrNode&&attrNode.specified)?node.getAttribute("cascaded"):null;attrNode=node.getAttributeNode("opaque");var opaque=(att
 rNode&&attrNode.specified)?node.getAttribute('opaque'):null;var noSubsets=node.getAttribute('noSubsets');var fixedWidth=node.getAttribute('fixedWidth');var fixedHeight=node.getAttribute('fixedHeight');var layer={nestedLayers:[],styles:[],srs:{},metadataURLs:[],bbox:{},dimensions:{},authorityURLs:{},identifiers:{},keywords:[],queryable:(queryable&&queryable!=="")?(queryable==="1"||queryable==="true"):null,cascaded:(cascaded!==null)?parseInt(cascaded):null,opaque:opaque?(opaque==="1"||opaque==="true"):null,noSubsets:(noSubsets!==null)?(noSubsets==="1"||noSubsets==="true"):null,fixedWidth:(fixedWidth!=null)?parseInt(fixedWidth):null,fixedHeight:(fixedHeight!=null)?parseInt(fixedHeight):null};obj.nestedLayers.push(layer);this.readChildNodes(node,layer);if(layer.name){var parts=layer.name.split(":");if(parts.length>0){layer.prefix=parts[0];}}},"Attribution":function(node,obj){obj.attribution={};this.readChildNodes(node,obj.attribution);},"LogoURL":function(node,obj){obj.logo={wid
 th:node.getAttribute("width"),height:node.getAttribute("height")};this.readChildNodes(node,obj.logo);},"Style":function(node,obj){var style={};obj.styles.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={width:node.getAttribute("width"),height:node.getAttribute("height")};obj.legend=legend;this.readChildNodes(node,legend);},"MetadataURL":function(node,obj){var metadataURL={type:node.getAttribute("type")};obj.metadataURLs.push(metadataURL);this.readChildNodes(node,metadataURL);},"DataURL":function(node,obj){obj.dataURL={};this.readChildNodes(node,obj.dataURL);},"FeatureListURL":function(node,obj){obj.featureListURL={};this.readChildNodes(node,obj.featureListURL);},"AuthorityURL":function(node,obj){var name=node.getAttribute("name");var authority={};this.readChildNodes(node,authority);obj.authorityURLs[name]=authority.href;},"Identifier":function(node,obj){var authority=node.getAttribute("authority");obj.identifiers[authority]=this.getChi
 ldValue(node);},"KeywordList":function(node,obj){this.readChildNodes(node,obj);},"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1"});OpenLayers.Format.WMSCapabilities.v1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMT_MS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Keyword":function(node,obj){if(obj.keywords){obj.keywords.push(this.getChildValue(node));}},"DescribeLayer":function(node,obj){obj.describelayer={formats:[]};this.readChildNodes(node,obj.describelayer);},"GetLegendGraphic":function(node,obj){obj.getlegendgraphic={formats:[]};this.readChildNodes(node,obj.getlegendgraphic);},"GetStyles":function(node,obj){obj.getstyles={formats:[]};this.readChildNodes(node,obj.getstyles);},"PutStyles":function(node,obj){obj.putstyles={formats:[]};this.readChildNodes(node,obj.putstyles);},"UserDefinedSymbolization":function(node,obj){var
  userSymbols={supportSLD:parseInt(node.getAttribute("SupportSLD"))==1,userLayer:parseInt(node.getAttribute("UserLayer"))==1,userStyle:parseInt(node.getAttribute("UserStyle"))==1,remoteWFS:parseInt(node.getAttribute("RemoteWFS"))==1};obj.userSymbols=userSymbols;},"LatLonBoundingBox":function(node,obj){obj.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("SRS");obj.bbox[bbox.srs]=bbox;},"ScaleHint":function(node,obj){var min=node.getAttribute("min");var max=node.getAttribute("max");var rad2=Math.pow(2,0.5);var ipm=OpenLayers.INCHES_PER_UNIT["m"];obj.maxScale=parseFloat(((min/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecision(13));obj.minScale=parseFloat(((max/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecisio
 n(13));},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol")};obj.dimensions[dim.name]=dim;},"Extent":function(node,obj){var name=node.getAttribute("name").toLowerCase();if(name in obj["dimensions"]){var extent=obj.dimensions[name];extent.nearestVal=node.getAttribute("nearestValue")==="1";extent.multipleVal=node.getAttribute("multipleValues")==="1";extent.current=node.getAttribute("current")==="1";extent["default"]=node.getAttribute("default")||"";var values=this.getChildValue(node);extent.values=values.split(",");}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1"});OpenLayers.Control.Graticule=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,intervals:[45,30,20,10,5,2,1,0.5,0.2,0.1,0.05,0.01,0.005,0.002,0.001],displayInLayerSwitcher:true,visible:true,numPoints:50,targetSize:200,l
 ayerName:null,labelled:true,labelFormat:'dm',lineSymbolizer:{strokeColor:"#333",strokeWidth:1,strokeOpacity:0.5},labelSymbolizer:{},gratLayer:null,initialize:function(options){options=options||{};options.layerName=options.layerName||OpenLayers.i18n("graticule");OpenLayers.Control.prototype.initialize.apply(this,[options]);this.labelSymbolizer.stroke=false;this.labelSymbolizer.fill=false;this.labelSymbolizer.label="${label}";this.labelSymbolizer.labelAlign="${labelAlign}";this.labelSymbolizer.labelXOffset="${xOffset}";this.labelSymbolizer.labelYOffset="${yOffset}";},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.gratLayer){this.gratLayer.destroy();this.gratLayer=null;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.gratLayer){var gratStyle=new OpenLayers.Style({},{rules:[new OpenLayers.Rule({'symbolizer':{"Point":this.labelSymbolizer,"Line":this.lineSymbolizer}})]});this.gratLayer=new
 OpenLayers.Layer.Vector(this.layerName,{styleMap:new OpenLayers.StyleMap({'default':gratStyle}),visibility:this.visible,displayInLayerSwitcher:this.displayInLayerSwitcher});}
+return bbox;},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ContactInformation":function(node,obj){obj.contactInformation={};this.readChildNodes(node,obj.contactInformation);},"ContactPersonPrimary":function(node,obj){obj.personPrimary={};this.readChildNodes(node,obj.personPrimary);},"ContactPerson":function(node,obj){obj.person=this.getChildValue(node);},"ContactOrganization":function(node,obj){obj.organization=this.getChildValue(node);},"ContactPosition":function(node,obj){obj.position=this.getChildValue(node);},"ContactAddress":function(node,obj){obj.contactAddress={};this.readChildNodes(node,obj.contactAddress);},"AddressType":function(node,obj){obj.type=this.getChildValue(node);},"Address":function(node,obj){obj.address=this.getChildValue(node);},"City":function(node,obj){obj.city=this.getChildValue(node);},"StateOrProvince":function(node,obj){obj.stateOrProvince=this.getChildValue(node);},"PostCode":function(node
 ,obj){obj.postcode=this.getChildValue(node);},"Country":function(node,obj){obj.country=this.getChildValue(node);},"ContactVoiceTelephone":function(node,obj){obj.phone=this.getChildValue(node);},"ContactFacsimileTelephone":function(node,obj){obj.fax=this.getChildValue(node);},"ContactElectronicMailAddress":function(node,obj){obj.email=this.getChildValue(node);},"Fees":function(node,obj){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){obj.fees=fees;}},"AccessConstraints":function(node,obj){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){obj.accessConstraints=constraints;}},"Capability":function(node,obj){obj.capability={nestedLayers:[]};this.readChildNodes(node,obj.capability);},"Request":function(node,obj){obj.request={};this.readChildNodes(node,obj.request);},"GetCapabilities":function(node,obj){obj.getcapabilities={formats:[]};this.readChildNodes(node,obj.getcapabilities);},"Format":function(node,obj){if(Ope
 nLayers.Util.isArray(obj.formats)){obj.formats.push(this.getChildValue(node));}else{obj.format=this.getChildValue(node);}},"DCPType":function(node,obj){this.readChildNodes(node,obj);},"HTTP":function(node,obj){this.readChildNodes(node,obj);},"Get":function(node,obj){obj.get={};this.readChildNodes(node,obj.get);if(!obj.href){obj.href=obj.get.href;}},"Post":function(node,obj){obj.post={};this.readChildNodes(node,obj.post);if(!obj.href){obj.href=obj.get.href;}},"GetMap":function(node,obj){obj.getmap={formats:[]};this.readChildNodes(node,obj.getmap);},"GetFeatureInfo":function(node,obj){obj.getfeatureinfo={formats:[]};this.readChildNodes(node,obj.getfeatureinfo);},"Exception":function(node,obj){obj.exception={formats:[]};this.readChildNodes(node,obj.exception);},"Layer":function(node,obj){var attrNode=node.getAttributeNode("queryable");var queryable=(attrNode&&attrNode.specified)?node.getAttribute("queryable"):null;attrNode=node.getAttributeNode("cascaded");var cascaded=(attrNod
 e&&attrNode.specified)?node.getAttribute("cascaded"):null;attrNode=node.getAttributeNode("opaque");var opaque=(attrNode&&attrNode.specified)?node.getAttribute('opaque'):null;var noSubsets=node.getAttribute('noSubsets');var fixedWidth=node.getAttribute('fixedWidth');var fixedHeight=node.getAttribute('fixedHeight');var layer={nestedLayers:[],styles:[],srs:{},metadataURLs:[],bbox:{},dimensions:{},authorityURLs:{},identifiers:{},keywords:[],queryable:(queryable&&queryable!=="")?(queryable==="1"||queryable==="true"):null,cascaded:(cascaded!==null)?parseInt(cascaded):null,opaque:opaque?(opaque==="1"||opaque==="true"):null,noSubsets:(noSubsets!==null)?(noSubsets==="1"||noSubsets==="true"):null,fixedWidth:(fixedWidth!=null)?parseInt(fixedWidth):null,fixedHeight:(fixedHeight!=null)?parseInt(fixedHeight):null};obj.nestedLayers.push(layer);this.readChildNodes(node,layer);if(layer.name){var parts=layer.name.split(":");if(parts.length>0){layer.prefix=parts[0];}}},"Attribution":function(n
 ode,obj){obj.attribution={};this.readChildNodes(node,obj.attribution);},"LogoURL":function(node,obj){obj.logo={width:node.getAttribute("width"),height:node.getAttribute("height")};this.readChildNodes(node,obj.logo);},"Style":function(node,obj){var style={};obj.styles.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={width:node.getAttribute("width"),height:node.getAttribute("height")};obj.legend=legend;this.readChildNodes(node,legend);},"MetadataURL":function(node,obj){var metadataURL={type:node.getAttribute("type")};obj.metadataURLs.push(metadataURL);this.readChildNodes(node,metadataURL);},"DataURL":function(node,obj){obj.dataURL={};this.readChildNodes(node,obj.dataURL);},"FeatureListURL":function(node,obj){obj.featureListURL={};this.readChildNodes(node,obj.featureListURL);},"AuthorityURL":function(node,obj){var name=node.getAttribute("name");var authority={};this.readChildNodes(node,authority);obj.authorityURLs[name]=authority.href;},"
 Identifier":function(node,obj){var authority=node.getAttribute("authority");obj.identifiers[authority]=this.getChildValue(node);},"KeywordList":function(node,obj){this.readChildNodes(node,obj);},"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1"});OpenLayers.Format.WMSCapabilities.v1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMT_MS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Keyword":function(node,obj){if(obj.keywords){obj.keywords.push(this.getChildValue(node));}},"DescribeLayer":function(node,obj){obj.describelayer={formats:[]};this.readChildNodes(node,obj.describelayer);},"GetLegendGraphic":function(node,obj){obj.getlegendgraphic={formats:[]};this.readChildNodes(node,obj.getlegendgraphic);},"GetStyles":function(node,obj){obj.getstyles={formats:[]};this.readChildNodes(node,obj.getstyles);},"PutStyles":function(node,obj){obj.
 putstyles={formats:[]};this.readChildNodes(node,obj.putstyles);},"UserDefinedSymbolization":function(node,obj){var userSymbols={supportSLD:parseInt(node.getAttribute("SupportSLD"))==1,userLayer:parseInt(node.getAttribute("UserLayer"))==1,userStyle:parseInt(node.getAttribute("UserStyle"))==1,remoteWFS:parseInt(node.getAttribute("RemoteWFS"))==1};obj.userSymbols=userSymbols;},"LatLonBoundingBox":function(node,obj){obj.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("SRS");obj.bbox[bbox.srs]=bbox;},"ScaleHint":function(node,obj){var min=node.getAttribute("min");var max=node.getAttribute("max");var rad2=Math.pow(2,0.5);var ipm=OpenLayers.INCHES_PER_UNIT["m"];obj.maxScale=parseFloat(((min/rad2)*ipm*OpenL
 ayers.DOTS_PER_INCH).toPrecision(13));obj.minScale=parseFloat(((max/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecision(13));},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol")};obj.dimensions[dim.name]=dim;},"Extent":function(node,obj){var name=node.getAttribute("name").toLowerCase();if(name in obj["dimensions"]){var extent=obj.dimensions[name];extent.nearestVal=node.getAttribute("nearestValue")==="1";extent.multipleVal=node.getAttribute("multipleValues")==="1";extent.current=node.getAttribute("current")==="1";extent["default"]=node.getAttribute("default")||"";var values=this.getChildValue(node);extent.values=values.split(",");}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1"});OpenLayers.Control.Graticule=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,intervals:[45,30,20,10,5,2
 ,1,0.5,0.2,0.1,0.05,0.01,0.005,0.002,0.001],displayInLayerSwitcher:true,visible:true,numPoints:50,targetSize:200,layerName:null,labelled:true,labelFormat:'dm',lineSymbolizer:{strokeColor:"#333",strokeWidth:1,strokeOpacity:0.5},labelSymbolizer:{},gratLayer:null,initialize:function(options){options=options||{};options.layerName=options.layerName||OpenLayers.i18n("Graticule");OpenLayers.Control.prototype.initialize.apply(this,[options]);this.labelSymbolizer.stroke=false;this.labelSymbolizer.fill=false;this.labelSymbolizer.label="${label}";this.labelSymbolizer.labelAlign="${labelAlign}";this.labelSymbolizer.labelXOffset="${xOffset}";this.labelSymbolizer.labelYOffset="${yOffset}";},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.gratLayer){this.gratLayer.destroy();this.gratLayer=null;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.gratLayer){var gratStyle=new OpenLayers.Style({},{rules:[ne
 w OpenLayers.Rule({'symbolizer':{"Point":this.labelSymbolizer,"Line":this.lineSymbolizer}})]});this.gratLayer=new OpenLayers.Layer.Vector(this.layerName,{styleMap:new OpenLayers.StyleMap({'default':gratStyle}),visibility:this.visible,displayInLayerSwitcher:this.displayInLayerSwitcher});}
 return this.div;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.map.addLayer(this.gratLayer);this.map.events.register('moveend',this,this.update);this.update();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.map.events.unregister('moveend',this,this.update);this.map.removeLayer(this.gratLayer);return true;}else{return false;}},update:function(){var mapBounds=this.map.getExtent();if(!mapBounds){return;}
 this.gratLayer.destroyFeatures();var llProj=new OpenLayers.Projection("EPSG:4326");var mapProj=this.map.getProjectionObject();var mapRes=this.map.getResolution();if(mapProj.proj&&mapProj.proj.projName=="longlat"){this.numPoints=1;}
 var mapCenter=this.map.getCenter();var mapCenterLL=new OpenLayers.Pixel(mapCenter.lon,mapCenter.lat);OpenLayers.Projection.transform(mapCenterLL,mapProj,llProj);var testSq=this.targetSize*mapRes;testSq*=testSq;var llInterval;for(var i=0;i<this.intervals.length;++i){llInterval=this.intervals[i];var delta=llInterval/2;var p1=mapCenterLL.offset(new OpenLayers.Pixel(-delta,-delta));var p2=mapCenterLL.offset(new OpenLayers.Pixel(delta,delta));OpenLayers.Projection.transform(p1,llProj,mapProj);OpenLayers.Projection.transform(p2,llProj,mapProj);var distSq=(p1.x-p2.x)*(p1.x-p2.x)+(p1.y-p2.y)*(p1.y-p2.y);if(distSq<=testSq){break;}}
@@ -3075,9 +3102,10 @@
 this.destroyRequest(response.priv);options.callback.call(options.scope,response);}},parseFeatures:function(data){return this.format.read(data);},abort:function(response){if(response){this.destroyRequest(response.priv);}else{for(var key in this.pendingRequests){this.destroyRequest(this.pendingRequests[key]);}}},destroy:function(){this.abort();delete this.params;delete this.format;OpenLayers.Protocol.prototype.destroy.apply(this);},CLASS_NAME:"OpenLayers.Protocol.Script"});(function(){var o=OpenLayers.Protocol.Script;var counter=0;var registry={};o.register=function(callback){var id=++counter;registry[id]=callback;return id;};o.unregister=function(id){delete registry[id];};o.getCallback=function(id){var callback=registry[id];o.unregister(id);return callback;};})();OpenLayers.Layer.WMS.Post=OpenLayers.Class(OpenLayers.Layer.WMS,{unsupportedBrowsers:["mozilla","firefox","opera"],SUPPORTED_TRANSITIONS:[],usePost:null,initialize:function(name,url,params,options){var newArguments=[
 ];newArguments.push(name,url,params,options);OpenLayers.Layer.WMS.prototype.initialize.apply(this,newArguments);this.usePost=OpenLayers.Util.indexOf(this.unsupportedBrowsers,OpenLayers.BROWSER_NAME)==-1;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,{maxGetUrlLength:this.usePost?0:null});},CLASS_NAME:'OpenLayers.Layer.WMS.Post'});OpenLayers.Control.TransformFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesetfeature","setfeature","beforetransform","transform","transformcomplete"],geometryTypes:null,layer:null,preserveAspectRatio:false,rotate:true,feature:null,renderIntent:"temporary",rotationHandleSymbolizer:null,box:null,center:null,scale:1,ratio:1,rotation:0,handles:null,rotationHandles:null,dragControl:null,initialize:function(layer,options){this.EVENT_TYPES=OpenLayers.Control.TransformFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.ini
 tialize.apply(this,[options]);this.layer=layer;if(!this.rotationHandleSymbolizer){this.rotationHandleSymbolizer={stroke:false,pointRadius:10,fillOpacity:0,cursor:"pointer"};}
 this.createBox();this.createControl();},activate:function(){var activated=false;if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragControl.activate();this.layer.addFeatures([this.box]);this.rotate&&this.layer.addFeatures(this.rotationHandles);this.layer.addFeatures(this.handles);activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.handles);this.rotate&&this.layer.removeFeatures(this.rotationHandles);this.layer.removeFeatures([this.box]);this.dragControl.deactivate();deactivated=true;}
-return deactivated;},setMap:function(map){this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},setFeature:function(feature,initialParams){initialParams=OpenLayers.Util.applyDefaults(initialParams,{rotation:0,scale:1,ratio:1});var evt={feature:feature};var oldRotation=this.rotation;var oldCenter=this.center;OpenLayers.Util.extend(this,initialParams);if(this.events.triggerEvent("beforesetfeature",evt)===false){return;}
+if(deactivated){this.unsetFeature();}
+return deactivated;},setMap:function(map){this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},setFeature:function(feature,initialParams){initialParams=OpenLayers.Util.applyDefaults(initialParams,{rotation:0,scale:1,ratio:1});var oldRotation=this.rotation;var oldCenter=this.center;OpenLayers.Util.extend(this,initialParams);var cont=this.events.triggerEvent("beforesetfeature",{feature:feature});if(cont===false){return;}
 this.feature=feature;this.activate();this._setfeature=true;var featureBounds=this.feature.geometry.getBounds();this.box.move(featureBounds.getCenterLonLat());this.box.geometry.rotate(-oldRotation,oldCenter);this._angle=0;var ll;if(this.rotation){var geom=feature.geometry.clone();geom.rotate(-this.rotation,this.center);var box=new OpenLayers.Feature.Vector(geom.getBounds().toGeometry());box.geometry.rotate(this.rotation,this.center);this.box.geometry.rotate(this.rotation,this.center);this.box.move(box.geometry.getBounds().getCenterLonLat());var llGeom=box.geometry.components[0].components[0];ll=llGeom.getBounds().getCenterLonLat();}else{ll=new OpenLayers.LonLat(featureBounds.left,featureBounds.bottom);}
-this.handles[0].move(ll);delete this._setfeature;this.events.triggerEvent("setfeature",evt);},createBox:function(){var control=this;this.center=new OpenLayers.Geometry.Point(0,0);var box=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([new OpenLayers.Geometry.Point(-1,-1),new OpenLayers.Geometry.Point(0,-1),new OpenLayers.Geometry.Point(1,-1),new OpenLayers.Geometry.Point(1,0),new OpenLayers.Geometry.Point(1,1),new OpenLayers.Geometry.Point(0,1),new OpenLayers.Geometry.Point(-1,1),new OpenLayers.Geometry.Point(-1,0),new OpenLayers.Geometry.Point(-1,-1)]),null,typeof this.renderIntent=="string"?null:this.renderIntent);box.geometry.move=function(x,y){control._moving=true;OpenLayers.Geometry.LineString.prototype.move.apply(this,arguments);control.center.move(x,y);delete control._moving;};var vertexMoveFn=function(x,y){OpenLayers.Geometry.Point.prototype.move.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.move(x,y);this._handle.geometr
 y.move(x,y);};var vertexResizeFn=function(scale,center,ratio){OpenLayers.Geometry.Point.prototype.resize.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.resize(scale,center,ratio);this._handle.geometry.resize(scale,center,ratio);};var vertexRotateFn=function(angle,center){OpenLayers.Geometry.Point.prototype.rotate.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.rotate(angle,center);this._handle.geometry.rotate(angle,center);};var handleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
+this.handles[0].move(ll);delete this._setfeature;this.events.triggerEvent("setfeature",{feature:feature});},unsetFeature:function(){if(this.active){this.deactivate();}else{this.feature=null;this.rotation=0;this.scale=1;this.ratio=1;}},createBox:function(){var control=this;this.center=new OpenLayers.Geometry.Point(0,0);var box=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([new OpenLayers.Geometry.Point(-1,-1),new OpenLayers.Geometry.Point(0,-1),new OpenLayers.Geometry.Point(1,-1),new OpenLayers.Geometry.Point(1,0),new OpenLayers.Geometry.Point(1,1),new OpenLayers.Geometry.Point(0,1),new OpenLayers.Geometry.Point(-1,1),new OpenLayers.Geometry.Point(-1,0),new OpenLayers.Geometry.Point(-1,-1)]),null,typeof this.renderIntent=="string"?null:this.renderIntent);box.geometry.move=function(x,y){control._moving=true;OpenLayers.Geometry.LineString.prototype.move.apply(this,arguments);control.center.move(x,y);delete control._moving;};var vertexMoveFn=function(x,y){Open
 Layers.Geometry.Point.prototype.move.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.move(x,y);this._handle.geometry.move(x,y);};var vertexResizeFn=function(scale,center,ratio){OpenLayers.Geometry.Point.prototype.resize.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.resize(scale,center,ratio);this._handle.geometry.resize(scale,center,ratio);};var vertexRotateFn=function(angle,center){OpenLayers.Geometry.Point.prototype.rotate.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.rotate(angle,center);this._handle.geometry.rotate(angle,center);};var handleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
 var evt=control.dragControl.handlers.drag.evt;var preserveAspectRatio=!control._setfeature&&control.preserveAspectRatio;var reshape=!preserveAspectRatio&&!(evt&&evt.shiftKey);var oldGeom=new OpenLayers.Geometry.Point(oldX,oldY);var centerGeometry=control.center;this.rotate(-control.rotation,centerGeometry);oldGeom.rotate(-control.rotation,centerGeometry);var dx1=this.x-centerGeometry.x;var dy1=this.y-centerGeometry.y;var dx0=dx1-(this.x-oldGeom.x);var dy0=dy1-(this.y-oldGeom.y);this.x=oldX;this.y=oldY;var scale,ratio=1;if(reshape){scale=Math.abs(dy0)<0.00001?1:dy1/dy0;ratio=(Math.abs(dx0)<0.00001?1:(dx1/dx0))/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
 control._moving=true;control.box.geometry.rotate(-control.rotation,centerGeometry);delete control._moving;control.box.geometry.resize(scale,centerGeometry,ratio);control.box.geometry.rotate(control.rotation,centerGeometry);control.transformFeature({scale:scale,ratio:ratio});};var rotationHandleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
 var evt=control.dragControl.handlers.drag.evt;var constrain=(evt&&evt.shiftKey)?45:1;var centerGeometry=control.center;var dx1=this.x-centerGeometry.x;var dy1=this.y-centerGeometry.y;var dx0=dx1-x;var dy0=dy1-y;this.x=oldX;this.y=oldY;var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;control._angle=(control._angle+angle)%360;var diff=control.rotation%constrain;if(Math.abs(control._angle)>=constrain||diff!==0){angle=Math.round(control._angle/constrain)*constrain-
@@ -3095,19 +3123,19 @@
 this.maxExtent=this.calculateMaxExtentWithLOD(this.lods[0]);this.serverResolutions=this.resolutions;if(this.overrideDPI&&info.tileInfo.dpi){OpenLayers.DOTS_PER_INCH=info.tileInfo.dpi;}}}},getContainingTileCoords:function(point,res){return new OpenLayers.Pixel(Math.max(Math.floor((point.x-this.tileOrigin.lon)/(this.tileSize.w*res)),0),Math.max(Math.floor((this.tileOrigin.lat-point.y)/(this.tileSize.h*res)),0));},calculateMaxExtentWithLOD:function(lod){var numTileCols=(lod.endTileCol-lod.startTileCol)+1;var numTileRows=(lod.endTileRow-lod.startTileRow)+1;var minX=this.tileOrigin.lon+(lod.startTileCol*this.tileSize.w*lod.resolution);var maxX=minX+(numTileCols*this.tileSize.w*lod.resolution);var maxY=this.tileOrigin.lat-(lod.startTileRow*this.tileSize.h*lod.resolution);var minY=maxY-(numTileRows*this.tileSize.h*lod.resolution);return new OpenLayers.Bounds(minX,minY,maxX,maxY);},calculateMaxExtentWithExtent:function(extent,res){var upperLeft=new OpenLayers.Geometry.Point(extent.l
 eft,extent.top);var bottomRight=new OpenLayers.Geometry.Point(extent.right,extent.bottom);var start=this.getContainingTileCoords(upperLeft,res);var end=this.getContainingTileCoords(bottomRight,res);var lod={resolution:res,startTileCol:start.x,startTileRow:start.y,endTileCol:end.x,endTileRow:end.y};return this.calculateMaxExtentWithLOD(lod);},getUpperLeftTileCoord:function(res){var upperLeft=new OpenLayers.Geometry.Point(this.maxExtent.left,this.maxExtent.top);return this.getContainingTileCoords(upperLeft,res);},getLowerRightTileCoord:function(res){var bottomRight=new OpenLayers.Geometry.Point(this.maxExtent.right,this.maxExtent.bottom);return this.getContainingTileCoords(bottomRight,res);},getMaxExtentForResolution:function(res){var start=this.getUpperLeftTileCoord(res);var end=this.getLowerRightTileCoord(res);var numTileCols=(end.x-start.x)+1;var numTileRows=(end.y-start.y)+1;var minX=this.tileOrigin.lon+(start.x*this.tileSize.w*res);var maxX=minX+(numTileCols*this.tileSize
 .w*res);var maxY=this.tileOrigin.lat-(start.y*this.tileSize.h*res);var minY=maxY-(numTileRows*this.tileSize.h*res);return new OpenLayers.Bounds(minX,minY,maxX,maxY);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcGISCache(this.name,this.url,this.options);}
 return OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);},getMaxExtent:function(){var resolution=this.map.getResolution();return this.maxExtent=this.getMaxExtentForResolution(resolution);},getTileOrigin:function(){var extent=this.getMaxExtent();return new OpenLayers.LonLat(extent.left,extent.bottom);},getURL:function(bounds){var res=this.getResolution();var originTileX=(this.tileOrigin.lon+(res*this.tileSize.w/2));var originTileY=(this.tileOrigin.lat-(res*this.tileSize.h/2));var center=bounds.getCenterLonLat();var point={x:center.lon,y:center.lat};var x=(Math.round(Math.abs((center.lon-originTileX)/(res*this.tileSize.w))));var y=(Math.round(Math.abs((originTileY-center.lat)/(res*this.tileSize.h))));var z=this.map.getZoom();if(this.lods){var lod=this.lods[this.map.getZoom()];if((x<lod.startTileCol||x>lod.endTileCol)||(y<lod.startTileRow||y>lod.endTileRow)){return null;}}
 else{var start=this.getUpperLeftTileCoord(res);var end=this.getLowerRightTileCoord(res);if((x<start.x||x>=end.x)||(y<start.y||y>=end.y)){return null;}}
-var url=this.url;var s=''+x+y+z;if(url instanceof Array){url=this.selectUrl(s,url);}
+var url=this.url;var s=''+x+y+z;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(s,url);}
 if(this.useArcGISServer){url=url+'/tile/${z}/${y}/${x}';}else{x='C'+this.zeroPad(x,8,16);y='R'+this.zeroPad(y,8,16);z='L'+this.zeroPad(z,2,16);url=url+'/${z}/${y}/${x}.'+this.type;}
 url=OpenLayers.String.format(url,{'x':x,'y':y,'z':z});return url;},zeroPad:function(num,len,radix){var str=num.toString(radix||10);while(str.length<len){str="0"+str;}
 return str;},CLASS_NAME:'OpenLayers.Layer.ArcGISCache'});OpenLayers.Control.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,drillDown:false,maxFeatures:10,clickCallback:"click",output:"features",layers:null,queryVisible:false,url:null,layerUrls:null,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,EVENT_TYPES:["beforegetfeatureinfo","nogetfeatureinfo","getfeatureinfo"],initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.WMSGetFeatureInfo.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options=options||{};options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
 if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{'move':this.cancelHover,'pause':this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{'delay':250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},activate:function(){if(!this.active){this.handler.activate();}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},getInfoForClick:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");this.request(evt.xy,{});},getInfoForHover:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer,url;for(var i=0,len=candidates.length;i<len;++i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMS&&(!this.queryVisible||layer.getVisibility())){url=layer.url instanceof Array?layer.url[0]:layer.url;if(this.drillDown===false&&!this.url){this.url=url;}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},getInfoForClick:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");this.request(evt.xy,{});},getInfoForHover:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer,url;for(var i=0,len=candidates.length;i<len;++i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMS&&(!this.queryVisible||layer.getVisibility())){url=OpenLayers.Util.isArray(layer.url)?layer.url[0]:layer.url;if(this.drillDown===false&&!this.url){this.url=url;}
 if(this.drillDown===true||this.urlMatches(url)){layers.push(layer);}}}
 return layers;},urlMatches:function(url){var matches=OpenLayers.Util.isEquivalentUrl(this.url,url);if(!matches&&this.layerUrls){for(var i=0,len=this.layerUrls.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(this.layerUrls[i],url)){matches=true;break;}}}
 return matches;},buildWMSOptions:function(url,layers,clickPosition,format){var layerNames=[],styleNames=[];for(var i=0,len=layers.length;i<len;i++){layerNames=layerNames.concat(layers[i].params.LAYERS);styleNames=styleNames.concat(this.getStyleNames(layers[i]));}
-var firstLayer=layers[0];var projection=firstLayer.projection;var params=OpenLayers.Util.extend({service:"WMS",version:firstLayer.params.VERSION,request:"GetFeatureInfo",layers:layerNames,query_layers:layerNames,styles:styleNames,bbox:this.map.getExtent().toBBOX(null,firstLayer.reverseAxisOrder()),feature_count:this.maxFeatures,height:this.map.getSize().h,width:this.map.getSize().w,format:format,info_format:firstLayer.params.INFO_FORMAT||this.infoFormat},(parseFloat(firstLayer.params.VERSION)>=1.3)?{crs:projection,i:parseInt(clickPosition.x),j:parseInt(clickPosition.y)}:{srs:projection,x:parseInt(clickPosition.x),y:parseInt(clickPosition.y)});OpenLayers.Util.applyDefaults(params,this.vendorParams);return{url:url,params:OpenLayers.Util.upperCaseObject(params),callback:function(request){this.handleResponse(clickPosition,request,url);},scope:this};},getStyleNames:function(layer){var styleNames;if(layer.params.STYLES){styleNames=layer.params.STYLES;}else{if(layer.params.LAYERS i
 nstanceof Array){styleNames=new Array(layer.params.LAYERS.length);}else{styleNames=layer.params.LAYERS.replace(/[^,]/g,"");}}
+var firstLayer=layers[0];var projection=firstLayer.projection;var params=OpenLayers.Util.extend({service:"WMS",version:firstLayer.params.VERSION,request:"GetFeatureInfo",layers:layerNames,query_layers:layerNames,styles:styleNames,bbox:this.map.getExtent().toBBOX(null,firstLayer.reverseAxisOrder()),feature_count:this.maxFeatures,height:this.map.getSize().h,width:this.map.getSize().w,format:format,info_format:firstLayer.params.INFO_FORMAT||this.infoFormat},(parseFloat(firstLayer.params.VERSION)>=1.3)?{crs:projection,i:parseInt(clickPosition.x),j:parseInt(clickPosition.y)}:{srs:projection,x:parseInt(clickPosition.x),y:parseInt(clickPosition.y)});OpenLayers.Util.applyDefaults(params,this.vendorParams);return{url:url,params:OpenLayers.Util.upperCaseObject(params),callback:function(request){this.handleResponse(clickPosition,request,url);},scope:this};},getStyleNames:function(layer){var styleNames;if(layer.params.STYLES){styleNames=layer.params.STYLES;}else{if(OpenLayers.Util.isArr
 ay(layer.params.LAYERS)){styleNames=new Array(layer.params.LAYERS.length);}else{styleNames=layer.params.LAYERS.replace(/[^,]/g,"");}}
 return styleNames;},request:function(clickPosition,options){var layers=this.findLayers();if(layers.length==0){this.events.triggerEvent("nogetfeatureinfo");OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");return;}
-options=options||{};if(this.drillDown===false){var wmsOptions=this.buildWMSOptions(this.url,layers,clickPosition,layers[0].params.FORMAT);var request=OpenLayers.Request.GET(wmsOptions);if(options.hover===true){this.hoverRequest=request;}}else{this._requestCount=0;this._numRequests=0;this.features=[];var services={},url;for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];var service,found=false;url=layer.url instanceof Array?layer.url[0]:layer.url;if(url in services){services[url].push(layer);}else{this._numRequests++;services[url]=[layer];}}
+options=options||{};if(this.drillDown===false){var wmsOptions=this.buildWMSOptions(this.url,layers,clickPosition,layers[0].params.FORMAT);var request=OpenLayers.Request.GET(wmsOptions);if(options.hover===true){this.hoverRequest=request;}}else{this._requestCount=0;this._numRequests=0;this.features=[];var services={},url;for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];var service,found=false;url=OpenLayers.Util.isArray(layer.url)?layer.url[0]:layer.url;if(url in services){services[url].push(layer);}else{this._numRequests++;services[url]=[layer];}}
 var layers;for(var url in services){layers=services[url];var wmsOptions=this.buildWMSOptions(url,layers,clickPosition,layers[0].params.FORMAT);OpenLayers.Request.GET(wmsOptions);}}},triggerGetFeatureInfo:function(request,xy,features){this.events.triggerEvent("getfeatureinfo",{text:request.responseText,features:features,request:request,xy:xy});OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");},handleResponse:function(xy,request,url){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
 var features=this.format.read(doc);if(this.drillDown===false){this.triggerGetFeatureInfo(request,xy,features);}else{this._requestCount++;if(this.output==="object"){this._features=(this._features||[]).concat({url:url,features:features});}else{this._features=(this._features||[]).concat(features);}
 if(this._requestCount===this._numRequests){this.triggerGetFeatureInfo(request,xy,this._features.concat());delete this._features;delete this._requestCount;delete this._numRequests;}}},CLASS_NAME:"OpenLayers.Control.WMSGetFeatureInfo"});OpenLayers.Format.WMSCapabilities.v1_3=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"LayerLimit":function(node,obj){obj.layerLimit=parseInt(this.getChildValue(node));},"MaxWidth":function(node,obj){obj.maxWidth=parseInt(this.getChildValue(node));},"MaxHeight":function(node,obj){obj.maxHeight=parseInt(this.getChildValue(node));},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("CRS");obj.bbox[bbox.srs]=bbox;},"CRS":function(node,obj){this.readers.wms.SRS.apply(this,[node,obj]);},"EX_GeographicBoundingBox":f
 unction(node,obj){obj.llbbox=[];this.readChildNodes(node,obj.llbbox);},"westBoundLongitude":function(node,obj){obj[0]=this.getChildValue(node);},"eastBoundLongitude":function(node,obj){obj[2]=this.getChildValue(node);},"southBoundLatitude":function(node,obj){obj[1]=this.getChildValue(node);},"northBoundLatitude":function(node,obj){obj[3]=this.getChildValue(node);},"MinScaleDenominator":function(node,obj){obj.maxScale=parseFloat(this.getChildValue(node)).toPrecision(16);},"MaxScaleDenominator":function(node,obj){obj.minScale=parseFloat(this.getChildValue(node)).toPrecision(16);},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol"),nearestVal:node.getAttribute("nearestValue")==="1",multipleVal:node.getAttribute("multipleValues")==="1","default":node.getAttribute("default")||"",current:node.getAttribute("current")==="1",values:this.getChildValue(node).split(
 ",")};obj.dimensions[dim.name]=dim;},"Keyword":function(node,obj){var keyword={value:this.getChildValue(node),vocabulary:node.getAttribute("vocabulary")};if(obj.keywords){obj.keywords.push(keyword);}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"]),"sld":{"UserDefinedSymbolization":function(node,obj){this.readers.wms.UserDefinedSymbolization.apply(this,[node,obj]);obj.userSymbols.inlineFeature=parseInt(node.getAttribute("InlineFeature"))==1;obj.userSymbols.remoteWCS=parseInt(node.getAttribute("RemoteWCS"))==1;},"DescribeLayer":function(node,obj){this.readers.wms.DescribeLayer.apply(this,[node,obj]);},"GetLegendGraphic":function(node,obj){this.readers.wms.GetLegendGraphic.apply(this,[node,obj]);}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3"});OpenLayers.Format.WMSCapabilities.v1_3_0=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_3,{version:"1.3.0",CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3_0"});OpenLayers.Process.WPS=OpenLayers.Class(Op
 enLayers.Process,{map:null,format:null,url:"",identifier:"",request:null,processDescription:null,executeOnInputReady:false,callbacks:null,checkStatusInterval:2000,initialize:function(options){OpenLayers.Process.prototype.initialize.apply(this,[options]);if((!this.url)||this.url==""){OpenLayers.Console.error("...invalid wps end point url...");throw"...invalid wps end point url...";}
@@ -3145,12 +3173,12 @@
 this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var format=this.format;var data=OpenLayers.Format.XML.prototype.write.apply(format,[format.writeNode("sos:GetFeatureOfInterest",{fois:this.fois})]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),data:data});return response;},handleRead:function(response,options){if(options.callback){var request=response.priv;if(request.status>=200&&request.status<300){response.features=this.parseFeatures(request);response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
 options.callback.call(options.scope,response);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
 if(!doc||doc.length<=0){return null;}
-return this.format.read(doc);},CLASS_NAME:"OpenLayers.Protocol.SOS.v1_0_0"});OpenLayers.Layer.KaMapCache=OpenLayers.Class(OpenLayers.Layer.KaMap,{IMAGE_EXTENSIONS:{'jpeg':'jpg','gif':'gif','png':'png','png8':'png','png24':'png','dithered':'png'},DEFAULT_FORMAT:'jpeg',initialize:function(name,url,params,options){OpenLayers.Layer.KaMap.prototype.initialize.apply(this,arguments);this.extension=this.IMAGE_EXTENSIONS[this.params.i.toLowerCase()||DEFAULT_FORMAT];},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);var metaX=Math.floor(pX/this.tileSize.w/this.params.metaTileSize.w)*this.tileSize.w*this.params.metaTileSize.w;var metaY=Math.floor(pY/this.tileSize.h/this.params.metaTileSize.h)*this.tileSize.h*this.params.metaTileSize.h;var url=this.url;if(url instanceof Array){url=this.selectUrl(paramsString,url);
+return this.format.read(doc);},CLASS_NAME:"OpenLayers.Protocol.SOS.v1_0_0"});OpenLayers.Layer.KaMapCache=OpenLayers.Class(OpenLayers.Layer.KaMap,{IMAGE_EXTENSIONS:{'jpeg':'jpg','gif':'gif','png':'png','png8':'png','png24':'png','dithered':'png'},DEFAULT_FORMAT:'jpeg',initialize:function(name,url,params,options){OpenLayers.Layer.KaMap.prototype.initialize.apply(this,arguments);this.extension=this.IMAGE_EXTENSIONS[this.params.i.toLowerCase()||DEFAULT_FORMAT];},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);var metaX=Math.floor(pX/this.tileSize.w/this.params.metaTileSize.w)*this.tileSize.w*this.params.metaTileSize.w;var metaY=Math.floor(pY/this.tileSize.h/this.params.metaTileSize.h)*this.tileSize.h*this.params.metaTileSize.h;var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(paramsStri
 ng,url);}
 var components=[url,"/",this.params.map,"/",scale,"/",this.params.g.replace(/\s/g,'_'),"/def/t",metaY,"/l",metaX,"/t",pY,"l",pX,".",this.extension];return components.join("");},CLASS_NAME:"OpenLayers.Layer.KaMapCache"});OpenLayers.Feature.WFS=OpenLayers.Class(OpenLayers.Feature,{initialize:function(layer,xmlNode){var newArguments=arguments;var data=this.processXMLNode(xmlNode);newArguments=new Array(layer,data.lonlat,data);OpenLayers.Feature.prototype.initialize.apply(this,newArguments);this.createMarker();this.layer.addMarker(this.marker);},destroy:function(){if(this.marker!=null){this.layer.removeMarker(this.marker);}
 OpenLayers.Feature.prototype.destroy.apply(this,arguments);},processXMLNode:function(xmlNode){var point=OpenLayers.Ajax.getElementsByTagNameNS(xmlNode,"http://www.opengis.net/gml","gml","Point");var text=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0],"http://www.opengis.net/gml","gml","coordinates")[0]);var floats=text.split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(floats[0]),parseFloat(floats[1])),id:null};},CLASS_NAME:"OpenLayers.Feature.WFS"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,format:'image/png',serverResolutions:null,initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this.extension=this.format.split('/')[1].toLowerCase();this.extension=(this.extension=='jpg')?'jpeg':this.extension;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TileCache(this.name,this.url,this.layerna
 me,this.getOptions());}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var res=this.map.getResolution();var bbox=this.maxExtent;var size=this.tileSize;var tileX=Math.round((bounds.left-bbox.left)/(res*size.w));var tileY=Math.round((bounds.bottom-bbox.bottom)/(res*size.h));var tileZ=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom();function zeroPad(number,length){number=String(number);var zeros=[];for(var i=0;i<length;++i){zeros.push('0');}
 return zeros.join('').substring(0,length-number.length)+number;}
-var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
+var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(path,url);}
 url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Format.WMSCapabilities.v1_1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.1",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.applyDefaults({"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1"});OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1_1,{version:"1.1.1",profile:"WMSC",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.applyDefaults({"VendorSpecificCapabilities":function(node,obj){obj.vendorSpecific={tileSets:[]};this.readChildNodes(node,obj.vendorSpecif
 ic);},"TileSet":function(node,vendorSpecific){var tileset={srs:{},bbox:{},resolutions:[]};this.readChildNodes(node,tileset);vendorSpecific.tileSets.push(tileset);},"Resolutions":function(node,tileset){var res=this.getChildValue(node).split(" ");for(var i=0,len=res.length;i<len;i++){if(res[i]!=""){tileset.resolutions.push(parseFloat(res[i]));}}},"Width":function(node,tileset){tileset.width=parseInt(this.getChildValue(node));},"Height":function(node,tileset){tileset.height=parseInt(this.getChildValue(node));},"Layers":function(node,tileset){tileset.layers=this.getChildValue(node);},"Styles":function(node,tileset){tileset.styles=this.getChildValue(node);}},OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC"});OpenLayers.Format.WMSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.0",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initia
 lize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.applyDefaults({"SRS":function(node,obj){var srs=this.getChildValue(node);var values=srs.split(/ +/);for(var i=0,len=values.length;i<len;i++){obj.srs[values[i]]=true;}}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_0"});OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector,OpenLayers.Layer.Markers,{isBaseLayer:false,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:true,encodeBBOX:false,extractAttributes:false,initialize:function(name,url,params,options){if(options==undefined){options={};}
 if(options.featureClass||!OpenLayers.Layer.Vector||!OpenLayers.Feature.Vector){this.vectorMode=false;}
 params=OpenLayers.Util.upperCaseObject(params);OpenLayers.Util.extend(options,{'reportError':false});var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);if(!this.renderer||!this.vectorMode){this.vectorMode=false;if(!options.featureClass){options.featureClass=OpenLayers.Feature.WFS;}
@@ -3188,20 +3216,20 @@
 labelSpan.innerHTML=layer.name;labelSpan.style.verticalAlign=(baseLayer)?"bottom":"baseline";OpenLayers.Event.observe(labelSpan,"click",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var br=document.createElement("br");var groupArray=(baseLayer)?this.baseLayers:this.dataLayers;groupArray.push({'layer':layer,'inputElem':inputElem,'labelSpan':labelSpan});var groupDiv=(baseLayer)?this.baseLayersDiv:this.dataLayersDiv;groupDiv.appendChild(inputElem);groupDiv.appendChild(labelSpan);groupDiv.appendChild(br);}}
 this.dataLbl.style.display=(containsOverlays)?"":"none";this.baseLbl.style.display=(containsBaseLayers)?"":"none";return this.div;},onInputClick:function(e){if(!this.inputElem.disabled){if(this.inputElem.type=="radio"){this.inputElem.checked=true;this.layer.map.setBaseLayer(this.layer);}else{this.inputElem.checked=!this.inputElem.checked;this.layerSwitcher.updateMap();}}
 OpenLayers.Event.stop(e);},onLayerClick:function(e){this.updateMap();},updateMap:function(){for(var i=0,len=this.baseLayers.length;i<len;i++){var layerEntry=this.baseLayers[i];if(layerEntry.inputElem.checked){this.map.setBaseLayer(layerEntry.layer,false);}}
-for(var i=0,len=this.dataLayers.length;i<len;i++){var layerEntry=this.dataLayers[i];layerEntry.layer.setVisibility(layerEntry.inputElem.checked);}},maximizeControl:function(e){this.div.style.width="";this.div.style.height="";this.showControls(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);if(e!=null){OpenLayers.Event.stop(e);}},showControls:function(minimize){this.maximizeDiv.style.display=minimize?"":"none";this.minimizeDiv.style.display=minimize?"none":"";this.layersDiv.style.display=minimize?"none":"";},loadContents:function(){OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layers
 Div=document.createElement("div");this.layersDiv.id=this.id+"_layersDiv";OpenLayers.Element.addClass(this.layersDiv,"layersDiv");this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("baseLayer");OpenLayers.Element.addClass(this.baseLbl,"baseLbl");this.baseLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.baseLayersDiv,"baseLayersDiv");this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("overlays");OpenLayers.Element.addClass(this.dataLbl,"dataLbl");this.dataLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.dataLayersDiv,"dataLayersDiv");if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layers
 Div.appendChild(this.baseLayersDiv);}
+for(var i=0,len=this.dataLayers.length;i<len;i++){var layerEntry=this.dataLayers[i];layerEntry.layer.setVisibility(layerEntry.inputElem.checked);}},maximizeControl:function(e){this.div.style.width="";this.div.style.height="";this.showControls(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);if(e!=null){OpenLayers.Event.stop(e);}},showControls:function(minimize){this.maximizeDiv.style.display=minimize?"":"none";this.minimizeDiv.style.display=minimize?"none":"";this.layersDiv.style.display=minimize?"none":"";},loadContents:function(){OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layers
 Div=document.createElement("div");this.layersDiv.id=this.id+"_layersDiv";OpenLayers.Element.addClass(this.layersDiv,"layersDiv");this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("Base Layer");OpenLayers.Element.addClass(this.baseLbl,"baseLbl");this.baseLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.baseLayersDiv,"baseLayersDiv");this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("Overlays");OpenLayers.Element.addClass(this.dataLbl,"dataLbl");this.dataLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.dataLayersDiv,"dataLayersDiv");if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layer
 sDiv.appendChild(this.baseLayersDiv);}
 this.div.appendChild(this.layersDiv);if(this.roundedCorner){OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",bgColor:"transparent",color:this.roundedCornerColor,blend:false});OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75);}
 var imgLocation=OpenLayers.Util.getImagesLocation();var sz=new OpenLayers.Size(18,18);var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,sz,img,"absolute");OpenLayers.Element.addClass(this.maximizeDiv,"maximizeDiv");this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';var sz=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,sz,img,"absolute");OpenLayers.Element.addClass(this.minimizeDiv,"minimizeDiv");this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);},ignoreEvent:function(evt){OpenLayers.
 Event.stop(evt);},mouseDown:function(evt){this.isMouseDown=true;this.ignoreEvent(evt);},mouseUp:function(evt){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(evt);}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Format.Atom=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{atom:"http://www.w3.org/2005/Atom",georss:"http://www.georss.org/georss"},feedTitle:"untitled",defaultEntryTitle:"untitled",gmlParser:null,xy:false,read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-return this.parseFeatures(doc);},write:function(features){var doc;if(features instanceof Array){doc=this.createElementNSPlus("atom:feed");doc.appendChild(this.createElementNSPlus("atom:title",{value:this.feedTitle}));for(var i=0,ii=features.length;i<ii;i++){doc.appendChild(this.buildEntryNode(features[i]));}}
+return this.parseFeatures(doc);},write:function(features){var doc;if(OpenLayers.Util.isArray(features)){doc=this.createElementNSPlus("atom:feed");doc.appendChild(this.createElementNSPlus("atom:title",{value:this.feedTitle}));for(var i=0,ii=features.length;i<ii;i++){doc.appendChild(this.buildEntryNode(features[i]));}}
 else{doc=this.buildEntryNode(features);}
 return OpenLayers.Format.XML.prototype.write.apply(this,[doc]);},buildContentNode:function(content){var node=this.createElementNSPlus("atom:content",{attributes:{type:content.type||null}});if(content.src){node.setAttribute("src",content.src);}else{if(content.type=="text"||content.type==null){node.appendChild(this.createTextNode(content.value));}else if(content.type=="html"){if(typeof content.value!="string"){throw"HTML content must be in form of an escaped string";}
 node.appendChild(this.createTextNode(content.value));}else if(content.type=="xhtml"){node.appendChild(content.value);}else if(content.type=="xhtml"||content.type.match(/(\+|\/)xml$/)){node.appendChild(content.value);}
 else{node.appendChild(this.createTextNode(content.value));}}
-return node;},buildEntryNode:function(feature){var attrib=feature.attributes;var atomAttrib=attrib.atom||{};var entryNode=this.createElementNSPlus("atom:entry");if(atomAttrib.authors){var authors=atomAttrib.authors instanceof Array?atomAttrib.authors:[atomAttrib.authors];for(var i=0,ii=authors.length;i<ii;i++){entryNode.appendChild(this.buildPersonConstructNode("author",authors[i]));}}
-if(atomAttrib.categories){var categories=atomAttrib.categories instanceof Array?atomAttrib.categories:[atomAttrib.categories];var category;for(var i=0,ii=categories.length;i<ii;i++){category=categories[i];entryNode.appendChild(this.createElementNSPlus("atom:category",{attributes:{term:category.term,scheme:category.scheme||null,label:category.label||null}}));}}
+return node;},buildEntryNode:function(feature){var attrib=feature.attributes;var atomAttrib=attrib.atom||{};var entryNode=this.createElementNSPlus("atom:entry");if(atomAttrib.authors){var authors=OpenLayers.Util.isArray(atomAttrib.authors)?atomAttrib.authors:[atomAttrib.authors];for(var i=0,ii=authors.length;i<ii;i++){entryNode.appendChild(this.buildPersonConstructNode("author",authors[i]));}}
+if(atomAttrib.categories){var categories=OpenLayers.Util.isArray(atomAttrib.categories)?atomAttrib.categories:[atomAttrib.categories];var category;for(var i=0,ii=categories.length;i<ii;i++){category=categories[i];entryNode.appendChild(this.createElementNSPlus("atom:category",{attributes:{term:category.term,scheme:category.scheme||null,label:category.label||null}}));}}
 if(atomAttrib.content){entryNode.appendChild(this.buildContentNode(atomAttrib.content));}
-if(atomAttrib.contributors){var contributors=atomAttrib.contributors instanceof Array?atomAttrib.contributors:[atomAttrib.contributors];for(var i=0,ii=contributors.length;i<ii;i++){entryNode.appendChild(this.buildPersonConstructNode("contributor",contributors[i]));}}
+if(atomAttrib.contributors){var contributors=OpenLayers.Util.isArray(atomAttrib.contributors)?atomAttrib.contributors:[atomAttrib.contributors];for(var i=0,ii=contributors.length;i<ii;i++){entryNode.appendChild(this.buildPersonConstructNode("contributor",contributors[i]));}}
 if(feature.fid){entryNode.appendChild(this.createElementNSPlus("atom:id",{value:feature.fid}));}
-if(atomAttrib.links){var links=atomAttrib.links instanceof Array?atomAttrib.links:[atomAttrib.links];var link;for(var i=0,ii=links.length;i<ii;i++){link=links[i];entryNode.appendChild(this.createElementNSPlus("atom:link",{attributes:{href:link.href,rel:link.rel||null,type:link.type||null,hreflang:link.hreflang||null,title:link.title||null,length:link.length||null}}));}}
+if(atomAttrib.links){var links=OpenLayers.Util.isArray(atomAttrib.links)?atomAttrib.links:[atomAttrib.links];var link;for(var i=0,ii=links.length;i<ii;i++){link=links[i];entryNode.appendChild(this.createElementNSPlus("atom:link",{attributes:{href:link.href,rel:link.rel||null,type:link.type||null,hreflang:link.hreflang||null,title:link.title||null,length:link.length||null}}));}}
 if(atomAttrib.published){entryNode.appendChild(this.createElementNSPlus("atom:published",{value:atomAttrib.published}));}
 if(atomAttrib.rights){entryNode.appendChild(this.createElementNSPlus("atom:rights",{value:atomAttrib.rights}));}
 if(atomAttrib.summary||attrib.description){entryNode.appendChild(this.createElementNSPlus("atom:summary",{value:atomAttrib.summary||attrib.description}));}
@@ -3236,4 +3264,5 @@
 if(this.internalProjection&&this.externalProjection){for(var i=0,ii=components.length;i<ii;i++){if(components[i]){components[i].transform(this.externalProjection,this.internalProjection);}}}
 return components;},parsePersonConstructs:function(node,name,data){var persons=[];var atomns=this.namespaces.atom;var nodes=this.getElementsByTagNameNS(node,atomns,name);var oAtts=["uri","email"];for(var i=0,ii=nodes.length;i<ii;i++){var value={};value.name=this.getFirstChildValue(nodes[i],atomns,"name",null);for(var j=0,jj=oAtts.length;j<jj;j++){var attval=this.getFirstChildValue(nodes[i],atomns,oAtts[j],null);if(attval){value[oAtts[j]]=attval;}}
 persons.push(value);}
-if(persons.length>0){data[name+"s"]=persons;}},CLASS_NAME:"OpenLayers.Format.Atom"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,slideFactor:75,draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keydown":this.defaultKeyPress});},defaultKeyPress:function(evt){switch(evt.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189
 :case 95:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});
\ No newline at end of file
+if(persons.length>0){data[name+"s"]=persons;}},CLASS_NAME:"OpenLayers.Format.Atom"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,slideFactor:75,draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keydown":this.defaultKeyPress});},defaultKeyPress:function(evt){switch(evt.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189
 :case 95:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.Control.AgsFindTask=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:false,asynchronous:false,initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.taskParameters={"contains":false,"outSpatialReference":null,"returnGeometry":true,"layerIds":[],"searchFields":[],"searchText":""};this._resultsParser={'parser':this.adapter.parseAgsResults['findResults'],'context':this.adapter};this.execute=this._bindFunction(this.execute,this);this.active=false;this.activate=function(){return false;};this.deactivate=function(){return false;};},execute:function(taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCal
 lbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsFindTask=new esri.tasks.FindTask(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{var agsFindParameters=this.adapter.encodeAgsFindParameters(_taskParameters);}catch(e){throw e;}
+agsFindTask.execute(agsFindParameters,_onExecuteComplete,_onCompleteError);}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsFindTask ...");throw"...'asynchronous' should always be set to 'false' for AgsFindTask ...";}},CLASS_NAME:"OpenLayers.Control.AgsFindTask"});
Modified: sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock/v1.js
--- sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock/v1.js	2011-07-07 16:41:02 UTC (rev 12160)
+++ sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock/v1.js	2011-07-09 00:05:04 UTC (rev 12161)
@@ -4,6 +4,7 @@
  * @requires OpenLayers/Format/XML.js
+ * @requires OpenLayers/Format/WFSTWithLock.js
  * @requires OpenLayers/Format/WFST/v1.js
Modified: sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock/v1_1_0.js
--- sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock/v1_1_0.js	2011-07-07 16:41:02 UTC (rev 12160)
+++ sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock/v1_1_0.js	2011-07-09 00:05:04 UTC (rev 12161)
@@ -1,4 +1,4 @@
  * @requires OpenLayers/Format/WFSTWithLock/v1.js
  * @requires OpenLayers/Format/GML/v3.js
  * @requires OpenLayers/Format/Filter/v1_1_0.js
Modified: sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock.js
--- sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock.js	2011-07-07 16:41:02 UTC (rev 12160)
+++ sandbox/august/trunk/lib/OpenLayers/Format/WFSTWithLock.js	2011-07-09 00:05:04 UTC (rev 12161)
@@ -18,7 +18,7 @@
         throw "Unsupported WFSTWithLock version: " + options.version;
     return new cls(options);
  * Constant: OpenLayers.Format.WFSTWithLock.DEFAULTS
Modified: sandbox/august/trunk/lib/OpenLayers.js
--- sandbox/august/trunk/lib/OpenLayers.js	2011-07-07 16:41:02 UTC (rev 12160)
+++ sandbox/august/trunk/lib/OpenLayers.js	2011-07-09 00:05:04 UTC (rev 12161)
@@ -276,6 +276,7 @@
             "OpenLayers/Rule.js",
             "OpenLayers/Format.js",
             "OpenLayers/Format/XML.js",
+            "OpenLayers/Format/XML/VersionedOGC.js",
             "OpenLayers/Format/Context.js",
             "OpenLayers/Format/ArcXML.js",
             "OpenLayers/Format/ArcXML/Features.js",
@@ -306,6 +307,7 @@
             "OpenLayers/Format/SLD.js",
             "OpenLayers/Format/SLD/v1.js",
             "OpenLayers/Format/SLD/v1_0_0.js",
+            "OpenLayers/Format/OWSCommon.js",
             "OpenLayers/Format/OWSCommon/v1.js",
             "OpenLayers/Format/OWSCommon/v1_0_0.js",
             "OpenLayers/Format/OWSCommon/v1_1_0.js",
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857.html
--- sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857.html	2011-07-07 16:41:02 UTC (rev 12160)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857.html	2011-07-09 00:05:04 UTC (rev 12161)
@@ -4,11 +4,12 @@
 		<title>OpenLayers WMTS (ArcGIS Server) Example</title>
 		<link rel="stylesheet" href="../../theme/default/style.css" type="text/css"/>
 		<link rel="stylesheet" href="../style.css" type="text/css" />
 		<script type="text/javascript" src="../../lib/Firebug/firebug.js"></script>
 		<script type="text/javascript" src="../../lib/OpenLayers.js"></script>
-		<script type="text/javascript" src="../../OpenLayers.js"></script>
+		<script type="text/javascript" src="../../OpenLayers.js"></script>
 		<script type="text/javascript" src="wmts-ags-epsg3857.js"></script>
 	</head>
 	<body onload="init();">
More information about the Commits mailing list
