[OpenLayers-Commits] r12108 - in trunk/openlayers: lib/OpenLayers/Format tests/Format
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sat Jun 18 15:33:30 EDT 2011
Author: ahocevar
Date: 2011-06-18 12:33:29 -0700 (Sat, 18 Jun 2011)
New Revision: 12108
   trunk/openlayers/lib/OpenLayers/Format/XML.js
   trunk/openlayers/tests/Format/XML.html
adding getXMLDoc method that allows creating XML documents with non-HTML compliant nodes (e.g. createCDATASection). r=bartvde (closes #3366)
Modified: trunk/openlayers/lib/OpenLayers/Format/XML.js
--- trunk/openlayers/lib/OpenLayers/Format/XML.js	2011-06-18 19:27:27 UTC (rev 12107)
+++ trunk/openlayers/lib/OpenLayers/Format/XML.js	2011-06-18 19:33:29 UTC (rev 12108)
@@ -848,6 +848,29 @@
         return uri;
+     * Method: getXMLDoc
+     * Get an XML document for nodes that are not supported in HTML (e.g.
+     * createCDATASection). On IE, this will either return an existing or
+     * create a new <xmldom> on the instance. On other browsers, this will
+     * either return an existing or create a new shared document (see
+     * <OpenLayers.Format.XML.document>).
+     * Returns:
+     * {XMLDocument}
+    getXMLDoc: function() {
+        if (!OpenLayers.Format.XML.document && !this.xmldom) {
+            if (document.implementation && document.implementation.createDocument) {
+                OpenLayers.Format.XML.document =
+                    document.implementation.createDocument("", "", null);
+            } else if (!this.xmldom && window.ActiveXObject) {
+                this.xmldom = new ActiveXObject("Microsoft.XMLDOM");
+        return OpenLayers.Format.XML.document || this.xmldom;
     CLASS_NAME: "OpenLayers.Format.XML"
@@ -879,3 +902,10 @@
     OpenLayers.Format.XML.prototype.lookupNamespaceURI,
+ * Property: OpenLayers.Format.XML.document
+ * {XMLDocument} XML document to reuse for creating non-HTML compliant nodes,
+ * like document.createCDATASection.
+OpenLayers.Format.XML.document = null;
Modified: trunk/openlayers/tests/Format/XML.html
--- trunk/openlayers/tests/Format/XML.html	2011-06-18 19:27:27 UTC (rev 12107)
+++ trunk/openlayers/tests/Format/XML.html	2011-06-18 19:33:29 UTC (rev 12108)
@@ -849,6 +849,19 @@
+    function test_getXMLDoc(t) {
+        t.plan(2);
+        var format = new OpenLayers.Format.XML();
+        var doc = format.getXMLDoc();
+        t.ok(doc !== document, "document returned from getXMLDoc is not the page's html doc");
+        var root = format.createElementNS("http://test", "root");
+        // appending CDATA created from a different document
+        var cdata = doc.createCDATASection("<foo></foo>");
+        root.appendChild(cdata);
+        var result = format.write(root);
+        var expect = '<root xmlns="http://test"><![CDATA[<foo></foo>]]></root>';
+        t.eq(result, expect, "document with CDATA section serialized correctly");
     </script>
More information about the Commits mailing list
