[OpenLayers-Commits] r12178 - addins/bookmark/trunk/lib/OpenLayers/Control
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Jul 21 09:56:06 EDT 2011
Author: hpbrantley
Date: 2011-07-21 06:56:05 -0700 (Thu, 21 Jul 2011)
New Revision: 12178
   addins/bookmark/trunk/lib/OpenLayers/Control/Bookmark.js
Minor cleanup; comments added.
Modified: addins/bookmark/trunk/lib/OpenLayers/Control/Bookmark.js
--- addins/bookmark/trunk/lib/OpenLayers/Control/Bookmark.js	2011-07-21 12:54:44 UTC (rev 12177)
+++ addins/bookmark/trunk/lib/OpenLayers/Control/Bookmark.js	2011-07-21 13:56:05 UTC (rev 12178)
@@ -51,7 +51,7 @@
      * APIProperty: allowDuplicates
-     * {Boolean}  Allow the bookmarks to be duplicated. If not, overwrite
+     * {Boolean}  Allow the bookmark names to be duplicated. If not, overwrite
      *            existing.
      *      Default to false.
@@ -298,7 +298,7 @@
                this.stack[i].func(this.stack[i].param);
                found=true;
-               break;  // break out of for when found
+               break;  // break out when found
          this.reindex();
@@ -317,7 +317,7 @@
      * {Boolean} False if not found
     zoomTo: function(label) {
-      OpenLayers.Console.log("zoomTo() deprecated. Use zoomToLabel");
+      OpenLayers.Console.log("zoomTo() deprecated. Use zoomToLabel(label)");
       return this.zoomToLabel(label);
@@ -334,7 +334,7 @@
     zoomToLabel: function(label) {
       f = this.find(label);
       if(f != false) {
-         OpenLayers.Console.log("found label " + f[0][1]);
+         OpenLayers.Console.log(f[0][1] + " found");
          this.zoomToId(f[0][0]);
          return true;
@@ -366,7 +366,7 @@
      * Method: sortByLabel
      * Sort stack by label values. Called by sort().
-    sortByLabel:  function(a, b) {
+    sortByLabel: function(a, b) {
          var x = a.label.toLowerCase();
          var y = b.label.toLowerCase();
          return ((x < y) ? -1 : ((x > y) ? 1 : 0));
@@ -376,7 +376,7 @@
      * Method: sortById
      * Sort stack by id values. Called by sort().
-    sortById:  function(a, b) {
+    sortById: function(a, b) {
          var x = a.id;
          var y = b.id;
@@ -399,6 +399,10 @@
      * APIMethod: store
      * Store the contents of the stack to a cookie referenced by
      * cookieName.
+     * Parameters:
+     * value - {String} contents of stack if storing. empty if expiring.
+     * expires - {Integer} number of days to retain.
     store: function( value, expires) {
       var expires = expires||this.cookieExpires
@@ -475,7 +479,8 @@
       OpenLayers.Console.log("cookie not found");
       return false;
      * APIMethod: expire
      * Expire cookie referenced by cookieName.
More information about the Commits mailing list
