[OpenLayers-Commits] r12124 - in trunk/openlayers: lib lib/OpenLayers/Format lib/OpenLayers/Format/OWSCommon lib/OpenLayers/Format/WPSCapabilities tests tests/Format tests/Format/WPSCapabilities
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Jun 22 05:54:36 EDT 2011
Author: bartvde
Date: 2011-06-22 02:54:35 -0700 (Wed, 22 Jun 2011)
New Revision: 12124
Added:
   trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities.js
   trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities/
   trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities/v1_0_0.js
   trunk/openlayers/lib/OpenLayers/Format/WPSDescribeProcess.js
   trunk/openlayers/lib/OpenLayers/Format/WPSExecute.js
   trunk/openlayers/tests/Format/WPSCapabilities/
   trunk/openlayers/tests/Format/WPSCapabilities/v1_0_0.html
   trunk/openlayers/tests/Format/WPSCapabilities/v1_0_0.js
   trunk/openlayers/tests/Format/WPSDescribeProcess.html
   trunk/openlayers/tests/Format/WPSExecute.html
   trunk/openlayers/lib/OpenLayers.js
   trunk/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js
   trunk/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js
   trunk/openlayers/tests/list-tests.html
add formats for WPS GetCapabilities, WPS DescribeProcess and WPS Execute, thanks ahocevar for the great rework on the patch, r=ahocevar, see #3307)
Modified: trunk/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js	2011-06-22 07:14:15 UTC (rev 12123)
+++ trunk/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js	2011-06-22 09:54:35 UTC (rev 12124)
@@ -232,6 +232,9 @@
                 delete obj.bottom;
                 delete obj.right;
                 delete obj.top;
+            "Language": function(node, obj) {
+                obj.language = this.getChildValue(node);
@@ -264,11 +267,21 @@
                     value: options.bounds.right + " " + options.bounds.top });
                 return node;
+            "Identifier": function(identifier) {
+                var node = this.createElementNSPlus("ows:Identifier", {
+                    value: identifier });
+                return node;
             "Title": function(title) {
                 var node = this.createElementNSPlus("ows:Title", {
                     value: title });
                 return node;
+            "Abstract": function(abstractValue) {
+                var node = this.createElementNSPlus("ows:Abstract", {
+                    value: abstractValue });
+                return node;
             "OutputFormat": function(format) {
                 var node = this.createElementNSPlus("ows:OutputFormat", {
                     value: format });
Modified: trunk/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js
--- trunk/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js	2011-06-22 07:14:15 UTC (rev 12123)
+++ trunk/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js	2011-06-22 09:54:35 UTC (rev 12124)
@@ -47,6 +47,9 @@
             "AnyValue": function(node, parameter) {
                 parameter.anyValue = true;
+            "DataType": function(node, parameter) {
+                parameter.dataType = this.getChildValue(node);
             "Range": function(node, allowedValues) {
                 allowedValues.range = {};
                 this.readChildNodes(node, allowedValues.range);
@@ -65,7 +68,46 @@
         }, OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"])
+     * Property: writers
+     * As a compliment to the readers property, this structure contains public
+     *     writing functions grouped by namespace alias and named like the
+     *     node names they produce.
+    writers: {
+        "ows": OpenLayers.Util.applyDefaults({
+            "Range": function(range) {
+                var node = this.createElementNSPlus("ows:Range", {
+                    attributes: {
+                        'ows:rangeClosure': range.closure
+                this.writeNode("ows:MinimumValue", range.minValue, node);
+                this.writeNode("ows:MaximumValue", range.maxValue, node);
+                return node;
+            "MinimumValue": function(minValue) {
+                var node = this.createElementNSPlus("ows:MinimumValue", {
+                    value: minValue
+                return node;
+            "MaximumValue": function(maxValue) {
+                var node = this.createElementNSPlus("ows:MaximumValue", {
+                    value: maxValue
+                return node;
+            "Value": function(value) {
+                var node = this.createElementNSPlus("ows:Value", {
+                    value: value
+                return node;
+        }, OpenLayers.Format.OWSCommon.v1.prototype.writers["ows"])
     CLASS_NAME: "OpenLayers.Format.OWSCommon.v1_1_0"
Added: trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities/v1_0_0.js
--- trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities/v1_0_0.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities/v1_0_0.js	2011-06-22 09:54:35 UTC (rev 12124)
@@ -0,0 +1,119 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Format/WPSCapabilities.js
+ * @requires OpenLayers/Format/OWSCommon/v1_1_0.js
+ * Class: OpenLayers.Format.WPSCapabilities.v1_0_0
+ * Read WPS Capabilities version 1.0.0.
+ * Inherits from:
+ *  - <OpenLayers.Format.XML>
+OpenLayers.Format.WPSCapabilities.v1_0_0 = OpenLayers.Class(
+    OpenLayers.Format.XML, {
+     * Property: namespaces
+     * {Object} Mapping of namespace aliases to namespace URIs.
+    namespaces: {
+        ows: "http://www.opengis.net/ows/1.1",
+        wps: "http://www.opengis.net/wps/1.0.0",
+        xlink: "http://www.w3.org/1999/xlink"
+     * Property: regExes
+     * Compiled regular expressions for manipulating strings.
+    regExes: {
+        trimSpace: (/^\s*|\s*$/g),
+        removeSpace: (/\s*/g),
+        splitSpace: (/\s+/),
+        trimComma: (/\s*,\s*/g)
+     * Constructor: OpenLayers.Format.WPSCapabilities.v1_0_0
+     * Create a new parser for WPS capabilities version 1.0.0.
+     * Parameters:
+     * options - {Object} An optional object whose properties will be set on
+     *     this instance.
+    initialize: function(options) {
+        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
+     * APIMethod: read
+     * Read capabilities data from a string, and return info about the WPS.
+     * Parameters:
+     * data - {String} or {DOMElement} data to read/parse.
+     * Returns:
+     * {Object} Information about the WPS service.
+    read: function(data) {
+        if(typeof data == "string") {
+            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
+        if(data && data.nodeType == 9) {
+            data = data.documentElement;
+        var capabilities = {};
+        this.readNode(data, capabilities);
+        return capabilities;
+     * Property: readers
+     * Contains public functions, grouped by namespace prefix, that will
+     *     be applied when a namespaced node is found matching the function
+     *     name.  The function will be applied in the scope of this parser
+     *     with two arguments: the node being read and a context object passed
+     *     from the parent.
+    readers: {
+        "wps": {
+            "Capabilities": function(node, obj) {
+                this.readChildNodes(node, obj);
+            "ProcessOfferings": function(node, obj) {
+                obj.processOfferings = {};
+                this.readChildNodes(node, obj.processOfferings);
+            "Process": function(node, processOfferings) {
+                var processVersion = this.getAttributeNS(node, this.namespaces.wps, "processVersion");
+                var process = {processVersion: processVersion};
+                this.readChildNodes(node, process);
+                processOfferings[process.identifier] = process;
+            "Languages": function(node, obj) {
+                obj.languages = [];
+                this.readChildNodes(node, obj.languages);
+            "Default": function(node, languages) {
+                var language = {isDefault: true};
+                this.readChildNodes(node, language);
+                languages.push(language);
+            "Supported": function(node, languages) {
+                var language = {};
+        "ows": OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]
+    CLASS_NAME: "OpenLayers.Format.WPSCapabilities.v1_0_0"
Added: trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities.js
--- trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Format/WPSCapabilities.js	2011-06-22 09:54:35 UTC (rev 12124)
@@ -0,0 +1,79 @@
+ * @requires OpenLayers/Format/XML.js
+ * Read WPS Capabilities.
+ * Inherits from:
+OpenLayers.Format.WPSCapabilities = OpenLayers.Class(OpenLayers.Format.XML, {
+     * APIProperty: defaultVersion
+     * {String} Version number to assume if none found.  Default is "1.0.0".
+    defaultVersion: "1.0.0",
+     * APIProperty: version
+     * {String} Specify a version string if one is known.
+    version: null,
+     * Property: parser
+     * {<OpenLayers.Format>} A cached versioned format used for reading.
+    parser: null,
+     * Create a new parser for WPS Capabilities.
+     * Parameters:
+     *     this instance.
+     * APIMethod: read
+     * Read capabilities data from a string, and return information about
+     * the service.
+     * Parameters:
+     * Returns:
+     * {Object} Info about the WPS
+        var root = data.documentElement;
+        var version = this.version || root.getAttribute("version") || this.defaultVersion;
+        if(!this.parser || this.parser.version !== version) {
+            var constr = OpenLayers.Format.WPSCapabilities[
+                "v" + version.replace(/\./g, "_")
+            if(!constr) {
+                throw "Can't find a WPS capabilities parser for version " + version;
+            var parser = new constr(this.options);
+        var capabilities = parser.read(data);
+        capabilities.version = version;
+    CLASS_NAME: "OpenLayers.Format.WPSCapabilities"
Added: trunk/openlayers/lib/OpenLayers/Format/WPSDescribeProcess.js
--- trunk/openlayers/lib/OpenLayers/Format/WPSDescribeProcess.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Format/WPSDescribeProcess.js	2011-06-22 09:54:35 UTC (rev 12124)
@@ -0,0 +1,180 @@
+ * Class: OpenLayers.Format.WPSDescribeProcess
+ * Read WPS DescribeProcess responses.
+ * Inherits from:
+OpenLayers.Format.WPSDescribeProcess = OpenLayers.Class(
+     * Constant: VERSION
+     * {String} 1.0.0
+    VERSION: "1.0.0",
+    namespaces: {
+        xsi: "http://www.w3.org/2001/XMLSchema-instance"
+     * Property: schemaLocation
+     * {String} Schema location
+    schemaLocation: "http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",
+     * Property: defaultPrefix
+    defaultPrefix: "wps",
+    regExes: {
+     * Constructor: OpenLayers.Format.WPSDescribeProcess
+     * Parameters:
+     *     this instance.
+     * APIMethod: read
+     * Parse a WPS DescribeProcess and return an object with its information.
+     * Parameters:
+     * Returns:
+     * {Object}
+        var info = {};
+        this.readNode(data, info);
+        return info;
+    readers: {
+        "wps": {
+            "ProcessDescriptions": function(node, obj) {
+                obj.processDescriptions = {};
+                this.readChildNodes(node, obj.processDescriptions);
+            "ProcessDescription": function(node, processDescriptions) {
+                var processDescription = {
+                    processVersion: processVersion,
+                    statusSupported: (node.getAttribute("statusSupported") === "true"),
+                    storeSupported: (node.getAttribute("storeSupported") === "true")
+                this.readChildNodes(node, processDescription);
+                processDescriptions[processDescription.identifier] = processDescription;
+            "DataInputs": function(node, processDescription) {
+                processDescription.dataInputs = [];
+                this.readChildNodes(node, processDescription.dataInputs);
+            "ProcessOutputs": function(node, processDescription) {
+                processDescription.processOutputs = [];
+                this.readChildNodes(node, processDescription.processOutputs);
+            "Output": function(node, processOutputs) {
+                var output = {};
+                this.readChildNodes(node, output);
+                processOutputs.push(output);
+            "ComplexOutput": function(node, output) {
+                output.complexOutput = {};
+                this.readChildNodes(node, output.complexOutput);
+            "Input": function(node, dataInputs) {
+                var input = {
+                    maxOccurs: parseInt(node.getAttribute("maxOccurs")),
+                    minOccurs: parseInt(node.getAttribute("minOccurs"))
+                this.readChildNodes(node, input);
+                dataInputs.push(input);
+            "BoundingBoxData": function(node, input) {
+                input.boundingBoxData = {};
+                this.readChildNodes(node, input.boundingBoxData);
+            "CRS": function(node, obj) {
+                if (!obj.CRSs) {
+                    obj.CRSs = {};
+                obj.CRSs[this.getChildValue(node)] = true;
+            "LiteralData": function(node, input) {
+                input.literalData = {};
+                this.readChildNodes(node, input.literalData);
+            "ComplexData": function(node, input) {
+                input.complexData = {};
+                this.readChildNodes(node,  input.complexData);
+            "Default": function(node, complexData) {
+                complexData["default"] = {};
+                this.readChildNodes(node,  complexData["default"]);
+            "Supported": function(node, complexData) {
+                complexData["supported"] = {};
+                this.readChildNodes(node,  complexData["supported"]);
+            "Format": function(node, obj) {
+                var format = {};
+                this.readChildNodes(node, format);
+                if (!obj.formats) {
+                    obj.formats = {};
+                obj.formats[format.mimeType] = true;
+            "MimeType": function(node, format) {
+                format.mimeType = this.getChildValue(node);
+    CLASS_NAME: "OpenLayers.Format.WPSDescribeProcess"
Added: trunk/openlayers/lib/OpenLayers/Format/WPSExecute.js
--- trunk/openlayers/lib/OpenLayers/Format/WPSExecute.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Format/WPSExecute.js	2011-06-22 09:54:35 UTC (rev 12124)
@@ -0,0 +1,243 @@
+ * Class: OpenLayers.Format.WPSExecute version 1.0.0
+ * Inherits from:
+OpenLayers.Format.WPSExecute = OpenLayers.Class(OpenLayers.Format.XML, {
+    namespaces: {
+        gml: "http://www.opengis.net/gml",
+        wfs: "http://www.opengis.net/wfs",
+        ogc: "http://www.opengis.net/ogc",
+        wcs: "http://www.opengis.net/wcs/1.1.1",
+        xlink: "http://www.w3.org/1999/xlink",
+    regExes: {
+     * {String} 1.0.0
+    VERSION: "1.0.0",
+    schemaLocationAttr: function(options) {
+        return undefined;
+     * Constructor: OpenLayers.Format.WPSExecute
+     * Parameters:
+     *     this instance.
+     * Method: write
+     * Parameters:
+     * options - {Object} Optional object.
+     * Returns:
+     * {String} An WPS Execute request XML string.
+    write: function(options) {
+        var doc;
+        if (window.ActiveXObject) {
+            doc = new ActiveXObject("Microsoft.XMLDOM");
+            this.xmldom = doc;
+        } else {
+            doc = document.implementation.createDocument("", "", null);
+        var node = this.writeNode("wps:Execute", options, doc);
+        this.setAttributeNS(
+            node, this.namespaces.xsi,
+            "xsi:schemaLocation", this.schemaLocation
+        return OpenLayers.Format.XML.prototype.write.apply(this, [node]);
+    writers: {
+        "wps": {
+            "Execute": function(options) {
+                var node = this.createElementNSPlus("wps:Execute", {
+                    attributes: {
+                        version: this.VERSION,
+                        service: 'WPS'
+                this.writeNode("ows:Identifier", options.identifier, node);
+                this.writeNode("wps:DataInputs", options.dataInputs, node);
+                this.writeNode("wps:ResponseForm", options.responseForm, node);
+                return node;
+            "ResponseForm": function(responseForm) {
+                var node = this.createElementNSPlus("wps:ResponseForm", {});
+                if (responseForm.rawDataOutput) {
+                    this.writeNode("wps:RawDataOutput", responseForm.rawDataOutput, node);
+                if (responseForm.responseDocument) {
+                    this.writeNode("wps:ResponseDocument", responseForm.responseDocument, node);
+                return node;
+            "ResponseDocument": function(responseDocument) {
+                var node = this.createElementNSPlus("wps:ResponseDocument", {
+                    attributes: {
+                        storeExecuteResponse: responseDocument.storeExecuteResponse,
+                        lineage: responseDocument.lineage,
+                        status: responseDocument.status
+                if (responseDocument.output) {
+                    this.writeNode("wps:Output", responseDocument.output, node);
+                return node;
+            "Output": function(output) {
+                var node = this.createElementNSPlus("wps:Output", {
+                    attributes: {
+                        asReference: output.asReference
+                this.writeNode("ows:Identifier", output.identifier, node);
+                this.writeNode("ows:Title", output.title, node);
+                this.writeNode("ows:Abstract", output["abstract"], node);
+                return node;
+            "RawDataOutput": function(rawDataOutput) {
+                var node = this.createElementNSPlus("wps:RawDataOutput", {
+                    attributes: {
+                        mimeType: rawDataOutput.mimeType
+                this.writeNode("ows:Identifier", rawDataOutput.identifier, node);
+                return node;
+            "DataInputs": function(dataInputs) {
+                var node = this.createElementNSPlus("wps:DataInputs", {});
+                for (var i=0, ii=dataInputs.length; i<ii; ++i) {
+                    this.writeNode("wps:Input", dataInputs[i], node);
+                return node;
+            "Input": function(input) {
+                var node = this.createElementNSPlus("wps:Input", {});
+                this.writeNode("ows:Identifier", input.identifier, node);
+                if (input.title) {
+                    this.writeNode("ows:Title", input.title, node);
+                if (input.data) {
+                    this.writeNode("wps:Data", input.data, node);
+                if (input.reference) {
+                    this.writeNode("wps:Reference", input.reference, node);
+                return node;
+            "Data": function(data) {
+                var node = this.createElementNSPlus("wps:Data", {});
+                if (data.literalData) {
+                    this.writeNode("wps:LiteralData", data.literalData, node);
+                } else if (data.complexData) {
+                    this.writeNode("wps:ComplexData", data.complexData, node);
+                return node;
+            "LiteralData": function(literalData) {
+                var node = this.createElementNSPlus("wps:LiteralData", {
+                    attributes: {
+                        uom: literalData.uom
+                    value: literalData.value
+                return node;
+            "ComplexData": function(complexData) {
+                var node = this.createElementNSPlus("wps:ComplexData", {
+                    attributes: {
+                        mimeType: complexData.mimeType,
+                        encoding: complexData.encoding,
+                        schema: complexData.schema
+                node.appendChild(
+                    this.getXMLDoc().createCDATASection(complexData.value)
+                return node;
+            "Reference": function(reference) {
+                var node = this.createElementNSPlus("wps:Reference", {
+                    attributes: {
+                        mimeType: reference.mimeType,
+                        "xlink:href": reference.href,
+                        method: reference.method,
+                        encoding: reference.encoding,
+                        schema: reference.schema
+                if (reference.body) {
+                    this.writeNode("wps:Body", reference.body, node);
+                return node;
+            "Body": function(body) {
+                var node = this.createElementNSPlus("wps:Body", {});
+                if (body.wfs) {
+                    // OpenLayers.Format.WFST expects these to be on the
+                    // instance and not in the options
+                    this.featureType = body.wfs.featureType;
+                    this.version = body.wfs.version;
+                    this.writeNode("wfs:GetFeature", body.wfs, node);
+                } else {
+                    this.writeNode("wps:Execute", body, node);
+                return node;
+        "wfs": OpenLayers.Format.WFST.v1_1_0.prototype.writers.wfs,
+        "ows": OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows
+    CLASS_NAME: "OpenLayers.Format.WPSExecute"
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js	2011-06-22 07:14:15 UTC (rev 12123)
+++ trunk/openlayers/lib/OpenLayers.js	2011-06-22 09:54:35 UTC (rev 12124)
@@ -333,6 +333,10 @@
                 "OpenLayers/Format/OWSContext/v0_3_1.js",
                 "OpenLayers/Format/WMTSCapabilities.js",
                 "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
+                "OpenLayers/Format/WPSCapabilities.js",
+                "OpenLayers/Format/WPSCapabilities/v1_0_0.js",
+                "OpenLayers/Format/WPSDescribeProcess.js",
+                "OpenLayers/Format/WPSExecute.js",
                 "OpenLayers/Format/XLS.js",
                 "OpenLayers/Format/XLS/v1.js",
                 "OpenLayers/Format/XLS/v1_1_0.js",
Added: trunk/openlayers/tests/Format/WPSCapabilities/v1_0_0.html
--- trunk/openlayers/tests/Format/WPSCapabilities/v1_0_0.html	                        (rev 0)
+++ trunk/openlayers/tests/Format/WPSCapabilities/v1_0_0.html	2011-06-22 09:54:35 UTC (rev 12124)
@@ -0,0 +1,30 @@
+<html>
+<head>
+    <script src="../../OLLoader.js"></script>
+    <script src="v1_0_0.js"></script>
+    <script type="text/javascript">
+    function test_read(t) {
+        t.plan(7);
+        var format = new OpenLayers.Format.WPSCapabilities();
+        var obj = format.read(doc);
+        t.eq(obj.version, "1.0.0", "Version parsed correctly");
+        t.eq(obj.languages.length, 2, "2 language entries parsed");
+        t.eq(obj.languages[0].isDefault, true, "First language is the default language");
+        t.eq(obj.languages[0].language, "en-US", "First language is US English");
+        var buffer = obj.processOfferings["JTS:buffer"];
+        t.eq(buffer.processVersion, "1.0.0", "processVersion for buffer is 1.0.0");
+        t.eq(buffer.abstract, "Buffers a geometry using a certain distance", "Buffer abstract correctly read");
+        t.eq(buffer.title, "Buffers a geometry using a certain distance", "Buffer title correctly read");
+    </script>
+</head>
+<body>
+</body>
+</html>
Added: trunk/openlayers/tests/Format/WPSCapabilities/v1_0_0.js
--- trunk/openlayers/tests/Format/WPSCapabilities/v1_0_0.js	                        (rev 0)
+++ trunk/openlayers/tests/Format/WPSCapabilities/v1_0_0.js	2011-06-22 09:54:35 UTC (rev 12124)
@@ -0,0 +1,112 @@
+var doc = new OpenLayers.Format.XML().read(
+'<?xml version="1.0" encoding="UTF-8"?>' +
+'<wps:Capabilities xml:lang="en" service="WPS" version="1.0.0"' +
+'    xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd"' +
+'    xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1"' +
+'    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink">' +
+'    <ows:ServiceIdentification>' +
+'        <ows:Title>Prototype GeoServer WPS</ows:Title>' +
+'        <ows:Abstract/>' +
+'        <ows:ServiceType>WPS</ows:ServiceType>' +
+'        <ows:ServiceTypeVersion>1.0.0</ows:ServiceTypeVersion>' +
+'    </ows:ServiceIdentification>' +
+'    <ows:ServiceProvider>' +
+'        <ows:ProviderName>The ancient geographes INC</ows:ProviderName>' +
+'        <ows:ProviderSite xlink:href="http://geoserver.org"/>' +
+'        <ows:ServiceContact/>' +
+'    </ows:ServiceProvider>' +
+'    <ows:OperationsMetadata>' +
+'        <ows:Operation name="GetCapabilities">' +
+'            <ows:DCP>' +
+'                <ows:HTTP>' +
+'                    <ows:Get xlink:href="http://localhost:8080/geoserver/wps"/>' +
+'                    <ows:Post xlink:href="http://localhost:8080/geoserver/wps"/>' +
+'                </ows:HTTP>' +
+'            </ows:DCP>' +
+'        </ows:Operation>' +
+'        <ows:Operation name="DescribeProcess">' +
+'            <ows:DCP>' +
+'                <ows:HTTP>' +
+'                </ows:HTTP>' +
+'            </ows:DCP>' +
+'        <ows:Operation name="Execute">' +
+'            <ows:DCP>' +
+'                <ows:HTTP>' +
+'                </ows:HTTP>' +
+'            </ows:DCP>' +
+'    </ows:OperationsMetadata>' +
+'    <wps:ProcessOfferings>' +
+'        <wps:Process wps:processVersion="1.0.0">' +
+'            <ows:Identifier>gt:Intersect</ows:Identifier>' +
+'            <ows:Title>Intersection</ows:Title>' +
+'            <ows:Abstract>Intersection between two literal geometry</ows:Abstract>' +
+'        </wps:Process>' +
+'            <ows:Identifier>JTS:length</ows:Identifier>' +
+'            <ows:Title>Returns the geometry perimeters, computed using cartesian geometry' +
+'                expressions in the same unit of measure as the geometry (will not return a valid' +
+'                perimeter for geometries expressed geographic coordinates</ows:Title>' +
+'            <ows:Abstract>Returns the geometry perimeters, computed using cartesian geometry' +
+'                perimeter for geometries expressed geographic coordinates</ows:Abstract>' +
+'            <ows:Identifier>JTS:isEmpty</ows:Identifier>' +
+'            <ows:Title>Checks if the provided geometry is empty</ows:Title>' +
+'            <ows:Abstract>Checks if the provided geometry is empty</ows:Abstract>' +
+'            <ows:Identifier>JTS:contains</ows:Identifier>' +
+'            <ows:Title>Checks if a contains b</ows:Title>' +
+'            <ows:Abstract>Checks if a contains b</ows:Abstract>' +
+'            <ows:Identifier>JTS:disjoint</ows:Identifier>' +
+'            <ows:Title>Returns true if the two geometries have no points in common</ows:Title>' +
+'            <ows:Abstract>Returns true if the two geometries have no points in common</ows:Abstract>' +
+'            <ows:Identifier>JTS:intersects</ows:Identifier>' +
+'            <ows:Title>Returns true if the two geometries intersect, false otherwise</ows:Title>' +
+'            <ows:Abstract>Returns true if the two geometries intersect, false' +
+'                otherwise</ows:Abstract>' +
+'            <ows:Identifier>JTS:isClosed</ows:Identifier>' +
+'            <ows:Title>Returns true if the line is closed</ows:Title>' +
+'            <ows:Abstract>Returns true if the line is closed</ows:Abstract>' +
+'            <ows:Identifier>JTS:isValid</ows:Identifier>' +
+'            <ows:Title>Returns true if the geometry is topologically valid, false' +
+'                otherwise</ows:Title>' +
+'            <ows:Abstract>Returns true if the geometry is topologically valid, false' +
+'            <ows:Identifier>JTS:buffer</ows:Identifier>' +
+'            <ows:Title>Buffers a geometry using a certain distance</ows:Title>' +
+'            <ows:Abstract>Buffers a geometry using a certain distance</ows:Abstract>' +
+'            <ows:Identifier>JTS:getY</ows:Identifier>' +
+'            <ows:Title>Returns the Y ordinate of the point</ows:Title>' +
+'            <ows:Abstract>Returns the Y ordinate of the point</ows:Abstract>' +
+'    </wps:ProcessOfferings>' +
+'    <wps:Languages>' +
+'        <wps:Default>' +
+'            <ows:Language>en-US</ows:Language>' +
+'        </wps:Default>' +
+'        <wps:Supported>' +
+'        </wps:Supported>' +
+'    </wps:Languages>' +
+'</wps:Capabilities>'
Added: trunk/openlayers/tests/Format/WPSDescribeProcess.html
--- trunk/openlayers/tests/Format/WPSDescribeProcess.html	                        (rev 0)
+++ trunk/openlayers/tests/Format/WPSDescribeProcess.html	2011-06-22 09:54:35 UTC (rev 12124)
@@ -0,0 +1,196 @@
+<html>
+<head>
+    <script src="../OLLoader.js"></script>
+    function test_read_WPSDescribeProcess(t) {
+        t.plan(16);
+        var parser = new OpenLayers.Format.WPSDescribeProcess();
+        var text =
+'<wps:ProcessDescriptions xml:lang="en" service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0"' +
+'    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"' +
+'    xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xlink="http://www.w3.org/1999/xlink">' +
+'    <ProcessDescription wps:processVersion="1.0.0" statusSupported="false"' +
+'        storeSupported="false">' +
+'        <DataInputs>' +
+'            <Input maxOccurs="1" minOccurs="1">' +
+'                <ows:Identifier>geom</ows:Identifier>' +
+'                <ows:Title>geom</ows:Title>' +
+'                <ows:Abstract>The geometry to be buffered</ows:Abstract>' +
+'                <ComplexData>' +
+'                    <Default>' +
+'                        <Format>' +
+'                            <MimeType>text/xml; subtype=gml/3.1.1</MimeType>' +
+'                        </Format>' +
+'                    </Default>' +
+'                    <Supported>' +
+'                        <Format>' +
+'                        </Format>' +
+'                        <Format>' +
+'                            <MimeType>text/xml; subtype=gml/2.1.2</MimeType>' +
+'                        </Format>' +
+'                        <Format>' +
+'                            <MimeType>application/wkt</MimeType>' +
+'                        </Format>' +
+'                        <Format>' +
+'                            <MimeType>application/gml-3.1.1</MimeType>' +
+'                        </Format>' +
+'                        <Format>' +
+'                            <MimeType>application/gml-2.1.2</MimeType>' +
+'                        </Format>' +
+'                    </Supported>' +
+'                </ComplexData>' +
+'            </Input>' +
+'                <ows:Identifier>distance</ows:Identifier>' +
+'                <ows:Title>distance</ows:Title>' +
+'                <ows:Abstract>The distance (same unit of measure as the geometry)</ows:Abstract>' +
+'                <LiteralData>' +
+'                    <ows:DataType>xs:double</ows:DataType>' +
+'                    <ows:AnyValue/>' +
+'                </LiteralData>' +
+'            </Input>' +
+'            <Input maxOccurs="1" minOccurs="0">' +
+'                <ows:Identifier>quadrantSegments</ows:Identifier>' +
+'                <ows:Title>quadrantSegments</ows:Title>' +
+'                <ows:Abstract>Number of quadrant segments. Use &gt; 0 for round joins, 0 for' +
+'                    flat joins, &lt; 0 for mitred joins</ows:Abstract>' +
+'                <LiteralData>' +
+'                    <ows:DataType>xs:int</ows:DataType>' +
+'            </Input>' +
+'                <ows:Identifier>capStyle</ows:Identifier>' +
+'                <ows:Title>capStyle</ows:Title>' +
+'                <ows:Abstract>The buffer cap style, round, flat, square</ows:Abstract>' +
+'                <LiteralData>' +
+'                    <ows:AllowedValues>' +
+'                        <ows:Value>Round</ows:Value>' +
+'                        <ows:Value>Flat</ows:Value>' +
+'                        <ows:Value>Square</ows:Value>' +
+'                    </ows:AllowedValues>' +
+'            </Input>' +
+'        </DataInputs>' +
+'        <ProcessOutputs>' +
+'            <Output>' +
+'                <ows:Identifier>result</ows:Identifier>' +
+'                <ows:Title>result</ows:Title>' +
+'                <ComplexOutput>' +
+'                    <Default>' +
+'                        <Format>' +
+'                        </Format>' +
+'                    </Default>' +
+'                    <Supported>' +
+'                        <Format>' +
+'                        </Format>' +
+'                        <Format>' +
+'                        </Format>' +
+'                        <Format>' +
+'                        </Format>' +
+'                        <Format>' +
+'                        </Format>' +
+'                        <Format>' +
+'                        </Format>' +
+'                    </Supported>' +
+'                </ComplexOutput>' +
+'            </Output>' +
+'        </ProcessOutputs>' +
+'    </ProcessDescription>' +
+'</wps:ProcessDescriptions>';
+        var res = parser.read(text);
+        var buffer = res.processDescriptions["JTS:buffer"];
+        t.eq(buffer.statusSupported, false, "statusSupported read correctly");
+        t.eq(buffer.storeSupported, false, "storeSupported read correctly");
+        t.eq(buffer.processVersion, "1.0.0", "processVersion read correctly");
+        var capStyle = buffer.dataInputs[3];
+        t.eq(capStyle.abstract, "The buffer cap style, round, flat, square", "capStyle abstract read correctly");
+        t.eq(capStyle.minOccurs, 0, "capStyle minOccurs read correctly");
+        t.eq(capStyle.maxOccurs, 1, "maxOccurs read correctly");
+        t.eq(capStyle.literalData.allowedValues["Flat"], true, "capStyle allowedValues read correctly");
+        var distance = buffer.dataInputs[1];
+        t.eq(distance.literalData.anyValue, true, "distance anyValue read correctly");
+        t.eq(distance.literalData.dataType, "xs:double", "distance dataType read correctly");
+        var geom = buffer.dataInputs[0];
+        t.eq(geom.complexData["default"].formats["text/xml; subtype=gml/3.1.1"], true, "geom complexData default read correctly");
+        t.eq(geom.complexData["supported"].formats["application/gml-2.1.2"], true, "geom complexData supported read correctly [1/2]");
+        t.eq(geom.complexData["supported"].formats["application/gml-3.1.1"], true, "geom complexData supported read correctly [2/2]");
+        var result = buffer.processOutputs[0];
+        t.eq(result.complexOutput["default"].formats["text/xml; subtype=gml/3.1.1"], true, "processOutputs default format read correctly");
+        t.eq(result.complexOutput["supported"].formats["text/xml; subtype=gml/3.1.1"], true, "processOutputs supported format read correctly [1/2]");
+        t.eq(result.complexOutput["supported"].formats["application/wkt"], true, "processOutputs supported format read correctly [1/2]");
+        text = '<?xml version="1.0" encoding="UTF-8"?>' +
+'<wps:ProcessDescriptions service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0"' +
+'    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xml:lang="en"' +
+'        <ows:Identifier>gt:VectorToRaster</ows:Identifier>' +
+'        <ows:Title>Rasterize features</ows:Title>' +
+'        <ows:Abstract>Rasterize all or selected features in a FeatureCollection</ows:Abstract>' +
+'        <DataInputs>' +
+'                <ows:Identifier>bounds</ows:Identifier>' +
+'                <ows:Title>Bounds</ows:Title>' +
+'                <ows:Abstract>Bounds of the area to rasterize</ows:Abstract>' +
+'                <BoundingBoxData>' +
+'                    <Default>' +
+'                        <CRS>EPSG:4326</CRS>' +
+'                    </Default>' +
+'                    <Supported>' +
+'                    </Supported>' +
+'                </BoundingBoxData>' +
+'            </Input>' +
+'        </DataInputs>' +
+'            <Output>' +
+'                <ows:Title>Result</ows:Title>' +
+'                    <Default>' +
+'                        <Format>' +
+'                            <MimeType>image/tiff</MimeType>' +
+'                        </Format>' +
+'                    </Default>' +
+'                    <Supported>' +
+'                        <Format>' +
+'                        </Format>' +
+'                        <Format>' +
+'                            <MimeType>application/arcgrid</MimeType>' +
+'                        </Format>' +
+'                    </Supported>' +
+'            </Output>' +
+        res = parser.read(text);
+        var vector2Raster = res.processDescriptions["gt:VectorToRaster"];
+        t.eq(vector2Raster.dataInputs[0].boundingBoxData["default"].CRSs["EPSG:4326"], true, "BoundingBoxData CRS parsed correctly");
+    </script>
+</head>
+<body>
+</body>
+</html>
Added: trunk/openlayers/tests/Format/WPSExecute.html
--- trunk/openlayers/tests/Format/WPSExecute.html	                        (rev 0)
+++ trunk/openlayers/tests/Format/WPSExecute.html	2011-06-22 09:54:35 UTC (rev 12124)
@@ -0,0 +1,364 @@
+<html>
+<head>
+    function test_write_WPSExecute(t) {
+        t.plan(1);
+        var expected = '<?xml version="1.0" encoding="UTF-8"?>' +
+'<wps:Execute version="1.0.0" service="WPS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"' +
+'    xmlns="http://www.opengis.net/wps/1.0.0" xmlns:wfs="http://www.opengis.net/wfs"' +
+'    xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"' +
+'    xmlns:wcs="http://www.opengis.net/wcs/1.1.1" xmlns:xlink="http://www.w3.org/1999/xlink"' +
+'    xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">' +
+'    <ows:Identifier>JTS:area</ows:Identifier>' +
+'    <wps:DataInputs>' +
+'        <wps:Input>' +
+'            <wps:Reference mimeType="text/xml; subtype=gml/3.1.1" xlink:href="http://geoserver/wps"' +
+'                method="POST">' +
+'                <wps:Body>' +
+'                    <wps:Execute service="WPS" version="1.0.0">' +
+'                        <ows:Identifier>gs:CollectGeometries</ows:Identifier>' +
+'                            <wps:Input>' +
+'                                <ows:Identifier>features</ows:Identifier>' +
+'                                <wps:Reference mimeType="text/xml; subtype=wfs-collection/1.0"' +
+'                                    xlink:href="http://geoserver/wfs" method="POST">' +
+'                                    <wps:Body>' +
+'                                        <wfs:GetFeature service="WFS" version="1.0.0"' +
+'                                            outputFormat="GML2">' +
+'                                            <wfs:Query typeName="sf:archsites"/>' +
+'                                        </wfs:GetFeature>' +
+'                                    </wps:Body>' +
+'                                </wps:Reference>' +
+'                            </wps:Input>' +
+'                        </wps:DataInputs>' +
+'                        <wps:ResponseForm>' +
+'                            <wps:RawDataOutput mimeType="text/xml; subtype=gml/3.1.1">' +
+'                            </wps:RawDataOutput>' +
+'                        </wps:ResponseForm>' +
+'                    </wps:Execute>' +
+'                </wps:Body>' +
+'        </wps:Input>' +
+'        <wps:RawDataOutput>' +
+'</wps:Execute>';
+        var format = new OpenLayers.Format.WPSExecute();
+        var result = format.write({
+            identifier: "JTS:area",
+            dataInputs: [{
+                identifier: 'geom',
+                reference: {
+                    mimeType: "text/xml; subtype=gml/3.1.1",
+                    href: "http://geoserver/wps",
+                    method: "POST",
+                    body: {
+                        identifier: "gs:CollectGeometries",
+                        dataInputs: [{
+                             identifier: 'features',
+                             reference: {
+                                 mimeType: "text/xml; subtype=wfs-collection/1.0",
+                                 href: "http://geoserver/wfs",
+                                 method: "POST",
+                                 body: {
+                                     wfs: {
+                                         version: "1.0.0",
+                                         outputFormat: "GML2",
+                                         featureType: "sf:archsites"
+                         responseForm: {
+                             rawDataOutput: {
+                                 identifier: "result"
+            responseForm: {
+                rawDataOutput: {
+        t.xml_eq(result, expected, "WPS Execute written out correctly");
+    function test_write_raw_data_output(t) {
+        t.plan(1);
+        // example request taken from: http://geoprocessing.info/wpsdoc/1x0ExecutePOST
+        var expected = '<?xml version="1.0" encoding="UTF-8" standalone="yes"?>' +
+'<wps:Execute service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" ' +
+'xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0' +
+'	http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">' +
+'	<ows:Identifier>Buffer</ows:Identifier>' +
+'		<wps:Input>' +
+'			<ows:Identifier>InputPolygon</ows:Identifier>' +
+'			<ows:Title>Playground area</ows:Title>' +
+'			<wps:Reference xlink:href="http://foo.bar/some_WFS_request.xml"/>' +
+'		</wps:Input>' +
+'		<wps:Input>' +
+'			<ows:Identifier>BufferDistance</ows:Identifier>' +
+'			<ows:Title>Distance which people will walk to get to a playground.</ows:Title>' +
+'			<wps:Data>' +
+'				<wps:LiteralData>400</wps:LiteralData>' +
+'			</wps:Data>' +
+'		</wps:Input>' +
+'			<ows:Identifier>BufferedPolygon</ows:Identifier>' +
+'</wps:Execute>';
+            identifier: "Buffer",
+            dataInputs: [{
+                identifier: 'InputPolygon',
+                title: 'Playground area',
+                reference: {
+                    href: 'http://foo.bar/some_WFS_request.xml'
+                identifier: 'BufferDistance',
+                title: 'Distance which people will walk to get to a playground.',
+                data: {
+                    literalData: {
+                        value: 400
+            responseForm: {
+                rawDataOutput: {
+                    identifier: "BufferedPolygon"
+    function test_write_request_responseDoc_defaultFormat(t) {
+        t.plan(1);
+        // taken from http://geoprocessing.info/schemas/wps/1.0/examples/51_wpsExecute_request_ResponseDocument.xml
+'		<wps:Input>' +
+'		</wps:Input>' +
+'		<wps:Input>' +
+'			<wps:Data>' +
+'			</wps:Data>' +
+'		</wps:Input>' +
+'		<wps:ResponseDocument storeExecuteResponse="true">' +
+'			<wps:Output asReference="true">' +
+'				<ows:Title>Area serviced by playground.</ows:Title>' +
+'				<ows:Abstract>Area within which most users of this playground will live.</ows:Abstract>' +
+'			</wps:Output>' +
+'		</wps:ResponseDocument>' +
+'</wps:Execute>';
+            dataInputs: [{
+                reference: {
+                data: {
+                    literalData: {
+                        value: 400
+            responseForm: {
+                responseDocument: {
+                    storeExecuteResponse: true,
+                    output: {
+                        asReference: true,
+                        identifier: 'BufferedPolygon',
+                        title: 'Area serviced by playground.',
+                        'abstract': 'Area within which most users of this playground will live.'
+    function test_write_request_responseDoc_specifiedFormat(t) {
+        t.plan(1);
+        // taken from http://geoprocessing.info/schemas/wps/1.0/examples/52_wpsExecute_request_ResponseDocument.xml
+'		<wps:Input>' +
+'			<wps:Reference xlink:href="http://foo.bar/some_WFS_request.xml" method="POST" mimeType="text/xml" encoding="UTF-8" schema="http://foo.bar/gml_polygon_schema.xsd"/>' +
+'		</wps:Input>' +
+'		<wps:Input>' +
+'			<wps:Data>' +
+'				<wps:LiteralData uom="feet">400</wps:LiteralData>' +
+'			</wps:Data>' +
+'		</wps:Input>' +
+'		<wps:ResponseDocument storeExecuteResponse="true" lineage="true" status="true">' +
+'			</wps:Output>' +
+'</wps:Execute>';
+            dataInputs: [{
+                reference: {
+                    href: 'http://foo.bar/some_WFS_request.xml',
+                    method: "POST",
+                    mimeType: "text/xml",
+                    encoding: "UTF-8",
+                    schema: "http://foo.bar/gml_polygon_schema.xsd"
+                data: {
+                    literalData: {
+                        value: 400,
+                        uom: 'feet'
+            responseForm: {
+                    lineage: true,
+                    status: true,
+                    output: {
+        function test_write_request_complexData(t) {
+            t.plan(1);
+    '<wps:Execute service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" ' +
+    'xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0' +
+    '	http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">' +
+    '	<ows:Identifier>Buffer</ows:Identifier>' +
+    '	<wps:DataInputs>' +
+    '		<wps:Input>' +
+    '			<ows:Identifier>InputPolygon</ows:Identifier>' +
+    '			<ows:Title>Playground area</ows:Title>' +
+    '			<wps:Reference xlink:href="http://foo.bar/some_WFS_request.xml"/>' +
+    '		</wps:Input>' +
+    '		<wps:Input>' +
+    '			<ows:Identifier>ResultPage</ows:Identifier>' +
+    '			<ows:Title>Nicely formatted HTML of the result</ows:Title>' +
+    '			<wps:Data>' +
+    '				<wps:ComplexData><![CDATA[<html><head></head><body></body></head>]]></wps:ComplexData>' +
+    '			</wps:Data>' +
+    '		</wps:Input>' +
+    '	</wps:DataInputs>' +
+    '	<wps:ResponseForm>' +
+    '		<wps:ResponseDocument storeExecuteResponse="true">' +
+    '			<wps:Output asReference="true">' +
+    '				<ows:Identifier>BufferedPolygon</ows:Identifier>' +
+    '				<ows:Title>Area serviced by playground.</ows:Title>' +
+    '				<ows:Abstract>Area within which most users of this playground will live.</ows:Abstract>' +
+    '			</wps:Output>' +
+    '		</wps:ResponseDocument>' +
+    '	</wps:ResponseForm>' +
+    '</wps:Execute>';
+                dataInputs: [{
+                    reference: {
+                    identifier: 'ResultPage',
+                    title: 'Nicely formatted HTML of the result',
+                    data: {
+                        complexData: {
+                            value: "<html><head></head><body></body></head>"
+                responseForm: {
+                        output: {
+    </script>
+</head>
+<body>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html	2011-06-22 07:14:15 UTC (rev 12123)
+++ trunk/openlayers/tests/list-tests.html	2011-06-22 09:54:35 UTC (rev 12124)
@@ -96,6 +96,9 @@
     <li>Format/WMSGetFeatureInfo.html</li>
     <li>Format/WMTSCapabilities.html</li>
     <li>Format/WMTSCapabilities/v1_0_0.html</li>
+    <li>Format/WPSCapabilities/v1_0_0.html</li>
+    <li>Format/WPSDescribeProcess.html</li>
+    <li>Format/WPSExecute.html</li>
     <li>Format/CSWGetDomain.html</li>
     <li>Format/CSWGetDomain/v2_0_2.html</li>
     <li>Format/CSWGetRecords.html</li>
More information about the Commits mailing list
