[OpenLayers-Commits] r12201 - trunk/openlayers/lib/OpenLayers/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Jul 29 10:00:40 EDT 2011
Author: fredj
Date: 2011-07-29 07:00:39 -0700 (Fri, 29 Jul 2011)
New Revision: 12201
   trunk/openlayers/lib/OpenLayers/Layer/WorldWind.js
fixed APIdocs. Non-functional change
Modified: trunk/openlayers/lib/OpenLayers/Layer/WorldWind.js
--- trunk/openlayers/lib/OpenLayers/Layer/WorldWind.js	2011-07-29 09:45:29 UTC (rev 12200)
+++ trunk/openlayers/lib/OpenLayers/Layer/WorldWind.js	2011-07-29 14:00:39 UTC (rev 12201)
@@ -21,20 +21,19 @@
      * APIProperty: isBaseLayer
-     * WorldWind layer is a base layer by default.
+     * {Boolean} WorldWind layer is a base layer by default.
-    isBaseLayer: true,
+    isBaseLayer: true,
      * APIProperty: lzd
-     * LevelZeroTileSizeDegrees
+     * {Float} LevelZeroTileSizeDegrees
     lzd: null,
      * APIProperty: zoomLevels
-     * Number of zoom levels.
+     * {Integer} Number of zoom levels.
     zoomLevels: null,
@@ -45,7 +44,7 @@
      * name - {String} Name of Layer
      * url - {String} Base URL
      * lzd - {Float} Level zero tile size degrees
-     * zoomLevels - {Int} number of zoom levels
+     * zoomLevels - {Integer} number of zoom levels
      * params - {Object} additional parameters
      * options - {Object} additional options
More information about the Commits mailing list
