[OpenLayers-Commits] r12098 - in trunk/openlayers:
	lib/OpenLayers/Format tests/Format
    commits-20090109 at openlayers.org
    Fri Jun 17 13:12:02 EDT 2011
Author: tschaub
Date: 2011-06-17 10:12:01 -0700 (Fri, 17 Jun 2011)
New Revision: 12098
   trunk/openlayers/lib/OpenLayers/Format/WKT.js
   trunk/openlayers/tests/Format/WKT.html
Enhance WKT parser to parse multi-line strings.  r=erilem (closes #3365)
Modified: trunk/openlayers/lib/OpenLayers/Format/WKT.js
--- trunk/openlayers/lib/OpenLayers/Format/WKT.js	2011-06-17 13:16:53 UTC (rev 12097)
+++ trunk/openlayers/lib/OpenLayers/Format/WKT.js	2011-06-17 17:12:01 UTC (rev 12098)
@@ -56,6 +56,7 @@
     read: function(wkt) {
         var features, type, str;
+        wkt = wkt.replace(/[\n\r]/g, " ");
         var matches = this.regExes.typeStr.exec(wkt);
         if(matches) {
             type = matches[1].toLowerCase();
Modified: trunk/openlayers/tests/Format/WKT.html
--- trunk/openlayers/tests/Format/WKT.html	2011-06-17 13:16:53 UTC (rev 12097)
+++ trunk/openlayers/tests/Format/WKT.html	2011-06-17 17:12:01 UTC (rev 12098)
@@ -232,6 +232,16 @@
         t.geom_eq(got[1].geometry, linestrings[0].geometry, "second feature's geometry is the correct linestring");
+    function test_whitespace(t) {
+        t.plan(3);
+        var wkt = "LINESTRING(7.120068\t43.583917,\n7.120154 43.583652,\n7.120385\t43.582716,\r\n7.12039 43.582568, 7.120712 43.581511,7.120873\n43.580718)";
+        var format = new OpenLayers.Format.WKT();
+        var got = format.read(wkt);
+        t.ok(got instanceof OpenLayers.Feature.Vector, "read a feature");
+        t.ok(got.geometry instanceof OpenLayers.Geometry.LineString, "read a linestring");
+        t.ok(got.geometry.components.length, 6, "read a geometry with 6 components");
     function test_Format_WKT_read_projection(t) {
         t.plan(1);
More information about the Commits
