[OpenLayers-Commits] r12174 - in sandbox/august/trunk: . examples examples/tasmania lib/OpenLayers lib/OpenLayers/Format lib/OpenLayers/Format/GML lib/OpenLayers/Format/WFST lib/OpenLayers/Layer lib/OpenLayers/Protocol/WFS lib/OpenLayers/Renderer tests tests/Format tests/Format/WFST tests/Renderer tests/manual
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Jul 20 13:26:53 EDT 2011
Author: augusttown
Date: 2011-07-20 10:26:52 -0700 (Wed, 20 Jul 2011)
New Revision: 12174
Added:
   sandbox/august/trunk/examples/label-scale.html
   sandbox/august/trunk/examples/label-scale.js
   sandbox/august/trunk/examples/sld.js
   sandbox/august/trunk/tests/manual/svg2-coordinaterange.html
   sandbox/august/trunk/examples/mobile-jq.js
   sandbox/august/trunk/examples/sld.html
   sandbox/august/trunk/examples/tasmania/sld-tasmania.xml
   sandbox/august/trunk/lib/OpenLayers/Control.js
   sandbox/august/trunk/lib/OpenLayers/Format/GML/Base.js
   sandbox/august/trunk/lib/OpenLayers/Format/GML/v3.js
   sandbox/august/trunk/lib/OpenLayers/Format/WFST/v1.js
   sandbox/august/trunk/lib/OpenLayers/Format/WKT.js
   sandbox/august/trunk/lib/OpenLayers/Layer/Vector.js
   sandbox/august/trunk/lib/OpenLayers/Protocol/WFS/v1.js
   sandbox/august/trunk/lib/OpenLayers/Renderer/NG.js
   sandbox/august/trunk/lib/OpenLayers/Renderer/SVG2.js
   sandbox/august/trunk/lib/OpenLayers/Util.js
   sandbox/august/trunk/tests/Format/WFST/v1.html
   sandbox/august/trunk/tests/Format/WKT.html
   sandbox/august/trunk/tests/Renderer/SVG2.html
   sandbox/august/trunk/tests/Util.html
Merge with trunk @ revision 12173
Property changes on: sandbox/august/trunk
___________________________________________________________________
Modified: svn:mergeinfo
   - /trunk/openlayers:10329-10354,10357-10502,10504-12158
   + /trunk/openlayers:10329-10354,10357-10502,10504-12173
Copied: sandbox/august/trunk/examples/label-scale.html (from rev 12173, trunk/openlayers/examples/label-scale.html)
--- sandbox/august/trunk/examples/label-scale.html	                        (rev 0)
+++ sandbox/august/trunk/examples/label-scale.html	2011-07-20 17:26:52 UTC (rev 12174)
@@ -0,0 +1,34 @@
+<!DOCTYPE html>
+<html>
+  <head>
+    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
+    <meta name="apple-mobile-web-app-capable" content="yes">
+    <title>OpenLayers Scale Dependent Labels</title>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+    <link rel="stylesheet" href="style.css" type="text/css">
+    <script src="../lib/OpenLayers.js"></script>
+  </head>
+  <body>
+    <h1 id="title">Scale Dependent Labels Example</h1>
+    <div id="tags">
+        label, scale, stylemap
+    </div>
+    <p id="shortdesc">
+        Demonstrates how to use a StyleMap for displaying scale dependent labels.
+    </p>
+    <div id="map" class="smallmap"></div>
+    <div id="docs">
+        <p>
+            This example uses rule based styling to change the how features are
+            labeled at different scales.  An <code>OpenLayers.Rule</code> object
+            can have <code>minScaleDenominator</code> and
+            <code>maxScaleDenominator</code> properties to control when the
+            provided symbolizer should be used.
+        </p><p>
+            View the <a href="label-scale.js">source</a> to see how this is done.
+        </p>
+    </div>
+    <script src="label-scale.js"></script>
+  </body>
+</html>
Copied: sandbox/august/trunk/examples/label-scale.js (from rev 12173, trunk/openlayers/examples/label-scale.js)
--- sandbox/august/trunk/examples/label-scale.js	                        (rev 0)
+++ sandbox/august/trunk/examples/label-scale.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -0,0 +1,72 @@
+// Create 50 random features, and give them a "type" attribute that
+// will be used for the label text.
+var features = new Array(50);
+for (var i=0; i<features.length; i++) {
+    features[i] = new OpenLayers.Feature.Vector(
+        new OpenLayers.Geometry.Point(
+            (360 * Math.random()) - 180, (180 * Math.random()) - 90
+            type: 5 + parseInt(5 * Math.random())
+ * Create a style instance that is a collection of rules with symbolizers.
+ * Use a default symbolizer to extend symoblizers for all rules.
+var style = new OpenLayers.Style({
+    fillColor: "#ffcc66",
+    strokeColor: "#ff9933",
+    strokeWidth: 2,
+    label: "${type}",
+    fontColor: "#333333",
+    fontFamily: "sans-serif",
+    fontWeight: "bold"
+    rules: [
+        new OpenLayers.Rule({
+            minScaleDenominator: 200000000,
+            symbolizer: {
+                pointRadius: 7,
+                fontSize: "9px"
+            maxScaleDenominator: 200000000,
+            minScaleDenominator: 100000000,
+            symbolizer: {
+                pointRadius: 10,
+                fontSize: "12px"
+            maxScaleDenominator: 100000000,
+            symbolizer: {
+                pointRadius: 13,
+                fontSize: "15px"
+// Create a vector layer and give it your style map.
+var points = new OpenLayers.Layer.Vector("Points", {
+    styleMap: new OpenLayers.StyleMap(style)
+points.addFeatures(features);
+var map = new OpenLayers.Map({
+    div: "map",
+    layers: [
+        new OpenLayers.Layer.WMS(
+            "OpenLayers WMS",
+            "http://vmap0.tiles.osgeo.org/wms/vmap0",
+            {layers: "basic"}
+        points
+    center: new OpenLayers.LonLat(0, 0),
+    zoom: 1
Modified: sandbox/august/trunk/examples/mobile-jq.js
--- sandbox/august/trunk/examples/mobile-jq.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/examples/mobile-jq.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -1,3 +1,6 @@
+// Start with the map page
+window.location.replace(window.location.href.split("#")[0] + "#mappage");
 var selectedFeature = null;
 $(document).ready(function() {
@@ -2,18 +5,14 @@
-    // Start with the map page
-    if (window.location.hash && window.location.hash!='#mappage') {
-        $.mobile.changePage('mappage');
     // fix height of content
     function fixContentHeight() {
         var footer = $("div[data-role='footer']:visible"),
-        content = $("div[data-role='content']:visible:visible"),
-        viewHeight = $(window).height(),
-        contentHeight = viewHeight - footer.outerHeight();
+            content = $("div[data-role='content']:visible:visible"),
+            viewHeight = $(window).height(),
+            contentHeight = viewHeight - footer.outerHeight();
         if ((content.outerHeight() + footer.outerHeight()) !== viewHeight) {
-            contentHeight -= (content.outerHeight() - content.height());
+            contentHeight -= (content.outerHeight() - content.height() + 1);
             content.height(contentHeight);
         if (window.map) {
@@ -24,13 +23,13 @@
             // initialize map
             init(function(feature) {
                 selectedFeature = feature;
-                $.mobile.changePage($("#popup"), "pop");
+                $.mobile.changePage("#popup", "pop");
+            initLayerList();
     $(window).bind("orientationchange resize pageshow", fixContentHeight);
-    fixContentHeight();
-    //init();
+    document.body.onload = fixContentHeight;
     // Map zoom
     $("#plus").click(function(){
@@ -48,7 +47,7 @@
-    $('div#popup').live('pageshow',function(event, ui){
+    $('#popup').live('pageshow',function(event, ui){
         var li = "";
         for(var attr in selectedFeature.attributes){
             li += "<li><div style='width:25%;float:left'>" + attr + "</div><div style='width:75%;float:right'>"
@@ -83,7 +82,7 @@
                         .appendTo('#search_results')
                         .click(function() {
+                            $.mobile.changePage('#mappage');
                             var lonlat = new OpenLayers.LonLat(place.lng, place.lat);
                             map.setCenter(lonlat.transform(gg, sm), 10);
@@ -97,7 +96,10 @@
         $('#searchpage').die('pageshow', arguments.callee);
-    $('#layerslist').listview();
+function initLayerList() {
+    $('#layerspage').page();
     $('<li>', {
             "data-role": "list-divider",
             text: "Base Layers"
@@ -122,7 +124,7 @@
     map.events.register("addlayer", this, function(e) {
         addLayerToList(e.layer);
 function addLayerToList(layer) {
     var item = $('<li>', {
@@ -133,7 +135,7 @@
             text: layer.name
             .click(function() {
                 if (layer.isBaseLayer) {
                     layer.map.setBaseLayer(layer);
                 } else {
Modified: sandbox/august/trunk/examples/sld.html
--- sandbox/august/trunk/examples/sld.html	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/examples/sld.html	2011-07-20 17:26:52 UTC (rev 12174)
@@ -6,92 +6,9 @@
-    <script src="../lib/Firebug/firebug.js"></script>
+    <!--script src="../lib/Firebug/firebug.js"></script-->
-    <script type="text/javascript">
-        var map, sld, gmlLayers;
-        var format = new OpenLayers.Format.SLD();
-        function init() {
-            map = new OpenLayers.Map('map');
-            map.addControl(new OpenLayers.Control.LayerSwitcher());
-            OpenLayers.loadURL("tasmania/sld-tasmania.xml", null, null, complete);
-        function getDefaultStyle(sld, layerName) {
-            var styles = sld.namedLayers[layerName].userStyles;
-            var style;
-            for(var i=0; i<styles.length; ++i) {
-                style = styles[i];
-                if(style.isDefault) {
-                    break;
-            return style;
-        function complete(req) {
-            sld = format.read(req.responseXML || req.responseText);
-            var hoverStyle = sld.namedLayers["WaterBodies"].userStyles[1];
-            hoverStyle.defaultStyle = OpenLayers.Util.extend(
-                {}, OpenLayers.Feature.Vector.style["select"]
-            gmlLayers = [
-                // use the sld UserStyle named "Default Styler"
-                new OpenLayers.Layer.GML(
-                    "StateBoundaries",
-                    "tasmania/TasmaniaStateBoundaries.xml",
-                        styleMap: new OpenLayers.StyleMap(
-                            getDefaultStyle(sld, "Land")
-                        isBaseLayer: true
-                    "Roads",
-                    "tasmania/TasmaniaRoads.xml",
-                    {styleMap: new OpenLayers.StyleMap(getDefaultStyle(sld, "Roads"))}
-                    "WaterBodies",
-                    "tasmania/TasmaniaWaterBodies.xml",
-                        styleMap: new OpenLayers.StyleMap({
-                            "default": getDefaultStyle(sld, "WaterBodies"),
-                            "select": hoverStyle
-                    "Cities",
-                    "tasmania/TasmaniaCities.xml",
-                    {styleMap: new OpenLayers.StyleMap(getDefaultStyle(sld, "Cities"))}
-            map.addLayers(gmlLayers);
-            map.zoomToExtent(new OpenLayers.Bounds(143,-39,150,-45));
-            var hover = new OpenLayers.Control.SelectFeature(
-                gmlLayers[2], {hover: true}
-            map.addControl(hover);
-            hover.activate();
-        // set a new style when the radio button changes
-        function setStyle(index) {
-            gmlLayers[2].styleMap.styles["default"] = sld.namedLayers["WaterBodies"].userStyles[index];
-            // change the style of the features of the WaterBodies layer
-            gmlLayers[2].redraw();
-    </script>
+    <script src="sld.js"></script>
   </head>
   <body onload="init()">
     <h1 id="title">Styled Layer Descriptor (SLD) Example</h1>
@@ -105,19 +22,10 @@
     <p id="docs">This example uses a <a target="_blank" href="tasmania/sld-tasmania.xml">SLD
     file</a> to style the vector features. To construct layers that use styles
     from SLD, create a StyleMap for the layer that uses one of the userStyles in the
-    namedLayers object of the return from format.read().</p>
+    namedLayers object of the return from format.read(). Look at the <a href="sld.js">sld.js source</a>
+    to see how this is done.</p>
     <p>Select a new style for the WaterBodies layer below:</p>
-    <form>
-      <input type="radio" name="style" onclick="setStyle(this.value)" checked="checked" value="0">Default Styler (zoom in to see more features)</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="3">Styler Test PropertyIsEqualTo</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="4">Styler Test WATER_TYPE</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="5">Styler Test PropertyIsGreaterThanOrEqualTo</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="6">Styler Test PropertyIsLessThanOrEqualTo</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="7">Styler Test PropertyIsGreaterThan</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="8">Styler Test PropertyIsLessThan</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="9">Styler Test PropertyIsLike</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="10">Styler Test PropertyIsBetween</input><br>
-      <input type="radio" name="style" onclick="setStyle(this.value)" value="11">Styler Test FeatureId</input><br>
-    </form>
+    <ul id="style_chooser">
+    </ul>
   </body>
 </html>
Copied: sandbox/august/trunk/examples/sld.js (from rev 12173, trunk/openlayers/examples/sld.js)
--- sandbox/august/trunk/examples/sld.js	                        (rev 0)
+++ sandbox/august/trunk/examples/sld.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -0,0 +1,99 @@
+var map, sld, waterBodies;
+var format = new OpenLayers.Format.SLD();
+function init() {
+    map = new OpenLayers.Map('map', {allOverlays: true});
+    var layers = createLayers();
+    map.addLayers(layers);
+    waterBodies = layers[2];
+    map.addControl(new OpenLayers.Control.SelectFeature(
+        waterBodies, {hover: true, autoActivate: true}
+    map.addControl(new OpenLayers.Control.LayerSwitcher());
+    OpenLayers.loadURL("tasmania/sld-tasmania.xml", null, null, complete);
+// handler for the loadURL function in the init method
+function complete(req) {
+    sld = format.read(req.responseXML || req.responseText);
+    buildStyleChooser();
+    setLayerStyles();
+    map.zoomToExtent(new OpenLayers.Bounds(143,-39,150,-45));
+function createLayers() {
+    // the name of each layer matches a NamedLayer name in the SLD document
+    var layerData = [{
+        name: "Land",
+        url: "tasmania/TasmaniaStateBoundaries.xml"
+        name: "Roads",
+        url: "tasmania/TasmaniaRoads.xml"
+        name: "WaterBodies",
+        url: "tasmania/TasmaniaWaterBodies.xml"
+        name: "Cities",
+        url: "tasmania/TasmaniaCities.xml"
+    var layers = [];
+    for (var i=0,ii=layerData.length; i<ii; ++i) {
+        layers.push(new OpenLayers.Layer.Vector(
+            layerData[i].name, {
+                protocol: new OpenLayers.Protocol.HTTP({
+                    url: layerData[i].url,
+                    format: new OpenLayers.Format.GML.v2()
+                strategies: [new OpenLayers.Strategy.Fixed()],
+                // empty style map, will be populated in setLayerStyles
+                styleMap: new OpenLayers.StyleMap()
+    return layers;
+function setLayerStyles() {
+    // set the default style for each layer from sld
+    for (var l in sld.namedLayers) {
+        var styles = sld.namedLayers[l].userStyles, style;
+        for (var i=0,ii=styles.length; i<ii; ++i) {
+            style = styles[i];
+            if (style.isDefault) {
+                map.getLayersByName(l)[0].styleMap.styles["default"] = style;
+                break;
+    // select style for mouseover on WaterBodies objects
+    waterBodies.styleMap.styles.select = sld.namedLayers["WaterBodies"].userStyles[1];
+// add a radio button for each userStyle
+function buildStyleChooser() {
+    var styles = sld.namedLayers["WaterBodies"].userStyles;
+    var chooser = document.getElementById("style_chooser"), input, li;
+        input = document.createElement("input");
+        input.type = "radio";
+        input.name = "style";
+        input.value = i;
+        input.checked = i == 0;
+        input.onclick = function() { setStyle(this.value); };
+        li = document.createElement("li");
+        li.appendChild(input);
+        li.appendChild(document.createTextNode(styles[i].title));
+        chooser.appendChild(li);
+// set a new style when the radio button changes
+function setStyle(index) {
+    waterBodies.styleMap.styles["default"] = sld.namedLayers["WaterBodies"].userStyles[index];
+    // apply the new style of the features of the Water Bodies layer
+    waterBodies.redraw();
Modified: sandbox/august/trunk/examples/tasmania/sld-tasmania.xml
--- sandbox/august/trunk/examples/tasmania/sld-tasmania.xml	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/examples/tasmania/sld-tasmania.xml	2011-07-20 17:26:52 UTC (rev 12174)
@@ -10,7 +10,7 @@
     <sld:Name>WaterBodies</sld:Name>
     <sld:UserStyle>
       <sld:Name>Default Styler</sld:Name>
-      <sld:Title>Default Styler</sld:Title>
+      <sld:Title>Default Styler (zoom in to see more objects)</sld:Title>
       <sld:Abstract></sld:Abstract>
       <sld:IsDefault>1</sld:IsDefault>
       <sld:FeatureTypeStyle>
Modified: sandbox/august/trunk/lib/OpenLayers/Control.js
--- sandbox/august/trunk/lib/OpenLayers/Control.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Control.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -116,8 +116,9 @@
     autoActivate: false,
-     * Property: active
-     * {Boolean} The control is active.
+     * APIProperty: active
+     * {Boolean} The control is active (read-only).  Use <activate> and
+     *     <deactivate> to change control state.
     active: null,
Modified: sandbox/august/trunk/lib/OpenLayers/Format/GML/Base.js
--- sandbox/august/trunk/lib/OpenLayers/Format/GML/Base.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Format/GML/Base.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -504,8 +504,9 @@
             "MultiPoint": function(geometry) {
                 var node = this.createElementNSPlus("gml:MultiPoint");
-                for(var i=0; i<geometry.components.length; ++i) {
-                    this.writeNode("pointMember", geometry.components[i], node);
+                var components = geometry.components || [geometry];
+                for(var i=0, ii=components.length; i<ii; ++i) {
+                    this.writeNode("pointMember", components[i], node);
                 return node;
@@ -516,8 +517,9 @@
             "MultiLineString": function(geometry) {
                 var node = this.createElementNSPlus("gml:MultiLineString");
-                    this.writeNode("lineStringMember", geometry.components[i], node);
+                    this.writeNode("lineStringMember", components[i], node);
                 return node;
@@ -528,9 +530,10 @@
             "MultiPolygon": function(geometry) {
                 var node = this.createElementNSPlus("gml:MultiPolygon");
                     this.writeNode(
-                        "polygonMember", geometry.components[i], node
+                        "polygonMember", components[i], node
                 return node;
Modified: sandbox/august/trunk/lib/OpenLayers/Format/GML/v3.js
--- sandbox/august/trunk/lib/OpenLayers/Format/GML/v3.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Format/GML/v3.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -378,8 +378,9 @@
             "MultiCurve": function(geometry) {
                 var node = this.createElementNSPlus("gml:MultiCurve");
-                for(var i=0, len=geometry.components.length; i<len; ++i) {
-                    this.writeNode("curveMember", geometry.components[i], node);
+                for(var i=0, len=components.length; i<len; ++i) {
+                    this.writeNode("curveMember", components[i], node);
                 return node;
@@ -394,8 +395,9 @@
             "MultiSurface": function(geometry) {
                 var node = this.createElementNSPlus("gml:MultiSurface");
-                    this.writeNode("surfaceMember", geometry.components[i], node);
+                    this.writeNode("surfaceMember", components[i], node);
                 return node;
Modified: sandbox/august/trunk/lib/OpenLayers/Format/WFST/v1.js
--- sandbox/august/trunk/lib/OpenLayers/Format/WFST/v1.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Format/WFST/v1.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -71,7 +71,7 @@
      * {Object} Maps feature states to node names.
     stateName: null,
      * Constructor: OpenLayers.Format.WFST.v1
      * Instances of this class are not created directly.  Use the
@@ -190,6 +190,10 @@
      *     in *modified.attributes* will be included. If *modified.geometry*
      *     is not set, the geometry will not be included.
+     * Valid options include:
+     * - *multi* {Boolean} If set to true, geometries will be casted to
+     *   Multi geometries before writing.
      * Returns:
      * {String} A serialized WFS transaction.
@@ -220,6 +224,7 @@
                     attributes: {
                         service: "WFS",
                         version: this.version,
+                        handle: options && options.handle,
                         outputFormat: options && options.outputFormat,
                         maxFeatures: options && options.maxFeatures,
                         "xsi:schemaLocation": this.schemaLocationAttr(options)
@@ -236,26 +241,43 @@
                 return node;
             "Transaction": function(obj) {
+                obj = obj || {};
+                var options = obj.options || {};
                 var node = this.createElementNSPlus("wfs:Transaction", {
                     attributes: {
                         service: "WFS",
-                        version: this.version
+                        version: this.version,
+                        handle: options.handle
                 var i, len;
-                var features = obj && obj.features;
-                var options = obj && obj.options;
+                var features = obj.features;
                 if(features) {
+                    // temporarily re-assigning geometry types
+                    if (options.multi === true) {
+                        OpenLayers.Util.extend(this.geometryTypes, {
+                            "OpenLayers.Geometry.Point": "MultiPoint",
+                            "OpenLayers.Geometry.LineString": (this.multiCurve === true) ? "MultiCurve": "MultiLineString",
+                            "OpenLayers.Geometry.Polygon": (this.multiSurface === true) ? "MultiSurface" : "MultiPolygon"
                     var name, feature;
                     for(i=0, len=features.length; i<len; ++i) {
                         feature = features[i];
                         name = this.stateName[feature.state];
                         if(name) {
-                            this.writeNode(name, feature, node);
+                            this.writeNode(name, {
+                                feature: feature,
+                                options: options
+                            }, node);
+                    // switch back to original geometry types assignment
+                        this.setGeometryTypes();
-                if (options && options.nativeElements) {
+                if (options.nativeElements) {
                     for (i=0, len=options.nativeElements.length; i<len; ++i) {
                         this.writeNode("wfs:Native",
                             options.nativeElements[i], node);
@@ -273,15 +295,24 @@
                 return node;
-            "Insert": function(feature) {
-                var node = this.createElementNSPlus("wfs:Insert");
+            "Insert": function(obj) {
+                var feature = obj.feature;
+                var options = obj.options;
+                var node = this.createElementNSPlus("wfs:Insert", {
+                    attributes: {
                 this.srsName = this.getSrsName(feature);
                 this.writeNode("feature:_typeName", feature, node);
                 return node;
-            "Update": function(feature) {
+            "Update": function(obj) {
                 var node = this.createElementNSPlus("wfs:Update", {
                     attributes: {
                         typeName: (this.featureNS ? this.featurePrefix + ":" : "") +
                             this.featureType
@@ -339,9 +370,12 @@
                 return node;
-            "Delete": function(feature) {
+            "Delete": function(obj) {
                 var node = this.createElementNSPlus("wfs:Delete", {
                     attributes: {
                             this.featureType
Modified: sandbox/august/trunk/lib/OpenLayers/Format/WKT.js
--- sandbox/august/trunk/lib/OpenLayers/Format/WKT.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Format/WKT.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -276,7 +276,7 @@
         'multipoint': function(str) {
             var point;
-            var points = OpenLayers.String.trim(str).split(this.regExes.parenComma);
+            var points = OpenLayers.String.trim(str).split(',');
             var components = [];
             for(var i=0, len=points.length; i<len; ++i) {
                 point = points[i].replace(this.regExes.trimParens, '$1');
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/Vector.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/Vector.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/Vector.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -474,7 +474,7 @@
         var ng = (OpenLayers.Renderer.NG && this.renderer instanceof OpenLayers.Renderer.NG);
         if (ng) {
-            zoomChanged && this.renderer.updateDimensions();
+            dragging || this.renderer.updateDimensions(zoomChanged);
         } else {
             var coordSysUnchanged = true;
Modified: sandbox/august/trunk/lib/OpenLayers/Protocol/WFS/v1.js
--- sandbox/august/trunk/lib/OpenLayers/Protocol/WFS/v1.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Protocol/WFS/v1.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -105,6 +105,9 @@
      * geometryName - {String} Name of geometry attribute.  If featureNS is not
      *     configured, the default is null to avoid failing on BBOX filters,
      *     and it will be set on <read>. Otherwise, the default is 'the_geom'.
+     * multi - {Boolean} If set to true, geometries will be casted to Multi
+     *     geometries before they are written in a transaction. No casting will
+     *     be done when reading features.
     initialize: function(options) {
         OpenLayers.Protocol.prototype.initialize.apply(this, [options]);
Modified: sandbox/august/trunk/lib/OpenLayers/Renderer/NG.js
--- sandbox/august/trunk/lib/OpenLayers/Renderer/NG.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Renderer/NG.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -38,10 +38,14 @@
      * To be extended by subclasses - here we set positioning related styles
      * on HTML elements, subclasses have to do the same for renderer specific
      * elements (e.g. viewBox, width and height of the rendererRoot)
+     * Parameters:
+     * zoomChanged - {Boolean} Has the zoom changed? If so, subclasses may have
+     *     to update feature styles/dimensions.
-    updateDimensions: function() {
+    updateDimensions: function(zoomChanged) {
         var mapExtent = this.map.getExtent();
-        var renderExtent = this.map.getMaxExtent();
+        var renderExtent = mapExtent.scale(3);
         this.setExtent(renderExtent, true);
         var res = this.getResolution();
         var div = this.rendererRoot.parentNode;
Modified: sandbox/august/trunk/lib/OpenLayers/Renderer/SVG2.js
--- sandbox/august/trunk/lib/OpenLayers/Renderer/SVG2.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Renderer/SVG2.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -73,8 +73,11 @@
      * Method: updateDimensions
+     * Parameters:
         OpenLayers.Renderer.NG.prototype.updateDimensions.apply(this, arguments);
@@ -92,20 +95,22 @@
         this.rendererRoot.setAttributeNS(null, "width", width / res);
         this.rendererRoot.setAttributeNS(null, "height", height / res);
-        // update styles for the new resolution
-        var i, len;
-        var nodes = this.vectorRoot.childNodes;
-        for (i=0, len=nodes.length; i<len; ++i) {
-            this.setStyle(nodes[i]);
+        if (zoomChanged === true) {
+            // update styles for the new resolution
+            var i, len;
+            var nodes = this.vectorRoot.childNodes;
+            for (i=0, len=nodes.length; i<len; ++i) {
+                this.setStyle(nodes[i]);
+            var textNodes = this.textRoot.childNodes;
+            var label;
+            for (i=0, len=textNodes.length; i<len; ++i) {
+                label = textNodes[i];
+                this.drawText(label, label._style,
+                    new OpenLayers.Geometry.Point(label._x, label._y)
-        var textNodes = this.textRoot.childNodes;
-        var label;
-        for (i=0, len=textNodes.length; i<len; ++i) {
-            label = textNodes[i];
-            this.drawText(label, label._style,
-                new OpenLayers.Geometry.Point(label._x, label._y)
Modified: sandbox/august/trunk/lib/OpenLayers/Util.js
--- sandbox/august/trunk/lib/OpenLayers/Util.js	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/lib/OpenLayers/Util.js	2011-07-20 17:26:52 UTC (rev 12174)
@@ -1865,6 +1865,9 @@
     if (!dmsOption) {
         dmsOption = 'dms';    //default to show degree, minutes, seconds
+	coordinate = (coordinate+540)%360 - 180; // normalize for sphere being round
     var abscoordinate = Math.abs(coordinate);
     var coordinatedegrees = Math.floor(abscoordinate);
Modified: sandbox/august/trunk/tests/Format/WFST/v1.html
--- sandbox/august/trunk/tests/Format/WFST/v1.html	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/tests/Format/WFST/v1.html	2011-07-20 17:26:52 UTC (rev 12174)
@@ -47,11 +47,11 @@
         t.plan(7);
         var snippets = {
-            "GetFeature": {maxFeatures: 1, outputFormat: 'json'},
-            "Transaction": null,
-            "Insert": insertFeature,
-            "Update": updateFeature,
-            "Delete": deleteFeature
+            "GetFeature": {handle: "handle_g", maxFeatures: 1, outputFormat: 'json'},
+            "Transaction": {handle: "handle_t"},
+            "Insert": {feature: insertFeature, options: {handle: "handle_i"}},
+            "Update": {feature: updateFeature, options: {handle: "handle_u"}},
+            "Delete": {feature: deleteFeature, options: {handle: "handle_d"}}
         var arg;
@@ -65,14 +65,14 @@
         updateFeature.modified = {geometry: updateFeature.geometry.clone()};
         updateFeature.geometry = new OpenLayers.Geometry.Point(2,3);
         var expected = readXML("UpdateModified");
-        var got = format.writers["wfs"]["Update"].apply(format, [updateFeature]);
+        var got = format.writers["wfs"]["Update"].apply(format, [{feature: updateFeature}]);
         t.xml_eq(got, expected, "Update request for feature with modified geometry created correctly");
         updateFeature.modified.attributes = {foo: "bar"};
         updateFeature.attributes.foo = "baz";
         delete updateFeature.modified.geometry;
         var expected = readXML("UpdateModifiedNoGeometry");
         t.xml_eq(got, expected, "Update request for feature with no modified geometry but modified attributes created correctly");
@@ -114,7 +114,7 @@
         t.plan(1);
         var snippets = {
-            "UpdateNoGeometry": feature
+            "UpdateNoGeometry": {feature: feature}
         var arg;
@@ -140,7 +140,7 @@
         t.plan(1);
         var snippets = {
-            "UpdateNullGeometry": feature
+            "UpdateNullGeometry": {feature: feature}
         var arg;
@@ -174,7 +174,44 @@
             t.xml_eq(got, expected, snippet + " request created correctly with multiple typenames");
+    function test_write_multi(t) {
+        t.plan(2);
+        var format = new OpenLayers.Format.WFST({
+            featureNS: "http://www.openplans.org/topp",
+            featureType: "states",
+            featurePrefix: "topp",
+            geometryName: "the_geom"
+        var feature = new OpenLayers.Feature.Vector(
+            new OpenLayers.Geometry.Point(1,2),
+            {foo: "bar"}
+        var insertFeature = feature.clone();
+        // null value does not show up in insert
+        insertFeature.attributes.nul = null;
+        insertFeature.state = OpenLayers.State.INSERT;
+        var updateFeature = feature.clone();
+        // undefined value means don't create a Property element
+        updateFeature.attributes.unwritten = undefined;
+        // null value gets Property element with no Value
+        updateFeature.attributes.nul = null;
+        updateFeature.fid = "fid.42";
+        updateFeature.state = OpenLayers.State.UPDATE;
+        var features = [insertFeature, updateFeature];
+        var expected = readXML("TransactionMulti");
+        var geomTypes = OpenLayers.Util.extend({}, format.geometryTypes);
+        var got = format.writers["wfs"]["Transaction"].apply(format, [{
+            features: features,
+            options: {multi: true}}
+        t.xml_eq(got, expected, "Transaction request with multi option created correctly");
+        t.eq(format.geometryTypes, geomTypes, "geometry types unchanged after write with multi option");
     function readXML(id) {
         var xml = document.getElementById(id).firstChild.nodeValue;
         return new OpenLayers.Format.XML().read(xml).documentElement;
@@ -230,7 +267,7 @@
 --></div>
 <div id="GetFeature"><!--
-<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0" outputFormat="json" maxFeatures="1" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
+<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0" handle="handle_g" outputFormat="json" maxFeatures="1" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
     <wfs:Query typeName="topp:states" xmlns:topp="http://www.openplans.org/topp"/>
 </wfs:GetFeature>
 --></div>
@@ -243,8 +280,50 @@
 <div id="Transaction"><!--
 <wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0"/>
 --></div>
+<div id="TransactionMulti"><!--
+<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0">
+    <wfs:Insert>
+        <feature:states xmlns:feature="http://www.openplans.org/topp">
+            <feature:the_geom>
+                <gml:MultiPoint xmlns:gml="http://www.opengis.net/gml">
+                    <gml:pointMember>
+                        <gml:Point>
+                            <gml:coordinates decimal="." cs="," ts=" ">1,2</gml:coordinates>
+                        </gml:Point>
+                    </gml:pointMember>
+                </gml:MultiPoint>
+            </feature:the_geom>
+            <feature:foo>bar</feature:foo>
+        </feature:states>
+    </wfs:Insert>
+    <wfs:Update xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
+        <wfs:Property>
+            <wfs:Name>the_geom</wfs:Name>
+            <wfs:Value>
+                    <gml:pointMember>
+                        <gml:Point>
+                        </gml:Point>
+                </gml:MultiPoint>
+            </wfs:Value>
+        </wfs:Property>
+        <wfs:Property>
+            <wfs:Name>foo</wfs:Name>
+            <wfs:Value>bar</wfs:Value>
+        </wfs:Property>
+        <wfs:Property>
+            <wfs:Name>nul</wfs:Name>
+        </wfs:Property>
+        <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
+            <ogc:FeatureId fid="fid.42"/>
+        </ogc:Filter>
+    </wfs:Update>
+</wfs:Transaction>
+--></div>
 <div id="Insert"><!--
-<wfs:Insert xmlns:wfs="http://www.opengis.net/wfs">
+<wfs:Insert xmlns:wfs="http://www.opengis.net/wfs" handle="handle_i">
         <feature:the_geom>
             <gml:Point xmlns:gml="http://www.opengis.net/gml">
@@ -256,7 +335,7 @@
 </wfs:Insert>
 --></div>
 <div id="Update"><!--
-<wfs:Update xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
+<wfs:Update xmlns:wfs="http://www.opengis.net/wfs" handle="handle_u" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
     <wfs:Property>
         <wfs:Value>
@@ -311,7 +390,7 @@
 </wfs:Update>
 --></div>
 <div id="Delete"><!--
-<wfs:Delete xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
+<wfs:Delete xmlns:wfs="http://www.opengis.net/wfs" handle="handle_d" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
         <ogc:FeatureId fid="fid.37"/>
     </ogc:Filter>
Modified: sandbox/august/trunk/tests/Format/WKT.html
--- sandbox/august/trunk/tests/Format/WKT.html	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/tests/Format/WKT.html	2011-07-20 17:26:52 UTC (rev 12174)
@@ -188,7 +188,7 @@
     function test_Format_WKT_read(t) {
-        t.plan(12);
+        t.plan(13);
         var format = new OpenLayers.Format.WKT();
@@ -204,7 +204,14 @@
         // test a multipoint
         t.ok(multipoint.geometry.equals(format.read(format.write(multipoint)).geometry),
              "format correctly reads MultiPoint WKT");
+        // test a multipoint without separating parens
+        t.ok(multipoint.geometry.equals(format.read(
+ 	        "MULTIPOINT(" + points[0].geometry.x + " " + points[0].geometry.y + "," +
+                            points[1].geometry.x + " " + points[1].geometry.y + "," +
+                            points[2].geometry.x + " " + points[2].geometry.y + ")").geometry),
+            "format correctly reads MultiPoint WKT without parens");
         // test a linestring
         t.ok(linestrings[0].geometry.equals(format.read(format.write(linestrings[0])).geometry),
              "format correctly reads LineString WKT");
Modified: sandbox/august/trunk/tests/Renderer/SVG2.html
--- sandbox/august/trunk/tests/Renderer/SVG2.html	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/tests/Renderer/SVG2.html	2011-07-20 17:26:52 UTC (rev 12174)
@@ -48,7 +48,7 @@
             return;
-        t.plan(5);
+        t.plan(7);
         OpenLayers.Renderer.SVG2.prototype._setExtent =
             OpenLayers.Renderer.SVG2.prototype.setExtent;
@@ -76,14 +76,16 @@
         t.eq(g_SetExtent, true, "Elements.setExtent() called");
-        t.eq(r.rendererRoot.getAttributeNS(null, "width"), "4", "width is correct");
-        t.eq(r.rendererRoot.getAttributeNS(null, "height"), "4", "height is correct");
-        t.eq(r.rendererRoot.getAttributeNS(null, "viewBox"), "1 -4 2 2", "rendererRoot viewBox is correct");
+        t.eq(r.extent.toString(), extent.scale(3).toString(), "renderer's extent is correct");
+        t.eq(r.rendererRoot.getAttributeNS(null, "width"), "12", "width is correct");
+        t.eq(r.rendererRoot.getAttributeNS(null, "height"), "12", "height is correct");
+        t.eq(r.rendererRoot.getAttributeNS(null, "viewBox"), "-1 -6 6 6", "rendererRoot viewBox is correct");
         // test extent changes
         extent = new OpenLayers.Bounds(2,3,5,6);
-        t.eq(r.rendererRoot.getAttributeNS(null, "viewBox"), "2 -6 3 3", "rendererRoot viewBox is correct after a new setExtent");
+        t.eq(r.extent.toString(), extent.scale(3).toString(), "renderer's extent changed after updateDimensions");
+        t.eq(r.rendererRoot.getAttributeNS(null, "viewBox"), "-1 -9 9 9", "rendererRoot viewBox is correct after a new setExtent");
         OpenLayers.Renderer.SVG2.prototype.setExtent =
             OpenLayers.Renderer.SVG2.prototype._setExtent;
Modified: sandbox/august/trunk/tests/Util.html
--- sandbox/august/trunk/tests/Util.html	2011-07-19 10:09:58 UTC (rev 12173)
+++ sandbox/august/trunk/tests/Util.html	2011-07-20 17:26:52 UTC (rev 12174)
@@ -1146,10 +1146,12 @@
             "toFloat rounds large floats correctly #2");
     function test_getFormattedLonLat(t) {
-        t.plan(1);
+        t.plan(3);
         var z = 2 + (4/60) - 0.000002 ;
         t.eq(OpenLayers.Util.getFormattedLonLat(z,"lon"), "02°04'00\"E",
             "LonLat does not show 60 seconds.");
+        t.eq(OpenLayers.Util.getFormattedLonLat(-181, "lon"), "179°00'00\"E", "crossing dateline from the west results in correct east coordinate");
+        t.eq(OpenLayers.Util.getFormattedLonLat(181, "lon"), "179°00'00\"W", "crossing dateline from the east results in correct west coordinate");
   </script>
 </head>
Copied: sandbox/august/trunk/tests/manual/svg2-coordinaterange.html (from rev 12173, trunk/openlayers/tests/manual/svg2-coordinaterange.html)
--- sandbox/august/trunk/tests/manual/svg2-coordinaterange.html	                        (rev 0)
+++ sandbox/august/trunk/tests/manual/svg2-coordinaterange.html	2011-07-20 17:26:52 UTC (rev 12174)
@@ -0,0 +1,50 @@
+<!DOCTYPE html>
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" >
+<link rel="stylesheet" href="../../theme/default/style.css" type="text/css" />
+<style type="text/css">
+    #map {
+        width: 512px;
+        height: 512px;
+        border: 1px solid gray;
+</style>
+<title>SVG2 coordinate range check</title>
+<script type="text/javascript" src="../../lib/OpenLayers.js"></script>
+<script>
+var WGS84 = new OpenLayers.Projection("EPSG:4326");
+var Mercator = new OpenLayers.Projection("EPSG:900913");
+var wkt = new OpenLayers.Format.WKT({ internalProjection: Mercator, externalProjection: WGS84 });
+function init() {
+    var externalGraphic, baseURL, baseLayer, layerOptions, hidemessenger;
+    var map = new OpenLayers.Map('map', {
+        controls: [
+            new OpenLayers.Control.Navigation(),
+            new OpenLayers.Control.PanZoom(),
+            new OpenLayers.Control.Attribution()
+        theme: null
+    baseLayer = new OpenLayers.Layer.OSM("OSM");
+    var viewLayer = new OpenLayers.Layer.Vector("View Layer", {renderers: ["SVG2"]});
+    map.addLayers([baseLayer, viewLayer]);
+    viewLayer.addFeatures([wkt.read("LINESTRING(2.4356174739332 48.816618174539, 2.4313688548536 48.826083884311)")]);
+    var lonLat = new OpenLayers.LonLat( 2.43686, 48.81742) .transform( WGS84, Mercator);
+    map.setCenter (lonLat, 16);
+</script>
+<body onload="init()">
+<div id="map"></div>
+<p>The map should show a line on top of the OSM layer. If it does not, then
+    either the CSS or the SVG coordinate range is exceeded.</p>
+<p>This test only works on browsers that support SVG.</p>
+</body>
+</html>
More information about the Commits mailing list
