[OpenLayers-Commits] r12185 - in trunk/openlayers: lib/OpenLayers lib/OpenLayers/Layer tests tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Jul 25 07:42:44 EDT 2011
Author: ahocevar
Date: 2011-07-25 04:42:43 -0700 (Mon, 25 Jul 2011)
New Revision: 12185
   trunk/openlayers/lib/OpenLayers/Layer.js
   trunk/openlayers/lib/OpenLayers/Layer/Markers.js
   trunk/openlayers/lib/OpenLayers/Layer/WFS.js
   trunk/openlayers/tests/Layer.html
   trunk/openlayers/tests/Layer/ArcGIS93Rest.html
   trunk/openlayers/tests/Layer/MapServer.html
   trunk/openlayers/tests/Layer/Markers.html
   trunk/openlayers/tests/Layer/WFS.html
   trunk/openlayers/tests/Layer/WMS.html
Set opacity on layer div, not on tiles and markers. r=fredj (closes #3431)
Modified: trunk/openlayers/lib/OpenLayers/Layer/Markers.js
--- trunk/openlayers/lib/OpenLayers/Layer/Markers.js	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/lib/OpenLayers/Layer/Markers.js	2011-07-25 11:42:43 UTC (rev 12185)
@@ -60,22 +60,6 @@
         OpenLayers.Layer.prototype.destroy.apply(this, arguments);
-     * APIMethod: setOpacity
-     * Sets the opacity for all the markers.
-     * Parameter:
-     * opacity - {Float}
-    setOpacity: function(opacity) {
-        if (opacity != this.opacity) {
-            this.opacity = opacity;
-            for (var i=0, len=this.markers.length; i<len; i++) {
-                this.markers[i].setOpacity(this.opacity);
      * Method: moveTo
Modified: trunk/openlayers/lib/OpenLayers/Layer/WFS.js
--- trunk/openlayers/lib/OpenLayers/Layer/WFS.js	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/lib/OpenLayers/Layer/WFS.js	2011-07-25 11:42:43 UTC (rev 12185)
@@ -590,21 +590,5 @@
         return extent;
-     * Call the setOpacity method of the appropriate parent class to set the
-     *     opacity.
-     * Parameter:
-    setOpacity: function (opacity) {
-        if (this.vectorMode) {
-            OpenLayers.Layer.Vector.prototype.setOpacity.apply(this, [opacity]);
-        } else {
-            OpenLayers.Layer.Markers.prototype.setOpacity.apply(this, [opacity]);
     CLASS_NAME: "OpenLayers.Layer.WFS"
Modified: trunk/openlayers/lib/OpenLayers/Layer.js
--- trunk/openlayers/lib/OpenLayers/Layer.js	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/lib/OpenLayers/Layer.js	2011-07-25 11:42:43 UTC (rev 12185)
@@ -349,6 +349,11 @@
             this.div.style.width = "100%";
             this.div.style.height = "100%";
             this.div.dir = "ltr";
+            if (this.opacity != null) {
+                OpenLayers.Util.modifyDOMElement(
+                    this.div, null, null, null, null, null, null, this.opacity
             this.events = new OpenLayers.Events(this, this.div,
                                                 this.EVENT_TYPES);
@@ -1269,11 +1274,8 @@
-            for(var i=0, len=this.div.childNodes.length; i<len; ++i) {
-                var element = this.div.childNodes[i].firstChild;
-                OpenLayers.Util.modifyDOMElement(element, null, null, null,
-                                                 null, null, null, opacity);
+            OpenLayers.Util.modifyDOMElement(this.div, null, null, null,
+                                             null, null, null, opacity);
             if (this.map != null) {
                 this.map.events.triggerEvent("changelayer", {
                     layer: this,
Modified: trunk/openlayers/tests/Layer/ArcGIS93Rest.html
--- trunk/openlayers/tests/Layer/ArcGIS93Rest.html	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/tests/Layer/ArcGIS93Rest.html	2011-07-25 11:42:43 UTC (rev 12185)
@@ -195,31 +195,6 @@
-    function test_Layer_AGS93_setOpacity (t) {
-        var params = {layers: "show:0,2"};
-        t.plan( 5 );
-        var map = new OpenLayers.Map('map');
-        map.projection = "xx";
-        tParams = { layers: 'show:0,2',
-                   format: 'png'};
-        tOptions = { 'opacity': '0.5' };
-        var tLayer = new OpenLayers.Layer.ArcGIS93Rest(name, url, tParams, tOptions);
-        map.addLayer(tLayer);
-        map.zoomToMaxExtent();
-        t.eq(tLayer.opacity, "0.5", "Opacity is set correctly");
-        t.eq(parseFloat(tLayer.div.firstChild.firstChild.style.opacity), 0.5, "Opacity on tile is correct");
-        tLayer.setOpacity("0.6");
-        t.eq(tLayer.opacity, "0.6", "setOpacity works properly");
-        t.eq(parseFloat(tLayer.div.firstChild.firstChild.style.opacity), 0.6, "Opacity on tile is changed correctly");
-        var pixel = new OpenLayers.Pixel(5,6);
-        var tile = tLayer.addTile(new OpenLayers.Bounds(1,2,3,4), pixel);
-        tile.draw();
-        t.eq(parseFloat(tile.imgDiv.style.opacity), 0.6, "Tile opacity is set correctly");
-        map.destroy();
     function test_Layer_AGS93_noGutters (t) {
         t.plan(2);
Modified: trunk/openlayers/tests/Layer/MapServer.html
--- trunk/openlayers/tests/Layer/MapServer.html	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/tests/Layer/MapServer.html	2011-07-25 11:42:43 UTC (rev 12185)
@@ -196,31 +196,6 @@
-    function test_Layer_MapServer_setOpacity (t) {
-        t.plan( 5 );
-        tUrl = "http://labs.metacarta.com/cgi-bin/mapserv";
-        tParams = { layers: 'basic',
-                   format: 'image/png'};
-        var tLayer = new OpenLayers.Layer.MapServer(name, tUrl, tParams, tOptions);
-        tile.draw();
-        map.destroy();
     function test_Layer_MapServer_Reproject (t) {
         var validkey = (window.location.protocol == "file:") ||
                        (window.location.host == "localhost") ||
@@ -411,27 +386,6 @@
-    function test_Layer_MapServer_Untiled_setOpacity (t) {
-        t.plan( 4 );
-        var tLayer = new OpenLayers.Layer.MapServer.Untiled(name, tUrl, tParams, tOptions);
-        map.destroy();
     // DEPRECATED -- REMOVE IN 3.0
     function test_Layer_Untiled_MapServer(t) {
         t.plan(1);
Modified: trunk/openlayers/tests/Layer/Markers.html
--- trunk/openlayers/tests/Layer/Markers.html	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/tests/Layer/Markers.html	2011-07-25 11:42:43 UTC (rev 12185)
@@ -121,33 +121,6 @@
-    function test_setOpacity(t) {
-        t.plan(1);
-        layer = new OpenLayers.Layer.Markers('Test Layer');
-        var opacity = 0.1234;
-        for (var i = 0; i < 12; i++) {
-            layer.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(0,0), new OpenLayers.Icon()));
-        layer.setOpacity(opacity);
-        for (var i = 0; i < 4; i++) {
-        var itWorks = false;
-        for (var i = 0; i < layer.markers.length; i++) {
-            itWorks = parseFloat(layer.markers[i].icon.imageDiv.style.opacity) == opacity;
-            if (!itWorks) {
-                break;
-        t.ok(itWorks, "setOpacity change markers opacity");
   </script>
 </head>
 <body>
Modified: trunk/openlayers/tests/Layer/WFS.html
--- trunk/openlayers/tests/Layer/WFS.html	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/tests/Layer/WFS.html	2011-07-25 11:42:43 UTC (rev 12185)
@@ -25,22 +25,6 @@
-    function test_Layer_WFS_setOpacity(t) {
-        t.plan(3);
-        var layer = new OpenLayers.Layer.WFS(name, "url", {});
-        layer.setOpacity(.5);
-        t.eq(layer.opacity, 0.5, "vector setOpacity didn't fail");
-        var layer = new OpenLayers.Layer.WFS(name, "url", {}, {'featureClass': OpenLayers.Feature.WFS});
-        var marker = new OpenLayers.Marker(new OpenLayers.LonLat(0,0));
-        marker.setOpacity = function() {
-            t.ok(true, "Marker setOpacity was called");
-        layer.addMarker(marker);
-        layer.setOpacity(.6);
-        t.eq(layer.opacity, 0.6, "setOpacity didn't fail on markers");
     function test_Layer_WFS_destroy(t) {
         t.plan(13);
Modified: trunk/openlayers/tests/Layer/WMS.html
--- trunk/openlayers/tests/Layer/WMS.html	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/tests/Layer/WMS.html	2011-07-25 11:42:43 UTC (rev 12185)
@@ -281,31 +281,6 @@
-    function test_Layer_WMS_setOpacity (t) {
-        t.plan( 5 );
-        tUrl = "http://octo.metacarta.com/cgi-bin/mapserv";
-        var tLayer = new OpenLayers.Layer.WMS(name, tUrl, tParams, tOptions);
-        tile.draw();
-        map.destroy();
     function test_Layer_WMS_Reproject (t) {
Modified: trunk/openlayers/tests/Layer.html
--- trunk/openlayers/tests/Layer.html	2011-07-25 08:52:15 UTC (rev 12184)
+++ trunk/openlayers/tests/Layer.html	2011-07-25 11:42:43 UTC (rev 12185)
@@ -786,14 +786,15 @@
-        t.plan(5);
+        t.plan(8);
         var map, layer, log;
         map = new OpenLayers.Map("map");
-        layer = new OpenLayers.Layer("");
+        layer = new OpenLayers.Layer("", {opacity: 0.56});
         map.addLayer(layer);
+        t.eq(layer.div.style.opacity, "0.56", "initial opacity correctly applied as layer.div style");
         log = [];
         map.events.register('changelayer', t, function(event) {
             log.push({layer: event.layer, property: event.property});
@@ -801,6 +802,7 @@
         layer.setOpacity(0.42);
         t.eq(layer.opacity, 0.42,
              "setOpacity() set layer.opacity to correct value");
+        t.eq(layer.div.style.opacity, "0.42", "opacity correctly applied as layer.div style");
         t.eq(log.length, 1,
              "setOpacity() triggers changelayer once");
         t.ok(log[0].layer == layer,
@@ -813,6 +815,12 @@
         t.eq(log.length, 0,
              "setOpacity() does not trigger changelayer if the opacity value is the same");
+        // 0 as initial opacity
+        layer.destroy();
+        layer = new OpenLayers.Layer("", {opacity: 0});
+        map.addLayer(layer);
+        t.eq(layer.div.style.opacity, "0", "initial opacity correctly applied as layer.div style");
More information about the Commits mailing list
