[OpenLayers-Commits] r12049 - trunk/openlayers/tests/Format
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Jun 6 04:07:58 EDT 2011
Author: erilem
Date: 2011-06-06 01:07:57 -0700 (Mon, 06 Jun 2011)
New Revision: 12049
   trunk/openlayers/tests/Format/GeoRSS.html
fix GeoRSS test_leading_space test in IE (References #2780)
Modified: trunk/openlayers/tests/Format/GeoRSS.html
--- trunk/openlayers/tests/Format/GeoRSS.html	2011-06-06 07:21:04 UTC (rev 12048)
+++ trunk/openlayers/tests/Format/GeoRSS.html	2011-06-06 08:07:57 UTC (rev 12049)
@@ -80,7 +80,15 @@
         var parser = new OpenLayers.Format.GeoRSS();
         var items = parser.read('<rss version="2.0" xmlns:georss="http://www.georss.org/georss"><item><description>  <![CDATA[foo]]></description></item></rss>');
         t.eq(items.length, 1, "item created");
-        t.eq(items[0].attributes.description, "  foo", "description value is ok");
+        // when parsing a node composed of both spaces and a cdata section
+        // (e.g. <description>  <![DATA[foo]]></description> IE8 ignores
+        // the leading white spaces, and reports that the node does not
+        // include a text node. For that reason, we need to trim the
+        // string value resulting from the parsing.
+        var description = OpenLayers.String.trim(items[0].attributes.description);
+        t.eq(description, "foo", "description value is ok");
     var shell_start = '<feed xmlns="http://www.w3.org/2005/Atom" \n              xmlns:georss="http://www.georss.org/georss">\n              <title>scribble</title>\n              <id>http://featureserver.org/featureserver.cgi/scribble?format=atom</id>\n              <author><name>FeatureServer</name></author>\n';
More information about the Commits mailing list
