[OpenLayers-Commits] r12058 - in sandbox/bartvde/exception/openlayers: lib/OpenLayers/Format lib/OpenLayers/Format/OWSCommon tests tests/Format/OWSCommon
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Jun 7 13:41:12 EDT 2011
Author: bartvde
Date: 2011-06-07 10:41:11 -0700 (Tue, 07 Jun 2011)
New Revision: 12058
Added:
   sandbox/bartvde/exception/openlayers/tests/Format/OWSCommon/v1_1_0.html
   sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon.js
   sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js
   sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1_0_0.js
   sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js
   sandbox/bartvde/exception/openlayers/tests/Format/OWSCommon/v1_0_0.html
   sandbox/bartvde/exception/openlayers/tests/list-tests.html
more work on the exception formats
Modified: sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js
--- sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js	2011-06-07 16:49:54 UTC (rev 12057)
+++ sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js	2011-06-07 17:41:11 UTC (rev 12058)
@@ -51,18 +51,18 @@
     readers: {
         "ows": {
-            "ExceptionReport": function(node, obj) {
-                obj.exceptionReport = {};
-                this.readChildNodes(node, obj.exceptionReport);
             "Exception": function(node, exceptionReport) {
-                exceptionReport.exception = {
-                    code: node.getAttribute('exceptionCode')
+                var exception = {
+                    code: node.getAttribute('exceptionCode'),
+                    locator: node.getAttribute('locator'),
+                    texts: []
-                this.readChildNodes(node, exceptionReport.exception);
+                exceptionReport.exceptions.push(exception);
+                this.readChildNodes(node, exception);
             "ExceptionText": function(node, exception) {
-                exception.text = this.getChildValue(node);
+                var text = this.getChildValue(node);
+                exception.texts.push(text);
             "ServiceIdentification": function(node, obj) {
                 obj.serviceIdentification = {};
Modified: sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1_0_0.js
--- sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1_0_0.js	2011-06-07 16:49:54 UTC (rev 12057)
+++ sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1_0_0.js	2011-06-07 17:41:11 UTC (rev 12058)
@@ -31,7 +31,16 @@
      *     from the parent.
     readers: {
-        "ows": OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"]
+        "ows": OpenLayers.Util.applyDefaults({
+            "ExceptionReport": function(node, obj) {
+                obj.exceptionReport = {
+                    version: node.getAttribute('version'),
+                    language: node.getAttribute('language'),
+                    exceptions: []
+                this.readChildNodes(node, obj.exceptionReport);
+        }, OpenLayers.Format.OWSCommon.v1.prototype.readers.ows)
@@ -41,7 +50,7 @@
      *     node names they produce.
     writers: {
-        "ows": OpenLayers.Format.OWSCommon.v1.prototype.writers["ows"]
+        "ows": OpenLayers.Format.OWSCommon.v1.prototype.writers.ows
     CLASS_NAME: "OpenLayers.Format.OWSCommon.v1_0_0"
Modified: sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js
--- sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js	2011-06-07 16:49:54 UTC (rev 12057)
+++ sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js	2011-06-07 17:41:11 UTC (rev 12058)
@@ -32,6 +32,14 @@
     readers: {
+                    language: node.getAttribute('xml:lang'),
+                    exceptions: []
             "AllowedValues": function(node, parameter) {
                 parameter.allowedValues = {};
                 this.readChildNodes(node, parameter.allowedValues);
Modified: sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon.js
--- sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon.js	2011-06-07 16:49:54 UTC (rev 12057)
+++ sandbox/bartvde/exception/openlayers/lib/OpenLayers/Format/OWSCommon.js	2011-06-07 17:41:11 UTC (rev 12058)
@@ -63,7 +63,12 @@
         var root = data.documentElement;
         var version = this.version;
         if(!version) {
-            version = root.getAttribute("version");
+            // remember version does not correspond to the OWS version
+            // it corresponds to the WMS/WFS/WCS etc. request version
+            var uri = root.getAttribute("xmlns:ows");
+            if (uri.substring(uri.lastIndexOf("/")+1) === "1.1") {
+                version ="1.1.0";
             if(!version) {
                 version = this.defaultVersion;
Modified: sandbox/bartvde/exception/openlayers/tests/Format/OWSCommon/v1_0_0.html
--- sandbox/bartvde/exception/openlayers/tests/Format/OWSCommon/v1_0_0.html	2011-06-07 16:49:54 UTC (rev 12057)
+++ sandbox/bartvde/exception/openlayers/tests/Format/OWSCommon/v1_0_0.html	2011-06-07 17:41:11 UTC (rev 12058)
@@ -4,21 +4,27 @@
     <script type="text/javascript">
     function test_read_exception(t) {
-        t.plan(2);
+        t.plan(6);
         var text = '<?xml version="1.0" encoding="UTF-8"?>' +
-'<ows:ExceptionReport version="1.0.0"' +
+'<ows:ExceptionReport language="en" version="1.0.0"' +
 '    xsi:schemaLocation="http://www.opengis.net/ows http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd"' +
 '    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ows="http://www.opengis.net/ows">' +
-'    <ows:Exception exceptionCode="InvalidParameterValue">' +
+'    <ows:Exception locator="foo" exceptionCode="InvalidParameterValue">' +
 '        <ows:ExceptionText>Update error: Error occured updating features</ows:ExceptionText>' +
+'        <ows:ExceptionText>Second exception line</ows:ExceptionText>' +
 '    </ows:Exception>' +
 '</ows:ExceptionReport>';
         var format = new OpenLayers.Format.OWSCommon();
         var result = format.read(text);
-        var exception = result.exceptionReport.exception;
+        var report = result.exceptionReport;
+        t.eq(report.version, "1.0.0", "Version parsed correctly");
+        t.eq(report.language, "en", "Language parsed correctly");
+        var exception = report.exceptions[0];
         t.eq(exception.code, "InvalidParameterValue", "exceptionCode properly parsed");
-        t.eq(exception.text, "Update error: Error occured updating features", "ExceptionText correctly parsed");
+        t.eq(exception.locator, "foo", "locator properly parsed");
+        t.eq(exception.texts[0], "Update error: Error occured updating features", "ExceptionText correctly parsed");
+        t.eq(exception.texts[1], "Second exception line", "Second ExceptionText correctly parsed");
     </script>
Added: sandbox/bartvde/exception/openlayers/tests/Format/OWSCommon/v1_1_0.html
--- sandbox/bartvde/exception/openlayers/tests/Format/OWSCommon/v1_1_0.html	                        (rev 0)
+++ sandbox/bartvde/exception/openlayers/tests/Format/OWSCommon/v1_1_0.html	2011-06-07 17:41:11 UTC (rev 12058)
@@ -0,0 +1,34 @@
+<html>
+<head>
+    <script src="../../OLLoader.js"></script>
+    <script type="text/javascript">
+    function test_read_exception(t) {
+        t.plan(6);
+        var text = '<?xml version="1.0" encoding="UTF-8"?>' +
+'<ows:ExceptionReport xml:lang="en" version="1.0.0"' +
+'    xsi:schemaLocation="http://www.opengis.net/ows http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"' +
+'    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ows="http://www.opengis.net/ows/1.1">' +
+'        <ows:ExceptionText>Update error: Error occured updating features</ows:ExceptionText>' +
+'    </ows:Exception>' +
+'</ows:ExceptionReport>';
+        var format = new OpenLayers.Format.OWSCommon();
+        var result = format.read(text);
+        t.eq(exception.code, "InvalidParameterValue", "exceptionCode properly parsed");
+    </script>
+</head>
+<body>
+</body>
+</html>
Modified: sandbox/bartvde/exception/openlayers/tests/list-tests.html
--- sandbox/bartvde/exception/openlayers/tests/list-tests.html	2011-06-07 16:49:54 UTC (rev 12057)
+++ sandbox/bartvde/exception/openlayers/tests/list-tests.html	2011-06-07 17:41:11 UTC (rev 12058)
@@ -105,6 +105,7 @@
     <li>Format/SOSGetFeatureOfInterest.html</li>
     <li>Format/OWSContext/v0_3_1.html</li>
     <li>Format/OWSCommon/v1_0_0.html</li>
+    <li>Format/OWSCommon/v1_1_0.html</li>
     <li>Format/XLS/v1_1_0.html</li>
     <li>Format/XML.html</li>
     <li>Geometry.html</li>
More information about the Commits mailing list
